Tesla Free Energy Pyramid
The Tesla pyramid is one of the best inventions that I can imagine. It is made of copper wire wound a flat coil, which is within a radius of a wavelength of the excitation frequency. The lowest coil is wound on the whole Druchmesser the pyramid. The flat coils are placed in parallel. In the distance of the inverse number Figanocci now the next flat coil is placed. It is recommended to overcome a 2 core copper wire and use. Thus, a primary and a secondary Schwinkreisseite be selected. On the primary side, the energy is selected to have a multiple of the earth frequency. The best frequency for the bottom coil is about 500 (k) Hz This is gewickeln in diameter of 20cm. The frequency of the second coil is to select the double of the first coil is 1000 (k) heart. This coil is to be placed 21 cm above the first coil. The diameter is in the second coil (2) is 15 cm, the distance is to the third coil now even 8 cm. The third coil is gewickeln diameter of 10 cm and excited with 2000 (k) Hz. The fourth coil is wound with a diameter of 5 cm and is provided at a distance of 5 cm above the bottom.
Frequzenzverdopplerschaltung with a rectifier can be implemented very easily. On forming the two capacitor plates are mounted on which are the Ausgansseite and are operated in parallel to the coils in resonance frequency. Important to see the electric field 90 ° to the magnetic field lines is mechanically look. On Ausgansseite via diodes, the load is applied. Depending on time of day or the other coil is more energized by the magnetic field.
Sincerely
Rafael Sergi, from Lucerne, written on 12.11.2012
The second picture give a capacitance of 90 degrees of the wire of the front from the FlatCoil.
Leave the flat coils and the capacitors are superimposed, thus results in an ideal mechanical and
electrical coupling. The components can be added as required. In the center is an ideal iron threaded rod
to connect to the earth and placing the Mitelpunktabgriffe. The size of the length can be a harmonic
Be more times the wavelength of the controlled frequency.
It can also Primary and Secondary Groups
Be formed. The Primary Group Drives
and the secondary group INPUT FEED consumers.
The consumer should be switched via diodes
be because of the load voltage
zusammenreisst must be ensured
the resonant circuit to maintain.
The tension is in the double resonance
Its size, according to the electrical engineering formulas
the quality is high and the slope
extremely steep. What I have not drawn
is that the components in one
Series resonant circuit can be built.
The series resonant circuit is a high voltage
Parallel resonant circuit and the high current
Flow. The internal resistance should be according
Adjustment to the consumer
be the same.
The Paralellschwingkreisbauweise is a
high internal resistance of the power source
and the series resonant circuit is a
low internal resistance of the voltage source
to be considered.
The drawing is an idea and I'm Glad
a feedback wenns together someone
has built.
Courtesy of the
This picture explain the different.
Capacitive transformer combined with Bilfilarer flat coil for space energy KonvertionTesla Pyramiede with a long coil in the center.
The housing is not made of metal and grounded
The sides are covered with sheet, operating in May
noT be touched. At the top, build one
Korohnahelix, whichever amplifier to the audio
playing. Which is the maximum BodenFlaschspule
Diameter of the pyramid. The upper flat coil
smaller. The longitudinal winding in the center is in resonance
with the capacity. Capacities are blue red
drawn the coils wrap always 2
Capacities. The capacitance and the coil are in
Response to control. The housing is
then under tension and has a
much higher potential than Earth.
Do not touch the power of Tesla Pyramid.
an audio amplifier
and a CD or functional
Generator, the lower coil
driven. It is also a primary
circular build a Galvanic
To achieve separation. the Doppelheilix
Forms at the top of the pyramid,
it appears that one change of Morph ???
hi i the the tourus pattern over zylinder coils and basket coils il drwa a picture over two pyramids how is the space of flatcoil 1/1.62 of the length and the zylinder basket coil emmited the magnetic tourus pattern filed, this is current load. the filed of magnetic generate a electrostatic field over face the metal pyramid area. so, you drife the flatcoil i say invers whit a audioamp and the Recvier Diods make a invers signal. the frequenty wafelenght is lamada 1/4 of the lengt space of thwo flatcoils.
