Here is another of my old papers suggesting means for accessing energy from electron precession. It assumes that in a very fast change of applied magnetic field the individual electron precessions are not able to instantaneously adjust their precession frequency to the new value, and in this temporary "non permitted" state they supply an anomalous longitudinal magnetization. It may be noted that in normal magnetic switching circuits where current is switched into a coil, the current rise-time (hence also magnetic field rise-time) is slow because of the low impedance drive circuit. Only on switch-off do we see a rapid field change (and that time constant is likely determined by stray capacitance). There are many claims for OU associated with fast back-emf spikes and my paper may offer an explanation for where the anomalous energy comes from. Enjoy!
Cant open doc files :(
The file opens fine with Wordpad, all figures and text are readable.
Smudge: Thank you for posting this as it is an area I have been experimenting in. I will give it a thorough read.
My plan is to use a normal coils and out of phase coils to create a bucking orthogonal field timed with the normal coil. I am using MnZn material and a very simple low power excitation circuit that will also easily detect the presence of anomalous energy.
I am also looking at any voltage developed at the ends of the ferrite material.
Kind Regards, Vortex1
Edit: Ok read the paper, looks very good. What is the current state of your experiments with this?
Quote from: Dave45 on June 03, 2014, 07:30:21 AM
Sorry I sent the wrong file. Should have sent the pdf version so here it is.
May I present this circuit for OU testing?
I also have variable frequency circuits that do not require an externa FG (frequency generator) drive, very simple two transistors.
Vortex1;
Would you mind integrating a high speed optoisolator in place of R3
with its EC resistor driven from inside the circuit? This is to acknowledge
the presents of a high "Cgd" value gate->drain parasitic capacitance often
associated with FET's. Now, The signal generator energy is used to drive
the LED PIN diode and the transfer function causes the FET circuit to drive
the energy to the FET gate. The function generator symbol should be
that of an AC source.
:S:MarkSCoffman
Quote from: mscoffman on June 03, 2014, 04:33:51 PM
Vortex1;
:S:MarkSCoffman
Hi Mark
Yes, a high speed optoisolator would work, also any of a number of FET driver chips or discrete transistor buffers. This was an elementary circuit meant to demonstrate a means for the average experimenter without expensive test equipment to verify if heading in the right direction. Advanced testing could come later when positive results as outlined on the drawing are obtained.
Regards, Vortex1 / ION
Very interesting paper, Smudge. Thank you for sharing it.
It leaves me with questions about the unstated or overlooked role of increased precession energy (and its harvest) in a number of devices where an external magnetic field is introduced. If I understand correctly, your paper looks at accessing the increased precession energy within a permanent magnet arising from the introduction of an external magnetic field. A question arises for me: Could this same increase of energy from the quantum domain (increased precession energy) be fostered in say, a piece of iron or a coil of iron wire (whose atoms might be precessing on their axes in response to earth's magnetic field), through the introduction of an external magnetic field?
Bob
Smudge:
thanks for the fantastic paper !! on Spinwaves !!
I also know that it's magnetism that alters gravity below are links to things that I study..
http://www.doctorkoontz.com/Scalar_Physics/Searl%20Effect/Experiments%20of%20Roschin%20&%20Godin_01.htm (http://www.doctorkoontz.com/Scalar_Physics/Searl%20Effect/Experiments%20of%20Roschin%20&%20Godin_01.htm)[/font]
Again thanks for all your scientific papers here on overunity..
Acca..
Some of this maybe old hat to you....
here is how to measure the magnetic moment..
http://wanda.fiu.edu/teaching/courses/Modern_lab_manual/ESR.html (http://wanda.fiu.edu/teaching/courses/Modern_lab_manual/ESR.html)
Here is a "Electron Spin Resonance Spectrometer" (ESR) (EN-35) device for $2250. that measures the value of a single electron's magnetic moment
https://www.thesciencesource.com/store/subject.php?product_id=641 (https://www.thesciencesource.com/store/subject.php?product_id=641)
Now this is VERY IMPORTANT as George has been absent since 2004 at least ten years ?? Why ?? here are some exerpts from his book, link below..
http://books.google.com/books?id=Tj_Lm9qWckwC&pg=PA59&source=gbs_selected_pages&cad=2#v=onepage&q&f=false (http://books.google.com/books?id=Tj_Lm9qWckwC&pg=PA59&source=gbs_selected_pages&cad=2#v=onepage&q&f=false)
And the Vasant Corporation is back. aerospace electronics engineer, George J. Bugh who is selling his book.. on spinwaves on ESR . link below... I have bought his book on amazon..
http://vasantcorporation.com/ (http://vasantcorporation.com/)
George J. Bugh videos on spinwaves
https://www.youtube.com/watch?v=ZkOuGRU8akA (https://www.youtube.com/watch?v=ZkOuGRU8akA)
https://www.youtube.com/watch?v=HjsL1zfmKvA (https://www.youtube.com/watch?v=HjsL1zfmKvA)
https://www.youtube.com/watch?v=craHcstJJZ0 (https://www.youtube.com/watch?v=craHcstJJZ0)
https://www.youtube.com/watch?v=izlcZPUMkdA (https://www.youtube.com/watch?v=izlcZPUMkdA)
https://www.youtube.com/watch?v=VDEtPGB13NM (https://www.youtube.com/watch?v=VDEtPGB13NM)
https://www.youtube.com/watch?v=EEMFqOvViDg (https://www.youtube.com/watch?v=EEMFqOvViDg)
https://www.youtube.com/watch?v=Ge4Ni3ke2I8 (https://www.youtube.com/watch?v=Ge4Ni3ke2I8)
https://www.youtube.com/watch?v=0TLshXC-xF4 (https://www.youtube.com/watch?v=0TLshXC-xF4)Wesley presents Daly part #2 Free Energy Device (schematic)
Wesley
Wesley presents:Daly part #3 Free Energy Device (schematic)
https://www.youtube.com/watch?v=KR99TnupvOU (https://www.youtube.com/watch?v=KR99TnupvOU)
Wesley
