Overunity.com Archives
Electric vehicles => Electric bikes => Topic started by: TommeyLReed on February 27, 2015, 04:59:28 PM
Title: E-Trike Kick Starter Project.
Post by: TommeyLReed on February 27, 2015, 04:59:28 PM
Hello all,
This is a project I'm working on as a 3 wheel bicycle (Trike).
My goal is to create this E-Trike with a range of 60 miles per charge at 20mph with a top speed of 35.
I am starting a $5,000 funding on kick Starter to build the first prototype.
Tom
https://www.kickstarter.com/projects/1475830610/e-trike-going-green (https://www.kickstarter.com/projects/1475830610/e-trike-going-green)
Title: Re: E-Trike Kick Starter Project.
Post by: ramset on February 27, 2015, 07:21:15 PM
Tom
wild looking ride !  60 miles on a charge is really a great distance .
I would imagine this would be in hilly terrain?
very nice simulation video ,also the regenerative braking is a great idea.
good luck with your campaign .
Chet
Post by: TommeyLReed on February 28, 2015, 12:52:26 PM
More update on specs:
Post by: ramset on February 28, 2015, 04:14:02 PM
Tom
Looks better every time...
have you ever built this type of trike before ?
Post by: telecom on February 28, 2015, 04:36:39 PM
What is the material for the frame?
Looks really nice, btw.
Post by: TommeyLReed on February 28, 2015, 04:58:18 PM
Hi Chet,
Yes I built a few recumbent in the past, I will look for a picture and put it up on this site.
Tom.
Post by: TommeyLReed on February 28, 2015, 05:07:14 PM
Hi Telecom,
I was thinking of aluminum frame.
I will have to make a prototype frame from plywood and double check all parts before going all aluminum.
Plywood will allow me to make a basic template and also I will be able to correct design before a finish design frame.
Tom
Post by: TommeyLReed on March 01, 2015, 08:58:54 AM
Hi All,
Got a few parts already to start the frame design, will make it out of laminated wood to test run this design.
https://www.youtube.com/channel/UCK3k2-Vhr19mtUqm42N687Q
Tom
Post by: MarkE on March 01, 2015, 02:12:38 PM
It looks nicely stiff in the Z axis, but I don't see what provides stiffness in the X axis.  Are you relying on the thickness of the material for that?  You might want to consider using square or round tubing along the top and bottom of your horizontal members so that they do not require excess material for the desired stiffness.
Post by: TommeyLReed on March 01, 2015, 03:01:30 PM
Hi MarkE,
I will be able to test the frame and make correction as need.
https://www.youtube.com/watch?v=HimcaUKzqxU&feature=youtu.be
Tom
Post by: Pirate88179 on March 01, 2015, 03:38:34 PM
Tommy:
Nice design.  I wish you a lot of good luck with your campaign.
Is that a solar panel on the front of your design?  If so, this is something I have thought about for a long time.  If you drive this to work on a sunny day...why not have it trickle charge while sitting in the sun in the parking lot all day?  I have not seen anyone do this before and I always wonder why.  The panel would not allow you to just drive on the sun but....as I said...it is just sitting there in the sun while you are at work...so why not get a few watts from the sun during this time?
If this is not your intention, you might want to consider this.
Best of luck to you Tommy.
Bill
Post by: MarkE on March 01, 2015, 03:43:09 PM
Quote from: TommeyLReed on March 01, 2015, 03:01:30 PM
Hi MarkE,
Tom
A lamination stack on either side of a pair of square tubes would be one way to stiffen up the X axis.
Post by: Magluvin on March 01, 2015, 04:01:43 PM
Nice. ;)
Ive been thinking about the same kinda thing. Been riding ebikes for 7 years now. Have 3 of them. One that I bought in the beginning has near 15k miles on it. Does 25mph, lots of low end torque, 48v. Running sla 14ah  Dura12-14F2 Duracell. Found at Batteries plus Light Bulbs stores, that are the same foot print as 12ah. Heavier than lith, but $150 every couple years if I take care of them properly. Had issues with lith bats back then. And even now, $600 for what I need, I cant say I have many years of faith in them yet. Still hear of people that are not happy with costs of replacing lith batts before their advertized life.
My idea was to make the frame out of pvc tubing and wrap with carbon fiber once the frame is complete. There are pvc tubes with thin walls to reduce weight, but makes a great core for framework. Pvc likes resin also. And the cost of the carbon fiber is not bad really. Had gotten 3 yrds of 4x4 weave, nicer look than 1x1, for about $60.  50in wide.  Possibly a couple hundred to complete a frame covering, depending on the framework. 1x1 is cheaper also. Surfboard resin is glass clear and uv resistant.
Wanted to do a bottom body with flip up canopy also. Needs to be small as wind can blow ya over. ;)
Im working with an Arduino Mega and the tft color touch screen as a controller and info center. All it has to do is intercept the throttle signal and modify it any way you want. Have presets for gradual throttle up or full power, how ever the user want to map the presets. My bike will spin out at quick full on from a dead stop. So a preset for rain would be useful to reduce spin.
One of my other bikes is a Tidalforce M-750 that I am replacing the stock controller with an Ardiuno/tft. The M-750x can do 30mph, where mine is set for 20mph. All due to programming, but no body seems to be able to hack them, yet. So I will be able to open up the capabilities to what ever I wish on that bike. Has a very strong motor. Will pull the front wheel off the ground, even being a lower power(programmed) model.  Legality in most all 50 states is 20mph max and under 750w/1hp.. The M-750 is 749w and stops accelerating at 20mph. Street legal. Meaning it is considered a bicycle.
