Overunity.com Archives
New theories about free energy systems => Theory of overunity and free energy => Topic started by: guest1289 on March 29, 2017, 06:50:27 PM
Title: Magnetic, And, Gravity, Motor, Update, And Notes
Post by: guest1289 on March 29, 2017, 06:50:27 PM
   Important Potential ?  Update To My  Magnet-Motor-3.5
        I was  thinking/searching for potential reasons why my  Magnet-Motor-3.5  might not function( since I don't know if it does or not ),  I thought of a possible ? reason( that it could potentially ? go backwards, but that means it would function anyway ?, unless it would all balance ),  and made a modification to my design,  and have posted the  modified-design-diagram below as :
  ____
  The Simplest Proof That Free-Energy Can Be Attained From Gravity Via Momentum ?
       - Use x-amount of energy to push a ball up a hill
       - not only will the ball roll down that particular hill,  but also,  because of the momentum it has gained in rolling down the hill,  it will also roll up( how far? ) another identical hill, or up a different hill
       -  I wonder if the total theoretical energy recoverable/gained?,  is more than  "x-amount of energy used to push the ball up the hill"
  ____
   Pelton-Wheel  Magnet-Motor Idea
       Some time ago I posted my idea about a  magnet-motor  that could be based on the  pelton-wheels  that are commonly used on hydro-electric-generators
    https://en.wikipedia.org/wiki/Pelton_wheel
     - IMPORTANT
         - Instead of the  pelton-wheel  being made of  magnets,  it  could be made of a strong diamagnetic material like  pyrolytic-carbon/pyrolytic-graphite or  bismuth
           IMPORTANT NOTE - According to a google search,  I think this was already designed and constructed using  pyrolytic-carbon/pyrolytic-graphite,  by someone else,  in the last couple of years,  so that would mean I did not invent that,  no surprise, it's such a simple idea.
             However, I don't know if the device I found on the internet uses the  'offset-effect' to overcome sticky-points,  but it may,  I think it may use multiple-magnets to drive it, I will look at it later.
       However, I was hoping to find a picture on the internet of a  pelton-wheel  with more than 2 rows of 'cups/half-balls',  and  'each'  row  should be  slightly  'Offset'  from the other rows,  in other words,  one that would sort of replicate the  'Offset-Effect'( to overcome sticky-points ) I use in my  magnet-motors  like in my Magnet-Motor-3.5( for example ),  although I used it in  magnet-motor  designs before that one.
       But at the moment I can not find a picture of such a pelton-wheel.
       Although,  you could just put a few wheels on the same shaft but slightly offset, out of synch, with each other.
   ____
Magnet-Motor Concepts For Use In Gravity-Motors
      I have noticed/wondered that maybe,  concepts used in many of my magnet-motors could possibly be used for  gravity-motors.
      But now,  the only concept I can think of, used in any of my  magnet-motors  that could maybe be used as a basis for  gravity-motor  could my  magnet-motor in the diagram  below :
     But then that would( almost sure ) be the same as all those other common  gravity-motor designs
Title: Re: Magnetic, And, Gravity, Motor, Update, And Notes
Post by: guest1289 on April 07, 2017, 08:02:59 PM
  guest1289
QuoteThe Simplest Proof That Free-Energy Can Be Attained From Gravity Via Momentum ?
   I think there is probably no possible energy gain in the example above.
   (  Flywheels : -  once flywheels are spinning,  they only need  input-energy  to maintain a certain speed,  they no longer need the initial  input-energy  to get them from not-moving - then to a certain speed  ,    at the moment I can't see if there definitely is or is not any possible energy gain there,  since it would all depend on the types of dynamos and pulsers( or motors ) that would be used,  and I may not even be correct in that last sentence   )
  ____
  guest1289
QuotePelton-Wheel  Magnet-Motor Idea
     - IMPORTANT
    When I re-looked at what I found via a google search,  it seems that what I found does  not  utilize  Pelton-Wheel shapes ( but it does use pyrolytic-carbon/pyrolytic-graphite )
  ____
    I later remembered that some  basic-principles  upon which my  Magnet-Motor-3.5 is based( which I had also used in  'at least'  one design prior to Magnet-Motor-3.5, 'or in more' ),  can also be the  basic-principles  of :
                     -  A Gravity-Motor . or
                     -  A Spring-Powered Motor
      So keeping in mind the  basic-principles  upon which my Magnet-Motor-3.5  is based,  the  'diagram below'  shows my design for either :
       That really makes wonder,  if the  'spring-powered-motor'  were to actually function successfully,  what could actually be the source of it's power down at an atomic/molecular-level,   could the  source  actually  be  the molecular-bonds  between atoms that cause the spring to always return back to it's original shape.
        Then that made me wonder/realize,  that the source of power that could potentially be derived from magnets,  could also 'possibly' be  the molecular-bonds  between atoms that  cause the  atoms( electrons? ) in magnets to all align in the same direction,  or at least,  that is another way of looking at it.
Post by: guest1289 on April 08, 2017, 11:37:53 AM
   Solid-State Version Of My Magnet-Motor-3.5
      Just posting it to post some general concepts,  I haven't thought of all the details, so I have no idea if such a device could ever run successfully .
      A solid-state version of my magnet-motor-3.5,   obviously the aim being to permanently keep current flowing in the device,  and self-running.
      The important component seems to be the  switch,  since in some versions of this device I hope the  switch  could  detect a  stronger-flux-path( stronger magnetic attraction ) in order to keep the device  switching from one  coil-core and to the next  coil-core.
       It is that  very  switching action which would generate the current in the device,  so I assume the output would be made of pulses.
       I would probably want to avoid using capacitors,  due to energy loss( electromotive-force out into the environment ?) when they discharge .
Post by: Zephir on April 08, 2017, 12:55:30 PM
The problem is, the magnetic flux cannot be interrupted or switched - only conducted or scattered into a larger volume. But at the end all magnetic lines of force must get close somehow and the force between magnets will get restored in this way. Even the magnetic pipes ("flux path conductors" in your diagrams) will be quite complicated and they consist of alternating layers of ferromagnet and superconductor (which prohibits the spreading of magnetic lines of force into outside).
Post by: guest1289 on April 08, 2017, 02:26:56 PM
  I forgot to post  probably my  simplest  and maybe( or maybe not, I don't know ) most  important  idea for a Solid-State Version Of My Magnet-Motor-3.5
    In the diagrams below,  diagrams 4.0, and 4.1,  if a single pulse of current is given to the coil,  then the  magnetic-field  emitted  by the  core or coil,  is attracted( or can be designed to be repelled ) away from the coil or core,  and towards the triangle-shaped  magnet or iron,  and because the  triangle is an  unsymmetrical type of shape ,   it may tend to  'progressively'( but obviously very fastly )  attract the emitted   magnetic-field( from the core or coil )  from the  weaker  end of triangle and to the stronger end of triangle,   in effect,   'creating more movement'  of the  magnetic-field  than  would  have occurred  by using  a  more  symmetrical shape( instead of the triangle ).
         More movement of the  magnetic-field can often result in more energy generated.
    My ideas for  solid-state  versions of my magnet-motor-3.5 are longshot ideas,  I'm only posting them in case they can be developed further.
    In  diagrams 4.2, and 4.3,  the coil, or the core,  is put inside a  cone which is either a magnet, or is made of iron,  for the same effect as above .
Post by: Zephir on April 08, 2017, 02:34:59 PM
This is an electromagnetic analogy of magnetic ramp (https://www.youtube.com/watch?v=V5RjEbdmAYw) - just instead of magnetic sphere the electromagnetic coil is supposed to climb along gradient of magnetic field. It works, it just doesn't generate any overunity (if we ignore somewhat esoteric SMOT device (https://www.youtube.com/watch?v=j-wnSdT_-fI), which wasn't proven yet)
Post by: dieter on April 08, 2017, 05:12:35 PM
I like your example with the ball rolling down the hill. Basicly every football is an overunity device.
But gravity isn't directly substitutable by magnetism. As there is no repelling in gravity.
Post by: guest1289 on April 09, 2017, 02:26:37 PM
Zephir
QuoteThe problem is, the magnetic flux cannot be interrupted or switched - only conducted or scattered into a larger volume. But at the end all magnetic lines of force must get close somehow and the force between magnets will get restored in this way. Even the magnetic pipes ("flux path conductors" in your diagrams) will be quite complicated and they consist of alternating layers of ferromagnet and superconductor (which prohibits the spreading of magnetic lines of force into outside).
   Yes, those are the types of details I have not worked out
   I'm mostly posting  overly-general-concepts   for a  Solid-State version of my  "Magnet-Motor-3.5",  rather than how specific components like the  'switch' would function
   The  'flux-path-conductors' I drew on the diagram are part of a  'component'  in the design that tries to  'maximize'  the strength of each pulse,  I don't know if it would work as designed,  anyone could replace them with a simpler design
     The  component  I drew containing the  'coil-with-core' and the 'flux-path-conductor'  are either a copy of  dieter 's  'pulsed-motor design'( the version of his motor I commented on ), or where I got the idea,  I just added a  'switch'( a 'switch' that I'm not sure how it would function )
       Note :  Dieter 's  'pulsed-motor design'  already had the switch,  but in that motor it was the rotor
     Note : "Magnetic pipes" / "flux path conductors",     I wonder if  a  'long-cylinder-donut-magnet'  can  conduct  the  magnetic-field  of another  magnet through it's hollow,  keeping in mind that  'magnetic-sphere'( monopole generator )  device built at the university in barcelona
     I only drew "Magnetic pipes" / "flux path conductors" because of dieter 's  'pulsed-motor design'( the version of his motor I commented on ),   I just assume that if anyone  were ever to build anything relating to my designs that they would replace any  unworkable components/concepts,   with   workable components/concepts
  _____
dieter
QuoteI like your example with the ball rolling down the hill. Basicly every football is an overunity device.
