Hi
this invigetion is great. The telsa pyramide i think have exess much presens. first you wired a flat coil and a kapacitor. the kapacitor is whit the lenth and aria in resoanaze whit the coil. The space between the kapazitive transformers is invers to the viganocci Chapter. also 21cm, 17cm, 11cm 8cm, 5 cm 3cm. The radius of the coil ist 1/4 of the landa wavelenght. the Wavelength have two great charakters, first you have a magnetic component and second you have a elektrostatic component. This products a eletrostatic fild an 90 degrees after 2 second later a magnetic static filed. This thwo comoponent ist includet in the kapazitiver transformator. Sorry but not patent it, ist danger :-( The load is on the second wire of the tesla flat coil, this tesla flatcoil ist copplet whit the Capacitance, this ist the perfekt osscilator "schwinkreis". Atach; the Couppel ist whit in resonance not on a opposite. in a opposite kill the magnetic filed the electric field. The coils over the etage have a double frequenzies whit a pulswhit modlulator and a ampliver can you give a short impulse. the on time impulse ist very schort to the off impulse.
and this picture view the maufacture
@sergirafael:
Have you built one of these "tesla pyramids"? Do you have photos? What input/output (volts, amps) do you really get??
truesearch
Hi i have not, here expain i the flat coil whatever is wired bifilar flat coil. The flat coil is a bifilar wound yu m; possibility umd heruasyukriegen in the back EMF energy. I give the size [s winding
the primary site and in the Red winding I give the secondary output side. The Magnetdfeldlinien be the bifilar winding
engegeng work. Thus one has the ausbäute höhcste. The audio amplifier is again a Musiksück, the speaker on the secondary
Page gives the music again electrically isolated. The center of the coil is earthed. This construction of a bifilar flat coil is also ideal as a
highly sensitive sensor can be viewed, he dedektiert fine fields. This can include a DC voltage instead of an amplifier is
are introduced, the speaker is again only the change of environment fields. The coil may have a diameter of plurality
Meters have. To generate a overunity effect, set the coil beneath best on a power line,
and captures the alternating fields of the high-voltage line. The coil diameter of a harmonic should lända 1/4 the wavelength
be the frequency. The coil wraps look best on strong tape then painted over with Siklikon. The time to the
build is 2 hours.
