Overunity.com Archives
News announcements and other topics => News => Topic started by: spacecowboy on February 09, 2017, 05:29:01 PM
Title: The over unity of series to parallel recharging.
Post by: spacecowboy on February 09, 2017, 05:29:01 PM
Made a little video on the over unity of series to parallel recharging with some demonstrations the average laymen can try. https://www.youtube.com/watch?v=VTA7a9l7Ifo (https://www.youtube.com/watch?v=VTA7a9l7Ifo)
Title: Re: The over unity of series to parallel recharging.
Post by: dieter on February 09, 2017, 06:16:41 PM
Interesting, but did you say whether you did test this successfully?
The motor is also interesting, it may cause some AC signals and cause high voltage spikes on both sides, some recharging the serials, he others, rectified by the diode the parallels. Similarity to Bedini to some degree.
Would be interesting to see some layman, actually perform this experiment.
Current flows from a higher to a lower potential. Where in normal consumption electrons and ions  are exchanched and eg. in a voltaic cell oxidize one side, doing it this way you are practically causing flow between two similar metals. I'm not sure tho, whether this is also valid for alkaline or LiPo etc.
Post by: citfta on February 09, 2017, 06:56:22 PM
Please see this reply:
http://overunity.com/17122/the-over-unity-of-series-to-parallel-recharging/msg499667/#new
Title: Re: The over unity of series to parallel recharging part 2
Post by: spacecowboy on February 12, 2017, 01:22:07 AM
Watch part 2 of this video at https://www.youtube.com/watch?v=zsHT5KrnQck (https://www.youtube.com/watch?v=zsHT5KrnQck)
Post by: Tito L. Oracion on February 12, 2017, 11:42:46 PM
we need to cut one wire in the motor and get the collapsing field and charge. [/size]
Title: Re: These videos have been moved to my unlisted section on youtube.
Post by: spacecowboy on February 13, 2017, 10:36:18 AM
The reason for this is both positive and negative. Turns out I had made some mistakes, but I was not wrong in everything. Given some conversation I had with a commenter on my youtube video page. Seems Seems my commenter and I were both right and wrong on over unity strangely. I was wrong about adding more parallel batteries to be recharged thinking that would equal over unity, it only equaled a less of a recharge there on those batteries. However by sticking to only 2 batteries in series to be used to run the motor and also that recharging only 2 other batteries in parallel this turned out to be correct and works well. My commenter said the only way to be sure was to run the motor by itself on just the two AA batteries and see how long the motor ran, and then compare that against how long the motor ran as the whole setup also recharged the two parallel batteries. Turns out that even when I run the motor alone on the two Fully recharged AA batteries in series it runs around 14 hours, which is the same the motor runs when the setup is recharging the 2 batteries in parallel. Plus I can then swap the recharged parallel batteries with the then two drained series batteries at the end of the experiment, and get the motor to run an additional 9 hours. So there is still progress here, but I will remake these videos again getting ti all straight because as they are now I was mistaken a bit. So again they are now listed in my unlisted youtube video section.
