Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: plaxius on January 29, 2015, 08:22:44 PM
Title: Akula Hendershot !!!
Post by: plaxius on January 29, 2015, 08:22:44 PM
https://www.youtube.com/watch?v=HmYfcgvf6Jc (https://www.youtube.com/watch?v=HmYfcgvf6Jc)
AKULA HENDERSHOT WITH OSCILOSCOPE SIGNALS ..
https://www.youtube.com/watch?v=VAK0UgTr2CE (https://www.youtube.com/watch?v=VAK0UgTr2CE)
https://www.youtube.com/watch?v=w3LRmSovEX8 (https://www.youtube.com/watch?v=w3LRmSovEX8)
Hendershot how to ..
Title: Re: Akula Hendershot !!!
Post by: alejandroguille on January 29, 2015, 09:57:56 PM
Quote from: plaxius on January 29, 2015, 08:22:44 PM
Es falso.
Is fakle !!!
Post by: NickZ on January 30, 2015, 09:59:19 AM
  The Akula/Hendershot generator version may mean that Akula has sold his rights to his earlier self running devices, and is now working on this Hendershot type circuit.
   Anyone know why he would go that route???
Post by: Void on January 30, 2015, 10:20:30 AM
Quote from: NickZ on January 30, 2015, 09:59:19 AM
Akula actually seems to be working on various over unity devices. Check his other recent videos such as:
http://www.youtube.com/watch?v=pYjREkw1v-A
and
http://www.youtube.com/watch?v=wPfR_y2aAeM
He also seems to be working on some other device that looks like maybe a pulse motor.
The Hendershot generator may be something he did a while ago...
All the best...
Post by: alejandroguille on January 30, 2015, 10:23:05 AM
This is totally false.
Now it is clear that akula is false.
At some point he was going to know who this guy was.
This guy is a fucking agent.
Post by: kEhYo77 on January 30, 2015, 10:51:07 AM
@Hi Void
The 00033 (https://www.youtube.com/watch?v=pYjREkw1v-A) vid is realy interesting.
Even without precise measurements for 21W input those bulbs seem to shine quite brightly,
especially after a while (@2:15), when he tunes the frequency. ???
This is along BiTT princilple with a twist. He tunes for two, far side LC tanks to reach resonance.
The geometry for an alternate magnetic path for the BEMF flux does the magic.
This is my 'freshly wound' primary. 0,8 mm (20 AWG) wire on a U-93 core.
And I am soldering >70kHz 200W amplifier for this puppy...
Will see how it goes. :)
Elo
Post by: MenofFather on January 30, 2015, 11:27:13 AM
Quote from: kEhYo77 on January 30, 2015, 10:51:07 AM
@Hi Void
Elo
He say that two 36 V 60 W lamps light on full brighness, then consumption 25 W.
Post by: Void on January 30, 2015, 11:30:31 AM
Quote from: MenofFather on January 30, 2015, 11:27:13 AM
Hi MenofFather. That sounds pretty good.
kEhYo77: Let us know how you make out.
All the best...
Post by: willz on February 03, 2015, 11:19:07 AM
Dont bother guyz.Akula has its own firm,his ferrite cors are custom made russian cores ,they resonate at khz range,as low at 17khz,he uses ofc cables,its very easy to get this components in russia,every store in moscow has ofc cable...
Post by: lipek11 on May 14, 2016, 08:13:56 AM
where are the coils L1, L2, L3?
Post by: lipek11 on May 22, 2016, 07:19:30 AM
what voltage is on light bulbs? 220V or 24V?
Post by: turbogt16v on May 22, 2016, 07:35:52 AM
Akula is well known russian troller,you really should not believe a man that has over 30 OU ,none of is replicated.
Post by: PolaczekCebulaczek on June 06, 2016, 06:56:37 AM
can someone translate this?? perhaps Wesley?
Akula hendershot how to :
https://www.youtube.com/watch?v=giK3ovIwnng
Post by: MenofFather on June 07, 2016, 04:07:36 AM
Quote from: PolaczekCebulaczek on June 06, 2016, 06:56:37 AM
https://www.youtube.com/watch?v=giK3ovIwnng (https://www.youtube.com/watch?v=giK3ovIwnng)
That is long video, wery long translate. And I not see here nothing inportant.
Post by: AlienGrey on June 07, 2016, 05:00:46 AM
Quote from: MenofFather on June 07, 2016, 04:07:36 AM
That is long video, very long translate. And I did not see here anything important.
Hi yes I have been following his vids, I found them quite interesting I don't mind the language but did you not notice the scope shots he was showing you and the module on the bench he uses to sample and protect his scope inputs ? they also have CC did you not play it in google and translate ?  ;) or was I watching something totally different.
PS you could try asking Wesley yourself directly. ;)
Also watch this https://www.youtube.com/watch?v=9tplRbd-fso
He presents it as a dorway.
Post by: PolaczekCebulaczek on June 07, 2016, 09:41:18 AM
QuoteThat is long video, very long translate. And I did not see here anything important.
you say that akula shows nothing interesting ? yet he build a working Hendershot device... it was real or not?
Lester device was some sort of earth magnetic field NMR so signal should change when device is positioned with respect to the earth magnetic field poles...
Title: Detecting fakes
Post by: thx1138 on June 09, 2016, 10:15:40 AM
Here are simple things I used to spot a fake:
Tablecloths - Why is there a table cloth at all? The Akula Hendershot device is mounted on a plywood board. There is no need for a tablecloth for insulation. Why does the tablecloth hang far over tabletop? To hide something under the table.
https://www.youtube.com/watch?v=HmYfcgvf6Jc (https://www.youtube.com/watch?v=HmYfcgvf6Jc) - Why is there a tablecloth?
https://www.youtube.com/watch?v=wPfR_y2aAeM (https://www.youtube.com/watch?v=wPfR_y2aAeM) - 0:04 - Why does it hang down so far?
Unexplained wires - https://www.youtube.com/watch?v=HmYfcgvf6Jc (https://www.youtube.com/watch?v=HmYfcgvf6Jc)
0:58 & 1:38 - Wire runs from device on shelf at the back to the back and under the table.
1:51 - Many unexplained wires to the left
3:19 - Different tablecloth clearly has something on the left running under the mounting board
3:30 - White wire at back running under mounting board
3:46 - Batteries to left where unexplained wires are located are below the level of the tabletop
IMO, fake.
Post by: PolaczekCebulaczek on June 09, 2016, 10:27:08 AM
all akula videos has this famous tablecloth,akula is the tableclooth man! lo he is thel russian troll ,gigant coil under table for sure.