Funny. My Trek is 500w and does about 25mph. Can pedal with to about 27 in final gear. Not a racing bike. $450 next to the bottom Trek. Has been very good to me.
there are kits that will do 55mph for 50 mi. Will need a much better bike though. Id say above $1000 to handle those speeds and pressures. My Trek has a pot control to adjust the throttle sig out and a switch to go from low preset to full power. Made it myself with radshack parts and project box.
Will post some pics of the bikes when I find where they are.
Good luck. Will be watching with interest what you come up with. My Trek, the 48v front wheel drive kit was bought on ebay 7 yrs ago and still runs great. Was about $600 on ebay. 500w  48v  15a fuse, about right.  Now you can get 1kw kit for $200 n change, w/o bat on ebay.
If you are going for manufacturing, check out Alibaba for your motors. Thats where all these ebay kits are coming from, and reduce your costs significantly.  ;)
Mags
Post by: TommeyLReed on March 01, 2015, 05:48:14 PM
Hi All,
Thanks for all the input.
I do plan to do solar panels in the front and maybe in the back also.
This is a better look at the main frame design, I can also make this out of aluminum later on.
I can print this frame out on paper and use a pantograph to trace onto the plywood for each part to build this frame like you see it.
Tom
Post by: TommeyLReed on March 01, 2015, 10:41:17 PM
Hi All,
What do you think about the E-Trike shirt?
Tom
Post by: MarkE on March 02, 2015, 02:00:58 AM
I think that the color and contrast could use tweeking to make the bike's form easier to recognize.
Post by: TommeyLReed on March 02, 2015, 05:11:00 PM
Hi All,
I started on the frame design today, I could not use a pantograph to copy from paper to plywood but it's looking good.
https://www.youtube.com/watch?v=3pCHrHFNcW0
Tom
Post by: TommeyLReed on March 03, 2015, 03:46:47 PM
Hi All,
Working on the shock assembly and front end today.
https://www.youtube.com/watch?v=dGKRnR5Wnoc&feature=youtu.be (https://www.youtube.com/watch?v=dGKRnR5Wnoc&feature=youtu.be)
Tom
Post by: telecom on March 03, 2015, 07:35:48 PM
Looks great!
Post by: TommeyLReed on March 05, 2015, 01:44:47 PM
Hi All,
Kick Starter has been sending emails for extra advertising, they already get 5-9% fees.
I cancel kickstarter and went with indiegogo.
https://www.indiegogo.com/projects/e-trike/x/5190342
Tom
Post by: Magluvin on March 05, 2015, 06:34:51 PM
Quote from: TommeyLReed on March 05, 2015, 01:44:47 PM
Hi All,
https://www.indiegogo.com/projects/e-trike/x/5190342 (https://www.indiegogo.com/projects/e-trike/x/5190342)
Tom
Hey Tommy
Why did you lower the goal to 2500?   From what I see, you will probably only be able to build the 1 bike with that?
What are your plans after that?
You could go for a lot more, while offering a whole trike to a pledge for giving an amount that covers it plus some for the time and effort.
Mags
Post by: Pirate88179 on March 05, 2015, 07:17:35 PM
Quote from: Magluvin on March 05, 2015, 06:34:51 PM
Hey Tommy
Mags
I agree. The QEG folks got like $300,000 and counting for something that does not, and can not work.  This is a real bike and I know you (Tommy) will make it work.  I like Mag's idea that for X donation, you get a complete bike.  Lots of folks will give $5, $10, etc and that will help too.  Go after this and get what you need to do this right.
We know this is not a scam and it is a real technology so...best of luck to you Tommy.
Bill
Post by: Magluvin on March 05, 2015, 07:38:06 PM
Quote from: Pirate88179 on March 05, 2015, 07:17:35 PM
Bill
Absolutely. ;) Could get big enough to provide tech jobs for veterans, etc. ;)
Mags
Post by: TommeyLReed on March 05, 2015, 08:04:22 PM
HI all,
Yes I agree to offer a complete bike.
I lower the price because I thought is would be the right thing to do while I have the wheels and batteries.
What's a good price for a basic E-trike?
The battery pack will cost about $1500.00 to build with new lithium cells for a 2000kwh bank with charging circuit.
Is $3000.00+ a good price for a lower range like 25 miles?
I can't change the asking amount but could add the $3000 -$4000 for a complete E-Trike R1 and R2 models.
Tom
Post by: TommeyLReed on March 05, 2015, 08:16:45 PM
Update link:
http://www.ebay.com/itm/48V-1000W-Electric-Bike-eBike-Bicycle-Lithium-20Ah-Battery-Alloy-Charger-BMS-/181429391476?pt=LH_DefaultDomain_0&hash=item2a3e08d074
Tom
Post by: Magluvin on March 05, 2015, 09:28:27 PM
Quote from: TommeyLReed on March 05, 2015, 08:04:22 PM
HI all,
Tom
Sounds about right for a specialized bike. There are ebikes going for 10,000 and up out there. 55mph for 50mi.  You should be able to get more than 25mi with that pack.  The 1kw motor may be an issue. 750w and under is street legal in all 50 states. 1kw can get you 30mph or better, but 20mph is street legal in all 50 states also.  My trek has a 500w 48v and it can do 25mph with 26in 2.0 tires.  And a 500w motor kit is cheaper. ;)
My bike is about 80lb with 14ah sla(4 of them) and Im 225lb. And it will peel out from a stop with full throttle.  Love that bike. I get over 20mi, with stops and goes along the way, where most kits are mile rated for no stops, just full throttle on a flat road. So with the 12ah, I would get less than 20mi with stops and goes as it was rated for 20mi, no stops. Its the acceleration from a stop that uses the most power. Best eff is at top speed.
