The Kapanadze Team has again published a new Video showing his "Aquarium-type" Generator that seems
to power a few KWatts of loads only needing a ground line and a start pulse from a 9 Volt Battery.
Here is the latest Video.
What do you think ?
Has he hidden there inside the Aquarium-box a few big Lithium Batteries or is this technology for real ??
https://www.youtube.com/watch?v=lHLydOHRfB0
Regards, Stefan.
Not saying it isn't real. Just saying that April 1 isn't the best date to release a new energy video.
Stefan:
I can't watch the video because I am at work but will view it when I get home. Thanks for finding and posting this. I did not know he was still around showing his device anywhere.
Bill
I think a) for real and b):
One more Kapanadze riddle solved (thanks to verpies (http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg478965/#msg478965))
Ever wondered why in the Kapanadze 2004 video they needed more than one attempt to switch on the lamps? Did Kapanadze use a switch with a loose or bad contact? Rather unlikely, I guess.
At 17:36 SWITCH ON (https://youtu.be/r99g4mjEvTE?t=17m32s)
At 20:45 SWITCH ON (https://youtu.be/r99g4mjEvTE?t=20m40s)
At 24:05 SWITCH ON (https://youtu.be/r99g4mjEvTE?t=24m02s)
And - astonishingly enough - here they needed more than one attempt in order to switch the lamps OFF!
At 18:37 SWITCH OFF (https://youtu.be/r99g4mjEvTE?t=18m33s)
What could be the cause of this strange behavior?
Below there is a snippet taken from ECT190, Cahier Technique, Ferroresonance (http://www.schneider-electric.com/ww/en/download/document/ECT190), it says »switching operations on the power system [...] can initiate the phenomenon by driving into saturation the iron core of one or two of the VTs of the parallel ferroresonant circuit [...]«.
One of the keywords here is »can«. It does not have to - but it can.
Hence, could that mean that one single switch on that Kapanadze device can drive the transformer hidden in the round box (http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/155715/) into saturation but it could happen that more than one tries are needed to get it into ferroresonance? Here one and the same switch either initiates the state of ferroresonance or it disrupts it?
Interesting. Then how to get a transformer out of that state of ferroresonance? The simplest method, I guess, would be to disconnect something within the device. But a single switch can't do that directly. So this would mean the better solution is to have two switches. And what do we see on the improved green box device? We see two switches!
One step closer to the ultimate solution. :)
Quote from: Zeitmaschine on April 01, 2016, 06:40:29 PM
The second switch is IMO most likely used to cut the holding circuit for the latching relay, operated by the start-up battery.
Nothing new.
Another simple case of driven series resonance. With "ferro" it doesn't make it more mysterious.
In a high school you can learn that resonance in electrical circuits leads to infinite ( in theory) voltages and currents.
Therm "ferroresonance" energed mainly from power distribution systems when at certain situation inductance of transformer primary in series with capacitance caused by long underground cables forms a series resonant LC circuit.
The point is: how to grab that currents and voltages without disturbing resonance.
And this is a Tesla way.
I know also another way,but I will keep it to myself for a moment :)
Quote from: pix on April 04, 2016, 01:52:03 PM
Nothing new.
The new part here is the explanation for that odd switching method in the 2004 video.
The ferroresonance paper says, closing or opening a circuit-breaker CAN lead to the occurrence of ferroresonance. It depends on the exact switching timing in respect of the current state of the magnetic field.
Furthermore the paper says ferroresonance latches into a stable state of resonance independent of precise parameter values (non-linear resonant). Kapanadze's output of energy does look stable indeed without disturbing the resonance.
But maybe one has a better explanation for that multiple toggling in that 2004 video?
In the meantime (how long that moment ever might be) we should not forget that high voltage pulses and ionization is also involved in that state of ferroresonance.
Kapanadze said (or said not) it is »resonance in resonance«. Since the energy always flows from higher frequency to lower frequency, the high voltage circuit (where the free energy is supposed to be hidden) is the first resonance at 100Hz and the output circuit is the second resonance at 50Hz. And that whole thing has to work with an ordinary three-phase transformer connected the wrong way round by means of a frequency doubler.
That's the theory.
