Overunity.com Archives
New Battery systems => Other new battery systems => Topic started by: BediniBattery on March 04, 2012, 11:26:07 PM
Title: OverUnity Lead Acid Battery Switching Circuit - Self Battery Charging
Post by: BediniBattery on March 04, 2012, 11:26:07 PM
FREE ENERGY TUTORIAL - WRITTEN BY Snail_007500 from universallyaware.ning.com (5th March 2012)
OverUnity Lead Acid Battery Circuit - Achieves Infinite COP & Self Battery Recharging
FREE ENERGY FROM THE VACCUM - DON'T KILL THE SOURCE
CLOSED LOOP CIRCUITS PREVENT OVERUNITY
YOU KILL THE SOURCE IF YOU KEEP THE CIRCUIT PERMANENTLY CLOSED
KEEPING A LOAD CONTINUOUSLY CONNECTED TO A BATTERY WILL KILL THE SOURCE
A BATTERY CANNOT RECHARGE ITSELF IF THE CIRCUIT IS KEPT CLOSED FOR LONG PERIODS
A BATTERY WILL ALWAYS RECHARGE ITSELF IF GIVEN THE OPPORTUNITY TO DO SO
THERE IS NO NEED TO RECHARGE A BATTERY IF YOU USE IT CORRECTLY
OVERUNITY IS INCREDIBLY EASY IF YOU ALLOW THE BATTERY TO RECHARGE ITSELF
The Purpose of the Switching Circuit
01.) To allow energy from the vaccum to enter the circuit & power the load.
02.) To achieve a very high degree of overunity by opening & closing the circuit continuously.
03.) To encourage self battery recharging by carefully matching the load to the batteries amp capacity.
04.) To identify when the best time to charge the battery is & how it should be achieved.
05.) To switch the battery in & out of the circuit in a controlled way & at a specific frequency. (Less Than 15 Hz)
06.) To prevent the battery from being permanently connected to the load.
07.) To prevent the source dipole from being killed.
08.) To maximise the efficiency of all overunity motors & circuits.
09.) To create a super battery which lasts 10 times longer & doesn't discharge itself.
10.) To provide a better way to power circuits when using batteries.
Overunity can only be achieved if you carefully match the battery capacity to the load it will power
If you attempt to draw excessive amounts of current from a battery, you can forget about overunity.
If you place too big a load on a battery, you will begin to kill to source.
No amount of feedback pulses from a motor / generator will change the situation.
If you place too large a load on the battery, you will be preventing the battery from recharging itself.
It is better to draw a small current for a long time & allow the battery to recharge itself when it is taken off the load.
I encourage everyone to do your own experiments, to determine what loads can be powered by a specific battery capacity.
The only way to know how fast a particular battery can recharge itself is to put it under load, vary the switching frequencies, on / off times, & then plot the results.
If you start at 20% of the Batteries Amp Capacity for these experiments - you can either increase or decrease the load.
The bigger the load, the greater the chance of the battery discharging.
Ideally you will need to do several long term tests to determine where the peak of overunity occurs & when it starts to drop.
The rated capacity of a battery is only for a closed circuit. If you are using a circuit which allows energy from the vaccum to power your circuit,
you are likely achieve excessive amounts of overunity. The amount of overunity you achieve depends on the load you will be powering.
In general if you draw less than 20% as an average, you should have a lot of success with self battery recharging.
When you get down to 10% you may be able to achieve infinite COP.
Charging Your Batteries With a Large 100 Amp / Hour Battery
When you charge a battery it must be done using a pulse charger, similar to a bedini circuit.
Charging should be done after the battery has been allowed to self charge itself.
You should only need to give the battery a top up, not a lengthy charge.
You don't need to build a bedini motor to do this.
You can make one of these pulse chargers using a 555 astable circuit with an adjustable pulse width, a (n type) mosfet & an iron dust or ferrite toroid.
If using an iron dust toroid T50-2, the frequency should be 30Khz & the number of turns = 45, using 0.6mm enammelled copper wire.
If using a ferrite toroid, the frequency should be about 5Khz & the number of turns = 8, using 1mm enammelled copper wire.
A single schottky diode can direct the back EMF spike to charge your battery, or you can use a secondary coil & a bridge rectifier.
