Overunity.com Archives
Solid States Devices => Tesla Technologgy => Topic started by: gemstone hell on December 09, 2014, 02:44:20 AM
Title: POST YOUR TESLA BASED THEORIES ON ENERGY GENERATION
Post by: gemstone hell on December 09, 2014, 02:44:20 AM
Hello all. This thread is a place to post your own Tesla based theories and designs for free energy. I have a helluva good one. Took me years to figure it out. Will I tell? Let's hear what you guys have to say. By putting these all in one thread everyone can get a good overview, instead of having to read through all the threads. So, post your ideas and tell us all why it might work and how Tesla influenced you to think it up! Also, if you have built a Tesla design yourself or want to discuss what you think his ideas meant, as there is some debate about this, then you can post about that as well. Please, no harsh comments for each other. Let's rise above the Above Top Secret Forum level. LOL Happy posting, OP
Title: Re: POST YOUR TESLA BASED THEORIES ON ENERGY GENERATION
Post by: forest on December 09, 2014, 03:22:07 AM
energy amplification thread  look for funny red picture  :-\ , long time ago in 2008 probably
Post by: sparks on December 09, 2014, 05:31:41 AM
   Tesla used faraday's law to obtain high voltages.  His transformers worked by changing the magnetic field in the primary very abruptly.  The faster you change the magnetic field about a conductor the higher the voltage induced.  The secondaries worked by turn to turn induction.  The current flowing in a turn induces a magnetic field change about it.  The turn adjacent to the turn in which the current is flowing experiences a change in the magnetic field about it and current flows in it.  Each turn acts as a primary and a secondary.  All these transformers are hooked in series so that they multiply the voltage induced in the first turn by the number of turns in the tesla secondary.  If the turns close coupled to the primary induce a voltage of l000volts and there are 100 turns in the secondary the voltage reaches 100,ooo volts.  Each turn acting like a battery all connected in series.  The induced voltage travels up the transformer and reaches the terminal faster than the current can flow through the wire which forms the secondary.  This appears as faster than the speed of light electricity but in reality the power is going up the tower length not through the wire itself.
  This can't happen at low frequency.  The current needs to flow only in the close coupled turns for the length of these turns.  So the frequency of the primary input is matched to the length of the secondary turn.   RF current flows in the first turns and then up the secondary as described above.
Post by: Doug1 on December 09, 2014, 07:05:33 AM
I concur with Sparks. I think most will not understand what he stated though. my experience has been with 4 volts dc from a dead 12 volt battery I was able to get up to 250 volts ac. In theory any voltage being positive and a modest amperage you can get what ever output you want if you have enough materials to build it.
  The law of induction states it very well.maybe too well. Tesla coil for electromagnets is pretty strait forward but seldom comprehended. Think like a child when reading patents "ask why" a lot. Be open to learning and less concerned with just copying. Without understanding the "why" there is no understanding the how to.
Post by: padova on January 29, 2015, 04:03:14 AM
Hello everyone I am new to this  forum.And in this area to.
For now, I've had several attempts with simple Solid state devices.
Here is a link to a theory of Tesla waves: http://users.beotel.net/~gmarjanovic/Tesla_waves.pdf
It's not my theory. Theory comes from mr. gmarjanovic
regards
Post by: uep57 on February 17, 2016, 05:17:07 PM
I've posted in this group the theory is the basis for the Tesla's waveguide get free energy from the vacuum because that waveguide is a negative resistor.
http://overunity.com/16399/teslas-transmission-waveguide-equations/new/#new
regards
UEP57
Fray Mamerto Esquiú
Post by: uep57 on February 19, 2016, 08:02:36 AM
This is the english version of the video
https://youtu.be/zZ-EFwdV49o
Bye
Post by: uep57 on February 19, 2016, 08:03:49 AM
Bye
Post by: thx1138 on February 29, 2016, 07:32:32 AM
Quote from: sparks on December 09, 2014, 05:31:41 AM
I've been wondering what the effect of the bold text in the following quote from the Tesla transmission patent is:
"The coil B [extra coil] is wound on a frame or drum D' of insulating material, with its turns close together. I have discovered that when so wound the effect of the small radius of curvature of the wire itself is overcome and the coil behaves as a conductor of large radius of curvature, corresponding to that of the drum. This feature is of considerable practical importance and is applicable not only in this special instance, but generally."
https://teslauniverse.com/nikola-tesla/patents/us-patent-1119732-apparatus-transmitting-electrical-energy (https://teslauniverse.com/nikola-tesla/patents/us-patent-1119732-apparatus-transmitting-electrical-energy)
In the patent, coil C is the primary, A is the secondary, and B is the "extra" coil wound around "drum..of insulating material" D'.
If I understand your post correctly, it means the purpose of the extra coil wound around a cylinder of insulating material is to decouple, if you will, the voltage from the current. Is that correct? Can you expound on that a bit please?
Post by: darediamond on March 01, 2016, 12:46:42 AM
Quote from: Doug1 on December 09, 2014, 07:05:33 AM
You nailed Dough by your words towards the end of your comment. "think like a child when reading patents" ask why" a lot. BE OPEN TO LEARNING AND L E S S COPYING"!!!!!