Quote from: Zeitmaschine on April 04, 2016, 06:15:43 PM
Ferroresonance occurs on the primary side of distribution transformers, when secondary is open or at very low load.
To overcome ferroresonance to occur- typically is adding some load ( resistor) on the secondary.
Load on the secondary kills ferroresonance.
And here they are,still churning out youtube video's,instead of basking in the sun on a beach in the Bahama's.
Unlimited free energy,but the millions or !death! has not found them yet :D
Brad
How do you know I'm not on the Bahamas right now? :(
But anyway, why connecting a load to the secondary coil?
cosmoLV (http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg312925/#msg312925): »Also output transformer is not transformer but choke where High voltage are producing light ionisation second "inductor" produces light magnetic field«
Neither do we need transformation of voltage (220V in and out), nor do we need a galvanically isolated secondary coil. What we do need is ionization and a magnetic field.
One more coincidence please ...
Watch and listen closely: When that guy tries to make the meter running backwards (https://www.youtube.com/watch?v=jcPKz7uEq-8) with his arc welder he needs seemingly more than one try.
Like Kapanadze needs more than one try to switch his lamps.
That might be something worth exploring.
Ferroresonance is a ephemeral phenomenon, but it does happen sometimes.
It really does happen ...and when it does it often blows up transformers.
IMO the first step is to reliably detect when a transformer has entered a ferroresonance ...without a blast shield preferably.
Quote from: verpies on April 19, 2016, 09:56:49 PM
Dear Verpies.
Is ferroresonance mechanical in nature?
I'm interested because before the days of AC and eddy currents most cores were made from bundles of soft Iron rods/wires and the Copper wires were Silk insulated. All very different to our modern methods.
Cheers Grum.
What could happen when we disobey that safety warning?
Maybe it should read: Doing so will bring welder output in resonance to ground, which makes free energy a serious possibility. Free energy means DEATH for all energy companies. ;D
Quote from: Grumage on April 20, 2016, 06:39:54 AM
Dear Verpies.
Cheers Grum.
Ah! radio Luxembourg on a radio that looked like church doors ! ;) most of them ran off DC back then.
Dear Verpies.
Cheers Grum.
its driving the coil wound on a ferrox core till it resonated but as it's a solid ceramic device it can explode like a resonating glass, becomes unstable, so it's mechanical I suppose.
If you want to find that frequency get a MOSFET and driver feed it with a VFO and monitor it on a scope it will make a hell of noise, the one we tried did. have fun. (it sounds like a pig squealing) poor thing.
AG
Stage Show
I watched the video and made some simple observations, draw your own conclusions to my version of events. Regards Arto.
Fools Paradise
- The Jug base is already plugged into the power strip and never gets moved.
- Kap's assistant keeps you focused on the earth lead and connection
- He then shows no current in the earth lead
- He puts his tongue on it to prove it has no power.
- This keeps your attention on the Box.
- The drama is now focused on the 9 volt battery
- The battery toggles a latching relay (Magnetic Latching Relay)
- He fills the jug with water and shows you the lights and its back
- Now he shows he has 14.8 amps coming from the Box
- They pick up the unit and the table proving no extra wires
- They switch the fan and heater on/off to prove it is connected
- Then a focus on the wires to the box
- Kap then explains in pseudo-technical terms about the Box
- He switches it off, the latching relay is now reset via an internal 9v battery
- Now the unit is OFF
Quote from: Artoj on April 20, 2016, 10:28:55 PM
Stage Show
My conclusion: How does Kapanadze manage that ALL observers in ALL his presentations a) if they independent, do not find the deception b) if they on the inside, do not come up with how the trickery was made?
Regarding the width of the page due to oversize images ::)
Firefox > Stylish plugin:
@-moz-document domain("overunity.com"){.attachments,.post{width:805px!important;overflow:auto;}}
Stage Show
Fools Paradise
Yep, so simple you'll laugh. :)
Did he move the heater and the fan to show there is no wires going to them ? If any of the appliances had power wires to any
of them it could power the entire show.
Its assumed that everybody that goes to a demo of Tariel is a fool.
If you assume this you live in a dream world where only you know anything.
