free energy can be multiplied with pulleys
USE PULLEYS TO MULTIPLY ROTATIONS = AC ELECTRICITY
What this Christian Warrior is trying to get out to the world,
is the simplicity of tHis Gift.
Free Energy is here + now, even free of all patent fees =
please Goggle free_energy + yolasie.
http://free-energy.yolasite.com/
free energy can be made simple,
you can use pulleys to multiply your electricity
instead of using oil to generate it
free energy is here now,,,
It is all done with pulleys. (mirrors of physical properties)
you use a small amount of electricity to rotate a very large pulley only the once,
then you get many times the power back out,
from the one or few generators connected to the same belt as the large pulley,
(rotating tens to hundreds of times the large pulley) all on the same belt
If you would like to know where this warrior is coming from,
please check these pages out :
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
for my mission, Please view any of these Bible web pages:
http://doorschristmustpassthrough.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://askthatprophet.yolasite.com/
but no one will listen to the simplicity of it
all you do is put power into a motor to turn a large pulley only one revolution
and then you get massive amounts of electricity back
from the many small pulleys attached in the same belt
Please realize the dark conspiracy covering this subject, yes this is dirt simple, almost too simple to work,,, yet it does indeed work, you just need the faith to try it. Seriously, just try it out, and you will get to see the workings of one of His Miracles. Please, don't let this miracle be hidden any longer. Let us start using the technology of Ezekiel to change the world for the better.
It's workings are super simple
You put power into a motor to drive a large pulley only once (little energy)
+ You get out a multiple of that electricity
Depending on how small the generator pulleys are
As well as how many generators with little pulleys attached
With the amount of belt that goes around one large rotation
You can easily get 10 – 20 times the rotations of the input pulley
Then you can double your rotations each time you add yet another generator
On your own belt system, (easily done – takes little torque)
I figure, you simply must gain a multiple of the energy that you put in
As you are only putting enough power into the drive motor to rotate it only once
And you get back many times the electricity
Not only having smaller pulleys,
But gaining more rotations per foot of belt that you go through
To double or tripling your rotations by adding additional generators
on their own mini-pulleys
Free Energy is such an obviously simplistic discovery,
- as well as being extremely free + easy to produce,
what is the only reason for us missing this basic idea,
- we have been dumb to this free energy technology .
This technology has been hidden for far too long,
Please, go to this website
Search free-energy + yolasite
Or if this website allows URLs
then try your hand at producing a digital prototype
on one of the many free electronic simulator software's out there,
that will help start producing electric toys + tools,
and how about everything that runs on electricity,
being reproduced with free energy power supplies built into them.
Let's restart our economies,
by building industries that reproduce all of our electronics,
so that they are all self powered. (non polluting)
= First though, is getting rid of all the gasoline motors in our motorized vehicles,
and putting a GEM in them.
All we need to do, is have enough faith in His Word
to build these GEM (Good Electricity Multiplier) Miracle motor
THIS DOES INDEED WORK
(think about how simple this is)
(you put power in to rotate one large pulley once)
(you run a belt to rotate mini-pulleys many time)
(then you could add many mini-pulleys)
(each one rotating hundreds of times)
(multiplying your AC electricity)
(YOU MUST GAIN FREE ENERGY)
LOGICAL REASONING
It takes little energy to turn a one foot circumference pulley,
which can be used to drive a belt that turns a mini pulley
of one inch circumference many times
This 12X you gain your AC energy from the many times the small pulley rotates,
or even more from the many generators on mini-pulleys you add (no torque)
you can twelve times the AC electricity with every extra genertator attached
12X + 12X + 12X + 12X each starts to add up very quickly
all of these generators run free of any torque
come on guys + gals, this is so simple that it just has to work
you only put the small amount of energy to rotate a big pulley once
and you use pulleys to multiply your rotations many times
you could have ten mini-pulleys rotating hundreds of times
you simply must gain electricity
the torque is your only problem
and that would be minimal
if you only had a 12 inch circumference pulley
then you have 3 mini-pulleys
rotating 36 times for each one rotation of your large input pulley
YOU JUST HAVE TO MULTIPLY YOUR ELECTRICITY
Originally Posted by Tom C
well its time for you to make something not just an electric wheelchair... please build it and put some meters on it...
Tom C
sorry Tom, but I happen to be poor + disabled, with shaky hands, so I cannot build it myself, nor can I afford to pay someone to build it for me
FREE ENERGY is so super simple. It only take one spark of DC electricity, to rotate a DC motor once, with a 100cm circumference pulley attached, giving you 100cm of moving belt, strap, rope or string. Then if you run this moving belt through 1 to 10 mini-pulleys of one centimeter circumference, you would get an output of 100 to 1000 cycles of AC electricity. There is no torque resistance from the mini-pulleys, as there is no current involved, or practically none, considering that to make this mechanism a self powered mechanism, you only need one spark of DC output to be sent back into the DC drive motor. These AC generators are just winding up massive voltages, which is all that you need to turn over your drive motor one single time.
