Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: awesomo4000 on November 28, 2006, 06:26:02 PM
Title: Pulse Motor Video
Post by: awesomo4000 on November 28, 2006, 06:26:02 PM
Has anyone seen this?
http://youtube.com/watch?v=f4gAKrn5pl4
Looks pretty neat.
Title: Re: Pulse Motor Video
Post by: Dingus Mungus on November 28, 2006, 06:55:21 PM
Hmmmm...
The load test was really interesting!
I hope someone here will contact the inventor for more details.
Post by: stevewal2 on December 07, 2006, 02:22:02 PM
I've just sent a message ot him on youtube, inviting him to post more stuff on overunity.com
Post by: stevewal2 on December 07, 2006, 04:15:45 PM
hi,
I've spoken to the builder of the motor Ian, and he's kindly given a link to his site:-
http://www.mintakafulcrum.net/ (http://www.mintakafulcrum.net/)
This was listed on the youtube page but I must  have missed it when I looked.
Anyway it's got lots of info, including circuit diagrams and plans.
Post by: msurucu on January 21, 2007, 12:53:32 PM
is there any differences from step motors?
Post by: CLaNZeR on January 21, 2007, 02:46:17 PM
Quote from: msurucu on January 21, 2007, 12:53:32 PM
Well main difference is that a Stepper motor is input only. So you have a number of coils inside a stepper motor and power is applied to all coils, this keeps the motor in a static position. Then you pulse each coil in the correct sequence to get acurrate movement. Common Steppers take 200 pulses for a full revolution, so excellent for CNC/Milling machines where accuracy is needed.
The pulse motors shown are moving the rotor away or towards the coils by a simple pulse to a electromagnet, but also there are coils that are pickups to collect the energy created by the magnets passing over them, again around the rotor.
So basically the idea with a pulse motor is to get more energy produced by the coils around the rotor than the energy used to drive the other coils that act as electromagnets.
After months of watching ebay to get some decent priced electromagnets, today I actually spotted some that look ideal for a pulse motor and won a bulk lot for a good price. I could of wound them myself but wanted manafactured graded ones that have equal power. I will probably have to wind the pickup coils myself, but in saying that there are a few Motor Bike Stators going cheap on ebay that may be ideal.
Sean.
Post by: msurucu on January 21, 2007, 04:04:45 PM
but i think step motor can be used as a pulse motor.
some step motor have a permament magnet rotor.
here some step motor images.
and link  http://www.interq.or.jp/japan/se-inoue/e_step1.htm
Post by: CLaNZeR on January 21, 2007, 04:40:15 PM
If you say pulsed coil 1 and 3 to drive the stepper, are you going to get more power out of the coils 2 and 4 to created more power?
You could pulse a stepper and it would turn and pull alot of current as it is designed that way.
You could attach a wheel to a stepper and use it as an alternator, at low revs they work fine, but as soon as you speed them up you get alot of resonance back.
Sean.
Post by: molux on May 15, 2007, 07:18:09 AM
Hy,
I'm french, and i have some problems to understand all on this website:
http://www.mintakafulcrum.net (http://www.mintakafulcrum.net)
1 - In this uTube page http://www.youtube.com/watch?v=f4gAKrn5pl4 (http://www.youtube.com/watch?v=f4gAKrn5pl4), the video publisher said:
The motor uses about seven watts of electricity, yet the mechanical output is 4 to five times that of the electical input. I hope that helps.
2 - Does someone find this information on the website http://www.mintakafulcrum.net (http://www.mintakafulcrum.net), and wich motor model who do that ?
This motor seems efficient, can someone work on it ?
Molux
Post by: ian on May 19, 2007, 03:58:46 AM
Hi everyone.
I am the builder of the motor that was posted here. Stephan asked me to come by and discuss it.
I just posted a new video here:
http://www.youtube.com/watch?v=5oIZTZeC6c4 (http://www.youtube.com/watch?v=5oIZTZeC6c4)
This is just a demonstration to compare with the other motor first posed here. The rotor is the same. The coil in this one is about 1.2 ohms and is bi-filler wound with the second coil picking up the bemf.
This uses the same amount of power running with one coils as the other motor with eight coils. Yet this one I can stop with two fingers, and the other I could not stop with all of my strength in my hand without burning my fingers
The single coil motor here runs at 2325 rpm and the one with eight coils at 2400 rpm. So they run at virtually the same speed and power input (~7 watts), yet the torque and hp on the eight coil unit is much greater for sure. Sorry I don't have prony brake numbers for you all. I put on on the eight coil model and it bounced to much to get a good reading.