There has never been any person saying Tariels stuff is fake other that skeptics saying he could have
done things to fake it.The complain is he cheated me ,didn't give anything,how many
other demos has he done that were not recorded.Hes done this over a long period of time
yet no one has ever come forward and said I have proof that its fake.
he should have had all the appliances unplugged, also the light,he should have had a short connection
from the box to the plug in receptacle.He should have moved every appliance from near the wall
and plugged them in one at a time.He should have shown an oscilloscope picture of the ac output
if its a modified output its locally generated,if a sine wave a possible hidden wire.
People forget the real purpose of Tariels demo's is to lure in an investor,using hes greed against him
make them believe that there going to go in business with Tariel in making these devices,remember the aquarium 2 team.
Tariels purpose is get the money for a demo then tell the investor to fuck off,and move to
the next victim and give them nothing.Is the device real,it depends on whither you believe a glass of water is half full or half empty.
If its real it can not work on principles taught in college,this is why the giant
brains that lost the ability to wear hats have no advantage,they tend to see the
trees not the forest.There is no way that this device device turns on with a 9v heavy battery
if you look at a past video,it takes a lot of current at 220v to start the device.
I would guess there's a big 12v battery hidden activated by a relay,the relay activates by 9v battery.Once the device starts its in a looped
mode,it doesn't need the 12v battery or the relay.I have done 2 hardware simulations,one electronic the other electro-mechanical
as long as you supply energy they will loop,this allows one to understand the behavior,since the difference is one you supply energy the other is energy by supplied by the device.
All of Tariels devices appear to be 50HZ,220vac,there is far too much Tesla hero-worship going on.
C'mon man. He had many years to master this device. It is just a matter of frequency and voltage step up to run it from 12V car battery or 9V 200mAh small battery in full closed loop. It probably require just to charge the buffer capacitor enough.
Quote from: a.king21 on April 22, 2016, 02:52:14 AM
Arto: did you know that Kapanadze has 2 patent applications?
Did you know he outlines the principle?
You should read the patents before you make foolish comments.
All you are doing is misleading people.
Who do you work for??
Unless Kapanadze is prepared to video a demonstration that at least shows all device peripheries moved from their initial positions and earth wires disconnected for close-up inspection, then he is simply inviting justified criticism and suspicion. Any comments about the modus-operandi of the device are justified in this situation, irrespective of what patents show.
He has done so already. He has all device peripheries moved from their initial positions and earth wires disconnected for close-up inspection in the green box video (http://www.hvlabs.hu/zpe/Gruz/free-energy.geo.avi). Just remaining the far-fetched possibility that the earth wire is secretly stitched together of two different types of wires (none of the spectators became aware of) in order to connect a hidden hot wire.
Here (for the records) the two TK patents which so far the brightest minds cannot comprehend:
WO2008103129A1 (http://www.sumobrain.com/patents/wipo/Independent-energy-device/WO2008103129A1.pdf)
WO2008103130A1 (http://www.sumobrain.com/patents/wipo/Energy-transformer/WO2008103130A1.pdf)
Maybe knowing that the Stepanov device (https://youtu.be/O3O2JahD67o?t=10m) uses a frequency doubler circuit (see illustration below) helps to understand part of the TK patents. And I don't think that the stuff under Stepanov's cardboard box is some sort of a decoy only. Because it's hidden in a way that it took me two years to figure out the function of those diodes, capacitors and that (barely visible) resistor.
Quote from: Zeitmaschine on April 22, 2016, 08:15:16 AM
But not with his latest 2016 video, which is what is under discussion, or with the Aqua2 earth - video evidence for disconnection of braided earth. Its not a far fetched possibly that the green box device cables were 'stitched', its more than likely IMO.
You are showing a power supply into the frequency doubler. What type of power supply is this?
All TK videos are under discussion. And mixing it up with Stepanov videos shall be no mistake too.
The definition of »far-fetched« and »likely«:
Bury a hot wire under the lawn. Attach an invisible connector to its end. Also attach a connector to the bearded man's sole of his shoe. Route a hot wire through his trouser leg and through his shirtsleeve. Connect this hot wire to the device by means of a fake piece of ground wire. Use a piece of ground wire that is multipolar in contrast to the unipolar ground wire connected to the faucet without looking different.
And of course, muzzle that weird wired man.