A circuit drawing 0.5 Amps at 12 Volts will charge a battery slowly, so increasing the power used to 2 amps or more is something you should be looking at if you want a fast charger.
You should get hold of another battery to do your charging. (100 Amp Capacity is Ideal) as this will only use 2% of the capacity.
When you have got your 100 amp battery, place the switching circuit before the pulse charger & begin extracting free energy from the vaccum & charge
your smaller batteries for free. The 100 amp battery will quite happily recharge itself after 1 hour of being taken off load, because you made sure
it was being used in overunity mode & you didn't keep the circuit closed, unlike every other circuit out there.
A battery is charged when its voltage reaches 15 volts.
Its normal voltage is between 12.7 & 13.5 Volts depending on the battery.
Now that you know the secret of obtaining free energy from Lead Acid Batteries, you can tell all of your mates.
My Original Article 13 Page Article Can Be Downloaded Here :
- http://www.mediafire.com/?qpudp49yqbsq4qd -
- My Facebook Group - https://www.facebook.com/groups/267745266621292/
The information that I am discussing here is already public knowledge, see the links below.
- http://www.cheniere.org/books/part4/s40.htm -
- http://www.cheniere.org/misc/battery%20poppers.htm -
- http://www.icehouse.net/john1/foreward.html -
- http://www.icehouse.net/john1/tesla.html -
- http://www.irf.com/product-info/datasheets/data/irf5305.pdf -
Here is a quote from Tom Beadens Website
In this scheme, we drive an ordinary d.c. series motor by a two wire system from an ordinary battery.
The motor produces shaft horsepower, at -- say -- some 30 or 40 percent efficiency, compared to the power drained from the battery.
This much of the circuit is perfectly ordinary.
The trick here is to get the battery to recharge itself, without furnishing normal power to it, or expending work from the external circuit
in the process. To do this, recall that a charged particle in a "hooking" del-phi river moves itself.  This is true for an ion, as well as for an
electron. We need only make the del-phi in correct fashion and synchronize it;  specifically, we must not release the hose nozzles we utilize to
produce our del-phi river or waves. The inventors who have discovered this have used numberous variations, but here we show a common one.
Title: Re: OverUnity Lead Acid Battery Switching Circuit - Self Battery Charging
Post by: ltseung888 on March 05, 2012, 09:45:55 AM
Thank you for your information.
I was planning to do a similar circuit in the next few weeks.  Now the task will be much easier.
God Bless.
Post by: Mira on March 05, 2012, 04:02:36 PM
How did you test this device?
Post by: BediniBattery on March 05, 2012, 06:01:21 PM
Quote from: BediniBattery on March 04, 2012, 11:26:07 PM
This is the drive circuit for testing either a P-Type Mosfet or a Normally Open Relay.
The start button / switch is used to charge the super capacitor via a low value resistor & provide power to the 555 circuit.
The 555 needs at least 3 volts before it will begin to self oscillate. Once the 555 circuit starts to oscillate, the power switching will take over & will continue to charge
the supercap until it is fully charged. The relay placed across the low value resistor is used as a current regulator or short circuit protection circuit. Its cheap & effective.
You may also want to add a low value resistor to the output of the supercap since they can be quite dangerous if accidently shorted out.
The relay is a bit noisy, so the P-Type Mosfet really is essentially.
There is a pulse width adjustment using the two diodes in the 555 astable circuit & a variable resistor.
You can play around with the timing here.
The capacitor is approx 10 micro farads, this is what determines the basic frequency, the other two resistor set the on / off time or pulse width.
The circuit will operate up to 48 volts provided the 555 has a regulated 12 volt supply, so this could power a 48 volt mains inverter.
The N - Type mosfet part of the circuit is used to drive a big relay if you want to use one.
You can test the performance of various loads with a relay if you don't have a P-Type Mosfet at hand.
The switching part of the circuit can be constructed using a N-Type Mosfet but it makes life much harder, so just get the right parts if you are going to try this. Also I could not find a direct pinout for the P-Type mosfet IRF5305. The data sheets forgot to tell us what the pins were.
There is a missing wire on the pulse charger diagram, pin 8 on the 555 is +12 Volts, its not a mistake, I just haven't put it in.
If you intend to build these circuits, make sure that you use the exact component values that are shown.
