My posts will not be frequent. Wesley
1. this schematic of the pump is not mine and it applies to electrical equivalent of water pump but this is absolutely the concept of electrostatic pump. ( search Free Energy Well Pump to find it - it is on web side not on video )
2. kapanadze coil capacitor https://www.youtube.com/watch?v=0Z3S4R_wycU (https://www.youtube.com/watch?v=0Z3S4R_wycU)
3. kapanadze coil capacitor https://youtu.be/0Z3S4R_wycU?t=597 (https://youtu.be/0Z3S4R_wycU?t=597)
Please note that frequency of spark gap is very low ~ 20Hz
4. Kapanadze Tent presentation - bank of capacitors serving as part of coil capacitor circuitry If you interested than please find model number and internal structure of it
Wesley
This is copy of translation done by:AlienGrey from Russian into EnglishQuote from: AlienGrey on May 25, 2018, 01:56:22 PM
Logged
stative
Hero Member
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #19885 on: Today at 04:26:04 PM »
Arunas may the ask You for help with the Translation as with the a well:
the Conversation of by Wesley with the Cheshire Cat https://www.youtube.com/watch?v=_9foRzZEZRo&t=613s (https://www.youtube.com/watch?v=_9foRzZEZRo&t=613s)
Please note Note That larger part of such conversation is not related to the this are subject
and there are few separate conversations.
find the right one.
Wesley says:
Easy answer: the
density of the electron beam in the conductor: electrons of different types of atoms have different degrees of freedom to move.
With some types of materials, such as metals, the outermost electrons in atoms are so loosely related,
that they randomly move in the space between atoms the effect of temperature changes in the room so that there is no need for an electric current in the conductor.
Since these practically unconnected electrons are free to leave their respective atoms and float
around in the space between neighboring atoms, they are often called free electrons.
In other types of materials, such as glass, the electrons of atoms have very little freedom of movement.
- the insulating material (foil) acts as a medium for increasing the electron density)
If we want the electrons to flow in a certain direction in a certain place,
we must provide the correct way for them to move, just like a plumber must
install a pipeline so that water flows where he or she wants it to flow.
electrons can move freely in the conductor.
They have a drift speed of 1 cm / s, but when we see a conductor (for example, an antenna), the electron
does not actually move along the entire length of the conductor, it just vibrates around its middle position, and its energy comes forward.
============================================ The
actual drift velocity is highly dependent from the geometry of the conductor, the magnitude of the current flowing
and the density of the mobile charge carriers (the drift velocity is proportional to the current and inversely proportional to
the cross-sectional area and the mobile carrier density). 50 Hz, in Russia,
electrons do not drift very far.
A large number of electrons collectively shift their positions .... a little, but the current but can be very high
Signals:
propagate along the wires at very high speeds.
If the lead is excellent, the signal propagation speed depends on the insulating material around the wire.
This is due to the fact that the energy transfer is actually in the electric and magnetic fields.
The Poynting vector is E transverse B and is proportional to the energy flux per unit area per unit time,
and since the electric field vanishes inside the conductor, no energy flows inside the conductor (!),
Only from the outside, in close proximity.
The propagation velocity of the signals then depends on the dielectric properties of the insulation, and usually
about 70% of the speed of light.
The electrons only flow in the conductor to satisfy the conditions of the electric and magnetic fields
obeying the Maxwell equations on the conductor surface.
About alternating current - the average AC value of the current in the circuit must be zero
(if there is no DC offset), the current flows back and forth continuously,
The opposition to the current flow through the AC Condenser is called the Capacitive Reactance
which itself is inversely proportional to the 'supply' frequency of the supply
This factor is directly responsible for storing the energy and density of electrons in the conductor.
so the larger the diameter of the conductor, the higher its ability to temporarily store energy
. So this is not really a diameter that is important, but the surface size of that conductor.
It can be porous or deformed.
================================================== ===== The
collection of the time charge can be made at any frequency (for example, the frequencies of the arrester spectrum,),
but the energy is fed further on at the resonant frequency of the equivalent of the LC circuit of this coil.
The best signals for this are narrow but short rectangular HV pulses. One of the best known methods
consists of two generators. ABOUT
One generator produces a sinusoidal signal at a frequency of 5-20 kHz, and the second oscillator modulates the sinusoid modulation
with a narrow high level of the deviative position-
or better say the positions on this sinusoidal signal (the best position is 5 degrees
after the maximum position of the positive sine wave)
Kapanadze's reel in the aquarium # 1 was made of a wide copper foil to increase its surface.
If you want to have a shorter coil length,
However, two copper foils, insulated with foil, greatly enhance the capacitive resistance of these two or
three or any number of them - the copper foil must be connected very accurately.
If you connect the last two ends of this foil together, you removed / removed the reactive impedance components to zero.
You do not want this to happen. (Bifilar form of communication).
Therefore, all the front ends must be connected together and have a foil in between.
But only one end should be used from the opposite end
to better understand this: - Take 10 thin copper strips of copper foil 5 cm wide - take 10 thin strips of foil 5 cm wide
If you use high voltage for pulses than the insulating film should be wider 5cm + 1cm ~ / = 6cm
- stack them one on top of the other.
-You can roll them up like a capacitor
- Front end (all insulated between copper strips) are soldered together.
- the other part (10 strips of copper foil), only one end of the length of use of the sandwich can be, for example, 10 m
but when it is rolled into Cylinders, it occupies little space
resonance frequency of such a condenser coil depends on its capacitance and inductive reactance.
Quick the Translation:
to the get a better Understanding of the this - take 10 thin copper foil strips 5 cm wide
the If you use high voltage for Pulses than the insulating film Should the BE Wider 5cm + 1cm ~ / 6cm
-You can roll them up as a condenser
- the front end (all insulated between copper strips) is soldered together but only from one side. That increases surface of such structure adding to it capacitive reactance.
On the other end of (10 strips of copper foil), you only use one end out of 10.
ther rest 9 ends must be not connected.
to better use the length of such a sandwich you can:
roll in all of them into a form of cylindrical structure.
Such structure occupies small space.
The frequency of resonance of such a coil capacitor depends on its capacitive and inductive reactances.
Spark gap bandwidth is from single Hz to 1GHz with one but significant High amplitude region.
Collecting energy by such coil capacitor is taking advantage of all of that spark gap spectrum components.
But output of coil capacitor ( the far end of just one of the 10 single copper strips) does it at resonance frequency of such coil capacitor.
IF you have noticed Tariel in TENT SHOW used humongous coils ( not Grenade) but strange it was to see big bank of AC capacitors next to it) !!!!
I assume but I'm not sure that these capacitors have been slightly modified to to form described by me here.
If not than please take model number from TENT PRESENTATION of such capacitors and you maybe able to find drawings of its internal structure
At the right frequency of stimulating impulses, you will be able to get the trigger of coil # 11 (or otherwise coil that is connected to the ground with diode)
look below for instructions.
Note:
by that we may also understand that use of capacitors.
How to make electrostatic pump:
You can also add another copper foil number 11 along with the other 10 (copper foil).
This copper foil is not connected at all to another.
Now connect this copper foil to the ground wire using a diode between the ground and the foil.
Polarization of the diode must be in its conducting direction from the ground to the copper foil.
You have now made an electrostatic pump.
И это - 90 % успеха вашего СE. (закрутите винтoм орехи царя)
Quick Translation :
You can also add another copper foil number 11 along with the other 10 copper foils.
This copper foil is not connected at all to set of others 10 foils.
but this strip is winded along with other 10 copper foil strips insulated in between .
Again please understand that even if these 10 strips are connected together from one side ,their surface is 10 times bigger than single copper strip.
that work at significantly lower frequencies .
this concept is taken from Tariel Kapanadze aquarium #1 ( the red coil cpacitor with shiny something in the middle).
You can see from the picture that he soldered all of copper strips in the middle
and than winded all together.
Than only one from strips was used from outside
I hope you can understand it .
And now connect this copper foil #11 with the ground wire using a diode in between
( using a diode between the ground and the foil #11.)
And this is 90% success of your FE. ((tighten the screw around the Russian king's nuts))
It is to much to translate. Try to use translator I hope it will come somehow logical.
This is due to me being allowed now to go that far with sharing of information that is in my possession.
-Please understand that number of strips is not critical.
- It is just one of solutions of Tariel.
- electrostatic pump is my own way to explain processes
Tariel was able to intuitively by errors and trials to understand how it works.
Tariel is not so advanced to be able to explain why it is happening. He only knows how to make it.
Later modifications especially by SR193 have been using slightly different approach.
Grenade coil serves partially similar function using canceling of reactances in 3D geometrical space of adjacent coils
It is not only one way to get results .
That is why I concentrated myself on understanding phenomena .
Honestly ....
Wesley
PS;
4. Kapanadze Tent presentation - bank of capacitors serving as part of coil capacitor circuitry Please find model number and internal structure of it
I did my part you do yours
Hi :)
I know this is a little out of your wheelhouse - so to speak... but was wondering what you thought of this idea...
(PDF attached of patent, next message has links to patents on web)
https://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg521687/#msg521687
Unfortunately the original videos are no longer available.... The difference between patent and Pierre's device is DZ Generator uses manual switching instead of external phases...
Hi Wesley,
Its good to see that you have started your own thread.
You wrote: -
"But interesting point I could make here:
not always all of the factors are immediately visible.
My friend is science Dr. Roy likes to say.
"Only the magician knows his tricks."
that does not mean that automatically all tricks are not scientifically valid."
A wise guy your Dr. Roy!
I hope you won't take this the wrong way but you do come across as being strongly biassed towards the opinion that Kapanadze's devices are genuine self-runners. I find this rather strange that given you clearly have good technical training and education and yet, although you have seen some of Kapanadze's first hand, you have never had the opportunity to conduct a proper physical instrument based technical analysis on any of them.
I'll leave you with these shots from Kapanadze's / Akula's videos that I feel uneasy with: -
Some notes from Zeitmachine in a other Kap[anadze related thread.
A COLLECTION OF GUNTIS/COSMOLV STATEMENTS
1) Tariel said, the device is very simple;
2) 220V goes in and 220V goes out; 50Hz;
3) everything is in the coil setup - actually in windings; it is a bifilar coil but in non-standard way, closed looped by itself;
4) all magic happens between coils; trigger coil is the output power coil; try to put your mind back to those years; no semiconductors, no RadioShack - nothing, just wires and transformers;
5) most important thing is to generate sharp pulses;
6) device is not transformer but choke where high voltage - no more than 2000 volts - produces light ionization; what you need is little high voltage to give birth to new electrons and lots of electrons forming around the wires, the second thing is to activate these electrons;
7) a static field or ionization is also called a dead magnetic field, but we can convert this field to perform work;
8) high voltage in specific frequency creates a dead magnetic field; if we synchronize this high voltage with the low voltage half-wave, then we can turn the core in an electric generator and it works like a combustion engine;
9) high voltage is injector and low voltage is piston, magnetic field is combustion chamber;
10) when impulses are generated, a magnetic field is created in a bifilar coil, so in total you have one source, but in fact you have resonant magnetic generator with two fields;
11) it is not enough to loop electricity through coils, you need to interact with medium (make a bridge); but remember always and always this is manipulation with time;
12) ions are attracted by ionization, this high voltage field is magnetized with vibrations and we get a very powerful magnetic field and this field is the outside power; energy is received on coil through magnetic field, not electrical or electrostatic;
13) this device is not a toy, it has a great ability to change our lives and it needs to be done in a smart way; we need to think globally; if anybody release schematics government takes fast control of it, it will be turned as illegal immediately; actually the effect in this device is very specific magnetic field, the technology by itself is like atomic reaction, but without pollution of radiation; BUT ... this magnetic field, if you make it stronger, it can kill you in seconds or, if you make it stronger, it can cause an effect like an atomic bomb; you cannot change the world or change the rules of our governments. With this device YES you can! Free Energy is only one side of it, other side is the most powerful weapon in human history after Nuclear Power! By the way, nuclear power sits far back compared to this (Free Energy) principle; it generates its own magnetic field which is not dependent of earths fields, without earth grounding the device produces too much power, but this is different story which is not related to Free Energy, there are more things, not only Free Energy ...
This seems to me related?
Quote from: stivep on May 27, 2018, 05:03:06 PM
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg521745/#msg521745 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg521745/#msg521745)
As of Today at 5 PM Eastern Time I have made addition to material posted previously.
Please visit link form above to see changes.
there it is.
Coil Cpacitor however there is no need to build one just fallow instructions on picture below
Wesley
On this Kapanadze device presentation in Turkey is ordinary "cosinus" capacitors. This capacitors used in industrial electric equpment on 50 Hz. These capacitors allow a long-time alternating current through themselves to several tens of amperes without overheating. Not very much amperes trought one, for example a capacitor of 20 kVar at 400 volts allows a current:Icap = 20 000 Var/400V* sqrt(3) = 29 A. These capacitors can be used in a resonant circuit at a low frequency, 10 to 500 Hz, with connecting many capacitors in parallel. These capacitors are not suitable for the Tesla coil due to overheating on the HF.
I think that this circuit with capacitors is needed by Kapanadze as a converter-"filter" of dirty nonsinusoidal current from his hidden X-Source into a pure sine current of 50 Hz, suitable for use in a conventional electrical network.
https://www.alibaba.com/product-detail/2017china-wholesale-market-three-phase-kvar_60684828500.html (https://www.alibaba.com/product-detail/2017china-wholesale-market-three-phase-kvar_60684828500.html)
Ok, Thanks Wesley, I think I do understand now, so just to be sure... before rolling the coil capacitor it should look like this: (side/ profile view)
and what frequency is recommended for 10m long, 5cm wide strips? and what type of impulses?
Re a coil capacitor....
This is a massive coil, wound just double layer (one inside, one outside). Inside is a large neodymium magnet, when it rotates, it generates a current flow in the coils. The coil ends independantly can be used as a + potential and a - potential, and thereby have a charge stored in the coil... this charge can then be used to kick the magnet to continue to rotate. There is very little drag effect because of lens when the coils are open...
https://www.youtube.com/watch?v=0xLFl5RhNgU
(I dunno it's been a work in progress for a while... this is somwhere in the middle... but towards the video leadin)http://open-source-energy.org/?topic=3128.msg49555#msg49555
Apecore this was the last Kapagen built, I almost electrocuted myself, way too dangerous to use 3200 volts in the ground. Also what was not seen was the Fe Mg Zr core inside that puts out beta electrons. That I self censored this device, I am really sorry for that... Need to study "spinwaves" as this Kapanadze devices type work on this method as I have posted this over many years and nobody seems to grasp that maybe Wesley only.. Iron isotope (s) will go nuke with ultrasonic waves and that sound is very bad as in the high pitch , Fe TV core will do that in each half that is why the paper is needed in that split.. Be very careful of that sound...
Acca..
Apcore yes T H Moray talkes about it. I will find it for you !
http://cheniere.org/books/excalibur/moray.htm
http://www.rexresearch.com/moray2/morayrer.htm
The Lilly Wave And Psychotronic Warfare.
http://thebridgelifeinthemix.info/technology/the-lilly-wave-and-psychotronic-warfare/#sthash.Vm2e0oDQ.dpbs
Quote from: ramset on May 30, 2018, 07:37:53 PM
NMR safety issues aside
If what AG is posting is true... "Psychotronic Warfare".[which would not surprise me]
Tinfoil hardhats should be standard issue during times of civil unrest or "other" :o
What you don't have one all ready ;D do you have an i phone ?
there is always the god frequency I wonder if that would work any better (the music tone before the
nazi's changed it ? don't know what i'm on about) that's a pity
Well the Schumann frequency is 8 but the universe is a 9 multiply 8 x 9 = ?
Talk to Stella about his research into the subject.
https://www.youtube.com/watch?v=GnEWOYKgI4o
AG
Quote from: Hoppy on May 30, 2018, 05:42:27 PM
I have always thought that ferrite is more likely the source of any free energy available, rather than the earth giving up energy from telluric currents or aetheric energy from high. I can also envisage potential danger in experimenting if this is the case, which is one of the reasons that I have stopped chasing the rainbow, at least until a lot more information on the true modus operandi is available and fully understood.
Seems reasonable,
It seems AG s post does points out some potential risk doing experiments.
Either we use a tin hat or we need to avoid those critical frequenty?
We should do some roundup in which freq. we need to avoid.
Greetings
Here is where the Italians discovered FeCl goes nuclear.. Sorry about the size
and so does (Fe Zr Mg) core.. P.S. it's the "TV core" yoke everybody..
Acca...
For these skilled in art:
You know what I'm talking about
Для специалистов квалифицированных в искусстве Вы знаете, что я говорю ...............
Уэсли
Wesley
And just did a search for FeZrMg alloy and the search engine went off line. Ok for other things tho. Hmmmmm?
Starting to see a pattern here. But then, if the combo goes beta, wouldn't want to be messing with it anyhow. Now without some lead sheilds.
As far as I'm aware :) Tariel in Green box used two grounds apart from each other.
1- cold water pipe.
2 copper radiator soaked with water and buried at depth of ~1.75 m
the distance between two grounds was around 25m
and now compare it to Wesley's contribution
Насколько я знаю, Тариэль в зеленой коробке использовал два гранда
1 - труба холодной воды.
2 медь: радиатор пропитанный водой и похоронили на глубине ~1.75 м, расстояние между двумя грандами былo около 25 м
и теперь сравните его с Уэсли и вклад
Note: please note that distance between grounds is pointed here - not distance between components of Tariel device.
Нота: прошу обратить внимание, что здесь указано расстояние между грандами, а не расстояние между компонентами устройства Tariel.
Wesley
At 11:23 in part 1 it can be seen that the water pipe is the only ground, as the end of the radiator cable can be seen laying on the ground. Despite this Kapanadze has claimed that the devices self-run with just one ground connection. The Aqua 2 device clearly demonstrates this.
Take a look at this shot: -
Quote from: Hoppy on June 02, 2018, 04:53:11 PM
At first video show (prior to link at 10:04) car radiator being buried. https://youtu.be/Goq76CQapyI?t=257 (https://youtu.be/Goq76CQapyI?t=257)
please look here .
https://youtu.be/Goq76CQapyI?t=604 link at 10:04 (https://youtu.be/Goq76CQapyI?t=604)
then video shows water pipe connection at 10:58 instead of radiator connection
https://youtu.be/Goq76CQapyI?t=658 (https://youtu.be/Goq76CQapyI?t=658)
Wesley
https://youtu.be/Goq76CQapyI?t=474 (https://youtu.be/Goq76CQapyI?t=474)
1. http://www.searchanddiscovery.com/pdfz/documents/2014/41332nelson/ndx_nelson.pdf.html NOTE: you need to place mark
I'm not robot 2. https://en.wikipedia.org/wiki/Earth_battery (http://www.searchanddiscovery.com/pdfz/documents/2014/41332nelson/ndx_nelson.pdf.html)
QuoteTo use the natural electricity, earth batteries fed electromagnets, the load, that were part of a motor mechanism.
3.https://babel.hathitrust.org/cgi/pt?id=nyp.33433023210184;view=1up;seq=80 (https://babel.hathitrust.org/cgi/pt?id=nyp.33433023210184;view=1up;seq=80) this is simply a jewel. 1885 book talking about earth battery construction start from page 72
it is related to third picture below
Wesley
http://www.searchanddiscovery.com/pdfz/documents/2014/41332nelson/ndx_nelson.pdf.html (http://www.searchanddiscovery.com/pdfz/documents/2014/41332nelson/ndx_nelson.pdf.html)
Wesley
Quote from: PolaczekCebulaczek on June 02, 2018, 03:01:18 PM
really? I always fought that green box worked on two ground wires, one for water pipe and other for buried radiator. I also dont like the Arunas diagram too, tesla coil secondary does not have such sharp waveforms?
Hi guys,
You could just drop PM to me while getting confused with that pic which Wesley added.
First at all, the one ground rod or two ground rods it does not matter.
Second, the Tesla coil and middle plate of capacitor(top load) are separated by spark gap in that pic. Which is giving spikes we all need.
Third, you have to utilize electrostatic laws in order to gain more particles on the wire from the ambient. This is where current gain is without using power source.
Cheers!
Wesley
Quote from: forest on June 03, 2018, 09:34:41 AM
First we must be sure about the energy source and the mechanism of extracting it.
Good you mentioned that part.
In situation we have with Kapanadze style devices - we are dealing with what is the current on the wires and what happens when more particles with charges are injected into wire.
As soon that is realized there is current amplification in result. Which is your Volts x Amps = Power on output.
T-1000
I agree about particles injected, but first how they are injected and second : how they are created or maybe they are already here but dormant till excited (Don Smith).
In fact this could be as simple as photoelectric effect caused by concentrated "cosmic rays" - that is explanation of Henry Moray and Nikola Tesla. Cosmic radiation may be involved also indirectly, that's my hypothesis. Somebody with knowledge and radio tools can easily prove Tesla radiant energy patent by using directed radio antenna, HV capacitor , HV diode or Avramenko plug and of course ground connection. Such experiments should already be in books. EM wave directed to polished and insulated metal plate connected to diode and one side of capacitor when other end is grounded should charge that cap (or AV plug used).
Quote from: stivep on June 03, 2018, 11:18:49 AM
Hoppy says:if this "source of energy" was hidden "out of sight" than it must have physical connection but you did not see it as well as you did not see two ground connected at the same time.
by that my last post remains valid and worth to be answered in the manner ( format) I provide my answer to you.
Wesley
I posted a clip showing what I think could be the physical connection. Can you see a telluric or aetheric connection or is it hidden. ;) Sorry if my formatting is not to your satisfaction. Good game.
I look forward to your next tranche of sketches on the theoretical modus operandi for the Kapanadze devices.
Quote from: Hoppy on June 03, 2018, 11:39:25 AM
aetheric":
QuoteSome curious distance-phenomena connected with electric sparks were observed in 1875 by Edison (who referred them to a supposed new " aetheric force "), and confirmed by Beard, S.
This wording can be excluded as phenomena in question have been discarded by official science. ( discarded: " no longer useful or desirable.")
the rest of remaining quote sounds like:
QuoteCan you see a telluric connection or is it hidden
However it is difficult to respond as we are talking in two different formats
I do appreciate your answer:
Yes I can see presence of telluric current in format that was explained by me in form of two grounds, at this particular video ( https://youtu.be/Goq76CQapyI?t=474 (https://youtu.be/Goq76CQapyI?t=474) )
6V measured by clamp meter .
For these who do not understand two ground connection please read my previous posts.
It was practically explained in 1885 without having any theoretical knowledge of science at 2018. They just could see phenomena and they could not explain its nature.So they did their best ( year 1885)
that is why picture from below should be interpreted as:
- YES we practically see something in 1885
- Yes we know how to practically use it in 1885
- NO we interpret it differently in 2018.I include again picture below
Wesley
Since this is Wesley's forum I am listing two clips form a Russian man in South Korea that is now selling the magnet generators to all for 28 K.. UNLISTED
as to the energy it's from magnets.. will provide more later..
Accca..
https://www.youtube.com/watch?time_continue=27&v=5XsjdSooSnw (https://www.youtube.com/watch?time_continue=27&v=5XsjdSooSnw)
https://www.youtube.com/watch?v=tldhi6nG2Zg (https://www.youtube.com/watch?v=tldhi6nG2Zg)
I see all kind of theories discussed,fact all of kapanadze devices operate at 50hz,in some devices
theres a frequency meter showing just that.In the green box video there is missing angles to show it could be real
this opens the door to people saying its a fake.The output in the green box video is
220v ac,it goes thru a stepdown transformer to provide a dc current to loop the device.The 5 lights
operate at 1000 watts each so 5 equals 5 kilowatts output.Every time the arc jumps a very large pulse
is induced into the coil carrying 220 ac it is mixed with this pulse,this causes a digital voltmeter to not show an ac voltage reading correctly
as is shown in the video.In addition this particular clamp meter, has a defect where it can show a fake current reading
I have a clamp meter like in the video it has this defect,I also setup an experiment to show this effect and posted this a long time ago.There is no current from the ground connection
at all.Tariel uses tricks to fake people out,he pushes its a Tesla invention because people believe Tesla is a
god,so focus on Tesla and go around in circles,its not a Tesla invention nor has anything to do with Tesla.
Tariel wants to sell the idea of a free energy device,but will never reveal the secret,because you can't sell this device
so hes video's are not meant to fully prove hes devices are real only to convince the investor its real to rob him.
For hes devices to be real the sources of the energy have to be very powerful given the large currents
powering the various loads.Could it be fake,its possible it could be fake,however,Tariel must be a genius
in faking people out,or the people viewing hes devices are dumb as shit or it could be the devices are real,but operate in a completely different manner than any known device.I'm of the opinion they operate in a completely different manner,conventional theory will not work.
In the style of Wesley. :) Boasting.
Finally I repaired it! Ancient spectrum analyzer, USSR, 1970s.
10 MHz - 40 GHz
It cost me a little money and a lot of work.
In both the green box video and the 2005 video he runs a stepdown transformer
with a bridge rectifier to provide feed back to loop the device,what voltage do you think
that transformer operates at and what frequency.
The clamp meter I have is made by the same company as the one in the green
box video,I bought it from harbor freight a while back.In the green box video your inducing large pulses,
why do you think he can't read 220 vac in a part of the video
,because the pulses cause false triggering in the meter.
Tariel is a very smart guy he must have discovered this fake current effect and used it to
create a wild goose chase.The arc ,spark gap and the large coil serve no purpose, its to fake you out that's related to something Tesla invented.
In one video he shows a 3 phase device in it ,there's a panel
that has a frequency meter it reads 50 Hz.
A certain Canadian guy presented a theory that the green box is fake
there is missing a few angles that would show hes theory would not work
however the green box video is missing these angles this was not an intent
but simply there not shown,so it could be a fake device based on the video shown.
Figuring where things go from a video is hard if an angle view is missing.
I'm from the USA.
People tend to idolize Tesla and almost refer to him as a deity
this causes them to make mistakes.
Everything starts out as an opinion,is something plausible, is what I ask,
does this means its completely correct no ,but it is possible.
What the voltage is and what frequency is,is important as related to the type of load used.
I don't see you provide any scientific proof,your assuming that the
measurement of the ground current was correct,and speculating on that.
Since you don't know how hes device works,your no better than anyone else.I can see that your not open to new ideas and have an ego problem
also,so this will be my first and last post.
https://www.youtube.com/watch?v=BgqUyJwdfVk
Two frequency meters show the output is 50 HZ
here is a jpeg of one,its a 3 phase device
If you want to understand Kapanadze you must see all videos of all devices together then search for missing answers in Barbosa&Leal patents. Wesley is partially correct , it's the flow of energy which exists around us, differently explained by various inventors. Some said about telluric currents, some about atmospheric electricity (even Figuera !) some about Earth magnetic field, some about cosmic rays or strange "aetheric force".
THEY ARE COMBINED , that's why we can't find the proper theory. We have situation of multiple energy sources and effects. Add to it possibility that magnetic field is a flow of stead state energy from different space-time and you see what a mess we have to explain !
Quote from: forest on June 04, 2018, 06:06:17 AM
This is good in theory.
https://en.wikipedia.org/wiki/Relativistic_electromagnetism (https://en.wikipedia.org/wiki/Relativistic_electromagnetism)
But how to this theory solder transistors and light bulbs? >:( It does not matter who and how, Tariel or someone else will start the topic and tell how to do it somehow.
Quote from: Sergh on June 04, 2018, 06:54:26 AM
if that is so, look no further than a Don Smith circuit and device lay out, if what you say works for you ;D
That was a long time ago... :'( Here is the original, "first release":
https://www.skif.biz/index.php?name=Forums&file=viewtopic&p=106822#106822 (https://www.skif.biz/index.php?name=Forums&file=viewtopic&p=106822#106822)
Dropbox :since this is more like diary or storage box I will store here some handy links that I found to be interesting or important.
So this is my :
Dropbox #1
High Voltage Electrostatics: http://www.keelynet.com/ (http://www.keelynet.com/)
-intro to electets:
htthttp://www.keelynet.com/electret.htmp://www.keelynet.com/indexjan16.html
-Self-Generating Electrical Discharge Alexander V. Frolov :
http://keelynet.com/energy/frolov1.htm (http://keelynet.com/energy/frolov1.htm)
http://keelynet.com/energy/frolov2.htm (http://keelynet.com/energy/frolov2.htm)
http://www.rexresearch.com/chernetskii/chernetskii.htm (http://www.rexresearch.com/chernetskii/chernetskii.htm) Plasmatron (this link is partially BS but has important information)
http://revolution-green.com/high-power-electrostatic-motor-95-efficency/ (http://revolution-green.com/high-power-electrostatic-motor-95-efficency/) High Power Electrostatic Motor with 95% Efficency
https://www.youtube.com/watch?v=H6oAZi8Cc5I (https://www.youtube.com/watch?v=H6oAZi8Cc5I)
three components we need :
1.electrical motor 1 or 3 ph.
2. capacitor
3. diode
all of them are present in the video.
The guy has no idea about (conditions and components needed):
a. resonance frequency
b. two grounds ,
But he has Variable Frequency Drives VFD
to get anything is needed.
(this video in in relation with material from above)
https://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg400411/#msg400411 Solar Lab reference links.
Wesley
Tinsel your a clever guy! any idea how I can generate a 9hz stand alone tone from a freely available crystal by division or knocking out bits ?
Since 9hz appears to be a resonant spacial lock on frequency rather than 8hz, the Don Smith device for one at 35.1khz.
Many thanks
ag
Quote from: AlienGrey on June 10, 2018, 06:17:24 PM
Many thanks
ag
Uh huh. I see you posted a link to my "subharmonic" demonstration video... but the message was lost on the target audience. Oh well.
Meanwhile: this might work for you:
MicroSemi ZL30167: among many other features:
"Four Programmable synthesizers generate any clock rate from 1 Hz to 750 MHz"
https://www.microsemi.com/product-directory/otn-timing/4622-zl30167
Get the exact, stable frequencies you need, beat them together, have a fine party.
Of course if you don't need absolute stability or multiple independent clocks you can generate a reasonable 9Hz signal with a 555 timer chip and a few resistors and capacitors.
So here is another factor supporting working model of Tariel Kapanadze devices promoted by me
Рабочая модель Тариэля Капанадзе, продвигаемая мной.
На этом острове нет электричества.
Тариэль подключил к устройству нагрузку 10 кВт. в виде лампочек.
Мы знаем что электродвигател без механической нагрузки тянет больше тока, только в течение первых нескольких секунд .
После этого требуется часть "начального тока". (этот конкретный двигатель ~ 0.71 A при 220V.)
Почему Тариэль нуждался в этом моторе?
Ответ в сообщении, -( сделанны мной ранее.) Просто прочитайте
Here below is the picture form presentation that was made on deserted remote island .
There is no electricity on that island.
Tariel had 10kW load connected to the device. in form of light bulbs
We know that electric motor without mechanical load takes larger current only during first few seconds and after that takes fraction of "start" current.
this particular one ~0.71 A at 220V.
So now THINK MY FRIENDS ...
Why Tariel was in need to have that motor there?
or
as an answer you take material posted by me earlier?
https://www.youtube.com/watch?v=oXLxTjc9m3k (https://www.youtube.com/watch?v=oXLxTjc9m3k)
Wesley
Many thanks
ag
Interesting, tell me more
Wesley
Quote from: stivep on June 10, 2018, 11:21:01 PM
Wesley
Well Well it's complicated but with out going in to it too much, but it looks like the earth resonates at a base frequency of 8hz
and the universe at 9hz it can get spooky but things tend to end up being high energy based at ether one or the other frequency, or a
combination like 432 adds up to 9 the energy of the universe creation it self like it or not, and also divides equally 9 and 8 and it also in
harmony with us humans as in PLEASING HARMONIOUS music.
If your going to pick a frequency or vibration everything has to be in tune.
However base 9hz or 432hz is not an easy frequency to synthesis of the shelf!
What does it have to do with this subject ? EVERYTHING!
AG
A century later EINSTEIN introduced Special Relativity and since then it was common to summarize MAX-WELL's equations with four-vectors.
http://www.zpenergy.com/downloads/Orig_maxwell_equations.pdf (http://www.zpenergy.com/downloads/Orig_maxwell_equations.pdf)
Wesley
Quote from: AlienGrey on June 11, 2018, 07:11:07 AM
... think i will try and get a a 9mhz xtal and a tube of cmos decade dividers 8) 8)
Hi AG,
You may consider these to get a 9 Hz signal:
1) There is accidentaly just a 9 kHz crystal on sale at ebay ( https://www.ebay.com/itm/263714732731 (https://www.ebay.com/itm/263714732731) ) and you divide the 9 kHz oscillator you build from that crystal by 1000 to get 9 Hz. No need for a tube of decade dividers but only 4 pieces... ;D
2) There is the NE567 (LM567) tone decoder IC you may know or be aware of. It has a precision RC current controlled oscillator (better than that of say in the NE555) capable of operating from very very low frequencies.
What I think it would also be practical to run the built-in oscillator at 9 Hz and phase lock it to the 9th harmonic of a 1 Hz reference clock you derive from a normal 32.768 kHz oscillator and divider chain used in crytal controlled watches.
Yes, the 9th harmonic of a 1 Hz square wave may have a small amplitude at 9 Hz but using say a 2nd order active op amp band pass filter for 9 Hz would help to clean up and amplify the 9 Hz signal component to feed the phase comparator input of the NE567 and establish phase lock with its internal oscillator, that would be your 9 Hz output signal.
Of course you would need to use good quality RC components for the active filter and for the NE567 oscillator (R1C1). Here is the data sheet: http://www.experimentalistsanonymous.com/diy/Datasheets/NE567.pdf (http://www.experimentalistsanonymous.com/diy/Datasheets/NE567.pdf) and pay attention to the several application hints too. Texas Instruments still manufacturs this IC as LM567, what is more a CMOS version LMC567 too.
Good luck. 8)
Gyula
PS, Wesley, sorry for this off-topic...
Guys,
I don t know its origin.. or its final doc.
Quote from: apecore on June 11, 2018, 02:46:15 PM
Guys,
From Gerry Vassilato's book
http://www.shamanicengineering.org/wp-content/uploads/2014/07/Gerry-Vassilatos-Secrets-of-Cold-War-Technology.pdf
http://borderlandresearch.com/book/secrets-cold-war-tech/chapter-1/7
Tesla doing disruptive discharges and projecting scalar waves (just voltage potential) that would manifest into current in distant metallic plates
We also found the shocking effect when tapping a stick welder's positive electrode to a large metal plate. Everybody in the room could feel a shock on their face and skin
Quote from: Belfior on June 11, 2018, 04:02:34 PM
Belfior,
Is it possible to repeat the "test" a several times to see if the effect occurs again?
Maybe ypu could also register some parameters... like voltage.....air moisturecontent etc. to see what the important parametersare?
Greetings
Quote from: gyulasun on June 11, 2018, 10:39:01 AM
Hi AG,
Good luck. 8)
Gyula
Gyula thanks for the information I already have a a simple circuit to produce 1hz from 32k768 xtal it' sorting out the 9hz from it that will deserve some thought I already have a couple of LCM567.
cheers
Any way might use a cd4046 and a 4017 divide by 9 should give me the 9hz or any freq 1 to 10 or a chip that has jam inputs not sure yet depends what bits i have.
AG
Hi AG,
You may find this paper (http://www.n5dux.com/ham/files/pdf/Synthesized%20Pulse%20Generator.pdf) also useful from this site (http://www.n5dux.com/ham/files/pdf/) once you fancy CD4046. :)
Gyula
"Dr. Le Bon's texts contain secrets – very deep secrets as concerns radioactivity and the various means of releasing the intra-atomic energy of which he is the true discoverer. As has been validated, Dr. Moray often would study these texts of Le Bon in order to further pursue his various directions in the field of materials science and of vibratory dynamics. Presumably, these topics were advanced far beyond what we have been told, although we see very clear indications that Dr. Moray was learning the exact modes of applying techniques which Dr. Le Bon had begun to utilize in his Belgian laboratory."
The Evolution of Matter
The Evolution of Forces
Two texts by Gustave Le Bon
Reviewed by Gerry Vassilatos
https://borderlandsciences.org/journal/vol/46/n02/LeBon_Evolution_of_Forces_Matter_Review.html (https://borderlandsciences.org/journal/vol/46/n02/LeBon_Evolution_of_Forces_Matter_Review.html)
It's energy from the nucleus that is Kapanadze secret as the amount of particles from this de-stabilization of Fe in the TV core would be so small that it would require very precise instruments to determine that. As to Free energy it's in the "atom"..
Acca..
Wesley thanks for the history, as I also work in Earth sciences..[/font]
It's good sometimes to read old American books.
In the books you can find answers to various questions.
http://www.gutenberg.org/files/1805/1805-h/1805-h.htm (http://www.gutenberg.org/files/1805/1805-h/1805-h.htm)
http://www.gutenberg.org/ebooks/author/634 (http://www.gutenberg.org/ebooks/author/634)
Yes, the launch for the mass appearance on the forums of the topic of electrets was this video:
https://www.youtube.com/watch?v=qc4jWOKdQQc (https://www.youtube.com/watch?v=qc4jWOKdQQc)
in which a foil with perforated holes is removed from the package.
This film looks like a waste of an electret film from the production of electret microphones. I wrote on several forums several messages about electrets and their properties. It was about 10 years ago. :-\ Then the topic of electrets became popular and spread around the world. :o
QuoteBrooklyn Eagle July 10, 1932 Nikola Tesla states: I have harnessed the cosmic rays and caused them to operate a motive device. Cosmic ray investigation is a subject that is very close to me. I was the first to discover these rays and I naturally feel toward them as I would toward my own flesh and blood. I have advanced a theory of the cosmic rays and at every step of my investigations I have found it completely justified. The attractive features of the cosmic rays is their constancy. They shower down on us throughout the whole 24 hours, and if a plant is developed to use their power it will not require devices for storing energy as would be necessary with devices using wind, tide or sunlight. All of my investigations seem to point to the conclusion that they are small particles, each carrying so small a charge that we are justified in calling them neutrons. They move with great velocity, exceeding that of light. More than 25 years ago I began my efforts to harness the cosmic rays and I can now state that I have succeeded in operating a motive device by means of them. I will tell you in the most general way, the cosmic ray ionizes the air, setting free many charges ions and electrons. These charges are captured in a condenser which is made to discharge through the circuit of the motor.
Probably it will be interesting. My old experiment with electret.
Someone has read that some high-voltage capacitors are sold by a shorted with external jumper. Because they, even 100% discharged, can independently accumulate a dangerous charge. But not every capacitor can do this. Most can not.
Let's create this feature of the capacitors artificially.
We take an ordinary "old scool" capacitor. For example, from the old Soviet microwave oven, K75-15 1 μf 5000 V. (https://images.by.prom.st/89785588_w640_h640_cid249172_pid65412256-11e5040f.jpg)
I chose this. But maybe some other one. I chose based on the fact that the capacitor should be with a combined dielectric. Dielectric - paper and plastic film. And everything is soaked in oil.
The paper does not press through when heated. Otherwise the softened plastic would be pressed and a short circuit formed.
so... let's go..
Very careful! Outdoors, not with combustible materials! Dangerous! Do not repeat!
(I drilled a small hole on the top of the condenser for the escape of gases. But I'm not sure that it's necessary. Depends on temperature.)
We take a small pan. We put the capacitor there. Place a wooden stand under the condenser so that it does not stand on the metal bottom of the pan. Fill this small pan with oil. Sunflower or similar. We charge the capacitor with high voltage (I had 3.2 kilovolts). Leave it connected.
Heat to near the boiling point of the oil, 227 °Celsius.
We are waiting for 20-30 minutes. Switch off the heating.
After 2 -3 hours, when the oil completely cools, turn off the high voltage and discharge the capacitor with a screwdriver.
It is advisable not to cook in this pan afterwards. If capacitor oil gets there, it can be very dangerous for health.
Connect the voltmeter to the capacitor through 1 gigaohm and observe how the capacitor is self-charged "from the air".
If one terminal of the capacitor is grounded, and the other is connected to a polished ball and blow it with ionized air (from Chizhevsky's chandelier) - the capacitor is charged much faster.
The capacitor charges itself to 100 - 200 volts for 20 - 40 minutes. The effect lasted about 2 weeks, gradually weakening.
Under other conditions, it can be different.
To obtain significant energy in this form is not applicable. Although, anything can be.
Scientists call it "Electrostatic Adsorption"
Quote from: AlienGrey on June 12, 2018, 05:03:10 PM
cheers
AG
Re above harmonious frequency's that don't appear to modulate your brain and are reported to have other useful properties of use here. :D
the 11.0592mhz xtal and a CD4060 are capable of producing multiple divisions of the 432hz frequency ie 1.382026 mhz will divide by 432 = 3200.
If this is of any use to you, with out going too deep feel free.
AG
Hi Wesley, guys,
I have been away for quite a while. Very busy with work.
Wesley thanks for posting your ideas on Kapanadze's devices.
A few comments:
It is good to have ideas, but I think most people would agree that at some point you have to put
those ideas to the test on the bench to see if they might 'hold water' or not. My approach over the years has been to take
various ideas found in forums like this and my own ideas as well and try to distill them down to the simplest test setups
I can come up with to put those ideas to actual bench tests.
Regarding some of the ideas you have been mentioning here:
Electrostatic charging of capacitors:
I have experimented with using a high voltage electrostatic voltage applied to one
plate of a HV pulse capacitor (low ESR) with the other plate of the capacitor connected to earth ground, and I
was only able to get a weak charging effect. The capacitor was 'charged' using HV discharge pulses
through a sparkgap and through a HV, high speed diode to rectify the pulses to DC, so the cap could charge.
I tried the HV diode in both orientations (cathode to ground, anode to ground) with the same very poor results.
Results: Very weak charging on the capacitor. Output power would be very tiny compared to input
power to drive the HV flyback transformer.
Using multi-plate capacitors:
I have run quite a few different tests with home-made multi-plate capacitors
at lower voltages being fed in different ways and taking off the power in different
ways and found that output power consumed by a load was always matched with a corresponding increase in input power.
Results: I was not able to find any test configuration that seemed to give more power out than in (at lower voltages).
At much higher voltages and using higher capacitance home-made multi-plate capacitors, you might see
different results, but based on my experiments with electrostatic charging of two plate HV caps mentioned above,
it doesn't look too overly promising from the point of view of my own actual bench test results.
If there is a way to get OU out of such a setup, it would seem there may be something else missing yet.
Wesley, I appreciate your efforts to share your ideas, but I find your ideas are sometimes a little too disjointed
and too cluttered with other info or comments, so sometimes hard to follow. For what it is worth, my suggestion
for people who have ideas of how Kapanadze's or others' claimed FE devices might work is
to try to condense your ideas down and make them as clear and to the point as possible.
Keep other less related comments and ideas completely separate from any specific idea you are trying to relate. :)
Then think about the simplest test setup you can try to put those clarified ideas to the test. If you make an effort to do it
that way, I think you will find that many ideas can be put to the actual test with relatively simple test setups.
Without distilling ideas down to a basic and straight forward and practical test setup, you only have ideas. :)
Remember Kapanadze was apparently not trained at all in electronics and also apparently didn't even have
an oscilloscope, so if his devices really work then the principle behind it would seem not to be very complicated.
From what I have seen, many people seem to try to over complicate things, even though they are aware that
Kapanadze was using only a very simple setup and apparently only had simple measurement tools such as
a voltmeter/multimeter and clamp ammeters.
I understand why many people think Kapanadze's devices must be fake, as how could such a simple
setup such as Kapanadze's early electronic devices such as shown in his 2004 video demo
power five 1kW bulbs fairly brightly and also self power the driving circuitry?
(Note: the 2004 Kapanadze setup showed that it had only one earth ground wire.)
However, Kapanadze has demoed his devices under various circumstances in front of various
different people and no one has so far reported any credible evidence of tricks that I have ever seen.
His devices could be fake, but, the island demo for one, realistically would have been very hard to fake
if the circumstances that were reported about that demo are fairly accurate. Kapanadze was said to have
been taken to a random beach on a random island by boat by some potential investors and his device
ran right there on the beach. For me anyway, although Kapanadze's or any other FE claimant's devices could be fake,
the varying conditions under which Kapanadze has demonstrated his devices over the years lends more credibility
to his claims than many other claimants, at any rate.
Wesley, the idea that Kapanadze's or Akula's seemingly similar setups could be geo-location dependent has also
occurred to me, and I have mentioned this possibility a few times in the past as well. This would mean
that if you are not in a suitable location, all your experiments on these types of setups might be pointless.
Don Smith definitely indicated strongly in at least one of his presentations that geo-location was important
for his earth grounded devices, for which some of the devices he presented were seemingly quite similar to Kapanadze's devices.
Don Smith's claims were not so credible to me however, as I am only aware of one presentation
where Don Smith put his suitcase device to the test in front of an audience, and it was a bit too short of a test
to try to draw any definite conclusions.
One thing that makes me question this geo-location dependent idea for Kapanadze's devices anyway, is Kapanadze seemed
to have no problem demonstrating his setup in Turkey, and I think someone mentioned that the island demo Kapanadze did
was in the Mediterranean area somewhere, if I remember correctly. His device apparently worked well on that island as well.
Akula's setup however, which may be related but different than Kapanadze's devices did seem to possibly be very geo-location
dependent, although Akula apparently did get his dual tesla coil device setup to self run and power one or two small
fluorescent bulbs at the same time, in Germany, according to one video that was posted to Youtube. It wasn't kW's
of output however.
Wesley, if you are interested, I will post info here on a related setup to Kapanadze's devices which I think has a lot of
similarities to Kapanadze's simple bare bones 2004 device and green box devices, and which is quite well documented,
and which I think is reasonably credible as well. Let me know...
Found this while searching an interesting lecture from Don L Smith.
https://www.youtube.com/watch?v=S81tQBaAsuU
watch it while it's still on !!
Did any one bother to observe or view and digest the Don L Smith film, I ask this as it is entirely relevant to our course.
If so you might be interested in the two postings below.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/fluxmg.html
https://en.wikipedia.org/wiki/Perpendicular
I hope this all helps.
regards AG
Cheers Void
If any ones interested on the 'Fux' aspect of the Tesla original device D L Smith worked on.
See link https://donsmithcoils.blogspot.com/2010/06/don-l-smith-device.html
Regards AG
Hi AG,
Okay on your comments in the Stiffler thread, thanks, and hopefully you manage to build a simple synthesizer with reasonably small components count. 8) Have you noticed my earlier reply to you here, perhaps you did:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg522477/#msg522477 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg522477/#msg522477)
Gyula
Quote from: gyulasun on June 26, 2018, 02:07:02 PM
Hi AG,
Gyula
Yes I did thanks however I had already worked through a PCB design by then, but did think of building your design but the the MM5369 looks as if it has gone extinct by 2006 (divide by 17) as well as the 74C90's it might be possible to use a PIC F509 or similar device for the MM5369
See here
http://www.frank-buss.de/PIC100/index.html
and the 7490's a CD4518 dual decade counter that's pretty fast at 8 volts.
If i can solve those problems it would be worth making.
AG
Hi guys.
Sorry that the schematic image is a bit wide. I am in a hurry.
I will just post the schematic and patent doc I was referring to. Don't have time to comment much right now.
In around 1923, an American electrical engineer named Frank Wyatt Prentice was doing research work for the railroad
in the area of wireless power transfer/wireless power control, and says he discovered that sending
a HV HF waveform (at resonance) from a long wire a little above the ground in the freq. area of about 500 kHz
to a receiving loop antenna was giving him a power gain (COP) of about 6.
For now I will just attach the schematic with some explanatory notes I added and the Canadian patent application
document which was approved in 1925. Not sure why he patented it in Canada, but maybe he was working in Canada
at the time, but that is just a guess. Maybe there was some other reason.
He hypothesized that when the long wire transmitting antenna was at resonance at around 500 kHz that it was resonating with
the earth currents and this caused the mysterious power gain (COP of about 6). He used a sparkgap in the long
wire antenna and tuned the wire for exact resonance, and had two earth ground connections at each end of the long transmitting wire.
He used a small tuned loop antenna to receive the power. He stated about 500 W input and about 3 kW output,
powering 50 x 60W carbon filament light bulbs to 'full candle power'. See the attached schematic and patent doc.
Although I am pretty sure he was just guessing about his antenna resonating at the same frequency as earth ground currents
which caused the power gain, he does make some interesting observations about how small height and frequency changes
affected the output power. What really made it work (assuming he wasn't making a major measurement error) is anyone's guess.
Replace the resonant long wire transmitting antenna with a resonant tesla coil and the small loop receiving antenna with a receiving coil
and you would essentially have a very compact version of the setup seemingly similar to Kapanadze. He said you could replace the
earth ground hop with a metal wire, but it reduced the performance. Maybe Kapanadze just figured out how to make this sort of setup
work with a single earth ground connection and much more compact arrangement...
P.S. I forgot to label #21 on the drawing. It is of course a sparkgap.
Frank Prentice may possibly have been a Canadian, as the patent ownership was listed as:
THE PRENTICE ELECTRIC POWER APPLIANCE COMPANY OF CANADA LIMITED
However, for some reason Frank Prentice put his location on the patent drawing as Meadville, Penn'a (Pennsylvania).
At any rate, what I am drawing attention to is the similarities of the setup in his patent doc to Kapanadze/DalyAkula devices. :)
An interesting side note on 'Frank Wyatt Prentice'.
I found an entry on the ancestry.ca website for a 'Frank Wyatt Prentice'.
The info listed seems to match reasonably well with the Frank Wyatt Prentice who filed the Canadian patent:
Frank Wyatt Prentice (1868 - 1937)
Born in Garrettsville, Ohio, USA on 1868.
Frank Wyatt Prentice married Adelia Roberts and had 6 children.
He passed away on 7 Nov 1937 in Hamilton, Ontario, Canada.
https://www.ancestry.ca/genealogy/records/frank-wyatt-prentice_69000255
So, if this is referring to the same 'Frank Wyatt Prentice', it seems he was
born in the USA but later moved to Canada. This would seem to explain why
this guy seemed to be associated with both the USA and Canada, and filed his
patent application in Canada. If it is the same guy, it appears some of his children
might still be alive, although they would be pretty old.
The wonders of the internet... :)
hm.. 500khz .. that's a wavelength of lambda 1= 600m
how ever one could use lambda1/4 as a coil ore box antenna without ending up having what's called a magnetic antenna as long as you use a relateivly long groundwire (say 20m for a first test) .
look at the videos of some of the guyes, some of em mad a lot of effort to get the best earth ground they can get .. and at the same time they use a sh..ty wire to connect to the device! an allways relatively long sooo?
just how i look at it :)
Quote from: Void on June 29, 2018, 12:14:30 AM
Here is some of what I take away from Prentice's patent comments as being noteworthy:
The frequency you tune to may well be quite critical, and you may have to experiment tuning through a wide range of frequencies
to see what might work in your specific location and with your specific setup. I think this would not be so easy to do at all with
a tesla coil which resonates at a specific frequency.
Hi Void,
Yes it could be a important parameter the location and its specific frequenty to tune.
This would not make it easyer due we would need to stick on the long wire principle........ Using the wire as a coil it would effect its inductance and therefore the needed caps to tune it in the right specific resonance (earth).
This all together probably the first step to think about is resulting in a lot of "mayor" changes...regarding the patent setup.
1- if specific frequenty is approx 500khz.... and the setup needs in that order a specific reactance from the capacitor this needs to be related to the wire inductance (coil part), so changing the wire into a coil would have a mayor effect on this relationship.
2- If the frequenty is not depending on the location .... and more related to the COP factor it would be possible to use shorter wire (same physical configuration),.. but using a higher frequenty.
This last statement is in fact also a kapanadze/ dally approach due the wire lengths are shorter and also the inductance ( now it is getting tricky,... 800 mter wire what would its inductance be?... would it approx. the same as the bifilar kapanadze coil? ( 100- 300uH)
Lets formulte some objectives before starting drilling groundrods..
a) Wire or coil in relation to capacitance / inductance reactance ........is a specific capacitance reactance needed?
b) Is wirelength a power factor or related to the needed eart(location) frequenty?
Just some out of the box suggestions.
Greetings
Quote from: Hoppy on June 29, 2018, 12:36:26 PM
We appear to again be wandering off onto esoteric operating theories that really in my opinion do not relate to what we witness as in Kapanadze's various demos. Kapanadze stated to a.king21's team during the Aqua2 demo, along the lines, that the earth ground was not essential and that the device could work without it, albeit at reduced performance. Also, Kapanadze was wary of operataing the device during stormy weather conditions. This information, if accurate, does not suggest to me that the source of energy was from the ground. The Aqua 2 device apparently had just one ground wire, so could not have operated using the two ground rod principle shown by Wesley. The clues here rather suggest an aeriel source of energy that is returned to ground via the device. Those that have carefully studied the 'green box' series of videos will have seen an aeriel wire from the perimeter fence adjacent the roadway, to the tree in the garden. Although its not possible to conclude that this wire was carrying energy to the device, nonetheless, in my opinion, its far more unlikely that the source of energy was contained within the device box itself. Ruling out simple deliberate faking, then maybe Kapanadze discovered some clever method of extracting energy using an elevated long horizontal aerial??
Hi Hoppy. I personally make no definite assumptions about how these setups might actually work,
if any do really work. That could end up leading a person down the garden path if they make one or more wrong assumptions.
However, we do know all the basic components used by people like Prentice and maybe Daly
as well, so, for people who are interested, experimenting with similar setups without making
any assumptions where ever possible is probably not a bad approach to take.
If the story and video of Kapanadze's demo on the island is at all accurate, there wasn't likely
any chance of Kapanadze or his friends preparing anything at the unknown location in advance.
Regarding Prentice. In 1923 when 'energy shortages' were probably unheard of, there wasn't likely any large
and pressing monetary motivation for Prentice to 'make up' the claims he made in his patent application. He probably
just viewed it as an interesting anomaly that might potentially be made use of commercially some day, but there probably
wasn't any pressing motivation at all back then for Prentice or others to spend too much time investigating it further.
This is why I find his patent document to be very interesting, and why I have posted the details here again.
My thought is why the sparkgap at the end of the long wire? Could it be doing something similar to what Kapanadze is using one for?
The problem for experimenters is sparkgaps generate a lot of HV electrical 'noise' (wideband radiation) and it often makes
digital equipment go on the blink or sometimes blows circuits. Not so easy to work with if you want to try to do careful measurements. :)
Quote from: Void on June 29, 2018, 10:26:51 PM
Hi Void,
Interesting thought about the Prentice long line spark-gap. If the Prentice patent bears a resemblance to Kapanadze's devices, then it might explain the apparently low tech and rather crudely contructed devices in his demos. The grenade might be acting as a HV step-down transformer. As you say, its a difficult platform for experimentation.
I think the following attached drawing is the general idea of how these setups might be 'over unity' (COP > 1).
The drawing is not at all meant to be a working OU circuit, but just shows the general idea of how these setups
might possibly achieve COP > 1. When we include interaction with the surrounding environment in a setup, we may
no longer have an entirely 'closed loop system', and the potential is there at least for seeing a COP > 1 by drawing in
energy from the environment somehow. Exactly how it might work, such as capturing cosmic or solar radiations / high energetic particles
or ions or other charged particles, or by resonating with telluric currents, or drawing in 'energy from the vacuum', etc. is still anyone's
guess I think, unless someone wants to spill the beans here. :)
Quote from: Void on June 30, 2018, 12:29:35 PM
Hi Apecore. Unfortunately I think no one can say for certain what might work and what might not.
My suggestion is for anyone interested to look at the basic components of circuits by
people like Daly, Akula, and Prentice, and try some different setups and see what kind of results you get.
If anyone gets any interesting results, they can post those results here if they like.
Void,
Thanks again for your response.
I do agree we do not know what might work... but we do have the oppertunity to disclose f.e. Wyatt's system step by step,... by doing tests and see whats happening,.... important is the explanation why it will or won't do what was expected.
I like your simple approach in your last post.... i do agree we have to "cut "the elefant in pieces... else we won t get in "standing up and walk"
I d like to combine the next step.. the resonance of the wire(19) in to your simple schematic.
In my opinion a wave wil to fit into wire (19)... The patent is suggesting that 0.8Km compares with 0.5Mhz.... when tuned.. its close to the ( 300/ 800 = 0.375Mhz)...
In this case probably a full wave between secondary (13) and SG (21)...
When we use shorter wire length ratio's the frequenty will increase....
I did some measurements on a 40meter wire in my garden... placing it in a big circle in order to have the both ends close together for measuring the inductance.
This 40meter wire has a inductance of approx 55uH.
If we want to start from the convetional way... (Coil>> Cap>> resonance) .. the HV caps connected to earth will be very small.
As comparing to the Wyatt setup.. the frequenty at a 40Meter wire would be 20 times higher.... about 10Mhz..
Unless this all makes it proabably much difficult i do think we need to stay as much as possible to the original Wyatt patent configuration.
I hope you agree with this approach.
Greetings
Apecore, it sounds like a good experiment approach to me.
I have conducted a number of experiments along this line already in the past,
so I am now taking a bit of time to review some of the basic setups by Kapanadze, Prentice, Daly, Akula again
and thinking about it all some more. As soon as I get some time I will continue with more experiments.
I am still reviewing info and thinking more about it all right at the moment. Trying to think
of some different approaches to take based on what I have already tried in my previous experiments. :)
Quote from: Void on June 30, 2018, 01:49:03 PM
Ok i m fine with that.
I will see if i can make a setup running on either a sub harmonic (primairy side).. in order to tune the secundairy at the approx. 10Mhz.
Getting it running and stable... should be the first goal.
And of coarse frequenty adjustable in order to tune the secundairy frequenty in most efficient way
Greetings
Negative resistance generator: Chua's Circuit Presentation and Applications chaotic generator.
some reference material.
We are interested with impedance generator based on resistance generator.
http://www.analogzoo.com/2018/01/negative-impedance-converters/ (http://www.analogzoo.com/2018/01/negative-impedance-converters/)
http://www.jestr.org/downloads/Volume6Issue4/fulltext11642013.pdf (http://www.jestr.org/downloads/Volume6Issue4/fulltext11642013.pdf)
https://www.youtube.com/watch?v=ezIBFuuJiy4 (https://www.youtube.com/watch?v=ezIBFuuJiy4)
https://www.youtube.com/watch?v=m-XsyeFfp-U (https://www.youtube.com/watch?v=m-XsyeFfp-U) (#0124) Relay Relaxation Oscillator with Negative Resistance
Wesley
With a grounded system one is looking at something similar to the lightening return stroke. The earth echos back a reciprocal of the E wave which needs to be converted from it's conjugant state by plasma coupling or inductance. Each bolt of lightening has up to six strokes one to the earth one back from the earth etc. http://apollo.lsc.vsc.edu/classes/met130/notes/chapter14/stroke3.html
look here, can you see the quandry of this Tesla device?
It is also negative resistance and what he used to record lightening strikes:
https://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes02.htm#Colorado%20Springs%20Notes%20-%20June%201-30,%201899
Hi Wesley. While the two separate earth ground approach may very possibly be a viable
way to achieve COP > 1 (Frank Prentice used two separate earth ground connections on his transmitting long wire, for example),
in all the Kapanadze demos videos I have seen, Kapanadze appeared to use only one earth ground connection (at a time). You have
seen Kapanadze's setup operating up close in person once or twice right? Do you agree that it only used one earth ground connection?
Just want to see if we are on the same page on at least that particular detail. :)
Quote from: stivep on June 30, 2018, 08:46:43 PM
Interesting video!
Quote from: Void on July 02, 2018, 12:01:45 AM
Do you agree that he only used one earth ground connection?
In presentation made for me Tariel used only one ground wire.
In the picture from my last post Romancorp used two grounds one was the ground
connected to heating system pipe feeding cast iron radiator.
the second ground was neutral wire from the outlet.
But in my posts in regards to capacitive coupling and antenna theory.
-So antenna at 10th floor of the building uses counterpoise or balancing mechanism for the antenna to work.
-So the antenna of the car radio uses metal body of the car as counterbalance.
-So the your cellphone walkie- talkie ( hand-held, portable, two-way radio transceiver.) uses human body as counterbalance.
at the time when your cellphone is on the table far from your body . the microprocessor of your fractal antenna in side makes SWR balancing with earth.
However early versions of cellphones did not use such microprocessors and that is why they have had antennas.
Mismatching of impedance from output of TX often made High End- (the RF amplifier) to burn.
That is why these devices where bulky . Due to that fact Wireless Cell Network was at that time designed to have 1 mile radius and not more than 1W output form cellphone RF transistor to an antenna.
That made Cellphones to be smaller but still heavy.( at that time)
Matching impedance of an antenna to expected 50 Ohm ( standard) output of TX by means of capacitive adjustable coupling with counterbalance ( ground)
is always done by LC circuitry.-where C and cpacitive reactance is leading.
Negative effect of this is that if you look at
Smith Chart you dealing with circuit showing
leading Capacitive Reactance means
High
Voltage , low current
Summary:
In regards to Loads. Please first read
power factor correction capacitors :
http://www.answers.com/Q/What_is_the_difference_between_lagging_power_factor_and_leading_power_factor (http://www.answers.com/Q/What_is_the_difference_between_lagging_power_factor_and_leading_power_factor)
In Kapanadze or any other later designs ELECTRICAL CIRCUIT MUST BE CLOSED LOOP.
You can employ any possible means or technique but the system will only work if that condition is present.
If you look at
waveguide https://en.wikipedia.org/wiki/Waveguide (https://en.wikipedia.org/wiki/Waveguide)
it does not differ from natural waveguide of the earth and ionosphere https://en.wikipedia.org/wiki/Earth%E2%80%93ionosphere_waveguide (https://en.wikipedia.org/wiki/Earth%E2%80%93ionosphere_waveguide)
Most of the things were made buy nature and we only repeated it into the scale of our comfort.
By that you may see physical one ground only ,and that is what gives you the headache.
Wesley
Quote from: Hoppy on July 02, 2018, 12:10:29 PM
Wesley,
Please explain how antenna theory relates to Kapanadze's devices?
Antenna theory explains balancing and grounding system.
antenna must have ground to be able to work.
The structure of antenna and Transmitter must have ground.
But in practice your receptors do not see the ground.
So where is the ground?
By that we may ask where is the second ground in Tariel device?
But that is actually very good for us- the people assuming that Tariel Device works.
Artificial ground
https://www.eham.net/reviews/detail/2118 (https://www.eham.net/reviews/detail/2118)
Wesley
Quote from: stivep on July 02, 2018, 11:12:31 AM
Hi Wesley. I think that the Romancorp guy has made some interesting experiments, but I don't
know that he has ever showed anything that looks like it might be a self-runner. Have you seen
a video of his that shows what looks like it might be a self-running setup? I have only watched a
few of his videos in the past. Hard for westerners to follow since he is speaking Russian.
BTW Wesley. You seem to be assuming that everyone in these forums has little or no knowledge of physics or
electronics and radio/antenna theory etc. Hoppy is trained in electronics I believe and he has many
years of experience at the bench from what I understand, and I am also formerly trained in electronics and
electrical engineering, although I have made my actual living in another area for the past many years.
I understand well about capacitors and inductors and AC circuit theory, including power factor and power factor correction,
and have even learned to create and use Smith charts a long time ago (I don't remember so much about them specifically any more),
and I have a fair bit of experience experimenting with different types of antenna setups in the past as well.
It is because of that knowledge and experience that I am inclined to think that using conventional analysis of these sort of setups
may only take you so far before you run into a wall, and may even lead you astray if you try to hold to that approach too rigidly.
Something seems to be going on in these setups which appears to defy conventional analysis, although I do
leave the door open that maybe there is a way to explain the operation of these setups with current understanding
and analysis approaches.
Frank Prentice tried to explain how his setup was producing a COP >1 by hypothesizing about his
setup resonating on a similar frequency as telluric currents, as I think for patent applications you have
to give some indication that you understand what makes your 'invention' work, but some of Frank Prentice's
other comments in his patent doc indicate that the frequency he needed to tune to was very dependent
on the height of his long wire above the ground. There was not one specific frequency that made it produce
a COP > 1. For this reason I think he was probably just guessing, offering an 'explanation' that seemed to
make sense from a conventional understanding point of view. :)
This is how I see things anyway. :)
Quote from: Void on July 02, 2018, 12:37:05 PM
The natural tendency is for people to try to analyze and explain these setups using a conventional understanding of DC and
AC circuits and radio and EM wave theory, etc, but the problem with that approach is that conventional analysis seemingly has no way to
explain how these setups can produce a COP > 1. This of course leads many people trained in science and engineering to assume that all people
making claims of COP > 1 with electrical or mechanical devices along these lines must either be frauds or nut cases. :) However, when I look
at cases like Frank Prentice and even Kapanadze, I have to say that there could possibly really be something going on in some cases
with these type of setups that defies conventional analysis and understanding. This is why I say it is probably better to
make no definite assumptions about how it might be producing a COP > 1, because conventional analysis of these setups may well just
lead you further down the garden path. What is really going on may be something that is just not understood yet, or maybe only
just hypothesized about in some scientific circles. That's how I see it anyway. :)
Void, Hoppy and Wesley,
You may hit the nail on his head.
If it is indeed a convential engineered setup ... probably many many related types of setups would be working for many years already.
The big secret is far from conventional electronics.... just think about Tesla's or Prentice background knowledge before they start discovering and testing.
There was no conventional knowledge as we have now.......
Difficulty is not to think in modern electronics ....on the other hand people without electronic background these days won' t start testing with these kind of setups.
So all stays uncovered.....(are we not all being trolled..... from the start we went to high school?)
We all think in resonance ....LC..... but never in earth_resonance....Tesla did...and Prentice also.
Maybe we only need to focuss on the phenomenom as Tesla did and what he or Prentice drove forward to there discovery?
Unfortunatel i did not finished my electric engineering....but maybe this will not constrain me thinking in different area.
But nevertheless we still need electronics... so you guys are still needed here.... its only the way we configure... hook_up and tune our devices have to be different.
Question...where they able to work into the Mhz region those days in 1920?
Is it for that they used longer wires because the frequency was the bottleneck?
Greetings
OK lets consider a Tesla coil, it probably has a L1 Primary of 800 turns, perhaps a 1Mhry inductance, but lets look at the L2 coil 2 or 3 Turns
perhaps .4uh inductance where we pulse it has any one made any experioments trying to tune the thing for optimum performance,
had any results ?
AG
Quote from: Void on July 02, 2018, 03:54:57 PM
........ but the strange thing here is Kapanadze has apparently claimed
that his setup can still work without an earth ground connection, but probably with poorer performance I would guess, and
Prentice also said he could connect a metal wire between the two ends of his long wire bypassing the ground hop, but it reduced
the performance, and Akula demonstrated in one of his earlier demonstration videos that his setup would still seemingly self run with
the earth ground wire not connected, but apparently with less power output capacity.
Don t forget,... wire laying on the ground or metal parts near the ground do have ground connection due it has capacitance......which could explains why the performance is less.
The air is electrostatic... so a conductor.
Again.... always a closed loop with earth,... we only set things in motion.... vibrating ... creating waves as Tesla said :)
greetings
Quote from: apecore on July 02, 2018, 04:04:19 PM
greetings
Hi apecore. Yes, this is true, but realistically the capacitance to ground of an electronic circuit
like Kapandze and Akula have used, sitting on a chair or a table is relatively small (maybe 1000pF or less as
a rough guess). We are talking about circuit setups that need to produce say at least 50 to 100 Watts to be able to self
loop and keep running. Try an experiment where you must rapidly pulse charge a capacitor of say 1000pF or less
and try to draw at least 50 Watts average power off that capacitor. I think you would need a very, very high pulse frequency to achieve
that by conventional means, if you follow me.
Quote from: Void on July 02, 2018, 04:14:34 PM
Or a high voltage and less puls frequenty.
P = 0.5 x C x V^2 x f
Here is something else to consider.
Kapanadze's 2004 demo video showed what appeared to be a very simple setup.
220V AC in connected to a power transformer and what looked like a diode full wave bridge rectifier.
A couple of devices on black heat sinks, which were probably transistors, his simple coil assembly, and
a small tobacco can with some wires running into it from the various external components. I think maybe there was
possibly another external cap visible near the diode bridge if I remember correctly. Besides an external ground wire connection,
that was the extent of his 2004 setup.
if you look at the way the sparkgap glowed in that 2004 video demonstration, it was clear that the
sparkgap was conducting relatively low current, and it was probably running at a least a kHz and very
possibly a bit higher in the kHz range to appear the way it appears in that video. This leads me to think that the
two devices on the two black heat sinks were probably transistors used in a push pull arrangement to
drive something like a small flyback transformer inside the tobacco can. The type of glow on the
sparkgap looks very much like the glow you will see from a flyback transformer discharging through a sparkgap and
running roughly in the frequency range of about 15 to 20 kHz or thereabouts.
In some later Kapanadze demonstrations he showed a sparkgap that seem to discharge at a lot lower
frequency and it glowed white like it was conducting a lot larger current. This could possibly have been done
in these later demonstrations to try to throw people off. The 2004 demo seems more interesting to me
because Kapanadze didn't seem to be trying to hide things too much except for what was in the tobacco can.
Maybe Kapanadze does make some sort of home-made capacitor or other component which he kept hidden
in the tobacco can.
What I am trying to point out here is the sparkgap seen in the 2004 demonstration was definitely
discharging at a low current (the soft violet glow color) and looks very similar to a sparkgap driven
by a simple flyback driver in the range of 15kHz to 25 kHz or so. In other words, the sparkgap looks like it
was probably driven by a typical flyback driver or some other very similar type of HV transformer driver.
Simple circuit setup.
220V at 50 Hz in.
Probably a flyback driver or very similar driving the sparkgap at low current. The flyback transofrmer may have been in the tobacco can (it would fit with no problem).
Maybe something else hidden in the tobacco can. Maybe a homemade capacitor as some people have speculated, or some other mystery component.
An earth ground connection.
That's all there was to it. There wasn't a whole lot of room in the tobacco can for much else.
Again I understand why many think it must be fake. There just wasn't a whole lot there.
However, if it is not fake, then it boggles the mind.
Such a simple setup with the sparkgap only conducting very low current, yet it apparently self ran
and could apparently power five 1 kW light bulbs at least fairly brightly while self running.
This is why I say that if it really works it may well be working on a principle that is as yet not understood. :)
Quote from: apecore on July 02, 2018, 04:26:08 PM
The voltage would have to be very high. Also, we are not likely really talking about 1000pF,
as only certain wires or coils had high voltage on them, The capacitance to earth from
high voltage wires or coils was probably a fair bit less I would think. :) Akula showed in that
demo I mentioned that he could light some bulbs as well as self run without an earth ground wire connected.
If it was legit, at any rate it seems something way out of the ordinary was occurring, whatever it may be. :)
I think we should be able to at least agree on that.
Prentice seems to have taken a bit different approach back in 1923, but given the general similarities to Kapanadze's setup
it may possibly work on the same mysterious principle (if they really work).
In Teslas system he concentrated on the B field for his wireless. If one will notice his later systems are always inductively matched to the ground then antenna wise a top load to capacitively couple to the air with a spherical cap. Modern RF we have abandoned the idea of ground match coupling beyond a mismatched wire, well aside from sub communication. Purturbing the scalar earth magnetic field and taking advantage of this on the receiving end works wonders.
Look at the Magnifying Transmitter patent and one can determine Dr Tesla was using 1/4 wave resonator for about 1mhz although the calculations are not quite accurate as the earth has a diff speed of propogation to free air.
Modulating RF as PM or FM produces the longitudinal factor which with dual sideband can deliver about 16/1 info over carrier freq. as with 4g
Quote from: Void on July 02, 2018, 05:00:22 PM
Sure the Earth makes a big difference but what about the wingdings and resonance 1/4 wave or less what do we know
about the wingdings ?
( the program keeps altering my spelling sorry about that)
AG
Quote from: AlienGrey on July 02, 2018, 06:51:47 PM
AG
I personally don't know what exactly Kapanadze was doing with his special coil.
His coil assembly used in his 2004 demo was similar to the one used in his green box demo,
or it was the same one, but I don't know what is known about how it was wound, beyond people guessing at it.
Jean-Louis Naudin thought he had figured it out with his 'kapagen' experiments, but when he eventually measured the
input and output power with a suitable method it had a COP < 1. It seems whatever info Naudin got about that
setup was either wrong in one or more ways, or he was still missing something else very important from the setup.
Kapandze's 2004 setup used less than 100 Watts at the input. Naudin's Kapagen used a lot higher input power
and had COP < 1.
Something related to consider.
A quarter wave resonant antenna or quarter wave resonant tesla coil requires a ground to
to work to its max efficiency, but a half wave resonant antenna does not require a ground or ground radials.
A quarter wave antenna has much less losses if you use many radials laid on or near the ground for the ground return
because the actual ground is typically quite *lossy* to radio frequencies. If the ground is lossy (has a significant resistance
at radio frequencies) then why did Prentice and Kapanadze get COP > 1 results when connecting to an earth ground point?
Again, for me it points to very possibly something else going on than what we typically see with radio antennas,
and what we might expect with conventional analysis. The ground is supposed to be lossy at radio frequencies, and at
lower frequencies and to DC as well.
If half wave antennas do not require an earth ground or ground radials to work to max efficiency,
then if Kapanadze wound a half wave resonant coil would he no longer need a ground connection?
I don't know, and I don't expect anyone to actually have an answer to that except maybe Kapanadze himself. :D
Wireless Power Transmission one wire and Negative Resistance http://www.mdpi.com/1996-1073/11/3/532/pdf
This lot should keep you busy !
Don L Smith
Video 1 1994:
https://youtu.be/U9sy8gPxj3k
Video 2 1995:
https://youtu.be/6Vnxdc1EGFY
Video 3 1996:
https://youtu.be/Ak8Vyqjoz1M
Video 4 1998: https://youtu.be/AmVe92YauZA
Video 5 2001:
https://youtu.be/Xgwg82ZVaDA
Audio 1 2003:
https://tinyurl.com/y7sdmse3
Video 6 2005:
https://youtu.be/_nG_Y7pTljQ
Video 7 2005:
https://youtu.be/cAOG8GzjaLE
Video 8:
https://youtu.be/xBF8VPYGl-g
TO GET THE KAPADNADZE CIRCUIT GOING, ONE NEED A VERY GOOD EARTH GROUNDING..PLUS AN UNDERSTANDING
OF STANDING WAVE FUNDAMENTALS.. AND OR MASSIVE CURRENT DISPLACEMENT THEORY.
Quote from: seychelles on July 04, 2018, 06:20:07 AM
Unless you have a degree ftom Oxford uni on In electromagnetism displacement of Maxwell's equations that is defined in terms of the rate of change of the electric displacement field.
The idea was conceived by James Clerk Maxwell in his 1861 paper On Physical Lines of Force, typically in connection with the displacement of electric particles in a dielectric medium.
Maxwell added displacement current to the electric current term in Ampère's Circuital Law. In his 1865 paper A Dynamical Theory of the Electromagnetic Field Maxwell used this amended version of Ampère's Circuital Law to derive the electromagnetic wave equation.
This derivation is now generally accepted as a historical landmark in physics by virtue of uniting electricity, magnetism and optics into one single unified theory.
The displacement current term is now seen as a crucial addition that completed Maxwell's equations and is necessary to explain many phenomena, most particularly the existence of electromagnetic waves. ect
Pay attention here! Generating a standing wave couldn't be simpler if one knows whats required one could simply get a tube wind two matched wingdings on the tube and a half or 1/4 wave, and winding on the top of a slider tube for tuning, be aware though simply faffing around with guesswork just wont do here! because you could simply be wasting your time and resources with complacency.
AG
Quote from: Hoppy on July 04, 2018, 12:02:50 PM
Those demos are often highlighted as some kind of substantive evidence that Kapanadze's devices are genuine. However, we have even less detail about these demos than we have for Kapanadze's home demos. Its not beyond possibility that these were staged to strengthen belief / enhance the illusion that his devices are genuine. Does anyone know the name / location of the island used for the demo, or exactly where the Turkey demo was staged?
I spoke to a guy from Turkey who is interested in such things a couple years ago via private email who said
he attended the demo by Kapanadze in Turkey. I didn't ask him where it took place, but that info has
probably been posted on the net somewhere at some point. It does seem to have been a real event. Sorry. :)
I think we all get that some people here _believe_ strongly that Kapanadze must be a fake,
but until that is established with some actual evidence instead of wild unfounded speculations,
some people here may well continue to discuss and experiment with these things on the off chance
that there might really be something to it. :)
Void the established proof that Kapanadze is the real deal is proof that it's real technology and that Wesley's experiment was proof of that effect is also real ..
I am sold that this power is from the "inter-Atomic" energy like the Coleman patent..
See Infinite Energy magazine it's all there the last 30 years is of proof , "just read and swallow some humble pie"..
Standard science is corrupted as is old models are still " force major" in education..
If you feel that your brain stamping was imprinted at the university level then " you have a problem..."
Threats to the "standard model" will be defended with very " deep brain washing at the university level"..
and worse if you step out of line .... Stephan Marinov was such a man RIP..
Kapanadze had no brain stamping as he is outside of that "system"...Russian science is also corrupt...
To step out of this " intellectual farm as you have been imprinted " takes learning effort...
Criticism is the " gang drive by shooting " of an postulate that is to be killed because ignorance is comfort.
Enjoy the "the Fourth" as most of the signers where hunted down and killed for their ideas..
Acca..
Hi Acca. I could be wrong of course, but I tend to think that Kapanadze's setups might
actually be legit, otherwise I wouldn't have spent so much time on it already. :)
Kapandze's 2004 setup, which I think was his most open and simple setup that I have seen
on video anyway, is sure a puzzler though.
Wesley, or anyone else, do we know for certain if Kapanadze's coil assemblies in his
2004 demo or green box demo, or other demos, had any sort of ferrite or metal core?
I seem to recall Kapanadze stating in an interview that he only uses air core windings,
otherwise he won't get the effect. Kapanadze could say things like that to try to mislead people however.
Has it ever been established whether his coil assemblies were really only air core coils?
Quote from: Void on July 04, 2018, 02:48:39 PM
Yes indeed and its strange to me that he ran this device on a cluttered work bench, given that his intention was to presumably persuade the audience that he had a self-runner.
VOID IF HE WAS NOT LEGIT , THEN ALL THOSE ELECTRICIAN ,ENGINEERS WHO WERE THERE VERIFYING
THE DEAL ARE A BUNCH OF ........
create HV HF using LV -> HV cap -> pulse to a trafo -> OU
if you charge the a cap bank 35000 times per second with 9000V, that is a significant charge in the caps. The load wants amps which is charge/time
Everybody seems to think it is something magical and they always have to pull in nuclear freaking fusion or Schuman frequencies or solar eclipses.
Hi AlienGrey
On your Reply #235 on: July 04, 2018, 03:27:21 PM
Without having a degree from oxford UV in electromagnetism displacement of Maxwell's equations the argument should be properly defined.
1, If your argument is based on the Maxwell displacement current then "Maxwell displacement current" either in vacuum or in dielectrics, neither generate magnetic field nor are sensitive to external magnetic fields. In other words current in dielectrics "The polarization current" does not act with potential forces on other currents and "external magnetic field" does not react with kinetic forces to the action of other currents.
2, Displacement current is a quantity appearing in Maxwell's equations that is defined in terms of the rate of change of electric displacement field. Displacement current has the units of electric current density, and it has an associated magnetic field just as actual currents do. However it is not an electric current of moving charges, but a time-varying electric field.
To conclude the above I quote from
"Harry McLaughlin" https://www.quora.com/profile/Harry-McLaughlin
a. A "changing" electric field CANNOT create a magnetic field
b. A "changing" magnetic field CANNOT create an electric field "end of quote"
3,The so-called "displacement current" term (1/4π) ∂E/∂t is not some current density generating magnetic field, as Maxwell supposed. This term gives information about the conduction currents which have been interrupted in the neighborhood of the reference point.
4, For what it worth, we cannot measure magnetic field produced by displacement currents but we can measure exactly the field of the interrupted conduction currents. Even if the details are not so obvious and require a skill to understand but what the equations imply is that the electric and magnetic fields depend only on the source charges. It is our orientation relative to the source charges and their motions that give rise to the details of the fields we measure.
From Maxwell basic equations the only sensible is the existence of εo and µo
∂E/∂x=-Zo ϵo ∂E/∂t
∂H/∂x=-μo/Zo ∂H/∂t
And they express that the E field causes the E Filed and The H field causes the H field
WOW what a discovery!!!!
The Equations only express that E and H fields are co-existent, co-substantial, and co-eternal like any two perpendicular sides of a brick neither the length affects the width or the width affects the length.
Hope it helps
jj
Quote from: Belfior on July 05, 2018, 10:15:59 AM
Everybody seems to think it is something magical and they always have to pull in nuclear freaking fusion or Schumann frequencies or solar eclipses.
Belfior
Your comments are some what erratic which of your ideas do you consider will bear fruit?
This is what Ruslan says about this clip.. Wow...!!!
"In general, so .... I'm fed up with your stupidities and insults. In this regard, no one else will receive anything. My video will not be any more. Bathe in your shit, disbelief and snot further. And I'll do it ... Instead of arguing with you (With idiots who do not do anything ... Only with the tongue can you do it) No more words!"
В общем так.... Мне надоели ваши глупости и оскорбления. В связи с этим больше ничего не получит никто. Видео моих тоже больше не будет. Купайтесь в вашем говне , неверии и соплях дальше. А я делом займусь... Вместо того чтобы тут с вами спорить (С идиотами ,которые ничего не делают... Только языком трепать умеете ) Больше ни слова !
read all his comments there too....
https://www.youtube.com/watch?v=L8ABhb5wDJ8 (https://www.youtube.com/watch?v=L8ABhb5wDJ8)
Acca...[/font]
Quote from: Acca on July 06, 2018, 08:24:34 AM
Acca...[/font]
Acca.... you carn't argue with that, it's been going on for years, there is a Don Smith (not sure what to call it book pamphlet of information.
It to is on the net any one who is interested should find it and digest it or just shut up and forget it, but in saying that there are the ones who stir good information with gibberish !
QuoteThis is what Ruslan says about this clip.. Wow...!!!
Ruslan is not the first inventor to get fed up with the ignorant masses vindictive ranting and he won't be the last.
The fact remains that there are inherently stupid people who will never succeed at anything and then there are brilliant, intelligent people who do things other people will never understand. The mistake most make is assuming anything they cannot personally understand cannot work... do you see the problem?. Obviously stupid people cannot understand anything however this is not the case for intelligent people like Ruslan and Kapanadze. The proof of there intelligence is the fact they have succeeded in making working devices and no amount of ranting and whining by the ignorant can change that fact.
You should be thankful Ruslan and Kapanadze have given you what they have to date.
This is Ruslan posts from the clip below seven months ago ... You may get some benefit from the theory as he is now pissed off now more than ever at the stupid people.. Who want a free device with no learning on their own..
"First of all, I do not owe you anything, it's time! Secondly ... if people do not grow their hands from there, it's their problem. I told you how it's done and showed it !!! And about the ships and so on ... I'm not even worried! For me, all will be done by lawyers. I'll return my generator and run it like two fingers .....! Now one more thing ... You just wrote here that you did not collect? So ? So you're waiting for a cookie? You see ... Until you start to think and do something, nobody will give you anything here. There are no such people! I say, get busy, do not sit here and do not listen to gossip. It will not be easy, but I want to assure you that the systems work for the entire 10,000%
Во-первых я тебе ничего не должен , это раз ! Во вторых ...если у людей руки не от туда растут ,это проблема их. Я рассказал как это делается и показал !!! А насчёт судов и так далее ... Я даже не парюсь ! За меня всё сделают юристы . Я верну свой генератор и запущу его как два пальца .....! Теперь ещё один момент... Ты сейчас тут написал что не собирал ?! Так ? Значит ты ждёшь готовенькое ? Понимаешь ... Пока ты сам не начнёшь соображать и что-то делать,никто тебе ничего тут не даст. Нет таких людей ! Говорю же , займись делом , а не сиди тут и сплетни не слушай. Будет не легко ,но хочу тебя заверить что системы работают на все 10 000 %
I've painted all the tips already many times. Do not think that a miracle will happen and you will do everything so easily. Nobody just does not give anything from the bald. you need to think for yourself. I have been working since 2013, while undermining my health and a lot of money sometimes in the pipe. Risking many .... You do not understand this! At the same time, I tell and suggest thoughts. But for some reason, no one listens, but all the time yelling: "Give me a scheme, give me a Scheme ..." And the funny thing is that people who have nothing to do with electronics and radio amateurs are getting into this business .... Agronomists are different, doctors .. .. Buying oscilloscopes and details without knowing even the use of it ...!
Я расписал все подсказки уже много раз. Не думайте что произойдёт чудо и Вы так легко всё сделаете. Никто просто так от балды ничего не даст. думать головой нужно самим. Я работаю уже с 2013 года , при этом подрываю здоровье своё и кучу денег иногда в трубу . Рискую многим .... Вам этого не понять ! При этом я рассказываю и навожу на мысли. Но почему то никто не прислушивается , а всё время орёт : " Дай схему, дай Схему ..." А самое смешное что в это дело лезут люди ,не имеющие никакого отношения к электронике и радиолюбительству .... Агрономы разные, врачи .... Покупающие осциллографы и детали не зная даже применения им... !
And where did you get that this bifel resonates? Remember once and for all !!! A high-frequency transformer can not be multi-layered. For the first layer transmitting, and the second accepting layer. Or vice versa ! This time ...! 2. Try to rewind the double Tesla and run ... :) will it work? NO !!! The effect of a standing wave can only be in a long conductor, or wound coil wound to a winding. I already told you about how Tesla compared water to electricity. On the watery surface you can not create another .... It's the same here! So the bif shakes on top, and the bottom of Tesla :) Next, think!
А с чего вы взяли что это бифеляр резонирует ? Запомните раз и навсегда !!! Высокочастотный трансформатор не может быть многослойным . Ибо первый слой передающий, а второй принимающий. Или наоборот ! Это раз... ! 2 . Попробуйте ко намотать двойную Теслу и запустить ...:) будет работать ? НЕТ !!! Эффект стоячей волны может быть только в длинном проводнике , или смотанном в катушку виток к витку . Я уже рассказывал про то как Тесла сравнивал воду с электричеством. На водяной глади нельзя создать ещё одну.... Тут тоже самое ! Значит биф мотается поверх , а снизу Тесла :) Дальше соображайте !
What the fuck is the fish? Are you all staring at the oscilloscope? What for ? Beat all the indications of the devices. Use the oscilloscope only to check the frequency and pulses ... Ie. their presence in the circuit. the rest should not be measured. 2. Where is the cold end of Biff? What the hell? The bif is rewound in order for one layer to work as a transformation, and the other as a filter! The transformer in the air can not be multi-layered ... Otherwise it just will not work as it should. I already said this more than once ... But why then you can not connect my explanations for each element separately? Where are you all in a hurry? Once again I say that in this system everything looks like an ordinary generator. But the force of the current pushing (magnetic field) in the coil to guide the EMF makes TESLA current and standing wave. Suppose there are two Tesla .. Reception-transmission ... In the system, you can get by with this one coil. But then you need to do the Kapanadze system! That is, put the standing wave into resonance. And it's stupid to choose capacitors for a surge arrestor. Not very effective and convenient. will all go for a walk and output voltage too. Therefore it is better to use Tesla to guide the high voltage voltage + the frequency of the Tesla receiver that is under your coil. Simply if you try to repeat the Shark ... Then there he hid this Tesla cunningly and when I was looking for how to create this wave in the first layer of Biff, I was tortured to horror. The system of course worked, but hemorrhoids and not stable. In fact, at the outlet of the Akulina installation 100 Hz and 209 volts was My last development on the ignition coil also worked on the same principle. The coil gave a pulse with a repetition frequency of 50 Hz. Because there the output is clean 50 Hz and 230 volts. Since it is by controlling Tesla that you get the current swing by inducing the EMF, in other words, twist the magnetic field in the coil or vibrate there with a frequency of 50 Hz .... Remember the words of Kapanadze? When you understand that this is so simple, you will laugh ... Draw conclusions
Какие нахрен рыбки ? Вы всё в осциллограф пялитесь ? Зачем ? Забейте на все эти показания приборов.Используй осциллограф только для проверки частоты и импульсов...Т.е. их наличие в схеме. остальное замерять не надо . 2. Где по вашему холодный конец Бифа ? Что за фигня ? Биф мотается для того чтобы один слой работал как трансформация, а другой как фильтр ! Трансформатор на воздухе не может быть многослойным... Иначе он просто не будет работать как полагается. Я это уже сказал не раз...Но почему то вы не можете связать мои объяснения по каждому элементу отдельно ?! Куда вы все спешите то ? Ещё раз говорю что в этой системе всё похоже на обычный генератор . Но усилие толкания тока(магнитного поля) в катушке для наведения ЭДС делает ТЕСЛА ток и стоячая волна. Допустим стоят две Теслы .. Приём-передача ... В системе можно обойтись и одной этой катушкой. Но тогда надо делать по системе Капанадзе ! То есть загнать в резонанс стоячей волны . А это тупо подбирать конденсаторы для разрядника. Не очень эффективно и удобно. будет всё гулять и выходное напряжение тоже. Потому лучше использовать Теслу для наведения высоковольтного напряжения + частота приёмной Теслы что находиться под вашей катушкой. Просто если вы Акулу пытаетесь повторить...То там он хитро спрятал эту Теслу и я когда искал как создать эту волну в первом слое Бифа , замучился до жути. Система конечно работала ,но геморройно и не стабильно . На самом деле на выходе у Акулиной установки 100 Гц и 209 вольт было Моя последняя разработка на катушке зажигания тоже работала по тому же принципу. Катушка давала импульс с частотой следования 50 Гц . Потому там на выходе чистые 50 Гц и 230 вольт . Так как именно управляя Теслой вы получаете раскачку тока наводя ЭДС , другими словами крутите магнитное поле в катушке или вибрация туда сюда с частотой 50 Гц .... Помните слова Капанадзе ? Когда вы поймёте что это так просто , вы будите смеяться ... Делайте выводы
I feel what you understand! But! it is the lower winding that is the resonator of the standing wave !!! But this is not a coming winding, but Tesla. All that is served on it ... Type Dali and the rest ... It's possible! For example, 25 watts of Shark in Germany. Exactly the same miracle I did for the states and the Lord on the channel has this device. It is in America and there it was launched by the Americans themselves. But I got there 40 watts and even a little more. But there is a minus .... Tesla there when transported raped by the company for transportation (throwing parcels) In general, it does not matter .... Kapanadze said about the fact that this is all available to everyone and patents weigh in nete in free download. There is also a rotoverr (Dynamo-car) Also by the way one of this opera ....
Чую что начинаете понимать ! Но ! именно нижняя обмотка и есть резонатор стоячей волны !!! Но это не приходящая обмотка , а Тесла . Всё что на неё подают ...Типа Дали и остальные... Это возможно ! Например 25 ватт Акула в Германии . Точно такое же чудо делал и я для штатов и у Лорда на канале есть этот девайс. Он в Америке и там его запускали сами американцы. Но у меня там получилось снять 40 ватт и даже чуть больше. Но есть минус .... Тесла там при перевозке изнасилована компанией по перевозке (швырянию посылок) В общем не важно .... Капанадзе говорил про то что это всё доступно каждому и патенты весят в нете в свободном скачивании. Там же есть и ротовертр (Динамо-машина) Тоже кстати одна из этой оперы....
So guys! I'll tell you all easier. If you want something to collect, do not pursue the power. So the pumping is simple without resonance. Tupa is a magnetic alternating field! Next ... Position the coils so that one coil with its own field does not stack with the other. That is, the shift must be done. Otherwise OLED will interfere! Now we remember Tesla and when we bring to her a sheet connected through a light bulb to the ground ... What do we observe? The answer is correct! Light bulb shine :) This current you need! Now, by inducing this all on your reel, the end of which is grounded ... You make the magnetic field longitudinal (pushing) and transverse, creating a flow of motion! I told you that the generator of BTG works like a normal generator. Hence Tesla pushes the current, or in other words, pushes or carries the magnetic field away from the pump by a longitudinal field. There is no OEDF! Nothing hinders and there is no resistance either! How are we in the classics? Currents on the sides of the coil?! Here! Boca then do not match :)
And now make a controlled Tesla! That is, interrupt the pushing of the current at a frequency below the pump. This is the current flow! Well guess what, finally, damn ....
How much can you say that?
Так ребята ! Я скажу Вам всем проще. Если вы хотите что либо собрать ,не гонитесь за мощностями. А значит накачка годиться простая без резонанса. Тупа магнитное переменное поле ! Далее ...Расположите катушки так чтобы одна катушка своими полем не складывалась с другой. То есть сдвинуто надо сделать. Иначе ОЭДС будет мешать ! Теперь вспоминаем Теслу и когда подносим к ней лист подключенный через лампочку на землю... Что мы наблюдаем ? Ответ правильный ! Лампочка светиться :) Этот ток вам и нужен ! Теперь наводя этим всем на вашу катушку ,конец которой заземлён ... Вы делаете магнитное поле продольное(толкающее ) и поперечное ,создающее поток движения ! Я же говорил что генератор БТГ работает как обычный генератор . Значит Тесла толкает ток или другими словами продольным полем сталкивает или переносит магнитное поле отрывая его от накачки. ОЭДС нет ! Ничего не мешает и сопротивления тоже нет ! Как у нас по классике ? Токи по бокам катушки ?! Воот ! Бока то не совпадают :)
А теперь сделайте управляемую Теслу ! То есть прерывайте толкание тока с частотой ниже накачки. Это и есть движение тока !!! Ну догадайтесь же уже наконец блин....
Сколько можно говорить то ?
I can not say anything about aluminum. Did not try! You need to tune in and Tesla resonate ... To get a current. Grenades do not need to be shaken. Still do not know why and what they do. You blink one layer long, the other a little shorter. All with one wire. A long coil pumps a magnetic field, a short one removes it. if there is not enough voltage, do the docks from the converter. But the output must be filtered by HF. Otherwise, your resonance will swim away
It is better to find ferrites 2000NM. And build as SR did. It is much better to start and understand the processes. I recall that the electromagnetic standing wave is working !!! Because of the addition of waves, we get an increase in the magnetic field, and then its effect! Antenna can also enhance? My theme - the broadcast. I collected not a few transmitters and antennas. Unfortunately homemade designs of this all can not be used in modern broadcasting, but I know about it all. You can put a good antenna system and not burn electricity to kilowatts in the feeder. There's something like that in the generators ...!
Не могу сказать про алюминий ничего. Не пробовал ! Нужно настроить в резонанс Теслу и приём ...Чтобы появился ток . Гранаты мотать не надо. Всё равно не знаете зачем и что они делают. Тупа мотаешь один слой длинный ,другой чуть короче. Всё одним проводом. Длинная катушка накачивает магнитное поле , короткая снимает. если не хватает напряжения , докинь с преобразователя. Но выход должен быть отфильтрован по ВЧ. Иначе твой резонанс уплывёт
Лучше найди ферриты 2000НМ . И сооруди как СР делал. Намного лучше будет для начала и понимания процессов. Напоминаю что работает электромагнитная стоячая волна !!! Из-за сложения волн мы получаем увеличение магнитного поля , а там и его действие ! Антенна же тоже может усиливать ? Моя тема - передачи в эфир. Я собирал не мало передатчиков и антенн. К сожалению самодельные конструкции этого всего нельзя использовать в современном радиовещании,но знаю я про это всё. Можно поставить хорошую антенную систему и не жечь электричество на киловатты в фидер. Тут в генераторах что то подобное ...!"
https://www.youtube.com/watch?v=9BUuuCLbYs4 (https://www.youtube.com/watch?v=9BUuuCLbYs4)
The Ruslan comments are from this clip posts..
Acca ..
Sorry for the delay in posting this late (months ago)..
Ruslan Kulabuhov free energy flashlight videos and files..
https://yadi.sk/d/Xpw0TXrF3NNsTt
1 Фонарик
https://www.youtube.com/watch?v=Z4qHPQocEQc (https://www.youtube.com/watch?v=Z4qHPQocEQc)
2 Фонарик , часть вторая !
https://www.youtube.com/watch?v=zNbIzIjyEMw (https://www.youtube.com/watch?v=zNbIzIjyEMw)
3 Фонарик без батареек
https://www.youtube.com/watch?v=o0R2T_JRGrI (https://www.youtube.com/watch?v=o0R2T_JRGrI)
4 Заключение !
https://www.youtube.com/watch?v=ekmi_Xqb8l8 (https://www.youtube.com/watch?v=ekmi_Xqb8l8)
UPDATE 19 Января 2018
https://www.youtube.com/watch?v=_le-AI8jp-E (https://www.youtube.com/watch?v=_le-AI8jp-E)
here are the perpetual Ruslan flashlight diagrams files..
Acca...[/font]
Quote from: Acca on July 06, 2018, 09:05:56 AM
Thank you Acca. That is really interesting!
P.S.
Wesley, this part is interesting:
Ruslan mentions that Akula could only get an output of around 25 Watts when he tried his setup in Germany,
and we have seen a youtube video posted previously for that.
Then Ruslan seems to be saying that he made a device for some people in the USA, and it also had a similar problem
in that it could only produce about 40 Watts? Ruslan seems to be saying that this device is in America?
He also mentions someone's name 'Lord' something? DragonsLord76? What did Ruslan say?
Wesley, can you improve on this translation? Sounds interesting...
Regarding this video:
TopRuslan 32 - Аппарат с использованием энергии окружающей среды 16вт
(TopRuslan 32 - The device using the energy of the environment 16W)
Ruslan commented:
Резонатор в этой системе отсутствует.
искра в качестве гашения лишних зарядов
Однополярный
There is no resonator in this system.
spark as a suppression(?) of extra charges
Unipolar
Looks like Ruslan has possibly figured out how to make it work in a similar way to Kapanadze.
Instead of a tesla coil it has a sparkgap which seems to be firing at a fairly low frequency and pulsing,
as would happen when repeatedly charging a cap to a high voltage and discharging through a sparkgap.
In another comment Ruslan mentioned he would not sell his devices any more because he
had to deal with police and court because someone in Lithuania apparently made legal trouble for him.
Ruslan still appears to be actively experimenting with these setups.
I was on the fence with whether Ruslan's demos might be legit or not, but I am starting to think
they just might possibly be legit as well. :)
QuoteHe also mentions someone's name 'Lord' something?
Let me guess?... Lord Kelvin. Aka Lord Kelvin's HV water drop electro-dynamic generator which leads full circle back to one Viktor Schauberger, the water wizard from Austria. Nikola Tesla was born in Croatia almost next door to Austria, maybe it was something in the water?.
Quote from: onepower on July 06, 2018, 08:50:34 PM
Oh struth a bottle full of water (a capacitor), Schauberger it means mountain man ! Have you got any thing useful for us like how to wind the bobbin ? mein Freund. ;D
I did a measurement of the sparkgap firing rate for Ruslan's mini 16W demo setup with the clear top.
It comes out to between 35 Hz to 37 Hz. The small variation may be due at least in part to my measurement error.
The sparkgap firing frequency on this setup is very regular, so it appears to be fired using electronically controlled pulses.
Quote from: Void on July 06, 2018, 11:14:26 PM
Ive seen some of Ruslans compact grenate devices before they just wind an inner tube resonant with the rest of
the wingdings and simply pulse it at that frequency (electronically). There is a formula for finding the frequency versus wave length chosen and also res freq of wire length it was in a commercially available book. Smith Kelly.
Hmm could that be half of 60Hz and he is using something to double that freq? Gap firing to a coil at around 30Hz, caps on both ends of the coil and you end up with 60Hz?
Better known as Smith Charts. Learn em, use em, they may be difficult at first but when you grasp them, makes calculating values easy. Then tune it.
Quote from: Belfior on July 07, 2018, 07:57:18 AM
Hi Belfior. Not sure what the output waveform might look like because he didn't show
any waveforms, and he may not show any more details than that. Ruslan's setup still seems more complicated
than Kapanadze's early demonstrations, so who knows if these Akula/Ruslan type setups might really work at
all the same as Kapanadze's setups. I think we all do have most of the pieces of what makes up these
Akula and Ruslan setups, as Akula and Ruslan did reveal a fair bit. I think they both may have held back on
one or more important details still however, so more experimentation still needed. I could be wrong, but I think
there may possibly be some clues there in all those comments and videos that were made previously. :)
Waited too long to modify so will add separate. Here is a quote from the search:
Smith chartThe Smith chart, invented by Phillip H. Smith (1905–1987), is a graphical aid or nomogram designed for electrical and electronics engineers specializing in radio frequency (RF) engineering to assist in solving problems with transmission lines and matching circuits.
The last five words, priceless.
https://youtu.be/qdJ1V_yDv-c (https://youtu.be/qdJ1V_yDv-c)
Wesley
Hi Hoppy. Kapanadze was not connected to the grid however.
You can not draw any significant power from the grid with just
a single earth ground connection, unless maybe you are directly
under high tension power lines.
Hi Wesley. Thanks for the video.
The Romancorp demo is questionable to me because it seems to be connected directly
to the grid, which opens the door for ground loops and similar. I am not sure what he was using as the
AC source (generator?) connected to one of the transformer winding pairs there. A separate
generator (isolated from ground?) or connected to the mains... Those kind of tests can be
misleading without taking great care to observe and identify what is completely isolated from ground
and what isn't. I have been fooled myself in some cases until I switched to battery power on generators
and measuring equipment to make sure I was fully isolated from ground.
Note:
When two electrolytic capacitors are connected '+' to '+', or '-' to '-', this is a way to
make a non-polarized capacitor from two polarized electrolytic capacitors. Required if
you want to use polarized electrolytic capacitors in an AC circuit. I would be concerned about
possibly causing an electrolytic cap to explode when doing this, but apparently this is an acceptable
way to make a non-polarized cap out of two individual polarized electrolytics.
Quote from: stivep on July 08, 2018, 04:46:17 PM
I will .. after I stop. I'm traveling
You do not watch my video carefully look at
Capacitor voltage Transformer
Capacitive Voltage Transformer Reactor
it is on my video in the description of the schematic next to
Tesla coil.
and than google it please.
Wesley
Hi Wesley. I think you may be misunderstanding me.
I was just pointing out that connecting '+' to '+' on two
polarized electrolytic capacitors is done to make a non-polarized
capacitor out of two polarized electrolytic capacitors. I was not implying anything
other than that. :)
Enjoy your travels!
Quote from: stivep on July 08, 2018, 01:41:19 PM
Wesley
Hah! Even TheOldScientist agrees with me. He is even saying "try to understand what I am saying!"
His input is 7V and some amps for covering copper losses. He is charging a cap with 165V. With that input. So how many Farads you need to run selflooped with 165V?
Quote from: Void on July 08, 2018, 04:27:07 PM
Agreed but we cannot be sure that there was not a concealled earth connected to grid neutral.
Quote from: Belfior on July 08, 2018, 05:03:56 PM
Hi Belfior. It is not about comparing input voltage to output voltage however.
It is about comparing average input power to average output power.
It takes power to charge capacitors. People sometimes forget this in their enthusiasm.
Having a sparkgap and/or earth grounds in the mix could possibly/potentially allow pulling in extra energy from the environment however.
We should not try to draw any conclusions from any test which is not self looped or which does make an accurate
measurement of average input power and average output power. That should be every free energy experimenters motto to live and breath by. :)
so if the secondary is looped with a cap so they are in resonance, then the cap will charge immediately, because there is no resistance?
You could charge a 9000V cap instantly with 7V input and maybe 200mA using a tesla coil or a flyback. Then if the freq is high, then the cap charges 200k times per second. That is a lot of charge going in, if the output side (trafo&inverter&mains voltage?) pulls 230V 60Hz
TheOldScientist tried to tell the viewers to try to understand. He basically says "if you can charge a capacitor to 165V with 7V 200mA input, there is a lot of charge there!"
Quote from: stivep on July 08, 2018, 04:35:21 PM
Please read my answer to Hoppy up there
You can always have one physical and another virtual ground and.... elevation potential .
Watch my video again please my friends
I actually posted how to build traditional first version of TK with spark gap. I just did not point at some details .
Wesley
So are you referring to the elevated 'washing line' from tree to roadside in Kapanadze's garden green box demo as the virtual ground and elevation potential?
