A few variants of magnetic generator
Magnet №1 vector of magnetic field is from left to right.
Magnet №2, vector of magnetic field is from the centre till the whole diameter. Make a cutout in the magnet or order a new one with the same shape (you can't heat the magnet above 80 C degrees otherwise it looses its magnetic properties).
Device for diagram of magnetic force field. 1 degree step.
Choose the number of stator's axis with the help of diagram.
Put together a circle stator's magnet from the magnets halves (radial magnetic field).
Magnets divide on the equal amount of axis.
The reducer with 1:1 intension is shown on the left picture. Join the level arm to reducer and get 1:3 intensions (central picture). Change the arm level on rotor and stator's magnets, get 180 degrees rotation.
The stator's magnets are around the rotor's magnets on the picture.
Magnetic disc
(variant №1)
Rotor is divided on 6 pieces (radial magnetic field) the amount of stator axis is seven. Step among the axis is 51,43 degrees. Rotor begins its motion clockwise on the axis. Stator from A point to B point is PULLING rotor and from B point to C point is PUSHING rotor (360 degrees stator's axis turn).
Vector of rotor's motion is perpendicular to the magnetic field of both magnets. The angle between vector's motion and vector's magnetic field must be minimal. How to change vector? Direction of induction of magnetic field should be changed or change the angle of rotor's segments (radial magnetic field).
Magnetic disc
(variant №2)
Increase the area of interaction of stator and rotor's magnets.
Rotor's axis is not perforating on the picture below.
The stator's magnet rotates with the rotor regardless of magnetic force field of both magnets. You can check it with experiment:
The cube and circle magnets are on the piece of plastic. Lower magnet A is rotating around the axis so upper magnet A rotates with the lower one. Cube magnets are bounded with the magnetic field, they rotate together. Circle magnets are bounded with the magnetic field but the upper magnet B does not rotate.
Experiment showed us that the rotor and stator's speed can be different and do not cause deceleration of reducer.
Comparison of rotor's sigments.
To continue this theme http://overunity.com/16607/working-magnetic-generator/msg484564/#msg484564
magnetic generator (no reduce).
