Hello!
I have to repeat this topic here (previous attempt at the corresponding YAHOO group).
Do you people have any degree of certainty about what we can fins in the big pots.
Yes, I know, that the exact construction remains unknown - if it would be known it would be known haow to build Testatika.
But still I think that any info is extremely important.
The central question - ARE THERE ANY MAGNETS OR ANY FERROMAGNETIC MATERIALS IN THE POTS ?
If yes, we have one direction of thoughts - if no - completely different (IMHO).
I gave some unfinished thoughts which I'm afraid todisclose prematurely before I receive new info about the presence (absence) of ferromagnetic media in the pots.
Maybe Stefan Hartmann can shed some light onto the subject ?
regards, Anton
Hi Anton,
it was said, that the big cans have multiple donut magnets stacked ontop of each other
with an airgap between them.
Between the donut magnets in the airgap
there are coils with very fine wire sitting there and
then an ouput wire was said to go vortex like inside the center
of the stacked donut magnets and coils.
But it was not clear to what this bigger output wire was connected.
This way at least Marinov describes the contens of the big cans.
The smaller longer higher cans at the back side of the 3 KW Testatika
are said to contain mountain crystal stones, which probably are slightly radioactive
and when hit with RF bursts or high Voltage pulses from the
cans being capacitors , give off some
excited radioactive beta decay, which is probably, where this machine
gets its huge power output.
So it converts excited via high voltage pulses stimulated radioactive decay into electrical power.
Thank you much, Stefan!
These pots are interesting devices indeed. I will think this way.
What about frequently mentioned Marinov's phrase on the subject ?
The capacitors have a cylindrical "grid", cylindrical plastic insulation and a copper spiral in the center... THAT'S ALL! I saw in one of the small machines and there are no magnets. - Stefan Marinov 9/4/90 (see e.g. http://rimstar.org/sdenergy/testa/potstheory1.htm)
Regards, Anton
Oh, just have forgotten to ask - Are there coaxial grids around this coil/magnet setup ?
Anton
Hi Anton and Stefan
From the information I have researched I am convinced that the 'big cans' of the Testatika are like the device used in tesla's disruptive discharge technology, and in EV grays motor he called the convertion tube as shown in the picture below.
This would explain the tremendous amout of energy that the Testatika is said to produce. Tesla said in his notes that to produce the radiant energy without stinging sensations you need to have the sparks resonate at about 10-50 mhz so I think that the magnets and capacitor is used to create the resonance.
In EV grays device it uses only one convertion tube or can in his circuit. He said his device 'split the positive'. He had to dump the extra energy into a ground after it created work. Since the Testatika uses two convertion tubes in its circuit it has a positive and a negative terminal and does not dump the energy.
So basicly what we have is a wimshurst electrostatic generator with the capacitors and the spark gap, the cans or convertion tubes, and the magnet and capacitor that resonates the spark at the correct frequency for radiant energy. All in all I think this is a very elegant and ingenious device that could be made cheaply.
I havn't been studying this for very long but I am tinkering with making a cheap replica in my basement. Please post with any info and ideas.
Mike.
Mike,
I've been working on just what you decribe - Wimshurst machine producing sparks and two spark gaps, each one just at the beginning of the two cans. See:
http://rimstar.org/sdenergy/testa/wimspark1.htm
-Steve
http://rimstar.org