A couple of Kapanadze quotes:
Kapanadze - at 8:38 in the 'Green Box' video demo:
"Some think that the device uses stray currents.
I would argue the opposite.
It is not of travelling fields and stray currents.
There is one thing, we take the energy from the environment.
The unit is assembled on the principle of Tesla."
Kapanadze - at 55:05: in the 'Green Box' video demo:
Between us speaking, grounding it is not required.
Instead of grounding, it is necessary to use a small circuit.
Quote from: Void on July 08, 2018, 06:01:27 PM
OK. I'll take that as a tentative yes. Wishing you a safe journey.
Quote from: Void on July 08, 2018, 06:34:21 PM
Theorizing is good, but if you can't demonstrate it on the bench it is only ideas.
Many seeming 'good ideas' and 'explanations' can quickly fall to pieces when put to a proper bench test.
I can testify to that. :)
the green box do'dar'dit is just a copy of the don smith device ! simple ! and so obvious!
Quote from: Void on July 09, 2018, 09:10:46 AM
Hi Hoppy. Aye, that does seem to be a real possibility to consider with these setups.
Drilling down into this, Kapanadze mentioned that he was worried about demonstrating the Aqua 2 device during a thunderstorm. Thunderstorms are apparently quite common during the Summer months in Georgia. In an electrified and muggy atmosphere, a long aeriel wire might well produce a reasonably good charge to storage caps, which in turn could deliver a fairly steady arc across a carefully adjusted spark gap. It has been suggested that the spark gap is just eye candy but maybe the spark is an essential requirement and important clue to the operation of all Kapanadze's devices.
Quote from: Void on July 09, 2018, 10:47:53 AM
Hi Hoppy. I know your idea is that maybe Kapanadze uses an overhead antenna wire
of some sort, similar to what T. Henry Moray apparently did, but it really seems he doesn't. Even if you only look
at the 'green box' demo, it seems unlikely to me no one would have noticed Kapanadze or one of his helpers
trying to hook an extra wire from somewhere into the green box, when others attending were standing all around
watching closely for any attempts at tricks. In other demos like the aquarium II demo, it was the same sort
of situation where people could inspect very closely for any external hidden wires. I personally think it is unlikely anyway.
If you have lightning strikes nearby, and you have wires connecting to the ground, it can potentially cause a surge/spike
to travel up a ground wire, so that may possibly be what Kapanadze was concerned about.
Now lets look at at the device single HV coil L1 with low voltage pulser input L2, so how do you get a standing wave out of a Tesla coil ? think about it !
you need 2 coils one out of phase with the other or shove L2 into the middle of the L1 winding, that way you get a phase shift at the lower end and upper end
you get current and the top you get voltage but L1 is a full wave crossing at L2 and L2 is 1/4 wave there is far more to it than that but talking to my
self here is falling on deaf ears!
You might find this table usefull, I claim no originality for it and it is published free yet might be copy right but found no such claim.
Don Smith provides instructions for winding and using the type of air-core coils needed for a Tesla Coil. He says:
1.
Decide a frequency and bear in mind, the economy of the size of construction selected. The factors are:
(a) Use radio frequency (above 20 kHz).
(b) Use natural frequency, i.e. match the coil wire length to the frequency - coils have both capacitance and
inductance.
(c) Make the wire length either one qu
arter, one half of the full wavelength.
For wire lengths in metres:
If using one quarter wavelength, then divide 75.29 by the frequency in MHz.
If using one half wavelength, then divide 150.57 by the frequency in MHz.
If using the full wavelength, then divide 304.19 by the frequency in MHz.
2.
Choose the number of turns to be used in the coil when winding it using the wire length just calculated. The
number of turns will be governed by the diameter of the tube on which the coil is to be wound. Remember
that the ratio of the number of turns in the "L - 1" and "L - 2" coils, controls the overall output voltage. For
example, if the voltage applied the large outer coil "L - 1" is 2,400 volts and L - 1 has ten turns, then each turn
of L - 1 will have 240 volts dropped across it.
I think the following bears repeating:
In one of Akula's early video demonstrations, Akula showed that his setup
could apparently self run and power one or more bulbs without an earth ground connection
to his device.
And here are a couple of Kapanadze quotes from his 'green box' video demo:
Kapanadze - at 8:38 in the 'green box' video demo:
Kapanadze - at 55:05: in the 'green box' video demo:
"Between us speaking, grounding it is not required.
Instead of grounding, it is necessary to use a small circuit."
I think it is something worth keeping in mind anyway. :)
Quote from: Thaelin on July 10, 2018, 04:53:29 PM
And that small circuit would provide the reverse polarity to the other. Then you a potential. Yes?
Or would a reverse node on a single wire produce the same.
Hi Thaelin. As Wesley also suggested previously, a 'virtual ground' of some type might work as well.
This could be a length of wire which is not connected directly to ground and which is tuned for resonance
at a desired frequency. The 'small circuit' might conceivably be an LC tuning circuit when connecting to a length of wire,
or car body, or airplane body, etc (virtual ground).
Quote from: Void on July 10, 2018, 06:37:05 PM
We see an old car parked in the roadside fairly close to the aerial wire in the green box video. The camera man pans to the roadside several times as if to direct attention to it.
Earlier Void was interested in the green box, you might be interested in this posting by whatsup
Try making heads or tails of the circuit ;D
Guys,
Will there ever be a moment when discussion about the ground connection ends?
Does it realy make a different in understanding its MO?
In my opinion i find it more interesting to talk about the quotes from Ruslan K posted by Solar lab on the 7th of July.
Some of the highligts....
".. You make the magnetic field longitudinal (pushing) and transverse, creating a flow of motion!
But the output must be filtered by HF. Otherwise, your resonance will swim away"
Greetings
https://www.youtube.com/watch?v=Z-M55XP3D4A (https://www.youtube.com/watch?v=Z-M55XP3D4A)
Wesley
Just looking through on the net as you do, found this informative video, watch it before it disappears.
https://www.youtube.com/watch?v=26QqUKoQpO4
I think you should be looking at the katcher circuit a sine wave is no good you need a verrrrrrrrrrrrrrrry narrrrrrrrrrrow pulse to
trigger it but voltage at the top is out of phase with the current your driving it with !
So what are you doing about that little problem ?
That's what you need to sort out, don't forget it's tuning !
AG
Hi All :)
https://www.youtube.com/watch?v=i889P5nOwhg
Much respect for this gentleman
Apecore:
For what Ruslan is doing with his experiments on grenades and more, it's all real.
Having to thank him for his exposure of what he did and all the variants of setups...
The experiences what I went thru and still am, just know now where to look at past months
are those short And "SHARP'' pulses, they are very necessary
in the operation and of course the necessary amount of input voltage as well to reach ionization.
Kacher can work but oscillations have to be disrupted at each pulse. Complete Sinus output wont do it.
I view the Grenade as a HF resonating capacitor receiver, a coil with very low inductance and so there is more to it.
My last observation, on 24V dc input was beautiful observing output,
yet it needed more ionization, more voltage at input.
As indicated on the Akula and Sergey schematics.
Akula indicated voltages around 30 to 60V DC.
Sergey Indicated voltages around between 0 - 140V DC.
and so there are more guys that have done it, secret is how you operate the Tesla coil and the receiver.
Think ;)...
It is all about the Tesla coil ( HV HF sharp impulse coil) Dally's method is another way but the same.
Tesla coil in this system IS the heart of the system creating the massive output properly tuned.
Proper Ionization ( the harvest ) + the right capacitance + Resonance
Wesley, nice to open this thread for updates :) keep it up.
we need also bit of everything.
Cheerz all ~
Wesley have a look at this
http://www.keelynet.com/gravity/carr3.htm
Quote from: PolaczekCebulaczek on July 15, 2018, 06:53:05 PM
Generating energy is easy to measure and verify and fear of stealing a secret is a poor excuse because such device would be quite complex and we all know why.
Hi PolaczekCebulaczek. I disagree that fear of the secret being stolen is a poor excuse.
For those people trying to make big money from these devices, that would of course be a big concern for them,
so they would definitely not be willing to show all details openly, if that is their motive.
Actually, based on what we have all seen, these devices are not really very complicated, circuit wise,
so it should not be so very hard for people to figure out the general principle behind them, if a few
things were not kept hidden. However, since people do not understand the concept behind them yet,
they have been stumped so far, even though the devices are not that complicated.
Actually I think the concept has been staring people in the face for many years now, but people missed
it because they just can't understand why it would work. It seems the 'secret' may be out before
too much longer however, so I expect people will then see that it has been staring them in the face for
several years already, but people just missed a couple of things, which may not be so complicated at all.
Why it works from a physics standpoint will likely still be a mystery for quite some time to come however.
Things are not 'supposed' to work that way. This is the reason I think that many people have been
stumped so far, and many others insist it must be fake. If they think it just can't work that way, they
may well not think to try it that way. :)
So, it seems the device construction itself is not overly complicated for anyone with some knowledge of electronics,
but the explanation of why it actually works will have to be left to the propeller-head physicists to mull and argue
over, maybe for many years to come... :)
P.S.
Anyways, I do have a respect for Wesley, I found his channel/research entertaining and I do like his work on NMR and Coleman, He possesses a lot of knowledge, has a real lab ( that I can only dream of) and he even survived WTC attack lol, so lots of potential there. I do believe in "some form of" cheap or even free energy (is a black hole not a OU device?) this is driven by HOPE because mankind needs this stuff to survive and the statement "Everything that can be invented has been invented." does not convinces me, universe has much more to offer.There is no reason to be rude, every opinion on this topic is needed in order to find the truth that is out there, somewhere and its aint easy.
I think Wesley has been doing a great job in sharing information on these type of devices for many years now,
and I am convinced his motivations are good. Although Wesley has a background in science, I think that
Wesley is not formally trained in electronics or electrical engineering, so it is understandable that he may not
be able to understand all the ins and outs of the electronics of these type of devices, so I think people should cut
him some slack. He has been doing the best he can. :)
PolaczekCebulaczek, and all
How should I enlighten on this...
dont' discard it..
Resonance plays a very important role on energy conversion devices but is not what brings that additional
external energy into the system(s).
That what brings that extra energy that we want to know about, where it comes from and how to use it...
comes from our SURROUNDINGS. How?
You will need HV IMPULSE, SHORT BURST, Continuous. simple Kacher wont do this on it's own.
Excitation of the particles.... they are in our space and everywhere.
The receiver coil must resonate with the HV impulse module ( coil ) to able to harvest that what comes
and collects 100% of the energy. Here is where Freq management is important, it will very for everyone.
its like having a radio station and try to tune your radio receiver to the transmitting signal.
Imagine A field being generated with HV and having to Collapse it abruptly right after and forcefully,
that is one way to create this condition.
This energy we could also view it electrostatic since it EMPs everything as well.
This is what charges the caps right away and fast. Ionizing.
by modulating that signal coming in it can be amplified with a secondary circuit.
"""LIGHTNING""", the discharge, The Ionosphere where many of the charges are flowing..
is our example of where this energy is coming from and it is abundant and infinite...
filling our planet and outer space is totally seeded by this.
Just need to know how to activate/excite these charges and make them usable.
Tesla coil needs to operate as HV Spike discharge device,
imagine like a Knife wave with a sharp drop to kill the oscillations
and repeat. as exmaple. It's this collapsing field which is making this exciting condition
It can be done with any other setups as well as long as it does this.
Vasmus was one who did it also, the relay helped well and his modulation circuit.
Ruslan did tell some years ago on a russian forum what it was when he was new to this,
he did say it is all about Tesla coil, the main ingredient.
So there are many others who had shown but did little or nothing on Knowledge.....
Cheerz~
Hi Wesley,
https://youtu.be/UXWw7TCcS_A?t=607 (https://youtu.be/UXWw7TCcS_A?t=607)
Cheerz~
Not ions but electrons which are here but are "dormant till cycled" like Don Smith said. I still cannot understand how Don was able to present so much correct information with so much mess around. You can re-watch his videos a catch some elements on schematics which he never explained but they are here. Look for example at secondary - how he showed it on actual devices and how it was represented on schematics.
It's incorrect to think that all such devices are made by people at garage. Look what happened to Barbosa & Leal... The energy source is one, quite complicated in fact with direct connection to Sun. All you have to do is connect all dots , all tips from inventors from all times...it was enough for Barbosa & Leal to make devices producing COP=100 but they made a mistake when presenting device powered from power grid.
Hi I my self got so fed up with all the BS on the subject I made a test rig for experimentation with
a fast NE555 and a MOS-FET current driver.
I first wound a miniature coil wit about 600 turns on it for L1 and L2
just had 2 or 3 turns it was quite good at that and would illuminate a LED 5Watt display as a load,
I also wound a bigger coil to play with a few 100 turns for L1 and L2 was 1/8th wave and tuned it to
the winding wave length with far better results
I used a 'c' across L2 secondary winding, wire length is critical for this device.
Here is the LF test rig I used
AG
Here in Russian is the "RUSLAN K." "mindset" of why he is the way he is.. looks like he is afraid of the collapse of the World system as he sees it...
This is a conversation with Polish guy.. Every one will just have to translate too him self, as Russian is hard to do a proper cut and paste google translate.. Sorry for that..
Acca...
Ruslan K 7 months ago
Для того чтобы этот аппарат запустить и он полноценно работал, прежде всего надо понять как работает электромагнитная волна. Затем разобраться с катушками... Каждый делает ошибку огромнейшую не понимаю как работает эта катушка. Мотаю не понимает вообще сути процессов и как это работает...! Есть ещё один товарищ сталкер который лечит мозги всем не понимает также ничего, я абсолютно ничего не сделав! Ни одного готового образца он не показал !!! Зато Болтунов развелось целая куча, никто не хочет думать головой а только одни оскорбления. Поэтому я и перестал всем рассказывать что и как...! Это ваша ошибка многих кто зубами скрипит и гонит, тем более оскорбляет. Поэты причине вы ничего не знаете будете дальше скрипеть зубами! А это очень просто всё сделать...! Надо только мозг включить
Walery Makarewicz 4 months ago
Руслан, ты прям как Капанадзе становишься. Всё намеки да коммерческая тайна. Че вы понять не можете что нужна инструкция по сборке и НАСТРОЙКЕ. У тебя получилось сделать самозапит. У Сталкера хорошо получается обьяснять материал. Ну так начните сотрудничать между собой - обьясни все Сталкеру, может у него получиться обьяснить все народу. Ведь большинство пользователей и так не будут понимать как работает генератор, а производить и продавать его массово просто не дадут. По-этому ни денег ни широкой славы затаиванием СЕ не добьетесь. Посмотрите на Н. Теслу - ему закрыли рот, обрезали финансирование, а потом забыли...
Ruslan K 4 months ago
Walery Makarewicz не не ...погоди ! Я не буду никаких инструкций писать . Эта вся херабора настолько проста что дальше некуда. Но если вы инженер, занимаетесь экспериментами и хорошо знаете что такое электроника и как движется ток . Что такое волна и как она себя ведёт в катушке, этот аппарат вам по силам !!! Если вы ждёте подробных инструкций... увы ! Нет и ещё раз нет. Это всё равно что дать обезьяне автомат .
Может и так, но по моему атомные электростанции, войны за нефть, голод и т.п. - вот это автоматы похлеще ... И все-таки без схем, инструкции настройки, инструкции безопасности это так и останется "гаражной" технологией. Капанадзе сам говорил, что он даже Саакашвили установку показывал и что? и ничего, ... официальным властям это просто невыгодно. Они бояться потерять контроль над счетчиками, власть и деньги. Ну ничего, остается надеятся что однажды такой как Ацюковский Владимир Акимович (спец по эфиродинамике http://www.atsuk.dart.ru) напишет книгу и выложит в открытый доступ.
Вы странный человек ! Никто ничего не выложит. будет катастрофа !!! Вы обрушите систему.
Какую систему? Систему, которая стоит на нефти, загрязняет и уничтожает природу, убивает сотни тысяч людей? так она и сама скоро рухнет. Будет безработица? Так уже сейчас роботы заменяют людей, по-этому проводят соцэксперименты по минимальному доходу, который выплачивают просто так - ни за что. Война? А разве сейчас мир на Земле? Сейчас в мире насчитывается почти четыре десятка вооруженных конфликтов и войн. БТГ это только одна из технологий, которые возникнут благодаря теории эфира. Просто возникнет новая социальная система, как когда-то возникали новые системы с открытием колеса, парового двигателя, электричества и т.д.
давайте не будем писать глупости ! Человек , это алчное создание . Я сейчас выложу подробности и начнётся бардак . И сразу же всё запретят. Потому что начнут продавать гаражные мастера это всё в массы. Причём рукожопые мастера , а таких тут пруд пруди. Это будет такая жопа, что пострадают простые люди. Нельзя так давать просто человеку с корыстными целями. Успокойтесь ! Я лично сам с 2013 года ночами не спал,занимаясь этим всем. И как любой другой, ценю свой труд. Потому подсказываю как могу,но подробно разжевать это будет слишком не просто и к тому же я сказал что не всем это должно попасть в руки !!! Не всем !!!
Таки да, наверное Вы правы - человек это алчное создание. Тогда появляется вопрос - сейчас под воздействием Вашей алчности, не уводят ли Ваши подсказки на ложный путь близких к открытию искателей СЕ? Ведь теперь они по логике алчности рассматриваются как конкуренты? Ну да ладно, на нет и суда нет. Приятно было пообщаться с создателем БТГ. Удачи!
Я не занимаюсь уведением в сторону ! Я хочу чтобы инженеры начали головой соображать, а типа "радиолюбители " (Деньга - любители) вредители отделились скрепя зубами. Вот что я хочу ! Пока на всех видео что я вижу и читаю тексты...Всё тупик и глупо ! Люди не понимают что такое генератор переменного тока. Не понимают и не хотят . Что я могу сделать ? Вот давайте к делу сейчас все.... Допустим ! Ответе мне на вопрос : Что такое Тесла и для чего она нужна в установке ?
Yury 38 4 months ago
Ruslan K Руслан привет!, тэслой в этой установке мы создаём свободные насители зарядов ,а бифом утилизируем в колебательном процессе;)
Ответ не верный ! Я вам про воду говорил ? Предметы на воде становятся легче ? Включайте соображалку . Магнитное поле вращающееся в индукционке ничего не напоминает ?
Ruslan K ок как писал Тэсла " эфир нужно охладить, создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора , примерно так?, я в опыте обнаружил влияние на колебательный контур от индуктора каторый просто качал транзистором, на ослике появилась ам МОДУЛЯЦИЯ, нагрузка загорелась ярче! Это оно?
йожын збажын 3 months ago
Walery Makarewicz он не становится, это один и тот-же человек, если бы эта хрень работала бы он бы сам подробную схему сборки выложил, а раз не вылодил и не запитал от этой зрени сварочник жто значит что все это фейк обычный.
саня клерк 1 month ago
НЕТ ! свободные носители зарядов ( это нам выполняет индуктор - а стоячая волна - ох как любит этот индуктор ))))) и не какой утилизации не происходит ( иначе это гибель для прекрасного момента ) просто --- используем работу этой красоты !!!! чем мог - чем мог !!!!!!
саня клерк 1 month ago (edited)
как писал Тэсла " эфир нужно охладить, создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора , !!! ДА!!ДА!!! ИМЕННО ТАК !!!! ---- но вот есть одна закавыка ( только когда вы - соберёте дэвайс и потом разберётесь как это работает --- вот тогда вам будет ясен смысл вот этих слов (нужно создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора)))))))) единственное что могу от себя добавить (зона малой энергии - это нашей современностью будет непонято ) !!! про цитирую нашим пониманием - дней наших ( активный вакуумный ноль или зона минус 1. с + 1 НАПРОТИВ или вакуумная исходная точка или (+0-) или ЭНЕРГЕТИЧЕСКИЙ ВАКУУМ двух полярностей ! эпицентр вакуума !!! намекаю как могу !!! зона дефицита энергии или чем мог - чем - мог !!! это похожее как у нас - у людей все и всё на приделе ( но ) взрыва не будет ! построили границу и обмен дефицитом
the concerns about giving away a FE device to just everybody are for sure something that has to be thougth.
How ever here is something that relates to the benchwork view. In this video the experimenter is showing something verry important. ( without knowing ..and no its not about hh0 gas,
https://www.youtube.com/watch?v=ZyW4dR4cUQM
i know it sound dumb .. but look the vid verry close
all the best JoJo
Onepower post is applicable as "the understanding of the principle of operation is still NOT proven in THEORY"... of KAPANADZE.. device... Wesley ...
Onepower has valid point as I still DO NOT understand how the bloody Kapanadze device still works in THEORY ...
I have built it and almost burned down my garage with high voltage.. I cannot and will NOT build another till the principle will be worked out as to the safety of such a unit.. as it is also a beta generator, I have proof.. The iron ferrite core sings a very high pitch oscillations like ultrasonic when it goes beta. .. So sorry as I am now suspecting this Kapagen, Kapanadze, Ruslan etc.
I like the post by Onepower and here is the US army crest in search of the "Truth" .. and some photos core of my Kapanadze beta core.. from long ago..
Acca..
in the clip below a ferrite core is in needed to operate the Kapanadze device..
https://www.youtube.com/watch?v=1-Sc9T4xH_o&feature=share (https://www.youtube.com/watch?v=1-Sc9T4xH_o&feature=share)
https://www.youtube.com/watch?v=jNheB3ZJ1h4 (https://www.youtube.com/watch?v=jNheB3ZJ1h4)
[/font]
https://www.youtube.com/watch?v=PqorIWlkhWI (https://www.youtube.com/watch?v=PqorIWlkhWI)[/font]
[/font]
Quote from: Acca on July 19, 2018, 07:34:44 AM
Acca..
[/font]
[/font]
Acca
The Search for truth is one thing but ignoring it when its found is another,and why do we need an aggressive 'military force' to find Americas idea of what the truth should be? one needs to remember 'Police and Army are political and therefor manipulated by the 'corporate political control' secret agenda' financed by brain washed programed taxpayers.
AG
Wesley
QuoteIt was not the case of looking like but looking as required and acting as expected.
That is how they could return their investment with profit.
And it was also the wish of retiring CEO willing to become part of History of world value and fulfill his own.
Therein lies the problem in my opinion. I was also expected to act as required... think about that?... act as required, as expected. As if to say you will act as I tell you to act because I also own you. No offense but that is basically the moment when I suggested they go fuck themselves. They can't afford me.
I find your comment about the CEO wanting to be a part of history familiar. It is strange isn't it?, a CEO who has done nothing of substance wanting to buy his way into the history books. To just sit on their ass in a three piece suit behind a desk manipulating people for profit and then just buy their way in. What is the going price nowadays?.
What I found is that we are all responsible adults in the room and all is well. Then... when the money boys don't get there way they get all red in the face and lose their shit like some 6 year old on a playground. It is fascinating to watch how a supposed adult can magically transform before your eyes. However we know they were never really credible were they?, there was that monster latent hidden under the surface who just came forth for all to see. You just have to know which buttons to push to see the real show... the real person.
QuoteI think case you described is right but not applicable mentioned by me above situation.
I apologize, I have a tendency to speak as if I am talking in the first person but imply a second or as a group from past experience. There are many middle men seeking inventors on the part of investors and I imagine there may be a handful who actually have something in the way of credibility and empathy.
In any case I have rambled on long enough, I'm going to take a break from the forums again... carry on with the show.
Wesley
QuoteIt is valid as much as it this unfortunate.
Tariel has no buyer but he had an offerer based on business rules. And he blow it.
You must be on time at the train station and if you late just 1 second, there is someone else inside the train.
You are just double loser.( lost the money and lost the time.)
In many cases
There is another way and solutions are why we are here is it not?.
The system is rigged, based on dependency and the easiest path however that is not the only path. If we know the operating principal we can cherry pick any outdated FE patent from the books, start building working units and then sell them on ebay for profit. We are now the boss and no middle men or investors are required. You see expired patents fall within the public domain, we are the public thus it is fair game for everyone everywhere.
Think about it... we make money so we win and if others want to copy our working devices and sell them we still win. The perspective is of course dependent on our intent... are we in it to corner the market at others expense or expand it for the benefit of all. You see this solution always comes full circle on itself and produces the desired result no matter which way the current flows. In my opinion either it is a real solution and it produces the desired effect or it's BS, it is what it is.
This is what I do Wesley... I analyse problems and find workable solutions. Why would we torment ourselves by doing what everyone else has done in the past despite the fact we know it cannot work?. What I propose is the fundamental premise of all FE concepts, we change the rules to produce a different result... the one we want. Is this so hard to understand?.
Quote from: stivep on July 19, 2018, 12:28:19 PM
In 2008 Tariel patent application was denied and revoked by means of qualification.
His application was assigned/ thrown into to group of patents that belongs to Perpetual Motion Machines.
Independently recreated and providing the same or similar performance devices based on corresponding and filed patent application, after the filing date are eligible as the prove of Tariel's patent.
Ways to prove it are by scientific evaluation or by means of proven existence in the form it was filed.
To bypass any possible delay I suggested to Tariel to give it to the public.
By means of grandfathering Tariel is entitled to the full rights to that patent at no time .
Even if anyone of us present the device in the form described by
Tariels application than Tariel's lawyers free of charge to Tariel will strip humanity from being able to use it without Tariel's acceptance.
Even if his application was revoked he has rights to reopen it and he will get patent.
All and any form of profit made by anyone till that time must be recovered on benefit of Tariel.
Well in some countries law does not allow to work back in time.
In such case prove of Tariel concept will be provided by number of devices replicated.
Tariel or his family after his death will become the wealthiest people on the surface of the earth.
Along with Mr Turk the patent attorney who signed the contract with Tariel for 50% of future income if Tariel's patent will be issued at any time in the future .
He did so and that is why Tariel got patent application without any expenses of his own.
Hi Wesley. It appears someone was trying to seriously con Kapanadze, if this is what they told him.
The content of Kapanadze's patent applications were so far off from even the basics of what is required in
a patent application that Kapanadze might just as well have submitted blank pieces of paper as his patent applications.
Patent applications have to contain sufficient detail that the patent application should be able to be
used as plans 'for anyone sufficiently skilled in the art' to build a working prototype, if the patent is for
some kind of device. We all know/suspect that at least some people/corporations may very likely intentionally leave out
some important details, or may put in a few purposely incorrect details in their patent applications to try to mislead
any potential competitors from getting their full 'secrets', but they would have to do this very subtly, otherwise if the patent
examiner suspected this they could disqualify the patent application.
In the case of Kapanadze's 'patent applications', they contain such incredibly vague block diagrams and vague descriptions that
no one can tell at all just what exactly it is that Kapanadze was supposed to be patenting. Some very vague arrangement of coils and some
other very vague circuits are alluded to for who know what exact purpose or function. It was so incredibly vague that the patent examiner must
have assumed the patent applications from Kapanadze were some kind of joke. ;D They are worthless to Kapanadze, and would/will
not legally protect him or his cosigners even from someone coming out with a seeming nearly identical device as Kapanadze has shown.
If someone advised Kapanadze that those completely vague and therefore completely useless patent applications he submitted
would somehow protect his legal rights, then the people advising him were either completely incompetent or complete and utter crooks.
I feel that the system has been rigged at least since Tesla was working for Morgan and Westinghouse. When he started talking about wireless transfer of energy Morgan pulled his money out. Also I bet they realized that they have lotsa infrastructure in place and they make billions by pulling cable in the air across the country. It would all be scrapped if wireless transfer was possible.
I think the current electrical education system is lobbied and sponsored by the energy providers. They dictate what is in the books (and what is not) and they decide who gets research grants for research packages THEY provide. So you can't just say "I want to research free energy", because they will tell you that you get 150000$ to research improved mileage on a petrol engine. Then if you make the engine 8% more efficient they raise petrol price by 15%...
I still think the "answer" is very simple like everything in Nature. We need to think how come do not arrive at this answer? Limitless energy is there. Even scientists agree to this. Why would it be impossible to harness it then? I think the concept of Ether is just all the EM radiation that is more or less evenly spread in the universe. My take on this is that something was removed, hidden or just not talked about. It is not in any school books and it should be the ONLY thing in the school books. Voltage does not get the credit I think it needs. Frequency is said not to affect power. This is very peculiar to me. Like pull your nose once. Then pull your nose 35000 times per second. Do you still have a nose?
Something has been stripped from the knowledge passed onto us. That is why I am asking the stupid questions and trying my own ideas out. I do have a bachelor degree in electrical engineering, but I don't keep it on my wall or preach the UU gospel like some do.
It is obvious that the game is rigged if you just loo outside and compare what you see to the crap they print in books.
Free energy -> anti-gravity -> gtfo of Dodge and let the banks stay here with the illuminati
Belfor can i ask your age ? only you seam to be able to write stuff but not read it, only i have seen two or three
ways of creating very efficient energy saving secrets that have been disclosed in the past week alone.
It is not just yourself but others appear to suffer from the same problem, unless it's some one to produce a ready made device or kit your waiting for, witch just isn't going to happen, so get real and start reading and thinking out
side of the box. Then you can show Tinsel and the rest of us how it's actually done snigger snigger!
Quote from: AlienGrey on July 20, 2018, 07:40:38 AM
I am 44 years old. I have not seen any energy saving secrets that actually work, but then again I only have time to read some threads and not every message posted on this web site.
I do read mostly books between 1880 and 1920. It seems there were many ideas and bench tested stuff that you cannot find in newer books. I am thinking outside the box every day and I try to write all my ideas down, so I might try them out later. If you learn your stuff in school from a guy who also learned all of it from books, you will not discover anything new. If the establishment (energy companies) is affecting the school books then you got zero chance of finding anything new or hidden. You really need to think outside the box to find anything new. Just lie on your back and look at the stars. Write everything down and later toss out everything that does not work.
Or there is the penicillin way and you will fall on to the discovery. Accidents also provided us with neodymium magnets and god knows what else?
My daughter is 11 months and I have maybe 2 hours a week to do some actual bench stuff, if I'm at home. During summer that means no bench time.
All the evidence is there to prove that the energy is also there. The answer will pop up eventually. The Egyptians had some pretty advanced knowledge (or the people before them) and they lifted stones bigger than we can lift now. So they knew something and did not require kacher circuits to use them.
When I find it I will give it to you. You say nobody will make a kit that you can just start using. Why you think that? Money does not make you happy. Greed is the only reason why don't have the secret out yet. That is not only sad, but might end this planet before we have means to fly to other planets&moons
Finding the secret might not even be the biggest problem. If you got limitless energy then everybody has it. Do we wan't everybody to have it? They will use it as a weapon.
World economy and people's jobs are in danger. Economy will survive and people too, because they always have. Airplanes, zeppelins, trains, cars, nuclear power, electricity and factories all changed the economy and some horse carriage makers lost their jobs.
Quote from: stivep on July 20, 2018, 09:01:47 AM
Here is my comment:
We have bunch of new guys, posting here.
And I started to respond to.. it was not smart.
I was telling that at some point activity of some trolls can be deleted along with their accounts.
please keep it in mind
I try to be friendly
Wesley
hmm..
as i'm one of the new guys i can asure you my last intend would be trolling this subject.
how ever for the most time i simply follow the topic .Over the years i found it more fruitfull to proof some ideas on the bench in
verry smal steps . A few ideas here are verry close to what i was abled to test. I'm not the forum hero anyway so to me it be ok both ways deletedore not.
have fun JoJo
Belfior thank you for your reply, Iwas wondering if you were a senior citizen and needed some pointers ect hope thats ok any way I'm pretty sure some of the basic useful youtube video's are on this tread and another
you found your self are of The old scientist youtube tread, regarding the questions your asking.
However there is so much spam it's getting dificult to find relevant stuff of interest.
Some of them were published by Wesley and very interesting and useful.
https://www.youtube.com/watch?v=JWD0Wy_UOEA
and this one too from Tin man
https://www.youtube.com/watch?v=KOGkKXD9ksQ
Quote from: AlienGrey on July 20, 2018, 12:04:09 PM
Belfior -there is so much spam it's getting difficult to find relevant stuff of interest.
https://www.youtube.com/watch?v=ZyW4dR4cUQM (https://www.youtube.com/watch?v=ZyW4dR4cUQM)
https://www.youtube.com/watch?v=KOGkKXD9ksQ (https://www.youtube.com/watch?v=KOGkKXD9ksQ)
I do thank you for that
Videos are Marvelous Wesley
Quote from: stivep on July 20, 2018, 04:24:36 PM
Quote from: Void on July 02, 2018, 06:01:45 AM (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg523213/#msg523213)
...in all the Kapanadze demos videos I have seen, Kapanadze appeared to use only one earth ground connection (at a time).
and
https://youtu.be/atlnVNy0IDE?t=169 (https://youtu.be/atlnVNy0IDE?t=169)
Here you have explanation about two grounds in Kapanadze patent application.
Can you comment on it
Hoppy, Void and others?
I said about two grounds system as principal requirement for Tariel Kapanadze device to work
Who is right and who is wrong.?
Wesley
The patent shows one ground symbol, so I cannot construe from the schematic that there are in fact two ground connections. As previously commented, I do not see two ground connections connected to the device at any point in the green box video. However, I am open to the strong possibility that there is a concealled wire which may be the second ground. Alternatively, any concealled wire could have been connected to an aeriel wire.
The video you posted does not in my opinion show that the increased charging rate of the capacitor is necessarily the result of energy drawn from the ground.
Please look here
https://youtu.be/atlnVNy0IDE?t=629 (https://youtu.be/atlnVNy0IDE?t=629)
Wesley
Quote from: stivep on July 20, 2018, 05:58:49 PM
Please look here
and than
look at the picture
Wesley
Hi Wesley. I have spent many many hours running all kinds of experiments along these lines
over quite a few years now, and from what I saw from the Old Scientist's experiments shown,
I did not see anything that I would say gave an indication of anything very unusual going on.
His exact experimental setup was not clear to me however, so without knowing his exact
setup I can't really comment further on it.
I was not suggesting that having two separate earth grounds is not a viable way to go when
trying to achieve COP > 1, as Frank Prentice used at least two separate earth grounds and
claimed to have measured a COP of around 6. I was just saying I did not see indications
that Kapanadze uses more than one earth ground connection. I am attaching a couple of drawings
from Kapandze's patent applications. They seem to depict only one single earth ground connection,
which is consistent with what we have seen in Kapanadze's video demos over the years.
what you see in the patents you can't see it on the demo video,
what you see in the video demo you can't see it in the patents.
the first video (tin can) and first the patent is the simplest, i think Ruslan has been succesfully conecting the dot.Ruslan last video (16 watt) look very similar to Kapanadze tin can video.
similar material, inverter 12 v dc to 220v ac,power suply 220v ac to 12 v dc ,coil wound look similar.
Ruslan : DO NOT PURSUE THE POWER (get the 220v ac from inverter?),TESLA CURRENT (with controlled Tesla),GROUND FROM EARTH
So guys! I'll tell you all easier. If you want something to collect, do not pursue the " POWER ". So the pumping is simple without resonance. Tupa is a magnetic alternating field! Next ... Position the coils so that one coil with its own field does not stack with the other. That is, the shift must be done. Otherwise OLED will interfere! Now we remember Tesla and when we bring to her a sheet connected through a light bulb to the ground ... What do we observe? The answer is correct! Light bulb shine :) This current you need! Now, by inducing this all on your reel, the end of which is grounded ... You make the magnetic field longitudinal (pushing) and transverse, creating a flow of motion! I told you that the generator of BTG works like a normal generator. Hence Tesla pushes the current, or in other words, pushes or carries the magnetic field away from the pump by a longitudinal field. There is no OEDF! Nothing hinders and there is no resistance either! How are we in the classics? Currents on the sides of the coil?! Here! Boca then do not match :)
Wesley,
Like the green box device, the Aqua 2 device appears to power a heavy load with a single ground wire so how does the dual physical ground wire theory add up to what we see in any of Kapanadze's videos?
If these devices are genuine, then the principle is very likely very simple as Kapanadze claims. The biggest clue in my opinion is that Kapanadze avoids running these devices in stormy weather, which suggests that there is a concealled connection to an aeriel wire, assuming the devices are not faked. I'm trying hard to join the dots.
Quote from: Hoppy on July 21, 2018, 04:05:21 AM
Wesley,
Hoppy the answer to your question is easy ! answer you haven't done your home work with watching the old scientist video's !
the single earth is a mono polar Tesla coil, Also do you remember some 2 years ago Nelson talking about the very same coil
wasting energy? you can also make a coil with out the harmonics. My advice to you is watch them while you can they are saying (catch us if you can) sounds like a pop group from the 60s ;D
P S two earths or none is a bipolar! reminds me of my psychology OU coarse I did, :o You say he doesn't run the device in a thunderstorm ;D :D a very verrrrrry wise man, surely you can work that out for your self! ;D ;D ;D
Quote from: Hoppy on July 21, 2018, 05:28:58 AM
Hi Alien,
I've watched most of his videos but cannot recall where he has demonstrated operation without a conventional power supply in a self-running mode. You continually write as if you have the 'knowledge' and proven the operating principle of the Kapanadze devices, by self-running your own device(s). Can you show any evidence of your achievement? As you are well aware there are many that can talk the talk.... ;)
Hoppy no I can't and I don't have the test equipment to develop such a device, did you notice the HF SG the Ols Sci was using
I only have a 5 MHZ device to get any where you need a 100mhz device with PW impulse drive.
Where are you perhaps we could pull resources ? you talk about the green box that device would be one of the easiest to play with and perhaps get going to prove one way or the other.
On the other hand tin mans device does prove the point quite well.
Ove course you could wind a Tesla coil 1Mtr long and work out the wire length for 100khz and tune it to that frequency to prove the point and then use a ferrox core transformer to collect it all. but the trick is done around the Tesla coil.
AG
Quote from: AlienGrey on July 21, 2018, 06:53:27 AM
AG
Do really think that Kapanadze is using a 100Mhz device with PW impulse drive?? ??? What point do you think Tinman's device proves?
Without some reliable info on what is in the green box, pulling resources without some 'inside info', would be rather pointless in my opinion.
Quote from: Hoppy on July 21, 2018, 07:08:03 AM
well the spark gap will send harmonics into the Ghz range ! and the green box coil has a 1/8 wave on that top copper tube
thats got to be at least 10 to 20 mhz, (that's how it works) ( but let's suppose he tiunes one of the layers 0.5uh with 47nf cap it's res would still be in the 2mh range and if you were buying a SG would you bother buying a SG with a top range
less than 100 to 300 Mz ? I wouldn't.
Your asking me stuff that's been on this tread in the last few pages, I wouldn't mind so much if you had read it! and knew how stuff
worked or supposedly is reported to work.
OK here is a test for you what significant difference would adding an earth to a mono pole Tesla coil make ?
Well...I think Kapanadze device works similar to Steven Mark, the principle seems the same but the realization is much safer because of many obstacles it cannot run-away except for a slight 1-2 seconds delay after disconnecting the power source. :P So I guess he is using the same method as Henry Moray - storing energy in capacitor and using kind of LC circuit where capacitor is gradually charged by radiant energy instead of power source. Of course the power output is diminished by a large factor also....
Quote from: forest on July 21, 2018, 10:51:36 AM
Forest,
Right it is ( as i believe) based all on the same fundamentals.
For the power part as you say the radiant energy is stored in a cap......., let me say it this way..... and i hope we get it more clear in possible explanations and facts.
Lets start simple,....i like that...
When you puls a coil... EMF is generated which is coming from the stored energy in the coil.
I would say this energy comes from the radiant energy present in the surrounding of this coil.
With 12V/ 0.2A pulsing a coil, i can charge a cap with 1000V,... needing a number of puls chargings.... so maybe this energy needs to be higher in the coils surrounding?
The HV from the kacher or from a separate source ..... is increasing the EMF charging.... or not?
With result that less pulses are needed to charge the same cap to 1000V.
So is this the deal we are trying to accomplish?
in my opinion there is no difference either we are talking about Kapanadze or other related setups..... they all use HV as a energy source and do create a sharp puls to activate a EMF proces in the "output" coil.
The only problem we have is that we can't get it working or maybe in small way
So this mechanisme needs to be better in place.... the way how this has to be done in order to get significant EMF is still one of the secret.
There are some relations or combinations in the setup which could be critical for this mayor effect;
1- Timing of the puls/ SG is not the missing link,... many of us have made lots of pulsing boards/ electronics in order to shift this puls.
2- Frequenty relation HV and resonance of the output coil,....is also something most of us has achieved in there testsetup.... but no significant effect yet...
3- Combination of (1) and (2)... Also here i would assume it is a logical next step after having the setup on the bench...... many of us have tried..
4- Particular output coil/ grenade configuration,.... here could be some secrets being hidden,.... altough the configurations available on the internet could be false.. so this could lead to a dead end on the bench.
5- (4) could become a endless story if it is realy critical,... we don t know which criteria yet'is used............ so (1), (2) and (4) hitting the jackpot has a low change
6- Output coil/ grenade wirelength versus (2) seems likely Short wave radio thechnique,.. this is also something what likes to be difficult and not easy to achieve..
This shortwave approach also implicates the whole setup and all its coils,....which is very critical... and thus again difficult to combine with (4) and/ or (2) etc.
Looking at Geo 's results.... maybe he has accomplished one of mentioned combination? Would be good to know if Geo tried a different modified grenade also and see if he gets same results?
At least to see if it is to determind what is related of the mentioned items.
Greetings
Apcore some how I'm not so sure it's the grenate, lets look at the green box. Any one played with that ?
pay attention to wire length to keep in resonance notice width of gap use SG and scope to tune first layer
with tune cap for max amplitude at around 500khz - 200khz
let us know how any one gets on.
winding coil a few pages back will do for playing with testing.
AG
I wrote this befor but ok let's try again.
kapadnaze as well as others made a great deal about groundig in almost all demos they had a relativly new groundpoint.
bury a car radiator and what not .
ask your self how would you improvise a god ground ?
bury a car radiator ore driving an long copper ore zinked steel rod outside in the ground ? looking for a spot where you have moist earth? yes all fine .. they did this.
what else you need ?
a suficiente wire diameter at least 6mm diameter ore more and best be fine multistrandet . kepp the wire as short as you can
what did they? .. the ground point was allways like 10meters away from the demo unit away often the wire was way longer ... and they always used cable that looks like they stole it from grandma's old vakuumcleaner.
have fun
Quote from: jojo500 on July 22, 2018, 12:19:32 AM
bury a car radiator ore driving an long copper ore zincked steel rod outside in the ground ? looking for a spot where you have moist earth? yes all fine .. they did this.
a sufficient wire diameter at least 6mm diameter ore more and best be fine multi-stranded . keep the wire as short as you can
what did they? .. the ground point was always like 10meters away from the demo unit away often the wire was way longer ... and they always used cable that looks like they stole it from grandma's old vacuum cleaner.
have fun
Isn't the wire length part of the wave length !n meters ?
Auto self-tuning resonant circuit:
https://www.youtube.com/watch?v=JaPvdN75dl4
https://www.youtube.com/watch?v=AFP6c7lwyoE
Quote from: TinselKoala on July 22, 2018, 04:01:16 AM
Tinsel Hi can you tell me what label the scmitt-trigger inverter chip is please and what
iC2A and IC2B actually do and connect as IC2C looks as if it would control the width. It might be
of interest that a 4093 would be easyer to get hold of in the junk box and common the 2 inuts or
just common one input to +ve line.
Also some guys might find your circuit useful for driving a Tesla coil under Test if a diode is added
between the MosFet and coil and a voltage limiter between MosFet and drain and ground.
Some kind of current limit feedback might be useful under fault conditions.
Many thanks ;D
PS Patric Kelly conference on alternative FE https://www.youtube.com/watch?v=2WXMZKqBP90
AG
Quote from: AlienGrey on July 22, 2018, 08:03:02 AM
Many thanks ;D
PS Patric Kelly conference on alternative FE https://www.youtube.com/watch?v=2WXMZKqBP90 (https://www.youtube.com/watch?v=2WXMZKqBP90)
AG
You must be talking about a different circuit than what I showed in those two video clips. The autoresonating circuit of TKoil X is very simple.
If you are talking about some of the other circuits others have listed above, I can explain the purpose of the chips if you specify exactly which diagram you mean.
Quote from: stivep on July 22, 2018, 07:50:51 PM
Information about FE device based on real example of it is available AS I PROMISED TO YOU.
I'm working on real data .
I will start from one source first
The second source independent from the first one and not related to the first one , is not yet going to be discussed.
It is a lot of work and not only that.
Wesley
Thanks for that Wesley. Its about time some reliable info was published, especially for those, like me, still stuck in the box. ;D
Quote from: TinselKoala on July 23, 2018, 01:45:22 AM
Err um This one! if you could
many thanks
The CD4046 is configured as a voltage-controlled oscillator. The potentiometer P1 controls the voltage input to Pin 9 of this VCO and thus controls its frequency. The oscillator produces an approximately square pulse train, coming out at Pin 4. The components surrounding the Schmitt trigger inverter stage IC2C, comprising the pot P2 and the cap and resistors, form a pulse-shortening network that transforms the more or less squareish output of the VCO into shorter pulses whose width is controlled by P2. The output of the pulse shortener is fed to the TC4420 mosfet driver chip (which also has Schmitt trigger input) which then drives the mosfet's Gate. The mosfet is in a low-side switch arrangement, switching current from the +12 volt supply rail through the transformer primary TR1. Two more stages of the IC2 are used to inhibit or disinhibit the VCO, depending on which of the two gates is getting a +12 volt input or is grounded out. This section could be connected to another oscillator to provide chopping or pulsing of the main VCO signal.
The Schmitt trigger inverter (IC2) could be any of a number of different part numbers. Generally there are 6 gates per chip, so in this circuit 3 are unused. It is good practice to tie the inputs of unused gates to ground or Vcc.
What you are showing is known as the Les Banki Nano-Pulser. The circuit I used in the exact video where you saw it is a variation on this circuit. This is not an auto-resonant circuit as it stands but could be "transformed" into one (no pun intended).
Quote from: Hoppy on July 22, 2018, 03:25:42 AM
I would like a few of those old vacuum cleaners for the cable! You were looking at some quality cable in the video!
I'm using 4mil to experiment I used 1/4 wave lemgth but 1/2 wave was much better but some 6mi multi strand like welding cable when it's working
I don't get the impression from the green box build and layout that the ground wire lengths are critical but as Alien points out the SG tuning to include a given ground wire length may be.
I think you might find it is!
More to the point, what do you think we need to replicate the green box, other than the box?
A HV PSU tuned to the selected low end frequency. (don't get too complacent or you end up with leaks in the system).
Quote from: TinselKoala on July 23, 2018, 04:57:06 AM
Hi sorry to be a pain, but have you a link to the Banki reference please ?
Also i note http://www.overunityresearch.com/index.php?topic=2578.msg49522#msg49522
your notes on the nano pulse PSU any chance of any information on that item and or pointers please.
Regards AG
https://www.youtube.com/watch?v=7pE83oajjoo&feature=youtu.be
This is first video
Wesley
Quotehttps://www.youtube.com/watch?v=7pE83oajjoo&feature=youtu.be
This is first video
Thx Wesley
Soo its time to dust off my granade coils and kachers? because I gave up on this and lost all hope.
Sergey Panov channel: https://www.youtube.com/watch?v=uUVybUtIdAo
Don't watch it unless you want to see spoilers in russian, next episode of wesley's news is coming soon!
aether22 Thanks for pictures, now i can see things better.
In case of Hendershot, I dont see any aether stuff, just a tricky yet consistent with electromagnetic theory method of extracting/converting energy from "slowly rotating big ball" and its weak magnetic field to "fast rotating small ball" with strong magnetic field, something like a transformer or a two small-big gear system analogy. It could work because of two factors; the fact that electromagnetism is relativistic and difference between true-geographic north and magnetic north (because of this earth mag field is rotating with earth, in faraday disk its not). Device needs tuning, very specific angles of magnetic field's are needed to make this work ( hendershot compass) and finally when earth mag field answers, the answer is in form of HF vibrating earth magnetic field, for that honeycomb coil is the best, its HF coil that can pick up wide spectrum of frequencies.Its not easy for me to explain this due to language barrier however right now I'm building a "proof of concept" a simulation where my earth is a weak slow magnet interacting with other things, I want to simulate the effect first to see if my theory is correct.They key is hendershot compass that I had replicated (I think i did), looking at hendershot solid state device wont tell you much however the magnet is there.
Wesley,
Thanks for your part 1 video. One observation about the ground wire length being a critical factor. When Kapanadze swapped over from the radiator to the water pipe ground in the green box video, the length was very much shorter and yet the device still functioned to light the lamps. Maybe Kapanadze's comment about his device having auto resonant tuning accounted for this.
There was no info about loop-back in the Ruslan circuit explanatory. I see this as a critical element to understand as it would surely affect front-end tuning, so should the loop-back be in place prior to tuning??
Quote from: Hoppy on July 24, 2018, 04:40:00 AM
Wesley,
First we should build the core device and see if we have some OU, even small OU would do, if the device is really outputting OU then it could melt when self looped OR perhaps not... if amount of energy grows to much then the device goes out of resonance for a while... free energy stops flowing, things cool down and after that back again to resonance and OU territory.
QuotePersonally I do not believe that what you describe makes sense or is possible, but I am not knocking what you are doing, I just don't see it, the earth rotates with it's magnetic field and IMO it cannot be tapped as you suggest, at the same time i do not expect I can convince you of that.
I can however see a lot going on that I have discovered that Hendershot lines up with, a lot of aetheric principles, at least 7 things without looking too hard.
But it does not hurt to incorporate my idea whatever you might believe, most are electrically neutral.
That is not to say I don't believe the earth magnetic field plays no part, I think it does, just not as a means of energy generation.
If you show me what you are looking to do I can give you pointers, things you could try.
At any rate, there is not chance that most devices have a "conventional" explanation as they show signs of aetheric energy, current that does not shock, different colour of illumination, arcing at low voltage, thermal and magnetic anomalies and other weird stuff. indeed, I am not sure this does not apply to Hendershot as well, but it applies to many devices. indeed a number of Free Energy devices have Antigravity as a side effect.
Logged
I'm not sure if my theory is correct, but i will try and see what would happened, there should be "something" because of third newton law (does third newton law works for magnetic fields too?) but what and how many I don't know. I just don't want to humiliate myself because this could be some stupid BS and lack of physics knowledge on me side lol. plus the language barrier so I will explain more and make some diagrams or even crude animation if I got the good results. The core idea is to push against earth mag field in some tricky way.
Anyways, the eather stuff could be related to magnetic fields, the bigger/wider the field the better, like in your transformer idea, so you could be right, once i made all sort of coil configurations and there were effects that i could not understand like primary bifilar canceling magnetic field coil(non inductive) that lights LED's on normal winded secondary while 0 current or voltage is shown on meter, some say that its capacitance effects but I'm not sure... same goes for coil made out of coil (wind coil on a thick insulated wire, this wire serves as core and then twist/wind this core on plastic pipe), in some cases i could power many leds with 0 currents on multimeter, yet cant charge capacitors with this, funny stuff.
Quote from: PolaczekCebulaczek on July 24, 2018, 07:34:29 AM
Funny, you just mentioned 2 major aether hacking methods...
So, the bifilar coil many have observed creates a beam out the center. By many people entierly independent of my efforts!
I have heard people talk about this!
What I have discovered, and really the outer coil in my inductor could be replaced with self cancelling bifilar, either totally cancelled or mostly...
What occurs is that if you induce aetheric energy (there is aetheric energy induced in electromagnetic induction, but normally not enough) in 2 opposite directions, the opposing flows create collisions, and this creates aetheric turbulence, and this creates pressure...
And this pressure squeezes and focus energy inside the bifilar coil, and if there is another coil inside of that it can gain a lot of aetheric energy, the more you create density on the center of the coil the more the center radiates energy back out, this is because you raised the pressure of the aether so all activity disturbs a thicker more lively aether.
But, the short version is that it makes aetheric energy increase in the center.
Actually ideally a spark gap, or something highly energetic could be in the center... Maybe a magnet, or a capacitor. But something, maybe a resistor or light bulb.
However I suggested separate coils because while the EMF and aetheric EMF (yes, there is an aetheric analog of everything) in these coils will still work, it also creates a magnetic N pole in the center, and I have found this kind of thing can create aetheric magnetic monopoles!! Not sure regular ones exist, but they exist aetherically!
Ok, now about the coil made of a coil...
So the first coil that I felt energy from after 17 years was a coil made of wire that was coiled around a central wire.
I could feel this coil issue and energy, even after it was disconnected the energy would persist, then I found if I made it asymmetric it would work without being connected to anything electrical, it just needs needs some bias.
I read comments below last Panov video. He state Ruslan Dębice can only light something like 100w bulb. Prawdopodobnie czegoś brakuje 😋 albo już ktoś dotarł do Panova i wytłumaczył mi co i jak..... Kiedy wreszcie zrozumiecie że urządzenie musi przedstawiać realną wartość dla ludzkości np pozwolić na ogrzewanie domu bez kosztów eksploatacyjnych a przy tym nie może być ani cienia wątpliwości że nie pobiera lewego prądu z sieci elektroenergetycznej. Do tego kwestie testòwt , zabezpieczeń, bezpieczeństwa , atestówa, bezpieczeństwast, instrukcji obsługi serwisu części itd. Bez wsparcia lokalnego rządu to sie nie uda.
Quote from: forest on July 25, 2018, 05:31:49 AM
Rough Google translation: Probably something is missing 😋 or someone has already reached Panov and explained to me what and how ..... When you finally understand that the device must represent a real value for humanity, for example, allow heating your home without operating costs and at the same time there can be no doubt that it does not charge the left electricity from the power grid.
This includes test, security, safety, approval, security, parts service instructions, etc. Without the support of the local government, it will not work.
Hmm, how do we construe the meaning of the highlighted text??
Quote from: Hoppy on July 25, 2018, 06:42:12 AM
Well does it or doesn't it use stray current from the grid?? Maybe this is what Wesley needs to establish during his visit to Latvia.
Panov said it can only give 100W and only when ground cable Has correct lenght. Sorry this tablet force je to wrote in Polish
Hi Guys, there is a recent message from Sergej Panov in Wesley channel:
"The device does NOT produce any free energy! It is a scam perpetrated by Kulabuhov! The device works from a hidden AC connected wire! The whole free energy Kulabuhov device is fake! End of story! Big scam!"
I am not an active member, but I read the post quite often, Perhaps someone with more clarity could explain the reason for the message?
Quote"The device does NOT produce any free energy! It is a scam perpetrated by Kulabuhov! The device works from a hidden AC connected wire! The whole free energy Kulabuhov device is fake! End of story! Big scam!"
now Panov claims that its a scam? why he changed his mind?? what the hell is going on between ruslan and panov??
Ok it seems that Panov was joking and here is the rest of it (truth?)
o whom it is necessary, comment, I will put a photo of super quality. Guys, do not cut it, do not swear, I'll ban and wash! Respect each other! Movie about running BTG near the end of the video, it's just an example of how Kulabukhov easily fooled us all! The principle / secret of the work of Kulabukhov's BTG is = PHASE! ..."
Basically if you look at the schematic that I show in video #9, those 2 relays play a role in turning the AC line on and maintaining it after you remove the battery. Buttons Start/Stop turn on and turn off the AC line. The device has unnecessary schematics and play no role whatsoever in generating of free energy as claimed by Kulabuhov. Fans spin, LEDs shine, Tesla works, it all looks real and works but the real energy comes from under a hidden wire that Kulabuhov had hidden under the neutral black thick cable(as seen on the video) that ran from his device to the ground. The ground markings on the black cable indicate that underside of them was loose because it housed an AC line. Basically Kulabuhov scammed people and myself for years, he sold me a free energy device that was rigged to work from AC line and deceived me, I had enough evidence to take him to a civil court and won all my money back - he didn't even show up in court to stand by his free energy claims.
Quote from: PolaczekCebulaczek on July 25, 2018, 07:50:56 AM
where is vid 9 pointer and all this quote information from and it's pointer ?
More to the point why is he and Ruslan never show storage caps don Smith and Daily originals devices had ?
Quote from: AlienGrey on July 25, 2018, 08:20:32 AM
Panov has this comment pinned to his most recent video here:
https://www.youtube.com/watch?v=Gy5za1r5gCw
Here's the exact quote from Sergej Panov in English:
"ENGLISH:
to stand by his free energy claims."
Here is what Panov wrote in Russian (translated to English):
"To whom it is necessary, comment, I will put a photo of super quality. Guys, do not cut it, do not swear, I'll ban and wash!
fooled us all! The principle / secret of the work of Kulabukhov's BTG is = PHASE! Guys, thank you, do not need any money,
save yourself for the details or for the family, but who wants to transfer, thank you to you, that's my yandeh number,
there are no others. Photos will soon make and lay out: <yandex link>
00:01 Schemes, boards, connections, drawings!
22:40 Disclosure of the secret / operating principle of the Kulubukhov perpetuum mobile, Bes-Fuel Generator!
1:06:15 The markings!
1:17:06 Focus-Pokus BTG! How Kulabukhov bred!
1:41:16 What says Kulabukhov after selling me BTG!"
So Sergej Panov is now claiming that the device he purchased from Ruslan is a fake.
I think a while back Wesley stated that this guy Panov is a troll trying to discredit Ruslan.
So, we have two possibilities. Either Ruslan's device is fake, or Sergej Panov is a troll who is making
a very big effort to discredit Ruslan. I'm not going to jump to any conclusions as I don't know anything
about this Sergej Panov guy, but there is no doubt that this looks bad for Ruslan. :)
Yeah i see two options:
1.Ruslan device was real but geo dependent so it didn't work for Panov in his country so angry Panov decided to discredit Ruslan by claiming its all fake.
2.Ruslan device was and still is fake, big scam.
any other possibilities? I don't think so...
Quote from: vasik041 on July 25, 2018, 11:36:58 AM
3. they are both scamers playing together :)
Ha ha you got to laugh at the bipolar response some one show me the proof !
Can any one do that ????????????????????????????????????????????
Quote from: AlienGrey on July 25, 2018, 03:15:31 PM
I don't think any one cane prove it works or it don't on here.
No i was referring to all this probable prof of admitting fraud the guy is admitting to !
where is it ?
I tend to follow the money trail on this type of puzzle. However, proof is conclusive, so evidence is likely the best we can hope for in a forum environment.
TK
QuoteSo, presumably YOU yourself can feel this energy you are talking about, coming from your designs, coils or images. So I propose a test. We will take one of your designs, coils or images, that you can feel, and we will put it into a box of some kind.
You may lose and the condition is called EM hypersensitivity
http://www.who.int/peh-emf/publications/facts/fs296/en/
Nikola Tesla claimed to have such sensitivity to EM energy and it is well documented in the art. It is also known that sharks have electro-reception with a sensitivity as low as 5 nV/cm. https://www.wired.com/2013/08/how-sensitive-are-sharks-to-electric-fields/
QuoteSuppose you put two D-cell batteries 1000 miles apart with a single wire connecting them. A shark could detect this faint voltage.
The real problem would seem to be arm chair critics who do no real experiments and corporations/government agencies who prostitute science in the name of profit/vested interests. Any fool should be able to feel the hair on their arm rise or move in the presence of HV fields. I can build a small HV circuit and put it in a box and take your money every time. The problem is most people are basically deaf, blind and dumb so far as awareness of the environment around them is concerned. They bumble about oblivious to everything around them then try to claim there ignorance is normal when it's not, it's just them.
tysb3
QuoteBasically if you look at the schematic that I show in video #9, those 2 relays play a role in turning the AC line on and maintaining it after you remove the battery. Buttons Start/Stop turn on and turn off the AC line. The device has unnecessary schematics and play no role whatsoever in generating of free energy as claimed by Kulabuhov. Fans spin, LEDs shine, Tesla works, it all looks real and works but the real energy comes from under a hidden wire that Kulabuhov had hidden under the neutral black thick cable(as seen on the video) that ran from his device to the ground. The ground markings on the black cable indicate that underside of them was loose because it housed an AC line. Basically Kulabuhov scammed people and myself for years, he sold me a free energy device that was rigged to work from AC line and deceived me, I had enough evidence to take him to a civil court and won all my money back - he didn't even show up in court to stand by his free energy claims.
Awesome, now if you could post a copy of the court transcript or some other proof such as a receipt then we could believe you. Otherwise you have as much credibility as the inventors you claim are fakes. There is only one tangible proof and that is tangible proof and it works both ways.
@ onepower (https://overunity.com/profile/onepower.106102/)
I put there information what about his video say Sergej Panov (https://www.youtube.com/channel/UCumjgeQXpjz4oaKXa7tZIwg) ,which part of it Wesley wrong interpreted. For more informatios ask Sergej Panov (https://www.youtube.com/channel/UCumjgeQXpjz4oaKXa7tZIwg)
Quote from: PolaczekCebulaczek on July 25, 2018, 09:32:57 AM
Hi PolaczekCebulaczek. Yes, it is possible that the device Panov bought from Ruslan is a
legit working 'FE' device, and possibly Panov just could not figure out how to make it work, or the
device does not work in his area. I can't see the point of Ruslan selling just one device to one person
like this if the device is a complete fake, as Ruslan would have known that doing that would most probably bring
very negative consequences for him. Panov's insinuation that Ruslan must have been using a hidden very thin wire
is only speculation I think. I don't think there is evidence that Ruslan actually did that, unless Panov has
provided some actual convincing evidence showing Ruslan doing that somewhere in one of Ruslan's demos, but we
all already know that hidden wires are always a real possibility in any of these kind of demos. So there is nothing
new at all with this idea.
@Wesley: It would still be interesting to us all here I think to have some translation from Sergej Panov's
video # 9, as this video contains commentary from both Sergej and Ruslan. I know translating
that whole video would be a big job, but it would be interesting to at least know if it is mentioned about what agreement
was supposed to have been made between Sergej and Ruslan, and why Ruslan agreed to sell Sergej one of his devices at all.
At the last part of the video # 9, Sergej includes video commentary from Ruslan on this. What is Ruslan saying there?
Without knowing more details about what all transpired there, it is hard for people to assess what is really going on with all this.
That's my opinion anyway. :)
Quote from: tysb3 on July 26, 2018, 08:08:11 AM
Hi tysb3. Wesley did not interpret it wrong. Sergej Panov first released a video claiming he
got Ruslan's device working, and he said he was going to release full details in later videos
explaining how everything works, and provide schematics as well. Then later Sergej released his
video # 9, in which he says he believes Ruslan just used a cheap trick of having a hidden mains
phase wire in the ground wire. Sergej made misleading claims in his earlier video about getting his
device working, so it is understandable that people were mislead by that earlier video from Sergej.
Quote from: Void on July 26, 2018, 08:49:03 AM
Well with all that has happened you didn't really think it would all go according to plan, did you?
A much more likely scenario is that Panov did not have the skill to figure out how it works, panicked then claimed it didn't work.
Look at the time line...
1) He claims he has it working and will release details.
2)He shows no proof he has it working as time passes.
3)He then claims it does not work and is a fake.
It would seem to me that he is trying to lay blame on the device or technology for his own lack of knowledge and understanding which is often the case.
Well we haven't had anything from Wesley, I.m more interested to see what else is available he has to share with us ;D
Hi onepower. I think Sergej Panov had Ruslan's device in his possession for a long time before he made this latest series of videos.
He had already sued Ruslan some time ago claiming the device does not work. Then in the last couple of weeks or so he posted
a series of videos in which he was showing doing a bunch of testing and analysis with Ruslan's device, and then he released a video
about a week ago saying he managed to get Ruslan's device working, and that he was going to release further details about how the
device works in upcoming videos. Then Sergej released his video # 9 a few days ago saying that he actually used a hidden phase wire
to power the device.
Void
QuoteHi onepower. I think Sergej Panov had Ruslan's device in his possession for a long time before he made this latest series of videos.
There is a very good reason these devices work in some places some of the time but not all of the time. Relative humidity, water in the air, will either dampen the HV resonant effects or short the device out all together. It is well known in the art and anyone with any amount of understanding of these kinds of systems should have figured this out.
A nearby thunderstorm produces even more variation because now the Earth Ground potential can swing from 100V/m to thousands of V/m overloading the device. Then when the wind blows humid air into the vicinity the unit shorts out and stops working all together. Why anyone would think a device extracting energy from it's environment would not be effected by said environment boggles the mind.
Imagine that, some people put hundreds of hours of testing into a device and it never works for no other reason than they didn't check the relative humidity in the room. It is often something that simple that many people over look that gets them.
It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so. Mark Twain
Quote from: onepower on July 26, 2018, 11:40:14 AM
I think most have been down this road before... it goes around the block and we always seem to
end up right back where we started. As one member suggested, the best option may be to stop blindly
following others and to take matters into our own hands.
Hi Onepower. It's up to any given person whether they want to spend some time running experiments
with these types of setups or not. There are several variations of these sort of devices out there, some
of which have been seen running up close by independent witnesses in person, so it shouldn't be
surprising that some people are interested in experimenting with similar setups, and trying to find
out more info about them. :)
However, one thing for pretty much certain is that despite what most anyone says about these 'FE' devices,
it appears anyone who might actually get one working is not very likely going to give out specific details
to the public for free about what makes their device work, as the potential is there to make big bucks from
a real FE device, if someone can actually get one working. :)
Sergej said that he found a spot to connect mains and then the device worked, with all tesla coils pushpuls, fans, leds and so on, those parts are just a decoy. Sergej did not modify anything , supposedly.
He also had shown all schematics and explained how mains current powered the device including relay's for battery.
Quote from: PolaczekCebulaczek on July 26, 2018, 12:20:34 PM
Ah, now the series of events is making sense. It a bit of backwards engineering. ;D 8)
Hi PolaczekCebulaczek. 'Supposedly' being the key word there. :)
I saw in Sergej's video where it looked like he actually had soldered his thin phase wire
in more than one place, but I don't speak Russian so I am not sure about what Sergej was
trying to show there. Anyway, the same circuit layout may work exactly the same if the
power source is looping back from the output of the coils in self loop configuration, or if a mains hot phase
wire is soldered in the same place instead (prior to the loop back diode bridge). I'm personally not jumping to
any conclusions here anyway. :)
QuoteHi PolaczekCebulaczek. 'Supposedly' being the key word there. :)
that would be a surprise, hwoever one thing just makes me wonder, why in forest demo ruslan insert a pipe in some bushy area instead of open field?
Wesley is trying to contact Ruslan, Wes would bring HIS OWN ground wire or choose a location for demo, he will inspect everything, no room for hoax this time, if Ruslan let him...
Quote from: PolaczekCebulaczek on July 26, 2018, 12:49:00 PM
Hi PolaczekCebulaczek . Yes, I agree, it would be essential for Wesley to be allowed to disconnect the ground wire
at least at the end of the ground wire which connects to the device and inspect fully, and also to be allowed to handle
the device however he wants to inspect the device for any possible hidden wires as well. Doing the demo at some
random location in the country side, with the exact spot chosen by Wesley would be very good as well.
However, I can pretty much guarantee you that no matter what precautions and steps Wesley may take,
such as the steps mentioned above, (if Ruslan agrees to something like this), and if the device still works,
people will still be insisting that Wesley was still just tricked somehow, or they will insist that Wesley has joined
up with Ruslan to fool everyone. ;D
Quote from: onepower on July 26, 2018, 12:04:40 PM
Void
Well it makes sense.
This means that the device needs to have a supply of condioned air?
Should not be that difficult.
Also the ionisation charge of the air trough the during thunderstorm should be relative easy to be controlled
Quote from: Void on July 26, 2018, 01:24:36 PM
And that would be the correct default position to take. Extraordinary claims need extraordinary levels of proof, after all. And what claim is more extraordinary than these: Self runners, not co-opted by the Russian military....
However, what is much more likely is that Wesley will not be allowed to perform the necessary inspections and experimentation to rule out hidden external or internal sources of power.
A third possibility is that the device won't work, and Ruslan and his cadre will fall back on the "onepower" excuse: not enough something in the air, too much other somethings, not Tuesday, not full enough moon, forgot to circle three times widdershins around the plinth....
Void
Uh-huh, and pulling excuses out of thin air can also get you into trouble.
The devices "work" whenever and wherever they are demonstrated by Ruslan and his cronies. I don't recall seeing a failed demonstration, presented alongside a relative humidity measurement.
While it is certainly true that we don't know all the factors involved in getting one of these things to work, and humidity etc. can indeed affect circuitry in various ways, one could seize upon many many factors to blame for them not working. Phase of moon and day of week are my favorites. The moon phase is linked to tides... what could be more powerful than ocean tides! And have you noticed that Trump News peters out on Friday and there is very little over the weekend, and on Monday the news activity picks back up....
Look up "Special Pleading" when you have a chance.
If that device works it would be a miracle. Remember Kapa aqua box video. That guy holding device said something important.
Quote from: apecore on July 26, 2018, 03:50:00 PM
Tinsel,
You are a smart guy, i almost whatched all your vid's with a lot of respect.
You like to make results... i can see that...
Lets assume the Ruslan device is legimit,.... ( as i am convinced it is)
What would be in your opinion the driving force to obtain the absorbtion of the tesla charge/ ionisated air energy into the output coil?
I d like to get focussed on engineering facts.... even in little steps... and after that the next one...... see relations,.. proof of concept.... and start again from there.. or try something els.. again,.. again ......... see those Amp and Volt meters doing crazy movements
We don't know who here on this forum have the same goals, having regard to the character where the discussion always falls back on shows that might be 8 out of 10 people here not to obtain OU.
Sorry if I offend people but it really seems so.
There is no spin or within the meaning of working on the bench.
Just endless discussion about the "fake issue".. which in my opinion is contra productive .... what does not make sense as you look what knowledge and experience is on board here.
There was that other guy Adrian Gustov (sorry about spelling.
let's look at his Tesla coil for a start his L2 had a lot of turns on it and it was a 1/3 way up his L1 coil, doesn't that give you some idea's ? current (tuned exciter coil) High Voltage count turns so is in resonance.
Oh and one of his video's he showed a stack of capacitors in a block, for tuning ? or Pulsing ?
In his later video's self osculating would not have run that Katcher the gap was to big it sugest's
a higher voltage driver circuit.
the video is ready now :
https://youtu.be/FJXVVD8IiQc (https://youtu.be/FJXVVD8IiQc)
It is somehow positive analysis of Ruslan Device.
It is A COPY of Akula device that was checked by Stepanov and examined by my friend Tiger.
Akula's device was also examined by German Investor in 2014 who visited Akula.
And Germans are not naive people. After that Akula spend more than year in Germany.
Tiger my friend was also ask to work in Germany.
video contains access to schematics and explanations
We may be dealing with targeted attack on
FE community and if not than Sergey is saying truth .
Please read description below video and give me Hand Up As I suspect that horde of Trolls will be targeting me again.
Wesley
Quote from: TinselKoala on July 26, 2018, 01:51:42 PM
... forgot to circle three times widdershins around the plinth....
Hi TK. Now you've gone and leaked the real secret of FE out...
Now everyone and their cat is going to be coming out with working FE devices. :D
Quote from: stivep on July 26, 2018, 07:12:34 PM
... and if not than Sergey is saying truth.
Hi Wesley. I don't think Sergej is wrong or lying when he says he hooked the phase line from
the mains to the relay contact on the device and it works. The relay(s) is/are setup as a latching
relay, so I think it should work the same whether you connect the output from the grenade coil to that
point on the relay, or a wire connected to the mains phase line, if the grenade coil were producing enough
power to maintain self looping that is. Since it should probably work the same either way, it doesn't
necessarily mean at all that Ruslan used a hidden mains phase wire.
TK
QuoteThe devices "work" whenever and wherever they are demonstrated by Ruslan and his cronies. I don't recall seeing a failed demonstration, presented alongside a relative humidity measurement.
I do not believe that is true and it was documented in this thread that Ruslan had units which did not work in other locations. I also remember reading of similar instances with the Kapanadze device.
QuoteWhile it is certainly true that we don't know all the factors involved in getting one of these things to work, and humidity etc. can indeed affect circuitry in various ways, one could seize upon many many factors to blame for them not working. Phase of moon and day of week are my favorites. The moon phase is linked to tides... what could be more powerful than ocean tides! And have you noticed that Trump News peters out on Friday and there is very little over the weekend, and on Monday the news activity picks back up....
My claim was made from first hand experience at the bench not theory. It is also well known in the art that PVC tubing for HV use should be warmed to drive off moisture or given a coat of varathane or epoxy to seal it. As well anyone can do a simple test, fire up a Tesla coil then spray some water mist near it... does it detune or not?. If you cannot or will not prove the matter for yourself then I'm sorry I cannot help you.
The fact remains that conduction increases as voltage rises and insulators and dielectrics can become conductors. At 500kV wood, water, earth and plastic containing moisture are very good conductors. All of this is explained in any textbook on HV phenomena, A.D. Moore for example.
I remember the hours of debate we had many years ago on every subject under the Sun and I put you in my top 5 most likely to nail this technology because of your experience ... what happened TK?. Why this?.
OK... for the moment let's stipulate that the device(s) DO work, self-run and power reasonably heavy loads.
Please explain, then, why or how the various militaries and intelligence agencies active in that part of the world have not co-opted the inventors, seized their inventions, and militarized them for the battlefield? Or simply suppressed them altogether.
Why has this not happened? Why are these inventors still running around in the open, posting on forums and YT.... where is the FSB? CIA?
Please explain. Do you know how much a liter of Diesel fuel costs, on the battlefields of Afghanistan and Syria? It's a lot more than you pay at the pump, that's for sure. There are extremely powerful motivations for militaries to get and use this technology. So why haven't they done it already? Why aren't they taking steps to keep this tech out of the hands of their enemies?
@onepower: My SSTCs do not go out of tune in varying environmental conditions, because I use autoresonating circuitry that automagically adjusts itself to remain in resonance. It's not hard.... maybe Ruslan should email me for a consult. I'll make him a special deal....And as far as me "nailing" this technology... have you ever tried nailing jello to the wall? Nevertheless I hope you've seen my TKoil X demonstrations and can make the connection....
Quote from: TinselKoala on July 26, 2018, 10:12:24 PM
Hi TK. Who knows, but here's a couple of guesses.... :)
1) I think Latvia and Kazakhstan are not under Russia's control. FSB and CIA are not free to do as they please
in those two countries, I think.
2) Many/most people educated in science and engineering will most likely assume that all these free energy device
claims are a bunch of malarkey, so governments and their advisers may well assume it is all nonsense for the most
part, so pay it little attention. Who sends in military personnel or security agents or whatever over an issue they assume is nonsense?
Quote from: stivep on July 26, 2018, 08:16:04 PM
Watch my video my friend.
I have spend 4 days, to make this video( 16 hours/day ) i hotel room just to prove that Sergey is likely wrong
or intentionally wrong. Intro was prerecorded
Wesley
Hi Wesley. Nice video! (You have been adding some cool video editing effects
in your videos in the past while BTW). I agree that it seems very unlikely that if Ruslan was
trying to scam Sergej with a fake device that Ruslan would leave a plainly visible 5 inch
piece of insulated wire hanging part way out the ground wire connection hole. Ruslan would
have to be a complete idiot to do that. It does seem much more likely that Sergej soldered
that wire there later, but I wasn't there so I of course can't say for certain what actually happened there.
The point is this phenomena exists and so do star people like it or not, and Criminals In Action Perhaps you should ask your questions to George Bush but then he can't handle the truth! Jello whats that ? try putting jello or swamp gas in a plastic bag before nailing bag to wall. Military another word for satanic minions and control ;D ;D no pun
But here perhaps we should be concerned in keeping in phase with the earths resonance yeah ?
To me it looks like Ruslan was trying to replicate Akula or Dally device (he spend a lot of work and money for circuitry and coils), failed and out of frustration decided to fake the device and created the YT/russian forum show, just for trolling or maybe for money from YT views and later sold the device to Panov for a juicy 5k E.
Even if that's the case then it does not mean that all devices are faked. Kapanadze, Vasmus and Akula (Akula used this suspicious thick wire too and he never removed the wire while performing demos) was hired be Germans yet none of his devices get to the market. For me the Vasmus demos were the most convincing; he really has shown all the connections, made outdoor video as well, removed ground wire then reconnect the ground wire and restarted the device, he even dissembled the device to small pieces. His best video (outdoor) https://www.youtube.com/watch?v=XlvZ6sVNAYU blurry but this is how a good FE demo should look like.
If Ruslan wont let Wesley inspect the device and choose location for demo then he is a finished conman.
Quote from: vasik041 on July 27, 2018, 12:20:43 AM
Sorry, don't want interrupt your entertainment, this is for those who interested in real thing...
Yep, this is exactly how my autoresonating TinselKoil X works ... only wirelessly. Load is placed in the ground connection to a _second secondary_ some distance away from the transmitting coil. Or even a third... fourth.... who knows, I ran out of wire.
https://www.youtube.com/watch?v=AFP6c7lwyoE (https://www.youtube.com/watch?v=AFP6c7lwyoE)
Quote from: Void on July 27, 2018, 12:13:33 AM
Misdirection is a key part of stage magic. When you are thinking that the magician has to be a complete idiot... that's when he is most likely to fool you.
https://www.youtube.com/watch?v=WbNNK1WaCL8
Quote from: AlienGrey on July 27, 2018, 12:15:29 AM
I like the way you think.
The Earth-plus-ionosphere is a big spherical capacitor. Where does the charge accumulate on a spherical capacitor?
Quote from: TinselKoala on July 27, 2018, 01:26:45 AM
Ha Ha ! between the surface of the outer sphere inner sphere (earth) and inner surface of the outer sphere.
What you should be asking is how do you attract charged particles/electrons from one or the other charged surfaces with
a Tesla coil thats outputting AC ?
I think Tesla had Givenchy the answer in 1900
Look again at Kapa aquabox in garden. IT is ciężki
This thread has certainly come alive! Thanks again Wesley for the translation of Sergey's video plus schematics.
I find it quite amusing that the Ruslan layout provides for a latching relay placed very conveniently next to the ground wire entry point for easy termination of a concealed phase wire. Added to that, he sells the device to Sergey with clear evidence that a wire had been cleanly cut from the relay terminal and when Segey eventually soldered a 'hot' phase wire to the terminal, the device sprang into life! IMO, one has to be naive to think that Ruslan ever video demonstrated the device working without the phase wire connected. I see no evidence that Ruslan's device was ever genuine but increasing evidence that it was a faked self-runner.
Another observation: If the length of the ground wire is critical, presumably the length of both Ruslan's and Sergey's home pipework has to be taken into consideration?
https://www.youtube.com/watch?v=L8ABhb5wDJ8 Lastest ruslan device, where is the hidden wire?
Quote from: PolaczekCebulaczek on July 27, 2018, 04:51:18 AM
https://www.youtube.com/watch?v=L8ABhb5wDJ8 (https://www.youtube.com/watch?v=L8ABhb5wDJ8) Lastest ruslan device, where is the hidden wire?
If its done properly, you won't see it in a Youtube video.
QuoteIf its done properly, you won't see it in a Youtube video
like this one?
https://www.youtube.com/watch?v=ljKX9Om7Z4s (https://www.youtube.com/watch?v=ljKX9Om7Z4s)
Yes! No hidden wire. Look especially how much static around. But device is light and and output also only 16W. Kapa had 2kW for such size because he had stronger fields
I once got it and even the chasis of car battery has a lot of static which light neon
Quote from: forest on July 27, 2018, 05:38:47 AM
That's normal when working with HV and TC's. Bright HV lit neon lights are not power output level indicators.
Quote from: forest on July 27, 2018, 04:25:10 AM
so it's heavy so ?
Remaining in my role as resident skeptic, I reply:
Hidden wire is not necessary when coil form is big enough for batteries containing plenty of energy to power the demonstration shown in the video. We only have the presenter's word that there are no lithium batteries inside the coil form. Each separate demonstration doesn't need to use the same method of trickery.
16 watts of light power at 220 VAC, a little spark gap, some HV/HF all over the device, less than five minutes of working shown... no problem for a LiPo battery inside the form.
There are plenty of red herrings, as usual. The best red herring, though, as I've often said, is a real fish, and Ruslan appears to know this too, because the devices _do_ work, that is, they oscillate, produce HV, drive loads using the principle noted above by vasik041 and illustrated by my TKoil X, and so forth. When supplied with power, that is.
Quote from: AlienGrey on July 27, 2018, 06:46:29 AM
so it's heavy so ?
lots of iron to produce very strong magnetic field
Quotehttps://www.youtube.com/watch?v=L8ABhb5wDJ8 Lastest ruslan device, where is the hidden wire?
True, its easy do drive 16 watt bulbs for a short while using HV discharges or resonant systems, single wire transmission is a possibility too, all of Ruslan demos can be faked by someone skilled in such art. If I would have a real FE device , then my demos would be long, outdoor, HD and detailed, showing all connections and even live streamed on YT.
Quote from: TinselKoala on July 27, 2018, 07:24:32 AM
My favourite is the Kapanadze Aqua 2 trick using the rather exotic ground wire - copper braided tube to conceal the phase / 'hot' wire.
Wesley Where are you ? I ask if your in Latvia ? you do know there is a Lunar eclips just starting there !
Strange coincidence don't you think so. Or are you oblivious to cosmic forces but rely on them for energy 8)
https://www.timeanddate.com/eclipse/lunar/2018-july-27
Good Luck AG
TK
QuoteHidden wire is not necessary when coil form is big enough for batteries containing plenty of energy to power the demonstration shown in the video. We only have the presenter's word that there are no lithium batteries inside the coil form. Each separate demonstration doesn't need to use the same method of trickery.
That is an interesting theory, so how would you explain T.H.Moray driving a 20 KW load from a box no bigger than 2 square feet, for hours on end in front of many credible witnesses, in the middle of nowhere at a random location using 1930's battery technology?. I understand they are different people from a different time in a different place however if your going to apply a bs hidden battery theory to every case then I would love to hear your theory on T.H.moray.
Do you have any idea of what it would take to generate 10 KW per cubic foot using conventional technology today in 2018?. I don't think you have any idea to be honest because even by today's standards it would be miraculous.
Then we have Daniel McFarland Cook using a few coils and an interrupter producing KW power levels in 1871. Do you understand the state of technology in 1871?, the automobile would not be invented for another 14 years, Tesla would not design his alternating-current electrical system for another 18 years. So did Cook generate KW power levels from hidden batteries in 1871 as well?. It's comical because a simple inventor from 1871 would seem to understand something all the rocket scientists and all the experts in 2018 cannot seem to grasp, as they say something so simple even a child could understand it. That has to sting a bit doesn't it?, everyone is a fucking genius... they just can't build anything that works.
Hello vasik041. Have you tested this?
If so, what kind of actual results are you seeing in your testing?
Quote from: onepower on July 27, 2018, 07:09:33 PM
TK
Show me his YouTube video and I'll theorize how he did it. Because that is all I'm working with in my "interesting theory" above. Give me the actual device and I'll for sure tell you how it works.
I can generate 10 kW per cubic foot using an ordinary car battery. Not for very long of course. Maybe you don't have any idea what I have ideas about. Or maybe you just don't know the difference between power and energy.
That's right, it has to sting a bit. All these people all trying to build something and they keep failing. Like I said before... show me Cook's YouTube video and I'll tell you my theory of how it works. Show me the actual apparatus and I'll definitely tell you how it works. What... no video, no actual apparatus, just "reports"? No wonder everybody keeps failing.
Heck, I've read lots of reports of a man rising from the dead three days after dying on a cross. Lots of people believe that. But nobody can actually verify it.
Quote from: Void on July 27, 2018, 08:52:13 PM
What his pdf shows is exactly what my TKoil X is doing. All except for the overunity of course. But it's easy to make overunity measurements on something like this.
Quote from: TinselKoala on July 27, 2018, 08:52:36 PM
I can generate 10 kW per cubic foot using an ordinary car battery. Not for very long of course. Maybe you don't have any idea what I have ideas about. Or maybe you just don't know the difference between power and energy.That's right, it has to sting a bit. All these people all trying to build something and they keep failing. Like I said before... show me Cook's YouTube video and I'll tell you my theory of how it works. Show me the actual apparatus and I'll definitely tell you how it works. What... no video, no actual apparatus, just "reports"? No wonder everybody keeps failing.
Well Don Smith managed it and Henry Moray did too!
Perhaps! your not getting mixed up with the Sun that's Said to dye on the 'southern cross' around christmas for 3 days
and then starts going again as the illusion of the sun rises again ? sounds familiar some how, can't think why. Perhaps the info has all got mixed up who knows.
Hello Void,This not my main research path, I work with magnetic fields.But yes, I made some experiments, there is definitely current in ground wire... and this make some people very nervous :)
Regards,-V.
PS Take a minute and read attached article, it's same principle but ionization achieved in a different way.
Quote from: TinselKoala on July 27, 2018, 08:54:12 PM
With all respect to you TinselKoala, your system is different.You are very smart guy, I do not believe that you do not understand it, so please don't mislead people :)
Quote from: vasik041 on July 28, 2018, 12:44:09 AM
Regards,-V.
Hi vasik041. That's an interesting article. Thanks for that.
Discharging the static charge in the air to ground to produce steady electricity.
It seems it would take a lot of balloons to even power a very small town, but still pretty cool!
vasik041
Thank you for the interesting article, I have studied Plauson's work.
Around 40 years ago when I was a young man I noticed a thunder storm about 10 miles away approaching our farm. Our 40 foot tower with a TV antenna also happened to have a broken ground strap. In the dead calm before the storm I remember hearing a load buzzing noise and found a thick 1" blue arc breaking across the broken ground strap.
Strange isn't it?, the layman would have us believe there is no power in the atmosphere but here was a near continuous thick blue 1" long arc jumping to ground from a relatively short tower in the dead calm... before the storm. I suppose seeing is believing but it shouldn't take a rocket scientist to find more creative means to produce similar effects in fair weather at the lower voltage of 100 V/m. If we know the energy is there and it is then it's simply a matter of approaching the problem from a different perspective. Do we simply allow the energy to flow at it's own rate to ground or can we increase the rate of conduction through other means?.
Quote from: Void on July 28, 2018, 01:31:36 AM
That's the idea of the HV static potential ! then you don't need balloons.
Quote from: onepower on July 28, 2018, 03:07:05 AM
Power depends on voltage and current. Putting "antenna" higher will increase voltage. Ionizing air around "antenna" increase current.
Here a link to an article with good explanation of this idea http://www.sciteclibrary.ru/rus/catalog/pages/9331.html. Perhaps Wesley can make proper translation, meanwhile you can use google translate
https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fwww.sciteclibrary.ru%2Frus%2Fcatalog%2Fpages%2F9331.html
History repeat...again ...
http://newlightondarkenergy.blogspot.com/ (http://newlightondarkenergy.blogspot.com/)
Quote from: nelsonrochaa on July 29, 2018, 12:10:54 PM
About the scope i will advice to you prefer tektronix i know they have a more affordable scopes available at moment . I really don't like Rigoli because some problems that i have with the equipaments when i use in German workshop . Almost need to be repaired .
The only thing i like about Rigoli is technical support ; everytime everything run ok during the process of repair in Rigoli .The best scope you could have to high freq switching and HV maybe could be a analog scope but is my opinion ;now here is a question that TK can help you given your experience with oscilloscope. :) lol
Thanks Nelson. Sounds like maybe Rigol is not much better quality-wise than a Siglent scope.
Yes, Tektronix would be really good if I can find a fairly new one that I can afford. :)
Nelson, do you have anything interesting you are experimenting with lately?
and then there is the "other" side of that story, the Scientific perspective [thx to member Reiyuki for "jokes"
snip
Energy cannot arise from nothing!
Well, except for this one time... https://en.wikipedia.org/wiki/Big_Bang (https://en.wikipedia.org/wiki/Big_Bang)
There is no perpetual motion!
.... except for the orbitals of every atomic element in the universe... https://en.wikipedia.org/wiki/Atomic_orbital (https://en.wikipedia.org/wiki/Atomic_orbital)
Quote from: ramset on July 29, 2018, 12:38:28 PM
snip
Yeah! one problem with that, you can't have nothing, nothing is always something! and then there is dark matter, what ever that is
is any ones guess but what is known about it is it's pulling the universe apart, fun ain'it ;)
Free energy is a charge in the atmosphere between earth and ionosphere from solar winds, tap into it one way or another and never buy another KW of power again!
Fun ain'it
Quote from: Acca on July 30, 2018, 01:41:13 PM
What "we heave here is that Kapanadze theory missing from this discussion "..
Now it's egos who is better with useless post here... Provide at least some theory of why this device is real as Wesley
has said...
Who are these Newbies with the intellectual capacity of a capacitor.. Say something that is original !!
University credentials just give you enough to fall flat and make you a village idiot.. Profound posts by Wesley
are the reason I read here. Idiots don't belong here.. I can see them on their silly phones..
Happy life from sunny today Poland..
Acca..
Well I know for a fact Ruslan is no NOVICE ! i forgot this little fact and a real gem! he had a video on his youtube,
He was in a field with an old transmitting Aerial tower the down lead had been cut and the top of the tower was some height, any way
but dismantled as far as aerials were concerned, anyway as Ruslan moved the cable it contacted the tower metal work with arks and
flashes!
My point is that is free energy from part the way to the ionosphere you or any one else would not need much to convert that static
to usable energy !
While we are at it the TK green device have a thing about two earths ? look at this picture of the green box
Quote from: Void on July 30, 2018, 03:04:33 PM
Actually, I am leaning towards Ruslan being legit.
Some recent info/videos posted by Ruslan in the past while indicate Ruslan may now have figured
out how to get the output at or near 50Hz. His devices seem to be progressing, and he is showing no
signs of stopping. :) Ruslan seems to be reluctant to release his devices willy nilly on the world
due to the effects it might have on the current world economic order, but Ruslan is still
showing things and commenting, but more low key now. He is really not hiding all that much, I think. ;)
Void,
I think you are on the spot right now,.. lets crush the "fake " narrative..
Some more information which would point at legimit narrative's.
Ruslan has built and (do) maintains a radio transmitter/station and that requires thorough knowledge of RF theory,
Transmission line theory, etc. along with hands on experience.
He has the equipment also!
Akula, who kinda started all this, has a DSA815 Rigol on his bench.
I am sure it is NOT there for decor.
These people are NOT just guessing and playing games, I do believe that they have something and that their devices do function.
Greetings
Quote from: apecore on July 30, 2018, 03:53:06 PM
Void,
Greetings
did you notice the thick black cable going into the center of the green box winding ?
Quote from: AlienGrey on July 31, 2018, 02:53:47 PM
Well it looks a bit like the earth cable to me.
Well,... can you prove it.....technical it could be a cable from the power grid to supply the greenbox with power?
so,... here we go again... :o
Quote from: apecore on July 31, 2018, 03:06:50 PM
Look on page 4 it would need some experimentation with HV dangerous stuff
Hi everyone,
I reveal something from sergey video that will make people go crazy once more.
I have attached screenshot from the youtube at 4.59...5.01 Minutes into video.Have anyone wondered why Amps became zero from Power supply after Kapanadze device was powered up.
https://www.youtube.com/watch?v=7pE83oajjoo (https://www.youtube.com/watch?v=7pE83oajjoo)
---------------------------------------------Additonally one part of the circuit revealed by Sergey which i need to convert And gate to Nand to resolve circuit error in that circuit.I found out it is a divide by 12 circuit.
30khz example input frequency would be converted to 2.5khz.Please do not ask me why.
May be keen to know that the word "Electron accelerator" do exist today.But it does sound crazy talking about it couple of decades ago. :D
magpwr
QuoteMay be keen to know that the word "Electron accelerator" do exist today.But it does sound crazy talking about it couple of decades ago.
Strange isn't it?, a battery accelerates electrons due to a chemical reaction, a solar cell accelerates electrons due to excitation across a band gap and all our generators accelerate electrons due to a changing magnetic field. Where once the free electrons were uniformly distributed within the material now they experience a force which causes them to start accelerating and move along a conductor.
In many respects we could simply throw out all the math, equations, rules and regulations and all the complexity and say energy is produced whenever free electrons experience a force and start accelerating. It does not matter how the force on the electrons causing them to accelerate is produced only that it is produced in some way. In fact this is the only requirement...period.
Steven Marks got it right in my opinion... everyone is trying to build the most complex devices and yet they still do not understand the basics. Steven said all you need to understand is all the possible actions and reactions in a single piece of wire. If you can understand this one thing then you have all that is required to build a FE device. Oh I can just see all the supposed experts throwing up there arms claiming they understand everything however it should be obvious they do not understand. They have missed something so basic, so simple even a child could understand it found in the understanding of a single piece of wire.
One cannot claim to understand anything when they cannot produce the desired results and the only real experts are the one's with working devices sitting on their bench... that should have been obvious.
Magpwr, a little advice, what your looking for does not show up on a simulator and in most cases it does not show up on a DSO unless you know what your looking for. As Ruslan implied... throw all your fancy equipment and your complex theories out the window and use your head.
Quote from: magpwr on August 01, 2018, 10:34:28 AM
Hi everyone,
That's most likely because its powered from the grid on a 'hot Wire' straight into the device!
Isn't that the 12 Volt input feed input from the start up battery ?
Think about this then for a change.
The Kacher suppose thats running with high voltage on it, how is that energy input into
the rest of the device ? The coil of wire with a few turns on it ? some things more basic don't add up.
Quote from: onepower on August 01, 2018, 11:45:30 AM
magpwr
Well the signal comes from only 1 half of the 494 not both so if it's running from 12kh to 18khz the 4017 would only output
divide by 2 (input) and divide by 6 to 9 and then there is the 4013 divide by 2 again. some where around 1khz ?
But then whats the point of that ? but what it could do with a cap and resistor or two is test the PUSH PULL is running,
but I could think of an easier way to do that, but there again it's output goes no where! Oh and the logic is driven at 5Volts
But the TL494 could be run from 12 Volts or 24Volts, fun ain'it ?
QuoteWell the signal comes from only 1 half of the 494 not both so if it's running from 12kh to 18khz the 4017 would only output
I think you nailed it and after reading page after page of this nonsense, Ad nauseam I want to pull out my hair. It would seem common sense has left the building.
Hoppy
QuoteThat's most likely because its powered from the grid on a 'hot Wire' straight into the device!
Or a secondary coil such as a Tesla coil connected to ground can produce a net charge on it's surface while a secondary coil such as a Tesla coil not connected to ground can only produce a charge separation along it's length and not a net charge. This thing you cannot seem to wrap your mind around can be found in any high school textbook.
Quote from: Hoppy on August 02, 2018, 03:36:56 AM
Maybe you can wrap your mind around and demonstrate how a TC can produce a continuous net charge without a power supply to drive it, whilst its 'top-load' is coupled to a grenade coil powering a heavy lamp load, also not being powered from a conventional power supply.
Hoppy I myself can do use and train my mind to do many things, and all my cats do many useful things
but I am have not as yet had occasion to see him (my top cat) do as you request 8) 8)!
I think you are asking for the meal to already made, but all the items for the meal are in this thread, Its just a question
of assembling the the individual items and then you can eat the meal. As you will already know many have found the meal already eaten.
As you might have guessed many of us are just back room boys and don't want to appear on stage eating our lunch!
Quote from: Hoppy on August 02, 2018, 08:32:54 AM
So that's tantamount to saying the 'proof is in the pudding' in the modern sense of the phrase. I call your bluff on that one ;D ;D ;D ;D ;D
Find your glasses and gloss over page 37 and READ IT !
TK and Hoppy ;D ;D ;D
Our planet in electrical terms is a kind of spherical capacitor, charged to about 300,000 volts. The inner sphere - the surface of the Earth - is charged negatively, the outer sphere - the ionosphere - is positive. The Earth's atmosphere serves as an insulator.
Find a way to collect it !
a way to use it https://www.youtube.com/watch?v=VZLtVrfz7y0
AG
QuoteOur planet in electrical terms is a kind of spherical capacitor, charged to about 300,000 volts. The inner sphere - the surface of the Earth - is charged negatively, the outer sphere - the ionosphere - is positive. The Earth's atmosphere serves as an insulator.
I believe it was Richard Feynman who said radiation and evaporation are the primary transport mechanisms which continually drive free electrons from the Earth to the atmosphere. What we see as lightning is the Earth capacitor trying to discharge and balance itself. We are in fact stuck between two area's of extreme potential looking for a path to find equilibrium.
You have to think about it for a moment, imagine you are stuck between two very large capacitor plates which are already charged. You did not create this energy nor does it appear from nothing... it is already present as explained above. Now all you have to do is find a way discharge some of the potential already present to produce an electric current. What kind of circuit could you place in between two charged capacitor plates which could discharge some of the potential?.
I will let you in on a little secret... if you can build a circuit which can discharge some of the potential between two charged capacitor plates at a distance in your lab or garage then you can do it anywhere. The secret is called science and if the premise is sound the premise must apply in every instance.
Strange isn't it?, who would have thought that using scientific principals, experiments and a little common sense could offer a little insight into the problem at hand. It's a pretty simple proposition... either your circuit works or it does not.
"Now all you have to do is find a way discharge some of the potential already present to produce an electric current."[/size] I AGREE ;D
Did you watch the video from my previous post ?
Quote from: stivep on August 02, 2018, 03:48:37 PM
d. it was noticed that using earth as e return wire ( means of connection) saves battery life anywhere from 50% to hundreds of %
Wesley
In comparison to which other tested circuit configuration?
I recall in my young days as a UK BR railway telecomms tech that dry batteries powering trackside 2- wire (very long line) code ringing telephones would still adequately function even when their batteries were swollen and leaking electrolyte. In this case it was nothing to do with earth return / telluric currents. Some of these batteries were known to have powered their phones for many years without replacement.
Quote from: Void on August 03, 2018, 10:11:52 AM
IMO, for people who want to have a chance at moving forward with understanding,
you must be able to prove/disprove your ideas/assumptions with actual physical tests and experiments.
This is a basic tenet of the physical sciences for a very good reason.
That was all I was saying Wesley. I don't think it is unreasonable at all, given all the unsubstantiated
and wild claims people frequently made in these forums. :)
Void
What you are asking ! You will be very lucky for some one to come out of the closet over
with out putting there existence in a life or death situation !
As you say loads of stuff on the net is total BS, I would suggest you abandon your 'have and to hold'
demands and relax and dig deeper into what is real.
A real Tesla device observe and learn, and don't dismiss this link as irreverent !
https://www.youtube.com/watch?annotation_id=annotation_3933099103&feature=iv&index=2&list=PLFsZmHTZL-zmfXxstlxuJgRE9bOGobEVu&src_vid=vemF7p0cbHU&v=0SaEPW_iMF8
Notice the Tesla coil exploits this very phenomena yet every one ignores it!
sorry to chime in in this "Tk and ruslan did not used a second ground"
thats verry true in meaning they hat only one line to earthground ... the second can just what you would call a virtual ground..even if its not the whole storry about it. just take pice of iron and use it as the second gnd.
how ever tesla as well as alexanderson made a graet deal about virtual grounding .. in terms of mass and material.
wesleys steps bevore are ment more ore less as basic setup to get a understanding how and why . at least thats how i look at it .
beside that i was abled to proof some his points .
have fun JoJo
Void
QuoteIMO, for people who want to have a chance at moving forward with understanding,
Proof
Quote from: jojo500 on August 03, 2018, 03:57:44 PM
have fun JoJo
I do not see Kapanadze or Ruslan using a virtual ground in terms of a mass of material. Nothing we see in their videos support the use of any more than a single physical earth ground point.
Which of Wesley's points have you been able to prove?
Quote from: Hoppy on August 04, 2018, 12:27:04 PM
Hoppy,....did we finaly end the GROUND wire chapter?. ;D
I am very glad we ended this GROUND connection chapter.
So what chapter is next?
Greetings
Quote from: Hoppy on August 04, 2018, 01:42:30 PM
- Hidden batterie
- Coil mode of operation
- Electrostatic mode of operation
- etc..
Indeed, whoa!
I started looking at a two ground system some time back.
https://youtu.be/mRz3oTLicT4
Sadly my own health deteriorated to the point of not being able to continue with experiments.
In the video I mentioned a gentleman who's handle is Dragon, he had developed a circuit that automatically charged a capacitor bank.
Don't forget that most early telegraph routes were " dowsed " to find the best efficiency ! ;) I was taught dowsing as an apprentice whilst training as an electrician for the local water supply company.
Cheers Grum.
When I was in the old tpu thread,the same thing happened, people
listened to the inventor say something and ran with it.I can't get this to build the device,conclusion it must
be important,this happens in this thread,your being tricked by Kapandaze.In the tpu thread it was the inventor
wants you to build hes device
and would never lie to you,stupidity reined in that thread.In this thread, its a Tesla invention,
it operates at high frequency,the coil construction is the secret.
Here is another of Kapanadze's devices,the ground wire can not be two wires Hoppy,
the fan that he uses operates at 220vac ,50 Hz so the output has to be 220 vac, 50hz.
At the max power it draws 14.8 amps times 220v=3,256 watts,the guy takes a current reading.
The ground in my opinion does not do anything, simply a trick to convince you its related to Tesla stuff.
Pay close attention to the two spark plugs no arc coming from them,whats a Tesla with no arc,LOL ;D.
As far as I can tell there is no hidden wire,so the next trick would be hidden batteries
and a dc to 220v inverter,the size of the inverter rules this out,max power 3,256 watts
for a 12 volt dc battery,the current draw would be 271 amps,I'm assuming a 100% conversion rate
for arguments sake,in reality,the current would be much higher.There is no room in the box for a large inverter or
battery that can deliver this amount of current.In my opinion the coil is a very important
part of the device,this is where the current is generated,notice two wires are tied together on the output white coil,in parallel to increase current.My opinion is the current is not generated in an ordinary way but in a completely different manner,this is why its very hard to figure out,you have to look at all the various devices Kapandaze has made. Check it out and discuss it,skeptics,how did he do it.
https://www.youtube.com/watch?v=EH9VhcDZYKg
Hi Cheappower2012. Good to see you contributing to this thread. I agree with most you wrote, other than there not being a hidden / 'hot' wire(s) powering the device. The hidden wire(s) in the video you posted is most likely routed through the wall into and through the channel section of one of the foot arms on the fan. Look closely. Until a more plausible explanation can be put forward, I'll stick with this one.
Quote from: cheappower2012 on August 05, 2018, 04:13:48 AM
Ah a window sales man, No spark ! BS whats that Zzzzzzzt and a spark at 1538 ???
Notice the Tesla coil and the TV tripper just behind it for high voltage to the Tesla coil
now look at the Tesla coil it self it's filled with something, and the end high voltage wire is dead thin, one would expect
a really high voltage ark there, but that coil must be resonating at a low frequency with it's length. The spark plugs limit
the high voltage and other things (EV Grey Tube).
I expect the black box on the left is filled with some sort of storage capacitors or is control.
Wesley what is the PCB to the right of the BLACK BOX it appears to have rows and rows of devices, can you comment on it pleas i'm curious ;)
Quote from: AlienGrey on August 05, 2018, 07:49:15 AM
That's not very kind to call Kapanadze a window salesman just because he uses a lot of glass to house his devices. ;)
The PCB's look as if they are from an old scrap TV, or other junked appliance. Eye candy.
Quote from: Hoppy on August 05, 2018, 08:24:33 AM
Or as i read somewhere he is using the PLL part of the TV board
Quote from: apecore on August 05, 2018, 08:34:58 AM
Possibly but that would not add up to his statement along the lines that the device is is so simple you'll laugh.
Hoppy
You are correct,on the possible hidden wire being run thru the wall.
You would only have to drill thru the concrete a small hole that leads
behind the wall
and place the fan leg to cover it,then connect thru the fans plug.
The only weakness is how smart is the guy that's paying
Kapanadze,is he a fool.A more believable demo would have been
connecting the heater only
close to the device and lifting the device up.I believe that there
are government agencies that
do grab devices that are real but will only act if there's a good
chance that the device is real,with kapanadze its always maybe its real or maybe its fake
its never a certainty one way or another.This video is from 2015 so he must have burned this guy and
moved on to the next victim One thing kills me,lol,when there's talk about
resonating at much higher frequency than 50 Hz, people forget all of Kapanadaze,s devices operate
at 50 Hz not higher frequencies.This does point to two conclusions one its a hidden wire in all cases or
its a brand new method of generating current that's unknown.
