The presented concept is a completely perpetual machine.
In this design there will be two inclined track systems .There will be also two seesaw system which will work to put the train on these inclined tracks and train will move with the help of gravity power.
These seesaw will get energy with a motor and this motor will work to press these seesaw systems.
HOW THIS DESIGN WILL WORK?
When the vehicle will be moved from right to left direction on the inclined surface then it will be started to move due to gravity.when this will arrived at the bottom track of seesaw then this seesaw will be balanced as the other arm of seesaw will have a counter weight equal to the train or vehicle.
Now this seesaw will work this vehicle on the second track which is inclined in opposite direction with the help of a motor as this motor will work to press the counter weight arm of seesaw and this seesaw will work as a lift up system to put the vehicle on the track.
In this way this mechanism will work turn by turn .When this vehicle will arrived at the bottom of left to right direction the same mechanism will work to put the train on the track again.
There will be some generators which will be attached with the wheel of Train coach(VEHICLE) and these generators will work to generate electricity .There will also a permanent magnetic linear generator system which will work to generate electricity.These generators will work on the equal polarity of magnets. In this generator only one magnet will be attached with vehicle and several with track in this way when vehicle will move on the track then these magnets will work to repel each other due to equal polarity to move a spring based generator.
The salient feature :
(1) this is completely a perpetual machine as we all know that there will be need of very very less energy to put the vehicle on the track due to balanced seesaw but the vehicle will generate more and more energy depending on the length of track system.
(2) the kinetic energy will be more than the input or out put will be more than input.
(3) A complete overunity tech .In this design there is no problem of inertia or friction.
I HAVE DONE MANY EXPERIMENTS ON THIS TECH AND ITS WORKS REALLY.
Seems,it must work.
This machine is based on gravity power and seesaw system.
We can make it more simple .
As per sketch there will be two seesaw system and both will be attached with a hook.This hook will work to hold the seesaw.There will a middle track which will work a pathway to transport the object from one seesaw to another seesaw.
there will be two motors which will work to inclined the both side seesaw systems by pushing the counter weight side of each seesaw.
When right side motor will work to push up the counter weight side of seesaw then it will be inclined and object will get start to move towards left side and arrived on the left side seesaw and now left side motor will work to push the counter weight side arm to inclined the seesaw and object will move towards right side.
In this way each seesaw will work turn by turn.
I would like to insist on some following point.
(1) The hook will work to hold the counter weight so that the seesaw couldn't be imbalanced after unloading the object.
(2) we can set up a generator under the counter weight to generate energy.
(3)the length of middle track will be less than the length of arm of seesaws.
(4)The motors will work to push the counter weights towards upside .
(5)we can take the object mass from 100 to 1000 kilogram.
(6) It will be single track system in this system no need of taking double track.
(7) It will work REALLY.
I would like to tell the members that the vikram_gupta11 and itsmepoojaagarwal86 bothare mine as a error has been occurring again and again when I go to submit by the user name of vikram_gupta11.So I create this second I.D.
Dear Sir,I would like to tell you that I have done some work on it before posting this thread with some wooden track and whatever sources I have and there is nothing negative result and even I couldn't find out any mistakes this time.so my earnest request to you that please consider it very seriously in the case of single track system.
Dear Sir,
I have test it with some wooden tracks and a ball and got the result what I was expecting.I also did some work on a BIG seesaw with some children and found that I 'm right as I will had to apply only 3 newton force to lift up the seesaw with children's weight(each side 150 kilogram).
Mr. hand cannot make me fool as I have done practice many many times and become expert that where ,when and how much force I should apply.
As per the attached sketch the stand which is attached with counter weight side of each seesaw will work to hold the position of seesaw so that the seesaw couldn't get imbalanced after unloading the ball . when motor will apply the force on counter weight Arm of left seesaw then the ball will get start rolling down and arrived on right side seesaw.But the counter weight arm will move towards down side and hit with a piston generator with attached stand, which will work to generate electricity.
if motors lift the counter weight arm up to 50 centimeter then using potential energy formula
P.E.=mgh
P.E.=1000*10*.50
P.E.=5000 joule
The output is 5000 joule and as per my worked on big seesaw the input will be only 3 newton force.
So I 'm 101% confident that this system will work .I would also like to attract your attention on a mechanical advantage of rolling ball and its distance from fulcrum.When motor will lift up the counter weight arm of seesaw and ball will get rolling down then the rolling ball will also apply a force as it will move further from fulcrum.
Sir,I don't have a high facility lab and I cannot afford the cost as my earning is very less but whatever worked I have done so far is before you and other members.
Now its depend on you whatever decision you take on this topic.
Thank you Sir!
Vikram Kumar Gupta
this is 101%over unity device and your mentioned question is only problem of sketch and nothing else.
OK!just adjoin the track of both seesaw and middle track only having distance in mm.
The real free energy.
