Overunity.com Archives
Energy from Natural Resources => Gravity powered devices => Topic started by: poplianil on January 02, 2015, 01:10:29 AM
Title: Bessler Theory Solved
Post by: poplianil on January 02, 2015, 01:10:29 AM
 Bessler had almost given the idea in his clues with too many unnecessary details to confuse everyone. After years  being on this subject I have solved the key how he lifted weights with little effort. Go thru the attachment ( Popli Gravity Wheel . pdf )  and balance is just creativity.
A validated way to prove overunity is possible through  mechanical methods.
Title: Re: Bessler Theory Solved
Post by: telecom on January 02, 2015, 05:01:49 PM
Quote from: poplianil on January 02, 2015, 01:10:29 AM
Hi,
sounds very interesting.
Can you please describe some more other methods, rather than the wheel, to utilize your idea.
Thank you!
Post by: poplianil on January 02, 2015, 11:33:24 PM
So far I am also still looking into that possibility.  It was difficult to get to this, how I can change the moments on leftside and yet use them on right side.
Use a wheel with Electro magnetic coils or solonoid with 50% max vertical movement. Easiest and least complicated.
I am still working on this will get back whenever I hit something.
Post by: poplianil on January 03, 2015, 05:42:04 AM
https://www.youtube.com/watch?v=5y7iDJFJGqI
Post by: MT on January 04, 2015, 06:24:30 PM
Hi Poplianil,
Thank you for posting this idea, I appreciate your effort given into this. I'm no expert in gravity machines, they are better here. Just noticed a possible issue with your wheel.
Yes it costs about half work to lift weight 10cms at 12oclock. But in order to stretch the spring between 3->12 there ought to be also work done as spring is attached to the wheel. The weight is static from 3 to 12 but spring is being stretched and it pulls on the wheel with increasing force from 0 up to 10kg on 12 hours. This force is effectively CW and works against your CCW rotation. I'm afraid that to overcome this CW force you need to spend half of the work you gained by cheaply raising the weight at 12. I still need to watch your video maybe you somehow solved this.
Marcel