AC sine wave, I guess?
Quote from: Zeitmaschine on April 22, 2016, 09:50:14 AM
At what frequency and where from do you think?
Kapanadze 2004 device = Stepanov cardboard box device
In each case frequency is 50Hz via sine inverter and 12V car battery. As we can see below, both devices are build upon the same components, but slightly different in design. Stepanov's transformer is hidden behind the big diodes, Kapanadze's transformer is hidden in the Sadolin tin can. Stepanov uses four big diodes, Kapanadze uses four small ones. Stepanov connects two small capacitors together, Kapanadze runs his device with one big capacitor. Stepanov shows us a power resistor on a heat sink, Kapanadze shows us two components on two heat sinks most likely working as resistor(s).
Problem remaining: How to connect those hidden transformers to those visible frequency doublers the right way?
Quote from: Zeitmaschine on April 22, 2016, 12:15:29 PM
Indeed! The fundamental problem: How to loop-back, so the battery and inverter can be removed as we see in Kapanadze's green box video.
If surplus energy arrives looping back should be a minor problem. 8)
One more comparison:
Left hand side, the resonant LC circuit works in 3-phase mode, right hand side the resonant LC circuit works in 1-phase mode. Left hand side the L is a choke, right hand side the L is a transformer (don't know to which extent that matters). The transformer in the background on the left hand side should have its smaller equivalent in the tin can on the right hand side.
Hoppy
QuoteIndeed! The fundamental problem: How to loop-back, so
Did it ever ocurr to you that the devices that do not need the inverter,battery and transformer with bridge rectifier bridge
to operate use 2 devices in one,one supplies the energy for the device to be looped for both devices.The other supplies energy to the load,this is how the aquarium 2 device works without an inverter.The 2004 device and the green box device ,are one device, so require an inverter,a big battery and a transformer with a bridge rectifier to achieve a loop condition.
Tariel is a lot smarter and ingenious than you might believe.
Kapanadze shows you how to loop back in his patents. duhhh.
Aking21
I have a lot of respect for you having the guts to try
to get Kapanadzes device to the general public,you also caught
Tariel at hes weakest moment,and he dropped hes guard.
You have been lied to from the word go,the patents are nonsense
they show nothing,lead to nothing.It is not a Tesla invention nor has it anything to do with Tesla,Tariel says it does, to make people
focus on Tesla not Tariel.There all kinds of ways of looping,you can use a hardware model to simulate a device then loop it,it doesn't matter as
long as you supply the energy, in a real device the device would supply
the energy,its not magic,some things have to follow known rules,some
must be outside known rules for a real world overunity device to be real.
Quote from: cheappower2012 on April 22, 2016, 06:57:28 PM
Hoppy
Cheappower,
The point I made about the need to remove the battery and inverter in the case of the green box device was that if the device works
outside of conventional principles, then the loop-back is needed for the device to run itself without help from any power supply provided by the user. A system working oiutside of conventional principles is clearly not what Tariel is running. I suggest that although I think I understand what you are saying, for the benefit of others, a block schematic from you would be better understood.
New video
https://www.youtube.com/watch?v=qUlLDQkqreA
https://www.youtube.com/watch?v=YY7dJQq5YQk
https://www.youtube.com/watch?v=oIivkWtSbR0
Leo48
Quote from: leo48 on April 23, 2016, 06:00:54 AM
New video
https://www.youtube.com/watch?v=qUlLDQkqreA (https://www.youtube.com/watch?v=qUlLDQkqreA)
https://www.youtube.com/watch?v=YY7dJQq5YQk (https://www.youtube.com/watch?v=YY7dJQq5YQk)
https://www.youtube.com/watch?v=oIivkWtSbR0 (https://www.youtube.com/watch?v=oIivkWtSbR0)
Leo48
So is this the real source of power, a generator complete with a long length of welding type cable and lamp board for the garden demo?
Perhaps the generator is located inside a black box as usual
Thanks to Leo48
A electric motor drives a hydraulic pump to generate oil pressure (don't know the correct name of that machinery). That electric motor is connected to Kapanadze's OU device. So the motor and the additional loads running on free energy.
At 4:16 in the first video something seems to get jammed for a moment, thus the motor overloads the OU device briefly so the lamps flicker.