But many people are riding around at 35mph and nobody(yet) has issues with cops.  Many police dont even know the law when it comes to ebikes. Sometimes they may say, "hey, you cant ride that on the sidewalk". But if it is within the limits of the law as I have posted, and it has pedals, it is a 'bicycle" period.  Just be nice with them and explain and it shouldnt be an issue once they understand.
But if they start cracking down, since there are more and more of them riding around, the power and speed will be a concern. You can use a resistor network on the throttle output to the controller to lower the top speed in your case. And have a turbo button to climb hills and such. ;)
The reason I was saying to ask for more is, you will need more funds to build more bikes. And the more funds you have to start with, the more parts you can buy in bulk and build the bikes cheaper. More profits, or happier customers, which ever you decide upon.
So, you can do another pledge drive after you finish this one and its a proven product. No biggy.  But it would be nice to just go for it, ya know? ;D
Keep up the good work. And best of luck. ;D
Mags
Post by: Magluvin on March 05, 2015, 09:32:28 PM
And if things go well, check out Alibaba.com to source your kits and batts. Some of the companies will sell singles, and others want a quantity buy in. Thats where the ebay sellers are getting them. ;)
Mags
Post by: TommeyLReed on March 06, 2015, 02:01:32 PM
Hi Mag,
Thanks for the input.
This is a test design look before I start doing welding on the front end a-frame and steering.
https://www.youtube.com/watch?v=vTLWFU4Mc4U
Tom
Post by: telecom on March 06, 2015, 05:15:34 PM
Its getting better every time!
R u planning a derailer on the rear wheel?
Post by: TommeyLReed on March 06, 2015, 06:28:39 PM
Hi Telecom,
Yes, I plan to do a derailer also.
I am looking at a air ride shocks, I can make them cheaper then spring shocks.
Tomorrow I plan to work on the front end.
Tom
Post by: picowatt on March 06, 2015, 06:54:48 PM
Caster, camber, and toe...
Post by: TommeyLReed on March 06, 2015, 07:07:57 PM
Yes Picowatt,
I will be able to also adjust the camber from the frame also.
I just got my steel in today, using 1"x1"x1/8 square stock for the (4) A-frame.
Tom
Post by: Magluvin on March 06, 2015, 10:25:14 PM
Quote from: TommeyLReed on March 06, 2015, 02:01:32 PM
Hi Mag,
https://www.youtube.com/watch?v=vTLWFU4Mc4U (https://www.youtube.com/watch?v=vTLWFU4Mc4U)
Tom
Hey tommy
Watched the vid. Looks good.  ;)   About the soaking of the wood. Just use thinner ply and bend it, then glass it. if you soak the wood to bend it, most all the water needs to be gone from the board before you glass it. If the wood gets warm or hot(resin curing, sun, etc), the water will expand and possibly delaminate the resin/glass from the wood, cause bubbles, etc.
Some other tidbits about the motor wheels...
if you ever take one apart, make a jig to separate the armature from the drum. The armature is the winding holder, stationary to the axle, and the outer diameter of the drum has the mags. My motor, 54 mags, little curve to them, about 1inx1/2inx 1/8in.  But all of them together have some serious pull on that armature. So a jig that separates them is a big plus. The biggest issue is the mags breaking if something goes wrong during manual separation. Lots of shims, one after another to lift all sides a bit unevenly, pain in the butt. And pain in the finger that happens to get caught in that bear trap.  Pulled mine apart to replace a bad hall sensor. There are 3 of them for timing. They are embedded in holes in the outer diameter of the winding cores to detect magnet positions for timing. I moved mine over about 1/16in to gain more bottom end. My plan with the arduino controller will be to add delay to those pulses from the halls to change the ratio of top speed or more torque. This will give the motors the best of both worlds. My first kit was a brushed Wilderness motor. The brush holder had slotted mounting screw holes for the same kind of adjustment. But that would take a mechanical deal to be able to adjust those while riding. So I figured with the delays on the halls, its a piece of cake to adjust on the fly.
The wheels that the motors come with are generally pretty much stronger than normal bike wheels. Spokes are fatter also. So dont get concerned about lots of weight on that rim. Chinese, but beef. Just check for loose spoke nuts once in a while. You wont know one came completely loos till it falls in the rim and jingles around. The rims are real stiff. So if a spoke becomes loose, the wheel wont wobble or seem bent to the side like a normal bike rim. So best to check them here n there. broke a lot of spokes on the trek rim. Hitting bumps and holes in the street at 25mph at a total of 300lb, snap, snap. Sidewalks are even worse at times.
Dont know what tire your using on the motor wheel. I recommend 2.0 tires. Adds a little more cushion to the ride. And looks better. Beefier. Razorbacks are  very resistant to puncture and flats.  Like 50 bucks but worth it if you dont want to fix flats pretty much ever. I go with bontrager street 26 2.0.  Last a long time and rare to get a flat. I learned my lesson. Was doing 30mi a day to work for 3 years. 1 day I had 5 flats. FIVE!!  UGH!   Just fixed one and 1 mile ahead, PSSSSSSssssss.  lol   About 38 bucks each. Worth every penny.  Also, for the tool kit, they have co2 cartridges to fill the tube.  Fast and on your way.  The little pumps. Over 200 pumps and not up to 65lb.  I dont mind a workout, but gees. Large cartridge will fill close to full. Got 3 in my kit. Havnt used one in a year. ;)
You can make a kickstand thing to raise the rear and also on the front for repairs and even maintenance. Just ideas for ya.
