Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: aether22 on February 19, 2018, 12:15:41 AM
Title: Magnetic rotary free energy effect
Post by: aether22 on February 19, 2018, 12:15:41 AM
I have found a Free Energy type effect.
This is as of yet not a way to generate conventional energy, but rather a way to generate one of 2 different powerful aetheric effects that can be tapped for energy.
I took a fan, this is a $5 USB fan with an Aluminium blade, I flattened the blade (not necessary, but it does spin much faster with less air to move) and removed the guard.
I then tried placing the pole of a magnet facing the side of the fan blade.
I discovered that one pole in gave energy to the fan blade (pic 1), the rotating fan blade began to create a vortex around the fan, but the other pole in energized the magnet.
I found that if the magnet poles were along the direction of movement (pic 2), one direction again energized the disk, but the other energized the magnet.
I combined the pole that pointing in energized the disk (Pic 3), and also made sure that pole was pointing toward the approaching fan blade, BTW the fan was spinning CCW on a vertical axis. This combined the 2 effects and was stronger than either alone.
I found that this was stronger again at energizing the fan blade.
You can of course have some magnets give energy to the disk, and some magnets, or electromagnets? take energy, this might be a way to get Free Energy!  I don't know.
I also found that if the magnet pole faced down (pic 4), it increased the energy in the disk further.
I also had a paper pattern printed up and placed on the disk, however this was a parallel experiment and it worked with and without this, pattern availible on request.
This is interesting as it no doubt relates to many different motor/generator Free Energy devices!
I have avoided mentioning which pole it is that should be facing in to the disk, I will confirm if asked, but I would like people to try this and see what they get when they try it each way.
I used a fan, but you could use probably anything rotating, anyone should be able to take a magnet and point it at a rotating thing, CD or record player might work.
There is nothing stopping you from having one or 2 magnets that are positioned to excite the disk and another that drains the disk and is itself excited.
I think this likely has some impact on the Bedini monopole motors!
Title: Re: Magnetic rotary free energy effect
Post by: aether22 on February 19, 2018, 12:17:44 AM
I would note that the field from this thing extends all over town, it's rotating up the aether and it can be felt if sensitive and observant.
Post by: FatBird on February 20, 2018, 06:53:33 PM
Most PC cooling fans have plastic blades.
Where can we find the ones that have aluminum blades?
Thank you for posting that.
Post by: truesearch on February 20, 2018, 07:34:01 PM
@aether,
Is that fan that you started with like this?
https://www.amazon.com/Ezire-Personal-Aluminum-Compatibility-Operation/dp/B072MRP179/ref=sr_1_8?ie=UTF8&qid=1519173053&sr=8-8&keywords=usb+fan+aluminum
That is an interesting effect that you are getting.
truesearch
Post by: sm0ky2 on February 21, 2018, 12:58:33 AM
What is the method for detecting this "energy"?
Post by: sm0ky2 on February 21, 2018, 01:07:56 AM
If I had to guess, I would say there's an energetic little ghost
inside the aluminum, I think his name is Eddy