Unfortunately the camera operator did not focus much on the important parts, like that transformer without casing which is - I guess - not a genuine part of that oil pressure generator.
That half-round thing is connected with 4 wires. Couldn't be a diode bridge? ::)
Resembles the diode bridge present within the cars dynamo
Leo48
Quote from: Zeitmaschine on April 23, 2016, 08:40:27 AM
Thanks to Leo48
Well it certainly looks more interesting than the Stepanov device. As for the motor overloading the OU device, I'm surprised you have X-ray vision specs! I could do with a pair of those to look closer at the root like wires I see in some videos. ;D
I knew it! I'm chased by diode bridges! (http://www.bing.com/images/search?q=diode+bridge+car+alternator&qpvt=diode+bridge+car+alternator&qpvt=diode+bridge+car+alternator&qpvt=diode+bridge+car+alternator&FORM=IGRE) :o
So do we (does Kapanadze) need a diode bridge to run a AC motor, or incandescent light bulbs, or an electric water jug, or an electric fan? If the answer is NO then that diode bridge clearly serves a different purpose.
Quote from: Zeitmaschine on April 23, 2016, 08:56:09 AM
Clearly no, if the diode assembly shown is for automobile applications.
Clearly no what? Since automobile applications running on 24V max. we got another important piece of information: That car diode bridge is not connected directly to mains voltage. What does that mean? What have we looked at just a few days ago? Wasn't that an arc welder circuit showing a diode bridge connected to the low voltage secondary side of the welder transformer? Low voltage high current.
Seems we need that diode bridge still but not the regular way.
One more coincidence. :D
Quote from: Zeitmaschine on April 23, 2016, 11:20:41 AM
Clearly no what?
??? Did you forget that you asked a question!
The bridges dynamo of the automobile are three-phase, and in this two of the three AC
inputs are connected to the secondary winding transformer, and third not connected,
the negative is grounded and the positive returns in the box
Leo48
»the positive returns in the box« - is that so .... :)
But I'm not sure if a simple 'No' is the correct answer to my question. The answer should rather be 'Perhaps'.
Asking myself how long it will still take until I hit the bullseye, just by thinking and looking at blurry images. :D
This is a 3-phase transformer connected to a 3-phase diode bridge. For illustration only.
Quote from: Zeitmaschine on April 23, 2016, 11:52:35 AM
Yes, perhaps, if you like the smell of smoked components. ;D
It could simply supply for low voltage electronic
Leo48
Quote from: leo48 on April 23, 2016, 01:29:22 PM
Leo48
That trafo and rectifier are way too big for the electronics. I'll hazard a guess that its used with the generator to send power to the devices in the garden videos via that long length of coiled cable.
Kapanadze its equipment uses recycled material and therefore it is greatest that's okay
Leo48
Schematic below just for illustration. :)
That resistor could be any load like an incandescent light bulb or a heater. In any case it would double the frequency supplied to the coil which is connected in series with the capacitor. The upper transformer is step-down 50Hz (mains in), the lower transformer is step-up 100Hz. Interesting configuration. One 3-phase transformer running at two frequencies at a time. But I think there is still something missing.
I managed to recover an enlarged photo of the transformer
Leo48
Hoppy
The way I view both the tpu and tariels device is a certain amount of it runs under conventional
electronic principles,the part generating the overunity does not,however a conventional electronic
method is used in a strange way to create the overunity.It takes a given amount of energy
in my opinion to create the condition that produces the overunity and this has to
be supplied or the condition stops,therefore the overunity stops.This is why the device must be
looped to operate.If you look at the 2004 video they take a reading of the current drawn by the device
to produce the output,that must be supplied to maintain the 4kw output.It looks to be around 80 to 100 watts.
The one device picture shows the method used in the 2004 and green box videos,the second picture is like the aquarium 2
video and others using a 9 volt battery to start the device.Of course there is more circuitry
in the 2 devices picture since the device one, has to generate an ac 50 hz signal and generate 220 vac
from the 12 volts and create an independent 50 hz 220 vac when powered by the second devices 50 hz,220 vac output.