This FREE ENERGY mechanism is in need of one more very important component, a full wave bridge rectifier, to convert your AC output generators into DC electricity, which is needed by your drive motor. I should state them as plural, just in case you have plural mini-pulleys, which would increase your total ability to tap power off of, both your AC or DC motor/generators. Once started running, (easily achieved by giving your large pulley with the DC drive motor a quarter turn by hand) this AC + DC power supply should be a perpetually running mechanism.(until the bearings dry out or some other mechanical break down)
FREE ENERGY is so super simple, that there simply MUST be something or someone,(evil forces) hiding it from the public eyes. Yes, there are in reality, two parts to this subject: (1) - how super simple this technology really is + (2) - how evil forces have an immensely powerful hold on this technology. First I will prove to you just how super simple this technology is, + second how powerful of a hold that Satan + his followers must have on our modern society, to be able to keep this technology hidden.
This FREE ENERGY mechanism is in need of one more very important component, a full wave bridge rectifier, to convert your AC output generators into DC electricity, which is needed by your drive motor. I should state rectifiers as plural, just in case you have plural mini-pulleys, which would increase your total ability to tap power off of, both your AC or DC motor/generators. Once started running, (easily achieved by giving your large pulley with the DC drive motor a quarter turn by hand) this AC + DC power supply should be a perpetually running mechanism.(until the bearings dry out or some other mechanical break down)
Now you should be able to tap AC or DC electricity off either motor, or maybe even both. If you find that you cannot get much current out of either of the motors that you are tapping off of, then all you need to do is add more of your mini-pulleys with the AC generators attached. Diagrams can be viewed at http://free-energy.yolasite.com/
free energy
This works by using, one spark of DC electricity is all that is needed to start this mechanism running = DC motor with large 100cm circumference pulley turning only one single time. The 100cm of belt is then run past mini-pulleys of one centimeter circumference, gaining 100 units of AC electricity. The pulley combinations multiply you total # of rotations, which when AC generators are added, becomes AC electricity.
TWO BIG POINTS ABOUT THIS BLESSED BIBLE BORN MIRACULOUS MECH
(1) – You can add as many mini-pulleys + AC generators as you would like, because these add no torque with their rotations. Torque comes from power generation = Voltage X(times) Current, and since we need only a spark of current, (practically none) to feed back into driving you DC motor, this negates the massive voltage you are generating with massive rotations of your generators. By the way, this massive voltage=pressure that you are easily generating with your massive rotations of your AC generators, is exactly what you need to push over your large drive pulley the one single time.
(2) – This Bible description,(Vision) that I was Given by God = (discovered), can be used for generating free energy, was from how a UFO motor looked while running. This could mean, if you are determined, that this mechanism might lead to anti-gravity + 1000 km/hr vectoring. Just think about this part of His GEM= (Geometrical Electricity Multiplier) of a Gift. Not only is this free energy good to help stop polluting our earth, but we could pay one time to build free electricity driven filters,(that run cost free) to help clean our atmosphere + water.
I know that most will reject this part of my description of how I came up with this Miraculous mechanism, but I still feel that I MUST state these awesome facts. This is a Gift from the God of our Holy Bible. He first gave me this in a Vision of a ten speed going uphill in 10th gear,(few rotations of pedals) and then back down the hill in first gear, (massive rotations of pedals). Since AC electricity is generated from rotations, I figured that the more rotations meant the more AC electricity you were multiplying.
I then took this logic and converted it, to perform a test with my electric wheelchair. I started out with a low battery, and went up a long steep hill as fast=(10th gear) as I could, until my battery died and my chair would not go any further up the hill. Then I went back down the hill slowly=(1st gear), until I got back to my starting point. I then repeated this action three times, of going uphill fast + back down the hill slowly, and each time I gained the power to go up the hill an extra 20 feet. So the 3rd time that I repeated this action, I was 60 feet higher up the steep hill. I had miraculously gained the power to go up this steep hill an extra 60 feet. Please remember, to have this experiment work on most any electric wheelchair, you must first change the settings on your electric wheelchair, to maximum torque,(1st gear) + maximum speed,(10th gear).
I was still unsure of Who had given me this Vision, so I ask my Lord for proof that this was from a His Spirit and not from evil spirits, trying to mislead me. I was shortly directed to Ezekiel 1:16, where the Word Stated plainly, "a (small)wheel in the middle of a (large)wheel". I did not have the technology nor money to build it exactly like it was stated, but I devised a simple way to used pulleys and a belt, strap, rope or string, that would simulate it.
I have been Shown many more important bits of information that can be found at http://beliefstoliveby.yolasite.com/ but my most important discoveries are here:
http://my2020vision.yolasite.com/
http://aliensandghosts.yolasite.com/
Dear Stefan,
Your site has almost 17,000 threads, most buried beyond any hope of discovery and yet you allow this hopeless idiot to start up more on his absurd nonsense to drown even more thoroughly those that exist.
