Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: indigo22 on July 26, 2017, 07:19:54 PM
Title: Tom van Keulen coil v9 setup free open source
Post by: indigo22 on July 26, 2017, 07:19:54 PM
open source free energy
Title: Re: Tom van Keulen coil v9 setup free open source
Post by: indigo22 on July 26, 2017, 07:37:23 PM
here is a video from a premier version https://www.youtube.com/watch?v=IBVxhauJgyw
Post by: wistiti on July 27, 2017, 09:23:05 AM
Hi indigo22!
Thank you for sharing your experiment!
I have some question about your diagram...
Do you use air core?
Can you clarify your drawing please... im not sure what is your output? Do you use 2 input?
Your 2nd layer is bucking but do you still use bifilar for the first or 2nd layer?
Thank you!
Post by: indigo22 on July 27, 2017, 02:53:17 PM
hi
aircores indeed plastic like a tesla coil the drawing iss a newer version then the video for more info check my site www.free-energy-revolution.com
Post by: indigo22 on July 27, 2017, 03:12:45 PM
i discovert that bifailer is unnesocery in this setup you just need a magnetic bias low volgae dc then a bias then the pulsing trigger i will make one right now and make a video remember this is open source and i think way more safe then pulsing a turoid
Post by: wistiti on July 27, 2017, 03:28:49 PM
A  tutorial video will be really nice!
Righ now im not really sure to understand what you are doing with this setup....
I have give a look to your site but did not find the info.
Thanks!
Post by: indigo22 on July 27, 2017, 03:43:15 PM
what don't you understand? :o
Post by: wistiti on July 27, 2017, 03:56:12 PM
Where is the output? Is it the 160vdc to batt on the right or the +/- at the top?
Do the battery are conected to a real ground in the soil or between their negative legs?
Also not sure to understand the pwm.
Post by: indigo22 on July 27, 2017, 05:33:25 PM
whow lot of questions no problem, if i was you i would start with the v2 version show in this picture the plus from the batterie goes to the bias to create 2 northpoles inside the coil, then 1 becomes the plus and 1 becomes the minus with a diode ofcourse the second bifailar winding can be pulsed in 1 direction that's why i adjusted my new design but if you wanna recreate my setup do it bifailar i use the wires from the john bedini coil i don't realy know what gauge that was i think 23 aand 26 but i'm not sure, i put the plus to the batterie let it go trough the coil then into the pwm with breakoutbord and pulse it back into the ground, this creates a falling of a magnetic field witch induces a radiant spike
Post by: indigo22 on July 27, 2017, 07:16:29 PM
this v9 is not tested jet it's just a rough scetsch the v2 work 110% but i'll take you trough it https://www.youtube.com/watch?v=vOqn5ggPjJ4
Post by: indigo22 on July 27, 2017, 08:00:25 PM
part 2 https://www.youtube.com/watch?v=yHg2jWrae60&feature=youtu.be
8)
Post by: indigo22 on July 27, 2017, 08:41:14 PM
part 3 sorry 4 tha quality didn't do anything different weird shit man anyway part 3 https://www.youtube.com/watch?v=wYerGuGISnk&feature=youtu.be
Post by: PARAV on July 27, 2017, 10:18:07 PM
Quote from: indigo22 on July 27, 2017, 08:41:14 PM
part 3 sorry 4 tha quality didn't do anything different weird shit man anyway part 3 https://www.youtube.com/watch?v=wYerGuGISnk&feature=youtu.be (https://www.youtube.com/watch?v=wYerGuGISnk&feature=youtu.be)
Hi Tom,
Thanks for sharing all this info .
In my 10 years on this forum --your set up looks like one of the most promising free energy ideas I have ever seen.
I too have a couple of questions.
Can you show us how to make the break out board? ?
Where is the breakout board connected in your version 2  ?
Can I use a couple of 12 volt batteries for the PS (24volts)?
Did you say that the frequency was around 20 kHz from the PWM ?
Sorry for all the  questions..
I've started winding the coil and will be standing by for further.
Thanks again and keep up the good work
Paul
Post by: indigo22 on July 27, 2017, 10:50:52 PM
hi Paul glad 2 help
yes please check picture
after it went into the coil then into the pwm breakoutboard into the ground
i rather play with the magnettic bias frequentie and size instead of pomping more volts and amps into it
Depents on the load some lightbolps have different frequenties on the sweatspot in this case with 1 lightbulb 27 microseconds on 57 off
btw you can also use the energy to load up batteries
Post by: indigo22 on July 27, 2017, 10:56:44 PM
whell this studie didn't come cheap i blew up dozens of arduino's raspberries transistors controlboards etc
right now i'm outha breakoutboards sow will send the next video soon
if you have any questions please ask don't be shy  8)
Post by: indigo22 on July 28, 2017, 12:29:34 AM
hope this is understandable :P
Post by: indigo22 on July 28, 2017, 07:58:44 AM
the magnetic bias the green wire acts as a fense the more voltage aplied the bigger the kickback from the pulsing wire ;)
Post by: indigo22 on July 28, 2017, 10:30:39 AM
be careful dough they locked me up for 5 years in a pcycichospital thats not uncommon for great inventers, the powers to be are not allowing those technologies, but i keep on fighting and spreading the word, even trough music check it out https://www.youtube.com/watch?time_continue=44&v=3qzQRlS5ruo
Post by: wistiti on July 28, 2017, 10:57:04 AM
Hi indigo22.