In my opinion only the white coil and the black box, is the device,there is a much larger battery hidden,its used to start the device,the 9 volt battery
does not start the device its used to activate a relay,that switches the larger battery.Remember in the 2005 device it took a lot of current to start the device.
Quote from: Hoppy on August 05, 2018, 08:43:33 AM
Hoppy,
The problem is we don't know which statements are for real.
This means we it can be a "Yes"or a "No"....
On the other hand.."the device is so simple you'll laugh"... is probablt only valid when its working on the bench in front of you.
Until that,... looking how much years and how many qualified people have been busy with it,......... it seems not so simple at all...
Alsi don t forget,... PLL may be a device to gain more efficiency,... holding the synchroisation process fixed.
As it would be working without PLL more parameters will have bad effect on stability... (f.i. Our Nick "Chaotic effect")
Question would be,... When a PLL is used... what would it control?
Greetings
Phase locked to the earths resonance (timing) that's not too difficult. You need about 10kv but no flying sparks
just pulsed, just static. possibly regulated.
Notice spark at 15.38 into video
Quote from: cheappower2012 on August 05, 2018, 08:56:40 AM
Hoppy
behind the wall
No large battery needed with a hidden 'hot-wire'.
Look closer at the gap between the fan leg and the wall.
Quote from: AlienGrey on August 05, 2018, 09:02:20 AM
Kapanadze could have produced sparks just for eye candy. They signify or prove nothing until the rest of the device is properly understood.
Quote from: stivep on August 03, 2018, 12:19:13 PM
My dear Hoppy .
the two grounds controversy:
Think about it as not important. Just not important for time being.
And After you have done it and wake up very next day than you can come back to your reality whatever you feel comfortable with.
Just do it for yourself.
Wesley
Wesley,
I'm comfortable assuming that the devices I have so far seen demonstrated are faked until such time as a plausible alternative explanation surfaces. As Cheappower 2012 correctly points out, these devices are powering their loads at 50Hz, so I see no reason to believe that HV or HF is necessarily required for operation. I respect that you are trying to be helpful but with respect, some of your posts are just coming over as riddles to me at the moment.
And again we passed another chapter 8) ;D ;D ;D
Hidden batteries/ additional power sources
Does this last post from Hoppy ends the Kapanadze discussion?
Well until we see no proof from Ruslans demonstration (open field/ BMW X5) i guess that one would be legimit?
Or not?
Greetings
Quote from: apecore on August 05, 2018, 10:13:15 AM
Or not?
Greetings
What with a battery buried under a pile of straw as in his last video but concealled more carefully this time! ::)
Quote from: Hoppy on August 05, 2018, 10:43:13 AM
Dammn Hoppy,
Your so good,... and do you know what is worst about it....
I m almost gonna believe you
i realy hope you are same so good thinking in the other direction ;) :P
Quote from: apecore on August 05, 2018, 10:46:16 AM
Which direction Apecore?? ;)
Quote from: Hoppy on August 05, 2018, 10:52:40 AM
Well,..... 180 degrees opposite..
The one without hidden batterie or external power sources.
Your direction leads us at the end of the road,... no project obligation/ goals to believe in.... it would be catastrophic for all those guys here ending up at the bench..
So please help us to find some light in this dark tunnel,.. in order to skip this batterie/ hidden power chapter :o
Quote from: apecore on August 05, 2018, 11:05:36 AM
I'll do my best if and when I find my compass. ;D In the meantime lets hope that Wesley can shed more light into that dark tunnel.
Ha Ha! battery's would explode with that kind of current.
Under stood ? when does he do that (stand under it?) i missed that bit.
Quote from: AlienGrey on August 05, 2018, 11:38:47 AM
??? What kind of current?
Quote from: Hoppy on August 05, 2018, 11:49:20 AM
14.7 at 240 Volt = 3528 Watts
3528 / 12 = 294 + conversion at 25% loss approx = 367.5 Amps
they might handle it for 15 Secs but the gassing would be horrendous after that
once it started you would need a blower, Have you ever seen battery's in a Telephone exchange ? ;D they would
be huge !!
Now suppose we have 10kv how many amps would that be ? about 2.5 amps for 25000 Watts ?
Quote from: AlienGrey on August 05, 2018, 12:01:21 PM
??? How did you come up with 14.7A at 240V!? Did he measure the load current and voltage in the forest video?
For those who repeatedly claim to exist batteries or network phase line in such devices,
a productive approach to understand if there is a real point's in these circuits demonstrations, would be try replicate the same effects demonstrated in the videos, even using batteries or phase line of the grid.
It would be a much better exercise than speculating about their veracity.
Just speculate, it does not seem a good exercise to find any answer that leads to clarification about the subject.
Let us agree that we need more than speculation to counter these demonstrations.
A good test would be, someone try demonstrate at least a 100W load like a resistive bulb or something similar, so the argument would be sustainable, to state that exist hidden batteries or phase line of the grid.
Do not you agree that it will be easier?
Otherwise they are just talk of the trick of guessing and nothing else.
Cheers
Nelson Rocha
Nelson,
What effects are you referring to? In terms of V & I measurements and waveforms, other than some 'iffy' clamp meter readings in the Kapanadze garden videos, to my knowledge, these have only ever been displayed at the bench using bench power supplies or batteries to power the devices.
Quote from: Hoppy on August 05, 2018, 01:12:03 PM
Nelson,
Hoppy,
What effects i'm referring ? I am referring to the loads used in the devices of TK or Ruslan .Is not this the topic of discussion?
How they can power such loads ,we can verify that there are several resistive loads, such as lamps, heaters etc.
What I said, is that they should try to replicate something identical, even with batteries, or phase of the grid.
I hope I have been clear now.
cheers
Nelson Rocha
Nelson,
IMO your proposal will not help to determine beyond reasonable doubt that Ruslan's or Kapanadze's devices are genuine or faked.
Quote from: Hoppy on August 05, 2018, 01:54:54 PM
Nelson,
IMO your proposal will not help to determine beyond reasonable doubt that Ruslan's or Kapanadze devices are genuine or faked.
Why do you say this ?Are you contradicting yourself?
The speculation you make about use a battery does not either help . how you know is fake ?
In other hand , if someone could reproduce the sames actions of their videos(TK , Ruslan) in the same conditions , maybe will be more easy and assertive say that could be a fake.
Do you agree ? Otherwize seems we are chase witches, as in the time of the Inquisition.
The loads used in videos of TK apparently could not be drive by batteries ..... like AG refer . is much load to be provide by a battery .
Now exist other chance , :) maybe TK knows how to use the existing energy even of a small battery to amplify the output, and then we are already talking about another situation. ;)
The problem is that type of systems could have a lot of aspects and approaches that make more difficult understand how they works, and use the argument that only could be fake , raises another question:
Are you or anyone else able to reproduce the same "fake" system? ups after all this years no one did that.
maybe i could dedicate a bit time to this device .
Cheers
Nelson Rocha
Quote from: nelsonrochaa on August 05, 2018, 02:26:08 PM
Cheers
Nelson Rocha
Not at all! As I commented in my post to Wesley - I'm comfortable assuming that the devices I have so far seen demonstrated are faked self-runners until such time as a plausible alternative explanation surfaces. I don't have proof these devices are faked any more than I and others have proof they are genuine. Feel free to demonstrate a fake self-runner if you think it might help.
Quote from: Hoppy on August 05, 2018, 04:11:30 PM
Curious see your position in relation to the subject of topic , but yes you have right ,you dont have proof that is fake , only a suposition . :)
Cheers
Nelson Rocha
Quote from: nelsonrochaa on August 05, 2018, 07:02:49 PM
Cheers
Nelson Rocha
Watch this carefully !! Tesla coil with no charge caps or spark gap in our Ruslan device, and with the device circuit in the video NOTICE THE DIFFERENCE!!
Note in the video the device might not exactly be tuned to 1/4 wave in his example but we are just looking at the difference of using charge caps
and a spark gap.
https://www.youtube.com/watch?v=yY8lGmibGVY
Quote from: AlienGrey on August 05, 2018, 08:10:44 PM
Watch this carefully !! Tesla coil with no charge caps or spark gap, and with NOTICE THE DIFFERENCE!!
https://www.youtube.com/watch?v=yY8lGmibGVY (https://www.youtube.com/watch?v=yY8lGmibGVY)
What are you talking about? That "Tesla Coil" in that video has both a spark cap and improvised charge caps. But the builder didn't quite manage to get things right, and his coil doesn't seem to be working as a quarter-wave resonator yet.
Here's my hybrid Tesla Coil, using a similar Royer oscillator driven TV flyback transformer for the HV power supply, running on 24 VDC input, still in tuning stage:
https://www.youtube.com/watch?v=jsfW6tT3cQA (https://www.youtube.com/watch?v=jsfW6tT3cQA)
https://www.youtube.com/watch?v=aIZClhoU2Xk (https://www.youtube.com/watch?v=aIZClhoU2Xk)
Quote from: TinselKoala on August 05, 2018, 08:28:58 PM
Hi Mr Tinsel ! Well as I see it The Ruslan Katcher has a lot of design problems.
1 as you point out it's not 1/4 wave 2 it has no charge capacitor tuning 3 no spark gap control and 4 the wave form is a sine wave.
Tinselkoala If you would like to contribute your expert-ease into the katcher circuit redesign to make use of using a EARTH magnification from the
earths resonance similar to the Don Smith circuit be my guest! ;D
@ Apecore,
I have been thinking about the next chapter. ;) Maybe we should try and answer Wesley's question to us, that is: "Think about all possible ways of earth being charged."
I'll kick it off by suggesting that we install some grounded lightning conductors in the vicinity of where we wish to experiment. :D
Quote from: Hoppy on August 06, 2018, 04:31:45 AM
Good morning Hoppy.
Your post reminded me of something that a.King21 spoke about when his team went to visit Tariel Kapanadse and the " Aquarium " demonstration.
The demonstration was postponed on one occasion because of an imminent electric storm in the vicinity.
Relevant??
The real versus fake discussion will continue indefinitely until " someone " " somewhere " proves otherwise. Let the friendly " banter " continue.
Cheers Grum.
Hi everyone,
I not gonna go in endless discussion but merely need to mention 2 pointers acquired for competent member-
1)Did anyone even bothered to know frequency of the kapanadze coil which the voltage from the multilayered output coil peaks upon applying sine-wave from function generator at the input coil.For this Air core-Peak starts from 750khz but really go up to around 1.0xxMhz
And many of you thought the air-core was efficient at 17khz....32khz.
2)Frequency acceleration can only be achieve at around 1.7..1.8Mhz depending on winding.But i am very sorry to say most of you will likely failed because this kapanadze coil only accept extremely tighttolerance like +-10khz from say 1.7xMhz else the high frequency from the output coil with 100nf capacitor with load will revert back to waveform that isn't fixed.I have not even go into the position of the pulse to apply yet.
I am using mica capacitor to generate stable frequency in Mhz which i can tune although this will not be in line with the tesla coil resonance with Antenna.The other method is to use AM ferrite rod to slowly lower frequency of the conventional tesla coil circuit until output appears to be running 8x times of input at 80khz for my case which is far from ideal and no ou."Base on previous old experiment".
Forgot to mention the L/C resonance is was at30khz with 100nf with 3layer input coil for the old version.But this winding needs to be reduced to 1layer and capacitor changed to approx 2.xxuf xxxVolts in order to achieve the similar resonance.After which frequency needs to be divided by 3 using 4017 as seen in Akula block diagram.May apply part(Front end only) of old Ruslan pll circuit using LM393N with below10resistor from the feedback coil after the 3 turn.
If my calculation are correct and to plan the accelerated frequency which was at 80khz for 10khz parametric oscillation will be raised to a higher towards 1Mhz."Electron accelerator device".
Not forgetting to mention google translation have improved a little more since the last translation was done for me /us by former member MenofFather as typed from Akula old video on Kapanadze coil tuning with the said circuit which was freely circulated.It will be useful to have dual monitor to see the difference in translation.Please use google translation to translate attach pdf document.
I will not waste my energy to get involve in discussion unless your pointer is really applicable to this device eg:Russian forum progress or are they more lost then we are.Thanks.
Think about it- it's getting hotter in almost every part of Europe and Asia countries.From cnn just saw that the carbon emission is the worst in 800,000 years as taken from soil samples.
Quote from: Grumage on August 06, 2018, 07:14:42 AM
Good morning Hoppy.
Relevant??
Cheers Grum.
Afternoon Grum,
Yes, relevant indeed in my opinion if we take the view that Kapanadze's devices are genuine. I highlighted A.King21's comment way back when I suggested that Kapanadze might have been using an aeriel wire energy collector. Putting the clues together, I see a picture emerging where the ground is highly charged in an area, possibly by use of grounded lightning conductors. The potential difference between the charged ground area and the device is then used as Wesley shows in his past video for "lazy folk ;D ": https://www.youtube.com/watch?v=qdJ1V_yDv-c&feature=youtu.be&t=474 (https://www.youtube.com/watch?v=qdJ1V_yDv-c&feature=youtu.be&t=474)
As I see this, a considerable potential difference is needed to supply enough earth current for transformation to a higher voltage at 50Hz resonance to run the type of loads seen in Kapanadze's videos. This would not be achievable in normal ground conditions. Couple this to the fact that Georgia is subjected to a fairly high level of electrical storms / charged atmosphere which may well provide the environmental conditions needed. Also, as you know, I have been insistent that I believe Kapanadze's bearded man was hiding a thick black cable in the coil he was holding, which could have been the second ground wire needed to support this mode of operation.
Quote from: magpwr on August 06, 2018, 08:41:26 AM
Come to the UK Magpwr, its only up to around 32C here. 8)
Do you really think that Kapanadze used highly tuned and elaborate electronics for his devices?
Quote from: Hoppy on August 06, 2018, 08:51:00 AM
hi Hoppy,
I find it hard to believe UK is even hotter than Singapore which is usually typical 30c anytime of the year.But my country is located near the equator.
Unfortunately yes the tesla coil needs to be within +-10khz as tested else output frequency will never be higher than the input.The output will appear higher immediately once the tesla coil frequency is right.Fix frequency pulse using mica capacitor does have it's own advantages over conventional tesla coil circuit.Tesla coil voltage need not even be 10Kv to see effect around
4.5kv...6Kv is enough base on my environment
humidity level of around 76%The divide by 3 using 4017 or via CLC using microchip as shown in my old video is absolute important i have tried already up to divide by 6 but find that only divide by 3 works after (feedback coil to LM393N to single gate of 74HC14 to shape pulse to reduce slew) .
Forget resonance or tight coupling the Kapanadze coil needs to be given a chance to oscillate at it's frequency which is much higher.Either you use L/C meter then apply using online formula to obtain approx frequency at resonance which needs to be below 32khz.But i stick at around 30khz.
The old input winding we had come up sometime back which is around 2 or 3 layers is invalid since capacitor value would be below 1uf to achieve similar resonance for testing purpose before applying divide by 3.
Take note duty from output of 4017 isn't 50% duty.Which why the duty cycle of the
red waveform appear wider as attached.This is the layout after 3 turns from coil to kapanadze i stick with.The NTC resistor shown in Akula circuit is a
"negative temperature coefficient, which means that the resistance decreases with increasing temperature.".Start with around 4.....6 Ohms resistor will do as well base on hands on experiment.NTC or resistor needs to be connected as shown in circuit else no high frequency which will appear as nice sine-wave "I am not sure if it suppose to be this way.It's a near impossible feat if you thinking from book-if tesla coil frequency combined with parametric\random waveform at low frequency approx 10khz can create a new waveform which is of sine-wave"
But i am not following the Akula tesla coil circuit portion after the diode as circled.But this circuit of Akula will work as tested but fine tuning will be hard.Only ferrite rod tuning will be applicable.KT805A which i have purchased from ebay sometime ago works as well as a mosfet with trimmer/resistor for tesla coil circuit.I meant in terms of high voltage production from tesla coil.
I got to go.It's night i would need to exercise to burned excess energy and promote blood flow to me brains. :)
---------------------------------------------Last important note
please use IGBT because it's a slow switching device and it's not sensitive to tesla coil frequency which is running in Mhz.Not forgetting the usual snubber circuit.This device have not failed me yet.Even tried
expensive Silicon Carbide Mosfet twice rated up to
1.2kv even that failed.
Side note:
Just heard from the organization that used to host Daniel Pomerleau's demonstrations for
the last several years, that Daniel Pomerleau died of a stroke on July 31, 2018 at the
age of 62. I was planning to try to get out and see one of his demonstrations this year,
if he held one, but the organization informed me that someone was making a documentary about him
earlier this year so they weren't sure when Daniel would be giving another demonstration, as
he was busy with the documentary people. There is a possibility that a documentary could be
released about him and what he did then, if they had time to film much before he passed away,
but it may be in French.
Daniel Pomerleau would apparently allow participants to bring their own meters/measurement equipment
to his demonstrations to make measurements on his demo setups, and you could bring in your
own electric devices such as radios or blenders or whatever, but not sure what he was able
to do with them, as I never saw one of his demonstrations. I was looking forward to attending one
of his demonstrations if I had the chance. Sad news.
Daniel Pomerleau - September 15, 1955 - July 31, 2018 (https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.conferencesquebec.com%2Factivites%2Ftabid%2F451%2FarticleType%2FArticleView%2FarticleId%2F377%2F30-juillet-2018-Daniel-Pomerleau-nous-a-quitte.aspx&edit-text=)
Here's an old listing for one of Daniel Pomerlaeu's former demonstrations where they
were inviting technicians to bring in measurement equipment:
Free Energy With Daniel Pomerleau (https://translate.google.com/translate?hl=en&sl=fr&tl=en&u=http%3A%2F%2Fwww.conferencesquebec.com%2Factivites%2Ftabid%2F451%2FarticleType%2FArticleView%2FarticleId%2F303%2F22-janvier-2017--Energie-libre-avec-Daniel-Pomerleau.aspx&sandbox=1)
@ Apecore,
Well Hoppy,
Seems a good idea.
Just tell me your idea how and why, i guess you have some space in the garden like me?
Lets duplicate same dimnensions etc. So we get some data to analyse.
I have 40m x 20m avalable.
Greetings
Quote from: apecore on August 06, 2018, 12:17:30 PM
Well Hoppy,
Seems a good idea.
Greetings
I think it prudent to first get the thumbs-up from Wesley, so as to not waste time and effort. Also, I would like to get other members ideas, which might be more practical. My available garden space is smaller at around 20m x 10m.
Ok, I'm in too!
Another interesting experiment might be to send up a single conductor using one of these " new fangled "
drone thingies, and measure the actual voltage across a capacitor between aerial and a suitable ground rod?
Not suggesting doing this in a thunderstorm, I mean, Ben Franklin was one lucky b#~[^{d to not have been " Kentucky " fried, wasn't he? :)
I discovered that with my own simple rod experiments both direction and distance played a part in the voltage seen between them.
Cheers Grum.
Quote from: ramset on August 06, 2018, 01:22:57 PM
I would hope those who try to Brand persons as supporters or ??due to geography ??
would try in this house ,[see Stefan's mission statement at forum headline]
Ramset,
You are right,...
I will not mix up politics and OU again
Greetings
Quote from: Grumage on August 06, 2018, 12:42:35 PM
Ok, I'm in too!
Cheers Grum.
Yes, personal safety is a big issue here. I would favour experimenting in an open space such as as park or farmland where a field kit could be used to data record over a given period of time. It should then be easier to standardise on distances, earth rod depths and height of atmospheric collectors. A good laptop and suitable software should then complete the kit, together with say a helium filled ballon to lift the aerial wire to a given height within the countries regulations. Oh and don't forget to get permission from the park manager / farmer.
Quote from: Hoppy on August 06, 2018, 01:46:01 PM
Plauson already used and patented balloons with aluminium coating and zinc needles. Latter ones for ionization I believe
https://en.wikipedia.org/wiki/Hermann_Plauson
http://0049606.netsolhost.com/pdf/GB157263.pdf
pulling a cable up with a drone and collecting electricity has already being tested
https://www.youtube.com/watch?v=qhXxSAv6rMg
Early German inventors also pulled "antennas" between mountain peeks and collected electricity
Thanks for the links Belfior, which I think suggests fairly conclusively that Kapanadze would need to have collected and stored copius amounts of atmospheric energy to run his devices. Kapanadze's devices appear to me to be based more along the lines of a grid derived power amplification system that Antanas is working on the other thread here (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/22680/). Nonetheless, earth wire point potential experiments (ref: Wesley's test point plan) might reveal an interesting anomaly that could start up that proverbial 'steam roller' effect.
Perhaps reinventing the wheel in testing as it appears we are going appears to have brought Hoppy's skepticism out of the closet
But perhaps Sending Hoppy over to see Roma, Nelson, Ruslan and TK would be a better idea to find out what is realy involved
might be a better idea to obtain any advantage in truth and or hidden expensive maintenance might be involved or trickery. ;D
Before we start playing round with special balloons systems or drones or even vintage car air ships floating around in the abyss!
Quote from: AlienGrey on August 07, 2018, 08:22:24 AM
Nice idea Alien. You can act as my Sherpa to carry all the test kit and vials of antidote and of course a pile of my vintage car mags for me to read on the journey. ;D ;D 8)
Quote from: Hoppy on August 07, 2018, 08:33:04 AM
We need results now !
https://www.youtube.com/watch?v=f3mA7nCTlco
https://www.youtube.com/watch?v=_Ise8Mvzub4
Quote from: AlienGrey on August 07, 2018, 08:45:10 AM
Our theme tune for the project / our rally cry! https://www.youtube.com/watch?v=hFDcoX7s6rEr (https://www.youtube.com/watch?v=hFDcoX7s6rE)
I intend to kick-off with the build below as shown in Wesley's 'lazy guys' video which suits me down to the ground (excuse the pun). I don't see that the trafo winding voltages are too critical, so I'm sure that most of us benchers can find a suitable one surplus to requirements.
Good evening Hoppy.
I've just glanced at the schematic you've posted and, I hasten to add that I've not watched the video either.
Is that a connection between the earthy Neutral and a domestic water filled radiator, or a high frequency square wave? ;) :)
Let's be honest here there's going to be some leakage voltage at 50 HZ enough to do something.
Cheers Grum.
Quote from: Grumage on August 07, 2018, 01:16:19 PM
Good evening Hoppy.
Cheers Grum.
Evening Grum,
Yes, indeed and there is of course some resistance in the pipework, so a voltage potential between the two earths. The question is, what does the resonant primary winding induce into the load winding.
An interesting statement from Ruslan in Wesley's last post: "So if we do cut the wire, and than, we do connect phase than we will have device working because we share the same common ground . got it!!" Also: "Every professional knows that system works on 220V ( Europe)." What do you make of that Grum?
Quote from: Hoppy on August 07, 2018, 01:43:31 PM
Evening Grum,
Bad translation from Wesley ;D
Evening Hoppy.
Well, Why not just put a plug on it ? :)
I've just noticed the back to back series connected electrolytic capacitors, not being really well up on electronics how or what value will be seen? Would the circuit become series resonant at 50 HZ?
Perhaps another way of reducing domestic electro smog?? Marginally brightening that dimly lit space perhaps?
Cheers Grum.
Quote from: Grumage on August 07, 2018, 02:19:23 PM
Evening Hoppy.
Cheers Grum.
This series back-to-back connection allows the combination to work as an AC capacitor with a capacitance of 2200uF (C1 + C2) / 2 in this example. Not a very safe thing to do. However, the general idea is to create a series resonant circuit at 50Hz with the primary windings inductance, which in this example would be around 5mH.
Like the waveforms we have seen from Ruslan, it still all smells very fishy to me.
Good question about whether its an grid 'earthy neutral' or full earth connection. I'm assuming its the latter.
From Nicks new/old Stiffler thread today
https://overunity.com/17249/dr-ronald-stiffler-sec-technology/msg524651/#new (https://overunity.com/17249/dr-ronald-stiffler-sec-technology/msg524651/#new)
https://www.youtube.com/watch?v=66KTJGlbKmM (https://www.youtube.com/watch?v=66KTJGlbKmM)
Stiffler quote
Doing final check on the parts to be used in the loop distance test. There will be no single wire, test will be through the earth only.
Sounds like the original tester had part of his garden or field was alkaline and the other half acidic ;D ;D ;D
How about some tests on one wire pulsed Tesla coils and or BEMF as in relay coils ask Nelson
I'm sure he can help.
Hi Hoppy. Ruslan is saying the same thing I have already pointed out here a couple of times, i.e.,
if you disconnect the the output from the grenade where it connects to the relay, and instead connect
the hot phase wire from the mains to the same point on the relay, then you can run the device from the mains.
(This will only work if your utility breaker/fuse box on your house or apartment doesn't have a GFI on the circuit being used).
So, just because the circuit may work when connecting the hot phase wire from the mains to that point, it may work
exactly the same when connecting the output wire from the grenade to that same point on the relay, if the grenade is
producing enough power, so it doesn't necessarily at all mean that Ruslan was using a hidden phase wire.
Hello Grumage:
The circuit from Romancorp which Wesley posted is questionable to me because it connects at one end to the mains neutral wire.
You would really want to test with two separate earth ground connections which are completely independent from the mains.
Wouldn't the joke be on all of us if Ruslan is like Daniel Pomerleau, and therefore only
Ruslan can get these devices of his to work due to some special innate ability. :)
(Just kidding.... I don't really think that is the case for Ruslan. :) )
Quote from: Void on August 07, 2018, 07:41:41 PM
That's all the more fishy then IMO.
Thanks for confirming the Romancorp device connection to grid neutral.
Here is the reply to the Wesley's video by Ruslan 17 hours ago:
"Ruslan K
17 hours ago
Hello ! Now I'll write your comment. I did not cut any wires there. The man saw clearly how everything works. This essay about the wire - FEDERATION! Cut the wire from the relay that was on the coil. Any specialist understands that the system itself is 220 volts. Cut the wire from the coil, start the phase, then we have zero? And here is the result. The system starts because there is a phase. This is logical! Now I explain why he did it .... Panov decided to portray himself as a hero and lied to the whole world. he offered me 10,000 euros for this device. And I suggested a more interesting option, and not this junk. But Panov strongly demanded to sell to him this is not a stable and demo option. Now let's think, why should he? Everything simply and brilliantly surfaced. He buys it, says he does not work ... I go to him, he looks through what I'm doing and tells everyone the secret of the system, thinking it's all so simple. Yes ! Wesley, it's just everything, but for someone who understands what he does. Obviously not for the prat of Panov.
I clearly said that "carry and leave me" then take away. But he wanted to see to reveal all the secrets later. It's not about the money, but about the fact that I ditched 5 years of life for this study in this field. And I want like all normal people to make money on it. As well as you all !!! But Panov is a hero ... He told many why he started this fuss ... To distribute all my works without payment. They say that YOU are not all tormented .... Ay yayayay what Sergei well done, clever simple! But not here it was .... Adequate person immediately understand who is Panov and who is all ... who went after this bastard. Immediately surfaced a huge amount of tin and anger. Look what will happen if all these evil people give this ?! It will be a global catastrophe. We will destroy ourselves in a short time. This system really works and gives an unlimited amount of energy. But it can only be given to specialists."
Acca...
Quote from: forest on August 12, 2018, 04:30:14 AM
onepower
Very good man. I agree 100%. The only reason why this technology is not as popular as heat pumps is GREED of those who earn so much money from fossil fuels. Unfortunately the competition of solar panels, heat pumps, wind generators and so on would make it even worse. If we do not start this technology and merge into existing renewable market it will never help humanity to save this planet. Only such technology which is available 24/7 and cheap enough for poor people along with eliminating fossil fuels and capturing CO2 from atmosphere can save this world. :-( They had the opportunity in 2012 to change global situation but they do not care
http://www.shamanicengineering.org/wp-content/uploads/2014/07/Gerry-Vassilatos-Secrets-of-Cold-War-Technology.pdf
If your interested in experimenting your self Try reading from page 25 'Shock Waves' for at least the next 10 pages or so and ignoring
any negative input from any one on the tread.
AG ...after all these years ...
..........Homework assignments now?
how about translated versions for those who are not fluent ?
or Books on Tape for those of us who have sight issues
or maybe just an experiment which shows an anomaly would.................... be nice....
Homework now ??
maybe some suggestions ??
"turn to Page" XX? for tomorrows test ??
on another note RE: FE
enuff with all this fancy wireless universe stuff .... they should bring a power cord to plug us into the sun [
https://www.nasa.gov/content/goddard/parker-solar-probe (https://www.nasa.gov/content/goddard/parker-solar-probe)
editnow i see page suggestions above .....
Quote from: onepower on August 12, 2018, 01:49:30 AM
Hoppy
The patent shows a single ground connection to the bottom of the secondary which is induced by the primary. This is common practice in Tesla coils and known to increase the output power at the top load by anyone who has ever built a Tesla coil. Should we accuse them of stealing power from the grid?... well no that would be absurd.
In fact it does raise the potential for reasons even a child could understand. When a secondary coil is "not tied to ground" the number of free electrons which could move in the closed circuit is limited by the number of free electrons present in the circuit itself. However when a secondary coil "is tied to ground" it has a near unlimited number of free electrons which could move in the circuit because now it is tied to the planet Earth. It is a slight difference and very easy to overlook... in the first case the circuit is closed upon itself and in the second case it is attached to a fucking planet with a surface area of approximately 510 million square kilometers and a potential gradient rising by 100 volts per meter vertically.
It is strange is it not?, we are literally swimming in an incomprehensibly massive sea of energy, a universe seething with energy and the only thing on some peoples minds is their oblique obsession with burning fossil fuels to whirl some magnets past coils of wire and transmitting this energy along more wires.
No offense but your hypothesis that all these inventors are somehow stealing power from a man made grid of wires is so fucking absurd and offensive I don't even know where to begin. An infinite universe with no apparent end seething with energy on every level and the best you can possibly imagine with all neurons firing is that they must have been stealing power from a man made grid of wires?... you have zero credibility in my opinion.
I think if you look at Henry T Moray's first device it looks a lot like a crystal radio with two resonant coil circuits. He said in a interview that he noticed that there was no current coming from the ground, but current going into the ground through the load. So his starting circuit is a crystal radio setup to get some initial volts and then pumping that voltage up and into caps.
I do believe we live in a sea of energy. I think we just need to see the things that people take for granted and that are normally not considered important. Like if you have this Moray system and you pump the voltage up to what ever you want with joule thieves, voltage doublers or tesla coils and in thew circuit as the tesla secondary you have a ground&cap that is in resonance with L2. In my opinion that system in resonance has no resistance anymore and the cap charges instantly. Then you got charge inside a cap and making that flow is amps. Then discharge that cap through a spark to a new primary and step down to 12V and the rectify to DC.
There is no I or current in the capacitor charge equation, so in resonance there should be no impedance and the cap charges instantly or with miniscule current. so two "secrets" used in the device. Resonance and the "zero" impedance on the tank at resonance. If you load push&pulls at 50Hz per second and your cap charging circuit is doing 220kHz a second you got a lot of charge in the the cap bank to pull into amps.
Maybe I am wrong, but the energy is there and the answer is something simple like that. I hope I got some bench time at some point and I will test my theories out. I also post the results if I fail totally, so nobody has to waste that time all over again.
PS. If I charge a coil that is over an iron rod. Then I cut the power there will be a back-EMF spike. Can I divert that spike with diodes to a new coil that is over the same core in a way, that it aides the flux in the core? So get the flux from the initial charging of the first coil and then get a bonus flux from the BEMF spike? The BEMF coil would go around the core and into the ground. Does the negative spike even go to ground?
I am not an electrician so this negative spike has me confused. Should I think of it like pressure? First I apply positive pressure (voltage) to charge the coil and when I stop, the coil wants to keep the current going by using negative pressure like "sucking"? What we see is the voltage going negative (sucking effect) and the current still going in the same direction as before for a short time. So no matter if I use positive voltage or the BEMF it will still wants to ground, because it doesn't matter if positive pressure is pushing it to ground or if the coil is "sucking" the current through with negative voltage?
Belfior
QuoteThere is no I or current in the capacitor charge equation, so in resonance there should be no impedance and the cap charges instantly or with miniscule current. so two "secrets" used in the device. Resonance and the "zero" impedance on the tank at resonance. If you load push&pulls at 50Hz per second and your cap charging circuit is doing 220kHz a second you got a lot of charge in the the cap bank to pull into amps.
We should understand that the stuff that moves along a conductor is free electrons. The free electrons move about randomly until they feel an electro-motive-force which compels them to move along the conductor which we call an electric current. So to say a capacitor was charged with no current involved is to imply the capacitor was charged with electrons which never moved to charge the capacitor. Whenever an electron moves in any way this motion is considered an electric current, a current is motion.
QuoteI am not an electrician so this negative spike has me confused. Should I think of it like pressure? First I apply positive pressure (voltage) to charge the coil and when I stop, the coil wants to keep the current going by using negative pressure like "sucking"? What we see is the voltage going negative (sucking effect) and the current still going in the same direction as before for a short time. So no matter if I use positive voltage or the BEMF it will still wants to ground, because it doesn't matter if positive pressure is pushing it to ground or if the coil is "sucking" the current through with negative voltage?
I would suggest you read this until something makes sense...http://amasci.com/miscon/whatis.html
Hell read the whole damn website because until we have mastered the basics of what electricity is and how it works were basically wasting our time. Unfortunately the FE forums are full of misleading and confusing information peddled by many people who have no fucking idea what there talking about.
If you want to move forward master the basics... what is actually happening in reality?... why is it happening?... how do I change what normally happens and make it do something different?. Do you know why I visit the forums?, 99% of it is complete and utter BS however every now and then I read something which makes me think. It makes me question my own perception of how I think things work in reality. You know they say a man who changes his mind is somehow fickle or undecided yet I change my mind one hundred times a day. How can one presume to make progress if they have learned nothing new which has changed their mind?... Learning is change and change is progress. How can we say something has changed but nothing has changed not unlike thinking a capacitor can charge without electrons moving as an electron current to charge it?.
Rule #1... if we have not learned something new which has changed our mind, our perception of things as we thought we knew it then nothing has changed. It doesn't get more fucking obvious than that does it?.
Quote from: onepower on August 12, 2018, 03:08:27 PM
Belfior
Thx for the site. I will read it.
Is it free electrons? Are there electrons? Do they move or are they in one spot as mass and their spin or other properties change, so that we interpret that as current or moving electrons? Is the energy actually outside the wire?
So are you actually telling it like it is, or are you telling me something that "was agreed on", which is a different thing?
Energy stored in a cap is CV^2/2. This tells me that current is no factor in that equation. So if the cap needs current to charge it means it has internal resistance. If current is needed it would be a factor in the equation. So obviously we don't have ideal capacitors, but what if you neutralize that resistance by using a resonant LC tank? How much charge can you get with just a HV source into that cap when in resonance? That charge will equal amps when you pull it out on the load side. If you get more charge into that cap than the load pulls then you can self loop.
I have seen lecturers take part capacitors. Grounding and connecting the plates together and rebuilding the cap. Once again the cap sparks when the plates are connected. So the charge was in the dielectric and not in the plates. So the "free electrons" were moved by current from +-plates to the glass dielectric?
From amasci site:
"What is electricity? This question is impossible to answer because the word "Electricity" has several contradictory meanings. These different meanings are incompatible, and the contradictions confuse everyone. If you don't understand electricity, you're not alone. Even teachers, engineers, and scientists have a hard time grasping the concept.
Obviously "electricity" cannot be several different things at the same time. Unfortunately we've defined the word Electricity in a crazy way. Because the word lacks one distinct meaning, we can never pin down the nature of electricity. In the end we're forced to declare that there's no such stuff as "electricity" at all! Here's a quick example to illustrate the problem."
So the problem with electricity seems to be that nobody understands it?
That is why I read the forums and read mostly the stuff that the crazy people write. Because we have been asking the wrong questions for about a hundred years now. Any breakthrough will come from the fringe areas if there is anything there to find. That unfortunately means that you go through a lot of bullshit, but every now and then you find a guy that has new ideas. Then you try to replicate and reproduce the effects.
F.Y.I.
O.T. ? Fun - Food for Thought - or a little of both ;)
https://www.youtube.com/watch?v=IXeXcbvBPJw (https://www.youtube.com/watch?v=IXeXcbvBPJw)
https://www.youtube.com/watch?v=J9b0J29OzAU (https://www.youtube.com/watch?v=J9b0J29OzAU)
https://www.youtube.com/watch?v=Y1MDOerruD (https://www.youtube.com/watch?v=Y1MDOerruDU)
[Ver 2. outside of coil - battery/magnets => rotate]
https://www.youtube.com/watch?v=yL0TRmprhEM (https://www.youtube.com/watch?v=yL0TRmprhEM)
Theory of operation - analysis!
FIN
At least those work when you build them. ;D
Hi Belfior. To say it as nicely as it can be said, the problem is you have no idea what you are talking about. :)
I would suggest doing actual experiments first so you can learn how things actually work in reality, then if
you eventually find something interesting in actual bench tests, you can then post about it here if you like. :)
Patented, ? 9564268
Garry
and 20150102676
Garry
Quote from: iflewmyown on August 13, 2018, 11:06:05 PM
Patented, ? 9564268
Garry
Hi iflewmyown. Yes, it appears they were granted a patent, but, very strange, as it
appears they have patented a Tesla coil with only minor variations from from what Tesla
has done and already patented. How does a patent examiner go about approving a patent
on what is basically just a tesla coil? It looks interesting however in regards to their claims,
so I will read through it more when I get a chance.
Quote from: Void on August 14, 2018, 09:00:30 AM
US20150102676 Patent.
https://patentimages.storage.googleapis.com/c2/73/cd/ed546d4872c866/US20150102676A1.pdf
related ?
https://groups.google.com/forum/#!topic/alt.engineering.electrical/iGvb86LXMFA
Garry
https://www.youtube.com/watch?v=70_xKJh91eE
Quote from: Hoppy on August 15, 2018, 11:17:36 AM
https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/ (https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/)
Wesley dear chap, your absence is deafening. ;) What's the latest on the Ruslan / Sergej saga?
Err Hoppy that circuit as it is wont work stuff is missing, enough stuff has been on here
to tell you you can't attract static with AC you would do better with an old TV eht coil or a perspex box full
of expanded polystyrene and a fan blowing it around, but don't dispose of it down the toilet you will never get rid of it !
:) ;) :D ;D ;D ;D ;D
There has been some discussion in this thread about using the electricity stored between the ionosphere and the ground. We are standing on one plate of a large capacitor, with our heads in the dielectric looking up at the other cap. plate.
I would like to tell a story which may relate to this. A couple years ago I built a Van de Graff generator in my shop. It stood about 5 ft. tall with an 18 in. ss ball on the top with teflon top roller. It was not a great performer giving 6 in. sparks to the knuckle or the 6 in. dia. ground ball. The shop it was in was I think important. The shop had concrete floor with 6 x 6 wire mesh embedded for reinforcement. The frame was mild steel down into the ground The outside walls were corrugated painted steel siding as was the roof. Inside was first a layer of 4 in. foam insulation over which were the internal walls of corrugated steel and ceiling of the same. The original purpose was to have the shop well insulated, airtight and the inside was bright white paint on the steel. My friend came over and was observing through the doorway and we decided to experiment with the machine to make longer sparks. The first thing we noticed was it would light most of the fluorescent bulbs on the ceiling when the power to them was shut off. Then when the ground ball on it's cable was moved close it would jump away from the top ball when the spark happened with a small amount of force. I could feel myself being charged any time I was in the room with it running but usually would discharge myself on the top ball. Then I decided to see how far the spark could be made to jump if I stayed away and let the charge build. I switched it on and stood upright with my right arm and first knuckle extended about four feet from the top ball. My friend was in the doorway opposite of me with the machine between us. I could feel the charge build as usual so I just stood their waiting. All of a sudden a spark jumped from my hand to the top ball about four feet away. It felt like I had been kicked by a mule in the center of my chest and my arm was pushed back into my shoulder joint with a painful jolt. I caught my breath and used the foot switch to stop the generator. My chest and arm hurt for three days, the first day like a crush injury. My friend who had been around electrical experiments for years asked me how my ears were. The rest of me hurt so bad I hadn't noticed my ears ringing. He said the spark sounded like I had fired a shot gun in the shop. I never heard it cause I hurt so bad.
Anyway, you can gather energy when you are standing inside of a capacitor, but be careful.
Wesley, if you think any of my posts here are off topic let me know or just delete them.
Garry
Hoppy..
Quote https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/ (https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/)
end quote
Aliengrey
quote
https://www.youtube.com/watch?v=70_xKJh91e E (https://www.youtube.com/watch?v=70_xKJh91eE)Err Hoppy that circuit as it is wont work stuff is missing
end quote
Just a note..I did speak with Luc about this fellow..he reminded me he worked hand in hand with him...and there was measurement error...
AG..perhaps you could tell what Bits were missing ??
Quote from: ramset on August 15, 2018, 05:19:36 PM
Hoppy..
end quote
Aliengrey
quote
end quote
Oops not that one the other one Hoppy was talking about the one we are waiting for the third video form Wesley !
I spider wired the HexFET to a Tesla coil the gate goes no where so whats the point of the HexFET driver or the divider
circuit ? more questions than answers on that device.
This video could hold some valuable information if the iron wire part works.
quote https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/]https://overunity.com/17328/overunity-device-by-tanju-argun-moderated/[/url]
end quote
Is this property suitable for experiments?
1. buried 6000 pound copper steel evaporative cooler 120 ft. from 2.
2. 36 ft. long 16" dia. pipe buried vertical 9 ft. in ground
3. 180 ft. 4 #2 conductors buried in conduit
4. 8 ft. copper coated ground rod
5. steel framed, concrete floor, steel sided and roofed shop building
Garry
Wesley may not like it, but I am just going to make a few points that have already been pointed
out, but still seem to be ignored by some people. :)
From what I have seen, Kapanadze has always used just one earth ground connection (at a time).
Kapanadze has stated his device can work with no earth ground connection by replacing the earth
ground connection with a 'special circuit'.
Akula has demonstrated one of his early devices could self sustain itself and power one or two light
bulbs at the same time, with no earth ground connection at all.
Indications are that the principle behind their devices is not dependent on a potential difference
between two separate earth ground points at a distance from each other.
I agree that Kapanadze did not at all likely 'invent' his devices, as he wasn't trained in science and electronics.
It is much more likely that he got this information from somewhere else. Possibly it came from old Soviet era military
research, and somehow Kapanadze got his hands on some of this info. Just a guess, but still a lot more likely than
the premise of Kapanadze coming up with his devices on his own. :) Kapanadze also claimed (in the green box video demo
I beleive) that he once 'invented' a car or motor that could run only on water. Where does an architect come
up with this stuff? ;)
Wesley, the two earth ground connections devices may hold some promise, but do not appear to
be directly related to what Kapanadze, Daly, Akula, and Ruslan have done. Until someone can actually
demonstrate something out of the ordinary with these two earth ground connection setups, it is just another idea.
However, Frank Prentice did use at least two separate earth ground connections in his 1923 patent, so there may be
some real potential there with that approach (no pun intended :) )
Just my opinion.
Does the yellow house not have any connection to the mains. It has no electrical power?
All the best...
P.S. Barbosa and Leal's 'captor loop' devices appear to have just drawn their power from the mains,
and had a tendency to fool power meters because the current was not returned back to the mains
via the neutral wire, but by an earth ground connection. Because of this their claims are very questionable,
(to anyone with at least a basic understanding of electrical systems anyway), and Barbosa and Leal have
stated they stopped all work on those devices back around Oct 2013 due to 'technical problems' .
I strongly suspect the 'technical problems' they were referring to is they finally realized the power was coming from
the mains. :) The Barbosa and Leal 'captor loop' devices were not at all credible devices IMO.
Quote from: stivep on August 17, 2018, 08:19:31 AM
is it that difficult to understand guys?
for current to flow there must be closed loop.
even one wire transmission using Avramienko fork is A CLOSED LOOP.
Hi Wesley. It seems to be a common misconception that there must be a closed loop for current to flow.
When you look at AC circuits, things are not so clear cut at all.
Eddy currents in an iron core are one example of currents that can flow which do not return back to the
source in a closed loop.
At radio frequencies, an RF signal will very happily flow on a single wire without there being much return to the
source via capacitance between the wire and ground. In fact the RF signal generator could be run by batteries and
completely isolated from earth ground, and there will still be an rf current seen on a single wire connected to a single
ended output of the generator. BTW, that in no way implies there must be free energy there however. The power is still coming
from the generator (under 'normal' circumstances anyway).
All the best...
The Question
So tell me what is the other choice for current to flow in open circuit.?
And since you do not have an answer
than two grounds / virtual grounds/ or any other form of explanation of how the circuit is closed
will be valid till proven otherwise, some time in the far future I assume.
Wesley
Ground to ground is one solution that might well work as a closed loop some are not disputing (well i'm not)
and might well try it some time.
But is saying that there is also ground to ether (upper atmosphere static charge) our Lithuanian friends have
been exploiting by lowing the upper level with ones own artificial device.
Whats not clear is how to do it, most circuits that have appeared on here are AC attract / repel,I would have thought
by observation that DC would attract a better result !
Also Tesla talked about a killer EMF when switching a knife breaker 'ON' and 'OFF', Guys should think about the very aspect
find it and read it.
I don't want to appear secretive but guys need to learn the other side of what is deliberately ignored buy minions to
the dark side of controlled ignorance. We are the consciousness of the universe use it and learn, don't wast it.
Quote from: Void on August 17, 2018, 08:35:02 AM
All the best...
Eddy Current only flows in close loop
Magnetic circuit is a closed path in which magnetic flux
flows;
https://en.wikipedia.org/wiki/Magnetic_flux (https://en.wikipedia.org/wiki/Magnetic_flux)
https://en.wikipedia.org/wiki/Eddy_current
RF signal ( electromagnetic wave) is carried by photon and has no current./ no mass./ it contains energy. "RF" -( photon) has momentum and, RF is omnidirectional.
However RF has pattern based on Tx antenna characteristic. RF is seen as "
more than one photon" and it is
continuous in given time frame.Photon loses its energy when colliding with matter. https://en.wikipedia.org/wiki/Photon (https://en.wikipedia.org/wiki/Photon)
The reminding energy of RF is detected and amplified by closed loop circuit including detector and resonance circuit mostly grounded (visibly)
Wesley
Quote from: stivep on August 17, 2018, 09:13:31 AM
Magnetic circuit is a closed path in which magnetic flux flows;
RF signal ( electromagnetic wave) is carried by photon and has no current./ no mass./ it contains energy. "RF" -( photon) has momentum and is omnidirectional. However it has pattern based on Tx antenna characteristic.
Wesley
Eddy currents do not have a *closed current path back to the source*, was my point there. :)
I am not talking about EM waves, I am talking about RF current on a single wire.
RF current will flow on a single wire that is an open circuit on the far end of the wire,
even though the capacitance from the wire to the generator ground can be very tiny.
Significant RF current can be induced on the single wire with little to no current return back to the generator's ground,
i.e., no significant closed current loop back to the generator 'ground'. This still draws power from the generator however.
P.S. I realize that Eddy currents are considered to be losses because they couple back to the
generator as a degree of 'load' via the magnetic field. Likewise, RF current generated on a single wire
does 'normally' draw its power from the generator, but the capacitance between the generator and the wire
can be very small, so how it couples back to the generator and causes power consumption may be more through
reflected current. The reflected current is then dissipated in the power output stage of the generator. I am not
entirely sure that is the complete picture, but that may well be what essentially is happening there. AC circuits have
a lot more parameters to consider than basic closed loop DC circuits, is my point. It can sometimes not be so straight forward
at all to fully analyze AC circuits. :) My general point is that when people think about 'closed looped circuits', they
should not confuse DC circuits and AC circuits. Too often here people seem to confuse the two.
Quote from: ramset on August 17, 2018, 10:25:37 AM
also a question on your mentioned remote location..
Do they use the Single wire Grid system there ,which is typical to some remote areas?.
Good question. I also asked Wesley whether the yellow house is connected to the power grid, or
whether it has no utility power at all, but so far Weslely did not answer.
Quote from: ramset on August 17, 2018, 11:18:36 AM
Wesley is an "Earth" scientist ,and I do not take his claims in his field with a grain of salt..
I am personally quite excited about his experiments here and there association with a "possible" TK MO
Sure whatever works for you. :)
As I have already said, I have no problems at all with anyone doing any experimentation they want, so
I don't understand some of your comments.
Just FYI, someone having a background in physics or other sciences in no way at all necessarily means they
have good practical skills and knowledge with electrical and electronics circuits and measurements.
That is a whole different ball game. Make of that what you will. ;)
Tariel included somethig tips in some video's. Search what he said what happen when you disconnect load from his devied
For Mr AlienGrey .... ;)
https://youtu.be/JcPu4Ie47vA
I just watched the video again, I'd like to say that the voltmeter reading was incorrect. It was after finishing the video that I discovered my DMM had effectively died.
For Wesley....
https://youtu.be/MXPtdzhSdfw
This " curiosity " was interpreted as a capacitive form of resonance....
Cheers Graham.
Quote from: Grumage on August 17, 2018, 11:56:24 AM
Cheers Graham.
Hi Grumage. Very very nice!
An actual reasonably clear demonstration. I bow to you. ;D
Yes, there could be different factors which cause that sort of effect.
Standing waves (cancellations and additions along the wire) on one or both of the wires going to the two grounds can
increase or decrease measured peak voltage. This is very dependent on the frequency being used and length of the wires and
the specific point on the wires where you are measuring, as with AC you will get standing waves on the wires. An increase in voltage
peaks in no way implies an increase in available power beyond what is being injected into the 'input' wire of course,
but it doesn't rule it out either.
Driving the input to one ground wire with a pulse waveform instead may give even more interesting results on the second 'return' ground wire. ;)
Nice job!
For Wesley....
Cheers Graham.
Grum Hi am I to understand you powered the pasture of field in the display with 250v mains ? and got a light bulb to light?
I don't suppose you tried just to read the voltage in the ground it self ?
If your interested I did see a BBC short film some time ago on BBC4 where the guy had an area where there were 2 lakes
one was from the sea and the other volcanic fresh water but acidic and both undrinkable he could light a car headlight bulb
with a bit of wire and a couple of cans between them. I didn't say it was impossible.
Also cable conductors are you aware it takes a rise time to pass current through and down a wire Tesla talked about this
but people ignore this little fact.
Hi Guys, I'll do a two in one.
Mr Void.
Thanks, I've laid a foundation, the door is open for others to try pulses etc....
Mr AlienGrey.
No I didn't use my domestic supply as we're on a PME overhead distribution system. I used my 220 volt pure sine EPS which was totally isolated and also used two 3 foot Copper rods, equally isolated from my incoming supply.
Perhaps this video will answer your other question? ;)
https://youtu.be/mRz3oTLicT4
Or how about this one?
https://youtu.be/x__NQOtrzf0
Cheers Graham.
Quote from: Void on August 17, 2018, 09:39:01 AM
https://en.wikipedia.org/wiki/Eddy_current (https://en.wikipedia.org/wiki/Eddy_current)
Picture from below :
https://youtu.be/qdJ1V_yDv-c?t=505
Wesley
Quote from: Hoppy on August 17, 2018, 01:43:37 PM
Wesley, what striking results did you get out there?
- 21V between the grounds
- Grounds response depends from orientation ( the lowest 11.7V)
- Amplification based on returning HV pulse back to one of the grounds.
upon sending 5000V impulse.
Wesley
in article http://www.erlphase.com/downloads/application_notes/Understanding_Sub_Harmonics.pdf (http://www.erlphase.com/downloads/application_notes/Understanding_Sub_Harmonics.pdf)
it is mentioned
QuoteCase 2: System Response to Sub-Harmonics with Three Phase to Ground Fault.
he highest of the is found at 12Hz
there is no circuit if there is no load.
there is no circuit if the load belongs to not your loop
there is no active circuit if your loop in test is not connected to the phase
in my case there is no inductive load in circuit with phase.,and that condition is expected for
sub-harmonic frequencies origination ( in my case)
in my case there is no three phase
In London You can have CT1 powering 1 building only and next to it another CT2 powering another building
Both loops will never see each other right?
Wesley
Quote from: stivep on August 18, 2018, 06:25:51 AM
in article
it is mentioned
there is no circuit if your loop in test is not connected to the phase
Wesley
Wesley,
Is it an SWER system? If it is then there is a power and voltage drop in each section.
Quote from: stivep on August 17, 2018, 01:25:17 PM
Wesley
Hi Wesley. You are still misunderstanding me, although I have already clarified the matter.
I was just pointing out that those currents do not form a closed current loop with the power source.
I don't think reasonably there is any way that what I am saying can be misunderstood.
Likewise the secondary winding on a transformer will have a current flowing on it between the secondary
winding's ends if connected together, but they do not form any sort of closed current loop back to the primary.
The secondary winding interacts with the primary via a magnetic field. This is all I am saying, and I think it should be
reasonably clear enough even to people who may have little understanding of electrical systems and electronics.
Quote from: Hoppy on August 18, 2018, 06:56:55 AM
Wesley,
No I assume it is not.
http://scholarsmine.mst.edu/cgi/viewcontent.cgi?article=6061&context=masters_theses
Maybe you can accept fact that most of measurement was made prior to re connection/ however
that should not matter if you read
Loop explanation from above
Wesley
Quote from: stivep on August 18, 2018, 07:27:15 AM
"magnetic field" is perfectly valid as a description of either - both the magnetic flux density and the magnetic field density are examples of a magnetic field.
And just using "magnetic field" is a lot simpler
However what you referring to :
density or field,
-and how Eddy current relates to your statement?
a changing magnetic field induces an electromagnetic force in a conductor.
but you have been referring to Eddy Currents, did not?
Correct me please
Wesley
Hi Wesley. Yes, and I have explained my point in detail already. :)
As I have said, I think what I have already stated was more than clear enough. :)
No worries at all if you still don't understand. :)
A suggestion for anyone who is going to do these types of experiments, if you don't at least have a
basic understanding about standing waves, I would suggest you read up on standing waves, and nodes and anti-nodes,
and have at least a basic understanding of these concepts as they apply to wires/transmission lines.
Resonance is a special case of standing waves where the developed standing wave nodes and anti-nodes
will correspond closely with the ends of a wire or coil, or at fractional intervals along the wire or coil such as
at 1/4 wave or 1/2 wave intervals.
Something to consider:
Frank Prentice stated he operated at a frequency of around 500 kHz, and said his long wire between his two earth ground
points was about 0.5 miles long (0.8 km). The wavelength of 500 kHz is 600 meters (0.6 km) or about 0.4 miles. So Frank
Prentice had a distance of more than a full wavelength between his two earth ground connections. Prentice claimed to have
measured a COP of about 6 when powering a bank of light bulbs at the output of his receiving loop antenna. He used a sparkgap
at the far end of his long wire, and also used tuning capacitors to tune the long wire for exact resonance at the frequency of operation.
The wavelength for 14 Hz (if I didn't make an error) is about 13,297 miles or 21,400 km. :)
The diameter of the earth at the equator is apparently about 12,500 km.
So, you have a problem. However in patent # US9564268, they claim (emphasis on the word claim) that coils tuned for resonance
at very low frequencies such as below 200 Hz, with a single earth ground connection point, can still take advantage of low frequency earth resonances.
That may possibly be a way to get around this very large wavelength problem. A possible step in the right direction. :)
How could this work? From what I recall of antenna theory, which is not extensive, a quarter wave resonating wire or coil has quarter wave resonance in the wire or coil,
and when connected to the earth through a ground connection, also creates a matching quarter wave resonant 'image' in the ground.
Essentially what this means from my understanding is we end up with the equivalent of a half wave resonant system, which is resonating both in the coil *and in the ground*
at the resonant frequency you are tuned to. You are forcing currents in the ground at your resonant operating frequency.
Tesla coils typically are operated at 1/4 wave resonance. Are you seeing the 'potential' and possible benefits now of Tesla's approach?
I believe Tesla was doing pretty much the exact same sort of thing with his magnifying transmitter experiments.
This is not at all to take away from any experiments with two earth grounds that anyone may want to try, I am just pointing out
some potential hurdles and how the tesla coil (really any quarter wave resonant coil) may get around these hurdles. Also, keep in mind that
Kapanadze said his system is based on Tesla's work, although whether it really is or not is anyone's guess.
Kapanadze's devices could possibly be based on a different principle.
Wesley, Patent US20150102676A1 appears to still be in application review status.
These 'Earth Energies Inc' folks seem to be trying to get patents on Tesla's inventions which
Tesla already patented over a hundred years ago by making a few minor changes here and there
to what Tesla showed in his patents. They already succeeded in getting a patent granted for US9564268.
Now that to me is just not playing fair at all. :)
So many people are trying to make big bucks in this area by trying to lock things down with patents, which
in many cases seems to relate back to or just builds on things that have already been discovered and experimented
with by others in the past. Meanwhile the Earth is on a fast track towards disaster due to climate change.
If I find a way to make a working free energy device, I will try to find a good way to release it openly to the public,
with no patent applications at all. This would mean getting professors from universities or reputable science labs to certify
it as working as claimed first. First I have to build a working FE device however. :)
Solarlab
QuoteIf you were a good student or you just wanted to please your teacher, you probably heard this and said to
yourself, "OK, energy is the ability to do work." If you were a really good student with a desire to learn or a
really bad student with a desire to point out your teacher's intellectual shortcomings, you should have then
asked the next logical question. What is work?
If Energy is the ability to do work
and Work is a Force acting over a Distance which is in fact motion
Then all Energy is motion
As Albert Einstein said, "nothing happens until something moves"... however he forgot to mention that everything everywhere is already in motion.
Now we have a dilemma because as we all know everything in the universe is already in perpetual motion on every level thus everything present everywhere is Energy. This is why we speak of the Conservation of Energy whereby Energy is neither created or destroyed only transformed. We have never created or produced Energy, what we have done is transform one kind of motion already present into a force acting over a distance acting on something which produced another form of motion.
The correct perspective is to understand that everything everywhere is already in incredible motion on every level. What we do is transform this motion producing a field of force which causes something else to move over a distance causing another form of motion. When I burn wood I excite the atoms and cause some molecules (hydrocarbons and O2) to become different molecules (CO2 and H2O). The Energy as the internal motion of the atoms in the material which is transformed then appears to excite atoms in the surrounding area as light and heat which are simply another form of Energy or motion. Nothing is created, nothing is destroyed, the motion is conserved and only the form of the motion has changed.
The correct perspective is to understand we are swimming in a sea of energy as motion everywhere in everything and there is no need to create or destroy anything. We only need to understand how to efficiently transform the Energy already present into the form we want. Strange isn't it... all we have to do is co-ordinate some of the motion already present within in a single piece of wire to produce a unidirectional force on some electrons and we can produce a usable electric current. It's so simple even a child could understand it and yet here we are. Barbarians swimming in a sea of energy still preoccupied with the adolescent notion that we need to burn everything. Rip it up, chop it down, bore your holes and suck it out then incinerate it... it's so fucking absurd it boggles the mind.
http://www.scopetnm.com/test-and-measurements/earth-tester/earth-resistance-meter/mdt20kwe
Quote from: Hoppy on August 18, 2018, 01:55:19 PM
http://www.scopetnm.com/test-and-measurements/earth-tester/earth-resistance-meter/mdt20kwe (http://www.scopetnm.com/test-and-measurements/earth-tester/earth-resistance-meter/mdt20kwe)
Thank You
Wesley
I have already commented with my ideas on why the tesla coil approach might potentially be used to exploit Earth resonances.
Here are some of my thoughts on the RomanCorp approach which Wesley seems to be experimenting with.
This also appears to me to be a potentially viable approach to try to exploit Earth
resonant frequencies due to the series resonance approach which is used. This approach may
possibly be a fair bit simpler than playing around with Tesla coils.
Although Wesley hasn't provided a lot of specific details so far about how he is doing measurements, but
if I understood his appraoch so far, Wesley seems to me to be on the right track of applying a high voltage
pulse to one ground rod and monitoring for any response results on the other ground rod. Such an approach
should help to find any resonant responses from your ground rod system. If you can't use a high voltage pulse
or HV pulse waveform to 'excite' one ground rod, then you can try just using a signal generator set to
a pulse waveform output, and sweep from very low frequency very slowly to higher frequencies as you
monitor for any resonant responses on the other ground rod. Take note of any resonant frequencies found.
Also take note that you may have to try moving one of your ground rods around to different locations
to look for a location that seems to give the best results, so you may well want to use a short ground spike
of some type which can easily be pulled out from the ground again as you test with different ground locations.
When you are testing for any resonant responses as described above, my recommendation would be to
use as short wire lengths as possible connected to each ground rod during this testing to help minimize
skewed results due to any resonant responses/standing waves on the connecting wires them self.
See the attached circuit drawing.
My drawing takes this circuit arrangement down to what I believe is its most basic form.
Notice that secondary winding L2 and C1 are in series. You may be wondering why not place C1
in parallel across L2 instead? The answer is that if C1 were in parallel to L2 instead of in
series to L2, at the resonant frequency of L2 and C1 there should be a high current bouncing
back and forth between L2 and C2, but there is not much current pumping action applied
to the ground 1 and ground 2 points. When L2 and C1 are arranged in series between ground 1 and
ground 2, you will now (potentially at least) have a current pumping action between ground 1 and ground 2
when operating at the resonant frequency of L2 and C1.
Let's say in the intial pulsing testing stage described above that, like Wesley, you appear to see a resonant
response at 7 Hz and/or 14 Hz or whatever frequencies. These would then be good choices to try as the
resonant frequency of the L2 and C1 combination. If your local mains power operates at 50 Hz or 60 Hz,
then that would probably be a good frequency to avoid. Let's say you are going to try with 14 Hz specifically.
You could then try using an off the shelf iron core transformer of a type shown in my drawing (two separate secondaries
with a reasonably high current rating). This might not be ideal, but should be an easy way to conduct initial testing without having to
fiddle around too much. Iron core transformers should probably work well enough at 14 Hz and 7 Hz,
I would guess. Also keep in mind that you will need to use low ESR capacitor(s) for C1.
Well, that's my ideas on a simple way of how to go about testing with this sort of arrangement
for anyone who still may have been unsure about how to go about testing with this arangement.
Wesley may have other ideas than what I describe here. These are my own initial ideas. :)
Test with any circuit arrangements at your own risk. Make sure you understand how to work
safely with such equipment and circuit arrangements.
Quote from: Void on August 18, 2018, 07:12:43 PM
hi void,
I'm surprised to see members and key person is going back to the basics.But i have no issue about it.
The answer you are looking for is already posted in my recent attachment RUS to Eng translation of Akula Telsa coil tuning pdf file.
What you guys are doing is already in line with Akula without realizing it yet.Akula did mention about you look for maximum
"current" movement/returns into/from Earth.So base from your circuit diagram referring to "output to load" will be seen as higher voltage because there is
higher current returns from Earth in order to power the transformer to load.
So long story short Akula did mention about getting best returns base on kapanadze device after finding out
1.7..1.8Mhz did provide
current returns after injecting various frequency to ground.
I have attached a simple Harmonics and Sub-Harmonics calculator from 7.83Hz or from 1.7Mhz.Once more for the third time.To make life simple
My only disadvantage as mentioned in the past is
less than ideal working space and height(Far from ground) and stainless steel(316) water pipe providing one of the world cleanest water supply which you can drink directly from tap."Above WHO standards".
Key tips before commencing any project do execute all possible scenario in your head first while sleeping then on assembly day you will find it easy to execute all possible combination like a game of chess. :)
Hi magpwr. Thanks for the comments.
Ok on your testing situation. Yes maybe not the greatest for grounded systems with HV.
I am actually not working on a Akula related device right now myself, or on Wesley's latest approach either.
I commented on the other circuit because so far Wesley did not say too much about his own
intended testing approach. I just gave some of my ideas of how to do some initial testing with it.
People would have to experiment to see if it might have any potential if anyone is interested, and they may
have to experiment with their own variations as well.
I am working on something that is my own idea these days. I don't have a lot of time these days
for testing, so it is moving along slowly. If I find anything noteworthy, I may make a simple demo video.
I don't really like making videos so much however, but we'll see. :)
All the best...
This is not a complete solution. The coils and capacitor will create their own resonances. These resonances have nothing to do with the Earth.
If you want to explore - you need to create resonance processes with the help of a short pulse. Observe the resonance response is necessary on a non-inductive load.
Use fewer transformers and coils. The explosive mixture of a coil with a capacitance will not allow us to understand where the resonance is from the coils and where from the Earth itself.
The task is very difficult.
According to one member of the Matrix Forum, he had contacts with scientists in the past who were probing the Earth with short pulses. It seems nothing interesting for our topic.
Although, they had other purposes.
In addition, you can read something more professional.
For example, about an UWB underground radar. (UWB - Ultra Wide Band. Similar to "short pulses")
Another interesting direction is the collection of the accumulated charge in the air from the near-surface ionization of the Earth.
It looks like a process in lightning. Only microscopic lightning will come out of the earth - from the grass, bushes, trees. For example, within a radius of 1 kilometer. (In terms of environmental friendliness and safety, there are many open questions.)
But for this it is necessary to create by means of a pulse a large potential difference at a distance between earthing connections.
It is necessary to hard discharge the capacitor charged to 30 - 50 kilovolts by the load having a resistance of several Ohms.
Air gaps are not exactly suitable, as they have more resistance.
It may be necessary to use high-voltage thyristors or powerful thyratrons for several thousand amperes per pulse.
Quote from: Hoppy on August 19, 2018, 03:28:34 AM
Hi Magpwr,
At my age, there is a danger of sleeping on the assembly line! ;D
Ha ha so was Tesla still alive when you were born ?
Quote from: Hoppy on August 19, 2018, 08:31:11 AM
That sounds about right to me. No good just tickling the ground.
What would that do since I*V=Watts.!
Electricity is like a train current takes time to getting going but passenger's just jump on
At random !
Quote from: Sergh on August 19, 2018, 04:06:18 AM
Hi Sergh. Nowhere did I suggest that anything is a complete solution however. :)
It is of course implied that the tesla coil would have to be operating on a frequency
that appears to provide a beneficial 'resonant response' from the earth ground connection, if you are trying
to exploit natural resonances or resonant responses in the ground. :)
A person would have to do some experimenting to look for any specific frequencies that appear to give a
'resonant response' from the ground. In my previous comment above, I gave some comments on how
a person might go about testing for that using two independent ground rods with short as possible
connecting wires to each ground rod. Chances are you will get better results if you can pulse the
'input' ground rod with higher voltage pulses, but, you never know, people may be able to get some
interesting results just using a pulse waveform from a signal generator.
All the best...
The voltage is all ready there the current has tof build up!
So how long would that take ?
Hi All :)
https://www.youtube.com/watch?v=VBrx4O10XkI
Cheers~
Are we talking about a Tesla coil in radiant energy mode, as Tesla exployted!
Tinselect talked about BEMF at switch off. But what about swich on ?
Oh dosent it exist?
Quote from: AlienGrey on August 20, 2018, 03:22:09 AM
Oh dosent it exist?
Hmm interesting... is there a bemf acting against the charging coil? There should be in my mind at least. There is some inertia to beat. I would like to see some bemf circuitry schematics
Quote from: TinselKoala on August 19, 2018, 07:51:25 PM
Well, perhaps there's a bit of translation loss here.
Anyone may do anything, that's true, but in order to draw conclusions, a real True Experiment should be performed.This involves a lot of brainwork before one starts twiddling dials and discharging caps and raising up earthworms.
So you need a testable hypothesis. Then you need to design experiments that actually test that hypothesis. Then you need to design control experiments so that you know what variables are actually influencing your results. Then you need to plan on doing your experiments enough times for statistically valid data to be gathered. Then you need to know how to analyze the data.
Often times in real academic research, the paper is written before any experimentation is actually performed, with the Data section using imaginary data and the Results/Conclusions written from both success and failure viewpoints. Then when the experiment is actually performed you just plug in the real data and massage the Conclusions part to match.
And one need not invoke the holy name of Tesla in vain. Just use the Scientific Method and you'll be fine.
Absolutely correct. This is the only way. Not just experimenting but also creating extraordinary eviden e. Not just measuring 20MHz RF with a DMM and claiming OU. First u need to claim the tests & results that would spoil your theory and then conduct them. Not just present "proof" that it works. People like their idea so much sometimes the proof is just measurement errors...
Quote from: Belfior on August 20, 2018, 05:29:50 AM
In Tesla interview on Google he talks about it but it's igored, Donald talks about a massive pulse
Of ENERGY!
Hi,
Can anyone point me any link where i can purchase RG-56/U cable online which is sold by the foot in order to create a stiff Antenna which is also 8000Volts rated.
Thanks.
In return i am able to show something that no one in this forum have seen before anywhere relating to frequency up-scaling after cable is converted to a Antenna and coil for tesla coil.
https://patents.google.com/patent/US690151A/en?oq=us20150102676 (https://patents.google.com/patent/US690151A/en?oq=us20150102676)
QuoteI have discovered that the south to north direction of the earth-current is maintained only when the plates: are of the same metal.
for these who are interested :
US20080191580A1 https://patents.google.com/patent/US20080191580A1/en (https://patents.google.com/patent/US20080191580A1/en)
Example of active above the ground positive counterbalance to earth ground utilizing telluric current
Wesley
Quote from: magpwr on August 20, 2018, 10:12:43 AM
Hi magpwr. I don't know, but this company might be able to help you:
https://www.awcwire.com/part.aspx?partname=rg56
Hi,
Thanks.
You need HV cable.
https://www.awcwire.com/producttoc.aspx?id=high-voltage-coax (https://www.awcwire.com/producttoc.aspx?id=high-voltage-coax)
http://www.repeater-builder.com/antenna/wa2ise-coaxial-cable.html (http://www.repeater-builder.com/antenna/wa2ise-coaxial-cable.html)
RG6U is only 600V
Wesley
Quote from: stivep on August 20, 2018, 12:58:20 PM
RG6U is only 600V
Hi Wesley. He was asking about RG-56/U, which is rated at 8000V.
I provided him a link to a company that sells it, but they might not sell it in really short lengths.
Magpwr would have to ask them.
Quote from: Void on August 20, 2018, 01:03:46 PM
They might be prepared to supply a short length as a sample.
https://www.spectrumaudio.com/belden-1855a-500-black-500-25awg-rg-56-u-wire/ (https://www.spectrumaudio.com/belden-1855a-500-black-500-25awg-rg-56-u-wire/)
300V only
https://catalog.belden.com/techdata/EN/1855A_techdata.pdf
Wesley
Quote from: stivep on August 20, 2018, 01:38:46 PM
300V only
Wesley
Hi Wesley. If you see the link I had previously posted to magpwr to AWC,
they list the type they sell as rated for 8000V, but the cable diameter is thick ---> 0.535 inches = 13.6 mm.
It may be too thick for magpwr's needs. There doesn't seem to be a lot of retail sources available for the
high voltage rated types of coax.
All the best...
https://patents.google.com/patent/US4127804A/en?oq=us20150102676 (https://patents.google.com/patent/US4127804A/en?oq=us20150102676)
this is yet another way to vary capacitance .
If it is used in conjunction with ..........https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg525072/#msg525072 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg525072/#msg525072)
than it will replace capacitor 11.
However this patent is independent energy conversion unit :
QuoteTwo inversely ganged variable capacitors having a common movable element varying the capacities such that when one capacitor is at maximum capacitance, the other is at minimum capacitance, have, after initially charging, a substantially constant contained or trapped charge distributed between the two capacitors. As the capacities of the capacitors are varied, a potential difference is developed between the fixed plate of one capacitor and the fixed plate of the other. When these two potential points are connected to a load, charge is transferred from one capacitor to the other as a current flow through the load. The total charge is not diminished, the energy supplied the load being the energy expanded on moving the movable charged plates. As the movable plates are moved in a cyclic manner an alternating current is provided to the load.
Wesley
us20150102676A1
https://patents.google.com/patent/US20150102676A1/en?oq=us20150102676A1 (https://patents.google.com/patent/US20150102676A1/en?oq=us20150102676A1)
the patent listed by me in https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg524989/#msg524989 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg524989/#msg524989)
contains scrambled pictures difficult to read.
I was encouraging you to study that patent
All of them can be employed in two ground system utilizing Telluric current as interacting Factor.
relation of ionosphere/ earth wave-guide/ telluric current
Wesley
Quote from: Void on August 20, 2018, 12:28:59 PM
https://www.awcwire.com/part.aspx?partname=rg56 (https://www.awcwire.com/part.aspx?partname=rg56)
hi void and stivep,
I am not sure what kind of coax cable Akula used for Antenna.But it would be nice to know.But i do notice there is a pattern related to coax cable with low Impedance say
48 or 50 Ohms does come with a thicker center copper core.This copper core looks like the only thing would allow the Antenna to stay in place.
I will try awcwire but the only thing i am not comfortable with is the RFQ part instead of the online Cart.
This circuit i attached may be considered old news but new in many ways only after i explain.
Not sure this will be of any help or even on topic. Delete if desired. In my early 20's, I worked on a ranch in Wyoming. Some of the time, I had to ride fence line as part of my job. On one occasion, the chap I was with decided to not heed protocol and just decided to grab onto both ends of a broken fence wire. It was early morning and things were wet as was his gloves. After considerable cussing and bitching, he connected the grounding wire. The resulting shock was substantial. It took him to his knees and left him shaking for a few minutes.
I was told that this was a thing called ground potential. Later in life I learned the why and what about it. I was told it can be nothing to thousands of volts potential. May not be much current but then what the hell. A ground wire strung log distance and a buried radiator could have one hell of a difference of charge.
thay
Quote from: Thaelin on August 22, 2018, 01:00:17 AM
thay
Same thing with the natural gas pipeline. They are heavily grounded to avoid sparking. I think they still debate if the current is inducted from a changing or moving earth's magneric field. The field is not very strong, but over hundreds of miles it accumulates.
My own WTF story is from my parents place. 4 car tyres piled up and the plastic hub caps on top of the pile. Caps had a round steel wire for fastening. My dad touched a hub cap and got shocked. He cursed and pulled away. He went back and touched a cap and was jolted again. Then he thought I had electrified the tyres and he got mad at me. We then inspected the tyres and found nothing. 4 tyres on wooden floor. You only got shocked from the hub caps. If you think about it it was 4 alloy rims insulated by the rubber. Then a plastic cap with a wire (antenna?) and you got an exfect
Quote from: Belfior on August 22, 2018, 02:52:32 AM
My own WTF story is from my parents place. 4 car tyres piled up and the plastic hub caps on top of the pile. Caps had a round steel wire for fastening. My dad touched a hub cap and got shocked. He cursed and pulled away. He went back and touched a cap and was jolted again. Then he thought I had electrified the tyres and he got mad at me. We then inspected the tires and found nothing. 4 tyres on wooden floor. You only got shocked from the hub caps. If you think about it it was 4 alloy rims insulated by the rubber. Then a plastic cap with a wire (antenna?) and you got an effect
I bet the fitter's name was Johnny ;D Old houses didn't use copper pipes it was ether steel or lead, lead in the late 1890's copper wire was hard to find
If you talked to the old guys you would pick up useful information.
Quote from: magpwr on August 21, 2018, 01:30:47 AM
hi void and stivep,
I am not sure what kind of coax cable Akula used for Antenna.But it would be nice to know.But i do notice there is a pattern related to coax cable with low Impedance say 48 or 50 Ohms does come with a thicker center copper core.This copper core looks like the only thing would allow the Antenna to stay in place.
When you get radiant energy going watch out if you haven't got over voltage protection it could damage the Mos-Fet
74hc 132 you need a good 6v suppressor like a 1N 5908 across it as it has been known to go back to the regulator as well, also Pic chips don't last long
with radiant, for warned for armed.
The magnetic field transducer of Andrey Melnichenko
English translated page: [[[*** English link modified - 01:30Z 23Aug18 ***]]]
https://translate.google.com/translate?depth=1&hl=en&rurl=translate.google.com&sl=auto&tl=en&u=https://realstrannik.ru/tehnomagija/366-transgenerator-magnitnogo-polya-andreya-melnichenko.html (https://translate.google.com/translate?depth=1&hl=en&rurl=translate.google.com&sl=auto&tl=en&u=https://realstrannik.ru/tehnomagija/366-transgenerator-magnitnogo-polya-andreya-melnichenko.html)
Russian original page:
https://realstrannik.ru/tehnomagija/366-transgenerator-magnitnogo-polya-andreya-melnichenko.html (https://realstrannik.ru/tehnomagija/366-transgenerator-magnitnogo-polya-andreya-melnichenko.html)
Technomagic page (RU): https://realstrannik.ru/tehnomagija (https://realstrannik.ru/tehnomagija)
@ Solarlab
Magnesium how would you describe it with respect of the end game you seek? i'm getting confused with your hypothesis.
Not magnesium MAGNETISUM ! it's my phone it alters words, i have had to use that as I have picked up so many trackers and treats
to my desk top 18 in total of here i presume now deleted.
I think there is slight connection between this topic and Figura discovery . Both need very strong Field. This is the secret which lies on fundiation of every ou
"How does the Tesla Transformer and associated, so called, Antenna helical coil interact with (influence) the Grenade Coil?"
Maybe there is a way to create a solid state flux/charge compression generator without the one shot energetic effect while minimizing the loss mechanisms.
Quote"An investigation aimed at optimizing the integration between a capacitor based prime power source and flux-trapping helical flux compression generator (FT-HFCG) is presented. An FT-HFCG simulation code, previously benchmarked with single and multi-pitch generators, was employed to study the kilo-joule class explosive system for this purpose. The details of this effort, which include the optimization of the field coil and stator coupling, as well as an examination of the effect of field coil parameters on the system performance, will be described in this document. For the simulated parameter space, the choice of field coil configuration caused the system energy gain to vary by 300%, and the optimum field coil configuration was found to be a single Litz wire conductor that had an axial length which was approximately 60% of the stator axial length."
source: https://www.semanticscholar.org/paper/Design-considerations-for-flux-trapping-helical-by-Young-Neuber/cce87fe5decead8c8ca43f35d785d378deb2ea32
Note: The zip file contains a pdf on flux compression generators it was 7k over the limit ::) so I had to compress it.
"Driving a conductive surface already containing a magnetic field" sounds like small antennas being driven with small power to make them appear electronically bigger.
Read this in one paper that described how to make small antennas appear bigger than they physically appear
Quote from: Belfior on August 25, 2018, 05:23:12 AM
Why would any one want to faff about with cultivating a magnetic field out side the ARadio field ???????
radio waves and magnetics < light speed and Lenny baby's law :( :( :( :( :(
that's the difference in Radiant energy field.
Quote from: DreamThinkBuild on August 24, 2018, 08:56:46 AM
try winding the thick wind the other way! and dump the mechanical switch ;D
F.Y.I.
The GROUNDING question is explained well by Gorchilin at http://gorchilin.com/articles/coil/?lang=en (http://gorchilin.com/articles/coil/?lang=en)
See Fig. 1.4 attached below - Left is the RLC coil model, Eqn (1); Right is the Long Line coil model, Eqn (2).
Now, with respect to the Grounding question;
compare the Right and Left models and the answer to grounding will become quite clear!
Quotes from Gorchilin's page:
Note: *math equations shown in MathJax Equation Source - primitive but it's the only way
to even show equations here.
The lumped and distributed resonances in the inductor
Hams and seekers of free energy, there are questions about the different types of resonance that we are here and will try to illuminate. The problem is what it is. Everyone knows that an inductor (hereinafter, simply coil) can be considered as concentrated, and as a long line. In the first case, the formula for determining the resonance will be performing classical Thompson formula:
f = 1/2\pi\sqrt{L\,(C_l + C)} (1)
where L is the inductance of the coil, C is its own capacity, and l is the external capacitance connected parallel to the coil.
In the second case, we consider the coil as a long line, where the wave takes some time to get from one end to the other. If this time is equal to the oscillation period of the oscillator, in a coil set the mode of the standing wave. In this case, the simplified formula would be:
f = {c\,k \over l} (2)
where c is the speed of light, k is the deceleration rate, which, in General, depends on the material of the dielectric, and l is the length of the winding wire in the coil. This formula is greatly simplified, since is actually nonlinearly dependent on the length and winding pitch, coil diameter and material of the dielectric. A more accurate formula can be found in [1]. The differences in these two approaches are already visible at this stage, and we will demonstrate that there are many more.
| Since the real processes that occur in the coil, is little known, and we shall not stop.
| Consider the mathematical model which with sufficient accuracy describe these processes,
| and the results of such calculations can be seen on real devices.
Two models
Consider the direct asymmetric long line DL in figure 1.1, which is excited from a sinusoidal voltage source E1, through the inductor L1. Take her private for the case where DL fits in exactly half the wavelength. Thus, on its edges, we get the maximum current, and in the center of the maximum voltage. All measurements will be carried out at a load resistance R1, the value of which will choose a lot less the wave resistance of the line. For the manifestation of two independent processes it is also important that DL was as far away from earth.
For the mathematical model this means that if DL is to roll into a coil, its diameter will be much smaller this distance. In this case, the calculation of the line is about to produce by the formula (2), since the parasitic capacitance is practically nonexistent and work well with the classical formula of Telegraph equations.
SEE ATTACHED DIAGRAM
If DL put in parallel to the capacitor C1 (Fig. 1.2), it will begin to work one process, almost do not affect the wave. It is obvious that in this case we are dealing with an oscillatory circuit, the inductance which is the inductance of the line segment DL. I.e. a second, independent model, which can be easily calculated by the classic formula of Thompson (1).
Now it is easy to imagine what happens if we turn this long line in a coil — slightly changes its own capacitance and inductance, and two of the process and will work almost independently from each other. By the way, in this case, the wave model is better to rely on more precise formula, presented in [1].
Why are these processes, and thus their models, are independent? Look at figure 1.4, which shows their equivalent circuits. DL is in the standing wave, and since R1 is much less than the wave resistance, wave — almost no losses (right). On the wave process capacity C1 does not render almost any influence, but it forms with the inductance DL RLC circuit, which in turn also works independently (left figure). Changing C1 also has no effect on the wave process, but completely changes the picture of the LC resonance.
According to the author, the independence of the processes due to their work in different reference systems. The assemblage point, or point of combining these two systems is the load R1.
For skeptics who believe that in the coil (or in a long line) can't go two independent processes at the same time, a simplified model (Fig. 1.3), which added another DC power source E2. It is bridged by a capacitor C2 to a lower internal resistance at high frequency. As you can see on R1 we get the constant offset from E2, and independent of the antinode of the current standing wave from E1.
The combination of the two models
Next, we will focus on the DL of a rolled coil. This option is currently the best studied. Our great experimenters provided the data, which suggests that when combining two models, the resistance of R1 increases dramatically the amplitude of the signal that rightly can be compared with the increase of the quality factor. This becomes very clear if we consider two independent models: if the processes are combined, it really will be the addition of the amplitudes. Also, researchers say about "the toe" — the phenomenon in which the increasing amplitude is kept even if there is some frequency deviation oscillator. But we'll talk about it another time, but for now imagine a calculator that can find points of combining the two models. http://gorchilin.com/calculator/reactor?lang=en
(http://gorchilin.com/calculator/reactor?lang=en)
In fairness it should be noted that for combining standing wave and LC resonance, working on the harmonics, all the same it is better to use a non-inductive winding DL. Then the wave process is almost unchanged, and focused resonance is easier. This type of winding the researchers called a "grenade" or "dumbbell".
*** See Gorchilin's page for a proper layout, diagram and notation of the equations.
FIN
Solarlab
good post... good to see some have not given up.
QuoteRuslan K 1 year ago (edited) - "In that setup, I use Tesla's patent on the removal of radiant energy!
Charging capacitors radiant dumped through the transformer in the load. The primary is a lot of turns,
the secondary is short for creating a current in the transformer. The ring should be with good magnetic
permeability !!! Otherwise, there will be little return. There I got only 150 watts to take off.
In this quote is a clue most people miss and for the few that do see it generally makes absolutely no sense. One can have a primary with many turns and a secondary with fewer turns however the secondary induced voltage can be equal or greater than the primary voltage. I think Ruslan knows this and the fact he understands that a Tesla coil is not required and other geometries may be superior is significant in my opinion. I came to the same conclusion, Tesla coils are simply too long and this takes away from the desired effect.
It's kind of like a puzzle and nothing makes sense until first we recognize what the piece is and then later where it fits in the bigger picture. Think about that... what looks just like a transformer but obviously is not entirely a transformer? , a transformer which has turns of conductor but does not always follow the turns ratio rule?. How can this be?, it makes no sense and then the piece fell into place and I felt silly that it took so long to understand something so simple, so fundamental in every aspect of nature. It is not for everyone.
This is what I absolutely fucking love about this field of technology... it never gives you an inch. Intellectually it's always an uphill battle and nothing is ever as it seems because everything is always fluid, dynamic and always changing. I have this simple rule... if I have not learned something new today which has completely changed my mind about something I thought I knew yesterday then I have learned nothing.
To "learn", ie."Gain or acquire knowledge of or skill in (something) by study, experience, or being taught"
To be "taught"?, but what if the people who presume to teach me are fucking half-wits... what then?. what if a majority of society is degenerate and prone to false beliefs what then?. Thus true learning must always rely on logic, reason, reality and above all else proof and not marginalized by mere populists beliefs.
So there you have it my friend and if you want to move forward there is only one question which should occupy your thoughts from this moment on... how, when and why does the standard transformer turns ratio rule or action between two coils not apply?. Any fool can read a textbook or google the question and tell me why it must apply but that is not the question I am asking... I am asking when it does not apply? and that is a very different question which apparently few have the intelligence to answer.
@Onepower
Quote from: onepower on August 26, 2018, 12:17:49 AM
Solarlab
why would any one bow to such disrespect on this tread ?
Quote from: Hoppy on August 27, 2018, 10:01:02 AM
As has been stated by Wesley & others, OU is not achievable.It has nothing to do with the basics being wrong.
People state all sorts of things, but it doesn't mean they are correct. :)
'Over unity' is just a term which indicates that you measure more power out
across a load than the measured input power. In my opinion there is nothing
at all wrong with the term, since its meaning is clear. Using the term COP > 1
may be a more acceptable term to some people, but both indicate the same type of result.
Neither term alone indicates or limits where exactly the excess energy is coming from, only that excess energy
is apparent. Most people probably accept that the excess energy would have to be coming from somewhere however,
such as possibly 'outside the system', but if you are talking about energy coming from outside a system, in such a case you first
need to define the boundaries of your system. Anyway, for me, it is not a big deal at all, since the meaning is clear in both cases.
You measure more output power than input power. Where the excess energy comes from would be dependent on each individual case.
Does the system include the honking great FM radio station's transmitting antenna in Ruslan's backyard?
Quote from: TinselKoala on August 27, 2018, 10:59:40 AM
Ha ha. What evidence do you have of such a thing?
I think Ruslan at least used to, and may still live in an apartment building.
His station has multiple transmitters covering large areas of the country, so I think the antennas would
not likely be in anyone's back yard (high power transmitters). :)
Or the generator in the bushes where "the grouund is moist enough for good earthing"...
Also what I think Wesley is saying that you can produce usable electricity without paying taxes or companies from telluric currents. That is also fine by me. That would also mean these are produced by radiation from space to ionosphere and ground being the other plate.
Ha ha Tinsel, you know very well that thats Ruslans daytime job!
There were no FM stations in the 30-40's
But Henry Moray used only the desert, so now where do you stand, cactus land ?
Morey's notes describe other strange phenomenon like listening to remote conversations and an ad on device
that could suck energy from a focused point that he demonstrated using rats and mice that just left
a carbon carcass, thats telling us the device sucked energy from the environment.
That's how it worked what it did
Belfior
QuoteI agree Ruslan might be throwing people off deliberately. I think if the device is henuine the egfect is trivial to achieve. He wants to cash in before everybody has it.
From what I have seen and read Ruslan has not deliberately thrown anyone off and only provided as much information as he is willing to give. If we expect to be paid for our work then so should everyone else otherwise we are hypocrites by definition. Does Ruslan deserve to cash in on all his hard work?... well yes, obviously. No one else anywhere would expect any less.
QuotePeople point me towards websites to go read i the basics. I think the reason we are still having trouble with OU is that it is the basics that we have that are wrong.
I don't think the basics are wrong only that we do not fully understand them and how they relate to one another. Logically, everything we do not understand cannot be inherently right or wrong... because we do not understand it.
QuoteMy current bet is still resonant tank (so the cap charges instantly) and high farads. Then you got charge that rquals amps/s
A resonant tank circuit is simply an electron current sloshing back and forth between a coil and capacitor and all the laws which apply to every electron current are still in force. So the moment we try to conduct or induce energy away from the source we lose something as we all know. Force is the impetus which drives all motion and if there is more motion or energy present in the system then an extra force must also have been present. Otherwise we return back to the dark ages thinking something must have been created from nothing which is hardly an option in my opinion.
An analysis of single wire earth return (SWER)system for rural electrificationhttp://scholarsmine.mst.edu/cgi/viewcontent.cgi?article=6061&context=masters_theses (http://scholarsmine.mst.edu/cgi/viewcontent.cgi?article=6061&context=masters_theses)
When I went to grounding system i was shocked to rediscover , again and again, mistake made even by very experienced electricians.
Most of us is looking for electrical properties of the ground and that is resistance
how limited ..
So if your ***WBSA at low low frequencies 1:200Hz ( or in Kapanadze 1kHz :20kHz)
is placed right next to your far away grounding rod, and your ground rod has increased LC than useful voltage at desired shape and frequency is
delivered after 300ft ( 100m) at ratio explained right here.
1.https://www.youtube.com/watch?v=FJXVVD8IiQc&t=13s (https://www.youtube.com/watch?v=FJXVVD8IiQc&t=13s)
Please look at very first 30 seconds of this video .
2. https://youtu.be/EH9VhcDZYKg?t=64 (https://youtu.be/EH9VhcDZYKg?t=64)
Wesley
Frequency is the number of occurrences of a repeating event per unit time. It is also referred to as temporal frequency, which emphasizes the contrast to spatial frequency and angular frequency. The period is the duration of time of one cycle in a repeating event, so the period is the reciprocal of the frequency.
Motion means movement. Motion can also be defined as a continuous change in the position of an object. Each type of motion is controlled by a different type of force.
Pressure is explained by classical mechanics as - continuous physical force exerted on or against an object by something in contact with it.
Voltage is electric potential difference, electric pressure or electric tension explained by quantum physics
Wesley
https://www.youtube.com/watch?v=Goq76CQapyI (https://www.youtube.com/watch?v=Goq76CQapyI)
Dual grounds from the first Kapanadze video...
Acca..
[/font]
An Introduction to
the Mysteries of Ground Radio
by Gerry Vassilatos
"specially placed telegraph and telephone lines operated for years without batteries at all. Station operators took this phenomenon for granted. Despite the "long dead and corroded Edison Cells", telegraph station operators continued the powerful exchange of "fat blue and sparking" signals for decades (Lehr).
Other researchers corroborated the fact that usable amounts of current could actually be derived from the ground, currents whose powerful displays permitted the elimination of battery cups and generators. The failure of all reductive electrical models to satisfactorily address these energetic characteristics became especially evident with the development of the "earth batteries", an outgrowth of these telegraphic observations (Bain, 1849). These simple material composites, made to be buried in earth, produced currents not explained through electrolytic action. Small buried earth batteries developed sufficient power to charge storage batteries. They were also employed to provide telegraphic (Bryan, Cerpaux, Dieckmann, Jacques, Bear), and later telephonic systems (Stubblefield, Strong, Brown, Tomkins, Lockwood) with uninterrupted operating power. Neither decomposing nor failing with months of buried use, the mysterious earth batteries contain an essential mystery which electrodynamic models cannot adequately explain."
https://borderlandsciences.org/journal/vol/53/n01/Vassilatos_on_Ground_Radio.html (https://borderlandsciences.org/journal/vol/53/n01/Vassilatos_on_Ground_Radio.html)
Acca..
Quote from: Hoppy on August 29, 2018, 06:36:46 PM
Wesley,
I can understand what you are thinking / driving at to a point but as I have already commented, I really have no evidence yet to cast an opinion on why Tariel needs a ground or whether he needs interaction. My gut feeling for what its worth, is that his devices if not faked, are not using aetheric or telluric energy but possibly some form of clever energy extraction through transmutation of matter. This would at least explain why successful replications have so far been elusive.
Tesla and Morey found it could suck energy from the surroundings it's old hat once one reads the scripts ! Only the fiction writers write the mills and boon stuff here ;D look on the Kernels (Tom Beardons web site) web page on This sick of pointing to it! Who invented the HF transistor Morey!
You'll have to start swimming or you'll sink like a log for the times they are a changing Bob Dylon
http://phils.com.au/moray.htm
http://www.cheniere.org/books/excalibur/moray.htm
Quote from: Acca on August 29, 2018, 03:40:57 PM
Acca..
Hi Acca. It wasn't the first Kapanadze video, and it has long been established that
Kapanadze only used one ground at a time. From what I recall reading of that event, the potential investors
who attended the demo didn't trust that the outdoor water pipe ground didn't have a hidden power source connected to it,
so they asked Kapanadze to make a new ground connection point right in front of them while they were watching.
Wesley,
Following on from my last post ref evidence, I have again posted, in my opinion an interesting video clip of the device you witnessed working in Tariel's garage. This rather strange looking earth 'wire' appears to have two separated conductors. Did you have the opportunity to very closely examine every inch of its length back to the grounding point?
Do not be fooled. Ground is not required. We need source of special electrons, energetic ones which are here but dormant till cycled. Why dormant ? Because they do not belong to the circuit, and obviously they are more energetic then normal free electrons in metal. They are continuously INDUCED but invisible because we move at the same speed !
Ground = metal :P
Quote from: forest on August 31, 2018, 04:37:51 AM
not cycled whats that ? do you mean charged, how to prove the paper hat ignorance exists, get rubber balloon coat with light metallic conductor connect fine wire to conductor about 200 ft fill balloon with hydrogen, hold earth end of balloon wire and let balloon go get electrifying free energy experience ;D ;D ;D
https://teslaresearch.jimdo.com/death-ray/
Quote from: Void on August 31, 2018, 05:02:01 AM
Hi Hoppy. That's an interesting thing to say considering there is no evidence at all of any such thing. ;) ;D
TK device is nothing like Roma or Ruslans device at all it works as a frequency voltage current amplifier
Have you seen the device on dragons den ?
https://www.youtube.com/watch?reload=9&v=YT60Nfj51fk
any way if you do it the TK way you need a pile of caps to store a cycle of energy in thats a lot of caps where are they?
Quote from: Hoppy on August 31, 2018, 09:22:05 AM
Look deeper. ;D ;) ;)
Hoppy this might help why you don't under stand whats doing on, I hope it helps :)
https://www.youtube.com/watch?v=fZjNJy9RJks
http://teslaradio.com/pages/wireless_102.htm
this is very well made article at the level worth to study.
Wesley
https://www.youtube.com/watch?v=HJylD7xpEiU (https://www.youtube.com/watch?v=HJylD7xpEiU)
first comment below the vid
ProfRaccoon (https://www.youtube.com/user/ProfRaccoon)vor 2 Jahren (https://www.youtube.com/watch?v=HJylD7xpEiU&lc=Uggef8L4RM4oa3gCoAEC)Finally, an independent experimental proof for Tesla's claim about a fundamental electrical earth resonance of about 12 Hz.. E explained this is not a Schumann resonance frequency of the earth-ionosphere cavity, so the 11.77 Hz signal might pass through the earth itself, such that the 'ground' frequency of 11.77 Hz is higher than the Schumann base resonance frequency of 7.83 Hz. Assuming the electric waves all have the speed of light, then the Tesla ground resonance wave length must be much shorter than the Schumann resonance wave length. This rules out as well, that the 11.77 frequency signal is Zenneck's earth surface TEM wave, since one should expect the ground frequency of such a wave to be close to the Schumann resonance (the ionosphere height is small compared with earth radius). So this test is a strong indication for longitudinal electric waves that travel through the center of earth. The earth diameter is about 12756 Km (measured from equator to the equator), and taking this length as exactly one wavelength, gives a frequency of 11.76 Hz (if one assumes the signal has light speed c= 300.000 Km/s ). It is very convincing (with respect to the claim that 11.77 is a natural frequency and not a system frequency) that two totally different Tesla coil systems with much different dimensions and system parameters both work optimal in case the spark gap frequency is tuned to 11.77 Hz. Great work, E!
https://youtu.be/bBhVDcZwAls?t=223 (https://youtu.be/bBhVDcZwAls?t=223)
This video starts from standing wave but it is worth to see it all.
Some useful links for thinkers: (Earth NMR) and more of nuclear processes
https://www.utu.fi/en/units/sci/units/chemistry/research/mcca/Pages/Sub-pages%20of%20Functional%20Materials/Applied-NMR.aspx (https://www.utu.fi/en/units/sci/units/chemistry/research/mcca/Pages/Sub-pages%20of%20Functional%20Materials/Applied-NMR.aspx)
https://www.bruker.com/applications/chemical/analytical-chemistry/inorganic-chemistry.html (https://www.bruker.com/applications/chemical/analytical-chemistry/inorganic-chemistry.html)
http://www.process-nmr.com/nmr1.htm (http://www.process-nmr.com/nmr1.htm)
http://newscenter.lbl.gov/2014/08/19/nmr-using-earths-magnetic-field/ (http://newscenter.lbl.gov/2014/08/19/nmr-using-earths-magnetic-field/)
http://www.teslatech.info/ttevents/2018conf/2018ETCp09.pdf (http://www.teslatech.info/ttevents/2018conf/2018ETCp09.pdf)
https://en.wikipedia.org/wiki/Secondary_emission (https://en.wikipedia.org/wiki/Secondary_emission)
http://www.jupiterscientific.org/sciinfo/numasses.html (http://www.jupiterscientific.org/sciinfo/numasses.html) Neutrinos Have Mass for Sure
https://www.researchgate.net/post/Why_do_resonance_peaks_occur_in_a_neutron_cross_section_spectrum (https://www.researchgate.net/post/Why_do_resonance_peaks_occur_in_a_neutron_cross_section_spectrum)
https://en.wikipedia.org/wiki/Free_neutron_decay (https://en.wikipedia.org/wiki/Free_neutron_decay)
Electrical and Earth/ impedance
http://www.hvpower.co.nz/TechnicalLibrary/RE+DS/Petersen%20Coils%20%20Basic%20Principle%20and%20Application.pdf (http://www.hvpower.co.nz/TechnicalLibrary/RE+DS/Petersen%20Coils%20%20Basic%20Principle%20and%20Application.pdf)
https://cr4.globalspec.com/thread/68715/Petersen-Coil-and-Capacitive-Charge-Current (https://cr4.globalspec.com/thread/68715/Petersen-Coil-and-Capacitive-Charge-Current)
https://uk.megger.com/electrical-tester-contractor-edition/october-2015/demystifying-loop-testing (https://uk.megger.com/electrical-tester-contractor-edition/october-2015/demystifying-loop-testing)
http://www.nlvocables.com/blog/?p=589 (http://www.nlvocables.com/blog/?p=589) Measuring Telluric Currents – First Trial
https://www.solacity.com/docs/Polyphaser/Ground%20impedance.PDF (https://www.solacity.com/docs/Polyphaser/Ground%20impedance.PDF)
https://www.nemasurge.org/wp-content/uploads/2015/01/grounding.pdf (https://www.nemasurge.org/wp-content/uploads/2015/01/grounding.pdf)
http://rexresearch.com/barbosa/barbosa.htm (http://rexresearch.com/barbosa/barbosa.htm) Nilson BARBOSA / Cleriston LEAL Earth Energy Generator
https://patentimages.storage.googleapis.com/c2/73/cd/ed546d4872c866/US20150102676A1.pdf (https://patentimages.storage.googleapis.com/c2/73/cd/ed546d4872c866/US20150102676A1.pdf) METHOD AND APPARATUS FOR EXTRACTING AND CONVEYING ELECTRICAL ENERGY FROM THE EARTH IONOSPHERE CAVITY
https://patents.google.com/patent/US1974483 (https://patents.google.com/patent/US1974483) Electrostatic motor
asymmetrical capacitors and more
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20040171929.pdf (https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20040171929.pdf) Asymmetrical Capacitors for Propulsion
https://www.researchgate.net/publication/2168167_Force_on_an_Asymmetric_Capacitor (https://www.researchgate.net/publication/2168167_Force_on_an_Asymmetric_Capacitor)
https://en.wikipedia.org/wiki/Biefeld%E2%80%93Brown_effect (https://en.wikipedia.org/wiki/Biefeld%E2%80%93Brown_effect)
https://youtu.be/09otx2Pfphw?t=2042 (https://youtu.be/09otx2Pfphw?t=2042) Voltage multiplier ( I have two of the units)
https://www.youtube.com/watch?v=bFssWFfFCFs (https://www.youtube.com/watch?v=bFssWFfFCFs) Big electrostatic ASSEMBLY .
Electrets:
https://patents.google.com/patent/CA2113048C/en (https://patents.google.com/patent/CA2113048C/en)
https://hypertextbook.com/facts/2008/JeffreyWong.shtml (https://hypertextbook.com/facts/2008/JeffreyWong.shtml)
http://iopscience.iop.org/article/10.1088/0960-1317/19/9/094003 (http://iopscience.iop.org/article/10.1088/0960-1317/19/9/094003)
http://aetherforce.com/electrets-permanent-electrical-magnets/ (http://aetherforce.com/electrets-permanent-electrical-magnets/)
The old scientist: ( Negative Resistance) subject:
https://www.youtube.com/user/TheOldScientist/videos (https://www.youtube.com/user/TheOldScientist/videos)
https://www.youtube.com/watch?v=RRp2nipT-S0 (https://www.youtube.com/watch?v=RRp2nipT-S0)
https://www.youtube.com/watch?v=5X43sKFfRts (https://www.youtube.com/watch?v=5X43sKFfRts) Stanley Meyer's Electron Extraction Okki Moeljadi
http://www.analogzoo.com/2018/01/negative-impedance-converters/https://www.youtube.com/watch?v=DBteowmSN8g (http://www.analogzoo.com/2018/01/negative-impedance-converters/https://www.youtube.com/watch?v=DBteowmSN8g) Lorenz Attractor - Physics 123 demo with Paul Horowitz
https://www.youtube.com/user/TheEngpjk/videos (https://www.youtube.com/user/TheEngpjk/videos) Patrick Kelly
https://www.youtube.com/watch?v=bBhVDcZwAls (https://www.youtube.com/watch?v=bBhVDcZwAls) TheMage00000 (https://www.youtube.com/channel/UC9RuDKWbf05CEr6Ss7lWvUQ)
https://www.youtube.com/user/overunitydotcom/videos (https://www.youtube.com/user/overunitydotcom/videos) overunity.com
Switching power supply:
https://www.youtube.com/watch?v=VLzcV9Sxt5Q (https://www.youtube.com/watch?v=VLzcV9Sxt5Q) Switch Mode Power Supply Measurements and Analysis
Simulation :(program tools)
https://phet.colorado.edu/en/simulation/legacy/capacitor-lab (https://phet.colorado.edu/en/simulation/legacy/capacitor-lab)
Wesley
:-\ wrong again, better read something like that https://www.andre-waser.ch/Publications/NikolaTeslasRadiationsAndCosmicRays.pdf or http://tesla3.com/paulo-and-alexandra-correa/
or even think about what Richard Willis said to Dragons
We are like bird on the HV line.
Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe. This idea is not novel. Men have been led to it long ago by instinct or reason; it has been expressed in many ways, and in many places, in the history of old and new. We find it in the delightful myth of Antaeus, who derives power from the earth; we find it among the subtle speculations of one of your splendid mathematicians and in many hints and statements of thinkers of the present time. Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature.
What Tesla is saying is simple : if Earth magnetic field is static , induced once and never again then our hopes are in vain... but if this is a generator inducing and synchronizing our magnetosphere with external cosmic source then we can tap huge amount of energy easily and almost without cost. We can use it to catch CO2 from atmosphere , to stop pollution and burning fossil fuels and to make every people life a dream...
Quote from: NickZ on September 03, 2018, 10:02:44 AM
Forest:
Some people may think that burning matter up (NMR) , is where it's at.
Although it can be "free" also, it's not what Tesla was after.
While more nuclear plants are being built at this time, even though the one in Japan is still uncontrollable.
