Here is GEM =a simple free energy technology for the Tribulation Saints
((( NEWS of this ancient technology will change the world )))
http://free-energy.yolasite.com/
I have the MOST IMPORTANT NEWS
To share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM=(Geometrical Electricity Multiplication) technology will eventually lead us to a way of defeating + repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor)
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only have to put one spark of DC electricity into this GEM=(Geometrical Electricity Multiplier) mechanism, to get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it. This GEM of a mechanism runs by converting the 10 X100 = 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor, by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology works by only having to put one spark of DC electricity in, which can return you 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity. These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) + torque is caused by producing power, which is P=IV, or Amps=current multiplied by Voltage, and massive voltage times practically zero current, still equals practically zero power=torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering.
http://beliefstoliveby.yolasite.com/
This technology is in the Holy Bible = in Ezekiel 1:16 where he is describing what a UFO motor looks like while it's running so this technology will eventually lead us to anti-gravity as well as not only speeds approaching the speed of light but also the ability to do 1000 kph vectoring
I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. He was worried about the rumors that anyone who actually built a working free energy mechanism was soon after found dead. So, because he feared for his life, as well as the lives of his family, he asked me to not give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
Quote from: that_prophet on January 18, 2017, 05:13:14 PM
Why even mention this person then, since it is pointless asking you to put us in contact with him?
If you were smart, you would at least get some pictures of his work and post them here.
To each their own I reckon.
Sorry, but I promised this guy that I would not gidve out his name, as he was worried about the rumors about the people that had built free energy mechanisms soon would end up dead. I believe that this is so simple, that it can be built by most people, with even half of a mechanical minded attitude. You only need to attach a large (100cm circumference) pulley to your DC motor, and at least one mini-pulley (1cm circumference) to an AC generator, and then connect them together with a belt, strap, rope or string. Then you put your AC generator output into your full wave bridge rectifier,(4 diodes) and connect the DC output to your DC drive motor. If you have it all connected right, you should be able to start this mechanism running by giving he large pulley a slight turn by hand. This motor + these generators would need to be the same voltage
Quote from: Dog-One on January 20, 2017, 07:56:21 AM
Hi all, Hi that_prophet, the stationary bicycle generator is coming along.
Have the main structure built, need to get some parts for mounting the bike and then a long v-belt.
The bicycle has a 28" wheel, so i guess that makes the rim around 26.5 inches in diameter.
Not sure if that is a large enough diameter to see effects.
The main intention is to use it for exercise, fun and charging 12 volt batteries for powering my efficient lights.
The secondary intention, is to hook up a motor by chain, to the pedal sprockets and test out what that_prophet has been sharing with an amazing determination.
peace love light
This is really very simple technology, as it use the circumference change in a large pulley=(100 cm circumference), + using the belt off it's one rotation,(100 cm of belt) to multiply the # of rotations of a small pulley,(1 cm circumference) + thereby multiplying your AC electricity, by adding AC generators to your small pulley. Turning one rotation of a DC motor into 100 rotations of the small pulley + getting an output of 100 cycles of AC electricity. (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor.
Quote from: SkyWatcher123 on January 20, 2017, 09:07:12 PM
peace love light
Quote from: that_prophet on January 23, 2017, 06:58:13 AM
When you understand even the tiniest crumb of this subject, that_prophet, you will realise what a knob you are.
"thereby multiplying your AC electricity"
no multipling frequency .... to power what ? USA runs on 50hz
" (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor"
DC motors dont run on "sparks" , is a spark an electrical quantity ?
a spark across a gap is current , practically NOT zero , have you seen commutator bars and brushes after there has been "sparks" ?
one_christian_warrior / that_prophet , the devils got ya in the head and you wont wake up
Hi all, i like his spirit and i am aware of the Wilson wheel and the Tilley generator.
Both of these have claimed similar effects from using either large masses or large wheels, with small generator pulleys.
I have finished the stationary bicycle generator main build, i need a long belt now.
The alternator, is a 48 volt from hydrogen appliances, i bought it many years ago and never used it, it has a built in rectifier.
Remember, we can agree to disagree, ultimately, all that really matters, is to be kind to one another.
Here is a couple pics of project so far.
peace love light
Skywatcher
your path is a wonderful option ,
A build to Teach [and possibly Learn ??
with much Gratitude and respect
Chet K
You will discover, Skywatcher, what you probably already know, and what our "prophet" apparently doesn't: it does indeed take some torque to rotate the generator's pulley, and the higher the voltage output the more torque it takes. And the more generators you have, the more power you need to input from the drive motor to turn the big wheel. This is what people have been trying to explain to "that prophet" for many years in at least 14 different threads.
In fact anyone who remembers riding their 10-speed bike with a generator for the headlight knows this: when you flip the generator down to contact the wheel, the bike becomes harder to pedal. Add a bunch more generators and you will eventually get to the point where you can't pedal at all because the drag caused by generating electricity is too great.
The story about someone getting this to "work" can only be true for certain limited definitions of "work". For sure, there is no such system that is self-sustaining, and to claim that there is.... well, coming from someone who professes to be a Christian, the claim is very sad to read. It has the same connection to reality as my claim that I have a herd of invisible pink unicorns in my backyard. Not only do I not provide any evidence for my unlikely claim... it would also violate local zoning ordinances.
Now if you will excuse me I have to go feed the unicorns.
Quote from: massive on January 23, 2017, 04:20:54 PM
The thing is if a highly efficient motor fed from an efficient friction less balanced dynamo might just work with a battery to charge in the circuit if the friction was almost eliminated to less than the charging gain.
The other thing Jesus wasn't a christian he was a Rabbi and any way it's just a title, and none of the biblical names exist it was all made up by the Emperor of the time and the Pope Sylvester and further God is short for Gadre'el who in the book of Honoc is Satan's real name, infarct the bible king James has over 260 errors ! from the original Arabic Hebrew scriptures, which are the oldest know written on local reed parchment to within AD30, so if you worship god it could be the wrong guy. Just thought i wold point out the truth for once :) :)
buddah wasnt a buddhist
http://www.energyscienceforum.com/showthread.php?t=1770
no mention of where one will find a DC motor that operates on a spark
http://free-energy-info.co.uk/Chapt19.html this has been around a long time .
its great skywatcher is going to whack together a bike gen but is prophet going to learn from it?
who's really running the show ?
https://www.youtube.com/watch?v=21FXqEWObLA&list=TLGGmacxG9RTarcyMzAxMjAxNw
and Todays Google image results from Antarctica
https://www.youtube.com/watch?v=wTM19wewp3w
warming is melting away ice which Hid old secrets ??
L Ron Hubbard wasn't a Scientologist
In fact he even went so far as telling people that it was
Complete b.s. Before he wrote it...
But they believe it anyways
That's the thing about gods unicorns and perpetual motion
They are just as hard to disprove as they are to prove...
Sure you can easily make a poorly designed "ou" motor
And prove that yours does not work
You could even provide evidence and theory about why
It can't work
But at the end of the day we are surrounded by forces that
Create lava, ice, tornados, and lightning
Why on earth are we trying to build an "isolated system"??
I think these physicists are trying to pull a fast one on us
Quote from: TinselKoala on January 24, 2017, 06:37:00 AM
TK: "the higher the voltage output the more torque it takes." is
IN REALITY a flawed statement, though I am certain you know the difference and meant to write current output or power output or wattage output - rather than "voltage output". Right?
Otherwise however, in general you are correct about
this system which that_profit continues to insist will function, but
IN REALITY does not.
It does not work
as presented for many well understood reasons;
BUT it does IN FACT shed a scintilla of light on one of several necessary requirements I am aware of in the design of
systems that can self-sustain .
In a system intended to self-sustain:
There needs to be a
voltage differential in order to be able to effect _a _c _c _e _l _e _r _a _t _i _o _n!
Will you tell everyone: What happens (that neither of us can stop) when any Matter is accelerated?
Please
Michael
I have a diagram of this mechanism on my web page
peace love light
"One spark of DC electricity is all that it takes to turn a large 100cm circumference once + this gives you 100cm of moving belt. You can get an output of 1000's AC cycles, by using many=10 mini-pulleys of 1cm circumference with AC generators attached. There is no torque problem, as your AC generators are just winding up massive amounts of voltage,,, with only one spark of current "
^^^ this is the first line on your link
what is one spark of DC electricity ?
what is it measured by ?
do you know that alternators take current to energise the rotor ?
is there now a torque problem from that ?
the word Electricity comes from the word electron = CURRENT
you can only be meaning to be trying to describe simple magnet rotor passing coils .
Large alternators when left open circuit generate hi volts and the next thing that happens is they arc across the coils.....a problem.
I doubt you have done research into components or you would be able to provide detailed info , theres none on your site or on your threads ...any of your many threads on the internet.
we all know your situation , so your concept is not based on experimentation but theres nothing to stop you from reseaching the components
https://www.electronicspoint.com/
if you bothered to look on overunity you would see there are loads of threads of projects or concepts where people are trying to over come electrical problems of torque , lenz law , losses etc
TIME IS VERY SHORT, + WE ARE LIVING IN THE END TIMES...
Why I believe that ISRAEL'S 7 YEAR PEACE TREATY MUST START
BEFORE JAN 15, 2019 = http://2020-vision.yolasite.com/ = 1st Door
Here is a GEM of a simple free energy technology, GEM= (Geometrical Electricity Multiplication)
This was given to me by my Father, + is for the Tribulation Saints. This could be easily built, out of one large pulley,(100 cm circumference) with a DC drive motor, a belt + at least one mini-pulley,(1 cm circumference) with an AC generator attached, to be used as your multiplier. The other things that you need are, a mounting frame + materials for your AC+DC generators/motor + full wave bridge rectifiers, one for each AC generator that you attach, to convert your AC outputs back into a DC for your drive motors input. These AC+DC motors must be the same voltage, for this mechanism to work smoothly.
((( NEWS of this ancient technology will change our world )))
I have the MOST IMPORTANT NEWS = http://free-energy.yolasite.com/ to share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome GEM of a God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM technology will eventually lead us to a way of defeating + even repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor) = with sparks even=color of "beryl". Unfortunately, this free energy technology is meant for the Tribulation Saints, and the door closes for it to happen within the same generation that saw Jerusalem in the control of Israeli forces, on January 15, 2019
This works by only having to use one spark of DC electricity to rotate a 100 cm circumference pulley once, and then you get as an output, one to ten times 100 units of AC electricity, by connecting your AC generator to 1 cm circumference pulleys. These 1 cm mini-pulleys only need to wind up massive voltage, with practically no current, (you only need 1 spark) to rotate your large 100 cm circumference pulley.
Now Satan, and his evil followers, do not want this free energy technology to get out to the world. They use the torque argument, along with the laws of thermodynamics, to pull most people from even taking a second look at this technology. When this technology uses simple ideas, like it does not take 100 times more energy to rotate a 100 cm circumference pulley, yet you can get the 100 cm of belt to rotate 10 of the 1 cm circumference 1000 times, and if you attach AC generators to these 10 mini-pulleys, you could get 1000 cycles of AC electricity.
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only need to put one spark of DC electricity into this GEM= (Geometrical Electricity Multiplier) free energy mechanism, to rotate your DC motor once, and get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 1 to 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it + rotates 100 times, returning you 1000 cycles of AC electricity.
This GEM of a mechanism seems to defeat the laws of thermodynamics by using large differences in circumferences of pulleys to multiply your # of rotations, + using AC generators to convert the 1to10 X100 = 100 to 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor. AC electricity is converted into DC electricity by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology is so simple in its workings, because you only having to put one spark of DC electricity in, which uses varying sized pulleys to return you 100's to 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using pulley mechanics = many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity
These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) and torque is caused when producing power, which is P=IV, or Amps=current(I) multiplied by (V)oltage, and massive voltage times practically zero current, still equals practically zero torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering.
This mechanism works on such simple straight forward logic, that I cannot see how that it wouldn't work. Still, for all of you doubters, I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. The only problem is, that he was worried about the rumors about anyone who actually built a working free energy mechanism, soon after went missing. So, because he feared for his life, as well as the lives of his family, he asked me not to give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
If you are interested in how I came to discovering how this simple GEM technology worked in the first place, as well as a few other things that He has shown me, please check out http://beliefstoliveby.yolasite.com/
BEFORE JAN 15, 2019 = http://my2020vision.yolasite.com/ = 1st Door
Of which, the second half of this duration, is known as the "Great Tribulation"
When Satan + all of the fallen angels + their offspring = (aliens + giants)
Will be sent to this earth, "woe to ,,, earth and of the sea!" (Rev 12:12)
We are allowed to "know that it is near, even at the doors" (Mat 24:33)
Because we are "this generation" that "shall not pass" = (Mat 24:34)
But in the original Greek, we are told that we must know, as in, this is worded more like a command. (Mat 24:33) "know that it is near," near to what = the door, as we are allowed to know when it's "even at the doors". These doors close on the deadlines, or when prophecy can no longer be fulfilled. Or, the day after the last day that that this prophecy can still be fulfilled, + the doors are plural, to accommodate His two arrivals = (Rapture + Glorious Appearance). Where the First Arrival is before the 7 year peace treaty begins + His Second Appearance is immediately after the peace treaty ends.
In (Mat 13:39) it says "the end of the WORLD"
Now hold on,,, our world is never going to end,
Proof= (Isaiah 45:17) + (Ephesians 3:21) = "world without end"
Where it is mistranslated + should I say "end of the AGE"
as in, the age of Christianity, (before True Christians are taken up in the clouds)
Or this WORLD SYSTEM,,,,,,,,,,,,
then using 51.6 as the
duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)
Starting with 1967.44, (when Israel took Jerusalem)
As Jerusalem was part of the 70 X 7s
MATH : 1967.44 + 51.6 = 2019.04
adding (6.9solar) = the 7 Hebrew year for the Tribulation,
then as for the door=deadline for Christ setting His feet on earth,
we would get 2025.94 = 2019.04 + 6.9
This way, we are shown both of the doors,
So 2020,(2019.04) is the DOOR,,,,,
Or should I say, one of the DOORs,
And 2026,(2025.94) is the other DOOR,
With so little time left,
As of Jan 17th of 2017,,, there is less than two years,,,
I would like to work 24/7,
But although I have been known to go 3 or 4 days,
without any down time,,,
I usually have my brain pass out,
for two to three hours, every two to three nights,,, lol
Your Bro,
. . . . . . . . joe
Just one of His Creations:
I mean that it only takes one spark to rotate the motor one time
the current that a DC motor takes to rotate one time
when this motor is attached to a 100 cm circumference pulley
you would get 100 cm of moving belt
which you run past 10 of the 1 cm circumference mini-pulleys,(or the size of your shaft/axle)
- with AC generators attached to these shafts/axles
giving you 10X100=1000 cycles of AC electricity
These AC generators take no torque to rotate
- as they only need to generate one spark of DC current
- + torque is cause when generating power, (P=IV)
- Or current times voltage
o - + since you only need to generate one spark of DC current to drive your DC motor=pracctically 0
- - + massive voltage times practically zero current
- - • Still equals practically zero power = practically zero torque
(this is only to keep this mechanism self powered)
YES,,, if you used a DC motor to drive your pedal axle, then this would be a good representation of the idea that I was given. My first Vision was a 10 speed bicycle, going uphill in tenth gear=(few rotations) + then going downhill in first gear= (paddling like crazy) = Where more rotations was equal to more AC electricity
Quote from: SkyWatcher123 on January 23, 2017, 08:55:56 PM
peace love light
you need to read what the difference is between circumference and diameter
https://en.wikipedia.org/wiki/Circumference
if you genuinely mean circumference , can you calculate what the actual diameter of the alternator shaft is in your proposed set up ?
you say the result is 1000 units / cycles of AC , you can find the formula for synchronous speed here to find out what your RPM actually is in the real world
https://en.wikipedia.org/wiki/Alternator
SPARK is not an electrical measurement and DC is not measured by a spark and a DC motor does not operate on a spark
https://en.wikipedia.org/wiki/Electric_spark
what DC motor is referred to in your proposed invention?
https://en.wikipedia.org/wiki/Dc_motor
you need to add some facts to your proposed invention
TIME is long ...... LIFE is short
I use circumferences so that I can easily calculate the # of rotations
one rotation of 100 cm circumference pulley
can generate 100 rotations of each one of your 10 times of 1 cm circumference pulleys
so you pay to rotate a drive motor once
+ get back the 100 rotations of each of your 10 AC generators
thereby using the circumference difference to multiply your # of rotations
yes, I know that it takes a lot more pressure/voltage to move your large pulley
but that is what you are winding up with your mini-pulleys = massive voltage
Quote from: massive on January 26, 2017, 01:47:29 PM
This works because of it not costing 100 times more power,
than it dose to rotate a 1 cm circumference pulley,
yet the 1 cm pulley will give you 100 cycles of AC electricity,
for just the one spark of DC electricity.
(I say spark because that is all the power,(the current is what moves it) that it takes
to rotate your DC motor one single time)
Quote from: that_prophet on January 27, 2017, 06:12:42 AM
This works guys,,, if you cannot see this logic,
of paying for only one rotation, to get 100 rotations,
using pulley mechanics to multiply your power ability,
then please believe me, when I say that a man has built 3 different versions, + they all work
PLEASE SHAKE OFF THIS EVIL MIST
that the fallen angels have hid this simple free energy technology
This uses the simple logic of how you can use pulley mechanics,
(wheel in the middle of a wheel)-(Ezek 1:16), = UFO motor
To multiply your total # of rotations,
This works because it does not costing 100 times more power
yet if you connect the 1 cm pulley with an AC generator attached,
to the same belt as the 100 cm pulley,
it will give you 100 cycles of AC
for just the one spark of DC electricity=
=(the small amount of electricity that it takes to rotate once)
(that it takes to rotate your DC motor one single time)
+ I use circumferences so that I can easily calculate the # of rotations
of your 10 X 1 cm circumference pulleys that you have attached
+ get back the 100 rotations for each of your 10 AC generators
that you have connected to your belt with your 100 cm pulley attached
thereby using the circumference difference to multiply your total # of rotations
but that is what you are winding up with all of your mini-pulleys = massive voltage
This works guys,,, if you cannot see the simple logic of trading one rotation for 100,
PLEASE SHAKE OFF THIS EVIL MIST,
That the fallen angels have hid this simple free energy technology with,
To get past the laws of thermodynamics + multiply your total # AC electricity
By using simple pulley mechanics to multiply your # of rotations,
Do this by starting with rotating a large 100 cm circumference pulley, (taking one rotation)
+ attaching a belt to 10 small,(1 cm circumference) pulleys,
To rotate these small 1 cm circumference many (100) times each,
+ by simply attaching AC generators to these small pulleys,
You can multiply your AC electricity by 1000, (10X100=1000)
if the small pulley is 1cm , thats 10mm , what is the diameter / the shaft size??
the formula is right there^^
"PLEASE SOMEONE,,, JUST BUILD ONE OF THESE SUPER SIMPLE FREE ENERGY MECHANISMS"
you said some one has already built one ^^
what type of DC motor ? does it have a commutator ? if yes then thats a problem
Hello massive,
. thank you for being interested in building this GEM-free energy mechanism for me + this whole world.
I cannot understand why others do not want to build this simple + easy to build free energy multiplier,,,
If not only to just shut me up,,, lol + show me that it does not work.
Although I cannot see how this simple logic cannot work,
the using varying sizes of pulleys to multiply your # of rotations
+ thereby, if you add AC generators to your mini-pulleys, you are multiplying your AC electricity.
Most everyone that I explain it to, say that it sounds like it should work + then they usually say something like,
"this seems so simple, but it can't work,,, else why hasn't someone thought of it long ago,,,"
Quote from: massive on January 27, 2017, 01:51:25 PM
I will do the calculations + have to get back to you
Although these measurements do not have to be exact.
You only need to have one large pulley on your DC drive motor,
And a very small pulley to attach your AC generators to
So that you can get a maximum multiplication of rotations of your mini-pulleys + AC generators
I used 100 cm + 1 cm to make it easy to show the math of how it multiplied your rotations
YES,,, I said that someone has already built one, actually he built 3 different versions of them, and he said that they all worked. (which I happen to be very thankful for)
The only problem is, that he was worried about the rumors, that speak of anybody that builds a working free energy machine, soon ending up dead or missing, and he also worries about his family. So he will not give me permission to give out his name.
Not sure what you mean, I was just talking about a DC motor. The only specific specs that I know of that needs to be followed is your AC + DC motors need to be the same voltage.
Hi all, just picked up an 86" length v-belt today at auto parts store for $18.
Will be testing it this weekend sometime with leg power and also turning pedals by hand, to get a feel for how hard it is to turn when charging a 12 volt battery.
Then the next step, is to hook a motor to pedal sprocket.
I have a 24 volt 200 watt brushed motor, from an electric scooter that should work.
I fully agree that_prophet, sometimes beliefs can act as chains upon us, preventing us from trying new things or even simple things we believe can't work.
I would say the same thing to all naysayers, build it, instead of just sharing opinions or beliefs.
If you build it, they or he will come. :o ;) :)
peace love light
. This uses such simple technology, by using the long belt that comes off a large circumference pulley=(100 cm circumference) which is rotating only once, (+costing very little electricity) This is to be converted into many,(100) rotations of a small pulley=(1 cm circumference). Thereby, using simple pulley mechanics, you are seemingly defeating the laws of thermodynamics + multiplying your total # of rotations, (+ by adding AC generators) you are multiplying your amount of AC electricity. These AC generators run free of practically any torque, as torque is caused when you generate power, (P=IV) or power is generated by multiplying the current times the voltage.
. So even though you are winding up massive voltage,(which gives you great potential to do work) you are multiplying this by only one spark of current. (practically zero current) and massive voltage, times practically zero current is equal to practically zero power,,, which takes practically zero torque. You only need to generate one spark of current, because that is all the current that you need to power your DC drive motor, to have this mechanism self powering. (of course you need to add a full wave bridge rectifier to convert your AC output into a DC input, that you need to drive your input drive motor)
. And lets not forget that you can drastically multiply your AC electricity multiplication factor, by simply adding additional small pulleys to the belt with your initial AC generator attached. If you add 10 (1 cm)-small pulleys you can multiply you AC electricity generation by 1000=10X100.
Quote from: SkyWatcher123 on January 28, 2017, 02:32:04 AM
peace love light
Please remember, that it is all of the evil spirits,
that are whispering in your ear,, THIS CANT WORK
(Satan is "god of this world") II Cor 4:4
they all want our money going to the oil rich countries
that in one way or another, fund terrorist
Quote from: that_prophet on January 29, 2017, 05:07:22 AM
. This uses such simple technology, by using the long belt that comes off a large circumference pulley=(100 cm circumference) which is rotating only once, (+costing very little electricity) This is to be converted into many,(100) rotations of a small pulley=(1 cm circumference). Thereby, using simple pulley mechanics, you are multiplying your total # of rotations, (+ by adding AC generators) you are multiplying your amount of AC electricity. These AC generators run free of practically any torque, as torque is caused when you generate power, (P=IV) or power is generated by multiplying the current times the voltage.
and all these evil spirits hate us humans, (fallen angels + their offspring)
I figure, this is because we are His greatest Creation
+ not these angels, (which were His top Creation)
they will no doubt enjoy seeing our deaths, the more the better
especially since I read that well over 90% of us humans, (I heard it was 98%) are headed for hell
where these evil spirits get to torture us for all eternity
we are all in this "life" thing for the long haul,,,
once you are even conceived, you are in this life think for all eternity
there is no end...................... (no way out), except if you ask Jesus into your heart
our only choice is where we spend eternity
with God,(our protector) in Heaven,
or elsewhere,(hell + then lake of fire) where nobody will protect you
Quote from: that_prophet on January 29, 2017, 07:16:21 AM
enjoying seeing our deaths, the more the better
especially since well over 90% are headed for hell
where these fallen angels get to torture us for all eternity
Please provide proof for these statements.
Hi all, Hi that_prophet, well they may be trying to whisper in my ear, but i am using discernment and i will never say something does not work, that is why i am building this, to try and see for myself.
And yes, i agree, there are many mansions in the one creators kingdom and each of us, as individuated expressions of this one source creator, will dwell in the mansion (frequency dimension) that we resonate with.
I choose the service to others mansion, with love and kindness.
I have to go back to auto parts store today and get an 88" v-belt instead, my measurement method of the pulleys was not right, you have to tape the string used for measuring, around the bicycle rim edge and small pulley edge, as i originally, in error, placed the string in the wheel rim well and pulley well.
Then you tape the string to the floor and measure the belt length one needs.
peace love light :)
Hi all, i have the proper v-belt installed and it runs nice and smooth with leg pedal power.
Next step, make electrical connections to alternator, i need a bolt to mount negative lead at alternator housing, then volt meter and 12 volt battery to charge.
Here's a pic of it ready to go.
peace love light
good for you . Im sure theres alot of people watching who wont post but they want you to do the build .
what model alternator or car did this originate from ?
I cant identify by the size of the fan
Shouldn't you have several alternators in the loop? Or do they come later? I'm wondering if there will be room unless you get some of those small 12vdc motors that also run as generators.
yes, great work...
and you should be able to add 1 or 2 of the alternators,
(without too much trouble... says the guy who is all theory... lol)
thereby double + even tripling your output,
and these altenators should run freely,
at least until you start drawing power off them
+ put it through full wave bridge rectifiers,(4 diodes)
if you are trying to eventually have this a self powering mechanism
and if you use a DC drive motor to run your pedal axle,
you should be able to multiply your AC power
by using pulley mechanics to multiply your # of rotations
+ multiplying rotations can be turned into AC electricity
by adding AC motors, or altenators, to your small wheels/pulleys
Quote from: Paul-R on January 30, 2017, 10:45:09 AM
Hi all, the alternator is a special modified one i bought many years ago, was planning to build a wind generator, but never did.
It is from hydrogen appliances online, it is a 48 volt model, i think #48120 and has a bridge rectifier built in and has neo magnets inside.
It was not cheap and is not necessary for this, i just had it on hand.
Multiple alternators would come later, not even at stage of input motor yet, more structure will have to be attached, to accommodate the drive motor to pedal sprocket.
peace love light
this pic is an alternator I pulled from a car in 2006 and repurposed for a job I was doing at that time .
toyota 12v reg/rect.
Its illegal to use petrol or diesel in tunnels so I rigged up a gen , motor , alt , batt , Warn 12v winch and pulleys to shift 3-4 tonne mass
Hi all, finished with the electrical for now, it charges well, it doesn't need much pedal speed or effort to get the 12 volt battery charging good.
I have a charger hooked up to the 12 volt battery, am charging my efficient nigh light, which has a 3ah 4 volt lithium ion.
I can even pedal while it's charging to help keep the 12 volt battery topped up.
Also have a volt meter on handlebars, so i don't push the voltage much past 15 volts.
peace love light
Hello SkyWatcher123,
. Since you are a fellow Christian, I thought that you might be interested in hearing "the rest of the story", on how I came to discover this technology. I believe that this was given to me for helping the Tribulation Saints, after I asked God for a way to help them make it through the soon coming Great Tribulation. You see, I believe in the pre-Trib Rapture, and I figured that I would not be around to help them later on, during the Great Tribulation.
. This also has another part to it, as I have always been very interested in the precise mathematics of Bible Prophecy, as this was how God proved to me that the Bible was Truth. It was a novel called "Armageddon", by the recently deceased Canadian author Grant Jeffery, and his systematically going through all the fulfilled Prophecies of the Bible, showing when they were given, and how they were fulfilled, right down to the exact day. To be exact, it was how the prophecy about Jesus entering the temple on the exact day that it was predicted, or should I say that it was His Rule of giving a second chance, after 10 times the original duration,,, that it predicted when Israel would become a nation, right down to the exact day, May 14th, 1948.
. We are warned, that no one knows the day or hour of His Return, but we are also told that we can "know that it is near", near to what, it cannot be the day of His arrival, because no one knows this date, maybe it is the door or deadline, because we are allowed to know when it's "even at the doors". Doors are plural to represent His both Comings, one to meet His born again followers in the clouds, and then a second time, when He sets His Foot on the Mount of Olives.
+ http://doorschristmustpassthrough.yolasite.com/
Remember that although we are warned "that day and hour knoweth no man" (Mat 24:36)
Because we are "this generation shall not pass" = (Mat 24:34)
as in, the age of Christianity, until the rapture occurs
(before the born again Christians are taken up in the clouds)
then using 51.6 as the duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)= linage of Christ
+ also used to accurately predict Israel's rebirth, to the day
As Jerusalem was needed, because it was part of the 70 X 7s
Where the last 7 includes the infamous 3.5 years of the Great Tribulation
then as for when the door=deadline closes for Christ setting His foot on earth,
These evil spirits have been, + are continuing to work hard at hiding this super simple free energy technology from us, for all of man's His-story, or at least since Ezekiel wrote his description of how it worked. AC electricity is created by rotations, and we can use varying sizes and the # of wheels/pulleys to multiply your total # of rotations, + thereby multiply our AC electricity. This works because your AC generators do not give any resistance unless you are drawing any amount of power off of them, and since you only need one spark of current,(practically zero) to rotate your DC drive motor once, keeping it running. Since power,(causing torque) is equal to current times voltage, or P=IV, and one spark of current, (practically zero) times even massive voltage, is still equal to practically zero.
Quote from: SkyWatcher123 on January 30, 2017, 09:10:16 PM
peace love light
Hi that_prophet, thanks for sharing, nothing surprises me much anymore, different body, different earth geography, apparently anything can be changed and seemingly in a blink of the eye.
I comprehend the theory of this device and it makes sense to me.
I just realized i can hook up the drive motor to the rear bicycle wheel sprockets, which should make it easier to implement, as the structure is already there to mount the motor.
So based on your theory, we should be able to power the motor, turning the large wheel, in turn rotating the small pulley attached to the alternator and then take the electrical off the alternator and direct that into the drive motor, giving us a self runner.
Though if we have a large enough excess, then we can instead, take the electrical off the alternator(s) and charge batteries.
While these batteries run the drive motor and we can then take the remaining excess from the batteries, in the hope we never deplete the batteries below what we started with.
I have a 24 volt-200 watt scooter motor, i will start planning and see how that works attached to the the rear wheel chain sprocket.
Why do demons hate people?
by Jesse Johnson
http://thecripplegate.com/why-do-demons-hate-people/
One would think that demons (who hate God) and people (most of whom hate God) would have at least an amicable relationship. After all, they are both opposed to God, and are both living in open rebellion against him. Shouldn't a shared enemy unite them?
Yet going all the way back to the first satanically possessed serpent, fallen angles have a track record of hatred and violence against people. Satan propelled the world into sin, while demons afflict the weak and cripple the strong. Why? Why do demons hate people so much?
Part of the reason has to do with the fall—not Adam's fall, but Lucifer's. Obviously Satan fell because of pride, and because of his desire to be like God. But Scripture also hints at why, and it goes back to creation.....
Angels were part of creation. They did not exist before the first day, and one of their first acts of existence was applauding at God's work (Job 38:5-7 )....
Angels remained unfallen on day 6....
The angels clearly appreciated creation. They applauded at it, and they were in awe of its beauty (Ezek 28:13 ). But God did not give the earth to angels. As Paul writes, "Now it was not to angels that God subjected the world..." (Hebrews 2:5 ). Instead, God made man. He made Adam out of dirt, and Eve out of Adam. And then God gave them dominion of the earth instead (Gen 1:26 )....
Psalm 8:6 says, "You have given him dominion over the works of your hands; you have put all things under his feet." This is exactly what some of the angels wanted. At the very least, Satan wanted dominion over the earth. He wanted to be like God. In fact, he compared his beauty to the beauty of man and creation (Ezek 28:17 )....
Quote from: Paul-R on January 29, 2017, 09:45:08 AM
Quote from: that_prophet on January 29, 2017, 01:16:21 PM
Quote from: SkyWatcher123 on January 31, 2017, 02:11:38 PM
If this is one of those razor motors, MY1016 or something like that as per Turion's 3 battery thread on Energyforum, I would not risk it on this project.
Hi all, it is a razor motor and it is not the proper design motor for the 3 battery setup.
And the other issue is, the small sprocket it came with will not work, it has teeth not meant for bicycle chain, it uses #25 chain.
And searching on-line for something that fits the 8mm shaft and has proper teeth for bicycle chain is proving difficult.
It looks like i will have to make my own sprocket somehow, or somehow connect the motor direct into the bottom bracket of pedals.
Like the videos on youtube, that show people using battery powered drills to make electric bicycles.
Still thinking about it and researching options.
peace love light
You could probably get a sprocket off some dumped bike's rear wheel derailleur (I think most bike chains are the same) and replace the sprocket on the motor. Most bike shops throw away a lot of these because the spokes are damaged and they aren't worth the trouble. If it doesn't fit, you could grind off the razor's teeth and araldite on the new sprocket.
Hi paul, thanks for the tips, i was thinking something along those lines.
I have a child's bicycle rear wheel with the small sprocket.
I looked up araldite, it looks like a kind of industrial super glue, would that be strong enough do you think.
How about jb-weld, do you think that is strong enough.
peace love light
Hi webby, thanks for response, that might work, i'll have to see what the sprocket looks like from the childs bike wheel.
The sprocket that came with the motor is very small, probably not even enough material to put bolts through to other sprocket, would probably need another piece of metal between the two, though will have to see.
I have a question for that_prophet, when you received the instructions of this technology, did they by chance warn you, that demons might attack those that attempted to build these simple devices.
Just wondering, because unless i'm imagining things, i am being attacked by certain individuals around me, it's very strange.
peace love light
Quote from: SkyWatcher123 on February 03, 2017, 02:05:45 PM
Its good enough for combat aircraft and missile launchers.
But, although the bonds of Araldite are greater even than the bonds of marriage, it is ESSENTIAL to clean both jobs chemically - or it is useless. Scrub both parts with hot sudsy water and a nailbrush, then, when dry, with ethyl alcohol if you have some, or propyl alcohol or industrial spirit. Mix EXACTLY equal amounts from each tube and mix very thoroughly.
(This is a lot of work to demonstrate to that_prophet that he is talking through his back passage. But his God knows this.
Sorry guys, for bringing religion into this subject, but I was sharing some of my theology topics, as it is this spiritual warfare that the enemy is using TO HIDE THIS SUPER SIMPLE WAY OF USING PULLEY MECHANICS TO MULTIPLYING AC ELECTRICITY.
(I have some newer + more defining descriptions of GEM -God's Electricity Maker )
And when it is shown that the concept doesn't work, the guy who is spending his time and money will be a demon in your eyes.
Get some toy motors, rubber bands and a battery and do the experiment yousef for god's sake. Order the parts online if you can't get out.
Don't put so much of your faith in a book that is the creation of man. Test everything you read before you believe it.
Quote from: pomodoro on February 05, 2017, 06:13:42 PM
please,,, please,,, show me how much of a hold that these evil spirits have on you
I was hoping that I could enrage many deceived people,
...... once they discovered how simple of an idea that these evil spirits were hiding
. . . . . . but I have not yet been able to break this solid hold that they have on the masses
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
--- All through what seemingly legally breaks the laws of thermodynamics
--- -- by using simple pulley mechanics, that we learn in grade school
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- turn into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your AC electricity
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
Sorry, but I have fallen on hard times, + find myself back living in a nursing home,
where I cannot even have my own personal nail clippers,
so I cannot build anything inside this cage, where tools are forbidden
................ but there is light around the corner, as others have said that they would take up the task,
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing, I mean those who had working models
the Book that I put all of my faith in is the Word of God
you should read a novel called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
as he systematically went through some Bible Prophecies,
and showed how they were fulfilled, even right down to the exact day
it was one of the rules with God, the one about how He gave a second to Israel
hats off to skywatcher for even bothering
did anyone take time to look at hydrogen appliances ? worth a look
http://www.hydrogenappliances.com/index2.html
PM alternators , the only general source I can think of is motorcycle alternators which are similar to fisher and paykel but smaller , single or 3 phase .
that_prophet , I kindve thought you wouldnt go near any formulas , the diameter of a shaft relative to its circumference is ,
10mm divide by Pi = 3.183mm ..... this is the diameter of the alternator shaft in your proposal
a faster revving alternator increases frequency , theres a formula for that too.
Tesla was supposed to train to become a priest but fortunately he dodged that bullet and became TESLA , the world didnt need another priest
the reason the nursing home wont allow you nail clippers or any other sharp object is because they dont want to risk losing their host , they prey on their residents or do they call them "clients".
Who are the owners or share holders of this place ? when the money stops suddenly they turf everyone out on the street
Massive, "USA runs on 50hz", I rather thought it was 60hz, shouldn't you have known?
Besides, this thread certainly has some entertainment value, like "Omen I-III", even tho I would vote for the seperation of Church and Technology.
It is threads like this that make us all look like delusional maniacs. And I won't even mention things like pedopriests and "witches" burnt at stakes. ok I did.
You may believe what you want, but notice that your preaching is cynical, selfjustifying and very annoying to most people.
Furthermore, as you want, according to the plan given to you by god, add any number of alternators to the belt, I would suggest you read about Lenzes Equation, about the additional brakeing by each alternator, esp. when power is extracted and used up, and then, once understood, tell god about it, so he or she can adjust his generator plan.
Don't get me wrong. I believe in the power of believe. And Jesus may be the greatest Philosopher, Revolutioneer and PSI gifted ever. But I don't believe in the vatican. And not in the vaticans bible that was basicly put together by the successors of the roman empire. That empire, from crucifications until the inquisition, is bloody and evil, dishonest and manipulative.
Hi all, Hi massive, thanks for encouragement, i am at a stand still until i can get the proper sprocket built and on top of that, it seems evil spirits are on the attack and living arrangements will be changing soon.
I can't say yet whether this simple technology works, i can say this, something is not liking me taking this seriously.
Also, the fact that so many seem compelled to come in here and other threads of that_prophets and repeat the same things, over and over, when they have not even tried to build anything, is highly suspect also.
As far as i'm concerned, there is most definitely a spiritual battle taking place and it seems very much like the matrix movie, where they seem to able to use some people here on earth, to do battle against the ones trying to make it a better place for all.
I need no book to tell me that.
peace love light
Dieter - Yes USA is 60hz
if the sprocket went on , then it can also come off ? . I dont know what these motors look like if it is press fit or cast but sounds small , maybe a shaft adapter with a grub screw ?
Quote from: that_prophet on February 05, 2017, 08:38:59 PM
-the Book that I put all of my faith in is the Word of God
it was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
that convinced me that the Holy Bible spoke Truth
Hi massive, thanks, yes a shaft adapter might be the easiest option.
The shaft as it is now, has threads at the end of it and the sprocket is very small.
Next thing is, can i find i shaft adapter to fit the existing shaft.
peace love light
this is ONLY an example
https://www.jaycar.co.nz/solid-shaft-couplers-female-type-i/p/YG2600
there are different types , some go to same size shaft , some are reducer going to a different dia shaft
I havent been near a bike for long time ,how is a derailer gear stuck on ?
remembering the thread needs to be saved so needs to be beyond reach of a grub screw because of (dare I say) Torque
Im assuming you dont want to destroy the motor , a large dia gear will do that every time.
If the shaft has a nut on the end then Im gonna guess its also keyed
Quote from: SkyWatcher123 on February 06, 2017, 01:02:33 AM[/font]Hi all, Hi massive, thanks for encouragement, i am at a stand still until i can get the proper sprocket built and on top of that, it seems evil spirits are on the attack and living arrangements will be changing soon.I can't say yet whether this simple technology works, i can say this, something is not liking me taking this seriously.Also, the fact that so many seem compelled to come in here and other threads of that_prophets and repeat the same things, over and over, when they have not even tried to build anything, is highly suspect also.As far as i'm concerned, there is most definitely a spiritual battle taking place and it seems very much like the matrix movie, where they seem to able to use some people here on earth, to do battle against the ones trying to make it a better place for all.I need no book to tell me that.peace love light
[/font]
I agree, satanic doctrine rules and globalization is its empire and throne. Aggression spreads like a virus, demonic. And all of us, truely searching for a way around the upcoming energy crisis, are faught by the satanic powers to be. But this happens to all people, regardless of religion.So excuse me for being harsh or cynical, even tho I feel a bit abandoned by God, I am still on the same side like you guys. Back on tech topic.