Please ban him.
that_prophet :
We know about Chas Campbell. We don't need you. Build your machine and prove us all wrong BEFORE you bore us further with your rubbish.
Absolutely won't work. Try it & see.
Quote from: Paul-R on July 03, 2016, 09:06:36 AM
Dear Stefan,
Please ban him.
Paul-R has a very strong point here. It is absolutely trivial to recognize that this is just another deception perpetuated by the energy cartel, and this post of mine is not about adding one more vote to the "this is an obvious hoax" box. Rather, the intent is to add some input about how to handle such situations, and how to battle the overwhelming assault of hoaxes.
Some of the old and experienced FE researchers already know what is going on in this field of online research. But it might be useful to highlight some aspects of the hard reality to the enthusiastic young researchers, who still think that everything is just fine, and there is no suppression. Let me paste here a paragraph that I wrote in another thread with some modifications:
The strategy of the energy cartel's disinfo organization is not too complicated: infiltrate the FE movement, establish your own puppet "authority" figures with intense advertisement, and mislead the herd into blind alleys. Channel their investments into waste bins, and make them fail over and over again by replicating the disinfo garbage "FE inventions", which should flood the internet. They should be so numerous, that the few real FE inventions should be lost in the heap of garbage, unrecognizable. This will lead the herd to utter frustration, and finally tired out and broke, they will become either idle passive watchers of the FE news, or just quit the research completely. Discredit the concept of FE by creating FE fads like Kapanadze, Keshe etc. and finally by busting them as hoaxes. Then people will finally associate all FE inventions with hoaxes, saying "... nahh! Not again! Here is yet another hoax, from another crackpot. Just ignore it!" And of course, the most important of all is to ignore and suppress the real guys, who invent real FE generators and/or spread the science about it. This is what has happened to Janos and me.
To bring FE to the masses it is not sufficient to only invent an FE machine. If that would be enough, then we would not be paying electricity and heating bills since at least the times of Tesla, and we could live in a paradise-like world of plenty. The inventor also has to mobilize enough money to enable the development of the invention for mass production, which is not pocket money; and it is next to impossible to get the "big money" to invest in FE. The third obstacle to overcome is the relentless disinformation campaign, and intense anti-free-energy brainwashing in educational institutions, mass media, patent offices, online websites, forums, and elsewhere, perpetuated by the energy cartel.
It is no wonder that no FE inventor has succeeded so far with breaking though all 3 of these obstacles. If the masses, or the representatives of people (we) don't help such inventors, and don't get big money interested in investing in real FE development for mass production, then there is really no hope for success. Then even after hundreds of years your descendants will live in a terribly polluted radioactive world, still using fossil fuels and radioactive materials for energy production and transport, and they will blame us for not having done anything (or enough) to ensure their energy independence, freedom, and good health, while there was still chance for success. Like we could blame our ancestors for not doing more, to protect our freedoms form the oligarchy, while they were less powerful than they are today. If we don't find a way to dispel the dense fog of confusion and ignorance spread by the disinfo organization, then who will do that? The inventors? That is not their job, it is not their field of expertise; they have better things to do.
We are mostly taking this subject easy, thinking that we are not obliged to move our little finger to help real FE inventions succeed, because it is just a hobby to us, and no one is paying us for this. But just think about it a little deeper! There are about 7 billion people on this planet, and if you count how many of them are interested in FE research, you will hardly pressed to find a few thousand or perhaps few 10000. Out of these, may be only a few hundred that is really doing something useful. If we are not obliged to dispel the dense fog of disinformation, find real FE inventions in the huge pile of hoax and idle chat, and get it into mass production, then who will do that? The inventors can't do it on their own, I hope you realize that. The rest of the 7 billion people will not do it because they are not interested, and/or too ignorant in this field to do anything. So the only people with the responsibility to fight this battle for the future generations is only us. If we don't do our duty, then your descendants will live in a terrible world as slaves terribly sick, living very short lives, with microchips implanted in their bodies.
Therefore it is absolutely necessary that FE researchers educate themselves in the art of disinformation, so that they should be able to recognize the agents of the energy cartel, and subdue their campaigns successfully. They are present everywhere, and if you think that this forum is an exception, then you are still asleep, having a rosy hypnotic dream. For the starters, here is a very informative introduction to the techniques used by the disinfo agents:
http://vigilantcitizen.com/latestnews/the-25-rules-of-disinformation/
After this little introduction, let's return to the suggestion of Paul-R to ban this user for spreading an obvious hoax. If this forum would be mine, I would surely do that, and I would ban not only this fellow, but many others as well. But then of course, the forum would not be so popular as it is now, and there would be less (or no) money for running the forum, and due to the lack of popularity perhaps many of the genuine members would not be here either.
As far as I am aware, the policies of the forum don't forbid the posting of hoaxes either, so basically this banning exclusively for this reason is a mute point. It would be also very hard for Stefan to decide whom to ban and who may stay in many cases where the deception is not so trivially obvious like in this case.