The four to five times power mechanical power output is my best guess by comparing with trying to stop the eight coil motor from spinning with that of an AC fan that was rated at 45 watts...
Post by: hartiberlin on May 20, 2007, 11:14:40 AM
Hi,
many thanks for posting this new video !
Looks very interesting !
How many amps do you get at the output into the bulb ?
Please try to use just a graetz full wave bridge rectifier at the output without
the caps and charge with these pulses directly a second battery and then
compare, if the second battery charges faster as the primary will discharge.
Then it will be simular to a Bedini system.
If you would still use the reed switch directly instead
of the transistor to pulse the primary coil, you will
probably get also a longer run time before the primary battery will discharge...
Mechanical switches are always better with coils and batteries energywise ,
due to the back current spark effect!
Many thanks.
Regards, Stefan.
Post by: dani1 on May 20, 2007, 12:10:12 PM
Ian, your video is very impressive! Good work.
can you post a schematic?, How do you wound your coils? Is the Bolt of the coil made from Iron?
regards, Dani
Post by: ian on May 21, 2007, 04:21:57 PM
Hi...
Quote from: dani1 on May 20, 2007, 12:10:12 PM
regards, Dani
It really is very simple. It is just a regular low grade steel bolt with the head ground from hex to round. The reed switch turns the transistor on and off. The coil is bi-filar wound(two wires). One wire for driving the rotor and the wire for taking the back emf off using a single reverse diode.
Post by: ian on May 21, 2007, 04:41:16 PM
Hi Stephan,
Quote from: hartiberlin on May 20, 2007, 11:14:40 AM
Hi,
Many thanks.
Regards, Stefan.
Thanks for your interest but this setup really is nothing special.
To answer your questions.
1) 120 ma from output side.. about 2 watts
2) I have not done that experiment with this motor. I made this for two reasons. A demo unit to show and compare the torque-power and input draw vs the output torque-power with my larger motor first discussed here. As you may notice, the input on both motors is the same. Yet the mechanical output on the one with more coils is considerably more. I don't plan on experimenting with this low watt demo model. The second reason i made it was to be able to show and explain to young people that are interested in this stuff.
3) Yes, mechanical switching is better. My other motor first posted here uses that. This little one was to low of an ohm rating to use these reed switches rated at one amp.
4) I am in the process of making a mechanical commutator for my eight coil motor. I have replaced the rotor with neo magnets and have added eight more coils as generator coils. This should be able to handle much more current... but I feel there is an inherent design flaw in the cores being a bit too small and not the best material, being just bolts, so i may oversaturate the cores too easily. But I should be able to get some real input vs. output numbers off this version.
Post by: stevewal2 on May 23, 2007, 04:23:57 PM
Wow that sounds really great Ian,
Would be great to get some mechanical output measurements on your new setup when its finished.
Good work!
Post by: ian on June 13, 2007, 04:31:31 AM
Hi everyone.
I just filmed this experiment today and uploaded...
http://www.youtube.com/watch?v=9kCkROMSGG0
Please anyone correct me if there is anything wrong in my calculations or anything else here...
Thanks in advance.
After watching this, it becomes extremely clear that using high strength magnets in a rotor and then repelling it with a pulse of a known quantity value of energy via a  pulse, will push the rotor further away, ie, more force than with weaker magnets.
Also, I will disclose here another fact about magnetic field geometries.
If a coil of wire has 500 turns with a known voltage has 5 amps running through it, it will give a B field value of 2500 gauss.  ie amps times number of turns.
If I have a second identical coil and I put them in series, then the resistance will double and the amps will be half.
The total B field strength will be 2.5 times 1,000 which equals the same as before 2,500 gauss.
Now take the two coils in series and add two more series coils to the first ones and put them in parallel with the first ones. The resistance now halves and we have a total of 5 amps as we did in the scenario with just one coil.
Each leg has 2.5 amps moving through it and a B field of 2,500 gauss. So now the TOTAL B field strength is 2,500 times 2 which equals 5,000 gauss.
So by just changing the geometry of the setup, we get double the B field strength for the same input watts, because the voltage is fixed in this experiment.
But it gets better. :-)
If we have just the one coil hitting a magnet, the force repelling the magnet will be the sum of the strength of both B fields. So in case on with on coil and one magnet, and let us say the magnet has the same B field of 2,500 gauss, then the repelling force will be 5,000 gauss.