     In my diagram,  in a previous post above in this thread,  I posted the diagram :
         'GRAVITY, OR SPRING, POWERED MOTOR.JPG'
       I then realized that in that diagram,  it would actually be the  'gravity/mass-powered-version'  that would be much more likely to function,  rather than the  'spring-powered-version',   because when the  spring  expands its force gets weaker,  unlike gravity which would never vary in strength in that device
        You could say gravity has N and S poles ,  when an object is going against gravity, or when it's falling
         if you read the beginning of this post,  you'll see that I mention that I either copied or adapted( I added a 'switch')  the  version of your  pulsed-motor  that I had commented on,  I doubt that either you or I care,  since all these designs go nowhere
         Note :  Your  pulsed-motor  already had the switch,  but in your motor it was the rotor
  _____
    I have just remembered the main reason why I think that a  'solid-state-version' of my  'magnet-motor-3.5'  could have some small chance of functioning
    In the 2 diagrams below,  at the bottom of each diagram there is a time measurement ruler,  if you look above the ruler you will see multiple rows of coils
     -  Each row of coils is slightly offset from the other rows,  which means that different  rows?/coils?  would pulse at different points in time from the other  rows?/coils?
     -  That is the primary justification for having so many coils and / or seperate rows-of-coils,  it is just like the  'numerous'  stators  and  'multiple'  rotor  'components in my   'magnet-motor-3.5'
      The  offset / un-synchronized pulsing between the different  rows?/coils?,   would mean that   'at any one point in time',    when a coil(coils ) is pulsed,   it provides the energy to activate a  pulse for another  coil(coils ) that is presently not being pulsed,   that is the exact method by which the  sticky-points in this  'solid-state-version' of my  'magnet-motor-3.5' are overcome
      Of the 2  diagrams / versions below,  maybe only the diagram/version containing the triangle shapes would provide the necessary  electromagnetic-propulsion that would keep this device going/self-running
Post by: guest1289 on April 09, 2017, 03:38:56 PM
  dieter had said on another thread that if you put a  '1-tesla'-neodymium-magnet  onto a piece of iron( of identical size ?/ shape ? ) ,  that you will then have 2-tesla ?
  ( it may have been the thread about 'simple experiments' to prove overunity via magnets  )
   Is that accurate / correct / precise  ?
   If it is correct,  then look at the 2 diagrams below,  is there any possibility for energy amplification if you maybe change the  core  shapes to squares instead of rectangles,  or whatever other modifications could be made
Post by: guest1289 on April 10, 2017, 03:38:09 PM
This post is just to post some things,  rather than needing any information
The Bifilar Pancake Coil
   - Maybe if it was made as a long cylinder,  instead of as a pancake, it could maybe generate more energy,  and block the ends of with pyrolytic-carbon/pyrolytic-graphite or  bismuth,  or with magnets,  to ensure as much as possible is reflected back into coil
   - And if it was made as a donut with some sort of diode component/effect,  then the energy would be continuously re-cycled
_______
Gravity-Shielding
   Gravity-Shielding ideas usually involve things like spinning superconductors, and/or electrical-flow
    But what about those forces between protons and neutrons that keep them together
    At close distance, those forces between protons and neutrons are enough to keep them together,  but maybe if you add up that total force in a mass, then that may explain the effect of gravity at long distances,  I wonder if it was theoretically possible to remove all the electrons( and? electromotive-force? ) from a material,  maybe it could be a gravity-shield.
_______
The Loss Of Energy When Capacitors Discharge
    When capacitors discharge, apparently they lose 50% of their energy into the environment,  I assume as electromotive-force and  heat
     What about encasing capacitors in  pyrolytic-carbon/pyrolytic-graphite or  bismuth, or inside magnets,  to reflect the lost energy back into the device.
     Although maybe it would cause them to melt.
_______
A Completely Shielded Electrical Circuit
    Using  pyrolytic-carbon/pyrolytic-graphite or  bismuth, or  magnets,  to completly encase an electrical-circuit,  to reflect as much as possible lost energy back into the circuit
Post by: guest1289 on April 12, 2017, 02:52:53 PM
  We know that adding  permanent-magnets  to an  electric-motor increases the speed/torque, and I read that the 'percentage' of the increase in the speed/torque decreases with the more magnets you add,  and I also read that according to a member on this site, that that problem( that the 'percentage' of the increase in the speed/torque decreases with the more magnets you add ) does not apply to solenoids/electromagnets.
   So, for a  DC-motor/Faraday-type-motor, I wonder if the   'diagram-below' ,   would be a  method to  add  permanent-magnets  to a  DC-motor/Faraday-type-motor  without the problem of [ "the 'percentage' of the increase in the speed/torque decreases with the more magnets you add" )
      In the   'diagram-below' ,  the grey-cylinders are cylinder-magnets( could be made of individual disk-magnets )  and the light-blue-cylinder is a  DC electrical-conductor( solid or hollow ).
      So theoretically( according to my unproven idea ) you could keep making the grey-cylinders and the light-blue-cylinder longer and longer,  and each time you do,  you gain more speed/torque.
  ______
  Spring-Powered-Version  Of My  Magnet-Motor-3.5
   My diagram on a previous post in this thread :
    contains both a  Gravity-powered-version,  and a Spring-powered-version,  of my  Magnet-Motor-3.5
       I then came to a conclusion that the  Spring-powered-version  'may' have even less chance of functioning than I thought,  because the force from a spring decreases as it expands.
        So, my solution would be to add another  'Identical-Spring' to each  spring-powered-moving-component,  However,  the 2nd-'Identical-Spring'  would  pull  down the  spring-powered-moving-component  while  the  1st-spring  in the spring-powered-moving-component is  pushing  the  spring-powered-moving-component down,  this way,  there will be no loss of spring-force as the spring expands.
  ______
   Gravity
  My possible explanation for what gravity is,  is that floating particles of Aether are  'on-average' like grid-points throughout the universe.
   So, on something like a proton, when one these Aether-Grid-Points touches a proton, it briefly? sticks to it through a  surface-tension-effect( like water-surface-effect, or casimir-effect, or magnets ) and then these Aether-Grid-Points form lines between the proton and any other relevant particles,  but to form those lines,  other particles of  Aether  float in to fill the gaps between the Aether-Grid-Points,  to form solid lines, with all the  particles of this  gravity-line made of Aether held together by the  surface-tension-effect( like water-surface-effect, or casimir-effect, or magnets )
     However,  then those lines of gravity would be so dense that they would out-weigh any other matter
     So, my explanation is that those lines of gravity form and collapse continually,  so fast that they don't form matter
  ______
  Pelton Wheel Magnus-Effect / Pelton Wheel Flettner Aircraft
    Simply my idea is to either add Pelton-Wheel like scoops to these rotating cylinders, or just add raised bumps, for whatever advantage
     I wonder if they actually misunderstand how this effect works,  I'm looking at the first diagram on the wikipedia-page for the Magnus-Effect,  and I wonder if what actually happens is that as the  bottom-cylinder-surface  rotates( at the exact horizontal instance of it's rotation )  'towards' the air,  it therefore creates more friction than the  top-cylinder-surface( which rotates 'away from' the air),  the result being lift.
  _____
   I had not taken sufficient notice before that the Bessler-Wheel/wheels have pendulum-type-devices( and other things ) linked to his devices/wheels, and not hidden from view
    The last incident of a fake-device hand-driven by a shaft through a wall may very well have occurred,  but it does not mean all his machines were fake, the designs would have been very hard to fine-tune to get them working, so he may failed on his last design.
     The  pendulums( and whatever else ) linked to his wheels could have been to break the symmetry of gravity?,  by linking the propulsion/momentum from the pendulumsl( and whatever else ) sitting outside the wheel,  to the propulsion/momentum emitted by the devices hidden inside the wheels,  in other words,  the momentum/proplulsion  from  two very different types of  devices/structures  with  different properties,  when  connected / interlinked,  break the the symmetry of gravity?
      The  pendulumsl( and whatever else ) sitting outside the wheels,  and linked to his wheels,  could have been a method to overcome the  sticky-points  of the device/devices hidden inside the wheels.
      It is possible that the device/devices hidden inside the wheels were either just the well-known older designs by previous-inventors,  things like balls or swinging-levers,  or,  that they were just devices designed to create noise to make people think that the secret was hidden inside the wheels,  when in fact the secret to his devices was in full open view all along.