So here is a suggestion about what could be done to at least somewhat counter the disinfo operations on this forum. Genuine researchers (not disinfo agents) supposed to dig out the potentially valuable inventions and threads from the heap of 17,000 threads, and put them on a list. Every member could have his/her own list. These lists could be posted in a thread specifically started for this purpose only, without comments to keep it information-dense and undiluted (no idle chat and off topic comments). Unfortunately the undercover disinfo agents could also post their bogus list, so this is far from a perfect solution, but it still can reduce the 17,000 threads to say few hundred potential threads. In a smaller heap of straw it is easier to find the golden needle.
Another additional filter could be then a poll, where forum members could give their votes at an independent poll-web-platform, which of these lists they trust and which they don't (preferably obliged to explain the reason for their votes). This poll again can be (and will be) contaminated with the bogus votes of disinfo agents, but still, it can be a useful information, that could further narrow down the numbers of potentially genuine FE inventions.
Further filters could be implemented based on objective merits of the selected few potential inventions. Like:
1. Is there any scientific – mathematical proof that they can produce FE based on the conventionally accepted rules of physics?
2. Was a proof-of-concept device already built?
3. What were the measurement results on such device?
4. Did anybody succeeded to replicate those measurement results, or at least attempted it?
5. What are the critics saying about such replications?
6. Is the principle of excess energy generation known for that invention?
7. Is there any need for an exotic new theory to explain the process and/or origin of FE; if yes does such theory already exist? Is it plausible; does it make good sense?
8. Can the device generate enough FE to supply at least the needs of a household?
9. How expensive is it to produce it; is it economical at all?
Etc.
Another, extremely important project could be to collect all the FE inventions that have already been proven to be hoaxes by honest replications, or by other reliable logical and scientific methods. This will again not be a perfect list, because it will again be contaminated by the disinfo agents, but still, it can help filter and narrow down the list of potential hoaxes to avoid.
When all these statistical and analytical data is available and well developed, then Stefan can have an easier job to decide on his own responsibility, which threads and inventions could make to the new category of "Most Probably Genuine FE Inventions" where those selected threads could be again categorized according to those categories where they have been found and properly belong (one ex. like "Solid States Devices"). Another new category could be ,,Most Probably Hoax FE Inventions". As already mentioned, the final result of all this filtering system will not be perfect, there may still be useless inventions in the "Genuine" category and genuine inventions in the "Hoax" category, but I hope you agree that a lot of useless junk, and idle chat will be filtered out and it will be easier to find the real thing in a smaller heap. The content of these categories don't have to be fixed either. They can be modified any time as soon as sufficient proof or reason emerges to remove or add some threads into these categories.
Also, I don't believe in the 100% efficiency and usefulness of "democracy" when it comes to FE research and its promotion. The democratic voting system (just like the popularization of certain FE inventions) can be very easily manipulated and results falsified by the energy cartel. This is the reason that the final decision about what gets into the final categories should be made by the owner of the forums and websites, and not decided solely by a voting system. This way personal responsibility can motivate the owners, to recognize and counterbalance any possible manipulations of the mentioned filters, or vote results.
This way hopefully there will be no need to ban people just because they post obvious hoaxes, while still helping researchers to find the real things they are looking for; and counter the overwhelming onslaught of disinfo hoaxes that steal the attention, time, and money of genuine researchers, and create untold frustration.
Just in case the page at the link I gave in my last post disappears, here are the rules reposted:
QuoteFrom Twenty-Five Ways To Suppress Truth: The Rules of Disinformation (Includes The 8 Traits of A Disinformationalist) by H. Michael Sweeney. These 25 rules are everywhere in media, from political debates, to television shows, to comments on a blog.
1. Hear no evil, see no evil, speak no evil. Regardless of what you know, don't discuss it — especially if you are a public figure, news anchor, etc. If it's not reported, it didn't happen, and you never have to deal with the issues.
2. Become incredulous and indignant. Avoid discussing key issues and instead focus on side issues which can be used show the topic as being critical of some otherwise sacrosanct group or theme. This is also known as the "How dare you!" gambit.
3. Create rumor mongers. Avoid discussing issues by describing all charges, regardless of venue or evidence, as mere rumors and wild accusations. Other derogatory terms mutually exclusive of truth may work as well. This method works especially well with a silent press, because the only way the public can learn of the facts are through such "arguable rumors". If you can associate the material with the Internet, use this fact to certify it a "wild rumor" which can have no basis in fact.
4. Use a straw man. Find or create a seeming element of your opponent's argument which you can easily knock down to make yourself look good and the opponent to look bad. Either make up an issue you may safely imply exists based on your interpretation of the opponent/opponent arguments/situation, or select the weakest aspect of the weakest charges. Amplify their significance and destroy them in a way which appears to debunk all the charges, real and fabricated alike, while actually avoiding discussion of the real issues.