Using pulley mechanics to multiply AC electricity
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this clean free energy technology is used)
(which not only reduces our pollution, from oil burning engines,,,)
(also reduces the funds being given to fund terrorists, which are grown in these oil rich countries)
--- --- by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity,
by paying for one rotation of a 100 cm circumference pulley,
and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
By using simple pulley mechanics to multiply your rotations = AC electricity
I mean those who had actually built working models
+ if you want to see how the Holy Bible can prove itself God inspired
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
http://decimationofthisevolutionfairytale.yolasite.com/
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
SAINTS
Quote from: dieter on February 06, 2017, 11:11:03 PM
I suggest you study the basic physics of a Lever.
That, or I may have completely misunderstood your concept.
The Lamb and the Truth will fight the evil, says the book. But can you bear the Truth? Knowledge must be Truth and Truth should become Knowledge.
kr
that_prophet , you said you have 3 years Electrical Engineering training and an IQ of 135
thats all fine but does your proposed invention contradict your 3 years training ?
and how ?
Posting this a multitude of times is not going to change
The fact that it does not work.
See my post in the other thread.
this technology does not go against any of my schooling = 3 years electrical engineering at UNB Fredericton OR my 1 year computer graphics specialist at COGS in Laurence-town OR my 2.5 years Information Technology at NSCC in Truro. Nor does it go against my 135 score on an IQ test rated to 120, nor my 165 score on an IQ test rated accurate to 145.
I took these IQ tests to prove my self competent,(85+) to get out of a nursing home, and out into an apartment.
which now I find myself back in,,,
should not complain though,
as it gives me food + shelter
this uses the simplest of pulley technology to
only pay for one rotation of a 100 cm circumference pulley
which gives you 100 cycles of AC electricity back in return,
for every 1 cm circumference mini-pulley with an AC generator,
that you choose to attach to the same belt
if you choose 10 X 100 = 1000 rotations OR 1000 units/cycles of AC electricity
now, try and tell me that you cannot get out of this your one spark of DC current,
which is all that you need to power your DC drive motor + rotate it once
Especially when the AC generators are just winding up massive voltage
Which is useful pressure to crank over your DC drive motor
Remember, you only need to generate,
one single spark of current, (practically zero)
To keep this running, by cranking this DC motor over once
And to create power costs you torque
P=IV + practically zero I-current times even massive Voltage
Is still equal to practically zero power = zero torque
Quote from: massive on February 07, 2017, 04:23:49 PM
and how ?
Quote from: that_prophet on February 08, 2017, 09:18:56 AM
I should ask for your money back.
You make a lot of claims. If you are so intelligent then why on earth do you keep posting in so many places when you have been told by several of us that you are being very annoying? If anyone actually wanted to build your device it would be much easier for them to follow what you want them to do if you kept all your comments in one thread. By posting all over the place you are only getting people irritated with you so that we refuse to read anything you post. And claiming to be some kind of prophet is not helping your cause either. Jesus plainly said there would be a lot of false prophets in the last days claiming to be from him. Your actions seem to indicate you are one of them. A real Christian does not deliberately annoy others. You have been asked before and I am asking again for you to keep your ideas to one thread only and not clutter up the rest of the forum with your posts.
Respectfully,
Carroll
Sorry, but I did not realize how strong of a hold that evil forces have on this world...
Especially against this God Given free energy technology, found in Ezekiel 1:16 = (UFO motor)
+ I just wanted this free energy technology to be shown to as many people as possible,
I thought that I could explain simple pulley mechanics, + it would be obvious that this technology works,,,
With a simple trading off of 1 rotation of large 100 cm pulley, for the 100 rotations of a small 1 cm pulleys
And I wanted more people to see just how powerful a hold that evil forces had on us
by hiding such a super simple pulley technology, to give us this GEM free energy technology
Considering that it only costs one spark of DC current, to rotate a 100 cm circumference pulley once
Which through simple pulley technology, would give us a return of 1000 units of AC electricity, from only 10 mini-pulleys
that have AC generators attached to them, + were connected to the same drive belt as your DC drive motor was attached
+ since it was obvious that 1000 units of AC electricity had more energy in it,
than the 1 spark of DC current, which you had to put into this GEM mechanism to start with
this was indeed a way to multiply your AC electricity
Quote from: citfta on February 08, 2017, 10:05:04 AM
Respectfully,
Carroll
NO,,, I BELIEVE THAT I HAPPEN TO BE THE ONLY ONE WHO SEES PAST THIS EVIL FOG.
Why else are these evil spirits causing me to have so much pain.
You would think that if I were writing what they preferred,
then they would not be causing me so many problems + pain
I tried to delete
I do believe you have reading comprehension problems. My post had nothing to do with your wild claims. My post was a respectful way of asking you to show some respect for the members of this forum by not posting the same thing several hundred times in different threads all over this forum. Responding by just repeating your ridiculous claims is not helping anyone.
Claiming someone is deluded by satan because they do not believe your claims is very arrogant and obnoxious. Your claims are not believed because you have shown no one any reason to believe them with you ideas about a single spark powering a motor when all of us that have worked for years with motors know that is not true.
Quote from: that_prophet on February 08, 2017, 12:22:10 PM
I thought that I could explain simple pulley mechanics, + it be obvious that this technology works,,,
With a simple trade off of 1 rotation of big 100 cm pulley, for 100 rotations of a small 1 cm pulley
And I wanted people to see just how powerful a hold that evil forces had on us
Considering that it only costs one spark of DC current, rotating 100 cm circumference pulley once
Which gave you a return of 1000 units of AC electricity, from only 10 mini-pulleys
that had AC generators attached to them, + were connected to your same drive belt
It doesnt take long for people to attck each other . first off sky watch deserves encouragemnet , hes earnt it by stepping up to have a go .
Its been established that_prophet is in a wheel chair etc , it is pointless to ask or suggest that he build it and actually unfair , even if he irrates some folk .
a DC motor does not run on a spark , a spark is not a QUANTITY . a spark is full current measuered/predicted to jump across a GAP
please add a link to a store that sells such a motor
If you actually have 3 years EE training you need to edit the word "spark" from every post you have and add formulas for frequency of the alternators .
this thread rests on sky watcher and pretty much no one else
... especially against this God Given free energy technology, found in Ezekiel 1:16 = (UFO motor)
This is Ezekiel 1:16 - No more and no less -
"The appearance of the wheels and their workmanship was like sparkling beryl, and all four of them had the same form, their appearance and workmanship being as if one wheel were within another".
And the subsequent verses are no more illuminating. It speaks of four identical shiny green wheels. One wheel within another - possibly an epicyclic gearbox type of construction. Where is the free energy?
Re: GEM=(Geometrical Electricity Multiplication)
now, try and tell me that you cannot get this one spark of DC current,
out of these 1000 units of AC electricity, that you have generated with these multiple of rotations,
because this one spark of DC electricity is all that you need to power your DC drive motor,
+ rotate it only one single time, + by using simple pulley mechanics,
you can multiply into 1000's of rotations + 1000's of units/cycles of AC electricity.
Which works out as useful voltage pressure, to crank over your DC drive motor
one single spark of DC current, (practically zero)
And creating power costs you torque
It is as simple as using the 100 cm length of belt off of one rotation of a 100 cm circumference pulley,
to be multiplied into 100 rotations of a small 1 cm circumference pulley.
Through simple pulley mechanics, you are multiplying your AC electricity
you are trading off one rotation of a large 100 cm circumference pulley,
into 100 rotations of, as many of the 1 cm circumference pulleys that you choose to add to the belt.
So, if you added 10 of these mini-pulleys, you would get 10X100=1000 rotations,
which by simply adding AC generators, you could gain 1000 cycles of AC electricity.
That is, you are only putting in one small spark of DC electricity,
+ have the ability to extract 100 units of AC electricity, for every mini-pulley that you add,
That has an AC generator attached to it
HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY
– when you working with basic pulley technology,,, physical abilities
+ using this simple physical ability of trading one revolution for 1,000's of rotations
-especially when you are dealing with rotations when speaking of generating AC electricity
Can we extract energy out of his senseless spam?
He may not be "perpetual" but I bet he could keep
A device running for a very long time......
http://overunity.com/17091/gemgeometrical-electricity-multiplication/msg499717/#msg499717
this uses the simplest of pulley technology,
where you only pay for one rotation of a large 100 cm circumference pulley,
which gives you 100 cm of moving belt to work with,
+ if you attach an AC generator to a 1 cm circumference pulley,
that will give you 100 cycles of AC electricity back in return,
that you choose to attach to the same belt.
if you choose 10 - 10 X 100 = 1000 rotations OR 1000 units/cycles of AC electricity
THAT'S A RETURN OF 1000 UNITS/CYCLES OF AC ELECTRICITY
– FOR ONLY ONE SPARK OF DC CURRENT
(it only costs one spark of DC electricity to turn over your DC motor once)
out of these 1000 units/cycles of AC electricity,
that you have generated with these multiple of rotations of many small pulleys,
because this one spark of DC electricity is all that you need to generate,
to power your DC drive motor, + rotate it only one single time,
+ by using simple pulley mechanics, you can multiply into 1000's of rotations
Which can easily switched into 1000's of units/cycles of AC electricity.
Which works out as useful voltage pressure, to crank over your DC drive motor.
And creating power costs you torque, P=IV
It's as simple as using 100 cm length of belt, off one rotation of a 100 cm circumference pulley,
into 100 rotations of, as many of the 1 cm circumference pulleys that you add to the belt.
for every mini-pulley that you add, that has an AC generator attached to it
(will pass laws, mandating that this tech is used + not oil burning engines,,, )
(which not only produce pollutants + cost money, but also funds terrorist)
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
It was how God predicted, to the exact day,,, May 14th, 1948
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
the DC motor takes only one spark of DC current to rotate one full time,
+ you get this "spark" of DC current by putting all of the AC units of electricity,
through a full wave bridge rectifier, (4 diodes)
this small amount of DC current =(1 spark),
rotates your DC motor once, with a 100 cm circumference pulley attached,
giving you 100 cm of moving belt to work with,
then if you run this 100 cm of belt past 1 to 10 mini-pulleys with AC generators attached,
you could get 100 to 1000 units of AC electricity,
THAT'S 1 SPARK OF DC, THROUGH PULLEY MECHANICS, GIVING YOU 1000 SPARKS OF AC
Quote from: webby1 on February 11, 2017, 11:12:50 AM
It is still your turn.
How do you convert that single spark of AC electricity into the current that the DC motor needs?
Quote from: Dog-One on January 20, 2017, 07:56:21 AM
Why even mention this person then, since it is pointless asking you to put us in contact with him?
I wanted to tell people that I had proof that this technology does indeed work,
but that the rumors about people disappearing, who had actually built working free energy machines
+ also, it was a good affirmation to me, that this GEM technology did actually work,
but i thought that the mathematics + logic was enough to prove that in theory at least, it had to work
If you were smart, you would at least get some pictures of his work and post them here.
yes, I agree that I should have gotten some pictures and figures of his experiments,
but I was so eager to assure him that he would not get discovered through me,
that I erased all his info from my computer, before I got to ask him any specific details
To each their own I reckon.
yes,,, I do not understand how Satan can have such a hold on mankind,
that we cannot see the simple logic of how many small pulleys can be used,
to multiply the # of rotations, which can easily be converted into AC electricity
Prophet you have made your point , now have some manners and give it a break for a while.
You seem to think demons are couding everyones head regarding this great discovery of yours but in reality its your reasoning that is clouded. I think you have schizophrenia friend, and i feel sorry for your plight but please calm yourself and focus on your mental health getting better. Your pain is not becaue of demons, its a medical condition that can happen to anyone of us and its a scary thought for sure. Just pray to God and forget the all other garbage in the bible.
Quote from: webby1 on February 11, 2017, 02:28:56 PM
This is where your device as you have described it falls flat on its face.
When you run that 1 AC spark through a FWBR to create the ...
... then if the spark is of any reasonable size, the voltage will blow the motor's coils
Your logic and my logic appear to disagree. Load is load. You add more on the output side, then more
torque is required on the input side. 1 = 1, 2 = 2, etc.
You show fear to the almighty pervasive Satan. Once you do that, he owns you.
Satan rules this planet. Why? Because we humans have allowed it. God has given us
what we need to throw off Satan, but it's too hard for us, or so we think and therefore act.
My suggestion that_prophet is to practice what you preach. You want to change the world?
Show me!
. This works on the simplest of pulley mechanics, to multiply AC power. It can get away with seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to multiply your total # of rotations. That can be significant, considering that AC electricity is created using rotations, and the more rotations equals the more AC electricity. If you use a DC motor to drive a 100 cm circumference pulley for one complete revolution, it only costs you one single spark of DC current, to give you 100 cm of moving belt.
. Then all that you have to do is add an even larger belt, and run this length of 100 cm of moving belt past 1 – 10 mini-pulleys of 1 cm circumference with AC generators attached, you can gain 100-1000 units/cycles of AC electricity. YES,,, that's a return of 1000 units/cycles of AC electricity, all for only one single spark of DC current. It is truly that simple,,, and why hasn't anybody figured this super simple free energy technology before? It is because evil spirits are still, and have been trying their hardest to hide this technology from us humans.
. How can you explain away this simple logic, of trading one rotation of a DC motor, for 1000 rotations of AC electricity. HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY,,, and you could be multiplying it by even greater factors, if you added a larger drive pulley, or more mini-pulleys of 1 cm circumference with AC generators on the same belt.
. Satan + his fellow evil spirits have been pulling the wool over our eyes for too long. Please, join me in defying the evil rule on this earth, and not only help stop funding terrorists, but help us gain the advantages of anti-gravity. I say this because I found this ancient technology in the Holly Bible = Ezekiel 1:16, where he is trying to describe what a running UFO motor looks like. "a wheel in the middle of a wheel", or as I pictured it, a small wheel, running on the inside of a large wheel. But, since I did not have that ability to have a small wheel, running on the inside of a large wheel, I decided to go with a pulley, and have both wheels=pulleys run inside this larger belt.
. Is not this sooooo simple, that it aggravates you to hear that this has been in the Holy Bible since the times of Ezekiel? I hope so, and that it proves to you that there is a most powerful spiritual warfare going on behind the scenes.
you have to delete the word "SPARK" and the word "UNIT" , these are not electrical measurements in Electrical Engineering
So, do you admit that this pulley technology works at multiplying AC electricity?
Quote from: massive on February 13, 2017, 03:01:58 PM
This uses the simplest GEM technology,,, by paying to power a DC motor to rotate once, with a 100 cm circumference pulley attached =(only one very small amount of current). This can produce you 1000 units of AC electricity, by simply adding a belt that is long enough to wrap around your 100 cm circumference pulley and 10 more 1 cm circumference pulleys with AC generators attached.
These AC generators run free of practically any torque, because you only need to generate such a small amount of DC current to drive your DC drive motor and you have 1000 rotations of AC generators to add up to your very small amount of DC current, which you must run your AC output through full wave bridge rectifiers to convert into DC.
Quote from: that_prophet on February 17, 2017, 05:54:47 AM
"No" and "Meaningless".
The best way to nudge you to an understanding, that_prophet, is to ask you to explain how a gearbox works and why it is useful.
you have used the word "units" again , theres is no such thing .......... only trying to help you out here .
when you increase speed you increase the frequency of AC = alternating current
as for the pulley ratio , if the DC (direct current) motor is revolving 1000 rpm , what rpm is the alternators spinning at ?
from that number of rpm you can calculate the frequency of the AC output of the alternators
theres a formula for that , used in electrical engineering
one positive out come of this thread is ...
http://hydrogenappliances.com/
What you are doing with the 100 cm circumference pulley and couple it to a 1 cm circumference pulley with a belt is to achieve a gear ratio 100/1.
What is this gear ratio doing?
Well, it will make the 1 cm circumference pulley take 100 revolutions while the 100 cm circumference pulley takes one.
Not only that. The torque you measure at the 1 cm circumference pulley is 1/100th of the torque on the 100 cm circumference pulley.
If you multiply the gear ratio with the torque ratio, you get a total energy gain of (100/1)x(1/100)=1. If you put a million lossless systems in series, you still got an energy gain of 1 - because 1x1x1x1x1x1x1x1x1x1.....(a million times)=1.
Vidar
what I happen to be doing is thrugh pulley mechanics I was trading one rotation of a large pulley for 1000 rotations of a 10 small pulleys,,, + with AC electricity, this can be very significant. the more rotations the more AC cycles of electricity
Quote from: Low-Q on February 17, 2017, 03:19:27 PM
Vidar
what I happen to be doing, is using simple pulley mechanics,
to change 1 rotation of a large 100 cm circumference pulley,
+ thereby multiplying the amount of AC electricity.
By simply adding a belt to connect these two pulleys,
and by simply adding 10 1 cm pulleys with AC generators,
we could multiply the total # of rotations to 1000
giving us 1000 cycles of AC electricity,,,
all for the cost of only a small amount of DC electricity.
(one "spark", small amount of DC current)
(this works because it does not cost 100 time more electricity )
( to rotate a 100 cm circumference pulley, compared to a 1 circumference pulley)
(yet the 1 cm pulley rotates 100 times as much)
( which is significant when talking about AC electricity )
( giving you back 100 cycles of AC electricity, if you add an AC generator )
YOU ARE PAYING FOR 1 ROTATION + GETTING BACK 100,,, OR 1000,,, OR MORE
by simply using pulley mechanics
Quote from: that_prophet on February 22, 2017, 06:00:32 AM
You are talking utter crap, that_prohet.
Does it not concern you that not one single person on this forum agrees with you?
Hello massive
« Reply #6 on: January 23, 2017, 10:20:54 PM »
• Quote
"thereby multiplying your AC electricity"
no multipling frequency .... to power what ? USA runs on 50hz
I say multiplying your AC electricity because every time you rotate your mini-pulleys with AC generators attached, you multiply your AC electricity by one more cycle.
Sorry, but I don't talk about time at all, so I don't use RPM. I just know how many revolutions that I will get, but I do not know how much time it was taking
+ I thought USA ran on 60hz
" (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor"
DC motors dont run on "sparks" , is a spark an electrical quantity ?
I say spark because it only takes one spark of current to rotate the DC motor one time, with a 100 centimeter circumference pulley attached
Ok, let's start calling it one small cycle of current = (the small amount of current that it takes to rotate the DC motor once)
a spark across a gap is current , practically NOT zero , have you seen commutator bars and brushes after there has been "sparks" ?
one_christian_warrior / that_prophet , the devils got ya in the head and you wont wake up
yes, I know that a spark causes arching, which is bad for any motor
I mean the small amount of current that it takes to rotate a DC motor once
I be multiplying my AC electricity by 100
paying for only one rotation of the 100 cm circumference
+ gaining back 100 cycles of AC electricity
Vidar
NO,,, IT DOES NOT COST 100 TIMES THE TORQUE TO ROTATE THE 100 cm CIRCUMFERENCE PULLEY
YET you can get 100 times the rotations
Profet,one good thing about having your nonsense here is that it represents the most childish attribute of many on here.You have a condition where your great belief in this invention clouds all judgment and you fight hard to be heard and believe.But because of your lack of basic science, you have no choice but to offer this simple childish invention, which is easily dismissed by the most infantile inventor. Now add a few formulas , computer simulators, jargon, oscillographs, and you can see how some more advanced inventors can start pulling the wool over the more senior inventors. So your posts have done much to my understanding of some others on here that seem to go on for years but never admit to having a major flaw in their theory, and like you have nothing to replicate successfully.So cheers for that dude.
This technology is truly very simple, as it uses the circumference difference of one large pulley of 100 cm, and many,(10) small 1 cm circumference pulleys. By using multiple smaller pulleys we can multiply then total # of rotations, and by adding AC generators, we can multiply our AC cycles of electricity. It is as simple as that, you are using the use of multiple pulleys to multiply your total # of rotations, which can be turned into AC electricity, by simply adding AC generators to the many, 10 small pulleys with AC generators attached.
You are taking the 100 cm of belt that you get from the one rotation of a 100 cm circumference pulley, which costs only the slight amount of electricity that it takes to rotate a DC motor once. This is called a GEM = Geometrical Electricity Multiplier because that is what it does, by using multiple # of small 1 cm circumference pulleys, with AC generators attached. So you only pay for one rotation of a large 100 cm circumference pulley, and get back a multiple of 100 rotations, for every 1 cm circumference pulley with an AC generator that you attach to the same belt. So, if you add ten small 1 cm circumference pulleys, then you would get a return of 1000 cycles of AC electricity, all for the cost of one rotation of your DC drive motor.
This mechanism should run perpetually, with the 1000 cycles of AC, when run through bridge rectifiers, should easily be able to produce enough DC electricity to crank your DC motor over once. These 10 AC generators would be easy to rotate, as they are just being used to wind up massive voltage, and only need to have the slight amount of current that a DC motor takes to rotate one single time. Since torque is caused when you are generating power, and power is current times voltage, P=IV. Since we only need the smallest amount of current, practically zero, and zero times even massive amounts of voltage still equals practically zero. Thereby these small pulleys should rotate with practically zero torque, and they should be winding up massive voltage, which can be used to crank the DC motor over just the once.
Just build this super simple GEM - AC electricity multiplying device, and watch it work. Once built, you should be able to start it running by simply giving the large pulley a slight rotation. These AC + DC motor/generators should run continuously, allowing you to tap electricity off of both your AC + DC generators/motors. If you find that this GEM free energy device does not have enough DC electricity to power your apparatus , then just add more 1 cm circumference pulleys with AC generators attached, to the same belt.
by simply using pulley mechanics, you can multiply your AC electricity cycles.
I originally added a battery into the system, to store the excess power, and added a warning to this mechanism, that left along, this battery charging device could explode + catch fire. I worried about this, because of it being able to continuously produce power, and overcharging the battery. I stated that you needed to have a cut off circuit, to prevent over charging.
This truly works guys + gals,,, I know that it sounds too simple to actually work. You are using simple pulley mechanics to multiply your total # of rotations, and by simply adding many small pulleys with AC generators attached, you could be using pulleys to greatly multiplying your AC electricity, instead of paying money to the terrorist for oil.
It is the billions of evil spirits that are screaming in your ears, "THIS WILL NEVER WORK" + "ONLY A FOOL WOULD TRY THIS". That is because they are desperately trying to hide this ancient UFO technology that can be found in the Bible = Ezekiel 1:16. They are + have been hiding this super grade school technology because they want us to keep buying oil,,, from countries that produce terrorist,,, to help create terrorism = what they like best
COME ON PEOPLE,,,,,,
PLEASE, shake off this spiritual dullness,
That is keeping us all blind to the simple logic,
That you MUST multiply your AC electricity,
When you only pay to rotate a large 100 cm circumference pulley once,
And you can, by adding a belt with ten small 1 cm circumference pulleys,
With AC generators attached to each small pulley,
Gain 1000 cycles of AC electricity
HOW CAN YOU NOT GET ONE SPARK OF DC CURRENT
Out of 1000 cycles of AC electricity
Because torque is caused when creating power,
+ you only need the minuscule amount of current to rotate a motor once,
Which is practically zero,,, + P=IV
So practically zero current times even massive voltage still equals practically zero
Now I used a DC drive motor,
So you would need to have 10 full wave bridge rectifiers,(4 diodes),
To convert your AC output into your DC for your drive motor
Welcome to the END TIMES
(as of 2:27 – 2017, all who are born again + looking 4 His Coming, have less than 23 MONTHS LEFT TO LIVE, on this earth, before the Door shuts on this last generation=(51.6 solar years calculated from the 14+14+14 generations of linage of Jesus) + also used to accurately predict the rebirth of Israel, right down to the exact day.
Email: ask_that_prophet@yahoo.ca
http://askthatprophet.yolasite.com/
http://my2020vision.yolasite.com/
http://free-energy.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://pre-trib-force.blogspot.ca/
http://hissalvation.yolasite.com/
http://godoflove.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
http://onechristianwarrior.yolasite.com/
http://ultimatejoysticks.yolasite.com/
http://ultimatevideogamecontrols.yolasite.com/
http://thegodofthebible.yolasite.com/
http://incaseofrapture.yolasite.com/
http://rapturequestion.yolasite.com/
http://whataboutisrael.yolasite.com/
http://myiqchallenge.yolasite.com/
http://evolutiondebate.yolasite.com/
http://biblefilescentral.yolasite.com/
http://whydoweinsultgod.yolasite.com/
http://jesus-christ.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://howlogicchosechrist.yolasite.com/
http://hisonlyword.yolasite.com/
http://whybornagain.yolasite.com/
http://bibleteachings.yolasite.com/
Quote from: that_prophet on February 27, 2017, 07:47:53 AM
Do you own a house, that_prophet ?
If so, I will buy it from you for $1,000, payable on completion of the transfer of the deeds with a clause saying that you can live in it for these 23 months.
Mark 13:32 "But of that day and hour knoweth no man, no, not angels which are in heaven, neither the Son, but the Father."
Matthew 24:11 "And many false prophets shall rise, and shall deceive many."
Both of these quotes were said by Jesus, the provider of real truth.
So it appears we have a false prophet because he is claiming to know something even Jesus said He didn't know.
Yes citfta, joe "knows" so many things, even scored genius on a human contrived IQ test.
With all that knowledge, that prophet should be able to enlighten us as to why, with only
23 months left of our existence, we should care about his GEM at all. But then again,
this would require us to forget about logic and rely completely on faith. Been there,
done that, got the T-shirt.
I got this through logic, and studying the Bible,
(Mat 24:33) - says (know that it is near, even at the DOORs)
Doors are plural,,, maybe this represents His Two Comings,
Once in the Rapture,
(I Thes 4:17) – (we which are alive,,, shall be caught up,,, to meet the Lord in the air,,,)
And once in all His glory, when His feet set on the earth again,,
(Rev 19:11-16) – (I saw heaven opened,,, His eyes were as a flame,,, on His head were many crowns,,, KING OF KINGS, AND LORD OF LORDS)
so, we are allowed to know the doors,
+ the 1st door is Jan 15th 2019
calculated from 1967.44 = when Israel took Jerusalem
which is part of the 70 X 7, of which the last 7 is the peace treaty
+ 51.6 years = duration of last generation
1967.44 + 51.6 = 2019.04
which is not when Christ will return,
but the end date for it happening within the same generation.
AS IN,,, IF JESUS DOES NOT RETURN BEFORE THIS
then the prophecy can no longer be fulfilled
Quote from: citfta on February 27, 2017, 10:11:12 AM
So you are claiming to know something Jesus said no man knows. So you are calling Jesus a liar.
You claim you figured it out with logic so you must be saying you are smarter than Jesus since He said even He did not know it.
I sure wouldn't want to be you at the time of Judgement.
I do not clam to know the day nor hour, which even Jesus does not know,
I happen to be showing you the 1st Door, or last date that the prophecy can be fulfilled,
which we are allowed to know in Mat 24:33 "know that it is near, even at the doors"
trying to point out just how close it is
we have less than 2 years before He MUST return
to have the prophecy fulfilled within the same generation
Quote from: citfta link=topic=17091.msg50104 6#msg501046 date=1488283507
Quote from: that_prophet on February 28, 2017, 09:28:57 AM
King James Version says:
Now learn a parable of the fig tree; When his branch is yet tender, and putteth forth leaves, ye know that summer is nigh:
33 - So likewise ye, when ye shall see all these things, know that it is near, even at the doors.
34 Verily I say unto you, This generation shall not pass, till all these things be fulfilled.
Well, its wrong. That generation did pass and all these things were not fulfilled
free energy is as easy as using pulleys to multiply your rotations,
+ considering AC electricity is made of rotations of an AC generator/motor,
this means that we can multiply AC electricity,,,
You pay for one rotation of a 100 cm circumference pulley,
+ get back 1000 cycles of AC electricity,
from AC generators that you add to the 10 small 1 cm circumference pulleys
that you add to the same belt.
It is the evil spirits that have hidden this super simple free energy technology from us,
Can you believe the simplicity of this technology that has been hidden from us,
I was hoping to make others aware of how simple this is,
To cause you be angry at what has been covered up
+ realize that there is a battle going on in this earth
between good + evil forces
This is a gift from God,,, found in Ezekiel 1:16
to the soon coming Tribulation Saints,
as the 7 years before the "end of the world" Mat 13:39
is the final 7 years of Israel's His-story
+ MUST begin before Jan 15th, 2019
Quote from: that_prophet on February 28, 2017, 02:42:46 PM
No, it isn't. It is rubbish. Your're wasting your time.
This is a gift, to all mankind, of the simplest form of free energy,
by paying for the one rotation of a large 100 cm circumference pulley,
we can multiply rotations to 1000 by simply adding 10 1 cm circumference pulleys with AC generators attached.
Now try + tell me that you cannot gain the power to rotate your drive motor one single time,
when you get an output of 1000 cycles of AC electricity to work with.
Quote from: Dog-One on February 27, 2017, 05:46:59 PM
with only a maximum of 23 months left, before Christ MUST return to rescue His born again followers,
which coincides with the last 7 years of His-story,
we need to get this free energy technology out now,
so many needed tools + equipment can be powered off the power grid,
to be used by all of the good people, that do not take the mark of the beast,
IF YOU TAKE THE MARK,,, YOU ARE DOOMED TO LIVE IN THE LAKE OF FIRE, ETERNAL
(YES, LIFE IS ETERNAL, + YOU ONLY GET YOUR CHOICE OF WHERE TO LIVE..........)
(WITH GOD, OR WITHOUT HIM)
so we can help these Tribulation Saints=(good guys + gals) survive the Great Tribulation,
which is the second half of the 7 year peace treaty with Israel,
because,,, I don't know, so that we can help the God fearing good guys + gals
as,,, because we are told to help others in His Good Book
But then again,
yes, this takes faith in considering logic, and not listening to the influence of evil spirits,
lying to you about this GEM free energy technology,
this is pure logic, it works on the logic of paying for the one rotation of a 100 cm circumference pulley,
and getting back 1000 cycles of AC electricity of output,
by adding 10 times 1 cm circumference pulleys with AC generators attached,
THIS AC electricity multiplier SIMPLY MUST WORK,,,
When you are only paying for the one rotation,
+ get a return of 1000's of cycles of AC electricity
how can you not be gaining free electricity,
when you are only paying for the one rotation of a DC motor,
+ gaining a return of 1000's of cycles of AC electricity
EVil-sOLUTION,,, isn't it amazing, what the "il-s" of life can reveal to you, the real meaning of words
Pure logic my ass this is pure shit.
After 23 months from now when nothing happens, please grow up and stop posting this crap.
GEM=(Geometrical Electricity Multiplication) http://free-energy.yolasite.com/
This is a Gift from our Father in Heaven, to all mankind, but especially to the soon coming Tribulation Saints
of the simplest form of free energy, using wheels within wheels-(Ezek 1:16)
we can multiply rotations to 1000 by simply adding 10 1 cm circumference pulleys.
This works on the simple logic,,, of using the mechanics of pulley technology,
Where you only pay the amount of current to rotate a large 100 cm circumference pulley once,
Then through pulley mechanics, you are gaining a return of 1000's of cycles of AC electricity,
by adding 10 small one cm circumference pulleys with AC generators
Quote from: pomodoro on March 04, 2017, 10:18:02 AM
Yeap. And then you use it all up attempting to keep that 100cm wheel turning.
Seems to be a common theme, people using stuff up they don't have to start with.
What are we down to, 22 months now?
The trouble with people like that_prophet is that they pull down the reputation of this site.
Quote from: Paul-R on March 06, 2017, 11:06:25 AM
In general, there are quite a few people who cannot explain their way of thinking.
If they could and attempted to walk through their idea, step by step, most would
realize their mistake.
It's a rare breed that can accurately communicate an idea with no missed steps
or overlooked calculations. In almost all cases they are able to do this because
they know the material inside and out, they've done the benchwork; they don't
need to read from a script. It's almost a shame we don't enforce some kind of
protocol here at this forum to ensure what is posted has actually been clearly
thought through. It would save us all a lot of headaches. There wouldn't be
threads with 1500 posts. After about 50 posts, there would be either a solid
concept and possibly a solution or it would be a dead idea, case closed.
This is based on the simple logic of it not costing 100 times as much energy to rotate a 100 cm circumference pulley as it does to rotate a one centimeter circumference pulley. Yet when you run the 100 cm of belt off of the one rotation of the large pulley, past 10 mini-pulleys of one centimeter circumference, we can multiply the amount of rotations by 100 for each mini-pulley, and if you added 10 mini-pulleys, then you would multiply the total # of rotations by 1000, and by adding AC generators to these 10 mini-pulleys, we can multiply AC electricity.
These 10 mini-pulleys run very easily, as they are only winding up massive voltage, needing only to generate the small amount of current to rotate the drive motor one single time. The massive amount of voltage is used to crank the large pulley over once, which would make this a self generating mechanism. This works by only having many small pulleys rotating freely, as they are only generating massive voltage, with extremely small amounts of current being needed to generate the large drive motor only one single time.
So you would get 1000 cycles of AC electricity, to produce only one spark worth of current, the amount needed to power your large pulley for one revolution.
Joe,
You're not seeing the obvious.
With a generator having a large pulley, it is easy to turn it.
A motor with a small pulley makes it easy for the motor to turn a load.
Your setup is ass-backwards. You have the motor connected to the
100cm wheel which means the slightest resistance on that wheel will
make the motor impossible to turn. Then to make matters worse you
have ten generators with small pulleys; again if these generators have
the slightest load on them you have no leverage, no torque to turn them.
Even if the generators have zero load, the bearing resistance will be
enough to where the large wheel skids instead of turns them.
What you are stating is attempting to use mechanical advantage completely
backwards. Instead, at every point you are creating a mechanical disadvantage.
I don't even have to get into the electrical side of your GEM, I can see
mechanically you have everything flip-flopped.
Now, if you were to reverse everything and use ten tiny little high speed
motors with small pulleys and one large low speed generator connected
to the 100cm wheel, you might actually have something worth experimenting
with. It would all depend upon how efficient those motors and the generator
is. I highly doubt you would be able to achieve self running, but at least
you would be fully utilizing mechanical advantage.
Just a side note, there are some motors out there that can reach incredibly
high RPMs and if the load is nearly non-existent, they consume almost
no power in those conditions. Ten of those motors might be able to turn
a wheel and provide enough torque to actually get a generator to produce
a little power without the motors loading up and slowing way down. If the
motors are all low voltage and connected in series... Who knows. Might
work.
Quote from: Dog-One on March 06, 2017, 03:03:48 PM
Yes, but that's not what we have here. The man has been told a hundred times and perseveres unchanged with his rubbish.
In reality, I wonder if he cares,. This thread and the two dozen others that he he created are merely a vehicle to publish his daft religious ideas. He has abused his privleges and Stefan should Yellow Card him for the sake of the site.
Have you tried energetic forum phat profet? You may get more belief over there. I believe there is a priest of two floating around over there.
I know for a fact he has tried there. I doubt if there is a forum anywhere he hasn't tried. Of course most of them kicked him out shortly after he got there or didn't even let him join in the first place.
If you use the DC motor to generate a single rotation of a 100 cm circumference pulley, giving you 100 cm of moving belt, which you run by ten 1 cm circumference pulleys, with AC generators attached, this would give you a total of 10 X 100 =1000 cycles of AC electricity. That is one rotation of a DC motor in, through pulley mechanics producing 1000 cycles of AC electricity output. Now, try and tell me that these 1000 cycles of AC electricity cannot produce enough DC current to rotate the motor once.
Quote from: pomodoro on March 08, 2017, 12:31:30 AM
Quote from: that_prophet on March 09, 2017, 04:51:11 AM
Actually they don't. There you go, I tried. So how many days left exactly ...700 or so I believe.
Quote from: pomodoro on March 09, 2017, 05:28:11 AM
Well actually they do produce enough electricity to turn the motor. IF the motor was not connected to the load. What he has been told a thousand times and still doesn't understand is that with all those generators or alternators whatever he wants to call them connected to the large diameter the mechanical load will be so large the motor will stop no matter how much power is applied to the motor. He refuses to understand the basic mechanical problem with his design. He just does not understand that it takes real power to turn a generator when it is loaded. He claims to be a genius but is unable to look up the simple basics of how a generator works. He also doesn't understand how a motor works because he keeps referring to a spark of electricity to run his motor. His very deep lack of knowledge has given him this delusion of an idea to produce electricity for free.
So his name is Joe ??
@ Joe ,
Do they Let you talk on the phone there ?[I heard you were recovering from a very serious head trauma ?
I hope your recovery is going well.
I'm sending you a PM.
respectfully
Chet K
Quote from: citfta on March 09, 2017, 06:48:48 AM
No, there is practically zero load on the AC generators, as they are only winding up massive voltage, as they only need to generate one spark of current. These AC generators only need to generate the small amount of current to rotate the DC drive motor one full time, and this is from 1000 revolutions of the AC generators. All of the 1000 revolutions from the 10 AC generators, only need to generate the small amount of current that it takes to rotate the DC drive motor one single time.
There is practically zero load on this system. Out of all 1000 revolutions of the AC generators, you only need to generate the minute amount of current that the DC motor needs to rotate one single time. Since torque is caused when power is generated, practically zero current times even massive voltage, still equals practically zero power = practically zero torque. These AC generators are just winding up massive voltage, which is exactly what you need to crank your DC motor over one time.
Quote from: ramset on March 09, 2017, 06:51:48 AM
@ Joe ,
Yes, they do let me have a phone,,, lol
I can message you my phone # if you would like
respectfully
Chet K
Thank you, and yes I have been recovering from a pretty severe closed head injury
this accident happened in 96, where I died twice, + then they even cut off my life support
it wiped out all of my short term memory, and 1 year of my long term.
I had to relearn everything, including how to speak
joe
Joe
quote
end quote
yes please do PM your number ,I will call you today
respectfully
Chet K
Let me explain to you, just how simple minded that we have been brought down to, by the evil influences that Satan + his minions. My hope is, to aggravate as many people as possible, by showing them just how pre-school super simple this AC electricity multiplication technique truly is, and to get you to think about the power that evil forces must have over us, to be able to hide such dirt simple technology from us for so long.
If you have a 100 cm circumference pulley, (about 3-4 inch in diameter), driven by a DC motor + rotated only one single time, then it would only take the smallest amount of power. Yet it should be the simplest to see that as an output, this would surely return us a great multiplication of electrical power. Please, forget about this evil talk about torque problems, this one AC generator is a free running motor, with the only resistance that is felt by your AC generator is the viscosity of the bearing lubricant.
I can say this because you are only looking for the slightest amount of current, that it takes to rotate a DC motor once, barely a spark of current. Since torque is caused when generating power, and power is defined as voltage times current, and when your current is practically zero, your total power is practically zero. This is from the most basic mathematical rule, where zero times anything is still equal to zero, where zero is substituted with almost zero.
This truly does work,,,
That is why Satan + all of his evil dominion are working their hardest to keep this hidden
Just think of 10 free running electric motors,
They would rotate so easily that there would be little to no torque resistance,
These generators would simply be winding up massive voltage, (electrical pressure)
10 X 100 = 1000 rotations,(and by attaching free floating AC generators to each )
Which is exactly what you need, to be cranking over your large drive pulley the one time,
You only have to pay to rotate a 100 cm circumference pulley once,
Which costs merely one small bit of current,
+ through simple pulley mechanics of using 10 1 cm circumference pulleys,
with AC generators attached, you can gain 1000 cycles of AC electricity
This works on the simple logic,,, of using the mechanics of simple pulley technology,
This GEM free energy technology is as simple as multiplying rotations with varying size + # of pulleys. By only imputing the minute amount of electricity to rotate your DC drive motor one single time, (a mere flash of current, enough to crank the motor over once, just a spark).
Think of it as 10 motors running free, with only viscosity of the lubricant as resistance, especially with the new sealed or magnetic levitation technology.
10 free floating motors, not connected to any wires, so they are running free of any resistance, and would be just winding up massive voltage. Isn't that amazing, that massive voltage - or back pressure, is exactly what you need, to crank over your large pulley.
The mini-pulleys with AC generators will rotate 100 times, for every one that you add to the belt. So, if you only added 10 mini-pulleys, you would gain 10 X 100 = 1000 cycles of AC electricity.
This works on the simplest of pre-school pulley mechanics, to simply multiply your total # of rotations + by simply attaching AC generators, we can actually multiply AC electricity,,,
YES, USING DIFERENT SIZE + # OF PULLEYS TO ACTUALLY MULTIPLY YOUR POWER.