Are we stupid, or just crazy? Or both...
Wesley: Please show us a safe NMR generator.
Did you like getting sick, as you seem to like recommending poisonous solutions.
NickZ Hi i'm not Wesley no, your referring to a type of static type of electricity (no magnetic charged current)
some call it radiant energy among other different other names. It draws energy from the environment or other things
or if not tuned can do other things which I wont discuss here, it's my guess you have no idea what i'm talking about
but it's another type of electricity that behaves so much unlike the conventional stuff we know. Are you sure that two
will ever be discussed on here?
some of my files that I have made for myself.
Examples of NMR in Ferrite replacement of metal compound in within the ferrite by ion
caused by FREQUENCY
at the same time energy level of ferrite has changed. everything is done by changing frequency of oscillation.
http://www.sciencedirect.com/science/article/pii/0022369771900369 (http://www.sciencedirect.com/science/article/pii/0022369771900369)
Nuclear magnetic resonance studies of Mn55
in the Mn substituted hexagonal ferrite Ba2Zn2-xFe12-yMnx+yO22
R. L. Streever, T. R. Aucoin and P. J. Caplan Institute for Exploratory Research, US Army Electronics Command, Fort Monmouth, N.J. 07703, U.S.A.
Received 22 December 1969. Available online 6 May 2004.
Abstract:The nuclear magnetic resonance (NMR) of 55Mn has been studied in single crystals of the planar hexagonal ferrite compound Ba2Zn2-xFe12-yMnx+yO22 for values of x + y of about 0·5.
The spin echo spectrum at 4·2°K shows a broad line extending from about 300 to 470 MHz which has been identified with Mn+3 ions (replacing iron) on octahedral sites and two relatively
narrow lines at 555 and 585 MHz which have been identified with Mn+2 ions (replacing zinc) on the two types of tetrahedral sites which occur in this structure.
Both Mn+2 lines are observed to shift to higher frequencies with externally applied fields which is consistent with this interpretation.
The Mn+3 lines have also been studied at 77°K and the Mn+2 lines in the range between 77 and 200°K.
The hyperfine fields and the temperature dependencies of the resonance frequencies for the Mn+2 ions on the two types of tetrahedral sites can be consistently explained in terms of the
different electronic environments of the two sites. It is concluded that a large percentage of the Mn ions in the compound are replacing Fe as Mn+3.
From the relative integrated intensities of the two Mn+2 lines, it is found that the Mn+2 ions are substituting onto the two types of tetrahedral sites with roughly equal preference.[/c]
US Army experimented in 1967 with NMR and Transmutation.From text above we see results of it.
It is stated that mechanism of transmutation and replacement by other inorganic substance was achieved.
But that includes energy transfer, and that is what we are interested with.(Lithuania Experiment)
Generation of metal–ligand cluster ion beams through pulsed discharge ionization and ablation
Ansgar Brocka, David L Cedeñoa and Carlos Manzanares Ia, , (Carlos_Manzanares@baylor.edu)
a Department of Chemistry, Baylor University, Waco, TX 76798, USA
Received 10 November 1998; accepted 30 July 1999.
Available online 28 February 2000.
QuoteAbstract Pulsed capacitor discharge ionization in supersonic expansions was investigated for the production of intense beams of molecular cluster ions
from seeded and ablated compounds.
A pulsed discharge based on a triggered spark gap switch was designed and used as a method for ionization and ablation.
Several combinations of nozzle geometry and electrode arrangement in front of a pulsed valve, were made to optimize the intensity of the ion beam as well as its composition.
The cationic metal–ligand complexes Cu+–(methanol)n, Cu+–(acetone)n, Cu+–(toluene)n, Cu+–(water)n, and Al+–(water)n were synthesized by ablation of the metal from
metallic discharge electrodes in a discharge gas mixture of helium seeded with the ligand of choice.
The cluster mass spectra of the expanded plasmas show little background ion signal besides the metal–ligand species.
Charge exchange processes in the expansion guarantee high ionization yields of the desired species and account for low backgrounds.
Changes in the successive binding energy of Cu+–(water)n clusters n = 1–4 are clearly observed in the cluster mass spectra as step formation.
A similar pattern found in Cu+–(acetone)n suggests the same trend in the successive binding energy as known for water.
Important is :Quote(phase, amplitude modulated) finite pulses run in parallel with all other events
https://kpervushin.wordpress.com/category/nmr-generator/ (https://kpervushin.wordpress.com/category/nmr-generator/)
(Wesley: you do not need to read this article)
This article is interesting from perspective of spark gap and HV involvement in ionization that is frequently present in all of FE electrostatic devices,
by use of capacitor. ===============================================================================================
http://www.phys.ufl.edu/REU/2009/reports/AntonioLorenzo.pdf (http://www.phys.ufl.edu/REU/2009/reports/AntonioLorenzo.pdf)
APPLICATIONS -X-RAYS & NMR :
for me this is very interesting article about X-ray - means photons and NMR but this article is not for everyonehttp://www.physics.usyd.edu.au/super/life_sciences/AN/AN6.pdf (http://www.physics.usyd.edu.au/super/life_sciences/AN/AN6.pdf)
http://www.youtube.com/watch?v=eBzmKgVnrP4 (http://www.youtube.com/watch?v=eBzmKgVnrP4)
Instead of the coil connected to PL259 (and affected by two other coils connected to modulator interacting with Earth Magnetic Field. -like in NMR ( one of the methods.
The second one is cryogenic.))
I have connected generator and I was modulating manually by frequency shift of +/- one of then thousand of 1 HZ !!!!
I have got enormous amplitude of interactive-resulting pick 10 times of amplitude of the primary signal.
Please look at spectrum analyzer and correct me with lower window setting.I put that window as Frequency domain.
The upper one is analog. Look at other parameters of that window
This was my video showing
strange impulses from generator ( mixer of two signals) made by CREATECH
http://freeenergylt.narod.ru/index/0-36 (http://freeenergylt.narod.ru/index/0-36)
Russian link related to FE and NMR 9 that is similar to setup used in my video from above. with CREATECH.https://youtu.be/NBXMG72gfqs?list=PL42F201860665F11A&t=474 (https://youtu.be/NBXMG72gfqs?list=PL42F201860665F11A&t=474) interesting phenomenon in plasma.
http://www.rexresearch.com/meyernmr/meyer.htm (http://www.rexresearch.com/meyernmr/meyer.htm) the old and much known
This PDF is for me very entertaining http://122.physics.ucdavis.edu/course/cosmology/sites/default/files/files/CW%20NMR/CWNMR012009.pdf (http://122.physics.ucdavis.edu/course/cosmology/sites/default/files/files/CW%20NMR/CWNMR012009.pdf)
but you may disagree
Plasma:
http://www.aetherometry.com/Patents/US5502354A1.pdf (http://www.aetherometry.com/Patents/US5502354A1.pdf)
http://aetherometry.com/Patents/US5449989A1.pdf (http://aetherometry.com/Patents/US5449989A1.pdf)
http://www.aetherometry.com/Patents/US5416391A1.pdf (http://www.aetherometry.com/Patents/US5416391A1.pdf)
\http://www.rexresearch.com/correa/correa.htm (http://www.rexresearch.com/correa/correa.htm) opinion about Correa.
http://www.aetherometry.com/Labofex_Plasma_Physics/Archive/CorreasUSPAbstracts.html (http://www.aetherometry.com/Labofex_Plasma_Physics/Archive/CorreasUSPAbstracts.html)
Abstracts
http://www.aetherometry.com/Labofex_Plasma_Physics/aspden_opinion.php (http://www.aetherometry.com/Labofex_Plasma_Physics/aspden_opinion.php)
additional material published by me at overunity.com
Lakhovsky Multiple Wave Oscillator original device http://www.youtube.com/watch?v=rRttn7xb0y8&feature=channel&list=UL (http://www.youtube.com/watch?v=rRttn7xb0y8&feature=channel&list=UL)
some links posted by me in the past : (Wesley: you do not need to read this articles)
Watch this: NMR in room temperature using Earth magnetic field. No Cryogenic!!
http://www.youtube.com/watch?v=7aRKAXD4dAg (http://www.youtube.com/watch?v=7aRKAXD4dAg)
http://www.youtube.com/watch?v=F2BED9aDEYw (http://www.youtube.com/watch?v=F2BED9aDEYw)
and this:
http://patft.uspto.gov/netacgi/nph-Parser?Sect2=PTO1&Sect2=HITOFF&p=1&u=%2Fnetahtml%%2FPTO%%2Fsearch-bool.html&r=1&f=G&l=50&d=PALL&RefSrch=yes&Query=PN%2F4291255 (http://patft.uspto.gov/netacgi/nph-Parser?Sect2=PTO1&Sect2=HITOFF&p=1&u=%2Fnetahtml%%2FPTO%%2Fsearch-bool.html&r=1&f=G&l=50&d=PALL&RefSrch=yes&Query=PN%2F4291255) http://www.rexresearch.com/meyernmr/meyer.htm (http://www.rexresearch.com/meyernmr/meyer.htm)
additional material TESLA book:
http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf (link does not work but can be found if needed) (http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf)
http://jnaudin.free.fr/html/mmcgen.htm (http://jnaudin.free.fr/html/mmcgen.htm)
http://freenrg.info/TESLA/Tesla_Switch/D3.pdf (http://freenrg.info/TESLA/Tesla_Switch/D3.pdf)
http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/ (link does not work but info is on overunity) (http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/)
http://jnaudin.free.fr/html/paraform.htm (http://jnaudin.free.fr/html/paraform.htm)
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296310 (http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296310)
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296308 (http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296308)
http://www.youtube.com/watch?v=b2n1-nvo7d4&authuser=0 (http://www.youtube.com/watch?v=b2n1-nvo7d4&authuser=0)
https://www.youtube.com/user/diggitydev/videos (https://www.youtube.com/user/diggitydev/videos)
Doc Schuster videos Wesley
Quote from: v8karlo on September 05, 2018, 03:54:07 AM
Hello everyone!
I've been looking at some old videos of Igor Moroz. First part https://www.youtube.com/watch?v=FFg9h_gGrFg (https://www.youtube.com/watch?v=FFg9h_gGrFg) and second part https://www.youtube.com/watch?v=IpAuvTBCugs (https://www.youtube.com/watch?v=IpAuvTBCugs) Basically, in second part, he is telling that he is returning same amount of energy to grid and in process using few hundred watts of light. He is using bifilar coil as the secondary in his transformer. So, the net consumption would be very little or nothing, frequency is grid frequency 50Hz. Looks very similar to Kapanadze.
Lost energy in close circuit could be recovered but not created . In this case the feedback of output power is injected again in system input .
Myself made some experiments about that point .
Example how could be possible recharge the same input source in same time . The video have 21 minutes is easy to see how much the input lower since start.
https://www.youtube.com/watch?v=I_eja4gmpcY&t=665s
https://youtu.be/Te7NcDY-afQ?t=35
Nelson Rocha
Now,
concerning the video about Ohms Law broken with HV Negative Resistor ( https://www.youtube.com/watch?v=RRp2nipT-S0 (https://www.youtube.com/watch?v=RRp2nipT-S0))
I found these two demonstrations of Fred B´s Tech Channel very interesting especially part 2 because of a good working sparg-gap simulation model. It clarified many questions I had:
https://www.youtube.com/watch?v=wU8LYiLLpGs (https://www.youtube.com/watch?v=wU8LYiLLpGs)
https://www.youtube.com/watch?v=N7gPeIVVy0A
Mike
Wesley that long NMR post is really good as I have been a supporter of the "inter-atomic" model and it's NO theory..
Italians have discovered through audio ultrasonics cavitation that iron chloride goes nuclear in 2008, and since that
discovery I know that the same effect is responsible for the extra electrons in the yoke core ferrite radiation that you
have been exposed to that gave you that radiation sickness.. See low energy nuclear radiation..
As to members who post anti- free energy posts I always see these distractors as fools or spies who spend allot of
effort to stop any progress through the "dogmatic science" leverage ... and there is many here of such anti-free
energy efforts shills, spies and total nut jobs..
Keep on and God speed in your efforts..
Acca..
"In L'Évolution de la Matière (1905), Le Bon anticipated the mass–energy equivalence, and in a 1922 letter to Albert Einstein complained about his lack of recognition. Einstein responded and conceded that a mass–energy equivalence had been proposed before him, but only the theory of relativity had cogently proved it.[36] Gaston Moch gave Le Bon credit for anticipating Einstein's theory of relativity.[37] In L'Évolution des Forces (1907), Le Bon prophesised the Atomic Age.[38][39] He wrote about "the manifestation of a new force—namely intra-atomic energy—which surpasses all others by its colossal magnitude," and stated that a scientist who discovered a way to dissociate rapidly one gram of any metal would "not witness the results of his experiments ... the explosion produced would be so formidable that his laboratory and all neighbouring houses, with their inhabitants, would be instantaneously pulverised."[40][41]"
transmutation if any is a by-product !
Quote from: forest on September 10, 2018, 06:25:02 AM
Ok. Theoretically is is simple. Let me explain. There is law of conservation of energy , true. However thee is no law of conservation of work done. In other words it's up to you how much work you can do with the amount of energy you have - mostly it depends on how good you can eliminate loses like friction.
So ? I think you start to see the picture. ...
Analogy to water. If you direct a stream of high pressure water into a still pool of water, there is more water moving than just the stream. Voltage we can just create.
Also you can create special situations where Nature will do the work for you.
Hi Wesley,
Upon searching "ionization accelerates transmutation" gave me interesting results which you may find it interesting related to acceleration.
Nuclear tranmutation to Nuclear fission 1932...1939 **(Nothing to do with actual Nuclear around late 1920s)
https://books.google.com.sg/books?id=rk5uBwAAQBAJ&pg=PA55&lpg=PA55&dq=ionization+accelerates+transmutation&source=bl&ots=OnWKIofSVO&sig=Ry9cTNZ_1myoQr5NUENVOVh5xQs&hl=en&sa=X&ved=2ahUKEwio7svPt7DdAhWBNI8KHUBoC9gQ6AEwAXoECAkQAQ#v=onepage&q=ionization%20accelerates%20transmutation&f=false (https://books.google.com.sg/books?id=rk5uBwAAQBAJ&pg=PA55&lpg=PA55&dq=ionization+accelerates+transmutation&source=bl&ots=OnWKIofSVO&sig=Ry9cTNZ_1myoQr5NUENVOVh5xQs&hl=en&sa=X&ved=2ahUKEwio7svPt7DdAhWBNI8KHUBoC9gQ6AEwAXoECAkQAQ#v=onepage&q=ionization%20accelerates%20transmutation&f=false)
The above is the early version way before NMR was mentioned anywhere. :)
---------------------------------------------------In the meantime completed improving my circuit to produce "ultra stable" interrupted frequency in Mhz for the tesla coil without the use
of mica capacitor for one of the 3 tesla coil driver embedded circuit,pulse generator.
Received parts to assemble the Antenna which i threw away sometime back along with tesla primary driving coil after failing to see OU.Accelerator with sine-wave 80khz will be shown once ready as it is before further modification to resolve existing "impedance issue".
SolarLab this things are in lack of "mathematical beauty"(this statement is important) as Dirac would say.
It goes like this:
first we have maxwell and this https://www.youtube.com/watch?v=DOBNo654pwQ
(can field exist without charge?)
then we have this https://en.wikipedia.org/wiki/Relativistic_electromagnetism (wikipedia is not enough to explain R EM) and this https://www.youtube.com/watch?v=1TKSfAkWWN0
and in the end we have this (yes this is my question that I've posted on stack exchange) https://physics.stackexchange.com/questions/422300/electromagnetic-induction-causes-electron-wave-function-collapse-inside-atoms/422449#422449
there is something missing, can you feel it? if so then what is it? perhaps it's the lack of understanding of fundamentals or nature's mathematical beauty in our understanding.
"Everything that can be Invented has been Invented" ?
LENR has gotten Legs and is most definitely our future [thx To member Wavewatcher ]
https://cryptome.org/2018/09/This-Is-Not-Cold-Fusion.pdf (https://cryptome.org/2018/09/This-Is-Not-Cold-Fusion.pdf)
and since this is a good news day
DUNE ...the Neutrino project also got legs...
https://www.fnal.gov/pub/science/lbnf-dune/index.html (https://www.fnal.gov/pub/science/lbnf-dune/index.html)
-------------Seems the first link won't open in some parts of the world :'(
so WW made a PDF
I find this cherkunov guy a bit strange. If he is posting these antigrav videos why doesn't go around the thing with a stick to show no wires? In one video he does, but only goes in the front of the device. The plates are not level, but the device floats straight? What kinda force is that?
Antigravity was patented by tt brown already
Quote from: Acca on September 22, 2018, 04:13:42 PM
and now for some Tesla technology from ....
Here it is just for you Wesley ...
it just goes to show you that this is a just a very strange WORLD ...
It's Tesla and very high voltage again it is juat SHOCKING that this stuff may be real.. Anti gravity...
And since it deals with TESLA type technology I am posting it here ...
ACCA..
Alexey Chekurkov (https://www.youtube.com/channel/UCzZxKT3BzBZOVVy8_YzP6Yw)
Published on Aug 18, 2018
Видео левитации диска. Желающих помочь в поддержке канала может последующему реквизиту. PayPal alex_a.v@mail.ru Payoneer alex_a.v@mail.ru
https://www.youtube.com/watch?v=VBrx4O10XkI (https://www.youtube.com/watch?v=VBrx4O10XkI)
https://www.youtube.com/watch?v=2JrkOfqm6eY (https://www.youtube.com/watch?v=2JrkOfqm6eY)
hi Acca,
Interesting video with additional details shown.
I noticed the creator of this device is using spinning magnets maybe
North,South,North,South,North,South mounted in a circular plate and combining with some kind of ionization from fly-back transformer.
It reminded me of a video seen sometime ago about "induction heating" of copper pipe using just spinning magnets on a circular metal maybe somewhat similar concept to a certain extent.
Definitely more efficient than a conventional induction heater since alternating magnets poles does the same thing for less energy.
Some of you may already know or heard about latest A/C motor technology with
magnets strategically placed in rotor to increase motor efficiency by around ~20%.
-------------------------------------------------------------Back to current Kapanadze build -I think i have solved what Akula used for the Antenna by using Solid core wire.Since this is the only thing that holds the primary and Antenna nicely in place.I am left with Antenna mounting brackets to dry up (epoxy) before commencing testing then demo.
Mag here in Poland there is a very large copper producer KGHM Copper. Some producers add zink to lower the cost of copper and other elements don't presume it's all the same copper wire..
Like Wesley has said isotopes of copper are many .. It may be the impurity that has an affect on the Russian Kapanadze device.. As of yet unknown ...A scientific method was not done here...
Variables are many it's like a combination lock as one adds to the depth of the tumblers in that, the chance to hit the right combination is in the orders of magnitude...randomness will not work trying to unlock that tumbler safe.
Complexity is in the state of mind as to an engineer looking at a suspension bridge it looks very simple to build and yet to an average man it is a hard thing to understand the complexity of individual parts...
As of yet that elusive effect in the " west " is missing.
Quote from: Acca on September 23, 2018, 02:18:08 PM
Acca I don''t have a white coat nor do I have a doctors degree but I have said and got ribbing back from many, perhaps this might help
it came from else where in this internet youtube concerning different metals but i will say it again 'iron or steel, this metal the skin effect 'charged
partials are one of the slowest to travel' and the gains are obvious !
Thanks Acca for mentioning this phenomena and Dr Tanju Argun university of Ankara Turkey~
"The Conservation of Energy Law"? edited and quoted.
In 1993 Tom Bearden came up with the idea of "Massless Displacement Current". I was inspired (Tanju Argun) by that.
As you might know there is a process called "The Skin Effect" where Electrons (charged particles),
before forming a current, must travel from the center of a conductor to the peripheric rim to travel. The time,
the electrons traverse from center to the rim is called the" Relaxation Time". We are talking Microseconds here. So, what I did here was to simply,
by just letting a big Capacitor to sniff the Potential of a 24 volts Battery for only 100 Microseconds. During these 100 microseconds,
electrons start to move to outside perimeter of the conductor to start the current.
But unfortunate for them time is not enough to form the current.
Instead those trapped electrons just attain a "Potential Gradient "across them.
So, the capacitor gets the Potential Difference across it with minimum current, which is called the "Mass less Displacement Current". In analogy;
the young man "the capacitor", just catches -a glimpse of a passing by super-mini skirted young lady- "the battery". Capacitor is loaded with minimum power.
Ideal case is to use iron wire or doped conductors and plates to block the electrons from forming a current by increasing the "Relaxation Time".
After 100 microseconds, the Mosfet switch opens and disconnects the battery from the capacitor.
AG
Quote from: Belfior on September 23, 2018, 05:07:40 AM
Antigravity was patented by tt brown already:)
antigrav levitation is not same thing like levitation :) .I made a video showing some sort of levitation some months ago with diamagnetic materials like aluminum under influence of dielectric fields , where is possible levitate a aluminum even without any wire connected . https://youtu.be/kXdBKhVG2Bg?t=1
I really don't believe that those videos show any type of real anti gravity process , maybe some sort of levitation but not some type of antigravity :) .
chears
Nelson Rocha
On the Cherkunov device:
When someone levitates an object,say thru the use of magnetic fields
the magnetic field is transferring the force of the weight,thru action/reaction
this is not an anti-gravity effect.You are merely pushing against the magnetic field,this provides a lift by repulsion which has a limited range,it transfers the weight to what ever its pushing against.In
hes device,lets say it weighs 3 pounds,you are providing a 3 pound lifting force to counter
the weight of the object,it is not pushing against anything.If it is not a
trick, it is extremely important,could an object escape the earths gravity
if it produced a small up ward force not dependent on chemical fuel.
Consider a balloon with helium it keeps going until it reaches the edge of the atmosphere.
A device if real would keep going until it escaped the earth.
The problem is if its real and he does a good test of hes device the government will move
on him quickly,can't have there enemies have this information.
Right now he would be considered a crackpot.
https://www.youtube.com/watch?v=iXLWu6jSHQU (https://www.youtube.com/watch?v=iXLWu6jSHQU)
https://www.youtube.com/watch?v=bPqEtBYnkmQ (https://www.youtube.com/watch?v=bPqEtBYnkmQ)
https://www.youtube.com/watch?v=X0WnddW5gZI (https://www.youtube.com/watch?v=X0WnddW5gZI)
https://www.youtube.com/watch?v=0xx_cyo3OX0 (https://www.youtube.com/watch?v=0xx_cyo3OX0)
https://www.youtube.com/watch?v=3r4wytAjrU (https://www.youtube.com/watch?v=3r4wytAjrU)
https://www.youtube.com/watch?v=jAsRp4dvJCU (https://www.youtube.com/watch?v=jAsRp4dvJCU)
https://www.youtube.com/watch?v=-FsmEwlgF94 (https://www.youtube.com/watch?v=-FsmEwlgF94) (video from our perspective valuable as he uses soft iron wires substituting ferrite core.)
https://www.youtube.com/watch?v=nHjayUoi8L4 (https://www.youtube.com/watch?v=nHjayUoi8L4)
https://www.youtube.com/watch?v=ARKHcq-Ee8g (https://www.youtube.com/watch?v=ARKHcq-Ee8g)
https://youtu.be/-kLkc7uS-r0?t=6 (https://youtu.be/-kLkc7uS-r0?t=6) rusting of ferrite particles is usually done in porcelain cylinders.
https://youtu.be/BHuWloNGo6c?t=47 (https://youtu.be/BHuWloNGo6c?t=47) we are not interested with neodynium, we are interested with process of manufacturing only
https://youtu.be/HhpPwg89j6I?t=70 (https://youtu.be/HhpPwg89j6I?t=70) Wesley's Wayne Kerr Magnetic Analyzer
https://youtu.be/flkrwW4Ht-I?t=14 (https://youtu.be/flkrwW4Ht-I?t=14) Wesley's LCR
https://youtu.be/izzujmKROWI?t=106 (https://youtu.be/izzujmKROWI?t=106)Wesley's Beta and Alpha
https://youtu.be/hnY1Zbi7sgM?t=21another (https://youtu.be/hnY1Zbi7sgM?t=21another) DIY
https://www.youtube.com/watch?v=z8jybTInqeQ (https://www.youtube.com/watch?v=z8jybTInqeQ) furnace
https://youtu.be/noGGcyPHtdI?t=166 (https://youtu.be/noGGcyPHtdI?t=166) not importanthttps://www.hitachimetals.com/materials-products/soft-ferrites/ni-zn-materials/stress-and-magnetic-field-resistance.php (https://www.hitachimetals.com/materials-products/soft-ferrites/ni-zn-materials/stress-and-magnetic-field-resistance.php)
http://tscinternational.com/tech13.pdf (http://tscinternational.com/tech13.pdf)
http://www.fair-rite.com/wp-content/uploads/2015/08/2007.pdf (http://www.fair-rite.com/wp-content/uploads/2015/08/2007.pdf)
https://www.youtube.com/watch?v=QvwXMPnbG8k (https://www.youtube.com/watch?v=QvwXMPnbG8k) ferrite material
https://www.youtube.com/watch?v=bt_0QcvsIbo (https://www.youtube.com/watch?v=bt_0QcvsIbo) ferrite material
http://www.hpmemoryproject.org/an/pdf/an_1297.pdf (http://www.hpmemoryproject.org/an/pdf/an_1297.pdf)
http://www.johnbreslin.org/files/publications/19960900_vpec1996.pdf (http://www.johnbreslin.org/files/publications/19960900_vpec1996.pdf) with HP 4194A ( Wesley's Lab) for Low frequency
second picture
http://www.ieice.org/proceedings/EMC14/contents/pdf/16P2-B3.pdf (http://www.ieice.org/proceedings/EMC14/contents/pdf/16P2-B3.pdf) for Low frequency
third picture
http://literature.cdn.keysight.com/litweb/pdf/5980-2862EN.pdfhttp://www.datatronics.com/pdf/distributed_capacitance_paper.pdf (http://literature.cdn.keysight.com/litweb/pdf/5980-2862EN.pdfhttp://www.datatronics.com/pdf/distributed_capacitance_paper.pdf) we do the same but with low frequency.
Capacitance of transformer is important at resonance. In Lithuania Experiment we had been at audible LF region.
Strong vibration.
Figure 6 shows the phase angle of current plotted against frequency, using a Hewlett Packard HP-4194A. The plot is the same coil as discussed in (2). The resonant frequency is 499 KHz
https://www.researchgate.net/publication/254057540_Analysis_of_the_Complex_Permeability_Versus_Frequency_of_Soft_Magnetic_Composites_Consisting_of_Iron_and_Fe73Cu1Nb3Si16B7 (https://www.researchgate.net/publication/254057540_Analysis_of_the_Complex_Permeability_Versus_Frequency_of_Soft_Magnetic_Composites_Consisting_of_Iron_and_Fe73Cu1Nb3Si16B7)
The complex magnetic permeability of most materials varies with frequency with iron powder peaking when exposed to magnetic fields close to 100 kHz [17].
Iron particles on the other hand have a peak complex permittivity of 50 at around 100 kHz [17].
iron filings are readily available at particle sizes of around 1 μm, and can be readily mixed with water, soil, or in our case, sand particles with average sizes of 1 mm as shown in ...
Wesley
Cherkunov levitation device is pure fake, I was about to debunk his outdoor demo and make a video using trash can lid but I could not find a suitable place nearby my house (two trees on the sides of an open field) its all about fishing line on bright background (sky) and the stick test is so simple to fake that you would laugh, I can tell you how its done but you will be ashamed that you didn't notice how its done.
There is no way on the world to generate such a lift using weak EM and magnets.
Same thing may be about Kapanadze but not that easy, for kapa-hoax I have some ideas but that involves "displacement ground current" in truly russian (and dangerous) fashion.
Right now I have no time for this stuff, working my ass of to survive in ex soviet poor country (bogactwooo macie w tej amerce nie to co u nas w polszy za miedza u putina )
I'm till working on woobling and vibrating magnetic motor project (not OU but just cool stuff)
Thats my two cents for now.
Hi,
Finally i have assemble the Kapanadze PVC support and Antenna after around 1 year of inactivity on this device.
Akula would likely use solid core copper "6 AWG solid core copper" which i used white shrink wrap as shown in yellow marker for Antenna.
This device was oscillating at it's own frequency around 80khz(Sine-Wave from kapanadze winding output) for input frequency around 10khz(parametric waveform, 1/3 sub-harmonics) which the circuit i have assembled was designed to operate at 1/3(Frequency divider) of it's resonance frequency after 3 turn toroid which the L/C resonance test was around 30khz.I had overlooked impedance mismatch back then and did not measure voltage at the 26 turns on toroid after the kapanadze was operating at a higher frequency
Forgot to mentioned tesla coil was on pulse interrupted at around 1.7Mhz around (multi pulse at 55us...60us wide need to re-confirm again base on last trimmer setting)for the accelerated frequency 80khz which appear as pure sine-wave.
I am still the only person in this forum whom did not use resonance since my belief before the findings was the kapanadze winding needs to oscillate at it's own frequency but unknown at that time whether it will go higher or lower than the drive frequency.------------------------------Hint for me was provided in this video of Akula device translated by Wesley.The device winding did look similar to Kapanadze and Akula was applying 1/3 resonance but in the reverse order.Coil was driven at around 55khz but the internal winding was designed to osc at 155khz which is around 3 times of input frequency.
--------------------------------------Reverse engineered Ruslan circuit and found that his device was using divide by12 (6 from 4017 and div 2 from Flip-Flop)
Tesla magic,prime number 3,6,9,12..That's all for now.It's late.
Hi everyone,
Latest findings while fine tuning device..many preparation to do before lift off. :)
Previously i mentioned 4017/74HC4017 configured as divide by 3 for Akula device.But the duty cycle output from 4017 isn't 50% (It's more like around 65% ) even if a 50% duty signal is applied to 4017 clk input.
Today i discovered the output of 4017 from mosfet driver is actually 49.5% and 50.5% since i am using small blue toroid(current sense) with 8 turns after the 3 turns from huge toroid(6mm sq) before the 0.47ufx2 Wima capacitor.The other i/c configured as divide by 3 with 50% duty 4xCLC previously shown in my youtube channel related to programming.This i/c no longer produce 50% duty if combined with current sense transformer.So in another words Akula is a smart guy.
I have attached the a pll image which previously i have made modification for the pll circuit to work.
Only for the experienced just use LM393N portion an combine with current sense blue toroid with 8 turns combine with 74HC14.74HC2G14(SOT23-6).But i am not advising anyone to work on this pll circuit(Tested to be working after minor mod) since resonance isn't the key.
Tuning without HV enabled and w/o Grounding.I noticed that output from 26 turns on toroid is around 422Vpp at around 11khz near square wave with 100nf 2kv CBB cap.The kapanadze out is also connected to 100nf CBB capacitor.Variable supply settings 12.6volts at 1.9Amps.
Quote from: magpwr on September 30, 2018, 09:40:53 AM
Hi everyone,
Hi Magpwr i'm not trying to be clever here but trying to clear my confusion, if my Tesla coil is tuned to, for the sake of argument 1.728mhz it will divide down to a 'base 8' Don Smith chose 31.5khz that's a base 8 and 9 ie base 9 3+1+5=9 the creator the universe, don't know if you know what i'm getting at here but 8 is the other energy that involves the earth..
Anyway the Akula Tesla coil or whatever you want to call it generates a sine wave so in effect if you follow that train of thought your pushing the static field then pulling it, How does that work ? so to get one polarity or the other you need a 10Kv full wave bridge, and if you want to use a spark gap or some other device you need a charge caps up to some sort of timing
looks complicated like a TV EHT fly back thus using the one haif wave to charge the cap and the other as the capacitor dis charge as per Don Smith and Mr TKap'zy.
Your thoughts please AG
Quote from: AlienGrey on October 01, 2018, 09:02:53 AM
Hi Magpwr i'm not trying to be clever here but trying to clear my confusion, if my Tesla coil is tuned to, for the sake of argument 1.67mhz it will divide down to a 'base 8' Don Smith chose 31.5khz that's a base 8 and 9 ie base 9 3+1+5=9 the creator the universe, don't know if you know what i'm getting at here but 8 is the other energy.
Anyway the Akula Tesla coil or whatever you want to call it generates a sine wave so in efect if you follow that traion of thoght uour pushing the static field then pulling it, How does that work ? so to get one polarity or the other you need a 10Kv full wave bridge, and if you want to use a spark gap or some other device you need a charge capst up to some sort of timing
looks complicated like a TV EHT fly back.
Hi AlienGrey,
I can't advise much on Don-Smith.But the only thing i understand is the lower the number of turns like Don-smith the higher the input voltage we need to use like neon-transformer with spark gap.
--------------------Back to Kapanadze the last round around 1 year ago i was using
6x10nf Mica 1000volts rated after 3 turns from toroid combined with
4layers on the primary coil in order to get around 30khz at L/C resonance signal test.
But i overlooked
impedance issue with low value capacitor since i was focused on resonance like the rest and but i was applying 1/3 resonance.The output is nice sine-wave at around 80khz if tuned right and it will stay that way even upon power on.
This time primary winding reduced to 2 layers on kapanadze and capacitor value increased to 0.47ufx2 parallel.
The output of kapanadze will look like this as attached without applying power to telsa coil at around 1.7Mhz.The probe used was x100 but settings was still at x10 re-attached corrected version.My scope is now running on battery power via pure sine-wave inverter after measuring power consumption at 230v outlet to be around 28watts.On 12v battery uses 2.7Amps with scope on.Saved money on portable isolated scope. :)
The device will start hissing once the tesla frequency is right at around 1.7Mhz and the test pen will glow at a distance from ferrite rod to Antenna at 12volts tesla coil supply interrupted pulse at 260ns(each pulse) at around 55us wide for now.
I am still tuning device at the moment with tesla and can't advise much for now and starting to kill IGBT now even with lowered varistor rating 150v from 470v.
Yes that is fast it's almost a |X10-9 a charged partials travel about 12" in that time, I made a PCB for that PLL circuit you published and i made it
I couldn't get it to be Equally Waited on the 4046 output gave up in the end and the pick up circuit was also crap, how have you got the decide by 3 etc
connected up ? one way would be to include a 4013 after the 4046.
AG
Quote from: AlienGrey on October 02, 2018, 06:43:42 AM
AG
hi AlienGrey,
That circuit was flawed which i have shown the amendment made merely at the front end
LM393N.Take note of the suffix.
You will need to use small blue toroid which is large enough to go over the 3 turns.
I can't stop you for trying with 4046 pll.I run from this pll stuff if i were you. :)
I have attached a
obsolete but working PLL circuit which can
lock onto L/C resonance(After 3 turns) between
17khz to 38khz which was saved for my my reference.Phase shift using just 2 gates 74hc14 after LM393N was implemented in my current circuit.
The distorted waveform i have attached previously needs to be dancing or fluctuating constantly without the HV tesla powered on.
This i think will indicate there is ionization happening at the kapanadze coil without tesla coil turned on.
This is just one of the key ingredient.
I just remembered to look for this effect which i forgotten to apply after the last Sunday experiment.
I will stick with battery like the last round.The mains powered scope is never the issue because not many ppl know the scope ground is also connected to scope earth.
I may need to redo the IGBT drive circuit using IR2113 like Akula circuit.But need time to do it on breadboard first.
I have attached image of the semi Tesla Coil then wind as semi Helix coil.Hint was given in Akula video or photo.
I have previously done experiment with
full Helix coil which produce the highest current reading to Earth via clamp meter*Used as indicator but not accurate measurement.
Tesla Transponder 2.0 -Interrupter 1.7Mhz (https://www.youtube.com/watch?v=Yun3HjsNNKs)https://www.youtube.com/watch?v=Yun3HjsNNKs (https://www.youtube.com/watch?v=Yun3HjsNNKs)
Do you mean this one ? https://www.youtube.com/watch?v=PPHipGkfSAY
How many turns are under the blue tape ??????????????????
Quote from: AlienGrey on October 02, 2018, 05:26:56 PM
Do you mean this one ? https://www.youtube.com/watch?v=PPHipGkfSAY (https://www.youtube.com/watch?v=PPHipGkfSAY)
How many turns are under the blue tape ??? ??? ??? ??? ??? ???
Hi Aliengrey,
The video about helix coil was posted in my youtube channel link as shown in previous post.Tesla transponder 1.7Mhz.
I can't recall how many turns left on tesla coil.But it's about the primary outer coil length at 4th top winding from the left.
Drawing shows grenade winding setup
Hi Wesley. For an alternative view regarding how ferrite or iron etc might be used to produce
free energy, you might be interested in George Bugh's ideas about Spin Waves. I don't necessarily
agree or disagree with his ideas, but I find them interesting. He is a very smart guy.
George J. Bugh Videos:
Spin Waves:
Overview_of_Spin_Wave_Technology_part_1
https://www.youtube.com/watch?v=VDEtPGB13NM
Overview_of_Spin_Wave_Technology_part_2
https://www.youtube.com/watch?v=EEMFqOvViDg
Overview_of_Spin_Wave_Technology_part_3
https://www.youtube.com/watch?v=Ge4Ni3ke2I8
Spin Wave Technology part 1
https://www.youtube.com/watch?v=ZkOuGRU8akA
Spin Wave Technology part 2
https://www.youtube.com/watch?v=HjsL1zfmKvA
Spin Wave Technology part 3
https://www.youtube.com/watch?v=craHcstJJZ0
Spin Wave Technology part 4
https://www.youtube.com/watch?v=izlcZPUMkdA
Gravity (I haven't watched these yet, just found them on his youtube channel):
Where Gravity Comes From, Part 1 of 3
https://www.youtube.com/watch?v=lB5qG5wHJ_s
Where gravity comes from part 2
https://www.youtube.com/watch?v=KSbG1vaxSWE
Where gravity comes from part 3
https://www.youtube.com/watch?v=J02-iLzjFbE
George J. Bugh Book (may not be currently available , goes into a bit more detail than his videos):
https://www.vasantcorporation.com/vc002.php
More Info on George J. Bugh and his Spin Waves ideas:
Spin Waves in magnetic levitation and propulsion:
https://www.vasantcorporation.com/downloads/swt_magnetic_levitation.pdf
https://www.kwtx.com/content/news/Scientists-studying-wireless-electric-transmission-in-Central-Texas-494839331.html (https://www.kwtx.com/content/news/Scientists-studying-wireless-electric-transmission-in-Central-Texas-494839331.html)
It's being undertaken by a Waxahachie company named Viziv and it uses a technology they call a surface wave system.
The Viziv surface wave systems will improve the quality of life for people everywhere by enabling the delivery of affordable electricity throughout the world,"
Wesley
Quote from: stivep on October 12, 2018, 08:45:05 PM
Wesley
This tower looks familiar somehow...
Quote from: Void on October 09, 2018, 03:29:10 PM
Spin Waves:
Gravity video 2 made me feel warm and fuzzy inside, when he said something like "do not consider an electron of a solid ball of matter, but rather a quanta of EM energy spinning in a vortice"
HOPPY this one is for you, do you remember some time ago Nelson showed us a board
where he could feed a lamp of something like 12 watts and use it to
feed another controlled 12-watt lamp that could go to full brightness ??
Did you think at the time it was a fraud? Like to know how its done after all this time?
well, it's not! here it's done with 2 35watt bulbs
please note i claim no originality for this technology as my own but respect others wishes.
AG
Quote from: ramset on October 13, 2018, 08:11:37 AM
Wesley
Got a Cowboy Hat and Boots !:'} ?
we might have a member or two close enuff for a field trip ?
would be nice to get some more photos / info [is that thing really there ?]
Chet
32°08'56.46" N 96°56'32.06" W
(imagery from March 2018 in Google Earth)
http://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide (http://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide)
https://www.youtube.com/watch?v=YX0MJjq9MuU&t=171s (https://www.youtube.com/watch?v=YX0MJjq9MuU&t=171s)
it's true? :) :o
Quote from: kolbacict on October 22, 2018, 05:36:04 AM
it's true? :) :o
Wesley
To understand think of Energy Frequency Vibration. Tesla
https://www.youtube.com/watch?v=WJhKXq2GoUY
Quote from: Belfior on October 24, 2018, 05:34:55 PM
Sure this thread and basically this forum is not about whining about different dark powers that are aiming to kill 7 billion people so they could rule more easily.
We gotta do something while we wait for Wesley to give us the plans to the mother ship!
you mean zero point energy! who was that kid who turned his brother into a Christmas tree? on his lab wall is a poster that's a clue !
https://www.youtube.com/watch?v=COH6PLjmJ3o
https://www.youtube.com/watch?v=keLN89CWZ-A
Quote from: jojo500 on October 24, 2018, 05:49:18 PM
that will never happen no matter how long you wait.
I prefer to go back to my bench rather than watch god knows how many videos posted by someone.
And now that I know that I live in the country of "Hitler's chair of Pergerman is Satans "I look from time to time down to the floor and try to look ashamed a bit .... ups did I really say that .. yeah I know germans not allowed to that.
What's that space travel by reverse engineering? look again on google. again you can view the throne on the internet try google (I've seen it) the museum also has some other interesting exhibits to view oh and I lived in Coln in the 80's it was a great place and so were the people.
Regarding the new Dneister video that wesley posted a link to,
Wesley are you certain that is not the same person as before (Adrian Guska/Dneister)?
I haven't really watched videos from that 'Adrian Guska' person before, except for a little bit.
This is some of the comments made for the video:
SlavVjache:
Днестр , привет. Ты здесь ?
что ты домашнюю электронику не бережешь?
Давненько тебя не было , какие новости у тех у кого получилось ?
живы здоровы ?
Dniester, hello. Are you here ?
What do you not take care of home electronics?
Long time you did not have any news from those who got it?
Are you healthy?
Dniester Basarabia:
Сдесь бываю редко нет смысла чтото расказывать и показывать сдесь...
У меня всьо отлично.
У тех у кого чтото получилось те давно ушли в оверлейные сети и I2P
и попасть туда можно по приглашению, ценная инфа хорошо скрыта от любопытных глаз и глупцов.
Dniester Basarabia:
I seldom have reason to tell and show here.
I have a very good one.
Those who have something turned out they have long gone into overlay networks and I2P
and you can get there by invitation, valuable info is well hidden from prying eyes and fools.
[The person who posted this video is saying that those who really have something (in the free energy research area, I presume)
are using private encrypted peer to peer IP communications to keep their discussions of these things private.]
Regarding the video, I find it quite interesting. This person seems to know what they are doing as far as electronics
construction is concerned, and also very odd that they can place their foot and hand right in that quite high voltage
corona discharge arcing and not get some degree of shocks or skin burns. The output current in those discharge arcs seems
fairly high. Maybe he was getting some shocks and skin burns but maybe he is more than a little crazy. ;D If he wasn't
getting any shocks and skin burns, then the question is why not with that apparent fairly high amount of output power?
Anyone have any comments on that?
The video I am referring to is:
"VTTC GU81M Dniester"
https://www.youtube.com/watch?v=Pj_1InKjrHk
Foma Sergeevich
Foma Sergeevich
3 days ago
Well, thank God, alive, and then the rumor on the Internet scattered that banged you.
Dniester Basarabia
Dniester Basarabia
2 days ago
Gossip and slander !!!!
The device is not a Katcher it's something like a Line powered Brovin high power device.
Quote from: Void on October 24, 2018, 11:43:46 PM
SlavVjache:
живы здоровы ?
Are you healthy?
Dniester Basarabia:
Dniester Basarabia:
Just wondering. Is it really arcs FROM the coil, or the ambient going INTO the coil as arcs?
Quote from: Belfior on October 25, 2018, 08:31:30 AM
The yellow flame is his skin burning into pin holes bet it smells nice.
What are you thinking of making an air ionizer energy waster or same thing they are not the same as that thing
is chucking RF energy all around and could me emitting harmful energy wave all around if not correctly sorted!
Maybe there is a reason the Van Allen belts did not kill the astronauts...
This guy drinks heavy water, swims in the cooling pools and eats uranium. He says it is a scam
https://www.youtube.com/watch?v=vkAFu7HQyzY
Hi Belfior. Well, to my way of thinking it is not really arcing until he places his foot or hand or some other
object close enough to the tesla coil that it starts arcing between the tesla coil and the object.
If an object is large enough and at least somewhat conductive, it can act as a sort of virtual ground
even if it is not directly grounded, and you can get some arcing between the tesla coil and the object.
The current flow would be AC however, since the high voltage on the tesla coil secondary is AC, so
I think it is not really in one direction or another. The corona discharge from an object may form around
an object first, and then spread from the object towards the tesla coil, as seems to happen in one part of that video.
That is not really a direction of energy transfer however, if that is what you mean. It is the direction the ionization
in the air took due to spreading electron avalanche.
Quote from: Belfior on October 25, 2018, 10:10:34 AM
seen it he died of leukemia ! Galen Windsor but can't find out when. He talks about 1986 so he was alive after that!
But what he is saying is energy control is a scam by the guv cartels of the world, as if we didn't know the planet is run by Satanic flys ;D
https://www.youtube.com/watch?v=vQTYaL9jCMo (https://www.youtube.com/watch?v=vQTYaL9jCMo)
https://youtu.be/TUdbzgCWFIY?t=899 (https://youtu.be/TUdbzgCWFIY?t=899)
Wesley
thanks Wesley this video (https://www.youtube.com/watch?v=hoqF3gjLIyI) corresponding to the one of my old invention (http://xname41.blogspot.com/2015/12/blog-post_98.html) for reducing power consumption of the high power LED matrix structures. But I went far into the development of this concept as I applied it to the infrared LEDs for efficiency systems for heating through my separate project on this issue
this is my concept (https://i.imgur.com/PJniVIf.gif) but with pauses between pulses
p.s. in the my theme pauses between pulses no used, but this is very important and must have pauses!
Quote from: NickZ on October 30, 2018, 10:19:06 AM
And you think that the U.S. military along with the Black Budget projects don't posses such free energy generators, already??? And, anti-gravity electromagnetic devices and space ships... We are being held in the dark about all this, for as long as possible. But, we need to do something about that. As this forum, along with all the other free energy forums are going no where.
There are no new self running devices being shown, other than magnet motors, etz... What is going on... Nothing new seen from Kapanadze, Akula, Ruslan, Cepren, or even Dr. Stiffler. Or any other guys that have self runners. Are we going to sleep through all this secrecy?
Wake up guys...
Yeah well said that man!
Surgh you're a comedian, right? nice joke any rate ;D
Quote from: Sergh on October 30, 2018, 10:25:09 AM
If the military had such a OU source and anti-gravity, we would have already seen colonies on the Moon and Mars.
But we do not have it!
Because money is spent on stupid guns, tanks, submarines, etc. :'(
You think so ! that's their strategy, they call it the mushroom effect, kept in the dark and fed BS! ;D
ever heard of dreamland and reverse engineering they are already here (rumor has it!
I think there are more and more people waking up and this makes the "dark side" shift gears, because they need to get absolute control before thew majority wakes up.
So free energy is a start and we need to get it out now. This is why people like Kapanadze really make me angry, because what they want is a short term goal that would get them a nice car and a new fridge.
When they launch WW3 and the survivors are under ground, then they can just close the air vents when they want compliance. The trumps are on the Moon or orbit and just wait.
free energy will give us anti-gravity and then the game is up for them. There is no nationalism or racism anymore, when we are out there exploring
More about:
Viziv former
TEXZON
Texzon commercial https://www.youtube.com/watch?v=7mZErR_ZR3E&feature=youtu.be (https://www.youtube.com/watch?v=7mZErR_ZR3E&feature=youtu.be)
Viziv wireless high efficiency Power transmitting technology.
1.Viziv is the successor if
TEXZON
2.Texzon Technologies, LLC Request for Part 5 Experimental License ELS File No. 0924-EX-CN-2017 https://apps.fcc.gov/els/GetAtt.html?id=202374&x (https://apps.fcc.gov/els/GetAtt.html?id=202374&x)
3. they use Zenneck wave propagation as means of communication with the remote of fix load ( cars , houses)
4.TEXZON TECHNOLOGIES CONFERENCE PAPER [DRAFT DATE: March 23, 2016] SURFACE WAVES *AND THE'CRUCIAL'PROPAGATION EXPERIMENT http://vizivtechnologies.com/wp-content/uploads/2016/09/TEXZON_Baylor_Corum16.pdf (http://vizivtechnologies.com/wp-content/uploads/2016/09/TEXZON_Baylor_Corum16.pdf)
4a.THE MICROGRID UNPLUGGED: ENERGY SURETY VIA WIRELESS POWER http://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf (http://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf)
5.Milford testing facility, tower seeks to send signals worldwide http://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide (http://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide)
7. Address of facility from point# 7: IH-35 in Milford, Texas near Dale Acres Rd
8.location of tower look at map and picture below ( this information might be misleading occupied by Russian trolls blog)
https://www.google.com/maps/place/32%C2%B008'57.3%22N+96%C2%B056'31.2%22W/@32.14908,-96.9420261,190m/data=!3m1!1e3!4m6!3m5!1s0x0:0x0!7e2!8m2!3d32.1492354!4d- (https://www.google.com/maps/place/32%C2%B008'57.3%22N+96%C2%B056'31.2%22W/@32.14908,-96.9420261,190m/data=!3m1!1e3!4m6!3m5!1s0x0:0x0!7e2!8m2!3d32.1492354!4d-) 96.9420111
9. web site of VIZIV http://vizivtechnologies.com/news/viziv-technologies-llc-partners-baylor-university-develop-potentially-revolutionary-electrical-distribution-technology/ (http://vizivtechnologies.com/news/viziv-technologies-llc-partners-baylor-university-develop-potentially-revolutionary-electrical-distribution-technology/)
10.
Baylor University (https://www.bing.com/aclick?ld=e3d4RhimKyZ_PUMm-lq3AQ7DVUCUzQAQ6igbb8ASFbmyLPY8dDPo6pm8F6IUDsuamlW-199FYCNoWaCGIbpctrADus6o5QK5HZyf-YJJBM6zndpKSZYDXitOfNjZpbtWNLaGpTwOKoDYzlimYvIWXc8oazW5mfh3jerhiVLcDclKdsbqno&u=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&rlid=c4b42d6b3e561504478b76b3eaedd505) publication about Viziv https://www.baylor.edu/research/news.php?action=story&story=202541 (https://www.baylor.edu/research/news.php?action=story&story=202541)
10a.Wireless power distribution goal of firm's Baylor partnership https://www.wacotrib.com/news/business/wireless-power-distribution-goal-of-firm-s-baylor-partnership/article_84a1f458-0f56-5f96-affe-92c7349120e0.html (https://www.wacotrib.com/news/business/wireless-power-distribution-goal-of-firm-s-baylor-partnership/article_84a1f458-0f56-5f96-affe-92c7349120e0.html)
11. Zenneck Wave explanation https://en.wikipedia.org/wiki/Zenneck_wave (https://en.wikipedia.org/wiki/Zenneck_wave)
12.Excitation and use of guided surface wave modes on lossy media Abstract: https://patents.google.com/patent/US9912031B2/en (https://patents.google.com/patent/US9912031B2/en)
13.Application of power multiplication to electric power distribution https://patents.google.com/patent/US7969042 (https://patents.google.com/patent/US7969042)
14. Total Funding Amount of Viziv $38.3M https://www.crunchbase.com/organization/texzon#section-overview (https://www.crunchbase.com/organization/texzon#section-overview)
15.
QuoteThis guy owns the patent:https://www.teslasociety.com/corum.htm
please look at it as a quote from source. Dr. James F Corum
16.
QuoteKen Corum is currently chief scientist for TEXZON Technologies (http://www.texzontechnologies.com/) in Red Oak, Texas, where his research is finding practical applications. https://www.evangel.edu/press_releases/2017/03/25/tesla-wireless-electricity-corum/ (https://www.evangel.edu/press_releases/2017/03/25/tesla-wireless-electricity-corum/)
17.Viziv Founding rounds https://www.crunchbase.com/search/funding_rounds/field/organizations/last_funding_type/texzon (https://www.crunchbase.com/search/funding_rounds/field/organizations/last_funding_type/texzon)
18.
QuoteDr. James F Corum looks at the Philadelphia experiment through the critical eyes of a scientist.
relate this to point#15
19.
Quotehttps://www.youtube.com/watch?v=AGglyC8QEnk&feature=youtu.be (https://www.youtube.com/watch?v=AGglyC8QEnk&feature=youtu.be) Dr. James F Corum looks at the Philadelphia experiment
20.
QuotePhiladelphia Experiment Al Bielek https://www.youtube.com/watch?v=QoJzt_FR7zc&feature=youtu.be (https://www.youtube.com/watch?v=QoJzt_FR7zc&feature=youtu.be)
21.
QuoteMontauk Project Al Bielek https://www.youtube.com/watch?v=8BOsC2CrLfo&feature=youtu.be (https://www.youtube.com/watch?v=8BOsC2CrLfo&feature=youtu.be)
22. Viziv: about us: http://vizivtechnologies.com/about-us/ (http://vizivtechnologies.com/about-us/)
23. I see it as not related but interesting :Superconducting Super Collider https://en.m.wikipedia.org/wiki/Superconducting_Super_Collider (https://en.m.wikipedia.org/wiki/Superconducting_Super_Collider)
24.
>Quote
They are straight up building what Tesla said could be done years ago.
A Texas company pushing to commercialize an idea championed by famed inventor Nikola Tesla more than a century ago has recruited help from Baylor University.
Viziv Technologies will be getting help from Baylor students and instructors as it works to develop a way to distribute electricity wirelessly over long distances.
The company's work focuses on the use of "a phenomenon known as a Zenneck surface wave to transmit electromagnetic waves along the interface of earth and air,"
according to a Baylor press release announcing the partnership.
Viziv is also working to develop use of Zenneck waves in communication, navigation and sensing, according to the press release.
It leases about 3,000 square feet in the 330,000-square-foot Baylor Research and Innovation Collaborative, where it has done research since 2013.
It has a total of about 30 employees between locations here and in Waxahachie and Milford.
"History is replete with examples of the power of people and organizations coming together to do what would be impossible individually,"
President and CEO Michael Miller wrote in the press release.
The company is backed by more than $50 million from investors, spokesman Michael Taylor said.
This will be its first partnership with a university.
Good fit Baylor's strong programs in electromagnets and power systems make the partnership a good fit,
Viziv Chief Technology Officer Randall Jean wrote in the press release.
"As an electrical and computer engineering professor at Baylor, my colleagues and
I were among the first to move our research into the BRIC in 2013," Jean wrote.
The Zenneck surface waves the company hopes to develop commercial uses for are "unaffected by lightning, geomagnetic disturbances,
solar flares or electromagnetic pulses such as those generated by a nuclear blast," and are "virtually impervious" to the physical attacks
and cascading failures during peak use that threaten the power grid, according to the press release.
"Currently about 17 percent of the world's population have no access to electrical power, and for many more people, availability is
spotty and unreliable," Baylor Vice Provost for Research Truell Hyde wrote in the press release.
"This technology has the potential to raise the standard of living for people around the world. Who wouldn't want to be a part of something like that?"
Viziv expects to double its employment over the next year, the press release states.
"We had a short-term agreement with Baylor to begin work and now have seen the arrangement extended," Taylor said.
"Our ultimate goal is to commercialize as many applications as possible. We have a number in the works but would prefer to keep those internally at this time."
The Baylor Research and Innovation Collaborative now has seven relationships with the private sector, including
L3 Technologies, which employs about 900 people locally, said Whitney Richter, spokeswoman in Baylor's Office of the Vice Provost for Research.
quote from https://www.reddit.com/user/Tha_Dude_Abidez (https://www.reddit.com/user/Tha_Dude_Abidez)
25. Quote
According to the website of the Waxahachie-based company website, Viziv Technologies is a pioneer in the field of electromagnetic wave propagation,
power storage, and electricity distribution. One of the technologies under development by Viziv is to create wireless power systems.
The site notes the company has a portfolio of more than 65 U.S. and international patents.
Testing at the tower and laborites in Milford will start in the fourth quarter of this year.
The Federal Communications Commission has already established the ranges of frequencies that will be used in the test.
The frequencies range are in use in the public and private sector.
"We will be doing interval testing that will be several minutes in nature in the beginning," Taylor explained.
"As we progress and fine-tune the system we will be extending (the test) where it could go for days and even weeks at a time to test the ruggedness of the system and its components."
Taylor explained the field strength used in tests is comparable to an AM radio and poses no danger to people or animals.
The test will work to establish a global signal at a very low frequency from a single location without using repeaters.
Thirty field intensity-monitoring stations placed at different sites around the planet will collect data from the tests.
Information gathered from these sites will be set back to be evaluated through a secured Internet and allow Viziv to gauge the signal's strength.
"Testing could range anywhere from six months to a year, just depending on how they go and what we see," Taylor stated.
"Then we will move on to the second and third major phases, which is the testing on the tower on Milford. Those revolve around other applications with the potential for energy transfer."
Taylor states some of the potential uses for the technology are in the areas of regional and global positioning systems, radio navigation, and very low-frequency radio communication.
This type of radio communication is not used for audio transmissions but to send small data packets.
He noted the U.S. Navy uses VLF radio to communicate with submarines and can be used to send a signal like Morse code.
quote from forum by F4STW4LKER
26. for comparison Tesla Tower https://www.youtube.com/watch?v=7mZErR_ZR3E&feature=youtu.be (https://www.youtube.com/watch?v=7mZErR_ZR3E&feature=youtu.be)
I have made some analysis :
shape of shadow is matching pictures and proving that this is Viziv tower ( the successor of TEXZON )
a capacitive electrode (top load) (E) in the form of a smooth metal sphere or torus (https://en.wikipedia.org/wiki/Torus) attached to the secondary terminal of the coil. Its large surface area suppresses premature air breakdown and arc discharges, increasing the Q factor (https://en.wikipedia.org/wiki/Q_factor) and output voltage.
This looks like internal part of the tower capacitive electrode but not like external dome of that capacitive electrode
For comparison to Tesla Coil https://en.wikipedia.org/wiki/Tesla_coil (https://en.wikipedia.org/wiki/Tesla_coil)
For these skilled in digging check building department of buildings in county district of Ellis County in Milford TX to obtain plans of the structure
the plans and building permits may be available on line
https://www.countyoffice.org/tx-ellis-county-building-departments/ (https://www.countyoffice.org/tx-ellis-county-building-departments/)
https://www.countyoffice.org/tx-ellis-county-property-records/ (https://www.countyoffice.org/tx-ellis-county-property-records/)
http://esearch.elliscad.com/ (http://esearch.elliscad.com/)
Milford is a town located in extreme Northern Central Texas in the southwestern corner of Ellis County, Texas United States.
The population was 749 in 2008.
Milford is located at 32°7′22″N 96°56′48″W / 32.12278°N 96.94667°W / 32.12278; -96.94667 (32.122701, -96.946553).
In Google map you see underground early stage of the structure https://www.bing.com/search?q=milford+tx+map&pc=MOZI&form=MOZLBR (https://www.bing.com/search?q=milford+tx+map&pc=MOZI&form=MOZLBR)
Here is the link to Map . You can zoom in and out, exactly on that structure by orienting on roads around
after logging into the map press control key and turn wheel on your mouse
http://www.texas-drilling.com/ellis-county/milford (http://www.texas-drilling.com/ellis-county/milford)
orient yourself at Ruth 35E and local road 308 up from Milford
look at picture from below :
How to find Viziv Tower
Wesley
Smart Meters Warning ! https://www.youtube.com/watch?v=gRR_u3oooHw
Realy they did some tests on radio wave smog in this country on bees and found in close proximity to mobile phone transmitters and a single
cell phone close to a hive and onlt 28% could find there way back if it does that to them what are they doing to us. with a smart meter, it's constantly nattering all the time.
HOWfar from long island are you !
Most people never even heard of HAARP,
THE HAARP SITES ARE LOCATED GLOBALLY WHERE THE RICHEST MINERAL BELTS ARE LOCATED. SUBSURFACE MINERAL EXPLORATION HAS BEEN DONE FROM SATELLITES BY RADIOTOMOGRAPHY THAT IS 100% ACCURATE.
I wouldn't want one especially on the other side of my sitting room wall with outa lead liner around it apart from the fire hazard
https://www.whatdotheyknow.com/request/haarp_installations_in_uk (https://www.whatdotheyknow.com/request/haarp_installations_in_uk)
Wesley
Why is it everyone with a vested interest in a given technology are always the first to claim it's 100% safe when obviously it's not?. Because they are willing to put their own interests before that of everyone else. There are decades of research which proves EM radiation in fact does harm.
https://www.ncbi.nlm.nih.gov/pubmed/24053963
https://www.ncbi.nlm.nih.gov/books/NBK208983/
http://www.who.int/peh-emf/about/WhatisEMF/en/index1.html
https://www.nature.com/articles/s41598-017-18953-z
https://www.intechopen.com/books/biomedical-engineering/biological-effects-of-electromagnetic-radiation
The difference between us is that I did the research and understand the many risks involving RF radiation and continue to do FE research knowing the risks. However to just ignore the risk simply because you have a vested interest and tell others there is no risk is dishonest.
There are more than enough business people killing people with there products due to there own ignorance... we don't need any more.
As asked for information on GLOBAL HONEYBEE PROBLEM
https://www.youtube.com/watch?v=dY7iATJVCso
1.https://www.ncbi.nlm.nih.gov/pubmed/24053963 (https://www.ncbi.nlm.nih.gov/pubmed/24053963)
2.https://www.ncbi.nlm.nih.gov/books/NBK208983/ (https://www.ncbi.nlm.nih.gov/books/NBK208983/)
3.http://www.who.int/peh-emf/about/WhatisEMF/en/index1.html (http://www.who.int/peh-emf/about/WhatisEMF/en/index1.html)
4.https://www.nature.com/articles/s41598-017-18953-z (https://www.nature.com/articles/s41598-017-18953-z)
5. https://www.intechopen.com/books/biomedical-engineering/biological-effects-of-electromagnetic-radiation (https://www.intechopen.com/books/biomedical-engineering/biological-effects-of-electromagnetic-radiation)
Wesley
On the Viziv
I did start a topic here
http://www.energeticforum.com/renewable-energy/21067-tesla-tower-texas.html
Member Ernst has expressed his opinion [he has Mini Wardenclyffe }
Chet
Quote from: ramset on November 02, 2018, 01:20:16 PM
On the Viziv
http://www.energeticforum.com/renewable-energy/21067-tesla-tower-texas.html (http://www.energeticforum.com/renewable-energy/21067-tesla-tower-texas.html)
Chet
Thank you for the link my friend
Wesley
Quote from: NickZ on November 02, 2018, 11:11:55 PM
Concerning the box? A riddle, perhaps...
My reply is that it would be so cold inside as outside the box.
No solar heating in Deep Space. So, most of the deep space crafts built up to now are nuclear powered, not solar powered, even though some may show solar panels. There is no light in deep space.
My point is that the creation of light on our planet, is not something that is "coming" from the Sun, as we are still being told.
So, what is this so called "Sunlight", and how do we create or manufacture it, for free? Without needing to burn things up...
There is no smoke traces inside the Great Pyramid, nor in any of the underground tunnels and chambers. "Got it"?
Yet, there are signs of glassified stone temples, possibly from previous nuclear explosions, or wars, many thousands of years ago.
I hope that it helps you to understand where I'm coming from. However, I'm not trying to convince, anyone, just trying to relay a message, to look outside the box, as well.
Hello there Nick yes i hear what you're saying only to well what NASA has told us quote no light till it hits our atmosphere but
the moon doesn't have one so how did Neil or was it Buzz kill the camera by pointing it at the sun and why wasn't the moon 'pitch black?
I can\t truly say as i have never been off planet yet but in saying that light is a wavelength isn't that like a radio wave?
A photon according to Science programmes on TV travels through space but on piggyback.
https://www.youtube.com/watch?v=yNntDhr2n4g
look at 36;24 how can you have an electromagnetic wave in nothing?
You might also be interested in capturing transferring and releasing energy
https://www.youtube.com/watch?v=_pKapNKJsU8
PS don't trust NASA they are like atoms they make up EVERYTHING ;D
Quote from: F6FLT on November 03, 2018, 07:08:51 AM
"the creation of light on our planet, is not something that is "coming" from the Sun, as we are still being told"
"The Sun is NOT like a nuclear reactor"
"Photons will polarize toward a light source, thus creating light"
"the sun can't radiate heat in a vacuum"
"the East coast of America is the most haunted place on the planet"
I am very impressed by the density of nonsense and misinformation per unit of line length in this thread.
The photon is the quantum of electromagnetic energy that is exchanged between matter and the electromagnetic field. Sunlight is the electromagnetic field indirectly produced by the sun's nuclear fusion reactions.
This is easily verifiable by observations, measurements and all kinds of experiments made since the end of the 19th century. That is why scientists produce today countless useful and real products. The current technology is the proof of the veracity of their knowledge while the pretentious uneducated people who deny it by the Dunning-Kruger effect have never produced anything but pathetic blah, blah, blah. Otherwise, ignorants and followers of conspiracy theories, where can we find the real products of your great thoughts?
Sorry for my reaction, it's only my fault, it's due to a severe, irresistible and now irremediable allergy to stupidities, and even more, to the vain and conceited spreading of these stupidities. :'(
Well when you scatter one's pearls of wisdom in front of swine one can occasionally expect them to be downtrodden into swill ;D
Hoppy Nick, I know what Nick means as I have seen either Buz Aldrin or Edgar Mitchell say it's our atmosphere that lets us see stuff from space and light.
True or not I can't say.
question why is space black ?
https://starchild.gsfc.nasa.gov/docs/StarChild/questions/question52.html
But what Wesley is asking us about his cube is their aren't too many atoms to give the heat too so how can you dissipate it too?
Nick, thanks for expanding on your understanding.
https://www.universetoday.com/136802/can-astronauts-see-stars-space-station/
This is a working link to the same PDF file:
https://www.rcpsych.ac.uk/pdf/NevilleHodgkinsonGoodNewsYouAreNotYourBrain.pdf
Gyula
Quote from: gyulasun on November 04, 2018, 05:55:14 AM
https://www.rcpsych.ac.uk/pdf/NevilleHodgkinsonGoodNewsYouAreNotYourBrain.pdf (https://www.rcpsych.ac.uk/pdf/NevilleHodgkinsonGoodNewsYouAreNotYourBrain.pdf)
Gyula
Thanks for that Gyula. I recommend the reading of Dr. Eben Alexander's book - Proof of Heaven.
Quote from: F6FLT on November 04, 2018, 01:35:43 PM
NDE is not proof of heaven. There are also negative NDEs, while the people who experienced them were just as respectable as those who had positive experiences. NDEs are only proof that we don't know everything about the brain, but no one claims that we would know everything about the brain.
Believers and the enlightened always try to place the paranormal or the religious in what is beyond human knowledge. Human knowledge is increasing and many places where religion had placed its mysteries have been swept away by science.
In the past we saw lightning as the wrath of Jupiter, rainbow as Diana's scarf, we wondered what the poor man with a harelip had done against God to punish him in this way, we saw the devil in the epileptic, we saw famine or epidemic as divine punishment... All these absurdities have fortunately been eliminated and ridiculed by rational thought and its ability to demonstrate that it was only superstition.
Unfortunately, the lessons of the past are not learned by irrational people who today reproduce the same mistakes as their elders, seeing divine creation in the big bang, AIDS as divine punishment, heaven in NDE or free energy in the raised stones of Stonehenge.
Jupiter? the ruler of Jupiter in my memory of Greek mythology was Apolo (a satan representation and of the American Freemasonry statue of liberty also) as for a spirit world your
in no position to quote either way on that one.
Have you ever come across a guy Michel Newton and his publications 'destiny of souls this subject was very popular in the tun of the minimum 2001
He found we had many many lives as if we are trapped in some sort of loop, I'm afraid I think he might have a point where we are part of a spiritual
a group with players we are each connected to and a purpose to fulfill in our lives journey,m there are others like John Edwards with that same gift or
curse depending on your view but one instinctively knows if someone you're connected with dies.
Some comment about Selflooped FE currently in Patent office
https://youtu.be/cywvTgiTebQ (https://youtu.be/cywvTgiTebQ)
Wesley
Have a look at this then https://patentimages.storage.googleapis.com/31/3b/ba/b873f8fea482c7/US6362718.pdf
What is "electrostatic phenomena" ? What makes some peace "electrostatic" ? How you measure it ? What is is POINT ?
Quote from: forest on November 06, 2018, 02:00:21 AM
Simple go to Google prompt, type in your question, look for an answer. Click on one.
answer https://www.google.co.uk/search?q=electrostatic+phenomena&rlz=1C1CHBF_en-GBGB813GB813&oq=%22electrostatic+phenomena&aqs=chrome.1.69i57j0l5.18836j0j8&sourceid=chrome&ie=UTF-8
Hi Forest. I think by 'electrostatic phenomena' Wesley may mean 'electrostatic induction', but
Wesley would have to explain exactly what he means there. :)
If we are talking that version, Electrostatic charge use to be a problem in the 60s back in the days of nylon clothes and shoe soles and particularly in high rise apartments and offices particularly when touching a metallic filing cabinet. It was also a big problem for the early 50s and 60s RAF pilots with the fuselage charging up with high altitude static potentials with deathly results til they started putting carbon etc in with the rubber mixture.
Tesla and others used laden jars to collect the stuff as they were made of glass.
Hi Wesley and members,
I am posting this Anomaly related to accelerated frequency output as just discovered from the kapanadze device of Akula.I also considered this device a Electron accelerator device.
The output of the kapanadze coil with 10nf 2kv ceramic cap and 5watt bulb in parallel produce around 36khz unfiltered waveform.In Akula circuit there is a low frequency line filter then a 5nf cap is connected at output.
But the input of the IGBT gate is driven at around 12khz.This is without powering on the Tesla coil yet.The 26 turns of toroid does seems to play a role only if 40nf 1kv ceramic capacitor is connected at it's output as shown in video.
I am still little lost as this is achieved merely by trial and error method using various hv ceramic capacitor at my disposal.
My youtube video posted today to reveal this Anomaly related to the input and output frequency.Screenshot was extracted from uncut video.
https://www.youtube.com/watch?v=_o2Ecwd71lU (https://www.youtube.com/watch?v=_o2Ecwd71lU)
Using resonance nothing new was achieved since output frequency would be the same as the input frequency.Kapandze coil would behave like a step up transformer but Air core.
Yes i am little lost at this point also because the last round i achieved pure 80khz sine-wave at output only if tesla coil was activated.But 100nf 2kv cap was used at output.But i did not record all the configuration made the last round around 1 year ago.Then took a year break from this device.
Hi Magpwr
Congratulations for your work.The last scheme that is out there...maybe it helps!
See the green and red circle, feeback to the IR 2153 oscillator.
https://postimg.cc/7f8dFy3x
Tynoo
Magpwr,
https://www.youtube.com/watch?v=JzSBWJu24gU
Quote from: Hoppy on November 07, 2018, 05:43:50 AM
Magpwr,
https://www.youtube.com/watch?v=JzSBWJu24gU (https://www.youtube.com/watch?v=JzSBWJu24gU)
Hi Hoppy,
I have seen the video have also achieved the d
amping type of waveform for some other configuration depending on the capacitor value used at output coil.She tried to show 1/2 and 1/3 harmonics as well but the waveform does looks very distorted.
Honestly the hint i have not mentioned but was shown in Tariel Kapanadze video.
Tariel was actually using much lower frequency via spark plug in order to shock kapanadze coil to self oscillate at a much higher frequency than the input.If you try pulsing a typical step up coil manually(low frequency)you may get bulb to light from the back emf.
But in order to power higher load there would have to be some kind of high frequency ringing happening in the kapanadze like coil.
This which we have not figured out on how to unlock fully.
Akula was using around 1.7Mhz much higher frequency to achieve similar feat.
The only trick left is how to apply low frequency to unlock kapanadze coil such that it will yield higher frequency.
Magpwr,
Magpwr and hoppy, both interesting videos isn't it golden ratio you want here? ie 1,2,3,5 etc
I tried using a pic chip a few years ago to generate the sequence with EW 50/50 outputs it starts to get complicated
with a micro and you need a vast amount of memory and you get jitter and 4 bits is the maximum.
If you look at the TK glass box the backboard has a pile of power transistors and other components
you don't suppose e is using simple logic to get golden ratio numbers and thus harmonics as an accelerator.
Any way to decide by 3 is easy with a CD4013 and a CD4093, as an xor gate it couldn't be easier
I will post a circuit later.
Read the section entitled: 'ON THE LIGHT PHENOMENA PRODUCED BY HIGH-FREQUENCY CURRENTS OF HIGH POTENTIAL AND GENERAL REMARKS RELATING TO THE SUBJECT.' in the following link:
https://teslauniverse.com/nikola-tesla/articles/light-and-other-high-frequency-phenomena (https://teslauniverse.com/nikola-tesla/articles/light-and-other-high-frequency-phenomena)
Is Kapanadze using a Tesla plasma lighting effect using high frequency and high potential on regular light bulbs to achieve high illumination from a conversion of a low power, low frequency input??
Hi Wesley. In my opinion, unless a person can at least show a video reasonably demonstrating that a
particular configuration produces 'over unity', or at least shows an interesting or unusual effect,
then any 'theories' and schematics, etc. that someone presents are likely not going to get too
much traction. It will likely just be seen as more unproven speculation to be added to the mountain
that can already be found here. This should really be a given at this point. :)
7. look at video https://www.youtube.com/watch?v=zg8V9XCgIqs (https://www.youtube.com/watch?v=zg8V9XCgIqs) ( no sound)
Fabrication of a KNO3 capacitor
Explanation of the video is in point below Note2a
Ferroelectric Capacitor
The construction of a KNO3 capacitor, and the hysteresis loop it displays.
The circuit used is the standard Sawyer-Tower circuit.
From TLP: Ferroelectric materials, http://www.msm.cam.ac.uk/doitpoms/tlp... (https://www.youtube.com/redirect?redir_token=r45Jl3cL7SRh50ErEBXfmaYFQQB8MTU0MTc4MjU0N0AxNTQxNjk2MTQ3&q=http%3A%2F%2Fwww.msm.cam.ac.uk%2Fdoitpoms%2Ftlplib%2Fferroelectrics%2Ffabrication.php&event=video_description&v=I_PFO4xIgJQ)
the link is not working but: there is copy here explaining what video is about https://www.doitpoms.ac.uk/tlplib/ferroelectrics/printall.php (https://www.doitpoms.ac.uk/tlplib/ferroelectrics/printall.php)
For these who want to know more https://www.doitpoms.ac.uk/tlplib/ferroelectrics/index.php (https://www.doitpoms.ac.uk/tlplib/ferroelectrics/index.php)
It will help also to look at:
https://www.youtube.com/watch?v=p7SkE5pERtA (https://www.youtube.com/watch?v=p7SkE5pERtA)
Ferroelectric capacitor
https://en.wikipedia.org/wiki/Ferroelectric_capacitor (https://en.wikipedia.org/wiki/Ferroelectric_capacitor)
Wesley
Note#3
from video https://www.youtube.com/watch?v=zg8V9XCgIqs (https://www.youtube.com/watch?v=zg8V9XCgIqs)
Square hysteresis:
QuoteWhat the square S-curve hysteresis loop means is that, in one region of operation, with only a very tiny voltage change,
you can get a rather enormous current change from that capacitor.
In another region of operation, you can get a very large voltage change from the capacitor for a very small current change.
In other words, biased into one region, you have essentially a voltage device.
In the other region, you have essentially a current device. Neither device will "cost" you very much energy to operate it in its region.
However, if you then nonlinearly mix the two outputs just right, as we filed on methods of doing, then bingo!
You had a mixer device whose output now had both large current and large power, but you "paid for" and input not nearly so much "energy dissipation"
(remember, engineers calculate energy dissipation flow, never energy transport flow!)
to the mixer as what would be output by the mixer.
The whole question is this.
We all know about ordinary nonlinear mixing and mixers.
We know that two signals can indeed be mixed nonlinearly.
Can we build a nonlinear mixer and a dual circuit, where we feed a voltage-like signal in and also a current-like signal in
to the mixer, get the two combined into a high voltage, high current signal output, and do that without back-field coupling onto the two input "signals"
to force equal energy dissipation in the input
3aFabrication of a KNO3 ferroelectric capacitor A capacitor can be made from potassium nitrate (KNO3), which is ferroelectric below 120°C.
(The temperature dependence of ferroelectrics will be explained later.)
The following video clip shows the construction of a KNO3 capacitor, and the hysteresis loop it displays.
The result is a hysteresis loop.
This arises from the fact that a system does not respond immediately to a given set of external conditions.
Rather, there is a history dependence and this is the basis for memory (two states are possible in E=0).
doitpoms@msm.cam.ac.uk, © University of Cambridge DoITPoMS, Department of Materials Science and Metallurgy, University of Cambridge
3b.Tom Bearden:
QuoteFerroelectric Capacitors and the Magnetic Resonance Amplifier
In a nonlinear ferroelectric capacitor there are three major nonlinear processes involved, so it is possible to carefully choose and arrange
conditions so that the current through the capacitor moves against the voltage across its terminals.
With adroit switching and timing, and some consideration for resonance effects, it is in theory possible to use such highly nonlinear effects in a circuit to allow
(1) an overpotential at the terminals of the battery as a reaction from the ferroelectric capacitor,
(2) consequent recharging of the battery via that back potential on the battery side, while the load is also being powered,
(3) consequent driving of the load on the load side of the terminals, and
(4) having a bypass ferroelectric capacitor across the terminals of the battery, where the capacitor is in the "current against the voltage" condition.
McLain and Wooten patented a great little MRA (magnetic Resonance Amplifier) system, based on that application.
Dr. Robert Bass, a very fine electrodynamicist of exceptional knowledge, experience, and ability wrote the patent for them, and assisted in their work.
For that he was persecuted, unjustly attacked, and suffered financial difficulties.
The "system" does not forgive highly qualified scientists who take a serious interest in "perpetual motion machines" — as permissible Maxwellian
open dissipative systems are erroneously and derogatorily labeled by the orthodox scientific community.
Any scientist violating that inquisition suffers the consequences.
After technical discussions back and forth, the Patent Office even notified
Wooten and McLain that the patent had been accepted and the patent would be issued.
Within days, to their consternation the patent was rejected and that was the end of that.
Wesley
Quote from: stivep on November 08, 2018, 09:16:36 PM
Note#3
Square hysteresis:
3a
3b.
Tom Bearden:
Wesley
hi stivep,
I recall there was mentioned of
S-curve hysteresis capacitor as one of the important requirement in one of the free-energy device i can't recall if it was Don smith or someone else.This was way before i even stumble upon Kapanadze discussion.
I can only recall fragmented information from my memory (Only Human)-There was mentioned of one of the American base company that manufacture this type of
S-curve hysteresis capacitor for the Navy or military.The last thing i can recall from my head that this type of capacitor was not available to public.Around 10years have past from my last research related to this cap.
Hi Wesley, So how big is this capacitor and how do we build such a capacitor to work in this device and have you any more build information?
SolarLab thank you for update
Thank you very much to speedy125 (https://overunity.com/profile/speedy125.79102/)
The new member for helping me to find links with Ferrocapacitor
Please look at:
topic
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Replay #6264 March 31,2011 Page 418 https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280009/#msg280009 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280009/#msg280009)
#6297 April 03,2011 Page 420 https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280255/#msg280255 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280255/#msg280255)
#6304 April 03,2011 Page 421 https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280291/#msg280291 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280291/#msg280291)
#6309 April 03,2011 Page 421 https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280301/#msg280301 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg280301/#msg280301)
Page 624 https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg307131/#msg307131 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg307131/#msg307131)
Wesley
NONE LINEAR CFAPACITORS
https://www.ferrodevices.com/1/297/files/chapter4-theoryofferroelectriccapacitors.pdf
THE TESLA TOWER
https://www.youtube.com/watch?v=7ATzLkr9JXk&feature=youtu.be
http://eng.sepc.ac.cn/images/mbs1.png do you see energy here ?
I see energy every where. :)
everything is energy a wave to be exact
Should I say some of you are completely ignorant?
You do not see immediate money than you do not care about me and anything else.
I do not accuse you about lack of understanding due to the fact that the sucker game is at your level of everyday study.
I'm getting help from Country of Tesla, but not much from you yet.
That's because perhaps we are having issues comprehending how it actually works at this stage.
I don't use ''understand'' as the word means just that to stand-under to admit to a contract of control :-X its a legal terminology from class levels
unlike to comprehend something ;)
Quote from: F6FLT on November 11, 2018, 05:50:27 AM
The MEG is a fundamental misunderstanding of Bearden that is tirelessly maintained from year to year as an urban legend, while of course it has never provided any energy.
This misunderstanding consists in believing that a parametric modification is made at a zero energy cost (the Steorn motor was based on the same error). Of course not.
In order for the switching coils to change the permeability of the controlled area, they must supply energy.
E=-dΦ/dt is always correct but different from -L*di/dt when L is not constant. When there is a change in permeability, L changes, and therefore the correct formula is E = -dΦ/dt = -d(L.I)/dt. This means that the product of the instantaneous values of I AND L must be integrated over time.
This is a consequence of the superposition of fields: although permeability is modified when the fields change, two fields from two sources always simply add up at any time but taking into account the instantaneous values of permeability and fields at this exact time.
The fields add they do not multiply! However, a modulation is a multiplication, not an addition. Therefore the flux from the Bearden's switching coils cannot modulate another flux, the result is only the sum of the two at any given time and the counter-EMF from the payload affects both.
Thanks for that I posted it out of interest to others, but at the same time one should note just because someone has a patent on something doesn't mean it works 8).
Also has any noticed backchat on the net that NATO is taking over western world governments in 2030 won't this mean the end of world individual sovereignty and the rule of the military eval flys? the age of Aquarius and the Georgia stones. :-\
https://www.youtube.com/watch?v=YhjHzdDYRXA (https://www.youtube.com/watch?v=YhjHzdDYRXA)
Chet have you been on holiday Wesley already commented ;D ;D on this link last week
I suppose one could always salvage the nitrate from a cold pack and mix with potassium (salt) minus the sulphate wait to crystal and wala!
see if it works
The ferro cap re-see charge circuit so what's the difference between this cap and a bunch of super caps or a load of poly film dumping it's
energy into a tank coil at the bottom of a tuned Tesla coil, to get energy out you need to put it in just remember that too frequency and
capsize are critical.
Has anyone tried using a triac instead of a spark gap that way you can lower the voltage but current can then be a problem?
Speedy 25
Hi Wesley!
Surface waves-general knowledge :
1. https://cosmolearning.org/video-lectures/surface-waves-2/ (https://cosmolearning.org/video-lectures/surface-waves-2/)
1a. same but in PDF http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf (http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf)
Review of Electromagnetic Surface
Waves: 1960 Through 1987 (Naval Weapons Centar) https://www.bing.com/ck/a?!&&p=00f3c31d269f6574JmltdHM9MTY3NzU0MjQwMCZpZ3VpZD0zN2IwYzNmMC1jZDk4LTYzNDUtMWZmYi1kMTM2Y2NkYjYyNzImaW5zaWQ9NTE1OA&ptn=3&hsh=3&fclid=37b0c3f0-cd98-6345-1ffb-d136ccdb6272&u=a1aHR0cHM6Ly9hcHBzLmR0aWMubWlsL3N0aS9wZGZzL0FEQTE5NzI3OC5wZGY&ntb=1 (http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf)
Isolation of the Zenneck Surface Wave: http://www.ee.ucl.ac.uk/lcs/previous/LCS2011/LCS1137.pdf (http://www.ee.ucl.ac.uk/lcs/previous/LCS2011/LCS1137.pdf)
https://youtu.be/wIIABIU3tRw?t=541 (https://youtu.be/wIIABIU3tRw?t=541)
For these who are into understanding surface wave please watch this video from the beginning.
https://en.wikipedia.org/wiki/Forbidden_knowledge (https://en.wikipedia.org/wiki/Forbidden_knowledge)
Wesley
corrected link:
http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf (http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf)
QuoteBarlow and Brown define a surface wave as
"...one that propagates along an interface between two different media without radiation,
such radiation being construed to mean energy converted from the surface-wave field to some other form (Reference 7)."
Since this definition covers a lot of territory, one of the major problems
with the surface-wave literature is
the proliferation of different names for what is essentially the same physical phenomenon (References 2 and 8 )
These waves:
-Zenneck,
-Norton,
-Sommerfeld-Goubau,
-inhomogeneous, -
radial,
-axial,
-azimuthal,
-lateral,
-creeping,
etc.-are all (at least in some sense) a type of or associated with a type of surface wave.
Throughout this report we will try to clarify all such terms and use them correctly
in association with the appropriate physical geometry or guiding process
From the quote of article (link above)
we see that:
1. Viziv used Zenneck Wave as one of the names.
2. that may be intentional as:
a- there is little to none publicly available literature about it.
b.-There is estimated half of a billion dollars at stake from the investors.
c.- investors must contribute and do not understand to much
d.- public must do not interfere and do not understand to much
2. form of phenomena in question can be ironically simple but just in some part of it
matching one basket of
all of mentioned names for Zenneck waves
3. Viziv might not have patent rights to any of these waveforms so how they can protect their investment?
By means of scrambling access to the receiver that must match the same algorithm
to gain access to energy that is already converted to Zenneck wave or any other name they hide it at.
By simple words:
You have Viziv transmitter and the receiver is like your satellite dish.
The satellite signal is out. All you need is to access it. and that is what you are paying for
- the code.
But if you just couple straight right into the Zenneck Wave or whatever name you give to it they going to go bankrupt.
But if you use your own energy from your own water mill and use Zenneck Wave as means of transportation than you can sale it to your neighbors
or power your own electric car in withing boundaries of your own area of coverage. ( city , county, state)Picture :
Red rectangle: explains controversy about different names associated with Zenneck Wave
Blue rectangle: explains simple conditions needed for Zenneck Wave and its associated other names for the same, to exist.
At the bottom of the page #4 please look at propagation phenomena and types of waves:
-Transverse electric
-Transverse magnetic TM
Transverse magneticTM is the wave that is mentioned in :
https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf (https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf)
by Viziv.And now all you need to do is:
- to use the other names used for the same and google it.
- try to find the sense and possible similarity in wording to article published by Zenneck associate
- Try to match statements for both.
All of that does not require knowledge, it is just simple way to compare text.
So what might be the outcome of your work?:
- money
- ideas for new solution, competitive to Viziv.
- freedom from "energy distribution guys"
- or the best of all.. turning it all to mutual use for general public.-
if you can overcome your selfishness. Wesley
Quote from: AlienGrey on November 13, 2018, 08:55:46 AM
Ferroelectric capacitor is a capacitor (https://en.wikipedia.org/wiki/Capacitor) based on a ferroelectric (https://en.wikipedia.org/wiki/Ferroelectricity) material.
Traditional capacitors are based on dielectric materials.
1.Ferrocapacitor keeps its state unchanged till it is changed
Another "animal" that is similar to ferrocapacitor and using using different names is:
varicap diode, varactor diode, variable capacitance diode, variable reactance diode or tuning diode
2 Capacitor usually decays in time by itself
2a Ferrocapacitor usually needs someone to push it for change.
Wesley
https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969 (https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969)
QuoteExcitation of the Zenneck wave is examined for both finite and infinit vertical apertures over a homogeneous conducting flat ground.
The infinite vertical aperture with a Zenneck wave variation is found to excite only the Zenneck wave with NO radiation field.
The finite vertical aperture excites a field which is similar to the Zenneck wave near the aperture but resembles the usual ground wave at large distances.
Numerical results for various aperture heights are given for frequencies of 1 and 10 MHz. Both homogeneous ground and sea water paths are considered
From that we know that vertical apertures over a homogeneous conducting flat ground. -Are the one responsible for phenomena known as
Zenneck wave with NO radiation fieldhttp://nedyn.com/Goubau_1951-X.pdf (http://nedyn.com/Goubau_1951-X.pdf) This is original uncut German article in English translated by
James F. Corum, Ph.D.
CPG Technologies, LLC
February 17, 2015
Wesley
Wesley...PDF here on original uncut ......reads 404 now [Not found
http://www.nedyn.com/Goubau_1951-X.pdfThis (http://www.nedyn.com/Goubau_1951-X.pdfThis) is original uncut German article in English translated by James F. Corum, Ph.D.
I thought I checked it when you first posted it was good ...but now NG..at least here in NE USA
Chet
Quote from: ramset on November 14, 2018, 11:25:58 AM
Chet
I did correct it .
and there is some striking revelation about Zenneck Wave in the picture below.
Yes it is striking.
Think about coverage of entire earth.
Wesley
Zenneck wave is a well-known science.
His teacher was Sommerfled who was the originator of eigenmode theory in waveguide. So far there has not been anyone capable of disproving any of Sommerfled's theories.
Quote from: stivep on November 14, 2018, 11:47:56 AM
I did correct it .
Yes it is striking.
Wesley
Chet
James Corum has done a great job in proving the existence of Zenneck wave. He is also a IEEE member.
https://wikivisually.com/wiki/Zenneck_wave
Hi SolarLab,
I didn't have any problem with the duplication after having realized that the cable ends must be sort-circuited, not open.
One end is connected to the FG via a coaxial T-shaped connector with a short-circuited middle input. However, my jumpers have a slight impedance so that a small part of the signal passes through and is reflected back and forth many times. For the same reason the scope probes at each end pick up the signal on the jumpers.
The first picture shows the comings and goings of a 16ns pulse repeated at a low rate of 797KHz so that we have time to see the reflections in the time of each period.
We can see that the attenuation at -3dB allows more than ten round trips of the pulse, which indicates low losses.
The second image is the signal of the 5 superimposed sine waves generated by the FG, at a frequency of 15.94 MHz for the lowest (the others are multiple).
The last image is the signals probed at the ends of the cable, FG side for the yellow trace, and the other for the purple trace.
The time between the maximum of one trace and the minimum of the other corresponds to the travel time of 30 ns in my 6 m line, velocity coefficient 0.66c.
This is the temporal signal while Gorchilin's animation showed the spatial representation, so it is necessary to do some mental gymnastics to understand that the two correspond, except that the amplitudes of the positive and negative oscillations are not exactly balanced, I don't know why.
Don't trust the volt level of the traces, I had a problem with a probe and the impedance multipliers of the probe are not declared correctly in the scope (but this is not related to the positive/negative imbalance).
In any case, a standing wave is always the superposition of at least two progressive waves which propagate in opposite directions. Progressive waves are always "hidden" in standing waves, so for me the Gorchilin's configuration is just a phase arrangement, it doesn't bring anything new. Spatially the energy is still static.
Reason for the study:
Viziv wireless tower to transmit energy around the earth
with no wires.
due to:
strong statement from Viziv officer and scientist James F. Corum, Ph.D.CPG Technologies, LLC February 17, 2015
who says in his paper, nothing less than -
inverse square law does not apply so there are no losses. (in horizontal plane- along the earth)The exact wording used is:
Quote if the total current strength in every source-segment remains invariable the field strength at any distance from the source also remains alike.
The field of the Zenneck wave for a certain normalized sheath-current strength may be designated by EB, HB Let the frequency be the same as that of the dipole.
and
K.L. Corum, Brigadier General (Ret.) M.W. Miller, Ph.D., and J.F. Corum, Ph.D
SURFACE WAVES and THE' CRUCIAL' PROPAGATION EXPERIMENT*
QuoteLet us assume that such a current density has been set up along the surface of the Earth, emanating from some injection point
(This condition has been established in practice with the use of Texzon's field-matched surface wave probes.)
By the generalized form of Ohm's law, such a current creates a radial electric field,over an equivalent circular aperture of infinite radius on the x-y plane,
and
QuoteZenneck wave ( is a transmission line mode) without exciting the radiation field!
In point:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527200/#msg527200 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527200/#msg527200)
PART#2 of Introduction to Zenneck Wave for beginners
what is interface:
look at picture below.
-The
Zenneck wave,
Zenneck surface wave or
Sommerfeld-Zenneck surface wave is an inhomogeneous
or non-uniform electromagnetic plane wave incident at the complex Brewster angle onto a planar or spherical boundary
interface between two homogeneous media having different dielectric constants.
[1] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-1)[2] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-2)[3] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-Goubau_1951-3)[4] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-Barlow-Brown_1962a-4)[5] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-Collin_2004-5)[6] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-Corum-Miller-Corum_2016-6)[7] (https://en.wikipedia.org/wiki/Zenneck_wave#cite_note-Corum-Corum_Bell_2016-7):p. 198
- https://cosmolearning.org/video-lectures/surface-waves-2/ (https://cosmolearning.org/video-lectures/surface-waves-2/)
-https://en.wikipedia.org/wiki/Zenneck_wave
Summary of part #1 and part #2:
-Most of literature for surface wave is dedicated to visible light bandwidth of TEM( transverse electromagnetic wave) -Viziv mention that some experiments have been conducted at frequency of
150 MHz. Fig. 3.
- 52 MHz Fig. 4.
- 1.82 MHz (Photo 2.)
- frequency of few Hz as low as Shumann frequency , was also mentioned but I lost link to article.
QuoteFig. 3. Burrows' 1936 measured Seneca Lake data over a range from 1 m to 2 km. Curve (1) is the lossless inverse field (Hertz).
Curve (2) is the van der Pol-Norton ground wave over a lossy medium (Seneca Lake) with measured data. Curve (3) is the
Sommerfeld-Zenneck surface wave over a lossy medium (Seneca Lake). Curve (4) is the lossless dielectric surface wave.
Curve (1) (the "inverse field") varies as 1/r. Curve (4)varies as 1/√r.
Burrows used a dipole antenna at 150 MHz.
at- https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf (https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf)
This technology may be also related but may not be as well. to Tariel Kapanadze Free Energy device.
I have witnessed his device working and found it legit.
But there was report that when Tariel presented his device on the island , lights in Motel from the other side of the water dividing Island from steady land lost its power for around 70%
This was the Motel where crew of Tariel Kapanadze was residing during the show time.
So it this is true than
Motel was acting as transmitter of energy and Tariel device on the Island was acting as receiver.
https://youtu.be/qdJ1V_yDv-c?t=684
If that is so than Tariel Kapanadze has the rights to the technology on the ground of priority rights of the earlier filing date.
He filed his application in 2008.
That application was rejected
Wesley
Hi, this looks like a retro pic from a practical television mag!
https://www.youtube.com/watch?v=qdJ1V_yDv-c&feature=youtu.be&t=684
See doctored image below!
Quote from: F6FLT on November 24, 2018, 07:14:22 AM
Related to Goubau's article, it should be noted that the propagation depends strongly on the nature of the surface.
Zenneck waves/ surface waves - do not radiate. They move along the interface. They are invisible in perpendicular plane ( vertically) above and below the interface (earth surface).
Long and medium radio waves propagate very well over the sea, which is a much better conductor than the land. Spain is about 400 km from my position with only the Atlantic Ocean in between. Spanish MW radio stations are perfectly received here with strong signals, even during the day, while stations 100 km away in the countryside are poorly heard.
Anyway, I am not able to extract here the slightest milliwatt from the hundreds of KW sent from Spain.
Yes you are. https://www.radio-electronics.com/info/rf-technology-design/rf-noise-sensitivity/receiver-signal-to-noise-ratio.php (https://www.radio-electronics.com/info/rf-technology-design/rf-noise-sensitivity/receiver-signal-to-noise-ratio.php)
Gain of your antenna is directly responsible for that mW..
Assuming frequency of all listed by you signals is within AM bandwith, than:
- direction of propagation
- Line-of-sight propagation ( terrain ) https://en.wikipedia.org/wiki/Line-of-sight_propagation (https://en.wikipedia.org/wiki/Line-of-sight_propagation)
- attenuation of the ground vs sea.
- distance is always obeying inverse square law.
And that is what makes some of AM station from particular direction of far away stations stronger.
Radiant energy is useful only if the energy receiver is coupled to the transmitter, which involves interaction between transmitter and receiver, otherwise the energy is not directed towards the receiver, and it is radiated even if no load is connected, which is a total waste
Antenna of Tx is the load to that Tx.( transmitter)
So if you apply Dummy Load instead of an Antenna than
-Dummy Load is purely resistive matching impedance of Tx , and all energy is dissipated by that load.
No radiation is taking place!!. https://en.wikipedia.org/wiki/Dummy_load (https://en.wikipedia.org/wiki/Dummy_load)
Radiant Energy: https://en.wikipedia.org/wiki/Radiant_energy (https://en.wikipedia.org/wiki/Radiant_energy) obeys inverse square law rules.https://en.wikipedia.org/wiki/Inverse-square_law (https://en.wikipedia.org/wiki/Inverse-square_law). radiation is taking place in all directions
(unless limited by characteristic of an antenna)
Based on material pointed by Viziv inverse square law does not apply to Zenneck Wave ( zenneck surface Wave)
QuoteNorton surface wave, other types of surface wave are the non-radiative Zenneck surface wave or Zenneck-Sommerfeld surface wave,
they are the trapped surface wave and the gliding wave. https://wikivisually.com/wiki/Zenneck_wave (https://wikivisually.com/wiki/Zenneck_wave)
Wesley
Sonoluminescence was covered by me in https://youtu.be/op4GgbE8xWI?t=388 (https://youtu.be/op4GgbE8xWI?t=388)
Wesley
Quote from: NickZ on November 24, 2018, 05:50:57 PM
AG:
Don't know what clip you are referring to.
The quote strip on that post takes you to it, does for me. It's close to the end
1898 11/30
"Tesla Describes his Efforts in Various Fields of Work" Electrical Review
As to the idea of rendering the energy of the sun available for industrial purposes, it fascinated me early but I must admit it was only long after I discovered the rotating magnetic field that it took a firm hold upon my mind. In assailing the problem I found two possible ways of solving it. Either power was to be developed on the spot by converting the energy of the sun's radiations or the energy of vast reservoirs was to be transmitted economically to any distance. Though there were other possible sources of economical power, only the two solutions mentioned offer the ideal feature of power being obtained without any consumption of material. After long thought I finally arrived at two solutions, but on the first of these, namely, that referring to the development of power in any locality from the sun's radiations, I can not dwell at present. The system of power transmission without wires, in the form in which I have described it recently, originated in this manner. Starting from two facts that the earth was a
conductor insulated in space, and that a body cannot be charged without causing an equivalent displacement of electricity in the earth, I undertook to construct a machine suited for creating as large a displacement as possible of the earth's electricity."
The mistake is assumption he thought about solar panels.
Quote from: NickZ on November 24, 2018, 09:20:32 PM
If that video at the end is from Old Scientist, well, he could barely light a florescent bulb, from his wireless transfer video while using big bike wheel sized coils, and a spark gap set up.
His test on wireless transfer from one coil to the receiving coil was about 8 inches distance, and barely and unevenly lighting a florescent tube. Not too impressive, nor the video that you posted a link to. Jacking the voltage up by a factor of 3, but unable to show it doing anything. Oh, the capacitor stores it. Like for a rainy day?
The device from YT video that you posted previously from jb-n107lab, was shown self running, and there is a recent video made about 4 months ago. Interesting... and supposed to be self running, as shown in his previous video. While no other self runners are being shown, at least that I'm aware of.
Don't be fooled by the lack of wasted radiation into space the focus is along the tube with bifilar wound L1 but that wasn't the focus there it was the waveform in
the blue box generated by the 'spark gap' was producing a 'SNAP' effect like a 'pistol shrimp'! he shows a threefold back for 1 in with that setup. Watch it again and observe every detail. see graph on the bottom of the previous page.
Related to Goubau's article, it should be noted that the propagation depends strongly on the nature of the surface. Long and medium radio waves propagate very well over the sea, which is a much better conductor than the land. Spain is about 400 km from my position with only the Atlantic Ocean in between. Spanish MW radio stations are perfectly received here with strong signals, even during the day, while stations 100 km away in the countryside are poorly heard.
Anyway, I am not able to extract here the slightest milliwatt from the hundreds of KW sent from Spain. Radiant energy is useful only if the energy receiver is coupled to the transmitter, which involves interaction between transmitter and receiver, otherwise the energy is not directed towards the receiver, and it is radiated even if no load is connected, which is a total waste.
Any DX er will tell you the signal is bounced off the ionosphere relating to its wavelength a bit like Luxembourg in the 60s pop culture but is that true? but how much POWER can you really capture from RF smog? When i was a school kid there was this old guy in phoneadeck's R&D he was an amateur radio enthusiast he had some homebrew radio with a triode and an output pentode 10 watts he could put a 100watt bulb in the output load an output the thing to over full brightness blackening the inside coating with a static charge on the outside. Explain that.
Quote from: stivep on November 24, 2018, 08:53:46 AM
The waves described in Goubau's article (http://nedyn.com/Goubau_1951-X.pdf) of which you provided the link propagate along the surface, and consist of the magnetic component that is along the surface, and also the electrical component that is in a vertical plane, perpendicular to the surface on which the wave propagates, but is vanishing a few wavelengths above. Although it propagates on the surface, the wave occupies a volume above the surface (of at least a half-wave height).
Any wave that propagates by carrying energy, radiates by definition. The waves in Goubau's paper radiate. If they didn't radiate, we wouldn't need the hundreds of KW that power AM radio transmitters. It is the fact that the wave carries energy from the source that makes us call it a "radiant wave".
Radiant waves are a solution to remote energy transmission only if they are focused between transmitter and receiver. This does not depend on whether the wave is a Zenneck wave or not, but on the ability of the wave to maintain its energy volume when it moves. When the Zenneck wave is an electromagnetic wave transmitted from a radiant pylon antenna, it travels in all directions 360° around the pylon, while remaining along land or sea surfaces.
If you want a wave that doesn't spread, you don't need Zenneck waves especially, but solitons (https://en.wikipedia.org/wiki/Soliton).
The problem is that we don't know yet how to produce this type of wave in free space (even on a surface).
This might be off topic but has anyone come across ARTICLE 13 IT COULD KILL THE INTERNET IN THE eu over copyright FULL STOP
STOP IT BEFORE IT BECOMES LAW!
Part #3 Zenneck surface Wave for beginners :
this part will be re edited during today and more information will be included.
For these who do not yet realized how important this study is to the whole world please go to links below:
1. historical path
Picture #3
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
https://patents.google.com/patent/US20180183128A1/en (https://patents.google.com/patent/US20180183128A1/en)
https://patents.google.com/patent/US20140252886A1/en (https://patents.google.com/patent/US20140252886A1/en)
2. relation to major players in Viziv.
a.-Dr. James F. Corum (Ph.D. in Electrical Engineering, Ohio State 1974)
b.- Kenneth L. Corum(B.A. in Physics, Gordon College 1976; Engineering graduate studies at U. Mass.)
Comment: relation between these two Corum - they might be brothers.
c-Brigadier General (Ret.) Michael W. Miller (B.A. University of New Orleans 1981; MBA University of North Dakota 1988; Ph.D., Walden University 2011.)
Comment : this US Army General is a medical doctor Healthcare management professional
but he is now
- President and CEO of TEXZON Technologies (Red Oak, TX),
-and President, Viziv Technologies, LLC
d.-http://vizivtechnologies.com/about-us/ here you have rest of the guys in Viziv
impressive list of people big money big corporations and oil industry interest.
Wesley
Selected by date chronology of posts about VIziv estimated half a billion US $ investment in energy transfer without the wire.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526668/#msg526668 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526668/#msg526668)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526966/#msg526966 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526966/#msg526966)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527019/#msg527019 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527019/#msg527019)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527029/#msg527029 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527029/#msg527029)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527045/#msg527045 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527045/#msg527045)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527048/#msg527048 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527048/#msg527048)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527240/#msg527240 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527240/#msg527240)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527282/#msg527282 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527282/#msg527282)
Thank you Francis from France for your participation 73.
Quote from: AlienGrey on November 25, 2018, 06:00:38 AM
It's true. It's the great discovery of the radioamateurs with the first US/France (F8BF) contact in shortwaves in 1924 while at this time it was thought that only long waves could reach long distance. Then shortwaves were used everywhere in the world.
A radio transmitter is an alternating current generator.
Compared to the mains current of electricity suppliers, it is only the frequency that changes. The former works in frequencies from tens of KHz to hundreds of GHz, the later at 50 or 60 Hz.
So when you connect a lamp to a radio transmitter, the lamp is simply powered by a current at 7 MHz or 145 MHz for example, while when you connect it to the mains, the current is at 50 or 60 Hz.
