ultra-battery-one kilogram weight-decades of driving-without charging Weight reduction- no engine, gearbox, no fuel, oil, just car body and el. motors .Did you know that scientist made battery (picture in middle) from uranium? And did you know that 7g of uranium is powering 3 millions of houses a day?And did you know that scientist made most powerful non nuclear energy material by pressing XeF2 by 100000 atmospheres, which is near of uranium on power basis? My idea is to replace XeF2 instead of uranium, and keep the princip how the energy is converting to electricity flow. Imagine one kilo of this battery and car is running for decades, also could be used in homes energy supply etc. Is the most powerful portable non-nuclear energy storage ever, The battery is made of Xenon difluoride (XeF2), a white crystal that's been placed in a diamond anvil cell. Pressure is able to reach a million atmospheres and when this happens, 3D metallic networks structures are formed. The formation causes compression and stores its power as chemical energy, generating a huge amount of it. Is the most condensed form of energy storage outside of nuclear energy .We'll see this technology used in super-oxidizing materials that can destroy chemical and biological agents, not to mention new fuels and, most obviously, an energy storage device,superconductors.I personally giving to this battery promised future or the idea which will press materials and use their energy from their deformed structures ,like personal electricity plant,its possible to regulate battery power as newly created nuclear battery in picture below,which works.Nuclear battery works like this:when high-energy beta radiation passes through the platinum and the nanoporous titanium dioxide, electron-hole pairs are produced within the titanium dioxide, creating an electron flow and a resultant electric current.The ionic solution is not easily frozen at very low temperatures and could work in a wide variety of applications including car batteries and, if packaged properly, perhaps spacecraft."radiation can be converted into electricity.So much so, that the water-based nuclear battery may well offer a viable alternative to the solar cell as a sustainable, lowpollution energy source.This principe could by transformed also for XeF2 and we can regulate that power.Comparing to uranium-Before being used to produce electricity, Uranium is extracted and then transformed into cylindrical 7g blocks, which will then be grouped together into tubes that will in turn be assembled into clusters and then installed in nuclear reactors. Uranium is the most energetic material known on earth: a 7g block of enriched uranium provides as much energy as 1 tonne of petrol or 1.5 tonnes of coal. A power station supplying a city of 3 million inhabitants only uses 3 kilos of Uranium a day.So one small battery with 7grams of XeF2 calculating with almost or i the same specification as uranium will replace one ton of petrol?50 kilos of petrol each fueling ,so it is one ton 1000/50=20 fueling times of car(around 700km per fuel tank x20 =14 000 km per one small battery(I do 14 000 km per year and I spent for fuel 1200 euro minimum a year) so if one kilo battery (1000gram /7 g= 142 years of driving)if even half energy of uranium,we can still drive 71 years,I couldnt find information how much power is truly from pressed FeX2 if is comparable to nuclear energy as scientist says than we can have product like battery as we now today almost everlasting for everyone. Safety-must be made lots of car crashes scenarios to keep passengers protected(car falling to water, burning contacts, possible battery damage etc)and how to switch battery off safely and quickly. If regulated and covered properly, safety will exceed current safety standards.
You need lots of energy to compress 1kg of that material by 100 000 atmospheres. Probably more than the number of charges needed to run a Tesla car in all its lifetime.
"You need lots of energy to compress 1kg of that
material by 100 000 atmospheres."
Lots of vice
Quote from: profitis on November 07, 2017, 07:13:37 AM
Lots of vice
There is a cable TV channel for that. http://www.viceland.com/ (http://www.viceland.com/)
All the vice you could ever want. (and lots of pot-heads)
(Sorry, I couldn't resist!)
XeF
2 is seriously evil. The decomposition products are xenon and fluorine gas.
Elemental fluorine tends to destroy everything it touches. It will even dissolve glass.
Exposure to fluoride compounds supposedly makes one subservient to the New World
Order, as well as causing bone problems.
"Exposure to fluoride compounds supposedly makes
one subservient to the New...World
Order, as well as causing bone problems."
Ur right it does