Yes, you can get away with seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to multiply your total # of rotations. This can be extremely significant, considering that AC electricity is created using rotations, and the more rotations equals the more AC electricity. If you use a DC motor to drive a 100 cm circumference pulley for one complete revolution, it only costs you one single spark of DC current, to give you 100 cm of moving belt.
. Then all that you have to do is add an even larger belt, and run this length of 100 cm of moving belt past 1 – 10 mini-pulleys of 1 cm circumference with AC generators attached, you can gain 100-1000 units/cycles of AC electricity. YES,,, that's a return of 1000 units/cycles of AC electricity, all for only one single burst of DC current, the small amount that is required to rotate the motor one full rotation. It is truly that simple,,, and why hasn't anybody figured this super simple free energy technology before? It is because evil spirits are still, and have been trying their hardest to hide this technology from us humans.
- I say this because I found this ancient technology in the Holly Bible = Ezekiel 1:16, where he is trying to describe what a running UFO motor looks like. "a wheel in the middle of a wheel", or as I pictured it, a small wheel, running on the inside of a large wheel. But, since I did not have that ability to have a small wheel, running on the inside of a large wheel, I decided to go with a pulley, and have both wheels=pulleys run inside this larger belt.
. Is not spiritual
. How can you not gain massive amounts of AC electricity, when you only pay for one rotation, and through simple pulley mechanics we can multiply our AC electricity.
I seriously hope that I have insulted your intelligence,
By showing you just how super simple this technology truly is,
Yet, it begs the question, why have we not discovered this simple technology long ago
f you attach a 100cm circumference pulley to a DC motor
it only takes one spark of DC current to rotate a DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley
then you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC generators attached
the greater amount of current you should be able to do work with
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
http://free-energy.yolasite.com/ = PUBLISHED 2001 OR 2002
(YET THERE IS SUCH A SPIRITUAL WARFARE GOING ON AGAINST IT)
((( evil spirits were hiding this tech = lies about torque being a problem )))
Now comes the bad+scary part of this awesome free energy technology discovery
You can easily see just how super simple this AC multiplication technology is
so why could not any one of the millions of above average intelligence have discovered this
long ago... as soon as AC electricity was discovered. Well this is hard positive proof
of there being powerful spiritual warfare going on all around us... + they were winning
I would say that these powerful evil forces were winning - if they could hide this from us
I happen to be Born Again-(28-11-88) + want this super simple free energy technology known
long before the first Door closes for Christ's return in the clouds by or before 2019.04
http://doorschristmustpassthrough.yolasite.com/ + http://2020-vision.yolasite.com
This technology is in the Holy Bible = in Ezekiel 1:16
where he is describing what a UFO motor looks like while it's running
so this technology will eventually lead us to anti-gravity
as well as not only speeds approaching the speed of light
but also the ability to do 1000 kph vectoring
We are warned that no one knows the day nor hour... (Mat 24:36) but it says that we will know
when it is near... near to what? maybe the door.... as we can know when it's"even at the doors"
(Mat 24:33) + I heard that in the original Greek it was worded like a command "know that it is near"
With this technology the Tribulation Saints can keep warm in our cold Canadian winters
even off the power grid. (remember the heat + light of fires would easily give away
your position visually... as well as via satellites)
notice that Doors are plural - because He show up twice =
1) - Rapture = "caught up together with the in the clouds"-(I Thes 4:17)
2) - "Glorious Appearing" at end of Tribulation -(Titus 2:13)
( + there are less than 2 years left before the door shuts, the door Christ MUST come back through) . . .
Joe
It was good to speak today ,we will try to get you a simple simulator program for your computer.
hopefully you will have a good time experimenting on the computer ,I have a family member who suffered brain damage at birth and I can appreciate the challenges that you face .
The only thing I ask is you keep your comments here in this thread ,and I will help you anyway possible and I am certain others here will also help.
and please keep in mind here at this forum we work on FE devices ,we really don't get into politics religion or sports [yeah that can be a problem too]
maybe you could start a religious Blog and put a link at the bottom of your posts ?
with respect
Chet K
Joe isn't crazy. He just made a small misinterpretation.
You gotta hand it to the guy, he has tenacity. You seem very certain.
After my two own ideas this is my 3rd best choice to try.
There is no difference now between the talking crazy, the talking frauds, and the misled.
My best bet is with the crazy guy... Slightly more .0043 %
Maybe I will try this thing. This pulley thing is my type of thing, another possibility in the flywheel department.
Now... If only your could save me time and make a good drawing instead of all this long text.
Quote from: ARMCORTEX on March 12, 2017, 05:33:57 AM
I doubt it. All he is good at is "cut and paste".
Here is a picture he posted in one of his twenty something threads on this forum.
This is so-caled QMoGen (http://peswiki.com/news:qmogen) (motor-generator) system.
The efficiency of motor and dynamo is always lower than one: no reason why it should work.
. This works on the simplest of pulley mechanics, to multiply the # of rotations + by attaching AC generators, we can actually multiply AC electricity. It can get away with seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to multiply your total # of rotations. That can be significant, considering that AC electricity is created using rotations, and the more rotations equals the more AC electricity. If you use a DC motor to drive a 100 cm circumference pulley for one complete revolution, it only costs you one single spark of DC current, spark=(the small amount of current that it takes to revolve one full time) to give you 100 cm of moving belt.
. How can you not gain massive amounts of AC electricity, when you only pay for one rotation, and through simple pulley mechanics we can multiply our AC electricity by 1000's of cycles.
There is no torque problems, because these AC generators take practically no torque to rotate. They are like free running motors until load is put on them, and because you have 1000 rotations to only generate one small bit of DC current, when divided out by 1000, each rotation does not cost practically any torque.
PLEASE,,, we could all be building our own AC electricity generators. We could start new industries, building all of our electric tool, toys + appliances, with self powering GEM motors in them.............
+ think about all of the pollution that we could be keeping out of our air, by making GEM motors for our automobiles
Quote from: Dog-One on March 07, 2017, 07:08:15 AM
Joe,
No, my setup is just right, I happen to be trading one rotation of a DC motor, + a large pulley,
For massive amounts of rotations of many small pulleys, with AC generators attached,
Returning me massive cycles of AC electricity
I happen to be trying to multiply the total # of rotations,
+ by adding AC generators, multiplying the total amount of AC electricity.
By trading one rotation of a large 100 cm circumference pulley
For 100 rotations for each of the 10 small 1 cm circumference pulleys = 10X100=1000
That is trading 1 rotation for 1000 rotations = using simple pulley mechanics
+ by adding AC generators to these 10 small pulleys, you are multiplying your AC electricity
And there is no torque problem, as these AC generators are just winding up massive voltage
As they only need to generate one spark of DC current,
Which is all the current needed to rotate you DC motor one single time
+ you get 1000 revolutions of your AC generators,
To add up to the one spark of current needed
That is one small bit of DC current,
Divided by 1000 cycles of AC electricity,
Which is equal to practically nothing
Joe
working on getting you that Sim so you can model these things
trying to get one with some support so you can get help working with it.
any questions let me know
I have been getting ready these last few days for a very strong storm which could collapse some of my Outbuildings
the storm is here now [2ft plus snow upto 80 MPH gusts
will touch base tomorrow [if I still have power....
thanks for your patience
respectfully
Chet K
Thank you Chet,
all that I can think of is, as long as it can handle many different size pulleys,
with many AC generators attached
I can't see why others can see this,
you are trading one rotation of a large pulley,
with the 1000's of revolutions that you can get from 10 mini-pulleys
you are creating massive voltage = electrical pressure
with your 10 free running AC generators = 10X100=1000
to generate the single bit of DC current that is needed to drive your DC motor one revolution
Sorry to hear about your storm troubles
+ sorry for not being here on Sunday, if you phoned then.
I was out to Church, + then visiting my ex-wife
Quote from: ramset on March 14, 2017, 10:37:48 AM
Joe
respectfully
Chet K
This uses the 100 cm of moving belt that comes off of one single rotation of a large 100 cm circumference pulley to run past 10 or multiple # of small 1 cm circumference pulleys to multiply your total # of rotations. Then by simply adding AC generators to these small pulleys, we can multiply the amount of AC electricity. Yes, by adding multiple small 1 cm circumference pulleys to the same belt as the large 100 cm circumference pulley, we can multiply the # of rotations, and by adding AC generators, we can multiply the amount of AC electricity. On one half of this system we are using the 100 cm of moving belt, to wind up massive voltage, by multiplying the # of rotations of free running generators on many small pulleys. Then, on the other side of this, we are using the high amount of voltage to rotate the large 100 cm pulley one single time. These many small pulleys run free of most any torque, because they are only winding up massive voltage, and only need to generate the small bit of DC current, that is needed to rotate the large pulley one single time, producing 100 cm of moving belt. I can say this because torque is needed to generate power, and P=IV, which is, power is equal to "I"-current times "V"oltage. Since the current is practically zero, and zero times even massive voltage is still equal to practically zero power=torque. http://free-energy.yolasite.com/
This uses the 100 cm of moving belt that comes off of one single rotation of a large 100 cm circumference pulley, that only costs a mere spark of current, the minute amount of current that a DC motor takes to rotate one full rotation. This moving belt is run past 10 small pulleys of 1 cm circumference, to multiply your total # of rotations. Then by simply adding AC generators to these small pulleys, we can multiply the amount of AC electricity. Yes, by adding multiple small 1 cm circumference pulleys to the same belt as the large 100 cm circumference pulley, we can multiply the # of rotations, and by adding AC generators, we can multiply the amount of AC electricity.
On one half of this system we are using the 100 cm of moving belt, off the single rotation of a 100 cm circumference pulley to wind up massive voltage, by multiplying the # of rotations of free running AC generators on 10 small-1 cm circumference pulleys, 10X100=1000. Then, on the other side of this, we are using the high amount of voltage to rotate the large 100 cm pulley one single time.
These many small pulleys run free of most any torque, because they are only winding up massive voltage, as they only need to generate the small bit of DC current, that is needed to rotate the DC motor one single time. This DC motor has a large 100 cm circumference pulley, producing 100 cm of moving belt to work with. I can say this because torque is needed to generate power, and P=IV, which is, power is equal to "I"-current times "V"oltage. Since the current is practically zero, and practically zero times even massive voltage is still equal to practically zero power=torque. http://free-energy.yolasite.com/
Joe
The software needs to be "Ezekiel enabled" or it won't produce the daft results that that_prphet requires to be confirmed.
it only has to produce 100 cm of moving belt, off the one rotation of a 100 cm circumference pulley, and then produce 100 rotations for every small1 cm circumference pulley that you attach. Then by adding AC generators to these small pulleys,,, it produces 100 cycles of AC electricity. That is trading one rotation for 100 rotations, + with AC electricity this can be very beneficial
Quote from: Paul-R on March 18, 2017, 08:41:16 AM
This works on the simple principle of through pulley mechanics, being able to trade one revolution of a 100 cm circumference pulley for 100 rotations of a one centimeter circumference pulley. This can be very significant, when you are talking about AC electricity, which is created by rotations. So, the more rotations can mean more AC electricity. So, in effect, you are using pulleys to multiply your AC electricity.
Hi all, Hi that_prophet, i just had a thought about an easier design, that may operate with the same pulley mechanics prophet is looking for.
Though this does not use individual pulleys.
How about one very large rotor wheel, like 3 feet in diameter or greater, with magnets around perimeter or close to edge.
This big magnet wheel could be separate mounted with dedicated bearings, then shaft coupler or chain or belt drive.
Then, one coil mounted at periphery, would act as the small pulley at alternator.
Then as many coils as one likes can be placed around wheel, next to the magnets.
This seems like the same principle.
One turn of the drive motor, will yield possibly 50 or more coil/magnet interactions, per coil, depending on how many magnets are on the wheel.
Add another coil and we have 100 coil/magnet interactions per drive motor turn.
Now couple this setup, with Thane Heins delayed lentz reaction coil design and things could get interesting.
Does this sound equivalent to your design principals that_prophet?
peace love light
Quote from: SkyWatcher123 on March 23, 2017, 12:17:23 PM
I think you'll find this is described in Patrick's Chapter 2.
Hi paul, yes i think if i recall correctly, that is the work done by lee tseung or someone else.
Though i don't think they have also implemented Thane Heinz coil methods.
So that could make things even more interesting, beyond the leverage, pulley mechanics advantage that, that_prophet is talking about.
peace love light
To rotate your DC motor you need massive voltage, + practically zero current, only enough current to crank over thee DC drive motor one single rotation. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this moving belt past 10 one centimeter circumference pulleys with AC generators attached, you would end up with 10X100=1000 cycles of AC electricity. These 1000 cycles of AC electricity are running free of practically any torque, as they are used to wind up the massive voltage that is needed to crank over you DC motor.
Torque is caused when you are generating power, and P=IV or Power is equal to "I"-current times Voltage. Since practically zero current times even massive voltage, still equals practically zero, there is practically zero power + torque being created. So, each half of this system is powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
Hi that_prophet, did you look at previous page, the post i made about a possible equivalent design.
Let me know if you think it fulfills the operating principal.
peace love light
This free energy method, (GEM=Geometrical Electricity Multiplication) is super simple, in that it uses multiple # of different sizes of pulleys to multiply the total # of rotations. Then by simply adding AC generators to these multiple # of mini-pulleys, we can actually multiply AC electricity.
Please remember, these AC generators run free of most all torque or resistance, + are like free running electric motors, with the only resistance being the viscosity of the bearing lubricant. These 10 AC generators only need to generate the minute amount of DC current to rotate this one DC motor one single time. That's practically no current divided by 1000 rotations, which is practically 0 divided by 1000. So you only need 1000th of practically nothing for current, and practically zero current times even massive amounts of voltage still equals practically zero. In being easily able to generate this miniscule amount of current, the amount to rotate a DC motor one single time. You now have the free output of a self powering set of 10 AC generators, along with the single DC motor's output.
You do not understand,,, this is sooooo...... simple,,,
This takes the 100 cm of belt that comes off the single rotation of a 100 cm circumference pulley,
+ runs this length of belt past 10 mini-pulleys of thee one centimeter circumference pulleys, which gives you 10X100=1000 rotations + by simply adding 10 AC generators, you can have 1000 cycles of AC electricity.
So although it may cost massive amounts of voltage to crank this large pulley over once, it only costs you one flash/spark/bit of current, to gain 1000 cycles of AC electricity, which can easily gain you the massive voltage that you need to crank over your DC motor one single time. And, because you only need the one little spark of current to rotate your DC motor once, these AC generators rotate with practically zero torque.
This is a self powering set of AC generators + your one DC motor, all that is missing is 10 full wave bridge rectifiers, to convert your AC output back into a DC input.
No, you are the one who does not understand, and you have definitely proven one thing: you never will understand.
Quote from: TinselKoala on March 26, 2017, 08:31:43 AM
He's a religious fundamentalist with a bunch of mistranslated scriptures. We should be glad he is not inclined to flying airliners into buildings.
BTW, TK, was it you who got together some hefty supercaps and used them to start a car? If so, how long do the caps keep their charge when left in a dry place?
Yes SkyWatcher,
I think that your system would work in a similar way.
you are trading one rotation to gain many cycles of AC electricity,
you would be only paying for one rotation of your drive motor,
+ gaining as many cycles of AC electricity as you had of magnets that you had around the edge
Quote from: SkyWatcher123 on March 25, 2017, 02:43:14 PM
peace love light
Quote from: Paul-R on March 26, 2017, 10:50:45 AM
No, not me. But I have some Nesscap brand aerogel supercaps on my workbench that keep their charge for weeks. They don't seem to discharge at all when not in use. I suppose there must be some internal leakage but I haven't been able to detect it yet.
Its was lasersaber using supercaps to start his car.
https://www.youtube.com/watch?v=z3x_kYq3mHM
ElectroBOOM Video :)
https://www.youtube.com/watch?v=tKki89sq0XY
Thanks to both of you.
http://free-energy.yolasite.com/ this is so simple that it should be obvious,,, you only pay one spark of DC current to rotate a 100 cm circumference pulley once, and through simple pulley mechanics, with 10 X 1 cm circumference pulleys with AC generators attached, you can easily gain 1000 cycles of AC electricity. These AC generators take practically no torque to rotate as they are only winding up massive voltage, with no need to gain any current, except for the one spark of current that it takes to crank over your DC drive motor once. Then these 1000 cycles of AC electricity easily have enough voltage to crank over your DC motor the one single time it needs to have this a self powering system. Of course you have to add 10 full wave bridge rectifiers, (4 diodes) to convert your AC output into the DC input that you need to power your DC drive motor.
PLEASE,,, DON'T LET EVIL FORCES HIDE THIS SIMPLE FREE ENERGY TECHNOLOGY ANY LONGER
I received this from God, after asking for a way to help the Tribulation Saints survive the soon coming Great Tribulation. http://doorschristmustpassthrough.yolasite.com/ I was first shown a 10 speed bicycle going uphill in 10th gear, and then back down in first gear. Then I later thought that it might have been an evil spirit leading me in the wrong direction, so I ask my Father to show me it was from Him, and not just evil spirits leading me astray. He Graciously pointed me to Ezekiel 1:16, where Ezekiel was trying to describe how a running UFO motor worked, "wheel in the middle of a wheel", or as I saw it, wheels inside of wheels. Since I did not have any thread technology where I could put wheels inside of wheels, I went with pulleys and a belt.
TIME IS VERY SHORT, AS WE ARE NOT ONLY LIVING IN THE END TIMES,
BUT ALL WHO ARE BORN AGAIN + LOOKING FOR HIS RETURN
= HAVE LESS THAN TWO YEARS TO LIVE,
BEFORE THE DOOR CLOSES ON THE BLESSED HOPE OCCURING
+ MILLIONS VANISH OFF EARTH.
Why I believe that ISRAEL'S 7 YEAR PEACE TREATY must start,
BEFORE JAN 15, 2019 when = http://2020-vision.yolasite.com/ = 1st DOOR closes
Of which, the second half of this duration, is known as the "Great Tribulation"
When Satan + most all of the fallen angels + their offspring = (aliens + giants)
Will be sent to this earth, "woe to ,,, earth and of the sea!" (Rev 12:12)
Remember that although we are warned "that day and hour knoweth no man" (Mat 24:36)
We are allowed to "know that it is near, even at the doors" (Mat 24:33)
Because we are "this generation shall not pass" = (Mat 24:34)
PLEASE ALERT THE WORLD ABOUT THIS HIDDEN TECH
((( NEWS of this ancient technology will change the world)))
Simplicity of using pulleys to multiply # of rotations, + by simply adding AC generators, we can actually multiply our AC electricity. It is truly that simple, and the only reason that we have not discovered this dirt simple pre-school technology before this, is the massive amount of spiritual warfare that is going on in order to hide it. Yes, Satan is teaming up with all of the evil spirits, to desperately hide this pre-school simple technology, and they have been able to cover it up for the most part, at least since the time of Ezekiel's writing in Ezekiel 1:16.
This uses the 100 cm of moving belt that comes off of one single rotation of a large 100 cm circumference pulley, that only costs a mere spark of current, the minute amount of electricity that a DC motor takes to rotate one full rotation. This moving belt is then run past 10 small pulleys of 1 cm circumference, to multiply your total # of rotations, and by simply adding AC generators to these small pulleys, we can multiply the amount of AC electricity. Yes, by adding multiple small 1 cm circumference pulleys to the same belt as the large 100 cm circumference pulley, we can multiply the # of rotations, and by adding AC generators, we can actually multiply the amount of AC electricity.
On one half of this system we are using the 100 cm of moving belt, off the single rotation of a 100 cm circumference pulley to wind up massive voltage, by multiplying the # of rotations of free running AC generators on 10 small-1 cm circumference pulleys, 10X100=1000. Then, on the other side of this, we are using the high amount of voltage, (electrical preasure) to rotate the large 100 cm pulley one single time.
These many small pulleys run free of most any torque, because they are only winding up massive voltage, as they only need to generate the small bit of DC current, that is needed to rotate the DC motor one single time, (which is practically nothing). This DC motor has a large 100 cm circumference pulley, producing 100 cm of moving belt to work with. I can say this because torque is needed to generate power, and P=IV, which is, "P"ower is equal to "I"-current times "V"oltage. Since the current is practically zero, and practically zero times even massive voltage is still equal to practically zero power = which means practically zero torque.
This works on the simple principle of through pulley mechanics, being able to trade one revolution of a 100 cm circumference pulley for 100 rotations of a one centimeter circumference pulley. This can be very significant, when you are talking about AC electricity, which is created by rotations. So, the more rotations can mean more AC electricity. So, in effect, you are using pulleys to multiply your AC electricity. http://free-energy.yolasite.com/
Best GEM = (Geometric Electricity Multiplier) free energy technology
This starts by only inputting one spark of DC current into a DC motor, or you could give the large 100 cm pulley a quarter turn with your hand, either option should start this free energy technology of an AC electricity multiplier perpetually running. This extremely minimal amount of DC electricity, is all that is needed to rotate your DC motor one single time. This can be very significant when you have a 100 cm circumference pulley attached, creating 100 cm of moving belt. If you ran this length of moving belt past 10 mini-pulleys with 1 cm circumference pulleys attached, you could produce 1000 cycles of AC electricity, as 10 X 100 = 1000. (now, try + tell me that you cannot gain enough voltage from these 1000 cycles of AC electricity to crank over your DC motor one single time)
Re: GEM=(Geometrical Electricity Multiplication)
In (Mat 13:39) it says "the end of the WORLD"
Now hold on,,, our world is never going to end,
Proof= (Isaiah 45:17) + (Ephesians 3:21) = "world without end"
This is mistranslated + should say "end of the AGE"
as in, the age of Christianity, (before Born Again Christians are taken up in the clouds)
Or this WORLD SYSTEM ENDS,,,,,,,,,,,,
then using 51.6 as the duration for the end time generation,
(calculated from 14+14+14 in Mat 1:17)
Starting with 1967.44, (when Israel took Jerusalem)
As Jerusalem was needed, as it was part of the 70 X 7s
MATH : 1967.44 + 51.6 = 2019.04
adding (6.9solar) = the 7 Hebrew year for the Tribulation,
then as for the door=deadline for Christ setting His feet on earth,
we would get 2025.94 = 2019.04 + 6.9
This way, we are shown both of the doors,
So 2020,(2019.04) is the 1st DOOR,,,,, (Rapture, meet in the clouds)
Or should I say, one of the DOORs,
And 2026,(2025.94) is the other DOOR, (when Christ sets His Foot on the Mount of Olives)
With so little time left,
As of Jan 17th of 2017,,, there are less than two years left,,,
I would like to work 24/7,
But although I have been known to go 3 or 4 days,
without any down time,,,
I usually have my brain pass out,
for two to three hours, every two to three nights,,, lol
Your Bro,
. . . . . . . . joe
Just one of His Creations:
EVil-sOLUTION – isn't it amazing just what the il-s of life can reveal
I hope that I may be able to shake up this world
I want to dissolve this EVil-sOLUTION fairytale
I would like to know how their Humanist scientists explain
How does our moon remain in its orbit
With the constant addition of space dust
We do not hear much about space not being empty
But it contains a steady stream of dust partials
Messing up the mass + the trajectory of orbits
+ Why is there only about 6000 years worth of dust on the moon's surface?
PLEASE,,, do the calculations for yourself,,,,,,,,,,,,,,,,
https://www.google.ca/#q=calculating+space+dust+sediment+on+moon&*
(the moon is GOD's Creation hourglass = proof positive of earth's age)
So, how much space sediment would there be on the moon,
After billions of years of precipitation,,, billions of even mm's of sediment,
Is still equal to many meters of sediment,
+ how much is on the lunar videos,,,,,,,,,,,,,,
LESS THAN AN INCH
This proves that our earth cannot be billions of years old
Isn't it amazing, that if you calculate the total amount,
That it works out to be just about 6000 years worth of sediment
Exactly what the Holy Bible predicts
If you find yourself alive today
Get use to it,,, life is forever
Your going to be here for the long run
That's Forever + Ever,,,
You only have one choice,,,
--- Where to spend eternity
--- --- Heaven =(place where God Is + Rules)
. . . . . or
--- --- Hell =(place where God does not rule)
Choose Christ today + become Born Again
(John 3:3)="Except a man be born again, he cannot see the kingdom of God."
TIME IS VERY SHORT, as we are not only living in THE END TIMES,
- but all who are BORN AGAIN + LOOKING FOR HIS RETURN
= have LESS THAN TWO YEARS to live,
before the DOOR CLOSES on the BLESSED HOPE occurring
when MILLIONS VANISH off this earth
BEFORE JAN 15, 2019 when= 1st DOOR closes: http://2020-vision.yolasite.com/
Of which, the 2nd ½ of this duration, is known as the "GREAT TRIBULATION"
We are allowed to "know that it is near, even at the doors-(close on last day)" (Mat 24:33)
« Reply #160 on: April 01, 2017, 11:44:15 AM »
PLEASE,,, DON'T LET SATAN (the beginning of lies) + EVIL FORCES HIDE THIS PRE- SCHOOL SIMPLE "GEM" OF A FREE ENERGY TECHNOLOGY ANY LONGER
I received this from God, after asking for a way to help the Tribulation Saints survive the soon coming Great Tribulation. http://doorschristmustpassthrough.yolasite.com/ I was first given a Vision of a 10 speed bicycle going uphill in 10th gear, and then back down in 1st gear. Which is very significant, considering that AC electricity is made from rotations of a coil of wire inside a field of 2 magnets. Then I later thought that it might have been an evil spirit leading me in the wrong direction, so I ask my Father to show me it was from Him, and not just evil spirits leading me astray. He Graciously pointed me to Ezekiel 1:16, where Ezekiel was trying to describe how a running UFO motor worked, "wheel in the middle of a wheel", or as I saw it, wheels inside of wheels. Since I did not have any thread technology where I could put wheels inside of wheels, I went with pulleys and a belt.
« Last Edit: April 01, 2017, 10:29:22 PM by that_prophet »
« Reply #161 on: April 02, 2017, 12:28:22 AM »
as in, the age of Christianity, (before waiting Born Again Christians are taken up in the clouds)
As Jerusalem was needed, it was part of the 70 X 7s
Which 69 of have already happened in the distant past
+ the last week is the infamous 7 year peace treaty with Israel + Europe + others
Of which the last half is "the Great Tribulation"
And 2026,(2025.94) is the 2nd DOOR, (when Christ sets His Foot on the Mount of Olives)
Your Bro,
. . . . . . . . joe
EVil-sOLUTION – isn't it amazing just what the "il-s" of life can reveal
I would like to know how these Humanist scientists explain
How did our moon remain in its orbit
With the constant addition of over billions of years worth of space dust
even billions of years worth of nanometers
LESS THAN AN INCH
Isn't it amazing, that if you calculate the total amount of dust
Exactly what the Holy Bible says that it should be
then I suggest you get use to it,,, life is eternal
That's Forever + Ever + Ever,,,
--- You only have one choice,,,
--- --- Where to spend this eternity that God has locked you into
--- --- --- Heaven =(place where God Is + Rules)
. . . . . or
--- --- --- Hell =(place where God does not rule)
Life in what we call reality is more like we were mere images on a video screen
Matter has no substance, we only see + feel it because of the specific energy it has
Minute particles spinning around orbits so quickly, that it appears to be in every position at all times
That is slowly wearing down, think of atomic halflife
Your spirit is the part that is eternal, (how do spirits evolve)
All matter was created by God
How can we believe this ridiculous Humanist doctrine that states in text books, as if real science
These super complex atomic structures, (Which man cannot even conceive how to create)
Were all made from a big bang = (this takes more faith than any other religion)
Explosions destroy not create
This works on the simplicity of only having to pay the small amount of electricity, (massive voltage + only one spark of current) for the one single rotation of a DC motor with a large 100 cm circumference pulley attached. Then you take the 100 cm of moving belt, that comes from the one rotation of your 100 cm circumference pulley, and run it past 10 of the 1 cm circumference pulleys. This would multiply your # of rotations to 10 X 100 = 1000, and if you added AC generators to these 10 mini-pulleys you would gain a total of 1000 cycles of AC electricity.
These AC generators would run free of most any torque, as they are just winding up massive voltage,(which is what you need to crank over your DC motor=electrical pressure) as the only current that they need to generate is the one spark, or practically zero. You only need to generate one spark of current, because that is how much current that it takes to rotate your DC motor, with the 100 cm circumference pulley one single time. Of course you would also need 10 full wave bridge rectifiers, (4 diodes each) to convert your AC outputs back into your DC input.
you are trading one rotation of a 100 cm circumference pulley, (taking massive voltage) for 1000 rotations = 100 rotations each from 10 mini-pulleys with AC generators (creating massive voltage)
This is so simple that it just has to work.
It only takes one spark of DC current to rotate a DC motor one single time,
+ If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm
of moving belt Then, if you run this 100 cm of belt past 10 of these free running 1 cm circumference mini pulleys you would get 10 X 100 = 1000 rotations.
If you add 10 AC generators, one to each mini-pulley,
These 10 AC generators run torque free, as they only need to generate one spark of DC current,
which is practically zero, and practically zero current, times even massive voltage,
is still equal to practically zero.
You just have to be multiplying AC electricity, when you only input one spark
= small amount of DC electricity that it takes to rotate a motor one single time,
+ get a return of 1000 cycles of AC electricity
These AC generators run free of most all torque, as they only need to generate one spark of DC current, to make this free energy technology self powered, + crank over your DC motor one time
This GEM free energy technology simply must work, as it only has to generate the slight amount of DC electricity to rotate a DC motor once, with the large 100 cm circumference pulley attached, giving you 100 cm of moving belt. When you run this 100 cm of moving belt past 10 mini-pulleys, you would gain massive amounts of voltage, from these 10 mini-pulleys of 1 cm circumference rotating 100's of tines each, equaling a total of 1000 cycles of AC electricity. That's one small bit of DC current in, that gives you a return of 1000 cycles of AC electricity output. (now try and tell me these 1000 cycles of AC electricity cannot produce on small bit of DC electricity, that you need as input in order to make this a self powering mechanism)
Quote from: that_prophet on April 12, 2017, 01:40:03 PM
I think we tried Joe, to no avail.
By the way, you forgot to post your picture.
+ If you attach a 100 cm circumference pulley to this DC motor it will give you 100 cm of moving belt
If you add 10 free running AC generators, one to each mini-pulley,
= small amount of DC electricity that it takes to rotate a DC motor one single time,
You are looking at the small size of these mini-pulleys + talking about a lot of torque to rotate them
when they only have free running AC generators attached, which take practically zero torque to rotate
as motors/generators only take torque to turn if they are generating power, which is equal to voltage times current
+ since you only need to generate one spark of current, (the amount to crank over your DC motor one single time)
+ this is to be generated by 1000 rotations from 10 generators, the cost per rotation is practically zero divided by 1000
which is less than practically nothing + I know that I also need 10 full wave bridge rectifiers, to convert your 1000 cycles of AC electricity into your needed 1 spark of DC current
PLEASE EXPLAIN TO ME,,, why is it that you do not believe that these 1000 cycles of AC electricity cannot give you the small amount of DC current that it take to rotate your DC drive motor one single time,,,,,,, (making this unit self powering)
Please, re-post the explanation then, OR try explaining it again
as I just cannot see how these 1000 cycles of AC electricity cannot, (with the assistance of full wave bridge rectifiers)
generate enough DC current to be able to rotate this DC motor only the one time
Quote from: Dog-One on April 12, 2017, 02:05:48 PM
Thanks for posting the pic Dog-One
I think that the pic is needed to better understand how it works
you are using the small amount of electricity to rotate a very large 100 cm circumference pulley
gaining you 100 cm of moving belt, which you run past 10 or more mini-pulleys of 1 cm circumference
if you add 10 free running AC generators, this could multiply your cycles of AC electricity to 1000
+ all for a cost of only turning over your DC motor once
My name is Joe Lynch + I have a pre-school simple way of using pulleys to multiply AC electricity. This can be done by only paying the small amount of DC current, for the single rotation of a DC motor with a 100 cm circumference pulley attached + then you run this 100 cm of moving belt past 10 mini-pulleys of only 1 cm circumference, with free running AC generators attached = you would gain 10 X 100 = 1000 cycles of AC electricity,,, all for the cost of enough electricity to crank over your DC motor once =(a mere spark)
These AC generators would run free of most all torque, as torque is caused when generating power, and power is defined as current multiplied by voltage. Even though you may be winding up massive voltage, (which is useful pressure to crank over your large pulley) you only need to be generating one spark of current, (practically nothing) the minimal amount of current that a DC motor needs to crank over once. So, practically zero current multiplied by even massive voltage still equals practically zero power + torque.
USING PULLEYS TO MULTIPLY AC ELECTRICITY
Please,,, explain to me why these 1000 cycles of free running mini-pulleys cannot generate enough voltage + the one spark of current, to crank over your DC motor one single time,,,
- each half generates what the other half needs
- massive rotations create massive voltage to crank over your DC motor once
- + the cranking over of the 100 cm circumference pulley, through 10 mini-pulleys, easily winds over 1000 rotations of your 10 AC generators
(my health has gotten far worse, my blood pressure is 180/90 all the time. The nurse just took it, + said that it was better, than the 195/90 that it was earlier) + I ask my Father to take me Home to Paradise most every morning now. This massive pain that I go through daily is getting me down. Sorry, but I no longer wish to fight this battle. I had to change my sheets, as they were soaked, + I must change my t-shirt twice a day now, morning + at night, as the cold sweats soak them
Quote from: that_prophet on April 13, 2017, 03:22:54 PM
Hi dog-one, Hi prophet, well i was trying to work on something and i was being attacked not much longer after i started to work on it.
There is most definitely a dark artificial force here and i surely didn't create it, it seems to get into people it can around you and then uses them to cause trouble or try to impede good works.
It's too bad really, this could be a great ride, unfortunately there is an infection that needs healing.
If and when, i am able to continue work towards this technology principle, i will do so to the best of my ability, but the road blocks need to be removed from this reality.
peace love light
Free energy is as simple as the pre-school technology of using pulleys + multiplying AC electricity with multiple size and #'s of pulleys = https://free-energy.yolasite.com/ - it is so super simple, that we should be ashamed of allowing satan + his fellow evil spirits, to have kept it hidden for so long = ever since Ezekiel 1:16, where it is first easily described how a UFO motor worked in the Holy Bible, "a wheel in the middle of a wheel". You only have to pay the one spark of DC current to rotate a 100 cm circumference pulley one single time,,,, + through running the 100 cm of moving belt, (which came off the circumference of pulley) + running it by 10 of the mini- 1cm circumference pulleys + attaching AC generators to each pulley, you can multiply your AC electricity to 10X100=1000 cycles of AC electricity,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one small spark of DC current =(just enough to rotate your DC motor one single time) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
Quote from: SkyWatcher123 on April 16, 2017, 09:58:02 PM
peace love light
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04
http://my2020vision.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://askthatprophet.yolasite.com/
http://possibletimingfortribulation.yolasite.com/
http://aliensandghosts.yolasite.com/
http://hissalvation.yolasite.com/
http://godoflove.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
http://onechristianwarrior.yolasite.com/
http://ultimatejoysticks.yolasite.com/
http://ultimatevideogamecontrols.yolasite.com/
http://thegodofthebible.yolasite.com/
http://incaseofrapture.yolasite.com/
http://rapturequestion.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://whataboutisrael.yolasite.com/
http://myiqchallenge.yolasite.com/
http://evolutiondebate.yolasite.com/
http://biblefilescentral.yolasite.com/
http://whydoweinsultgod.yolasite.com/
http://jesus-christ.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://howlogicchosechrist.yolasite.com/
http://hisonlyword.yolasite.com/
http://whybornagain.yolasite.com/
http://bibleteachings.yolasite.com/
http://pre-trib-force.blogspot.ca/
Free energy is as simple as the pre-school technology of using pulleys to multiply rotations
+ multiplying AC electricity with multiples of both size and #'s of pulleys
- this is so super simple,
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
HIDDEN FREE ENERGY TECHNOLOGY IN BIBLE
GEMs could be used to electrically convert h2o into hydrogen fuel + O2 to have the fire power,
Yet you still have a GEM to convert bad carbon monoxide or dioxide back into O2 + carbon
That way we could have the instant power of the combustion engine,
and still have it in a way that covers up most of its polluting characteristics
This technology is super simple, by just working on the mechanical effects of it not taking 100 times more electricity to rotate a large 100 cm circumference pulley as it does a 1 cm circumference pulley. Yet you can get 100 cm of moving belt off your large pulley, which if you run through one or many 1cm circumference mni-pulleys, thereby multiplying your rotations by 100 times the # of mini-pulleys that you choose to attach. If you simply attach AC generators to these mini-pulleys, you would be multiplying massive amounts of AC electricity.
Every household could have one or many of these GEM power supplies in it.
- One for every voltage, OR
- One for every room
As these mechanisms are simple to build
- Not very costly for parts
- - 1 DC drive motor, + at least I AC generator + belt to connect them
- - One full wave bridge rectifier for every AC generator
- - Wire, enough to go from your AC motor(s) to you rectifier(s) + to DC motor
- - - Then you need to connect wire leads from your DC output of your rectifier
- - - - As well as your AC output motors, (just in case you need an AC output)
- - A small amount of Sauder + flux
- - + some metal, wood or plastic, to construct framing for the mechanical parts
- - - of this Miraculous mechanism
We could even put them in our electric cars
- + no more plugging your car in to gain a charge from your house 120V power,
- but we could
- - plug our car's in, to power your house,
- - - with a little voltage conversion
Description of how to build a GEM = Geometrical Electricity Multiplier
. . . . . . . . . . . . . . . . . . . . . <<<free energy machine>>>
--------------------------------(AC motor=AC generator)-------------------------------
You start with a large (100cm circumference) pulley + you attach a DC motor to the center shaft of it
Then you need at least one small (1cm circumference) mini-pulley,
(the more the better) = More generators = higher current capability
<<because more AC generators=higher capability of current flow>>
Then you would need to build a framing system to hold the
- motor + generators in alignment for the belt to run smoothly
This could be made out of whatever you had in supply,
- (1)-wood + nails + screws,
- (2)-metal strapping or lengths of iron rods,
- (3)-plastic rods + glue
I say that you need a belt, but in reality you could use a strap, elastic, rope or even tied length of string, to connect your large pulley + your mini-pulleys together.
- pretty convenient, for the many Tribulation Saints, who cannot buy anything without the Mark
This technology is simple + easy to manufacture, out of most parts that you could find around any back yard garage. All that's needed is one large wheel with a DC motor on it, and at least one small wheel with an AC generator of the same voltage attached, and a belt or strap or rope to connect them together. Oh yah, you will need at least one full wave bridge rectifier, to convert your AC output back into your DC drive motor.
this way, the Tribulation Saints can have a way of creating free electricity, in order to heat and light their place of living. This would also give them electricity to charge batteries + run radios + other communication devices
Other possible names for the letters of GEM
- God's Energy Mechanism
- Good Electricity Maker
It only takes one spark of DC electricity to rotate a DC motor once. If you attach a 100 cm circumference pulley, this will give you 100 cm of moving belt. If you run this length of belt through 10 mini-pulleys of 1cm circumference, + attach AC generators to them, you would get 1,000 units of AC electricity
THAT'S ONE SPARK OF DC ELECTRICITY IN = 1,000 UNITS AC ELECTRICITY OUT
(please, try to find a way around this AC electricity multiplier)
Torque is not a problem,,, as these generators are only winding up massive voltage,
which is exactly what we need to rotate your drive motor, and practically no current = (only one spark)
This is GOD 's Gift to mankind + as well as the natural world around us
Yet it was + is being hidden by evil spirits
This was Given to us way back in Ezekiel's time, (Ezekiel 1:16)
- yet evil spirits have kept this Gift hidden all these years
- Just look at how ridiculously simple this technology truly is,
- and ask yourself just how gullible we were,
- to not see through the evil spiritual warfare that was hiding it from us.