The new video from Tariel is outrageous,I agree with leo48 the black box is the real device,the
motor connected to the what ever that is,is to distract the investor.Hes using the same fake out that he used with the magic wheel.The transformer used is connected to the 3 phase motor not a functional
part of the black box in my opinion.
Cheappower,
Thanks for the schematics to explain the two modes of operation. I had heard that Tariel messed about with generators and here is the proof. That long length roll of thick black cable is telling in my opinion. If he was running the green box device from the generator, via that cable, we have been concentrating our thoughts on the wrong end of the device!
As we can see, the transformer of the Kapanadze 2004 tin can setup is connected the same way like in the Kapanadze 2015 hydraulic setup. Four wires going to the primary coil, two wires going from the secondary coil to the diode bridge.
There is one difference though (because we can't see it in the 2004 video): There are two wires connected to diode bridge positive. And just as a coincidence, in my previous schematic there is one capacitor and one resistor connected to that diode bridge positive, this makes two wires.
But now we know for sure that the transformer in the 2004 video is a step-down one, because the diode bridge from car alternator is not suitable for grid voltage.
Question: Maybe by chance we could see a resistor on a heat sink anywhere mounted on that hydraulic frame? Just guessing ...
Part-Number of that diode bridge is: БПВ 46-65-01 (http://www.amperavto.ru/index.php?route=product/product&product_id=2549)
Zeit,
Don't get over excited about that transformer, as I think the generator is being turned by a motor running on liquid fuel of some kind. You can hear it circulating just before the motor starts up.
New physics? Liquid fuel in a closed bucket runs a motor working as generator that lights up a bank of lamps? ???
This could be considered as OU also. :)
I am not sure. It could be magnetoacoustic in nature, like in
this video (http://overunity.com/Magnetostrikci%C3%83%C2%B3) or even nuclear ...or both.
Quote from: leo48 on April 23, 2016, 08:39:49 AM
I think the setup is as as follows: -
The hydraulic pump and motor are housed in the red barrel. The black box has a rear entry hole for a cable link to the red barrel, so that in normal mains operation, the transformer supplies low voltage, high current to drive the motor. A mains isolated AC supply is taken from the blue generator into the black box where it is terminated to the outgoing supply cable. In order for the generator to continue operating during the mains disruptions, a heavy duty battery is housed in the red barrel and switched to power the motor.
Quote from: verpies on April 26, 2016, 05:13:28 AM
I am not sure. It could be magnetoacoustic in nature, like in this video (http://overunity.com/Magnetostrikci%C3%83%C2%B3) or even nuclear ...or both.
The link seems to be broken.
Quote from: Hoppy on April 27, 2016, 04:31:07 PM
Blue is an
induction motor (http://www.bing.com/images/search?q=induction%20motor&qs=n&form=QBIDMH&pq=induction%20motor&sc=8-15&sp=-1&sk=). It can't work as generator.
But there is something we know now:
a) The frame is ground, the device needs no additional grounding.
b) The diode bridge minus is connected to frame, therefore ground.
c) Device can self-run without external inverter.
So, what is missing in the red box below? It can't be much, can it?
Quote from: Zeitmaschine on April 27, 2016, 08:10:22 PM
http://youtu.be/qauZ4WBwAOM
Blue is an induction motor (http://www.bing.com/images/search?q=induction%20motor&qs=n&form=QBIDMH&pq=induction%20motor&sc=8-15&sp=-1&sk=). It can't work as generator.
http://www.redrok.com/cimtext.pdf (http://www.redrok.com/cimtext.pdf)
http://www.smallhydropower.com/induction.htm
You sure?
Now explain to me a) why Kapanadze should go through the length of exciting inconveniently an induction motor first to use it as generator, and b) what size your heavy duty battery must have to output KWatts of energy without running low during the demonstration.
To point a: It is not in order to have an output at 50Hz, because the green box setup runs at 50Hz without turning a large motor first. To point b: The ammeter shows around 10A at 220V equals 2200W that would make a current of 183A drawn from a 12V battery, if I'm correct.
On the other hand, the 2004 setup needed also »excitation«. The lamps are never lit immediately when connected to the inverter. Should that be a hint that this blue motor is part of the resonant circuit not simply connected to it?