Can you please give the spec of the blocking capacitor and the polarity connections?
Thank you!
Post by: indigo22 on July 28, 2017, 11:23:59 AM
no sorry i can't i have never tested this setup
'but i recon 200 v dc the output goes into the minus then the plus goes back into the 12 volt batterie
Post by: indigo22 on July 28, 2017, 03:47:10 PM
i'm thinking of putting som kinda micrometalmix with epoxy into the aircore coil to maximize the performance
Post by: indigo22 on July 29, 2017, 05:09:35 PM
building the Tom van Keulen coil v9 part 4 https://www.youtube.com/watch?v=iCIwZlVeJfA&feature=youtu.be
:P
Post by: indigo22 on July 29, 2017, 07:37:13 PM
building the Tom van Keulen coil part 5 DIY Breakoutboard https://www.youtube.com/watch?v=VZgQp5TISPA&feature=youtu.be
Post by: indigo22 on July 29, 2017, 07:58:56 PM
ok how bout thiz we all built this thing and share i'll help you as much as i can but just build et
Post by: PARAV on July 29, 2017, 08:58:27 PM
Quote from: indigo22 on July 29, 2017, 07:58:56 PM
[/quote
Hi Tom.
I have the coil almost done.
I am having great difficulty in figuring out which jumper leads are going from the breakout board to the
trigger coil (is that the right one?)and which one goes from or to the PWM.
Can I use my frequency generator instead of a PWM ?
It is really hard to see and understand how the circuit is all hooked up on your videos as they are not very clear-with a lot of shadows and low light.
It would be a real  great help if you can make a  more detailed  schematic with all the connections
to and from the breakout board and the PWM and your coil wires as those things seem to the most important part of the project.
I am excited about this project but am frustrated in trying to figure out the connections,
I\m sorry to be a pain but I know you are really trying hard to get this out.
Thanx again--and appreciate all your help---Paul
P.S. I'm building the v 2 version
Post by: indigo22 on July 29, 2017, 10:12:08 PM
a breakoutboard has a transistor witch means it has a trigger often the left pin then a plus and a ground and an extra connection to the ground for the pwm but let me try to draw it
Post by: indigo22 on July 29, 2017, 10:29:34 PM
 :) hope this helps
Post by: indigo22 on July 29, 2017, 10:39:46 PM
i wind all the windings clockwise sow when i'm starting to wind i start at the left of the coil then wind it downwards
Post by: indigo22 on July 29, 2017, 10:43:47 PM
tom van keulen part 6 millitarie grade https://www.youtube.com/watch?v=vciAd5r-LWk&feature=youtu.be
Post by: indigo22 on July 29, 2017, 11:56:42 PM
btw the v9 setup is not tested yet since we are using a seperate magnetic bias we crete more distorsion in rmf field sow be very carefull and don't start with 160 volts start with 12 8)
Post by: PARAV on July 30, 2017, 10:45:15 AM
Quote from: indigo22 on July 29, 2017, 10:29:34 PM
:) hope this helps
Hi Tom,
Wow! that's awesome ------now I got it --Thanx -so much
Pa\ul
Post by: indigo22 on July 30, 2017, 12:47:21 PM
no problemo Paul,
if you have any more questions please ask good luck it WILL work lol 8)
Post by: indigo22 on July 30, 2017, 03:29:44 PM
if thiz shit is surpressed we have 2 fight 2 get thiz out
i challence you all 2 build it and i'll help you any way i can just get thiz shit out
Post by: indigo22 on July 30, 2017, 05:01:30 PM
i have wounded lot's of coils with hand i just wanna show you the good way, with your left hand  thumb bend the wire to the coil with your left pointing finger try to push it back to the windings
Post by: indigo22 on July 30, 2017, 06:55:26 PM
part 7 https://www.youtube.com/watch?v=pnOoYogGLOY&feature=youtu.be
3rd layer isn't as great as i wanted but let's try it 8)
Post by: indigo22 on July 30, 2017, 08:22:25 PM
part 8 https://www.youtube.com/watch?v=oc0socEBs5o&feature=youtu.be
first test with the new coil magnetic bias isn't even connected jet i get 52 volts ac from 16 volt pulsed dc
2be continued 8)
Post by: indigo22 on July 30, 2017, 08:39:30 PM
remember i haven't chsnged the pwm jet haven't used the magnetic bias you get my point :-X
Post by: indigo22 on July 30, 2017, 09:36:59 PM
part 9 https://www.youtube.com/watch?v=ETapVf3qYdM&feature=youtu.be  ::)
Post by: indigo22 on July 30, 2017, 11:08:59 PM
whow it's quite here hope everybody is building the coil lol
here's part 10 10 volt bias tryout
https://www.youtube.com/watch?v=uDlky8fMR5U&feature=youtu.be
Post by: indigo22 on July 31, 2017, 12:25:41 AM
18 volt magnetic bias no current 110 volts output ;D
part 11 https://www.youtube.com/watch?v=PduDZoqMt1w&feature=youtu.be
Post by: indigo22 on July 31, 2017, 02:09:55 AM
20 volt magnetic bias 198 volts output :o 8)
part 12
https://www.youtube.com/watch?v=FN7wt3DWi48&feature=youtu.be
Post by: kampen on July 31, 2017, 01:41:20 PM
Hi Tom,
thanks for sharing your work and this looks very good, keep up the good work.
