Hello everybody !
Please see the attached file , containing descripton of idea for an overunity transformer.
Please feel invited to comment it .
Since I don't have enough funds to build and test it if someone is thinking that the idea is promising it will be fantastic to test it and to post the results.
Many thanks in advance.
Here is also pdf version of the description file.
Anyone interested in my idea?
There are some Bulgarian people doing interesting work, and also, you may be interested in this:
http://www.inkomp-delta.com/page3.html (http://www.inkomp-delta.com/page3.html)
Thanks a lot. Anyone else? Come on there should something more than just visit this page and speak with those people.
Have you invented the magnetic amplifier / saturable core reactor?
http://www.sigmaelectricals.com/map.htm
http://www.themeasuringsystemofthegods.com/magnetic%20amplifiers.pdf
http://www.ti.com/lit/ml/slup129/slup129.pdf
It si a magnetic amplifier, but other type (other working principle, compared to those amplifiers in the links) of amplifier. Not like the one in the links.
Thanks a lot. Anyone else or other opinion?
I think you have read nothing or understood nothing about the idea if you simply compare it to magnetic amplifier.
No , its not magnetic amplifier.
The bottom line idea is simply to increase/boost the magnetic field from primary coil through means if magnetic induction.
The sole reason I call it my idea is because I didn't saw it earlier. I came to this possible conclusion by myself. Maybe it is already known. It doesn't matter for me. I just want to know is it working or not. Other mistake is to compare it to Thane Heins transformer like those in the link below :
https://www.google.com/search?q=thane+heins+transformer&safe=off&espv=210&es_sm=122&source=lnms&tbm=isch&sa=X&ei=HNTSUpS1KOLFyQPdxIHoBQ&ved=0CAkQ_AUoAQ&biw=1366&bih=642#facrc=_&imgdii=_&imgrc=Cr1HegyCAPhAvM%253A%3BlteRdhluTa9SYM%3Bhttp%253A%252F%252Fwww.overunity.com%252F7833%252Fthane-heins-bi-toroid-transformer%252Fdlattach%252Fattach%252F76002%252Fimage%252F%252F%3Bhttp%253A%252F%252Fwww.overunity.com%252F7833%252Fthane-heins-bi-toroid-transformer%252F30%252F%3B640%3B400
but its quite different from Thane-Heins transformer on its working princple. Its not magnetic amplifier and its not thane heins transformer.
Please read more carefully.
I've tried to explain the idea as simply as possible, but unfortunately for me the explanations are not my strong feature.
Anyone else or other opinion from the users above?