You can seemingly break the laws of thermodynamics, simply because it does not take 100 times more power to rotate a 100cm circumference pulley than it does to turn a 1cm circumference pulley. They both take the same current = one spark of DC, the larger one only take a slightly greater voltage. You are gaining 100 rotations of an AC generator. These are practically free running, as they are only winding up massive voltage. The physical resistance only happens when you are taking power out of it = voltage times current times duration of time
My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
This is so super simple, that I be ashamed of being human, and so ridiculously gullible, to believe these ridiculous lies about torque being a problem. These are free running electric motors/generators, and the ease that these can be rotated is going against only the viscosity of the lubricant, or practically zero. Think of it this way, the only resistance from rotation is caused from the power being generated by the motor/generator, which is only one single jolt or spark –(the amount of current that the motor takes to do one single rotation), which is practically zero current, and mostly all voltage, which is the electrical pressure to crank over this large pulley. Especially since we have 1000 rotations to divide it by, so the torque is he minuscule amount that it takes to produce one spark of current, the amount it takes to rotate only the one time, and then divide it by 1000. This is far less than nothing, so these 10 generators should be free running.
This is the biggest deal since the first wheel. You are using simple preschool pulley technology, to not only multiply the # of rotations, but since AC electricity is only made of the rotations of a coil through a magnetic field. It is the next generation wheel, "wheel in the middle of a wheel" –(Ezekiel 1:16). This pulley mechanism is a super simple way of gaining free energy, by only paying for the one rotation of a DC motor with a large 100 cm circumference pulley connected, and getting back 1000 cycle of AC electricity, from 10 attached pulleys of 1 cm circumference, with AC generators attached, 10X100=1000. I state the Holy Bible quote, as this was the answer that I was given, when I questioned if this really came from the Spirit of God, and not from evil spirits just trying to confuse me. It is in the Bible where Ezekiel is trying to describe what a UFO motor looks like while it was running, with the color of arcing electricity in the motors/generators. So this is not only free energy, by letting electricity generate itself, but a way to travel in the heavens, in what they called "chariot of fire" or "wheels were lifted up". I was thinking that this might have something to do with generating such a massive voltage, that it somehow repels against the voltage of objects.
There is no resistance from the mini-pulleys with AC generators attached. Think about them as free running motors, with nothing attached to them, as there is no resistance to them,,, they are only free running motors, as these 1000 cycles of AC electricity only have to generate one single bit of current, only enough to rotate your DC drive motor one single rotation, (practically nothing)+ torque is only caused when you are generating power, + P=IV or power equals "I"-current multiplied by "V"oltage. So, no matter how much Voltage you are winding up, when you multiply it by practically zero current, it still equals practically zero Power, which takes practically zero torque. Because zero times anything is still zero. All that they are doing is winding up massive voltage, that is used to crank over your DC motor, and because you only have to rotate it one single time, we don't need to create any current,,, only one spark,,, to crank over your DC drive motor once..... no torque is needed.
THIS IS HOW SATAN HIDES THIS SIMPLE TECHNOLOGY
Can I ask you/warn you to be sure and give 10% to the church, (not catholic) as this was a Gift from God, for His Saints,,, Pre-Trib + the Tribulation Saints
PLEASE,,,
Check this out with any Christian friends that you might have, especially mechanical engineers.
Although I tried to give this, (in an earlier version), to 3 churches + one retired Minister so far, with no takers so far. I will send this version to them as well.
I can't understand why no one could see this obviously super simple GEM free energy technology.
Is satan so powerful, and mankind so unworthy,,,,,,,,,,,,,,,,,,,,,,,,,
@That_Prophet
Ezekial's wheel in a wheel, must have some significance, other
than that which you have understood it to have.
When one increases the rpm s of the generators (as in your drawings)
by using small pulleys on the generators and a large pulley on the
motor..... one also increases the energy needed to run the motor.
The generators will turn faster, but the motor is also more difficult to turn.
This is Just like on a multi gear bicycle, when one has to push harder
on the pedals when in higher gears.
This may be hard for you to believe but, that design has been tried many many
times before and does not produce extra energy.
I have had many ideas that did not work out. Disappointing as this can be,
one must move on / progress if one is to have any chance of finding a free
energy source.
Its not the devel's work, its just the way God and nature designed puleys.
regards
floor
Quote from: Floor on May 25, 2017, 09:19:41 AM
Its not the devil's work, its just the way God and nature designed pulleys.
... and gearboxes.
QuoteHE IS COMING BACK BEFORE 2019.04
Joe, I realize this is hard for you, but have you thought about what you will do
if God does NOT come back before 2019.04? What if everything is just the same,
only more so, in two years?
Many people have forecast God's return and they have always been wrong before.
They have given away property and money, shunned their families and even worse,
only to be left standing out in the rain on some mountaintop while God laughs at
them from on high. And the world goes on, in all its evil ways.
I think you should be prepared, in case your prediction is wrong, so that you aren't surprised.
https://www.youtube.com/watch?v=9oY1M3sk_bs
I have a doubt in calculation provided by video uploader.
"Here :- Diameter is 2.5 meters X Weight is 12 tons X Gravity 9.81 X Efficiency 92% = 270 KW generated per hour"
Weight 12 tons itself is a force (=mg). So, why it is again multiplied by 9.81? If we remove 9.81 from the above equation, we get output power roughly around 27 KW which would be equal to (or less than) the energy he is taking from the grid.
When we purchase something one Kg from a shop, do we purchase one Kg mass or one kg weight?
Quote from: TinselKoala on May 25, 2017, 02:53:04 PM
Then I will just go on,,,
I know that I cannot know that it will happen before then,
we cannot be sure of the length of the generation,
but I believe that this is the door=deadline,
which we are allowed to know, "know that it is near, even at the door"
did you ever think of (near to what), if we are not allowed to know the date,
maybe He is saying near to the door, or deadline
I do not claim to know the day,
I claim to know the door, which is the day that we are promised will not occur,
before this does happen = Jesus will Return before this day
yes,,, I agree, we should all be prepared,
for the soon coming door closure,
if not my date,,, then please find it,
we are promised that this is a date that we can know,
and this would be a count down date,
we can know that it will be before this date,
and we could be counting down the days until,
Quote from: Newton II on May 26, 2017, 07:09:06 AM
That's not even a "calculation", it's just taking a bunch of numbers and multiplying them all together to get the 270 "kilowatts per hour" number. It makes no sense.
. . The thing is, that if you so easily give up on this super simple free energy technology, then you will be not only be helping, but joining with Satan, and his evil forces, in helping keep this easy to build free energy technology from an energy hungry humanity. Then, if you truly think of this with a logic mind, and you are using AC electricity generators in the mini-pulleys, this just has to work
. . Yes, this free energy technology was given to the soon coming Tribulation Saints, which live through the 7 year peace treaty with Israel, the revived Roman Empire in Europe, and probably many other nations. I don't understand why you assume that these mini-pulleys will be under major torque, they only have free running AC motors/generators attached to them, which would only generate torque if they had major power being generated. They only need to generate one small blip of current, which is used to cank over your DC drive motor one single time,,, which is practically zero current, and even massive voltage times practically zero current, still equals practically zero power=costs practically zero torque.
. . You are listening to evil spirits to much, there is no torque problem
Quote from: Paul-R on May 25, 2017, 11:56:03 AM
... and gearboxes.
@That_Prophet
yes, I know that it has more to it than free energy,
because this was a UFO motor,
having anti-gravity properties
why do you think these mini-pulleys are so hard to rotate,
they are just attached to free running motors/generators,
these AC generators are running free
as P=IV, and the "I" is only one small spark, (practically zero)
so, since you only need practically zero current,
then "P"ower is equal to practically zero,
which means torque is practically zero
why would the motors be more difficult to turn, they still only have free running motors/generators attached,
but these mini-pulleys have no torque to go against them,
as they are just free running generators attached, with no resistance,
or very little resistance = divided by 1000 cycles = less than nothing
+ no,,, this design has not been tried before, except by the guy that built 3 working models, that says they work great
energy source.
regards
floor
but this one does work,
and it is so simple that it MUST work,
You are using pulley technology to multiply rotations,
+ since AC electricity is created by rotations,
you can actually use pulleys to multiply AC electricity
you only pay to rotate a large 100 cm circumference pulley once = only on spark of DC
+ through the use of 10 mini-pulleys of one centimeter circumference,
you can get a return of 1000 cycles of AC electricity
I have had only one guy tell me that he built one, no, he told me that he built 3 different versions,
+ they all worked great,,,,
but he was worried about the rumors, of people that had actually built working free energy machines,
soon had bad things happen to them + their families,
so he did not want me to give out his name
Quote from: webby1 on May 26, 2017, 08:45:22 AM
...The real thing is, even when those that have built this tell you it does not work you simply carry on,, you ignore the information you do not want to hear,,,,,
you are not using logic, you are listening to satan and his evil demons,
telling you that torque is the problem
just think of 10 free running motors = no resistance but the viscosity of the lubricant
these would be easy to rotate, as they are just winding up massive voltage
which is exactly what you need, to crank over your large pulley the one single time
Quote from: webby1 on May 26, 2017, 02:01:29 PM
I could not get it to work,, BTDT,, I have tried variants of the same thing as well.
I do not believe that any person has built 3 that worked great,, you do realize how unbelievable it is that someone would not only build 1 but 3,,, why???
You have been informed of what the issue is that you choose to ignore,, the gearing up of RPM means the counter force created by that one little spark is geared up as well,, so 100:1 for RPM means 100:1 for the torque needed,, so that almost no current and almost no force quickly becomes really large really fast.
sorry to hear that,
I thought that it was simple + easy to build
as this technology was/is for the Tribulation Saints
who would not be able to buy much,
without taking the MARK,
which they would never take,
as it would condemn them to eternity in a place worse than hell
What is "BTDT"?
he probably built 3 to prove that it was easy enough to do,
or maybe 3 different voltages, like 1.5V + 9V + 12V
SORRY, but no, I have not been informed of any issues,
except the torque lies that the evil spirits have been lying to you about
these mini-pulleys + AC generators run freely
as they only need to generate one small spark of DC current,
in order to crank over your DC drive motor one single time
HERE IS A SIMILAR TYPE OF GEM
except the 4 medium size pulleys,
you would replace with 10 extremely small pulleys
+ 10 AC generators + 10 full wave bridge rectifiers
Quote from: webby1 on May 26, 2017, 03:56:25 PM
NO!
I am going by my EXPERIENCE.
You ask me to think about it,, why don't you?
Why will you not think abut the counter force, why will you not accept that the gearing that provides the higher RPM also supplies a higher torque back against the prime mover.
what counter force?
these are free running motors/generators
there is no counter force to rotate them
As a side note I noticed that if you get ignored on your thread you post on other threads,, is that the work of a good soul,, or is that evil at work?
yes, I first went on many forums + threads,
trying to get it out to as many as I could, as fast as I could,
this was to give away His GEM gift to as many people as I could
I thought that it was good to give things away.........................
If you can look past the evil whispering in your ear, you can see just how simple this is. Think about how small of amount of electricity that it takes to turn over your drive motor once. It might take plenty of voltage=electrical pressure to crank over this large 100 cm circumference pulley the one single time, but it takes practically zero current, (only one single spark of current). This means that it takes practically zero power to do this, because practically zero current,(1 small bit) multiplied by even massive voltage, still equals practically zero power, which takes practically zero torque.
And then there is your massive output, from your 10 free running AC generators, connected to your mini-pulleys of only 1 cm circumference pulleys. This configuration could produce 10X100=1000 cycles of AC electricity, and all from the one small bit of DC electricity, a mere spark of current. Now do you see why I call this a Geometrical Electricity Multiplier. You are multiplying one small spark of DC electricity into 1000 cycles of AC electricity.
Yes, Joe, everyone reading here and everyone you have presented this idea to all understand perfectly well what you are trying to say. You don't have to keep repeating the same thing over and over, on thread after thread. WE GET IT.
But what YOU don't understand, what you refuse to understand, is that your initial assumptions are FALSE. Hence your scheme will not work. YOU DON'T GET IT.
You are in fact spamming thread after thread, forum after forum, with your FALSE assumptions, which have led you to believe as you do. YOU are the one listening to "demons" !! And you refuse to be helped. There is no hope for you, dear Joe.
You make further claims without support. "Somebody" has told you he has built three of these things that work. But you offer no proof at all of this utterly _revolutionary_ claim. Why don't you ask that "somebody" what he pays for his electricity to run his home, and let us see his last six months worth of electricity bills.
I know why you don't .... and so do you.
Quote from: TinselKoala on May 26, 2017, 07:40:47 PM
He thinks he is pleasing his God who probably got really fed up a long time ago.
The making of GEM free energy technology
You start with one large 100 cm circumference pulley,
+ you attach one DC motor to it, + this is your drive motor,
can be any voltage, as long as the same as your AC generators
Then you get 1-3 mini-pulleys, each of 1 cm circumferences,
+ then you attach 1-3 AC generators to them,
YOU MUST attach all of these pulleys together,
With a belt, strap, elastic, rope or even a piece of tied string,
Now you connect these generators to 1-3 full wave bridge rectifiers,
To convert your AC output back into the DC of your input drive motor,
Then you run wires from the DC output of your full wave bridge rectifiers,
+ run them back into the input leads of your one single DC drive motor,
Now if you only start to rotate your large 100 cm pulley, only a quarter turn,
This will generate enough power to not only start your DC drive motor working,
But it should be able to keep your DC drive motor running perpetually,
It should be able perpetually keep the system running because of pre-school pulley technology,
You see that the 25 cm of belt that you get from only a ¼ circumference of large pulley,
Is more than enough belt to give you 25-75 cycles of AC electricity,
By passing this 25 cm of belt by your 1-3 mini-pulleys of only 1 cm circumferences each
So each of these 1-3 mini-pulleys get to rotate 25 times each,
That's 1 to 3 X 25 = 25 to 75 cycles of AC electricity,
Now try and tell me that you cannot get the one spark of DC current,
Out of these 25-75 cycles of AC current
Remember that these 1-3 mini-pulleys are running free of most all torque,
As the only resistance these 1-3 generators have, (other than viscosity of lubricant)
Is the resistance of the power being generated by them,
Which is P=I V, which is "P"ower is equal to "I"-current multiplied by "V"oltage,
+ remember that no matter how high of a "V"oltage that you are winding up,
You do not need very much "I"current, you only need one short bit of current, (practically zero)
+ remember zero times any number is still equal to zero = (law of mathematics)
So,,, even massive "V"oltage times practically zero "I"-current,
Still equals practically zero Power = which take practically zero torque,
= these mini-pulleys are running practically free
Now, please remember, these 1-3 mini-pulleys, with AC generators attached, run practically torque free
because torque comes from generating power, and P=IV, where I is equal to practically zero
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
It doesn't matter how many times you keep repeating this, it still IS NOT TRUE!
You just can't seem to understand that it takes TORQUE to turn a generator. And motors do not run on a spark of electricity. They run on a continuous supply of current. That current coming from the generators will load the generators requiring TORQUE to turn them. Your idea has been tried many many times with failures each time. It DOES NOT WORK!
If Christ is coming back in two years as you claim then why bother trying to make free energy? If He comes back then, we won't need any energy.
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04 - http://doorschristmustpassthrough.yolasite.com/. I believe that we were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started. Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
This technology is so super simple, that it is proof of there being a battle going on against good + evil, how else could this dirt simple pre-school learned, pulley technology not have been found. You only have to pay the energy to rotate a large 100 cm circumference pulley one single revolution, (a mere spark of current) + you can get a return of 100-300 cycles of AC electricity. I say hundreds of cycles of AC electricity, as you can add as many of the 1 cm circumference pulleys as you want, all running past the same 100 cm of belt that comes off of of your DC drive motor + 100 cm circumference. Thereby multiplying the # of 100 time multipliers as you want to invest in.
Please remember, these mini-pulleys with AC generators attached, run free of practically free of any torque, as they are just free running motors/generators winding up massive voltage,(which is exactly what you want) where they only need to generate one small spark of DC current, in order to have this mechanism a self powering mechanism..
The making of this simple GEM =(Geometric Electricity Multiplication) free energy technology
+ then you attach AC generators to them,
because torque comes from generating power, and P=IV, where "I"-current is equal to practically 0
Please be assured, that all governments will not be long passing laws, stating that all polluting equipment + vehicles MUST soon switch to this pollution free way of operating all of our gas guzzling vehicles + equipment as fast as possible. Just think about how much free money this world will seem to have now, not having to add the cost of gasoline into their products. I don't just mean for the cost of electricity, to heat, light + build your product, but the cost of shipping, everything from the materials to build it, but the cost of transportation of your workers, to and from the worksite.
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,,
Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6 + 9 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies the bird, + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, that would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
FREE ENERGY from the description of how a running UFO motor looks in the Holy Bible
I have a most generous gift, http://free-energy.yolasite.com/ that I believe came from the God of the Holy Bible. I believe this because when I asked Him for a way to help the soon coming Tribulation Saints. I was shown a Vision of a 10 speed driving uphill in tenth gear, and then downhill in first gear, where the pedals were rotating like crazy. I then converted this into one large 100 cm circumference dive pulley, (powered by a DC motor) + this freely turning 10 of the 1 cm circumference pulleys, with AC motors/generators attached. This dirt simple GEM free energy mechanism only has an input one small bit of DC current, (only one spark) + has an output of 10X100=1000 cycles of AC electricity,
NOW THAT'S A FREE ENERGY MULTIPLIER
The thing is, that there is the most powerful spiritual warfare going on about this simple free energy technology, and evil forces will immediately start confronting you as soon as you start looking into this. I can be sure that evil forces will whisper in your ear, many ways that this cannot possibly work. For why should evil spirits want us to be able to stop buying oil, from nations that in one way or another tend to promote terrorist, and their careless destructive ways. I believe that God gave me this technology back in the early 2000's when He first gave me a Vision of a 10 speed bicycle going uphill in 10th gear, and then back downhill in 1stgear. This is very significant where AC electricity is concerned, where you may need massive voltage, to crank over the pedals on the way up, but it costs way less current, as the motor runs for only a few rotation. Then when you run the bicycle down the hill in 1st gear, you would be winding over your AC generators massive amounts of time. Please remember that AC electricity is generate through rotations of a coil of wire through a magnetic field, and the more rotations means more AC electricity.
I will guarantee that massive evil spirits will try and give you many reasons that this could never work, trying to discourage the idea of this even working. I can guarantee that Satan and all of his evil spirits will find many of ways for this not to work, whispering to you that only fools would believe in this stupid technology. It might take massive voltage to crank over your large 100 cm circumference pulley, but it takes practically zero current to rotate the DC motor the one single time. This means that there is practically zero torque needed to turn these AC generators over, as torque is only caused when you are generating power. + Since power is defined as P=IV, where "P"ower is equal to "I"-current times "V"oltage, and since you current is practically zero, and we all know that zero times anything, even massive voltage, would still be equal to zero,,, or practically zero.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
This is so super simple, that I MUST state, that I happen to be ashamed of being human, and so gullible, that I believed these ridiculous lies about torque being a problem. These are free running electric motors/generators, and the ease that these can be rotated is going against only the viscosity of the lubricant, or practically zero. Think of it this way, the only resistance from rotation is caused from the power being generated by the motor/generator, which is only one single jolt or spark –(the minuscule amount of current that the DC drive motor takes to do one single rotation), which is practically zero current, and mostly all voltage, which is the electrical pressure to crank over this large pulley.
Especially since we have 1000 rotations to divide it by, so the torque is even, the minuscule amount that it takes to produce one spark of current, what it takes to rotate only the one time, and then divide this small amount by 1000. This is far less than nothing, so these 10 generators should be free running.(torque is only cause when you are producing power, and even massive Voltage multiplied by practically zero current, <one spark>, is still equal to practically zero. Because any # multiplied by practically zero, always equals practically zero.
Having the first Door closing by 2019.04, http://my2020vision.yolasite.com/ we have less that 20 months now, before the pre-Trib Rapture + signing of the infamous 7 year peace treaty with Israel, ushering in the anti-christ + the "Great Tribulation" + then Christ will set His Feet on the Mount of Olives, to fulfill the second part/Door of this prophecy, when He Comes again to this earth. This coming cannot be the arrival that no one knows, because the Tribulation Saints will not only know when this arrival will be, but they will be counting down the days until.
http://overunity.com/17091/gemgeometrical-electricity-multiplication/
Quote from: citfta on May 31, 2017, 08:24:48 AM
http://free-energy.yolasite.com/ = (PLEASE GO HERE, to see more about this GEM of free energy)
How much torque does it take to rotate a free running motor/generator = practically none
These motors/generators are pretty much free running
As for all of their 100 – 300 rotations, they only have to generate the small amount of current,
that it takes to rotate your drive motor one single time,,, only one small spark of current,
and this is divided by 100 – 300 rotations of you AC generatots
It only takes torque when you are generating power
+ the 100 – 300 rotations of these 1 – 3 generators only have to generate a spark of current
I say one spark because if your motor is running a 60 times per second, which is not a very fast motors
Then one rotation is only 1/60th of a second in duration =(a mere spark to me)
This is all that your 1-3 generators have to generate,,,,,,,,,,,,,
To rotate you DC drive motor to move one single rotation
Where has it been tried before ?
How can you go wrong when you only have to generate the single bit of current,
that your drive motor takes to rotate one single time,
+ you get 100 – 300 rotations of AC electricity to do it,
Seems easy enough to me.
You are using the dirt simple laws of pulley mechanics to multiply rotations,
+ since AC electricity is generated by simple rotations
You are using the dirt simple laws of pulley mechanics, to multiply your AC electricity
IT IS TRULLY THAT SIMPLE..................................
NOW, can you believe how gullible that listening to these evil spirits has made you,
I hope this not only clues you in, to the powerful evil forces out there,
But it convinces you of your need to seek God, + take Jesus into your heart,
Thereby becoming Born-Again, and maybe even start looking for His Second Coming,
+ get to use His "Blessed Hope" + get to leave this earth in the Rapture,
Before the soon coming 7 years of this false treaty,
where the second half will be the "Great Tribulation"
+ SATAN HAS CLOUDED YOUR MIND, SO THAT YOU CANNOT UNDERSTAND HOW SIMPLE THIS IS
It will be less than 20 months now,,,, before 2019.04 the Door will close,
One of the Doors that we are allowed to know
Mathew 24:33 = "know that it is near, even at the doors"
Doors are plural because of His two Comings = Rapture + Glorious Appearing
Do you want to hear how super simple this technology is,
You only pay to crank over one 100 cm circumference pulley,
Then you use the moving 100 cm of moving belt off this large pulley,
+ run it past 10 mini-pulleys of only one centimeter circumferences,
All that you have to do is add AC generators to these 10 mini-pulleys,
Giving you a free return of 100 cycles of AC electricity.
And don't you believe that torque is a problem,
You have 10 X 100 = 1000 cycles of AC electricity,
To make up the one spark of DC current that you need,
That this DC drive motor needs to be cranked over the one time,
Giving you the 100 cm of moving belt = off 100 cm circumference,
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS
+ how powerful this spiritual warfare is,
to be able to hide this super simple AC multiplier from us gullible humans...............
Quote from: webby1 on June 01, 2017, 01:43:21 PM
No one is saying that you can not.Right here you have said "practically zero" NOT ZERO.I moved this here so that it is not missed up there,,
You are NOT multiplying a number by ZERO,, so it IS something. Practically nothing is still something.
No it is not.
"Practically" is what is known as a weasel word.
https://www.merriam-webster.com/dictionary/weasel%20word
Take some classes in advertising,, you will learn better phrases to try and fool everyone with your delusion.
@that_prophet
Build your machine. Theories doesn't make things work, or make sense, untill you have proven that the experiment corresponds to the theory.
If the experimental outcome corresponds to the theory, the theory is correct, but if the theory doesn't correspond to the experimental outcome, you must discard the theory - not the experimental outcome.
Good luck with your build, and please post your experiment here when you're done.
Br. Vidar
webby1
Quote from: webby1 on June 02, 2017, 09:38:01 AM
While the "spark" is happening there is current flow.
While there is current flow there is a counter torque created.
The only current that you need to generate is the "spark"
Only enough current to rotate your motor one single time, (which is practically nothing)
How long does the spark last?
It depends on how fast your DC motor is rotating
At 60 cycles per second, it would 1/60th of a second,
This speed does not matter, because what I was trying to show you,
Was that for every single rotation of your DC motor,
You are, through simple pulley mechanics, getting a return of 100 cycles of AC electricity
So you are multiplying your AC electricity by 100 times, for every mini-pulley that you add to the belt
If your version of "practically zero" is used to equal zero then the time the voltage and current of the spark is happening is zero time,, how much power is there when it lasts for zero time?
The point is, with even one mini-pulley, you are gaining 100 rotations/cycles of AC electricity,
That you can join together, to gain back the small amount of DC current that it takes to rotate once
you are using simple pulley mechanics, to multiply your # of rotations,
which with AC electricity, you are multiplying your AC electricity,
so if you added 10 mini-pulleys + AC generators,
you could get a return of 10X100=1000 cycles of AC electricity,
+ all for only one single "spark" of DC current,
now,,, your input is practically nothing,
only one "spark" of current, (extremely small amount)
+ your output is 1000 cycles of AC electricity
CLEARLY YOU ARE GAINING A MULTIPLE OF THE POWER THAT YOU ARE INPUTTING
(1000 cycles,(duel sparks) of AC electricity, for the single spark of DC electricity)
you are trading one "spark" of DC electricity, (very small amount),
for the 1000 cycles of AC electricity, (a pretty large amount)
YOU ARE USING SIMPLE PULLEY MECHANICS, TO MULTIPLY YOUR AC ELECTRICITY
+ torque is not a problem, as you only need to generate one "spark" of current,
which is practically zero already, but you get to divide this by 1000 cycle of your AC output
sooooo,,,,,,,,, practically zero/1000 which is even less current needed
these AC generators are free running motors/generators
Quote from: webby1 on June 06, 2017, 11:17:16 AM
Do the math,, you have already had how to do that explained to you a few times, with the answers even.
Sorry, but I have nothing sufficiently explained
But I will prove that this works, by other peoples YouTube videos
Why is it that you have not provided a proper mathematical analysis of your idea, why have you not shown a proper mechanical analysis,, why do you choose to use meaningless terms,,
Sorry, but I thought that one rotation of a big pulley,
Giving you a multiple of 100 rotations,
Or in their setup it's only 3-5 times
More importantly, why am I wasting my time with you.
Not sure, maybe a part of you can see past the haze that evil forces are in control of this evil mist,
+ are getting a glimpse of how simple this is,
I can not answer that last one so I will just stop.
This pulley technology works,,,
Here are a couple of ideas that others have,
Knowing or not knowing that it is based on the same GEM technology
Only theirs only has one mini-pulley, + not 3 or 10 like in mine,
+ you can see how these do work
https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t=3s
Guess what,, I do not have to worry about if it works in reality or not,
because others have done it for me,,,, YESSSSSSSSSSSSSSSSSSSSSS
not only have others done this for me, but lots have done it,
+ all with the most positive results. They use the one on one models,
instead of my diagram of 3 to 1, or my theories of 10 to one,
BUT THIS IS PROOF POSITIVE THAT THIS GEM TECHNOLOGY WORKS,,,
Here are a few of ideas that others have,
but just watch + learn THESE DO INDEED WORK
GEM technology is true free energy,
When you use the belt off the circumference of the large 100 cm circumference pulley,
+ run this by 1 to 10 mini-pulleys, off your one centimeter circumference pulley"s"
you are multiplying you # of rotations by 100, times however many min-pulleys that you have
1 rotation of your large 100 cm circumference pulley,
gets turned into 10 X 100 = 1000 cycles of AC electricity
this was free for all to use, in the old first posted gets the patent rights
except for that former President,
That switched the patent law to be more accessible to others
+ In theirs it only has one mini-pulley, + not 3 or 10 like in mine
Quote from: Low-Q on June 02, 2017, 08:23:58 AM
@that_prophet
Br. Vidar
+ you can be sure that more people will come out with their own GEM tech
mankind will hopefully move quickly with this new found pulley technology
where in no time, people will be starting up factories to add this free energy tech
to all electronics + electric mechanisms + yes, even automobiles,,,,,,,,,,,,,,,,,,
can you imagine cars that don't cost any fuel to travel, any amount of distance you want
+ think of how the cost of everything will go down, with no fuel costs to transport stuff,,,,,,,,
PLEASE DON'T FORGET, THIS FREE ENERGY MECHANISM WAS FOUND POWERING A UFO
in Ezekiel 1:16, so we need to experiment with this tech, + see how it can be used in levitation
Quote from: that_prophet on June 09, 2017, 09:21:56 PM
https://www.youtube.com/watch?v=IjN1refTtHg (https://www.youtube.com/watch?v=IjN1refTtHg)
https://www.youtube.com/watch?v=A1ZGOgcZp_g (https://www.youtube.com/watch?v=A1ZGOgcZp_g)
https://www.youtube.com/watch?v=RD2GrpBIMXc&t (https://www.youtube.com/watch?v=RD2GrpBIMXc&t)
The largest motor have a much smaller rotor than original. This will make space for a small battery inside (multiple button cells). The battery is connected to the terminal and the commetators/brushes when the rotor is turned fast enough (Centrifugal switch).
Therefor he measure zero voltage on this motor when it's not running to "convince people this is not a hoax.
There is videos on youtube revealing this trick.
Vidar
there are no need for extra batteries,
this works on the same GEM technology as mine does,
you are only paying for a little more power to rotate the larger pulley, (higher voltage to turn it)
yet you get many times, (10X) the amount of moving belt off the large pulley,
+ when you run this larger length +(10 cm) of belt past a 1 cm circumference mini-pulley,
you would get 10 rotations, Now, if you added an AC generator to this mini-pulley,
you would get 10 cycles of AC electricity, for only one rotation of your drive motor,
that's 10 cycles/rotations of AC electricity, for every one rotation of your DC drive motor, (= multiple)
+ there is no torque problem, as the AC generator is free running,
because it does not have to generate practically any power,
only the little bit of current that a DC motor takes to rotate one single time
+ please don't forget that you can gain another multiplication factor, (doubling it with every addition)
- by simply adding another mini-pulley + AC generator
so, if you added 3 of these mini-pulleys, with free running AC generators attached,
you would gain 30 cycles of AC electricity
+ don't listen to the torque problem, as these AC generators generate no power = no torque
as they only have to generate the small "spark" of current needed to crank the DC drive motor over one single time,
which is practically nothing, + zero times anything is still equals zero,,,
Quote from: Low-Q on June 13, 2017, 06:57:37 AM
Vidar
Unfortunately you're wrong about the concept. There are loss in the belt, pullys, motor, generator, electronic voltage regulator, wires etc. The 10 to 1 ratio is only a gear ratio.
Analyze the torque multiplied with RPM for both wheels. If one is ten times different, the torque is also ten times different.
The voltage measured on the largest motor while running is surprisingly stable close to 12V. While the voltage measured on the small motor is very close to 5V. By "accident" very suitable for the USB output. The voltage regulator (electronic circuit) is the cause of the stable 5V output.
The energy is not only the voltage. You must multiply it with Ampére. Energy P = U (Volt) x I (Ampére). I see no Ampére measurements in the experiment. So the energy is supplied from a hidden battery. The classical way is to hide inside the motor.
I've been working with such motors and voltage regulators for many years. I know exactly in detail how they work.
The video is fake. Sorry.
Vidar
Quote from: that_prophet on June 13, 2017, 10:56:23 AM
. This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it.
. Now, you have just multiplied your single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
. If you run wires from your AC generator output, + put them into the input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn.
. You must have your AC generator + your DC drive motor of the same voltage.
. This is so simple + cheap to build guys + gals, please build one to prove it works,,,
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
. So we have less than 19 months to live, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope" http://my2020vision.yolasite.com/ http://beliefstoliveby.yolasite.com/
@that_prophet
You might not have much time to live, 19 month as you say (how can you be so sure?). According to a few religions, we humans has been soon ending our life and will travel into the heaven for thousands of years. Why are you so convinced it will end in 19 months, when we have been wrong for thousands of years? Get your feet on the ground, and get sane :-)
Anyways, repeating your claims about your OU does not help. You've got an easy and straight forward explanation why your idea won't work.
I recommend you to move on, and spend the rest of your assumingly 19 month of life, to do something more important. Be with friends and family.
A meaningful life is not chasing the undoable, but spending your time with your loved ones and make a change where it is possible to make a change.
I respect your guts to move on with the undoable, but you're banging your head against a wall here. You can keep on doing that for the next 19 months, but it is very counterproductive :-)
Br. Vidar
Quote from: Low-Q on June 16, 2017, 04:26:04 AM
@that_prophet
I can be so sure because Scripture says we can "know it's near, even at the doors"
Did you ever wander why it says that you can know that it is near,
Near to what, if you're not allowed to know the day, how can you know that it is near?
Near to the door/deadline, because we are told that you can know the generation.
+ I used 51.6 years for the last generation, as it was used to predict the year of Israel's rebirth as a nation.
It is also calculated from the ling of Jesus, from the birth of Abraham to Jesus, the 12,12+12
This may not be the right duration for the final generation, but it sure seems the best to me,
I think this generation started when Israel took Jerusalem, as the Holy City was part of the 70 7s,
Which the last 7 is the final 7, before Christ comes back to earth,
To Rule for His Millennium = 1,000 years
Others were wrong because they were trying to predict the day of His arrival,
Which we are warned that we cannot know
My feet are on the ground,,, for now... lol
Yes, I believe that once conceived, we are all in this life Gift forever,
We all live eternal, + we only get a choice of where to spend our eternity,
With a Loving Father + Big Brother + Holy Companion, Who will be with us for all eternity,
All Three Personages Who love you + care about how you are doing, helping us always.
Or,,, without God to help us, in a place where we have to fend for ourselves,
In a place that is worse than hell, surrounded by evil people + evil spirits,
Both of which do not care about you, + are just fending for themselves,
+ remember that all of these fallen angels that are surrounding you,
Have a deep seeded hatred for us humans,
Blaming all of their troubles on us humans,
Because God chose us to be His Greatest Creations
I keep repeating it because you can't seem to understand the simplicity of it,
You are using the pre-school simplest technology of pulley mechanics to multiply your rotations,
+ AC electricity is made of rotations, so you are effectively multiplying you AC cycles of electricity
Effectively, you are using simple pulley mechanics to multiply your amount of AC electricity
Thanks for the recommendations, but I know that the Tribulation Saints will need this GEM tech,
To survive the coming Great Tribulation = (the 2nd half of the 7 year peace treaty with Israel)
I think that a meaningful life is one spent close to God our Creator
Doing His Will, which I think finding free energy for the Tribulation Saints most surely is,,,,,,,,,,,,,,
Br. Vidar
I said my life on this earth will end
As in, I will be going to Paradise for a little over 7 years = the 2520 days
+ the time before the 7 year peace treaty, that my Lord chooses to remove us from this earth,
This is simplicity at it's best, where you are using the longer length of belt,
That comes off a large 100 cm circumference pulley,
To run past a mini-pulley or 2 or 3 for that matter, of only 1 cm circumference,
+ multiply your rotations by 100, 200 + 300 respectively.
Where by simply adding free floating AC generators,
You are easily multiplying your AC cycles of electricity
It is truly that simpler,,,,,,,
Can you believe how much influence these evil spiritual beings can be,
To be able to hide this super simple pulley technology from us
If I remember correctly, you said we should forget about the torque.
Well using a 100cm diameter pulley to run a 1cm diameter pulley, with a regular timing belt for example, will increase the AC voltage 100 times if the generator and the motor are of the same kind. We can agree on that one.
What you dont grasp, is that the smallest pulley is attached to an AC generator that also produce 1/100th of the electric current. If the largest pulley require 100 W @ 100 V @ 1 A, the smallest pulley will produce 1000 V @ 0.1 A which happens to be 100W too. Practical experiments has proven this concept since not long after electricity was discovered.
I'm afraid you're wrong, and the practical experiments are right.
The industry could not design electric drive mechanisms correctly if your theory were right. The very computer you use to post on this forum would not work if you were right.
We could not send out space probes to monitor the moons of Saturn, or fly by Pluto to take pictures of it and send pictures back to Earth.
The lightning during a thunderstorm would not be there, you food would not exist. You would not be able to see the beautiful sunset every evening. The whole universe would not exist if you were right.
What is happening in 19 months? Absolutely nothing. The proof will eventually stand right before your eyes that nothing special happens in 19 month. However, you will still be repeating your posts 2 years from now. Or find something else to post :-) You will be convinced about something very different from what you are convinced about now.
For example, you will be convinced that you have been fooled by your own religion. You will probably become an atheist, and then dig for knowledge that applies to the every day physics. You will finally become sane with your feets still planted on this Earth.
Vidar.
He is sure it will work because it is written in the bible don't you get it? ;D And you are Satan or antichrist or whatever if you don't believe in bible ;D . It's catch 22 with this bible fanatics.
Hihi. I'm not satan.
What you learn from childhood is what you think is right. I learned about the bible myself. I was raised i as a Christian. However, what values did I learn? Loving your next unconditionally.
That is the bottom line.
No need to determine judgement day. If it comes and when it comes, nobody knows. Jesus will come back as unexpected as a lightning from a cloudless blue sky. In what form, how the return appears, nobody knows. Not like a tall man with beard and long hair.
I never did see your name in the bible. It does not tell about a repeated post at overunity.com. Because the bible was written by man long before internet. How couldn't our allmighty God foresee that? The text is instead inspired by great, and not so great ideas. Not by any God.
Quote from: pulp on June 19, 2017, 01:44:41 AM
Low-Q link
Quote from: Low-Q on June 18, 2017, 11:13:25 AM
Please listen to this good little bit of sanity here, (instead of evil spiritual lying in your ears)
These mini-pulleys with AC generators are pretty much free running,
As they only gain resistance from turning when they are generating power,
+ the only tiny little bit of power that they need to be generating,
is the one mere spark of current that it takes to rotate the DC motor one single time : (practically 0)
That's all,,, and this mere short burst of current is divided by 100
1/100th of a spark,,, less than nothing, that's why I say torque is in no way a problem,
PLEASE,,, try to explain to us where all this mythical torque is coming from
NO!!! first, I don't think that your equation is valid anyway. You're talking about laws in electronics, and that is only where my theory starts, as I want us to realize that we can also use the laws of pulley mechanics to multiply the amount of power on one side of the equation.
The large pulley only needs a fraction of the current that you are talking of,
Remember, it is only driving one AC generator, now though pulley mechanics, it is rotating 100 times,
+ what is AC electricity made of,,, but rotations of a coil through a magnetic field.
So,,, we are multiplying any amount of AC electricity that we choose.
Now I will need you to explain how my theory messes up the laws of physics,
How does my theory mess up electric drive mechs
+ how does my theory mess up how computers work
+ sending out space probes,,,
Please explain your logic, or lack of
How can my theory stop lightening + food from existing,
+ even being able to see a beautiful sunset,
How does my theory make it so the whole universe would not exist
I think that you are just exaggerating a little, no a lot,,,
Because you seeing my logical argument starting to win
Within the next 19 months, we are assured that Jesus will return to take his followers before this starts
+ the 7 year peace treaty with Israel will start before this door close,
Vidar.
The 1/100th of a spark is still a spark and greater than nothing.
The spark is responsible for the energy input. Energy supplied to a rotary system creates torque. No matter how little energy you put in.
If you load the generator, the motor wont turn a complete round anymore if it is so that the motor turn one round when it is not loaded.
See for yorself by building it :-)
Theories remains theories. Practical experiments remains true.
Vidar.
Quote from: Low-Q on June 19, 2017, 11:36:38 AM
I was raised to not believe in God,,, it was mathematics + logic that brought me to Christ
http://whybornagain.yolasite.com/
http://howlogicchosechrist.yolasite.com/
Then why are we assured that we would know when it was near, even at the doors.
He wants us to know how close His Coming is, for our comfort
My name is in the Bible Code, and all about me,,,
The Bible Code is more proof that His Bible came from God.