Post by: Neuro on July 31, 2017, 02:31:33 PM
Is anyone here who can confirm Toms results?  8)
Post by: indigo22 on July 31, 2017, 02:44:57 PM
don't b lazy just build it  :P
Post by: Neuro on July 31, 2017, 02:50:54 PM
No thanks! I'm waiting for the version as a closed loop without any external batteries...!  8)
Post by: indigo22 on July 31, 2017, 03:05:22 PM
i'm gonna clean my house now it's bout time to many hours working sow i hope you get my point be very carefull with the magnetic bias 160 volts do need a big load otherwise you blow som up 8)
Post by: indigo22 on July 31, 2017, 03:52:48 PM
Neuro first off all the bateries are used as a bias som no current i can go on and on but your wasting my time if you don't understand it by nbow then fuck off
Post by: indigo22 on July 31, 2017, 04:08:36 PM
i wanna help people who at least know what they are doing and try to break them outha the skool teachings and be open minded to alternatives and anomalities
not som 14 year old kind who's gonna tell me it's al bogus sow
build it
test it
share your experiance
that's all i'm asking thanks guys
Post by: PARAV on July 31, 2017, 05:49:31 PM
Quote from: indigo22 on July 31, 2017, 04:08:36 PM
build it
test it
Hi Tom,
Thanx again for putting all your time in to share  this project.
I've been working feverishly on version #.2 - but sadly -I have to take  a break to take the family for summer vacation .
I'll keep working on the coils and break out boards while gone though.
I'll get back to finishing it up hopefully, in a couple of weeks, when we get back.
One more quick question on vers.#2 .
Is there a couple of blocking diodes that have to be placed near the battery and or at the load output of the + wire?
There is no earth ground required in that set up?
Thanx in advance
Paul--from Ontario, Canada
Paul
Post by: indigo22 on July 31, 2017, 05:58:15 PM
hi Paul
the breakoutboard has a diode in it and you wanna keep the diodes as minimal as possible cus they eat energy and have a satturation
mostly we use a diode to load up a second batterie sow the voltage or potential goes to the diode then into then plus of the loading batterie
i can remember what i used in v2 it's been a long time but try it out make a vid and i'll command
keep up tha good work bro 8)
Post by: wistiti on July 31, 2017, 06:37:00 PM
I will also share my replication when i have the time to finish it. Im also out of spare building time righ now... am working on v9.
Really interesting concept...
Thank you!
Post by: indigo22 on July 31, 2017, 06:51:05 PM
 8)good work bro you won't get dissapointed just share as much as you can
here are the magnetic fields https://www.youtube.com/watch?v=mVRgqQ2vZ6w&feature=youtu.be
Post by: indigo22 on July 31, 2017, 07:00:57 PM
looking @ the quadrant from 18 2 20 you don't wanna use 160 volt
keep it safe unless you know better  8)
Post by: indigo22 on July 31, 2017, 07:27:55 PM
with the v2 the collector bias also acts as a magnetic bias v9 is the way 2 go 4 complete control  ;)
Post by: indigo22 on July 31, 2017, 07:30:05 PM
understand me good i do not have all the questions jet, i do like 2 see people build it and share it and make modifications to it to make it more efficiant, eremember this is open source from me  :o
Post by: indigo22 on July 31, 2017, 07:41:58 PM
ok sow let me introduce myself, i'm Tom been studiyng the occult for a while and came acros free energy, started of with permanent magnets neo's then could not figure out how to shield the southpole, sow i went on to studie energy from the vacuum and studied under Srgt Thomas Bearden and John Bedini.