The difference is in the possible couplings. At frequencies starting from MHz, the dimensions of coils, capacitive plates, lines... have significant dimensions compared to wavelengths, which makes their coupling, possibly by tuned circuits, easy and efficient at some distance around the wavelength, by recovering almost all the power supplied by the transmitter.
This is not the case at 50 or 60 Hz where there is hardly anything but the core transformer that couples efficiently, with primary and secondary very close to each other unlike RF couplings.
When the waves propagate along the surface of the earth or the sea (daytime propagation of waves in AM radio), they spread all around the antennas. Even if there were no loss in the ground, even if the antennas were very directional, the attenuation would be in 1/r².
When they are reflected on the ionized layers of the high atmosphere, only part is reflected (the rest is lost in space). They can also be reflected several times between the ground and the ionized layers as in a waveguide, attenuating with each reflection. In all cases they also spread out, which implies attenuation in 1/r² in addition to all other attenuations. This is the reason why the radio receiver receives only few µV to hundreds of µV that must be amplified. A good receiver amplifies the signal by up to 130 dB so that it can be used, it is enormous, which underlines the extreme weakness of radio signals after a long path.
About Luxembourg in the 60s pop culture, their transmiter had a power of 1300 KW (http://exvacuo.free.fr/div/Radio/Audio-Video-Photo/RTL%20208/RTL%20208%20-%20Station%20announcement,%20broadcasting%20with%20the%20power%20of%201.3%20million%20watts.mp3) (it's a mp3 jingle :) ) in the 1970's, and the signal could be heard even in Canada during night propagation which allowed reflections on the ionised atmospheric layers.
Quote from: F6FLT on November 25, 2018, 01:27:50 PM
What let you think that there are waves? Funny idea.
Maybe this video might change your views, or not. https://youtu.be/5AUA7XS0TvA
There's a lot more than just waves out there. It's the "Cosmic Soup" which Tesla and others have mentioned, repeatedly.
Quote from: stivep on November 26, 2018, 06:14:50 AM
The result to us is simple.
Russians might push Tariel to give it for free to the world.
And not because the Russian government is so kind and nice, but because Russians will have no choice.
They rather let all world energy industry suffer instead of just Russians being punished by lack of sale of their gas and oil.
And that is why word [/sub]"if" is important in science .
Wesley
yeh what if? well if they do can they please do it before the EU which is probably a Vatican controlled gagging order to kill the internet with its evil article 11 the hyperlink and 13 other peoples CONTENT BOTH ARE USED IN OUR DAILY USE HERE!
and THUS plunges us back into the dark ages, and Russias idea of free energy is most probably a stick of radioactive material coated in a semiconductor material
with power cables running from it. JOKE. Yeah so bring it on! Mint the Burman cat gives a groaning agreement ;D
But wait couldn't we find some way to use their evil laws against 'THEM'?
Wesly very interesting post thanks foir that one!
Can I get your opinion on this one (i'm OK on translation. but is it BS or fact without actually building it ?
https://www.youtube.com/watch?v=F8q8CWTjpAY
I would appreciate any positive feedback on this post
NickZ in the PDF 'cold war secrets' it talks about sharp narrow pulse and a long recovery period a relay' if you look at Nelson's
old website on YouTube most of his stuff was started with a battery and a vibration sound he showed a modified relay coil
why not start there but I think you will need to experiment for the correct timing of the LC and on off ratio. Mind boggling! 8) 8)
Quote from: Void on November 26, 2018, 11:05:34 AM
Hi Wesley,
Have you seen anywhere where anyone associated with Zenneck wave research is claiming
that a COP > 1 can be achieved using Zenneck wave technology? Wireless Power transmission
on a large scale is cool if someone can make it work, but if it if it doesn't produce a COP > 1 then
it seems it is not all that significant.
COP more than one is nothing new or uncommon.
https://www.quora.com/What-is-the-difference-between-efficiency-and-COP (https://www.quora.com/What-is-the-difference-between-efficiency-and-COP)
But as Nick Z said we do not know what kind of implication by means of interaction we can expect from Zenneck Wave and its consequences in physical world.
Wesley
Quote from: NickZ on November 26, 2018, 10:27:42 AM
AG: Nelson will not totally disclose his secret, as well. Why don't you start there, instead? Let us know how it goes.
because I'm working on other ideas and already stretched with lack resources and if we all work on different
things we might get somewhere if we help each other
What happened to the view that electron stress produced an excess of charged-energy pos and neg separation? back to the old hammer shrimp again?
Quote from: AlienGrey on November 26, 2018, 10:11:26 AM
https://www.youtube.com/watch?v=F8q8CWTjpAY (https://www.youtube.com/watch?v=F8q8CWTjpAY)
Power supply has limited current.
like weak person holding the pile of wood in more or less comfortable position, so his summary vector of power dissipation
uses more or less energy for holding the same load with or without additional losses.
ratio between both primaries winding is 1:1
ratio between primary and secondary is 1:1.5
Power
Supply is limited with current. Control light-bub at PS indicates more or less comfortable to the PS dissipation of available power.
But Energy dissipated at the grid ( outlet) will show you no gain.
And the experimenter does not provide us with any measurement of power delivered to the PS.
There is nothing interesting here taking place.
Wesley
Quote from: stivep on November 26, 2018, 11:10:51 AM
Wesley
Hi Wesley. Yes, I know what 'COP > 1' represents. :)
So, I take it from your response then that you are not aware of anyone associated
with Zenneck wave research claiming a COP > 1 is possible. The reason I was asking you
this is because Kapanadze has demonstrated an apparent COP of roughly around 60
(based on the the measured power input compared to the approximate power output to the
light bulb bank. There is no indication that I have seen that Kapanadze was using 'Zenneck waves'.
This idea can only be speculation without any indications at all that he was doing so.
Quote from: Void on November 26, 2018, 01:56:12 PM
That is interesting Void.
Power measured before interface with traditional equipment not prepared to see real power of Surface Wave should show ZERO 0V
Tariel did show Self Runner but connected to the ground. By that relation of COP is 0V ratio to value of dissipated energy at the output, measured by the load in W.
I agree that :
QuoteThis idea can likely be a speculation without any indications at all that he was doing so.
However
QuoteI'm not aware of anyone associated
But what about the losses?
What about the inverse square law?
By traditional understanding of laws of conservation of energy ( thermodynamics) there should be no gain unless some kind of interaction I'm not aware of is present.
Also some statements in Zeneck papers about no losses in relation to the distance from transmitter to the receiver are difficult to be accepted.
But I might be not enough educated in
Zeneck Surface Wave science.
Just the fact that they mentioned it is not only risky if presented in front of patent office but courageous.
The origin of no losses can be analyzed as well. I do not want to look funny by claiming gain of unknown origin , equaling losses so net value is zero.
That is why they did not say it in their patents, but in scientific paper
In this case:
Quote, if the total current strength in every source-segment remains invariable the field strength at any distance from the source also remains alike.
page 5 under the picture.
Wesley
Quote from: NickZ on November 26, 2018, 06:32:52 PM
That's unfortunate Wesley, that you "can do nothing with it". Tesla could. I know what to do with it, so did Kapanadze, but you still don't believe him, nor me. That's ok, I'm not trying to convince anyone. I know there are others out there that will understand, and know what to do with it. Concerning where any extra energy comes from. It's the action that counts, words are not enough to see empirical results. And guys like Kapanadze are where the action is at. Good thing that he knew what to do with it. You saw the proof first hand, that was not enough for you?
https://www.youtube.com/watch?v=Q_ApR2IxBcY
Think the way Tesla did. Earth is metallic conductor of minimal resistance due to immense size. It's like a slide of very thick copper wire. So we know if a wire is powered by electric current there is magnetic field around the wire. The disturbance in this magnetic field in very small area around the wire cannot dissipate if the wire is insulated and very thick - like Earth.
There is a documentary in YOUTUBE with the guy on the technical guy on site talking about it, he wasn't denying any of it. I found it looking up surface waves it also said HF waves are bounced of the ionosphere and ULF bounce back to earth onto its surface so it is really related. I'm sorry if the other effects it produces don't agree but it's a really eval device.
Part #4 Zenneck surface Wave for beginners :
For these who do not yet realize how important this study is to the whole world please go to links at the bottom of this post.below:
Transmitter and receiver of Zenneck Wave.
Today I'm presenting schematic and Transmitter of Zenneck Surface wave.
Not much to say. Think about AC source 213
-as multiform and multiphase signal of the same amplitude and of very high power.
or
-as the same form but multiphase signal of the same amplitude and of very high power.
Power is send by energy units per time frame, presumably without losses. (Wesley: Well I have problem to accept it as of yet )
This is Viziv secret to scramble access to this energy by creating algorithm that must be used by receiving station/ electric motor ship/ electric car/
to access the energy transmitted in this form.
In addition internet and all communication( TV/telephony/ digital) including some form of submarine communication may take advantage of use of the same means of surface wave.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527284/#msg527284 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527284/#msg527284)
Wesley
Quote from: AlienGrey on November 27, 2018, 02:53:35 PM
No but jb-n107lab has taken his self-running video's down he hardly has any vid's now, there was some Russan or Lithuanian guy sounded like Dolometo
I can't find his website anymore and others too.
point is is it because they are all fakes as Hoppy says or did they work ? Still as you say it all helps to pass the time ;D ;D
PS thanks for skimatic info on part 4 will look through hyper links with interest.
AG: Here is jb-n107lab youtube site: https://youtu.be/QGo0Dd663ow Last video was posted about 4 months ago. I think that all his videos are there, still.
Quote from: NickZ on November 27, 2018, 04:25:02 PM
AG: Here is jb-n107lab youtube site: https://youtu.be/QGo0Dd663ow the Last video was posted about 4 months ago. I think that all his videos are there, still.
tHAT IS WIERD! with your hyperlink it goes to it but if I view his videos it does not list them, unless i grab the video name and search for that name and
it does come up with the three-part 7,6 and 4, if you listen carefully there is a tone with a slower pulse (spark gap cap dump of energy into the coil, well that's
what it sounds like.
Hoppy: The idea with Dr. Stiffler's "diode loop" is that there is no need to provide the needed amperage to the leds.
But with just some fluffy voltage, and tiny amount of mAs, the diode loop along with the gutted AC led bulbs themselves would provide and manufacture their own juice to power the bulbs. "Energy out of thin Air". And that part of it does work as he has stated. Unlike the 0.7v drop that most normal diodes circuits would lose, on each diode placed in line. But, other than that, I don't see all that much benefit, nor is there the normal lumen levels at the bulbs, either. Yet my diode loop system is self running while connected to my small solar panel which maintains the batteries up, each day. And may be a more economical way to go, than using just the simple bulbs and batteries. This is all very hard to prove, because once you connect anything up to the circuit, like scopes, multi meters, etz... You just messed up, how it all works. So, in case you don't understand where the Doc is coming from: https://youtu.be/8VRqf8E8VIM
Nick,
Dr Stiffler refers here (https://www.youtube.com/watch?v=7lbYjqU48Mw) to: "a special frequency that's been known about for hundreds of years being picked up by his PSEC. Self-running - yes, so long as the signal is maintained. Have you worked out what this signal is yet? I would stick with your solar panel to get sufficient milliamps needed to light up your LED's to a usable brightness.
Quote from: NickZ on November 28, 2018, 10:55:20 AM
His explanation sounds like BS to me! Fluffy voltage?? He fails to show how he is generating the AC signal shown on the schematics.
Quote from: Hoppy on November 28, 2018, 11:37:01 AM
Nick,
Hoppy:
Not sure where he said that, about the special frequency, but he has mentioned that the 13.5MHz signal is what has worked best for him. My crystal oscillator works best at 12Mhz, and the output at the L3 coil is also a steady 12MHz. Although I tune my coils to 13.5MHz, they seam to work better using the 12MHz crystal oscillator frequency. My rig is on day and night. The Doc is using a 25v signal generator, for testing and also to provide the AC signal to the diode loop. If that is what you were wondering about. It has been shown on his previous videos
The PSEC self runner project may have been running on at a different frequency, which I don't recall at this time.
What special frequency has been going on for hundreds of years, is unknown to me. But, it's still about energy from thin air.
In any case, it is much easier to fine tune onto the "special frequency" with the SG, than a fixed oscillator, with only moveable ferrite cores to tune with, which don't actually change my frequency, at all. Yet, there is an increase in output at the bulbs while tuning, although the running frequency stays rock steady.
I don't know IF the Docs concept concerning the amperage provided by the diode loop along with the led bulbs is correct, or not. But there is something, to the line of switching diodes, along with the series placed led bulbs, that raises the voltage, compared the amount of wattage that would be used normally. Some of these oscillators can run on flea fart power, while producing some minimal light levels. It's all interesting, in any case. Still the lower lumen levels are the bottle neck, here, in comparison.
Fluffy voltage was a term that I placed there, not the Doc. However, look at how much amperage jb-n107lab used to start his rig with. So, fluffy voltage it is. Believe it or not, it's up to you.
Nick,
Dr. Stiffler refers here (https://www.youtube.com/watch?v=7lbYjqU48Mw) to: "a special frequency that's been known about for hundreds of years being picked up by his PSEC. Self-running - yes, so long as the signal is maintained. Have you worked out what this signal is yet? I would stick with your solar panel to get sufficient milliamps needed to light up your LED's to a usable brightness.
Hoppy SPECIAL 'Freq' if you put 13500000 into your calculator both 1+3+5 = 9 remember what John Lennon said about it also 13500000/ both 9 and 8 divide with no remainder, in fact, any number that a multiple of 432 and some others will work
You both mentioned A Gustov I couldn't get that Tesla coil to work the sec is too large and too far away from the secondary input something wasn't right for a start if you wind the sec input winding closer to the Tesla winding you get a sine wave ;) that's just an ordinary Tesla coil even Tesla couldn't get any gain out of that ;) he pulsed his but if you do that the waveform is the wrong way round (a loss) too many actions without a reaction back The trumpet has to go nose on the left to open out on the right! not the other way round I tried a test rig and mine was the wrong way round :D :D :D :D :D :D
A few years ago a Russian speaking guy sent me a scope shot of his drive is that fast or what ? notice the frequency it's a bit of a beast with two 8s to back it up >:( 8)
Quote from: AlienGrey on November 28, 2018, 01:08:57 PM
Hoppy SPECIAL 'Freq' if you put 13500000 into your calculator both 1+3+5 = 9 remember what John Lennon said about it also 13500000/ both 9 and 8 divide with no return, in fact, any number that a multiple of 432 and some others will work
OK, so where is that RF frequency coming from to power Dr. Stiffler's PSEC shown in the video link I posted earlier, as it is not connected to a SG?
Quote from: Hoppy on November 28, 2018, 01:18:31 PM
every thing i got to work of sorts has had to have an earth and a battery or snake oil to run it,
Last minute revelation:
From Ansis from Latvia.at 7:30 AM of Latvian Time.
Hi, Wesley! I think I know the answer to the 1000 000$ question.
In my previous post I made a simple discovery, Tariel Kapanadze is ordinary man, genius.
That is it! How he made amplification of energy to 1000X? I listen all his tapes. Resonance!!!+ Synchronization!!!+ Capacitance!!!+ Ground wire, which is Amplifacation source!!!
How to make it simmmmplyyyy? (smile) Answer is very simple.
We need 555 timer, which works in the frequency of transformer, which is ordinary TV or whatever Hi Voltage transformer with Tesla schematic, diode and Capacitor at the end.
Next, we need Ion Wind channel! We change "gap" and we synchronize all processes of charge/discharge/self charge.
But!!! Ion Wind tube is Not ORDINARY!!! There is section, which "suck the Earth Electrons" and collect all energy in the Capacitor or Battery!!!
LiPo battery or Lead. It is little cheating, but not much!
In fact I was able to catch that effect, and my 2 mates from Latvia was able to catch it too, but we don't understand, because all go to flames or in big massive explosion! Yes, it's very simple!
Note! When effect comes, 300 Ohm resistor will start burn out! Voltage on battery will start go up. I just play with Ionization...
This is only my observations - in one moment everything will go out of Ohms law.
I don't know how to make "ground electron suction", but that is Kapanadze secret, I know.
All Chubinidzes, SR and others do the same. Magnetic Field is an exchange between processes.
We see fat wires in all setups. It is why there is 5KW.
related to picture #2
Solution of ground electron energy can be taken from/with transformer which we add in the schematic. It is only my speculation!
Wesley
Hoppy:
In that video I think that he has the oscillator connected only to the grids ground on his SG.That is an old video, so hard to remember, but he never took the device outdoors away from everything. He thought that he didn't need to. But, he does need to do that. However, I now know that there is no way that stray AC alone could cause the LEDs to be able to light that bright.
"This so-called Zenneck wave is simply a vertically polarized plane wave solution to Maxwell's equations in the presence of a planar boundary that separates free space from a half space with a finite conductivity. For large conductivity -- this depends on the frequency and dielectric constant, too -- such a wave has a Poynting vector that is approximately parallel to the planar boundary. The amplitude of this wave decays exponentially in the directions both parallel and perpendicular to the boundary (with differing decay constants)."[/font][/size]
http://web.mit.edu/redingtn/www/netadv/zenneck.html (http://web.mit.edu/redingtn/www/netadv/zenneck.html)
Quote from: stivep on November 28, 2018, 01:35:29 PM
Wesley
I'm not surprised looking at that circuit diagram!
It was in old times, when I try to make efficient Ionisation and work with Ion Wind generator. Today I decide to tell about it to Wesley. Idea is simple. Very very simple. Kapanadze is genius.
Quote from: NickZ on November 28, 2018, 01:42:21 PM
Hoppy:
Definitely no ground connection or power supply in that video Nick. Just a loop antenna receiving that 'special' frequency.
Part #5 Zenneck surface Wave
for beginners :
Today I'm presenting principal secrets of the Transmitter of Zenneck Surface wave.
1. Transmitter (
Tx) of Zenneck wave directly comes from Maxwell equation and Zenneck in 1906 made special formulation to these waves.
2. Tx is made of 2 metal conducting materials (balls- spheres or any other shape) with one directly above the other and the certain distance from the earth.
3. pic 1 there are two regions affected by electrostatic charge of T1 and T2.
4. 213 is typical signal generator delivering waveform to the 209
5. 209 is regular amplitude and phase regulator between T1 and T2 creating corresponding charge Q1 and Q2
- guided electromagnetic field is limited by direction in its electric and magnetic field such as antenna yagi or by guided modes
- guided modes are surface wave modes of electromagnetic wave propagation
5a- types of guided modes interesting to us:
TEM- Transverse electromagnetic (like wave directed by Yagi antenna.)
TE- Transverse Electric
TM- Transverse MagneticQuotehttps://en.wikipedia.org/wiki/Transverse_mode (https://en.wikipedia.org/wiki/Transverse_mode)
The TE stands for transverse electric mode.
When the electric field of the signal is perpendicular to the direction of propagation through waveguide, it is called the TE mode.
In this mode the magnetic field components are in the direction of propagation.
The TM stands for transverse magnetic mode
TM mode -the electric field is in the direction perpendicular to that of propagation, so ONLY the magnetic field propagates within the waveguide,
TE mode - the magnetic field is in the direction perpendicular to that of propagation, so ONLY the electric field propagates within the waveguide,
- radiated electromagnetic field is regular electromagnetic propagation of electromagnetic wave in radial axis (not used in Zenneck wave/surface wave )
- radial axis is propagation from one single point out radially
6. The device creates two regions
Region1 and Region2 with interface ground/air
-Region1 and Region2 are above and below the interface. -interface is the boarder used for propagation of surface wave known as Zenneck wave.
-Zenneck wave inside the interface is directional( flat but cylindrical )and is called guided surface wave mode
- "cylindrical" will be explained later if needed.
7. By use of two ( can be more than 2 )charged e.g spheres, + 209 + 213 we create
polyphase waveguide probe.
- word polyphase means:
having several AC signals of the same current but having different phase in the same point in time.
it is used in Quotea complex angle of insertion of an electric field synthesized by the polyphase waveguide probes,
polyphase waveguide probe provides phase shift in a ground current that facilitates the launching of a guided surface-waveguide mode on a
lossy conducting medium in the propagation interface
-propagation interface is interface ( line) between ground and air.)
-lossy conducting medium is a ground (the earth) in the vertical axis to the interface.the more far away you are from interface Up/Down ( vertically)the more of the signal is lost or not existing.
that means that your losses can be close to zero if Zenneck wave travels directly in the interface and does not reflect from uneven or nonuniform part of interface.
-guided surface-waveguide mode is the mode used by Zenneck Wave
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527386/#msg527386 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527386/#msg527386)
Wesley
Quote from: Ansis on November 28, 2018, 02:36:19 PM
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527428/#msg527428
Ansis is the author of information about his view on Kapanadze secret and you can ask him all questions
Wesley
Quote from: Hoppy on November 28, 2018, 02:38:46 PM
Yes, pretty amazing though. No battery, either. But, needs to pre charge the cap first, I think.
He should return to the PSEC tests, instead of trying to send mAs through the ground.
Re Ansis's circuit diagram using a 555 and a modified color tv's LOPT for creating an ion wind. looking and thinking about the circuit
leads me to visualize what's actually happening here. I'm not really sure of what first might appears.
First, we appear to be generating a POSITIVE UHV and secondly with the DIODE and the 0.1 Capacitor at 20KV would be a huge thing!
like 10 microwave oven caps in series which would be quite lethal once it charged up, perhaps jumping approximately 20mm or so
anyway besides that with the high impedance of the LOPT device it would take time to charge that size of capacitor up and it sounds
like you have to trim the charge time somewhat of the LOPT core gap which alters the energy storage time.
However, when a significant UHVoltage is reached depending on the Spark Gap the energy stored in the capacitor will be released causing a
reflection back into the LOPT primary of that energy causing the effect Ansis describes.
Sounds like fun but I wouldn't like to spend much cash on the components ;D ;D ;D PS don't get your fingers to close to the charged caps!
PS it would be very interesting to observe an oscillograph display printout of the waveform timing on a working device.
AG
Hi Ansis,
Thanks for posting your circuit diagram. Given that it is not surprising and even expected that the 300R resistor could smoke / device burn-out with this circuit, what else leads you to believe that this could be the basis of Kapanadze's devices?
Quote from: NickZ on November 28, 2018, 05:56:45 PM
Yes Nick, which is why some have commented that his lab is probably close to a strong source of RF.
MIT paper. from 1996.
So is Surface wave and one of its forms Zenneck Wave
Here is some basic for you my friend to study :
1.https://wikivisually.com/wiki/Zenneck_wave (https://wikivisually.com/wiki/Zenneck_wave)
2. http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf (http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf)
3. this article is easy , and you know most of it but it is good as refreshment: https://electronicspani.com/spherical-capacitor/ (https://electronicspani.com/spherical-capacitor/)
4. I have found specially for you easy way to compare your comment about MIT 1996 to today's opinion in regards to subject in question.
after you finish all above than go here:
https://www.youtube.com/watch?time_continue=4&v=wIIABIU3tRw (https://www.youtube.com/watch?time_continue=4&v=wIIABIU3tRw)
and than go here:
https://www.youtube.com/watch?v=ZTZ9SLux6OA&feature=youtu.be (https://www.youtube.com/watch?v=ZTZ9SLux6OA&feature=youtu.be)
and than go here:
http://www.aces-society.org/includes/downloadpaper.php?of=J2003N-S6P13&nf=59bf91af42aa7fd4fdbdf04b7b9bd2dc (http://www.aces-society.org/includes/downloadpaper.php?of=J2003N-S6P13&nf=59bf91af42aa7fd4fdbdf04b7b9bd2dc)
Wesley
by Department of Electrical Engineering at United Arab Emirates University - University of Sharjah.
https://patents.google.com/patent/US20140252886A1/enbut (https://patents.google.com/patent/US20140252886A1/enbut)
what about the sphere or two spheres inside the sphere ( earth/ ionosphere) https://electronicspani.com/spherical-capacitor/ (https://electronicspani.com/spherical-capacitor/)
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en) and picture below
This is also Viziv!!!!!!!!!!!!!!!
Wesley
Part #6 Zenneck surface Wave for beginners :
- principal secrets of the Transmitter of Zenneck Surface wave.
Conditions: to lunch Zenneck surface Wave
1. Tesla coil like structure can be build using two capacitors.( e.g spheres) ( or more)
These capacitors are placed vertically in line one above the other [in the imaginary line perpendicular to the ground ( earth)]
adjustments shown on the picture makes Zenneck wave
2. Mirror image of the charges in the two spheres is created in the ground.
3. Regular Electromagnetic Wave is alive "forever" once is transmitted.
surface wave dies when the switch of the transmitter is switched OFF.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527435/#msg527435 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527435/#msg527435)
Wesley
A Zenneck wave (https://en.wikipedia.org/wiki/Zenneck_wave) spreads from the source like the wave generated by a falling stone on the water surface. Then its energy density decreases in 1/r².
A soliton (https://en.wikipedia.org/wiki/Soliton) wave maintains its shape and its energy while progressing.
Tariel was right.
Energy is from around us.
That does not contradict anything that was published by Viziv and Corum brothers.
Corum Brothers have found part of that what was presented to us by Tariel Kapanadze
Vasmus, Anonim, SR, Chubanidze, Akula, Ruslan. and many others.
However Corum brothers did it late in terms of patent application.( expired 20 years patent life - 1988 ) and not finishing or abandoning application.
Tariel Kapanadze Patent application was filed in 2008.
every
m vertically from earth to ionosphere has potential
100V /m
10m=1000V
100m=10 000V
1000m=100 000V
at the height of typical airplane flight it is
12000m= 1 200 000V
Earth is natural
waveguide. https://en.wikipedia.org/wiki/Waveguide (https://en.wikipedia.org/wiki/Waveguide)
The earth is in form of circular closed donut/doughnut or waveguide
Waveguide guides electromagnetic wave at certain given conditions.
giving to that form of electromagnetic wave desired shape!!!!! ( squeezing it, forming it)- inhibiting it in given direction.
Electromagnetic wave is showed here( read text under video frame) https://www.youtube.com/watch?v=XFBHmG6gtIU (https://www.youtube.com/watch?v=XFBHmG6gtIU)
QuoteIn 1864, James Clerk Maxwell mathematically predicted the existence of electromagnetic waves. An electromagnetic wave consists of two oscillating fields, one electric and one magnetic, which propagate in space carrying energy. These two fields lie in orthogonal planes and therefore an electromagnetic wave is called plane-polarized.
In that waveguide you have nonuniform presence of charges manifesting itself often in form of lightnings.
One single lightning triggers series of lightnings in waveguide around the earth , and the more lightnings are triggered , the more of avalanche of lightnings is created.
At one point conditions in that waveguide does not permit for that avalanche to be continued.
When Lightning strikes it converts potential energy into kinetic energy..
That form factor however is now not an electrostatic charge but AC .
Whenever we deal with with AC in open space we deal with photon as a carrier of energy .
Photons can not interact with each other apart themselves, they can not see each other but they are properties of the electromagnetic wave.
Electromagnetic wave of given frequency can not interact by that with any other electromagnetic wave but...
BUT... BUT... (Cerenkov radiation)
please do not go to link from the quote you do not need it now.
QuoteFor a wave that experiences anomalous dispersion and propagates with the external magnetostatic field, distinguishing features of the energy-flux velocity and the ratio of the electric to the magnetic energy density as functions of the wave number https://www.researchgate.net/publication/227230220_Slow_electromagnetic_waves_in_tangentially_magnetized_ferromagnetic_films (https://www.researchgate.net/publication/227230220_Slow_electromagnetic_waves_in_tangentially_magnetized_ferromagnetic_films)
( this quote from above will be needed for you to understand that there is use of ferrites/ ferromagnetic films or ferrite-like materials used by other people who filed patent applications for their FE or simply used it in their devices)
I wet to South of America to eliminate/ or conform one of variables of the puzzle.
That was two ground structure. My posts are posted here. You need just to find them.
That gave me information about the structure of positioning of vital elements of the device.
So
Slow wave is created by interaction of two waves.
Well two waves can not interact with each other right?
You can't slow down one EM wave using another wave, but you can slow down the wave's energy flow.
This sets up a standing wave
https://www.quora.com/Can-you-slow-down-an-EM-wave-with-radio-waves (https://www.quora.com/Can-you-slow-down-an-EM-wave-with-radio-waves)
The same way the lightning strike is created " in the middle of nowhere" but inside of earth ionosphere earth guide
We can create electromagnetic wave causing standing wave be alive.c We are at the same exactly waveguide
And as a result of that we create.. what.. lightning around the earth? NO.. no no...
We can build antenna that is small and does not look like an antenna .. but more like Tariel Kapanadze coil
and this antenna is made out of:
- clockwise
-and counterclockwise coils and
- bifilar coil structure. https://en.wikipedia.org/wiki/Bifilar_coil (https://en.wikipedia.org/wiki/Bifilar_coil)
Note : most of experimenters who made successfully working device and/or these who filed patent application, do not understand what energy is coming from including Tariel Kapanadze.Please recall my quote about monkey
from my previous post=============================================================================
QuoteIt is well known in the electromagnetic arts that efficient, linear antennas are usually constructed from elements having lengths that are significant portions of a free-space wavelength at the operating frequency.
It is also known that if those lengths are made equal to integer multiples of one quarter wavelength, standing waves may be induced in the antenna.
It is also understood that operation of an antenna at one of its self-resonance frequencies, if possible, is desirable to increase antenna efficiency.
At the self-resonant frequencies, standing waves are produced on antennas and the reactive component of the feedpoint impedance is zero.
This efficient operation contrasts with the familiar "matched" operation where the impedance of an antenna is conjugately matched by an
external network to the impedance of a transmitter or receiver to improve performance. Reactive power losses are experienced both in
the antenna and in the matching network, when a matching network is used, so that overall system efficiency is not maximized.
It is also established that horizontally polarized electromagnetic waves suffer greater ground wave propagation losses than do vertically polarized waves.
Therefore, vertically polarized waves are preferred over horizontally polarized waves for communication over the surface of the earth.
The antenna can be in form of torus or cylinder forming toroidal, helical electrically conducting path.
So lets talk for a moment about torus shape instead of Kapanadze cylindrical shape of the clockwise and counterclockwise coil.
QuoteIn a simple case, the structure has a single conductive path, such as a copper wire or other electrical conductor, disposed on the surface of a torus in uniformly spaced turns.
The axis of the helical path lies on a circle which is described by the major radius of the torus.
(A toroidal surface is generated by the rotation of a closed planar figure about a rotational axis lying outside the figure.
When that figure is a circle, the surface generated is a torus.
For a torus, the distance between the rotational axis and the center of the rotated circle is the torus' major radius.)
When the conducting path on the toroidal surface is electrically excited in a pre-selected frequency range, a pair of slow electromagnetic waves
i.e., ones with propagation velocities less then the speed of light, propagates along the path.
At the resonance frequencies of the toroidal path, an inhibited-velocity standing wave is established along the electromagnetically-closed path, which in this elementary example is approximately equal to the circumference of the torus
QuoteThat wavelength of (wire) conducting structure wounded on the torus is shorter than a free-space wavelength at the frequency of resonance.
Therefore, at the primary resonance frequency, the toroidal structure behaves electrically as if its circumference were one free-space wavelength
long when that circumference is actually physically smaller than one free-space wavelength.
Thus an electrically small, resonant structure is achieved
That is why Tariel Kapanadze coil is so small.
By combining a number of the toroidal conducting paths just described and by controlling the relative phases of the electromagnetic energy supplied to each path,
various embodiments of the structure and various antenna radiation patterns may be created.
the conducting paths have opposing senses, i.e., are contrawound.
QuoteBy appropriately feeding the contrawound paths, an electrically small, self-resonant antenna providing purely vertically polarized radiation having an omnidirectional radiation pattern may be realized.
One half of the electrically conducting path may be eliminated in the structure by employing the image theory technique.
A conducting image surface electrically supplies the missing portion of the path.
The image surface may be a conducting sheet, a screen or wires like counterpoise
arranged to act electrically as a conducting sheet, or may be the earth.
That gives to the device potential to be in motion like powering the car, boat or ship.
by means of counterpoise/ sheet of metal/ screen of wires.
Antennas as small as few-thousands of the free space wavelength have been build and successfully operating with submarines
But they did not use the image concept and they have been employed to resonate in mode suitable to energy extraction.
A particularly intriguing application of the structure is the construction and operation of a waveguide probe at the primary or higher mode resonance frequencies of the waveguide formed by the surface of the earth and ionosphere.
Because these resonance frequencies, the so-called Schumann resonances, are so low, e.g., about 8, 14 and 30 Hz,
it has not heretofore been practical even to attempt to build a self-resonant structure to operate at any of the frequencies.
Although a waveguide probe resonantly operating at one of the Schumann resonance frequencies would be physically large,
it would still be electrically small and therefore realizable, as well as efficient.
Because propagation losses are so low at the primary Schumann resonance frequency
(below 0.25 dB per Mm according to published data), signals at that frequency may be transmitted to any point on the earth without significant attenuation.
So how about if we try to receive this energy bouncing in the waveguide by relatively small antenna that was named by Corum Brothers the probe
using standing wave, and very small antenna that does not look like antenna...
Well this requires from me to show you 3 patent application not made by Corum Brothers
including Tariel Kapanadze structure.
QuoteAn electrically small, efficient electromagnetic structure, that may be used as an antenna or waveguide probe, having an electromagnetically closed, velocity-inhibiting conducting path,
for supporting a standing, inhibited-velocity wave in response to the flow of an electrical current through the path and a process for establishing the standing wave.
Use of the structure is particularly advantageous at the lower end of the electromagnetic spectrum, where it produces purely vertically polarized radiation
in directional and omnidirectional patterns.
The structure may be used to
excite and extract energy from the earth-ionosphere cavity at the Schumann resonances.
the exact quote of one of papers is:
"electromagnetic structures that can function as antennas for /../ receiving electromagnetic energy
and as waveguide probes in cavities for /../ extraction of electromagnetic energy."
I
Wesley
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527478/#msg527478 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527478/#msg527478)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527521/#msg527521 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527521/#msg527521)
Wesley
Thanks for the friendly clarification I'm glad that's cleared up :D :D have a good day there.
I feel like I need to repeat for you AlienGreey how to achieve small form factor
of the receiving antenna ( Tariel Kapanadze coil):
(wounded counterclockwise)
-conducting paths is more than 1 path. but I'm talking about just two
- phases of each path in relation to each other are the most important ( crucial).
- and to make it working you need countrawound, but there are shapes of an antenna that do not need that. however they need to be bifilar.
- use of ferrite helps but is not always mandatory that is why most of FE devices uses ferrites.
- when traditional material if regular transformer made from plates, is used, or the core is wounded as donut of continuous circularstrip
one of techniques
dividing/ splitting magnetic flux into two controlled path can be applied by
making slot in the middle of the ferrite core and pushing in it additional winding at 90 degrees.
Wesley
look up.
this set of ferrite connection is taken from patent application not related to Corum brothers
I will make separate video about it and it claims FE 10W input to 15kW output
The reason of me placing it here is because it uses the same means( mechanism) of flux control as it is used by probe antenna
Wesley
Wesley Thanks for device layout the two toroids are easy to get hold of but the U shape would have to be a custom device, however,
would it be possible to mount the permanent magnets on the top of the toroids and a flat ferrite rod over the top depending on the thickness
of the wire wrap.
Two coils are activated at positive part of impulse and than the other two
So switching is done between each set of two coils.
that means first impulse activates the same first set of coils
Magnetic flux is switched in direction flowing on doted line now.
Than second impulse ACTIVATES the same second set of coils.
Switching continues the same way for impulse 3 and 4 // 4 and 6// and so on.
Wesley
Hi Wesley,
The patent application was familiar to me and was mentioned here:
https://overunity.com/8597/solid-state-orbo-system/msg224747/topicseen/#msg224747 (https://overunity.com/8597/solid-state-orbo-system/msg224747/topicseen/#msg224747)
full text and drawings for those interested:
https://patents.google.com/patent/US20090096219A1/ (https://patents.google.com/patent/US20090096219A1/)
Perhaps a related or useful paper is here:
https://www.researchgate.net/publication/224289652_Analysis_of_a_Virtual_Air_Gap_Variable_Reactor (https://www.researchgate.net/publication/224289652_Analysis_of_a_Virtual_Air_Gap_Variable_Reactor)
Gyula
Quote from: gyulasun on December 03, 2018, 05:21:33 PM
Hi Wesley,
Gyula
I do very much appreciate your comment here :)
give me few hours you will know why.
Wesley
Ted Annis 15kW FE
https://youtu.be/DNxob3yY4LE (https://youtu.be/DNxob3yY4LE)
Ted Annis made vital information removed but when you compare the versions of different time of publication you will find that what you looking for .Just look at that what is removed or what is different :) ,when you take foe of them
related literature:
https://patents.google.com/patent/WO2009046265A1/tr (https://patents.google.com/patent/WO2009046265A1/tr), compare different versions !!!! from different years
https://patentimages.storage.googleapis.com/62/00/84/e06f92b5a2938e/WO2009046265A1.pdf (https://patentimages.storage.googleapis.com/62/00/84/e06f92b5a2938e/WO2009046265A1.pdf) compare different versions !!!!
https://patentimages.storage.googleapis.com/5b/06/7a/a683a3e327631c/US20140091890A1.pdf (https://patentimages.storage.googleapis.com/5b/06/7a/a683a3e327631c/US20140091890A1.pdf), compare different versions !!!!
https://www.tedmagnetics.com/ (https://www.tedmagnetics.com/)
https://maritime.org/doc/neets/mod01.pdf (https://maritime.org/doc/neets/mod01.pdf)
http://info.ee.surrey.ac.uk/Workshop/advice/coils/mu/#bhcurve (http://info.ee.surrey.ac.uk/Workshop/advice/coils/mu/#bhcurve)
https://www.doitpoms.ac.uk/tlplib/ferroelectrics/printall.php (https://www.doitpoms.ac.uk/tlplib/ferroelectrics/printall.php)
http://fullfunctioneng.com/info/Hall%20vs%20VR.pdf (http://fullfunctioneng.com/info/Hall%20vs%20VR.pdf) !!!! important
http://www.cmi-ferrite.com/products/Gapped.htm (http://www.cmi-ferrite.com/products/Gapped.htm)
http://www.eamagnetics.com/product/ceramicferrite/ (http://www.eamagnetics.com/product/ceramicferrite/)
https://www.youtube.com/watch?v=zg8V9XCgIqs (https://www.youtube.com/watch?v=zg8V9XCgIqs)
Wesley
. https://youtu.be/DNxob3yY4LE?t=498 (https://youtu.be/DNxob3yY4LE?t=498)
Wesley
This is my concept for closing the magnetic path.
Why to change the path you can simply turn it on, activate.
Ferrite core or even the coil itself closes the flow of the stream by connecting the top and bottom together. If you have a ferrite it must be far enough away not to connect the rings and activated only when the voltage is turned on. In the case of the coil itself it does not matter.
Thank you for your comments my dear friends.
I have some positively shocking revelation in area of Ted device.
I must:
- check if I'm authorized to publish it.
- decide if I want to make another video or just publish it.
- decide which forum is technically the most interested with Ted technology .
Down here is some preview.
This is photo not drawing.
descriptors are the addition that was written later on the picture
That what you see it was fax copy .
Wesley
Hi Wesley,
Sorry I have been busy and haven't following this thread that closely.
By 'Ted device', do you mean the TED device from these guys:
"U.S. Patent 9,742,252 was issued on August 22, 2017 for the PMIG with rotary reluctance switches.
A US patent application was filed in December 2016 for the PMIG with electromagnetic reluctance switches.
The application for the PMO is in process."
https://patentimages.storage.googleapis.com/18/91/dd/7a7068f79f2d64/US9742252.pdf
The topic of this thread seems to be jumping around all over the place. :D
I suggest combining streams in such a simple way. Why shouldn't it work? We don't have to change the polarization just to enable one field.
- US20070242406A1 2007/10/18 by Annis and Eberly?
Electricity generating apparatus utilizing a single magnetic flux path
Wesley
There is something in addition to my previous post.
If you want to maximize the effect than you need that material that was shown in my video click here:
https://youtu.be/DNxob3yY4LE?t=504 (https://youtu.be/DNxob3yY4LE?t=504)
Wesley
DISCLAIMER: Any experiment you try is at your own risk
that applies to all videos/posts/ notes/ comments of mine.
Quote from: r2fpl on December 07, 2018, 04:10:28 AM
Hi r2fpl, Like your idea - analysis - simulation. Your probably aware that I promote CAE as it seems to
be the next logical step to our finding the roots to this free excess energy.
Here's a paper you might find interesting:
"Hybrid Reluctance Machines with U-Shaped Electromagnets and Permanent Magnets"
https://upcommons.upc.edu/bitstream/handle/2117/83433/436-15-andrada.pdf (https://upcommons.upc.edu/bitstream/handle/2117/83433/436-15-andrada.pdf)
In particular Fig 1. (A and B) and Figs 15., 16, 17.
TIP: (in case your not familiar), to search for related patents go to https://patents.google.com/ (https://patents.google.com/)
In the search window simply enter the key words relating to your search,
for example: "
permanent magnet reluctance switching stationary generator" (without the quotes),
also, check the "light bulb" to the right (should be default ON);
and the "grad cap" if you want non-patent literature.
Example - Some related patents:
US6362718B1 Motionless electromagnetic generator
https://patentimages.storage.googleapis.com/31/3b/ba/b873f8fea482c7/US6362718.pdf (https://patentimages.storage.googleapis.com/31/3b/ba/b873f8fea482c7/US6362718.pdf)
US4006401A Electromagnetic generator [can't help but love this one!] 1975-12-12
https://patentimages.storage.googleapis.com/f3/22/c6/1fd63bdf889b9c/US4006401.pdf (https://patentimages.storage.googleapis.com/f3/22/c6/1fd63bdf889b9c/US4006401.pdf)
US20070242406A1 Electricity generating apparatus utilizing a single magnetic flux path
[posted previous in question to Wesley]
https://patentimages.storage.googleapis.com/7c/4f/fd/c4741774526b59/US20070242406A1.pdf (https://patentimages.storage.googleapis.com/7c/4f/fd/c4741774526b59/US20070242406A1.pdf)
Good luck and have a great weekend!
SL
SolarLab: Thanks !
I did 3 simulations to confirm the paths and of course everything had to agree.
The simulation confirms the conventional functioning of the MEG. The flux path depends on the permeability.
The interesting question concerning energy is the mutual coupling between the switching coils and the output coils, and the energy wasted to change the permeability.
That's what I ask myself 10 years ago and that I tested. The answer is that the conventional functioning was confirmed, we have a set of coupled coils with a core of non constant permeability which doesn't change anything in the energy conservation.
Thank you both of you guys.
.. honestly thank you for your contribution../..
please do it again:
in configuration as in Ted's patent application
1. as shown below.
2. as shown below but with two other coils included( not in the picture)
3. as shown below but showing what is happening exactly
here: https://youtu.be/DNxob3yY4LE?t=234
Note: please position the two magnets exactly as shown in picture below in relation to C bracket.
That means :
C bracket has two magnets on the inner side and than the rings are touching the magnets .
So the moment of switching is important.
The claim from patent application says about 1500V 1 to 10A out of 1V 1 to 10 A
So take the lowest number from the drawing shown here :
https://youtu.be/DNxob3yY4LE?t=433 (https://youtu.be/DNxob3yY4LE?t=433)
it says after 100ms=250V 2A
or any gain ... just any
After You do it, I'll try to be ready for another one.
It may take some time but not much.
Wesley
Hi all,
Just to add to the whole thing - when you split operation into 2 parts:
1) method of causing magnetic flux path change (multiple patents applications)
2) method of extracting energy from magnetic flux path change (no patent applications so far)
The second one is obvious and is root cause why all patent applications going old as https://figueragenerator.wordpress.com/patents/patent-44267-year-1908/ (https://figueragenerator.wordpress.com/patents/patent-44267-year-1908/) are incomple for practical applications...
Cheers!
http://www.physics.mcgill.ca/~peter/publications/hysterisis-loop-construction-JAP-2003.pdf (http://www.physics.mcgill.ca/~peter/publications/hysterisis-loop-construction-JAP-2003.pdf)
Thank You very much
Wesley
for these in both English and Russian.
who are interested with NMR as that was assigned to Lithuania Experiment
English version:
https://ia600604.us.archive.org/23/items/HighResolutionNuclearMagneticResonance/PopleSchneiderBernstein-HighResolutionNuclearMagneticResonance.pdf
Russian Version:
https://books.google.com.ua/books?id=EJfQDAAAQBAJ&printsec=frontcover&hl=ru#v=onepage&q&f=false
Please let me know if these links opens for you with no problem , or I need to give you alternate link.
Wesley
F.Y.I.
Rather than post "snapshots of simulations;" it is far more benneficial and instructive to
actually work through a problem, hands-on, in situ; as you adjust the parameters and watch the
interactions in pseudo real time.
However, snapshots are good for high-lighting concepts or to target points of interest but they
don't suffice when dealing with a dynamic event or environment.
So, in short, you're better to do it yourself - it's like breathing; doesn't help much if someone
else does it for you!
Now days you can do this, at no cost; it's easy to get started and very straight forward to actually do.
They can be resource intensive however (near 6 days to do a very detailed, 1 pass, full EM on a so
called grenade coil running on a 2.8GHz 32 core 256GB RAM workstation).
Thus; here are a couple of options:
CST Studio Suite Student Edition (no cost but some restrictions)
"Introduces you to the world of electromagnetic simulation, making Maxwell's equations easier to
understand than ever. With this free edition you have – bar some restrictions – access to our powerful
visualization engine and some of the most advanced solvers of CST Studio Suite." [CST is a high end 3D EM
product, easy to use, gives excellent results]
https://www.cst.com/academia/student-edition (https://www.cst.com/academia/student-edition)
CST Student includes the following solvers: Time domain, Frequency domain, Low frequency, Static and Thermal
but apparently no third party CAD import or export or optimization is provided.
Quickfield EM Field Modelling - Student Edition
https://quickfield.com/free_soft.htm (https://quickfield.com/free_soft.htm)
Altair FEKO Electromagnetics - Student
https://studentedition.altair.com/ (https://studentedition.altair.com/)
https://altairuniversity.com/free-hyperworks-2017-student-edition/ (https://altairuniversity.com/free-hyperworks-2017-student-edition/)
Many other major CAE providers have similar options such as Comsol Multiphysics (my favourite, along with CST),
Ansys, etc... as well as a variety of open source options (below).
https://www.engineering.com/Education/EducationArticles/ArticleID/13143/Free-Engineering-Software-for-Students.aspx (https://www.engineering.com/Education/EducationArticles/ArticleID/13143/Free-Engineering-Software-for-Students.aspx)
List of OPEN SOURCE SOFTWARE
http://emlab.utep.edu/opensource.htm (http://emlab.utep.edu/opensource.htm)
Check them out. I can not recommend any of these open source programs since I personally have no extensive
experience with any of them.
Anyway; just some more interesting and useful additions to the "Tool Kit."
NOW - for those who are going to whine and complain that there are no examples of the type of work we are
all are doing here, please keep in mind "this is YOUR job," this is where YOU achieve YOUR claim to fame!
If it were already accomplished - we wouldn't be here!
FIN
@ stivep Andrey Melnichenko https://vk.com/id285085326
I would like to say that one of my ideas is HV.
There are two magnets and we create a spark between them. The question: do we combine the magnetic fluxes of both magnets in this way?
That would be great :)
Would it be so simple ?!
https://www.youtube.com/watch?v=u7oziZUJy5Q
Quote from: gyulasun on December 10, 2018, 06:06:07 PM
In his patent US9742252 (but also in his earlier applications) Ted mentioned a Bulgarian inventor, Valerij Ivanov
who has had "electrical means of implementing a reluctance switch". This method was discussed in 2008 here in
this forum (besides a Bulgarian forum which was later changed to another named forum). Here is the topic on this
forum, from Page 2 where a replication attempt was also shown by a Bulgarian member:
https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134122/#msg134122 (https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134122/#msg134122)
https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134280/#msg134280 (https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134280/#msg134280) and
https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134670/#msg134670 (https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134670/#msg134670)
https://www.youtube.com/watch?v=z4bMgDUpuWI (https://www.youtube.com/watch?v=z4bMgDUpuWI)
https://web.archive.org/web/20170807105029/http://www.inkomp-delta.com/page2.html (https://web.archive.org/web/20170807105029/http://www.inkomp-delta.com/page2.html)
http://www.dvenergy.eu/ (http://www.dvenergy.eu/)
https://www.youtube.com/user/Waleri1021/videos?view=0&shelf_id=0&sort=dd (https://www.youtube.com/user/Waleri1021/videos?view=0&shelf_id=0&sort=dd)
Gyula
Very much Thank you for your contribution -good help my friend
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=202008009291U&KC=&FT=E# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=202008009291U&KC=&FT=E#)
https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134494/#msg134494 (https://overunity.com/4300/a-truly-overunity-transformer-meg/msg134494/#msg134494)
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=BG&NR=109554A&KC=A&FT=D&ND=&date=20070630&DB=EPODOC&locale=en_EP#
Wesley
Quote from: r2fpl on December 10, 2018, 10:04:44 AM
https://www.youtube.com/watch?v=u7oziZUJy5Q (https://www.youtube.com/watch?v=u7oziZUJy5Q)
Very nice video Thank you.
Wesley
https://youtu.be/UkVdrTMZMEY (https://youtu.be/UkVdrTMZMEY)
watch: https://youtu.be/eMrXS9uiQCo (https://youtu.be/eMrXS9uiQCo)
Hoppy: Ok then, I guess it's all perfectly normal. Good thing forest fires normally don't burn trees down, as they are all wet inside.
Thanks. What a relief. https://youtu.be/ZWvuPcurB6Q
Quote from: NickZ on December 12, 2018, 01:30:19 PM
By who, Hoppy?
This is not the first of these types of exterminations. Nor possibly the last. Imagine, what's next...
As you can see in that video, homes and cars are melted to nothing, but the trees are not. Wild camp fire??? A dog sits patiently waiting for his owners to come home, 10 days after the fires... on another video. There are several other videos showing what did cause these fires. I won't go into that, at this time.
AG may be pointing in the right direction. This planet is being turned upside down, while we just watch, and say "by who".
I know that you are an informed guy, Hoppy. So...
Nick,
Thanks for the links which I had not seen. The truth is buried in the crap and its alarming!
Quote from: F6FLT on December 13, 2018, 06:35:39 AM
There's no need to shout, Aliengrey.
I'm talking about method. Do you really believe that by doing anything, you can achieve our goal? What is your point of view on the method? Is it to repeat acts of faith by chanting "energy comes from emptiness" or "be blessed Mr. kapanadze"?
This is what I have been hearing for 15 years with Bearden and all other useless people, and their concrete results are much emptier than the quantum vacuum. If you do not take into account the general failure we face, you are condemned to remain there forever, repeating the mistakes of the past.
Err can you point me to your 'EXPERIMENTS'on here please or are you just a scribe? ;D ;D or point me to anything you know of that grabs
energy from the ground we can test?
PS If Mr TK wants to bless us he just needs to give the world FE know how, sorry i think my spell checker has just corrected all your bad hand writers :D :D :D :D :D :D
@aliengrey @r2fpl
I started my experiments with a setup inspired by Naudin's Kapagen and Kapanadze's patent (see photo).
I tried to complete the assembly with a possible "frequency stabilizer" and "filter" (LC circuit, cap?...) but as Kapanadze lies by omission in his patent, my chance to succeed by experimenting at random was almost nil, as for everyone else. The rest proved it.
If some have succeeded and do not want to show us their solutions, it would be completely stupid since they do not hold the patent anyway, and so the idea that this situation would be real is just as stupid as a conspiracy theory.
Now, you two aliengrey and r2fpl, I would be happy if you would present us with your own setups and what you retain as experimental signs of OU.
Not trying to find fault but an undergraduate guy I now made what you show it looked lethal :D 8) but it only had about 1.5 kv
thats not 3.5 kv and it needs to be a fast tunable spark a dump of energy if you read Morays notes.
The only device I have seen that appeared to work is this device by Don Smith it involves a series of capacitors with bleeders that charge
up to about 3.5 to 4kv fed by a LOPT and a string of 1kv 1amp diodes (12) feeding a 3.5 inch 6 turn coil made from car brake fluid tube
It appears to produce heavy current sparks that appear to dissipate more energy going in than out oops.
Already posted on thread
https://www.youtube.com/watch?v=dfMtQYYkZto (https://www.youtube.com/watch?v=dfMtQYYkZto)
Quote from: Void on December 13, 2018, 12:17:58 PM
From what I have seen of Kapanadze's demo videos, and I have watched many of them very closely,
they do hold up pretty well to scrutiny.
Like you, I have watched his videos and also thought they stood up fairly well to scrutiny, until I glimpsed this clip from the green box garden video. The suspect cable / wire coming into sight behind the guy operating the green box is going towards the bearded guy who holds the coil of ground cable throughout the video. That was part of the 'trick' in my opinion.
Hi Wesley!
If you have capacitor 10uF 12V full, that is not a lot.How can you raise energy of that cap?You simply put in series that cap with output of HV Tesla coil.If the Tesla coil has output of 1000V, than on your 10uF cap will be 1000+12V.And 10uF 1012 V is a lot of energy. First try with smaller capacity of 1uF. It is lethal.
Fill the cap with low voltage high Amp and put it in series with HV output of Tesla coil, flyback?? (unidirectional pulse, watch the polarity so the output is in series with cap) to raise the voltage of that line. After cap put in series spark gap so the cap do not bleed before you hit it with HV.
After the spark gap put in series step down transformer. Now you have HV spark of 10uF. A very big spark.!
Load the bullet, fire the bullet!
It is Bootstrap method. How to raise the voltage on cap to drive the mosfet? With Bootstrap method you can raise Bootstrap cap of 100uF 12V to 100uF 500V easily. Anyone think of that??
It is also voltage doubler circuit but with spark gap and modified. One phase fill the cap from low voltage source. Second phase hit it serial with HV so the 10uF can jump across the spark gap! Easy! A little bit of practice and you will do it!
It is too simple so nobody can see it.
Picture is from Kapanadze patent. He made mistake and draw it!That's why he made second patent to hide the mistake!
It is serial connection of the coil and capacitor. (Power line and already full capacitor). Voltages are adding on capacitor.
Nothing is violated, it depends on law of serial connection. But not two capacitors. Capacitor and coil. A little bit different.
Remember a Steven Mark story of two currents. One 5V and 5A and second HV. In serial they produce kick.
Kapanadze and Steven Mark are all the same principle. All of them are.
https://patentimages.storage.googleapis.com/5e/87/a8/c7c74fe8c29b46/US20090206675A1.pdf (https://patentimages.storage.googleapis.com/5e/87/a8/c7c74fe8c29b46/US20090206675A1.pdf)
picture #2 and #2a.
Picture 2 and 2a is the picture of actual transformer
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg528069/#msg528069 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg528069/#msg528069)
Wesley
Quote from: v8karlo on December 13, 2018, 01:25:51 PM
Hi Wesley!
Hello there , i have just one question,
How will a 12v rated cap survive a 1000v spike?
Quote from: stivep on December 13, 2018, 05:25:30 PM
It is surprising that such an idea, which is not new, which is near-field coupling, which is part of the state of the art, could have been patented. Everyone knows that energy can be transported from one capacitor plate to the other, and that a capacitor has no theoretical limit for the spacing of its plates.
https://www.google.com/search?q=GeoFusion;+Don+Smith+partial+replication+Cloud+version&rlz=1C1CHBF_en-GBGB813GB813&tbm=isch&source=iu&ictx=1&fir=ix-LTfLQs6RAJM%253A%252C4546FcEWALYZKM%252C_&usg=AI4_-kRp65rZd_3cYDnJloqJS_xSkFMn0w&sa=X&ved=2ahUKEwjI89iupZ_fAhWiNOwKHY_WD24Q9QEwAnoECAUQBA#imgrc=_ (https://www.google.com/search?q=GeoFusion;+Don+Smith+partial+replication+Cloud+version&rlz=1C1CHBF_en-GBGB813GB813&tbm=isch&source=iu&ictx=1&fir=ix-LTfLQs6RAJM%253A%252C4546FcEWALYZKM%252C_&usg=AI4_-kRp65rZd_3cYDnJloqJS_xSkFMn0w&sa=X&ved=2ahUKEwjI89iupZ_fAhWiNOwKHY_WD24Q9QEwAnoECAUQBA#imgrc=_)
Quote from: AlienGrey on December 14, 2018, 08:45:30 AM
What if i just send you the other vid ;D ;D ;D
Hi AG, Is there a reason you can't post the video link here?
Quote from: Hoppy on December 14, 2018, 11:06:53 AM
Yes, that's correct and clearly shown in the videos.
What video are you talking about Hoppy ? we can put Vera on the case ;D ;D
Look here! ramset and wattsup show spiral pipe wind input for current input (i'm not sure how that works).
https://www.overunityresearch.com/index.php?topic=237.100
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/5985/
Quote from: stivep on December 14, 2018, 01:59:23 PM
Perpetual motion is not achievable, OU does not exist and never existed but FE exists and is real.
Wesley
I have not closed the door on OU. More power out than being input,
but with no discernible source of where the excess energy is coming from.
To that I say maybe.
Energy from seemingly nowhere may seem quite illogical, but I will let my tests
tell me what is really possible. Sometimes our thinking leads us astray, and
that can work in all directions. 8)
My dear Wesley, I know that. You saw the device. And I and hundreds of people saw the amazing Dynamo walking on the water:
https://www.dailymotion.com/video/xt2yu2
Does that prove he can walk on water?!
Years ago there was a guy use to run a sword through his heart, he used to boast about it, it was on TV live you couldn't fake it, it's very bad Satanic stuff, but true.
Quote from: stivep on December 14, 2018, 02:36:18 PM
You just contradicted yourself.
anytime you take energy out it creates shortage of that energy.
anytime you take water out from the cap creates shortage of that water.
That is why overunity does not exist and never existed
Energy must come from somewhere and be converted to usable to us form of energy
Conversion takes energy too.
Wesley
Hi Wesley. I said 'no discernible source' and 'seemingly'.
I think that should clarify what I mean there.
I realize that energy is not supposed to just appear from nowhere.
It should be coming from 'somewhere', or at least this is our current accepted view. :)
P.S. There was no contradiction in what I said.
Quote from: ramset on December 14, 2018, 02:33:59 PM
Thank you for responding my dear Friend Ramset
But I did want to ask Wesley if he has Gas spectrometer to test 1 MM iron wire for a McFarland Cook replication ?few samples to check for iron purity ?
Chet
Optical Emission Spectrometer you have in mind
. I assume?
or if it is EDXRF I have it SEA5120 by Seiko
https://www.youtube.com/watch?v=CQ3gPFfgDp8&t=770s
However my LN2 plant is not working now.
Please specify field of testing
Please provide me with link to experiment.
I have choice concentrate on making my video or do something else.
The crowd is waiting and may become impatient.
Since I mentioned me as home grown, self-made filmmaker I would like to deliver quality too.
Wesley
builders discussion thread
http://www.overunityresearch.com/index.php?topic=3677.msg70487;topicseen#msg70487 (http://www.overunityresearch.com/index.php?topic=3677.msg70487;topicseen#msg70487)
last page of topic prior to sourcing material for replicators// http://www.overunityresearch.com/index.php?topic=1616.msg70418;topicseen#msg70418// (http://www.overunityresearch.com/index.php?topic=1616.msg70418;topicseen#msg70418//not)
--not (http://www.overunityresearch.com/index.php?topic=1616.msg70418;topicseen#msg70418//not) wishing to sidetrack here ,will be a topic at this forum once I can get the right wire from 1870 period to start builds
Quote from: stivep on December 14, 2018, 02:44:25 PM
Optical Emission Spectrometer you have in mind. I assume?
Wesley
I believe Ramset was asking if you have some equipment which can test a sample of iron wire for iron purity.
McFarland Cook was a guy in the past who many locals considered to be crazy because he said he was
going to turn a metal storage shed on his property into a flying machine using his claimed free energy generator
invention. He submitted a patent application for his free energy invention. Basically just coils of wire
on iron rods. He never ever got his metal storage container flying, but it's rusty remains are still in existence.
I have a picture of it somewhere that I found on the internet previously. :)
Quote from: Void on December 14, 2018, 02:57:38 PM
Yes that is EDXRF
It is scientific grade research device
But it does not show bonds.
So it will be precise in form of investigative tool showing periodic components from lithium to uranium.
some limitations I have mentioned in previous post
Wesley
Please do not halt movie production ,am trying several sources for purist possible ironwire [no carbon]
Chet
Sorry to interject But AG posted some link and I wish to understand why ?? post Number 1529
maybe he can reboot other thread with Question [I think gas tubes ?? ]
sorry for intrusion
Chet
Err because Hoppy posted TK had wire he thought was feeding all his bulbs, and google pointed me to your thread! and i understand if you are quick grabbing ions before magnetic whirlpool starts an excess of energy is created
But Chet wouldn't it be better to use nanocrystalline tape instead of copper tape?
Quote from: F6FLT on December 14, 2018, 03:36:10 PM
Hi Void,
If there are measurements of the ground wire current and scope traces, I'm interested in. Could you or someone else point us them?
With regard to speculation, there is also a question of method to be applied.
The proposals "here is a functional device" and "there is evidence of cheating" are not at all equivalent.
This is linked to the burden of proof (https://en.wikipedia.org/wiki/Burden_of_proof_(philosophy)), which lies only with those who make the first assertion, the positive assertion (the second being relative to the first one). It is a question of logic, and in the absence of sufficient technical details on the device, that is all that remains. To get out of a belief system, proof must be provided by those who claim that the machine works.
Are you asking how to create an experiment on how to prove how to suck the energy out of the ground?
Hi Void,
Hi F6FLT. The measurements on the ground wire were done with a clamp ammeter placed over the ground wire.
This can be seen in a couple of the earlier video demos if I recall correctly, but I don't have web links handy.
I am aware that there are factors that could potentially render such measurements unreliable.
I make no claim about whether those readings taken could be considered reliable or not.
Kapanadze is not trying to prove anything to the world as far as I know. Last I heard a few years ago
he was looking for someone to buy his technology from him. If someone were interested in buying the technology
from him, it would be up to them to make sure proper steps are taken to determine the device works as
claimed before paying him. I do not claim to know whether Kapanadze's device is genuine or not,
so no belief system involved at all. I keep an open mind because what I have seen seems to hold up reasonably well to scrutiny.
Hoppy this is about all i have found
https://www.youtube.com/watch?v=r7C1b7-w3Hs
but if your thinking of sucking energy from the ground here, think about how thunder and lightning works!
the ground must be more negative than the sky so to do that won't you need produce a high positive pulse?
But remember although it's more positive than the ground it's still more negative than the sky ;D ;D
Quote from: AlienGrey on December 14, 2018, 06:52:21 PM
Actually,the clouds become negatively charged at the bottom,and positively charged at the top.
Once the charge separation becomes high enough,the negative charge discharges to !what is now! a positively charged earth surface.
Brad
Maybe for the fact that nobody tries to place mercury, which is a fuel.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg195032/#msg195032
Mercury is banned and threatened with imprisonment in my country. There are other harmful substances, too, and they do not have such restrictions. That would be interesting. Of course, mercury is harmful, so everyone knows.
Does Kapanadze use mercury?
Quote from: F6FLT on December 15, 2018, 04:47:55 AM
@Hoppy and Void
Thanks for the information about measurements of the ground wire with a clamp ammeter.
Nevertheless I'm afraid it's by far not enough: a clamp ammeter is generally designed for low frequencies (less than 10 KHz, ideally the mains frequency) and for sine signals. If there are RF currents it can be totally disturbed due to resonance or antiresonance in the inner coil. A trick consisting to put RF power in the wire couldn't clearly be viewed. As already mentionned, extraordinary claim require indisputable facts, especially when no other elements allow a duplication.
Hi F6FLT. It appears you did not read my reply to you. I already stated clearly that I was
fully aware that there are factors that could potentially make the clamp ammeter readings unreliable.
However, since we don't know the frequency and type of waveform(s) which were on the ground wire and output wire,
it is unknown if those current readings were at all accurate or not. However, the readings seemed to be ballpark for
the rough amount of power the light bulbs were apparently consuming.
Quote from: F6FLT on December 15, 2018, 05:16:32 AM
I don't agree. Kapanadze filed a patent. A patent is a publicity for an invention intended to be used in the general interest of people while respecting the intellectual property of the inventor. So this is proof that Kapanadze wants to prove something. If he has filed a patent that cannot be used, that is what we are seeing, it is cheating and he is accountable.
The only excuse I could see, which in fact is not really one, is that he has something but he is unable to understand the least reason of the functioning. This would explain why he is not cooperative because someone else could find the cause and filed another patent including the principle of functioning. In any case, once again, we are involved in idle speculation from which Kapanadze's device never comes out!
What you write here is of course just at the level of speculation, calling it 'proof' to try
to bolster what you prefer to believe; AKA rationalization. People typically file patents to
try to protect their 'intellectual property'. Those patents were filed in conjunction with a company
that Kapanadze was working with at the time. From what I have seen, it is not so uncommon for people
to file patent applications and leave out critical details in order to establish them self as the 'inventor',
but still not give away the 'critical secrets' of the invention. Possibly that is what they were trying to do.
I don't know. Anyway, as I have said I am not much interested in baseless speculation. You are free
to believe and assume anything you like, but I will reserve judgment until I see some actual credible
evidence either way.
This is not a coaxial cable! This is the HV cable from spark plugs (car). This is clearly visible.
If you watched your film carefully, you would have seen it. Same cable but green and blue is GreenBox/Kapanga version.
Quote from: Void on December 15, 2018, 03:22:58 PM
Hi Hoppy. What do you feel is off topic with regards to: "Wesley's Kapanadze and other FE discussion forum" ?
(I still haven't watched that video section yet, but I will get to it as soon as I have a chance. I am running around today. ) :)
Hi Void,
I have re-looked at those frames many times and I'm still uncertain about things because of poor video quality but my instinct is telling me that if there is a trick then its the bearded man dealing it.
To put it crudely, I feel that the thread is becoming an academics pissing contest!
Quote from: r2fpl on December 15, 2018, 02:11:21 PM
It does not make any difference if it is coaxial cable or just HV spark cable.
The only that counts is 1 conductor and dielectric.
Yes dielectric is the most important here.
It was a need for so many years to get to this conclusion.
That is why I ask all of these questions our friend
F6FLT
https://electronics.stackexchange.com/questions/172642/why-does-a-capacitor-create-a-90-degree-phase-shift-of-voltage-and-current (https://electronics.stackexchange.com/questions/172642/why-does-a-capacitor-create-a-90-degree-phase-shift-of-voltage-and-current)
Wesley
Off Topic:
Regarding Daniel McFarland Cook, he was an interesting guy.
He was the successful inventor of a popular sugar evaporator machine in the 1800's.
He also has a granted patent for an induction based free energy device which I think he said was going to
be the engine for his flying machine.
https://patents.google.com/patent/US119825A/en?oq=US119825
I referred to his flying machine as a metal 'shed', but looking at the picture again, it looks more like it
might have been a custom made capsule for the purpose of being McFarland Cook's flying machine. :)
It was in later years used by somebody else to be a smoke house, I believe.
Am I on the right thread here?
Wesley Hi re the caduceus coil Any idea what the pipe Dia was 'roughly' and the number of turns and possibly
wire diameter the drawing shows about 40 turns if that's anything to go on?
Many thanks, AG
Quote from: Hoppy on December 15, 2018, 04:02:15 PM
Hi Void,
Hi Hoppy. I watched the video closely again, including the frames with the bearded guy, but
can't see any wires that I can definitely say are out of place. With ground wires and possibly
lengths of unused wire laying on the ground that they weren't using, and with poor video quality
I can't really say what might be suspicious or not there. :)
Hi everyone,
There is an article which isn't easy to find in the internet which is related to "Nikola Tesla interview with lawyer 1899" unedited version not the newspaper version.
Inside article Tesla spoke of current amplification to and from Earth using interrupter setup for Tesla's coil.Question is how do we know if there is current amplification from Earth using Tesla coil with interrupter circuit only.
Achieving frequency acceleration is one thing but current amplification is also very important.
As mentioned previously i am at a disadvantage since i am living in a high rise apartment.Nowhere near ground for me.
I reread Daniel McFarland Cook's free energy device patent "improvement in Induction Coils".
As a quick test, I connected a couple of identical transformers, primary 1 to secondary 2,
and primary 2 to secondary 1 in a self-looped arrangement, as Cook seems to have described
in his patent, but he used iron rods instead of steel transformers. I then pulsed this transformer
arrangement with a DC pulse from a 12V battery to see what the waveform looks like on the
transformer wires. I then reversed the wire connections between one of the primary/secondary
connections to see what the difference would be. Nothing too much out of the ordinary was seen.
In the second wire polarity connection test I did (wires flipped), the pulse was a little more self sustaining,
but only a little bit. Nothing much out of the ordinary, I think. See the attached scope shots.
In one newspaper article written about Cook during the time when Cook was still experimenting
with his fee energy generator Cook claimed that "he has sent chunks of iron through the roof of a
building into the air out of sight, and, in his opinion, clear beyond the influence of gravitation into
the ether beyond. He is not confident of his ability to control aerial locomotion, but he hopes
to master this branch of the subject before he dies." . The article did not provide any details
on what exactly Cook was doing when he supposedly sent chunks of iron through the roof of a building.
Was Cook crazy, or did he discover something really unusual? I don't know.
Quote from: Void on December 16, 2018, 01:03:26 AM
What Cook had was an actual patent. I would think they would check the device before granting this patent, since you are trying to patent the "impossible". Funny how the patent is missing the page or pages that explain the part C or what ever he had with the coils.
He was so convinced about his levitating car, that he was witnessing some anomalies. I doubt he got terahertz pulses going, so what comes to mind is asymmetric caps, electrogravitics or pulsed magnetic fields. Shooting metal through the roof is easy with a coil.
I think he is a good example what an inventor can do in a barn
Quote from: stivep on December 16, 2018, 02:02:29 PM
No it is rather about violent and aggressive collision
TM mode of TEM surface wave, can only travel in the interface
Wesley
If we assume that the earth is the cover of the capacitor it is missing on the other side. The way to force one side to close the circuit is the key to this energy. If we don't take other elements as fuel.
Belfior: Regarding D. M. Cook, yes, maybe he used a big honking battery to provide a very large
current pulse to some kind of large coil arrangement, and used that to send pieces of metal
through the roof of a building. Back in the mid to later 1800's, that might well seem like a very mysterious
effect, and might lead Cook into thinking that it could be used to make a large metal capsule fly.
Regarding Cook's free energy 'Electromagnetic Battery', Cook seemed to be convinced that it would
continue to conduct a significant current after being given an initial start pulse to get the action started.
He mentioned using iron bars or magnets up to 3 inches in diameter and 2 to 6 feet long for the iron cores.
The only thing I can think of that might be doing something unusual in that simple arrangement is maybe if soft iron
is used in iron bars of that size and with coils with many turns, maybe something to do with the magnetic domains
flipping back and forth in the soft iron bars helps to self-sustain the pulsing action, but it seems to be quite a long shot
at best. Cook's free energy invention never seems to have gone anywhere beyond his own experiments and
patent however.
Hoppy:
Yeah, I found that the video quality is too poor to try to analyze too closely for things like that.
And what about this stuff then ?
http://aetherwavetheory.com/ULF-14-5.html and this
https://www.google.com/search?q=a+barden+caduceus+coil+research+page&rlz=1C1CHBF_en-GBGB813GB813&tbm=isch&source=iu&ictx=1&fir=XFRTtfzsoCdSKM%253A%252C0Kn4mCaRBagKCM%252C_&usg=AI4_-kRYj-EY8T2GkhnzegFEqO-9B_fwbw&sa=X&ved=2ahUKEwi4xZK8rKbfAhXzSRUIHZUlBE8Q9QEwAXoECAUQBg#imgrc=vUjxA5C0c_iuBM:
And this http://www.angelfire.com/un/weirdlabs.com/screas.html
RE Gorchilin claims...here is a quick paper from Smudge on the Theoretical aspects of the claim ,not to say that in Practice actual events...are to be ruled out ?
apparently the math for the theory part has huge issues .
respectfully
Chet K...ps still sorting vendors for Cook materials
and also Melnlnchenko investigation is in progress[for some reason link not transferring yet ?
Quote from: SolarLab on December 17, 2018, 01:15:20 PM
Just curious, where did (5.3) go?
If you read his paper, he substituted (5.2) into (5.1) to get (5.3) (which I didn't bother to reproduce) and then multiplied by current I to get (5.4) which I did reproduce.
Smudge
Quote from: ramset on December 17, 2018, 11:52:52 AM
sorry to interject ,but I was taught some time ago ,if you want to cause a brawl among men....
start talking about politics religion or sports....the fights will shortly follow.
perhaps we have enuff conflict for a while ?
not just one mans opinion......
In many cases on this forum, you need to read between the lines. Also you need to understand, that when people are arguing about stupid shit, they are not using their time trying to find free energy.
Then you just start giving points to people based on their posts. Started an argument -> one point. Started waving his hands, shouting and posting youtube videos, when somebody made an interesting question -> one point and so on and so on.
Then you watch this forum for a year and look at the stats.
ramset, the error of your analysis is to differentiate UL = dLI/dt. Gorchilin doesn't do that.
True, L depends on t, but it is not necessary to differentiate it :)
Otherwise, this leads to an error that occurred at ramset.
This is exactly why Smudges paper was shared , for discussion and clear understanding , I have sent him a note .EDIT TO ADD FOR REFERENCE TO THIS DISCUSSION
as already written before,
respectfully
and also Melnlnchenko investigation is in progress[for some reason link not transferring yet ? ... (https://overunity.com/Themes/default/images/icons/clip.gif) Making sense of Gorchilin.pdf (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/170800/)
....(32.01 kB - downloaded 39 times.).
Quote from: arhitrade on December 18, 2018, 03:54:01 AM
Induced voltage is proportional to rate-of-change of flux, and since flux=L*I/N it is proportional to the rate-of-change of the product L*I. Normally L is a constant so U=-L*dI/dt is correct (the manner in which Gorchelin sums the voltages that negative sign disappears). But when L is not constant then U=-d(L*I)/dt is the correct version to use. Gorchelin is in error. If you believe otherwise please explain why.
Smudge
Quote from: Smudge on December 18, 2018, 04:27:39 AM
Smudge
i dont agree with that.
Induced voltage is proportional to the rate of change of the electric field,not the magnetic field.
The magnetic field is a result/bi-product of current flow,and so voltage must exist prior to any magnetic field or magnetic flux.
Brad
You don't agree, Brad, but that's the way it is. The induced emf in a circuit crossed by a magnetic flux is obtained either by integrating E along the circuit or by the magnetic flux through its surface, it's a consequence of Stokes' theorem, it's a mathematical identity.
Emf = -dΦ/dt (Faraday's Law) = ∮E.dl (E electric field = -∂A/∂t, dl a circuit element where current is induced).
If L changes, the circuit of the inductance changes, therefore ∮E.dl changes too, proof that dΦ/dt is also changing.
The formula U=-d(L*I)/dt given by Smudge is correct. See equation 8.69 here (https://books.google.fr/books?id=RlVVBQAAQBAJ&pg=PA619&lpg=PA619&dq=U%3D-d(L*I)/dt++"changing+inductance"&source=bl&ots=qjOM6_vb18&sig=SssnuGwe-74luJr7IrfFfGGSZ-U&hl=fr&sa=X&ved=2ahUKEwiY-dmJqqnfAhWvz4UKHUg6Df4Q6AEwBnoECAkQAQ#v=onepage&q=U%3D-d(L*I)%2Fdt%20%20"changing%20inductance"&f=false)
Smudge
https://en.wikipedia.org/wiki/RLC_circuit
Pay attention to "Series RLC circuit".
I hope the topic of the error is closed.
Quote from: F6FLT on December 18, 2018, 06:43:20 AM
The part i do not agree with is-Induced voltage is proportional to rate-of-change of flux,
Voltage across a coil is induced by the electric field,there need be no magnetic flux at all if the coil is open. A magnetic field only exist if a current flows through the conductor,but an EFM can exist across a coil without the flow of current,hence-no magnetic field.
So induced voltage is a result of the changing electric field,not the changing magnetic field.
Brad
Quote from: tinman on December 18, 2018, 09:27:00 AM...
If the coil is open and there is no magnetic flux, there is no induced voltage.
I rephrase:
the induced voltage is the integral of the electric field along the circuit of the inductance and this integral is the corollary of the variation of the magnetic flux through the circuit surface. It is not even a question of physics but of pure math once the magnetic field has been defined as the curl of the vector potential A, and the electric field as E=-∂A/∂t. See the Stockes theorem applied to the magnetic field.
∮A.dl = ∫∫dS.(∇xA) (A, dl, ∇, dS being vectors)
You see the electric field on the left through the vector potential, and the magnetic field on the right in the curl of A. The two equations are strictly equivalent. [induced electric field along the circuit] <=> [flux of the magnetic field through the circuit surface]. One can't exist without the other.
bRAD IS DEAD RIGHT! if I pulse a coil before the magnetic vortex starts explain that, or if I use a caducous wound coil the magnetics is canceled out! or if I block the magnetic field with dielectric charge Leny boys low no longer applies. Your talking conventional theory, that no longer applies here. Ilke it or not!
Quote from: arhitrade on December 18, 2018, 07:57:40 AM
That whole treatise is for linear circuits where R, L and C are linear. Gorchelin is not dealing with linear circuits. If you follow the link on that wikipedia page to "linear circuits" you will find the following statements.
Because they obey the superposition principle, linear circuits are governed by linear differential equations.......
In contrast, nonlinear circuits usually do not have closed form solutions. They must be analyzed using approximate numerical methods by electronic circuit simulation computer programs such as SPICE, if accurate results are desired.
The behavior of such linear circuit elements as resistors, capacitors, and inductors can be specified by a single number (resistance, capacitance, inductance, respectively).
In contrast, a nonlinear element's behavior is specified by its detailed transfer function, which may be given by a curved line on a graph. So specifying the characteristics of a nonlinear circuit requires more information than is needed for a linear circuit.
I too hope the topic of the error is closed.
Well which is it? Rate of change of E or H field? Then we can proceed talkin about open coils, which I pulse and get induced voltage on L2. The same way I circumvent Lentz law. Originally I thought Faraday was talking about the rate of change around a conductor. People think this is a coil of wire. It can be any conductor. Like gas in a tube or salt water
Smudge, equations with nonlinear elements are composed exactly the same as with linear ones. But their decision - here you are right - can not be analytical. But Gorchilin does not solve them anywhere, and only considers the energy of the constituent elements.
A solution can also be analytical in non-linear cases, but only in simpler cases.
What we do know is that the fundamental equations are valid all the time when we take the instantaneous values (with some precautions), e. g. B(t)=µ(t).H(t) or I(t)=d(C(t).U(t))/dt...
Quote from: AlienGrey on December 18, 2018, 10:51:12 AM
... if I pulse a coil before the magnetic vortex starts explain that, or if I use a caducous wound coil the magnetics is canceled out! or if I block the magnetic field with dielectric charge Leny boys low no longer applies.
The current and the magnetic field are the same reality. The magnetic field grows with the current, i.e. when charges move. It's also easily explained by relativity, just a question of relative motion between charges.
The magnetic field is never cancelled everywhere space, it's just that you're not looking in the right place.
Please, spare us your over-simplifications.
QuoteYour talking conventional theory, that no longer applies here. Ilke it or not!
It applies everywhere except in the imaginary realm of beliefs.
Quote from: arhitrade on December 18, 2018, 12:06:18 PM
Yes and those energies are not given by the usual LI
2/2 or CV
2/2 if C and L are non-linear. To see that you only have to chart flux v. current or charge v. voltage to establish the area that defines energy is not triangular. If you don't want to do it graphically you need to do it by integration and that integral cannot assume that L or C is constant. I stand by my paper, Gorchelin is in error.
What happens if "everyone" is right? It sure could/would create a complex "stew!" So to speak.
I think that is what Gorchilin used, at least that is what he did in the past.
MathCAD Express (student) - free forever:
https://www.ptc.com/en/products/mathcad-express-free-download (https://www.ptc.com/en/products/mathcad-express-free-download)
So, now I ask whats the interactive relationships of an Induced Electric Field, a Magnetic Field and Current?
Does this explaination, taken from nature, make any sense?
Induced voltage is an electric potential created by an electric field, magnetic field, or a current. The induced
voltage in natural and man-made material is carefully planned in many disciplines, including safety and
equipment protection.
Field-induced voltage is created by either an electric or magnetic field. A voltage-induced electric field is
when a capacitor or condenser is charged with a direct current and a positive charge on one plate and a
negative charge on the other plate are induced. The same capacitor will have a voltage across its
terminals, and this is field-induced voltage. In voltage alteration, the resulting current flow changes voltage
level. When lightning discharges a cloud formation, the extremely high voltage that has previously caused
the lightning decreases to a certain level determined by air and ground conditions.
This voltage may further create a magnetic field, thus it may be referred to as an induced voltage magnetic
field. When lightning hits the lightning arrestor on top of a radio tower, the current surge travels toward the
ground on the grounding cable. This current generates a transient magnetic field that may induce a voltage
on any nearby conductor. The transformation may recur as extensively as the intensity of the original energy
allows. This may suggest why the damage to equipment due to current and voltage surges during lightning
storms can be extensive.
Quote from: F6FLT on December 18, 2018, 10:35:30 AM
I rephrase:
Ah,perhaps we are not looking at the same thing here.
If an open coil is exposed to a changing electric field,then an emf will be produced across that coil.
This is what i am stating.
There need be no magnetic field to induce an EMF across two points.But when an EMF exists across two points,then an electric field also exists.
Brad
Quote from: Smudge on December 18, 2018, 02:18:33 PM
Yes and those energies are not given by the usual LI2/2 or CV2/2 if C and L are non-linear. To see that you only have to chart flux v. current or charge v. voltage to establish the area that defines energy is not triangular. If you don't want to do it graphically you need to do it by integration and that integral cannot assume that L or C is constant. I stand by my paper, Gorchelin is in error.
Differentiation for nonlinear circuits is not a good method. It is better to use the integration and some mathematical techniques that allow you to bypass difficult places. This makes Gorchilin.
smudge
QuoteYes and those energies are not given by the usual LI2/2 or CV2/2 if C and L are non-linear.
In the summer of 2018 I developed some new theories and as is generally the case the normal always seems to morph into something new and quite strange. Now we know the energy stored on a capacitor is 1/2 CV^2 however few have bothered to question what this means?. Why 1/2?, and it was thought that this was an average as in other equations however it is not. Why 1/2?, when an ideal capacitor should be just QV until we realize one cannot charge a capacitor from any source without a series inductor unless we want to lose 1/2 the energy... but why?. Why?, not unlike the two capacitor paradox whenever a singular charge density on one surface is distributed over two surfaces with twice the surface area then so must the charge density be reduced by exactly 1/2 thus the energy must be reduced by exactly 1/2. It is charge density or the well known law of coulomb forces aka like charge repulsion. What is truly strange is that so few have been able to correlate the similarities between electron charge density and the well known gas laws such as Boyle's Law. So what is Boyle's Law?, P1*V1=P2*V2 or if the gas density is distributed over 2X the volume/surface area then the pressure is reduced by 1/2. The mind fart here is understanding that an energy "gain" could very well be an illusion when considering the fact that we squander away 1/2 the total energy with every translation from point A to B due to nothing more than our own ignorance to the facts. Wouldn't that be a shit show?, the icing on the cake as we destroy this fucking planet.
Thus it is not the variable C as a mostly meaningless lumped sum variable, not V as a singular variable never describing the extent of the true difference in potential but the potential in itself relating specifically to charge density. Expand the surface area through electron conduction by 2X then logically we can expect the the charge density to be reduced by 1/2 following well known laws thus the reasoning as to why 1/2 in the equation 1/2 CV^2 becomes known to us. Who would have thunk it?, the moment those charges redistribute themselves over a greater surface area there energy is diminished in some way?... it should have been obvious and in fact it is. However what is obvious when it is not?... unobvious obviousness?, that is...quite fucked.
Thus it is not some abstract notion such as non-linearity which comes into play in my mind and I believe that is the wrong level of reasoning. Non-linear with respect to what?, with respect to where and how?. If any given process was quite linear or natural yet my perception and reasoning of it was not which part of this equation is in fact non-linear?. You see this is the problem with thinking we can be objective from a subjective perspective... it is an illusion. In truth our supposed claim of objectivity is simply a way of saying you should believe my personal flavor of subjectivity because I feel my take on reality is superior to yours which is kind of fucked up because we have reduced science and reality to a pissing contest.
My theory is this... nobody should tell me what I should believe they should convince me. Give me compelling proof or evidence or justification by way of logic and reason and I will be forever in there debt but know anything less is not enough nor should it be. Its's almost 2019 ladies and I intend to get this party started, the time for the standard tomfuckery and trumpignoramacy has long since past and it's time for some for some real men to step up to the plate.
Quote from: tinman on December 19, 2018, 12:08:09 AM
Brad
Now it's clearer. You're right there need be no magnetic field to induce an EMF across two points, but as soon as an open coil is exposed to a changing electric field, the magnetic field is generated. The magnetic field and the current are concomitant, they are not the cause of either of them (yes, it can be surprising), that was my point.
Quote from: F6FLT on December 19, 2018, 03:44:10 AM
So do we need to change Faraday's law of induction, since it talks about the rate of change of the magnetic field? What if you form a changing electric field before the charge carriers move? There will be voltage induced, but no energy lost
What are you burbling on about? none of this stuff (pages) has anything to do with FE! :( :(
onepower
QuoteWhy 1/2?
QuoteNon-linear with respect to what?
QuoteGive me compelling proof or evidence or justification by way of logic and reason
In the case of inductors it is well known that on the familiar B v. H chart an area represents an energy density. What is not so well known is the fact that on a flux (Phi) v. mmf (Ni) chart an area represents energy directly. The first image below shows the flux v. mmf chart for an inductor being charged from zero current at time t=0 to some current at t=T. (I add those times because this whole issue arose from Gorchelin's paper and he uses those). Clearly the inductance is a linear function of current. The green area represents the energy now stored in the inductor, and that energy is recoverable when the inductor is discharged. That area is a triangle and we all know that the area of a triangle is 1/2 base times height. That is where the 1/2 comes in, and it is clearly seen the area is 1/2Li^2 where i is that final value at t=T. Expressed mathematically that energy is given by int(Phi.di), and since in this case Phi=Li/N the integral also yields that 1/2.
The next image is for a non-linear inductor where the core goes into saturation. Again the green area is the stored energy and it is clear that this is
not given by 1/2Li^2. Again that energy is recoverable when the inductor is discharged. In either case it matters not a jot how i varies with time over the charge or discharge period, it can rise or fall linearly in sawtooth fashion or non-linearly like a half cosine wave. Again expressed mathematically that energy is given by int(Phi.di).
It is possible to get more energy out than that put in if the non-linearity changes between current rise and current fall. For instance if during current rise we have something like the second image, then during current fall it changes to a linear fall as in the first image, then we put in the small green area and get out the large green area. This requires some additional feature to change the flux v, mmf line. Stearn demonstrated something in Dublin that did just that, they used toroidal coils wound onto ring cores on their stator and had magnets brought close to the cores by the rotor. While the magnet was away from the core the flux and current build up was linear, but when the magnet got close it cross-saturated the core whence the coil flux dropped to near zero inducing voltage into a load resistor. That produces a clockwise hysteresis loop yielding an electrical energy gain. For this to be OU it must be shown that the differing forces on the magnet for approach and recede do not account for that energy gain. I am not sure that Steorn ever did show that.
Smudge
Wesley
Good to read , and I agree with AG on your movie ,I suppose you know this is a tuff audience
Might be a good idea to bring some Snickers Bars... :) [inside joke between film critiques here , I've read here you don't watch TV ]
Chet
few examples below during intermission at Wesley's theater
http://www.funnyplace.org/stream/snickers-cranky-old-man-25389/ (http://www.funnyplace.org/stream/snickers-cranky-old-man-25389/)
https://www.youtube.com/watch?v=18ya0-OZ58s (https://www.youtube.com/watch?v=18ya0-OZ58s)
Quote from: Smudge on December 19, 2018, 03:27:15 PM
onepowerIn the case of inductors it is well known that on the familiar B v. H chart an area represents an energy density. What is not so well known is the fact that on a flux (Phi) v. mmf (Ni) chart an area represents energy directly. The first image below shows the flux v. mmf chart for an inductor being charged from zero current at time t=0 to some current at t=T. (I add those times because this whole issue arose from Gorchelin's paper and he uses those). Clearly the inductance is a linear function of current. The green area represents the energy now stored in the inductor, and that energy is recoverable when the inductor is discharged. That area is a triangle and we all know that the area of a triangle is 1/2 base times height. That is where the 1/2 comes in, and it is clearly seen the area is 1/2Li^2 where i is that final value at t=T. Expressed mathematically that energy is given by int(Phi.di), and since in this case Phi=Li/N the integral also yields that 1/2.
The next image is for a non-linear inductor where the core goes into saturation. Again the green area is the stored energy and it is clear that this is not given by 1/2Li^2. Again that energy is recoverable when the inductor is discharged. In either case it matters not a jot how i varies with time over the charge or discharge period, it can rise or fall linearly in sawtooth fashion or non-linearly like a half cosine wave. Again expressed mathematically that energy is given by int(Phi.di).
Smudge
Love the last paragraph.
Perhaps check out my new thread on OUR.
Brad
Quote from: ramset on December 19, 2018, 04:17:26 PM
Wesley
Chet
Better stuff on youtube !
Probably not.
Just non-linearity is probably not enough to yield free energy. If you use a harmonic balance simulator to simulate a circuit based on a nonlinear parametric inductance you will find that the sum of power across the whole spectrum is always less than the total input power.
[size=78%]All non-linear elements will generate harmonics. Unfortunately, there is a law which dictates that, in a closed nonlinear system, the sum of the normalized power of all the harmonics combined is always less than one. The only time you can get some apparent gain is when dL/di < 0 but this gain usually happens in a high order harmonic component. I just cannot remember what this law is.[/size]
[size=78%]I think, if you want to get something really phenomenal, you'd better focus on violating some text-book physics laws, like v>c, open-circuit instead of closed circuit... etc, etc...[/size]
onepower In the case of inductors it is well known that on the familiar B v. H chart an area represents an energy density. What is not so well known is the fact that on a flux (Phi) v. mmf (Ni) chart an area represents energy directly. The first image below shows the flux v. mmf chart for an inductor being charged from zero current at time t=0 to some current at t=T. (I add those times because this whole issue arose from Gorchelin's paper and he uses those). Clearly the inductance is a linear function of current. The green area represents the energy now stored in the inductor, and that energy is recoverable when the inductor is discharged. That area is a triangle and we all know that the area of a triangle is 1/2 base times height. That is where the 1/2 comes in, and it is clearly seen the area is 1/2Li^2 where i is that final value at t=T. Expressed mathematically that energy is given by int(Phi.di), and since in this case Phi=Li/N the integral also yields that 1/2.
Smudge
WHAT DO YOU THINK THIS IS ALL ABOUT ?
https://www.thevintagenews.com/2018/06/27/nikola-tesla-fbi/
Chet never mind Marathon bars here is a clue is she really singing sail away or something else |?
https://www.youtube.com/watch?v=2zkjQVh5KmQ
Quote from: Belfior on December 19, 2018, 09:48:18 AM
How do you change an electric field without moving charges?
You have to move the charges of the source of this field, and this displacement will influence other charges which will form the induced current.
19th century electromagnetism is a simplification, very practical for engineering, but using concepts that do not directly correspond to elements of reality (such as a "flux").
There are only charges surrounded by their coulomb field, and only one force, the coulomb force f=q1.q2/(4.π.ϵ0.r²).
For convenience we say that the charge q2 creates a field E=q2/4.π.ϵ0.r², and that a charge q1 in this field is subjected to a force F=q1.E.
From these two only elements of reality that must be considered, the charge with its field, and the coulomb force, everything else results directly, through the play of movements as described by relativity. Only relativity explains electromagnetism without ambiguity or paradoxes.
In 19th century electromagnetism, we have the Lorentz force F=q.vxB that deflects a charge moving in a magnetic field. But from the point of view of the charge in its proper referential, v=0 so there is no Lorentz force. The charge only sees an electric field, this field being E=vxB, which is the result I was talking about, related to the relativistic effect of velocity on the charge's electric field: when a charge moves, its coulomb field compresses in the direction of travel and extends transversely. This is a consequence of length contraction. Transverse reinforcement is what we see as a "magnetic field".
The magnetic field is the Lorentz transform of the electric field, and vice versa. It's the same physical reality, seen from different points of view because of relative movements. Take one and you see an electric field, the coulomb field, take another and you see what you call a magnetic field which is the coulomb field deformed by the speed.
The interplay of forces between the charges is only that of Coulomb's forces, taking into account the relativistic effects on the electric field as soon as charges move, and possibly the delay of mutual influence related to time needed for a field to be built.
The charges act in the same way on each other, whether they are on the source side or the destination side and the reciprocity prevents an action without reaction. Sorry, not the right way for free energy, we have to be much more smarter! ???
AG..Quote
https://www.thevintagenews.com/2018/06/27/nikola-tesla-fbi/ (https://www.thevintagenews.com/2018/06/27/nikola-tesla-fbi/)
https://www.youtube.com/watch?v=2zkjQVh5KmQ (https://www.youtube.com/watch?v=2zkjQVh5KmQ)
end quote
Well not certain about the Tesla Link but the ENYA song my favorite and sailing my passion...and here at the 9 min 30 sec Mark is sailing OU IMO a sailboat sailing 30 MPH for thousands of miles in no wind [just ...Gravity Flow?.
https://www.youtube.com/watch?v=S9-QQx_JynU&feature=youtu.be&t=560 (https://www.youtube.com/watch?v=S9-QQx_JynU&feature=youtu.be&t=560)
and also during intermission at Wesley's theater ,I see the one glove Challenge by TinMan to Smudge above ...on another possible impossibility ??
http://www.overunityresearch.com/index.php?topic=3684.msg70549;topicseen#msg70549 (http://www.overunityresearch.com/index.php?topic=3684.msg70549;topicseen#msg70549)
Hi Everyone,
Before commencing discussion.Merry Christmas and a Happy New Year in advance.
2 Songs I would like to delicate just once this year-
One for Russian comrade/member whom indirectly assisted to translate some of the important Akula speech some time ago.This which I have previously attached in a another kapanadze topic some time ago.
Николай Емелин - Рукава
https://www.youtube.com/watch?v=YPRIlt1MOKw (https://www.youtube.com/watch?v=YPRIlt1MOKw)
Another song for rest of the Audience.
Hozier - Take Me To Church (Dj Mike Radio Edit)
https://www.youtube.com/watch?v=mh0J3xRPe40 (https://www.youtube.com/watch?v=mh0J3xRPe40)
Now back to topic
I need to relay this to some audience whom are researcher or maybe a book worm.
A very important but easy to read article related to Electrical power-
Knowledge of Power is Power
https://www.egauge.net/blog/2015/09/30/knowledge-about-power/ (https://www.egauge.net/blog/2015/09/30/knowledge-about-power/)
I would need any member to advise me if the ions emitted by tesla coil is considered diamagnetic or paramagnetic.Any Tesla setup for specific ion output?
Kindly explain some details as mention above which will assist me to understand certain experiment which I have limited knowledge on what i am dealing with.
Then I can proceed to reveal some more findings related to Akula Kapanadze coil. :o
If I am satisfied with the explanation.
sorry to interrupt Magpwr important question ,But I have been trying to get this Link to work ..The work of Andrey Melnichenko discussion and observations ,if tests show promise a topic will be started here.these claims have been made for many many years ...trying to see why its taking so long [if provable]
http://www.overunityresearch.com/index.php?topic=3683.msg70540;topicseen#msg70540 (http://www.overunityresearch.com/index.php?topic=3683.msg70540;topicseen#msg70540)
Hi magpwr,
https://www.youtube.com/watch?v=PuR3TPcf7f8 (https://www.youtube.com/watch?v=PuR3TPcf7f8)
Might help a bit - paramagnetic Cu...
https://chem.libretexts.org/LibreTexts/Mount_Royal_University/Chem_1201/Unit_2._Periodic_Properties_of_the_Elements/2.07%3A_Magnetic_Properties_of_Atoms_and_Ions (https://chem.libretexts.org/LibreTexts/Mount_Royal_University/Chem_1201/Unit_2._Periodic_Properties_of_the_Elements/2.07%3A_Magnetic_Properties_of_Atoms_and_Ions)
http://periodictable.com/Properties/A/MagneticType.html (http://periodictable.com/Properties/A/MagneticType.html)
Looks like Cu = paramagnetic [copper metal] (somewhat affected by magnetic field)
and Cu+ = diamagnetic [copper ion] (not affected by magnetic field) {some theories}.
If the ion(1) is in "Air" (70% Nitrogen [paramagnetic] and 30% Oxygen [diamagnetic]
or an electron particle {or energy wave} moving through the Air [?], or vacuum (CRT) [?].
(1) Ion is basically an atom or molecule where the number of electrons does not equal the total number of protrons,
yielding a positive or negative charge.
Example: Magnetic field (yoke) action on an electron beam (fast ion stream from hot cathode) directs the charged
electrons to a "pixel" location on a CRT's inner phosphor face. The released energy lights up the pixel.
Magnetic fields steer or deflect the electron beam but do not affect the electron speed, the HV [grid] does that.
[ ??? I could be wrong] It's a complex process at this detailed level and there are conflicting theories to pick from.
https://www.youtube.com/watch?v=sENgdSF8ppA (https://www.youtube.com/watch?v=sENgdSF8ppA)
Lots of "stuff" to ponder and sort out!
Quote from: ramset on December 20, 2018, 01:57:50 PM
hi ramset,
I have read the article in pdf.I realized that this experiment is somewhat similar to what Akula have shown in his channel some time ago with 2 bulbs.
For simplicity I have attached Akula and the Transgender circuit for everyone to see.
In Akula video what I can recall is the bulb located on the left side of the circuit would dim but the bulb to the right would be brighter.
I have actually tested(In virtual circuit) the interesting part of Akula circuit which the nanosecond pulse generator around 5ns was actually created by 2 transistor connected in series to the gate of IRF840.This was found to be around
5ns in the virtual settings once it hit the breakdown voltage. This is nicely done with minimal trigger circuit.
This is activated by the sine or square wave fed to the transformer(top) input.In circuit is shown as not connected to anything.
I merely associate these 2 circuits which does the same thing with bulbs but design differently.In Akula circuit the bulb to the left side of the circuit if dim would represent as low current passing through.
I have not dug deeper into it maybe because of other project distraction.But it's definitely worth the time to experiment with one of the 2 mentioned circuit.
All this talk about E field not being possible with the H field. So can I create a static electric field and then feed that into a capacitor and if I can't, what might be the reason?
What is stopping me using a Kelvin water dropper to charge a cap?
https://en.wikipedia.org/wiki/Kelvin_water_dropper
Quote from: Belfior on December 21, 2018, 07:32:41 AM
You can charge a cap with a static field,but as soon as the charges in that static field start to move into the cap,it is no longer a static field.
And when charges start to move or vary in time,a magnetic field then also exists.
Yes,you could charge a cap with a kelvin water dropper,and also with the likes of a peltier module.
But as a cap requires current flow to charge,a magnetic field is formed as soon as current starts to flow.
One question to ask would be this-- when you take a plastic comb,brush it through your hair,and then find that a small piece of paper is attracted to the comb,when the piece of paper was heading toward the comb,did any current flow?,and was a magnetic field also produced?.
The same can be asked when two opposite poles of two magnets are attracted to each other.
We know that a magnetic field already exists,but when the two unlike poles are pulled together,was there any flow of current,and did an electric field exist at that point in time?
Brad
Quote from: SolarLab on December 20, 2018, 08:57:23 PM
Hi magpwr,
hi SolarLab,
I appreciate the effort made for trying to explain ion to me.It is not a easy thing to fully understand. :)
Since you have brought up CRT which i had read sometime back but forgotten something valuable.
Related to display-HV in crt apart from charging the high voltage plates at the back of crt and
accelerates Electron beam.
Going back to nature-
In nature "ionization" plays a crucial role in tropospheric "cloud formation"
No lightning(
HV) can be produced without clouds
Ions->HV
Related to bench experiment-
Need to do the reverse from nature.Generate HV from tesla coil.Using HV to generate ions (Likely paramagnetic ions.Wild guess for now) to
alter the NMR of Cu.
HV->Ions
Why bother with that snail form of charge, It's antique junk ;D A plasma ball would be a much quicker if your really that desperate and you could try to cover the ball in a silver paper ;D to collect the ions but you might need some diodes and high voltage caps as well.
BUT BE AWARE CHARGING A CAP WITH STATIC IS NOT 'SCALAR' BUT IT CAN STILL KILL YOU AND IF YOU USE AN EARTH IT WILL BE MORE LETHAL.
Ps note some countries label mobile phones as GRADE 2 CARCINOGENIC ;D ;D DUE TO THE MICROWAVE OUTPUT have you tried seeing if thats a form of scalar?
Air Ions and Electrostatic Formulas [information from an instrument maker - good]
Electrostatic Formulas for Force, Voltage, Discharge Time etc. on Charged Samples or Surfaces
https://www.alphalabinc.com/electrostatic-formulas/ (https://www.alphalabinc.com/electrostatic-formulas/)
[relates to AlphaLab's Air Ion Counters and Surface DC Voltmeters and other instruments]
Contains some excellent information and formulas regarding electrostatics, ions, etc...
About Air Ions (included in the above):
https://www.alphalabinc.com/about-air-ions/ (https://www.alphalabinc.com/about-air-ions/)
{ambient environmental effects on the system - enclosed in fish tank ??? ?}
Quote from: F6FLT on December 22, 2018, 05:46:30 AM
So the microwaves would be as dangerous as coffee, salmon, chips, pasta, canned tomatoes, milk, sugar... (https://www.msn.com/en-in/health/nutrition/the-20-most-carcinogenic-foods/ss-AAkcj2t) which are also carcinogenic?
If you eat chips while on the phone, you'll surely drop dead. I'm also terrified! ;D ;D ;D
What isn't? nothing is sacred once the MonsanoSatan flys get on it, but that's another distortion. I was just testing if you had discovered the other connection between the phone and the microwave and what you seek.
PS You eat chips i use sockets, do you mean pomms frits?
Happy New Year From Wesley USA
https://youtu.be/KLAPRNWuAn4 (https://youtu.be/KLAPRNWuAn4)
Wesley
Very well done.
However, do you really need the line 6 (i.e. TEM line) in the circuit?
The ground itself is already a TM waveguide. You should not need a closed circuit to make it work.
Blueplanet
Quote from: stivep on December 22, 2018, 05:43:41 PM
Wesley
I have been lurking in this thread, feeling very hesitant to post anything technical. This time, I need to make an exception:
(Just watch the video demonstration in this page for more information)
https://ieeexplore.ieee.org/document/8548540?arnumber=8548540&source=authoralert (https://ieeexplore.ieee.org/document/8548540?arnumber=8548540&source=authoralert)
Wesley
Wesley, many thanks for sharing your interesting video, be safe be aware and Merry Christmas to you and your family.
Best video i have seen since slice bread.
Thanks for sharing.
Merry Christmas and A PROSPEROUS NEW YEAR.
The energy-saving light bulb is on. With an ordinary Tesla coil, too, they will light up and you don't have to touch anything.
When you put the microwave bulb into the RF stream, it will also light up.
I see such similarities here.
What about your health - if the rubber is damaged....
Transferring this power to the output makes sense and shouldn't be too harmful, so if the 90 degree phase shift generates power, why let it go into the ether?
I see here two common or different versions for Kapanadze.
1.accelerating electrons by HV
2.accelerating electrons through a 90 degree phase (and/or HV)
Wesołych Świąt !
Quote from: SolarLab on December 23, 2018, 01:07:31 AM
Nikola Tesla Quote:
The scientists of today think deeply instead of clearly. One must be sane to
think clearly, but one can think deeply and be quite insane.