Even more strange, switch on (https://www.youtube.com/watch?v=oIivkWtSbR0) at 0:04 then at 0:14 the motor starts suddenly (after relay clicking). 10 seconds (in first video 12 seconds) delay, what for? Sounds like a small pump stirs up the oil prior to start. But what would the purpose of this when it runs on a battery (and a motor) hidden where the oil is supposed to be?
Quote from: Zeitmaschine on April 28, 2016, 07:45:06 AM
You sure?
The battery is not hidden where the oil is supposed to be. The oil is outside of the red barrel that houses the motor and battery. The green box device if powered from this generator at a remote location, would of course not need to run on battery, as the mains would supply the motor via the step-down transformer.
The total length the 3-part video shows the motor running is 4m 19s. The voltage across the lamps is unlikely to be a full 220V and probably a lot less. So, even if the full 220V was applied, the current would be more like 100A. With a run time of just 4m 19s, this would be no problem for a battery capacity of 100A/h or more. The current would stay reasonably level looking at a typical discharge curve. As has been mentioned before, the real test is to see the device running for much longer periods of time, which are clearly beyond the capacity of batteries that could physically be hidden within a given device.
That's quite a stretch. How did Kapanadze make sure no observer will demand a runtime that exceeds the capacity of the battery? We should think about that.
Meanwhile a transformer theory of mine: The primary coil of a step-down transformer is supplied by 220V 1A, the secondary coil generates 22V 10A (for simplicity sake). So what has to happen that the secondary coil generates 220V 10A? We need a stronger magnetic field, I guess. The normal way to strengthen the magnetic fields in the transformers core would be to rise the voltage supplied by the primary coil (saturation disregarded). But doing so will also rise the current going through the primary coil (thus the stronger magnetic field). But what if there were a different way to get a stronger magnetic field in the core of the transformer? A static electric field (http://blog.modernmechanix.com/static-on-moving-object-forms-magnetic-field/) can generate a magnetic field when set in motion. Now if we set that static field in motion not mechanically but by means of another magnetic field within a transformer, where one coil generates a static field and one coil a magnetic field. Will those magnetic fields add up? Or even multiply?
Quote from: Zeitmaschine on April 28, 2016, 10:30:19 AM
Not at all. As I understand things, Kapanadze runs the show. I imagine that observers don't demand anything when on his turf! They may ask nicely but I'm sure that he would not have allowed anything that might risk spilling the beans. You may recall the security guys he had near the house during the transparent box demo.
Both points of view are good,however the concept that a investor
is a complete fool and would not demand a much longer run is not totally creditable.
People with money are very tight with there money,small fish maybe greedy enough.
This silly contraption in my opinion is a return to the mechanical
wheel type of devices that he did a long time ago.The question is why,did the investors reject
the solid state devices or did Tariel cheat so many people that
nobody lines up to invest in any devices so he has to come up with a new
trick,overunity oil motor turning generator.In my opinion the real power source is the black box
The black box powers the motor which turns the oil pump,the excess is used to power lights,heater.
If the motor is 3hp the devices output would be enough to power the motor and load.
If the generator provided the current to a load ,at start up it would slowly
light the lamps up,notice no load on, as the device powers up.If this was an inverter/battery setup
it should power up real quick.In any case there is no real information of use in this new device
Tariel looks to be in much better health so he will not screw up.
An induction motor running as a generator needs to be running at speed before being loaded.
It is highly probable that this generator was running the garden devices via the cable we see coiled up. As to whether the generator was running OU remains unknown. However, if I were an investor, I would certainly want to see that red barrel opened up before signing-up but I really cannot see Kapanadze allowing that. No enclosed volume of space capable of hiding an energy source capable of powering a device can be simply dismissed. The black box is too small to hide anything significant. It appears to be just a cable termination box, with maybe some control circuitry. There is a cable access into the red barrel in the back of the box.
Quote from: Hoppy on April 29, 2016, 04:26:02 AM
The Sadolin tin can is also too small to hide anything significant. Nothing new here.
In video #2 I can here a German voice saying »Machma [Machen wir] uns die Aufnahme, daß man die durchgucken kann.« Second voice: »Ja, ja, ja«. (We should take the record in order to look it over. - Yes, yes, yes.)
Does this mean something? Perhaps not.