WAO WHAT AN EYE OPENER!!
Post by: delboy on March 25, 2016, 03:45:15 PM
Hi all,
As topic says "TESLA BASED THEORIES ON ENERGY GENERATION" I will give some comments..
Tesla did produce large coils for generating HV/HF (high voltage - high frequencies). Ask your self why did he do that? Obviously not to throw sparks all around to impress somebody because that is what is left today and what everbody do, sad but SO TRUE!
Compare his design and have in mind that it was over 100 years ago (no electronics to drive FETs MOSFETs etc.)
He started in NewYork and his laboratory became to small for what he had in mind to do. Read his patent 645576 where he explains in details how his one working coil was designed. Some of characteristics :
- diameter of coil 240 cm
- source power 50 kV
- primary cap. Cp=0,04 uF
- primary ind. Lp=10uH
That will give resonant freq. about 250 kHz[/size]
-Primary turns Np=1 (stout stranded cable)
-Secondary turns Ns=50 (AWG. No.8  ~ 3,2mm diameter of wire)
-mechanical-break 5000 times/second
Output voltage from 2 to 4 MegaVolts !
Compare that design with design of today. You did not produce TRUE TESLA COIL, you are just making some copies to impress someone.
And what about receiver? When we are going to see some receivers like Tesla made in patent 787412. It doesn't have to be "through ground", it can be one-wire connection between Transmitter and Receiver.
Guys we are 120 years late, we are not moving forward. We are stucked somewhere in 1890s where only three-phase system of power distribution is working.
No HV / HF designs for industrial purpose, no education in schools, yes that is true, not even 1% of what Tesla designed after 1890 is found in school books ?!
Do I have to mention that Tesla moved in Colorado Springs and designed coil 15 meters in diameter with only 35 turns on secondary ?!
Try to read something about Tesla but read it chronologically because only that way you will understand Tesla. Read his patents, notes and articles... and maybe you will find "how deep rabbit hole is".   ;)
Post by: padova on April 10, 2016, 04:44:53 AM
But to this days, except maybe in one case, no one has ever successfully replicated his magnifying transmitter.
All work was stolen a century ago. :) sad but true.
Post by: delboy on April 10, 2016, 06:53:31 AM
Quote from: padova on April 10, 2016, 04:44:53 AM
I do not agree! After 100 years nobody to replicate something that Tesla very well described and patented and published ! Do you have 100 000 $ to build something like that for GLOBAL purpose ??? If NO than try to build something for HOME USE but build it in way Tesla described, patented and published. Problem is that people do not know what and how to do with it, and they think they are the SMARTEST and build TC for spark light show to become lightning masters  :D  That is situation today. We have better copper wire, better switches, better insulation than Tesla had and NOTHING. It is like you give airplane to some tribe in jungle and what would they do with it, they would just have sitting around and look at it, maybe afraid, maybe surprised who knows. But point is that they would not know how to use it, what is purpose etc.
Tesla made AC POWER system distribution with PURPOSE and everything is working okay, but one thing is wrong, you have to keep stove burn coal if you want POWER. You are wasting almost 60% of what you invest (COAL) than you GET (water steam) to run turbine and generators because steam turbines are only 35% effective, we didn't even try to change this with Tesla turbines that are 95% effective. Next step is to eliminate coal stoves and water steam turbines (he tried but who is Tesla to decide that big STEP)
No resonant accumulating system that will give power only if receiver is connected. That would be third industry revolution and Tesla did it. It is up to you to understand it.
We were not prepared for that and those up that rules our lives (GOVERNMENT) acts strange when you give them POWER over something. Imagine how they act when you try to take their power away ;)
Century passed you say, but look around, everything you see there is Tesla and we did everything to forget about him and his teachings. You will not find in school books his spiral coils, impedance phenomena , how to build TC because there is no school for HV / HF high voltage high freq. You have school for high voltage but 50 or 60 Hz and you have schools for high freq. radio amateurs etc. but nothing combined. In this way Tesla reminds me on Bruce Lee where he states that you have to combine all arts to become BEST OF ALL.
What would you do if you would have your own true TC, it is same as if you ask yourself what would I do if I have bomb. Would you keep it for your self or would you sold it? (If you know how to drive plain than you will use it correctly) ;) Because today everything is money, at least 99% of people think it is.
Remember how Tesla reacted when someone asked him would that ship that is operated wireless be used for transport of some bombs in wars and ask your self what you approve and what not! Would you split Earth in two pieces  with some machine or would you say "Hay if you give me 1 billion dollars than I will not do it" !
Post by: forest on April 10, 2016, 08:41:24 AM
It's not just about Tesla. He patented some strange devices to show he learned the secret knowledge hidden from very old times. Our current world knew about it for sure from the Faraday times. The so called "crooks" like Daniel McFarland Cook were proof of that.
Post by: Overmind on July 01, 2016, 02:57:12 AM
Tesla's tower was similar in concept to how pyramids worked as power plants (yes, they were power plants, not graves).
If you want to generate power in a similar manner, perhaps you should check the similarities more closely.
I currently try to take the 'capture power from any possible sources approach' since there are plenty things that spam us with power currently...we just need to convert it into usable power.