when i created my first perpetuum mobile i got locked up for 5 years in a pchykick hospital, now i'm free for almost 3 years and starting to share my experimance cus they are 2 good 2 be true.  :D
Post by: lancaIV on July 31, 2017, 07:54:07 PM
Post by: indigo22 on July 31, 2017, 08:40:10 PM
a newbie with 1975 posts get the fuck outha here and don't come back we have a serious discusion here >:(
Post by: lancaIV on July 31, 2017, 08:49:21 PM
 indigo22 (http://overunity.com/profile/indigo22.104450/)  Jr. Member
    (No subject)  « Sent to: lancaIV (http://overunity.com/profile/lancaiv.1554/) on: Today at 05:29:07 AM »   Reply (http://overunity.com/pm/indigo22.104450/sa/send/f/inbox/pmsg/76842/)
Quote (http://overunity.com/pm/indigo22.104450/sa/send/f/inbox/pmsg/76842/quote//)
   PLEASE LEAVE MY TOPIC ALONE
Post by: indigo22 on July 31, 2017, 10:27:43 PM
Always trhat guy who is trying to fuck it up for evrybody, admin pleace del this dude i have no time for this shit now back on topic guys
Post by: indigo22 on July 31, 2017, 10:39:33 PM
that's how standard nsa procedures work they watch you wait for the right moment then say something to you where you gonna react to to keep the topic not talk about the topic but bitchtalk ... smart but i caught you now get the fuck outha here > :(
Post by: indigo22 on July 31, 2017, 11:17:55 PM
CAN WE PLEASE LK ABOUT THE MAGNETIC BIAS NOW PLEASE??  ::)
Post by: indigo22 on July 31, 2017, 11:49:39 PM
i need people who are willing to try and build som of my ideas i can't do this alone
you need 2 have at least 1 ossiloscoop with big resistor and willing to wind a coil yourself
let's be real i got 198 volts ac from 16 volts 0.12 a pulsed dc from the v9 version
that's the way to go V9
now i wanna know if you pump up the magnetic bias how much it will increase and i'm wondering bout pulsing the magnetic bias what differance that will make
Post by: indigo22 on August 01, 2017, 12:05:43 AM
using a buck converter multiple coils 6 wire winding..... you get the point  :P
Post by: indigo22 on August 01, 2017, 12:17:26 AM
See me as the commander but 4 now i need soldiers  ???
Post by: indigo22 on August 01, 2017, 12:40:03 AM
also you can make the coil smaller it will stil work, Bob Boyce said you need allot of copper to make a aircoil work i disagree https://www.youtube.com/watch?v=hm2KO5fFGNw
Post by: citfta on August 01, 2017, 06:38:54 AM
Quote from: indigo22 on July 31, 2017, 11:49:39 PM
How much current do you have at 198 volts ac?  Voltage alone means nothing without current.
Post by: indigo22 on August 01, 2017, 01:50:50 PM
whell build et and you show me how much you get i think i gave you all the clues not it's up to you guys
Post by: citfta on August 01, 2017, 02:33:30 PM
I am not interested in building something that only increases voltage.  Unless there is current with the increase you only have a simple transformer.  An increase in voltage alone can be done with any transformer.  Nothing special about that.  Show me a video with a load on the output and some accurate voltage and current measurements and I will gladly build a bunch of them.  I don't waste time on projects that show no evidence of being useful.
Post by: indigo22 on August 01, 2017, 02:58:35 PM
dude don't be lazy first read and watch everything then come back www.free-energy-revolution.com
8)
Post by: indigo22 on August 01, 2017, 03:00:42 PM
Post by: casiano on August 02, 2017, 11:27:58 AM
Cifta is right without current, voltage means nothing.My oscillator setup has 5.5 volts at input and  450 volts at output,but the current...you know.Im still tweaking but i doubt there would ever be overunity.
Post by: indigo22 on August 02, 2017, 12:31:56 PM
damn youy lazy cunts first watch all videos there are videos with amps everything to profe my point
looks like i'm teaching childeren here
if you can't or won't watch and learn maybe you should find another hobbie and let the big boys talk
8)
Post by: casiano on August 02, 2017, 02:09:34 PM
In your video above your input is 16.2v with 0.05a and the output is a lightbulb.How is that overunity without any measurements.
Post by: indigo22 on August 02, 2017, 05:22:20 PM
owh dear god  .... you tell me
Post by: indigo22 on August 02, 2017, 05:23:45 PM
when you figured it out please come back  8)
Post by: indigo22 on August 02, 2017, 05:31:27 PM
ok for this last time i'll reply i'm using 16 volt pulsed dc and using 0.05 amps..got it now down to 0.01 amps but anyway i'm lightning up a 220 volt ac 0.06 amps light to the brightest, i don't know what you don't understand, if you need any help go here https://itunes.apple.com/us/app/the-calculator-free-and-easy-calculating/id398129933?mt=8
Post by: indigo22 on August 02, 2017, 05:35:16 PM
and we are on version 9 right now way more advanced and way more potential 8)
Post by: indigo22 on August 02, 2017, 05:45:46 PM
ok let me explain in human language
the coil i made is like a guitar first you got single wire all round acts as the amplifiar box, the bigger the box the harder the sound, the more voltage aplied the bigger the kickback from the pusing coil, the second wire acts as a collector of the vibrations between the first and 3rd layer and by useing 2 collectorwires in opposite directions we even boost it up more, then we got the trigger wire on top that's like the plectrum
hope thiz make sence
have fun Tom
Post by: indigo22 on August 03, 2017, 01:01:28 PM
tom van keulen coil v10
Post by: indigo22 on August 03, 2017, 03:28:01 PM
1st magnetic bias low voltage dc 2nd high voltage dc maybe opposite direction dunno right now ttrest it ;) keep up the good work guys  8)
Post by: indigo22 on August 03, 2017, 05:25:53 PM
 8)
Post by: indigo22 on August 03, 2017, 08:49:01 PM
electronic workbench test 1
handy tool for testing  :o 8)
https://www.youtube.com/watch?v=bXWRDVRthmQ&feature=youtu.be
Post by: PARAV on August 03, 2017, 09:24:09 PM
Quote from: indigo22 on August 03, 2017, 05:25:53 PM
8)
Yo Yo -Tom
Wow ! you are really going gang busters on this version 9.