5. Sidetrack opponents with name calling and ridicule. This is also known as the primary attack the messenger ploy, though other methods qualify as variants of that approach. Associate opponents with unpopular titles such as "kooks", "right-wing", "liberal", "left-wing", "terrorists", "conspiracy buffs", "radicals", "militia", "racists", "religious fanatics", "sexual deviates", and so forth. This makes others shrink from support out of fear of gaining the same label, and you avoid dealing with issues.
6. Hit and Run. In any public forum, make a brief attack of your opponent or the opponent position and then scamper off before an answer can be fielded, or simply ignore any answer. This works extremely well in Internet and letters-to-the-editor environments where a steady stream of new identities can be called upon without having to explain criticism reasoning — simply make an accusation or other attack, never discussing issues, and never answering any subsequent response, for that would dignify the opponent's viewpoint.
7. Question motives. Twist or amplify any fact which could so taken to imply that the opponent operates out of a hidden personal agenda or other bias. This avoids discussing issues and forces the accuser on the defensive.
8. Invoke authority. Claim for yourself or associate yourself with authority and present your argument with enough "jargon" and "minutiae" to illustrate you are "one who knows", and simply say it isn't so without discussing issues or demonstrating concretely why or citing sources.
9. Play Dumb. No matter what evidence or logical argument is offered, avoid discussing issues with denial they have any credibility, make any sense, provide any proof, contain or make a point, have logic, or support a conclusion. Mix well for maximum effect.
10. Associate opponent charges with old news. A derivative of the straw man usually, in any large-scale matter of high visibility, someone will make charges early on which can be or were already easily dealt with. Where it can be foreseen, have your own side raise a straw man issue and have it dealt with early on as part of the initial contingency plans. Subsequent charges, regardless of validity or new ground uncovered, can usually them be associated with the original charge and dismissed as simply being a rehash without need to address current issues — so much the better where the opponent is or was involved with the original source.
11. Establish and rely upon fall-back positions. Using a minor matter or element of the facts, take the "high road" and "confess" with candor that some innocent mistake, in hindsight, was made — but that opponents have seized on the opportunity to blow it all out of proportion and imply greater criminalities which, "just isn't so." Others can reinforce this on your behalf, later. Done properly, this can garner sympathy and respect for "coming clean" and "owning up" to your mistakes without addressing more serious issues.
12. Enigmas have no solution. Drawing upon the overall umbrella of events surrounding the crime and the multitude of players and events, paint the entire affair as too complex to solve. This causes those otherwise following the matter to begin to loose interest more quickly without having to address the actual issues.
13. Alice in Wonderland Logic. Avoid discussion of the issues by reasoning backwards with an apparent deductive logic in a way that forbears any actual material fact.
14. Demand complete solutions. Avoid the issues by requiring opponents to solve the crime at hand completely, a ploy which works best for items qualifying for rule 10.
15. Fit the facts to alternate conclusions. This requires creative thinking unless the crime was planned with contingency conclusions in place.
16. Vanishing evidence and witnesses. If it does not exist, it is not fact, and you won't have to address the issue.
17. Change the subject. Usually in connection with one of the other ploys listed here, find a way to side-track the discussion with abrasive or controversial comments in hopes of turning attention to a new, more manageable topic. This works especially well with companions who can "argue" with you over the new topic and polarize the discussion arena in order to avoid discussing more key issues.
18. Emotionalize, Antagonize, and Goad Opponents. If you can't do anything else, chide and taunt your opponents and draw them into emotional responses which will tend to make them look foolish and overly motivated, and generally render their material somewhat less coherent. Not only will you avoid discussing the issues in the first instance, but even if their emotional response addresses the issue, you can further avoid the issues by then focusing on how "sensitive they are to criticism".
19. Ignore proof presented, demand impossible proofs. This is perhaps a variant of the "play dumb" rule. Regardless of what material may be presented by an opponent in public forums, claim the material irrelevant and demand proof that is impossible for the opponent to come by (it may exist, but not be at his disposal, or it may be something which is known to be safely destroyed or withheld, such as a murder weapon). In order to completely avoid discussing issues may require you to categorically deny and be critical of media or books as valid sources, deny that witnesses are acceptable, or even deny that statements made by government or other authorities have any meaning or relevance.
20. False evidence. Whenever possible, introduce new facts or clues designed and manufactured to conflict with opponent presentations as useful tools to neutralize sensitive issues or impede resolution. This works best when the crime was designed with contingencies for the purpose, and the facts cannot be easily separated from the fabrications.
21. Call a Grand Jury, Special Prosecutor, or other empowered investigative body. Subvert the (process) to your benefit and effectively neutralize all sensitive issues without open discussion. Once convened, the evidence and testimony are required to be secret when properly handled. For instance, if you own the prosecuting attorney, it can insure a Grand Jury hears no useful evidence and that the evidence is sealed an unavailable to subsequent investigators. Once a favorable verdict (usually, this technique is applied to find the guilty innocent, but it can also be used to obtain charges when seeking to frame a victim) is achieved, the matter can be considered officially closed.