Post by: guest1289 on April 12, 2017, 03:36:08 PM
   I forgot to add in that post above I made just now,  that maybe a reason why scientists can't get their maths to add up regarding  mass-anomalies of the universe or is it gravity-anomalies of the universe  is because of an unequal distribution(density?) of Aether in different parts of the universe,  in reference to my theory I posted in the post above
    on the outermost areas of the universe it could be logical that there would be less aether ,  although there would be all sorts of other factors also causing unequal distribution(density?) of Aether in different areas
  _____
    Also, it would seem that  All-Permanent-Magnet-'Full'-Levitation  does in fact seem to be connected  directly/or,-not-completely-directly  to a method of overunity,  otherwise you would see it posted
Post by: guest1289 on April 13, 2017, 08:58:45 AM
   Can electric-currents flow in a wire or any conductor in both directions at the same time.
     (  can 2 DC-currents flow in a wire( or any conductor) in both directions at the same time )
   NOTE : For the following, I know that coaxial-cable is made of 2 separate conductors,  the central-wire, and the metallic-shield( which also has current running through )
   Some time ago,  I had found a webpage claiming that in antennas/coaxial-cable, I can't remember if it was antennas or coaxial-cable,  that it is known that  DC-electric-current flows through them in both directions at the same time.
    I can see some logic that that may be possible in antennas, since current is not  forced through them in 2 directions at the same time,  rather,  that the antenna  receives only as much as it can from the air,   and if there is any type of current that is fed from the tv/radio to the antenna, then that is the only current that is forced through it ,  therefore,  the antenna could naturally balances how much current it allows to pass in both directions at the same time.
   But then there's the problem inductance,
   [   I think,  that when a DC-current flows through a wire,
         - that it is the inductance-effect which causes the wire to emit an electromagnetic-field,
          -  that it is the same inductance-effect that allows a  current-carrying-wire  to  induce an electric-current in a 'separate'  previously non-current-carrying wire,
               that   "causes a wire( which is not being induced ) to emit an electromagnetic-field  when a DC-current flows  it     ]
     - So that if  2 DC-currents  were to flow in a wire( or any conductor) in both directions at the same time,  then it would also be their  'electromagnetic-fields'  that would be colliding ' inside, and outside of the wire or antenna ,  which would make it even more difficult to occur.
     My theory I have just typed above, about :
  "that when a DC-current flows through a wire,
         - that it is the inductance-effect which causes the wire to emit an electromagnetic-field"
      could possibly be tested using a single strand/wire of graphene( instead of the normal graphene mesh ),  since a single strand/wire of graphene would only be 1-atom-thick( have a cross-section of 1-atom )
,  although at this stage it is getting too complicated/advanced for me to think about, or at least for now anyway
      EDIT :  Any suitable  electrically-conductive  material could be used instead of graphene, as long as it's only 1-atom-thick( have a cross-section of 1-atom )
  ______
In my post :   "Reply #10 on: April 12, 2017, 08:52:53 PM"  I forgot to add the diagram for :
QuoteWe know that adding  permanent-magnets  to an  electric-motor increases the speed/torque, and I read that the 'percentage' of the increase in the speed/torque decreases with the more magnets you add,  and I also read that according to a member on this site, that that problem( that the 'percentage' of the increase in the speed/torque decreases with the more magnets you add ) does not apply to solenoids/electromagnets.
    So the diagram for that post is below .
  ______
Post by: guest1289 on April 14, 2017, 09:47:53 AM
  Thinking of different ways to achieve  propulsion( rotation, or any propulsion ) via electromagnetic-fields( generated from electricity ) acting against permanent-magnets,
   Or,  via electromagnetic-fields( generated from electricity ) acting against any other forces,  like for example,  against electric-fields from electrets
   Or,  via  permanent-magnets acting against  electric-fields  from electrets
   In the diagram below, the central-grey spheres are  permanent-disk-magnets,  and they are surrounded by a  loop-of-DC-current,  or by a   half-loop-of-DC-current  in the second version
   I don't know if the diagram produces any rotation,  but the reason I have drawn it is to try and visualize the  electric-field  emitted by the  loop-of-DC-current( or by a half-loop in the second version ),  to try and see if it should cause any rotation.
   I have read on this site, and on other places on the internet that  electric-fields  and  the  magnetic-fields  from  permanent-magnets  do in fact interact, in terms of achieving a propulsion effect,  it's definitely something I have found almost no information about
  Another possibility for that diagram could be to replace the  central-grey spheres which are  permanent-disk-magnets,  with  electrets
Post by: guest1289 on April 18, 2017, 02:37:20 PM
     I avoid including advanced electronics or integrated-circuits in the designs I post on this site, since there are often simpler ways of achieving the same effects, and/or I have little knowledge of electronics/IC's
In previous posts on this thread I posted my  design/designs  for a  solid-state  version of my  magnet-motor-3.5,  and in those designs I could have used  a  sequential-switching-component,  to switch from one coil  and to the next coil  and to the next coil  etc
    Maybe a  'jacob's ladder' spark-gap  type device  could be the sequential-switching-component,  and if a device like that could be miniaturized then maybe it could be a future electronics-component like  capacitors/diodes/resistors
Post by: guest1289 on April 18, 2017, 04:00:31 PM
   In the diagram below of my  Spring-powered-version  of my  Magnet-motor-3.5, it shows the exact spacing between the  Spring-Powered-Components  that would ensure that there is   never   more than  one   Spring-Powered-Component  going  up-hill on  1  down-up  section of the track,  in order to minimize the  up-hill  section as being a sticky-point in the motor,     however,    I'm not sure if that would actually make a difference in terms of the over-all forces occurring in the motor.
    AND ALSO : In the diagram below,  I have connected 2 identical motors with a    connecting-rod,  this further replicates some advantageous forces occurring in my magnet-motor-3.5.
        This connecting-rod  could?  make it possible for one motor to help the other motor get over a  sticky-spot  especially when the first motor has no  spring-powered-component  going  up-hill  on the  relevant  down-up  section of  the  track  ,   this,  and  maybe the  spacing-concept in the previous paragraph,  are very important concepts  translated  from my magnet-motor-3.5  .
   IMPORTANT NOTE :  In a previous post I mentioned that it may be necessary to  add a  2nd-'Identical-Spring'  to each  spring-powered-component   to eliminate the problem of the force from springs decreasing as they expand  :
QuoteI then came to a conclusion that the  Spring-powered-version  'may' have even less chance of functioning than I thought,  because the force from a spring decreases as it expands.
Post by: guest1289 on April 18, 2017, 04:55:59 PM
    Perpetual-Motion Of Gases Powered Generator
    In gases( and liquids ) the  'atoms / molecules' never stop moving.
    My idea( as far as I know) is that some type of gas would be held( maybe under pressure ) in a container lined with a   'special-material'( something similar to photo-voltaic materials )
     When a gas-atom  collides with the   'special-material' ,  a photon( or part of the electron ) goes into the  'special-material' and causes electrical-current to flow in the 'special-material'.
Note : Obviously the  'special-material'( something similar to photo-voltaic materials ) should not have any protective layer of glass or plastic
    I choose gas rather than liquid since I assume  that gas-atoms collide with things at a much higher velocity than liquid-atoms.
    When an  atom-of-gas  bumps into  something,  it is always the electron-shell  of the atom-of-gas  that bumps  into something,  so as far as I know( or guess ) this is  'one'  reason why  electrons are  continuosly  loosing and gaining photons( each time electrons loose or gain photons they go into a higher or lower orbits )
Post by: Zephir on April 18, 2017, 10:10:18 PM
In my theory the overunity can be generated from thermal fluctuations by lowering their dimensionality at some point. If we put a charged capacitor inside the hot gas, then the molecules of gas will hit the capacitor and they will induce voltage spikes into it. This noise can be measured as a common thermoelectric noise within electronic circuits and it indeed decreases with temperature.
The problem is, this noise cannot be rectified and utilized in any way, once the rectifying diode remains as hot, as the gas, the energy of which we are just trying to utilize. Once we will cool this diode, then yes, the noise of diode will be lower than the thermoelectric noise and we would get some voltage on it. The problem is, such an energy production will be just another form of thermoelectric pile, because the diode will gradually heat itself just with the electric noise, which it rectifies. So we must cool it for to keep the production of energy running and this cooling would also require an energy.
In this respect it's interesting, that the we can drain a quite substantial energy flux by cooling surface with cosmic space. Recently such a surface has been constructed (http://physicsworld.com/cws/article/news/2014/nov/27/device-cools-itself-in-the-blazing-hot-sun) by layering of nanosurfaces and it keeps cool itself between 4 and 5 degrees below the surrounding air temperature - which is already temperature difference worth of utilization with classical thermoelectric Peltier cell.
For example, Ann Makosinski (http://www.cbc.ca/news/technology/body-heat-powered-flashlight-takes-teen-to-google-science-fair-1.1317745) did use (https://www.googlesciencefair.com/en/projects/ahJzfnNjaWVuY2VmYWlyLTIwMTJyRAsSC1Byb2plY3RTaXRlIjNhaEp6Zm5OamFXVnVZMlZtWVdseUxUSXdNVEp5RUFzU0IxQnliMnBsWTNRWXA2ZVVBZ3cM) power converter integrated circuit, LTC3108 (http://cds.linear.com/docs/en/datasheet/3108fc.pdf) for it. The circuit contained FET's that would oscillate at voltages as low as 20mV. When used with a recommended   transformer, the IC would provide well over 2.5 volts AC. Ann got for 50 mV DC from the Peltiers about 6 mA at 5 Volts AC which was sufficient to light the LED. The result was a bright light at just 5 degree Celcius of Peltier differential.
