Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: Gabriele on May 30, 2015, 01:13:03 PM
Title: Capillarity engine?
Post by: Gabriele on May 30, 2015, 01:13:03 PM
Hello.After Glass sheets are submerged we separe them and restart the cycle. What do you think? Someone with metods to calcolate energy obtained and spent?
Title: Re: Capillarity engine?
Post by: Gabriele on May 30, 2015, 02:01:15 PM
Should be possible. Cause we don't are using gravity but magnetic fields,and as you know m.f. is a non-conservative field.
P.S. Green field is to improve intelligence,as you know
Post by: Gabriele on May 30, 2015, 02:22:11 PM
Sorry if i answer myself alone,but sometimes appens. :o Whut do you think? I computated and energy gained in 0.2g x 100cm(with glasses of 1cm x 1cm x 100cm) and an energy used to separate in 50g x 0.1 cm
Post by: Gabriele on May 31, 2015, 07:23:59 PM
I need two or three milions dollars to share you a gravity engine,not magnetic or omopolar,but gravity. I'm going to build one with s********** tomorrow, i don't know. Need only a glass ring,some s********** and water. I hope not a perpetual motor. In septembar im goiung to iscribe myself in an university cours, i dont know,phisycs,psichiatria,hell... to became a doc. ...ui
Post by: Gabriele on May 31, 2015, 07:32:14 PM
Or if you sell me a green card i can came to USA and study fate. I have some methods like others to feel better in situations caos describe cats or watermelons but not bananaS cause worst enemy of a scientist is : orange juice,sweet dreams of marilyn manson and another thing called often mer or england. But i know and i understand i'm happy very often and strong like belgium beers. Hello!
Post by: Gabriele on June 01, 2015, 05:32:59 AM
Sorry,fake
Post by: Low-Q on June 02, 2015, 06:11:24 AM
Quote from: Gabriele on May 30, 2015, 01:13:03 PM
The calculus is simple: Energy spent - energy out = 0
The capillary effect does not behave as WE want it to, but how the NATURE want it to. So this effect applies in both ends of a capillary tube or plates, and does not work in only one direction.
Using magnetism does not change anything.
Vidar
Post by: RomanEmpire on June 02, 2015, 11:46:35 AM
This could help, not perfectly in theme, but I think it can be an inspiration
https://www.youtube.com/watch?v=JXKM6D9rPis
Post by: Gabriele on June 02, 2015, 01:20:40 PM
If you want i'm onest,i didn't calculated with precision the energy needed to separate glass walls. I'm sure if we have the situation rappresented in first picture(not me :p) we have to admit vertical forces are different for each situation. Understand that we don't have ties between two glass walls with anti-adeshive surface,i supponce underwater we can put the two very thin glasses in orizzontal situation near surface and win to separate them only a very little force. With 2, 1cmx1cmx100cm glasses we obtain 0,2gx100cm and at a deep of 1mm to separate them for an half of centimeter 0,1g x100cmx distance (0,5). I remember you that when we separate the two plates water run inside generating energy. And we can also add surfactants to amplify the force will act on two glass objects.