There is a lot of oscillation with the pulse generator when you look at it on the oscilloscope. It does not affect the driving mosfet, but tends
to affect the mains powersupply. Use a 12 volt battery to power this circuit, ideally with the overunity switcher placed before it.
You can also use a secondary coil on the pulse generator to isolate the two batteries.
A 1 to 1 ratio is good & then feed it into a full wave schottky rectifier to charge the battery.
A few drops of superglue on the coil keep it from coming apart.
The iron dust toroid T50-2 works well at that frequency 33khz,  I can't recommend ferrite for this circuit.
Again use the exact component not one twice the size.
- http://powermagnetics.co.uk/pace-components/micrometals-iron-powder-cores/rf-applications/t50-2-micrometals-iron-powder-toroid -
I use schottky diodes for the flyback circuits, signal diodes for the 555 timer circuit.
The N-Type Mosfet is a HUF75337G3 - http://www.datasheetcatalog.org/datasheets/120/170920_DS.pdf -
The P-Type Mosfet is a IRF5305 - http://www.redrok.com/MOSFET_IRF5305_-55V_-31A_6mO_Vth-4.0_TO-220.pdf -
At the present time I have tested the above circuits for functionality, I still need to design & make a small PCB so I can really test it out.
If the circuit provides a good deal of overunity, it should be possible to charge very large batteries using a small one, thats the goal.
This is my facebook album with all the images-
https://www.facebook.com/media/set/?set=a.271859256223535.63319.100001983889140&type=1
Post by: TheOne on March 05, 2012, 08:16:48 PM
Thank you for the circuit
I have a question about the capacitor. What is the voltage required for the capacitor?
I have some capacitor of about 10V at 100000 UF, this is to big? can I put 2 in serie to make a 20V?
Thank you!
Post by: BediniBattery on March 07, 2012, 09:48:20 PM
8th March 2012
Here are two improved circuits which have been proven to function correctly off 12 volts.
The previous two diagrams I uploaded should be ignored since there are special requirements to switch the P-Type mosfet correctly.
The circuit performs well running a motor, or powering a resistive load, with or without a super capacitor on the output.
I tested a load of 18 ohms at 12 volts with a 6 farad car audio capacitor to keep the ripple to a minimum.
The current being drawn was 0.6 Amps.
The ripple itself was very small on the scope, the pulse width was 50% & the switching frequency was between 1 to 5 Hz.
The capacitor size does make a big difference.
The switching mosfet remained cold throughout & did not get hot at all, so this means it is being swiched on & off correctly.
As far as overunity is concerned this is a tricky subject. I do believe the switching circuit has improved the batteries ablilty to supply power
for longer, however, I have also concluded that some method of recharging the battery is needed. Usually you will just see the battery voltage fall
when you connect a load to it, but this switching circuit prevented that from happening for the most part.
The battery voltage did eventually begin to fall when a 0.6 Amp load was connected for more than an hour, across the super capacitor.
I have noticed that a battery can recharge itself to some extend, particularly when it is fully charged.
This usually occurs when you are applying brief loads & not using the battery for long experiements.
The circuit does its best to prevent the battery from being continuously connected to the circuit.
If there are any overunity gains to be had in the discharge cycle then you are going to get them.
I will be doing some more tests using (one battery to power the pulse charger circuit & charge a slightly discharged battery.)
There will be a number of different tests to determine whether using high current pulses can speed up charging.
I never saw anyone stack up a load of batteries & charge them all in series.
Do you get more charging from doing this or not.
If the pulse is going through a number of batteries, are they all being charged?
Overunity must come from the recharging cycle rather than the discharge cycle.
If John Bedini managed to get his motors to run continously without external power sources, there must be a trick to doing this.
I don't believe the magnets had anything to do with the charging of the battery, but I could be wrong.
Focus on the charging aspect to achieve overunity as this seems to be more productive.
There are a number of circuits to try out, switched capacitor charging & the tesla switch.
Two capacitors are charged with 12 volts, then placed in series & a load is powered while the battery is charged.
Two batteries charge one battery & power the load. The 3 battery are cycled around in one direction.
There are a number of ways of powering a load while charging a battery, but the charging is done using current, not a voltage spike.
All these circuits need to be tested completely so large supercaps are needed for these experiments. 6 Farads for 0.5 Amp Load.
Any Volt Micro - This is a mini switching regulator which steps up 4 volts to 15 volts.
