Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: gearturbine on August 29, 2013, 09:09:08 PM
Title: Novel RotaryTurboInFlow Atypical Tech / Gearturbine Project-Featured Development
Post by: gearturbine on August 29, 2013, 09:09:08 PM
GEARTURBINE PROJECT
Atypical InFlow Thermodynamic
Technology Proposal Submission
Novel Fueled Motor Engine Type
*State of the art Innovative concept Top system Higher efficient percent.
Have similar system of the Aeolipile Heron Steam device from Alexandria 10-70 AD.
[/font]
http://www.youtube.com/watch?v=0cPo9Lf44TE (http://www.youtube.com/watch?v=0cPo9Lf44TE)
YouTube; * Atypical New • GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
[/font]
*8-X/Y Thermodynamic CYCLE - Way Steps:
1)1-Compression / bigger
2)2-Turbo 1 cold
3)2-Turbo 2 cold
4)2-Combustion - circular motion flames / opposites
5)2-Thrust - single turbo & planetary gears / ying yang
6)2-Turbo 2 hot
7)2-Turbo 1 hot
8)1-Turbine / bigger
-New Form-Function Motor-Engine Device. Next Step, Epic Design Change, Broken-Seal Revelation. -Desirable Power-Plant Innovation.
-With Retrodynamic Dextrogiro vs. Levogiro Phenomenon Effect. / Rotor-RPM VS InFlow / front to front; "Collision-Interaction Type" - inflow vs. blades-gear-move. Technical unique dynamic innovative motion mode. [Retrodynamic Reaction = When the inflow have more velocity the rotor have more RPM Acceleration, with high (XY Position) Momentum] Which the internal flow (and rotor) duplicate its speed, when activated being in a rotor (and inflow) with [inverse] opposite Turns. A very strong Novel concept of torque power thrust.
-Non-waste parasitic looses system for cooling, lubrication & combustion.
-Shape-Mass + Rotary-Motion = Inertia-Dynamic / Form-Function Wide [Flat] Cylindrical shape + positive dynamic rotary mass = continue Inertia kinetic positive tendency motion. Like a Flywheel.
-Combustion 2Two continue circular [Rockets] flames. [ying yang] opposite to the other. – With 2TWO very long distance INFLOW [inside propulsion] CONDUITS. -4 TURBOS Rotary Total Thrust-Power Regeneration Power System. -Mechanical direct 2two [Small] Planetary Gears at polar position. -Like the Ying Yang Symbol/Concept. -Wide out the Rotor circumference were have much more lever [HIGH Torque] POWER THRUST. -Military benefits; No blade erosion by sand & very low heat target signature profile. -3 points of power thrust; 1-flow way, 2-gear, 3-turbine. *Patent; Dic. 1991 IMPI Mexico #197187 All Rights Reserved. Carlos Barrera.
[/font] ::) :P
