I do not often cover pure science, but this could be a major breakthrough.[/font][/size]
New research suggests that it is possible to create a new form of light by binding light to a single electron, combining the properties of both. According to the scientists behind the study, from Imperial College London, the coupled light and electron would have properties that could lead to circuits that work with packages of light - photons - instead of electrons.[/font][/size]
http://revolution-green.com/binding-light-single-electron-combining-properties/ (http://revolution-green.com/binding-light-single-electron-combining-properties/)
Kind Regards
Mark
Combination from experiment results
https://innovatechbuild.com/tag/lighting/ (https://innovatechbuild.com/tag/lighting/)
"In their experiments, the team was able to generate 69 picowatts of light from just 30 picowatts of energy. They did so by harnessing waste heat, which is caused by vibrations in the bulb's atomic lattice, to compensate for the losses in electrical power. The device also reacts to ambient heat in the room to increase its efficiency and power the bulb."
and "quantum computering"
will become a "energy source" and not a "consumer".
okay ! including the transmission steps light-to heat-to-electricity-to-light, a circuit/cycle process.
+ quantum neuronal logic : superposition
http://www.popularmechanics.com/science/a22179/flexible-quantum-computer-reprogrammed-with-lasers/ (http://www.popularmechanics.com/science/a22179/flexible-quantum-computer-reprogrammed-with-lasers/) ~ parallel network
+ http://www.engineering.com/DesignSoftware/DesignSoftwareArticles/ArticleID/11076/MIT-Cracks-Nanoscale-Heat-Transfer-Calculations.aspx
+ https://www.nasa.gov/sites/default/files/atoms/files/arc-16211-1_optical_fiber_for_solar_cells.pdf
