https://www.youtube.com/watch?v=omUSfYuVT1c&t=0s
http://brilliantlightpower.com/suncell/
Being greater than ten thousand times brighter than sunlight, the corresponding reduction in the area of the photovoltaic converter gives rise to a projected cost of the SunCell® of about $50 to $100/kW compared to over ten times that for conventional power sources of electricity.
all comments welcomed
respectfully
Chet K
PS
thanks to member Tagor for bringing this Up
				Quote from: ramset on January 07, 2017, 09:56:49 PM
very good
ramset : wait and see ( 2018 ) !
				These guys have been at this for quite some time and appear to be
progressing forward, as their advanced prototypes seem to produc more and more light
If my understanding of their process is correct (from their early experiments)
They give the oxygen an extremely negative charge, this bounds the shared electron
To shorter than plank distances to their perspective proton.
The strong force then separates the atoms from their ionic bond.
The negatively charged nitrogen is closely matched by the
Electronegativity of the Hydrogen atom in this small-orbit state.
Literally forming the electrical equivalent of anti-hydrogen,
Or an antiproton. This releases photons is the form of:
1s=>-1s
Transition back to the ground state takes place by the handshake
H(-) < H(+)
Matter + Antimatter = Matter + energy
This is contrary to the assumptions made by antimatter theory.
Which states that matter + antimatter = E^2
The two are mathematically equivalent since
E = mc^2
				I have never seen a convincing proof from BLP of the energy content of that bright light.  How do we know that the bright light is not just an underunity silver welding arc ?
They have never shown that graphite sphere absorb that bright light and heat up to incandescence (although that's excusable because heated graphite burns up in air. That's why they plan to surround it all with pressurized Argon).
Also, in
this video (https://youtu.be/AhIoDxjaibQ?t=1441) BLP states:
Quote from: Brilliant Light Power...a gas injector to inject hydrogen derived from water and an injection system comprising an electromagnetic pump to inject molten silver and a very stable solid source of oxygen that reacts with the hydrogen to form the hydrogen to hydrino catalyst.
Thermolysed H
2O or HO or HHO as a catalyst inside the graphite sphere is implausible because oxygen + graphite react and burn up when heated.
				Quote from: verpies on April 09, 2017, 10:11:51 AM
https://www.youtube.com/watch?v=4Bomq8S0ynQ
				Quote from: sm0ky2 on January 08, 2017, 11:05:25 AM
...and anti-hydrogen will not gravitate in space (it will gravitate in time) and shrink away from our 3D spatial frame of reference with the speed of light.
Quote from: tagor on April 09, 2017, 11:04:54 AM
https://www.youtube.com/watch?v=4Bomq8S0ynQ (https://www.youtube.com/watch?v=4Bomq8S0ynQ)
...but that's from 2009 when they did not even think of having two molten streams of silver enclosed in a graphite sphere.
If you have a video showing that sphere absorbing the extreme UV light on the inside and heating up to incandescence on outside, you will make a believer.
				Quote from: tagor on January 08, 2017, 01:17:00 AM
very good
And just how long has Mills been telling us to "wait and see"?  Answer: since 1991.
Here's a prediction: In 2018, we (and investors) will once again be told.... "wait and see". Perhaps by 2020?
Lather rinse repeat.....
More info:
https://en.wikipedia.org/wiki/Brilliant_Light_Power
				Quote from: TinselKoala on April 09, 2017, 02:24:36 PM
Looks like 25 years ;) , ...but their power density has been improving exponentially with time ...and now they showcase a working prototype that you can see
here (https://youtu.be/AhIoDxjaibQ?t=3756).
Quote from: TinselKoala on April 09, 2017, 03:00:38 PM
The claim by BLP, however, is implausible, because that much energy and that high temperature, combined with the evolved gases, would destroy that nice graphite sphere structure in a minute. ("minute" here meaning an unspecified but relatively short time interval.)
Elsewhere in the video that is addressed by pressure equalization outside and inside of that graphite sphere.
Inside the sphere is silver, and the atmosphere of 97% Argon and 3% Hydrogen so no potential for chemical reaction and the evolution of additional gasses...unless water or oxygen gets in there.
What miracle solder is used to solder up that copper piping?
Elsewhere in the video that is addressed by retracting these heating coils after the initial startup (the silver melting phase) and pumping water through these coils/pipes to cool them and the remainder of the apparatus..
@TK
I am just answering your questions because it seems that you have not watched all of the available videos.
I am not a believer.  I would be if I saw that graphite sphere heated up to incandescence.  So far I have not - just spetroscopy and calorimetry measurements in
this video (https://www.youtube.com/watch?v=AUKsOxCn8Ac&t=1029s).
				@Wesley
In this video (https://youtu.be/AhIoDxjaibQ?t=4290) there is the claim of 3000ºK temperature of the graphite sphere (the black body radiator).
Also watch this (https://youtu.be/AhIoDxjaibQ?t=997).