Hi Solarlab. It appears to me that many people seem to think that someone is either
insane or not insane, delusional or not delusional, but in my experience that is not at all
a correct perspective. In my experience the delusional/sanity level of any given person in
this world actually falls on a bell curve, along the lines of what I indicate in the following attachment.
As you can see in the attached drawing, the center of the bell curve is actually quite a ways over
to the right, well into the more delusional range of the scale. :) I believe that this is a much more
accurate view of the where people in this world really sit in regards to how delusional each given individual is. :)
in these times "viewing reality as it is" is very far from what you get from TV and other sources. Delusional are the people that believe all that
Quote from: Belfior on December 23, 2018, 08:11:48 AM
Delusional are probably all of us in the grand scheme of things. :)
Hi,
There is no return wire. The energy propagates along the surface of water in much the same manner which Marconi or Tesla has suggested. The meter has no connection with the source. It was there just to show you how much voltage (and current) was captured by the neon lamp, which requires 120 volts to light up.
As I explained to you in another thread, you may need an RF ground but this RF ground is no more than a small piece of open ended metal (so-called antenna), a body or whatever similar. It does not need a physical connection with the ground of the energy source.
Marconi and Tesla were the originator of the concept of monopole wireless power transfer. Zenneck and Sommerfeld have just tried to explain Marconi's or Tesla's experimental results with Maxwell's equations.
Zenneck theory is in direct contradiction to the law of relativity. It also violates the law of energy conversation. Perhaps, this was the real reason why it has attracted so many nay sayers. However, Zenneck's controversial theory has been experimental proven by many research groups.
Don't hesitate to ask questions.
Blueplanet
Quote from: F6FLT on December 23, 2018, 08:15:38 AM
Isn't that too good to be true? Because whenever it is Avramenko's transmission by a single wire, what I observe is only a circuit looped by a terminal capacity, to ground, and so back to the generator. Their experiment on water is not fully convincing. Nevertheless this paper could raised a doubt in my mind.
I will now take a look at the other documents referred to in this one, and at the other documents of the authors.
In any case, great subject, right on the mark.
Thank you blueplanet!
Quote from: NickZ on December 23, 2018, 09:54:33 AM
So, Wesley, where is the free energy part??? All shown videos are using a source of power to run the device. Where is the similarity to what Kapanadze or Ruslan has done to light 4 to 5.000w worth of bulbs, with NO extra power source. What was shown is only lighting leds bulbs just a few feet away.
Hi Nick. I also don't see the connection between Zenneck waves and Kapanadze/Daly/Akula/Ruslan setups,
but maybe we are missing something there. :)
We are living in a world that is full of illusion. One source of illusion is the so-called Norton wave. Another one is C.R. Burrows' theory. Both of them were inventor of fake science. The topic of surface wave has completely lost favor for one century simply because of their junks. The more you read their junks, the more you will get confused.
I should add one more: scalar wave :)
Quote from: blueplanet on December 23, 2018, 10:14:41 AM
Nothing new just scalar wave ....
https://www.youtube.com/watch?v=FasAn7aJa6o
https://www.youtube.com/watch?v=gGdKqdpztuY
Nelson Rocha
Quote from: nelsonrochaa on December 23, 2018, 10:28:55 AM
Nelson Rocha
Hi Nelson. Nice experiments. I am not convinced that what you are showing there is related
to scalar waves however. I think it is just demonstrating the ability of of EM waves to propagate
down a single wire and to couple energy into conductive materials.
Our mad scientist friend Wesley showed a light bulb lighting on a block of plastic, which should not be conductive
at all, so I found that quite interesting. I am not sure why the light bulb lights up when Wesley touches it to the plastic block.
It would appear that maybe the plastic block builds up a static electric charge on its surface somehow, or maybe
it acts more like a conductor when radiated with high frequency radiation in certain frequency ranges?
https://www.youtube.com/watch?v=-BbVqrDv1bk
This is an experiment with a piece of Teflon which keeps the charges in itself and transmits it to a rotating disc. I don't know how much it has to do with this, but obviously the Teflon affects the increase in voltage.
Firstly, thanks to Wesley for taking the time to put together his interesting video. However, like Nick, I'm wondering where the free energy enters the demonstrations shown in the video. We are led to believe that Kapanadze's devices had no conventional mains or battery power supply and started simply from the pulse from a small alkaline dry PP3 or similar battery. What was the source, nature and quantity of the supply of energy used to charge the dialectric material / glass of water in the video? I was lighting neon lamps and LED lamps years ago from the terminals of isolated SLAB's when running Bedini SSSG's.
Quote from: F6FLT on December 23, 2018, 12:42:45 PM
Are you sure it's Teflon? (the types I know are not translucent).
I wonder what makes the asymmetry that allows to separate positive and negative charges while the setup seems symmetrical.
The Teflon is the applied rectangle and the disk is Plexiglass.
This is my film.
The board is Tivar anti-static plate
made for people working with sensitive electronics.
1.5x12x12 inch
dk 2-5-10
It prevents electrostatic damage to components.
Label is shown on my video.
But that only says that you do not analyze my video carefully.
As always the devil is in details .
However at the end of video I used pad made from rubber with Ortec name on it.
- between glass and plate
Wesley
Quote from: stivep on December 23, 2018, 01:46:23 PM
Hi Wesley. I thought in the video you said it was non-conductive plastic, but I watched the
video just after waking up, so I wasn't too alert yet. :)
I didn't hear you say it was an anti-static plate. What is the resistance if you measure across it
with an ohmmeter? Does it measure a resistance?
Quote from: Void on December 23, 2018, 02:55:34 PM
You didn't read Morey's book pdf'S this type of wave whatever you want to call it can eat through glass plastic or any insulator.
and suck energy from you given the right characteristics and a Faraday cage is of no use whatsoever.
https://www.youtube.com/watch?v=sAnfBemgyb4
Tivar or UHMW Polyethylene is a type of thermoplastic polyethylene that features an extremely high molecular density.
This makes it a durable material, with the highest impact resistance of any thermoplastic presently made.
It has low moisture absorption, a very low coefficient of friction, is self-lubricating, and is highly resistant to abrasion.
Very high resistance.
Protects against electrical charge build-up
But that is not the most important.
Wire must have an insulation to work with surface wave.
And if winded with magnet wire it will not work.
Just forget the lightbulb. This is not important.
It is like looking at the car and thinking is it electric or gasoline or any other fuel operated.
Just look inside of it...
Do not look at car front head lights.
Wesley
Hi Wesly I've been your followers for a couple of years now - when you took part in our Polish forums. I have to say that I admire your knowledge, analytical and synthetic skills;) as well as your stubbornness, commitment and reasonableness in FE activities. It seems to me that we have a common "Alma Mater": PG ;) I am by profession and passion the designer of electronic systems, based mainly on single chip microprocessors, which I'm doing until now, even after I've retired. Coming back after this personal introduction to the subject: I think that a "coupled pair" of two generators generating simultaneously functions such as sine and cosine (i.e. a 90 degree shift) could be easily realized through DDSs (Numerically Controlled Oscillators - NCOs). Then only the power amplifiers on some powerful MOSTEFs, the Tesla coil and fast rectifiers on the secondary side. The question is what frequency the device should work on: do you follow the principles used in the construction of the Tesla coil? I greet you and the Forum members beautifully! Merry, Healthy and Successful Christmas and Happy New Year!!! Jerzy
Quote from: stivep on December 23, 2018, 03:27:58 PM
Hello Wesley. Now that you have explained that the tivar plastic block is for anti-static use,
it makes more sense to me that you can light the light bulb when touching it. It has carbon
added to it to give it the conductive anti-static properties (accounts for the dark black color). A data sheet
for this type of product states:
"The incorporation of an effective carbon black grade renders this material electrostatic dissipative properties. "
This gives it the conductivity to absorb energy from the TEM waves radiating in the room, although the surface
may be plastic coated so you may measure the surface as being an open circuit with an ohmmeter.
As with Nelson's videos, I am not so sure your demonstration is showing Zenneck waves (or scalar waves in Nelson's case),
but I find it interesting that the distilled water also lights the light bulb. The issue I see with what you are showing
is that you probably don't need a dielectric at all to light the light bulb. I think you should be able to lay a sheet
of aluminum foil on the table and touch the light bulb to the aluminum foil, and the light bulb would also light.
This is because the EM waves transfer energy to conductive objects, in the near field at least. However, maybe there
is more to it than that, but I would need to see some explanation regarding how what you are doing is different
that what we can expect to see when just radiating with 'ordinary' TEM waves radiation. I don't think you have done that,
but maybe I am missing something.
Dear friends I'm not at home and my wife really expect from me to have more time dedicated
to time spend together after long week making the video.
Note:
1.please do not confuse
Fig # with
coil #Fig# say about drawing
Coil# says about particular coil on the given Fig.
2.
Please assume that Tariel know about energy transfer using surface wave.He did not understand how it works but knew how to make it work.
He had no idea about surface wave.
3.He also noticed that High Power energy receivers for some reason works when "hold in hands"
4.
credible source: Tariel got major part of his art from old Russian scientists who for some reason vanished shortly after meeting him.
5. After Tariel start to measure using primitive tools amount of light from light bulbs he conformed that heat exchange comes to strange but real-
-the same lightbulb gave more light than if it was connected to the grid for much less energy use indicated at input.
6. Tariel used coaxial cable and/or HV automotive cable and made prick in the wire to just get the right phase shift.
7. Another way is to use additionally a capacitor and that can be seen in his "Tent presentation"
8. Tariel is just old architect who learnt all the basic electric knowledge .
That is why he was in need to have someone he could trust and who knows more.
That was the guy who was always with him on every video.
Short:
- in https://youtu.be/KLAPRNWuAn4?t=201 (https://youtu.be/KLAPRNWuAn4?t=201) you see winding used by Alexey Pastukhov that is matching the way we winded coils in Lithuania Experiment.
For more information about Lithuania Experiment contact Arunas T-1000
These are the two primary windings.
In
3:57 you see two pipes structure instead of one pipe proposed by Andrey. (https://youtu.be/KLAPRNWuAn4?t=217 (https://youtu.be/KLAPRNWuAn4?t=217))
The pipe is made from soft iron or you can use ferrite kielbasa
(like SR 193) with conductive soft iron pipe inside or even copper foil around( preferred iron or bunch of very soft iron wires instead of pipe)
The second pipe is connected to ground. Do you remember me pounding at, two ground structure for so long ?
I went to South America to check it.
The pipe is replacement of
coil #5. and both the figure# 2 and figure# 3 are shown here: https://youtu.be/KLAPRNWuAn4?t=454 (https://youtu.be/KLAPRNWuAn4?t=454)
At fig3# coil# 5 is replaced by iron pipe ( or in my case by two pipes now is called
coil #10)
However coil from figure #3 as coil made not from pipe but from wire is presented in figure #2 - will work as well.
The
Charge Line Bournlea I specified in words as:
Quote"You can not see it at the driver"
That means driver will not see it.
It is also said:
Quote" depends where you are in regards to 50 ohm impedance of the coil you will have inductive or capacitive reactance leading and that can be seen at the Smith Chart."
( the wording is little different.)
We are looking for capacitive response from the Charge Line.
It is also said :
Quoteit makes voltage reversed in sign doubling the voltage
In video https://youtu.be/qdJ1V_yDv-c?t=482 (https://youtu.be/qdJ1V_yDv-c?t=482) I have shown the structure with two primaries in little different arrangement.
You can clearly see at the bottom of Tesla coil first primary and on the top of it second primary
However coupling was different . That means primaries have not been identical.
the upper coil used air gap and ferrite core like in flyback.
That gap serves as temporary energy storage. in every flyback transformer and that is what makes trick in phase delay +
Charge Line. Once you understand how the mechanism works , "there are many ways to Rome".
But
coil #5 fig #3 (from my last video link above ) must be in resonance. so it is frequency dependent.( slowly increase the frequency till you get it)
Akula, Ruslan had used two generators with rectangular shape impulses making 90degrees phase shift.
Tariel used mostly sinusoidal wave form that made the life easier for him, but the effect to achieve significant energy, was much more difficult to do.
("Sinus is good up to 1kW till becomes a pain")
Yes square wave is more friendly but so much frequency dependent.
The important is the rapid sharp rise time of square impulse to make violent interaction that is why it is preferable.
https://youtu.be/qdJ1V_yDv-c?t=541 (https://youtu.be/qdJ1V_yDv-c?t=541) this part was heavily criticized by SolarLab.
But that is just another way to go.. using plasma and spark gap.
In patent application of Andrey Pastukhov he mentioned about means of transmission line : wire, gas, air/plasma.
In some instances Tariel used electrical motors as shown in my video https://youtu.be/qdJ1V_yDv-c?t=651 (https://youtu.be/qdJ1V_yDv-c?t=651)
The interaction between two primary coils and
coil #5 must be violent.
The frequency and amplitude must be the same but phase must be shifted at 90.
Practical observation shows that slight (but rapid) !!!!!!! variation of frequency of one oscillator even for fraction of 1 Hz in sharp square signal make trick well done.. However it is observable with sinusoidal as well.
that can be seen in my old video:
https://youtu.be/F2BED9aDEYw?t=94 (https://youtu.be/F2BED9aDEYw?t=94). look down the video.
So just wiggling ( rapidly one of oscillators makes that strange response.... That what everyone ignored was small word
NMR https://youtu.be/KLAPRNWuAn4?t=430 (https://youtu.be/KLAPRNWuAn4?t=430)
and that makes us back to Lithuania Experiment.
https://youtu.be/KLAPRNWuAn4?t=520 (https://youtu.be/KLAPRNWuAn4?t=520) shows all mechanism and similarity of all of the guys who made the device .
It also says that for square wave shape it is recommended to use two generators instead of just one and capacitive phase shift.
Starting from that point in my video it is the most important part to understand.
Do not get confused: Yes even if Tariel knew about surface wave energy transfer he went much deeper to get his self-runner. ... just because he could...
not because he know what he is looking at.
That is why he could fool people around .. even in front of Turkish Ankara scientific institutions when glass table presentation was taking place.
Out there they build Faraday cage and made Tariel life more difficult but ... there was 2.5 mill on the table for TMZ and Ministry of Finance was involved.
Tariel simply did not have much choice.. do the job right...
TMZ was dead in 2008 because Tariel did not want to cooperate and say more.
My dear troll group visiting this forum:
I know how much push "they" make on you, to get the job done.
I really feel your pain.. and stress you are exposed too.
How much do they pay you for it...?
There is a nice group of guys on this forum, who can easily spot you..
Because you are characteristic.
Secret of Tariel , Akula, Ruslan is also characteristic , but is clean , innocent.
All they wanted is money for their work.
They are not Trolls.
I wish the best to you all. Including Trolls.
Wesley
Hi Wesley. If you are busy, there is no need to answer.
Well, I really don't see anything in your explanation above that requires surface waves/Zenneck waves
to be involved. It is almost like you are trying to shoehorn that in, but there is really no requirement
for it there that I can see. Also, in your demonstration in your video, I would be very surprised if you
also couldn't lay a sheet of aluminum foil on the table and the light the light bulb as well. No need
for a dielectric sheet that I can see anyway. Just some honest feedback. All the best for the new year.
Quote from: stivep on December 23, 2018, 09:03:22 PM
Void my friend. go back to my post from above :
2. Please assume that Tariel knows about energy transfer using surface wave.
Please notice how easily the LED that should work at 440V 1A lights uphold in hands of the first and second guy touching it in the beginning of my last video.
Whatever dirt we may put on Tariel......... he did it.
I got to go....
Wesley
Wesley Yes he did my Russian is atrocious but I stuck at translating a good bit of his garden party video, when he was in the room with the bed he says he found a way of locking the two waveform phases but which ones back then now it all adds up thanks very much. ;D
Quote from: blueplanet on December 23, 2018, 10:22:02 AM
Mr Blue Planet I have a question for you, do you know what a scalar wave is exactly and what produces it ??
Does it agree?
2x sine 10V / 50Hz
As Wesley has pointed out, please assume that Zenneck surface wave is the only key to understanding of the physics of overunity.
I am sorry I am not interested in scalar wave, norton wave, etc, etc.
Quote from: AlienGrey on December 24, 2018, 05:22:47 AM
Quote from: r2fpl on December 24, 2018, 06:05:02 AM
Does it agree?
2x sine 10V / 50Hz
Hi r2pl,
I have attached simplified version. :o
The hint was already provided in my previous link few days back.
Knowledge of power is power.
Square wave 90° phase shifted as attached.Obtained from some random sites.
Circuit indirectly related to HV interrupter phase shift circuit was also attached by me 2..4 weeks back.
So is a surface wave ET looking down seeing some illuminate oil tycoon giving a hand gesture only when ET gets closer sees it's his two fingers ie little finger and index finger. Yes, very funny who do we trust ET, the Illuminati, or the remote viewer on none. :'( :-[
Quote from: magpwr on December 24, 2018, 08:12:50 AM
Hi r2pl,
I have attached a simplified version. :o
The hint was already provided in my previous link a few days back. Knowledge of power is power.
Square wave 90° phase shifted as attached. Obtained from some random sites.
you can do it with 2D types or JK flip-flops but you need 2 clock pulses to drive it with (easy) another set of output transistors to drive the coil
Quote from: F6FLT on December 24, 2018, 10:05:07 AM
For those who would be interested, as I had only found Melnichenko's last patent in Russian, I had it translated by DeepL (except the first page), see attached file.
I recall that several years ago when Melnichenko had his website up and also had
his demonstration video, I tried replicating his setup he was showing at that time, and
I could not see any signs of OU in that setup. It was several years ago that I tried replicating
that setup, but I seem to recall that I found that Melnichenko was making some obvious error in his
calculations or assumptions, although I can't recall now what the error was that I found.
It might possibly have been that he wasn't taking phase angle properly into account, but I can't recall now for sure.
At any rate, I could not find any indication of OU in that particular setup that Melnichenko was
showing on his web page a few years ago, and he provided all the details for his simple circuit setup,
so it shouldn't have been a matter of missing something in the setup.
I have reedited my previous post so please read it again.
Wesley
Quote from: magpwr on December 25, 2018, 12:07:48 AM
hi Wesley,
Good day to you.
I merely need clarification is polyphase as mention and Polyphasic waveform the same thing.Not easy for me to visualize. I have attached old experiment base on similar waveform base on a single shot of high voltage nanosecond pulse.
Hi that's a lot of diodes how about using a dc to dc to get about 150 volts and using a fast low voltage bipolar transistor and
exploiting it's breakdown voltage to get around 5 nano secs? it would be far cheaper.
Quote from: AlienGrey on December 25, 2018, 12:34:32 AM
Hi AlienGrey,
The reason i reveal my previous circuit (Divide by 3)only because i saw that you created a pcb for the pll project.Since i thought it is pointless to give to someone whom merely do electronic components assembly.
Recall that i achieved around
178khz but 2Vpp sine-wave from Kapanadze coil was because i was using low frequency IGBT.Snubber circuit resistors need to changed to 10Ohms 2...3watt(SMD low inductive).Akula if he still sticked with IGBT it would be 50N6S2(Because base on datasheet can handle up to 200khz).In this case i don't see the harm in using Mosfets since snubber issue was resolved.Even if you take inductance reading from kapanadze coil output and combine with 5nf as was used in provided Akula circuit.Then you will roughly know what is the estimate resonance frequency of the kapanadze coil output as base on Akula circuit.
May i ask have you done anything related to my provided circuit during December.
Honestly i am little lazy to touch any project during this holiday season except research. :D :D :D
Hi r2pl,
The hint was already provided in my previous link few days back. Knowledge of power is power.
Hi magpwr,
I think you've done everything to make sure it doesn't work.
You don't have to turn the phase 90 degrees, just do one of the two possibilities:
Invert the coil or/and give a half sine signal.
My question is now:
Does Kapanadze give HV or generates HV?
For believers in patents:
Patents are for the rich and for corporations. When a poor person has something that a rich person wants, a rich person simply takes it, so when someone tells me about a patent, it's naive.
What we want to do will not be protected by any patent. Is it clear to everyone!
https://www.youtube.com/watch?v=ZA5cZ2Mvj5I
r2fpl ...the FE patent trap
getting a patent application for a true FE device is like handing a man a stick to beat you with.
Regardless IMO it would be like trying to patent clean water or fresh air [ethics ?]
More from Naser Technology in English
https://www.facebook.com/naser.technology/videos/vb.287496675051713/832476320291928/?type=2&theater (https://www.facebook.com/naser.technology/videos/vb.287496675051713/832476320291928/?type=2&theater)
Quote from: ramset on December 25, 2018, 07:34:13 AM
r2fplthe patent trap
More from Naser in english
Yeah! the Bushes were getting there slowly. They were trying it with people by cloning and changing peoples DNA, it's about greed,
Dear magpwr
I'm taking a minute as my wife after Hanukah and my video making work, expects some attention.
Please look at application of polyphase and effects of this application by carefully reading US 2018/0183128 A1
https://patents.google.com/patent/US20180183128A1/en (https://patents.google.com/patent/US20180183128A1/en)
look for word polyphase e g [0028]
I'm sure it helps a lot.
..also some about surface wave as "I think many of you simply do not understand it yet.
Wesley
Quote from: NickZ on December 25, 2018, 09:57:51 AM
Stivep:
To help us understand, you need to show some proof. Not just a guy lighting a small led bulb a foot away from it's source. Perhaps it's you that doesn't get it. There is no free energy in surface waves, no OU, nor self running, either. So, what is all the hype about??? We are still waiting for your supposed bomb shell of a device. Did you forget about that, already? Or, I guess I must of missed it. The fact is that you are showing nothing new, and trying to impress with useless surface waves, and the like. Really Wesley... Are you going to keep kicking a dead horse???
Note that the method of producing a wave for Tesla is determined by the two coils which are in opposition and their phase angle is 90 degrees. Many of the devices described mention an angle of 90 degrees whatever it means.
Did you do this system for Tesla ? I didn't do it so I don't know if there is more than just a remote energy transfer. In this setting of coils I see the possibility of generating an additional "wave" or something there for the effect of ether stimulation. It's all my theory, but it's worth checking it every time. Because once you don't check and ...
Sorry that I answer not asked.
NickZ:
I'm sorry that you didn't understand what I wrote. This is translated by GTranslator :(
Writing the answer you answered partially to the question but I still don't know if you are using a 2x primary coil for the Tesla coil? If so, I understand your fears that there is no more energy from the inserted energy.
Quote from: SolarLab on December 24, 2018, 02:07:02 PM
His invented devices do work (many have sucessfully tested certain versions), use conventional theories, and can be
readily analyzed using advanced electromagnetic computer aided engineering tools. If you have followed Andrey at all,
you also know he has a variety of differing designs, including some self running types.
Hi Solarlab. Who has successfully tested certain versions of Melnichenko's devices?
Where has Melnichenko demonstrated a self-running device?
All the best...
Quote from: blueplanet on December 24, 2018, 06:08:54 AM
As Wesley has pointed out, please assume that Zenneck surface wave is the only key to the understanding of the physics of overunity.
I am sorry I am not interested in a scalar wave, Norton wave, etc, etc.
Mr. Blue planet You asked a question by saying in another post by stating Wesley needed earth return wire or should do.
Obviously, your self and others don't understand how a 'scalar' or whatever you wish to call it works or what it actually is Well for your reference and others
who don't know it is a 'Dielectric' charge are you any the wiser now? a dielectric charge is like charging a capacitor and throwing it, it's a dielectric charge
produced by the top load of the Tesla coil. You don't necessarily need the earth.
AG
Where did you get this story from?
I don't recall such a stupid statement.
I have never said the receiving end of a wireless energy harvesting system need a earth return wire. I said it might need a RF ground, but this RF ground is completely different thing.
As I said many many times (since the beginning when I rejoined this forum), I stand by the original concept of Zenneck/Sommerfeld surface wave or Tesla's surface wave, or Marconi's surface wave.
I am an independent researcher who sticks to fact. You don't need to convince me with your belief in "scalar" wave.
If you think you are well ahead of Zenneck/Sommerfeld, Tesla or Marconi, that's also fine with me.
Quote from: AlienGrey on December 25, 2018, 01:50:46 PM
AG
Quote from: blueplanet on December 25, 2018, 04:02:20 PM
Thanks for your 'stupid' comment which says more about you than me, I suggest you re-read your question to your first post since my question to you
is not what you have replied to here,
As you have brought up a reference to RF earthing perhaps you can explain the difference so others can understand your reference to others.
and please keep any reply civil,
AG
Once again, I need to re-emphasize that the RF ground does NOT need any connection with the earth connection of the energy source. I have never said anything about RF earthing or whatever. (Edit: RF ground is the same as RF ground stub.)
Zenneck wave is a well known science. Unlike the dark age, when the trolls have brainwashed the society with their negative information, a lot of scientists have nowadays published their experimental findings that are not quite consistent with the laws of relativity. Before misleading the world with your minority opinion, please read the literature in the IEEE digital library for more background understanding first.
https://ieeexplore.ieee.org/search/searchresult.jsp?newsearch=true&queryText=zenneck%20wave (https://ieeexplore.ieee.org/search/searchresult.jsp?newsearch=true&queryText=zenneck%20wave)
The reason why you keep arguing with me is because you have NOT read anything about surface waves, Tesla's wireless power transfer or Marconi's first breakthrough experiments done in Italy. There is a lot of important information in this surface wave.
You might have read a lot about scalar waves from some internet sites. But if you have little or no appreciation about the implication of the Poynting vector being zero along the transmission pathway, there is no point to further any discussion.
Quote from: AlienGrey on December 25, 2018, 06:28:55 PM
AG
BP your bedside manner is atrocious and rude and your hyperlink points to a commercial/corporate charging information center.and does nothing to help people on this DIY thread.
The thing is Wesleys Film covers a lot of ground in his coverage, the first part is obviously about a different concept ' surface waves.
I was asking you about the Don Smith, Dally, Ruslan device. Since your 'Handle' leads one to assume your a 'Save the planet', 'Guru'
Perhaps I should have made that clearer.
What a wonderful helpful being to society you really are!
AG
Quote from: NickZ on December 25, 2018, 12:01:14 PM
Stivep: Ok, you sound tired. I'm just a little hung over, and maybe we are also tired of hearing about all those things that we can't understand. Like Zenneck waves, and such. But, only you can understand, yet produce nothing to show for it as any type of proof.
Ok, I will forget about the light bulb, and it's output, and focus on the source of the energy instead.
Perhaps you'd like to show some measurements, some scope shots, explaining the output power, even without the bulb.
I will look over your re-posted link. As I am more interested in being accurate, than in being nice. And to provide proof for my ideas.
It's much easier for you Wesley if you provide some proof, then you won't have to worry about being nice, or not. Otherwise this thread is going in the direction of the original TK thread. 1500 pages, and not a single working replication. Just speculation, and talk.
How about if you show how and explain why the dielectric is charged, as your video with Andrea has no sound and the text is unreadable. And your video with the light bulb, is not clearly explained. At least, not to me. Or do you want us to have to guess about what is happening.
To Nickz,
I think you are being extremely inconsiderate knowing that Wesley is on Vacation at the current moment.You seems to be arguing with him as if he is a customer support service and act like he own you something valuable.Please stop trying to ruin his vacation with his wife.Please again.
Can't you just wait for him to return back from Vacation then continue your whatever argument with him say next year.
I hope you understand.
Quote from: stivep on December 25, 2018, 09:38:01 AM
Dear magpwr
Wesley
hi stivep,
I manage to skim through the entire document in one pass.
No questions but amazed by the way Zenneck is done.
Basic findings-
1)The reason why 1.85Mhz was selected is merely to strike a balance between distance and energy density.
2)10Mhz can be used but distance will be shorter.
3)Earth besides sea and etc is considered a
"lossy conducting medium".
The above experiment can be recreated especially on the transmitter side.
Interesting article but i think it is nothing to do with current amplification(for kapanadze device) to and from Earth which require using interrupted/Gated pulse to emulate a longitudinal waveform.
This is just a concept of keeping the wave standing by two Tesla coils which regulate themselves. If there were such variants, I did not know about them.
how many free energy experiment a man have to do before he finds the real DEAL.
THE ANSWER MY FRIEND IS BLOWING IN THE WIND THE ANSWER IS BLOWING IN THE WIND..https://www.youtube.com/watch?v=AGX_rESRYIU
Quote from: Void on December 26, 2018, 11:52:31 AM
Quote from: SolarLab on December 24, 2018, 08:07:02 PM
"His invented devices do work (many have sucessfully tested certain versions), use conventional theories, and can be
you also know he has a variety of differing designs, including some self running types."
All the best...
Hi Solarlab. I did not see a reply to my questons above. Can you please reply?
Thanks.
Regarding lighting LED lights with the EM field around a HV tesla coil or similar:
LED's don't require much power at all to light up brightly. Same with small neon bulbs.
Especially so for LEDs.
Agreed. Wesley's LED lighting demo was more akin to a magicians trick than a meanigful demonstration of something scientifically significant.
Quote from: Hoppy on December 26, 2018, 02:53:11 PM
Hi Hoppy. I wasn't singling anyone out, but just referring in general to videos such as the following
where it seems to be implied that lighting some LED lights that way at relatively low power is indicating
some amazing mysterious phenomenon:
Naser Technology - NASER - Quantum Nanometer Range Generator
https://www.youtube.com/watch?v=NimRFxeEm2U
Igor Moroz - TROSes - "oscillators" 3; radiant
F.Y.I.
WO2017209652A2 Inventor Андрей Анатольевич МЕЛЬНИЧЕНКО Original Assignee Андрей
Анатольевич МЕЛЬНИЧЕНКО Priority date 2016-06-01
Method and device (variants) for generating electrical energy by partially separating the magnetic field of a
ferromagnetic substance from a magnetization coil
https://patents.google.com/patent/WO2017209652A2/en?assignee=Melnichenko+Andrei&scholar&oq=assignee:(Melnichenko+Andrei) (https://patents.google.com/patent/WO2017209652A2/en?assignee=Melnichenko+Andrei&scholar&oq=assignee:(Melnichenko+Andrei))
To better understand it just think about two stones striking one against another.
You create electromagnetic wave that in did about many different wavelengths gives out X-ray nm wave. (Ionizing Radiation)
However Andrey device does not produce majority of such wavelength. That is easy to spot in few moments of his video.
https://www.youtube.com/watch?v=XXfur0642_Y (https://www.youtube.com/watch?v=XXfur0642_Y)
in https://youtu.be/XXfur0642_Y?t=2403 (https://youtu.be/XXfur0642_Y?t=2403)
Staruhin ask question: how far that field extends? and Andrey immediately moved far away from answering that question!!
in https://youtu.be/XXfur0642_Y?t=2491 (https://youtu.be/XXfur0642_Y?t=2491) Andrey is facing question :how far the radius of the field extends
Andrey answer is: " unlimited, it can travel in waveguide.. It depends form power of generator."..
And he cuts short Mr. Staruhin.
If we were to deal with nm waves X-rays and up than starting from very low microwaves the propagation in near field and far field is by means of line of sight
(a straight line along which an observer has unobstructed vision.)
We did not have any obstructions so we should see even distribution of EW ( electromagnetic wave) to the end or "radio horizon"
however we see problem here :
https://youtu.be/XXfur0642_Y?t=2679 (https://youtu.be/XXfur0642_Y?t=2679)
please watch this sequence for another 20 seconds.
You see clearly lack of linear distribution in near field according to inverse square law. So Andrey knew that he has two points of response where he has got, two maximum of amplitude.
draw the the sinusoidal waveform from an antenna to the window and fallow the places in that video where Andrey shows light in lightbulb. and place maximum of amplitude in near the window.
If wavelength is 2m than divided by 4 = 50cm. The distance between two highest amplitudes is about 1m. Take 1 period and you come with approximately 144MHz.
.his quantum theory Louis Victor Pierre Raymond de Broglie and Cerenkov theory simply does not work with explanation of the device.
That is why Andrey did not get patent ,( his application was filed in 2012.)
dominating frequency in his "Quantum" NASER generator is around 144 MHz.
Here is my paper showing 90 degrees from my old video :
https://youtu.be/KLAPRNWuAn4?t=636 (https://youtu.be/KLAPRNWuAn4?t=636) look at left lower picture drawing showing 90 deg.
The polyphase could be created by means of Andrey that is - of Kapanadze or by concept of Corum brothers.
Here is the link :
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
Here is the link :
Wesley
Quote from: NickZ on December 26, 2018, 08:22:55 PM
Stivep: Thanks for your reply.
Why are you not showing the part that is actually driving the two spheres (or whatever you're using), and their driver circuit?
https://patents.google.com/patent/US20140252886A1/en (https://patents.google.com/patent/US20140252886A1/en)
( the lower sphere was my dielectric and it was not connected to the wire.
all I have had was physical placement of dielectric" sphere" in space
between earth and ground to see if it will charge.
That is also the easy way to determine position of that "sphere" vs frequency where generator and impedance matching circuit is connected to upper sphere and the ground.
The polyphase can be created by two generators I have 7 of them in total.
The frequency of operation from 24kHz to 470 kHz.
but I can go lower by downconverter http://www.rfwireless-world.com/Terminology/Upconverter-vs-Downconverter.html (http://www.rfwireless-world.com/Terminology/Upconverter-vs-Downconverter.html)
The means of shortening sphere diameters in regards to free space is explained in red color link from my post above.
The Corum brothers talk only about 1.25Mhz as the lowest.
Yes I'm at 47kHz so I can match some lower harmonic of
Schumann.
Akula Kapanadze and so on.
Clockwise counterclockwise and bifilar. there are means of making "sphere" smaller. Read the red link
the closest to Schumann fundamental the better. But not me nor Corum Brothers we do not know how to go there.
I'm probably much closer than Corum brothers are.
If you go there than you have virtually no losses around entire earth.
So for you to understand me better I do not know how to go to ~7.8 Hz but I do not need to...
You do not have to be ideal..
To get what you want to get from it.
Wesley
It is customary in science when someone is submitting a scientific paper for peer review that readers
will respond back with frank and sometimes harsh criticisms. Sometimes the criticisms are
valid and sometimes the criticisms are not valid at all, but if that which is being submitted for review
has real merit it should be able to stand up to close examination. No one ever gets to the truth by
pussyfooting around it. I don't think harsh criticisms are really ever necessary however, but being frank
I think is necessary if a person really is interested in getting to the truth, so I try to be frank when
giving people feedback. :)
I don't think that it has been convincingly demonstrated by anyone in the several posted videos here where LED lights are being
lit up due to a strong HV EM field, that some unusual wave type or form of energy is being generated in those demonstrations.
Not saying it is necessarily not the case. I am saying I don't think it has been convincingly shown so far, IMO.
If someone thinks there is good reason to think that an unusual type of wave is being generated in those demonstrations,
then I would suggest that they consider taking a step back and try to think of ways to conduct tests that show that those
special waves or unusual form of energy they think they are generating really does have unusual properties that
differ from 'normal' EM fields and transverse EM waves. Think of ways that those unusual properties can be tested and
demonstrated in a test setup, would be my suggestion.
It is known that sparkgaps and corona discharge in general will generate high frequency radiation in the range of UV thru X-rays
and even higher in the range of gamma radiation, but the X-Rays and other radiation such as gamma radiation are typically
not at a high enough level to be dangerous unless the corona discharge itself is really high energy. If you think a setup similar
to what Wesley has described is producing very high frequency radiation of some kind, you could possibly employ a
spectrum analyzer that goes well into the GHz range and/or a radiation detector to detect alpha/beta/gamma radiation levels.
A really good high frequency range spectrum analyzer is probably quite expensive however. :)
I have already commented previously that I have seen some potentially promising results in the past in
some of my tests regarding combining two waveforms at different phase angles to each other (such as at 90 degrees).
In one of my test setups I was able to see the same sort of unusual extra 90 degree phase shift occur
in the output waveform when the two input waves were combined that Ruslan had demonstrated in one of his early demonstrations.
What I found is that there is one extra 'feature' I needed to employ to see that effect at the output. I have not heard anyone
mention that extra 'requirement' so far in terms of how to apply it to this particular type of arrangement. I have been hesitant to mention that openly
so far because there is often so much mudslinging and BS flying here, and also times in the past when I have pointed out some other experimental observations
I thought were interesting here it is either completely ignored or one or more people make some braying donkey comments in response. ;D
I can fully understand why people hold back on sharing some stuff like that when so many are just here to troll and bray. Ha ha. ;)
My testing so far (in the last couple of years) was done at too low a power level to be able to draw any definite
conclusions at all about whether what I was seeing could produce anything along the lines of OU, but it seems
to at least hold some possible potential. Because of those tests I have done, what Wesley has detailed about
combining two waveforms at ninety degrees seems to me to very possibly hold some real potential, since I have
seen some interesting things as well when experimenting along the same lines. I think Wesley may very possibly be
on the right track in regards to that, but the surface wave stuff and requirement for a special dielectric
arrangement I am not convinced about yet. :) I am currently working on a unrelated concept I have of my own
design, not related to this stuff, which so far is not producing even near OU, but it should be increasing efficiency at
least compared to a more conventional approach, but still need to do a lot of testing and think of ways to try to improve
the setup to have any chance at OU. No one ever said this kind of research should be easy going. Ha ha. Stick with it guys.
I think you may be closing in more on Mr. Kapanadze. Just maybe need to put the pieces together now in the right way. So easy, right? Ha ha. ;D
Maybe your lucky day is coming soon...
Schumann Resonance Today
Frequency
IEEE is not a corporate body. If you have difficulty in downloading those papers you can seek help from the corresponding authors. Or just use the DOI number of the paper to retrieve the original copy in the internet archives.
My partner from Ukraine and I are among those who have contributed to IEEE but I am not an expert or savior. The reason why I have to be here is because the reputation of this alternative energy is getting too low. Nowadays everyone can claim to be an expert in the field of free energy. Even the copy cats having no contribution to the body of the knowledge can be in charge of this field. All the functional OU machines are now being labelled as scams. Whenever a real researcher comes up with a really functional devices, these greedy trolls become so agitated to an extent that they need to kill the researchers.
Take no offence. If I were given an mission to save this planet (which I admit I am not qualified to), my first priority would be to save those honest contributors to the body of knowledge who are starving to death. I would not be interested in giving a treat to the greedy trolls who have chosen to destroy humanity.
Quote from: AlienGrey on December 26, 2018, 07:26:46 AM
AG
Quote from: r2fpl on December 27, 2018, 05:18:26 AM
Frequency
Hmm those values are so close to powers of 2 (2,4,8,16,32,64 etc) that I wonder if the startup freq is inaccurate? When all the freqs match powers of 2 then you got the starting freq right
Quote from: Void on December 27, 2018, 12:05:03 AM
I think in any research there is always room for criticism, when it is based on some grounds. If people criticize just because this goes against their belief, then it is just BS. I feel that people get also offended way to easily, when they hear any criticism. I think we are at a point where any new invention comes from either intuition or pure luck. We have made up all these "laws of the universe" and we don't even understand magnetism yet. I think everybody should go to the roots when this phenomena was found and start from the ground up. They need to understand what is actually happening and not learn electromagnetism from a book that says something like "PM cannot do work"
Here is my logic again:
1. If there is free energy, there is active suppression in place
- it has already been found before and energy industry needs it go stay hidden
2. If this suppression has vast resources, then all school books, science and schools are tainted
- Energy industry will use their resources to keep it hidden. Best way is to teach something that checks out (math), but has little or nothing to do with reality. Some things you lie about and some things
you just don't tell. You make it a religion and you call others crazy.
3. If we were put on this planet and we need energy, the universe will provide it for us without us destroying this planet. Radiation (ambient energy) from space, Sun being the largest contributor, seems to be the way to go. It supplies almost all energy we got here in different forms.
- Looking at the devices we already have, it seems to me that we already know how to disturb the ambient and collect energy. It is just hidden behind jargon and we do not realize it
4. Energy can't be destroyed or created. Seems to me like it was all created in the Big Bang, so it is everywhere. Sometimes in matter and sometimes heat&light, but always in a vibration. When last of those vibrations diminishes, this universe collapses to a singularity. We do stupid things to the energy like dissipate backEMF with a diode over the coil. People really need to think what they are doing. They are repeating stuff they were taught in school without realizing, what they are actually doing.
- L2 in a transformer already collects energy from the universe. You are told it comes from L1 and you can't ever get 100% conversion. Well the only reason is that there is a return cable in L1. You owe
that energy immediately and since ideal components or wires are hard to come by, you always get less tan 100%
- same thing with caps. Displacement current is energy from the ambient. You create imbalance between the plates and the universe tries to compensate. What every you gain, you put back into the negative terminal
@Void: many people here do not want to understand for various reasons. Somebody just wants the device and schematics. I can understand if this feels a bit rude towards the inventor. Some people are just trolls. They say nonononono and then some BS or try to get an argument started. some people are after money and they won't give you the actual secret. They might give you a schematic that is missing the principal bit and they hope you fix the problem he could not. Then he applies for a patent and tries to get rich, but he gets killed. If somebody thinks that people would not murder anybody because of free energy, please fill your pockets with rocks and walk into a lake. Save everybody some time
What I really want is a forum that behaves like Aristotle said "It is the mark of an educated mind to be able to entertain a thought without accepting it." but it seems those are hard to come by. That would be a forum where intuition ignites the intuition of others. Ideas would be proved on a bench and not by saying "everybody knows, that you cannot go faster than light"
QuoteHere is the link :
Wesley
On the subject of being frank and honest, I would like to know how electrically efficient are the demonstrations in Wesley's 'bombshell" video?
Is there anything that is 100% known about Kapanadze devices?
For example:
1. Whether the HV is generated from the flyback or it is the effect of coils in the circuit.
2. Is there a full 50Hz sine signal?
3. ?
Are we looking for something that is not there?
Quote from: r2fpl on December 27, 2018, 10:11:12 AM
Yes - that opinions on the modus operandi of his devices are 100% surmise. :(
Quote from: Hoppy on December 27, 2018, 10:24:52 AM
Maybe something is known?
In my opinion HV is resonated for the generation of electrostatic field which is added to the sinusoidal wave of the second winding. This is probably the closest answer from what I know.
The secret is how to get connected and by what ?
For example:
3. ?
Well let's look at a Tesla coil since some of the video content suggests there is high voltage coils, if we put a small neon close to a Tesla coil
the ions are said to ignite the gas in the gas envelope but with an LED it has no gas just a PN junction my Tesla coil alone does not do this
however if we had something similar like an EMP pulse it would (and also destroy most electronics in close proximity. ;D ;D ;D ;D
AG
Quote from: AlienGrey on December 27, 2018, 11:07:58 AM
however if we had something similar like an IMP pulse it would (and also destroy most electronics in close proximity. ;D ;D ;D ;D
AG
IMP impulse or rather EMP ? Such a pulse is an electromagnetic wave of high energy and frequency. If we add the direction to it, we have the beam focused like a laser.
Even the basic information is not behind what can be seen in the films.
For example:
3. ?
Hi r2fpl. I looked at Kapanadze's 2004 demo video closely when I was trying to ascertain
what the essential components of his device might be, as that appears to be the most stripped
down and basic version of his device. His later devices became more complicated looking and
most probably have decoys on them.
Tariel Kapanadze 2004 04 28 5KW
https://www.youtube.com/watch?v=Tj3neKg5KMc
You see an input transformer connecting to the 50 Hz AC output of the blue inverter box, with rectifier
diodes and a filter cap I believe at the output of that transformer.
Then it appears to be two transistors on heat sinks with the wires going into the tobacco can.
You have a spark gap firing at what appears to be fairly low current and I guess firing at probably 1 kHz at least,
from the appearance of it. So, maybe the two transistors are used as a flyback driver to drive the
sparkgap seen on that device at maybe 15 kHz to 25 kHz. You then have Kapanadze's coil assembly and an earth ground connection.
I think it is unknown what all is in the the tobacco can, but there isn't much room in there for a lot of components.
I think Kapanadze doesn't likely have another generator circuit in the can, as he probably would have
mounted the heatsinks for a second generator outside the tobacco can as well for good air flow. Maybe I am
forgetting some other component there, but I think that was about all that was visible in that 2004 setup.
So, the possible difference I see there from Daly/Akula/Ruslan is Kapanadze only seems to have
one generator circuit there in that 2004 demo. It looks like possibly a very simple two transistor
astable multivibrator type flyback transformer driver arrangement. So, other than the 50Hz AC
(probably rough) sinewave coming from the blue inverter box output, it looks like to me there is only the
one other generator circuit. I don't think he has two generator circuits there, but maybe another
generator circuit is hiding in the tobacco can.
So, if it is only a flyback driver to create HV to drive the sparkgap and then the incoming 50 Hz AC from the inverter,
then it seems not likely Kapanadze is combining two waveforms from two separate generators at 90 degrees or whatever,
as the control circuitry to do that doesn't appear to be there.
So whatever Kapanadze is doing in that very basic 2004 circuit arrangement, it appears to be
a very simple arrangement. Yet the power output was supposed to be roughly in the vicintiy of 5 kW.
This is probably why many people assume it is fake, as the 2004 setup appears to be very very simple.
So, then, if it doesn't have two separate generator circuits, then what is Kapanadze doing?
In the later green box video demo, I believe someone takes out a frequency meter and they measure
very close to 50 Hz at the output of his device. So, only a sparkgap combined with the
50 Hz waveform from the blue inverter box? The other possibility is the (apparent) astable multivibrator
circuit is used to create a squarewave and there is another small HV flyback driver circuit in the
tobacco can, with the heatsink for that inside the tobacco can, but that seems less likely to me.
There is not a whole lot of room in that tobacco can.
Looking at Kapanadze's 2004 setup is probably the best one to focus on I think, as it appears
to be the most open and most basic arrangement. If there is not two separate generator circuits,
then maybe Kapanadze is doing something even more simple than many people think, assuming it is not
a complete fake of course. :)
Nick:
Wesley has not replicated Kapanadze's device or for sure he would have demoed something showing OU. :)
Wesley: I honestly think you are trying to mix apples and oranges by trying to shoehorn this surface
wave and dielectric stuff into what Kapanadze is doing. Take a close look at Kapanadze's 2004 demo video
in which I have provided a link above. How do you tie that simple arrangement to surface waves and dielectrics
and Schumann resonance? I am not seeing it if it is there.
.one of components of polyphase must interact with boundary of Schumann waveguide.
For that you need surface wave.
The same surface used by surface wave.
is shared by Schumann waveguide.
Wesley
Void: Thank you for explaining although I already know it all. When I was asking, I wanted to know more. These trivial questions would give a lot of answers but I see that nothing is known.
Kapanadze's installation in 2004 is possible because he had already done other with "engine". There was also a film from German television.
I think Kapanadze's secret is a breaker. It is not a transistor. It is a mechanical device like an ordinary motor with blades. More a relay. Why? The answer is simple, right!
Hello Wesley my friend ...and I will say it again as well. :)
We can't ignore Kapanadze's 2004 very simple demo setup just because it doesn't fit in with someone's current pet theory.
Kapanadze appears to likely only have one generator circuit in that setup, and if that is right it is therefore probably
driving the sparkgap. The only other waveform there in that case would be the output from the blue inverter box.
Whatever Kapanadze is doing there appears to be very simple. Wesley if you can explain how what you are
saying ties in with what we see in Kapanadze's 2004 demo, I am listening. It appears though that you instead just
sidestepped this question because you can't explain how Kapanadze's simple setup in 2004 ties in with your latest theories. Yes? No?
Maybe someone gave you some info on Kapanadze's device that you take as credible, but it has to fit with what
we see in the 2004 demo video, no? Can you offer any explanation of how your theories tie in with Kapnadze's 2004
very simple demo setup? That is a sincere question.
Quote from: r2fpl on December 27, 2018, 11:50:56 AM
Hi r2fpl. I was just reviewing what is shown there to emphasize how very simple and basic his setup was
in that 2004 demo. Some people seem to overlook that and seem to be looking for something a lot
more complicated, IMO. If Kapanadze's devices are not fake, then what he is doing appears to
use some quite simple technique. Just a very simple combining of a 50 Hz sinewave and HV impulses
into a special coil arrangement connected to an earth ground? Could it really be that simple?
To me, that's what it appears he might be doing in the 2004 demo video anyway. :)
Phase shift can be created by use of capacitor or .pricking cable to see if you are at 90
And that is kapanadze . insulation of the electrical wire or HV wireis of the same value.
one generator is ok.
Andrey Pastukhov even used 50/60Hz and created 90
I agree that antenna must have vertical polarization and it's image needs to be mirror reflected by earth
If you look at Fig 21 it uses flat copper plate with half circles
And is exactly the same as Fig 23 but this one is made from wires and half circles
at kapanadze we see strange coil
That uses polyphase and is not important if it has 2 or more components
Or if it uses 60Hz and than creates 90
it can create surface wave and by that couple it's-own polyphase component
With Boundary (The earth!! ) of. Schumann waveguide.
origin of energy!
Whatever exist in waveguide it must impact boundary of it!
Wesley
Quote from: Void on December 27, 2018, 01:24:21 PM
Hi Wesley. Thanks for the reply. I will think it over and see if I can piece it all together. :)
P.S. Wesley, when you saw Kapanadze's demo in person, were you able to tell if his coil
assembly was an air core coil or not?
Kapanadze claimed that there is nothing inside the coil but that does not have to be true if the pipe was made of iron or Cu :)
Quote from: Void on December 27, 2018, 11:54:22 AM
I think we need to go further. I think there is a better quality than this https://www.youtube.com/watch?v=3thvqFhFIfY
but the old German document had Tariel showing his generator&motor, but what caught my eye was that he powered it with simple electronics on the front side of the glass box. I think he learned from this and was hiding this in later videos
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg528913/#msg528913 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg528913/#msg528913)
when I was trying to film inside the coil Tariel helper distracted me, doing everything possible for me to do not look at it.
And he was successful. He was scared bit I analyzed it only after the show.
So I did not see inside of the coil.
In comparison to 2004 video I do not have clear explanation.
I can fantasize more or less:
The motor with two disk is very much known structure and it is nothing new. it requires significant current.
Spark gap has significant impact on phase relation of all elements of plasma.
Two discs and rotation could be related to the structure https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
where clearly Mr Corum says about rotational access that is virtual.( around infinite torus)
But it is to much of assumption to make any sense of it
The regular electrical motors in Kapanadze device never had any load on it.
I assumed it to be just components of phase shift generating system.
From energy stand point
I was testing two ground structure in South America and it could be that Telluric current is impacted with Schumann waveguide and surface wave interaction by means of polyphase.
( surface wave interaction with Schumann waveguide boundary) gives us some sense of energy origin in Tariel device.
Wesley
I have an idea.
Make copy of Andrey device.
the coil 5 and coil 7 ( from my video are grounded.)
# 6 transmission line can be anything. HV cable or coax or spark gap just like Kapanadze glass table in Turkey.
build Corum receiver.from his patent.( just piece of wire.)
Make it at the distance of few meters in such a way that there is no chance for "air" "EM involvement from that Tx on the receiver. Rx.
Connect anything , any indicator to Rx and play with Tx.( that is Andrey Tx)
You do not need anything that has higher number than #7 ( look at my video)
You can also try to have only 3 and 4 with phase shift squeezing 5
I showed it in two versions ( one of it is NMR)
forget about coil #7
just ground #6 and place cap on the top of #6
You can also try to make #7 winded on Teflon.( the dielectric)
or instead of cap use nice large piece of polymer .
Wesley
From our Tesla's landsman to Wesley
Wesley
chapter 2 part2
(Text is slightly edited. I just pointed at intention of our friend for you to make it even better)
Wesley
The published material starts from chapter 3
the next post is chapter 2
and the last one is chapter 1
so it was published upside down
chapter 2 part 3
Wesley
THANKS FOR MY BIRTHDAY PRESENT FOR THE 30/12/1961. I WILL BE BUSY REPLICATING IT..
HERE IN THE SEYCHELLES ISLANDS RIGHT IN THE MIDDLE OF THE INDIAN OCEAN.. PROSPEROUS NEW YEAR TO ALL.
F.Y.I.
A Repost...
Ruslan/Kapanadze Generator - Fundamental Therory of Operation - Overview:
1. The basic device (Ruslan, Kapanadze, et al.) is a "Current Amplifier." Consisting of a 240VAC 50Hz
or 60Hz Oscillator [LF Osc] with a low current output.
2. To boost the current capability a second pulse oscillator of much higher frequency (narrow pulses)
[HF Pulse Osc] is gated and drives a High Voltage generator (Tesla Transformer or other similar device).
3. These High Voltage Pulses (coulombs) are used to increase electron movement (Joules) in the
coil/wire - that is, to increase the "Current Flow"; a.k.a. electron speed; thus increasing the current
capability of the system - as such, it facilitates Current Amplification.
There are electrons already in the wire/coil but they have to be moved along more rapidly, or pumped
with a higher potential difference, in this case a series of precisely timed high voltage pulses, to increase
the systems current output capability. The output voltage is not changed that much even before filtering.
4. This "HV Pumping Action," so to speak, will increase electron flow in the coil wire once the polarities
and timing are synchronized properly. Sort of like increasing water pressure (V) to increase the flow
rate (I) to get more gpm (Wh).
5. Of course you should mitigate the "HV pump spikes" - maybe a "Folded-Back Helical Coil Filter"
scheme might work.
6. A portion of the devices generated excess energy is tapped to power the systems oscillators and generation
of the high voltage. Very efficient low loss design techniques and isolation are employed throughout combined
with judicial non-use of ferrites, yield a low feed-back power requirement and a high frequency of operation.
When considering Coulombs, Joules, poynting vector, potential and kinetic energies, it appears this is the way
this type of device functions; or at least this is one way of looking at their theory of operation.
A Good Read:
Review the following link. Contains many very good points of discussion focused on how to create excess energy.
Some postulations are yet to be refined but by and large many are logical and viable. Think about the six points
above as you review.
http://www.aboveunity.com/thread/current-and-voltage-amplification-key-to-energy-machines/ (http://www.aboveunity.com/thread/current-and-voltage-amplification-key-to-energy-machines/)
Another Good Source:
This link highlights Andrei Melnichenko, he's been doing excess energy research for over 20 years and it appears he
is near to bringing products to the market. Of NOTE are the many design iterations he has investigated, as shown in
the pictures.
NOW consider that if he had had a modern CAE (e.g. COMSOL Multiphysics) capability at his disposal - many of the
various configurations and material properties would be entered as parameters into the simulations and the different
scenarios compared; and optimised - saving many hours and costs. We now have this capability.
http://www.hyiq.org/Reference/Profile?Name=Andrey%20Melnichenko (http://www.hyiq.org/Reference/Profile?Name=Andrey%20Melnichenko)
One Approach to Developing Your Own Device:
Once you have the concept down as best you can; build a version, do your CAE analysis, component proof experiments
and build-up measurements, as needed; then expand your system-wide hypothesis. Now, convert what you have learned
into a mathematically based model (with the help of the open math CAE) with a rough theory. (see my previous posts for
CAE sources - Student - Free versions)
Build up your theory and your device in logical, digestable steps; varifying as much as possible along the way. Trust your
thinking and your brain first; take the great wisdom of others with a great deal of skepticism.
Then polish your theory, perfect your device, have some peers review it (it will be explainable to ones skilled in the art if
you have done your work correctly; if not, they will tell you), and then publish or patent, what ever is the best for you, and
everyone overall.
Plus, publish in proper journals, blogs, interest group discussions, contests, etc.; don't waste your time, effort, and stress on
forums such as this - no one of sane mind reads them, nor could they even read them if they wanted to, and quite frankly the
forum participants are generally not of any real concequence (sad but true, and you all know it).
BTW The SAEC Forum analysis report is due tomorrow by COB. So behave if you can.
FIN
THE MOTHER AND FATHER OF FREE ENERGY IS EFFICIENCY AND ONE
NEEDS TO KNOW WHERE THE ENERGY IS COMING FROM. REASON BEING
ENERGY CAN NOT BE CREATED OR DESTROY, BUT CONVERTED.
ENERGY CAN NOT BE CREATED OR DESTROY.
This is not quite true. No law in universe is linear, then universe will be dull place.
Zero device is tripling (creating more) current in C1, C2 and C3 with help of law of serial connection.So it is creating more.
BEFORE YOU GO.. JUST A FEW IDEAS CIRCUIT WISE.. WILL THIS CIRCUIT WORK.
WITH YOUR TRANSFORMER. THANKS
Seychelles!
The both devices are AC input.
Anything which can provide AC will work.
The Zero device is voltage hungry but output depends on number of capacitors in series, they are lowering output voltage.
So you have to find balance between input voltage and number of capacitors.
I used SG3525 with IR2110 so I can influence frequency and with frequency and duty cycle you control input.
Just make simple experiments and measure the output.
I really must go to my work now.
Share with each other everything you do.
You will crack everything very fast.
http://tinyurl.com/ybfdv7lv
Does the simulator work properly?
Guys i see you have started a nice party here.
Wesley
Thanks a lot for what you are doing. Very inspiring video of yours, but also thanks for being in the middle with V8Carlo, sharing with us his idea.
V8Carlo.
Really there are not any words to express my gratitude. I was strungling a lot to return some energy back to the source but it was never enough to overcome the input energy. I hope that your idea will be implemented soon by one of us for demonstration. I already have the gear to test it.
Is that possible to post again your pdfs? Looks like a bad link. Also, i don't understand why i can not copy the images. For some reason it is locked by administrator?!
Best regards
i guess this might be the circuit required.
otherwise this one.
What do you mean?
The red circle is showing an Earth ground connection.
Do you remember this drawing?
Did Kapa draw it?
There is no overunity the real gain comes from coupling to something that is willing to cooperate and share.
Wesley
https://bit.tube/play?hash=QmRVVYaonuv5d493TVoNfovVWNuZC26Pn3pwVrSfgUv1dz&channel=49137&fbclid=IwAR1b00zDiTRryPZf2ZhyuAJQEqqUo9Anl5YMeC56ag_cspvqDHhfupUrYPo
Does anybody have any idea about this generator?
Do not say that this generator is fake, but please explain it under the assumption that it is real.
The second post.
I did not hear any answer.
Aye, I agree. If you want any hope of seeing a COP > 1, your setup must be designed to draw in
excess energy from some external source, whether you can identify what that external source of energy is or not. :)
https://teslauniverse.com/nikola-tesla/patents/us-patent-568176-apparatus-producing-electrical-currents-high-frequency-and
Try to imagine that this patent is 100% Kapanadze. Not possible? Certainly?
What do the two coils do? What is in the diagram? so why do I want to put two coils on one core!
What do we read in the description of the Tesla patent.
Why does Kapanadze use HV? and what is HV there.
If it's just for deception, because all you need is two coils, a capacitor and a breaker. The rest are oscillations, maybe HV is oscillated.
Why reject it because it is too simple to be true?
yeah just build the bloody thing and test the out come.
i am in seychelles and i have already ordered the parts
you people you can just go down the road and get all the
necessary parts.. just build it.. build it let bullshit talk later on.
Quote from: Void on December 28, 2018, 10:43:04 AM
Hi Hoppy.
Kapanadze was showing what was said to be five 1kW light bulbs lighting quite brightly. I don't think you could
light them to any significant brightness that way.
Clearly not in my opinion, if the bulbs were a genuine 1KW each. However, the bulbs power rating was hotly debated a few years ago, together with the likely power dissipation, given how misleading camera caught light levels can be. If the lamps were genuinely 1KW, then its more likely that the blue inverter was eye candy as suggested back then and bypassed internally to power the device directly from the rectified mains to perhaps operate along the lines of V8Karlo's 'Q' circuit.
As Seychelles suggests, lets just build the bloody thing and then resume the BS once the results are in. ;D
Quote from: NickZ on December 28, 2018, 10:09:41 AM
There is no Kapa. Where did the diagram come from? The Kapagen device? It is also not a free energy device, but needs a input source. No kapagen replications have even been shown to self run, and is why no one is working with it anymore these days.
It's the Mr Previn circuit I tried it but the wind has to be tuned to the frequency your using Re Old scientist experiment, with 50/60hz
you would need a lot of winds and one has to be out of phase with the other.
Quote from: r2fpl on December 28, 2018, 11:15:31 AM
Hi r2fpl. Kapanadze did say his devices come from Tesla's work, so it is possible.
I don't think anyone is necessarily rejecting it out of hand, just that so many different circuits have been
posted over the years that it is quite a mess now.
This is an interesting bit from Tesla's patent 568,176:
"It will be apparent from a consideration of the conditions involved that were the condenser to be
directly charged by the current from the source and then discharged into the working circuit a very
large capacity would ordinarily be required, but by the above arrangement the current of high electromotive
force which is induced at each break of the main circuit furnishes the proper current for charging the
condenser, which may therefore be small and inexpensive."
It's hard to say for certain, but it sounds like Tesla is possibly talking about a considerable efficiency gain there.
Quote from: Hoppy on December 28, 2018, 11:31:02 AM
Hi Hoppy. I saw a comment from someone here a long time ago who was from that part of the world
who said he recognized that type of light bulb and confirmed that they are rated at 1kW.
I am not sure what you mean. ??? Anyone is free to build and test whatever they like. I explained clearly why I think
it won't work produce free energy, and, as I have also mentioned, I have confirmed this in my own testing as well
on similar types of arrangements. Anyone is free to test and draw their own conclusions, so I don't see any reason for
anyone getting their panties in a twist. ;)
Quote from: Void on December 28, 2018, 11:51:53 AM
Hi Void,
See the simulation. However, it is very interesting.
Note that the current is the same and only the voltage increases in the capacitor.
It is very important to choose the frequency for resonance.
This is for a frequency of about 50Hz. The voltage increases rapidly.
If we change 50Hz to 1kHz and give HV 1-2kV with appropriate resonance we should get an immediate increase in the capacitor.
The difference in capacitor capacity will be at the level of pF. The capanadze tunes the copper coil through the wire inserted there. What does it do and how much it is in capacity!!!!!!!!! pF!!!!
I WOULD COME TO THE CONCLUSION WHEN A CIRCUIT IS AT RESONANCE
IT INVOKE SUPER CONDUCTIVITY AT ROOM TEMPERATURE,, THE QUESTION HOW
TO INVOKE MORE CURRENT FROM THE CIRCUIT..
Quote from: Jeg on December 28, 2018, 07:25:35 AM
Wesley
V8Carlo.
Really there are not any words to express my gratitude. I was struggling a lot to return some energy back to the source but it was never enough to overcome the input energy. I hope that your idea will be implemented soon by one of us for a demonstration. I already have the gear to test it.
Is that possible to post again your pdf? Looks like a bad link. Also, I don't understand why I cannot copy the images. For some reason, it is locked by administrator?!
Best regards
Jeg have you got MSpaint? then copy to paint or just save it to download folder, If copied to paint 'select all' then copy' then you have it
to stick where you like ;D ;D
Hoppy Imagin electricity ENERGY is like gold or currency! and a capacitor is the bank, well as long as everyone doesn't want their savings
back all at once banksters are free to use as they like, You can guess the rest.
Quote from: r2fpl on December 28, 2018, 12:10:32 PM
Hi Void,
Standard resonant tank circuit stuff.
Interesting to the uninitiated.
V8karlo has not posted overunity info. It all runs down.
All the best with it!
The fact that he posts he is frightened for his life is delusional
Quote from: AlienGrey on December 29, 2018, 02:30:58 AM
Thanks mate! ;)
About the topic, i have also stoped beleiving in magic. I just haven't found any energy amplification to any of the projects i worked with! Looks like Steinmetz was right when talked about proportionality in change between all electrical values when it comes to electricity. So for me if there is something in to it then circuits like V8Carlos is the real deal. It doesn't give amplified energy, but a way to reuse again and again the same portion of energy that initially was used, compensating any losses by injecting energy from the battery itself during each cycle. A system of this kind normally would selfrun "for ever".
If this is the case then it is silly easy to confuse people making them to beleive that two oscillators is the real deal, or that the materials are essential for the operation, or that special geometric coil forms can produce OU! :o
About "closed" and "open" systems, IMO i don't believe that a "closed" system exists in electricity. Even a single cable shortcutting a battery creates a magnetic and dielectric field which interacts with the big earth/ionosphere dielectric.
I wish you all a happy new year. ;)
THERE IS NEVER SUCH THING AS A CLOSED ELECTRICAL SYSTEM.
FIRST THEY CALL A PUMP A GENERATOR. WELL ENERGY CAN NOT
BE GENERATED AND OR DESTROY. WHEN AN ELECTROMAGNET IS
CONNECTED TO DC POWER, THE MAGNETIC FORCE PUSH OUT
THE INVISIBLE FLUID AROUND IT IS CALL ETHER..ETHER IS WHERE
THE REAL ENERGY IS. WHEN THE POWER IS SWITCHED OFF THEN
ETHER SPRINGS BACK TO IT,S ORIGINAL POSITION AND FORCING
THE SO CALL ELECTRON DOWN THE POWER LINE. BEMF EMF.
Hi Markus!
Thank you for your fifth mail. I don't have much time these days because of my job.
I will try to answer your question (not all of them).
I choose this one.
What is difference in a number of capacitors in Zero device?
There is non linearity there. It is not obvious. It is kind of hidden.
Let's say that the source current is 1A. With 3 caps in series they will produce 3 x 1A = 3A. With the help of Czero cap the voltage will raise to 525V. (input voltage is AC 220V, Europe)
So 525V / 3 caps = 175V on each cap (C1, C2, C3). So 175V is output voltage.
Now, if we add 1 cap more in series we will have 4 caps in series. They will produce 4A. And the voltage on each will be 525V / 4 = 131V on each cap. Difference in voltage is from 175V to 131V = 44V.
If you add 9 caps they will produce 9A and voltage on each cap will be 525V / 9 caps = 58V.
If you add 10 caps they will produce 10A and voltage on each cap will be 525V / 10 caps = 52V.
Difference of output voltage between 9 and 10 caps in series 58V – 52V = 6V.
Difference between 3 and 4 caps in series is 44V (on output).
Difference between 9 and 10 caps in series is 6V (on output).
See difference here (44V and 6V).That means that with each cap added you gain 1A and after number of caps the output voltage drops only for little. That means that you have to raise input voltage only for a little and you gain always 1A with every cap.
After a 20 caps in series you have to raise input voltage only for the fraction to raise output voltage on that caps but with every cap added you gaining always 1A. It is serial connection law.
What about after 60 or 200 caps? You have to raise input voltage only for 1V or less to gain 1A. There is no limit to this.
What about after 1000 caps? You wanna power your city?
These is easy to me because I played with that device for a while, but it is hard for someone who see it for the first time. I tried to explain this simple as much as I can. I hope I helped.
Please don't send me more mails. My mail is full. I can not read it all.
v8karlo: Thanks for your contribution. Even though your circuit may not produce any extra energy, it may allow the circuit connected up that way, to run longer. Of course, this would need to be tested by some of us here. So, it's good that you are here with us, to give us a helping hand with all this.
My father and his parents were also from Zagreb, from the old Yugoslavia. I was born in Venezuela, so I am a South American Croat. I highly believe in Tesla, and his ideas on free energy. Unfortunately, the free energy ideas, and his inventions have been hidden from us, to a great degree. Can you explain why you are so scared. Perhaps that can help us to understand your concerns. And also, why did you stop working on the device that you have shown, after so many years of working to achieve the results that you have obtained. Also, do you still have the device assembled and working, or not. Sorry for all the questions. Thanks again,
Nick Zec
Quote from: r2fpl on December 29, 2018, 09:40:07 AM
v8karlo: I also asked earlier.
I think you might find the answer in this little video https://www.youtube.com/watch?v=fRFQVMJf5eI
Quote from: AlienGrey on December 29, 2018, 10:09:21 AM
There is everything.
well said wesley. i admire some one who is willing to share,
and if it jell with my reasoning then i will be there to provide
the very little i can..you can learn from a rock and a rock talk back
to you just ask a geologist. please for those who is reading this JUST
BUILD THE BLOODY THING AND UP AND ON WE SHALL ALL LEARN.
I WILL NEVER GIVE UP ON FREE ENERGY RESEARCH EITHER,
UNTIL DEATH DO ME PART AND OF COURSE I WILL NOT BE
RESTING IN PEACE EITHER..I HAVE ALREADY ORDERED THE
PARTS FROM ALIEXPRESS AND GOD WILLING I WILL PUT IT
ALL TOGETHER..
Quote from: seychelles on December 29, 2018, 12:05:19 PM
ALL TOGETHER..
Hi which one are you building? nothing in the junk box you can sling to gether?
alien gray i will build both..
Quote from: seychelles on December 29, 2018, 10:37:23 PM
Well the Zero cap one is charging on a phase shift thing watch see if your electric meter detects it ;D before you spend too much on it's parts
maybe I'm stupid, but could somebody explain the papers or the idea, what makes this remarkable?
Just read them once, but it seems the idea is that 3 caps in series triple the amperage. I do believe, that the free energy is hiding behind something simple, but this made even me think like "whaaat!?!"
Then it uses the grid and barely lights a bulb. So not trying to put the idea down, but if someone could explain the principle?
IT could barely light a light but look at the source inline bulb light
not lit at all, the same 25 watts light..
capacitor is to current as coil inductor is to voltage.
It looks like a current converter on the second circuit.
Quote from: Belfior on December 30, 2018, 05:02:36 AM
Nothing remarkable. The series connected caps are charging so fast on the first phase, that the input bulb filament cannot heat quickly enough to glow. On the second phase, the transistor is switched on and the caps discharge into the output bulb.
Quote from: r2fpl on December 30, 2018, 05:45:59 AM
Agreed.
The both circuits Zero and Q are made to show the principle and how it can be done.
Zero is showing multiplication.
Q is showing how can you use electricity and return it to source at same time.
The both devices are using same principle based on law of serial connection to raise the voltage of circuits.
I made Zero visual so you can see difference with your eyes.
It purpose is to change mindset of the people.
Make your Zero circuit and measure it while working.
Measure voltage on C1, C2, C3 while it works.
Can you fake the heat at output?
It is very cheap project which everyone can do.It is a starting point.
Happy New Year to everyone in the world!
Quote from: v8karlo on December 30, 2018, 07:30:18 AM
It is the right observation. Power trough L2 is bigger then trough L1.Remove C3 and work with C1, C2 only. The L1 will light up but L2 will light up more. You will still see the difference in power.
You CAN NOT fake the heat if there is no real power!
Do your experiments and change your mindsets.
There is only one small issue here. Power on L1 is NOT power consumed from power source. Current is not power.
Quote from: vasik041 on December 30, 2018, 07:34:19 AM
Yes well L1 is still connected to the grid. With an AC grid it does not matter, which way you plug your device into it. It is push&pull and not from plus to minus. This means the voltage has to be there to light the L1 bulb AND the current in L2 seems to be bigger.
I think what you are saying is that maybe the same current goes trough L1, but there is very little voltage?
V8Karlo,which savings or circuit work C.O. P. should be ex(s)pected ?
At first a great work which gives partial explanation these methods related :
series connection
https://patents.google.com/patent/WO2004100349A1/en (https://patents.google.com/patent/WO2004100349A1/en)
Voltage step down transformer
https://patents.google.com/patent/WO2016070292A4/un (https://patents.google.com/patent/WO2016070292A4/un)
load controler
https://patents.google.com/patent/US5130608A/en
(https://patents.google.com/patent/US5130608A/enWow) !! WOW!!
! - effect " Example 1" saving results related
And about dotation/ donation let me see
Sincerely and good entrance in 2019 and success
OCWL
p.s.: in search for the cheapest " zero energy" infrared heat system
https://patents.google.com/patent/GB2203529A/en (https://patents.google.com/patent/GB2203529A/en) + most efficient energy drive !?"ONLY" 15° C ambiental room temperature ?
In the 70' 13° C has been the average indoor ambiental temperature in the U.K. !
Quote from: Belfior on December 30, 2018, 07:41:10 AM
Power from source != power on lamp
Quote from: Hoppy on December 30, 2018, 07:51:42 AM
Yes: the message is: brush up on basic electrical principles to avoid getting mislead!
It uses simple existing principles. It does not violate any of the laws. It is made to be simple.
If I used 100 components in there, nobody will be able to understand. It is stripped to minimum so you can understand it.
Build CZero. Start from there. You all have voltmeters.
For a start you don't need anything else.
At the end it is project which can be made in an hour?
Why talk to much?
my advise is to use low esr electrolytic capacitors to increase
life expectancy and increase efficiency.
When powerline in second part of Zero circuit has more voltage in it it becomes source.
It is trying to move back to grid. It opposes grid. Grid is at lower voltage at that moment.
At that moment it is trying to feed the grid.
It becomes source.
Quote from: v8karlo on December 30, 2018, 08:23:29 AM
It becomes source.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900104&CC=DE&NR=3821856A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900104&CC=DE&NR=3821856A1&KC=A1#)
zero crossing : http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3821856&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Quote from: r2fpl on December 30, 2018, 08:02:12 AM
You mention that this may be a relationship with Kapanadze. You can say what you have on your mind.
The Kapanadze device is lighting bulbs and that energy his device is returning to source at same time.
That is why he needs to add to source only a little to keep it going. It is obvious when you look his videos.
The Kapanadze himself said : The energy is not lost, it is been captured!
How do you capture energy which is already used?
I think, but this is only my thought that he using something like Q device principle!
It is my observation I made only on what I saw in his videos.
He had more than 20 years to perfect it, but in first videos he started lighting up only small bulb in his hands in that video.He didn't start with monster.
Quote from: Hoppy on December 30, 2018, 08:59:47 AM
Well, I think you are a little closer to the truth by suggesting that his devices are connected to the grid.
If you are using 20A and returning 19A to source do you need grid?
You have to add to source only 1A to keep it going and rest 19A is for you.
v8Karlo,who claims such work process efficiency ?
About pulsed dc devices and how these function/ oscillation generators parametrical works :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5942858A&KC=A&FT=D&ND=3&date=19990824&DB=&locale=#
Quote from: v8karlo on December 30, 2018, 09:17:05 AM
I like that idea but why not return all of it and just start it on a 9V PP3 battery.
Quote from: Hoppy on December 30, 2018, 09:26:21 AM
Because there are losses that have to be compensated. ;) Hi Hoppy
I have been using the Dr. Stiffler type of "double diode loop" circuit. Which seams to do the same or similar thing that Karlo's device does. That device uses a series connected line of 4148 diodes (16 switching diodes), to increase the voltage, higher than just the oscillator and the L3 coil both running at 12MHz can do by themselves. Adding a capacitor to the output, back to the input may also help to raise the current. I'll try that.
Geofusion and I had used a line of several capacitors on the induction circuits that we had built previously, which also helps to raise the voltages. Perhaps there is something to all this. Anyone built the monster up yet? My only question is how long a battery power model would run, without a "little help".
And this also reminds me of the Barbosa tests, where the grid line positive rail is connected to a a bulb, and then to earth ground, instead of the grids ground. Caps are used there as well. But, I could only obtain up to a 25w bulb to light in this way. Which is about the same as Karlo's bulb output, if it's even that high.
There will be always losses in circuits so the returned energy will be always less then input.That small difference you have to add, replenish source.
How small are losses? It depends how efficient circuit is.
From a distance it looks like device spends nothing or little but it is not true.
It spends lots of power but most of power it returns to source.
Reality bites:
https://en.m.wikipedia.org/wiki/Exergy (https://en.m.wikipedia.org/wiki/Exergy)
https://en.m.wikipedia.org/wiki/Thermodynamic_limit (https://en.m.wikipedia.org/wiki/Thermodynamic_limit)
https://en.m.wikipedia.org/wiki/Johnson%E2%80%93Nyquist_noise (https://en.m.wikipedia.org/wiki/Johnson%E2%80%93Nyquist_noise)
But there is not a need for total recapture: 51% recharge efficiency gives the repowering force for a new cycle
If most of the energy returns to the source, what happens with this lost energy. There is no simple logic here. The energy is lost in the bulb but it could power the system, so how is it possible that the bulb works and "90%" returns to the source. There is a mistake in my reasoning.
Quote from: v8karlo on December 30, 2018, 09:37:36 AM
So; what proportion of the source supplied energy do you estimate is dissipated as heat loss in what you described as the 'hot' L2 bulb in the 'Zero' circuit?
BTW - Units of energy cannot be interchanged for units of power, current or voltage.
Quote from: r2fpl on December 30, 2018, 10:01:20 AM
Yes, the 90% return to source logic is BS.
Lets spark some fire.
Following image is from Q topology.
Yellow is across the input capacitor.
Reference for both the probes is common and it is the ground of battery,
Blue is across Czero.
All caps are 470uf/400V
Input to my push pull is 24Vdc.
Load=40 and 70 watts incadesent which anyway shines bright.
Czero almost 37 volts when charges and 12 when discharges. This is a 25 Volts difference.
Input current from battery looks steady 2A with or without the Q-feedback topology.
Normally i would expect that during return cycle, input voltage to be increased over 24volts. Or at least the input current to drop down even a litle. I;ll check if i have any errors in connections.
If someone really has something, they will be able to demonstrate it. That is for 100% certain.
If they are trying to protect a 'secret' they can simply place the secret part in a box to protect their 'secret'.
People who do not have anything can't demonstrate anything, because they have nothing. ;)
They will make excuses of why they can't demonstrate what they are claiming, such as they
are trying to keep a low profile because they are afraid of MIB's/evil secret agents, or they are trying to protect someone's
patent, etc. This is of course all nonsense. If they were trying to avoid getting the attention of MIB's/evil secret agents they
would say nothing at all, and if they want to protect a secret they can just simply place the secret part in a box, and then
they can demonstrate their amazing device with no issues. ;D
No demo? Then 100% for certain there is nothing there. It is very hard to demo something that doesn't
really work or which has never actually been tested on the bench and proven to work, unless it is just a scam
or a hoax. Hot air out equals hot air in.
https://www.youtube.com/watch?v=dOJfr_lz0jU
This guy exactly shows processes in all of known devices.
Two generators.
90 degrees.
and rectangular impulse
that rectangular impulse can be generated by third generator.
injected before the maximum of amplitude.
He even shows how to calculate parameters
The only addition that I have made was to provide certain and convincing, common elementary structure to all. Akula Tariel Vasmus, Ruslan and others.
in my video https://youtu.be/KLAPRNWuAn4 (https://youtu.be/KLAPRNWuAn4)
In addition to that:
I made conclusion that Viziv surface wave can interact with Shumann waveguide with one if its polyphase components.
And that is till now the only explanation pointing at energy origin used than by devices able to interact such Tariel Kapanadze based concept.
the base for all of it is Tesla Coil.
Viziv and FE devices of Tariel Kapanadze concept uses Tesla Coil.
I need to give credit to T-1000 My friend Arunas from England for Lithuania Experiment.
Wesley
Quote from: Jeg on December 30, 2018, 02:38:30 PM
Hi Jeg,
very nice, but:
What is the input cap? C1?
Blue is across CZero?? You mean from common ground (battery) to CZero/L1 or to CZero/B1?
Load is 40 and 70W (110W), so 2 bulbs? And what voltage (240V, 12V)?
Input current is 2A, so at 24V = 48W input?
I have a similar setup build, but with the requested 12V input, will post some details later today.
Itsu
I too build the Q device, but the bulb B1 (12v/21W) does not light up (without feedback).
CZero is 2x 10uF parallel / 400V bipolar, it has about 18V DC across it
C2 is 22uF / 250V electrolytic, it has about 35V DC across it
Below screenshots show:
gate signals (running at 10Khz)
drain signals
Signal across L1
Signal across B1 (nada)
Controller is TL494 with IR2113
MOSFETs are IRFP260N
(see https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg474350/#msg474350)
Picture shows the setup.
Input is 12V from a stack of supercaps (6x 100F = 15F) and draws only about 90mA.
Am i doing something wrong? Is the feedback needed?
Regards Itsu
Now with feedback.
B1 very dimly glows now.
Input current went up from 90mA to 400mA (12V).
Same screenshot as Jeg (i think):
yellow is across C1 (supercaps)
Blue is across common ground (minus supercaps) and L1/CZero.
Green is current through B1.
Running at 60Khz like jeg.
So the feedback leads are needed.
Itsu
Using a 12V / 5W bulb for B1 goes better, some more light.
Same setup as above with feedback.
After 5 minutes, voltage across C1 has dropped from 12V to 9V.
After 8 minutes, at 8.65V, the TL494 shuts off.
Itsu
Quote from: itsu on December 30, 2018, 04:46:41 PM
Very nice setup Itsu, as always. If I understand your results correctly, then I am shocked that it didn't
work as claimed for you. :)
Link to dragon lord
: https://www.youtube.com/user/DragonsLord76/videos (https://www.youtube.com/user/DragonsLord76/videos)
https://www.youtube.com/watch?time_continue=3&v=wIIABIU3tRw (https://www.youtube.com/watch?time_continue=3&v=wIIABIU3tRw)
This is the heart of first element to FE.
The ability to send energy to earth air interface.
Although there are many different surface waves and modes please understand that being able to send means being able to receive at some distance.
We can receive instead of transmit.
Using polyphase with many components you can make one of it interact with Schumann waveguide.
This is your energy source.
structure listed : https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529169/#msg529169 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529169/#msg529169)
watch this:https://www.youtube.com/watch?v=ZTZ9SLux6OA&feature=youtu.be (https://www.youtube.com/watch?v=ZTZ9SLux6OA&feature=youtu.be)
Wesley
slow waves
https://cosmolearning.org/video-lectures/slow-waves-2/ ( click on the video) (https://cosmolearning.org/video-lectures/slow-waves-2/)https://cosmolearning.org/video-lectures/slow-waves-2/ (https://cosmolearning.org/video-lectures/slow-waves-2/)
https://youtu.be/wIIABIU3tRw?t=1163 (https://youtu.be/wIIABIU3tRw?t=1163)
https://youtu.be/KLAPRNWuAn4?t=883 (https://youtu.be/KLAPRNWuAn4?t=883)
Kapanadze first excited the connection and than he received the energy.Viziv sends energy and excites surface wave and they receive that what was send with the receiver.
-All of them use Tesla coil
-All of them use HV
-All of them use bifilar clockwise and counterclockwise winding to slow wave and keep phase shift.
-All of them use ground wire
-All of them use standing wave.
Corum brothers thought about Schumann waveguide in 1988
Tariel did it by errors and trials knowing nothing about surface wave
Do you remember Рыбки? fishes from Sergey Panov video.
https://youtu.be/7pE83oajjoo?t=511 (https://youtu.be/7pE83oajjoo?t=511)
look at upper right corner.
And compare the fishes with
https://youtu.be/5xUf94WlfI4?t=635 (https://youtu.be/5xUf94WlfI4?t=635)
the same fishes right?
Wesley
https://youtu.be/5xUf94WlfI4?t=1255 (https://youtu.be/5xUf94WlfI4?t=1255)
Buck boost Autotransformers
https://www.youtube.com/watch?v=QtByASWDFwE (https://www.youtube.com/watch?v=QtByASWDFwE)
The Current Transformer
Question: What results when you have an open secondary CT?
https://www.electronics-tutorials.ws/transformer/current-transformer.html (https://www.electronics-tutorials.ws/transformer/current-transformer.html)
1000A High Current Transformer Experiment
https://www.youtube.com/watch?v=ID7gG6krecI (https://www.youtube.com/watch?v=ID7gG6krecI)
FIN
Hi itsu ;) Nice to see again scopeshots of yours!
Well, i tested one bulb at a time. First 40W and then 70W. Both Incadesent bulbs at 220V.
Yellow is across the input capacitor C1. Blue is taken as you said between L1 and Czero.
Yes input is approximately 2X24V=48W. (with the 40W bulb)
I see at your last scopeshot that your input voltage (yellow) slightly inceases when feedback returns back some energy. Judjing by your very high input capacitance, looks like a generous return. Probably i have a flaw in my wiring connections as i don't see any change across my input capacitor C1=470uF.
Itsu, V8Carlos
I think there is a flaw in the original Q-circuit. When Czero charges , L1 steals charges from the input capacitors, something that has to be blocked.
Itsu it will be easier if you could measure with your current probe, what flows between D1 and C2 and to what direction.
If this is true then the addition of D3 is of a necessity.
Also if everyone agree to move this conversation in the old kapanadje thread or in a new one for not disturbing the guys here.
Quote from: Jeg on December 31, 2018, 05:19:25 AM
We are struggling years on bench with Ruslan's bullshits! What you just described it has already been tested with so many different ways i really can't remember. Yes the timing that you say is correct. But you always need power to create high voltage peaks. No matter how much power you need, at the end of the superimposition we are again at the starting point. Pout=Pin-losses.
About this 90 degrees thing is a nice subject for loosing few years more until to understand that the above equation doesn't ever change. But this is only my personal opinion of cource ;)
Guys i open again the old rusty Kapanadje thread for the V8-tests.
It will be good to start new tread Q.
About Q device. It uses energy trough bulb in both 2 phase. But it is returning energy only in 1 phase. So it should be 50% returned. In reality, losses, lets say 45%. If you could manage it to return energy in both phases you have your monster. It is that simple.
I work during New Year Eve so i wont be able to be on forum.for a few days. I write this from my mobile. The idea is real and the principle is good. You decide.
Quote from: stivep on December 30, 2018, 07:25:58 PM
And now you will be able to know how Wesley was able to excite dielectric.https://youtu.be/KLAPRNWuAn4?t=883 (https://youtu.be/KLAPRNWuAn4?t=883)
Oh, Wesley..
When this antenna worked, I could show you such "wonders" at a distance of 5 kilometers from it.
https://www.youtube.com/watch?v=e7eoZIGGDGk (https://www.youtube.com/watch?v=e7eoZIGGDGk)
https://realt.onliner.by/2018/04/27/radio (https://realt.onliner.by/2018/04/27/radio)
Happy New Year!
Hi Jeg. Yes, the idea of applying high voltage impulses at around 90 degrees has been
discussed and experimented with here for several years already. I haven't ruled out
the Kapanadze/Daly/Akula/Ruslan devices myself as of yet. I am still inclined to think
at least some of those may really work. Kapanadze may be doing something different
than the others, if his demos have been legit, as his setups seems to produce a lot more power,
and apparently in a more stable way.
Regarding V8Karlo, there will not likely at all be any magic found there. At best you might see a
small efficiency gain in some such schemes, but when energy from the battery (or mains) is
dissipated through a resistive load, that energy is gone. It can't be magically recovered back
again in such a closed loop arrangement. Stepping up the voltage at the output of a device and trying
to feed it back to the power source typically causes the device to consume even more power than without that feedback. :)
V8Karlo has not even given any test results at all explaining how he made measurements,
or any actual efficiency gain measurements. As best as I can guess, he couldn't get anything to
work so he posted his PDFs hoping someone here could make improvements for him. However,
the problem is this:
If there is no influx of energy drawn in from outside the device, you will never see
any energy increase beyond what the input power source is supplying. The best anyone can do with any such arrangements will be to possibly improve efficiency
a little, but the COP will always be <= 1. In the case of V8Karlo's setups, there will not likely
be any much efficiency gain seen at all, if tested properly. Too many losses with all those diodes.
It would likely be more efficient to feed the bulbs directly from the secondary without all the other
lossy components. :-)
If someone wants any real hope of seeing 'magic', you have to think about how to draw in
extra energy from external to your device. The extra energy will have to come from somewhere.
Quote from: Void on December 31, 2018, 10:20:40 AM
work so he posted his PDFs hoping somewhere here could make improvements for him. However,
the problem is this: If there is no influx of energy drawn in from outside the device, you will never see
I dont see any of yours ideas around. Why is that? Where is your work?
Quote from: v8karlo on December 31, 2018, 02:19:13 PM
Hi v8karlo. Not that it is relevant, but on my test bench, as always. ;)
I I come across something that I think is genuinely noteworthy, and if I feel like it,
I may show it. None of that changes the fact that the circuits you posted are not likely at all
going to do anything special, for the reasons I have already clearly explained. Sorry, but that
is just the reality of the situation.
Quote from: v8karlo on December 31, 2018, 02:32:04 PM
It is better to do anything than Nothing like you do. I noticed that you two attacking anyone who has any idea at all.is it because you can not do something? You are smart guys. But you are not using that.
Hi v8karlo. Rather than trying to deflect, why not just address the legitimate issues raised?
I have explained clearly enough why it should not work. Why not just show a demonstration with
proper measurements of how those circuits you posted will improve the efficiency over just powering
a light bulb directly with a battery or with an inverter? You have already posted the circuit details, so posting
a demo should not be an issue. It should be quite straightforward for you to do if you have really measured
some unusual efficiency gain with these setups. All the best...
Quote from: v8karlo on December 31, 2018, 03:23:53 PM
My best regards to you.
Stay inert and do nothing like you always do. For you, I am faking heat without power. Probably by magic.
Yeah magic is a keyword if they want to see how your device works and learn
then build the dam thing scope it and give us all a rest.
Happy new year to everyone.
But does it work if some clever Geza allocated you with a smart meter? He, He!
v8karlo Thing is Karlo is a thinker and a doer.
AG did post this in Kapanadze topic but it should probably go here first ?
AG ..Power from the Sun ...
Stefan put these links in the comments
..Snip
overunity.com >>> Go here: The full website is: http://zpower.biz/ (http://zpower.biz/) or: http://zpower.net/ (http://zpower.net/) And here new infos: https://spark.adobe.com/page/sRdP4qaNoCRW0/ (https://spark.adobe.com/page/sRdP4qaNoCRW0/) (https://www.youtube.com/redirect?redir_token=mpQ6Xh9poO6LD-CBP0z4TXsatnt8MTU0NjQzNjg5N0AxNTQ2MzUwNDk3&event=comments&q=https%3A%2F%2Fspark.adobe.com%2Fpage%2FsRdP4qaNoCRW0%2F&stzid=UgxcsJ23eItv-Mxp1rh4AaABAg.8pXX5fpaz1l8pY2BK0RCF8) http://fluxpowertechnology.com/ (http://fluxpowertechnology.com/)
PS..
in another bit of open source FE business a member at Energetic forum that shares his work asks a question about iron Oxide [he is a good man and can use all the support this community can offer IMO
and besides helping him it would be useful for experimenters here working with 3d printers or "other" in outside the box experiments...
http://www.energeticforum.com/renewable-energy/21092-velocity-factor-black-iron-oxide.html (http://www.energeticforum.com/renewable-energy/21092-velocity-factor-black-iron-oxide.html)
Quote from: ramset on January 01, 2019, 10:18:35 AM
in 10:19 https://youtu.be/MsJwRznsf4o?t=612 (https://youtu.be/MsJwRznsf4o?t=612)
The guy says about oscilloscope in such a way that the conclusion indicates variable components.
in 10:31 https://youtu.be/MsJwRznsf4o?t=631 (https://youtu.be/MsJwRznsf4o?t=631)
The guy is warning about dangerous shock. That indicates HV.
However measurement shows 15.5V.
Well easy enough HV low current = low voltage High current
So meter is switched to DC and it only shows DC component.
The AC component can not damage the meter as the current is low.
But meter on AC does not show it. It shows only 138 mV.
We have enclosure of helicopter light that has light bulb replaced. The original lightbulb was 800W : 28V DC = 28.571A
The guy conforms that he removed original lightbulb and all electronics from the enclosure.
We assume that replaced lightbulb used the same mirror and it was at nominal 24V with the device now at ~ 18V of steady DC component under load.
At my Gamma Scientific PHO 4040, light from the video at its brightest point was compared to light of incandescent flat light from 45W light bulb.
This light was recorded and than projected and measured on the same screen of my computer side by side .
The light used as my reference was measured from the distance of 3.5m .
That is close to the estimated distance of the camera to the reflector from the video.
The two brightest points of both indicated ~ 42W .
However if we approximate focused light beam from helicopter reflector using mirror. we come to lightbulb of 35W running at approximately 50% of its nominal brightness.
that means 16-17W.
And now lets take as a base for calculation the maximum of possible - nominal 45W.
So my error in calculation of power dissipated by the reflector can be within 45:100 x 35= 15.75
15.75 : 2 = +/- 7.875%
So the effective range of energy consumed by Lightbulb inside the reflector is in average its maximum around 20 to 22 W
To low 12W to 15W.
That is why the guy used helicopter reflector mirror instead of just regular incandescent lightbulb.
He wanted to impress potential viewer with light intensity.
Please note that the original lightbulb used 4 wires than connected to regular outlet box.
The module with quote
Quote5 different frequencies
can be simply digital switch switching relay inside enclosure to the battery using one single impulse.
the stack of plates can be additional battery (in addition to the one hidden in the helicopter light enclosure .)
enclosure of that reflector has enough place for quite good battery inside.
Wesley
... and it is not even a full moon.
Meanwhile, let's get back to the lab, and see what we have on the slab... ;D
My current test setup with some new improvements seems to still be showing COP < 1, but so far at least seemingly giving
quite high efficiency. I know I can get the efficiency at least a little better yet, as I haven't fully optimized the setup yet.
Will I be able to break the COP = 1 barrier? Chances are I won't, but I am not giving up (yet). :) My current circuit concept
at least theoretically should be at least quite efficient, which my latest design appears to be so far, and by my way of thinking
it might possibly do even a little better than it is performing now once I get everything optimized. What's my point?
My first several tries at this circuit did not perform well at all, but I observed what were the main issues with
the setup and thought about how I might be able to address those issues. I then made changes to the setup
in a step by step manner and observed whether my new changes helped or not. I am learning from both my
failures and from what helps improve the setup's performance. My suggestion is take things step by step
and don't be put off by failures. Learn from those failures and use this new knowledge to design better setups.
Theory and ideas can only take you so far. You must start testing at some point on the test bench, and approaching
this testing in a systematic and step by step progressive manner is probably a very good idea, IMO. Don't
let failures discourage you, but you must be willing to observe carefully and think about the implications from different
angles so you can learn from your failures. My two cent's worth for the new year. ;D
P.S. As has been pointed out already here, if the theory behind your test setup does not include a way to draw in
energy from external to your test setup into your test setup, you are not likely at all ever going to see a COP > 1.
Start with a theory for achieving COP > 1 which you think potentially at least holds some promise, then put this theory
to the test systematically on the test bench. If it doesn't work at all as predicted and you have tested it well, then
you probably need to go back to the drawing board at that point. :)
Paul just dropped this
https://www.dropbox.com/s/xjto75krz7vtyuj/Tesla%20Turbo%20%C2%A9%20Copyright%202019%20-%20All%20Rights%20Reserved%20-%20Open%20Source%20Project%20v0.1.m4v?dl=0 (https://www.dropbox.com/s/xjto75krz7vtyuj/Tesla%20Turbo%20%C2%A9%20Copyright%202019%20-%20All%20Rights%20Reserved%20-%20Open%20Source%20Project%20v0.1.m4v?dl=0)..
over here...
http://www.energeticforum.com/renewable-energy/21075-nikola-tesla-s-turbine-secrets-global-open-source-project-4.html (http://www.energeticforum.com/renewable-energy/21075-nikola-tesla-s-turbine-secrets-global-open-source-project-4.html)
Not sure if he has achieved phase change with gain [ala Clem]or ??
and yes I know.... its not good to hug the plastic at a zillion RPM [very exciting.... Butt ?!!]
actual demo starts at 2 min mark ,runaway ?or ? at the end//
Quite possible they are seeing a second stage hitting its design window and needing much less input,....self run would tell for certain if they hit a phase change with gain or ??..
regardless the fearless hand does seem to initiate the increase RPM when he applies that back pressure to the out flow [standing wave hand tuned exhaust .....
wild stuff indeed
https://www.youtube.com/watch?v=rCC8mY7ykM4 (https://www.youtube.com/watch?v=rCC8mY7ykM4) (part 2)
[Includes Grenade in simulation Schematic]
https://www.youtube.com/watch?v=dOJfr_lz0jU (https://www.youtube.com/watch?v=dOJfr_lz0jU) (part 1)
Thank you ACCA
FIN
Addendum:
RUSLAN videos (physical device appreciation)
FIN
Quote from: blueplanet on January 02, 2019, 08:56:33 AM
Good stuff.
Thank you my friend
Wesley
I do not take any responsibility for your action .
to make your understanding clear I say do not do it ever.
That applies to all post of mine and all videos of mine.
So guys the whole trick is in that so called "mirror reflection of the ground phase"
At certain point you trapping electromagnetic wave inside of that interface between air and ground.
but in reverse we may say that we are dealing with Schumann waveguide having one of its boundaries shared with our receiver.
that is the earth.
All lightnings and all energy fluctuations are affecting that boundary .
Now what we need is the receiver. that matches exactly phase dependent energy inside of that interface.
- Kapanadze receiver.
- Akula receiver
- Ruslan reciver
- SR193 receiver
- Vasmus receiver
- Chibanidze receiver
When Corum brothers where talking about protecting their energy send by their Viziv tower they said that
It is impossible for anyone to be able to steal this energy because algorithm requires
exact phase match of that polyphase components.
Yes they are right.
They can create zillions of polyphase components.
Their problem is:
That they do not know that nature does not care about their polyphase.
Wesley
Legal Note: I do not take any responsibility for your action .
That applies to all post of mine and all videos of mine.Quote from: forest on January 02, 2019, 03:16:46 PM
"Read my post again.[/size]the energy is extracted from Schumann waveguide."
only in this case I think, it's still not explanation at all
I'll try again:
In traditional approach:
You have suspended sphere in the air
You can move sphere up down
The mast is telescopic structure made from PCV
The HV of Tesla coil is right below
The primary winding of Tesla Coil is at the bottom.
However that coil is not on the ground.
This is your transmitter.
The height of the sphere is your tuning factor.
The diameters and other vital structure elements are given on the picture.
The receiver can be exactly the same if you already phase matched it.
So how to do it;
Legal note : never do it. :) 1.Make two identical structures
2.the first one is your transmitter. Tx
3.the second one is your receiver. Rx
4.place both of them at the distance of 20 meters.( so Rx is not in Near Field in Tx)
5.Try to tune the transmitting structure primary coil using at first regular function generator.It is tricky as you need right polyphase.
it should be close to 90 degrees ( not exactly 90) but I got it at 45 degrees.
6.Try to adjust your receiving structure similarly and have oscilloscope connected ( at best spectrum analyzer) to the low voltage primary coil of Receiving structure.
7."Blindly" play with frequency of transmitting function generator and height of the sphere.
8. make sure that your Tesla coil works on its resonance frequency. So you must calculate or measure its highest point of resonance.
NOT ITS HARMONIC resonance!!!!!!!!!!!!!
9. observe using another person what is going on at the receiver side.
10. than minimize the power from generator to 50% ,retune both the Rx and Tx
11. than minimize the power to 10% and retune .
Wesley
Hi Wesley. In my experience in this area of research only the test bench can tell you what actually works
and what does not. What might seem easy in theory often doesn't work out that way when put to the actual test. :)
Nature has a tendency of getting in the way of our ideas. Here is reminder of what Kapanadze's basic 2004 setup looked like.
Quote from: lancaIV on January 02, 2019, 04:33:15 PM
No concern that this "transmitter" technology is probably restricted in use by
a. https://www.itu.int/en/Pages/default.aspx (https://www.itu.int/en/Pages/default.aspx) International frequency band use or national b. Genfer Konvention : acoustic weapons/instruments
c. health-regulations: electro-magnetic compatibility
We have had in the last thirty years sufficient discussions ( studies ? ) about electro-smog.
No my friend:
Acoustical wave is longitudinal wave that is property of classical physics.
Zenneck wave is in area of quantum physics and is electromagnetic TEM that has nothing to do with acoustics.
It is also non radiative. - After the
Near Field it disappear . It does not exist in
Far Field. Well sort of...
If your Tx is not transmitting omnidirectional electromagnetic wave, but flat surface wave than there is no way for any agency or anyone to find its presence.
We are talking about
not radiating TEM and its TM ( transverse magnetic mode ) not about EM Wave.
There are no receivers in the world for it known to me.
Think about non polluting flat wave like flat squashed elephant, or
flat ant squashed by bulldozer and now in the interface.
- the elephant is your 1000W
- the ant is your 1W
Viziv license expired.
if you want to be on line with regulation you can check your local regulations.
Wesley
Quote from: lancaIV on January 02, 2019, 05:27:18 PM
Okay, thanks a lot !
What I see is an "Experiment" period licence, expired.
What I see here is a relatively huge tower
https://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwide
(https://www.waxahachietx.com/news/20180611/milford-testing-facility-tower-seeks-to-send-signals-worldwidein) In relationship to "1000 W" transmitter power range.I hope that your "tower" is portable ! ;)
Sincerely - OCWL
False assumption.
Small tiny antenna that resonates at frequency X is equal in performance to huge antenna at frequency X.
the only difference is in efficiency of that antenna.
However receiving antennas are more forgiving.
When your transmitter has high VSWR it just damages the Tx
When your receiver has impedance mismatch it simply receives less.
Think about your car radio with broken antenna.
http://www.antenna-theory.com/definitions/vswr.php (http://www.antenna-theory.com/definitions/vswr.php)
Corum Brothers are not gods and their experience is much below Tariel Kapanadze practical experience.
Tariel theoretical experience is very low. He had no idea what he was playing with.
What they know that they use.
First microwave was at the size of truck.
Please read my previous post again
I have made some addition to it.Wesley
Quote from: lancaIV on January 02, 2019, 06:03:48 PM
I do not conceptual understand your used expression " same performance" and your resume that it only depends from the efficiency.For me, following high fidelity devices, it depends from the receiver: thereby included tuner , equalizer and modulator, Amplitude + Frequency + Time Modulation .The antennas function:: tube or channel or " black/white whole"
I explained it in the link talking about VSWR. Please read it, in my previous post.
So it is not size of an antenna but impedance match that makes an antenna of any size to transmit energy.
The physical aperture of an antenna is only important if you targeting specific performance.
e.g. Your Far Field in given frequency at desired direction.
You can use half wave or quarter wave length of dipole antenna . But you can shorten that antenna with baluns( shortening coils.) like G5RG
You can use the same length of wire minus its capacitive wind to wind factor coiled in coil.
It will work beautifully. But now this antenna is very small.
As long as SWR is 1:1 or close to it.
However SWR 1:5 in receiver is still excellent antenna.
That is why I said receiving antennas are more forgiving.
Tesla coil is the coil. But you can stretch HV coil wire and it will work.
Now your traditional receiver has sensitivity of 0.1uV in average.
That says only about receiver ability to process signals that are 0.1uV over the noise floor.
And that has nothing to do with the antenna.
Antenna is independent creature good or bad for you at given frequency range.
And its
gain is measured with db (Decibels .)
I must totally disagree with you . Antenna is not the filter.
It does not block anything it only resonates or not.
And it has bandwidth with one particular highest frequency of its resonance that gives you the highest level of the signal in TX or RX.- with proper impedance match.
-or the highest gain.
I'm just insignificant member of shadows of the crowd.
Wesley
I told you guys before what I think Mr. Kapanadze's secret is, but for some reason
no one believes me.
mr kapanaze secret is to understand that the earth and the atmosphere is an actively
charged asymmetrical massive capacitor. what most people fail on is that you have to have
a massive ground system, because that is where the mass of the charge current is coming from.
this guy explain so clearly even a carpenter can understand it.
https://www.youtube.com/watch?v=yk4CJLjNwfQ&t=3s
Moin Moin or Good morning ! The light-wave frequency oscillation spectrum has his "trinity": in Units( included pseudo-) eV, dB and nm.
Next :
https://en.m.wikipedia.org/wiki/Harmonic (https://en.m.wikipedia.org/wiki/Harmonichttps://en.m.wikipedia.org/wiki/Harmonic_(disambiguation)
Caution the meaning differences : https://en.m.wikipedia.org/wiki/Harmonic_(disambiguation (https://en.m.wikipedia.org/wiki/Harmonichttps://en.m.wikipedia.org/wiki/Harmonic_(disambiguation))
and
classical physics-"philosophy" :
- https://en.m.wikipedia.org/wiki/Laplace%27s_demon (https://en.m.wikipedia.org/wiki/Laplace%27s_demon) - https://en.m.wikipedia.org/wiki/Maxwell%27s_demon (https://en.m.wikipedia.org/wiki/Maxwell%27s_demon)
What means " Paradigma, Axiom" in a Meta -World?
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529359/#msg529359 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529359/#msg529359)
Wesley
I don't think the transmitter receiver pair is the simplest we can do. If you look at Kapanadze device they look much simpler. In fact I believe all you need is a transformer, capacitor and the switching mechanism.