But such a way of energy generation isn't still free energy in classical sense, overunity the less. We are just draining an energy from accelerated cooling of Earth with cosmic space, i.e. we are still utilizing solar and geothermal energy - just in indirect and diluted way not worth the effort.
In my opinion the situation with utilization of thermoelectric noise will change, if we wouldn't collect voltage fluctuations with 3D resistor, but with some thin narrow 2D plate (graphene layer) or even 1D nanowire (carbon nanotube). The trick here is, once we constrain electrons in their motion in one dimension, then the energy of their vibrations increases in remaining dimensions. The thermoelectric noise at the end of such nanowire will be therefore larger, than at previous 3D case and we can rectify it even with diode at the same temperature. Recently so-called time crystals (https://www.reddit.com/r/Physics_AWT/comments/5rmgsm/scientists_create_a_new_kind_of_matter_time/) (a miniature perpetuum mobiles in essence) were observed, which are working on the same principle (constraining motion of charged particles with Penning or magnetic trap).
Because the PN junction of diodes is actually quite narrow, even common LED diode (https://phys.org/news/2012-03-efficiency.html) can exhibit a tiny overunity, once it gets polarized in the proper direction. Of course, such an effect is quite weak at the case of single diode - but we can multiply it with usage of graphite nanolayers or nanotubes suspended within charged electret - which is IMO the principle, on which the Steorn Orbo Cube technology (https://www.reddit.com/r/Physics_AWT/comments/4u4ljs/graphite_based_thermoelectric_generators/) was working.
Post by: guest1289 on April 21, 2017, 12:51:43 PM
  Below is a diagram of some designs I made which are intended to cause either gas( or liquid ) or aether,  to propel itself in just one direction,  just through the  perpetual-motion characteristic of  gas( or liquid ) molecules/atoms.
  I have some slight reason to think that the point near the triangles marked  'interaction-point',  is the point of  'maximum-pressure-?' where gas/liquid/aether would tend to be ejected   from the triangles, although of course material would equally be drawn in again after ejection
  I also included a half-dome design
   I assume aether would have no reason to have the perpetual-motion characteristic of  gas( or liquid ) molecules/atoms,  but I included it in this description anyway.
   ( and I assume there's alternate theories that aether is always darting around all over the place )
    For an  aether-version,  the walls of the containment-shape of the device would either be magnets or electromagnets or electrets
   My/these  designs  also have some sort of similarity with the way the surprising electromagnetic-space-drive tested  by the space-agency functions,  keeping in mind the shape used by the  electromagnetic-space-drive ,  although the similarity becomes ambiguous/confusing
   UPDATE : I have now attached another diagram to this post,  in which I have optimized the design
                  Also note,   the gas( or liquid ) or aether is intended to flow inside a closed loop for power generation or for whatever else
Post by: guest1289 on April 21, 2017, 01:31:12 PM
   Is it correct.  that  if you have a   radio-receiver  that has been tuned to be in resonance  with a   specific-radio-transmitter  that the  radio-receiver  will bend the  radio-waves  trajectories  in order to draw them into the  receiver,
       In other words,  that the  radio-receiver  will behave like a magnet attracting iron-filings that have been thrown in the air
   that would disprove science much more than magnet-motors
   Is it on youtube etc
    If this is correct, and keeping in mind that different components inside devices like computers transmit at different frequencies and I assume at different  'resonances',  then that could shut down individual components of computers and other devices
    And keep in mind that living things also emit radiation,  do they have a resonance
    What about a hot cup of water,  could you theoretically have a  radiation-receiver that would be in resonance with that hot cup of water,  and could it freeze it
    (  could it refreeze the earths north / south pole,  or freeze volcanic lava,  and if a  tornado has resonance could it turn of a tornado or other weather modification etc ,  clouds/thunderclouds,  deep earth electrical currents  etc)
    In tests to determine the resonance of different objects, the object is either sitting  or held by something,  would that not affect it's resonance,  would it be better to magnetically or diamagnetically or electrostatically levitate it instead ,  although even that could affect it's resonance
Post by: seychelles on May 06, 2017, 10:46:36 AM
A new magnet motor by LARSKRO.
https://www.youtube.com/watch?v=s18h5X2sDZU&feature=iv&src_vid=71vtcl-G4dw&annotation_id=channel%3A58793cbf-0000-2
Post by: ramset on May 06, 2017, 11:26:58 AM
Seychelles
is he a member here ?
I see a bit different spelling?
he says this
Thanks. The rotor is made up of 8 x 12pcs. 0.3mm transformator iron sheet,  as you see.
The magnets must be adjusted in strength, so transformer sheet iron does not become saturated, otherwise it will not run.
No, batteries or no electric motor at all.
can you invite him here for a respectful discussion?
he does seem to contradict himself in his introduction?
Thx
Chet
Post by: guest1289 on May 07, 2017, 01:27:06 PM
Quotehttps://www.youtube.com/watch?v=s18h5X2sDZU&feature=iv&src_vid=71vtcl-G4dw&annotation_id=channel%3A58793cbf-0000-2
  That  magnet-motor  was apparently,  either  built from plans purchased from  gravityflight,   or,   maybe the person who made the video is the person who supplied the plans to gravityflight
  From what I saw on the video.  I wonder if maybe it is  simply  'broken-symmetry-of-sticky-points' and a  propelling-force,   just like many of my  magnet-motor designs
   - Not sure if I'm correct,  I notice that swirls have been cut into the wooden? disc,  to make  flexible/springy arms,  I wonder if they are really necessary
   Obviously( or I assume ) this idea of  'broken-symmetry-of-sticky-points' and a  propelling-force,  goes back many years,  although at this exact moment I can only think of one  magnet-motor( famous, and was patented ) which used the concept,  I wonder if there were more and how far back the concept dates
   An impressive video if it's genuine,  it would be great if  someone could  start a thread especially for this  magnet-motor,  since not everyone will check this  thread ,   however,  keep in mind, :
  ________
guest1289
QuoteIs it correct.  that  if you have a   radio-receiver  that has been tuned to be in resonance  with a   specific-radio-transmitter  that the  radio-receiver  will bend the  radio-waves  trajectories  in order to draw them into the  receiver,
  Obviously I was wondering if people have devices that get  free-energy from radio-station-broadcasting-towers etc,  things that get more energy and work further away than  fluorescent-tubes
   (  And I assume this is different to what people who had  high-power-electrical-grid-towers  on their land used to do,   they would bury electrical-cable  around the tower to get  free-energy from the tower via inductance )
   I did not find  any  proven or replicated  experiments to confirm this works( referring to the concept/concepts  on     http://amasci.com/tesla/tesceive.html     )
   If there's any reputable youtube videos ,  please post links
   ( It seems that this is,  or may be how  'Tesla's Power Receiver' worked,  and also,  reading Dollard's work is maybe too difficult for me )
   The link below is the most solid material,  or written in the most understandable terminology,  I have found to date on this concept :
   However,  keep in mind, that there seems to be 2 different  concepts in this topic :
     ( 1 ) - You emit a radio-signal( same amplitude and frequency, but offset phase,   as the target  radio-signal), to funnel the  radio-signal from the  target-transmitter into your device to  gain  the energy
     ( 2 ) - Your equipment funnels in the  radio-signal from the  target-transmitter by a method other than 'emitting a radio-signal'  ,   so your device can gain the energy,  I assume this would be the most difficult method
      Regarding method  '( 2 )' ,  I think the following text in that webpage describes a method to achieve it :
QuoteThis is not "radio," where wavelength is the same size as the components. This is "circuitry", where wavelength is huge, and circuits are small, and the antenna operation more resembles "AC wiring" rather than "EM radiation."
     If that  quoted-text  above does not describe a method to achieve method  '( 2 )',  I know that it is in that webpage because I had found it there a week or two ago,  however,  now I can't specifically remember where in that page it describes it.
      -  I thought it was in the  'updates' on that page,  now I can't remember or be sure where on that page it was
     Tesla had stated somewhere  that the  source of the energy from his overunity? invention( was it one of his inventions related to this ) was  not  'electromagnetic' ,   that makes me wonder if the source of the energy from his overunity? invention  was  'gravity',   that his  Solid-State-?  invention converted gravity to electricity,
        -  Is it possible he visually confirmed this by observing an  anti-gravity-effect
    And, if a  radio-receiver-device was to be  funneling energy from a  radio-transmitter-device as described on  http://amasci.com/tesla/tesceive.html  ,    would there be a physical pulling force between them,    for-example,     if the  receiver-device   and  transmitter  were on free-floating boats,  would  they move toward each other,   either like an artificial version of gravity,    or,   as a possible alternate explanation of how gravity works,   if so,   then could this be an idea for producing  anti-gravity
Post by: dieter on May 08, 2017, 02:43:15 PM
The only thing like that I know from Tesla is his "Magnifying Transmitter" Patent. Professor Turtur tried to replicate it, but stated the gain is in the 1000th of the actual sender energy, and, Turtur has problems with his reputation. But then again, being a professor researching in the OU field does ruin ones reputation quickly anyway.