According to the Stefan-Boltzmann law (https://en.wikipedia.org/wiki/Stefan%E2%80%93Boltzmann_law), which states how many Watts of photon radiation is emitted from a blackbody surface of 1 square meter area:
1m2 at 100ºC emits 1.1kW of light        (the temperature of boiling water)
1m2 at 2227ºC emits 2.2MW of light     (the temperature of the filament in a common incandescent light bulb)
1m2 at 2727ºC emits 4.6MW of light     (3000ºK)
1m2 at 3000ºC emits 6.5MW of light     (the temperature of the filament in a halogen incandescent light bulb)
1m2 at 3422ºC emits 10.6MW of light   (the melting temperature of Tungsten)
1m2 at 3642ºC emits 13.3MW of light   (the sublimation temperature of Graphite)
1m2 at 3880ºC emits 16.9MW of light   (the melting temperature of Tantalum Carbide)
1m2 at 4727ºC emits 35.4MW of light   (5000ºK)
1m2 at 5327ºC emits 55.8MW of light   (The surface of the Sun at 5600ºK)
1m2 at 5930ºC emits 84.0MW of light   (the boiling temperature of Tungsten)
More than 99% of the light coming out of Randall Mill's SunCell is in the invisible hard UV range (10nm - 250nm).  Photovoltaic cells are insensitive to these wavelengths !!!
That's why Mill's surrounds his plasma with a graphite sphere that is supposed to absorb the UV light and heat up to 3000ºK, which makes it glow with blackbody radiation (https://en.wikipedia.org/wiki/Black-body_radiation) on the outside of that sphere...effectively re-emitting the energy in the form of longer wavelength light.
Blackbody radiation at 3000ºK consists of much lower light frequencies, to which photovoltaic cells are sensitive to.  To achieve ~40% light-to-electricity conversion efficiency, these PV cells must be the expensive 3-layer kind.
This UV --> GlowingBlackbody --> PV --> Electricity conversion, is the Achille's heal of his device, especially that graphite burns up in oxygen at these temperatures, unless it is surrounded by Argon, etc...
This video (https://www.youtube.com/watch?v=CtA4FdRrCkY) contains more information.
...and this video (https://vimeo.com/194678559) is a review of their developments by a 3rd party.
				If this company is still In New jersey [the actual unit ?
may be able to get a visit there ?
maybe Wesley would like to go too?
we shall see ?
respectfully
Chet K
				Quote from: ramset on April 09, 2017, 03:48:58 PM
we shall see ?
respectfully
Chet K
If you visit the company and ask questions, look around, etc. do you really think they would show you or tell you anything that could disconfirm or falsify their claims?
				@verpies: No, I did not watch those entire videos. The first few seconds of the first one was enough for me... the boilerplate legal disclaimer that basically says "this presentation contains forward looking statements that may not actually be true." So I turned it off and went out to mow the lawn. At least I know for sure I'm performing work when I do that!
Wouldn't you like to see the wiring and connectors that allow somebody to get 6 megawatts of continuous power out of something that basically could fit in a one-car garage?
				Quote from: TinselKoala on April 09, 2017, 05:04:21 PM
Don't give them money then.
...but you should look at the technical aspects of their claims and try to identify any technical flaws even if it is for the purpose of busting an investment scam.  You already raised some points (gas evolution, pipe soldering)
I raised another one: Any water inside the graphite sphere will thermolyze at 3000ºK to oxygen and react with the graphite...effectively burning it up.
I would ! ...although the claim is for 330kW of electricity because the sphere does not have a surface of 1m
2. and part of its blackbody radiation escapes as heat.
Even more, I'd like to see that sphere heated to incandescence.
				Quote from: stivep on April 09, 2017, 05:31:50 PM
Is it he is full of  scam  and trying to extract money from less fortunate in brain power but quite well with money ?
Verpies  convince me and you  will be beneficiary along with  rest of you charge free.
I cannot convince you because I am not convinced myself.  So at this time I am not a proponent of melting silver and doing expensive experiments.  I only advise gathering information at this stage.
I will be a believer if I see that reaction chamber heated to incandescence.  So far I have not.
I think that they are not cheating on the spectrum of that bright light, but they might be wrong about its intensity.  It might be just a glorified underunity silver
electric welding arc.
Also, I see an engineering error in the practical design, namely: any water in that chamber at 3000ºK will become thermolized to oxygen and that will react with the graphite...effectively burning it up.
Anyway, they are located close to you, so if you can present yourself as a company man with big bucks, then perhaps you could drive there with Chet and verify the intensity of that light with some kind of
black bottle of water and a thermometer.
				In my opinion it shouldn't be difficult (https://www.youtube.com/watch?v=TBMfp5EsgZc) to organize arc discharge between silver electrodes underwater (or inside the water vapor) and to measure overunity.