Mags
Post by: Pirate88179 on March 06, 2015, 10:39:10 PM
Mags:
I like your thinking on this.  Very good ideas.
As far as I can find out, KY has no laws on electric bikes.  Now, what would be the difference between an electric bike and an electric motorcycle?  I would guess...speed.  But, I find nothing saying anything about this.  The 50cc motorized bike I built complied with all of the laws here pertaining to motorized bikes.  Well...almost all.  Speed was supposed to be limited to 25 mph but I could hit 36 on a flat road.  The law said I needed a step through frame (think scooter) so I built it using a girl's bike.
Has anyone done an electric bike using a trailer for the batteries?  I mean, a small bike trailer could hold several car sized batts and/or even the motor.  I have seen tube videos of guys using trailers for gas engine bikes with larger engines than the law allows for but, the law seems confused on the trailer bit.  Four 12 volts car batteries on a bike trailer with a nice solar panel on the top could power your e-bike for a long, long time.  Otherwise, build a battery pack out of 18650 li ion cells.  (Like 50 of them)  I could make an e-bike go over 100 miles/charge easily I believe.  You could even use 2 motorized hubs on the trailer and leave the bike stock.  Batts and motor in the trailer.
Sorry Tommy...
Design is looking good and I hope you raise a lot of money to make a lot of them.
Bill
Post by: Magluvin on March 06, 2015, 11:18:43 PM
Quote from: Pirate88179 on March 06, 2015, 10:39:10 PM
Mags:
Sorry Tommy...
Bill
Hey Bill
Its a federal law.  Some states or cities may have their own laws also, Like I heard that S.C. allowed 30mph. But that was hear say.  In cali, you can have higher speeds up to 35 with registration. Tag I suppose.
The gas motors work pretty good. Cheaper than electric for a kit usually. For me the drawbacks are noise, cant bring it in the apt due to fumes. And can make you smell like you have been using a leaf blower all day. lol. The hub motors are very quiet. Some have internal gears that are noisy. Some are chain drive and noisy also. But the motor like Tommy has, like mine, there is a hum, but pretty quiet. Wont wake the neighbors. Or a baby. lol And the low end torque is incredible. Ya have to ride one to gain full appreciation, There is a stigma to electrics for some reason. A lot of people tend to think of the little electric cars kid ride. Like 3 to 7 mph. But once they take my bike for a spin, they seem to take a long time to come back.lol But then they are amazed and say, I would have never known till I road it. I have 3 bikes. Total miles of about 25k. Lost count. Trek has about 15k. Little walmart triax with wilderness kit about 6k mi. And the tidalforce m750 about 5kmi. I still sold.
Electric is awesome. My fiero will us a dc motor, 9in dia, 15in long.  Will beat a normal fiero all over the place. Whats really cool about electrics also is that you can exceed the typical constant power input over 10 times in spurts. So the motor I want is a Net Gain Warp9.  like 18 hp at 72v rated. But you can give it up to 300v. Figure how long do we really need to be accelerating, then we only need about 16hp to keep the vehicle at 65mph. Some vids on YT show guys with evs using this motor and its just plain sick. 72v wont get ya very fast. 40, 45 maybe.  So I want to run 144v. Just transportation. Will do 70mph or so.
Would love to build hub motors for the fiero. Gota do a lot of thinking on that one.
Mags
Post by: Magluvin on March 06, 2015, 11:29:51 PM
Oh yeah, the trailers.  Yeah that can be done. Look up bicycle trailers. They have them for kids, and other uses. Pretty simple and neat hookup to the bike. Heck, I could put enough sla batts on that to go 100mi.  LIPO probably 200 or more mi.
High Power Cycles has some expensive stuff
http://www.hi-powercycles.com/hpc-revolution-coming-soon/ (http://www.hi-powercycles.com/hpc-revolution-coming-soon/)
Up to $12,000
Revolution X 5.0-
Power- 5000W
Voltage: 90V
Top Speed: 50+MPH
Max Range (@20 MPH): 50+ Miles
RockShox Boxxer World Cup Keronite front fork 203mm travel
RockShox VIVID RC2 rear air shock- 8+" of frame travel
Schlumpf High Speed Drive (2.5X) Allows high speed pedaling past 50 MPH!
Mags
Post by: Pirate88179 on March 06, 2015, 11:30:25 PM
Quote from: Magluvin on March 06, 2015, 11:18:43 PM
Hey Bill
Mags
Well one thing I think I know about dc motors is that the torque curve is flat.  In others words, if I am saying this right, unlike a gas engine, a dc motor has all of its torque at 10 rpm as well as 3,000 rpm.  I drive an electric golf cart every day at my job.  it is very anemic and only does about 16 mph.  It will not even spin the tires on solid ice, as we have had here all week!  But, the motor controller is programmed with an acceleration curve. (I spoke to the repair guy)  He said he can hook up his laptop and increase the top speed to 27 mph.  It uses 5 large 12 volt cells. (each larger than the big battery in my van) and the charge only lasts one full 8 hour day of patrol.  I am not impressed with it at all.
But, I could get into an e bike for sure.  Around here, as long as you looked like you were pedaling and there was no exhaust noise and smoke coming from the bike you could probably pass a cop doing 50 mph and they would leave you alone.  I looked at those hub motors before building my other bike and a single hub motor would have cost me more than I paid for my bike (new) the engine, and the drive system.  Then I would have to buy the batteries and controller.