It was fulfilled Bible prophecy that convinced me that this was truly the Word of God
http://biblefilescentral.yolasite.com/
NO,,, I don't think that you + most others do understand,
The pure simplicity of this pre-school technology being used to multiply AC electricity,
Because you are too easily fooled by the evil spirits lying to you through whispering in your ears,
You listen to this utterly stupid fiction of there being a torque problem,
When torque is only a problem when there is massive current being used, not in this miniscule amount,
This amount of power being generated is so small that it is barely mentionable,
Think about it, you only need to generate the smallest spark, just enough to crank over a DC motor once,
+ you get 100 rotations of your AC generator to divide it into, that is practically zero, divide by 100
YES,,, apparently I do have to keep repeating it, because you don't seem to understand it, desperately hanging on to this false torque problem
Sorry, but what I don't seem to be understanding, is where this false torque is supposedly coming from,
Please explain, what "FALSE assumptions",
+ no, I do not tend to listen to demons, as
I ask Him to prove it was from Him and not evil spirits, trying to be leading me astray
I was not sure if you read it in my http://free-energy.yolasite.com/ website, but very early on, I asked God to prove that this idea was from Him, and not evil spirit leading me astray. That was when He pointed me to His Word, in Ezekiel 1:16 "wheel in the middle of a wheel"
Sorry, but I promised him that I would not give out his name,
As he was worried about the rumors about people that found free energy, were soon found dead
Low-Q link
Because you seeing my logical argument might be starting to win
Vidar.
Sorry, but I believe that I will be in Paradise by then, enjoying the wedding feast, while the world experiences hell on earth, at least in the 2nd 3.5 years. No,,, I would not turn against Christianity, as the many fulfilled Bible Prophecies proved it correct for me, especially when it predicted the rebirth of Israel, even down to the exact day..................
Quote from: ARMCORTEX on March 12, 2017, 05:33:57 AM
You gotta hand it to the guy, he has tenacity. You seem very certain.
After my two own ideas this is my 3rd best choice to try.
There is no difference now between the talking crazy, the talking frauds, and the misled.
My best bet is with the crazy guy... Slightly more .0043 %
Maybe I will try this thing. This pulley thing is my type of thing, another possibility in the flywheel department.
YES,,, PLEASE BUILD MY IDEA,
I think that it is very easy to build,
+ have an even better way of discribing how to build it
. This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large circumference pulley one single time, (one mere spark of current). Then you run the large amount of moving belt, (many cm of circumference) past a mini-pulley of only one centimeter circumference, giving you many rotations, which you covert into many cycles of AC electricity, by simply adding an AC generator to this mini-pulley. You are using the many cm's of belt that you get off the single rotation of your large circumference pulley + by running this length of belt past a 1 cm circumference pulley, with an AC generator attached, you are gaining a multiple of AC electricity.
. Now, you have just multiplied your single rotation from a single burst of DC current into many cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem, this is a simple electric motor, which is very easy to rotate. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, and this small bit of current is divided by 100.
. Please don't listen to the torque problem, as torque is practically non-existent. This AC generator is pretty much free running, as for all of its 100 rotations, it only has to generate one small spark of DC current. That is one small spark of current, that is divided by 100, so you only have to generate 1/100th of a spark of current per rotation, or 1/100th of practically nothing.
. This is so simple + cheap to build guys + gals, please build one to prove it works, in any + all voltages
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that Satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture+ start of 7 year peace treaty) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
. http://free-energy.yolasite.com/ This works because of the simple mathematics of how a large pulley of 100 cm circumference does not cost 100 times more energy to rotate than a 1 cm circumference min-pulley. Yet the 100 cm of belt off of the large pulley can rotate the 1 cm small pulley 100 times, giving you 100 cycles of AC electricity. Now, try to tell me that 1 spark=short burst of DC is equal to 100 cycles of AC electricity. WHY = you have just used pulley mechanics to multiply AC electricity by 100 + if you only add 3 more mini-pulleys to the same belt, you can change your multiplication factor from 100 to 400. NO,,, Don't listen to evil spirits, trying to lie to you about torque problems. There is only torque if you are generating power, and the only power you need to generate is enough power to crank over one extremely small DC motor, and that is divided by 100 rotations. Sorry to destroy your excuse for this perpetual AC electricity generator, but this takes no torque, less than no torque, no torque divided by 100 even..
. So we have less than 19 months to live, on this earth, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope"(Titus 2:13) + the signing of the 7 year = 2520 day Peace Treaty with Israel = http://my2020vision.yolasite.com/ + http://beliefstoliveby.yolasite.com/
Now... If only your could save me time and make a good drawing instead of all this long text.
Ok, how about this diagram, it is close, with 4 mini-pulleys instead of the one in my theory,
+ of course the circumferences are not drawn to scale,
Where the large pulley is not quite drawn right,
+ the mini-pulleys are in no way drawn as small as they should be,
Truthfully, they do not need to be so large, nor do they need to be so small,
This mechanism will work as long as the mini-pulley turns about 10 times as many as the large pulley
This is the best draing that I have,
(sorry, but I cannot seem to get this to allow me post any pictures, please look in reply#197)
I will continue to try to post a new diagram
Quote from: massive on January 23, 2017, 04:20:54 PM
"thereby multiplying your AC electricity"
no multipling frequency .... to power what ? USA runs on 50hz
I mean that you are multiplying your # of AC cycles or units of electricity
The frequency is not what I happen to be dealing with here,
I have only been dealing with the total amount of cycles,
+ using the free + simple pulley mechanics to multiply the total amount of AC cycles,
Thereby doing the seemingly impossible, + actually multiplying your amount of power,
Which uses the free laws of pulley mechanics, to sidestep the laws of conservation of energy
That states both sides of your equation must be equal
" (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor"
DC motors don't run on "sparks" , is a spark an electrical quantity ?
a spark across a gap is current , practically NOT zero , have you seen commutator bars and brushes after there has been "sparks" ?
I say spark as that is how I was trying to the extremely small amount of current,
That an electric motor/generator takes/produces to do one single rotation
This is an extremely small amount of electrical current,,, the smallest "spark" of current,
For a motor running at 60 hertz, that would last only 1/60th of a second long
= that is why I call it a spark, being only an extremely short amount of time
one_christian_warrior / that_prophet , the devils got ya in the head and you wont wake up
Sorry, but I think that it is all of you that the devils have got you messed in the head,
+ no matter how hard I try, you don't seem to even seem to want to wake up,
You all seem to enjoy this little dream world that evil spirits have you in,,,
HOW CAN YOU CONTINUE TO BELIEVE THAT IT IS SOOOOOOO HARD,
TO ROTATE A SINGLE MOTOR/GENERATOR ONE SINGLE ROTATION.
(these motors/generators are not seized, + are extremely easy to rotate)
Ok. This is what I suspected. I think you need some serious help. Really!
Vidar.
Quote from: that_prophet on June 21, 2017, 11:33:46 PM
http://whybornagain.yolasite.com/ (http://whybornagain.yolasite.com/)
http://howlogicchosechrist.yolasite.com/ (http://howlogicchosechrist.yolasite.com/)
http://biblefilescentral.yolasite.com/ (http://biblefilescentral.yolasite.com/)
hi vidar, good that you realise....
let it be for next 19 months...
rgds
spark
It's a simple technology where you pay the small amount of DC electricity for one rotation of a large pulley
+, then you get back the massive AC electricity off many rotations of a smaller pulley, OR MANY SMALL PULLEYS.
of course you have to attach AC generators to these small pulleys
It is truly that simple,,,
do you see how deceptive those many evil spirits have been for soooo long,,,,
http://free-energy.yolasite.com/ ,,,,,, pre-school pulley technology -
+ it's 18 months now.......... before Jan 15th, 2019 = Door closing, which we are allowed to know
HAVE WE BEEN SO DUMED DOWN, THAT WE STILL CANNOT SEE THROUGH THIS EVIL MIST
Quote from: sparkmen on June 24, 2017, 04:04:20 PM
rgds
spark
EVil-sOLUTION – isn't it amazing what Truth can be revealed, when the "il-s" of life are included.TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this Door closes on 2019.04 – Jan 14th. http://doorschristmustpassthrough.yolasite.com/. Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural hear, because of the two appearances of Jesus, the first is in the clouds,(Rapture) + then as His Foot touches earth, on the Mount of Olives. DOOR = (Christ must return before this date)
Mankind was given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel,(which are all male, because God only wanted there to be a set # of angels) with human women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. Free energy can be found in a UFO motor description in Ezekiel 1:16
What is AC electricity, + how is it made = out of the rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. + This coil is extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant) would only come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varying sized pulleys, can be easily used to multiply the total # of rotations. This is one free energy technology that we all will need and love = no cost, no need for any fuel or exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans. Think that this may actually be a good enough reason to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is,
Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley,
Then you use the 100 cm of moving belt off this large pulley circumference ,
+ run it past one mini-pulley of only one centimeter circumferences,
All that you have to do is add an AC generator to this mini-pulley,
That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output,
How can you not multiply your AC electricity
Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity
+ you could easily multiply your AC cycles of electricity
You are using simple Pulley mechanics to multiply AC electricity cycles
You have 100 cycles of AC electricity,
This motor – generator power system is self powering,
It can do this by creating massively more electrical power from your many # of AC cycles,
That you can produce from your many AC generators, attached to many of these mini-pulleys,
Which are so easy to rotate, because it does not take 100 times more power to rotate a large pulley,
Yet this large pulley gives you 100 cm of moving belt off one single rotation,
Which by passing by a mini-pulleys with AC generator, can produce 100 cycles of AC electricity, thereby multiplying your total amount of cycles of AC electricity,
By only needing a miniscule amount of DC current to rotate only once,
+ producing as many hundreds of cycles of AC electricity,
as you added the # of mini-pulleys, with AC generators attached
+ how powerful this spiritual warfare must be,
We can use pulley mechanics to freely multiply rotations,
Thereby we are using pulley mechanics to multiply cycles of AC electricity
I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. And can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,,,,,,,,,,,,,,,,
Think about this, for how long have they been able to hide this free AC multiplying technology,,,,
http://possibletimingfortribulation.yolasite.com/
http://evotutionfairytale.yolasite.com/
(here is a diagram that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1 not 4)
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking evil forces's words for it, when the billions of evil spirits throw excuses at you, for why this will never work. My email is in one or many of my websites.
http://fire-starter.yolasite.com/
PLEASE DON'T FORGET, THIS FREE ENERGY MECHANISM IDEA CAME FROME A UFO MOTOR
HOW TO BUILD GEM TECHNOLOGY
. This is so dirt simple that you will kick yourself, after you break through this crafty little evil lie about torque being a problem, and discover just how super simple this GEM technology truly is. How is AC electricity made, by using many rotations of a coil through a magnetic field, and we can use a set of varying sized pulleys to multiply your total # of rotations. So, we can effectively multiply our amount of AC electricity by using the simple pulley mechanics, of a large 100 cm circumference pulley can be converted into 100 rotations of a 1 cm circumference. Then, if you only add a free running AC generator, you can be effectively multiplying your amount of AC electricity. This mechanism uses pulley mechanics to actually multiply your total amount of AC electricity.
. This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it. You are merely using the 100 cm of belt that you get off the single rotation of a 100 cm circumference + by running this length of belt by a 1 cm circumference pulley, with an AC generator attached.
. Now, you have just multiplied your single rotation from a single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
. This is so simple + cheap to build guys + gals, please build one to prove it works, in any + all voltages. I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that Satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture+ start of 7 year peace treaty) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
http://free-energy.yolasite.com/ is a simple pulley technology, where you pay the small amount of DC electricity for one rotation of a large pulley, and then you get back the massive amount AC electricity off many rotations of a smaller mini-pulley, or maybe even many mini=pulleys. It is truly that simple,,, you are using pulley mechanics to multiply the total # of rotations, and by the simple addition of AC generators, thereby you are multiplying the total # of cycles of AC electricity. Do you see how deceptive these evil spirits have been, and doing this for so long, hiding this pre-school pulley technology. Now of course you will have to attach AC generators to each of the small mini-pulleys in order to multiply the # of cycles of AC electricity.
YOU ONLY PAY FOR ONE ROTATION OF A LARGE 100 cn CIRCUMFERENCE PULLEY
+ BY SIMPLY USING THE PULLEY TECHNOLOGY OF MANY MINI-PULLEYS
YOU CAN MULTIPLY YOUR AC ELEVTRICITY BY 1000
IF YOU USE 10 MINI-PULLEYS OF 1 cm CIRCUMFERENCE PULLEYS
WITH AC GENERATORS ATTACHED
(+ these mini-pulleys with AC generators attached take no torque to rotate, as remember you only need to generate the super small amount of power to rotate one DC motor one single time = in order to have this system self powering)
+ of course you need full wave bridge rectifiers, to convert your AC output back into the DC electricity that your drive motor needs
QuoteYOU CAN MULTIPLY YOUR AC ELEVTRICITY BY 1000
No, you can't. Our allmighty God did not create physics to work this way.
You, on the other hand practices the 2.nd and/or the 6.th deadly sins:
2. A lying tounge
and/or
6. A false witness that speaketh lies
So, stop trolling this forum with lies.
Vidar
PLEASE EXPLAIN YOUR LOGIC,,,, why will my GEM technology not work?
back your condemation up with facts + logic
please explain to me where I went wrong
in multiplying massive amounts of AC cycles, from mini-pulleys
off one small bit of DC electricity to rotate a very large pulley
Quote from: Low-Q on June 28, 2017, 07:45:41 AM
2. A lying tounge
and/or
Vidar
You've got explanations already, but you refuse to believe them because you for some reason believe that common well known physics doesn't apply. Have you ever done practical experiments that is based on your idea? If you do, you will be surprised how physics doesn't care about God, the bible, or any codes in it.
Quote from: that_prophet on June 28, 2017, 09:09:14 AM
This has already been explained to you several times by those of us that have actually worked with motors and generators for years. Your biggest mistake is you keep ignoring the torque fact. You keep insisting it doesn't matter. IT DOES MATTER! You cannot just ignore the torque requirement just because you don't think it matters. IT DOES MATTER! In order to turn even one small alternator faster than the DC motor driving it the DC motor will require much more than a small spark of electricity. It will require a steady supply of current that will exceed the amount you can get from your alternator. And as you add more alternators the current requirement will go up again for each alternator you add.
You are not a prophet from God. You are being used by satan to convince non-believers that Christians are a bunch of crackpots that believe in foolishness. I really feel sorry for you. You obviously want to help others but instead you are only causing irritation by your constant insistence that you are correct. You keep posting the same thing over and over again when it should be clear to you that no one on this forum believes what you believe.
I am a Christian. I believe in the rapture. But the Bible makes it clear that only God knows when that will be. Even Jesus said he did not know. I do believe we are approaching the end times but to set a time for the rapture is clearly not in agreement with what the Bible says. You are doing a disservice to God and to your fellow Christians by making these false claims.
Please stop posting on this forum. It should be clear to you that you are not going to get any followers here.
Respectfully,
Carroll
I bet my balls that he will repeat his post any time soon.
Vidar
. This works, http://free-energy.yolasite.com/ because of the simple mathematics of how a large pulley of 10 cm circumference does not cost 10 times more energy to rotate than a 1 cm circumference min-pulley. Yet the 10 cm of belt off of the large pulley can rotate a 1 cm mini-pulley 10 times, giving you 10 cycles of AC electricity. Now, try to tell me that 1 spark=short burst of DC current is equal to 10 cycles of AC electricity. WHY = you have just used pulley mechanics to multiply AC electricity by 10 + if you only add 3 more mini-pulleys to the same belt, like in my diagram, you can change your multiplication factor from 10 to 40. So that's 40 cycles of AC electricity that you have multiplied from one mere spark of DC current. You MUST be multiplying your electricity with this simple GEM = (Geographical Electricity Multiplier) free energy pulley mechanism. Now, please remember that you could massively multiply your GEM factor to 1000, if you had a large pulley of 100 cm circumference and you added 10 of your mini-pulleys to the same belt. (10X100=1000)
. NO,,, Don't listen to evil spirits, trying to lie to you about torque problems. There is only torque if you are generating power, and the only power you need to generate here, to make this mechanism self powering, is enough power to crank over one small DC motor, and that is divided by 10 cycles of AC electricity. These generators are like free running motors that are not connected to anything, with just the viscosity of the lubricant in the bearings as resistance. Sorry to destroy your excuse for this perpetual AC electricity generator, but this takes no torque, less than no torque, no torque divided by 10 even. You are not breaking the laws of thermodynamics, as you are only using pulley mechanics to freely multiply rotations. It just happens to be convenient, that these rotations are giving you the ability to generate AC electricity, and a lot more electricity out than you put in.
Quote from: citfta on June 28, 2017, 02:47:05 PM
Respectfully,
Carroll
I KNEW IT! ;D ;D ;D LMAO!! ;D
You are a funny one, dude. A troll, but its fun to se some one missing the bulls eye by so much. Again, and again, and again ;D
Quote from: that_prophet on June 29, 2017, 02:26:48 PM
. This works, http://free-energy.yolasite.com/ (http://free-energy.yolasite.com/) because of the simple mathematics of how a large pulley of 10 cm circumference does not cost 10 times more energy to rotate than a 1 cm circumference min-pulley. Yet the 10 cm of belt off of the large pulley can rotate a 1 cm mini-pulley 10 times, giving you 10 cycles of AC electricity. Now, try to tell me that 1 spark=short burst of DC current is equal to 10 cycles of AC electricity. WHY = you have just used pulley mechanics to multiply AC electricity by 10 + if you only add 3 more mini-pulleys to the same belt, like in my diagram, you can change your multiplication factor from 10 to 40. So that's 40 cycles of AC electricity that you have multiplied from one mere spark of DC current. You MUST be multiplying your electricity with this simple GEM = (Geographical Electricity Multiplier) free energy pulley mechanism. Now, please remember that you could massively multiply your GEM factor to 1000, if you had a large pulley of 100 cm circumference and you added 10 of your mini-pulleys to the same belt. (10X100=1000)
YOU CAN MULTIPLY YOUR AC ELEVTRICITY BY 1000 \
IF YOU USE 10 MINI-PULLEYS OF 1 cm CIRCUMFERENCE PULLEYS ] = ME
WITH AC GENERATORS ATTACHED /
No, you can't. Our almighty God did not create physics to work this way.
Yes He did, when I asked Him to show that this tech was from Him,
+ not evil spirits just leading me astray,,,
He showed where this technology was in the Holy KJV Bible
= Ezekiel 1:16, where God's Word was "a wheel in the middle of a wheel"
which I interpreted as a little wheel on the inside of a large wheel.
but because I did not have anything to simulate this technology,
I decided to use pulleys to simulate this technology
+ Why can't you, as these are free running motors = easy to rotate = no torque at all
2. A lying tounge
and/or
Vidar
Both of your accusations involve lying,
Which I did not do + challenge you to prove,
Thereby I would hope that you will learn His Truth
About this Miraculous mechanism for mankind
Your interpretations are wrong. How can you be so sure based on a gut feeling?
Second, if you ask God, you get the answer you want to hear because the answer comes from your own head.
A wheel in a wheel can be anything with wheels or nothing to do with wheels.
If you want accurate information, that you don't by reading the bible, ypu must turn to science.
Appearently, God created man in his own image. That also includes modern scientists. Who else created them?
I know it is a dead end discussing this with you. YOU have something to prove. Build that pulley mechanism and show the world that you are either insane or a genious.
Vidar
Quote from: that_prophet on July 02, 2017, 04:08:07 AM
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this Door closes on 2019.04 – Jan 14th - "know,,, even at the doors" http://doorschristmustpassthrough.yolasite.com/. Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural, because of the two appearances of Jesus, the first is in the clouds,(Rapture) before the 7 year peace treaty is signed + then His second arrival is as His Foot touches earth, on the Mount of Olives. DOOR = (this is not the date of His Arrival, which we are warned that nobody can know, but this is the date that Christ must return before) A day that the Tribulation Saints will not only know, but they will probably being counting down the days until. = (He Returns when the 7 year peace treaty ends)
EVil-sOLUTION – isn't it amazing what Truth can be revealed, when the "il-s" of life are included. Mankind was given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation = when this GEM tech will be needed) where most all of the fallen angels, and Nephilum = offspring of fallen angels,(which are all male, because God only wanted there to be a set # of angels) with human women, will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. I confirmed that this free energy technology, in the early 2000's + was from God, by finding it in a UFO motor description in Ezekiel 1:16
What is AC electricity, + how is it made = out of the rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. This coil is extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would only come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations.
This is one GEM of a free energy technology, that we all will need and love = no cost to run, + no need for any fuel to purchase or exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of pre-school technology out before. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. Think that this may actually be a good enough reason to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/ - http://free-energy.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference , + run it past one mini-pulley of only one centimeter circumferences, All that you have to do is add an AC generator to this mini-pulley, Giving you a free return of 100 cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology - You are using the dirt simple laws of pulley mechanics to multiply rotations, + since AC electricity is generated by simple rotations Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity + you could easily multiply your AC cycles of electricity by even greater amounts, By simply adding more mini-pulleys with AC generators to the same belt
IT IS TRULLY THAT SIMPLE .................................. You are using simple Pulley mechanics to multiply AC electricity cycles + thereby seemingly breaking the third law of thermodynamics - And don't you believe that torque is a problem, Electric motors/generators are extremely easy to rotate, + You have 100 cycles of AC electricity, To make up the one single spark of DC current that you need, So this DC drive motor can be cranked over the one single time, Giving you the 100 cm of moving belt = off 100 cm circumference,
This DC motor + AC generator power supply system, is a self powering mechanism. You can freely do this by creating massive amounts more of AC electrical cycles/power, by your many # of rotations of your many mini-pulleys + AC generators, by simply attaching more free running AC motor/generators, to each of the new mini-pulleys, or possibly attaching multiple AC generators to the same mini-pulley. That you can produce from your many AC generators, attached to these mini-pulleys, Which are so easy to rotate, because it does not take 10 times more power to rotate a large pulley, Yet this large pulley gives you 10 cm of moving belt off one single rotation, Which can by passing by mini-pulleys with AC generator, produce 10 cycles of AC electricity, thereby multiplying your total amount of cycles of AC electricity, By only needing a miniscule amount of DC current to rotate only once, + producing as many tens of cycles of AC electricity, as you added the # of mini-pulleys, with AC generators attached
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS + how powerful this spiritual warfare must be, to be able to hide this super simple AC multiplier from us gullible humans..............
We can use pulley mechanics to freely multiply rotations, Thereby we are using pulley mechanics to multiply cycles of AC electricity - I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. And can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,,,,,,,,,,,,,,,,
Think about this, for how long have they been able to hide this free AC multiplying technology,,,, - http://doorschristmustpassthrough.yolasite.com/
here is a fuller description + a diagram, but the small pulleys should be much smaller + only 1 not 4 http://free-energy.yolasite.com/
Come on Canadians,,,
Come on Nova Scotia,,,
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I live in Nova Scotia, and find myself in hard times. If you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking evil forces' words for it, when the billions of evil spirits throw excuses at you, for why this will never work. My email is in one or many of my websites, or you can use one_christian_warrior@yahoo.ca
knowing or not knowing that it is based on the same GEM technology
+ you can be sure that more people will come out with their own GEM tech mankind will hopefully move quickly with this new found pulley technology where in no time, can you imagine cars that don't cost any fuel to travel, any amount of distance you want + think of how the cost of everything will go down, with no fuel costs to transport stuff
Quote from: Low-Q on July 02, 2017, 06:19:21 AM
Vidar
HOW TO BUILD GEM = FREE ENERGY TECHNOLOGY
. This is so dirt simple that you will kick yourself, after you break through this crafty evil lie about torque being a problem. You will discover just how super simple this GEM technology truly is. How is AC electricity generated, by using many rotations of a coil through a magnetic field, and we can use a set of varied sized pulleys to multiply your total # of rotations. So, we can effectively multiply our amount of AC electricity by using the simple pulley mechanics, of a large 10 cm circumference pulley can be converted into 10 rotations of a 1 cm circumference pulley. Then, if you only add a free running AC generator, you can be effectively multiplying your amount of AC electricity. This mechanism uses pulley mechanics to actually multiply your total amount of AC electricity.
. This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on free basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 10 cm circumference drive pulley one single time, (one mere spark). Then you run the 10 cm of moving belt, (off the 10 cm circumference pulley) past a mini-pulley of only 1 centimeter circumference, giving you 10 rotations. You can freely covert into 10 cycles of AC electricity, by simply adding an AC generator to this mini-pulley. You are merely using the 10 cm of belt that you get off the single rotation of a 10 cm pulley + by running this length of belt by one or many 1 cm min-pulleys, with an AC generator attached. You could be multiplying your amount of cycles of AC electricity by 1000, if you used a larger 100 cm drive pulley + 10 of the 1 cm mini-pulleys with AC generators attached. (100X10=1000)
. Now, you have just multiplied your single rotation from a short burst of DC current into 10 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem, unless you are generating lots of power. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 10 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this generator is generating practically zero current, divided by 10.
. If you run wires from your AC generator output, + put them into the AC input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn or more. Of course you must have a belt, strap or piece of rope or string to connect these pulleys together.
. Please don't listen to the torque problem, as torque is practically non-existent. This AC generator is pretty much free running, as for all of its 10 rotations, it only has to generate one small spark of DC current. That is one small spark of current, which is divided by 10, so you only have to generate 1/10th of a spark of current per rotation, or 1/10th of practically nothing.
. You must have your AC generator + your DC drive motor of the same voltage, and at least one full wave bridge rectifier, to convert your AC output back into a DC input for your drive motor. You could also have a larger dive pulley, or add more mini-pulleys to this same belt, + then attach AC generators to each of them also, both modifications would be giving you a higher multiplication factor to your GEM.
. This is so simple + cheap to build guys + gals, please build one to prove it works, in any + all voltages. I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that Satan is laughing his as# off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture+ start of 7 year peace treaty) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
. So as of mid June, 2017 we all have less than 18 months to live on this earth, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope"(Titus 2:13) + the signing of the 7 year = 2520 day Peace Treaty with Israel MUST occur http://my2020vision.yolasite.com/ + http://beliefstoliveby.yolasite.com/
. This works, http://free-energy.yolasite.com/ because of the simple mathematics of how a large pulley of 10 cm circumference does not cost 10 times more energy to rotate than a 1 cm circumference min-pulley. Yet the 10 cm of belt off of the large pulley can rotate a 1 cm mini-pulley 10 times, + if you attach an AC generator, this mini-pulley will be giving you 10 cycles of AC electricity. Now, try to tell me that 1 spark=short burst of DC current is equal to 10 cycles of AC electricity. Why are you freely able to multiply the amount of AC electricity = you have just used pulley mechanics to multiply AC electricity by 10 + if you only add 3 more mini-pulleys to the same belt, like in my diagram on my website, you can change your multiplication factor from 10 to 40. So that's 40 cycles of AC electricity that you have multiplied from one mere spark of DC current. You MUST be multiplying your electricity with this simple GEM = (Geographical Electricity Multiplier) free energy pulley mechanism. Now, please remember that you could massively multiply your GEM factor by 1000, if you had an even larger pulley of 100 cm circumference and you added 10 of your mini-pulleys to the same belt. (10X100=1000) That's 1000 cycles of AC electricity, from one mere small spark of DC electricity. Now, that's what I call a real GEM of a free energy idea, or an AC electricity multiplier.
. NO,,, Don't listen to evil spirits, trying to lie to you about torque being a problem. There is only torque if you are generating power, and the only power that you need to generate here, to make this simple mechanism self powering, is enough power to crank over one small DC motor, and that is divided by 10 cycles of AC electricity, or practically nothing. These generators are like free running motors that are not connected to anything, with just the viscosity of the lubricant in the bearings as resistance. Sorry to destroy this evil inspired excuse for this perpetual AC electricity generator not working, but this takes no torque, less than no torque, no torque divided by 10 even. You are not breaking the laws of thermodynamics, as you are only using pulley mechanics to freely multiply rotations. It just happens to be convenient for mankind, that these rotations are giving you the ability to generate AC electricity, and giving you a lot more electricity out than you are putting in. I feel that I must repeat my argument against this evil torque lie again, there is no torque problem. It is not a problem as you are only generating the small amount of electricity that it takes to rotate a small motor one single time.
YES, we are warned that no man knows the day + hour, but we are also assured that we can "know that it is near, even at the doors." Doors are plural, to represent His two Comings http://doorschristmustpassthrough.yolasite.com/ = 1 – our blessed hope, when He secretly arrives in the clouds + no one knows, to receive His Bride, before the 7 year Peace Treaty, + 2 – His Glorious Appearance, after the 7 year Peace Treaty ends, a day that the Tribulation Saints will not only know, but will be counting down the days until. So why is it, that these doors are never mentioned, especially now, when the first door is about to happen, on 2019.04. http://my2020vision.yolasite.com/ We are missing a most important part of this prophecy, as we are told that we would not only know when it was near, but we would even know the doors=deadlines. Well, I guess that it happens to be my job, telling everybody that the first door/deadline is coming up very quickly,,, + it's January 14th, 2019. This door is about to shut, a door/deadline that Christ MUST return before, and this is a door that I believe we MUST know.
This is so simple that it scares me, at the vast spiritual warfare that these evil spirits have managed to dumb down a whole population of earthlings. This uses the simple and free technology of pulley mechanics, where you only pay for the one rotation of a 100 cm circumference pulley, and by using 10 mini-pulleys of one centimeter circumference with AC generators attached, you can gain a return of 10X100=1000 cycles of AC electricity, for as many of these 100 cm circumference pulleys that you choose to attach to this drive pulley. So, we could be freely multiplying as much AC electricity as we want to,,, yes, this GEM technology is truly a free energy – AC electricity multiplying machine.
YES, GEM PULLEY TECHNOLOGY CAN FREELY COVERT ONE ROTATION OF A MOTOR INTO 1000'S OF CYCLES OF AC ELECTRICITY. (+ don't listen to these evil lies about torque being a problem = these are only electric motors, and are easy to rotate unless massive current is needed, which is not needed in this little mechanism)- Free Energy is that simple, AC electricity being multiplied by pulley technology. Our problems are solved,,, now we just need people like you to go out there and start converting all of our gasoline powered technologies into GEM powered mechanisms. By the way, if we still have a need for the combustion engine, we can use GEM technology to convert H20 into H2 + O2, and then when we burn the hydrogen, there are not so many toxic chemicals being produced.
YESSS,,,,, GEM PULLEY TECHNOLOGY CAN FREELY MULTIPLY AC ELECTRICITY
Think about it this way, you only have to pay one spark of DC current, for one rotation of a large 100 cm circumference pulley. Then you can run the 100 cm of belt, past 10 of the 1 cm circumference pulleys with AC generators attached, giving you a return of 10X100=1000 cycles of AC electricity.
THAT'S A RETURN OF 1000 UNITS/CYCES OF AC ELECTRICITY, FROM ONE MERE SPARK OF DC
WHY CAN NOBODY SEE HOW OBVIOUS THIS IS,,,,,,,,,,,,,,,,,,,
You only pay the small amount of DC current, to rotate a 100 cm circumference pulley once
Which is only one mere spark, (the small bit of electricity to rotate a motor once)
+ through GEM pulley technology you are using 10 mini-pulleys of 1 cm circumference
From the 100 cm of belt off your large pulley, you multiply your total rotations by 10X100=1000
+ by simply adding 10 AC generators, you can gain 1000 cycles of AC electricity
That is multiplying your rotations by 1000, through GEM pulley mechanics
And by simply adding 10 free running AC generators,
You are gaining a multiple of 1000 cycles of AC electricity,
+ forget the lies about torque,,, as there is none.
These AC generators are running free
OK,,, PLEASE SHOW ME THOUGH PHYSICS OR MATHEMATICALLY WHY THERE IS THIS FICTIONAL TORQUE
Several of us have already told you over and over again that the torque is not fictional. IT IS VERY REAL. But you continue to ignore us. When you multiply speed you also multiply the torque. This is just very basic high school level physics. I am very sorry this seems to be beyond your comprehension level. Please take the time to do some basic research about how generators and motors work. Also do some basic research into torque versus speed physics. These things are very simple and basic to understand. And they prove without a shadow of a doubt what we have been telling you. Most of the people that have been telling you your system can't work have actually worked with motors and generators and alternators. We have seen the torque requirements first hand and have even measured those requirements.
Please stop posting on this and other forums about this idea. And if you insist the rapture is going to be in two years then join a rapture forum and preach over there. I do believe in the rapture but the Bible is very clear no one knows when that will be.
Respectfully,
Carroll
He is sailing his boat alone in the middle of the pacific ocean. Maybe he will be found stranded on one of the most remote island Henderson island in the pacific. His claims will fit well there among the other 18 tons of trash on that island.
I'll bet he will find both salvation and Jesus there too. And enough trash to build his device.
Vidar
Quote from: citfta on July 10, 2017, 04:31:04 PM
Respectfully,
Carroll
It appears Aaron on the Energetic Forum has gotten tired of Joe posting the same thing over and over again over there also. He has given Joe until the end of the week to post a video or pictures of a working device or he will be banned. I just wish he would restrict his posting to only one thread here but he seems determined to continue to post all over the place here, even in other peoples threads. To me that seems like enough to get him banned here also. If he would keep his posts to just one thread I would not consider that enough cause to ask for him to be banned.
This is such a super simple GEM=(Geographical Electricity Multiplication) pulley technology, that I hope it will clue you into just how powerful this spiritual warfare truly is, to be able to hide such an easy free energy technology. It only takes one small spark of DC current, to rotate a 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. Then you run this 100 cm of moving belt past 10 of the 1 cm circumference mini-pulleys, with free running AC generators attached, giving you 10X100=1000 cycles of AC electricity as a return or as an output. That's one minute bit of DC current in, giving you a return of 1000 cycles/units of AC electricity as an output. How can you not be multiplying your AC cycles of electricity, when through simple pulley mechanics, you are drastically multiplying your total # of cycles of AC electricity, by merely adding free running AC generators to your 10 mini-pulleys.
How can you not be multiplying you AC electricity, when you are only inputting one single spark/jolt of DC current, while you are gaining a return of 1000 cycles of AC electricity? These AC generators have practically no torque against them, as they are being used as free running motors/generators, with practically zero resistance to them. This is because even if they were being used to power your DC drive motor, they would only have to generate one small spark of DC current, which is practically zero power, and that would be divided by 1000 cycles of AC electricity, equaling practically zero torque, and that minuscule amount of power is being divided by 1000 units/cycles of AC electricity
You are using simple pulley mechanics to multiply your rotations by 1000, and by simply adding free running AC generators to your mini-pulleys, you are actually multiplying your AC electricity. Yes, that's right, you are using pulley mechanics to freely multiply your total # of rotations, + by simply adding 10 free running AC generators, you are actually multiplying your total amount of AC electricity. This is because your AC generators do not have to produce practically any power, so these generators have practically zero torque against them.
HOW SIMPLE MINDED HAS THESE EVIL SPIRITS MADE OUR HUMAN RACE, to not be able to see how simple this GEM AC electricity multiplication mechanism truly is. Where you only pay for one rotation of a large 100 cm circumference pulley, and through simple pulley mechanics, with free running AC generator, you are gain a return of 1000 cycles of AC electricity. HOW CAN YOU NOT GAIN THE MINISCULE AMOUNT OF DC ELECTRICITY, WHEN YOU HAVE 1000 CYCLES OF AC ELECTRICITY TO WORK WITH.
Please do not listen to the evil forces talk about torque being a problem, as great torque only comes from when you are generating large amounts of power. To make this GEM mechanism a self powered, you would only need to generate the smallest amount of power. You would only need to generate enough power to crank over your large pulley one single time, which is practically zero, and that minute amount gets divided by 1000 cycles of AC electricity. Do you see just how small amount of power that you must generate, to have this free energy mechanism self powering. With all of your 1000 cycles of AC electricity, you only need to generate one mere spark/jolt of DC current, and this super small amount of power is divided by 1000. So it's 1000th of one mere spark of DC current, so it is less than no torque at all.
COME ON YOU SERIOUSLY MISLED MANKIND, PLEASE SEE THROUGH THIS EVIL MYTH OF THERE BEING A TORQUE PROBLEM,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, PLEASE, WAKE UP PEOPLE + SEE THROUGH THESE LIES OF EVIL SPIRITS. SHAKE OFF THE MEDILING OF THESE EVIL SPIRITS, TRYING TO CONFUSE THE SIMPLICITY OF THIS GEM TECHNOLOGY. THIS IDEA CAME IN EZEKIEL 1:16 + IS DISCRIBING HOW A UFO MOTOR LOOKS WHILE RUNNING. SO THIS WILL NOT ONLY GIVE US THIS SUPER SIMPLE WAY OF MULTIPLYING FREE ELECTRICITY, BUT IT COULD HELP US DRAMATICALLY IN OUR FUTURE SPACE EXPLORATION WITH UFO FLIGHT TECHNOLOGY.
Yes,,, sure thing, penalize the guy who cannot produce a working model, not only because of his disability, but his place of living, that will not even allow him to have a single screwdriver, because one of his fellow neighbors might accidentally hurt him or herself on it.
This guy who is honestly trying to get this satanically blinded population to see how simple free energy is,,, by simply paying for one rotation of a DC motor with a 100 cm circumference pulley attached, would give you 100 cm of moving belt. If you ran this 100 cm of moving belt past 10 of the 1 cm circumference pulleys with free running AC generators attached, you would gain 10X100=1000 cycles of AC electricity.
THESE AC GENERATORS RUN FREE FROM MOST ALL TORQUE, BECAUSE TORQUE IS CAUSED BY POWER GENERATION + THIS ONLY NEEDS TO GENERATE ONE SINGLE SPARK OF DC CURRENT, TO ROTATE YOU 100 CM DRIVE PULLEY ONCE. (practically non-existent torque) So you have 1000 cycles of AC free energy to work with, in attempting to generate one mere speck of current, (just enough to rotate your drive motor one single time + guess what you have to start this work by, only 1000 cycles of AC electricity)
Use the minuscule amount of DC electricity that it takes to rotate one large pulley of 100 cm circumference, and through the LAWS OF PULLEYS, you can use 10 mini-pulleys of 1 cm circumference, to drastically multiply your total # of rotations by 1000 = 10X100
AND THESE AC GENERATORS DRAW ZERO TORQUE IN ROTATING, AS THEY ONLY NEED TO GENERATE ONE MERE SPARK OF DC CURRENT,,, AND THEY GET 1000 CYCLE TO DO IT WITH
THAT'S ONE SPARK OF CURRENT, DIVIDED BY THE 1000 ROTATIONS THAT YOU ARE GENERATING
<<<<<<<<<<<< THINK OF THESE GENERATORS/MOTORS AS RUNNING FREE >>>>>>>>>>>>>
As they get 1000 cycle of AC electricity, to only generate the miniscule amount of current that it uses to rotate only one single time
AC electricity is generated by rotations, so the more rotation = the more AC electric cycles that you are generating, off 10 absolutely free running AC generators. AND NO, THESE AC GENERATORS ARE NOT CAUSING ANY TORQUE, AS THEY HAVE PRACTICALLY ZERO POWER BEING GENERATED BY THEM. THINK OF THESE MOTORS AS COMPLETELY FREE RUNNING, AS THEY DO NOT NEED TO GENERATE ANY POWER. Remember these 1000 cycles of AC electricity, only have to generate the super small amount of electricity that it takes to rotate this DC drive motor one single time,,, only one spark, one short burst of current.
You are seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to turn one rotation of a large 100 cm circumference pulley, into 1000 rotations of 10 min-pulleys, + by simply adding 10 AC generators
Quote from: citfta on July 11, 2017, 04:54:38 PM
Free energy in it's simplest form, uses GEM AC electricity multiplication with variable size pulleys.
This is soooooo simple, that I hope that you will feel great anger at the evil spirits, + know about them.
They clouded your head + misled your mind, throwing lies at you, so that it dumbed you down,
So that you would not be able to understand .................. T.O.R.Q.U.E is a big factor = BIG LIE.
It uses preschool taught pulley mechanics; to mega multiply your total # of rotations. Trade 1 for many
Do you want to know how you can seemingly break the laws of thermodynamics?
By produce more electrical power output, than you have to put into this system.
You are using the free mechanical laws of pulleys, to multiply your # of rotations,
+ isn't that Truly Amazing, that simple rotations of a coil inside a magnetic field,
Is how you can easily generate AC electricity = how easy is it to rotate a toy motor = no back torque
Now please don't talk about this fairytale torque problem.
Think about this, how easy it to rotate these new small toy motors, disconnected from any wires,
Yes, this is because they are practically running torque free, + unplugged
Because if you are talking about backpressure of a small electric motor,
You would need massive current, to produce even a little backpressure,
And here we are talking of only a mere spark of current used = practically no current
Think about the minute power that it takes to rotate a toy motor, one single time
If you attach a large 100 cm circumference pulley to it, then you would get 100 cm of moving belt.