Quote from: forest on January 03, 2019, 11:12:28 AM
When you make pair of Tx, Rx to work,based on my link, the only what you need to remember is 2 generators.
Everyone with no single exclusion used it.However looking at Marconi in Bolinas California ,he in 1920-1923 was trying to do it bases on original
Tesla'sConcept. - using only 1 generator with phase shift. Look at history about Marconi.I did.
Schumann waveguide boundary has only
2 polyphase components to match........... likely.
Wesley
Hi Wesley. I think the problem is that just saying that these devices are drawing the excess energy
from surface waves travelling along the surface of the Earth (possibly at a Schumann resonant frequency)
does not appear to help people much from a practical point of view in getting these setups working. However,
maybe I have missed some specific practical details that you have outlined here or in your video, so I will try to
review everything again this weekend if/when I get the chance. All the best...
for our learned colleague lancaIV . you should not stop
you meds.
https://www.youtube.com/watch?v=dihQuwrf9yQ
I follow this diskussion for some while now ... its not my intend to express my view on the topic ..
how ever this is eventually little aid for wesley to help some guys here out in termes of understanding..
1 http://www.vlf.it/inductor/inductor.htm about schumann phenomena
2 https://www.nonstopsystems.com/radio/frank_radio_antenna_magloop.htm scroll down and look for distribution of voltage and current .
all the best Jo
Hi Wesley. No worries at all. There is no rush.
I was just giving you some feedback on your post.
Quote from: jojo500 on January 03, 2019, 04:07:36 PM
1 http://www.vlf.it/inductor/inductor.htm (http://www.vlf.it/inductor/inductor.htm) about schumann phenomena
2 https://www.nonstopsystems.com/radio/frank_radio_antenna_magloop.htm (https://www.nonstopsystems.com/radio/frank_radio_antenna_magloop.htm) scroll down and look for distribution of voltage and current .
all the best Jo
Thank you very much my dear Jo.
Wesley
Quote from: lancaIV on January 03, 2019, 01:16:21 PM
Is " resonance" good ( = desireable) or is it bad ( = neutralize, eliminate) ?
Explanation about the several kinds and views of " resonance" and how to treat :
https://patents.google.com/patent/US7843299B2/en (https://patents.google.com/patent/US7843299B2/en)
Very entertaining Thank you. This patents uses typical method of magnetic amplifiers by implementing additional winding exactly as primary winding but acting as parallel resonance circuit.,
that means in resonance all frequencies are allowed but one.. and if you short them to ground than you have reluctance switch when core is used.
when core is not used such as air transformer you have perfect overload preventing mechanism.
There is one moment useful to us for general understanding of our phenomena of interest.
Wesley
Important links with corresponding pictures.:
1. http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html (http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html)Please go to middle of the page and look for picture ad #1
QuoteOriginally Posted by William Beaty
This only can work because the long, thin coil will support slowly-moving electromagnetic waves,
and the electron-sea within the metal of this coil behaves as if it's become compressible...
The EM fields are transverse. And the only thing which acts like a "longitudinal" wave is the density of free electrons in the wire.
The author of this comment on original drawing did make mistake.
look here https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529434/#msg529434 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529434/#msg529434)
2. http://www.tuks.nl/Mirror/tfcbooks_Tesla/articles/tws12.htm (http://www.tuks.nl/Mirror/tfcbooks_Tesla/articles/tws12.htm)
3.https://www.youtube.com/watch?v=uii9clp_DSg (https://www.youtube.com/watch?v=uii9clp_DSg)rybki.. the fishes.
That is what makes slow wave the
group velocity
You can write in YouTube word "group velocity" to find easier to understand material.
Wesley
Wesley's contribution as an insightful deep thinking investigator has brought up very important points to take to the bench, his many lab experiments should be applauded.
Typical social engineering trying to get people to toss out the baby with the bathwater. One must consider the source of derision, as there is an intended outcome.
Another possible challenge to the Corrum bros is the Robert T Hart patents for antenna design claiming mag field perturbation without EM radiation. Claims are different workings similar at the surface boundary. US20070013595A1 When tuning is correct reactance cancels EM component.
https://en.wikipedia.org/wiki/Evanescent_field
"The first objective of this article is to explain what surface plasmons and surface plasmon polaritons are. The term surface plasmons (SPs) was first coined in the middle of the 20th century to study the response of thin metal foils at petahertz frequencies when subjected to fast electron bombardment. SPs are coherent electron oscillations that exist at the interface between two materials where the real part of the permittivity changes sign across the interface. When an SP couples with a photon, the resulting hybrid excitation is called a surface plasmon polariton (SPP). SP refers to the charge oscillations alone, while SPP refers to the entire excitation of the charge oscillations and the electromagnetic (EM) wave. Under the right conditions, the photon can excite a longitudinal wave of electrons in the metal. The second objective is to describe the evolution of these concepts over the years and illustrate their relation to a surface wave and not to a Zenneck wave. Both Zenneck and surface waves are transverse magnetic (TM) waves. The surface waves thus cannot be excited by transverse EM (TEM) waves but rather by an electron beam that can be effectively generated by a source of electrons or a quasiparticle such as an evanescent wave, which can tunnel through the medium and thus excite the electrons. This electron wave produces its own EM wave, and this plasmonic wave is confined to a very small region near the interface. Hence, SPP is a surface wave with a longitudinal field component that propagates at the interface between a metal and a dielectric at petahertz when the conditions are right and can propagate along the metal-dielectric interface at a wavelength that is shorter than that of incident light until its energy is lost either via absorption in the conductivity of the metal or through radiation in free space. The longitudinal surface wave of an SPP is sometimes wrongly associated with a Zenneck wave. A Zenneck wave is produced at the zero of the reflection coefficient of a plane incident TM wave (at the Brewster angle of incidence) on an air-dielectric interface, whereas surface waves are produced when the TM reflection coefficient is infinite. Both the Zenneck wave and the surface wave are TM waves and are nonradiating, as they have, in general, exponentially decaying fields with distance. For the Zenneck wave, the evanescent transverse field components do not change appreciably with frequency (because the phenomenon of Brewster angle is independent of frequency), whereas for a surface wave, with an increase of the frequency the wave is more closely coupled to the surface. This property makes it possible to distinguish between these two evanescent waves. SPP is generally coupled with Raman scattering and not with Rayleigh scattering. These points are illustrated in the remainder of the article. Hence, surface plasmons/polaritrons are surface waves that are the solution of Maxwell's equations unless perhaps there is a resonant Raman scattering, which is equivalent to exciting the structure with an incident frequency corresponding to the electronic absorption bands, as illustrated in "A Survey of the Various Natures of Light Scattering"
After5 seconds reading: Peta-Hertz !!!
WELLCOME : Fermi-Dirac Dimension
similar re-/search: https://books.google.pt/books?id=v_K6jmnGTS4C&pg=PA43&lpg=PA43&dq=zpe+mead&source=bl&ots=pwEFF0FmhC&sig=F2_H4wwEajK1bzoM_tGW-yl6G2Q&hl=de&sa=X&ved=0ahUKEwiO_5qz5dTfAhWLMhQKHe6tD-AQ6AEIGzAG#v=onepage&q=zpe%20mead&f=false
You can dream out the device but actually this is prototype stage in lab !After the prototype the mass production machine prototype,........
What helps to have an antenna if the L...-gap is a. too short b. too large https://en.m.wikipedia.org/wiki/Larmor_precession (https://en.m.wikipedia.org/wiki/Larmor_precession)
Raman- Bose + Einstein-Bose
KONDENSAT ! ???
Quote from: F6FLT on January 04, 2019, 06:33:31 AM
I notice a lot of misinformation here and there.
A Zenneck surface wave is a planar electromagnetic wave that propagates at the boundary interface between two media with different dielectric constants. Instead of extending in 3D, it extends in 2D, with rapid attenuation when moving away perpendicular to the surface.
There is nothing new about this, it is always an electromagnetic wave with its electric field perpendicular to the surface and its magnetic field parallel to the surface.
It has been used since the beginning of the 20th century for long and medium wave radio transmissions. A hectometric frequency band has even been reserved for exclusive maritime use, due to the excellence of this type of propagation on the sea surface.
As always in radio where the signal weakens in 1/r², surface wave or not, it is therefore impossible to use these waves to transmit energy.
Tesla's transmission device has nothing to do with Zenneck's waves, because of the very low frequencies it used, which meant that the transmitter and receiver remained in the same near field, unlike the LW and MW radio waves. This was precisely the interest of the device, since the strong coupling obtained in this way made the transfer between transmitter and receiver much more efficient.
With very low frequencies, therefore very long wavelengths, it became possible to envision long distances while remaining in the near field. But it means forgetting that the efficiency of such a system depends on the size of the radiating elements, relative to the wavelength. If the Schumann frequencies were to be used efficiently, towers would have to be built whose height would represent at least 10% of the earth's radius!
Sorry for the believers in Tesla as God, but on long-distance energy transmission, Tesla screwed up, he was a much better engineer and inventor than a physicist.
hi F6FLT,
I think you have misinterpreted Tesla's method of transmission like the rest of the 99% typical crowd whom prefer to believe in Marconi whom applied "electromagnetic waves" for long distance radio communication.
Isn't that what we were taught.
But words like Zenneck's waves or maybe surface waves was not used during that era but that is not the point.
After Wesley have presented his
Zenneck[/color][/font][/size]
demonstration.
The first video i can directly associate/recall is Eric Dollard-
Tesla's Longitudinal Electricity.Before you start commenting on anything.
Please watch Eric dollard full video or start from 34minute into video as provided.
https://www.youtube.com/watch?v=DFa-IymyWHM (https://www.youtube.com/watch?v=DFa-IymyWHM)
From the above video it's easy for me to understand which type of dielectric containing a particular noble gas can be used to enhance transmitting range better than what Wesley likely have used for the recent zenneck video which is already considered a successfully replicated demo model. :D
I do admit one thing-surface wave even if fully understood can't be used for
interstellar communication. :-X
Gabriel Kron said his network analyzer for the navy worked without the power source after it was started from battery. He said negative resistors exist and open circuits using them is the answer.
Trying to hunt down his paper where he said this, but it seems every archive has the other papers and not his...
The Tensor is the Tensor society's paper and this paper is from 1963-64
He also said that in systems theory it is customary to replace negative resistance with a capacitor and positive with a inductor. Then he said that if the system appears to have a negative resistance in it, it behaves like there is one. So no "actual" component is necessary, if the system thinks there is one.
Also interesting that only reference to Kron's paper is in Bearden's page and the reference to that paper says "unknown". Everybody else references Bearden. Took me a while to track down which paper Bearden was referring to
Gabriel Kron "The Frustrating Search for a Geometrical Model of Electrodynamic Networks"
http://www.energeticforum.com/archive/index.php/t-962-p-7.html (http://www.energeticforum.com/archive/index.php/t-962-p-7.html) 01-09-2019 6:13 AM
https://books.google.pt/books?id=XvIkBQAAQBAJ&pg=PA181&lpg=PA181&dq=the+frustrating+search+for+a+geometrical+model+of+electrodynamic+network&source=bl&ots=HlovmX8w2a&sig=W6OCyvSDgvcHH0AfpCgEm5Myjp4&hl=de&sa=X&ved=0ahUKEwiv_JDFyNTfAhUGkRQKHZi6DjMQ6AEIFDAC#v=onepage&q=the%20frustrating%20search%20for%20a%20geometrical%20model%20of%20electrodynamic%20network&f=false (https://books.google.pt/books?id=XvIkBQAAQBAJ&pg=PA181&lpg=PA181&dq=the+frustrating+search+for+a+geometrical+model+of+electrodynamic+network&source=bl&ots=HlovmX8w2a&sig=W6OCyvSDgvcHH0AfpCgEm5Myjp4&hl=de&sa=X&ved=0ahUKEwiv_JDFyNTfAhUGkRQKHZi6DjMQ6AEIFDAC#v=onepage&q=the%20frustrating%20search%20for%20a%20geometrical%20model%20of%20electrodynamic%20network&f=false)
http://www.quantum-chemistry-history.com/Kron_Dat/KronGabriel1.htm (http://www.quantum-chemistry-history.com/Kron_Dat/KronGabriel1.htm)
Quote from: lancaIV on January 04, 2019, 11:38:37 AM
Gabriel Krohn "The Frustrating Search for a Geometrical Model of Electrodynamic Networks"
Yes I know the paper where that article was by Kron. What I can't find is the actual paper "The Tensor"
https://archive.org/details/TensorsForCircuits
Probably there is it to find
https://youtu.be/KLAPRNWuAn4?t=620 (https://youtu.be/KLAPRNWuAn4?t=620) watch it for another two minutes.
The phase match is created by use of two generators, but you can use one generator with phase shift.
The initial phase relation is created by 9V battery powering generators.
Than the energy from one of polyphase components is interacting (matching phase shift) with surface wave.
Part of that energy is used to keep the generators working.
We need to understand that we do not deal with transmitted energy but with receiver. Rx
Receiver is more forgiving than Tx
Wesley
To get an idea about possibilities:
https://worldwide.espacenet.com/publicationDetails/biblio?CC=US&NR=5590031A&KC=A&FT=D#
https://en.m.wikipedia.org/wiki/Mie_scattering
And citing documents
https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=5590031A&KC=A&FT=D&ND=&date=19961231&DB=&locale=
Quote from: lancaIV on January 04, 2019, 02:41:28 PM
Hi lancaIV. That is an interesting patent. They claim their device will convert 'high frequency zero point
electromagnetic radiation energy to electrical energy', and their patent was granted (US5590031A).
https://patentimages.storage.googleapis.com/37/c6/ba/566c00e9b0f513/US5590031.pdf
They use two dielectric spheres.
"Abstract
A system is disclosed for converting high frequency zero point electromagnetic radiation energy to electrical energy.
The system includes a pair of dielectric structures which are positioned proximal to each other and which receive incident
zero point electromagnetic radiation. The volumetric sizes of the structures are selected so that they resonate at a frequency
of the incident radiation. The volumetric sizes of the structures are also slightly different so that the secondary radiation emitted
there from at resonance interfere with each other producing a beat frequency radiation which is at a much lower frequency than
that of the incident radiation and which is amenable to conversion to electrical energy. An antenna receives the beat frequency radiation.
The beat frequency radiation from the antenna is transmitted to a converter via a conductor or waveguide and converted to electrical energy
having a desired voltage and waveform."
It is interesting, but Mr. Kapanadze does not seem to use two dielectric spheres or other such dielectric structures.
Void, Kapanadze: Impedance matching network here
Mead, Nachamkin: beat frequency circuit and transformer
It is to compare and to search and find the easiest way to get "common" DC or AC current.
Quote from: Hoppy on January 04, 2019, 04:52:05 PM
Thanks Wesley. The Kapanadze green box device lamp load is connected between the ground wire (running through the centre of the antenna / grenade) and one end of the antenna winding - see attached clip. This does not make sense to me in relation to the schematics you posted in your reply to me. Can you explain this please?
I'll try.
There are many ways to receive surface wave.
Viziv page shows three different concepts.
Tariel Kapanadze used at least 5 different concepts.
The common factor for all of that from Viziv and Tariel together is the means of tuning.
Note: I have seen green box only on video.Note: second picture is related only to that particular concept
Word rotation means change of angle only.
Note: original patent application of Corum Brothers says:
about CW/CCW winding !!!!! read it you'll see it.
They knew about it.
Wesley
Quote from: Hoppy on January 04, 2019, 06:24:47 PM
Thanks Wesley. However, the kapanadze load is misplaced in respect to your crossed representation because the load is in series connection with the one leg of the antenna and the ground wire.
look at picture 12a you have series connection.
just cut out impedance matching box as if it did not exist.You use it only if you need it.
You can do the same with 12b
There you go
You may still call it parallel but it is series with respect to ground
You may say there is no ground.
Than think about counterpoise.
Kapanadze concept was much more advanced but it was very unstable and highly reactive.
Kapanadze was trying to move his device only in vertical axis Y. Walking with it would ruin his show.
I did the same here with placing dielectric on the top of another.
https://youtu.be/KLAPRNWuAn4?t=1174 (https://youtu.be/KLAPRNWuAn4?t=1174)
and not to much.
Wesley
I decided to make comment ,
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
contra-wound
combined
= CCW/ CW = Kapanadze coil
Wesley
#2074 James Corum 1980 priority year patent to citing documents
https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=4751515A&KC=A&FT=D&ND=&date=19880614&DB=&locale= (https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=4751515A&KC=A&FT=D&ND=&date=19880614&DB=&locale=)
with newest 2018 entry from CPG Technologies ( not to promote only to compare 1980 knowledge with 2018 technical standart)
Quote from: stivep on January 04, 2019, 08:41:32 PM
Yes please do it.
We may assign his coil to one of concepts of Corum brothers.
Thank you.
By the way I did not list Daly
Look also at word: combined.
from text above.
Wesley
Hi Wesley. OK, after reviewing the pictures of Daly's coil disassembly, there was not
any special counter windings like Akula and Ruslan used that I can see. Daly did have have two
to three layers of wire for his output coil on one end of the coil form, but all the turns seems to have
been in the same direction for his output coil. He just seems to have wound it that way to be able to
fit all the turns he wanted for his output coil on there, and there was extra room at one end of the coil form
since the coax he used for the high voltage impulses didn't run the full length of his coil form.
I believe Akula first copied Daly's setup, and then made his own variations after that, of which Ruslan later copied.
I believe I see a common general approach in all these devices, and therefore I think I have the general idea of how
to try to replicate these devices. Once I finish my experiments with my current test setup not related to these devices,
I will try to do a proper replication of these type of devices based on the way I think these devices need to be configured.
If I get anything working, I will try to make a demo video. :)
I would say it is definitely still unknown where the extra energy is coming from for these devices, assuming they really work
as claimed and shown, and I am inclined to think Kapanadze may be sincere when he says he thinks the energy comes from the
'surrounding ambient environment'. In other words, I think no one is really quite sure where the actual energy is coming from, is my guess.
First a person has to get a setup of this type working, and then you can let the propeller-head physicists argue over where the energy
is really coming from. ;)
Quote from: stivep on January 04, 2019, 06:34:57 PM
There you go
and not to much.
Wesley
Yes, with 12a but not with 12b.
"You may say there is no ground."
"Than think about counterpoise."
"Walking with it would ruin his show."
So, its an inductive coupling from a TX ground coil??
Definition : Macro Regime and Quantum Regime ! https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4720642A&KC=A&FT=D&ND=3&date=19880119&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4720642A&KC=A&FT=D&ND=3&date=19880119&DB=EPODOC&locale=en_EP#)
Definition : Schumann resonances ! https://en.m.wikipedia.org/wiki/Schumann_resonances (https://en.m.wikipedia.org/wiki/Schumann_resonances)
Pardon me, but let me become ( very, common ?) vulgar/" ordinaer" : Me interests a BS neither which NAME the energy to useable power spectrum has(ZPE,Vacuum,Near/Far, et cet.) nor how the device ( at first) has to be constructed : common Tesla antenna, flat antenna,mesh/ array,
macro-/micro-machinery ..... !
The first target is to reach a sustainable development aspect bewaring device which shall satisfy the first interests stage : available environmental energy conversion !
Wesley, yes resonance is suppressed in the grid network(as to read in the Dinnan/Meta-C papers), but begin to
think for example about small fluorescent bulb ballast and their ( "interference, mismatch)net grid distortion and think then bigger : industrial by 100 KW and more electric devices inertia/ inrush voltage or current phase !
Maxwell- Wien displacement laws ! The comercial world pays for " Blindstrom/ apparent current" compensation !
Off-grid (" island-solution) we can experiment with all physical possibilities ( caution : chance/ risk ratio ), on grid there are clearly physical and technical ( by concept) restrictions and limitations ! Which has to be respected ! By free will and law !
About Nikola Tesla : a great inventor ( honor : Physics Unit : Tesla ) for the other side : how had been N. Tesla without the creative partnership with Charles, " Prometeus", Steinmetz ?How many " creative thinker" in the Tesla Labs saw their work later as " INVENTOR : Nicola Tesla, assigned".
Loud thinking without reflex ex(s)pectation
"Denkmal des unbekannten Inventors" , Schweigesekunde (Minute , dafuer :P ,zu lang )
DIE S(ch)AU MUSS GO ON ( or OFF)
Sincerely
OCWL
https://de.m.wikipedia.org/wiki/W%C3%A4rmerauschen (https://de.m.wikipedia.org/wiki/W%C3%A4rmerauschen)
Quantentheoretische Erweiterng
Boltzmann : What is a " black" what is a " white" body, STRICT BLACK or STRICT WHITE : dB,nm,eV !
( what is in Quantum Physics : body) "Ultra-Violett"- Katastrophe ,
is to enter a " Katastrophe"- stage a need , to preserve from ?
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FW%25C3%25A4rmerauschen
Hi everyone,
I am curious if kapanadze coil(maybe input coil) itself needs to emit ions during kacher interrupter off state.Akula or someone had mentioned about this few years ago but information stored became fragmented. :'(
After watching Tariel first video taken from bedroom and Akula older device.I noticed that both devices operated from high dc voltage after rectified 220volts main as provided from inverter.
It wouldn't make sense to use high voltage WIMA or microwave oven capacitor after 3 turns from yoke if we are using low voltage 12 or 24volts to power the yoke or toroid.
The last time(few years ago) I tried using rectified dc voltage from 12volts to 220volts inverter using typical pwm generator without kapanadze coil attached and found out after 3..4 turns from my large nanocrystalline toroid produce around 210Vpp.
Base on recent experiment with div by 3 circuit prev attached-Achieving higher stable frequencies from kapanadze coil after kacher was power on did not produce any high enough voltage <30Vpp to even power up a isolated A/C to dc converter.
This is something to consider why high voltage capacitor was used in the first place.
Screenshot attached from my old video to reveal voltage from 3turns in which the toroid was powered by high voltage dc supply using pwm circuit.
https://www.youtube.com/watch?v=cGRPKNhC_TE (https://www.youtube.com/watch?v=cGRPKNhC_TE)
Quote from: Void on January 04, 2019, 01:07:51 PM
Hi Belfior.
It sounds like you are having a frustrating search finding the G. Kron article. ;)
If you can't find a copy of the article online, you can try going to
a library and see if they can find the article for you. They can check if any libraries
out there have a copy, and can possibly get a copy of the article for you if they can find the
particular publication at a library out there. A university library may be able to help you find it
if a public library can't help you. Give them the following info:
G. Kron, The frustrating search for a geometrical model of electro-dynamic networks.
Tensor (new series), 13, 111 - 128 (1963).
However, Gabriel Kron was by all indications a complete and total propeller head.
Unless you are comfortable with advanced math as applied to complex engineering topics
you may not understand much about what he wrote about in that article, but you never know.
There might be a few interesting tidbits in there that aren't expressed in complex mathematical equations.
Yeah I contacted some sites, that had other The Tensor articles and a university, that has them all. The university has all of them PAST that date, when Kron published his :(
I would like to learn tensor math and systems analysis, but I also have a life. I just want to read what Kron actually said. The other tidbits in Kron's books are pretty interesting like "Maxwell breaks down if the system is moving" and it seems to mean that you get anomalies, if the coils and other components are rotating
Quote from: F6FLT on January 05, 2019, 05:06:55 AM
I spoke about efficiency of antennas.
We do not care about Far Field We only care about reactive not radiative region,
look at picture; https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/171104/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/171104/image//)
At Schumann resonances (< 30 Hz), the wavelength is > 10,000 Km
Here is small practical antenna at Schumann bandwidth.
When series circuit is at resonance both reactive components of impedance Xc and Xl are out of phase 180 cancel each other. the total current will be E=I*R . R never cancels .
( "phase" is not, to say it correctly, a property of reactance itself.) the max signal is out at that given frequency only (+/- width of the bandwidth)
Impedance is the total opposition to AC current. !!!! I hope it helps you F6FLT to understand it better.
Ohm's Law for impedance as : I = E / Z–Symbolized by the letter Z (in Ohms),
includes both Resistance and Reactance (May be stated as a value and angle, i.e.100/_45o–May be stated as R + jX, i.e. 10 + j20)
Some material for F6FLT to read: https://pdfs.semanticscholar.org/32fb/ebcb46e2420cef0a1c5e373f4ba4c1067b39.pdf (https://pdfs.semanticscholar.org/32fb/ebcb46e2420cef0a1c5e373f4ba4c1067b39.pdf)
The shortest antenna sizes used in practice are about 1/10 of a wavelength and they are poor. At Schumann resonances (< 30 Hz), the wavelength is > 10,000 Km.
Here you have below 2m long Schumann frequencies antenna .
Wesley
ELF antenna... (https://en.wikipedia.org/wiki/Extremely_low_frequency)
These antennas have long been made by hams around the world. You can buy an industrial manufactured such antenna.
The output is very, very weak signal, cannot usable as FE/OU.
https://www.aaronia.com/products/antennas/Magnotracker-ELF-6/ (https://www.aaronia.com/products/antennas/Magnotracker-ELF-6/)
QuoteInternal Amplifier: 25dB (optional 35dB), battery powered (3-4 hours) or continuosly powered via included power supply
(25 dB - is the first preamp stage.)
Work with such an antenna is possible only with the use of several additional low noise amplifiers with a gain of 10,000 or more. And a very good filter is also needed, otherwise nothing except the background of 50 - 60 Hz can be seen.
Hi there interesting work but must have cost a lot and you must have spent a lot of time building it too.
Can I just show you an attempt I recently made to do some of Wesly's ideas to see if they work for me
I have used one of my collection of Tesla coils 8) ;D Most of them well all of them tune down to 8hz
one way or another ie 'F' of the coil / by 8 to a whole number no remainder, they all do it. this one I'm showing
here tunes at 1,386,152 Hz / 432 (8 and 9) = 3211
I have yet to rewind the top layer to 90deg phase shift and retest with my cd4013 phase shift circuit.
Ionized gas or water in a glass, distilled or not, all this is equivalent to thick iron nail for microwave.
My last experiments, a radio transparent box with highly purified, distilled and deionized water 10 mm thick of water, covers the waveguide with microwave 22 GHz 200 milliwatts completely. 200 milliwats without water little warms the skin on the fingers. With the water - absolutely nothing on output is detected by the microwave diode, 1 millivolt. The detector diode D606 (USSR) works up to 50 GHz and above.
Without water - diode rectifies 2 volts.
http://www1.lsbu.ac.uk/water/microwave_water.html (http://www1.lsbu.ac.uk/water/microwave_water.html)
1.
https://www.youtube.com/watch?v=MBH5-oHqzp4 (https://www.youtube.com/watch?v=MBH5-oHqzp4)
for your entertainment ,some of you may find it very helpful.
This part is essential to understand Zenneck Wave later on. But it is in line with my video
https://youtu.be/KLAPRNWuAn4?t=385 (https://youtu.be/KLAPRNWuAn4?t=385)
2. http://electriciantraining.tpub.com/14182/css/Surface-Wave-76.htm (http://electriciantraining.tpub.com/14182/css/Surface-Wave-76.htm)
This is sort of old way to understand surface wave but very easy explained .
It points in fundamental to surface wave vertical polarization.
3. http://rexresearch.com/corumzenneck/US2017077715A1.pdf
This PDF is part of http://rexresearch.com/corumzenneck/corumzenneck.html
The details about how to do it are to be found in early versions of applications filed by Corum Bros.
4.https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=4751515A&KC=A&FT=D&ND=&date=19880614&DB=&locale=
Thanks to our German friend lancaIV we can easily dig in it.
Wesley
YOUR FUTURE and WORLD FUTURE WITH CORUM BROS FEW YEARS FROM NOW:
Patents of Corum; James F. :
do not forget there are two brothers I have listed only one of them.
1.MODULATED GUIDED SURFACE WAVES 14838852 Aug 28, 2015
2.EMBEDDING DATA ON A POWER SIGNAL 10079573 Sep 8, 2015 patent
electric load of the receiver circuit is modulated with reference to a data signal.
3.FREQUENCY DIVISION MULTIPLEXING FOR WIRELESS POWER PROVIDERS Sep 9, 2015 10033198 patent.
for wireless power providers using Zenneck surface waveguide probes to transmit power.
4.CLASSIFICATION OF TRANSMISSION Sep 9, 2015 10027131 patent
assigning authorization to the user of energy from Zenneck wave.
5.LOAD SHEDDING IN A GUIDED SURFACE WAVE POWER DELIVERY SYSTEM Aug 22, 2016 10027177 patent
send load shedding instructions to a plurality of user devices. You can be disconnected at any time.
6.ADAPTATION OF POLYPHASE WAVEGUIDE PROBES Sep 9, 2015 10027116 patent
A probe control system can be used to adjust the polyphase waveguide probe based on characteristic
of therein.
7.GEOLOCATION WITH GUIDED SURFACE WAVES Aug 28, 2015 10001553 patent
fixing a navigational position using guided surface waves
8.GLOBAL EMERGENCY AND DISASTER TRANSMISSION Sep 8, 20159997040 patent
method for disaster warning recovery including a power modulator.
9.MINIMIZING ATMOSPHERIC DISCHARGE ON A GUIDED SURFACE WAVEGUIDE PROBE 62467956Mar 7, 2017 application.
eliminating or minimizing atmospheric discharge within the guided surface waveguide probe.
Atmospheric discharge can be minimized to a nominal amount according to one or more factors, such as, for example, the use of a corona hood,
the effective diameter of the internal coil, the effective diameter of the tube, and the shape of the charge terminal.
methods of eliminating Schumann waveguide influence -and we need/(may) to do reverse of it.
10.CHARGE TERMINAL DESIGN FOR GUIDED SURFACE WAVEGUIDE PROBE 62467986Mar 7, 2017 application
guided surface waveguide probe/to launch a guided surface wave/ elevated to a height above the ground/
structure supports: charge terminal;/one section of internal coil/that is coupled to generator;/
a conductive tube conductively coupled to the at least one section of internal coil at a bottom end,
and coupling conductors that extend radially away from a top of the conductive tube to points located on an inner surface of the charge terminal.
That tube is shown here in Aleksey Pastuchov patent application: https://youtu.be/KLAPRNWuAn4?t=220 (https://youtu.be/KLAPRNWuAn4?t=220)
with my modification. and 90 degrees of phase shift is explained in my video.
Fig 3. on my video https://youtu.be/KLAPRNWuAn4?t=448 (https://youtu.be/KLAPRNWuAn4?t=448) shows you original drawing from Pastukhov
11.ADJUSTMENT OF GUIDED SURFACE WAVEGUIDE PROBE OPERATION 62468130 Mar 7, 2017 application.
Disclosed transmitting and receiving energy device in the form of a guided surface-waveguide mode along the surface of a the ground
excited by a guided surface waveguide probe.
12.GUIDED SURFACE WAVEGUIDE PROBE SUPERSTRUCTURE 62468213Mar 7, 2017 application.
structure includes a charge terminal elevated to a first height and a phasing coil elevated to a second height above aground.
/ includes a non-conductive support structure to support the phasing coil and the charge terminal.
The non-conductive support structure includes a truss frame that supports the phasing coil at the second height above
the lossy conducting medium and supports the charge terminal at the first height above the lossy conducting medium.
The structure further includes a substructure bunker constructed in the lossy conducting medium.
The substructure bunker can include foundational walls, a grounding grid formed in a foundational seal slab, and a
covering support slab at a ground surface elevation of the lossy conducting medium, the covering support slab supporting the non-conductive support structure.
13.GUIDED SURFACE WAVEGUIDE PROBE WITH INSULATING MATERIAL IN SUPPORT PLATFORM NEAR COIL(S) 62468022Mar 7, 2017 application.
description similar to previous one.
14. MINIMIZING ATMOSPHERIC DISCHARGE WITHIN A GUIDED SURFACE WAVEGUIDE PROBE 62467963 Mar 7, 2017 application
a charge terminal elevated over a lossy conducting medium. The shape of the charge terminal is designed to minimize atmospheric discharge.
A top portion of a coil being configured to provide a voltage to the charge terminal with a phase delay that matches a wave tilt angle associated
with a complex Brewster angle of incidence associated with the lossy conducting medium is recessed within a hollow region of the charge terminal.
We are looking for interaction with Schumann waveguide.
15.MEASURING OPERATIONAL PARAMETERS AT THE GUIDED SURFACE WAVEGUIDE PROBE 62467979 Mar 7, 2017 application.
Disclosed is an exemplary of guided surface waveguide probe.,/ the guided surface waveguide probe is made of:
charge terminal elevated to a height above the lossy conducting medium;
a support structure that supports the charge terminal;
an internal coil that is supported within the support structure and is coupled to an excitation source; a
conductive tube having a first end conductively coupled to the at least one section of internal coil, wherein a second end
of the conductive tube extends vertically towards and is electrically coupled to the charge terminal;
at least one sensor electrically coupled to the charge terminal or the internal coil, wherein the at least one
sensor measures an operational parameter of the guided surface waveguide probe; and a non-conductive
channel connected to the at least one sensor by which data associated with the operational parameter is communicated.
16.SUPPORT STRUCTURE FOR A GUIDED SURFACE WAVEGUIDE PROBE 62468163Mar 7, 2017
I did not include abstract here. there are many of support structures with drawings.
17.ANCHORING A GUIDED SURFACE WAVEGUIDE PROBE 62467884Mar 7, 2017 application.
waveguide probe can be suspended from a support structure manufactured from a nonconductive material,
the support structure comprising a plurality of beams. A base bracket is configured to receive at least one of
the plurality of beams and further comprising a hole. The base bracket rests upon a pad. An anchor bolt protrudes
from the pad through the hole of the base bracket. Also, a fastener engages the anchor bolt to secure the base bracket to the pad.
18.SYSTEM AND METHOD FOR MEASUREMENT OF TEMPERATURE ON A GUIDED SURFACE WAVEGUIDE PROBE 62468161 Mar 7, 2017 application
he system also comprises a temperature sensor positioned on one of the non-conducting structural components.
19.Detecting Unauthorized Consumption of Electrical Energy Sep 9, 20159885742 PATENT!!!!!
Aspects of detecting the unauthorized consumption of electrical energy are described. In some embodiments,
a system includes a guided surface waveguide probe that launches a guided surface wave along a surface of a terrestrial medium.
The system further includes metering systems that are distributed within a geographical region associated with the guided surface waveguide probe.
The system also includes at least one computing device and memory storing computer instructions that cause the at least
one computing device to generate an energy flow map using data obtained from the metering systems.
20. EXCITATION AND USE OF GUIDED SURFACE WAVE MODES ON LOSSY MEDIA Sep 10, 2014 9941566 patent.
Disclosed are various embodiments for transmitting energy conveyed in the form of a guided surface-waveguide mode
along the surface of a lossy medium such as, e.g., a terrestrial medium by exciting a guided surface waveguide probe.
21. HIERARCHICAL POWER DISTRIBUTION. Sep 8, 2015 9887557 patent.
a first guided surface waveguide probe launches a first guided surface wave along a surface of a terrestrial medium
within a first power distribution region. A guided surface wave receive structure obtains electrical energy from the first guided surface wave.
A second guided surface waveguide probe launches a second guided surface wave along the surface of the
terrestrial medium within a second power distribution region using the electrical energy obtained from the first guided surface wave.
22.EXCITATION AND USE OF GUIDED SURFACE WAVE MODES ON LOSSY MEDIA Mar 7, 2013 9912031 patent.
exciting a guided surface waveguide probe to create a plurality of resultant fields that are substantially mode-matched to a Zenneck
surface wave mode of a surface of a lossy conducting medium.
23.GLOBAL ELECTRICAL POWER MULTIPLICATION Aug 16, 2016 9899718 patent
a global power multiplier includes first and second guided surface waveguide probes separated by a distance equal to a quarter wavelength
of a defined frequency and configured to launch synchronized guided surface waves along a surface of a lossy conducting medium
at the defined frequency; and at least one excitation source configured to excite the first and second guided surface waveguide
probes at the defined frequency, where the excitation of the second guided surface waveguide probe at the defined frequency
is 90 degrees out of phase with respect to the excitation of the first guided surface waveguide probe.
THIS IS EXACTLY ALEKSEY PASTUHOV PATENT APPLICATION!!!!!!!!!!!!! FROM MY VIDEO
In another example, a method includes launching synchronized guided surface waves along a surface of a lossy
conducting medium by exciting first and second guided surface waveguide probes to produce a traveling wave propagating along the surface.
24. EXCITATION AND USE OF GUIDED SURFACE WAVE MODES ON LOSSY MEDIA Mar 7, 2013 9910144 patent.
methods for transmission and reception of electrical energy along a surface of a lossy conducting medium medium.
In one example, a receive circuit is used to receive electrical energy from a guided surface waveguide probe that
transmits the electrical energy in the form of a Zenneck surface wave along a surface of a a lossy conducting medium
25.OBJECT IDENTIFICATION SYSTEM AND METHOD 20180175630 A1 June 21, 2018 application.
An object identification system includes a guided surface waveguide probe that produces a guided surface wave;
and an object identification tag having a receive structure and a tag circuit, the tag circuit coupled to the receive structure
and electrically powered as a load on the probe by conversion of the guided surface wave to electrical current at the receive
structure, the tag circuit configured to emit a return signal containing a tag identifier when electrically powered by presence
of the guided surface wave.
26. OBJECT IDENTIFICATION SYSTEM AND METHOD 20180172798 A1 June 21, 2018 application
this is another one.
26.EXCITATION AND USE OF GUIDED SURFACE WAVES 20180166884 A1
June 14, 2018 application.
transmitting and receiving energy conveyed in the form of a guided surface-waveguide mode along the surface of
a lossy medium such as, e.g., a terrestrial medium excited by a guided surface waveguide probe.
27.SITE PREPARATION FOR GUIDED SURFACE WAVE TRANSMISSION IN A LOSSY MEDIA 20180166762 A1 June 14, 2018 application.
Aspects of a guided surface waveguide probe site and the preparation thereof are described. In various embodiments,
the guided surface waveguide probe site may include a propagation interface including a first region and a second region,
and a guided surface waveguide probe configured to launch a guided
surface wave along the propagation interface. In one aspect of the embodiments, at least a portion of the first region
may be prepared to more efficiently launch or propagate the guided surface wave.
Among embodiments, the portion of the first region, which may be composed of the Earth, may be treated or mixed
with salt, gypsum, sand, or gravel, for example, among other compositions of matter.
In other embodiments, the portion of the first region may be covered, insulated, irrigated, or temperature-controlled,
for example. By preparing the site, a guided surface wave may be more efficiently launched and/or propagated.
28.VARIABLE FREQUENCY RECEIVERS FOR GUIDED SURFACE WAVE TRANSMISSIONS 20180159374 A1 June 7, 2018 application
guided surface waveguide probe and a guided surface wave receiver, where the guided surface wave receiver comprises
processing circuitry that (a) identifies at least one frequency from a plurality of available frequencies associated with a
transmission of Zenneck surface waves along a terrestrial medium, and (b) adjusts a frequency at which the guided
surface wave receiver receives electrical energy from the Zenneck surface waves via the terrestrial medium to a predetermined frequency.
29. CHEMICALLY ENHANCED ISOLATED CAPACITANCE
20180159339A1 June 7, 2018 application
transmitting energy conveyed in the form of a guided surface waveguide mode along the surface of a lossy conducting
medium such as, e.g., a terrestrial medium by exciting a guided surface waveguide probe. In one embodiment,
compensation is provided to elevate isolated capacitance of a terminal of the waveguide probe in the form of mounted charge devices.
30.ENHANCED GUIDED SURFACE WAVEGUIDE PROBE 20180151934 A1
May 31, 2018 application.
31.SUPERPOSITION OF GUIDED SURFACE WAVES ON LOSSY MEDIA 20180151933 A1 May 31, 2018
, Zenneck surface waves are launched along a surface of a lossy conducting medium using an array of guided
surface waveguide probes and a predefined field pattern of the Zenneck surface waves is maintained.
The individual ones of the guided surface waveguide probes include a feed network electrically coupled to a charge terminal.
The feed network provides a phase delay that matches a wave tilt angle associated with a complex
Brewster angle of incidence associated with the lossy conducting medium.
32.CHANGING GUIDED SURFACE WAVE TRANSMISSIONS TO FOLLOW LOAD CONDITIONS 20180145540 A1 May 24, 2018 application
guided surface waveguide transmit system includes a guided surface waveguide probe configured to transmit a
guided surface wave along a lossy conducting medium. The system further includes a controller device configured
to receive load status data and signal for the guided surface waveguide probe to adjust transmission of the guided
surface wave based at least in part on the load status
data.
33. RETURN COUPLED WIRELESS POWER TRANSMISSION 20180138753A1
May 17, 2018 application.
a system includes a guided surface waveguide probe including a charge terminal elevated at a height over a
lossy conducting medium, and a feed network. The system further includes a conductor coupled to the guided
surface waveguide probe that extends a distance away from the guided surface waveguide probe across the lossy
conducting medium, and at least one guided surface wave receivers coupled to the conductor. The a system includes
a guided surface waveguide probe including a charge terminal elevated at a height over a lossy conducting medium, and
a feed network. The system further includes a conductor coupled to the guided surface waveguide probe that extends a distance
away from the guided surface waveguide probe across the lossy conducting medium, and at least one guided surface wave receivers
coupled to the conductor. The conductor can help to provide additional efficiency in power transfer between the guided surface waveguide
probe and the guided surface wave receivers, especially when the operating frequency of the probe is in the medium, high, or very high frequency
ranges.conductor can help to provide additional efficiency in power transfer between the guided surface waveguide probe and the guided surface
wave receivers, especially when the operating frequency of the probe is in the medium, high, or very high frequency ranges.
34.WIRED AND WIRELESS POWER DISTRIBUTION COEXISTENCE 20180138720 A1 May 17, 2018
distribute power across various regions. Power from a power plant can be distributed to sub-transmission stations.
For example, a transmission probe can be configured to launch a transmission frequency guided surface wave
for power transmission over a transmission region. A sub-transmission station can receive the transmission
frequency guided surface wave. A sub-transmission probe can be configured to launch a sub-transmission
frequency guided surface wave to transmit power over a sub-transmission region to transmit power.
A distribution station can receive the power from the sub-transmission frequency guided surface wave. it is to shut down entire region including your cellphone
by Viziv.
35.Guided Surface Wave Transmission of Multiple Frequencies in a Lossy Media 20180138719 A1 May 17, 2018 application
various embodiments for transmitting energy at multiple frequencies via a guided surface wave along the surface of a lossy medium such as, e.g.,
36.SIMULTANEOUS MULTIFREQUENCY RECEIVE CIRCUITS 20180123343 A1 May 3, 2018 application
various receive circuits by which to receive a plurality of guided surface waves transmitted by a plurality of guided surface
waveguide probes over a surface of a terrestrial medium according to various
embodiments.
37.Field Strength Monitoring for Optimal Performance 20180106845 A1 April 19, 2018 application.
various embodiments for adjusting an operational parameter of a guided surface waveguide probe according to measurements
received from one or more measuring devices. A measuring device measures the conditions associated with an environment of the
measuring device. The measuring devices communicates the measured data to the guided surface waveguide probe.
Adjustments can be made to one or more operational parameters of the guided surface waveguide probe according to the measured data.
This is the way to limit you and request you to obey requests .( of the authority)
38.HYBRID GUIDED SURFACE WAVE COMMUNICATION 20180034502 A1 February 1, 2018
hybrid communication in which a first message from a guided surface wave probe
node is embedded in a guided surface wave, and a second message from a guided surface wave receive node
uses a different messaging mechanism.
39.MEASURING AND REPORTING POWER RECEIVED FROM GUIDED SURFACE WAVES 20180031619 A1 February 1, 2018
various approaches for measuring and reporting the amount of electrical power consumed by an electrical load
attached to a guided surface wave receive structure. A guided surface wave receive structure is configured to obtain electrical
energy from a guided surface wave traveling along a terrestrial medium. An electrical load is coupled to the guided surface wave receive
structure, the electrical load being experienced as a load at an excitation source coupled to a guided surface waveguide probe generating
the guided surface wave. An electric power meter coupled to the electrical load and configured to measure the electrical load.
Wesley
expression of may personal opinion only according, to US constitution.
http://jnaudin.free.fr/html/afep01.htm (http://jnaudin.free.fr/html/afep01.htm)
What they saw 1999 as success and why is this now 20 years " dormant" ?Somebody knows this guy named Stefan Hartmann ? ::)
Lanca..maybe ask him to comment [find the thread here somewhere and Ping it?
just a note ,our friend Ernst has written a book [I understand limited release] here
https://www.amazon.com/dp/1793151040
http://rexresearch.com/corumzenneck/US2017077715A1.pdf (http://rexresearch.com/corumzenneck/US2017077715A1.pdf)
Wesley
EMP-warshttp://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3706385&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en (http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3706385&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en)
EMP= Pc+ Pi
https://en.m.wikipedia.org/wiki/Black_hole_information_paradox (https://en.m.wikipedia.org/wiki/Black_hole_information_paradox)
https://en.m.wikipedia.org/wiki/White_hole (https://en.m.wikipedia.org/wiki/White_hole)
k.i. s.s. :-* keep ...... METHODIK
Many questions, kinetikal Stephen Hawking space related, and resolution trial :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Pavel+imris&IN=&CPC=&IC=&Submit=Search (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Pavel+imris&IN=&CPC=&IC=&Submit=Search)
https://ieeexplore.ieee.org/document/7139133/keywords#keywords (https://ieeexplore.ieee.org/document/7139133/keywords#keywords)
Wesley
#2
Lines expressed in vectors "A" shows polarization
of the ground field necessary for lunching surface wave known as Zenneck Wave.
This wave can carry on electrical energy to the receiver //anywhere in the world.
It may be used for internet , telephony,switching on of devices, geolocation similar to GPS.
Powering electric vehicles in motion and as punishment tool by government by restricting access
selectively to appliances and services.
e.g.
1. an individual who has refrigerator may have it disconnected for unpaid in time credit cart
2. electric cars may have battery allowing them to drive 1 mile and message in his vehicle \may tell them to stop at exit 123
or his car will be disconnected for driving violation that happened 5 minutes ago.
messing with ID code may be punished by law.
for reference:
US Patent 2017/0077715 A1 Authentication to enable/disable Guided wave receive equipment
James F. Corum
-expected to be implemented in ~5 years from now,.
Wesley
Legal note: this is expression of may personal opinion only according to constitution of
USA
#3
US2017077616 (A1) ― 2017-03-16
Wesley.
USA
#4.
methods of tuning structure from above:
Original document: US2017077616 (A1) ― 2017-03-16
Wesley
USA
#5
methods of tuning structure:
explanation of mirror image in the ground created by impedances above of the ground.
means of underground waveguide.
Normally Zenneck wave is in the interface between ground and air.
for more explanation please read original patent.
Wesley
USA
https://www.minotech.de/forschung/raumenergiekonverter/kapanadze-konverter/?mobile=1 (https://www.minotech.de/forschung/raumenergiekonverter/kapanadze-konverter/?mobile=1)
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.minotech.de%2Fforschung%2Fraumenergiekonverter%2Fkapanadze-konverter%2F%3Fmobile%3D1 (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.minotech.de%2Fforschung%2Fraumenergiekonverter%2Fkapanadze-konverter%2F%3Fmobile%3D1)
written: Tellus= Erd-Teller/Erd-Scheibe =Earth/Erde
" Erde" phon : aers'e~ Erz(Mineralgestein/mineral core/ earth rock like granit, but also ground )
vulgar: AErde ( soft "d" like th and hard " d" like t problem)
a. Erd(e)- b. Strahlung = a. earth/ telluric b. radiation or current
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FRadi%25C3%25A4sthesie (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FRadi%25C3%25A4sthesie)
(Manfred) Curry ( Diagonal) Gitter
(Ernst) Hartmann Gitter
"Tellurmeter": Radiation meter/measure instrument
https://www.minotech.de/forschung/technik-projekte/tellurmeter/ (https://www.minotech.de/forschung/technik-projekte/tellurmeter/)
http://www.norbertmoch.de/_physik_technik_kosmologie/nikola_tesla.htm (http://www.norbertmoch.de/_physik_technik_kosmologie/nikola_tesla.htm)
Tariel Kapanadze
2009: demonstration KapaGen with 100 KW , output Halogenlamps
QUESTION 1
"100 KW", pure or pulsed KWp ?
http://guns.connect.fi/innoplaza/energy/story/Kanarev/ (http://guns.connect.fi/innoplaza/energy/story/Kanarev/) about measuring :Pulse Power
15 KW power ~ average 144 W pulse power
http://jnaudin.free.fr/kapagen/ (http://jnaudin.free.fr/kapagen/)
2010 JLN experiments max. efficiency : 96%
QUESTION 2
" efficiency" definition like by a transformer measuring or efficiency like a "free energy converting" solarcell ?
Analysis by step-by-step
Stop for today
Sollen wir nun auch in Polnisch communizieren, Wesley/forest ?
I see no reason to think Kapanadze's device is related to 'Schumann Resonances', but
anything is possible I suppose. For those who are interested, here is some info on it:
https://www.nasa.gov/mission_pages/sunearth/news/gallery/schumann-resonance.html
"Schumann Resonance
At any given moment about 2,000 thunderstorms roll over Earth, producing some 50 flashes of lightning every second. Each lightning burst creates electromagnetic waves that begin to circle around Earth captured between Earth's surface and a boundary about 60 miles up. Some of the waves - if they have just the right wavelength - combine, increasing in strength, to create a repeating atmospheric heartbeat known as Schumann resonance. This resonance provides a useful tool to analyze Earth's weather, its electric environment, and to even help determine what types of atoms and molecules exist in Earth's atmosphere.
The waves created by lightning do not look like the up and down waves of the ocean, but they still oscillate with regions of greater energy and lesser energy. These waves remain trapped inside an atmospheric ceiling created by the lower edge of the "ionosphere" - a part of the atmosphere filled with charged particles, which begins about 60 miles up into the sky. In this case, the sweet spot for resonance requires the wave to be as long (or twice, three times as long, etc) as the circumference of Earth. This is an extremely low frequency wave that can be as low as 8 Hertz (Hz) - some one hundred thousand times lower than the lowest frequency radio waves used to send signals to your AM/FM radio. As this wave flows around Earth, it hits itself again at the perfect spot such that the crests and troughs are aligned. Voila, waves acting in resonance with each other to pump up the original signal.
While they'd been predicted in 1952, Schumann resonances were first measured reliably in the early 1960s. Since then, scientists have discovered that variations in the resonances correspond to changes in the seasons, solar activity, activity in Earth's magnetic environment, in water aerosols in the atmosphere, and other Earth-bound phenomena."
Graphs of Schumann resonance frequency power levels from magnetometers located at various locations around the world:
https://www.heartmath.org/gci/gcms/live-data/gcms-magnetometer/
"The Schumann Resonances Power graph summarizes the information presented in the Spectrogram Calendar and illustrates the dynamic changes occurring in the Schumann Resonances region of the magnetic field. Power is the sum of the power in all frequencies detected by the site magnetometer from 0.32 to 36 Hertz and is calculated for every hour. A 24-hour moving average of this power data is plotted for each site and updated hourly."
Magnetometer locations:
GCI001 California, USA GCI002 Hofuf, Saudi Arabia GCI003 Lithuania GCI004 Alberta, Canada GCI005 Northland, New Zealand GCI006 Hluhluwe, South Africa
And attached are a couple of drawings depicting Tesla's ideas on wireless power transmission
around the world, which were said to be drawn by Tesla himself in 1925 in a memo (I don't know if that is accurate).
Hi Wesley. I got those diagrams from this site:
https://teslauniverse.com/nikola-tesla/images/diagram-teslas-wireless-power-system
https://teslauniverse.com/nikola-tesla/images/tesla-small-scale-model-wireless-power-system-using-surface-earth-conductor
Wesley, have you seen this?
http://www.ic.gc.ca/opic-cipo/cpd/eng/patent/253765/summary.html?query=+253765&start=1&num=50&type=basic_search
Old patent to broadcast 500 kHz. signal on long antenna and receive more power back from earth.
Thanks for all your info and staying power. Don't let the trolls distract you.
Garry
Quote from: Void on January 07, 2019, 06:50:54 PM
https://teslauniverse.com/nikola-tesla/images/diagram-teslas-wireless-power-system (https://teslauniverse.com/nikola-tesla/images/diagram-teslas-wireless-power-system)
https://teslauniverse.com/nikola-tesla/images/tesla-small-scale-model-wireless-power-system-using-surface-earth-conductor (https://teslauniverse.com/nikola-tesla/images/tesla-small-scale-model-wireless-power-system-using-surface-earth-conductor)
This is what that old picture represent.
I did it because I was testing my new version of the program used before.
The interesting part of it is that part of inner foil ring connected to coil and capacitor is actively resonating making parallel resonance circuit.
But because rest of the same ring( the bigger part of it) is also connected to coil and capacitor than coil and capacitor is
acting as a bridge affecting balance between the two "halves".
This is definitely valid concept.
Wesley
Quote from: stivep on January 08, 2019, 12:40:27 AM
Wesley
Hi Wesley. Nice drawing. To me it looks like the outer ring is not connected to the inner ring,
but Tesla shows an electrostatic field linking the two rings. It is a very interesting setup, and quite large.
It is quite similar in some ways to what they call a magnetic loop antenna these days, but the magnetic loop
antenna doesn't have the outer ring.
All the best...
Quote from: Void on January 08, 2019, 01:22:00 AM
All the best...
there are many variations of a magnetic loop antenna. and yes also with 2 loops if you want so, and many others like made from coax with ore without matching transformer externnal ore transformation just made with 2 diffent loops sices .. depanding on the band you like to work.
How ever .. i postet some pages bevor a link about voltage and current distribution in such struktures .. well worth to spend a little thinking about.
best regards Jo
Quote from: jojo500 on January 08, 2019, 04:37:36 AM
Hi Jo, yes, I am familiar with the magnetic loop antenna. However, the Tesla drawing doesn't show a loop with
more than one turn, it shows the second larger outer loop not connected to the inner loop, but the inner loop
is almost as large as the outer loop. That is a little different. The drawing also indicates that the two ends of
the coil assembly are 'grounded', I believe, but they are attached to the inner loop, so not sure if that means the
inner loop is grounded or what is meant there.
#6
ONE OF ELEMENTS FOR UNDERSTANDING ENERGY EXTRACTION from Schumann waveguide AS WELL AS ENERGY TRANSMISSION IS
POLYPHASE book about Tesla.
http://www.gutenberg.org/ebooks/39272.epub.images?session_id=634b29fc2d9110f7c01fa58c1797857b4b3f2327 (http://www.gutenberg.org/ebooks/39272.epub.images?session_id=634b29fc2d9110f7c01fa58c1797857b4b3f2327)
click on CHAPTER IV.
Modifications and Expansions of the Tesla Polyphase Systems.
Although it talks about generators it gives you understanding what is polyphase.
part of this book that interests us is
QuoteThe Inventions, Researches and Writings of Nikola Tesla: With Special Reference to His Work in Polyphase Currents and High Potential Lighting
see drawing (below)
http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.3>=2 (http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.3>=2)
The distribution of electrical power by means of terrestrial cavity resonator modes
James F. Corum, Ph.D *
Associate Professor
Department of Electrical Engineering
West Virginia University
MORGANTOWN West Virginia 26506-6101
United States of America * now: Senior Research Scientist
Battelle Memorial Institute
505 King Avenue
COLUMBUS, Ohio 43201-2693
The reason that I brought this article to your attention is that in 80ties he took work listed at article right below
of:
High altitude Project Tesla transmitter, Leadville, Colorado
A quarter-wave coaxial cavity as a power processing plant
Mark Nash, James Smith, Robert Craven 339 Engineering Sciences Building
MORGANTOWN, West Virginia 26506
and implemented to his patent applications. By means of patent laws known knowledge can not be patented.
So as much as we may respect Mr.Corum he may lose his patent rights because of that the very fundamental part of his intellectual property.
Please read it and try to understand it
Picture #7
Resonance The phenomenon of the resonant rise on a transmission line, and in any cavity resonator, is physically due to coherent reflection of forward and backward
traveling waves occurring at critically spaced terminating surfaces.
The occurrence of standing waves, or stationary field distributions, is common to all
resonators and is indeed the mechanism by which energy storage and voltage, current and impedance transformation are realized in distributed circuits. The simple field distributions of most cavity resonators share great qualitative, and indeed some analytic similarities with the standing waves present on
transmission line resonators.
A thorough conceptual appreciation of the phenomenon of resonant rise may be obtained from consideration of a vector
diagram representation of the incident (E1) and reflected (E2) waves on a resonant length of line. Figure 2 shows the familiar sinusoidal voltage
distribution associated with the open circuited lossless resonant line and the resulting phases of the two waves at different points in the distribution (2).
Under lossless conditions the load reflection coefficient is unity with zero phase angle and the load impedance is infinite. As a result, the incident and
reflected waves have equal magnitudes at the load, and the reflection occurs such that the resulting phases of the two waves are also the same.
As the figure demonstrates, this phenomenon yields a terminal point voltage that is the arithmetic sum of the incident and reflected components.
Wesley
USA
#7
section #7
go down of the page till you see pictures from below.
along the bottom of the picture 7( original picture 2) you see sinewave.
This is how we start to create SW surface wave.
First we need vertically polarized wave in space between air and earth.
Figure 2. Vector Diagram representation of the incident and reflected voltage waveforms on resonant transmission lines (2)
The criteria for resonance is inherent in the spatial voltage distribution and requires the voltage maximum and minimum be separated by one quarter wavelength.
This means that regardless of the loading, the system must be, electrically, ninety degrees long.
This can be easily demonstrated with a Smith chart analysis of the capacitively loaded
resonator.
Wesley
USA
#8
Foreshortened Coaxial Resonator The example presented in this paper to illustrate the coaxial cavity resonator is a discharge device where the potential for discharge is built up in a spherical capacitor.
It is appropriate to show how this capacitive load will change the operating parameters at the resonator. Numerical values presented are appropriate for the demonstration model.
The material presented comes from published work (3) and is in part the result of mutual theoretical development conducted by the authors and
Dr. F. Corum on this research project. (Some of this material will also be found in the monograph "Vacuum Tube Tesla Coils" by James F. Corum and Kenneth L. Corum).
For the capacitivly loaded transmission line, the length at resonance will be less than a quarter wavelength long due to the change in the angle of the reflection coefficient at the load end.The result of this change
is that the line is not only physically shortened but that stationary >/4 sinusoidal field distribution is effectively shortened.
Figure 3 ( is the figure first on the top)
shows the comparison between the unloaded and loaded distributions.Lumped Equivalent Example Consider the resonator shown in Fig. 4 ( is the second from the top)with its equivalent transmission line model.
The capacitance of the sphere must be calculated and the load parameters evaluated.
Figure 4. The capacitively top loaded coaxial cavity and its equivalent transmission line circuit for Smith chart analysis. The capacitance to ground of an isolated sphere is given below and may be used as a reasonable approximation for the top loaded sphere. C sphere = 4 pe o r (m) ( 8) Where r(m) = radius in meters Thus C top = 5.65 pF
Wesley
USA
#9
RF Power Processing The first individual in the literature to realize that the RF resonant systems might be used to advantage in the processing (or transformation)
of large electrical energies for engineering applications was Nikola Tesla. He first developed the "distributed helical resonator" strictly as a means of generating high
voltages and the resulting spectacular discharges for which he is famous.
He completed extensive empirical testing and optimization of this structure during the late 1890's and proposed a variety of possible applications including wireless
transmission of power and the concept of directed energy weapons.
When examining Tesla's Colorado Springs Device as a model for a power processing system four basic processes can be observed.
The conversion of power from 60 Hz to RF; the transformation by pulse modulation to high peak power and variable duty factor;
the input coupling system; and the output couple to the load,
Figure 6. These block components may be implemented by standard RF
in a variety of ways depending on the magnitude of the powers to be processed and the desired efficiency.
The blocks comprising the resonator have been developed in the preceding sections and only the source considerations remain to be considered.
Tesla implemented pulse moderation via a special breakwheel.
As the break occurs and the spark is quenched
(Tesla used a magnetic field and forced-air to quench the spark quickly).
The high voltage transformer reactance is reintroduced across the primary
tank detuning it to lower the "Q pri" and reduce the impedance which is coupled into the secondary.
The secondary, which is now free of the loading of the ringing primary, now rings at its self resonant frequency (f sec) which is identical to that of the extra coil
where the voltage (V sec) is stepped by resonant rise (VSWR). The primary capacitance (C p) is recharged during the break interval.
This pulse is the manifestation of concentrated energy that can be pumped into the surface wave lunched in interface between earth and air.
Not only energy in uniform form can be transferred to that earth air interface but it can be used for :
military operations.
In place of incident, receiver may be placed and that receiver may convert that particular impulse to..........
However that is one of many options.
Collision of two or more conflicting surface waves exactly at 90 degrees in phase do not need anything but single piece
of conductive structure or conductive/dielectric sandwich , acting as receiver .
https://youtu.be/KLAPRNWuAn4?t=1187
That "may" be:
"piece of pipe or metal rod or structure that at given point start to resonate and acts like receiver in resonance.
By that any structure "able to respond" can be affected by changing frequency gradually up till critical point of resonance is reached.
It is unfortunate that
"any time" activated B -
can be build along any structure during their construction period and years later activated when needed.
Another application of SW is to "possibly" provide an active spying on anyone in any time and in any place right now today.
Despite of how reliable is speculation about Tesla involvement in so called
http://www.teslasociety.com/tunguska.htm (http://www.teslasociety.com/tunguska.htm)
was there is real application of surface wave in this area.
Wesley
USA
Hello Wesley , in small you have this concept as Tate Ambient Power Modul
and about RF conversion to electromotive force an old french invention, anno 1920 poste domini :
https://worldwide.espacenet.com/publicationDetails/description?CC=FR&NR=521330A&KC=A&FT=D&ND=3&date=19210709&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=FR&NR=521330A&KC=A&FT=D&ND=3&date=19210709&DB=EPODOC&locale=en_EP#)
Do not want to disturb
A good night wishing ( Venezuela? Okay, have a nice day)
OCWL
http://www.leedskalnin.com/CookElectroMagneticBattery.html (http://www.leedskalnin.com/CookElectroMagneticBattery.html)
https://en.m.wikipedia.org/wiki/Lecher_line
+ " knode " + Kirchhoff----------------------------------------------------
https://patents.justia.com/inventor/erich-bieramperl
http://www.sensortime.com/
Nikola Tesla used a high speed mercury switch to enable his impulse energy. This is subsequent to the magnetic and air quenched spark gaps.
http://www.freepatentsonline.com/0613735.pdf
#10.https://www.youtube.com/watch?v=7ATzLkr9JXk (https://www.youtube.com/watch?v=7ATzLkr9JXk)
https://youtu.be/ypMX2htnyWE?t=149 (https://youtu.be/ypMX2htnyWE?t=149) at the first minute of this video anomaly is reported.
but video opens from given time. So you need to back.
We need to notice that narrator is completely uneducated in surface wave and the only important in this video is his comment about Corum Bros.,
The rest of it is garbage.
Yet this is another way to explain phenomena of surface wave to fully understand what it is.
2. Wave localization in a random medium
at p-age 7.
Bragg scattering in a periodic medium
http://web.mit.edu/1.138j/www/material/chap-5.pdf (http://web.mit.edu/1.138j/www/material/chap-5.pdf)
In this paper both mechanical and electromagnetic phenomena obey the same principals.
Bragg resonance and Bragg scattering are the phenomena explaining creation of surface wave and surface wave interface response.
Used in military for surveillance.
In radars for pinpoint location of bigger than mechanical wave of the ocean objects.
Can/may be applied to flat paces in Arizona Texas spotting illegal emigrants.
So the similarity to Zenneck wave is that in patent pending literature both use the same referrals.
http://journals.tubitak.gov.tr/elektrik/issues/elk-10-18-3/elk-18-3-5-0912-331.pdf (http://journals.tubitak.gov.tr/elektrik/issues/elk-10-18-3/elk-18-3-5-0912-331.pdf)
Bragg resonance
QuoteYou can show that at one or several fixed frequency and fixed angle values you get a very strong reflection. That is Bragg resonance
One of applications of technology is to employ surface waves
to do "the same".
https://www.raytheon.com/capabilities/products/hfswr (https://www.raytheon.com/capabilities/products/hfswr)
http://web.mit.edu/redingtn/www/netadv/zenneck.html (http://web.mit.edu/redingtn/www/netadv/zenneck.html)
this is easy history of Zenneck surface wave.
Wesley
USA
#11
Frequency vs roughness of the terrain .
Wesley
USA
Sorry wesley thats all way over the fence and leads to nothing
in short https://www.youtube.com/watch?v=pglHXorTJlc
Good morning! I think Kapanadze type device can work only because all electric grid "earthing" is connected with water-earth. It is stealing from that line. For good stealing of electricity we need 1. Very good buried rod to the "see level"(where thick copper mesh is laying in the water). 2. We need "resonator" tuned to 50Hz in East and 60Hz in the West. Coil is "matrjoshka type" inside/outside combined bifilar/inductor type resonant Current amplification device. All tuned to Main Frequency. 3. We need "fake" second pole. It is grounded "volga" type buried in the ground car radiator in Kapanadze video. 4. All system work in the principles of 50Hz Magnetic Field to Current type Amplification device which Magnify Magnetic field which is presented in the Water surfaces of the World. Spark/Inductor is Key to Success. Without Spark we can't realise that. 20 meters of wire is for pole's creation. In fact it is Amplifiere. Be happy!
Quote from: Ansis on January 09, 2019, 03:26:46 AM
A simple Tesla coil refutes your answer.
You guess if you know ? because you write that you guess.
There is no Free Energy. You must understand that. But, there is 50/60Hz Magnetic Field across the World. That's it! And yes, that what I am wright here is mine opinion. I discussed that in Skype conference/chat room. I think about Kapanadze device about 15 years from now. It is what I see. You can see it different. It is your World!
Please provide a schematic of your idea.
.Hoppy If you think about it there must be FREE energy to gain with scalar waves because of the way Tesla says it works
and what Tesla says is what Wesly showed in the Rusky guy Andrey Pastukhpv showed in the original video with his LED's as the wave travels it ionizes charge carriers
thus amplifying the original that was transmitted it's in that video ! everything else is out of reach.
You must have also seen those people who use smoke to send out smoke rings ! is it a wave or a punch?
Joke isn't a good I'd dear, an old lady with 20/20 vision? keep eating the carrots. ;D ;D
Quote from: Ansis on January 09, 2019, 03:49:23 AM
If I put a 10m rod into the ground, will I see the 50Hz phase there? It depends on where this rod will be.
Near the high-voltage pole (transformer), the resistive meter shows a value of 0.5A.
Kapanadze claimed that he did not need grounding. The device can even be in the car. Grounding is needed for two-phase systems.
I think to do what you say I would need:
1. Grounding
2. Phase 50 Hz
3. Large KV potential with 50Hz phase
4. modulation and output coils
A Kapanadze device came out to us.
Did the people from Turkey 100Kw understand that their meters are standing still but the power plant sees a drop in power? that is the question !
Answer is in the "water pipe". You guys remember how Kapanadze and Gia drink and touch "water pipe" and tell - There is nothing!!!!! Lie's! For Amplitude Current we know about "nature of the AC". It have Minimum and Maximum. In One wire, there is 2 states of "nature" of AC Current. Why it is not killing us? Because of separation between Electro Magnetism and "condactivity"... Water have EM nature, but 1 single wire cant produce Current! That is it!
It is from my chat in Skype. It is for educational purpocess only.
Quote from: Ansis on January 09, 2019, 06:30:29 AM
To be sure, you need to build such a layout, otherwise it's just guesses.
Hi Wesley,
Using nature to demystify science eg:longitudinal waveform(Tesla HV interrupted pulse)-
I have attached waveform from a Electric Eel in order to correlate longitudinal waveform occurring in nature eg:Earthquake.This is also one of the least studied waveform.
Electric eel uses "interrupted HV pulse" to shock it's prey in water a lossy medium.Earth is also a lossy medium.
Merely using nature to present facts.Tesla was one of the first to implement interrupted pulse for his Tesla coil project.
This is to justify -Interrupted pulse is indeed creating/emulating longitudinal waveform.
http://www.noisescanner.com/ (http://www.noisescanner.com/) or google ( or other search machines) : nearfield holography
https://www.google.com/search?q=nearfield+holography&ie=utf-8&oe=utf-8&client=firefox-b
sound camera http://decibel-or.bruit.fr/ (http://decibel-or.bruit.fr/) d(ezi) B(el)/dB - Technology
Tesla coil described as distributed transmission line circuit model by Corum Bros
http://www.tuks.nl/pdf/Reference_Material/Corum/Corum-Tesla_Coils_and_the_Failure_of_Lumped-Element_Circuit_Theory.pdf
#11.
There is no other way but first understand what you dealing with and how it works and than, you can play with it, make money on it, or even damage someone else business with it.
Surface wave in general can have many forms.
( like humans white, black, yellow /// and they have their specific to each of the groups general behavior)
Some special conditions of surface wave are: modes like TE - Transverse electric , TM - transverse magnetic.
1. Electromagnetic waves are transverse.
2. Longitudinal wave has nothing to do with electromagnetic transverse wave, but can be in form of mechanical transverse wave.
By that we can use mechanical wave behavior to explain, the very same mechanisms in quantum physics.
So in surface wave it helps for these who wants to understand quantum phenomena if we use classical physics as an example.
Mechanical wave behavior of surface wave.
https://www.youtube.com/watch?v=CNbwCUA6VVs (https://www.youtube.com/watch?v=CNbwCUA6VVs)
https://www.youtube.com/watch?v=g3cTFrHqjv8 (https://www.youtube.com/watch?v=g3cTFrHqjv8)
https://www.youtube.com/watch?v=oFhMrwQHvFo (https://www.youtube.com/watch?v=oFhMrwQHvFo)
Because Propagation of Seismic Waves: Rayleigh waves is mentioned in Corum bros patents I attached simulation:
https://www.youtube.com/watch?v=6yXgfYHAS7c (https://www.youtube.com/watch?v=6yXgfYHAS7c)
Wesley
USA
Who is Texzon :
https://www.electricchoice.com/blog/timeline-history-energy-deregulation/ (https://www.electricchoice.com/blog/timeline-history-energy-deregulation/)
https://www.youtube.com/watch?v=4T-QYv-zlrQ (https://www.youtube.com/watch?v=4T-QYv-zlrQ)
So talking about Viziv we rather should talk about Texzon
https://www.youtube.com/channel/UC4u_8s0uT1luS6Sgm1DBtjQ (https://www.youtube.com/channel/UC4u_8s0uT1luS6Sgm1DBtjQ)
Wesley
Quote from: r2fpl on January 09, 2019, 07:14:03 AM
Single wire can't produce current? What natural law is that?
Quote from: Belfior on January 09, 2019, 09:57:13 AM
Think again.
Quote from: r2fpl on January 09, 2019, 10:11:39 AM
Think again.
Well I have seen a lamp lit on the end of a single wire. You can give me all the explanations about surface waves and what not, but there must be current going through the lamp
So reality is that the lamp lights up. how can you make that disappear with an equation and second law of thermodynamics?
Quote from: Belfior on January 09, 2019, 11:14:46 AM
a. wireless by RF ? b. https://en.m.wikipedia.org/wiki/Vortex_tube (https://en.m.wikipedia.org/wiki/Vortex_tube) similar "Resonator -tube " electrostatic process?
A coil view a. by eyes 1:1, by 1:10, 1:100,1:1000, .........micro-scale scopic view : change?
particle/ coil inner structure( holes,channels) ,
particle de-/ formation 3d- volume( not quantity !)/ velocity/ mass- relativity
Quote from: lancaIV on January 09, 2019, 06:40:12 AM
http://jnaudin.free.fr/html/fep01.htm (http://jnaudin.free.fr/html/fep01.htm)
"MUST BE POWERED BY A BATTERY SOURCE"
Wesley
Re a patent and American Laws ,giving a true FE device [in writing]to a Patent office .Like handing a man a stick to beat you with ,and showing him where it hurts the most [instructions]
Just one mans opinion about the Patent Trap and most countries national security clauses .
they would rather we fiddle while Rome Burns...
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=2008103130A1&KC=A1&FT=D&ND=&date=20080828&DB=&locale=#
" ....... has to receive energy from a power supply constantly. "
Other " Kapanadze":
https://worldwide.espacenet.com/publicationDetails/biblio?CC=WO&NR=2008103129A1&KC=A1&FT=D#
wmbr
OCWL
https://en.m.wikipedia.org/wiki/TRIZ (https://en.m.wikipedia.org/wiki/TRIZ). only 35 parameters, fine !
the "displacement money" producing real/ fictive value share-machinery :example between " skyrocking/ six-feet-under" dreams
https://www.greentechmedia.com/articles/read/aquion-the-bill-gates-and-kleiner-perkins-funded-advanced-battery-startup#gs.8M40819v (https://www.greentechmedia.com/articles/read/aquion-the-bill-gates-and-kleiner-perkins-funded-advanced-battery-startup#gs.8M40819v)
Skyrocking investments : 190 Mio.
https://www.greentechmedia.com/articles/read/bankrupt-aquions-salt-water-battery-assets-sold-to-austrias-bluesky-energ (https://www.greentechmedia.com/articles/read/bankrupt-aquions-salt-water-battery-assets-sold-to-austrias-bluesky-energ)
Groundrocking R. O. I. : 2,8 Mio.
WIPO : the " fictive" granted patent economic value evaluation ( patent court base for law suits)
Nice "fairness"-system today : you have juridical the right, anybody infriges your right, you want satisfaction from the yury but you have to bring the " estimated infringment value" as " law suit deposit" !
Judgement-Poker, that is it ! F.e. : the Apple / Motorola-Qualcom-Samsung-...... infringment processes
ALONE against the " Grand Yury" and their " deposit demand" !
Many U.S.-Patent-Office granted patent applications are withdrawn by the European Patent Office !
Time to think about the " system quality" !
Assets real value, assets by credit for " house investments by credit" ?
Estate finance system based by credit : by how many lever-stages totally ?
actually : 37 "soft money units" ~ " 1 hard money unit"
Lohn-Preis-Kredit-Spirale-up/ down : 0,3/0,3/0,3
If what you have drawn is right, there is no possibility of transferring power even over a meter because the capacitance shunting effect manifests as a AC short at high frequencies. Unfortunately, this goes against the conventional ground radio theory which has already been well written in text book.
Quote from: F6FLT on January 10, 2019, 01:16:32 PM
Now I think about, what process is similar to the Kapanadze generator. I know. It is feedback of Microphone and Speakers. You know that. We have 3 parts. 1. Microphone 2. Power Amplifiere 3. Speakers We must create feedback loop between these 2 parts and we get excitation. Maybe that is not correct word, I am not English man. But you know. We Amplifiere that what is inside "water pipe" and when we get effect we start to extract energy.
Quote from: Ansis on January 11, 2019, 07:51:08 AM
It's only part of the system.
The device does not need grounding form low fq. Grounding is only for HV with Hi Fq.
The secret is in the construction of the "coil" and the result that we get at the output. This is the same effect as in Don Smith.
The phase is needed only at the start of the device and it is obvious when we know what effect it has. Wesley showed it but no one understands the meaning because every now and then he shows new ones.
This is not about coils! this is about understanding only one enhancement effect by working.
What is being amplified inside the water pipe? It may be more effective to provide a schematic of what you are trying to describe / put over to us. I am interested to understand more about your theory but with respect, as you suggest, there is a communication problem.
Now I think about, what process is similar to the Kapanadze generator. I know. It is feedback of Microphone and Speakers. You know that. We have 3 parts. 1. Microphone 2. Power Amplifiere 3. Speakers We must create feedback loop between these 2 parts and we get excitation. Maybe that is not correct word, I am not English man. But you know. We Amplifiere that what is inside "water pipe" and when we get the effect we start to extract energy.
Ansis do you mean positive feedback? PS not sure I am (united nations) me ;D when I was a kid in Gmunden leather lederhosen but the kids here
were real nasty now they are old and still the same! :-\ anyway Wilhelm Reich, was Viktor Schauberger not so much the hero there.
OK. What I have? I have original? Kapanadze drawing.
My theory is based on Tesla and Classic Physics and of course I am more like a Forensic Investigator.
Take picture.
Quote from: Ansis on January 11, 2019, 11:03:04 AM
Take picture.
To which version do you want to match it?
I love true. I think about that trick of Kapanadze.
All these 15 years peoples think about that too.
I take video's, take all possibilities, take all theories and try to investigate everything.
What we know?
1. Device is not working without "water pipe".
2. Water pipe is connected with grid through "earthing".
3. Non of the coils can create FE.
4. Spark alone is useless.
5. Spark on the Inductor makes/create Energy(Magnetic Field) amplification.
6. 0×1=0
7. 1×1=1
8. No free lunch.
OK. Take second picture.
It is not final or something real, but it is something what we can draw after picture 1, original? Kapanadze drawing.
Understand: this is not about the schema, just about the principle. After these years of searching, it should be clear to everyone why they can not do it.
Don Smith showed the principle and 100% of the device, but he never said anything to make it work.
Example: you have to make a cake; you know all the ingredients because you see them, you know the proportions, you know the temperature, so why do not you go ?! maybe you're using bad ingredients.
Ansis, much easier :
https://overunity.com/17279/split-flux-transformer/msg529903/#new (https://overunity.com/17279/split-flux-transformer/msg529903/#new)
Magluvin prototype !
transversal and longitudinal waves in one MEG !
Inductor : ( Volt - Ampere winding turns coils) x Inductee : Ampere-"turns" = impuls/-es/ oscillation/-s
Artificial " Tornado "-seeding and earning ; explanation : Biot-Savart Law
and Lord Kelvins Spring/Condensator-Analogon
https://www.britannica.com/biography/William-Thomson-Baron-Kelvin (https://www.britannica.com/biography/William-Thomson-Baron-Kelvin)
Melvin Prueitt : M.E.C.H , Motor-Engine-Compressor-Hydraulic in one
to M.E.C.A.E. , Magneto-Electric Compressed Air Engine ( Ion-Wind-pressure)
Idea is Tone Fork 440Hz.
We make kick and Fork start to resonate.
More kicks, lauder sound.
Thicker Inductor, more Amplification.
Fork=50Hz resonator, Kick=Spark.
http://www.audio-perfection.com/spice-ltspice/distortion-measurements-with-ltspice.html (http://www.audio-perfection.com/spice-ltspice/distortion-measurements-with-ltspice.html)
https://en.m.wikipedia.org/wiki/Total_harmonic_distortion (https://en.m.wikipedia.org/wiki/Total_harmonic_distortion)
Symphony meets PUNK, and PUNK IS KRANK ( ~ ill )!
https://m.youtube.com/watch?v=sgpa7wEAz7I (https://m.youtube.com/watch?v=sgpa7wEAz7I)
Short "Silence-MOMENTS" by kindly " ART OF NOISE" : https://m.youtube.com/watch?v=ux3u31SAeEM (https://m.youtube.com/watch?v=ux3u31SAeEM)
Differ : der Moment and das Moment, German: poly-phrase, take time to reach the " right tone "
Harmony-teach : https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FPythagoras (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FPythagoras)
Inside part of Coil=Resonator must be?
It must be material which "answer" to the kick.
It means Kick - Answer(50Hz Magnetic pulse) e.t.c.
This process must be without saturation, like in Tube Single Ended transformers.
Transformers where is paper between E and I steel plates.
If you remember, 50Hz humm is what we hear when Kapanadze turn ON his device.
"paper" : Diluol tranked cellulosic/plastificated material
http://chemico.com.mx/productos/diluol-xz/ (http://chemico.com.mx/productos/diluol-xz/)
https://news.rpi.edu/luwakkey/2280 (https://news.rpi.edu/luwakkey/2280)
"Hostalen/Hostaflon" ...... electro-static. http://www.matweb.com/search/GetMatlsByTradename.aspx?navletter=h&tn=Hostalen (http://www.matweb.com/search/GetMatlsByTradename.aspx?navletter=h&tn=Hostalen)
https://en.m.wikipedia.org/wiki/Cellophane (https://en.m.wikipedia.org/wiki/Cellophane)
Ever try to stay under-saturation ( + environment influence controle )
A "Diskothek" in full function : closed door/ door opening? Loudness/acoustics" Pegel" inside and outside, before/ after
Radio in kitchen : closed/ open refrigerator door?
The Biot -Savart law : the second : https://en.m.wikipedia.org/wiki/F%C3%A9lix_Savart
And of course it is not LC resonance, because LC resonance = High Impedance or Z.
We search ELECTRO MECHANICAL type of resonator.
It must SOUND!
It is not Coil + Capacitor like we think in Radio electronic circuits.
It is not.
ION WIND ~ Sound
+ a kind of Morse-Alpabet~ winded reverse f. e. South-Italia " Tarantella"( Tarantula, Spinne)
SPIN -Kind : Information -language translation
We can https://m.youtube.com/watch?v=0QDKLglEP5Y (https://m.youtube.com/watch?v=0QDKLglEP5Y) the ACT,
but do we understand the (e)MISSION INSIDE
When are YOU loud? THE BEST and the WORST MOMENT translated
Body/ material " ache"/ stress
It can be Supermalloy pipe, cut in the style of flute...
How to make it?
Take violine bow (fiddlestick) put it in the Sound Fork type of standing and start to "play".
Record your frequency, adjust if needed. But,it is not so easy. This bar must be
part of Coil. It is tricky....
Interesting type of resonators.
Cut ring resonators (split ring).
Make search in the Internet.
What is interesting?
It is very similar what we see in Kapanadze original?.
There is Ferrite Rings?
Maybe split rings?
Maybe not ferrite?
This is investigation, guys.
There is no icecream which we can take and eat... (Ready to use schematic with all parameters for China Manufacturers).
Chinese mass production ?
Ram-Widder-Pump
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Toribio+bellocq&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Toribio+bellocq&IN=&CPC=&IC=)
Toribio Bellocq. : water flow. / AC current-flow
to
https://www.google.com/search?q=rexresearch+all+electric&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=rexresearch+all+electric&ie=utf-8&oe=utf-8&client=firefox-b)
Valentin Kutienkov and Viatcheslav Marukhin
for some easier :
http://rexresearch.com/Kutienkov/kutienkov.htm (http://rexresearch.com/Kutienkov/kutienkov.htm)
Inside information to correct : not 10€/KW but 100€/KW
Es Ist immer gut ueber viele Asse, im Aermel und Anderswo, zu verfuegen! 8)
Tschau
Quote from: Ansis on January 12, 2019, 07:52:59 AM
Yes. China friends will make coppies.
It is not bad, but if we will make schematic of Kapanadze and it will be stealing from grid?
Just think, what will be?
There will be catastrophe.
All pipes will rust in 1 year!
Think about it.
You live in 10 000 people area. Every 100 of them will buy EnergeticAmplifiere of Kapanadze, screw it to water pipes and after some time all metal pipes will go dead...
And everyone who will own that type of FE go to jail, because of sabotage.
The only place where it can work without harm is in the private property with private "earthing".
Well! if it was true perhaps someone has one like that, I don't know to be honest and it wouldn't be free energy would'it!
Anyway, it's a bit hypothetical as Wesley was saying he had been in that garage and it was a good distance from any power so
that's not really the case here is it and I for one wouldn't buy into shit like that.
Anyway in saying that most electric companies are Crookes these days as if you listen to
Eric Dollard, he says they can make energy from balancing L and C and it's high time that crap was stopped
and that they let us all have had a stake in their technology windfall.
There is a change whose some has not remarked : physics chemistry and elementary physics
matter specification and the reziprok : anti-matter
https://en.m.wikipedia.org/wiki/Isotropy (https://en.m.wikipedia.org/wiki/Isotropy) and anisotropy
https://en.m.wikipedia.org/wiki/Topology (https://en.m.wikipedia.org/wiki/Topology)
https://en.m.wikipedia.org/wiki/Metamaterial (https://en.m.wikipedia.org/wiki/Metamaterial)
Metachemistry, an-/ organic
You say : "Right! " and I say : " Left or right! "
THE VARIANCE WILL STAY
Quote from: Ansis on January 12, 2019, 03:11:09 AM
We create 2 poles.
1 pole is "water pipe", second is car radiator (GreenBox video).
There is no evidence from the videos that Tariel used two grounded poles connected to the device at any point in time. This point has already been discussed way back in this thread.
Quote from: lancaIV on January 12, 2019, 08:30:47 AM
Aliens don't use Antimatter whoever she is, in the interview with the J rod he talks about Zero matter.
Hoppy I a know nothing of anyone using 2 earth con-rods! Talking in Russian is no longer any big deal TK show or talk
of 2 earths is where to reference also in Weslys video Wesley says a second phase can be constructed from using a cap Realy well try it!
In reality with ac and resistive inductance current will lag voltage, all you can do is use a cap to make the RL appear as a resister
that won't alter a phase shift in a single phase supply.
Probably for some of interest, E.L.F.-spectrum related :
https://en.m.wikipedia.org/wiki/Nicholas_Christofilos (https://en.m.wikipedia.org/wiki/Nicholas_Christofilos)
Nice Sunday wishing
OCWL
p.s.: Frequency-Pulse or EMP = EMPi+ EMPc
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Nicholas+christofilos&CPC=&IC=
Quote from: Jeg on January 13, 2019, 07:00:43 AM
Indeed there is something in to it which needs further analysis, and so i couldn't let the above statement floating like that. It would be iresponsible from my side. Sorry guys.
Phase shift by itself is nothing out of the ordinary. But in some cases it can be used in to our advantage. Like for example when we mix current and voltage together. (see fireballs).
Hi Jeg,
Fyi only.
Someone posted some external link in this topic few days/week back upon reading one of the article reveal about
phase shift which matches what Akula would put in his circuit diagram for certain device.
There is 2 devices of his with this symbol as attached which match the external link posted by someone.
Nothing much or is it.
Quote from: magpwr on January 13, 2019, 09:47:52 AM
Hi Jeg,
Fyi only.
Someone posted some external link in this topic few days/week back upon reading one of the article reveal about phase shift which matches what Akula would put in his circuit diagram for certain device.There is 2 devices of his with this symbol as attached which match the external link posted by someone.
Thanks Magpwr. I remember at Ruslan's replication attempts, that the three turns coil (yoke core) was altered by 90 degrees in relation with the 28 turns output. This was because the 3 turns where in series with a cap inside the current loop, resonating. So this phase shift exists in the operation of Ruslan device. But it needs something more... obviously.
https://www.youtube.com/watch?v=wMePf2vec_c (https://www.youtube.com/watch?v=wMePf2vec_c)
https://youtu.be/KLAPRNWuAn4?t=248 (https://youtu.be/KLAPRNWuAn4?t=248)
https://youtu.be/KLAPRNWuAn4?t=1220 (https://youtu.be/KLAPRNWuAn4?t=1220)
Wesley
https://www.youtube.com/watch?v=vmW7h5YgZL8
How to get electric field from electric potential. in relation to spherical capacitor of Tesla HV coil.
Wesley
Hi Wesley. LEDs/LED bulbs will light any time they have a suitable amount of
potential difference across their terminals (anode/cathode) which can supply the
relatively small amount of current they need to light up. When you place the end of a LED bulb
on an at least a somewhat conductive surface which is in a strong HV electric field,
and touch the other terminal of the LED bulb with your finger, your body is acting as a
virtual ground at a much lower voltage potential to complete the circuit. Without knowing the
input power to the voltage source(s) you were using to create the HV electric field, I think it is not really
possible for anyone to judge whether there was anything out of the ordinary going on there
in your demonstration or not.
I tested with this a little today with just a flyback transformer driver at about 4.5W input power to the
flyback driver and it could light a small led bulb, although not very bright, when I put the end of the
LED bulb into a small bowl of commercial filtered water (DC resistance measured 8 to 11 megaOhms),
and touched the other terminal with my fingers. The bowl was placed close to a capacitive 'top load'
connected to the HV terminal of the flyback driver. The LED bulb I was using didn't light very brightly at that
low 4.5W input power level however. That might be due to the circuitry that is in the bulb reducing the
current flow to the LED bulb with the low input power level to the flyback driver not being enough to overcome that.
What total power input were you using when you lit the LED bulb? So, you think that the phase shift when
using the 'charge line' makes a big difference in performance? Were you monitoring the input power difference on
your high voltage source(s) comparing when the LED bulb was not lit compared to when it was lit?
Quote from: Ansis on January 12, 2019, 04:10:08 AM
https://books.google.pt/books?id=FzbBK6m8qxEC&pg=PA98&lpg=PA98&dq=parametric+generator+papalexi&source=bl&ots=DAhHCWmxUk&sig=5vw-mY_uWBFGvdXUXmvC5WdmOMM&hl=de&sa=X&ved=0ahUKEwjD8anI3uzfAhWNgM4BHdnXC7UQ6AEIETAD#v=onepage&q=parametric%20generator%20papalexi&f=false (https://books.google.pt/books?id=FzbBK6m8qxEC&pg=PA98&lpg=PA98&dq=parametric+generator+papalexi&source=bl&ots=DAhHCWmxUk&sig=5vw-mY_uWBFGvdXUXmvC5WdmOMM&hl=de&sa=X&ved=0ahUKEwjD8anI3uzfAhWNgM4BHdnXC7UQ6AEIETAD#v=onepage&q=parametric%20generator%20papalexi&f=false)
videre : Video. audire : Audio signare( written, spoken ?) : Signal (~ physics: pulse )
https://en.m.wikipedia.org/wiki/Undertone_series (https://en.m.wikipedia.org/wiki/Undertone_series)
https://en.m.wikipedia.org/wiki/Subharmonic_function (https://en.m.wikipedia.org/wiki/Subharmonic_function)
https://pages.mtu.edu/~suits/overtone.html (https://pages.mtu.edu/~suits/overtone.html)
La-la-la-la-la-la-la : tone scale ? harp strings, claviatur strings / "synthetic strings" : syntheziser/ keyboard
eV, nm ! : dB ?
Sub-harmonic resonance to super-harmonic resonance. : total resonance bandgap and bandwidth
Color : Klangfarbe "Dreiklangdimension". https://de.m.wikipedia.org/wiki/Klangfarbe (https://de.m.wikipedia.org/wiki/Klangfarbe)
VIDEO-/AUDIO-SIGNAL : TEMPERAMENT/TIMBRE
https://m.youtube.com/watch?v=N9dsjcTzHoM (https://m.youtube.com/watch?v=N9dsjcTzHoM)
" ..... Lichtspielimpressionen, so farbvoll ...... "
A-/ Symetrie. ( or Dis-) Symetrie
A-/ Synchron. ( or Dis-) Synchron
A-/ Harmonic ( or Dis-) Harmonic
Is an Orchestra in its dynamics " dictatur" or " democracy"
The Dirigent : Dictator or Demokrat ?
How to become the right democratic Dirigent from the "E.M.L.O",
Electro-Magnetic Light Orchestra, Light-Cinema
Look I'm no professor on this (cabbage) whatever that is ;D but yonks back Akula started some experiment with a 555 and a cd4017 and a pile of diodes
and a 4 phase toroidal winding, does anyone remember that one The commentator talks about connecting with the earth's magnetic Force while trying to push it along the table (here we go round the mulberry bush) ;D Akula started showing it and then 'bang' gone, nothing!
now Wesley is into 90 deg phase shift.
Also, does anyone know what a photon generator is it takes in seawater produces ENERGY many times OU and then chucks the sea water back out or round again (re Revers the Grid campaign? published by free energy party on Facebook look up Dave Parker if interested not me.
Also there is this https://www.youtube.com/watch?v=70_xKJh91eE READ his notes !!!!!
Quote from: Void on January 13, 2019, 11:17:57 PM
I did not touch any other terminal of the lightbulb as you see on the pictures
Wesley
Quote from: Hoppy on January 14, 2019, 04:35:26 AM
:( C'mon Wesley, stop playing tricks and put all your cards on the table.
At first it is possible. Needs to be little warmer. And I really do not want to show this lab from outside.
As I said, I created surface wave on the interface.
Interface is the space between two different lossy mediums ,
where one of it is dielectric and the other is air.
And because I was still in in Near Field that is why I had sparks in my mouth.
I have had no horizontal space to be outside and do the same. Too cold.
However at parking lot approx 1120m (1.120km) away . I was still getting strong reading.
No I did not try light bulb there. I have XYZ isotropic field meter with XYZ probe connected by fieberoptics so it eliminates any parasitic influence on the probe and processing unit.
that was reading not XYZ space.
But earth air interface.. with some form of resonant transformer just placed on the surface of it.
Wesley
Quote from: stivep on January 14, 2019, 08:51:51 AM
Wesley
Even if you are not touching the other terminal of the light bulb directly, your hand holding the bulb glass capacitively
couples to the other terminal on the bulb. If the electric field is strong enough, that will be enough, especially at higher frequencies.
The fact that you have ignored the question a few times about what input power levels you are using to light the bulb is not
good at all Wesley. The electric field must be very strong to have caused sparking in your mouth,
so presumably you are using a relatively high amount of input power to create the HV electric field.
Quote from: F6FLT on January 14, 2019, 10:28:14 AM
I agree with you. Wesley plays with classical electromagnetism, highlights classical phenomena, and tries to bluff us by lying by omission: unknown transmission power, unknown received power, unknown distance between light and antenna, unknown antenna type, capacitive coupling never mentioned....
I too played at remotely turning on lights (only 10W RF for this one (http://exvacuo.free.fr/div/Sciences/Exp%C3%A9riences/Em/Induction/Lampe%20Ensemble.jpg)). When you know the domain, you can see his tricks. He would like us to believe in brilliant discoveries when there is nothing, perhaps he deludes himself out of ignorance or wants to parade. Our objections are ignored, and the thread is continued with irrelevant comments, and with links to academic science that we never see him to rigorously apply to what he is talking about. This thread has become a joke.
Instead of faffing about around the bush trying to display some kind of guilt trip to the other party, why don't you ask the other party if they are interested I a nondisclosure contract, or if they are interested in any other way, instead of just winding them up?
No offence but then everyone might get what they want.
Quote from: stivep on January 14, 2019, 11:12:15 AM
Everything in it's time frame
Nothing brilliant just physics
Read my previous post again
You may have noticed that there was no metal structure near by. I was touching antistatic board specially made to prevent electrostatic discharge
and damage of sensitive electronic components.
So please show me anyone who presented such experiment in youtube with 120W equivalent of incadescent lighbulb.
-that was maximum I have tried ever with this setup till now
Wesley
Hi Wesley, as already mentioned, without at least indicating the total input power applied,
your demonstrations of lighting a LED bulb does not tell anyone anything at all. I have explained why.
Read my previous posts again. See the attached picture where I show the origin of this type of secret free energy technology.
I can't reveal any more details beyond what I have indicated on this picture of Tesla, as I
am planning on patenting this technology so people don't try to steal my IP. Once I have
patented this, I may reveal more details if enough people suitably grovel at my feet. ;)
All the best...
And yes, Fabrice Andre use 220W from grid!!!
Kapanadze use Power from Grid in Turkey experiment!!!
Kapanadzes device is Amplifiere!!!
There is no FE.
GreenBox video last only some minutes and after listening of "tapes" I know about that!
Quote from: Ansis on January 14, 2019, 01:20:21 PM
To lancaIV.Re : to Ansis
You are supermega troll of overunity.com!
Who makes me an offer to built a COP=1 and doing a grid connection is for me not a troll but in simple words a.
an equipment seller b. a maths idiot
Your jazz is funny!
I am not doing jazz but listen to jazz-playrrs and play their music or vids
You are a Clown! Life is funny, CHARLY, n'est ce pas?
You are like a bomb in the ass! For anybody a foot is enough
Here is the End.I hope not that you are planning your sudden final :'(
Music!
Music-box A https://m.youtube.com/watch?v=r1OnVxfy6iM (https://m.youtube.com/watch?v=r1OnVxfy6iM).
to Z. https://m.youtube.com/watch?v=66zUY8UZn4M (https://m.youtube.com/watch?v=66zUY8UZn4M)
wmbr OCWL
F.Y.I.
Interesting and helpful REAL LIFE examples of the use of modern Computer Aided
Engineering (CAE) to find the answers and solve the mysteries of excess energy generation.
Example #1.
https://www.youtube.com/watch?v=rCC8mY7ykM4
Intro/Overview: "Watch to the end if you want to understand! Installation Principle
Ruslan Kulabukhov 2019, Tariel Kapanadze, Stephen Mark, Akula083 Calculator
http: //cxem.net/software/download/cal ... Single Phase Current Push System
https://vk.com/doc442363570_487639626 Two Phase Current Push System
https: //vk.com/doc442363570_488467031 Two Phase Current Push System for Meier
Cell https://vk.com/doc442363570_489097188"
Example #2 (today).
Another proof that modern Computer Aided Engineering (CAE) software tools can/will
definitely assist in FE research.
https://overunity.com/15154/selfrunning-free-energy-permanent-magnet-motor-the-simon-magnet-motor-motor/msg530048/#msg530048
From Simon to Hartiberlin [Stephan posting]: Quote, in part:
"Now, after having perfected my understanding of how to rightly use ANSYS Maxwell,
I simulated the two modified versions that he built; the software confirmed the behaviour
of the prototypes.The software confirmed the extremely high cogging torque and the
extremely short deceleration time.
Here's the sweet part. The software revealed that for the prototype to work, the rotor
magnets should be reduced to either 40, or 30, or 20, or 10, etc. (Note, his prototype
has 50 rotor magnets.) The software also revealed that the net forward and net back
magnetomotive forces(mmfs) of the prototype are heavily dependent on the airgap
lengths between the rotor magnets."
It's for sure happening; as hoped and expressed - yay!:
Using modern Computer Aided Engineering to solve the Excess Energy (Free Energy)
mystery; as promoted and predicted here in this "SAEC Project paper presented in the
forums December 29, 2018:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529052/#msg529052
ALTERNATE ENERGY DEVELOPMENT - TIME FOR A PARADYNE CHANGE
Quote, in part:
"Recent capabilities in the areas of worldwide networking and Computer Aided Engineering (CAE)
have reached a level where it is now possible to employ skilled energy developers throught the world
by linking them all together to collectively engineer solutions through the use of a coordinated, modern,
analysis and simulation engineering tool set."
Interesting - could be we're "Three in the Green," "On course and on the Glide Path,"
"our Rate of decent is good," and we'll be at the "Destination Gate" within a few minutes!
Just a heads-up about some real work that's actually taking place out here... Hopefully it will
help to relieve the depression and dispare that some appear to have right now and serve to inspire!
Some REAL proofs. Lots more in the pipeline.
FIN
Some interesting videos
https://www.youtube.com/watch?v=BPk345S4GGY
https://www.youtube.com/watch?v=eH2TWPJiwEA
now, you can do a third coil on top of this loosely coupled and this will be very close to Kapanadze device I think
Quote from: Ansis on January 14, 2019, 12:03:31 PM
There is no FE.
Hi Ansis,
Nothing surprising about that but what is amplified - the voltage?
This is 90 deg phase shift try getting that out of a TL494
Quote from: forest on January 14, 2019, 03:14:00 PM
https://www.youtube.com/watch?v=BPk345S4GGY (https://www.youtube.com/watch?v=BPk345S4GGY)
https://www.youtube.com/watch?v=eH2TWPJiwEA (https://www.youtube.com/watch?v=eH2TWPJiwEA)
The second video with the Zatsarinin transformer is the change from Kirchhoff circuit law to Ampere law well demonstrating. !
https://m.youtube.com/watch?v=Dz0GUqxCPp4 (https://m.youtube.com/watch?v=Dz0GUqxCPp4)
https://books.google.pt/books?id=Xry7DAAAQBAJ&pg=SA4-PA22&lpg=SA4-PA22&dq=zatsarinin+transformer&source=bl&ots=XVbJ2PchAJ&sig=KuRjHfd37JyNS01yg4hSkOjQI-Q&hl=de&sa=X&ved=0ahUKEwiGkteQqe7fAhWh1-AKHY68DhkQ6AEIFzAE#v=onepage&q=zatsarinin%20transformer&f=false (https://books.google.pt/books?id=Xry7DAAAQBAJ&pg=SA4-PA22&lpg=SA4-PA22&dq=zatsarinin+transformer&source=bl&ots=XVbJ2PchAJ&sig=KuRjHfd37JyNS01yg4hSkOjQI-Q&hl=de&sa=X&ved=0ahUKEwiGkteQqe7fAhWh1-AKHY68DhkQ6AEIFzAE#v=onepage&q=zatsarinin%20transformer&f=false)
not unknown :
https://www.overunityresearch.com/index.php?topic=2315.0
Thank you SolarLab for delivery of Russian News
Спасибо за доставку ваших новостей.
Трамп называет его поддельные новости. Посмотрите на это снова.
Wesley
type of the dielectric
Look at sparks at the edge
compare it with video https://youtu.be/KLAPRNWuAn4?t=1187
Wesley
Hi Wesley. I did already point out to you here that those anti-static blocks that you have
contain a lot of carbon (very conductive) to give the material its anti-static properties.
This is why the material is a dark black color. The material may be covered with a thin plastic
coating to act as an insulator to lower voltages, but HV will pass right through such a thin plastic
layer and be conducted away, which is how it works as an anti-static material.
If you measure the surface resistance with an ohmmeter, does it measure infinite resistance?
If so, then it is probably coated with a thin layer of insulating plastic. Basically those carbon filled
anti-static blocks are about the same as using a block of conductive metal. :)
Quote from: Void on January 14, 2019, 08:20:25 PM
https://www.quadrantplastics.com/na-en/products/engineering-plastics/standard/tivarr-uhmw-pe-family-of-products/tivarr-dryslide/ (https://www.quadrantplastics.com/na-en/products/engineering-plastics/standard/tivarr-uhmw-pe-family-of-products/tivarr-dryslide/)
No my friend the resistance is >20GOhm
Product Overview
Electro Static Dissipative
Ideal for dusty environments
Helps reduce surging
Won't mar packaging or products
Corrosion-resistant
Self-lubricating
Reduces noise
No moisture absorption
Product Data Sheet (http://qepp.matweb.com/search/DataSheet.aspx?Bassnum=P1SMP17)
http://qepp.matweb.com/search/DataSheet.aspx?Bassnum=P1SMP17&ckck=1 (http://qepp.matweb.com/search/DataSheet.aspx?Bassnum=P1SMP17&ckck=1)
Product Details:Modified with special lubricants,
TIVAR® DrySlide has the lowest coefficient of friction of any of the TIVAR® products.
The enhanced coefficient of friction and anti-static properties make
TIVAR® DrySlide an excellent performer in dusty environments.
Even damp boxes or parcels covered in shrink-wrap won't stick to
TIVAR® DrySlide. In addition, the enhanced surface lubricity won't
mar packaging or products, but allow them to move freely without jamming from dirt, grit or static build-up.
TIVAR® DrySlide is and available in 48" x 120" sheets, with gauge sizes ranging from 1/4" to 2".
Wesley
Wesley
Hi Wesley my friend, I did already quote you this here earlier, I believe, directly from the Tivar product literature, but here it is again:
"The incorporation of an effective carbon black grade renders this material electrostatic dissipative properties."
As I said before, it has carbon in it to give the material its *conductive* anti-static properties.
If the material wasn't conductive to high voltages it would be useless as an anti-static material for floor mats or whatever else. :)
Again, as I have explained, the material may well be plastic coated to give it a very high resistance to lower voltages
(rendering it as an insulator as a floor mat for example if someone accidentally touches voltages such as 120V or 220V),
but high voltages will easily jump across the thin insulating plastic coating and dissipate through the conductive carbon
in its interior, allowing it to work as an effective anti-static material. Those Tivar blocks in strong (high voltage) electric fields
are almost like blocks of conducting metal. I would guess that if you puncture the Tivar material with some pointy multimeter probes
and measure the resistance that way that it may well register as a quite low resistance, not that I am asking you to damage
your Tivar blocks if you don't want to. :) All the best...
Quote from: Void on January 14, 2019, 09:48:12 PM
look here:
| Surface Resistivity per Square |
1e+05 - 1.00e+9 (http://qepp.matweb.com/tools/unitconverter.aspx?fromID=141&fromValue=1.00e%2b9) ohm1e+05 - 1.00e+9 (http://qepp.matweb.com/tools/unitconverter.aspx?fromID=141&fromValue=1.00e%2b9) ohmASTM D257
Wesley
Corona seen on conductor in Tesla coil has nothing to do with dielectric.