Like anything else, the price is coming down so, I will take another look at these.
Can you pm me with a link to any videos you might have of your bikes?  I can send you the one I have of my 50cc bike, which I no longer have.
Bill
Post by: Magluvin on March 07, 2015, 12:40:31 AM
Never did any vids of the bikes. Can though.  Just found my pics
Here is my first bike and the trek.  Looking for my tidalforce pics. They can be found on the net also.
Also a pic of my speed control box. Top sw is power, bottom sw switches between a preset and full power.
Mags
Post by: Pirate88179 on March 07, 2015, 03:31:59 AM
Very nice.  Nice bikes there.  I noticed the hub was on the front wheel....does that make it hard to drive?
Bill
Post by: Magluvin on March 07, 2015, 10:25:34 AM
The front wheel drive does take getting used to. But it has advantages also.
Being there is no noise of a running motor, it is always possible to hit the throttle by accident when walking the bike. With rear wheel drive, it can knock you over or jam a spiky pedal into the back of your leg, etc.  The front drive will slip, but the rear digs in when walking the bikes. Yeah yeah, just shut off the switch. lol. But it will happen.
The other thing, when riding, front drive helps navigate tight turns and zigzags. Where a rear drive can push you over if you turn too hard. Its something you have to experience. The tidalforce bike is rear dr, so I do have experience between the 2.
Mags
Post by: Magluvin on March 07, 2015, 10:39:40 AM
The Triax was my first ebike. $169 at walmart, $300 for 36v wilderness kit. The trek bike was $350 new on sale from $450 due to new models coming out, and the kit was $600, batteries and all 7 years ago.  Bags and lights extra. I recommend building your own always. For the same price, a prebuilt is usually lower quality.
Mags
Post by: TommeyLReed on March 07, 2015, 08:11:25 PM
Hi All,
Ok I just finished the A-frame for the front steering and shocks.
I decide to go all metal, it's cheaper then fiberglass.
https://www.youtube.com/watch?v=Qhz7avdFgkM
Tom
Post by: telecom on March 07, 2015, 08:36:24 PM
Looks great, what shock absorbers r u using?
Post by: TommeyLReed on March 07, 2015, 09:14:17 PM
Hi Telecom,
I have be thinking of building simple air shocks, getting a 4" water rubber hose.
Tom
Post by: telecom on March 08, 2015, 10:59:14 AM
Interesting idea - they probably will work quite well!
Post by: TommeyLReed on March 08, 2015, 05:14:16 PM
Hi All,
This is the update on the front end assy.
https://www.youtube.com/watch?v=g4BThxz6G2U
Tom
Post by: MarkE on March 08, 2015, 07:48:27 PM
It looks very solid.
Post by: TommeyLReed on March 09, 2015, 06:31:21 AM
Hi All,
Boy I get so many trolls today, no wonder I hate YouTube!
I have cancel all of my videos, I will put up the finish E-Trike in a few weeks or sooner.
I love making people eat their words, just another push to finish it ASP!
I will put up picture on this channel to show up dates.
Tom
Post by: TommeyLReed on March 09, 2015, 12:18:17 PM
HI all,
https://www.youtube.com/watch?v=1n8wM0wvBDo
I will not but too many videos up, but it will be finished in a week or two.
Waiting for parts.
Tom
Post by: ramset on March 09, 2015, 01:04:54 PM
Tom
I'm out of town ATM,just catching up when I can.
The Trolls have no idea what you're capable of.....
thx
Chet
Post by: DreamThinkBuild on March 09, 2015, 01:20:06 PM
Hi Tom,
I'm always inspired by your craftsmanship. Keep up the good work.
Ignore trolls they are worthless creatures who will never have the skill to build anything except their own self loathing.
Post by: MarkE on March 09, 2015, 01:27:20 PM
Quote from: TommeyLReed on March 09, 2015, 06:31:21 AM
Hi All,
Tom
You can make the videos private, and/or you can disable comments.  Be assured that there are a lot of people that appreciate the skill and effort you put into your projects.
Post by: TommeyLReed on March 10, 2015, 10:21:15 PM
Post by: TommeyLReed on March 10, 2015, 10:25:41 PM
Hi All,
Waiting for parts, but should be finish with the complete E-Trike frame by next week end.
Tom
Post by: TommeyLReed on March 20, 2015, 09:39:49 PM
Hi All,
I got my parts in yesterday to finish the E Trike frame.
https://www.youtube.com/watch?v=9ph-ChZpBhE
Tom
Post by: MarkE on March 21, 2015, 04:58:46 AM
It looks like it is coming along nicely.
Post by: TommeyLReed on March 21, 2015, 10:19:42 PM
Hi All,
Ok just finished the front axle and steering assy today.
https://www.youtube.com/watch?v=3cBzbbHgYKA&feature=youtu.be (https://www.youtube.com/watch?v=3cBzbbHgYKA&feature=youtu.be)
I'm also planning to install a small  700w gasoline generator to recharge the batteries when they get too low, just like a Prius system.
Tom
Post by: telecom on March 22, 2015, 06:45:14 PM
Hi,
will u be selling parts?
Post by: TommeyLReed on March 22, 2015, 10:53:39 PM
Hi All,
Boy I move fast building stuff, did another 5hr today.
Look how much is done now.
https://www.youtube.com/watch?v=uj7izhX2OoI&feature=youtu.be
Tom
Post by: MarkE on March 23, 2015, 12:43:53 AM
Nice progress.