This mere spark-(short burst) of DC current is all that it costs for input power.
Now if you ran the 100 cm of moving belt past 10 free running 1 cm circumference min-pulleys,
That are connected to AC generators , you would get 1000 cycles of AC electricity. (10X100)
+ now try to tell me that we cannot get 1 small burst of DC current, out of 1000 sparks of AC electricity
This should run so smoothly, that you only need to give the large pulley a nudge, 1/12th of a turn
To start this GEM free energy AC electricity multiplier/generator
This Miraculous Gift was given to us at this particular time, for the soon coming Tribulation Saints,
To help them survive the soon coming Great Tribulation, door = deadline = 2022.49 = 2019.04 + 3.45
Now please remember people, I do not claim to know the date it is going to happen by, but
My date settings are the dates that the doors close on it being able to happen by, http://doorschristmustpassthrough.yolasite.com/ within the same generation = 51.6 solar years
Dates that we are assured that we can know = (Mat 24:33) "know that it is near, even at the doors"
+ doors are plural to be for both His Arrivals, the Rapture in the clouds. (before the Tribulation starts), which no man knows + when His Foot touches the Mount of Olives, (at the end of the Tribulation),
a day that the Tribulation Saints will be counting down the days till it comes
As in, within this last generation, (before Christ Arrives)
+ I used the 14, 14 + 14 generations of Christ's linage, to calculate the time span for this last generation
Not only because it is more Christian + not just Jewish, it being Christ
But because this same duration was used in predicting the exact date that Israel became a nation.
This was using a little know rule with God, about Him giving a second chance after 10 times the original duration. + if you multiply the # of days from when this was first prophesized,
to His First Arrival in Jerusalem, by 10 times,
Miraculously it turns out to be the exact day that Israel became a nation again
Please read "ARMIGEDDON" by the dead Canadian author Grant Jeffrey,
This novel helped me see that the KJV Bible was God's Truth. KJV is oldest + least edited version,
+ then soon afterwards to admit that I was a sinner, who the Father could not even look upon,
Realize that I could never become Holy enough, or physically pay for all of my sins =
(it would totally atomize me), I believe God when He says that I could not stand to pay for my sins.
But our Father=(God the Brains) was so merciful, to find a way for Jesus=(God the Body)
To not only pay for my sins, but give us the Holly Spirit=(God the Spirit) to live with us for all eternity
http://beliefstoliveby.yolasite.com/ + http://biblefilescentral.yolasite.com/
These AC generators take no torque to rotate, as they are just winding up massive voltage,
These AC generators only needing one single spark of current, (practically zero)
These AC generators are running practically torque free, as they only need to generate one mere spark of current,(practically zero) and torque comes from generating power. So even massive voltage
Massive voltage gives this mechanism great electrical pressure,
To crank over your large pulley only the once
+ because you only need one revolution, you don't need much current –(practically zero)
Which also means that it takes practically zero torque to rotate
Torque comes from generating power and power equals your current times voltage – (P=IV)
P=IV or current multiplied by voltage, and since your current is practically zero,
I would say that practically zero power was being generated, which takes practically zero torque
Now please don't tell me that this large pulley could not gain the voltage/pressure to rotate once,
Especially if that is what these free running AC generator are good at doing,
Massive rotations is great at generating massive voltage, + easily rotated
Now try and tell me that your large pulley cannot rotate 10 free running mini-AC generators
OK, then you only have to rotate one single mini-pulley, as even 100 cycles of AC electricity,
Should be enough AC electricity to gain this single small amount of DC current =(I spark)
I just used 10 of them to show how massive of voltage this could be used to generate,
Maybe even enough voltage pressure to levitate a object,
Remember, this idea came from my reading the description of a working UFO motor in (Ezek 1:16)
Respectfully,
Carroll
I don't claim to know the date of His Arrival,
I was only pointing out how close the door was to closing,
for this Prophecy to fulfill the part about it being within the same generation
I know it's not fictional, just so small it's irrelevant = you sound like a skipping record
if you keep saying it LOUDER + LOUDER, then that does not make it more relevant
+ just how much torque does a toy electric motor cause for resistance
I liked learning physics, + made high 80's in all the math + science classes in high school
my only 90 was in chemistry... where I made 100 so many times in a row,
that the teacher made me take the next test alone, in front of him, I made another 100
this GEM system does not even use speed,,,
it can be so easily explained by one single rotation
I learned how motors worked in grade 6 or 7, when I added a fan to my Halloween costume helmet
satan + his evil followers have got you so messed up in the head,,,,
please stop listening to these evil forces + embrace this GEM technology = Gift from God
+ we are allowed to know when the doors occur
"know that it is near, even at the doors" (Mat 24:33)
DOORS are plural, to represent His Both Comings
Rapture = blessed hope + "meet the Lord in the air"-(1 Thes 4:17) = which no one knows
Glorious Appearing with His Born Again Followers, which the Tribulation Saints will not only know
but they will be no doubt be counting down the days until
Respectfully,
joe
HERE IS MORE EXPLANATIONS
Free Energy is super simple
Yet, it is being hidden by evil spirits
I hope that after you see just how ridiculously simple this technology is,
That you will see through the spiritual fog,
Questioning how we missed this GEM of a free energy technology
- GEM = (Geometrical Electricity Multiplication) technology
Not finding it so hard to acknowledge that there is a real spiritual warfare
How else could we miss this simple + easy to produce free AC ELECTRICITY?
IN REALITY,,,,,
It is all done with wheels, or in this case variable sized pulleys
It uses a small "wheel in the middle of a wheel" that is large (Ezek 1:16)
Which is Ezekiel's description of a working UFO motor mechanism
To put it in layman's terms, you use pulley mechanics, to multiply # of rotations
Which in electronics terminology, is multiplying AC electricity
INPUT - expending one spark of DC current = electricity into a DC motor,
This one spark will rotate the DC motor one full rotation
If you attach a 100cm circumference pulley to this DC motor,
Then attached a longer than 100cm belt to this pulley,
You would gain 100cm of moving belt,
+ have room to add a few mini-pulleys as your output
Which you would then run through 10 attached mini-pulleys,
Each mini-pulley has a 1cm circumferences,
If you then attached AC generators ,this gains you
OUTPUT - 10 X 100 = 1000 cycles of AC electricity
Thereby multiplying your one spark of DC electricity into 1000 sparks of AC electricity
There is no torque problems, as you are just using the AC generators
To wind up massive voltage,,, + torque only occurs when you generate power
Power being voltage times current
And the total amount of current that we need to generate
To make this GEM mechanism self powering, is one spark
Or practically zero current, hence practically zero torque
You can seemingly defeat the laws of thermodynamics,
By using the physical capabilities of rotating a large circumference pulley once
To gain massive lengths of belt from a large circumference pulley
+ then running that massive length through many mini-circumference pulleys
Thereby you are multiplying your rotations = multiplying AC electricity
Respectfully,
Carroll
Quote from: that_prophet on July 14, 2017, 08:59:15 PM
Are you familiar with the abilities of pulley mechanics?
Especially the way you can use the length of belt off one rotation of a large pulley,
To freely + drastically multiply the # of rotations of one or many mini-pulleys,
This happens to be a most significant advantageous ability,
Especially when it comes to the cycles of AC electricity,
Where more rotations, is equal to a greater supply of AC electricity
WARNING – THIS GEM IS GIVEN TO US NOW, FOR THE SOON COMING TRIBULATION SAINTS,
+ WILL BE A MOST NEEDED FREE ENERGY TECHNOLOGY FOR THE WHOLE WORLD.
THE BAD NEWS IS, THAT THIS COMES WITH THE FAST APROACHING GREAT TRIBULATION,
=(within the next 5 years) Which is the second half of the infamous 7 year peace treaty with Israel,
as of July, 2017 = as the door closes for the Great Tribulation to begin on 2022.49
Meaning that this Prophecy can no longer be fulfilled, after date occurs, or this door closes
THIS USES GEM PULLEY TECHNOLOGY TO SEEMINGLY CHEAT,
THE FIRST LAW OF THERMODYNAMICS,
BY GAINING MORE ELECTRICITY OUTPUT THAN YOU PUT IN
This GEM=(Geometrical Electricity Multiplication) free energy mechanism uses pulleys to work miracles
By using one rotation of a large pulley, this can be freely multiplied mechanically, into massive rotations,
By the use of multiple mini-pulleys + since AC electricity is generated by using rotations,
If you can multiply the # of rotations, then you can also multiply the amount of AC electricity
Free energy in its simplest form, uses GEM = AC electricity multiplication, using variable size pulleys.
This is soooooo simple, that I hope it will make you feel great anger towards all of the evil spirits,
+ learn about these evil spiritual forces,(fallen angels + their offspring) as being part of reality,
Yes angels + demons are real, and fortunately this means that the God of the Bible is Real as well.
These spirits have clouded your head + misled your mind, throwing lies at you, making you dumb
So that you would not be able to understand ......... T.O.R.Q.U.E being a big factor = is a BIG LIE.
+ Trade every single rotation of your drive motor, into massive amounts of rotations of mini pulleys.
(remember AC electricity is made from rotations) = you are actually multiplying AC electricity
By produce more electrical power output, than you put into this electricity multiplication system.
You are using the free mechanical laws of pulleys, to multiply your total # of rotations,
To start this GEM perpetual free energy AC electricity multiplier/generator running
http://my2020vision.yolasite.com/ + http://doorschristmustpassthrough.yolasite.com/
+ within the same generation = (51.6 solar years).
These are dates that we are told that we can know, but in the original Greek writings,
it was worded like a command, (Mat 24:33) "know that it is near, even at the doors"
As in, within this last generation, (before Christ's Second Arrival)
Not only because it is more Christian + not just Jewish, with it being Christ's birth date ++++++++++++++
But because this same duration was used in predicting the exact date that Israel became a nation again.
This was using a little known rule with God, about Him giving a second chance to the nation of Israel,
But not after another same duration again, but after 10 times the original duration.
Please read "ARMIGEDDON" by the Canadian author Grant Jeffrey,
These AC generators are running practically torque free, as they only need to generate 1 spark of current,
=(practically zero) and torque comes from generating power.
So even massive voltage multiplied by practically zero current, still equals practically zero
This pulley technology works,,, Here are a few of ideas that others have, Knowing or not knowing that
it is based on the same GEM technology, theirs only has one mini-pulley, + not 3 or 10 like in mine https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t=3s
I know torque is not fictional, just so small it's irrelevant = you sound like a skipping record
if you keep saying it more + more, then that does not make it any more relevant
my only 90 was in chemistry... where I made 100 on tests, so many times in a row,
that the teacher made me take the next test alone, in front of him, I made another 100,,, lol
I don't remember taking any IQ tests before in my life, but because of my closed head injury,
in order to get myself out of the first nursing home, after I had relearned all of the life skills to live,
which included how to speak, as when I first woke up in the hospital, I could not even speak one word,
I guess the closed head injury was worse than I first though, or maybe it was from lack of oxygen,
From the twice my heart stopped, once in the ambulance + once in the hospital, shortly after the accident,
but first I had to prove myself competent to live on my own, + deal with my lack of short term memory,
taking a few online IQ test, I scored a 135 on a test accurate to 120, + a 165 on a test accurate to 145
where 100 was average + I only needed to make a score of 85, to prove my own competency.
this GEM system does not even need to use speed, to produce the needed DC electricity
it can be so easily explained with only one single rotation of your drive motor
I learned how motors worked in junior high, when I added a fan to my Halloween costume helmet
A costume that I continued to work on every year, adding more LEDs or other additions to it every year
In reality it was a full set of body armor, made out of ¼ inch plywood + backed with carpeting
One year, I think grade 7, I even built a flaming sword, flame proofing it by covering in tin foil,
+ having a spray-nine pump built into the handle with a hose + nozzle pointing at the blade
So as long as I had a lighter to start it, + by squeezing the pump ever 3-5 seconds,
I could keep the blade in steady flames, I had large pill bottles filled with methyl hydrate for fuel
I believe that satan + his evil fellow evil spirits + fallen angels have got you so messed up in the head,,,,
Just stop listening to these evil forces + embrace this GEM technology = (God's electricity multiplier)
Now please don't misunderstand me, as I don't claim to know the date of His Arrival,
I was only pointing out just how close the door was to closing, (last day prophecy can be fulfilled)
Rapture = blessed hope + "meet Him in the sky" = which no one knows
a date that we are not only encouraged to know,
but in the original Greek, I heard that it was worded like a command
"know that it is near, even at the doors" (Mathew 24:33)
BS! ;D
"BS!"
Bcareful.there is ONE part of the bible that stands the test of time and that is: MARK 3,29
To rotate your DC motor, with a large pulley attached, you need a lot of voltage, + practically zero current, (1 mere spark) only enough current to crank over the DC drive motor one single rotation. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this 100 cm of moving belt past one free running, one-centimeter circumference pulleys with AC generators attached, you would end up with 100 cycles of AC electricity. Yes, that's only paying for one rotation of a large pulley, using pulley mechanics, giving you a return of 100 rotations of a mini-pulley, + by adding a free floating AC generator, you are gaining a total of 100 cycles of AC electricity.
These 100 cycles of AC electricity are running free of practically any torque, as they are used to wind up the massive voltage, which is needed to crank over you DC motor only once. (all voltage + practically zero current =(only one spark)). I say spark because it would only take one extremely short burst of current, (just enough to rotate your DC motor one single time)=one small burst of current, if the motor was running at 60 cycles per second=slow, it would only be 1/60th of a second = only one short spark
Torque is only caused when you are generating power, and Power is equal to "I"-current times Voltage, or P=IV. Since practically zero current,(only one spark) times even massive voltage, still equals practically zero power, there is practically zero power + zero torque being created. So, each half of this system is powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
http://free-energy.yolasite.com/ This is so simple that I want you to be shaking your head, at mankind not seeing the simplicity of this long ago,,, as you are only paying for one single rotation of a large 100 cm circumference pulley, and you are getting in return 100 cycles of one cm circumference pulley, with an AC motor/generator attached. You are using simple pulley mechanics to trade one rotation for 100 rotations. Yes, the large pulley would take more voltage/pressure to rotate, but guess what your motor/generator on the one centimeter pulley is busy generating,,,,,,,,,,,,,,,,,,, MASSIVE VOLTAGE.
I want you to see how simple this technology is: http://free-energy.yolasite.com/, so that you can see through this spiritual fog that hangs over us, as we come closer + closer to the first Door = 2020, closing for His Return. http://my2020vision.yolasite.com/. This is a door that we are not only allowed to know, but commanded in Greek "know that it is near, even at the doors" Mat 24:33 http://doorschristmustpassthrough.yolasite.com/, because this free energy is meant for the soon coming Tribulation Saints. I want you to be able to see through this evil darkness that satan =(the god of this world-2 Cor 4:4) has set over our unknowing + unbelieving world.
ONCE YOU SEE THE UTTER SIMPLICITY OF THIS GEM OF A GIFT = FREE ENERGY, I hope that you will start looking at the BIBLE, for the Truth that it is. http://beliefstoliveby.yolasite.com/, and see how the free gift of Christ's Salvation, solves the problem of us humans, being able to live with our Holy Righteous GOD. Who we are made in the Image of = Father/Son/Holy-Spirit = mind/body/soul
How GEM free energy works
This runs on inputting an extremely small amount of power into a DC motor, (1 spark of current)
To drive a large 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt.
+ it drives a 1 cm circumference mini-pulley, for 100 times. + if you add an AC generator to mini-pulley
Giving you an output of 100 cycles of AC electricity, all for one spark of DC electricity input
How can you not gain power, when you are trading one short burst of DC electricity for 100 cycles of AC
Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity
These mini-pulleys run free, as they are just winding up massive voltage + use practically zero current.
+ Torque only occurs when you are generating power, the more power, the more torque
Power is equal to I-current multiplied Voltage, or P=IV
We are not generating practically any power because no matter how massive the Voltage is
With the I-current being practically zero, this means that the power being generated is practically zero
Meaning that the amount of torque that it takes to rotate these mini-pulleys is equal to zero
You are just using one single rotation of your large 100 cm circumference pulley to give 100 cm of belt,
+ then you run this long 100 cm of belt past one free running mini-pulleys of only 1 cm circumference,
If you attach an AC generator, this will gain you the amazing return of 100 cycles of AC electricity
That's right, you are only inputting the small burst of DC current, that it takes to rotate a DC motor once, which is through the free properties of pulley mechanics, (trading one rotation, for 100 rotations)
+ the one rotation of a 100 cm circumference pulley does not cost 100 times more power to rotate.
yet you are gaining 100 times more AC cycles of electricity.
This is how you are able to use pulley mechanics, to actually multiply AC cycles of electricity
Bs! ;D
This http://free-energy.yolasite.com/ technology runs on 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. + it drives inputting an extremely small amount of power into a DC motor, (1 spark of current) to drive a large a 1 cm circumference mini-pulley, for 100 times. + if you add an AC generator to mini-pulley, giving you an output of 100 cycles of AC electricity, all for one spark of DC electricity input. How can you not gain power, when you are trading one short burst of DC current for 100 cycles of AC electricity. Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity
These mini-pulleys run free, as they are just winding up massive voltage + use practically zero current. + Torque only occurs when you are generating power, the more power, the more torque. Power is equal to I-current multiplied Voltage, or P=IV. We are not generating practically any power because no matter how massive the Voltage is, with the I-current being practically zero, this means that the power being generated is practically zero. Meaning that the amount of torque that it takes to rotate these mini-pulleys is equal to zero
You are just using one single rotation of your large 100 cm circumference pulley to give 100 cm of belt, + then you run this long 100 cm of moving belt past one free running mini-pulleys of only 1 cm circumference. If you attach an AC generator, this will gain you the amazing return of 100 cycles of AC electricity. That's right, you are only inputting the small burst of DC current, that it takes to rotate a DC motor once, which is through the free properties of pulley mechanics, (trading one rotation, for 100 rotations) + the one rotation of a 100 cm circumference pulley does not cost 100 times more power to rotate. yet you are gaining 100 times more AC cycles of electricity. This is how you are able to use pulley mechanics, to actually defeat the first law of thermodynamics + actually multiply your # of AC cycles of electricity.
This is so super simple, that I hope this wakes you up to the powerful spiritual warfare that is going on all around you, in this godless world. You are only inputting the smallest amount of DC electricity, (massive voltage, but only one short burst of current, and you can get 100's of cycles of AC electricity back in return). Through pulley mechanics you are trading one rotation of a large 100 cm circumference pulley attached to a DC motor, for 100's to 1000's of rotations of a 1 to 10 of the 1 cm circumference pulleys attached to AC generators. These AC generators run with practically no torque, because these 100 to 1000 rotations only have to generate the smallest amount of current, (one spark). They are just winding up massive voltage, and only have to generate one small burst of DC current, just enough to rotate the DC motor one single time. This is now a self generating set of DC + AC motor/generators, allowing you to tap off of them DC + AC electricity.
This is a technology that will be needed by the Tribulation Saints before 2022.49 arrives, (door for Great Tribulation) http://my2020vision.yolasite.com/ when not only the door closes on Christ's first arrival in the clouds,(2019.04), but the door closes for the second half of the infamous 7 year Peace Treaty closes http://doorschristmustpassthrough.yolasite.com/ I can only hope, that you will start looking into the Bible, for ways to survive this coming trial of mankind, http://beliefstoliveby.yolasite.com/ when half the population of this earth will not survive. Or even better, becoming born again, + using the "blessed hope" to be able to go to the Wedding of Christ + escape the coming judgment on mankind.
"Bs!"
I happen to be disabled + on disability pension, + I love + spend most days studying His Word,
so I do any errors honestly, but thanks for the warning
sorry that I could no longer edit my last words,,,
so I must rewrite this whole page, to make changes,
Yes, this is the last of the end times,.2020 is when the first door will close.
This is when we will need free energy
How GEM = free energy device works
This http://free-energy.yolasite.com/ technology runs on a large 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. + it only takes inputting an extremely small amount of power into a DC motor, (1 spark of current) to drive a large pulley one single time, causing a 1 cm circumference mini-pulley, to rotate 100 times. + if you add an AC generator to the mini-pulley, gives you an output of 100 cycles of AC electricity, all for one spark of DC electricity input. How can you not multiply your power, when you are trading one short burst of DC current for 100 cycles of AC electricity. Surely you can gain more than one spark of DC current, out of 100 cycles of AC electricity, to make this a self powering device. This pulley technology freely multiplies rotations, and AC electricity is made from rotations, so you are actually multiplying AC electricity.
These mini-pulleys run free, as they are just winding up massive voltage + only need to generate practically zero current. + Torque only occurs when you are generating power, the more power, the more torque. Power is equal to I-current multiplied Voltage, or P=IV. We are not generating practically any power because no matter how massive the Voltage is, with the I-current being practically zero, this means that the power being generated is practically zero. Mean that the amount of torque that it takes to rotate these mini-pulleys is equal to practically zero. Each half of this free energy powering system, generates more than enough of the input power for the other half of this self powering GEM=(Geometrical Electricity Multiplying) mechanism. The massive amount of rotations of the mini-pulleys produces more than the voltage needed to crank over your DC motor once. + The 100 cm of belt off your large pulley, is more than enough to rotate your mini-pulley enough times to gain the one single burst of current, when put it through a full wave bridge rectifier.
This is so super simple, that I hope this wakes us up to the powerful spiritual warfare that is going on all around you, in this godless world. You are only inputting the smallest amount of DC electricity, (massive voltage, but only one short burst of current, and you can get 100's of cycles of AC electricity back in return). Through pulley mechanics you are trading one rotation of a large 100 cm circumference pulley attached to a DC motor, for 100's to 1000's of rotations of a 1 to 10 of the 1 cm circumference pulleys attached to AC generators. These AC generators run with practically no torque, because these 100 to 1000 rotations only have to generate the smallest amount of current, (one spark). They are just winding up massive voltage, and only have to generate one small burst of DC current, just enough to rotate the DC motor one single time. This is now a self generating set of DC + AC motor/generators, allowing you to tap off of them DC + AC electricity.
This is a technology, that will be needed by the Tribulation Saints before 2022.49 arrives, (door for Great Tribulation) http://my2020vision.yolasite.com/ when not only the door closes on Christ's first arrival in the clouds,(2019.04), but the door closes for the second half of the infamous 7 year Peace Treaty closes http://doorschristmustpassthrough.yolasite.com/ I can only hope, that you will start looking into the Bible, for ways to survive this coming trial of mankind, http://beliefstoliveby.yolasite.com/ when half the population of this earth will not survive. Or even better, becoming born again, + using the "blessed hope" to be able to go to the Wedding of Christ + escape the coming judgment on mankind. This free energy technology can be found in the Bible, where Ezekiel is describing what a UFO motor looks like, while it is running. (Ezek 1:16)
Quote from: profitis on August 04, 2017, 03:08:40 PM
"Bs!"
profits = that_prophet
Thank you for the bs. again dude. ;D
Why is it that nobody talks about the soon closing doors, which are deadlines, these are must happen before dates, that we are allowed to know...? (Mat 24:33)
TIME IS SHORT, Yes, this is the very last of the end times, as 2019.04 is when the first door will close.
http://my2020vision.yolasite.com/ These are Doors that we are not only allowed to know, but in the original Greek, it is worded like a command, (Mat 24:33) "know that it is near, even at the doors" These Doors are deadlines, or must happen before dates. Doors are plural, to represent His both Comings = 1-(Rapture) + 2-(Glorious Appearance)
Time is coming to the point when free energy will be needed most, during the Great Tribulation, when people will be forced to take the mark, to purchase or do most anything. PLEASE, NEVER TAKE THE MARK, AS IT MEANS THAT YOU WILL SPEND ETERNITY IN THE LAKE OF FIRE. (a place worse than hell)
JESUS IS GOD, + HE IS COMING BACK VERY SOON,,,
(before 2019.04) when the 1st door closes, for His Arrival in the clouds, to remove His Bride for the Wedding
THIS IS A GIFT FOR THE TRIBULATION SAINTS.
Are you familiar with the abilities of pulley mechanics? - http://free-energy.yolasite.com/ Especially the way that they can use the length of the belt off one rotation of a large pulley, To freely + dramatically multiply the # of rotations of one or many mini-pulleys. This happens to be a most significant advantageous ability, especially when it comes to the cycles of AC electricity. Where you can actually multiply your supply of AC electricity, by simply adding some mini-pulleys connected to AC generators, where the more rotations that you gain, are equal to a greater supply of AC electricity.
Think about how easy that it would be to rotate a mini-pulley of 1 cm circumference for 10 times, with a free running motor/generator attached to it. This motor/generator would be only building up massive voltage, which is just what you need, to crank over your large pulley one single time. Each half of this mechanism has exactly what the other half needs.
To rotate your DC motor, with a large pulley attached, you need a lot of voltage, + practically zero current, (1 mere spark=short burst of current) only enough current to crank over the DC drive motor one time. With this one rotation of your DC motor, you are also rotating a 100 cm circumference pulley, which gives you 100 cm of moving belt. If you run this 100 cm of moving belt past one free running, one-centimeter circumference pulley, with an AC generator attached, you would end up with 100 cycles of AC electricity. Yes, you are only paying for one rotation of a large pulley, + using pulley mechanics, which is free + easy, giving you a return of 100 rotations of a mini-pulley, + by adding a free floating AC generator to this mini-pulley, you are gaining a return of 100 cycles of AC electricity.
These 100 cycles of AC electricity are running free of practically any torque, as they are just being used to wind up the massive voltage, which is exactly what is needed to crank over you DC motor one time only. (all voltage + practically zero current =(only one spark)). I say spark because it would only take one extremely short burst of current, (just enough to rotate your DC motor one single time)=one small burst of current, if the motor was running at 60 cycles per second=slow for electric motors, would only be 1/60th of a second = only 1 short spark. With pulley technology you can easily + freely multiply your total # of rotations.
Torque is only caused when you are generating power, and Power is equal to "I"-current times Voltage, or P=IV. Since practically zero current,(only one spark) times even massive voltage, still equals practically zero power, there is practically zero power = zero torque being created. This works by each half of this system, being powered by the other half of this system, where the many cycles of the AC generators are just winding up massive voltage, which is needed to crank over your DC motor just one single time.
http://free-energy.yolasite.com/ This is so simple that I want you to be shaking your head, at mankind not seeing the simplicity of this long ago,,, realizing the awesome power that evil forces hold, to hide this super simple free energy technology from mankind for so long. You are only paying for one single rotation of a large 100 cm circumference pulley, and you are getting in return 100 cycles of a 1 cm circumference pulley, with an AC motor/generator attached. You are using simple pulley mechanics to trade one rotation for 100 to 1000 rotations =(100 X 1 to 10) mini-pulleys. Yes, the large pulley may take lots of voltage/pressure to rotate, but guess what your generator on the one centimeter pulley is busy generating,,,,,,,,,, MASSIVE VOLTAGE.
I want you to see how super simple this technology is, so that you can see through this spiritual fog that hangs over us, as we come closer + closer to the first Door = 2020, closing for His First Return, in the clouds. http://my2020vision.yolasite.com/. This is a door that we are not only allowed to know, but we are commanded to know, in the original Greek "know that it is near, even at the doors" (Mathew 24:33) http://doorschristmustpassthrough.yolasite.com/, because this free energy is meant for the soon coming Tribulation Saints. I want you to be able to see through this evil darkness that satan =(the god of this world - 2 Cor 4:4) has set over our unknowing + unbelieving godless world.
ONCE YOU SEE THE UTTER SIMPLICITY OF THIS GEM OF A GIFT = FREE ENERGY, through pulley mechanics, you can freely multiply the # of rotations, and since more rotations of an AC generator means you are multiply your cycles of AC electricity, you are using pulley mechanics to actually multiply your amount of AC electricity. By only paying for the one rotation of a 100 cm circumference pulley, you can multiply your AC cycles by 1000, with 10 mini-pulleys of 1 cm circumference, with AC generators attached. (10X100=1000)
Now let me thoroughly destroy this pathetic myth about torque being a problem. These 10 mini-pulleys with AC generators attached, are all free running, as for all of the 1000 rotations of these AC generators, the only amount of DC current that you need to generate, is one simple little spark, or practically nothing. Because that is all that it takes to drive your 100 cm circumference pulley, that will start this free electricity multiplying mechanism running, as it only takes one spark of DC current. Remember that torque only comes from when you are generating power, and the only power that we are generating is practically zero, which takes practically zero torque,, or free running.
I hope that you will start looking at the BIBLE, for the Truth that it holds. http://beliefstoliveby.yolasite.com/ and see how the free gift of Christ's Salvation, solves the problem of us humans becoming good enough, + being able to live with our Holy, Righteous GOD. We don't have to worry about becoming good enough for God, as Jesus-(God the Son) stepped in and solved the problem for us. He Knew that we could never handle the punishment for the sins that we had committed, so He paid for our sins in our place, and all that we have to do is accept his Gift of Salvation.
We are made in the Image of GOD
= mind/body/soul
Yes, I may have chosen the wrong duration, (51.6) for this end time generation, but using the linage of Jesus, the 14, 14 + 14 generations seemed the most likely to me. Now comes what I think of as His Sign of approval. This same duration of time, 51.6 solar years, was used to accurately predict the date of the rebirth of the nation of Israel. RIGHT DOWN TO THE EXACT DAY EVEN.
Quote from: pulp on August 06, 2017, 04:55:33 AM
NO PROB
If you use a large amount of voltage to gain the electrical pressure to crank over this large 100 cm circumference pulley on a DC motor one single time. It might take massive voltage, but it would only take the smallest spark of current. With our modern day 60 cycles per second AC electricity outlets, that would last 1/60th of a second. (which is only a spark to me) With only this short spark of current, you are not creating practically any power, which means that you are not expending practically any torque either, which is why these 1 cm circumference mini-pulleys are practically free running. By the way, guess what this AC generator is building up when it is rotating many times = massive voltage, (which is just what you need to start rotating a DC motor, with a large 100 cm circumference pulley attached. EACH SIDE OF THIS GEM MECHANISM GIVES YOU EXACTLY WHAT THE OTHER SIDE NEEDS. (so, you have a self powering electricity mechanism giving you both AC+DC electricity that you could tap power off of)
Einstein said that the definition of lunacy is the repetition of the same thing expecting something different to happen.
This clearly defines you, that_prophet, as a lunatic.
Your interpretations are wrong. How can you be so sure based on a gut feeling?
ME = it is logic that I work on
Second, if you ask God, you get the answer you want to hear because the answer comes from your own head.
ME = sorry, but it does not come from my own head, His Words come from His Holy Spirit, which is now a part of me, but I don't believe He is only in my head. + He does not tell me what I want to hear, a lot of times He rebukes me, showing me not only how I messed up, but He often shows me how I should have handled it better
A wheel in a wheel can be anything with wheels or nothing to do with wheels.
If you want accurate information, that you don't by reading the bible, ypu must turn to science.
ME = I enjoy studying all sciences, and I try to use logic for most all things in my life, including my learning that I needed salvation. I read this awesome novel called "Armageddon" by Grant Jeffrey = Canadian author. He systematically went through some very important Bible prophecies, pointing out when they were given, and when they were accurately fulfilled, right down to the exact day predicted. The one that got to me, was the prophecy about Jesus entering the temple on the exact day it was predicted. It was no so much this exact prophecy that freaked me out, but the little know rule of God giving a second chance after 10 times the original prophecy duration. I happen to be talking about the awesome happening of Israel getting its second chance + becoming a nation again, on the date that was exactly ten times the duration of the first prophecy, calculated from the day he entered the temple, fulfilling he first prophecy
Quote from: Low-Q on July 02, 2017, 06:19:21 AM
Apparently, God created man in his own image. That also includes modern scientists. Who else created them?
ME = yes, GOD Created not only the physical + mental, but time itself, the unimaginable
I know it is a dead end discussing this with you. YOU have something to prove. Build that pulley mechanism and show the world that you are either insane or a genious.
Vidar
ME = please find me a good + free electronics simulator that has pulleys in it along with AC + DC motors, and I will gladly build it digitally for you, as I have fallen on hard times, + live in a place that won't allow me to build it physically
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm circumference pulley, past any # of mini-pulleys of 1 cm circumference, then you could get in return 100 rotations for every mini-pulley that you choose to attach to the same belt. This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity.
What is AC electricity + how is it made = out of the rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain 1000 = 100X10 cycles of AC electricity. All these cycles of AC electricity are from the single burst of DC electricity, which is only the amount that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you generate power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage, you only need to generate one single spark of current, and P=IV, or power equals current multiplied by voltage. So your total power output would be practically zero multiplied by any amount of voltage that you are winding up, which would still be equal to practically zero.
Mankind was given this best Gift = http://free-energy.yolasite.com/ from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, when this GEM tech will be most needed. This is the worst time for earth, where not only is there constant war, but most all of the fallen angels, and the Nephilum , will be sent to this earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (how can we be billions of years old when the moon will leave orbit within 10,000 years, + all orbiting bodies would have messed up orbits, because of the yearly amount of space debris addition) http://possibletimingfortribulation.yolasite.com/
http://aliensandghosts.yolasite.com/
This is free energy technology, that we all will need and love has no cost to run, + no need for any fuel to be purchased. Nor would there be any toxic exhaust to cause environmental or even noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would only come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity. . Think that this may actually be a good enough reason to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
You are using the dirt simple laws of pulley mechanics to multiply rotations, + since AC electricity is generated by simple rotations Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity + you could easily multiply your AC cycles of electricity by even greater amounts, By simply adding more mini-pulleys with AC generators to the same belt
IT IS TRULLY THAT SIMPLE
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS + how powerful this spiritual warfare must be, to be able to hide this super simple AC multiplier from us gullible humans. We can use pulley mechanics to freely multiply rotations, Thereby we are using pulley mechanics to multiply cycles of AC electricity
I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. Can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,, Think about this, for how long have they been able to hide this simple free AC multiplying technology,,,, - http://possibletimingfortribulation.yolasite.com/
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Everybody has heard that the "day + hour knoweth no man"-(Mat 24:36), but why does nobody mention the soon arriving doors that we are not only allowed to know, but in the original Greek, it is worded like a command = "know that it is near, even at the doors",,, + that 1st Door will close on 2019.04 + the 2nd Door will close on 2025.94. So we are guaranteed that Jesus will set His foot on the Mount of Olives before the year 2026.
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST Door closes on 2019.04 – Jan 14th http://my2020vision.yolasite.com/ - "know,,, even at the doors" http://doorschristmustpassthrough.yolasite.com/.
Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural, because of the two appearances of Jesus, the first is in the clouds,(Rapture) http://rapturequestion.yolasite.com/ before the 7 year peace treaty is signed + then His second arrival is as His Foot touches earth, on the Mount of Olives. DOOR = (this is not the date of His Arrival, which we are warned that nobody can know, but this is the date that Christ must return before) A day that the Tribulation Saints will not only know, but they will probably being counting down the days until. = (He Returns when the 7 year peace treaty ends)
EVil-sOLUTION = isn't it amazing what Truth can be revealed, when the "il-s" of life are included.
http://evotutionfairytale.yolasite.com/
+ http://evolutiondebate.yolasite.com/
+ http://decimationofthisevolutionfairytale.yolasite.com/
PROOF OF CREATION = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all stellar objects, like planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years, as in less than 10,000 year
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST Door closes on 2019.04 – Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/
Free Energy is all done with pulleys, costing only the power to rotate a large pulley once,
you can gain or multiply massive amounts of AC electricity, by running this long length of belt off your large pulley circumference,
past a few mini-pulleys with AC generators, all costing only one spark of DC current
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could get in return 100 rotations for every mini-pulley that you choose to attach to the same belt. This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity.
What is AC electricity, + how is it made = it is made out of the easy rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain you 1000 = 100X10 cycles of AC electricity.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached.
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, when this GEM tech will be most needed. This is the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (how can we be billions of years old when the moon will leave orbit within 10,000 years, + all orbiting bodies will have messed up orbits, because of the yearly amount of space debris addition) http://possibletimingfortribulation.yolasite.com/
This is free energy technology, that we all will need and love = no cost to run, + no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
This is one super simple GEM of an idea, and it is made from pre-school technology, so why was this not out long ago. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. I still have problems getting people to believe that there is no torque problem. Think that this may actually be a good enough reason for you to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one mini-pulley of only one centimeter circumferences, All that you have to do is add an AC generator to this mini-pulley, giving you a free return of 100 cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
PROOF OF CREATION = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all stellar objects, like planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years. Less than 10,000 year
DEAR STEFAN,
IN THE NAME OF ALL THAT IS HOLY, PLEASE NOTE
THAT THIS IDIOT HAS BEEN WARNED. PLEASE NOW
BAN THIS USELESS PRAT.
PAUL
I can give you a free to run, perpetual power supply = http://free-energy.yolasite.com/. This GEM mechanism can do this because of how AC electricity is created by rotations. as in the more rotations the greater amount of AC electricity, and pulleys can be used to multiply rotations. So, you are using pulley mechanics to multiply your total amount of AC electricity, by trading one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference pulleys as you choose to add to the same belt. If you add AC generators to these mini-pulleys then you could be multiplying AC electricity. If you added 4 of these mini-pulleys with AC generators attached, you would gain 400 cycles of AC electricity, and all for the single burst of DC current, the minute amount of current that a DC motor takes to rotate one single time.
These mini-pulleys would be easy to rotate, as the only resistance that they would generate, would be caused by any power that they were generating. These mini-pulleys would only be winding up massive voltages, because the only current needed to rotate your large 100 cm pulley on a DC motor, is one simple spark, or short burst, the amount to rotate your large pulley only one single time. Torque is only caused when you are generating power, and power is generated by current multiplied by voltage. Since we only need one single spark of current, (practically zero) the total amount of power being generated would still be practically zero, costing practically zero torque.
This was given to mankind before the first door closes = http://my2020vision.yolasite.com/
Especially for the soon coming Tribulation Saints http://doorschristmustpassthrough.yolasite.com/
Sorry if it offends you, that I add a little bit of Biblical stuff in my explanations, but when I came up with this super simple idea, it was just after asking God for a way to help the Tribulation Saints. Just think about how super simple this AC electricity multiplier truly is, and how the voices in your head tell you that it cannot work. When how much more simple can it be, then to only pay for the one rotation of a large 100 cm pulley, when you can get a return of 100 cycle of AC electricity, for every 1 cm mini-pulley that you attach to the same belt, (with AC generators attached). Yes that's an input of one single spark of DC current, returning you 100 cycles of AC electricity for every mini-pulley that you attach to the same belt. If you only added 4 mini-pulleys, you would get a return of 40 cycles of AC electricity. Please remember, that there is a most powerful spiritual warfare going on over this GEM technology.
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST Door closes on 2019.04 – Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion are easily established using pulleys, costing only the power to rotate a large pulley once, you can gain or multiply massive amounts of AC electricity, by running this long length of belt, off your large pulley circumference, past a few mini-pulleys with AC generators, gaining you massive amounts of AC electricity, all costing you only one mere spark of DC current
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity.
This is free energy technology, that we all will need and love, has no cost to run, and no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
EVil-sOLUTION = isn't it amazing what Truth can be revealed, when the "il-s" of life are included. http://decimationofthisevolutionfairytale.yolasite.com/
Can you believe the problems that I have had, getting this super simple way of using pulleys to multiply the total amount of AC cycles of electricity? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations, so you are effectively multiplying AC electricity. .
There is a most powerful spiritual warfare going on over this GEM technology. Can you believe the problems that I have had getting this super simple way of using pulleys to multiply the total amount of AC electricity cycles? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations. It should be obvious.
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity. This AC generator takes no torque to rotate, because although it would be winding up massive voltage, it does not need to be winding up practically any current-(1 mere spark) which is practically zero. Torque is only caused when you are generating power, and you are generating practically zero power, as power is equal to voltage times current. So, no matter how massive of voltage you are generating, it is multiplied by practically zero current, as we only need one spark of current, or practically zero. This works because zero times anything is still equal to zero, and practically zero works the same way.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) to keep this GEM mechanism running, you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating you massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached?
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, is when this GEM tech will be needed most. This will be the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (How can we be billions of years old, when the moon will leave orbit within 10,000 years) + all orbiting bodies will have messed up orbits, because of this yearly amount of space debris adding mass.
This is free energy technology, which we all will need and love, as it has practically no cost to run, and there is no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? Evil spirits are, and have been hiding this simple technology from mankind. These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God + not from evil forces, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity.