Post by: gotoluc on May 09, 2017, 08:57:36 AM
Quote from: ramset on May 06, 2017, 11:26:58 AM
Seychelles
he says this
Thx
Chet
Hi Chet,
Larskro wrote this in the videos description box (first thing below video) you need to click show more to see it all.
self running devices are a fake, they CAN´T run. This magnetmotor is a replication of a Gravimag magnetmotor. I want to start a discussion . I am so tired of all the videos that declares - self-running engines, magnetmotors, free energy devices, overunity power, vacuum energy, selfpowering, gravity motors, perpetual motion free energy, etc. - Do not be fooled by these videos. Nothing will work without input of energy. There can never get more energy out than coming in. This is a fact. This is a law of nature. Everlasting machines can never run. Do not waste your time with replications of such things. Sorry for your energy dreams. Free energy comes from the SUN and wind.It is my opinion. Have a good day. Larskro
and in the below comments a youtube user aviatrix2 posted a good explanation of how it works.
He's just spinning the shaft with one finger from below.  Watch him squeeze it tighter when it starts.
A good guess since the shaft is so long
Kind regards
Luc
Post by: Magluvin on May 09, 2017, 10:15:58 AM
Quote from: gotoluc on May 09, 2017, 08:57:36 AM
Hi Chet,
Kind regards
Luc
Back when Mh was encouraging others to build fake motors 'for learning purposes' larskro had a simple motor with 2 coils wound on hex bolts mounted in a base with a magnet rotor an led and reed sw.  I was a little intrigued and began questioning him on it. And Mh sure enough joins in. Thats what when i thought maybe Lars was one of his recruits. lol
So larskro finally gave in and said there was a battery inside one of the coils by laying a AAA batt next to the motor.  The battery was too big to fit what was shown. I asked him to show the battery that was actually inside the coils and he would not show it. Then he drew a circuit that couldnt work as a pulse motor. Then he redrew the circuit again and it had issues. ??? :o Then Mh went on to describe the circuit saying that the led was only getting its power from the battery not the coil collapse current as his own drawn circuit wouldnt allow that. Then I freaked. What the heck is really going on here? The guy that built it cant describe the hidden pulse motor circuit, twice,  nor provide an accurate battery size designation yet kept specifying it was a fake. And then Mh is simply stating that the led is being lit by a 1.5v battery of which cannot happen on its own. So it all had me sucked in due to the mass of terrible info given all to the point of me thinking, maybe its a real self runner. Otherwise why all the dodging and misinfo splattered all about.  Mh and I both got put on Mod for the arguments of that time.
I dont care for the attitude of guys like larskro. There is enough fakes out there that nobody needs to do it for years to further beat it into peoples heads. And MH at the time was actually recruiting others to do just that!!  Why why why? ??? I know many people that dont have any technical knowledge, yet they have ideas on free energy. The simplest kinds that we all know dont work so far but they have a general idea. And if there is FE out there, Id rather not have peoples minds deliberately molded to the 'it cant happen' mindset when really we just dont know for sure yet.
Mags
Post by: guest1289 on May 09, 2017, 07:03:04 PM
  So the
   magnet-motor was not genuine .
   And the last post indicates that  'no'  magnet-motor  has ever worked, which would include my designs.
   Even if someone now posts to say that some magnet-motor's  have worked,  they will have no way of proving it satisfactorily,  so it's probably a waste of time saying either way
   And what about  All-Permanent-Magnet-Full-Levitation, you've got two of the most reputable members on this site stating they achieved it at home,  one even built it as a successfully-functioning-bearing  ,  and yet no one posts any pictures,  could it be for the same reason why no one posts proof of functioning  magnet-motors
  _______
dieter
QuoteThe only thing like that I know from Tesla is his "Magnifying Transmitter" Patent. Professor Turtur tried to replicate it, but stated the gain is in the 1000th of the actual sender energy, and, Turtur has problems with his reputation. But then again, being a professor researching in the OU field does ruin ones reputation quickly anyway.
   Sudden stupid thought( I have not yet googled or read anything about Tesla's  "Magnifying Transmitter" ) ,  what if the Tesla  "Magnifying Transmitter"  used the earths-atmosphere  or  Aether  as  a  'Secondary-Coil-With-Core'  and the effect is intended to  propogate/increase with distance( for-example,  propogates/increases from air-molecule to air-molecule,  or from aether-particle to aether-particle ),  although I'm guessing that for whatever reasons it 'may-?' not  'all' have worked as well as intended
   -  It could have been a variation of my idea
   -  So it would have been at a very specific and high-frequency( maybe an unusually very high frequency )
   -  Keep in mind,  that it turns out that most-?/many-? things do not have just  'one'  RESONANT frequency,  they have many-? or is it numerous-?,  or maybe within a frequency-range or ranges it might be hard to find frequencies that are not their resonant-frequencies
   Have you ever thought of moving to some sort of warmer climate,  I know cold weather is great for letting your creativity/inventiveness  run at top-speed because you've got natural-cooling from the environment,  but life is usually so difficulty there you're potential usually goes to waste and amounts to nothing,  in other words you achieve nothing( not just in overunity ),  unless your circumstances/affluence are already higher than average( in which case they are often high achievers )
   (  I tried moving north last year,  but was quickly informed( I can't find a better term at the moment ) that that was not an option for me,  ironically,   if I would have moved to a country north( from where I live now ) at any time prior to  November-2008,   I would have had 'no'  'significant'  problem in living there .
      A second reason why I tried moving north last year was to see if I could move into more productive/different circumstances,  since reasons why I am so unproductive( low-achiever ) are not what they seem, or a bit too hard to explain or be understood,  even though they are so simple )
Post by: guest1289 on May 16, 2017, 06:18:35 PM
   On the subject of antigravity, or propulsion
   Posting my post :
   http://overunity.com/17270/a-free-or-cheapest-method-to-trade-in-stock-forex-or-penny-stock/msg506260/#msg506260
   from the other forum,  onto here :
   Capacitor Propulsion in a high-vacuum :
    https://www.youtube.com/watch?v=CGN65lse5yE
    And,  in a lower vacuum :
    https://www.youtube.com/watch?v=hw1N5wNzJk8
    They say it is very difficult/costly to replicate the same vacuum as space, on earth,  so why do they not just test this Capacitor-Propulsion  and others up in space,  maybe because it might work
     The tests above may indicate indicate it is not( or not the same as )  ion drift or ion wind being generated in air
    It may work because of one of the examples in the  Faraday-Paradox( there is a wikipedia page for the  Faraday-Paradox ).
      If  you  spin a   Disc-Shaped-Magnet( near  'nothing' else ),  an  electrical-current  will be generated onto the magnet,  and can be collected from the magnet.
     It works because  the  magnetic-field of the   Disc-Shaped-Magnet  does not spin with the magnet,    in other words the magnetic-field  stays stationary and causes friction( induction ) with the  Disc-shaped-Magnet  which generates an electrical-current onto the magnet.
   So the magnetic-field  is ?  made up of  Aether or stationary-? particles sitting in a grid/lattice pattern in space.
   Therefore it is possible  Capacitor-Propulsion could be pushing against Aether or stationary-? particles sitting in a grid/lattice pattern in space.
   The webpages below do not mention any tests carried out in space
   https://en.wikipedia.org/wiki/Electrogravitics
   https://en.wikipedia.org/wiki/Biefeld%E2%80%93Brown_effect
   https://en.wikipedia.org/wiki/Thomas_Townsend_Brown
   The following quoted text is from my post :
   http://overunity.com/17203/magnetic-and-gravity-motor-update-and-notes/msg506161/#msg506161
QuoteTesla had stated somewhere  that the  source of the energy from his overunity? invention( was it one of his inventions related to this ) was  not  'electromagnetic' ,   that makes me wonder if the source of the energy from his overunity? invention  was  'gravity',   that his  Solid-State-?  invention converted gravity to electricity,
    That could be another method of anti-gravity,  emitting a field that is in resonance with gravity but somehow out of phase with it,  or should it be completely synchronised/in-phase with gravity
   The following quoted text is from the same post :
QuoteHowever,  keep in mind, that there seems to be 2 different  concepts in this topic :
    So number ( 2 ) method may-? be a method of anti-gravity without needing to emit a field,  and may be be different to  gravity-shielding,  I think it is mentioned on :
     That  webpage above is where I became aware of number ( 2 ) method, and it makes no reference to gravity,   except for a link  your can find by searching for the  text  "gravitation"
    So I just made some assumptions/theories from that page
Post by: guest1289 on May 16, 2017, 08:00:46 PM
     Still on the subject of anti-gravity, or propulsion .
     I had thought that  Tesla had either found a  solid-state  method  way to turn gravity into electricity,  and or that he had discovered an anti-gravity( or propulsion ) effect related to this.
     I was probably, or possibly wrong.
     Tesla famously said somewhere,  that  wireless  waves/transmission were  not  'electromagnetic' ,  rather that it was actually  'sound' in nature.
      (  I wonder if he actually said,  or meant to say,  that it was  'like' 'sound' in nature  )
      Sound-waves are described by science, as mechanical,  a wave made of the compression of the medium in which they travel.
      And yet I remember reading in more than one source,  that some people do actually regard  sound-waves  as being  'part of the electromagnetic-spectrum',  or 'somehow'  'part of the electromagnetic-spectrum'.
       -  I assume that a  sound-wave  does actually carry an amount of energy,  so maybe that is why some people can fit it into their version of the 'electromagnetic-spectrum'.
      And as far as I know, gravity, or  gravitational-waves  are also somehow described by science,   as mechanical,  a wave made of the compression of the medium in which they travel.