Post by: TommeyLReed on March 23, 2015, 11:02:22 AM
Hi All,
Just finished the front shocks assy.
Ready for the seat and steering assy.
Looking for a test run this week.
https://www.youtube.com/watch?v=eRtDMyZPIqU&feature=youtu.be
Tom:-)
Post by: MarkE on March 23, 2015, 01:12:06 PM
It is definitely coming along.
Post by: TommeyLReed on March 23, 2015, 03:49:37 PM
Thanks Mark,
I just did a weight test with the wheels and hub motor.
92lb, not too bad without batteries.
Tom
Post by: MarkE on March 23, 2015, 06:41:11 PM
It looks rigid and sturdy.
Post by: Magluvin on March 23, 2015, 06:56:51 PM
Quote from: TommeyLReed on March 23, 2015, 03:49:37 PM
Thanks Mark,
Tom
Thats not bad at all 92lb.  ;D    My bike is about 70lb with batts, and its made of alum mostly. I see in the vid your going with sla batts? Did you change your mind on the big box of lipo batteries? Maybe I missed something.   If you do make lipo packs, make individual packs of the total voltage you want to use and parallel them. If you put them all in 1 pack the heat doesnt have an easy way out. Then put the packs spread out to distribute weight.  There was an electric car made by college students and they used LOTS of AA NIMH batteries distributed throughout the car. Good idea. Individual packs are easier to take apart to repl bad cells. Some do fail. ;)
Mags
Post by: TommeyLReed on March 23, 2015, 07:27:11 PM
Hi Mag,
I'm still am planning to build a lithium battery pack, I have about 400 (18650) cells.
I can test run this trike with the (4) 12v10ah batteries.
I also plan to build a small 2-stroke generator for charging when the batteries get low.
Tom
Post by: ramset on March 23, 2015, 08:05:49 PM
Tom
Really looking Like a Pro Build...The whole thing Just Looks Cool  8)
I do like the ride height your ending up with too..
Chet
Post by: Pirate88179 on March 23, 2015, 08:29:43 PM
Tommy:
The high C.G. could prove to be a bit unstable at speeds over 120 mph.  (Just kidding)
No one can say that is not a very strong build.  I really like the way the front end has come together with the addition of those shocks.  I can't wait to see a road test of this baby.  I also like the way that you have designed in flexibility for batteries of different types and your generator.
I wish you the best with this, it is going to be great.
Bill
Post by: TommeyLReed on March 24, 2015, 11:44:43 PM
Hi All,
I got a old bicycle from the junk yard today for parts.
This is a update:
https://www.youtube.com/watch?v=ftx78bS0FFc&feature=youtu.be
Tom
Post by: TommeyLReed on March 30, 2015, 12:25:52 PM
Hi all,
Just about ready for a test run.
https://www.youtube.com/watch?v=iufm4XwMbG4
Tom
Post by: ramset on March 30, 2015, 02:27:50 PM
Tom
I could not cover that with a body...its turning into a real piece of Art !!
I would Paint it some super bright color ,  very nice bends too..
Sweet !!
Post by: TommeyLReed on March 30, 2015, 08:13:13 PM
Hi All,
Looks like I will be doing a test run tomorrow....
Finished the seat today.
https://www.youtube.com/watch?v=uUlz9MhENJM&feature=youtu.be
Tom
Post by: telecom on March 30, 2015, 08:40:09 PM
I really like the "pedal by wire" idea!
Best regards.
Post by: ramset on March 30, 2015, 09:39:20 PM
geeZZe I agree with Telecom..
Tom That is a cool idea ..... 8)
Post by: TommeyLReed on March 31, 2015, 05:23:23 PM
Hi All,
Ok I did a simple test run today.
Problems with the lead acid batteries, but it works great.
https://www.youtube.com/watch?v=l6qGwabXyJc&feature=youtu.be
Tom
Post by: telecom on March 31, 2015, 07:16:29 PM
It runs really great and solid.
How did the sharp turn go, was the bike tilting to the side?
Post by: TommeyLReed on March 31, 2015, 07:25:21 PM
Hi Telcom,
I was able to solve the battery problems, this is a better view of the E-Trike speed.
I even fell in the snow going snow triking.
https://www.youtube.com/watch?v=naH3V2lgXKg
Tom
Post by: ramset on March 31, 2015, 09:12:11 PM
Tom
MUCH better view ,you can really see the height of the whole rig, very impressive stance  .
It really seems like it could do 50 MPH  :o
I keep thinking about your Pedal By wire idea ,very very cool stuff.
thx for sharing
Chet
Post by: TommeyLReed on April 01, 2015, 06:54:52 AM
Thanks Ramset,
I got a 2kw low rpm stepper motor just for this peddle power flux capacitor reactor, even Scotty would like this design...lol
I will test it very soon to power a 500w light bulb....
Tom
Post by: TommeyLReed on April 01, 2015, 11:46:53 AM
Hi All,
This is a test using a stepper motor to generate power from peddling.
https://www.youtube.com/watch?v=SeOdRlGoc18
Tom
Post by: telecom on April 01, 2015, 12:34:01 PM
Quote from: TommeyLReed on March 31, 2015, 07:25:21 PM
Hi Telcom,
Tom
Terrific,
I want to have one!
I like the idea of having  battery under the seat - makes it more stable.
regards
Post by: TommeyLReed on April 02, 2015, 08:24:35 AM
Hi All,
Working on the 2-stroke gasoline generator recharging system using a 400w 24v x 2 dc motor.