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one or more mini-pulleys of only one centimeter circumferences, All that you have to do is add an AC generator to these mini-pulleys, giving you a free return of 100's of cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120 volt, + 12 volt, to powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16. http://aliensandghosts.yolasite.com/
PROOF OF CREATION + A YOUNG EARTH = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years. Less than 10,000 year
Everybody has heard that the "day + hour knoweth no man"-(Mat 24:36), but why does nobody mention the soon arriving doors that we are not only allowed to know, but in the original Greek, it is worded like a command = "know that it is near, even at the doors",,, + that 1st Door will close on 2019.04 + the last Door will close on 2025.94. So we are guaranteed that Jesus will set His foot on the Mount of Olives before the year 2026.
I can give you a free to run, perpetual power supply = http://free-energy.yolasite.com/ This GEM mechanism can do this because of how AC electricity is created by rotations. as in the more rotations the greater amount of AC electricity, and pulleys can be used to multiply rotations. So, you are using pulley mechanics to multiply your total amount of AC electricity, by trading one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference pulleys as you choose to add to the same belt. If you add AC generators to these mini-pulleys then you could be multiplying AC electricity. If you added 4 of these mini-pulleys with AC generators attached, you would gain 400 cycles of AC electricity, and all for the single burst of DC current, the minute amount of current that a DC motor takes to rotate one single time.
There is a most powerful spiritual warfare going on over this GEM technology. Can you believe the problems that I have had, getting this super simple way of using pulleys to multiply the total amount of AC cycles of electricity? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations, so you are effectively multiplying AC electricity. .
Obviously you have a lot of free time. Instead of continually posting the same thing over and over why don't you take the time to learn how motors and alternators really work. Then you would see how foolish your idea really is. Your lack of understanding is clearly seen by almost anyone that reads your many many threads.
And you are totally wrong about God inspiring you with this idea. God is not the author of confusion. He does not inspire people to build devices that go against the very principles and physical laws He put into place. I do believe God may have inspired some to build machines that we would call Free Energy machines but your idea is not one of those machines.
Quote from: TinselKoala on May 25, 2017, 02:53:04 PM
Joe, I realize this is hard for you, but have you thought about what you will do
if God does NOT come back before 2019.04? What if everything is just the same,
only more so, in two years?
I will praise the Lord for the increase in time
Many people have forecast God's return and they have always been wrong before.
but they were trying set a date for His Arrival,
+ I want to show you the door/deadline, which we are allowed to know,
remember that we are allowed to "know when it is near, even at the doors"
what I want to point out is how near the doors are to closing
They have given away property and money, shunned their families and even worse,
only to be left standing out in the rain on some mountaintop while God laughs at
them from on high. And the world goes on, in all its evil ways.
I think you should be prepared, in case your prediction is wrong, so that you aren't surprised.
I will be pleased that we have more time, to help others gain a relationship with our Lord
+ try to figure out which length of time to use, if not 51.6 solar years,
which is taken from the 14, 14 + 14 generations of the linage of Jesus
I don't repost the same thing, but I change the wording a little, trying to see if people can understand it better. . . + usually it is because I cannot edit my last post any more. Sorry about this one, I noticed to late, that I could still edit my old post.
how simple can this be, you are trading the power to rotate one large 100 cm pulley,
for 100 rotations of a mini-pulley of only 1 cm
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a DC motor with a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM-(Geometrical Electricity Multiplier) device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. (As for torque, it only comes from generating power, and power is voltage multiplied by current) + We only need to produce one single spark of DC current to make this a self-powering mechanism. So one spark of DC current, (which is practically nothing) multiplied by even massive voltage, would still equal practically zero power, which takes practically zero torque to rotate.
Quote from: citfta on August 25, 2017, 01:00:18 PMYour lack of understanding is clearly seen by almost anyone that reads your many many threads.
... almost anyone...?
Who agrees with him?
Quote from: Paul-R on August 26, 2017, 10:16:52 AM
In one of his many many spam posting threads on this forum he did have one person who tried to build his device. So I have to give a little doubt that everyone can see how foolish his idea is.
I see he has now gone back to the tactic of posting all over this forum again even though he has been asked several times to restrict his posting to one thread. I feel it is way past time for him to be banned. He has already been banned from the Energetic Forum for his continual posting with nothing to back up his claims.
I want to be the first person to step up
I am NOT going to build this piece of crap !
Quote from: citfta on August 26, 2017, 03:27:24 PM
Oh, Yes. You are quite right. Skywatcher, I think.
I recall reckoning that his strategy was to build one and show that it didn't work in order to close that_prophet down. But it would not have worked. He wouldn't have believed it and would have put Skywatcher down as an instrument of Satan, or somesuch.
Stefan should ban him or charge him £1 per word.
What lack of understanding,,,
I believe that it is you guys that have the lack of understanding,
Mostly because of you're listening to the voices in your heads,
These voices are from evil spirits, that are trying to hide this simple technology from mankind,
+ they seem to be doing their jobs well, as you are listening to them,
Instead of paying attention to my reasoning, and listening to my logical explanations.
My proposal is to use the minuscule amount of DC current, (one mere spark of current),
To rotate a large 100 cm circumference pulley one single time,
Then to use the 100 cm of moving belt off of the 100 cm circumference pulley,
To run past 1 to 10 of the 1 cm circumference mini-pulleys, with AC generators attached,
Gaining you 100-1000 cycled of AC electricity, + all from the one single burst of DC current,
This can be done, because these mini-pulleys are easy to rotate,
As they do not have to generate practically any amount of power,
They are just winding up massive voltages, which takes very little power,
This is because the only amount of current that you need to generate is one mere spark,
Because the only current that you need to generate is just enough to rotate a DC motor once.
Please explain to me exactly why this will not work,,,,,,,,,,,,,,,,,,,
Each side of this mechanism produces more than enough of what the other side needs.
The massive amounts of rotations of the mini-pulleys produce massive voltage,
Which is needed to rotate your DC motor with one large pulley
+ the one rotation of the large pulley, generates a long length of strap,
Which is what your mini-pulleys need to produce many rotations, giving you massive voltage
Open source was what I was trying to do, before Obama changed the patent laws, so that anybody can patent it. Before, once I published it http://free-energy.yolasite.com/, which I did in the early 2000's, only I could patent it, + I was never going to patent it,,, leaving it open source.
Quote from: that_prophet on August 27, 2017, 01:42:53 PM
There is simple tool called screwdriver if you find out how to use it you will find the answer yourself.
Here is why, in case you do not know it;
"HORSEPOWER is the only "POWER" that is capable of driving a conventional alternator/generator on this planet."
What you loosely propose is not capable of providing and does not provide the single thing that is REQUIRED.
If you care to: you can read more about that sentence here: http://www.backgauges.com/Gen-E-Sys%20II/power.html
Sparks just will not cut it to keep a POWERPLANT generating POWER.
Yes the screwdriver comment/remark by Pulp is a good clue as to what you missed.
Hi all, Hi paul-r, that is not correct, i was attempting to put something together, though things transpired around me of a negative nature and i could not go further.
Does this mean that something is resisting attempts to build some kind of replication, i don't know, we should really ask ourselves that question.
that prophet should be allowed to continue posting, though yes, if it is the same topic of discussion, there is no need for multiple threads.
Also, to share my thoughts, unless one has tried to build his device with a genuine effort, then i cannot see how one can conclude anything.
peace love light 8)
hi i concur with skywatchers, here is evidence that energy can be extracted from gravity, inertia.
https://www.youtube.com/watch?v=4qXnR_d6yPw
Thank you SkyWatcher
Yes, I believe that any who try to build this GEM technology, will find themselves under great persecution from evil spirits. But this technology does work, and I was hoping to explain well enough to prove, with no good results. I don't understand why people do not see the Truth in this free energy system. You only need to produce a very small amount of current, (1 spark) only enough to rotate your DC motor, with a 100 cm circumference pulley attached, only one single time. That will give you 100 cm of moving belt, which you can run past one pulley of 1 cm circumference, with an AC generator attached, returning you 100 cycles of AC electricity. Now, try and tell me that you cannot get one single spark of DC current, out of these 100 cycles of AC electricity, to power your large DC motor + a 100 cm pulley one single time. PLEASE,,, explain to me what part of this free energy mechanism will not work.
Quote from: SkyWatcher123 on August 27, 2017, 10:30:09 PM
peace love light 8)
When it comes to electronics, it is not me that has a lack of understanding,,,
I built + wired a 32' by 16' by 2 story addition to my mom's house in grade 12 # 2, (failed English)
+ I rebuilt + rewired everything past the firewall on a Datsun B210 in my Christmas break at UNB
+ I designed + built a wiring harness to connect on/off switches + batteries for my Halloween costume
Which connected over 200 LEDs, a light chaser, helmet fan, switches, batteries + voice amplifier on it
+ I made 80's in 2.5 years of electrical engineering at UNB, New Brunswick, Canada
So I believe that it is you guys + gals that have the lack of understanding,
Mostly because of you're listening to the ever present voices in your heads,
These voices are from evil spirits, that are trying to + have been hiding this simple technology from mankind,
+ they seem to be doing their jobs extremely well, as everyone seems to be listening to them,
To rotate a DC motor + large 100 cm circumference pulley one single time,
Notice that these AC generate would rote extremely easily, as they are just winding up massive voltages,
As great amounts of torque, is only needed when you generate power, + P=IV OR,
"P"ower = "I"-current multiplied by "V"oltage, + we only need a small amount of I"-current + "P"ower,
Then you put this AC electricity through a full wave bridge rectifier,
This will give you massive voltage + the mere one single spark of current to rotate your DC motor once.
You only need the one spark of DC current, because the single rotation of your 100 cm pulley,
Gives you the 100 cm of moving belt that you need to run past your 1 cm circumference pulley,
With the AC generator attached, giving you 100 rotations, or 100 cycles of AC electricity.
This mini-pulley + AC generator is the easiest to rotate, because it is only winding up massive voltage,
Needing practically no current, as it only has to generate one single spark of current,
The one spark, is just enough current to rotate your DC motor + 100 cm pulley one single time,
This small amount of DC current/electricity, would be just enough to give you 100 cm of moving belt,
Which is easily run past one single 1 cm circumference pulley, with an AC generator attached,
+ guess what this half of the GEM mechanism could be giving you, yes 100 cycles of AC electricity.
Torque only comes from when you are generating more power, and because power is equal to current multiplied by voltage, and although you are winding up massive amounts of voltage, you only need one single spark of current. (which is practically zero). So, even massive voltage times practically zero current, times practically zero current, is still equal to practically zero power, costing practically zero torque to generate.
Which is needed to rotate your DC motor with one large pulley one single revolution
+ the one rotation of the large pulley, generates a 100 cm long length of strap,
Which is what your mini-pulleys need to produce many rotations, giving you massive voltage.
+ this massive voltage is just what you need to crank over your DC motor once,
Giving you the 100 cm of moving belt, to pass by your 1 cm mini-pulley, giving you 100 rotations
Open source was what I was trying to do, before Obama changed the patent laws, so that anybody can patent it. Before he did this, once I published it http://free-energy.yolasite.com/, which I did in the early 2000's, only I could patent it, + I was never going to patent it,,, leaving it open source.
Temporal Visitor
Quote from: Temporal Visitor on August 27, 2017, 03:44:11 PM
Yes, but the only amount of horsepower that is needed to drive this GEM mechanism is practically none
As you only need to generate one extremely small amount of current, just enough to rotate your DC motor once.
That is because that is all that this GEM mechanism needs to rotate your DC motor once,
As this one rotation of your DC motor, with the 100 cm circumference pulley attached,
Would give you 100 cm of moving belt, which is used to gain you 100 rotations of a 1 cm circumference pulley,
That has am AC generator attached, giving you 100 cycles of AC electricity,
+ then you add another spark=(short burst) of current, and start this system all over again
Do you even read my text,,, please give me specifics on what you don't believe works + why it doesn't,
I have not seen one thing that goes against my GEM technology workings
I got 80's in my 2.5 years of electrical engineering at UNB college, so I know a little about what I speak of
I took 2.5 years of Electrical Engineering, so I have already read plenty of info on this subject + what I see as your biggest problem with my GEM technology is torque, which I see that there is very little of, and you seem to think is a major problem.
I say spark because that is what I call the minuscule amount of DC current/electricity that the DC motor takes to rotate one single time. That is because this single rotation of the DC motor, with a 100 cm circumference pulley attached, is all that is needed in your one half of this GEM free energy producing mechanism. This gives you 100 cm of moving belt, to pass by your 1 cm mini-pulley, which gives you 100 cycles of AC electricity
Sorry, but I do not care to know, just what his dig was supposed to be all about.
I think that it is awful hard to get others to listen to someones reasoning + logic,
(which is being craftily hidden by evil spirits), when you bring any insults into this conversation
In this two pulley mechanism, you have one large 100 cm circumference pulley and one small 1 cm circumference mini-pulley. This mini-pulley + AC generator runs freely, as it is just winding up massive voltage, and does not need to generate practically any current at all, (only one spark). Torque comes from generating power, and if you only have to generate one small burst of current, (practically zero) you would be producing practically zero power, which takes practically zero torque. Your drive motor only takes the one spark, or short burst of current, as this is all that we need to crank over the DC motor one single time, and rotating this large 100 cm circumference pulley.
This gives you 100 cm of moving belt, that you can run past a single 1 cm circumference mini-pulley, with an AC generator attached, gaining you a return of 100 cycles of AC electricity. This mini-pulley is extremely easy to rotate, even with the AC generator attached, because with all of these 100 cycles AC electricity, you only need to produce the one single mini-burst of current. This is because one short burst of current is all that it takes to rotate a DC motor one single time. This AC generator takes practically no torque to rotate, because torque is only caused when producing power, and you only have to produce a single burst of current. This is because no matter how great of a voltage you generate, it is still multiplied by practically zero current, which would equal practically zero power, costing practically zero torque.
By the way, my system only shows you one rotation of the DC drive motor, so that is why I do not deal with rpm stuff. Although the other end of the belt drives the mini-pulley 100 revolutions, I only deal with the single revolution of the DC drive motor. This one rotation of the drive motor, through pulley mechanics, giving you 100 rotations of a 1 cm circumference mini-pulley, and if you attach an AC generator to it, this will give you 100 cycles of AC electricity. This works because each side of the system produces more than enough of what the other side needs. The massive rotations of your AC generator would produce massive voltage, which is just what you need to crank over your large 100 cm pulley + DC motor the one single revolution. The DC motor has a large 100 cm pulley to drive your 1 cm mini-pulley 100 revolutions, giving you 100 cycles of AC electricity. This would give you plenty of voltage-(electrical pressure) to crank over your DC motor the one single time.
Can you believe the power that these evil spirits have, keeping this super simple free energy technology, where you are using pulleys to multiply AC electricity. This is so simple that it's totally ridiculous that we have not discovered this a long time ago, like as soon as we discovered how to generate AC electricity. I hope this makes you angry at the deception, and maybe even gets you to build this super simple AC electricity multiplier. First, please let me give you a strong warning, because as soon as you start trying to reproduce this GEM free energy technology, you will run into many bad things, which will not let you finish building it.
Everyone will try to convince you that it is a stupid idea, maybe even threatening your friendships, if you continue with building it. There will be so many bad things happening to you, which you will surely choose to stop your work on this super simple technology. If you do not stop trying to build this GEM=(Geometrical Electricity Multiplier), then I cannot tell you what these evil spirits will do. Think about how super simple this method of using pulleys to multiply AC electricity truly is, and realize that there may have been many who have died try to get this GEM technology out.
Would you like to be told, just how super simple this free energy mechanism is, and the easy to build this simple technology of using pulleys to multiply AC electricity. You only need 2 pulleys, one large one + one small one, one DC motor + one AC generator of the same voltage, a full-wave bridge rectifier, the wires to connect these units together, and the hardware to put this mechanism together. These pulleys are attached together via a belt, strap, elastic or even a tied length of string or rope. Remember that this GEM tech needs to be easy + cheap to build, as it will have to be built by Tribulation Saints, people that cannot buy or sell. This lack of doing commerce is because they choose not to take the mark.
They are extremely wise in not taking the mark, which includes some sort of worshiping the anti-christ, because taking the mark will mean that they are assured of spending eternity in the lake of fire, a place that it is even worse than hell. Although they will eventually be forced to take this mark, because not taking the mark, will eventually mean that you will be beheaded. By the way, does this type of execution sound like any religion that you know of? Now, I dare you to try and build this super simple, and super cheap to build, free energy, electricity multiplying GEM technology, and please be careful, as these evil spirits will soon be turning your life upside down.
The large 100 cm circumference pulley, which is connected to a DC motor, and only has to rotate the
one single time, costing only one spark of current, an extremely small amount of, (practically zero)
electricity to rotate. This single rotation would give you 100 cm of moving belt, which you could easily
run past 1 to 10 mini-pulleys of 1 cm circumference with AC generators attached, giving you a return
of 100-1000 cycles of AC electricity.
These mini-pulleys rotate extremely easily, as even though these AC generators are winding up massive
voltage,(which is exactly the voltage pressure that you need to crank over your large pulley the one single
time) they only need to generate the one mere spark of current. Generating power is what cost you
torque to rotate, and since you only need one spark to rotate your DC motor for one revolution, which
is practically zero current, you are generating practically zero power, taking practically zero torque.
Free Energy is so simple that it can be generate with a large pulley attached to a DC motor, at least one mini-pulley connected to an AC generator of the same voltage, 4 diodes, some wire to connect your electrical components together, and a belt to connect the two pulleys together.
The way this works, is that you are using the 100 cm of moving belt off of one rotation of your large 100 cm circumference, which does not cost 100 times more power to rotate, yet if you run this 100 cm of moving belt past a 1 cm circumference pulley, you would get 100 cycles of AC electricity.
HERE IS A REPLY WITH A LESS RELIGIOUS TONE NTO IT
I would like to share this GEM-(Geometrical Electricity Multiplier) technology with you + the world.
This is a totally free to operate, AC electricity multiplier mechanism. https://free-energy.yolasite.com/
((( NEWS of this ancient technology will change our world ))) Ezek 1:16 from UFO motor description
Free Energy from a GEM perpetual power supply is so simple to build, that it can be generate with a large 100 cm circumference pulley attached to a DC motor, + at least one mini-pulley of 1 cm circumference, connected to an AC generator of the same voltage, 4 diodes - to build a full wave bridge rectifier, some wire to connect your electrical components together, and a belt to connect the two or more pulleys together.
This uses the simplicity of how it does not cost 100 times more power to rotate a 100 cm circumference pulley than it does to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of belt/strap that comes off your single rotation of a 100 cm circumference pulley, past at least one 1 cm circumference pulley that is connected to an AC generator, you can get a return of 100 cycles of AC electricity. This could be done for every 1 cm pulley that you choose to connect to the same belt.
Yes, that's an easy way to gain a multiple of 100 cycles of AC electricity, for each of the 1 cm pulleys connected. The best part is, this can be done from the one single rotation of your DC drive motor, which costs a mere spark of DC current. This "spark" is the small burst of current that it takes to rotate your DC motor one single time. Remember, this DC motor is connected to a 100 cm circumference pulley, giving you 100 cm of moving belt/strap..
Please don't listen to the lies about torque being a problem, as these mini-pulleys run extremely free of torque, as large torque is only caused when you generate massive power. Power is generated by multiplying voltage by current, and though you are generating massive amounts of voltage with your 100 rotations of your AC generator, you only need to generate one small spark of DC current to rotate your DC motor one single time. So, since power is generated by multiplying voltage times current, this would mean that although you are generating massive voltage, it is multiplied by practically zero current, only a spark, which means that you would be generating practically zero power. This would mean that because you do not need to generate practically any power, meaning that you are using practically zero torque. With this single rotation of your DC drive motor, attached to a large 100 cm circumference pulley, giving you 100 cm of moving belt, to rotate your mini-pulleys 100 times each, gaining you massive voltage, and making this mechanism a self powering unit.
The best part about this is, you can get a return of 100 cycles of AC electricity for as many mini-pulleys that choose to attach to the same belt. So if you added 10 mini-pulleys, you could gain a multiple of 1000 cycles of free AC electricity. These mini-pulleys + AC generators would truly run extremely freely, because although you are winding up massive voltage with them, (exactly what you need to crank over your large 100 cm pulley) you only need to generate the one spark of DC current, to rotate your DC drive motor. Torque is caused when generating power, and power is calculated by multiplying voltage times current, so even though you are winding up massive voltage, it is multiplied by practically zero current, so in the end you are generating practically zero power, costing practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by adding an AC generator to your mini-pulley, you are actually freely multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor + large 100 cm pulley the one single time.
Each side of this GEM mechanism gives exactly what the other side needs. The massive voltage that the many rotations of the mini-pulley generates is electrical pressure to rotate the large pulley once, + the one rotation of your large pulley, gives you 100 cm of moving belt that you need to generate 100 revolutions of your 1 cm circumference pulley connected to an AC generator. You will also need a full wave bridge rectifier, (made of 4 diodes) to change your AC output back into DC to power your DC drive motor.
This GEM free electricity generator works on freely multiplying rotations by using the 100 cm of moving belt off of one rotation of your large 100 cm circumference pulley, and running it past at least one 1 cm circumference mini-pulley. Then by simply attaching AC generators to each mini-pulley, you can be freely multiplying 100 cycles of AC electricity, and all for the cost of one spark of DC current. Yes, with this GEM mechanism you can freely multiply any amount of AC electricity, for as long as you would like to continue to let it run.
You will need massive amounts of voltage to crank over your large 100 cm circumference pulley the one single time, yet it costs only one mini-spark of current, because of only having to rotate your large pulley once. This single rotation will give you 100 cm of moving belt, which you can easily pass by any # of 1 cm circumference pulleys with AC generators attached. These mini-pulleys would generate you 100 cycles of AC electricity for each + every mini-pulley that you choose to add, so if you added 10, you would be generating 10X100=1000 cycles of AC electricity. Now, let me point out that you are only putting one spark of DC current into this GEM free energy mechanism, while you are freely gaining 1000 cycles of AC electricity as an output.
This GEM mechanism will rotate these AC generators, freely winding up massive voltage, which is exactly what you need, to gain the electrical pressure to crank over your large 100 cm pulley. These mini-pulleys run extremely easily as although they are freely winding up massive voltage, you only need an extremely small amounts of current, (1 burst to crank over your DC motor once). Because power is equal to voltage times current, and since the current is only equal to one mere spark, or practically zero, and zero times anything is equal to zero, you are not generating much power at all.
This is dirt simple + deals with pure logic,,, you are only paying one spark of DC current, for one rotation of a large 100 cm circumference pulley, and getting back 100 cycles of AC electricity for every 1 cm circumference pulley that you attach with an AC generator, to the same belt or strap that you have going around you large 100 cm pulley. So if you attached 10 mini-pulleys of 1 cm circumference, you would get a return of 10X100=1000 cycles of AC electricity. It is truly that simple, as you can get 100 cycles of AC electricity, for every mini-pulley of 1 cm circumference that you choose to add + all costing you only one mere spark of DC current, (your drive motor is DC, with a 100 cm circumference pulley attached)
There is no torque problem, as the total output that you need to drive your drive motor,(making this a self powering system) is only one mere spark of DC current. These many rotations of your mini-pulleys are just winding up massive voltage, which is exactly what you need to crank over your large 100 cm drive pulley. One thing that you will need to add to this GEM mechanism, is a full wave bridge rectifier, (4 diodes) to convert your AC output back into a DC input for your DC drive motor
+ yes I did get someone to actually build 3 different versions of this, and he said they were dirt simple to build + they all worked great. But he was afraid of the rumors about people that had invented free energy machines being killed soon after, so I not only did not mention his name, but I threw out the stuff he sent me. I did this because I thought that this GEM system was so simple to follow + build, that many others would build it. I did not realize that trying to build this super simple 2 pulley mechanism would bring down the hoards of evil spirits on others, like it did me,,, you will start loosing friends and family, as they first ridicule you, and then turn against you. You will even find difficulties in buying the few parts to build it. (Satan + his demons try to be every wheres )
By the way, I was hoping that you might be interested in how I discovered this new/old free energy technology, so I will tell you where it came from, in this last few paragraphs. The idea on how this super simple preschool pulley technology was, came to me in a Vision, right after I prayed to my Father, and asked Him for a way to help the Tribulation Saints be able to survive the soon coming Great Tribulation. If you do not believe in God or evil spirits, then please explain how this super simple GEM pulley technology was missed for so long.
Evil spirits want us spend a lot of money on fuels to run our lives, and not just to make it harder on us to live, but because the countries that produce most of our oil, have terrorist in them, which one way or another, receive money from this oil revenue. Terrorism is surely a life stile that evil spirits are a follower of, and a method of Satan's choosing.
That's not to mention the pollution that free energy would prevent us from putting into the atmosphere and environment. GEM Free Energy could also easily + at no cost, be reversing our pollution problems, by using electricity to take the carbon + other bad chemicals out of the air that we survive on.
TIME IS SHORT=the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START
before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ + although it warns us that no one can know the day nor hour, we are allowed to know the dates of these doors, as it says in (Mat 24:33) "know that it is near, even at the doors", http://doorschristmustpassthrough.yolasite.com/.
WARNING,,, IF YOU TRY + BUILD THIS GEM MECHANISM, YOU MAY FEEL THE FULL WRATH OF SATAN + 1/3 OF THE ANGELS THAT FOLLOWED HIS EVIL WAYS = because they do not want us humans to have this free energy mechanism, and not spend massive money on oil, which in one way or another gets into the hands of terrorists.
Sorry, but although this idea came to me about 2000-2001, I have not managed to get anything built for it. At the end of my writing I tried to explain the main reasoning for not showing any progress in building a working model of the idea=(spiritual warfare). Not only did everything start falling apart in my life, but it was more than , as friends + family started turning against me. I put this warning at the end of my writing to try explaining the troubles that people will find themselves in, if they were thinking of trying to build this super simple GEM technology, (only an AC + DC motor, a large + a small pulley, 4 diodes, some wire + a belt) they would be fighting against an unknown amount trouble from fallen angels + demons. (evil wants us to keep supporting terrorists by paying for oil)
One other valid excuse that I have for not having a working model for this GEM technology is, that I happen to be a paralyzed man with shaky hands that has no money as I happen to be on Canada Pension. There is also the major hindrance of living in a nursing home, where I cannot have my own set of nail clippers, let alone being able to keep wire cutters + a soldering iron in my room. So, even if I could manage to do the delicate work with my shaky hands, I would not be allowed to have the tools in my room
The closest that I got to a working model of this GEM was my old late 80's P-200 Quickie electric wheelchair. I got them to make my settings the closest to max torq + max speed, and by simply driving uphill fast + going back downhill slow, I could keep recharging my chair, so that I would never have to plug it in to recharge. Even that was not enough proof though, as they soon started telling me that I could not do this for ever, because all that I was doing is wearing out the battery's ability to charge, so eventually I would ruin my batteries. You could have a perpetually running AC generator + DC motor
in union, if you had any electric wheelchair with the settings set to the max + a small hill nearby.
FREE ENERGY FROM 1 ROTATION OF DC MOTOR + 100 cm circumference PULLEY = GIVES YOU 100 ROTATIONS OF AC GENERATOR ON A 1 cm circumference PULLEY ------ TESLA RULES ----- (+ don't listen to the torque lie, as there is no torque problem, because even though you are generating massive voltage-[which is exactly what you need to crank over your large pulley] you only need to generate one mere spark of current, (the amount of current that it takes to crank over the motor one single time) + power is calculated by voltage time current, so even massive voltage multiplied by practically zero current, still equals practically zero power, costing practically zero torque)
Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier)=AC type - free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one large pulley attached to a DC motor, + at least one mini-pulley, (the smaller the better) connected to AC generators, both motors must be of the same voltage, 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor's needs), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together. This has to be dirt simple + cheap to build, as the people that will need to be built this are the soon coming Tribulation Saints, whom cannot buy or sell. The Door closes on the peace treaty signing on 2019.04 - http://my2020vision.yolasite.com/
This works on the simplest of principles, the principles of basic preschool pulley mechanics, where you only have to pay the small amount of electricity,(only a spark) that it takes to gain one single rotation of a DC motor, with a large 100 cm circumference pulley attached to it. With this one rotation of a large pulley, you can freely gain a long length of 100 cm of moving belt, which will give you a multiple of 100 rotations, for your one rotation of a DC motor. This could be multiplied by as many 1 cm circumference mini-pulleys that you wish to attach to this same belt. Then all that you would have to do is, attach AC generators to each of these mini-pulleys that you choose to attach to the same belt as your large 100 cm pulley.
You could freely gain 1000 cycles of AC electricity from this single burst of DC current, if you chose to attach 10 mini-pulleys to the same belt/strap, with AC generators attached to each one. Please don't listen to these fake worries about torque being a problem, as these mini-pulleys would run free of any torque, as torque comes from when you need to generate power. Power is calculated by multiplying voltage time current, and although your many rotations of these mini-pulleys are generating massive voltage, (which is exactly what you need to crank over your DC drive motor), you are in need of only one mere spark of current. So, even massive amounts of voltage, when it is multiplied by the almost zero amount of current that it takes to rotate a DC motor once, it would equal out to practically zero power, cost practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by adding an AC generator to your mini-pulley, you are actually multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage + practically no current, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor once. This one rotation of a large 100 cm pulley, can be converted into 100 rotations of a mini-pulley of 1 cm circumference. Since AC electricity is created by rotations, and more rotations is more AC power, multiplied rotation is equal to multiplied AC electricity.
The simple way that this works is that you are only putting in the small amount of DC electricity to rotate a DC motor one single time, (one spark, or short burst of current) with a large 100 cm circumference pulley attached. Then with the 100 centimetres of moving belt that you get off the 100 cm circumference pulley, and you run it past a 1 cm circumference mini-pulley to rotate 100 times. Then by adding an AC generator to this mini-pulley, you can gain 100 cycles of AC electricity. It is truly that simple, as you only pay for one rotation of a DC motor attached to a large pulley, and you get a return of 100 cycles of AC electricity from a mini-pulley.
The mini-pulley runs free of most all torque, as even though it is winding up massive voltage, it only needs to generate one single spark of current. Torque is only generated when you are generating power, and even though you are generating massive voltage, it is multiplied by practically zero current, (only a spark), equalling practically zero power, which takes practically zero torque to generate. The 100 cycles of AC electricity should easily be able to produce the one spark of DC current that the drive motor needs, making this a self powering mechanism.
Each side of this mechanism gives you more than enough of what the other side of this mechanism needs. The massive rotations of the AC generator gives you plenty of voltage to crank over your drive motor the one single time. Then the 100 cm of moving belt that you get off your one rotation of your 100 cm circumference pulley attached to your drive motor, easily winds over your 1 cm pulley attached to an AC generator 100 times, giving you 100 cycles of AC electricity.
Just keep on repeating yourself Mr. Prophet. The concept will not work, but we do have a good perpetual laugh as long you perpetually keep on repeating yourself ;D
I bet my manhood that you will repeat your idea :o
Cheers
one guy built 3 different versions, but he will not go public
Sorry, but i do not know how to make this any simpler, than you are only paying for the one rotation of a large 100 cm circumference pulley, and then through simple pulley mechanics, you are getting a return of 100 cycles of electricity. There is no torque problem, as you only need to generate the one single spark of DC current, which is practically nothing, and even massive voltage times practically zero current, is still equal to practically zero power, costing practically zero torque.
This is dirt simple to build, and very inexpensive in parts, but you will all listen to the evil spirits whispering in your ear that it's ridiculous, and never take the small amount of effort + time to build it. Now, if you do actually decide to try this, watch out for the hard times that will come upon you, as evil spirits will fight you the whole way.
Satan + his evil followers have been messing with your mind, to keep you from seeing the simplicity of this. You are only paying for one rotation of a large 100 cm pulley, and then through simple pulley mechanics, you are gaining a return of 100 rotations of a 1 cm mini-pulley. Then if you add an AC generator, you get 100 cycles of AC electricity. All for one burst of DC current.
HOW TO BUILD A GEM
Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier=AC type) free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one large pulley attached to a DC motor, + at least one mini-pulley, (the smaller the better) connected to AC generators, both must be of the same voltage, 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor's needs), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together. This has to be dirt simple + cheap to build, as the people that will need to be built this are the soon coming Tribulation Saints, whom cannot buy or sell. Door closes on treaty signing = 2019.04 - http://my2020vision.yolasite.com/ "know that it's near, even at the door " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
yes, but how much horsepower does it take to rotate a free floating AC generating
These are my thoughts = the mini-pulley will turn freely,(as these 100 rotations only need to generate one pulse of DC current) + only building up massive voltage, which is just what you need to crank over your DC motor one single time. There is no torque involved in rotating this mini-pulley, as there is no power being generated. You are only generating massive voltage, as you only need to generate one spark=(small burst) of current + power is generated by voltage multiplied by current=(one small burst)
I say that you only need to generate one spark of current, as that is all that the DC motor needs to rotate one single time, which rotates a 100 cm circumference pulley, giving you 100 cm of moving belt. This 100 cm of moving belt rotates a 1 cm circumference pulley 100 times. Yes, I know that these DC motors can take more than one pulse of current, but the point still is, that it takes an extremely small amount of current. (3 sparks for a 3 phase motor)
I cannot get the simple parts together to try this out for myself,,, (evil influence) please build this super simple free AC electricity multiplier, as evil forces keep hindering my attempts,,, this seems simple enough in logic = your mini-pulleys turn freely, as you are only winding up massive voltage, which is exactly what you need, to crank over your large pulley once, on a DC motor. There is no torque problem, as you only need to generate one small burst of current, (only a spark to rotate the motor one single time)
PLEASE,,, SOMEONE BUILD THIS SUPER SIMPLE AC ELECTRICITY MULTIPLIER + NOT ONLY HELP THE TRIBULATION SAINTS, BUT OUR WHOLE WORLD = NO MORE OIL MONEY GOING TO TERRORISTS
(here is my latest version of my description of how this GEM works) = sorry for having to repeat this, but I can no longer modify my earlier posts
FREE AC ELECTRICITY FROM 1 ROTATION OF A DC MOTOR, with a large 100 cm circumference pulley attached = gives you 100 rotations of an AC generator attached to a 1 cm circumference mini-pulley <----- TESLA RULES -----> (+ don't listen to the evil torque lie, because there is no torque problem) This is because even though your many rotations are generating massive voltage-(which is exactly what you need=[electrical pressure] to crank over your large pulley the once) you only need to generate one small spark of current, (the amount of current that it takes to crank over the DC drive motor one single time) + power is calculated by multiplying voltage time current. So even massive voltage multiplied by practically zero current, is still equal to practically zero power, costing you practically zero torque =(easy to rotate). [one rotation of DC drive motor is converted into 100 rotations of AC generator]
Multiplying Free AC Electricity is super simple with this GEM-(Geometrical Electricity Multiplier)= AC type of free electricity multiplying mechanism at http://free-energy.yolasite.com/ This is a device that can be easily + cheaply be assembled by using one large pulley attached to a DC-(Direct Current) drive motor, and then you add to same belt at least one mini-pulley, (the smaller the better) connected to an AC generator, and both motors must be of the same voltage. You will also need 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into the DC input for your DC drive motor), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string,(easily fixed with no money by Tribulation Saints) to connect the two or more pulleys together.
This works on the simplest of principles, the principles of basic preschool pulley mechanics, where you only have to pay the small amount of electricity,(only a spark) that it takes to gain one single rotation of a DC motor, with a large 100 cm circumference pulley attached to it. With this one rotation of a large pulley, you can gain a long length of 100 cm of moving belt, which will give you a multiple of 100 rotations of a 1 cm circumference pulley, all from your one rotation of a DC motor. This could be multiplied by as many 1 cm circumference mini-pulleys that you wish to attach to this same belt. Then all that you would have to do is, attach AC generators to each of these mini-pulleys that you choose to attach to the same belt as your large 100 cm pulley, giving you 100 cycles of AC electricity for each mini-pulley that you choose to attach.
You could freely gain 1000 cycles of AC electricity from this single burst of DC current, if you chose to attach 10 mini-pulleys to the same belt/strap, with AC generators attached to each one. Please don't listen to these false worries about torque being a problem, as these mini-pulleys would run free of most any torque, as torque only comes from when you need to generate power. Power is calculated by multiplying voltage time current, and although your many rotations of these mini-pulleys are generating massive voltage, (which is exactly what you need to crank over your DC drive motor), you are in need of only one mere spark of DC current. So, even massive amounts of voltage, when it is multiplied by the almost zero amount of current that it takes to rotate a DC motor once, it would equal out to practically zero power, cost practically zero torque.
You are seemingly cheating the laws of thermodynamics by using pulley mechanics to freely multiply the # of rotations, and then by simply adding an AC generator to your mini-pulley, you are actually multiplying AC cycles of electricity. The AC generator is running very free, as it is only winding up massive voltage + practically no current, as it only needs to generate one mere spark of DC current, just enough to rotate your DC drive motor the one time. This one rotation of a large 100 cm pulley, can be easily and freely converted into 100 rotations of a mini-pulley of 1 cm circumference. Since AC electricity is created by rotations, multiplied rotation is equal to multiplied AC electricity.
Pulley's have different circumferences, so one rotation of a 100 cm circumference pulley can easily produce 100 cycles of an AC electricity from a generator attached to a 1 cm circumference pulley. This gets even better if you add additional AC generators attached to more 1 cm circumference pulleys, gaining you another multiplication factor. If you added 10 X 1 cm circumference pulleys, you could gain a total of 1000 = 100 X 10 cycles of AC electricity, all multiplied by using pulleys from 1 short burst of DC current =(1 spark)= just enough to crank a DC motor over once. Guess what you need as electronic pressure = high voltage = just what your AC generators are winding up.
So, each side of this dual AC + DC power supply perpetually generates more than enough of what the other side needs. The one pulse of DC current lets you crank over your large 100 cm circumference pulley the one time, gaining you 100 cm of moving belt. + This 100 cm of moving belt lets you generate 100 cycles of AC electricity, by simple running it past a 1 cm circumference pulley with an AC generator attached. These 100 cycles of AC electricity create more than enough current=(a single spark) + massive voltage = (electrical pressure) which is just what you need to crank over your DC motor + large pulley the single time.
. This super simple free energy https://free-energy.yolasite.com/ =(AC electricity multiplying technology) of using varying sized pulleys, (pulley mechanics) to freely multiply your total # of rotations. The crazy part about this, is that since AC electricity is created using rotations, then you are actually easily + freely multiplying your total amount of AC electricity cycles. This is done by only paying the single burst of DC current, to crank over a 100 cm circumference pulley once. Then by using pulley mechanics, and running 100 cm of moving belt past a 1 cm circumference pulley, returning you 100 rotations, which by adding an AC generator, this could give you a return of 100 cycles of AC electricity. (rotates easily, because you only need to generate one short burst of current = practically zero) Torque is caused when you generate power, + power=voltage multiplied by current, and since current is practically zero, then power + torque are both practically zero.
. With this AC electricity multiplying mechanism you would be able to gain 100 units of AC electricity, all from the small spark of DC current that it takes to rotate a DC motor one single time. Please don't listen to this fictitious lie about torque being a problem, as there is no torque problem with this mechanism. With these many rotations of your AC generator you are just winding up massive voltage, (which is just what you need to crank over your large pulley the once), as you only need to generate one small burst of current, (or practically zero). Power is voltage multiplied by current, and even massive voltage multiplied by practically zero current, still equals practically zero power, which takes practically zero torque.
- Your 100 cm large pulley only has to rotate once, which causes your 1 cm mini-pulley to easily spins 100 times = building up massive voltage, which is exactly what your large pulley needs to crank over the one single time. Each side of this mechanism, through pulley mechanics, gives you more than enough of what the other side needs. The long length of belt that comes off of the large 100 cm circumference pulley gives you 100 rotations of your 1 cm circumference mini-pulley. Then your 100 cycles of AC electricity gives you more than enough voltage (electrical pressure) to crank over your 100 cm circumference pulley the one time, and remember, it only needs the smallest amount of current, just a mini-burst, only enough to crank over your DC motor one single rotation, or practically zero.