This is what I am powering the 555 timer & the mosfet gate switching with a 12 volt battery.
- http://www.dimensionengineering.com/anyvoltmicro.htm -
- http://www.technobotsonline.com/anyvolt-switching-regulator-0.5a.html -
The NPN Transistor is BC546 for 48 Volt Operation - http://www.radiotechnika.hu/images/BC546_50.pdf
Improved circuit with gate drive protection & seperate any volt switching regulator to provide +3 volts above the source voltage. The circuit can be used up to 48 volts dc if the capacitors are changed & a seperate regulator can supply the 555 with 15 volts.
I am using a 6 farad car audio capacitor across the load, which has its own LED volt meter.
- http://www.ebay.co.uk/itm/6-Farad-Car-Audio-Amp-Power-Cap-PowerCap-Capacitor-Digital-LED-Voltage-Display-/370584756750?pt=UK_In_Car_Technology&hash=item564892a20e -
Post by: mscoffman on March 10, 2012, 12:36:14 PM
Post by: SkyWatcher123 on June 11, 2012, 03:15:24 AM
Hi bedinibattery, any updates or results on these ideas, thanks.
peace love light
tyson
Post by: segar on January 14, 2013, 06:45:45 AM
hi,bedini did you have tested this circuits ?, and waht is the result you have?  did you have any data if you tested,please post if you have this information
thanks
Post by: Eighthman on January 14, 2013, 09:45:16 PM
Question:  I have heard that these circuits quickly wear out lead acid batteries.  I think this happened to Bill Boyce's SA friend (Wyty... something).
I do know that powerful pulses can knock off chunks of lead sulphate.  Any ideas about this?
Post by: magpwr on January 15, 2013, 06:12:38 PM
Hi All,
Please re-define the title correctly To Lead-ACID battery DESULFATOR .It's misleading.Please don't be offended.
I have already build a battery desulator base on PIC12F629 using 8 pin micro-processor could recover even 0.9v maintenance free Lead-acid battery(2Ah) to 12volts in 2days.
Even some of circuit people build tend to use a "lead-acid battery" when they noticed a rise in battery voltage ,the creator of circuit thought they have have created OU device.
They didn't know they have merely created a good battery desulfator device.
A real OU device should be running on ultra-caps or nimh battery where the internal self-discharge rate is higher.If there is voltage increase in cap or nimh then it could be the real deal without using any input batteries.
The switching cycle is 55us on with 1s off in infinte loop for programming the PIC12F629.This is just a replica of 555 base found in instructables site.I did micro-processor version merely to lower component count.
Please look at this link where i posted full finding around 2 years ago and even mentioned the 2 ways to check a 12volt battery(If the internal resistance is being lowered) while it's being desulfated or after desulfated.
http://www.instructables.com/id/PIC12F629-Lead-Acid-Battery-Desulfator/ (http://www.instructables.com/id/PIC12F629-Lead-Acid-Battery-Desulfator/)
Post by: segar on January 16, 2013, 05:00:19 AM
HI, magpwr i have see your circuits and some explanation about your circuits you have built and tested as so far in the low current and the standard voltage , i have some question on it about this ,and i need your advice on this questions.
1. the circuits you build is low current and the L1 ,value of inductor its 1mH ,and the L2 ,220uH ,if this two component is i change to any other value for charging the battery of 60aH/24VDC battery bank means ,how to i design this coil for reach that current to have charge in the 6.or 8 hours duration charging time ,can you give some advice on this,please.
2. my system battery bank is 24v/60ah and my planing is to drive the lamp,dvd,computer,and etc, atleast for the 3.to 4 hrs time, and i want to connect with 1000watt inverter system for drive this load after the full charge the battery bank of i mentioned.
please advice for my design and for testing in my home projects  .
thank you
Post by: magpwr on January 16, 2013, 08:46:33 AM
Hi Segar,
I have not tested on 24volt battery but i believe the only component you need to amend from my circuit is
R1=1K OR 1.2Kohms
D2:1N5819
IRFZ44V needs to be changed(Currently 60v but spike is around 44v for 12volts on bad batteries).
You merely need to get mosfet which could support at least 120v or 150v.
If you purely using it for maintenance of existing good batteries then mosfet could be 100v.
Please leave fuse at 500mA.