Also I am building a low rpm hub motor for peddle power.
https://www.youtube.com/watch?v=Lr0WTqO9E_I
Tom
Post by: Magluvin on April 02, 2015, 01:21:44 PM
Quote from: TommeyLReed on April 01, 2015, 11:46:53 AM
Hi All,
https://www.youtube.com/watch?v=SeOdRlGoc18 (https://www.youtube.com/watch?v=SeOdRlGoc18)
Tom
Hey Tommy
Lookin good. ;)
2 things
A good bicyclist can put out something above 100w.
My Tidalforce bike used circuitry for regen that sent charge to only portions of the 30 d cell series pack. This way ebraking has more effect. Or in your case, make a relay circuit that switches through the batteries sequentially.
For example. Any dc or pwm driven motor/generator, just like a pulse motor, if it is free wheeling at top speed, then if you were able to physically turn the motor faster by another means while the motor is at top speed, you will get to a point that the motor no longer consumes from the source, and turn the motor faster and it can send charge back to the source. Like Lasersabers 3d printed motor. Great example. So my tidalforce is pulling x amount of current at 36v at 20mph. But if they had set it up to send power from the hub back to the whole bat pack at the same time, the motor would not have above 36v coming out unless the motor were spinning at a rate of 25 to 30mph possibly more. So since the output voltage from the motor is less than the input at the same rpm then it cannot charge the source as a whole. So send it to individual batteries in sequence instead of trying to generate the full pack voltage. Like if you put a smaller motor lower power motor on the output demo in the vid, the motor would be in overdrive instead of just moderate running..  So charging the batts individually, they will get more charge from the work. ;)
Also think about a geared settup and/or with a flywheel on the pedal charge.
Mags
Post by: TommeyLReed on April 02, 2015, 02:35:03 PM
Hi Magluvin,
Yes I agree.
I have a different design using regen breaking.
As the regenerated breaking occur, this energy is stored in a super capacitor bank. The micro controller will do slow charge on the  battery bank 1 while the other is being used. So you have two battery bank to run the trike, but only one is being used while the other is fully charge or being charged.
I design a system last summer that will scan each 12v battery up to 10 cells that will charge in a cycle, so 48 v is only 4 cells when using 12v batteries.
Tom
Post by: TommeyLReed on April 05, 2015, 08:52:14 AM
Hi All,
Waiting for parts for the generator system, but started on a 2kwh+ battery bank.
https://www.youtube.com/watch?v=5dNmV3y4Ys8
Tom
Post by: TommeyLReed on April 07, 2015, 12:16:21 PM
hi All,
This is the battery bank set up.
2 sets of 48v@24ah battery banks.
https://www.youtube.com/watch?v=m14Vf2IAPpQ
Tom
Post by: ramset on April 07, 2015, 12:59:23 PM
Tom
Your pioneering new ground... recycling / repurposing [green word]
batteries to help make our world a better place.
what a project [battery repurposing]
That seems a whole cottage industry in itself, to be clear NOT a job for the inexperienced.
Chet K
Post by: TommeyLReed on April 09, 2015, 09:51:07 AM
Hi All,
I have been busy working, but this is my battery design with built in 4a fuse for each cell.
https://www.youtube.com/watch?v=1wCNHMnNcsI
Tom
Post by: TommeyLReed on April 10, 2015, 08:23:58 PM
Hi All,
Looking for bicycle fenders, but they are too high so I did a experiment with pvc tube and this is how this fender looks.
https://www.youtube.com/watch?v=LJa0mMspAdY
Tom
Post by: ramset on April 10, 2015, 08:32:41 PM
Tommey
How many times to get it looking that good ?
And it does look Good !!
Post by: TommeyLReed on April 10, 2015, 08:46:36 PM
Hi Chet,
This was the first time, using the rim of a bicycle.
Tom
Post by: markdansie on April 11, 2015, 01:31:18 AM
Love this project as I do all your adventures.
Published a story on it.
http://revolution-green.com/tommey-reeds-e-trike/
Kind Regards
Mark
Post by: TommeyLReed on April 11, 2015, 07:45:13 AM
Thanks Mark,
Great write up....
Tom.
Post by: TommeyLReed on April 12, 2015, 09:55:35 AM
Hi All,
I wanted to do a better way to make Fenders or even bend PVC, this is by far a simple way to make any design using a heat gun.
https://www.youtube.com/watch?v=vB8LHxXeJyY
Tom
Post by: TommeyLReed on April 12, 2015, 02:59:21 PM
Hi All,
This is the update on the E-Trike and how the recharging system will work.
https://www.youtube.com/watch?v=QXlQFd42Yws
Tom
Post by: ramset on April 12, 2015, 03:46:21 PM
Tommey
Wait till Revolution Green gets wind of your color choice
Maybe you should ask Mr.Dansie to Sponsor A REVOLUTION GREEN Paint job??
Those fenders Just POP  :o ...gotta do the Back one too.
Love your Poly oven  .
Post by: TommeyLReed on May 26, 2015, 05:07:47 AM
Hi All,
Been really busy with work and other stuff.
This is a update on the E-Trike test run I did yesterday.
https://www.youtube.com/watch?v=kmcN8BtLPTA
Tom.
Post by: MarkE on May 26, 2015, 10:58:42 AM
That's really nice work.
Is the motor a pulse motor???
Post by: TommeyLReed on May 26, 2015, 12:17:49 PM
Hi Mark,
Its a 3 phase 1000w hub motor, not the best choice due to load climbing hills.
I have a 1000w DC motor that would work better but added chain and gearing would increase weight.