Now in our third case with the series parallel circuit, with 4 coils repelling 4 magnets, the total repelling B field against 4 magnets of 2,500 gauss each plus the electromagnet B field strength of 1,250 gauss for 3,750 gauss times 4 coil permanent magnet & electromagnet pairs for a TOTAL B field repelling strength of 15,000 gauss. This is THREE times the the field strength of the single coil alone.
This is with the same input of five amps as in case. Input watts is totally irrelevant to output.
Now add to this the fact that very strong neo magnets want to attract themselves to the cores on their own, and the fact the a B field in an electromagnet is the mu of the metal times the current times the number of turns, then by adding a good mu metal core, we get even more free magnetic field strength.
Now add to this as some strong permanent magnets on the end of the stators, and the attraction force is even greater for free.
... and I haven't even started to recycle the bemf yet... '-)
Food for thought I guess...
Wishing everyone success in whatever direction one goes for high COP values...
ian
Post by: hartiberlin on June 13, 2007, 05:11:48 AM
Hi Ian,
well done video demo.
The problem I see with your calculation is,
that it is only for the static case.
You normally have to build up a magnetic field inside
the coil.
When the coil has more inductance L,
then it takes more energy from the cap to build this
up as E= 0.5 x L x i^2
So now you need to compare the energy stored in your cap:
E= 0.5 x C x voltage^2
and the Energy you moved the magnet mass away, which is
E= force x distance.
As force= mass of magnet x g ( earth acceleration )
we can write:
E= mass of magnet x g x distance
this must be the same as
E= 0.5 x C x voltage^2 so we can write:
0.5 x C x voltage^2= mass of magnet x g x distance
so now we can calculate the maximum distance to:
distance= 0.5 x C x voltage^2 / (mass of magnet x g )
so in your case the maximum distance should be:
0.5 x 0.01 F x 12,5Volts^2 / 0.03 kG x 9,81=  2,65 Meters.
So as you have losses in the coil resistance and maybe your magnet
is not exactly 30 Gramms, you should get without losses about2.65 Meters
distance, but you only get around 50 cm !
Now , if you succeed to shoot this magnet more than 2.65 Meters away you have overunity !
Maybe try with a core inside the coil or a bigger coil !
Will be intersting to see, if you will succeed !
Also you could try to increase the mass of the neodym magnet.
Good luck !
Regards, Stefan.
Post by: ian on June 13, 2007, 06:18:51 AM
Hi, I just weighed the the neo magnet with a scale for more than 30 grams. It weighs 50 grams.
So:
0.5 x 0.01 F x 12,5Volts2 / 0.05 kG x 9,81=  0.7964 Meters.
now we have to add resistance to this, in this case the mu resistance of air and the surface should be the difference between of 0.7964 meters and my measurements of about 0.56 meters giving a mu value of 0.73 for combined static and moving.
I think you may have missed my main point though... in that the same amount of energy was used to propel a heavier object over three times further with no extra energy input from the operator.
Also, the other information in that post on the geometry of the coil setup is quite valid.
The other thing you mention about building up the L inside the coil in with a moving magnet... I measured the inductance to the secondary coils in my motor(as the meter won't measure the primary because it needs a higher resistance), but I figure they are very close. It measures at 0.3 Henrys.  My rotor when spinning is running way less than 0.3 seconds duty cycle(on time). Also, I heard Bedini say that this is what needs to be done. Run the coils inductively.
I'm having a bit of a hard time building my commutator, but am almost there, so I'll post more as I go...
Thanks for your time Stephan,
ian
Post by: hartiberlin on June 13, 2007, 06:26:33 AM
Hi Ian,
in normal motors you always have the counter EMF voltage, when the rotor
magnet induces back into the driving coil ,so you always have to put more
power into the driving coil than your rotor magnet delivers...
But this may not be the case, if you do it via repelling pulses as you do...
Anyway, with fast pulses you have a dynamic system and as you need
to put energy up into the coil to build up the field,
it takes longer when you use more wire and the inductances
of the coils gets bigger...
So I am curious to see, if you will find a a way around it and
can violate Lentz law this way...
Please keep us informed.
Many thanks.
Regards, Stefan.
Post by: hartiberlin on June 13, 2007, 06:31:14 AM
Quote from: ian on June 13, 2007, 06:18:51 AM
So:
Did you misscalculate it ?