Small typo, it should read: »I can hear a German voice« :)
http://infinitysav.com/freeenergydevice -- claims to be located in Seoul, S. Korea
http://www.youtube.com/watch?v=1n2KuK_YD5U
What language is being spoken?
(snip)
Typically, a component will conveniently fail, ending the demonstration, and no spare parts are available -- until after the observers have had to catch their flights home. At which point a new video will be published showing the "repaired" unit again working.
This is an old trick, used many times, but it still works. See PESN for examples.
Quote from: TinselKoala on May 01, 2016, 05:00:49 AM
http://infinitysav.com/freeenergydevice (http://infinitysav.com/freeenergydevice) -- claims to be located in Seoul, S. Korea
http://www.youtube.com/watch?v=1n2KuK_YD5U (http://www.youtube.com/watch?v=1n2KuK_YD5U)
Sounds Russian ?
Quote from: gyulasun on May 01, 2016, 05:43:47 AM
Sounds Russian ?
Sure, Russian. And device resembles Akula small devices.
Quote from: forest on May 01, 2016, 06:54:15 AM
Also with hidden battery in the transformer?
Quote from: TinselKoala on May 01, 2016, 05:06:44 AM
End of the demonstration due to a failing component? Surely the investor won't be amused.
Quote from: Zeitmaschine on May 01, 2016, 09:25:46 AM
In Kapanadze's case, the investor is kept well away from the source of power - the generator, so any failure is down to environmental conditions, which are of course outside the control of the operator. For example, in the case of the green box device, a dodgy earth wire, not sucking up enough current, or a stormy atmosphere in the case of the Aqua2 device.
Diagram from Kapanadze's Patent WO 2008/103130 A1
file:///C:/a/0%20%20%20Misc/0%20%20%20Energy/Kapanadze/Patent%202.htm
My hunch is that where it says Freq Gen, is really a Spark Gap which will generate a Frequency & a LOT of harmonics.
For the input, an inexpensive Neon Sign HV transformer should work OR possibly a Microwave Oven Xfmr?
It's HV output can probably jump across a car spark plug gap.
The Voltage has to be high enough to jump the Spark Gap & energize Primary Coil 1.
The Diagram From The Web (bottom photo) shows a Spark Gap.
It looks like he uses an automotive Spark Plug for a Spark Gap in some of his videos.
Just to prove things out, I believe we can temporarily LEAVE OUT parts 6, 9, 10, 11, 12.
QuoteMy hunch is that where it says Freq Gen, is really a Spark Gap which will generate a Frequency & a LOT of harmonics.
My intuition rather says that »Freq Gen« could mean
Frequency Doubler. Of course in the patent it would have been too obvious to write it in such a plain way.
»In the Century article Tesla compares extracting energy from the environment to the work of other scientists who were, at that time, learning to condense atmospheric gases into liquids. In particular he cited the work of a Dr. Karl Linde who had discovered what Tesla described as a "self-cooling" method for liquefying air. As Tesla said, "This was the only experimental proof which I was still wanting that energy was obtainable from the medium in the manner contemplated by me.« Tesla's Fuelless Generator (http://home.earthlink.net/~drestinblack/generator.htm)
Now we can compare the block diagram below with Linde's
self-cooling method (http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg376052/#msg376052) and with Kapanadze's patent drawing above. Can we recognize any similarities?
The frequency doubler works like an AC valve. The energy can only flow from 50Hz input to the 100Hz output but not vice versa. On the other hand mixing 100Hz with 50Hz should result in an energy flow from high to low frequency. Hence what could happen if by any chance the grounding of the high voltage between the two transformers supplies that loop with a little bit of additional energy during each oscillation cycle?
Regards ;D
The Donald Lee Smith Coil is actually a center tapped Tesla Coil (a deeply interesting realization). :D
The primary LC circuit resonates at a given frequency. Assuming the secondary LC circuit (L2a) resonates at a different frequency (maybe twice or half), then what is the frequency of L2b? Is it the primary frequency because it is driven by the primary coil's magnetic field or is it the secondary frequency because it is directly (galvanically) connected to that secondary LC circuit (L2a)?
And what could be the direction of the flow of electrons coming from ground?
Could there be any unforeseen outcome?