Tom
Post by: Magluvin on May 26, 2015, 06:00:11 PM
Quote from: TommeyLReed on May 26, 2015, 12:17:49 PM
Hi Mark,
Tom
hey Tommy
What voltage system are you running on that motor/controller? 36v? or 48v?
Some of these controllers are multi voltage. Not sure how they determine shutdown when batts are low when going from one voltage level to another.  But I would think that a 1000w, even with the weight you are claiming, should climb hills quite good. My 500w, shown below, can maintain 15mph on its own up a fairly steep grade. 25mph max. Bike is about 75lb and Im 220.   So im just wondering if the trike is actually putting 1000w into the motor, or can it be that it needs more voltage input to do so.  Some are 72v and more.
The pic below I just took last night. Replaced a bad hall sensor.  Also repl another so all are the same. Had 1 go bad before. Replaced it. This time the one I already replaced is still good, so the originals just aint worth a crap.  Dont know why they would go bad.  Too much flux?  Maybe bad supply voltage to the halls.  Too much.  But seems ok. Could be a once in a while blip.
Mags
Post by: TommeyLReed on May 26, 2015, 07:53:27 PM
Hi mags,
I'm using a 48v battery bank, but my 12 cells of lithium battery is only about 44v, I will need to add one more cell bank to get the 48v.
Lead acid will really push this trike over 30mph, I don't know how many amps I'm pulling yet.
Still have to add the meters and speedometer to get a better reading.
Tom
Post by: Magluvin on May 26, 2015, 09:38:30 PM
Quote from: TommeyLReed on May 26, 2015, 07:53:27 PM
Hi mags,
Tom
I use a WattsUp meter inline. Gives voltage, amps whats real time and AH and WH .  100Apeak 60v max, I think. Never had it that high, but you can look up specs if you like.  Use anderson connectors. Great connectors.
Mags
Post by: Magluvin on May 27, 2015, 12:09:53 PM
Quote from: Magluvin on May 26, 2015, 09:38:30 PM
Mags
"Gives voltage, amps whats real time"   Whats is suppose to be watts. ::) ;D   Watts uP wit dat? ;D
Mags
Post by: Magluvin on May 27, 2015, 12:12:16 PM
Again, watts uP wit dat?  lol  just me.
Pic I forgot to upload.
Mags
Post by: TommeyLReed on May 30, 2015, 08:57:32 AM
Hi All,
Ok just finished front disc brakes system.
https://www.youtube.com/watch?v=5nqhYiqJk6Y
Tom
Post by: TommeyLReed on June 03, 2015, 06:56:42 PM
Hi All,
The E-Trike works so good that I painted it today.
This is called the Cheetah E-Trike.
https://www.youtube.com/watch?v=29oT7r23wX0
Tom
Post by: MarkE on June 04, 2015, 02:56:06 AM
Quote from: TommeyLReed on June 03, 2015, 06:56:42 PM
Hi All,
Tom
Parallel recharging is the best, as is parallel discharging provided that you have independent charge management for each battery.  The downside is that it is expensive.
Your project is looking great.
Post by: TommeyLReed on June 04, 2015, 06:59:34 AM
Thanks Mark,
This is a special mechanical switch I'm working on for recharging and regenerate braking.
Two version I designed.
This will work off the brake cable, being mechanical will keep it cheap and simple.
I do have a electronics version with H-Bridge design, but it would need delay timing for each battery. So a simple micro controller would be needed to switch each battery in a simple  order.
My other thought is to add a 12v ac inverter to convert 120v ac bring it down to 48v dc.
This just might be something that would be easy on the battery bank and keep all of then in series.
Two golf cart battery would work great for this project then.
Post by: markdansie on June 05, 2015, 02:05:04 AM
We updated your story
I am a huge fan and want one of those for the Philippines
Mark
Post by: TommeyLReed on June 07, 2015, 09:46:59 AM
Thanks Mark,
This is the added hybrid E-Trike to recharge the batteries and travel like a Pruis.
https://www.youtube.com/watch?v=3rWP3eLKsy8
Tom
Post by: TommeyLReed on June 08, 2015, 09:20:25 PM
Hi All,
Did a test run with the hybrid system running and got 15 miles at 20mph on 10oz of gasoline.
The small 2-stroke engine is a 25cc and about 1hp with a 48v10a@3000 rpm to drive the E-Bike.
Comes out to be about 192mpg.
https://www.youtube.com/watch?v=K3Dokuj2FNQ (https://www.youtube.com/watch?v=K3Dokuj2FNQ)
Tom
Post by: Spirit on June 09, 2015, 12:50:08 AM
TommeyLReed I think it would be great too if you add an ultrasonic gasoline vaporizer to your motor.
see youtube search:  https://www.youtube.com/results?search_query=ultrasonic+gasoline+vaporizer
Post by: TommeyLReed on June 09, 2015, 06:17:37 AM
Hi Spirit,
If I was using a 4-stroke engine then that would be a great idea, but this is a 2-stroke that need mixed oil/gas.
If I use a vapor carb on this engine, it would last just a few minutes before it burns up the rings and lock up to be thrown away.
Tom
Post by: SkyWatcher123 on June 09, 2015, 05:16:09 PM
Hi tommy, awesome job on your tadpole trike.
My suggestion for another thing to add, fully enclosed fairing, taking into consideration the engine noise and exhaust with fairing.
This way you could attach solar panels to it and be protected from rain and cold.
peace love light
Post by: TommeyLReed on February 09, 2016, 08:02:37 AM
Hi all,
Update on this great build.
https://www.youtube.com/watch?v=mJhK2MUyomQ
Tom
