With metallic spherical barbecue and High Tension
Also for air car
Air electrode
HT and barbecue
Aerator
Total: 80 euro....
Most simple
Tea filter
Hi Franco. Looks interesting. What is the purpose of 'burning air'?
Do you mean it will produce an actual flame of some type at the nozzle at the top?
All you need to do is apply a high DC voltage, plus to the tea bag filter and minus to the barbecue body?
How do you get the air to start burning?
With no explanation, I am not sure what you are trying to achieve. :)
Also curious as to what this helps to do in terms of energy consumption.
@Franco -- Does this device "ionize" the air?
Build it! Is very simple at cost 100 $.....
Hi Franco. Thanks for ignoring the question. ;D
As Terbo mentioned, it looks like it is a large air ionizer.
You can buy commercially made air ionizers cheaper than that,
hence the questions about what you are trying to achieve.
All the best...
Build, build........
Meanwhile you build the reactor, then we'll see what to use for power it
Quote from: franco malgarini on August 23, 2017, 11:47:38 AM
Oke Franco,
I will give it a try.
I guess a different kind of metal ball instead of the BB would also possible or are there limitation to the amount of air inside the reactor.
Second question your HV unit....feeding it from the grid?... i assume the higher the voltage the better?
Greetings
I work hard on the "etheric" body of the researchers
"I work hard on the "etheric" body of the researchers"
Haha malgarini I know you.you wants to stealit the ideas lol!
In the barbecue reactor we will put also a piezoelectric trasducer:
http://www.conrad.it/ce/it/product/751553/Trasduttore-di-segnale-con-elettronica-serie-AL-60S-Pressione-sonora-85-dB-4-7-VDC-Contenuto-1-pz;jsessionid=2149FFEAB414227CC7A543434117D5F8.ASTPCEN22?ref=list
