Overunity.com Archives
News announcements and other topics => News => Topic started by: e2matrix on February 22, 2017, 10:28:01 PM
Title: Electrical Calculations Pro for Androids - and other very useful info
Post by: e2matrix on February 22, 2017, 10:28:01 PM
Electrical Calculations Pro for Androids to help the Free Energy movement get calcs right ;)
and if you really can't afford the $1.99 ....  available here free:
http://www.freeapk.es/electrical-calculations-v6-1-0-pro/
Features:
Wire size
Calculation of voltage drop
Calculation of current
Calculation of active power
Calculation of apparent power [PRO]
Calculation of reactive power [PRO]
Calculation of resistance
Motor from three-phase to single-phase
Capacitor start motor single-phase [PRO]
Calculation rpm motor [PRO]
Motor efficiency [PRO]
Maximum torque [PRO]
Diagram three-phase motor (6 leads)
Diagram three-phase motor (9 leads) [PRO]
Diagram three-phase motor (12 leads) [PRO]
Code resistors 4 colors
Code resistors 5-6 colors [PRO]
Color code inductor [PRO]
Colors resistor from value
SMD resistor code [PRO]
Fuses [PRO]
Sum resistors
Sum capacitors [PRO]
Conversion ?-Y [PRO]
Conversion HP/KW
Table AWG/mm²
Conversion of section
Conversion cm/inch
Conversion length [PRO]
Conversion voltage (Amplitude) [PRO]
Conversion sin/cos/tg/f [PRO]
Conversion energy [PRO]
Conversion temperature [PRO]
Conversion pressure [PRO]
Conversion Ah / kWh [PRO]
Conversion Gauss / Tesla [PRO]
Conversion RPM - rad/s - m/s [PRO]
Reactance [PRO]
Impedance [PRO]
Resonant frequency [PRO]
Voltage divider [PRO]
Zener diode as voltage stabiliser [PRO]
Resistance to reduce voltage
Resistance for led
Power factor correction [PRO]
Power factor correction of small loads [PRO]
Power factor correction of transformer MV/LV [PRO]
Battery life [PRO]
Primary/Secondary winding of transformer
Short circuit current [PRO]
Short circuit current with transformer substation [PRO]
Current carrying capacity IEC [PRO]
Current carrying capacity NEC [PRO]
Conductor resistance [PRO]
Table of cables reactance IEC [PRO]
Table of cables reactance NEC [PRO]
Table of resistivity [PRO]
IP/IK/NEMA protection classes
Antenna length [PRO]
Electrical symbols
Electricity around the world
Joule Effect [PRO]
Wiring color codes
SI Prefix
Unit of measurement
Fault current of strings [PRO]
Ethernet wiring (RJ-45) [PRO]
Pinout Ethernet with PoE [PRO]
RJ-11,14,25,48 [PRO]
Pinout Scart [PRO]
Pinout USB [PRO]
Pinout HDMI [PRO]
Pinout VGA [PRO]
Pinout DVI [PRO]
Pinout RS-232 [PRO]
Pinout FireWire (IEEE1394) [PRO]
Pinout molex [PRO]
Pinout Sata [PRO]
Pinout Apple Lightning [PRO]
Pinout Apple Dock Connector [PRO]
Pinout PS/2 [PRO]
Fiber optic color code [PRO]
Pinout led [PRO]
Pinout Raspberry PI [PRO]
Pinout ISO 10487 (Car audio) [PRO]
Pinout XLR (Audio/DMX) [PRO]
Formulary [PRO]
Also look for Electronics Toolkit Pro - another great App for your Android phone or tablet
Title: Re: Electrical Calculations Pro for Androids - and other very useful info
Post by: Lakes on February 23, 2017, 05:09:47 AM
Is this just for Androids or can humans use it as well? :)
Sorry.... :D