     Obviously I assume it's more complicated than that,  or that a definitive answer is not actually known.
   __________
   Applying the 'broken-symmetry-of-sticky-points' in  my Magnet-Motor-3.5,  to the designs of :
     - The Bessler-Wheel
     - A  Spinning-Generator
    The Bessler-Wheel( using the 'broken-symmetry-of-sticky-points'  principle in  my Magnet-Motor-3.5 )
    -  Note : I am assuming  the  Bessler-Wheel  contained no magnets,  and for this idea I am  'not'  including any magnets.
    -  I wonder if a possibility of how the  Bessler-Wheel  functioned was that it had  more  than  one  'row' of  'identical-devices'  hidden inside  the wheel ,   all  on the same shaft .
       The  result would be that the sticky-points from one  'row'/'wheel'  would  actually  help another   'row'/'wheel'  to get  past it's own sticky-points,  and if you have enough   'rows'/'wheels'  on the same  shaft,  the whole shaft should spin as  freely as if there were  'no'  'rows'/'wheels'  on the  shaft( only the weight/inertia would be noticed ).
       I  'may' see a difference here to my  'Magnet-Motor-3.5' ,  because in this  'Bessler-Wheel'  idea  I  think  I 'may' see that the  propulsion-forces  would be affected by this set-up  where as in my  'Magnet-Motor-3.5' I don't think the propulsion-forces  would be affected .
       It does have some significant differences to my 'Magnet-Motor-3.5',  so I don't know if this guess of the 'Bessler-Wheel' is valid.
    A  Spinning-Generator( using the 'broken-symmetry-of-sticky-points'  principle in  my Magnet-Motor-3.5 )
       - Generators( and electric-motors ) have cogging-torque, sticky-points that can be noticed when the device is not powered.
       - So, my-? idea( I assume commonly known ) is   'simply'  to put multiple generator-wheels  on the same  shaft,  but not having the coils from the different generator-wheels  aligned  with each other,  rather,  that they are completed  UNALIGNED  with each other.
           The  result would be that the sticky-points from one wheel would  actually  help another wheel to get  past it's own sticky-points,  and if you have enough generator-wheels  on the same  shaft,  the whole shaft should spin as  freely as if there are  'no'  generator-wheels  on the  shaft( only the weight/inertia would be noticed ).
Post by: guest1289 on June 27, 2017, 07:53:04 PM
guest1289
QuoteA  Spinning-Generator( using the 'broken-symmetry-of-sticky-points'  principle in  my Magnet-Motor-3.5 )
    Edit : The site went down as I pressed to post this post
              ( I assume people had already thought of this before I posted it )
    I think that some people claim that this theory cannot work,    because when each coil( with or without a core ) is pulsed,    it instantly becomes an   electromagnet,  which temporarily 'sticks' to the magnet( or electromagnet ),   so that this  becomes a secondary set of sticky-points which would cause this theory to fail.
      But I think this theory would / may still overcome this  secondary set of sticky-points( made of electromagnets ),  just the same as the first set of sticky-points.
    I do not actually read posts on this site anymore, so I don't know if anyone has already posted the following idea.
    I have another version of this idea/theory,  and that is that instead of using  coils( with or without cores ),  it would use  Radially-Designed-Electrophorus's  all  offset from each other but sitting on the same shaft.
    This idea would  use  Permanent-Electrets like those used in  microphones.
    (  obviously  electrophorus's  still  have that very strong sticky point when you are lifting the plate up from the electret,   but they  do not additionally  become  electromagnets ,   so,  they only have one set of sticky points.
Post by: guest1289 on June 29, 2017, 04:58:03 PM
    Imploder For Producing  'Strangelets'
     I think(  not sure ) that mine, and other peoples  overunity  designs/devices( excluding my purely magnet-motor designs,  but  including my  broken-symmetry-of-sticky-points-electrical-generator ) ,  would get the  free-energy/extra-energy  from the environment.
     I think it would be in the form of  photons?/quarks?  floating or moving  in the vacuum ,  in other words  photons?/quarks?  would  be sucked into the iron-cores( cores sitting inside coils ),  or maybe sucked directly into the coils ,  or other components.
     (  I had read about research where it was claimed that a  specific-frequency for an  iron-core had produced  overunity,  and that research( or article about it ) claimed the   iron-core  was drawing the  overunity/extra-energy  from it's environment.   )
        But many people believe that the  free-energy/extra-energy  would come from  ions  floating in the environment.
        If they are correct,  then these devices would either not work in the vacuum of space,  or would produce much less free-energy,  even though there is still a quantity of  ions per square-meter  in space.  )
      My idea is that these devices could be used as the basis for devices to produce  'strangelets'( matter  which has the density of protons/neutrons ).   Although I assume that past a certain size 'strangelets' would sink straight to the earth's-core, if not causing any other problem.
      Maybe one method,   would be to  'very-suddenly'  disconnect a  'Secondary-Load'( energy-consumer ) connected to the  overunity-device,   'Note'  that  this  'Secondary-Load'  would not be a  'load'  that  spins  or powers  the  overunity-device,  it would just be an energy-consumer,
       SO THAT  then,    photons?/quarks?  being sucked into a specially designed   'electromagnetic-cone'  would be compressed together to produce  strangelets .
      My following idea is not completely logical :
         - My original idea was that if an   'electric-motor'  was  the   'Secondary-Load'( energy-consumer ) connected to the  overunity-device,   'Note'  that this  'electric-motor'  would not be the  'electric-motor' that spins  the  overunity-device,  it would just be an energy-consumer,
            SO THAT  then,    if you would  then  use  a  3rd-electric-motor( which is not electrically connected to the  overunity-device )  to  spin(  via gear-wheels or something )  the   'Secondary-Load'/'electric-motor'( energy-consumer )  MUCH FASTER  than  it is actually being powered at,   that  that would cause a  'VERY-UN-NATURAL-ENERGY-DRAWING-EFFECT' ,   and result in the production of a  strangelet.
            However,  a problem with this particular version of the   'Imploder-Idea'   is that you may not be certain where abouts in the  overunity-device  the compression of photons?/quarks? may occur( as a result of the  'VERY-UN-NATURAL-ENERGY-DRAWING-EFFECT' ),  so that you may not be sure where in the  overunity-device  to put something like an  'electromagnetic-cone' to compress  photons?/quarks? .
   Note :  Yes,  I know or assume,   that photons?/quarks? have no electric-charge and that they are probably not  affected by magnetic-fields,  so the use of  an  'electromagnetic-cone' would very possibly be useless.
               These types of details are things that I would probably never bother studying,  for various reasons  etc.
Post by: guest1289 on June 29, 2017, 06:41:10 PM
    The  Negative-Resistor
    I  thought of  another possible  answer as to how the 'Negative-Resistor' described on   http://www.cheniere.org/misc/kron.htm  may have worked .
    I thought that it may have been a type of  cathode-ray-tube,  but obviously not used to produce images,  instead they may have used  crt's just for the beam of  electrons.
    Normally in wiring/conductors  electrons are apart from each other,  scattered about,   so that their  electric-fields( electro-magnetic-fields? ) are  diluted? by the wiring/conductor material.
    Electric-Current  is primarily  composed of    'Electromotive-Force'( which is made of electro-magnetic-field?, energy-plasma?, photons?/quarks? ),  although the source of the 'Electromotive-Force'  is  electrons.
    So,  If you have a beam of electrons in a vacuum, like in a  cathode-ray-tube,  you have a very un-natural  situation,  it is like a line composed of the  most efficient-batteries in existence,  so if you could minimize energy losses enough,  in a closed-circuit  containing the  cathode-ray-tube,   it could maybe be an  overunity  and/or  self-running-device,
    Especially when you consider that the   number of electrons  in the beam of the  CRT  will not be  soaked up by the wiring/conductors  of the closed-circuit  because usually these materials have exactly the number of the electrons that they need and they will resist absorbing more than they naturally require.
    PLEASE NOTE :
         - Up until a year or so ago I read and understood via  Wikipedia's-pages  that  'electric-current'  is primarily composed of    'Electromotive-Force'( https://en.wikipedia.org/wiki/Electromotive_force ) flowing through conductors,  and that electrons merely drift through the conductor,  although I assume that the source of the  'Electromotive-Force' is the electrons.
           Now on  Wikipedia's-pages  I read that the electrons flow in the opposite direction to the  electric-current.
           Not only has  Wikipedia  possibly changed what I read about 'electric-current'  being primarily  composed of    'Electromotive-Force',   but it has also become more complicated.
           I ASSUME THAT WHAT I ORIGINALLY READ ABOUT  'electric-current'  being primarily  composed of    'Electromotive-Force',  is not now being suppressed ,  I don't know.
_________________
     CRT Curiosities
     I had been thinking about crt's,   and the more I thought about them,  the more unexplained and curious they become,  but now I forgot some of my questions etc.
    One important question I can't find the answer to,   is that I cannot see how a closed-circuit is formed to allow the  electrons  hitting the  'phosphor-coated-tv-screen'   to be directed back into the  tv-circuit,   are these just wasted  electrons that  vaporize  when they hit the  'phosphor-coated-tv-screen',  so that the  'wall-power-socket'  is providing a constant supply of  100%-disposable-electrons,   that's totally different to how I thought electricity works,   and I never realized that  electricity can work that way.