I was just going to ask you a few hours ago to make up a schematic on it.
I am now going to abandon the version 2 and go ahead and work on this version 9 now as it sounds like it might be a more efficient set up.
I am going to rewind a new coil with the extra wire.
Now comes  a few questions.
Is the trigger wire still around # 26 gauge. and the other  turns of wire are around # 24 gauge or larger?
I am not sure about where the 160 volts dc comes from or goes to..  Is it a separate power supply?
Is that blocking cap --that 1 farad one in the video??
Are the 2 diodes ultra fast switching diodes?? or do they need to be ?
Thanx again for the schematic.
Looking forward to seeing this through with you.
Paul
Post by: citfta on August 03, 2017, 09:33:51 PM
In post number 81 your schematic shows the blocking cap connected backwards.  Since it has polarity markings on it I assume it is an electrolytic cap.  When connected backwards they have very high leakage and can even explode.  You also have the diode connected to the positive post of the battery backwards.  With the leakage of the cap and the backwards diode you are charging the battery from the 160 volts DC power source.  You are in danger of overcharging the battery and or exploding it also.
You are claiming OU based on your video evidence.  However there is not nearly enough information in your videos to determine if that is true or not.  I am NOT saying you don't have OU.  I AM saying there is no way to know from your videos.  They are made in a room so dark you can't see any of the wiring or connections.  You have all those other lights in the background only adding confusion to the video.  You claim you are pulsing it with 16 volts at 0.05 amps.  And you claim you are lighting a 220 volt bulb with 0.06  amps.  The problem is you are not showing anything about how much power is being supplied by your "bias" supply.  I am willing to keep an open mind about your claims but so far your evidence is very weak.
One last comment.  If you want to be taken seriously you need to make better drawings.  There is a free circuit drawing program called TinyCAd.  It is very easy to learn and will make your drawings look much more professional.  I use it regularly.
You of course can take my comments any way you want to, but they are meant to be helpful and maybe guide you a little in your efforts.
Respectfully,
Carroll
Post by: indigo22 on August 03, 2017, 09:56:06 PM
Hi Paul
//Is the trigger wire still around # 26 gauge. and the other  turns of wire are around # 24 gauge or larger?
the v9 uses the biggest wire from the bedini coil we don't use the smaller one
pleace do not start with 160 volts dc start with 12 and slowly up it
yes for this setup but i think you can better use a 200 volt dc cap
yes indeed
mur
great 2 have good company ;)
Paul
Post by: indigo22 on August 03, 2017, 10:17:27 PM
electronic workbench part 2
i'll show you what pulsing a coil does, this program doesn't lie, it's only negative spikes but it's not sow hard to figure out to capture that and tranform it into dcplus or ac
https://www.youtube.com/watch?v=UxKoGTGH6ks&feature=youtu.be
8)
Post by: indigo22 on August 03, 2017, 10:33:36 PM
Hi Carrol,
thanks for taking time first of all i try the best i can second i think the dc blocking cap is how i connected it with the v9 version, about the bias of the movie 10 times oveerunity i don't connect the bias at all sow i'm only using what you see
hope it's clear this way
take care bro
Post by: indigo22 on August 04, 2017, 12:15:49 AM
but you might b right about the blocking cap i don't use that that often
Post by: Void on August 04, 2017, 10:03:17 AM
Hi indigo22.
It looks you are using a 220V LED lightbulb? If so, what are the ratings on the LED lightbulb
from the package it came in?
If you are sending big high frequency jagged pulses to the lightbulb, measuring the average or RMS
voltage applied to the lightbulb can potentially be tricky, and measuring the current might not
be so straightforward as well.
If you want people to be able to follow what you are doing more easily, a suggestion would be to
post your simplest circuit diagram which you think is overunity, and just stick with that simple circuit for now
here until people are clear on exactly what you are doing. If you post info and videos on other circuits at
the same time here, it will probably be a lot more confusing for people to try to follow what you are doing.
Just a suggestion.  :)
All the best...
Post by: indigo22 on August 04, 2017, 10:46:56 AM
hi Void,
no i want advanced students if you wanna show overunity and make it simple 4 everybody then goto the John Bedini schoolgirl model and built that, we are creating new coils that's my hobbie
8)
Post by: Void on August 04, 2017, 11:54:51 AM
Hi indigo22.
The fact that you did not answer my questions about the lightbulb, says it all.
