Overunity.com Archives
Energy from Natural Resources => Gravity powered devices => Topic started by: Meta on January 14, 2017, 02:45:25 AM
Title: Keshe Test by Westly
Post by: Meta on January 14, 2017, 02:45:25 AM
I happen to know the devise accesses gravity, so its posted here.
Westly's test
https://www.youtube.com/watch?v=TXcAIbgvK_I&feature=youtu.be
There's three metaphysical ideas that Westly needs to observe and practice.
1. It is said, by the learned, that one must believe in the devise...
2. It is said, that the devise will slowly increase in potential as more load is added to it.
3. It is said, that the wire that is connected to the devise, will become an energy producer in itself, eventually.
Title: Re: Keshe Test by Westly
Post by: Meta on January 17, 2017, 03:59:10 AM
Westly receives a package from a friend, seemingly, from Japan?
It's a Keshe generator worth $2,000 dollars.
One would expect Westly to use the Scientific Method upon this generator and for the preliminary beginning he does, in hooking the generator up to a load then takes measurements of wattage, amps and in and out voltages.
He finds, by his own words, the Keshe generator is producing overunity by 1%.
One would think that Westly would be interested in the long term performance of the generator, to scientifically determine if the generator outputs the same volts, amps and wattage over time or if it decreases or increases, since he has physical possession of the machine.
What does Westly do? He tares into the generator with two screwdrivers with violence. Only Putin's Russian bombers over Syria, bombing ISIS, is more aggressive....or maybe a Russian bear attacking the bald head of Keshe, would be a better analogy.
Westly and a friend, now virtually destroy a $2,000 overunity machine, and it now lays broken apart and in pieces on Westly's bench. Very scientific approach there. He further pulls wires out of a rolled up piece of paper with powder on it. This he scatters to the wind left un-analyzed, or at least he says he can analyze it on one of his machines in his lab but we never hear about it again, what's on the paper. Anyone can find what the powder is by following Keshes videos. Now Westly finds the ball in the middle of every coil of wire and its called the "gans". Westly picks at it and a hole in it reveals a gel inside but he doesnt analyze this either.
All in all, with the preliminary cursings of Keshe and the screwdriver treatment of the generator, I conclude the purpose of the tear down was not to actually analyze it and distribute information, but rather to bad mouth the name of Keshe and destroy his machine. Westly just thru away $2,000.
Post by: conradelektro on January 17, 2017, 07:21:50 AM
Quote from: Meta on January 14, 2017, 02:45:25 AM
Could you verify these metaphysical happenings? Did you observe and measure these wonderful happenings? Did you ever hold a device in your hands that did these metaphysical ideas?
I guess you report hearsay! I say, you read about these metaphysical ideas or you saw some YouTube videos. And now you believe them without any physical evidence.
Wesley has a pretty chaotic way doing his test of the device. He should have clarified the power factor on the output (he only shortly mentioned the power factor at the input) https://en.wikipedia.org/wiki/Power_factor . Such wonder devices which show a little bit more on the output than on the input work with a smaller power factor on the output. There is less real power at the output than on the input.
But at least Wesley had the device in his hands. Did you ever come close to such a device in the real world?
Greetings, Conrad
Post by: Hoppy on January 17, 2017, 09:57:11 AM
Quote from: conradelektro on January 17, 2017, 07:21:50 AM
Greetings, Conrad
If you ever do, then pass the parcel quickly.  :o
Post by: Kator01 on January 17, 2017, 08:04:38 PM
Hello,
hope this here will enlighten those who believe in this man:
http://www.keshefacts.org/ (http://www.keshefacts.org/)
also ties to the agent Gordon Duff and "Veterans today"
https://keshefacts.wordpress.com/2016/03/ (https://keshefacts.wordpress.com/2016/03/)
it´s  an unbelievable mess
Kator01
Post by: Meta on January 18, 2017, 11:45:33 AM
conradelectro
_____________________________________________________________
Notice I said,
"It is said, by the learned".
I speak to many other people other than to you. I learn what they have done with their own Keshe generators. The statements I made here pertains to these people. One of them is building his own generators and he is located in Peru. He claims his generators work and that he has sold several to the locals.
Tell me why I should verify it to you?
Will you not ignore what I offer?
Yes you will.
You've already made up your mind.
Westly could have verified his generator if he had the foreknowledge of waiting for the machine to begin to increase its potential slowly, over time, but that change is all but gone, since he destroyed the machine and has altered it.
Post by: conradelektro on January 18, 2017, 12:27:23 PM
Notice I said,
Yes you will.
Well, well, I was right, you have no first hand knowledge or experience. And therefore your uttering is worthless, just hearsay.
Yes, I will ignore what you offer. But not because I am ignorant. I ignore you, because you have nothing to report.
See, the biggest problem with all OU devices is that only people who have nothing to offer speak. It therefore is a question of believe. Believe is not verification!
You are entitled to believe whatever you want. But please separate that from proof.
Whatever Wesley did wrong, it does not prove the device would work. I know, logic is difficult.
Greetings, Conrad
Post by: Meta on January 18, 2017, 12:36:57 PM
conrade,
If you understand reality you would also know that there is no verification and there is no such thing as proof, no matter how many times you repeat that slogan....so you are lost before you begin.
Post by: conradelektro on January 18, 2017, 01:58:42 PM
Quote from: Meta on January 18, 2017, 12:36:57 PM
I might not understand much of reality, but I understand enough to question:
This would be a miracle. And to believe a miracle I would have to be present. Stories about such a miracle are just not enough.
But you may believe that, if it makes you happy.
Greetings, Conrad
Post by: forest on January 20, 2017, 02:27:09 AM
Agree. Imagine Kapanadze doing such a show and saying : guys you must now look at this device for a week and it will become overunity :-)
Post by: Meta on January 23, 2017, 04:23:36 AM
You clowns really imagine you're hotstuff with all your logical arguments, don't you, with 1103 pages of logic just on one attempt to duplicate Kapanadze. Don't lecture me about logic.