- I would use a DC drive motor with a 100 cm circumference pulley + at least one AC motor-generator with a 1 cm circuference pulley as output generators, each one giving you back a return of 100 cycles of AC electricity. SO, FOR ONE SHORT BURST OF DC CURRENT:(only enough DC current to crank a DC motor over one single time = (1 spark), with 10 mini-pulleys YOU COULD GAIN a return of 10X100 =1000 CYCLES OC AC ELECTRICITY
- The only reason that this super simple free energy technology has been kept under wraps, is because of all the evil spirits using spiritual warfare to hide this simple free energy mechanism. The workings of this AC electricity multiplying mechanism are so simple, that it works as proof of evil spirits working behind the scene's. How else can you explain us not being able to see this simple use of different sized pulleys to multiply the total # of rotations. Now since AC electricity is generated by rotations, you can actually multiply the # of cycles of AC electricity.
- This works by the simple rotating of one or many 1 cm circumference pulleys many amounts of times, building up massive voltage, which is just what you need to crank over your DC drive motor the one single time. These AC generators would run free of most all torque because even though they are winding massive voltages-(electrical pressure to crank over your DC drive motor once), you only need to produce the one short burst of current. Since power is voltage multiplied by current, even massive voltage when multiplied by practically zero current, would equal practically zero power + torque.
- The reason that I only deal with a "spark", or short burst of current for my DC drive motor, is that is all that it takes the DC drive motor to rotate once. This one rotation of the drive motor, with a 100 cm circumference pulley attached, gives you 100 cm of moving belt. This 100 cm of moving belt would produced 100 cycles of AC electricity from an AC generator attached to a 1 cm circumference pulley running off the same belt. This 100 cycles of AC electricity, when run through a full wave bridge rectifier, could easily produce your on short burst of current, and we already mentioned that we were generating massive voltages, more than enough to crank over the DC drive motor one single time.
- How much simpler can you make it, by only inputting the small burst of DC current, and gaining back a return of 100 cycles of AC electricity. How can you not multiply your AC electricity. Are you going to try and tell me that 100 cycles of AC electricity would not be enough, to create one single spark of DC current. This would make this AC + DC dual electricity generating mechanism self powering, and the more mini-pulleys with AC generators attached, the more electrical pressure that you would acquire, to let you draw more current.
- Can't you see how dirt simple this is, to only have to be inputting one single "spark"= super short burst of current into a DC motor, with a 100 cm circumference pulley attached. This would give you 100 cm of moving belt, which if you ran past a 1 cm circumference pulley with an AC generator attached, then you would gain a return of 100 cycles of AC electricity. And don't you dare listen to this evil lie of Satan's, about torque being a problem, because this lie holds no strength. Torque is only caused when you are generating power, and power is your voltage multiplied by current. Yes, your massive rotations of your AC generators are generating massive voltage, you only need to generate one small spark of current, which is practically zero. Even massive voltage when multiplied by practically zero current, equals practically zero power, costing you practically zero torque, which equals free moving AC generators.
- Can you believe how much of an influence that these evil forces have on our society, to be able to hide this super simple GEM – AC electricity multiplying pulley technology from us for all these years. I hope that you can see this GEM technology for the super simple free AC electricity multiplying technology that it is, and are not falling for this ridiculous lie about torque being a problem. This DC drive motor only needs one "spark", or short burst of current to rotate the once, so your total input of power is extremely small, meaning that the total torque needed to rotate these AC generators is extremely small. You only need to input a small burst of current to rotate the large pulley attached to the DC drive motor once, so your output, though producing massive voltage, only needs to produce the smallest amount of current. This means that your total amount of power being outputted is practically zero, costing practically zero torque, meaning that these mini-pulleys + AC generators are running free of most all torque.
here is GEM =a simple free energy technology for the Tribulation Saints (2nd Door = 2022.49)
HOW TO BUILD A GEM = free energy – (AC electricity multiplying technology using pulleys)
= found in UFO motor in Ezekiel 1:16 = http://free-energy.yolasite.com
(can be any voltage, as long as AC+DC generators/motors are the same voltage)
. Multiplying Free Energy is super simple with this GEM-(Geometrical Electricity Multiplier) =AC type free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can be easily + cheaply assembled by using one 10-100 cm circumference large pulley attached to a DC motor, + at least one of the 1 cm circumference mini-pulley, (the smaller the better) connected to AC generators, both must be of the same voltage, + 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor), a lot of wire to connect your electrical components together, and a belt, strap or tied piece of rope or string, to connect the two or more pulleys together.
. Then you will need to build a framing form out of wood, metal or plastic, to hold your pulleys + motors in the right position to rotate easily. This has to be dirt simple + cheap to build, as the people that will most need to be built this, are the soon coming Tribulation Saints, whom cannot buy or sell without taking the mark. (+ taking the mark means an eternity in hell) The door closes on treaty signing on 2019.04 - http://my2020vision.yolasite.com/ + the door closes for the start of the Great Tribulation on 2022.49. Although it warns us that "the day nor hour knoweth no man", in the same paragraph we are told that we are allowed to, "know that it's near, even at the doors " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
. + There is no torque problem as these massive amount or rotations by the AC generator are like a free running motor, and are the easiest to rotate. The generator rotations are free running as they are just winding up massive voltage, and only need to generate one or a few short bursts of current, (practically zero, when you are talking about current). This is because these 10-100 cycles of AC electricity only need to generate the minimal amount of current, which it takes to rotate a DC motor over one single time. Since torque is caused by generating power, and power is equal to voltage multiplied by current, and the current is practically zero, the total power is equal to practically zero, costing practically zero torque =(free to rotate).
. You can almost think of this generator as a free floating motor, having practically no resistance to rotation at all. This is because for all the 10-100 rotations that this generator does, it only has to produce enough current to rotate your drive motor the one single time. So, you get 100 rotations of this AC generator, to be only having to produce the small amount of current that it takes to rotate your drive motor one single time. That gives you 10-100 to one odds, causing the assurance of this mechanism to be able to run perpetually.
. I figure that this uses massive pulley multiplication to wind up an extremely massive voltage, to the point of which the voltage is so extremely high, that it starts repealing other objects, including the earth = how you get levitation. How can you not multiply your cycles of AC electricity, when you only pay for one rotation of a large 100 cm circumference pulley, and then you get a return of 100 cycles of AC electricity from a 1 cm circumference pulley? Remember, the more cycles of AC electricity that you have, means the more power you are generating.
Pulleys can be used to increase torque, or freely multiply rotations, and since AC electricity is created using rotations of a coil through a magnetic field, you can effectively use pulleys attached to AC generators, to freely multiply AC electricity. You could use one rotation of a 100 cm circumference pulley, to rotate 10 X 1cm circumference pulleys 100 times each, totaling 1000 cycles of AC electricity.
Why can't we use pulleys to multiply cycles of AC electricity, instead of paying for oil to generate it. It would only take one short burst of DC current, to rotate a 100 cm circumference pulley one single time. This would gain you 100 cm of moving belt, which if we ran through any # of 1 cm circumference pulleys, with AC generators attached, then we could gain 100 cycles of AC electricity, for each mini-pulley that we added. With only one mini-pulley + AC generator, that would mean that we could gain 100 cycles of AC electricity, for only the small amount of DC current that it takes to rotate a DC motor one single time. Would this not be a way of using pulley mechanics to generate more electricity,(100 cycles of AC) than you are inputting, (1 short burst of DC current)
I know that you might think torque would be a problem, but torque is in no way a problem. Torque is only generated when you are creating major power, and power is calculated by multiplying voltage by current. Yes, we are winding up massive voltage,(which is just the electrical pressure that we need, to crank over your DC motor with the large pulley attached) but we only need to generate the smallest amount of current to make this unit self powering, (one short burst = only enough to crank the DC motor over once= practically zero). Even massive voltage multiplied by practically zero current, equals practically zero power, which takes practically zero torque = easily rotated.
FREE ENERGY IS THE MOST SIMPLE SECRET,,, THAT I WILL NOW EXPOSE,,,,
YES, TRUMP WILL BE PRESIDENT IN THE START OF THE 7 YEAR PEACE TREATY = THAT MUST START BEFORE THE FIRST DOOR CLOSE = 2019.04 = Gen 51.6 + 1967.44
. There is a real battle between good + evil going on in this world all around us, and the infamous 7 year peace treaty with Israel MUST start before the first door closes on 2019.04. This is the first of a few doors that we are told that we can know, and in the original Greek, we are even warned that we MUST "know that it is near, even at the doors" –(Mat 24:33). http://my2020vision.yolasite.com/ –(Mat 24:33). Did you ever wonder how we can know that it's near, if we cannot know the day nor hour. What we can know though, is when the door shuts for this to happen within the same generation. This is how we can know that it is near, as we can know when the first door will shut, so that's how we can know that it's near to the door.
. We are even warned when the Great Tribulation MUST start, and it is before the second door closes on 2022.49, http://doorschristmustpassthrough.yolasite.com/ . This is when we will truly need to use this GEM free energy technology, especially the people in the northern and southern regions of our planet, where the winters are the coldest. We would need this free electricity to keep us warm, as you could not use fires to help keep yourself warm, as the heat and light would give away your position. Please remember, that all of the regular police and army personnel would be against the saints, as they would be run by the global forces, which would be on the side of the enemy anti-christ's. People cannot buy or sell without the MARK + All evil forces will be kicked out of heaven -(1.atmosphere + 2.space + 3.home of God) + sent to our earth. This is when the anti-christ will be killed + Satan will animate his dead body, trying to imitate the resurrection of Jesus.
. HOW TO BUILD A GEM = free energy - (AC electricity multiplying mechanism using pulleys) = found in description of a UFO motor in Ezekiel 1:16 = (this can be any voltage, as long as AC generators and the DC motor are of the same voltage) - Here is GEM = a simple free energy technology for the Tribulation Saints (2nd Door = 2022.49) - Multiplying Free Energy is super simple with this GEM-(Geometric Electricity Multiplier) =AC type free electricity multiplying mechanism at http://free-energy.yolasite.com/. This is a device that can easily + cheaply be assembled, by using one 10-100 cm circumference large pulley attached to a DC motor, + at least one of the 1 cm circumference mini-pulleys, (the smaller the better) connected to AC generators, both must be of the same voltage, + 4 diodes to build a crude full wave bridge rectifier-(converts your AC output into DC input for your drive motor), a lot of wire to connect your electrical components together, and a belt, strap, elastic or tied piece of rope or string, to connect the two or more pulleys together.
. This works on the simple principle that a 100 cm circumference large pulley does not cost 100 times the amount of electricity to rotate that a 1 cm circumference mini-pulley does. Yet the 1 cm mini-pulley could gain you 100 cycles of AC electricity, where this 1 rotation of the 100 cm pulley would only cost you 1 cycle of AC electricity. This could be multiplied further by simply adding more mini-pulleys, so if you added 10 mini-pulleys to the belt, you could gain 1000 = (10X100) cycles of AC electricity. So, through simply pulley mechanics we could be multiplying the total amount of AC electricity.
. Then you will need to build a framing form out of wood, metal or plastic, to hold your pulleys + motors in the right position to rotate easily. This has to be dirt simple + cheap to build, as the people that will most need to be built this, are the soon coming Tribulation Saints, whom cannot buy or sell without taking the mark. +(but receiving the mark would condemn us to an eternity in the lake of fire = a place even worse than hell) The door closes on treaty signing on 2019.04 - http://my2020vision.yolasite.com/ + the door closes for the start of the Great Tribulation on 2022.49. Although it warns us that "the day nor hour knoweth no man", in the same paragraph we are told that we are allowed to, "know that it's near, even at the doors " Mat 24:33 http://doorschristmustpassthrough.yolasite.com/
. + There is no torque problem as these massive amount or rotations by the AC generator are like a free running motor, and are the easiest to rotate. The generator rotations are free running as they are just winding up massive voltage, and only need to generate one or a few short bursts of current, (practically zero, when you are talking about current). This is because these 10-100 cycles of AC electricity only need to generate the minimal amount of current, which it takes to rotate a DC motor the one single time. Since torque is caused by generating power, and power is calculated by using voltage multiplied by current, and the current is practically zero, so the total power is equal to practically zero, costing practically zero torque = (which is free to rotate).
. You can almost think of this generator as a free floating motor, having practically no resistance to rotation at all. So, each side of this AC generator + DC motor paired mechanism will produce more than enough of what the other side needs. You will get 10-100 rotations of this AC generator that gives you massive voltage and since you only needs to produce the smallest amount of current, which it takes to rotate your drive motor one single time. This gives you 10-100 cm of moving belt, to run past one or more of the 1 cm mini-pulleys, with AC generators attached, causing this side of the mechanism to be able to produce more than enough of what the other side needs. This gives you the assurance of this mechanism being able to run perpetually, as each side of this dual power mechanism gives you more than enough of what the other side needs. (you also need a full wave bridge rectifier to convert your AC output back into DC for the input of your drive motor)
http://beliefstoliveby.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
Rapture Quotes = Scriptural references
(Mathew 24:31) his angels shall gather his elect
(Luke 21:36) pray that you may be able to escape
(1st Thes 4:17) after, we still alive will be caught up with them
(Revelation 3:10) keep you from the hour of temptation
(Revelation 4:1) door was open, come up hither
(1st Cor 15:52) in a flash, in the twinkling of an eye... we shall be changed.
(Titus 2:13) while we wait for the blessed hope + the glorious appearing
STEFAN: PLEASE BAN THIS MAN NOW BEFORE YOUR REPUTATION SUFFERS
Are all of you taken in by this evil spiritual warfare,,, mainly the lie about it costing you torque to rotate the mini-pulley with an AC generator attached. This uses the simple principle that it does not cost you 100 times more electricity to rotate a 100 cm circumference pulley, than it does to rotate a 1 cm circumference pulley. Yet if you run the 100 cm of belt past a 1 cm circumference pulley with an AC generator attached, you would gain a multiple of 100 cycles of AC electricity. All of these cycles of AC electricity are produced from the one burst of DC current that your DC drive motor takes to rotate the one single time. Then if you added another two or three mini-pulleys with AC generators, you would gain another 200 – 300 cycles of AC electricity.
This does not cost you any torque, because even though you are winding up massive voltage, you only have to produce one small burst of current to power your drive motor, which is practically zero. Torque is caused when you are generating power, and even massive voltage when multiplied by practically zero current, is going to equal practically zero power, which costs practically zero torque.
My name is Joe Lynch + I have a pre-school simple way of using pulleys to multiply AC electricity. This can be done by only paying the small amount of DC current, for the single rotation of a DC motor with a 100 cm circumference pulley attached + then you run this 100 cm of moving belt past 10 mini-pulleys of only 1 cm circumference, with free running AC generators attached = you would gain 10 X 100 = 1000 cycles of AC electricity,,, all for the cost of enough electricity to crank over your DC motor once =(a mere spark) These AC generators would run free of most all torque, as torque is caused when generating power, and power is defined as current multiplied by voltage. Even though you may be winding up massive voltage, (which is useful pressure to crank over your large pulley) you only need to be generating one spark of current, (practically nothing) the minimal amount of current that a DC motor needs to crank over once. So, practically zero current multiplied by even massive voltage still equals practically zero power + torque. USING PULLEYS TO MULTIPLY AC ELECTRICITY
These generators+motors should be self-powering. I say this because the long length of belt that comes off of one rotation of your DC drive motor, with a large 10-100 cm circumference pulley attached, when run past a 1 cm circumference pulley with an AC generator attached, should easily be able to generate to small amount of DC current that the drive motor takes to rotate one single time. This is of course after you run the AC output of your generator through a full wave bridge rectifier, to convert your AC output into the DC input you need for your DC drive motor
. and the many rotations of your AC generator should gain the extra voltage that you would need to crank over your large 10-100 cm circumference pulley the one time.
This uses the long length of belt, which comes off a large 100 cm circumference drive pulley, to multiply the # of rotations to 100 cycles of AC electricity. It does this by running the 100 cm of belt, past a 1 cm circumference pulley attached an AC generator. This pulley arrangement can convert the 100 rotations into 100 cycles of AC electricity.
ARGUEMENTS
- If you get the torque problem argument = there is no torque involved in rotating this AC generator, as this generator is free running, as it is just winding up massive voltage. Torque is only needed when you are generating power, and power is defined as voltage multiplied by current. The only current you need to be generating to make this mechanism self-powering, is a few mere bursts, only enough to crank over your DC drive motor one single time. When talking about current, this is a simple spark, or practically zero current. Since even massive voltage multiplied by practically zero current, is still equal to practically zero power, which costs practically zero torque.
This Spatial Effect Generator = https://www.facebook.com/SegMagneticsInc/ looks more like the mechanism described as a UFO motor in Ezekiel 1:16, that I confirmed my Vision of a 10 speed bicycle going uphill in 10th gear + then back downhill in 1st gear was from God,,, and not from evil spirits = http://free-energy.yolasite.com/. I could not build it as this type of complex mechanism, so I decided to go with simple + affordable pulleys with a belt to connect them together. I later found out how evil spirits hate this simple free energy mechanism, and started messing with everything + everybody in my life. Don't believe me, then just try to build this dirt simple, easy + cheap mechanism to build, and just see the hard times that fall on you. You will even find that your friends + family will call you crazy, and start turning against you. I will warn you, that only the strongest Spiritual Warriors should try and build this dirt simple GEM free AC electricity multiplier.
This does not break the laws of thermodynamics, it simply uses the free laws of pulley mechanics to use a length of belt to convert 1 rotation of a large 100 cm circumference pulley into 100 rotations of a 1 cm circumference mini-pulley . We are using the 100 cm of belt that comes off of your large pulley, to gain 100 free cycles of AC electricity. These 100 cycles of AC electricity cost practically no torque, as they are just winding up massive voltage -(which is just what you need to crank over your large pulley the once), as we only need to generate a few small bursts of current to crank over your large pulley on your drive motor the once. Torque is only needed to produce power, and power is defined by voltage multiplied by current. So no matter how high of a voltage we are generating, when it is multiplied by a few short bursts of current (3 bursts for a 3 phase motor), or practically nothing when we are talking about current, the total is still practically zero power, which costs practically zero torque. That would make this dual power supply mechanism self-powering, so that you could easily just tap power off either or both AC + DC power supplies.
Hello fellow inquisitive one, . . . . . . . . . . . CHRISTIAN AGE ENDS BY 2019.04 = 1st DOOR closing
http://doorschristmustpassthrough.yolasite.com/ Ezekiel 1:16 speaks of a UFO motor as wheels within wheels, + this is a self powering set of motors http://free-energy.yolasite.com/ = This is how I confirmed my Vision of a ten speed going uphill in 10th gear + then back down hill in 1st gear, was from God,,, also the fight I had in trying to get people to see through the evil forces hiding this dirt simple free AC electricity multiplication. Free energy is as simple as imputing one short burst on DC current, to drive a large 100 cm circumference pulley for one single rotation. This would move 100 cm of belt past 1 to 10 mini-pulleys of 1 cm circumference, each with AC generators attached, giving you an output of 100 or 1000=10X100 cycles of AC electricity as an output.
« Reply #1 on: September 17, 2016, 11:37:08 AM »
you can multiply the # of cycles of AC electricity by 100, by only having to pay for one rotation of a 100 cm circumference pulley, + then getting back 100 rotations from every single one cm circumference pulley + generator, that you choose to attach to the same belt as the 100 cm pulley. This way you can multiply your output by even more, as you would get a return of 100 cycles of AC electricity, for every one cm pulley that you choose to attach.
can you believe that I was first came up with this technology between 2000 + 2002, + soon after published it on the web @ http://free-energy.yolasite.com/
THANK GOD !!!
I have been trying to tell people about how simple free energy could be,
by using pulleys, we could be freely multiplying AC electricity, or even DC apparently.
Somebody has built one very similar on UTUBE,,,
@ https://www.youtube.com/watch?v=NxpoiCFKmPg
FREE ENERGY IS NOW HERE,,, FOR ALL TO USE FREELY.
No more paying for gasoline,,,,
No more giving terrorists our money.
Prices should start going down, on almost everything
most things that need to be powered by AC + DC electricity, or even fossil fuels should now be made with self powering GEM perpetual power supplies
This should start a massive amount of new free energy inventions.
No more polluting the air we breath, with gasoline engines,,, ALL ELECTRIC AUTOMOBILES.
No more polluting our atmosphere by heating our homes + workplaces = FREE ELECTRICTY
No more pollution for lights + cooking our food = FREE ELECTRICITY
No more paying high electricity bills
Everything should be much cheaper = less shipping costs + practically zero energy costs
GOOGLE "free energy" "using pulleys"
My Ministry websites:
http://possibletimingfortribulation.yolasite.com/
http://aliensandghosts.yolasite.com/
http://fire-starter.yolasite.com/
free energy is done using pulleys
you can multiply the # of cycles off AC electricity by 100, if you pay for one rotation of a 100 cm circumference pulley, + then get back 100 rotations of a one cm circumference pulley + generator, that you choose to attach to the same belt as the 100 cm pulley. This way you can multiply your output by even more, as you would get a return of 100 cycles of AC electricity, for every one cm pulley that you choose to attach.
can you believe that I was first given this technology in 2000 or 2001, + soon published it on the web @ http://free-energy.yolasite.com/
THANK GOD !!!
Free Energy is easily done using pulleys. If you use a large drive pulley of 100 cm circumference, then this would give you 100 cm of moving belt, all for a few cycles of AC electricity, or for a few bursts of DC current. If you run this 100 cm of moving belt past 1 to 10 mini-pulleys of one centimetre circumference, you would gain a multiple of 100 times the cycles of AC electricity for every mini-pulley that you add. So, if you added 10 mini-pulley, then you would gain a multiple 1000, or 10 X 100 cycles of AC electricity.
This works because it does not cost 100 times as much energy to rotate a 100 cm circumference pulley as it does to rotate a one centimetre circumference pulley. Yet we can get 100 cycles of AC electricity out of the 100 cm of moving belt from only paying for the one rotation of the 100 cm circumference pulley, if we attach an AC generator to the one centimetre circumference pulley. This can be even more significant, by adding additional mini-pulley, because we can multiply our total amount AC electricity, by as many of the mini-pulleys that we add.
Hello fellow inquisitive one, . . . . . . . . . . . . . CHRISTIAN AGE ENDS 2019.04 = 1st DOOR closing.
Ezekiel 1:16 speaks of a UFO motor as "wheels within wheels". This self powering set of motors
https://www.youtube.com/watch?v=NxpoiCFKmPg is almost identical to the GEM idea that I was showed. Free energy is as simple as imputing one short burst on DC current, to drive a large 100 cm circumference pulley for one single rotation. This could move 100 cm of belt past 1 to 10 mini-pulleys of 1 cm circumference, each with AC generators attached, gaining you an output of 100 to 1000=(10X100) cycles of AC electricity. If you used an AC drive motor, this pulley technology, could be simply multiplying one cycle of AC electricity into 100 cycles of AC electricity. http://free-energy.yolasite.com/
How can you not gain the minimum amount of electricity that it takes to rotate a DC motor one single time. Especially when you can have 100's or 1000's of cycles of AC electricity to use in acquiring this small amount of electricity that it costs to rotate a motor one single time. Now you have a self powering set of motors, that you can tap power off of. This could be any voltage he you choose, and the more mini-pulleys that you use, gives you greater ability to draw current though your taps off these running motors.
+ with this single rotation of the 100 cm circumference drive pulley you would gain 100 cm of moving belt, which through attaching AC generators to 10 mini-pulleys of one cm circumference, will give you the 1000 cycles of AC electricity. Each side of this dual motor mechanism will gain you more than enough of what the other side needs, which makes this a self powering mechanism.
http://fire-starter.yolasite.com/ otat
http://biblefilescentral.yolasite.com/
https://www.youtube.com/watch?v=O1vtx5sDxrg
This should be extremely obvious, yet evilo forces are clouding our minds with lies about torque being a problem. This works because it does not cost 100 times as much power to crank over a 100 cm circumference pulley as it does to rotate a 1 cm circumference pulley. Yet, if you ran the 100 cm of moving belt that comes off of the single rotation of a 100 cm circumference pulley, and ran it by a 1 cm circumference pulley then you would gain a multiple of 100 rotations, which by adding an AC generator, you could easily turn into 100 cycles of AC electricity.
So, you can convert a few pulses of AC or DC eletricity, used to rotate a 100 cm circumuference pulley only once, into 100 cm of moving belt. Then by simply attaching an AC or DC motor/generator, this can be converted into 100 cycles of AC or DC eletricity, for every 1 cm circumference pulley that you choose to add to the same belt as the 100 cm circumference pulley is attached to. If you added 10 mini-pulleys, then you would be able to gain 1000 cycles of AC or DC eletricity, and all from a few short bursts of AC or DC eletricity.
free energy is done using pulleys,,,,
TRY THIS OUT FOR SIZE,,,,,,,,,,,, THIS IS ALMOST IDENTICAL TO MINE = https://www.youtube.com/watch?v=NxpoiCFKmPg
This simple mechanism uses different sized pulleys to freely multiply the # of rotation.
I use the single rotation of a 100 cm circumference pulley can freely and easily be converted
into100 rotations of a 1 cm circumference pulley.
So, through simple pulley mechanics, we can multiply one rotation,
of a large 100 cm circumference drive pulley,
into 100 rotations of as many 1 cm circumference pulleys
that you choose to add to the same belt as the 100 cm drive belt..
This works because of the circumference change in the pulleys
+ nobody would listen to my idea of using pulleys to multiply AC electricity
I was hindered by evil forces + my friends and family,
were deceived by evil forces, and would not help me in building it
THANK GOD !!!
by using pulleys, we could be freely multiplying AC electricity, or even DC apparantly.
my mechanism used AC generators + a full wave bridge rectifier.
I did not realize that you could use a DC motor both ways,
with DC in, as a motor + as a generator, giving you a DC output also
FREE ENERGY IS NOW HERE,,, FOR ALL TO USE AS MUCH AS WANTED
I truly cannot see how Satan + his evil 1/3 of angels,
as well as all the spirits of millions, if not billions of half breed creature,
that we humans experimented with before the flood,
that these can so easily hide this dirt simple technology,
with it only being the simple use of the long length of belt,
that comes off a large 100 cm diameter pulley,
to be run by a 1 cm circumference pulley with an AC/DC motor/generator
returning the free multiple of 100 cycles of AC/DC electricity
We can stop using fossil fuels +,,,,,
Having everything powered by fossle fuels or electricity,
being recreated with it's own GEM free energy mechanisms being built into it.
This works on simple logic, yet evil forces have kept it hidden all of these years. If you don't believe in evil forces, then please explain how this super simple free AC electricity multiplication using pulleys technology was kept hidden, and not discovered long ago. Pulleys can be used to drastically multiply the # of rotations freely. Since AC electricity is generated using rotations, then why cant we use pulleys to multiply the total # of cycles of AC electricity.
So, you would only have to pay for the one rotation of a 100 cm circumference pulley. Then if you set up a mechanism that ran the belt off of the large 100 cm pulley, and ran it past 10 mini-pulleys of 1 cm circumference pulleys with AC generators attached, then you drastically multiply your cycles of AC electricity. With this simple set up of 11 pulleys, you could gain a return of 1000 cycles of AC electricity, and all costing you only the smallest amount of electricity that it takes to crank over your drive motor once. = 1 to a few cycles of AC electricity.
This works on the simplest of logic, as you only have to pay for the smallest amount of power to make a single rotation of a 100 cm circumference pulley. Then, by attaching 10 mini-pulleys of 1 cm circumference, with AC generators attached,,,,, YOU CAN GAIN A RETURN OF 1000 CYCLES OF AC ELECTRICITY = ALL FOR A FEW BURSTS/SPARKS OF AC OR DC ELECTRICITY<<< HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY = PAY 1 + GAIN 1000 >>> and please don't listen to the torque lies by evil spirits, as the only torque this needs to produce, is the small amount of torque that it takes to rotate your drive motor ONE SINGLE TIME =(practically zero, when you are talking about current)
THIS SHOULD END ALL DEBATES,,, WE CAN USE PULLEYS TO MULTIPLY AC ELECTRICITY,,,,,,,, + if we stopped listening to the billions of evil spirits -(which enjoy the money that we give to terrorist,,,, promoting terror) then we could be discovering how this " a wheel in the middle of a wheel" (Ezekiel 1:16) technology can be used in UFO's to gain anti-gravity
THIS IS HOW WE CAN FREELY MULTIPLY AC ELECTRICITY USING PULLEYS
A belt from1 rotation of a 100 cm circumference pulley, when ran past 10 mini-pulleys of 1 cm circumference, with AC generators attached, could gain 1000 cycles of AC electricity. http://free-energy.yolasite.com/
+ don't listen to the torque lies, as the only torque that is needed here, is the torque that it takes to crank over your drive motor one single time = practically zero current = zero power = zero torque
I HAVE DISCOVERED THE SECRET THAT TESLA WANTED TO GET OUT TO OUR WORLD = SIMPLICITY OF FREE AC ELECTRICITY MULTIPLICATION USING PULLEYS – Also found in our Holy Bible in Ezekiel 1:16 – where he describes the workings of a UFO motor as "wheels within wheels" .
. This https://www.youtube.com/watch?v=NxpoiCFKmPg is almost identical to the idea that I was shown in the early 2000's + soon put on the web @ http://free-energy.yolasite.com/ . Simple logic tells us that "yes we can" freely multiply AC electricity with pulleys, if we are only having to input a few bursts of AC or DC current,(however many phases it is) to gain the single rotation of a 100 cm circumference pulley. Then if we run this 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference with AC generators attached, then through simple pulley mechanics, we can easily gain 1000 cycles of free AC electricity. This way you must be multiplying your input power. You are using the God given abilities of pulleys to freely multiply the # of rotations, and by simply attaching AC generators, to freely multiply cycles of AC electricity.
. If this mechanism can easily generate the needed few pulses of AC or DC electricity that the drive motor needs to keep this free AC electricity multiplier running, then wouldn't that make this a perpetual motion power supply mechanism. It is hard to believe that the 1000 cycles of AC electricity output, cannot generate the small amount of energy needed to crank over your single drive motor the one single rotations. Not only is this simple, using only 2 motors, 2 pulleys and a belt free energy mechanism a perpetual motion machine, but it can even be a steady electricity producer. This free energy technology will be needed by the Saints after 2019.04, http://my2020vision.yolasite.com/ when the door will close for the signing of the infamous 7 year peace treaty. But this will be needed most after the mid-point of this treaty, when the Great Tribulation http://doorschristmustpassthrough.yolasite.com/
AC electricity is generated using rotations + the use of pulleys can be freely used to multiply the # of rotations,,,, SO WE CAN USE PULLEYS TO MULTIPLY AC ELECTRICITY. Don't listen to the torque lies, because the only power that this 1000 cycles of AC electricity needs to generate, is the small amount of power that it takes to crank over your drive motor one single time. Torque is only needed when you are generating power, and power is defined as voltage multiplied by current. Since the current needed is only a few short burst, (depending on how many phase the motor is), which is practically zero when you are talking about a steady current. Practically zero current when multiplied by even massive voltage, would still be equal to practically zero power, costing practically zero torque. Which means that their is no torque problem = that is a big phony lie that evil spirits tell you.
THINK OF IT THIS WAY = PURE SIMPLICITY. You only have to input one rotation of a 100 cm pulley + using a simple belt connected to 10 mini-pulleys of 1 cm circumference with AC generators attached = you can freely gain a return of 1000 cycles of AC electricity = 10 X 100 rotations.
HOW CAN THIS NOT BE A PERPETUAL POWER SUPPLY – or are you trying to tell me that with 1000 cycles of AC electricity. (notice that I did not state any voltages = because this free AC electricity generator can be any voltage)
My math is simple = This single rotation of a 100 cm circumference pulley, freely multiplies into 100 rotations of every 1 cm circumference mini-pulley that you choose to attach to the same belt. If you attach AC generators to these mini-pulleys-(you could add many) then you could gain 100 cycles of AC electricity, for every mini-pulley that you add. Now, don't you think that these 100 cycles of AC electricity could manage to gain the small amount of power that it takes to rotate the DC drive motor once,,, with a 100 cm circumference pulley attached = this is perpetual motion realized + even better, as you could tap AC or DC electricity off this set of perpetually running motors.
-(I wanted to find a way to help the Tribulation Saints survive the Great Tribulation) 2nd Door=2022/49
I found this technology from the description of how a UFO motor looks as it runs, in EZEKIEL 1:16)
https://www.facebook.com/groups/274842009339398/?ref=bookmarks
Hello fellow inquisitive one, HIS BRIDE HAS LESS THAN 4 MONTHS TO LIVE
On this earth, before the Rapture takes us off this earth, + we go to the Wedding
The 1st thing that I want you to know, is the TRUTH about the RAPTURE
CHRISTIAN AGE ENDS before 2019.04 or JAN 14.57 = 1st DOOR closing
When He first showed me this free energy technology, I wanted to be sure,
that it came from good spirits + not evil spirits
I later found this tech in Ezekiel 1:16 speaks of a UFO motor as "wheels within wheels",
+ because of free multiplication of rotations, this is a self powering set of motors = FREE ENERGY
THIS GEM TECH IS SIMPLE LOGIC, THAT EVIL FORCES ARE HIDING .
Free energy can be generated using pulleys,
because pulleys can be used to freely multiply the # of rotations
+ since AC electricity is generated by rotations, then we can use pulleys to multiply AC electricity
WHY DOES NOBODY SEEM TO THINK ABOUT, or MENTION
THAT THE FIRST DOOR IS COMING TO A CLOSE ON 2019.04,
or JAN 14.57 = (COMING UP IN LESS THAN 4 MONTHS) This is +
not a prediction of the date that this will occur by, but this is the date
that this prophecy can no longer be fulfilled past this date. This is where
the "end of the world" miss-translation is found + should be translated
as "end of the age", as in "Christian age". This is a deadline, or when
the door closes on it still being able to fulfill the prophecy about
it happening within t within t were both the signing of 7 year peace treaty
with Israel + the pre-Trib Rapture MUST happen before this
first door closes. Please Google "doorschristmustpassthrough"
This is some very important NEWS to
share with this world. Although we are warned of that the "day +
hour knoweth no man", we are also assured that we would know
"when it was near, even at the doors". This first door will close on
2019.04 = DEADLINE for signing of infamous 7 year peace
treaty with Israel + the Pre-Trib Rapture.
Did you ever wonder how we could know
that it was near, if no one could know the day. It was
because we could know the generation, and all generations have an
end date. Well this end date could be the door, as in when the
door will close on it being able to fulfill the prophecy about
"this generation shall not pass". I know that there are a lot
of duration for a generation, but i figured that it was probably
the 51.6 solar year duration, as this was the same duration that
was used to accurately predict the rebirth of Israel.
We are told that there are 14 + 14 + 14
generations from Abraham to Jesus in (Mat 1:17)
14 + 14 + 14 = 42 generations
2,167 is the year for the Birth of Abraham.
http://www.stanford.edu/~meehan/donnelly/bibchron.html
http://www.israel-a-history-of.com/story-of-abraham.html
http://www.olive-tree.net/redemptiveplan/Chronological/Old%20Testament/overview%20I.htm
2,167 / 42 = 51.595
51.6 = duration of our end time generation
PROOF -(this was the same duration used
to predict the date of Israel's rebirth = to the exact day)
GOD'S SECOND CHANCE RULE, (sorry that I forget the book + verse)
= 10 times original duration = duration from when
prophecy was given + day Jesus entered the
temple=(prophecy fulfilled), then multiply # days by 10 = May 14th
948 = rebirth of Israel = 2nd chance for Israel to show this world Christ
(please read the novel called
"Armageddon", by Grant Jeffrey )
as this novel symptomatically went
through all of the fulfilled
prophecies in Scripture + displayed the
reality of every one being
fulfilled to the day = in the Holy
Bible KJV. This novel helped me
discover Scripture as TRUTH + I soon after became Born-Again
USING PULLEYS – Also found in our Holy Bible in Ezekiel 1:16 - where he describes the workings of a UFO motor as "wheels within wheels"
1st DOOR closing = 2019.04 - signing of 7 year peace treaty
+ 2nd = 2022.49 – Great Tribulation = most all evil is sent to earth
+ 3rd = 2025.94 – Jesus Christ sets His Feet on earth
= FREE ENERGY IS POSSIBLE = http://freeenergy.yolasite.com/
It is as simple as the lesson that you
learned way back in preschool, where they showed you how a single
rotation of a larger pulley could be converted into many
rotations of a smaller pulley. Well, this can be a significant
thing, when talking about AC electricity, as more rotations can
mean a greater amount of cycles of AC electricity. So, in effect,
you can use pulleys to freely multiply the amount of AC
+electricity that you have.
Think of only paying for the single
rotation of a DC motor, (a few bursts of current) with a 100 cm
circumference pulley attached, rotating 1 to 10 mini-pulleys of 1 cm
circumference, attached to AC generators + giving you a return of 100
to 1000 cycles of AC electricity, (10 X 100 = 1000). + don't you
listen to the evil spirits, whispering that torque is a problem,,, =
because the only torque that you need to produce, with these 100 to
1000 rotations of AC generators, to make this GEM device a self
powered free energy system, of one DC motor + 1 to 10 AC generators,
is the minute amount of current that it takes to crank over your
single DC motor one single time = a few short bursts, which
equals practically nothing, when it comes to current. This is
because practically no current multiplied by even massive voltage,
still equals practically zero power – costing practically zero torque.
Q1
– IS THE RAPTURE SCRIPTURAL TRUTH = YES, there are many scriptural proofs
. (Rev 4:1)-",,, a door was opened in heaven,,, Come up hither,"
. (Mat 24:31)- ",,,send his angels,,, they shall gather together his elect"
. (Luk 21:36)= "Watch,,,and pray always,,, be accounted worthy to escape"
. (1 Thes 4:17)= ",,,remain shall be caught up,,, to meet the Lord in the air:"
. (Rev 3:10)= ",,,I also will keep thee from the hour of temptation,"
. (1Cor 15:52)= ",,,in the twinkling of an eye,,, and we shall be changed."
. (Tit 2:13)= "Looking for that blessed hope,"
AND the glorious appearing = (He comes twice)
Q2
– WHEN DID THIS GENERATION START = 1967.441,
. this final generation has already stared
. the day that the Jewish army took Jerusalem
. in the six day war of 1967 this final generation started
. which was a prophecy about Jerusalem = (holy city)
. so the generation could not have started before this time
Q3
– DO YOU BELIEVE IN SCRIPTURE
. well, Scripture assure us that there is a door/deadline
. as in, the day of the Lord MUST arrive before
. (Mat 24:34) "Verily I say unto you,
. This generation SHALL NOT PASS = (die)
. till all these things be fulfilled."
THIS IS THE 1st DOOR, WHICH WE ARE ALLOWED TO KNOW
"know that it is near, even at the doors" (Mat 24:33)
This ( http://free-energy.yolasite.com/ ) free AC electricity multiplier works on the simplest logic, of a 100 cm circumference pulley not costing 100 times the power to rotate as a 1 cm circumference pulley, yet if you run the 100 cm of moving belt, (which comes off of the single rotation of a 100 cm circumference pulley) past 1 to 10 of the 1 cm circumference pulleys with AC generators attached, then you could freely gain 100 to 1000 cycles of AC electricity,,, and all for the small amount of energy that it takes to rotate a DC motor once.
Think of it this way, you are only paying slightly more power to rotate a 100 cm circumference pulley, than you pay to rotate a 1 cm circumference pulley. Yet if you run the 100 cm of moving belt that comes off the one rotation of a 100 cm circumference pulley, past 1 to 10 mini-pulleys of 1 cm circumference pulleys with AC generators attached, you could freely gain 100 to 1000 cycles of AC electricity. These 1000 cycles of AC electricity are multiplied from the smallest amount of energy that it takes to rotate a 100 cm circumference pulley one single time.
Ok a dead thread but, to convince anyone you have to explain where on earth is it getting its energy from?
Not the 1 dc to 100 ac ratio but explain where is the energy coming from regarding the 1 dc to 100 ac ratio.
Anyways some food for thought > https://100777.com/spiritual/beings_having_a_physical_experience
Are these ac motors extracting energy or is it perpetual.. i think perpetual with the way you are saying, but how do you overcome the bit where most have failed to have perpetual machine?
Quote from: lltfdaniel1 on February 04, 2021, 12:00:16 PM
From nowhere. A rubbish thread pushed on by a religious zealot.