22. Manufacture a new truth. Create your own expert(s), group(s), author(s), leader(s) or influence existing ones willing to forge new ground via scientific, investigative, or social research or testimony which concludes favorably. In this way, if you must actually address issues, you can do so authoritatively.
23. Create bigger distractions. If the above does not seem to be working to distract from sensitive issues, or to prevent unwanted media coverage of unstoppable events such as trials, create bigger news stories (or treat them as such) to distract the multitudes.
24. Silence critics. If the above methods do not prevail, consider removing opponents from circulation by some definitive solution so that the need to address issues is removed entirely. This can be by their death, arrest and detention, blackmail or destruction of their character by release of blackmail information, or merely by proper intimidation with blackmail or other threats.
25. Vanish. If you are a key holder of secrets or otherwise overly illuminated and you think the heat is getting too hot, to avoid the issues, vacate the kitchen.
Please ZL, no voting, no filters, no bureaucracy. People with some technical background can decide for themselves if they read or skip a message. I had to laugh with the posting of "that_prophet". Your post about disinformation is great, but don't underestimate the visitors at this forum. We are not believers in the way religious people do or adherents of an ideology. The only similarity is that we believe in miracles.
Berto3,
I am glad you liked the information about the disinfo methods.
My suggestion would not change the present functioning of the forum, you and other members will still have to decide on your own what to read and what to ignore, just like now. My suggestion would only add two extra categories to the forum and few extra threads, which don't exist at the moment. The purpose of these extra categories is to offer assistance to those who wish to use them. Nobody would be forced to read these two extra categories, and nobody would be forced to participate in creating and maintaining those lists and filters. It is all purely voluntary.
I am not a beginner in FE research and I can also recognize most of the hoaxes without investing much time, effort, and money. However, I would be very thankful if some altruistic people with lots of free time and patience would be kind enough to read through those 17000 threads, and pre-mine useful information for me.
I have got no time to read this huge amount of text. So I have got no idea what good info nuggets might be hidden at the bottom of this heap of threads. There is no chance for me to ever find them if somebody doesn't post into those threads to make them appear on the front page, and make me curious enough to check them out. Even if this would happen, and I would visit the front page while it is listed, and would check it out, the thread might be so long in itself that I would not be able to read all the posts in it, and might miss something very useful and important, hiding within that thread. Therefore a mining of useful threads, information, and inventions can be only beneficial, and help people. This does not involve bureaucracy, because no threads and no posts will get deleted. Only extra information offered for those interested.
Bureaucracy is not involved when mining threads that are deemed to discuss genuine FE generators or principles. Every volunteer can collect and offer his own selection and simply post his list in a specified thread. The vote can be organized by Stefan or a moderator entrusted by Stefan at an independent online voting platform. This is not bureaucracy, but simply the right of a site owner, and a source of possibly useful information. Again you don't have to read the results of such polls, you may ignore it if you wish so. The evaluation of inventions based on objective merits does not require bureaucracy either. It is put together based on facts supported by proofs. If necessary, again everybody can have his own version of this offered, besides perhaps the one generated by general consensus and offered by the site owner. The same arguments are valid for creating the list of obvious hoaxes as well. Therefore I don't see any reason why would this hinder your activities and research (unless you wish to support the disinfo campaign).
Quote from: Berto3 on July 06, 2016, 07:02:46 AMPeople with some technical background can decide for themselves if they read or skip a message... but don't underestimate the visitors at this forum. We are not believers in the way religious people do or adherents of an ideology. The only similarity is that we believe in miracles.
It is a mistake to generalize, and assume that if you can easily recognize hoaxes, then all the other researchers with good intent must be able to do the same. I am convinced that the majority of the researchers who read this forum (not only members who post) can not recognize the hoaxes. There is countless proof of this on this very forum. Just take a look at the great interest in pursuing hoaxes like Keshe, Kapanadze, Milkovic, MEG, etc. Apparently many genuine researchers with honest intent and good heart are not able to recognize hoaxes, especially when they are not as trivial as the one of Chas Campbell.
Therefore I still maintain that such added feature and effort would be very useful to many, myself included, and it would not hinder genuine researchers who would still not want to use it.
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
How many useless threads about the exact same thing does this guy have to start before someone bans him?
In theory, there is no difference between theory and practice. In practice, there is.
ZL
The claim of 'energy cartel disinformation campaign' is baseless. There are NO 'OU' devices in existence, PERIOD. Saying that you infer something does not make it a fact.
Now, you will likely brand me as a disinformation agent. I wish they would pay me.
But there is free energy devices. 1 solar panel, yes we all know it get it energy from the sun.
That is all good but it is free energy. 2 any living trees again it generate oxygen and so much other very useful
stuff to much to mention. 3 the sun the source of so much energy all the fossil fuel was generated from the sun..
3 the whole universe run itself very quietly from its own recycling process all free energy..