      - Maybe this is some kind of  quirk  of  Alernating-Current
     -  I assume it's not some type of  knowledge-suppression,  and  that the truth is that it is actually  photons or  'pulses-of-electromotive-force', that are actually hitting the   'phosphor-coated-tv-screen',  instead of electrons.
         I'm sure there are lot of scientific-tests existing proving it is actually electrons,  and not anything else.
          -  If it was photons or  'pulses-of-electromotive-force', that are actually hitting the   'phosphor-coated-tv-screen',  then  why would a handheld-magnet  be able to warp the image on a crt,  since photons are un-affected  by purely  magnetic-fields.
     Also,  exactly how can a  handheld-magnet  warp the image on a crt ,  electrons only have an electric-field,  and that electric-field  is affected by the  electro-magnetic-fields  of the  electro-magnets  built into the  crt,   to direct the electron to a specific spot on the tv-screen
     Although obviously,   the source of the  magnetic-field  from the  handheld-magnet  is actually electrons.
    Note : Yes, it seems that probably,  the problem is that I don't sufficiently understand how a crt for tv's works,  despite reading the  wikipedia-page,  that's not a criticism of the website, because I think the answer is probably on the  wikipedia-pages  for the devices that pre-dated the crt for tv's.
Post by: guest1289 on June 29, 2017, 08:12:02 PM
   Using The Time-Dilation Effect Of Centrifuge- Like Devices To Achieve Overunity
    It 'may' be  the Time-Dilation Effect that is responsible for various unexplained phenomenon that people have noticed about gyroscopes etc.
    Obviously from the center of a centrifuge-like device to it's outer rim,  the greatest time-dilation 'time-difference' occurs between the 'center' and the 'outer-rim',  if for example the radius is 5cm,  then at each .05mm increment of the radius the effect is very little or non-existent compared to that at the  'outer-rim',
      In other words you  cannot  point at any exact  1-point on the radius as being where this effect occurs,   you can only compare  the 'center' to the 'outer-rim'( or to any point on the  radius ),   so it's all relative,  almost like it's non existent( or maybe it is non-existent ).
    An Idea
    One of my ideas is to have the center of the  spinning-wheel  be a cathode,  and a point on the rim be an anode,  and have a spark jump between the two
     -  The spark could jump in a vacuum
     -  Or,  the electricity could travel between the cathode and the anode simply via a wire or via a superconductor.
     I'm thinking that since  individual-electrons  spin so fast in their orbits,  that they already experience  time-dilation,
     And that because  electric-current  travels so fast,   that it also  already  experiences time-dilation
            SO,  I'm thinking that mixing the  time-dilation  experienced by  electrons  and  electric-current,   WITH  the time-dilation  effect of  centrifuge-like devices,  that it  will possibly amplify some sort of effect of broken-symmetry  in the overall  situation,   possibly by adding( bringing )  electrical-current-material( electrons?, photons?, electro-motive-force? ) from another point in time 'INTO'  the  'PRESENT'-Electrical-Output( the closed-circuit means it's also the input ) of the device.
_______________________
   The Siberian-Coliu Device
   This device is too difficult for me to see how it was claimed to have functioned,  even though I read as much as possible,  since I have no actual educational background in anything related to this website.
   However,  what I'm really interested in is that  'composite-disk-magnet' :
    -  From a side-view( and from above ),  how does it appear on  magnetic-field-viewing-film
    - And,  much more interestingly( but directly related to the above ),   how does it behave in the  'Faraday-Paradox'  tests :
         -  'Faraday-Paradox'  test -   a disk-magnet  rotating on it's own axis and unaffected by anything else will generate  an electric-current onto itself,  because it's own magnetic-field stays stationary,  so it  acts  against the disk-magnet  to generate a current
         -   And the other 2  'Faraday-Paradox'  tests may also be useful
     The more I think about that   'composite-disk-magnet'  the more difficult it is work out what it is or what goes on,  theoretically,  if any device using it  functioned successfully,  maybe it is because this   'composite-disk-magnet'  is a  'round-about'  way of creating a  magnetic-field  that is constantly flowing around in a  circle-? ,  a bit like putting together two  u-shaped-magnets together to form a  donut-magnet,  but obviously not the same.
Title: Re: Magnetic, And, Gravity, Motor, Update, And Notes
Post by: guest1289 on June 29, 2017, 09:40:26 PM
guest1289
    Obviously ELECTRIC-MOTORS  also  have cogging-torque, sticky-points that can be noticed when the device is not powered.
    So you could use the method above in the  quoted-text  to eliminate that cogging-torque from  electric-motors,  by  placing multiple electric-motors on the same shaft etc,  etc,    HOWEVER,  I assume that the  result  would be that because the  cogging-points  would be neutralized that the electric-motors  would lose all grip and not turn at all-?,  but I am not actually sure what the result would be.
     Also,  in the idea in the quoted-text above :
Think about how easy it would be to increase the power output of that device merely by geometrical means,     in other words simply increase the  'diameter'  of the generator-wheels( and use the extra space to add more coils etc ),  so the power output is increased.
         ( And you could use 100%-floating magnetic-bearings,  using permanent-magnets or electromagnets( those would need an initial temporary  external power-input )
________________________
   Also,   the  "Electric-motors turning Electric-generators" device  would/may  not actually need to contain any  permanent-magnets at all,  since you could achieve it all just with wiring / electro-magnets,   so initially you would need to feed the  device with electricity  to achieve the electromagnetic-fields  and then the device would then self-run without needing any external input.
   I read an article some weeks ago that apparently this had already been achieved 2 or 3 years ago.
   Some weeks ago I read about a theory in classical-physics that explains overunity/free-energy( or at least in the situation that it explained it ),     basically the theory said something about particles that move through mediums in spiral-trajectories,  cause other particles in the medium to move in spiral-trajectories,  so that that effect is all amplified, repeated by each new particle caused to move in a  spiral-trajectory,   that certainly reminded me of my theory of what may happen in the  iron-cores( sitting inside coils ) of electromagnets or induction.
    (  I forgot to bookmark the website,  it may have been somewhere  on  http://amasci.com ,  or it may been some other site )
   To win against any debunker on this site that claims that no proof exists that any device has ever achieved  overunity and / or has been self-running,
     -  You should remind them of how easy it is to defeat the laws of magnetic-levitation,   simply by floating an appropriately shaped  permanent-magnet  in the center/above a  donut-magnet ,
        To make it easier,  my idea is to add a string to the bottom of the floating-magnet and then to simply add an appropriate-weight( that constantly floats, it never touches any other object ) at the end of the string so that   the floating-magnet  is merely kept in place via gravity,  this definitely defeats the laws of magnetic-levitation, and at least one member on this site confirmed that using the  donut-magnet  works
     -  Then you should ask the debunker why this method to defeat the laws of magnetic-levitation  does not appear on the  wikipedia-page  for  magnetic-levitation,  or why any other method that defeats the laws of magnetic-levitation does not appear on the  wikipedia-page  for  magnetic-levitation or  anywhere else,  obviously it's because of suppression,  I assume because the floating-magnet apparently also exhibits perpetual-motion
Post by: guest1289 on July 27, 2017, 07:39:16 PM
I think I don't receive all of my email, only some
Post by: guest1289 on July 28, 2017, 09:08:52 PM
  Just a clarification,  I think I don't receive all of my email, on my  external  email-address( john.backerwww@gmail.com ),  not referring to   overunity.com
   (  there would be no way of finding the cause etc )
Post by: guest1289 on November 01, 2017, 06:55:47 PM
One of 2 posts I'm making today
I assume I'm typing what everyone realizes
While thinking( not to build ) about using  FRICTIONLESS( I assume magnetic friction exists in them ) Magnetic-Gears( wikipedia.org/wiki/Magnetic_gear ),  as SPEED-AMPLIFIER-GEARS( like in a transmission etc ) ,   FOR
   -  An electric-motor to drive a  frictionless-generator(a generator that has no magnetic or electromagnetic friction),
   -  OR, for an initial wheel( no motor anywhere at all ) to turn a final wheel in SPEED-AMPLIFIER-GEARS, maybe with a flywheel
    ......to design an overunity device(referring to the above ),   I suddenly realized something that may directly explain what I typed about a little known part of  "classical-physics" that I mentioned on my post on this thread on -
     « Reply #33 on: June 30, 2017, 03:40:26 AM »
      As far as I remember,  it related to 'particle physics' ,  vortices,  or vortices made of  radio-waves,  electromagnetic-waves( different spectrum )
      I can no longer find what I read about  "about a little known part of classical-physics",  however,  what I realized ,   may  'explain'   all the  'unknown'  origins of overunity :
       -  such as devices relying on  electromagnets( etc ) containing  iron-cores
       -  devices relying on  speed-amplifier-gears
       -  centrifugal devices
       -  self-sustaining tornadoes, vortices
     Any point( away from the center ) on a spinning-wheel,  it travels through space( rotates ) faster, than the center of the wheel.
      So maybe,  think about an electron in an atom in an iron-core ,  with each higher orbit that that  electron can travel in ,  it may travel/orbit faster than at the lower orbits ,   if you think of it as a spinning-wheel( since usually electrons usually stay in the atom if they have no reason to leave )
       Electrons and their fields obviously interact with other things,  so with a higher orbit and therefore higher speed,   they will interact with things more strongly
       This may  mirror ,  what occurs in gear wheels,  this merely geometrical,  more outward point on the gear wheel,  may produce overunity just through geometry.