For me this technology is very similar to plasma electrolysis (Mizuno) (http://jlnlabs.online.fr/cfr/) or Energoniva experiments (https://www.lenr-forum.com/forum/thread/4802-energoniva-a-water-plasma-transmutation-technology-from-russia/) from Russia (see YouTube (https://www.youtube.com/results?search_query=%D0%AD%D0%BD%D0%B5%D1%80%D0%B3%D0%BE%D0%BD%D0%B8%D0%B2%D0%B0)), which are also produced overunity and transmutations reportedly.
				Quote from: Zephir on April 10, 2017, 10:46:59 AM
Oh really?
Quote from: Zephir on April 08, 2017, 12:26:10 PM
We aren't here to discuss opinions, only facts or rational ideas. Once you have no evidence or at least indicia for your suspicion, then you're religious troll who believes in things without rational substance. A pathoskeptic troll being more specific. That's my opinion about you - like it or not.
				All links in my post are factual - no ideas, only experiments. Actually everyone, who ever attempted for plasma electrolysis and measured heat evolved during it reported overunity or COP ~ 5  - 10: Mizuno, Naudin, Vachayev, Bazhutov, Prosvirnov, Andi (https://www.freefromfuel.com/lenr/) and others - so that this process looks quite reliable.
				Zephir
I am told you want your own thread, please start your own thread
we actually have access to good people here that can arrange visits to places like the company mentioned in the tittle of this thread .
your libelous and disruptive behavior will insure that never happens here
Libel
a published false statement that is damaging to a person's reputation; a written defamation.
this is not what we do here !!
MOVE TO YOUR OWN THREAD
				I see: pathoskeptic liar accusing me of lies or even crime - the true nature of overunity forum reveals itself.
Just admit, that your very agenda is to prohibit the spreading of knowledge about overunity research here... :-)
Mizuno (http://www.rexresearch.com/mizuno/mizuno.htm)
Naudin (http://jlnlabs.online.fr/cfr/html/cfr10.htm)
Vachayev (http://rulev-igor.net/theme_171.html)
Bazhutov (http://www.e-catworld.com/2015/06/29/report-bazhutof-plasma-electrolysis-system-provides-up-to-6-times-excess-heat/)
Kanarev (http://www.making-hydrogen.com/plasma-electrolysis.html)
Prosvirnov (http://lenr.seplm.ru/)
Kanzius (https://nick2.wordpress.com/2007/09/14/kanzius-and-penn-state-chemist-rostum-roy/)
Andi (http://www.e-catworld.com/2016/03/07/diy-cold-fusion-experimenter-claims-cop-11-with-a-naoh-electrolysis-system/)
Mills (http://onlinelibrary.wiley.com/doi/10.1002/er.3142/abstract)
				Thank you !!
Zephir
Just admit, that your very agenda is to prohibit the spreading of knowledge about overunity research... :-)
Mizuno
Naudin
Vachayev
Bazhutov
Prosvirnov
Kanzius
end quote
I will be speaking again with Stefan in the next few days
he mentioned you would work in your own thread
seems you are not ,and also you are committing crimes {slander]
until you respect the rules here ,there is no point to your presence here.
				In which sense I don't follow the rules? I'm talking here just about overunity plasma water technology and I'm documenting every my claim.
Whereas you're coming here, attacking me hysterically - even accusing me of crime(!) - and doubting what I'm writing without arguments.
This forum is about exploration and discussion of overunity - not its dismissal and ridiculing its supporters.
You should be banned immediately from here with such an attitude.
				See also water spark plug (http://overunity.com/5024/urgent-water-as-fuel-discovery-for-everyone-to-share/#.WOytK5eLVyA) experiment of Ganga Shakti (https://www.youtube.com/watch?v=FxnRQ7fkWtE)
some answear in this video :
https://www.youtube.com/watch?v=Xqw9_72VWz4
https://www.youtube.com/watch?v=hVN7qf3DlX0
				Quote from: tagor on April 19, 2017, 11:20:55 AM
some answer in this video :
Which question does it answer?
				Quote from: verpies on April 20, 2017, 08:21:50 AM
can we manage 2 megawat in a garage with a plexiglas
				Quote from: tagor on April 21, 2017, 02:38:09 AM
can we manage 2 megawat in a garage with a plexiglas ?
At what time index (min:sec) is this shown?
I am sure Mr.Koala would like to jump to it and watch it.
				Quote from: verpies on April 21, 2017, 06:11:35 AM
				Breakthru news
 report PDF attached below
    Randy Booker Validation Report of Brilliant Light Power SunCell Published: Generation of Kilowatts of Excess Heat "Real and Reproducable"
https://e-catworld.com/2020/01/22/randy-booker-validation-report-of-brilliant-light-power-suncell-published-generation-of-kilowatts-of-excess-heat-real-and-reproducable/ (https://e-catworld.com/2020/01/22/randy-booker-validation-report-of-brilliant-light-power-suncell-published-generation-of-kilowatts-of-excess-heat-real-and-reproducable/)
