OF course we all know this theory unless it is my theory :D
8) ;D
which is
the power u use to archive some kind of movement or heat or anything if u reverse and give it what it is supposed to give u it will give u the power which u supposed to give in the beginning
same as the alternators idea ..etc
ok the idea is
reverse engineering the hair dryer ..... u see it take like 2500 watts to heat just a small piece
of metal or ceramic to 300 degree or something
what if u use the fernesel lens with sun to heat it
it will give u the same power which u supposed to use
at least 1000w for one piece woww
this could be something very nice
and the other idea i dont want to make another topic
using the solar oven and puting like 10 / 180w thermal electric ships with heat sink
so the part which u want it to be hot inside the oven and the part which u want it cold out
why oven ??
if u put normal heat with anything (fire tourch , sun , or any other way ,,the heat will go away in the air )
what if u close the heat to not escape but in only one place which is by the chips
it doesnt have to be perfect to get alot of power because im sure u will get alot of power
im sure of my idea
and the more heat isolation u make on the oven ( i dont know is there some kind of glass that isolate heat to be not heat from the other surface ) the more power u get
ofcourse u can use ferensel lens to heat the oven or even mirrors but put paint the inside with anything black better to be a back liquid as liquid absorbs heat and doesnt gve it all away
using this idea i think u can easy get around 1000-to 1500w or higher if more chips
easy to make and not expensive
by the way it is better to put a low watt fan on the siinks ...or u can use a type of ice ..i dont remember it is name now
try try //.....and feed back
so this be like a worshop
im very busy right now buying somethings
no one replied or said anything this is strange
Too hard to read.. please just use non bold, non center text.. just normal.. Thanks
the efficiency of thermo-electric generator is about 5% so you will get very little power out of your device
may be ur not updated
look at this
http://www.ebay.com/itm/GIANT-62mm-545-Watt-THERMOELECTRIC-PELTIER-COOLER-MOST-POWERFUL-TEC-on-EBAY-/310391676716?pt=LH_DefaultDomain_0&hash=item4844c91f2c
545 watt for only 43 dollars
the efficiency is the difference of temperature between the two sides
if u can make one side too hot and the other cool ....u successed
u can see also here
http://www.tegpower.com/
and ive explained up how to make it
and i dont think that no one tried my way even in youtube u can search as long as u can
but the new thing will be if u reverse engineer the hair dryer
u will tell me why while u have this chips
i will tell u .....that this chips needs temperature difference
but if u use the hair dryer u will not need the temperature difference
what im searching for now
is something realy hard to find
is there any kind of glass that totally isolate the heat means that one side is so hot and the other side is not hot
keep searching guys im sure of what im saying
Quote from: theshiningeagle on April 09, 2012, 08:37:04 AM
look at this
http://www.ebay.com/itm/GIANT-62mm-545-Watt-THERMOELECTRIC-PELTIER-COOLER-MOST-POWERFUL-TEC-on-EBAY-/310391676716?pt=LH_DefaultDomain_0&hash=item4844c91f2c (http://www.ebay.com/itm/GIANT-62mm-545-Watt-THERMOELECTRIC-PELTIER-COOLER-MOST-POWERFUL-TEC-on-EBAY-/310391676716?pt=LH_DefaultDomain_0&hash=item4844c91f2c)
u can see also here
http://www.tegpower.com/ (http://www.tegpower.com/)
I think you are confusing what the peltier modules max running wattage vs. the watts it could potentially produce (running it in reverse, i.e adding a heat source and cooling the other side)..
The 545 watts is the peak watts the unit will DRAW, not MAKE.......
it even states this on the ebay link you posted.. "
Maximum power consumption 545 Watts"
Like someone already posted, the best your going to out put from any peltier module is around 5%