I get 1.59 Meters for this as the result...
Regards, Stefan.
Post by: ian on June 13, 2007, 06:52:48 AM
Quote from: hartiberlin on June 13, 2007, 06:31:14 AM
So:
Regards, Stefan.
... could be.. it's late and I'm tired...
Post by: ian on June 13, 2007, 06:58:44 AM
Quote from: hartiberlin on June 13, 2007, 06:26:33 AM
Hi Ian,
Many thanks.
Regards, Stefan.
A few years back I was in contact with a fellow at a major university who built and tested many pulse motors. He said that because we are repelling the magnet, that the stator field direction was the same direction as the induced magnetic field so they reduced the lentz effect...
but yes, well see... wish i had a milling machine right about now.. :-)
Thanks again,
best regards,
ian
Post by: ian on September 11, 2007, 05:58:09 AM
So:
Regards, Stefan.
I'm not big on Lorentz... but I just had a thought here.. put a magnet on each side of the coil, then add the two distances... maybe I'll try the experiment again to see...
Post by: ian on September 11, 2007, 06:00:20 AM
Hi everyone...
Thought that I would share my latest experiments with the group...
http://www.youtube.com/watch?v=Y_wdcsWiZCY (http://www.youtube.com/watch?v=Y_wdcsWiZCY)
This is a modification from previous experiments. The rotor is bigger and uses powerful rare earth magnets. I built a special commutator because I wanted to use the previous proven circuits on this model but reed switches can't handle the high current and transistors only work on the negative side of the coil bank where the circuit required the switches on the positive side. So I made an adjustable commutator. One of the circuits did not work with this model so far. In fact, these magnets are so strong, that when supplied with the large current needed to get the rotor up to working speed, I believe I over-saturated the small cores of the coils.
Still more test to do on this model.
On the first half of this video the motor is running on 24 volts using this circuit,
http://www.mintakafulcrum.net/Instructionsmk4.htm (http://www.mintakafulcrum.net/Instructionsmk4.htm)
which did seem to work to some degree as the motor does appear not to draw extra current under load.
I'll do more testing but I need six batteries to do this properly.
The second half of the video the motor is running from one battery bank and with no recovery circuits. The draw goes up considerably under load.
The circuit that i was hoping to use, did not work at all for some reason...
http://www.mintakafulcrum.net/Instructionsmk5.1.htm (http://www.mintakafulcrum.net/Instructionsmk5.1.htm)
If anyone can tell me why, It'd be greatly appreciated...
Thanks in advance,
ian
Post by: Thaelin on September 11, 2007, 06:53:34 AM
Hi Ian:
   Have built quite a few of this style of motor. One thing I should bring up for you at this stage is your amp readings are misleading. The reading you are seeing is an average of the actual. What I mean is you are seeing pulses, not a steady amp draw. If seen in a scope it would be a series of spikes instead. To know the true draw of a coil is to hook it up to a batt long enough for the meter to level out. I some times could see six and eight amp draw on one of the coils and it had six. You also have to factor in time of the pulse as well.
   On the link to the push/pull circuit, I see no reason it would not run. Since I was not able to see your setup, it would not be fair for me to comment on what my thoughts would be. Happy experimenting   ;D
thaelin
Post by: ian on September 11, 2007, 06:50:51 PM
Yes.. I know what you mean.. the coils bank is 3.4 ohms. This into 36 volts gives ~10 amps. Yes.. the meter gives an "average". That is what I want. This is why i use an analogue meter instead of a digital. From what I've seen of Bedini, he uses an analogue amp meter for his motors as well and he seems to know what he is doing quite well. I could see that if there was some sort of resonance with the meter, then it may show reactive amps and therefore not a true reading.
Thanks for your time to look...
ian
Post by: tropes on September 16, 2007, 05:14:38 PM
Ian
Do the two wires switch on simultaniously or is the pulse for driving the rotor slightly advanced? Do you think I could use such a bifilar coil on my Sotropa Motor?
Peter
Post by: ian on September 16, 2007, 09:39:32 PM
Ian
Peter
Hi Peter... No the primary is used to pulse the coil, and the secondary is used to just send the collapsing magnetic field to a cap.. You could swich it but you don't have to. Yeah you could use this.. but a single coil will work just as good imho...
Call me if you like.. I'm home and free for a bit. although, I'm in the shop at the moment.. thank God... waiting for a special tool.. so in the meantime I'm building this...
