Here is a buoyancy device which eats the ball at the top and shits it out from the bottom causing perpetual plumbing! This device makes use of momentum and collission unlike other buoyancy devices. If you use a lengthy tube, the momentum gained by the ball should be sufficient enough to cause perpetual plumbing! Will it work?
http://jestr.org/downloads/volume1/fulltext12.pdf
And how exactly is the water level achieved as shown in the pic,with out flowing around to the side of the U shaped pipe,into the ball holding cavity?.
Quote from: tinman on February 02, 2014, 07:14:09 AM
Water is standing on mercury below it. There is no empty space below the water. Since mercury is a heavy liquid, the level of mercury is far less than level of water in the tube. The weights of several balls acting on the bottom most ball pushes it to some extent into the mercury, eventhough the ball is lighter than mercury and floats in both liquids.
There is nothing wrong in figure or idea. The question here is, the momentum of ball falling from the top is sufficient enough to push the bottom most ball through balance portion of mercury to the bottom of water, so that from there ball floats to the top and cycle repeats.
Please study this section of Simanek's Museum:
http://www.lhup.edu/~dsimanek/museum/buoy4.htm
Quote from: TinselKoala on February 02, 2014, 08:56:43 AM
The important difference between Simanek's drawing and the one above is, Simanek's drawing shows only one ball which gains and loses energy as he has explained in that section. But the drawing above has several balls which have their own weight and total weight altogether act on the bottommost ball pushing it to some extent inside mercury and storing initial potential energy in it. Now you need energy only to cover the balance portion of mercury and not the entire portion. If the falling ball (this ball falls on another solid ball making a collission and not directly on mercury) from the top provides this balance energy then bottommost ball should cover the balance portion of mercury and move towards top of water.
Since mercury is a very heavy liquid, the energy required to push the ball through it will be high. So, whether this system works - I don't know.
Quote from: Newton II on February 02, 2014, 09:41:35 AM
Ball is lighter than mercury and water. When mercury is supporting such a lengthy column of water on left side, will it allow the still lighter ball to penentrate through it? Mercury will easily support weight of all the balls put together and will not allow the bottom most ball to penentrate through it to the extent shown in that figure.
Does it really need to be mercury? How about oil and water? At least, this could be tested easily. Will the oil and water surface level be the same? I know, it's a silly question. But I really never tried this.
That is where the down fall is,and why it wont work. Since mercury is 13.5 times as heavy as water,it will take 13.5 times as much force to displace the mercury as it would the same amount of water at 4*c.
negative........
Quote from: dieter on February 06, 2014, 04:54:33 AM
You can use water with lighter oil like petrol or kerosene.
I had tried an experiment with water, kerosene and candle wax ball. Candle wax sinks in kerosene but floats on water (unlike the ball used in the above experiment which floats on both liquids). The wax ball was sinking down through kerosene and stop at the junction of two liquids. In whatever fashion (angle) you keep the tube, ball will finally settle only at junction.
It reminded me of one important propery of liquids which says that " liquids communicate pressure equally in all directions".
Hence when ball reaches the junction of two liquids, it need not necessarily pass through and float on heavier liquid because the heavier liquid communicates the pressure in downward direction also and holds the ball at junction itself.
Conducting experiment is never a waste of time even if it doesnot work because you will learn lot of things from it. Since this experiment is simple and inexpensive, you can try and see.