You are obviously not interested at all in trying to explain to people what you are doing,
otherwise you would have answered the questions. I asked politely enough. :)
By the way. You were making a very obvious error when you said that the output
power for the setup in one of your videos was 220V x 0.06 Amps. You don't take
the nominal voltage for the lightbulb (220V) and use that to calculate the output power
being consumed by the lightbulb. :o You have to measure both the output RMS voltage
across the bulb and the output RMS current through the bulb to be able to determine the output power.  ;D
I watched several of your videos and if you are using a LED lightbulb, they can light up
fairly brightly with only low power, so all indications are it is not overunity. You would need
to know how to do proper measurements to be able to determine the output power to the bulb
with any accuracy, and when you are powering a bulb with a jagged pulse waveform as your
circuit seems to produce, being able to measure the output power being consumed by the bulb
can be quite tricky. Many people here have been at this sort of thing for many years, and some may
be willing to help you to learn how to do proper measurements if you ask politely, but from what I
saw from some of your very rude replies in this thread, I suspect that isn't likely going to happen.  ;)
People who have been looking into this area for quite some time see all sorts of claims of overunity here and
in videos on youtube, and probably at least 95% of the time the person making the claim either has little to no idea
of what they are talking about, or they are trying to pull a scam. Given this, if you want people here to
take you at all seriously, you first and foremost need to be polite and respectful with people, and be willing
to answer questions, and be open to constructive criticisms pointing out problems or potential problems
with your setup or your approach. If you can't do that, then it is actually you who is just wasting other people's time.  ???
If you want to share and discuss openly, then share and discuss openly. If you don't want to share openly, that's fine,
but you are definitely just wasting peoples' time here in that case.
Good luck with your experiments...
Post by: citfta on August 04, 2017, 01:25:39 PM
Quote from: indigo22 on August 04, 2017, 10:46:56 AM
hi Void,
8)
I have built several Bedini schoolgirl circuits.  I have also helped several dozen people get theirs to work when they had problems.  If you think there is OU in the schoolgird circuit you don't really understand how to do proper measurements because as interesting and educational as the Bedinin schoolgirl circuit is,  THERE IS NO OU THERE!  I have worked with that circuit for several years.  It is a very efficient circuit but it is not OU.  I have seen things that make me believe OU is possible.  Your circuit may be OU but without proper measurements as Void has pointed out there is no way to verify that.
Carroll
Post by: indigo22 on August 04, 2017, 02:53:04 PM
to disreaspect my grand teatchere you f$%&(* ing as@#%$%^&le get the fuck outha here >:(
Post by: casiano on August 04, 2017, 03:16:03 PM
Well....that tells everything.
Post by: indigo22 on August 04, 2017, 03:43:35 PM
ecxectamente anyone who even try 2 disrespect John Bedini has a war with me
don't even try to do that agian i'm kartel yoúr familie will be very sorry John died again under wierd surcomstances last year
i've spent 6 years in the hole justr to keep my mouth shut, if you asshole wanna war you get it
citfta  you have no idea who you focking with
Post by: citfta on August 04, 2017, 03:58:16 PM
Sorry about your lack of reading skills.  I showed no disrespect at all for John Bedini.  I spoke with him in person at the first energy conference.  His schoolgirl circuit is what got me interested in looking for OU.  John himself said there is no OU in the schoolgirl circuit.  I have watched many of his interesting videos and learned some things from him.  Your silly threats mean absolutely nothing to me, except to show me what kind of person you are.  But they could easily get you banned from this forum.
As several have asked, if you really have something, then clearly show it so it can be properly evaluated.  If you are not interested in proving your claims then you are wasting everyone's time here.
Carroll
Post by: indigo22 on August 04, 2017, 06:30:29 PM
you full of bulshit and you know it i was 1 of his students and ask Thomas Bearden the schoolgirl produces 8 to 10 times overunity. i've watched all his movies i know what i'm talking about and i know what your doing i'll look up in my archive on where he says it but i'll come back on that, but i don't think your here to participate just to fuck the confercation up pleace leave else i'm gonna ask the moderattor to remove you from this forum sorry
Post by: indigo22 on August 04, 2017, 06:36:48 PM
i'll look it up make a vid and maybe then you finaly shut up just gimme a sec 2 find it
:o
Post by: indigo22 on August 04, 2017, 06:38:47 PM
How important is the duty cycle of the blockform sharp pulse??
electronic workbench  8)
https://www.youtube.com/watch?v=2UeUwV9hmtA&feature=youtu.be
Post by: citfta on August 04, 2017, 07:09:55 PM
Quote from: indigo22 on August 04, 2017, 06:30:29 PM
If you think the schoolgirl circuit produces 8 to 10 times over unity then you clearly do not know how to compare input to output.  I will not be holding my breath waiting for you to show me a video where either Tom or John ever said that.  Because I know neither of them have ever said that or written that.  You just keep digging yourself a deeper hole.
If you want to report me to the moderator go right ahead.  When he looks at the posts you have made I know who will be leaving and it won't be me.