        So instead of just thinking about it in terms of electrons,  what about thinking about it in terms of electric or magnetic or gravitational fields.
        Could this cause self-sustaining tornadoes, or vortices, or even cause them to become larger.
     I also tried to think about this in terms of  Emitted Photons( I assume that this will not work with photons,  since they don't seem to be the same as a point on a  spinning-wheel,  away from it's center, but I don't know )
       -If you sit in an office chair in space,  and while you spin yourself around in the office-chair,  you throw a baseball away,   emit  a photon
     -  the baseball will not only travel directly away from you,  in direction 'x', it will also have the Sidewards-Direction-Of-Travel-'W'( CAN PHOTONS HAVE THIS SIDEWARDS MOTION ?)
     -  At 20-meters away from you, the baseball/photon,  will have a Sidewards-Direction-Of-Travel-'W' of 40-meters a second
     -  But at 100-meters away from you, would the baseball/photon have a  Sidewards-Direction-Of-Travel-'W' of   more  than  40-meters a second
     -  So,  at a sufficient distance away from you,  would the  baseball/photon have a  Sidewards-Direction-Of-Travel-'W' of   more  than  the speed of light
     -  Since a photon is no longer connected to the object that emitted it,  after it is emitted,  I assume that a   Sidewards-Direction-Of-Travel-'W'  would just remain constant, no amplification,  but this is not the same as electric or magnetic or gravitational fields,
Post by: guest1289 on November 01, 2017, 07:32:57 PM
Post by: guest1289 on November 01, 2017, 07:52:46 PM
THE 2ND OF 2 POSTS I'M MAKING TODAY
(   check on this page,  my      « Reply #36 on: November 01, 2017, 11:55:47 PM »        )
Electromagnetic-Eavesdropping of computer-screens,  would also affect people contacting owners of those screens,  or even people not contacting owners of those screens,  through browsing etc
( obviously this is the least aspect of  situation,  but anyway )
Imagine how it would affect electromagnetic-eavesdroppers themselves,  if very very detailed information and photos about them( etc etc............. ) appeared on the computer-screen they eavesdrop
How difficult would this be to do,  especially if a totally anonymous 'once-off' email-address was used.
(  I have no way at all of getting these details-etc  myself, and it would be just about the only way of affecting ......................... )
(   I have never received any such email,  and have never had any data on t--m,  only few details I have noticed indirectly about them  t--m on media )
Of course, I wonder if I would actually receive any such email if it was sent,  or if it would just be deleted at any point before I would check my email )
( If anyone wants to affect t--m for free,  good as possible )
Also,  My phone - 605 673 265 ( dialing code is 34 )
If anyone wants to send me 'very very detailed information and photos'  about the bnjmn-motor-generator,  and secodarily even about the p1-motor-generator( prefer about the bnjmn-motor-generator ) please do so directly to my email address :    john.backerwww@gmail.com
Post by: guest1289 on December 06, 2017, 05:51:57 PM
    My  blog   https://johnbacker.blogspot.com.es/
Post by: sm0ky2 on December 06, 2017, 07:50:49 PM
Quote from: dieter on April 08, 2017, 05:12:35 PM
But gravity isn't directly substitutable by magnetism. As there is no repelling in gravity.
It is this difference between two conservative fields, that allows energy to be extracted
between them.
I refer to this as the flux-to-mass ratio of a given pair of magnets.
It is related to the gravitational field, but of different magnitude and without the
time constant.
E=mgh and the mass and height lifted by the opposing magnets (maximum)
The greater the flux-to-mass ratio, the more mass is lifted higher.
Post by: sm0ky2 on December 06, 2017, 07:56:11 PM
@guess1289
You propose an interesting scenario.
What happens if we send an electric current through a wire
Around the circumference of a centrifuge
In the direction of rotation?
Technically (and I mean by technicality) we would have a
superconductor.
Post by: postingsite on February 24, 2018, 02:11:13 PM
Quote from: sm0ky2 on December 06, 2017, 07:56:11 PM
@guess1289
superconductor.
I wonder if there's a useful invention there,   an easier more convenient way( in various situations ) to achieve  'Quantum Levitation'
If,  by using your idea,     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA ),    could be achieved,    would that prove or disprove  the  'theory of relativity'  regarding constant speed of light
And what about if you implement your idea,  by already using superconductor at the start
Post by: postingsite on February 24, 2018, 02:26:54 PM
@guess1289
superconductor.
I forgot to add something to my post 15 minutes ago :
http://overunity.com/17203/magnetic-and-gravity-motor-update-and-notes/msg517155/#msg517155
Your idea ( possible invention,   may have been,  or may not have been,   inspired by guest1289  's post :
http://overunity.com/17203/magnetic-and-gravity-motor-update-and-notes/msg507817/#msg507817
( Note - Your idea does not seem possible using guest1289 's described design,  only the design you suggested may( or may not ) function successfully,  but may depend on the correctness of  einstein's theory of a constant speed of light )
For example,  as the centrifuge component spins,  coils placed on the rim of it's outer circle-perimeter could be acted upon by an external stator-permanent-magnet,  in order to power your idea,  and via your idea     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA ) could be achieved
Post by: sm0ky2 on February 24, 2018, 03:02:54 PM
I believe Einstein to be correct, in that c is constant for local space-time.
However, the actual value of c may vary from our location to another part
of the universe.
So, the experiment should confirm Einstein's predictions.
even though they may not be entirely correct.
Post by: sm0ky2 on February 24, 2018, 03:08:20 PM
Quote from: postingsite on February 24, 2018, 02:11:13 PM
If,  by using your idea,     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA (https://www.youtube.com/watch?v=Ws6AAhTw7RA) ),    could be achieved,    would that prove or disprove  the  'theory of relativity'  regarding constant speed of light
Well......  relativisticly speaking,
The electrical signal should be restricted to c
this May manifest as an increase in magnetic field intensity.
Proportional to the rotational velocity.
Post by: sm0ky2 on February 24, 2018, 03:10:02 PM
Maybe a decommissioned MRI machine could be recycled for a cost-effective test
Post by: postingsite on February 24, 2018, 05:59:15 PM
Quote from: sm0ky2 on February 24, 2018, 03:10:02 PM
  it seems MRI machine's use liquid-helium( and nitrogen ) for cooling the main electromagnet ( the main source of it's field ),  although,   I assume they do actually also spin some electromagnets
  alternatively,    place some coils on the rim of the outer circle-perimeter  of a  centrifuge( or other spinning component ),    then place an external stator-permanent-magnet to generate current in the coils,     in order to power your idea,     and via your idea     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA ) may be achieved
  Although,   I just realized,   that in your idea,  if the current and the wire are both rotating,  then any predicted effect may be nullified,  since they are both rotating
   however,  what if the  'quantum-levitation' effect is solely because of an increased speed of the current
   Also,  I'm not sure if this relates to the Faraday-paradox,  in particular,  the following post :
http://overunity.com/16769/faraday-paradox-revisitedmagnetic-field-rotation-question/msg490265/#msg490265
allcanadian
Re: Faraday paradox revisited,magnetic field rotation question.
« Reply #47 on: August 22, 2016, 09:19:00 AM »
QuoteWe have three scenario's.
1)only the conductive disk rotates relative to a stationary magnet... a voltage is induced.
2)the conductive disk and magnet rotate together...a voltage is induced.
3)only the magnet rotates... no voltage is induced.
Scenario 2 is unique in that we do not need a conductive disk if the magnet itself is made of conductive material. A magnet rotating on axis will induce an Emf or voltage from center to perimeter or vice versa thus a separate conductive disk is not actually needed.
  Although,  the following post may contravene the assumptions gained from the paradox :
http://overunity.com/16769/faraday-paradox-revisitedmagnetic-field-rotation-question/msg491719/#msg491719
    I have re-read that post,  and it seems correct,  in regard to the paradox,
Post by: sm0ky2 on February 24, 2018, 08:19:09 PM
Yes they must be supercooled to get them into their superconducting state
But Nibtinol wire is very expensive (niobium-titanium alloy)
So recycling it from an old machine would be cheaper.
Post by: sm0ky2 on February 24, 2018, 08:27:48 PM
@posting
I'm not sure if simply rotating a magnet in its own field will work
Most magnets ARE electrically conductive.
So why use a separate disk conductor at all?
someone would/should have noticed if it worked without the disk.
we would just draw current off the magnet.
Post by: carlcool on February 26, 2018, 03:58:41 PM
Greetings,  I have invented over unity, now what should I do? any advice.
Post by: postingsite on March 04, 2018, 06:50:32 PM
  I have re-checked how quantum-levitation works,  it involves more things than just the speed of the current,  it involves various other effects,  unless anyone wants to disprove their theories
Post by: sm0ky2 on March 05, 2018, 02:43:24 AM
Quote from: carlcool on February 26, 2018, 03:58:41 PM
Share it with the world, and free us of the energy crisis
Post by: profitis on March 05, 2018, 08:58:30 AM
" Greetings,  I have invented over unity, now what
should I do? any advice"
you must now quickly determine which branch of the nsa is going to be your friend: the killeen texas branch or the queens,NY branch
