Overunity.com Archives
Energy from Natural Resources => Heat to mechanical energy conversion => Topic started by: TommeyLReed on December 03, 2015, 09:32:16 AM
Title: Building a jet engine for under $100.00
Post by: TommeyLReed on December 03, 2015, 09:32:16 AM
Hi All,
I been working on lots of projects these past weeks, and added this jet engine to it.
My goal is to build a mini jet engine for testing different fuels for under $100.00.
Also I want to put it on my E-Bike to wake people up....lol
I also have a theory of using plasma in the jet  engine combustion chamber to see if it's able to run without any other fuels. Due to the fact it's heat that drives the jet engine, why not try plasma?
https://www.youtube.com/watch?v=WdCmPgClnG8
Tom
Title: Re: Building a jet engine for under $100.00
Post by: truesearch on December 03, 2015, 10:52:48 AM
Tom:
Are you planning to share your build progress and plans here on this forum? I'd be interested in watching (and dreaming  :)  ).
truesearch
Post by: TommeyLReed on December 03, 2015, 11:29:52 AM
Hi Truesearch,
Yes I do plan to put up videos on this jet engine build, I just added another one.
https://www.youtube.com/watch?v=fDtSTfVet1k
Tom
Post by: Nink on December 03, 2015, 11:38:40 AM
$100 would be good  US $2,349.98
http://www.ebay.ca/itm/Spark-T12-12kg-Turbine-Fully-Auto-Kero-Start-Jetlegend-RC-Jets-Engine-T-12-/140959598158?hash=item20d1d8c64e:g:2pUAAOSw~OdVf9pp
Post by: lancaIV on December 03, 2015, 02:56:12 PM
low-budget  solutions ? http://www.vortechonline.com/jets/
Post by: TommeyLReed on December 03, 2015, 03:45:16 PM
Hi LancaIV,
Interesting link, but for $100.00 I will try to build this jet engine with 50lb of thrust. The key is combustion chamber design and compress air pressure.
Tom
Post by: Paul-R on December 04, 2015, 10:09:33 AM
Quote from: TommeyLReed on December 03, 2015, 09:32:16 AM
When I was doing Mech Eng back in the 60s, my recollections of the theory of aerodynamics suggest to me that you have taken on the mother of all projects if you want to achieve any level of efficiency at all.
But I wish you well and will follow your progress.
Post by: TommeyLReed on December 04, 2015, 10:39:58 AM
Hi Paul-R,
Thanks you, many people don't realize just how simple things can be and yes it can be hard for many today to build a jet engine, but I'm in that group..
People are programmed into thinking it takes money and lots of formulas to build even the most simple project, I don't agree with any of them.
Formulas of aerodynamics can only go so far and yet many prototypes based on calculations fail due to the fact too many numbers just can't be calculated that ever adds up.
The key to any engine running on fuels is compression this includes jet engines.
I have no problem getting this jet engine to run, I also have more advanced ideas to increase fuel efficiency.
Thanks for your comments.
Tom
Post by: Paul-R on December 05, 2015, 09:39:07 AM
Quote from: TommeyLReed on December 03, 2015, 03:45:16 PM
~Yes, and the angles of the compressor turbine blades as you go from root to tip, and for each disc stage.
i.e. the angle the air flows out of one stage must be the same as the angle it flows into the next stage, bearing in mind the adding of the speed of the rotor and the speed of the air.
You've no problems if you are happy with really crap fuel/power performance.
Post by: TommeyLReed on December 07, 2015, 04:53:36 PM
Hi All,
I been busy with work but I'm working on the diffuser for impeller and will be making a simple sand casting with scrap aluminum and mill it to my specs.
By the way I'm only $20 in this build with scrap and parts.
I should have the impeller diffuser done very soon.
https://www.youtube.com/watch?v=N2gJp4QLC8g
Tom
Post by: TommeyLReed on December 13, 2015, 01:57:23 PM
Hello all,
I been working on the diffuser today and just about finished.
https://www.youtube.com/watch?v=YZadIgo_360
Tom