Post by: indigo22 on August 04, 2017, 07:29:23 PM
at citfta your not talking 2 a dumb cunt here dude look at thiz  :o
https://www.youtube.com/watch?v=DIvIngswyt4&feature=youtu.be
damn spending my time 2 prove a point to nsa infistraters or a 14 year old boy anyway i don't wanna lose my respect here sow
citfta please apollegize or leave  >:(  8) and don't ever try to disrespect a great inventer again hope you learned from it, over and out
Post by: indigo22 on August 04, 2017, 07:30:41 PM
whell i did spent my time to look it up to bad for you you now pleace let the big boys talk  8)
Post by: indigo22 on August 04, 2017, 07:40:32 PM
 :D ;D didn't expected that hey lol
thank God i can dream the energy from the vacuum series  :P
Post by: indigo22 on August 04, 2017, 07:56:33 PM
HEY SIFSHITFA are you gonna apollegize or what you said as i remember :
i took the time to shoot the video upload it spend my energy not vacuum lol into it and now you gonna walk away like a dog with his tale between his legs.. shame on you
Post by: Void on August 04, 2017, 08:24:00 PM
Quote from: citfta on August 04, 2017, 01:25:39 PM
Carroll
Hi citfta. Yes, if the Bedini 'schoolgirl' circuit can produce OU, you would think someone should have been able
to demonstrate this by now. Many people have been playing around with that circuit and variations for many years,
and I personally haven't seen any demos that seem to convincingly show signs of OU. If someone knows of a video
demo of that circuit that seems to show OU, feel free to enlighten me. :)
Given indigo22's very rude behavior here in this thread towards some people, I would suggest
people just ignore him, unless you like having foul language directed at you for just asking some questions,
or for just pointing out some apparent problems with the setup or the approach taken.  :o
Also, indigo22 seems to think that having larger voltage spike peaks in the output stage of a circuit than the
supplied input voltage, is an indication of OU.  ;D  It seems it is not likely this is going to lead anywhere...
All the best...
Post by: citfta on August 04, 2017, 08:29:50 PM
I don't sit at my computer waiting for you to post something.  You are just not that important.  Yes you were correct that Tom said that.  And I was not aware he did.  So yes you are correct.  However I never said anything that could be regarded as disrespectful about John Bedini.  I said his school girl circuit is NOT OU and it is not.  Many many people have tried to make it OU and in spite of what Tom said no one that I am aware of has even gotten any OU from it.  And I am talking people with years of experience in the field of OU research.  So I have nothing to apologize about.  Continue on with your thread.  I don't have any more time to waste trying to help you.  You have an agenda of leading people astray so I'll let you get on with it.  The oil companies will be proud of you efforts.
Post by: citfta on August 04, 2017, 08:32:16 PM
Hi Void,
Yes you are correct on all points.  You were typing same time I was it seems.
Take care,
Carroll
Post by: indigo22 on August 04, 2017, 08:36:01 PM
SPAM SPAM SPAM DAMN, you spread no info i was right no appiligy now get the fuck out here you both corporate oil disinfo distractors, i see into you remember that
Post by: indigo22 on August 04, 2017, 08:37:32 PM
look at what they have done the last real reply was from my frind paul howmuch topics was that ago??
Post by: indigo22 on August 04, 2017, 08:46:17 PM
ok now i'm gonna contrtact the administratotrs here you are willingly trying to fuck up my topic and that's the only reason why i have a big mouth thanks guys
Post by: indigo22 on August 04, 2017, 08:54:42 PM
look forward into what Stepan gonna do with you 2   ???
Post by: indigo22 on August 04, 2017, 09:07:19 PM
and 4 tha record i apolligize for my language been in the milletary sow thats normal
Post by: PARAV on August 05, 2017, 09:51:21 PM
Quote from: indigo22 on August 04, 2017, 09:07:19 PM
Hi Tom,
I see that the Measurement Police have been paying you a visit--lol.
Those guys are quite knowledgeable and really know their stuff when it comes to electronics.
You can't blame them for asking for some measurements.
In my humble opinion though --they are having a hard time understanding the concept --as I did as well -- but by going over and over
your videos I 've been able to see some sort of a pattern that looks promising.
My biggest surprise and acceptance of this concept was when you were able to self loop the one with the Bob Boyce coil.
I think if you can explain to the rest of the
Post by: PARAV on August 05, 2017, 10:01:03 PM
Quote from: PARAV on August 05, 2017, 09:51:21 PM
Hi Tom,
Oops sorry ,
I  cut myself off .
Anyway, If I can continue----
If you can show and explain to the rest of the experimenters -- the self looping concept of your invention.---This would be great!
This may get more of  the guys jumping into this and trying it out and improving on it - if need be.
I'll be back in a couple of weeks (family vacation)
Hang in there and don't give up -- keep at it.
Paul
Post by: ARMCORTEX on August 06, 2017, 01:01:35 AM
There is nothing to explain, Indigo22 is an ingnorant clown and parav is just his 2nd account.
Let's hope he stops spamming this forum with his non over unity simplistic and inefficient pulse transformer that cannot light a 100 watt lightbulb.