ALL energy is essentially free; we pay for extraction, processing, transportation and: wait for it: PROFIT, that evil word.
This site is not about free energy, but OU.
free energy is done using pulleys
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS THE GEM OF AC ELECTRICITY MULTIPLIERS
GEM =(Geometrical Electricity Multiplier)
Your device is useless!
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense. You have had numerous people tell you that your idea will not work. That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
MOTORS DO NOT RUN ON A SPARK OF ELECTRICITY!!! They have to have a continuous source of current that comes from a generator that requires torque to turn it. Follow the links I gave you and try to learn something instead of spamming this entire forum with your foolishness.
if you attach a 100cn circumference pulley to a DC motor
it only takes one spark of DC current to rotate DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley then.
you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have practically zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC + DC electricity
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
I happen to be Born Again + want this super simple free energy technology out
before the first Door closes for Christ to return in the clouds by or before 2019.04
It warns us that no one knows the day nor hour... but it says that we will know
when it is near... near to what? maybe the door.... as we can know "even at the doors"
This way the Tribulation Saints have it to keep warm in our cold Canadian winters
even off the power grid. (remember fires would give away your position)
Doors are plural because He does show up twice = Rapture + at end of Tribulation
BETTER EXPLAINATION
Re: GEM=(Geometrical Electricity Multiplication)
« Reply #61 on: Today at 01:09:57 PM »
by that_prophet@yahoo.ca
= joe Lynch
Just one of His Creations
Using pulley mechanics to multiply AC electricity
I was hoping that I could enrage many deceived people,
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this tech is used + not oil burning engines,,, which funds terrorist)
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
--- All through what seemingly legally breaks the laws of thermodynamics
--- --- by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your rotations = AC electricity
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing,
I mean those who had actually built working models
the Book that I put all of my faith in is the Word of God
+ if you want to see how the Holy Bible can prove itself God inspired
you should read a novel called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
after 10 times the original duration
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
Posting this a multitude of times is not going to change
The fact that it does not work.
See my post in the other thread.
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a DC motor with a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM-(Geometrical Electricity Multiplier) device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. (As for torque, it only comes from generating power, and power is voltage multiplied by current) + We only need to produce one single spark of DC current to make this a self-powering mechanism. So one spark of DC current, (which is practically nothing) multiplied by even massive voltage, would still equal practically zero power, which takes practically zero torque to rotate.
This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity. This AC generator takes no torque to rotate, because although it would be winding up massive voltage, it does not need to be winding up practically any current-(1 mere spark) which is practically zero. Torque is only caused when you are generating power, and you are generating practically zero power, as power is equal to voltage times current. So, no matter how massive of voltage you are generating, it is multiplied by practically zero current, as we only need one spark of current, or practically zero. This works because zero times anything is still equal to zero, and practically zero works the same way.
What is AC electricity, + how is it made = it is made out of the easy rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain you 1000 = 100X10 cycles of AC electricity.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) to keep this GEM mechanism running, you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating you massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached?
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, is when this GEM tech will be needed most. This will be the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (How can we be billions of years old, when the moon will leave orbit within 10,000 years) + all orbiting bodies will have messed up orbits, because of this yearly amount of space debris adding mass.
This is free energy technology, which we all will need and love, as it has practically no cost to run, and there is no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? Evil spirits are, and have been hiding this simple technology from mankind. These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God + not from evil forces, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity.
This is one super simple GEM of an idea, and it is made from pre-school technology, so why was this not out long ago. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. I still have problems getting people to believe that there is no torque problem. Think that this may actually be a good enough reason for you to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one or more mini-pulleys of only one centimeter circumferences, All that you have to do is add an AC generator to these mini-pulleys, giving you a free return of 100's of cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
IT IS TRULLY THAT SIMPLE
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
PROOF OF CREATION + A YOUNG EARTH = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years. Less than 10,000 year
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120 volt, + 12 volt, to powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16. http://aliensandghosts.yolasite.com/
Most people have heard that the "day + hour knoweth no man"-(Mat 24:36), but why does nobody mention the soon arriving doors that we are not only allowed to know, but in the original Greek, it is worded like a command = "know that it is near, even at the doors",,, + that 1st Door will close on 2019.04 + the last Door will close on 2025.94. So we are guaranteed that Jesus will set His foot on the Mount of Olives before the year 2026.
Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural, because of the two appearances of Jesus, the first is in the clouds,(Rapture) http://rapturequestion.yolasite.com/ before the 7 year peace treaty is signed + then His second arrival is as His Foot touches earth, on the Mount of Olives. DOOR = (this is not the date of His Arrival, which we are warned that nobody can know, but this is the date that Christ must return before) A day that the Tribulation Saints will not only know, but they will probably being counting down the days until. = (He Returns when the 7 year peace treaty ends)
EVil-sOLUTION = isn't it amazing what Truth can be revealed, when the "il-s" of life are included. http://decimationofthisevolutionfairytale.yolasite.com/
I can give you a free to run, perpetual power supply = http://free-energy.yolasite.com/ This GEM mechanism can do this because of how AC electricity is created by rotations. as in the more rotations the greater amount of AC electricity, and pulleys can be used to multiply rotations. So, you are using pulley mechanics to multiply your total amount of AC electricity, by trading one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference pulleys as you choose to add to the same belt. If you add AC generators to these mini-pulleys then you could be multiplying AC electricity. If you added 4 of these mini-pulleys with AC generators attached, you would gain 400 cycles of AC electricity, and all for the single burst of DC current, the minute amount of current that a DC motor takes to rotate one single time.
These mini-pulleys would be easy to rotate, as the only resistance that they would generate, would be caused by any power that they were generating. These mini-pulleys would only be winding up massive voltages, because the only current needed to rotate your large 100 cm pulley on a DC motor, is one simple spark, or short burst, the amount to rotate your large pulley only one single time. Torque is only caused when you are generating power, and power is generated by current multiplied by voltage. Since we only need one single spark of current, (practically zero) the total amount of power being generated would still be practically zero, costing practically zero torque.
This was given to mankind before the first door closes = http://my2020vision.yolasite.com/
Especially for the soon coming Tribulation Saints http://doorschristmustpassthrough.yolasite.com/
Sorry if it offends you, that I add a little bit of Biblical stuff in my explanations, but when I came up with this super simple idea, it was just after asking God for a way to help the Tribulation Saints. Just think about how super simple this AC electricity multiplier truly is, and how the voices in your head tell you that it cannot work. When how much more simple can it be, then to only pay for the one rotation of a large 100 cm pulley, when you can get a return of 100 cycle of AC electricity, for every 1 cm mini-pulley that you attach to the same belt, (with AC generators attached). Yes that's an input of one single spark of DC current, returning you 100 cycles of AC electricity for every mini-pulley that you attach to the same belt. If you only added 4 mini-pulleys, you would get a return of 40 cycles of AC electricity. Please remember, that there is a most powerful spiritual warfare going on over this GEM technology.
There is a most powerful spiritual warfare going on over this GEM technology. Can you believe the problems that I have had, getting this super simple way of using pulleys to multiply the total amount of AC cycles of electricity? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations, so you are effectively multiplying AC electricity. .
Here is what I wrote in my GEM forum, the place that I write in MOST often
FREE ENERGY FROM 1 ROTATION OF DC MOTOR + 100 cm circumference PULLEY = GIVES YOU 100 ROTATIONS OF AC GENERATOR ON A 1 cm circumference PULLEY ------ TESLA RULES ----- (+ don't listen to the torque lie, as there is no torque problem, because even though you are generating massive voltage-[which is exactly what you need to crank over your large pulley] you only need to generate one mere spark of current, (the amount of current that it takes to crank over the motor one single time) + power is calculated by voltage time current, so even massive voltage multiplied by practically zero current, still equals practically zero power, costing practically zero torque)
Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier)=AC type - free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one large pulley attached to a DC motor, + at least one mini-pulley, (the smaller the better) connected to AC generators, both motors must be of the same voltage, 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor's needs), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together. This has to be dirt simple + cheap to build, as the people that will need to be built this are the soon coming Tribulation Saints, whom cannot buy or sell. The Door closes on the peace treaty signing on 2019.04 - http://my2020vision.yolasite.com/
This works on the simplest of principles, the principles of basic preschool pulley mechanics, where you only have to pay the small amount of electricity,(only a spark) that it takes to gain one single rotation of a DC motor, with a large 100 cm circumference pulley attached to it. With this one rotation of a large pulley, you can freely gain a long length of 100 cm of moving belt, which will give you a multiple of 100 rotations, for your one rotation of a DC motor. This could be multiplied by as many 1 cm circumference mini-pulleys that you wish to attach to this same belt. Then all that you would have to do is, attach AC generators to each of these mini-pulleys that you choose to attach to the same belt as your large 100 cm pulley.
You could freely gain 1000 cycles of AC electricity from this single burst of DC current, if you chose to attach 10 mini-pulleys to the same belt/strap, with AC generators attached to each one. Please don't listen to these fake worries about torque being a problem, as these mini-pulleys would run free of any torque, as torque comes from when you need to generate power. Power is calculated by multiplying voltage time current, and although your many rotations of these mini-pulleys are generating massive voltage, (which is exactly what you need to crank over your DC drive motor), you are in need of only one mere spark of current. So, even massive amounts of voltage, when it is multiplied by the almost zero amount of current that it takes to rotate a DC motor once, it would equal out to practically zero power, cost practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by adding an AC generator to your mini-pulley, you are actually multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage + practically no current, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor once. This one rotation of a large 100 cm pulley, can be converted into 100 rotations of a mini-pulley of 1 cm circumference. Since AC electricity is created by rotations, and more rotations is more AC power, multiplied rotation is equal to multiplied AC electricity.