I have used car battery with ups(not using internal ups battery) on my pc\monitor.It works.
I'm unable to advise further.sorry.
Post by: segar on January 16, 2013, 11:24:42 PM
HI, magpwr
i have read your reply and understand ,so thank you very much your support and reply to me as fast, will keep and touch with you
thank you my friend
Post by: Google on March 14, 2014, 04:08:41 AM
The overunity quacks like bedini and bearden have done more harm to the name of Tesla than anyone else.
Post by: SeaMonkey on March 18, 2014, 08:42:19 PM
Quote from: Google
They've certainly found it profitable to attach
Tesla's name to their marketing strategy and
product line.
Post by: Hoppy on January 07, 2015, 04:24:06 PM
Has anyone tried charging lead acid batteries in series with series wound universal type motors, such as used in most domestic products such as vacuum cleaners electric drills etc? I have an experimental charger using a vacuum cleaner motor run from a 240V to 90V (2 x 45V windings in series) toroidal transformer. The motor has a bridge rectifier at the input, so I have connected the battery on the DC side of the rectifier in series with the motor winding. Charging current is 0.5A with input power from the mains at approx.60W. Adjusting the torque on the shaft of the motor will increase the charging current, although I have found that with the motor running with no mechanical load, effectively charges 12V batteries up to 30A/hr capacity. The charge will condition the battery and leave its standing voltage high as with a Bedini type charger.
Post by: pomodoro on January 07, 2015, 08:44:57 PM
The simplest of these chargers consists of two things. A capacitor to the live wire of your mains and a diode bridge connected to the other end of the cap and neutral. The high voltage DC spikes charge/condition the battery and the cap limits the current. Very simple and very effective. The cap and bridge need to be appropriate for mains use.
Post by: a.king21 on January 08, 2015, 02:05:13 PM
Quote from: Hoppy on January 07, 2015, 04:24:06 PM
Have you checked out Turion on the energetic forum. He's been experimenting with his 3 battery system using a scooter motor and other motors in series for years.
Post by: Hoppy on January 08, 2015, 06:45:22 PM
Quote from: a.king21 on January 08, 2015, 02:05:13 PM
Yes, I've followed the EF thread from its beginning and is one of the reasons I posted my question, as I have found as Turion has, that there is a long term progressive improvement in the capacity of batteries placed in series with brushed motors. The net capacity improvement in repeated cycling within a 3BGS system is considerable. I have found that the universal series wound motor is superior to standard DC PM or pulsed PM motors by virtue of the constantly switching counter magnetic fields of the in-series armature and rotor windings. These alternating magnetic fields, together with the carbon brushes, produces some very high frequency and powerful transients in the nano-second time domain, which I believe create a very effective de-sulfation waveform with important relaxation times provided by the 50Hz sinusoidal grid frequency. I have found this method to be superior to the Bedini SG mechanical energiser methods. However, as with the Bedini energiser, care needs to be taken in limiting charging voltages but efficient cold charging is achieved with the minimum of charging current, although overall device electrical efficiency is poor.
Post by: SeaMonkey on January 08, 2015, 11:34:36 PM
The discussion here has taken a very interesting turn
thanks to Hoppy's question.
Your findings Hoppy are food for thought as well.
I've had very good success in desulfating lead-acid
batteries with low powered inductive discharge desulfators
which draw up to two amperes at about 14 Volts.
I've tried higher power units too but have not had
the same sort of success.  It seems that low powered pulsing
for an extended length of time slowly desulfates with the
best chance of not harming the battery being rejuvenated.
The very short (nano-Seconds up to several micro-Seconds)
pulses do seem to have some 'magic' in what they're able
to accomplish.
Capacitive discharge desulfation with those same very
narrow pulses up to about 50 Volts for a 12 Volt battery
seem to be equally effective.
My experience has been that trying to desulfate too quickly
leads to excessive heating and more likelihood of  damage.
Post by: profitis on January 11, 2015, 01:44:46 PM
Bedini should not be dismissed too fast as the principal is correct.if the backspike with its massive voltage is evenly distributed over many cells in series you should have some gain.its this re-distribution of backspike power which most people fail at.most people want to cram it into a single cell which causes loss of ir heat and consequently efficiency loss.a backspike is a window to an inverted population and statistical 2lot disruption.