Post by: indigo22 on August 06, 2017, 11:12:14 AM
at ARMCORTEX
thank god your ip is logged now we can find you trough ip trace
8)
Post by: indigo22 on August 06, 2017, 11:13:53 AM
Hi Paul
have a good holiday me 2 i'm out for now
8)
Post by: Void on August 06, 2017, 11:53:27 AM
Post by: ARMCORTEX on August 06, 2017, 02:08:48 PM
There can be no ip hiding from "we".
There is only Tom can keulen, who lives in poorly lit basement.
The people from "we" have a motto, speak gently and carry big stick.
The wannabe, have no motto, speak like messed up jamaican and carry drug brick.
In the military these people get kicked out for being psychotic, for acting up to superior officers, for not doing their beds. A general is somebody who can take a punch and has spotless uniform. You could not be a kitchen aide, too messy.
Post by: indigo22 on August 06, 2017, 04:57:44 PM
ohw stapt on sombodies toos there i love it bring it on 8)
Post by: PARAV on August 06, 2017, 07:44:57 PM
Quote from: ARMCORTEX on August 06, 2017, 01:01:35 AM
Armcortex,
Grow up and just start studying the videos --try not to be so negative --you sound like my wife for crying out loud.
She's OK -though.
Post by: ramset on August 06, 2017, 07:57:27 PM
OOOOOH
smart ......back peddle on the wife comment
the wives have eyes everywhere it seems..... 8)
Post by: indigo22 on August 09, 2017, 06:37:32 PM
ok ramset i don't know why your not kicked
your answer:
OOOOOH
1st off all has nothing to do with the topic
your acting like a child
and you've ruind my topic thanks now let the big boys talk ok
Post by: ARMCORTEX on August 10, 2017, 02:26:57 AM
Why is your screen so dirty?
Please quit spamming this forum with repeat threads.
We understand, you have a coil that YOU think is overunity, but we know better than to believe you.
Your real world results indicate error of measurement, and I would not believe it even if I saw it in one of your videos.
Are you done now?
Post by: indigo22 on August 10, 2017, 05:14:12 PM
standdard NSA procedures
1st change the subjuct to someting totally differant
////Why is your screen so dirty?
2nd now he's trying to get a responce sow it's still talking about his subject my dirty screen
////Please quit spamming this forum with repeat threads.
think they are all new and importand
////We understand, you have a coil that YOU think is overunity, but we know better than to believe you.
i don't think i don't believe i know
////Your real world results indicate error of measurement, and I would not believe it even if I saw it in one of your videos.
i'm not a religous savior i'm doing the best i can to get millitarie information to the public
///Are you done now?
hell yeah with you my frienbd i'm deffinaitly done
Post by: indigo22 on August 10, 2017, 05:22:11 PM
i can tell your just a rookie try som neurolinguistics that might work better on your next vic Tom van Keulen
Post by: indigo22 on August 10, 2017, 05:33:27 PM
the nsa studies the flow of the converstion specialy on this forum
if you're not qualifield to reconize these behaviors from our enemy
maybe your not a good admin.. i would have kicked them out
i good thing is your logged their ip but it could be routed
, i even had navel inteligance from the us on my site
use trace ip and i use a secret ip logger on my site
be safe guys
we're fighting a war here  NEVER FORGET THAT
Post by: indigo22 on August 10, 2017, 05:39:27 PM
ok open your minds now
what would you do if you own an oil company and som tom van keulen gonna tel you we don't need you anymore
we have the sollution
yes think 4 a moment actxactly..
monitor him 24/7 hack his pc install camera's into his house make him look insane in everr means possible and discredit his information or delete it
guys if you wanna fight for som i'm with you
in the name of Jesus
goodnight
Post by: indigo22 on August 10, 2017, 05:42:14 PM
but i have 2 give you credit ramset and the other agent
we haven't talked about free energy
Post by: TinselKoala on August 10, 2017, 08:16:08 PM
You don't need any help from "nsa" to look insane, you are doing just fine all on your own.
Post by: indigo22 on August 11, 2017, 12:23:22 AM
is this a topic to burn me down or are we creating som here??
if inwas you an nsa agenyt i would have done my homework and know the triggers to get me upset
again try neuroliguistic programming you might learn a thing or two
this doesn't pss me off yet you gattah do better
4 the record i don't hate you, but then again you have to look at the mirror every day
knowing you protect a secreect that keeps the oil companies alive
i have no respect 4 you at all cus you all know damn whell what your doing
Post by: ehsan on June 28, 2018, 05:54:13 PM
It really Works?!!!
read This page: https://www.free-energy-revolution.nl/latest-updates/
Post by: indigo22 on September 11, 2022, 02:22:06 AM
Unfortunatly jimdo.com completely erased my website all my info and videos are gone and got an email i can never create a website on their servers anymore
Post by: alan on September 11, 2022, 08:05:30 AM
Why's that?  Maybe they got harassed or blackmailed.
They can't delete your youtube video's, these are gone too. Could you re-up them?
Post by: indigo22 on September 11, 2022, 10:32:29 PM
Yes is works, they don't close clown sites :-X
Post by: alan on September 12, 2022, 04:46:59 PM
what?