There was no single piece of wire or any conductor.
This part of a big slab is totally dielectric and anti-static and uniform in its consistency.
Surface wave is giving you HV charge on the surface of dielectric.
Surface of dielectric is the interface with air.
In contrast to it the wood below can not serve as lossy conducting medium as it is not conducting.
Earth is used as returned wire for HV and LW power networks.
The difference between surface of dielectric is that at frequencies higher than approximately 52MHz uneven surface cancels continuity of the surface wave.
With earth however there is a need for proper resonant transformer to be able to receive the surface wave.
In addition I was in Near Field and that can explain sparks in my mouth.
Wesley
Hi Wesley. I haven't worked with that specific material before, but I know well the reason
it has carbon infused into the material (gives it its dark black color). The carbon is in there
100% for certain to make the material conductive to high voltages. The carbon may possibly be
interspersed thoughout the material with other substances in such a way that gives it a high resistivity
to lower voltages (say less than 500V) even in its interior, but for absolute certain that material
is conductive enough to high voltages or it would be completely useless as an anti-static material.
To continue to deny something that obvious would be completely ridiculous. :)
Also, it absolutely would not show high voltage corona discharge between the Tivar blocks if the
material was not at least somewhat conductive to high voltages. It doesn't take super high conductivity
in a material for it to conduct a significant current when a high voltage is applied across it. That Tivar
material with the carbon compound in it is very clearly conductive enough to high voltages to act as
an effective anti-static material, or they most definitely wouldn't be selling it as such, and also as seen
in your video screen shot, to allow corona discharge to occur between the two blocks of Tivar. :)
Carbon is a quite a good conductor, especially when high voltage is applied across it. If you have any doubts,
please look it up, and please do contact the manufacturer of those Tivar blocks and ask them why the material
has carbon in it, and ask them what that Tivar material's conductivity is when subjected to very high voltage. ;)
Quadrant EPP TIVAR® DrySlide UHMW-PE, Lubricant Filled, Electro Static Dissipative
UHMW-PE
QuoteRedco™ Ultra High Molecular Weight Polyethylene (UHMWPE) has extremely low moisture absorption, a very low coefficient of friction, is self lubricating and is highly resistant to abrasion (10 times more resistant to abrasion than carbon steel). Redco™ UHMW has the highest impact strength of any thermoplastic presently made and is highly resistant to corrosive chemicals, with an exception of oxidizing acids.
Redco™ UHMW plastic is known for its durability, machinability, versatility and cost-effectiveness. Virgin UHMW is FDA compliant and is used in applications where high levels of friction are likely to arise including chain channel, wear strips, belt scrapers, guides, and rollers. Redco™ UHMW can be machined into virtually anything from small bearings to large sprockets and liner systems. Due to an extremely low coefficient of friction, its inherent lubricity minimizes friction resulting in a smooth, noiseless operation.
Outperforming and more cost effective than metal in many applications. Redco™ UHMW is highly durable and available in a wide variety of formulations and grades.
https://www.redwoodplastics.com/products/uhmw-polyethylene/ (https://www.redwoodplastics.com/products/uhmw-polyethylene/)
Quotequote from data :
https://www.astm.org/Standards/D257.htm (https://www.astm.org/Standards/D257.htm)
here you have its electric properties based on American standards.
D257
Nothing you say is found here.
this is American product not some of Far East, Eastern European garbage
Wesley
Quote from: lancaIV on January 14, 2019, 05:39:33 PM
not unknown :
https://www.overunityresearch.com/index.php?topic=2315.0 (https://www.overunityresearch.com/index.php?topic=2315.0)
from "ENERGY AMPLIFICATION":
https://m.youtube.com/watch?v=71vtcl-G4dw
Quote from: stivep on January 14, 2019, 11:04:38 PM
Dear Void. Corona seen on conductor in Tesla coil has nothing to do with dielectric.
Hi Wesley, I was talking about the corona discharge (low level arcing which is clearly visible between the
two blocks of TIVAR in the picture which I highlighted above. This corona discharge is occurring
because you are holding on to one of the TIVAR blocks which is effectively grounding it, and since
the TIVAR blocks are clearly conductive at high voltages due to the carbon content in them, the other TIVAR
block charged to a high voltage due to the very strong electric field it is in is creating corona discharge (low level arcing)
in the small air gap between the two TIVAR blocks. FYI, 'sparking' is a type of short term corona discharge. :) Arcing is where
the air completely breaks down due to a high voltage and you have a considerable current (relatively speaking)
passing from a higher voltage potential to a lower voltage potential through the air or other medium.
All the best...
Quote from: Void on January 15, 2019, 03:21:28 AM
All the best...
Wow, I thought several hours before , not that I do not know this papers, but reading it more concentrated :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Ken+hayashibara&IN=Kazumi+masaki&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Ken+hayashibara&IN=Kazumi+masaki&CPC=&IC=)
f.e.:
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4701675A&KC=A&FT=D&ND=3&date=19871020&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4701675A&KC=A&FT=D&ND=3&date=19871020&DB=EPODOC&locale=en_EP#)
60 W : (130 V x 200 A) arc discharge current ( which makes part of the inrush current kind )
60 Wnominal average : 26000 VA peak
Voltage divider,Frequency divider : Pulse divider
impulse spark gap : Space-Time calculation f.e. electrophorese like EDM or arc welding or Plasma welding
Maths world "Raum-Zeit/Space-Time" : https://de.m.wikipedia.org/wiki/Kartesisches_Koordinatensystem
applied f.e. 4d- nano-chirurgy by C.N.C. and in future EPROM based
Quote from: Hoppy on January 15, 2019, 04:49:36 AM
Excellent video Void and the music! 8)
Maybe this will help rid this thread of this LED bulb lighting nonsense and get back to ways to light Kapanadze style 1KW bulbs with free energy. ;D
Hi Hoppy. Thanks for watching mate. You would think that such an experiment will help to dispel some myths,
but that is not typically how things go around here unfortunately. ;D We will see what Wesley has to say
about this experiment and the conclusions I draw from it. :)
Thank you for your video and your time.
anything what you say at any frequency would be noted in literature as this material is used in American government test facilities.
In Product Data Sheet (http://qepp.matweb.com/search/DataSheet.aspx?Bassnum=P1SMP17)on the top you see material listed:
UHMW-PE
I explained in https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530113/#msg530113 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530113/#msg530113)
and in
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530118/#msg530118 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530118/#msg530118)
Material used in experiment had nothing to do with charcoal or any conductive material under any circumstances.
so again Void :
It is the type of insulator that never becomes conductive
All of you can not accept that this is how surface wave manifests itself on dielectric.
Visual presentation of how Kapanadze device works in the field may give to some of you some answers .
There is former airport about 40 minutes from me.
It could be any flat open field I could find. But it is to cold outside.
I'm going to make few tests.
the bottom line is:
The same Zenneck surface wave used by Viziv is used by Tariel Kapanadze to extract energy from Shumann waveguide.
Energy fluctuation inside the waveguide are affecting its boundary.
Shumann waveguide boundary Earth serves as interface.
And method of extraction of this energy was the dilemma that one may patent to no longer deal with disbelieve of crowd.
If it does not work for you it works for other guy
what's a problem?
Wesley
well it means there was a source of zenneck waves in 2004 near Kapanadze house.... right ?
Quote from: forest on January 15, 2019, 11:18:22 AM
Well what happened to the German guy Otto as a matter of interest?
Not a german guy, but with first name Otto :
https://www.google.com/search?q=otto+tpu-ecd&ie=utf-8&oe=utf-8&client=firefox-b
Otto Sabljaric : R. I. P .
Otto died a few years ago. Unfortunately. He may have been Serbian, but I'm not sure.
Guys: The Schumann resonance frequency is now frequently changing, and has had bursts of up to 90hz.
Which means that if a device is tuned to an older Schumann frequency, it may not work the same now.
What if this mentioned frequency has nothing to do with what Tesla was mentioning about tapping into the ambient surrounding energy. The Cosmic soup, etz... What if you leave the planet? What frequency does deep space hold?
May we be barking up the wrong tree? Maybe it's not the Schumann resonant frequency at all, that we should be tuning into.
Winfried Otto Schumann
https://de.m.wikipedia.org/wiki/Winfried_Otto_Schumann (https://de.m.wikipedia.org/wiki/Winfried_Otto_Schumann)
https://www.google.com/search?q=schumann+frequenz&client=firefox-b&oq=schumann+frequenz&gs_l=mobile-heirloom-serp.3..0l5.2996.8303.0.9122.9.4.0.5.5.0.236.724.0j3j1.4.0....0...1c..34.mobile-heirloom-serp..0.9.868.NgDB960H3Ls (https://www.google.com/search?q=schumann+frequenz&client=firefox-b&oq=schumann+frequenz&gs_l=mobile-heirloom-serp.3..0l5.2996.8303.0.9122.9.4.0.5.5.0.236.724.0j3j1.4.0....0...1c..34.mobile-heirloom-serp..0.9.868.NgDB960H3Ls)
Theta-Welle
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Ken&IN=Kazumi+masaki&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Ken&IN=Kazumi+masaki&CPC=&IC=)
f. e.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=24&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990921&CC=US&NR=5954630A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=24&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990921&CC=US&NR=5954630A&KC=A#)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19871201&CC=US&NR=4710655A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19871201&CC=US&NR=4710655A&KC=A#)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890530&CC=US&NR=4834701A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890530&CC=US&NR=4834701A&KC=A#)
~ NLP : Neuro-Linguistic-Programming
https://en.m.wikipedia.org/wiki/Neuro-linguistic_programming (https://en.m.wikipedia.org/wiki/Neuro-linguistic_programming)https://m.youtube.com/watch?v=Wds0JSpKtpg (https://m.youtube.com/watch?v=Wds0JSpKtpg)
also : propaganda ( pagare : to pay)
sublime(s) selling instrument during shopping or by radio-/ tele-vision
" product placement" / mind occupation
https://www.google.com/search?q=dr.+kazumi+masaki&ie=utf-8&oe=utf-8&client=firefox-bm (https://www.google.com/search?q=dr.+kazumi+masaki&ie=utf-8&oe=utf-8&client=firefox-b)
EEG and EKG
https://www.google.com/search?q=brain+machine&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=brain+machine&ie=utf-8&oe=utf-8&client=firefox-b)
At last, as ultra-mind and ultra-fast-learning machine ( cheaper than a ultra-learning curse ) :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.neurophone-energy.com%2F (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.neurophone-energy.com%2F)
DIY- plans in the internet- universe to down-load
Mind maping : left brain ware and right brain ware seriell or parallel work
+ v. Klausewitz and Kaizen : cold economy war against the CONSTITUTION and CIVIL RIGHTS
Quote from: NickZ on January 15, 2019, 12:23:48 PM
Hi Nick. I have not so far seen anything at all that gives any compelling indication that Kapanadze
may be making use of Schumann resonance waves at the surface of the Earth or similar. Kapanadze
himself may not know at all where the energy is coming from. He may just know what to do to
make a working device based on some info someone passed on to him at some point, or possibly from
some obscure document he came across, and possibly just not know where the extra energy is coming from.
(Assuming it really works as claimed and as demonstrated by Kapanadze).
Quote from: blueplanet on January 15, 2019, 09:20:50 AM
This is another piece of disinformation because of the minority opinion.
Previously, another vocal individual has voiced the same concern. I was trying to comment but I finally gave up. Every real antenna engineer knows what's wrong with your concerns #1 and #3.
Can you read these articles from independent engineers?
http://www.vlf.it/kurt/elf.html
http://www.longrangelocators.com/forums/showthread.php?t=18969
https://jwcn-eurasipjournals.springeropen.com/articles/10.1186/s13638-018-1157-7
If you are a electronics engineer, you need to understand how low the level of energy is.
Wesley,
if (https://www.history.com/this-day-in-history/alexander-graham-bell-patents-the-telephoneif) there has not to be the dependance from one frequency bandgap/bandwidth solely, what would you use as total receiveable radiation spectrum " diaphragm" ?
https://www.history.com/this-day-in-history/alexander-graham-bell-patents-the-telephone (https://www.history.com/this-day-in-history/alexander-graham-bell-patents-the-telephone)
Electro-magneto-acoustics : opto ( parabol, hyperbol)
dormant bonanzas : WIPO-archive
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Alexander+Graham+bell&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Alexander+Graham+bell&CPC=&IC=)
Bauer, ......., Fessenden :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Fessenden&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Fessenden&IN=&CPC=&IC=)
https://en.m.wikipedia.org/wiki/Reginald_Fessenden
Schumann waveguide should not be seen as Schumann resonances per say .
Schumann Resonance only allows you to send signal from point A to point B without significant losses.
That includes Ground Wave, Surface Wave, and traditional electromagnetic communication.
The guided wave travels along curvature of the earth.
And that is about all in this area.
Corum Bross included that information in their patents.
The novelty is extraction energy from that Schumann Waveguide.
So in the big picture there are two alternatives:
1- Tariel knows about Surface Wave but he had no idea that he deals with Surface Wave.
Theoretically to make Tx and Rx for such assembly is about 1 to 3 days.
And for these who did it before 1 to 3 hours.( with help of two, three people in physical assembly)
1a- testing and tuning takes few hours to few days but less than 3 days for starters.
1b- There is indication that in the island presentation light in the motel dimmed significantly.
Tariel was across the water on the island. Part of his crew was in the motel.
That fact was absolutely proven by my very credible sources.
However we may say that it was purely coincidental.
2- Tariel knowing technique of Zenneck transmission went further up and extracted energy from Schumann Waveguide
That is in theory even simpler than transmission of Zenneck Wave as you do not need transmitter.
Each lightning strike creates avalanche of lightning strikes around the earth.
QuoteHigh quality lightning data has only recently become available, but the data indicates that lightning occurs on average 44 times every second over the entire Earth, making a total of about 1.4 billion flashes per year.
All of them must dissipate in the earth.
Wesley
Quote from: Void on January 15, 2019, 03:02:45 PM
Hi Wesley, thanks for the comments.
As I see it, the problem is IMO that you have not said or demonstrated anything so far that
would seem to lend concrete support to the idea that low frequency waveforms at the Earth's surface
are being tapped into as the source of the extra energy. I am not saying that idea is necessarily
wrong, just that I don't think you have presented anything which seems to give real support to this idea
of yours. Why do I say 'low frequency' above? Because Schumann resonance frequencies are supposed to
be quite low frequency.
It will always come back to the same point with anyone anywhere (not just here) in regards to these type of ideas.
If a person can't show anything concrete to back up the notion that energy is being extracted from the Earth's surface,
then people can only take it as an as yet unsupported idea. That's my point of view anyway.
Related Schumann frequency spectrum :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.planetware.de%2Ftune_in%2Fschumann.html
Hi Wesley. You seem to be taking people's natural hesitance against jumping to conclusions
about these sorts of things personally, but it is not personal at all. For myself, not wanting to jump
to any conclusions about this sort of stuff comes from long experience.
I am actually not ruling out what you have been saying at all in regards to Earth surface/ground waves
of low frequency as being the possible source of extra energy in these setups. I am thinking about
it and trying to see how it might work. The fact that Frank Wyatt Prentice seems to possibly have done
something similar to that approach in 1923, makes me think it may be possible. See the attached
Prentice drawing again.
The top 'Transmitter' section has a long 800m approx. wire a short distance above the ground
and a sparkgap at the end near the end grounding point. The sparkgap may cause disruptions/disturbances
in the ground underneath which may draw in energy into the long wire from low frequency waves in the Earth
and thus increase the energy on the long wire by a factor of about 6 when it was all tuned properly.
The small receiving loop is tuned to the transmitter frequency and receives this 'amplified energy' from
the long transmitting wire. If we replace Prentice's 800m long wire with a short tuned coil, it might
still work about the same. It does seem to possibly mirror Kapanadze's setup fairly closely, except
Kapanadze used a much more compact transmitter/disrupter and receiver coil assembly. Am I close
to your ideas Wesley? :)
P.S.
Maybe what Kapanadze had in his tobacco can besides a flyback transformer was a tuneable HV capacitor (#23 in Prentice's drawing)...
Hi Wesley. You can find the PDF file for that Prentice patent attached to my message here:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg523030/#msg523030
Wesley Hi this is my contribution a four-phase clock contribution.
If you want a 50 Hz or 60 you have to drive it with 4 times that frequency
The CD4046 is simply a stable VFO
https://overunity.com/6763/energy-amplification/3555/ (https://overunity.com/6763/energy-amplification/3555/)
#3556 and #3564
Tekla Ozkan " simple thinking" ( ~ Tanaka Saburo, Keiichiro Asaoka Inverter generator)
http://www.patentsencyclopedia.com/app/20090079393 (http://www.patentsencyclopedia.com/app/20090079393)
Attention, probably " getuerkt" ! ::) ;) ;D
For " more complexity thinker" :
Triangle 1 : DC/AC left-/ or up helix
Triangle 2: AC/DC right/ or down helix
Tornado ? N-P-N holes principle ?
N1 : CCW or CW
P
N2 : CW or CCW
NPN Trans-Resistor " Transistor" , a. Photo-copler b. Phono-copler to RTS/HTS
BTW : https://www.ebay.co.uk/itm/1932-Bridgeport-Phono-Electric-Trolley-Bus-Ad-wg393-MBFA2Q-/290875565380?redirect=mobile (https://www.ebay.co.uk/itm/1932-Bridgeport-Phono-Electric-Trolley-Bus-Ad-wg393-MBFA2Q-/290875565380?redirect=mobile)
alloy material mix ?
To Void, Wesley.
I see you are back on the right track!
Void, I think like you about 15 years from now.
Your Wireless Video was realy good!
Wesley, I think Kapanadze use sea water like medium, but very thick multi strands wire which he buried in the Sea was Antena. It is Energy from Medium, which contains EM Field. He makes loop.
In that loop he amplifiere field.
Thats it!
Quote from: F6FLT on January 16, 2019, 11:34:42 AM
Schumann resonance does not allow us to send a signal from point A to point B without significant losses. The losses are considerable, question of wavelength far too long for the possible sizes of radiant systems.
In front of you, you do not only have blind believers in fairy tales or uneducated ignoramuses. You have curious, critical and competent minds, with strong objections which you do not respond, or by digressions, and which you confuse with missiles.
QuoteSchumann resonance frequencies are lower than expected for an ideal cavity, i.e., two concentric layers of infinite conductivity filled by a lossless dielectric medium [Jackson, 1999 (https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2002JA009779#jgra16904-bib-0008)
https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2002JA009779 (https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2002JA009779)
https://en.wikipedia.org/wiki/Schumann_resonances (https://en.wikipedia.org/wiki/Schumann_resonances)
QuoteIn the normal mode descriptions of Schumann resonances, the fundamental mode (https://en.wikipedia.org/wiki/Fundamental_frequency) is a standing wave (https://en.wikipedia.org/wiki/Standing_wave) in the Earth–ionosphere cavity with a wavelength (https://en.wikipedia.org/wiki/Wavelength) equal to the circumference of the Earth.
That is in my previous post I said:
QuoteThink about Standing Wave deformation at your higher Schumann Resonance frequency
And you'll get your FE.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530166/#msg530166 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530166/#msg530166)
Quotesome harmonic of the fundamental earth resonant frequency—up to approximately 25 – 35 kHz—is used for the oscillator frequency.
In this frequency range the around-the-world propagation efficiency is in the general area between 93 to 87%
https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/ (https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/)
Please read all of it!!
QuoteAppendix II, "The Zenneck Surface Wave"]
The oscillatory transformer provides the high voltage alternating current needed to periodically charge the transmitter's elevated terminal.
A monochromatic subcarrier signal is then added.
This is in the form of an abrupt lower frequency electrical impulse applied at a rate approaching the fundamental earth resonance frequency.
Higher frequency impulses, above the oscillator frequency are also added at every harmonic of the low frequency subcarrier impulse, be it
the fundamental earth resonance frequency or some lower harmonic of same. [Corum & Corum]
While the following quote refers to the use of an RF alternator in conjunction with a resonance transformer to produce continuous waves,
it appears to be applicable to the excitation of earth resonance modes as well. .
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
QuoteBecause propagation losses are so low at the primary Schumann resonance frequency (below 0.25 dB per Mm according to published data),
signals at that frequency may be transmitted to any point on the earth without significant attenuation.
Wesley
https://www.wired.co.uk/article/230-percent-efficient-leds (https://www.wired.co.uk/article/230-percent-efficient-leds)
Many did read this news but forgot !
A. "electrical efficiency > 100%" as term for FE devices
B. " .... It begins to cool down..."
C. ".... and applied smaller and smaller voltages. Every time the Voltage was halved,
the electrical power was reduced by a factor of fourbut the light power only
dropped by a factor of two. ...."
Quote from: lancaIV on January 17, 2019, 04:21:22 AM
A. " ...."
B. " ...."
C. ".... "
D. "....69 picowatts of light, of course, is a very small amount" 69 picowatts = 0,000 000 000 069 Watt, very very very small amount energy from ambient heat, not usable.
I had seen this article when it came out, source paper here (https://journals.aps.org/prl/abstract/10.1103/PhysRevLett.108.097403). It would be revolutionary in principle, since it would be a Maxwell demon.
On the practical side, the energy in question is on the order of tens of pW, so no practical interest without considerable improvements.
But there are worse things. This scientific paper is questionable. Cooling was not measured but calculated. The paper was refuted, a real measure would have indicated an absence of cooling:
http://large.stanford.edu/courses/2012/ph250/kumar2/
"The authors did not directly observe cooling, mostly because they did not thermally isolate the diode, instead they chose to keep the temperature fixed! They calculate the net cooling. In simple terms, one would not observe cooling in the recombination dominated region."
Quote from: Sergh on January 17, 2019, 04:29:14 AM
"C. THE RATIO FROM POWER FACTOR AND HEAT FACTOR APPLIED "( + Newton* meter Factor)
" picowatts "- device as q.e.d. for him and his POWER KW/KVA RATIO description :
to mega.
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Quote from: F6FLT on January 17, 2019, 04:47:33 AM
http://large.stanford.edu/courses/2012/ph250/kumar2/ (http://large.stanford.edu/courses/2012/ph250/kumar2/)
In the recombination dominated region I expect : 0 change in Kelvin !
Quote from: lancaIV on January 17, 2019, 04:51:09 AM
to mega.
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en (http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en)
https://www.unitjuggler.com/convert-power-from-pW-to-W.html :'(
Small update.
To everyone.
Do you have Made in China Joule Thief type HiVoltage transformer, Tesla style?
https://thumbs2.ebaystatic.com/d/l225/m/mjrpl-NbzG9qfntqZiM2lcw.jpg
Do you have "metal water pipe"?
All magic is in "pipe" and in the HiVoltge source.
When you playing with Sparks, Ozzone :), nothing extraordinary.
But when you attach "water pipe" through wire to the violet terminal of the mini Tesla style transformer, be very very carefull, because "mixture" of Currents can kill you!
I get internal burning of my finger with "cooked flesh" smell and black dot.
This is that.
When you have these 2 parts together and if you make loop, than we can get "energy".
Kapanadze love that word.
Энэргия пошла!
Quote from: Sergh on January 17, 2019, 06:25:18 AM
https://www.unitjuggler.com/convert-power-from-pW-to-W.html (https://www.unitjuggler.com/convert-power-from-pW-to-W.html) :'(
VA~ W ( several power definitions!) VAh ~ Wh
LED: Unit VOLT x Unit AMPERE ~ Unit Lux as power indicator
1/2 from above Unit VOLT x ? Units Ampere ~ Units Lux
as reduced a . Light b. electric power factor
FACTOR OF FOUR : FACTOR OF TWO
Mukherjee device:
DC-motor( and generator) in one + Controle-Unit
Technical process to counterbalance F( orce) :
balance,wagging,
left side leg and right side leg
Left side leg :
Paragraph : " If in a conventional generator the field strengh B....... F= B LI
Right side leg :
Paragraph : " If the field strength of the electrical device -edit: is- 2B...... F'=2Bx L x I
F/F': B/2B : 1/2 Ampere current x 1/2 nominal Voltage = 1/4 nominal VoltxAmpere
Edit : f.e. B/10B : 1/10 Ampere current x 1/10 nominal Voltage = 1/100 nominal Volt x Ampere
( Counter-) BALANCE OF POWER
Pico-Watt ...... Watt, KiloWatt, MegaWatt
::) IS this the End? NO, coil length = the I from BxLxI variation and
the " pure output energy force" can be also extracted from the shaft : kinetic force/ energy as power source
There are many FE devices, based by physics formula applying and logical maths. ! Conventional EE-regime and Quantum-regime!
To have a pure 80% -<100% pure electromagnetic converter is a very good beginning !
1Watt-hour source : seems not much
1 hour = 60 min. = 3600 sec.
Let 1 Wh cycling 3600 times/h= 3600 Wh
Hertz: " motionfree" rotation/ cycling
Hz,KiloHz,MegaHerz,GigaHz,TeraHz,....
1 Wh x THz- times : ? Wh
80% to < 100% EMF efficiency
+ elektret EF and/ or permanent rmagnet MMF
Efficiency amplifier : > 100%
Quote from: AlienGrey on January 17, 2019, 11:19:38 AM
Well, you guys really need to watch this video !!
https://www.youtube.com/watch?v=W_fRKxz_UNo (https://www.youtube.com/watch?v=W_fRKxz_UNo)
thank you for so much help :o
Oh, happy days!
Article 17 EU General Data Protection Regulation (EU-GDPR). Privacy ...
www.privacy-regulation.eu/.../article-17-right-to-erasure-'right-to-be-forgotten'-GDPR...
Article 17 - Right to erasure ('right to be forgotten') - EU General Data Protection Regulation (EU-GDPR), Easy readable text of EU GDPR with many hyperlinks.
http://www.privacy-regulation.eu/en/article-18-right-to-restriction-of-processing-GDPR.htm
Article 18
EU GDPR
"Right to restriction of processing"
In that video, the guy gives a lot away if you listen.
Have you read the bit about G4 yet ?
Quote from: AlienGrey on January 17, 2019, 02:52:58 PM
Yeah well that starts real soon can't you wait? anyway did you get anything from it ?
well since i'm from the EU . i have to wait what i be ordered to do ,, so you wont get it.
your a real help to this topic .. thank you verry much ( for nothing)
https://youtu.be/wFiW2lqdnlM?t=604 (https://youtu.be/wFiW2lqdnlM?t=604)
Wesley
Personal opinion expressed only
Quote from: stivep on January 17, 2019, 03:39:27 PM
Testing will start 23 days from now
First electrical energy delivery outside the continent 1 year from now
After that any device like Kapanadze may be hunted as a crime of illegal use electrical energy delivered from Viziv.
So you guys may 1 year from now be fighting big corporate money machine, if you say that your device has got electrical energy from the ground
It is you who must prove innocent not them
Wesley
Hi Wesley. Interesting. I personally am more inclined to think the energy for
Kapanadze/Daly/Akula etc. devices may be coming from some unknown source other
than some type of EM waves in the ground, but I don't know for sure of course. Anything is possible.
All the best...
little more of Viziv tower
https://youtu.be/erbTVkrn9hk?t=142
Wesley
Hi Wesley. They seem to have some serious investment money behind them.
All the engineering and construction for that big tower will not have been cheap.
The problem with transmitting power through the ground, assuming it eventually
works to some degree or other, is I think that many people may well try to figure out
how to tap into it and get free electricity. It seems to me that would be pretty hard to detect.
A lot of people put up pirate satellite TV antennas and receivers to receive satellite TV for free. :)
Also, I think they got a grant, but a grant wouldn't likely cover all the costs for all the R&D and construction
on a big project like that. I wonder who is funding these guys? Someone with apparently lots of money anyway...
Who needs a Kapanadze free energy device if the Corum brothers are going to transmit
free power to me. All I have to do is figure out how to build a portable Corum brothers power receiver,
and I can use it where ever I go to get free power. ;D
Kanarev says in conclusions, that his tests prove OU consistently
http://guns.connect.fi/innoplaza/energy/story/Kanarev/generator/
Memo
Links to remember :
1.https://rd.springer.com/article/10.1007%2FBF03000465 (https://rd.springer.com/article/10.1007%2FBF03000465)
2.https://patents.google.com/patent/WO2008103130A1/en (https://patents.google.com/patent/WO2008103130A1/en)
3. (https://patentimages.storage.googleapis.com/11/82/39/a569b2985034bb/US20060163971A1.pdf)https://patentimages.storage.googleapis.com/11/82/39/a569b2985034bb/US20060163971A1.pdf (https://patentimages.storage.googleapis.com/11/82/39/a569b2985034bb/US20060163971A1.pdf)
4.http://physics.oregonstate.edu/~minote/COURSES/ph632/lib/exe/fetch.php?media=emch7.pdf (http://physics.oregonstate.edu/~minote/COURSES/ph632/lib/exe/fetch.php?media=emch7.pdf)
5.https://www.youtube.com/watch?v=ujYcDErKvAw (https://www.youtube.com/watch?v=ujYcDErKvAw)
6.https://www.youtube.com/watch?v=B9fEkKB9lIw (https://www.youtube.com/watch?v=B9fEkKB9lIw)
7.https://digital.library.unt.edu/ark:/67531/metadc834300/m1/2/ (https://digital.library.unt.edu/ark:/67531/metadc834300/m1/2/)
8.https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=WO&NR=2008103130A1&KC=A1&FT=D&ND=&date=20080828&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=WO&NR=2008103130A1&KC=A1&FT=D&ND=&date=20080828&DB=&locale=#)
9.https://patentimages.storage.googleapis.com/35/0c/ae/5fb821ecb48489/WO2008103130A1.pdf (https://patentimages.storage.googleapis.com/35/0c/ae/5fb821ecb48489/WO2008103130A1.pdf)
10.http://web.mit.edu/redingtn/www/netadv/zenneck.html#waitwave (http://web.mit.edu/redingtn/www/netadv/zenneck.html#waitwave)
11.http://jnaudin.free.fr/html/fep01.htm (http://jnaudin.free.fr/html/fep01.htm)
12.https://link.springer.com/article/10.1134/S106422691711016X (https://link.springer.com/article/10.1134/S106422691711016X)
13.https://agupubs.onlinelibrary.wiley.com/doi/epdf/10.1029/RS013i006p00969?purchase_referrer=www.bing.com&tracking_action=preview_click&r3_referer=wol&show_checkout=1 (https://agupubs.onlinelibrary.wiley.com/doi/epdf/10.1029/RS013i006p00969?purchase_referrer=www.bing.com&tracking_action=preview_click&r3_referer=wol&show_checkout=1)
14.https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969 (https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969)
15.http://www.teslasociety.com/tunguska.htm (http://www.teslasociety.com/tunguska.htm)
16.http://www.norbertmoch.de/_physik_technik_kosmologie/nikola_tesla.htm (http://www.norbertmoch.de/_physik_technik_kosmologie/nikola_tesla.htm)
17.https://teslauniverse.com/nikola-tesla/images/tesla-small-scale-model-wireless-power-system-using-surface-earth-conductor (https://teslauniverse.com/nikola-tesla/images/tesla-small-scale-model-wireless-power-system-using-surface-earth-conductor)
18.https://teslauniverse.com/nikola-tesla/images/diagram-teslas-wireless-power-system (https://teslauniverse.com/nikola-tesla/images/diagram-teslas-wireless-power-system)
19.https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2017077616A1&KC=A1&FT=D&ND=3&date=20170316&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2017077616A1&KC=A1&FT=D&ND=3&date=20170316&DB=&locale=#)
20.http://rexresearch.com/corumzenneck/corumzenneck.html (http://rexresearch.com/corumzenneck/corumzenneck.html)
21.https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2017070057A1&KC=A1&FT=D&ND=3&date=20170309&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2017070057A1&KC=A1&FT=D&ND=3&date=20170309&DB=&locale=#)
22.https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5590031A&KC=A&FT=D&ND=&date=19961231&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5590031A&KC=A&FT=D&ND=&date=19961231&DB=&locale=#)
23.https://books.google.pt/books?id=v_K6jmnGTS4C&pg=PA43&lpg=PA43&dq=zpe+mead&source=bl&ots=pwEFF0FmhC&sig=F2_H4wwEajK1bzoM_tGW-yl6G2Q&hl=de&sa=X&ved=0ahUKEwiO_5qz5dTfAhWLMhQKHe6tD-.AQ6AEIGzAG#v=onepage&q=zpe%20mead&f=false (https://books.google.pt/books?id=v_K6jmnGTS4C&pg=PA43&lpg=PA43&dq=zpe+mead&source=bl&ots=pwEFF0FmhC&sig=F2_H4wwEajK1bzoM_tGW-yl6G2Q&hl=de&sa=X&ved=0ahUKEwiO_5qz5dTfAhWLMhQKHe6tD-AQ6AEIGzAG#v=onepage&q=zpe%20mead&f=false)
24.https://www.k-meyl.de/go/Primaerliteratur/Wireless-Energy-Transfer.pdf (https://www.k-meyl.de/go/Primaerliteratur/Wireless-Energy-Transfer.pdf)
25.http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html (http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html)
26.http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html (http://www.energeticforum.com/renewable-energy/8466-teslas-magnifying-transmitter-replications-4.html)
27.https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06?navId=paper-header (https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06?navId=paper-header)
28.https://ieeexplore.ieee.org/document/7139133/references#references (https://ieeexplore.ieee.org/document/7139133/references#references)
29.https://ieeexplore.ieee.org/document/7139133/keywords#keywords (https://ieeexplore.ieee.org/document/7139133/keywords#keywords)
30.https://www.youtube.com/watch?v=ArSssJx5wg0 (https://www.youtube.com/watch?v=ArSssJx5wg0)
31.http://dg7ybn.de/Phasing/Phasing.htm (http://dg7ybn.de/Phasing/Phasing.htm)
32.http://file.scirp.org/pdf/CN20100100010_90948227.pdf (http://file.scirp.org/pdf/CN20100100010_90948227.pdf)
33.http://electriciantraining.tpub.com/14182/css/Surface-Wave-76.htm (http://electriciantraining.tpub.com/14182/css/Surface-Wave-76.htm)
34.https://ieeexplore.ieee.org/document/7139133/figures#figures (https://ieeexplore.ieee.org/document/7139133/figures#figures)
35.https://www.hydro-international.com/content/article/underwater-electromagnetic-propagation (https://www.hydro-international.com/content/article/underwater-electromagnetic-propagation)
36.https://hello-earth.com/nikolatesla/thedisturbinginfluenceofsolarradiationonthewirelesstransmissionofenergy/electricalreviewandwesternelectrician6july1912.htm (https://hello-earth.com/nikolatesla/thedisturbinginfluenceofsolarradiationonthewirelesstransmissionofenergy/electricalreviewandwesternelectrician6july1912.htm)
37.http://web.mit.edu/redingtn/www/netadv/zenneck.html (http://web.mit.edu/redingtn/www/netadv/zenneck.html)
38.https://spectrum.ieee.org/energywise/green-tech/solar/japan-demoes-wireless-power-transmission-for-spacebased-solar-farms (https://spectrum.ieee.org/energywise/green-tech/solar/japan-demoes-wireless-power-transmission-for-spacebased-solar-farms)
39.https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/ (https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/)
40.http://www.tfcbooks.com/teslafaq/q&a_038.htm (http://www.tfcbooks.com/teslafaq/q&a_038.htm)
41.http://www.tfcbooks.com/mainpage/glossary.htm#slow-wave (http://www.tfcbooks.com/mainpage/glossary.htm#slow-wave)
42.https://cosmolearning.org/video-lectures/diffraction-gratings-2/ (https://cosmolearning.org/video-lectures/diffraction-gratings-2/)
43.https://www.youtube.com/watch?time_continue=1876&v=UFh7hkLeL10 (https://www.youtube.com/watch?time_continue=1876&v=UFh7hkLeL10)
44.https://www.youtube.com/watch?v=5xUf94WlfI4&feature=youtu.be&t=635 (https://www.youtube.com/watch?v=5xUf94WlfI4&feature=youtu.be&t=635)
45.https://www.youtube.com/watch?v=MBH5-oHqzp4 (https://www.youtube.com/watch?v=MBH5-oHqzp4)
46.https://en.wikipedia.org/wiki/Near_and_far_field (https://en.wikipedia.org/wiki/Near_and_far_field)
47.https://www.youtube.com/watch?v=fsZEwOY69Ss (https://www.youtube.com/watch?v=fsZEwOY69Ss)
48.https://www.teslacoildesign.com/construction.html#construction_sparkgap (https://www.teslacoildesign.com/construction.html#construction_sparkgap)
49.https://patents.google.com/patent/US20140252886A1/en (https://patents.google.com/patent/US20140252886A1/en)
50.https://patentimages.storage.googleapis.com/9d/2b/2a/fa977b9aae1691/US4751515.pdf (https://patentimages.storage.googleapis.com/9d/2b/2a/fa977b9aae1691/US4751515.pdf)
51.https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
52.https://wiki2.org/en/Surface_wave (https://wiki2.org/en/Surface_wave)
53.http://iopscience.iop.org/article/10.1070/PU1989v032n04ABEH002705/pdf (http://iopscience.iop.org/article/10.1070/PU1989v032n04ABEH002705/pdf)
54.https://www.youtube.com/watch?v=KTiL22xMQDc (https://www.youtube.com/watch?v=KTiL22xMQDc)
55.https://patentimages.storage.googleapis.com/53/e0/43/3b122f703647fe/WO2017209652A2.pdf (https://patentimages.storage.googleapis.com/53/e0/43/3b122f703647fe/WO2017209652A2.pdf)
56.https://patents.google.com/patent/WO2017209652A2/en?assignee=Melnichenko+Andrei&scholar&oq=assignee:(Melnichenko+Andrei (https://patents.google.com/patent/WO2017209652A2/en?assignee=Melnichenko+Andrei&scholar&oq=assignee:(Melnichenko+Andrei))
57.https://patents.google.com/patent/US20180183128A1/en (https://patents.google.com/patent/US20180183128A1/en)
58.https://ieeexplore.ieee.org/document/8103565 (https://ieeexplore.ieee.org/document/8103565)
59.https://ieeexplore.ieee.org/search/searchresult.jsp?newsearch=true&queryText=zenneck%20wave (https://ieeexplore.ieee.org/search/searchresult.jsp?newsearch=true&queryText=zenneck%20wave)
60.https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=202008009291U1&KC=U1&FT=D&ND=&date=20080911&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=202008009291U1&KC=U1&FT=D&ND=&date=20080911&DB=&locale=#)
61.http://www.energeticforum.com/renewable-energy/20648-teslas-experiments-faraday-cage-don-smith.html (http://www.energeticforum.com/renewable-energy/20648-teslas-experiments-faraday-cage-don-smith.html)
62.https://teslaresearch.jimdo.com/ (https://teslaresearch.jimdo.com/)
63.https://www.scribd.com/document/350641326/A-Quarter-wave-Coaxial-Cavity (https://www.scribd.com/document/350641326/A-Quarter-wave-Coaxial-Cavity)
64.http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&a=d&c=envl&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.4.1 (http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&a=d&c=envl&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.4.1)
65.https://apps.dtic.mil/dtic/tr/fulltext/u2/a637392.pdf (https://apps.dtic.mil/dtic/tr/fulltext/u2/a637392.pdf)
66.https://www.physicsforums.com/threads/limitations-to-the-practical-use-of-atmospheric-electricity.649898/ (https://www.physicsforums.com/threads/limitations-to-the-practical-use-of-atmospheric-electricity.649898/)
67.https://en.wikipedia.org/wiki/Atmospheric_electricity (https://en.wikipedia.org/wiki/Atmospheric_electricity)
68.http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.3>=2 (http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0envl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL1.4&d=HASHa4422b7fbbfa2350e1c317.3>=2)
Wesley
Wesley, #2386 : the last sentence : ;)
Der Sohn eines Hannoveraners stolpert ueber einen "(ueber-)spitzen" " need" !
https://m.youtube.com/watch?v=PAYiHp9QUwE (https://m.youtube.com/watch?v=PAYiHp9QUwE)
" ..... wollen Bummsi-Bummsi machen ?" OMG :o , Dictionary-Translation-Anarchie :P
Now the anglo-saxonic version - in short " inglitsch( Rutsch-Danger 8) !)" :
https://m.youtube.com/watch?v=k_Gn6a3WbYw (https://m.youtube.com/watch?v=k_Gn6a3WbYw)
" .. bouncy, bouncy... ?" OMG :o , Dictionary-Translation-Pornography ;D
"need": phonetic : nees cause a soft "d"~ s
Niss~ Brauchen
Saxonics " (ge-)niessen", not to misunderstand with " nissen : Hattschi : Gesundheit ! "
For yor list : https://www.google.com/search?q=spintronic&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=spintronic&ie=utf-8&oe=utf-8&client=firefox-b)
http://www.pakua.com/sintonia/?lang=dehttps://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.pakua.com%2Fsintonia%2F%3Flang%3Dde (http://www.pakua.com/sintonia/?lang=dehttps://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.pakua.com%2Fsintonia%2F%3Flang%3Dde)
Less Stress
https://m.youtube.com/watch?v=v_EWWyJfgPc (https://m.youtube.com/watch?v=v_EWWyJfgPc)
Quote from: r2fpl on January 18, 2019, 07:50:09 AM
These are not Schumann's resonance waves in Kapanadze's devices.
I think you will find all the KT device ones that work are base 8 or 9 or a combination and even the Don Smith device was 31k5 (3+1+5=9)!
Or you could do it the dummy's way 31,500khz / 9 goes 3500 times! which is the Univers! or the God number
Quote from: Hoppy on January 18, 2019, 04:01:18 AM
Void,
I'm wondering if it intended to replace the wired grid but not the power generating hubs? I cannot see this idea being viable unless all infrastrucure costs, including de-commissioning and removal of the existing grid networks are bourne by the tax paying public, so therefore, only escalating energy costs to look forward to. Also, the system will need to be able to pinpoint all leakage and illegal tap points to stop guys like you from getting a free meal ;) There are likely to be H&S issues that although unlikely to raise real problems to its implementation in the US, may well in Europe under its present political structure. So, likely just a rich guys toy at present.
Hi Hoppy. Yes, I would guess that is the plan. Maintaining the wired power grid is
very costly, so if power corporations could do away with all that cost by sending power
to most places via the ground, they could greatly increase profits, and that is what
corporations are all about. Maximizing profits. Yes, at this point it just appears to be
an expensive experiment, so that is why I was curious who all is funding this project.
It will be interesting to see what they can do with their variation of a Tesla magnifying transmitter
tower under a new name. :)
Brain-Space~ Gedanken-Raum : Space-Age-Creativity
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Winfield+salisbury&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Winfield+salisbury&CPC=&IC=)
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Siegfried+stargard&CPC=&IC=&Submit=Search (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Siegfried+stargard&CPC=&IC=&Submit=Search)
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Dd&AP=&PR=&PD=&PA=&IN=Manfred+gregor&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Dd&AP=&PR=&PD=&PA=&IN=Manfred+gregor&CPC=&IC=)
Quote from: Hoppy on January 19, 2019, 04:22:49 AM
Most likely not. We do not see him make any fine tuning adjustments and the length of ground cable appears not to be critical, as he swops over from the radiator ground wire to the water pipe ground and these are very different lengths of wire. The electrical conductivity of the ground is probably more important, as the device appears to work better on the water pipe ground. I think Ansis is closer to the truth, that the device is using the water pipe with its 'hard' connection to grid earth as part source of the energy supplied to the device. I think the discussion would be more productive if ideas on how indirect grid connected powering might be achieved, that is without a straight and faked direct connection to Tariel's house mains consumer unit, at least to eliminate this possibility, rather than continue with the more complex and esoteric idea of powering with surface waves.
There are rather two possibilities:
1.The system works by supplying it with energy through air and ground. Just like the Tesla wireless system.
2.On the principle of accelerating electrons by an HV resonator.
#1 - the success of such a system is 100% and this is a scam.
#2 - such systems have low efficiency but all work 100Mhz to nGhz
What would happen if they were forced to operate on frequencies of 10Mhz and less?
Quote from: lancaIV on January 19, 2019, 05:52:36 AM
https://m.youtube.com/watch?v=Q9YsuEeCTqs (https://m.youtube.com/watch?v=Q9YsuEeCTqs)
Hi!
There is only 1 biggg problem with Kapanadze "coil"(That is not Tesla Coil).
We need Sinuss+Spark.
Every transformer with 50-400Hz range, have metal cores.
Ferrite is used at much higher frequencys.
In original? Kapanadze drawing we see Ferrite+Bifilar type of core-coil.
In fact, my friend tell me, look at Kapanadzes desktop!
There was black material and hammer.
Skype commrades remember what I write about very low technology of Kapanadze.
We see primitive laboratory.
No HiEnd.
Core is veryvery important part of All "FreeEnergy" generators.
TPU or Kapanadze use the same principle.
MagneticField multiplication with Mechanic type of resonators!!!
I think, we must copy Kapanadzes coil.
And yes.
Inductor 6 turns is connected in series with 6+6 fat wires(Litz or simple?).
It is important to feel all lenth of coil with Magnetic Pulse+Sinuss!
It is for Maximum efficiency.
Maybe Spark must be tuned to Maximum and Minimum of 50Hz "modulation".
To make copy of that coil we need 1?- 3? days?
We need 2 generators.
I have only oscilloscope and no generators.
I use PC. :)
The system must be open or grounded. This is the basis for further action.
The principle is the same only describes it differently.
http://www.nutsvolts.com/magazine/article/the_magnetic_amplifier
The " magnetic amplifier" for itself is a system control device ! Which makes part for a semi-loop FE-device !
Loop-/ closed systems= storage
generating maschines: open input/output circuit !
Quote from: jojo500 on January 19, 2019, 06:20:58 AM
if you look how slopy his kontraptions are made i would say if anything than a few khz .. but never MHZ ore above.
how ever i said this long bevore. Look at all the work they put in to the groundingpoint and than look what cable the use
one woult think if you want to have a perfekt ground you keep the distance close to your device and use som substandcial wire for that.. but they don't so what does this wire?
Agreed, in electrical best practice sense but I think Tariel chose his demonstration area as higher importance over the location of the grounding point. So, the ground is important to the optimum efficient functioning of the device but its length is not critical in my opinion. We observed no evidence that the device could operate without the ground wire, despite Tariel's comment to the contrary. However, we did observe that the quality of the earth connection had a marked effect on the brightness of the lamp load. Also, the heavy gauge of the ground wire and clamp meter readings, suggests that it may have been carrying a heavy current but not necessarily at a full grid voltage level. How could Tariel have powered his device from a cleverly 'processed' high differential ground voltage, so as not to have registered on his consumer electricity meter and without making any wire connections within his service compartment / box / cupboard? Remember, at the time Tariel carried out his box demos, grid power 'tapping' was well practised and widespread in Georgia. We need to totally eliminate the liklihood of this before seriously considering the alternative more technically complex possibilities already put forward.
if you look how sloppy his contraptions are made I would say if anything than a few kHz .. but never MHZ ore above.
however, I said this long before. Look at all the work they put into the grounding point and then look what cable the use one would think if you want to have a perfect ground you keep the distance close to your device and use some substantial wire for that.. but they don't so what does this wire?
I don't think so! You really need to read more
To lancalV.
Ordinary MA use Direct Current for amplification of Amplitude Current.
I think there is no FE in MA only.
Current came from Accumulators.
If Tariel steal energy from grid, than Figure 9 is candidate of "magic".
But...
Just think little bit different!
If we get super mega magnetic material with Supermaloy or beter magnetic properties, we can save DC.
Chubinidze use Supermaloy(Пермалой).
In Audio Amplifiers Supermaloy use for Small Signal amplification.
Because of High Efficiency transformers was small, but effective in 20-20000Hz.
But material is very expensive and I have no money for experiments, but I use very
small piece for 25Hz flutter and wow elimination. Very effective!
Quote from: Ansis on January 19, 2019, 10:13:24 AM
To lancalV.
But...
Supermaloy ? What to do? to Mhz resonance ?
there is no magic core there.
To lancalV.
What current comes from accumulators? Please expand on your statements.
To Hoppy.
You must read that.
It was respond to lancalV link.
Hello Ansis, a new beginning ? ;)
Okay,
A. http://www.nutsvolts.com/magazine/article/the_magnetic_amplifier (http://www.nutsvolts.com/magazine/article/the_magnetic_amplifier)
Figure 3,4
B. https://m.youtube.com/watch?v=lB3HBoKPbOQAC (https://m.youtube.com/watch?v=lB3HBoKPbOQAC) AC-circuit + DC-controle circuit
C. https://m.youtube.com/watch?v=cBFAe3rArCg (https://m.youtube.com/watch?v=cBFAe3rArCg)
Comment : 2nd poste Alex Manzanero then Doug Konzen
https://m.youtube.com/watch?v=QoYDbHhbaNY.
(https://m.youtube.com/watch?v=QoYDbHhbaNY)Part 6
https://m.youtube.com/watch?v=pDXKnk9hFMI (https://m.youtube.com/watch?v=pDXKnk9hFMIPart)
Part (https://m.youtube.com/watch?v=pDXKnk9hFMIPart) 5
https://m.youtube.com/user/kdkinen (https://m.youtube.com/user/kdkinen)
EMF + MMF
https://m.youtube.com/watch?v=RIAQvvfAE0M (https://m.youtube.com/watch?v=RIAQvvfAE0M)
EMF + MMF
https://tesla3.com/hilden-brand-jack/ (https://tesla3.com/hilden-brand-jack/)
"..Double the flux lines four times the force... " electromagnetic valve a. DC circuit b. Impulse DC a2. force amplifying b. force neutralisation
1 x AC- circuit + 2 x DC circuits
Magnetic Amplifyer circuit feed and battery feedback circuit ? ( Made in Algerie)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true& (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19831209&CC=FR&NR=2528257A1&KC=A1#)locale=en_EP&FT=D&date=19831209&CC=FR&NR=2528257A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19831209&CC=FR&NR=2528257A1&KC=A1#)
The above feed and feedback circuit also useable here :
https://worldwide.espacenet.com/publicationDetails/description?CC=JP&NR=H11204353A&KC=A&FT=D&ND=3&date=19990730&DB=EPODOC&locale=en_EP#
Quote from: Ansis on January 19, 2019, 11:23:22 AM
To Hoppy.
You must read that.
OK. You were referring to the MA DC bias current. What do you think would be the effect of using a pulsed HV DC bias current as I suggested in my earlier post- 2399?
It appears I have a different perspective than at least some of you guys on this. :) I think that the energy
source may at least possibly be the surrounding 'ambient environment' as Kapanadze has said,
meaning not specifically drawing the extra energy from the ground in some sort of classical way (not a
classical electrical energy 'receiver'). What the exact mysterious energy source might be is anyone's guess however. :)
My view about this possibility is based on some observations of these type of setups, but also based on some
things I have observed in my experiments in the last two to three years as well.
I have mentioned that I have been experimenting on a setup that is not related to Kapanadze setups or similar,
and up till now I have not seen anything in my tests that would really suggest 'OU', but in the last few days
I tried a new variation, and with some new adjustments last night I see something that I will say is 'potentially interesting'.
I have been at this type of experimenting for quite a few years so I don't jump to any conclusions at all when
I see something in my testing that is showing something potentially interesting, but my latest test setup
is at least showing some *possible* potential. :) It is only very low power right now and I will need to investigate a lot
further to see if I can scale this 'effect' up with the eventual goal of trying to make the setup self-looped. The power
output is just too low right now to try to self loop it.
Basically I am testing with a 12V 5AH SLA battery and only powering a very small load that measures total
battery power draw of about 19mW (I know a very tiny load for 5AH battery :) ), but the voltage on the battery
has not dropped below 13.20V for about 12 hours of continuous running so far. I have been using this type
of SLA battery in my testing for several years and I know those batteries will normally quite quickly fall
below 12.9V even when powering such a small load, even with some energy feedback to the battery.
My current test setup has feedback back to the battery as well, but it is holding (so far) at 13.20V. I know
what specific changes I made to get this new type of result. It is way too early to say if my latest test setup is
really drawing in some 'extra energy' or not however, (and as we all know, chances are it isn't), but the results so
far are at least interesting.
The setup does not rely on any earth ground to work. I am making no assumptions here about OU whatsoever
as it is way too early to try to draw any conclusions, (I know better than that ;) ), but the reason I am mentioning
all this is this setup is testing a specific type of approach to try to draw in extra energy into the system, and
it has nothing to do with drawing in extra energy from the ground. If by some small chance it really is drawing
in extra energy from outside my test setup, then it is not coming from the ground. It would have to
be coming from the 'ambient', whatever that might be. :)
Question for Hoppy or anyone else with an electronics background or experience with opto isolators:
I am using opto isolated Mosfets (opto isolators driving the gates) to try to avoid any potential coupling
of energy from the Mosfet driving circuitry (energy coupling from the gate drivers to the drain/source).
In your experience/estimation, could any energy still couple from the gate drivers to the Mosfet
drain/source if I am using opto isolators to drive the gates of the Mosfets I am using? One possible source for
extra energy in my test setup might of course be the gate drivers if the opto isolators can still capacitively
couple energy from the driver circuitry through the opto isolators to the drain/source side of the Mosfets.
However, if energy could be coupled through an opto isolator that way, it would kind of defeat the
purpose of an opto isolator completely isolating the gate driving circuitry from the transistor itself, no?
The operating frequency for the mosfets in my test is below 100 Hz, so any coupling due to capacitance from the
gate driving circuitry to the mosfets should be small anyway at below 100 Hz, I would think anyway.
Any feedback on this from anyone with experience with opto isolators will be appreciated. :)
Quote from: Void on January 19, 2019, 01:17:40 PM
drain/source if I am using opto isoaltors on the gates of the Mosfets I am using? One possible source for
The current frequency for the mosfets is below 100 Hz, so any coupling due to capacitance from the
Hi Void,
I would hope not given their electrical isolation spec!
In regards to your experiment, as you will probably appreciate it is very unlikely that even if you use the same battery, intervals between tests will alter results. This is why, if you recall, that JB best practice test guidelines were to always condition LA batteries over a number of cycles before doing a number of load tests (at least 10), then averaging the results on the number of load tests conducted. Comparing results with long time intervals between them, despite using identical test setups, when using LA batteries, especially SLABS, is not good science in my opinion.
This is very interesting, since in my perspective you cannot get extra energy using classical methods. Like how I see a transformer is that L1 agitates the ambient and as a result you get energy in L2. The problem here is that in L1 you return the energy to the negative rail and it destroys the source. So L2 is free energy minus some resistances or what ever and it can't ever go over what L1 was taking.
You might not see the same as I do or you might claim I'm just full of bullshit, but maybe you can admit that just by changing the perspective you can now see a transformer in a new light AND you are already using free energy. So the OU question is how to agitate L1 without destroying the source?
Quote from: Hoppy on January 19, 2019, 01:42:22 PM
Hi Void,
Hi Hoppy. Thanks for the feedback. Regarding the SLA's, perhaps, but sometimes you just have to
be practical however. Little SLA batteries are very convenient for doing bench testing where you
want to try to feed back energy from the circuit being driven back to the supply battery. I have been
testing with these same SLA batteries for several years now and I know their characteristics quite well now
at different current draws. Even with very small current draws these small 5AH SLA batteries
will always drop from their rest voltage down to about 12.9V at least within about an hour or so, if not quicker,
depending on the exact current draw, and then continue to fall from there at a slower rate. I do know
for sure that the SLA battery I am testing with holding at 13.20V for over 12 hours now with a
measured current draw of just below 1.5 mA on an analog ammeter with a 10mA full scale, is at least out
of the ordinary for these batteries, and I have done a lot of testing over the last few years with these same batteries.
At any rate I am not attempting to draw any sort of conclusions at all yet, as I have mentioned. I am currently
looking for possible mundane sources of 'extra energy' into my test setup that uses opto isolated mosfets , so that is
why I was asking for opinions on the the opto isolators, for example.
Something else to keep in mind here about lead acid batteries is that their charge and discharge efficiencies
are apparently rated at around 50% to 90%, depending on the exact lead acid battery type and how new the
lead acid battery is, and the operating conditions, etc., so when current is drawn from a LA battery there
is energy loss in the internal resistance in the battery, and energy is also lost when charging a LA battery as well.
I think it is not overstepping too much to say that a 5AH lead acid battery holding at 13.20V after 12 hours with a
measured average current draw of about 1.5 mA isn't too bad, even if it has nothing to do with OU, which
the chances are. At any rate, it will be interesting to see if this current test setup continues to hold at 13.20V
for much longer, or if it starts to fall off soon. :)
Hi Belfior:
I have an open mind. I have actually considered and looked into many things over the last several years.
Don Smith was the first I personally came across to throw around ideas about drawing in energy from the ambient.
I have tested many different approaches over the years just to get a better understanding of how different
arrangements really perform in practice. Often, certain approaches outlined in forums like this don't work at all
as claimed when you actually test them and put them through their paces. The main problem is this, all circuit
components have losses. Batteries have internal resistance as well so batteries have losses just from drawing
current from a battery. Capacitors, diodes, and transformers and even air core coils and have losses, as well
as active devices like transistors as well. Loads connected to the secondary of a transformer reflect back to the
primary side for all intents and purposes, and thus increase the overall power consumption. This is why some people
have tried to build specially wound 'lenzless' transformer designs, but from what I have seen that approach
has not proven successful, at least from what I have seen. Lenz law describes why a coil or wire acts as a coil
or wire, so beating Lenz law seems to not make sense to me. To achieve OU, we have to overcome all sorts of
losses in our circuit setups, so the only way I can see that happening is to be able to draw in extra energy from
outside your test setup. This would have to be quite considerable to overcome all circuit losses in a typical scenario
I think. It is therefore not an easy task by any means, IMO. :)
P.S. An update on my test setup. Just measured the battery voltage and it has now finally dropped 0.01V
down to 13.19V. Not bad I think considering the battery's unloaded rest voltage after charging and then sitting for
a while was around 13.28V. This is the best results I have had with this type of setup so far, so I seem
to at least be making some small improvements in overall efficiency. :) Based on these latest results I
think it is worth my putting in more effort to try to improve performance further and to try to scale it
up to higher power. I typically only have some time on weekends lately to work on it, so it will
move along slowly. It's a time consuming process... It can take a lot of thinking and work and testing, etc.
just to make tiny gains in efficiency. Not saying anything at all about OU, just working on trying to make
improvements to the overall efficiency. :)
To Hoppy.
There is Classic Physics and "Underground".
In real life we just make circuits.
In FE? field, which is more like "magic", we try to make play like alchemy guru's, but "are we guru's?"
All that what we know, see, think is more like an illussion.
Because it is so much easyer to fake something than try to give explanation of that.?
OK.
Let's be honest.
I have no FE device.
No of my friends in Latvia is not have FE device.
To fake FE is simple.
We take "pipe".
We take "nothing" and pipe+nothing=something.
Easy.
There is many David's Copetfield's.
Remember Train which wanish?
Magic?
Or trick?
P.S. For me is important to understand, who is lie'er, who is scam'er and where is possibilities of something I don't understand or don't know.
Dear Hoppy, I am ordinary and I don't know is DC Current Spikes can make magic, but there is MF Amplification in that process. Polar Pulse? Unipolar? All FE community is so stupid, because we not collect results!!!! We just blahh blahh blahh. No. Everything must be documented, shered, published and "team" must be learned of members try's, errors, discoverys... It's not happening. Only fight... If you really want proof/ reject something which is related with FE? than we must take action and say: Yes or No (Jesus words).
I hope You understand.
Smile.
Hi Void,
Thanks for your reply. I spent around four years and countless hours running in depth battery load testing with Bedini energisers using SLA and wet cell LA batteries. The Peukert effect at fractions of the C10 discharge current levels, gives some very surprising results as you are observing. JB used this effect, coupled with a degree of inductive back spiking helping to desulfate / clean plates, to run some of his energisers for many years on small LA batteries.
Hi Ansis. There is nothing at all wrong with the idea that people could potentially make better progress
here if everyone worked as a team and openly shared their knowledge and work and test results, etc.
However, in reality it is a very small few who really do the actual work and put in the long hours experimenting
and who really know what they are talking about. That is the real problem. People will tend not to be so inclined
to share too much of their hard work and hard earned knowledge in situations like that. It is understandable, no? :)
Yes. I know, understand.
I hope someone proof fake or make FE? in one day!
But, I don't believe.
Perpetum Mobile is more than 100 years old, but never exist!
Good night!
Quote from: Hoppy on January 19, 2019, 03:58:32 PM
Hi Void,
Hi Hoppy. Thanks. Yes, I am well aware of all those things. However, I have probably run about
40 or 50 test runs with close variations of this particular arrangement alone in the last couple of months,
so I know well what is normal discharge rates for my specific setup and what is out of the ordinary.
The latest results do appear to be somewhat out of the ordinary compared to all the other test runs. However, I certainly
could still be overlooking something which is contributing to the seeming out of the ordinary results I am seeing,
and I am still looking into it to see if I could be overlooking something. No one said this type of experimenting is easy. :)
It really takes a lot of careful analysis and testing to try to avoid getting tripped up. Ha ha.
Quote from: Ansis on January 19, 2019, 04:09:03 PM
Good night!
Hi Ansis. You seem to be confusing 'perpetuum mobile' with a system
that has a COP > 1. I suggest you read up on heat pumps to get an idea of
what COP > 1 means. People often use the term 'over unity' because it is a
relatively commonly known term, but COP > 1 is the correct way to describe how
a free energy setup would supposedly work. :)
Quote from: Ansis on January 19, 2019, 02:52:40 PM
Smile.
Hi Ansis,
Yes, I do understand you. I agree that scientific method and team work is almost completely missing from these threads. Nonetheless, the threads are a source of information, true or false, to encourage thinking. Certain ideas have motivated me to experiment as I enjoy chasing the FE rainbow but not in a really serious way now that I'm retired from working for a living. There are other forums better suited for serious research but I like this one for a good general chat on FE concepts.
Hi all it might be a strange observation but to build something we need to know how it works and some idea
of some hardware to build apart from the circuit, I published on here what else is there?
That is correct alien gray..
The way i understand it is the interpretation of the current displacement theory
of Maxwell or who ever the genius was. I watch the video of that lightning strike,
and what i observe is the igniter or seeding of the whole process happen from the atmosphere
and then the eternally charge earth respond. so the kapa circuit does the same but has to be at resonance
and in synchronization with the train of the standing wave set up in the earth line. One thing very very
important is the earth rod has to be super connected to the earth ground.
@ VOID, to prove that an air conditioner is an over unity machine is easy.. It can more
efficiently cool your room and heat up water simultaneously than just cooling your room..
That has to be proven, but from my little experience that is over unity..Not by this observation,
but by calculating the electrical power consume as per the work done.
Quote from: seychelles on January 19, 2019, 11:36:19 PM
Hi seychelles. It is not over unity. For example the electric circuitry and electric components in a heat
pump are not producing more energy than they are consuming (which would be over unity), the heat
pump is pumping heat from one place to another. If the total energy in the heat that is pumped
is greater than the input electrical energy being expended by the heat pump circuitry, then
that would be a COP > 1. Look up coefficient of performance (COP) if you want to learn more about it.
All the best...
What i am saying is that if a person calculate the time it take to cool a
1liter condenser, of water and heat up a different 1 liter evaporator of
water simultaneously one will come to the conclusion that the electrical power consume
in this process compare to work done is cop >1..
About heatpumps.
There is 1 Country which have Heatpumps with COP>10000 or more :)
It is Iceland.
Because they have Vulcanic heat for Free! :)
In Latvia where is cold in Winter, we are not so happy.
Peoples who make very deep drills in to the ground, get better results, but if they make cheep
setup, then COP≤1. I know many real stories...
Quote from: Ansis on January 20, 2019, 02:34:36 AM
About heatpumps.
It is Iceland.
Searchmachine : Super Deep Fusion Drilling
Each place on earth can have this " Vulcano-deep whole"- dis-/advantage and explore potential
Quote from: seychelles on January 20, 2019, 01:02:59 AM
https://www.google.com/search?q=hot+cold+thermal+generator&client=firefox-b&oq=hot+cold+thermal+generator&gs_l=mobile-heirloom-serp.3...21730.26639.0.27274.9.9.0.0.0.0.225.1382.1j7j1.9.0....0...1c..34.mobile-heirloom-serp..2.7.1058.SjivexS_WCA (https://www.google.com/search?q=hot+cold+thermal+generator&client=firefox-b&oq=hot+cold+thermal+generator&gs_l=mobile-heirloom-serp.3...21730.26639.0.27274.9.9.0.0.0.0.225.1382.1j7j1.9.0....0...1c..34.mobile-heirloom-serp..2.7.1058.SjivexS_WCA)
A very cold side for free ( Ant-/Arctic )or a very hot side for free ( Solar concentrating Tower ) ?
Or a cold/colder/coldest cascade ( - 180° C ) Schukey Delta Omega Machine :
https://www.google.com/search?q=schukey+delta+omega&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=schukey+delta+omega&ie=utf-8&oe=utf-8&client=firefox-b)
Probably also by analyzing : "Diode" ! Material, configuration, function in a conductor, effect
and micronizing such idea :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1#)
for example for up to 2000x solar field concentrator cells as cooling device or Plasma charge controler
Easier : an " endless belt, bimetalic" , hot bassin and cold bassin and belt moving from hot to cold to.....
Endless belt motor :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+motor&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+motor&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=)
Endless belt generator :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+generator&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+generator&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=)
Endless belt converter :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+converter&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+converter&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=)
Quote from: Void on January 19, 2019, 04:16:19 PM
Hi Void,
The problem in getting any meaningful results is that the useable capacity of an LA battery is clearly very dependant on the condition of its plates. Repeated load test cycles conducted with short intervals between them will show small improvements until the battery condition stabilises, which can take many cycles. Starting a series of test cycles after a few days rest will again exhibit the same general behaviour. The other problem is that equally timed re-charges from set voltage data points do not return equal amounts of capacity to a battery, so with non-linear charge and discharge curves, attempting to scientifically establish that there is a real FE effect when experimenting with LA batteries is in my opinion futile given battery vagaries.
Void, there are " battery charger" studies : with-/ out software controle
By LA-batteries : memory-effect, the first load DOD sometime decides!
THE MOTHER AND FATHER OF FREE ENERGY IS EFFICIENCY AND
ONE NEED TO KNOW WHERE THE ENERGY IS COMING FROM. So ansi is
half correct, so here in Seychelles it is bloody hot and 80% humid, so the energy
is already available from the ambient air.. The air con is a very efficient heat pump.
I rest my case SOORY STIVEP..
Well this was something I wasn't think I ever see. Egyptian djed pillar made out of stone
https://www.youtube.com/watch?v=-cPuMugnCvQ
maybe tesla coils or other coil under it. I never believed djed was a battery, but a series cap
About Bedini and LA batteries.
I work much with accumulators and everything which is done by Bedini is BS.
Sorry fans, I love true.
Battery is simple device and every battery die.
LA die of staying a side.
Just leave it without charging and it is dead.
LA must be Always under DC Current with Voltage which is more! than 6×2.1V=12,6V.
I have 13,2V on battery in Winter time always.
I use LM317 chip which works beautifully.
With Voltage allways connected LA battery can work 5-7 years.
Death is comming if we drop LA battery with Undervoltage.
It is 10V.
Never do that.
There is Rick Friedrich.
Listen about Bedini from him, BUT!!! He is sometimes shoot BS too.
He is right about plate deformations.
All other his theories is sometimes right sometimes BS.
Be wise!
Always!
Good advice Ansis. :)
Hmm Lead Acid are crap I have one for my shed roof solar panel the LA cost a fortune and it wastes 50% and the regulator wastes another 30% of the energy I have some super caps I got when an electronics company went bust my advice is dump the lead acid and get Super caps as the price comes down
Another thing The Akula device and Adrian Gustove machine has anyone got it going or had any results with it yet?
Only with Wesleys posting and Solar's posting there might be some other avenues to explore with the phase shift
rotating memento.
Only wasn't it strange how everyone had toroids working with a ring of PP3 batteries in them then it all died ;D ;D
Joking apart though what happened to all Akulas designs?
Nope.
Quote from: Ansis on January 20, 2019, 05:58:37 AM
It is 10V.
Never do that.
Be wise!
Always!
I have to thank Rick Friedrich for putting up all the don smith videos on YT, but I do not care for his theories that much. He is a Bedini funboy and worked with Bedini. Not a big fan of Bedini either. What is his legacy in this world, if we still have no free energy?
Yes, I see the storage also actually as hurdle,
calculating with max. 40% battery capacity to load and only 300 cycles (~ 100% DoD) lead batterie-set makes the free energy delivery 300-400% more expensive !
Interesting Dick Fradella his charge-device, he wrote in his older eartlink pages about life expectance expanding from a 90- days battery to 10 years ( 3650 days) daily use ! ( DoD ? Accumulated Output ? )
With positive and negative user/ criticaster feedback in the internet- heaven/ he'll :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.bticcs.com%2Fpub.htm (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.bticcs.com%2Fpub.htm)
About cap-"ery" technology progress as example ( Eestor, what's happened?)
http://kilowattlabs.com/ (http://kilowattlabs.com/)
and Stanfords 200,000 cycles peak device : https://newatlas.com/nanowire-electrode-hundreds-thousands/42926/
Note the Don Smith device charges up a cap much like a TV set scan circuit then at peak voltage it dumps the lot into the
LOPT and the flyback emp produces a huge spike of EHT but the protocol has something missing it's not ready for the next
cycle in the Steven |Mark video the other guy talks about using 8 spark plugs at 600hz
In fact for proof of Spark Amplification, we need only plastic pipe,
6 windings of Inductor, 6+6 windings of fat wire about 2-3mm(2) .
Than we need Darlingtone transistor (30W) and Induction Coil of Car+PC generator of impulses.
Than we need experimenting with "inside".
Bifilar? Normal? With core or not, with Ferrite rings/Magnets + Earth water pipe.
Thats all.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529449/topicseen/#msg529449 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg529449/topicseen/#msg529449)
#2084 : WHz
https://en.m.wikipedia.org/wiki/Radiant_energy (https://en.m.wikipedia.org/wiki/Radiant_energy)
Spectral Flux
Spectral Intensity
Spectral Radiance
Spectral Flux Density
Spectral Radiosity
Spectral Exitance
Spectral Exposure
More : Radiometry, Photometry
Quote from: Ansis on January 20, 2019, 07:41:59 AM
Thats all.
Ansis,
With respect, if you want people to fully understand your circuit idea, please draw a schematic. Your written description makes no sense to me.
Coil Kapanadze.
The material was a few days on the net and was removed.
Someone makes sure that information is not leaked.
Shown step by step on how to do it.
To Hoppy.
Go back in history here in chat.
You will find original? Kapanadze drawing and my version of "what I see".
I think you will understad everything.
Just go back and scrool chat.
Ansis, from Russia and C2= granted but international classification : H02N11/00 = alleged perp. mob.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=5&adjacent=true&locale=en_EP&FT=D&date=20131110&CC=RU&NR=2012118402A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=5&adjacent=true&locale=en_EP&FT=D&date=20131110&CC=RU&NR=2012118402A&KC=A#)
Kapanadze : air core transformer ( ionizer tube) and converter
https://en.m.wikipedia.org/wiki/Air_ioniser
(https://en.m.wikipedia.org/wiki/Air_ioniser)Electrostatic discharge ionizer or balanced ion generator
https://en.m.wikipedia.org/wiki/Static_electricity
Quote from: Hoppy on January 20, 2019, 08:25:27 AM
Ansis,
Hoppy does Ansis mean a Car Plug Coil ?
but you can wind 6+6 turns on a TV EHT coil and get loads off volts off it too
If you does see that video of Kapanadze, just look another time.
What do you see?
All Kapanadzes videos with original? Kapanadze drawing give very many information.
Very many peoples don't understand simple thing, Primary is Spark coil coil with Inductor.
Secondary is Output.
Thats all.
Super simple schematic.
There can be variations in connections.
Video: https://youtu.be/ceDEIg9ETbA
https://www.britannica.com/biography/Joseph-Henry (https://www.britannica.com/biography/Joseph-Henry)
That's all?
Motronik : internal or external ( air) combustion engine process
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.powerboxer.de%2Ftheorie-technik%2F48-leistung-und-zeitpunkt (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.powerboxer.de%2Ftheorie-technik%2F48-leistung-und-zeitpunkt)
Quote from: AlienGrey on January 20, 2019, 10:19:30 AM
That's what he says in his post above.
I take some pictures.
Just look and compare with original? drawing of Kapanadze.
We see. 2 parts..., but in GreenBox original? there is 1 Coil which is 2 Coils in one.
I call it "Matrjoshka" coil, it is from Russian Wood Doll, there is many smaller parts inside of Wood Doll.
Quote from: Hoppy on January 20, 2019, 10:39:52 AM
all the postings in-between were not posted between my post and then, but point taken.
Ansis yes that device and modules along the back wall have you any idea what they do ? because I haven't and he must
have batteries stored somewhere and capacitors and in the middle is that card with all those devices with heat sink tabs on
them 'mind-boggling' or is it all BS ?
Did you see my "yellow" picture?
There you see 2 generators.
One 50Hz, second is Auto Car Induction coil which is for Spark generation.
I think all is working with 50Hz frequency for "water pipe" energy sucction from the grid.
Yes, yes, I know.
We must proof or reject that.
Thats it.
To Alien.
There is Battery.
Of course.
No FE.
But!
Stimulation is only small amount of energy and there must be loop for recharging.
Quote from: Hoppy on January 20, 2019, 05:07:07 AM
Hi Void,
HI Hoppy. Thanks for the comments. Yes, as I mentioned previously, I am aware of all of those
factors and taking it all into account. Also, as I mentioned, in the last couple of months I have done
about at least 40 test runs with my test arrangement with small variations. I therefore of course
have a very good idea of what is within normal variations for the battery and setup I am testing with and
what is not. :) I also mentioned that I am not attempting to draw any conclusions at this point, so
relax mate. :) Everything is well under control and very scientific. Couldn't possibly be more scientific. Ha ha. ;)
As I said before, if I think I see something that looks potentially interesting, I will try to scale it up
to higher power if possible, and with higher power I should be able to analyze better. Despite
what you say, if you leave a test setup using a battery running appropriately long enough with a reasonable load,
it will most definitely separate the wheat from the chaff. I won't attempt to draw any definite conclusions without
doing all the appropriate testing first. You probably won't find a more cautious experimenter in this area than myself.
I don't try to draw conclusions unless there is very good reason to. Everything is well under control. ;)
That's good news Void. Good luck. :)
Quote from: Ansis on January 20, 2019, 11:21:44 AM
To Alien.
There is Battery.
Of course.
No FE.
But!
Hi Ansis,
If there is no FE why is Kapanadze putting on these elaborate demos?
To Void.
I am very sorry, but if you never ever put your LA battery under 10V, than your battery go long way.
It is very important for everyone to know, Battery's love Current Charging which is 10 times less than Maximum Capacity.
Bedini type of Charge is Pulses.
It is very bad.
I am so sorry.
There is impulses, without Constant Current.
It is bad.
Battery MUST WORK!
It means we must charge/ discharge it!
LA is must be discharged to 10V, not more!
LA go to Sulfation when under 10V.
______________________________________________________
If you want your Smartphone/Laptop/Tablet battery work 5-7 years or more do simple thing.
Discharge to 5% of energy, emediatly charge it to 100% if you will use it now, if not, charge to 90%, switch off.
LiPo dont love storage with 4,2V.
Storge is good with 3,6V on element.
My electric bike battery storage voltage is 3,6V in Winter, when I not drive.
To Hoppy.
Kapanadze want 1 000 000$ for his device, but I think, that is not FE.
Do you think, Turks are stupid?
Thay does understand his trick.
I think like that, because no one is interesting in his device.
Only we, strange peoples.
Quote from: Ansis on January 20, 2019, 12:08:19 PM
To Hoppy.
Agreed! ;D That suggests that the fake was so simple you will laugh.
Quote from: Hoppy on January 20, 2019, 12:10:03 PM
No, it suggests that you guys are blindly speculating. ;)
Quote from: Void on January 20, 2019, 01:23:23 PM
Yes, we all are in the absence of any real evidence that the devices are genuine or not. ;)
Anyway, I think we are now ready for another drenching from surface wave spec! :o ;)
Nick,
If we dig any deeper we'll bury ourselves! :D
Don't we just love this thread. ::)
Will the real free energy device please stand up. ;D
I see lots of room for digging yet.
I dig, therefore I am. :)
Quote from: Void on January 20, 2019, 01:59:20 PM
Well, I'm just wondering how long the elephant intends to stay in the room.
Nice!
Today we start to think right!
Because of understanding of "fake nature of FE".
All these years peoples believe in possibility of "energy from nothing".
It is not possible.
Energy is from somwhere. Wind, Solar, Waves, Flow, Heat e.t.c.
Kapanadze coil is only extracion of Energy from grid?, medium?,
EM field through "water pipe" ground?
I am happy, because today we all understand it!
Hurray!
Hmm sounds like I've missed the shuttle to zeta reticule again back to Serpo! ;D 8) 8) 8) it's a bright sun!
So where is Ansis's yellow picture ?
I post it here again?
I posted it in Overunity.com, but where?
OK. Take it.
And Kapanadzes original? picture too.
Quote from: Ansis on January 20, 2019, 04:28:30 PM
Yes I have seen that paper on another posting you made but not on OU :o 8)
but thanks anyway. It's certainly an interesting idea. but not enough information he obviously knows much about stuff than us mushrooms in the west, kept in the dark and fed BS that's us!
I don't agree that we need to charge&discharge batteries. I think we need to charge a cap with a battery, but then use that charge to do something and not let it go back to the negative rail.
If you charge a cap you just made the battery terminals a bit longer. You lost something in the resistances, but you didn't send mass charges into the negative terminal thus destroying a part of the polarity&potential. You need to remove the perversion from the circuits and that is the return line. You gotta to be a wizard to make up for all that energy you just used to destroy your own battery.
I think you can pretty much use any device for OU, if you just stop destroying your own power source.
Is there a way to raise voltage and then zap it back to the source? Connecting positive to positive has no effects, but what if you zap back something like the displacement current?
positive terminal -> DC pulse -> coil -> diode -> load coil -> cap plate1 so then we got load coil or cap plate2. one we use for load and one we use for recharging the battery
About" FE" battery tale.
All Bedini's and Beardens and others show something which is not exist in real life.
All they's motors, wheels and others kind of "magic" works in "no state" situation.
In real life, which is charging and discharging of Real Current, the only think which can save
accumulator today is to put parallel supercapacitors with accumulator, but price and selfdischarge is
situation when all that together is BS. :)
There is 2 bad situations when battery go dead.
First, battery is overdischarged with heavy loads+heat+physical damage of battery.
Second is scenario when battery work in soft mode without recharging properly.
To avoid that, we use proper batterys and chargers.
Some peoples use HiFrequency to "rejuvenate" battery.
It is BS.
When LA is sulfated, that is finish.
There is no real possibilities to make it new again.
I spend more than year to "play with magic devices", it is BS.
This video of Master IVO is about Kapanadze device.
There is Ground+Bifilar interactions between.
https://youtu.be/xHDrmGPY-78
There he is doing something which is about "strange" voltage rise on the Capacitor which is
conected through Abramenko plug to the ground(water pipe).
P.S. All that is important when we try to put "Kapanadze puzzle" together.
Yes and this video too.
https://youtu.be/uhY27Zoor-Q
About Tesla bifilar coils properties.
He say, That type of coil have Standing Wave properties!, at Resonance frequency.
It is very "resonate" with my understanding of Kapanadze generator working principles.
Quote from: Ansis on January 21, 2019, 10:21:38 AM
https://youtu.be/xHDrmGPY-78 (https://youtu.be/xHDrmGPY-78)
From the video I can see lack of understanding of classical properties of electromagnetic field .
First there is no such thing like "
dielectric field."Quotedielectric field can sometime be seen as:
The average total electric field acting upon a molecule or group of molecules inside a dielectric. Also known as internal dielectric field.
There is not
static magnetic field in AC .However at the beginning
of video it is clear +/_ suggesting
DC.
But than we dealing with high current in
DC circuit,and than there is no capacitance in DC for that coil.There is no
fluctuating capacitance in DC.Every aluminum foil based capacitor can be converted to bifilar Tesla coil pancake structure.
Only for AC we are talking about significant capacitive reactance in this structure.
For AC at 645kHz the third coil acts as secondary coil of Tesla coil structure .
Since we are dealing with resonant transformer the ratio 2:1 cuts 50% of the voltage and that equals
50V.
[(two primaryP connected in series = P+P at 100V)-( second winding equal to single primaryP)] = P =50V
Than connected to Avramenko Fork
The effect is NOT due to "dielectric field" of bifilar coil.
It is due to phase delay on the single wire transmission line where two ends of the diodes are indicators of delta T slow wave delay.
In this article :
http://www.doctorkoontz.com/Scalar_Physics/Avramenko%27s%20Plug/single%20wire%20power%20transmission.htm (http://www.doctorkoontz.com/Scalar_Physics/Avramenko%27s%20Plug/single%20wire%20power%20transmission.htm)
Wesley
https://m.youtube.com/watch?v=Dnrm8jT_6B8
Minute 6:00 : multimeter un touched/ touched : +- factor 10x
In my "yellow" picture I draw "direct amplification" circuit(not correct, but principle),
with output of 50Hz 220V.
But in Masters Ivo video which is here: https://youtu.be/KbtK9jrk_JI
We see another possibility(of course he work with wall power and water pipe),
of possible Kapanadze device explanation.
If he is capable to charge capacitors in very quick time, than Kapanadze type device,
can be DC to AC converter(but in Kapanadzes video there is only small boxes).
Of course we look at any explanations.
Why is this video important?
Because Kapanadze use that Abramenko plug for 1 or many purpoces.
it's getting bether and bether :o
waiting for the next bombshell of nothing 8)
"From the video I can see lack of understanding of classical properties of electromagnetic field .
First there is no such thing like "dielectric field."" Wesley..
Eric Dollard in this 1987 video at 8:18 min talks about "Dielectric" fields..
https://www.youtube.com/watch?v=2HaqcuRCsEE (https://www.youtube.com/watch?v=2HaqcuRCsEE)
Classic borderland labs video from 1987. Eric Dollard gives a demonstration of the two sides of electricity, the decaying electromagnetic side and the growing dielectric side, and shows his singing Tesla coil burning Golden Ratio patterns into wood. Peter Lindemann demonstrates his Rotating Parametric Transformer operating at 108% efficiency. Shows an Alternating Current N-Machine providing the researcher with AC waveforms directly extracted from space. Amazing science from the golden days of borderland research!
Acca..[/font]
Oh come on we know what Clark's game was and I don't buy into that game, we are more likely to end up like Venus burning fossil fuel and blowing shit into the air since that's the way to create an atmosphere on Mar known as terraforming.
What's your next excuse Solar? 8) :)
Quote from: stivep on January 21, 2019, 01:49:47 PM
Great! Then I think he has a fair chance to find something useful...
Today, I decide to prove something and I do.
At first we need 2 parts of devices.
One part is that HiVoltage transformer from ebay, I
gave a picture before. It is Joule Thief type device about 1,4$.
Second device is Impulse power convertor from Main 220V50Hz to 12V DC.
I use Z323 Logitech converter(it was laying around).
Setup is very simple. I charge capacitor on the Z323 with HiVoltage.
When Capacitor is reach about 150V DC in that moment power supply STARTS
and LED lamp consume energy which is stored in Z323 capactitor and FLASH out.
This is trusty experiment, because we see difference in charge/discharge time of
different kinds! of setup.
I will prove that, we can cheet when we work with old equipment in my case
C1-68 old russian type osciloscope.
Experiments is split in 2 parts.
Direct Capacitor charging without "ground" of Osciloscope connected to Z323 Capacitor (-) terminal.
Direct Capacitor charging with "ground" of Osciloscope connected to Z323 Capacitor (-) terminal.
Direct Capacitor charging with "ground" of Osciloscope with reversed AC terminals (Main cord of Osciloscope) connected to Z323 (-) terminal.
Second part is the same, but I use "water pipe" like "ground and Abramenko plug for Z323 Capacitor charging.
I will make schematic drawings and pictures with results in new post.
I use LiPo 18650 battery and Current consumption was 1.5A and Voltage was 3.0V under Current conditions.
I post here 4 pictures.
First with parts. (Is changed to Fourth)
Second with First experiment where I connect JT output to Diode Bridge.
Third with Abramenko plug connection.
Fourth I explain why "so strange results" is achieved.
Quote from: Acca on January 22, 2019, 06:47:17 PM
Acca..[/font]
Group of loved by us renegades, not significant enough to become icons of fame for our children is shrinking.
Eric Dollard was young renegade before he becomes old homeless.
He was proposer in front of crowd, watching him asking lady physics.
The crowd was important to him, not Physics
opinion of friend:
it's a guy sitting on a hill (he says that he has to do this out in the bushes - why, are the "guys in black" going to swoop down make him "gone"?),
reading from his self published works, pointing at the pages in his hand, suggesting the audience purchase his work to be able to follow the diagram,
showing a bunch of blurry over-exposed photographs without really explaining the whole set-up.
He shows high wooden poles and concrete blocks and describes what used to be there...
It's a 20 year old video, citing research finding that occurred before the turn of the 20th century, using outdated, discredited concepts from the history of science.
He talks of Luminferous Aether!
This was a popular concept disproved by the Michael-Morley experiment in the 1880's!
Even great mind's like Hertz can be wrong about some things (probably many things), many of the greatest ancient philosophers
believed that rotting flesh would spontaneously produce maggots (the idea that flies laid eggs in the flesh was not yet known).
It kind of reminds me of "Alien Autopsy" videos...
This idea that RCA was a shadow branch of the United States remains unproved to me.
As far as I know RCA was created when General Electric bought
The American Marconi Company and re-named it RCA, both companies are and were privately held business.
I have a lot of problems when he reads stuff like "infinite velocity" and "totally lossless".
These are at best theoretical concepts and do not exist in this world of ours, yet Dollard scatters them about.
Tesla may have believed them, but science requires proof, not story telling.
I don't care what Tesla, Dollard, or for that matter
Erasmus and Aristotle wrote - electromagnetic waves do not travel faster than the speed of light in a vacuum.
In order to refute that they have to actually show this happening!
He mentions "Archetypal Flow of the Aethers in Nature" - what does this mean?
In my humble opinion absolutely nothing. He cites Wilhelm Reich the Orgone discovering Psychiatrist in the middle of this ramble (something
about massless energy - so much for the law of conservation of mass-energy, where energy can be converted into matter and then back again to energy).
He mentions the spontaneous creation of energy ab initio!
He says some energy is totally unassociated with the laws of thermodynamics!
He shows what now are recognized as fractal patterns (I guess he didn't read any of Mandelbrot's work) that occur all around us in nature, both
inorganic and living, and because organic life uses these fractal qualities it is signs that the non-living fractals are somehow imbued with a "life force"!?
He's got it completely reversed - the physical world doesn't mimic biological patterns, biology uses the same forces in nature for its own benefit.
It makes as much sense as showing the similarity that the sun has to the chicken's egg, and suggest that the sun possesses "chicken egg force".
You basically have to throw out all the past 100 years 's concepts in physics and make up new stuff, all unproven, because some guy wrote it down somewhere many years ago???
He talks about extra-dimensional components outside time and space? ???
What the heck is that? ??? ?
Monopolar electricity???
"Inversion of Consciousness" ???
I don't know what he means by "virtual grounding"
(I assume this is not a real ground), it's incredibly unclear to me in this video and is far from sufficient to establish that longitudinal electromagnetic waves exist.
As far as I know that device he is using is operating as a magnetic loop antenna, although not very common, they are used by many people without violating
any presently held theories of science.
If I were some Machiavellian Madison Avenue propagandist this would be a great video to discredit the field.
I'm beginning to think that you're holding out on some kind of time machine that allows you to have 28 hour days to review all this stuff<g>.
The comments section on YouTube look like the video is "preaching to his own choir",
I don't see any critical review of the material offered in the video.
He seems presented as the prophet of the god Tesla - sainthood is actually mentioned!
Tesla was brilliant, but erratic, and he like all member of the human race, are not always right.
Regarding Marconi, I will look into his history, but in all my reading, great entrepreneurs were never cautious people.
They were bold gamblers, the ones that won (at least once).
The trouble with entrepreneurs is that given enough time they eventual gamble wrong and lose...
Wesley
Quote from: Ansis on January 23, 2019, 09:06:03 AM
First with parts.
Hi Ansis,
Thanks for the results of your experiment. You mentioned in an earlier post that Kapanadze used an Avramenko plug. Where is the single wire that feeds the plug in his device setup?
Quote from: Hoppy on January 23, 2019, 10:15:05 AM
Hi Ansis,
ok even it makes me look stupid .. is there one halve of bridge used as an AV plug ?
To jojo.
Yes. Half bridge=Abramenko plug.
About Window size reducing in Chrome and others browsers.
Use Ctrl+ for Bigger letters (pictures, contest).
Use Ctrl- for making (images and letters, contest) smaller.
P.S. This trick is known for programmers but ordinary peoples (very many) don't know about that.
Wesley thanks for that long reply on Dollard as he has been elevated to a demi-god, and the operative word is his mathematical understanding of Maxwell. As you have pointed out that the "experts in their field" are many times wrong and their character has allot to do with their mind set, there are many forms of mental illness and as levels such as being homeless with despair.. I tend to look to at history as foundation of past constructs where advancement and failure has to be balanced by objective of the persons past life of learning...
Keep on as time stands for no one..
Acca...
Wesly yes Eric is a character but he knows how to do the hardware some time ago he published some calculations on (stuff) about transmission lines and standing waves and reflections I couldn't fault them or his knowledge on that subject.
Re the speed of light, you can't go faster than light! try a longitudinal punch and if still not convinced how to the Ebons get here?
they are 40 light years away and they can do it in 10 months they said that traveling in wormholes is instantaneous but the speeding up and slowing down takes the time and they can only jump so many light years and have to slow down the video about it is on youtube take your pick there are dozens which you can watch! but don't tell me they are not here. come back and do that when you know more if we are not wiped out again for our stupidity and greed.
Ansis Hi and what are the boards you are showing ?
Why would the speed of light be any kind of limit? If it is then it must be just a special case.
You can hear all kinds of explanations why that is, but I can't see why any of them would hold in every case.
You need Ebon technology all I know is magnetics slows things down and aliens get here and the American Junta take the piss out of us mortals! ;D ;D
All what I did is proof of "extra energy" is comming from Main Power Supply.
Old electronic equipment is not isolated and is always connected through parasitic
capacitance to the grid power source.
Sometimes, peoples claim COP>1, because oscilloscope show "picture".
In my experiments I sometimes see "extra energy", but that is only because my
oscilloscope is not build properly.
__________________________________________________________________________________
About Abramenko plug.
It is very good if we want charge some Capacitors through 1 wire and "ground".
Where that part is in Kapanadzes generators?
If he use AC to DC conversion of Current.
In original? picture he use it to make Unipolar pulse.
I think very hard about "what is original? Kapanadze drawing look like?"
It's look like gigantic speaker!
All those ferro rings, coils, rings, coils...
In old days I do very many experiments with Audio.
I have selfmade HiEnd. :)
One idea which was popular in 1990s was relaited with Magnetic Flux amplification
inside Speaker Coil.
It was done by making like that:
Ordinary Speaker have Magnet- Ring magnet!
Outside is N, inside S Magnetic Poles or vice versa.
Coil is moving inside by adding Electric Field to Coil.
To make Magnetic Flux stronger(reduction of Distortions),
we glue oposite pole magnet at the top.
But now!!!
Think about that. If we see Kapanadze generator like 10 speakers together,
which have physically connected Resonator!!! which go from Left to Right!!!
it can answer our question - What is Kapanadze generator!
Why I think we must "rethink" everything?
Because my experiments with High Voltage to Low Voltage conversion
through impulses in the past gave me 96% efficiency.
Not more.
We experimenting with Induction heaters too.
Efficiency is 92%.
No magic.
I see no magic in every type of Converters.
P.S. Some time ago I listen WITTS organisation's lectures in the Internet.
But, it is BS.
I like Timothy's believes, but there is no explanations for peoples who
want to understand something "real".
You know, Google spying on Us!!! :)
https://youtu.be/MpA2D3KbXGo (https://youtu.be/MpA2D3KbXGo)
Our French friends can ask this man about "magic" results?
Thank you!
Quote from: F6FLT on January 25, 2019, 06:22:09 AM
In French here : https://www.youtube.com/watch?v=EXXEjkwUemI&t=0s
It is just a single transistor oscillator, whose feedback is made using a hall effect sensor.
No "magic" results. The LED lighting does not indicate that it would receive more than the 1.2W used as an input. This is another useless video by a dreamer who wants to keep his illusions, and consequently does not make serious measurements of input and output powers. In the comments on youtube, he therefore receives congratulations from Georges Chaniotakis, notorious fake video maker.
Oh this looks so cool! Single transistor oscillator for my own setup!
If I want to use this for an oscillator, should I use a MOSFET or a transistor? If I charge a cap from 9V battery, how can I use the HAL sensor to switch a transistor or fet?
Quote from: Belfior on January 25, 2019, 06:49:25 AM
There is different types of HS in the market.
The best sulution is this.
If you have some different HS in your "box", than take a Datasheet and there will be explanation.
In most of Datasheets, there is schematic of connection with some types of transistors or
You can search Google for pictures with your type of HS.
In French here : https://www.youtube.com/watch?v=EXXEjkwUemI&t=0s (https://www.youtube.com/watch?v=EXXEjkwUemI&t=0s)
Plus, he hides half of the circuit and then asks for a donation! ::)
Quote from: Hoppy on January 25, 2019, 09:37:43 AM
did you notice 2 different waveforms one a squar and 12v at 100ma using ferrox and the other a negative going pulse
and 190ma using iron garden wire. Amazing ;D ;D don't people like to spin a web
Blue Kapanadze
https://youtu.be/EACw5uECgno
In fact we can make JT with similar Coil like Franch man.
Test without Magnets and with.
Here is small notefication.
The best transformer is with very small gap between wire and core.
If we make setup which resonate inside, than we create gap, which is bad, frow Induction point, but maybe 2 times longer core with fixed and fully filled core with magnet on the end can give Amplification?
P.S. For realisation of JT circuit with ordinary transistor we need second winding with small diameter wire winded with fat wire or use system like this:
https://i.ytimg.com/vi/OqQSJjRJ6EQ/maxresdefault.jpg
Every kind of circuits will give different results of course, because of different transistor opening moments.
HS is good for very sharp and low output Impedance if we compare with JT.
But!!! If there is possibility that Magnet can make Amplification, it will be usefull.
Good evening!
Today I decide to look at Kapanadzes screenshots again I recognize some parts.
In fact original? Kapanadzes drawing and new setups is the same, but no equal.
In new setup I recognize old russian TV Voltage multiplier.
What I know is.
Tesla Coil with 200kHz? and 25kV output which from Multiplier go to the 2 spark plugs with Anodes "against" and than to Inductor.
Next, is interesting!
I look at strange box of 12 something.
It is what?
It is 12 Hi Voltage Flybackcoils without Anode which go not UP, but Down.
In old original? these coils is mounted Inside Matrjoshka Coil, but in new design, it`s separate!
Now it is clear, he use some "amplification" with many "receivers - amplificator`s".
How is it work?
I think similar like all TPUs, but no one knows.
Question.
Is it possible to use 12 Hi Voltage coils at the receiver end and take 12 times more energy from output side?
Let`s think.
We have 200 000 pulses per 1 second.
Maybe there is some strange phenomena?
Quote from: Ansis on January 27, 2019, 10:37:36 AM
Good evening!
What I know is.
It is what?
How is it work?
Question.
Let`s think.
You would be better off making a forward-thinking SciFi film that way the US Guv would find a way
to produce the hardware ! The dark side makes use for idle minds and hands saying is true 8) 8)
To Alien.
In fact, I just thinking about Kapanadzes generator.
I don't know what it is, just thinkering about.
There is very many similarities with other mythical devices.
But, if I will understand how it works, I will share principal with everyone,
because it is right.
Why I will never give the exact schematics?, because of 1001 realisation techniks.
If we know principle, we can build it ourselves.
https://youtu.be/zE4GjB1cWLQ
Explanation of Tariel Kapanadze
Wesley
https://youtu.be/zE4GjB1cWLQ (https://youtu.be/zE4GjB1cWLQ)
Wesley
Good creative thoughts are exemplified here... Effort has made to explain this enigmatic Corum construct.
Artistic video is captivating, had me sitting up, now the audio is only in one ear hard to listen in my noisy subway..
Acca..
You are an artist on the bleeding edge...
Memo :
1. Sommerfeld and Zenneck wave propagation for a finitely conducting one-dimensional rough surface
https://vdocuments.mx/sommerfeld-and-zenneck-wave-propagation-for-a-finitely-conducting-one-dimensional.html (https://vdocuments.mx/sommerfeld-and-zenneck-wave-propagation-for-a-finitely-conducting-one-dimensional.html)
2.[IEEE Propagation Conference (LAPC) - Loughborough, United Kingdom (2010.11.8-2010.11.9)] 2010 Loughborough
Antennas & Propagation Conference - Isolation of the Zenneck surface wave
https://vdocuments.mx/ieee-propagation-conference-lapc-loughborough-united-kingdom-2010118-2010119-58526242b641c.html (https://vdocuments.mx/ieee-propagation-conference-lapc-loughborough-united-kingdom-2010118-2010119-58526242b641c.html)
3.Download - Observation of Zenneck-type waves in microwave propagation experiments (https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html)
4.Observation of Zenneck-type waves in microwave propagation experiments
https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html (https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html)
5.Possibility of superluminal behaviors for X -like and Zenneck waves
https://vdocuments.mx/possibility-of-superluminal-behaviors-for-x-like-and-zenneck-waves.html (https://vdocuments.mx/possibility-of-superluminal-behaviors-for-x-like-and-zenneck-waves.html)
6.Electromagnetic Surface Wave Attenuation Caused by Acoustic Wave Radiation
https://vdocuments.mx/electromagnetic-surface-wave-attenuation-caused-by-acoustic-wave-radiation.html (https://vdocuments.mx/electromagnetic-surface-wave-attenuation-caused-by-acoustic-wave-radiation.html)
7.Surface-wave luneberg lens antennas
https://vdocuments.mx/surface-wave-luneberg-lens-antennas.html (https://vdocuments.mx/surface-wave-luneberg-lens-antennas.html)
8.Excitation of sea surface wave by short-wave radiator
https://vdocuments.mx/excitation-of-sea-surface-wave-by-short-wave-radiator.html (https://vdocuments.mx/excitation-of-sea-surface-wave-by-short-wave-radiator.html)
9.Surface Wave Propagation Preliminary work developing a method for surface wave detection Amy Zheng Andrew Johnanneson.
https://vdocuments.mx/surface-wave-propagation-preliminary-work-developing-a-method-for-surface-wave.html (https://vdocuments.mx/surface-wave-propagation-preliminary-work-developing-a-method-for-surface-wave.html)
10.Lens design for surface wave applications
https://vdocuments.mx/lens-design-for-surface-wave-applications.html (https://vdocuments.mx/lens-design-for-surface-wave-applications.html)
11. https://vdocuments.mx/search?q=Zenneck+surface+wave&per_page=8 (https://vdocuments.mx/search?q=Zenneck+surface+wave&per_page=8)
12.On the relation between Surface Plasmons and Sommerfeld's Surface Electromagnetic Waves
https://www.semanticscholar.org/paper/On-the-relation-between-Surface-Plasmons-and-Waves-Dyab-Abdallah/593dd702a9b6051652a7fbf4dc4f2df38e7697a7 (https://www.semanticscholar.org/paper/On-the-relation-between-Surface-Plasmons-and-Waves-Dyab-Abdallah/593dd702a9b6051652a7fbf4dc4f2df38e7697a7)
13.Brief overview about Surface Wave theory and applications
https://www.semanticscholar.org/paper/Brief-overview-about-Surface-Wave-theory-and-Balosso- (https://www.semanticscholar.org/paper/Brief-overview-about-Surface-Wave-theory-and-Balosso-)
Sokoloff/e7f1b1a020f0f0d2bf7c45d68075690246678a79?tab=abstract&citingPapersSort=is-influential&citingPapersLimit=
10&citingPapersOffset=0&citedPapersSort=is-influential&citedPapersLimit=10&citedPapersOffset=10
14.Zenneck surface oscillations in the sphere dielectric resonator immersed in high lossy liquid
https://www.semanticscholar.org/paper/Zenneck-surface-oscillations-in-the-sphere-immersed-Ganapolskii-Eremenko/d41299173437028b336c26a8772ade0f109d62d1 (https://www.semanticscholar.org/paper/Zenneck-surface-oscillations-in-the-sphere-immersed-Ganapolskii-Eremenko/d41299173437028b336c26a8772ade0f109d62d1)
15. https://www.semanticscholar.org/paper/Surface-Waves-Barlow/686d2a3ce72918969e9a74edb49364521b2357cc/figure/4 (https://www.semanticscholar.org/paper/Surface-Waves-Barlow/686d2a3ce72918969e9a74edb49364521b2357cc/figure/4)
16. https://pdfs.semanticscholar.org/d3c2/de8b26cfcb179dc63ec3e3c7ed75ffefe494.pdf (https://pdfs.semanticscholar.org/d3c2/de8b26cfcb179dc63ec3e3c7ed75ffefe494.pdf)
17.The Excitation of Plane Surface Waves
https://www.semanticscholar.org/paper/The-Excitation-of-Plane-Surface-Waves-Cullen/d3c2de8b26cfcb179dc63ec3e3c7ed75ffefe494 (https://www.semanticscholar.org/paper/The-Excitation-of-Plane-Surface-Waves-Cullen/d3c2de8b26cfcb179dc63ec3e3c7ed75ffefe494)
18.The application of electromagnetic surface waves to wireless energy transfer
https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06 (https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06)
19.THE PROPAGATION AND EXCITATION OF SURFACE WAVES IN AN ABSORBING LAYER
http://www.jpier.org/PIER/pier19/02.970718p.Ling.SU.pdf (http://www.jpier.org/PIER/pier19/02.970718p.Ling.SU.pdf)
20.Surface wave
https://wiki2.org/en/Surface_wave (https://wiki2.org/en/Surface_wave)
21.Why Do Surface Waves Exist?
http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf (http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf)
22.Excitation of the Zenneck surface wave by a vertical aperture
https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969
Wesley
Frequency of work is the basis for action.
Quote from: NickZ on January 29, 2019, 08:31:11 AM
Boring, boring, boring, boring, boring, and boring. Oh, and more boring.
If someone doesn't understand it they will say it's boring. This is the case, for example, in the music of Jazz
Quote from: r2fpl on January 29, 2019, 08:50:34 AM
Well you have to understand where this statement is coming from. Nick wants the schematic/working device and not some videos or even a scientific paper, that requires him to understand something.
He is tired of wiring coils and pulsing them. He wants his free energy now, because he is entitled to it.
Dla r2fpl:
https://www.youtube.com/watch?v=JGywu9BJJCU (https://www.youtube.com/watch?v=JGywu9BJJCU)
Widze ze sie zajales na serio tematem.
Dla mnie to wyglada jak zmiana impedancji pola przez dodanie zarowek w kierunku blizej rezonansu.
To samo mozna zrobic wkladajac reke.
To samo bedzie rowniez jesli czestotliwosc struktury zmieni sie przez dodanie komponentow LC
w XYZ przestrzeni - w kierunku rezonansu.
Srobuje zrobic porownania:
Ja wiem ze twoja konfiguracja byla inna.
Chce tylko zebys rozumial co robi co.
Zaczynasz z 52MHz bo wtedy nie masz duzych wymiarow.
Robisz sobie pare rozdzielona dystansem.
Czyli odb. - robisz dokladnie tak jak i nadajnik.
dopiero kiedy uda ci sie przekazac energie z punktu a do b. to bierzesz dokladnie ten sam nadajnik ktory jest teraz twoim wzorcem.
Teraz traktujesz ten nadajnik jak by to byl teraz twoj nastepny odb.
i probujesz dostroic do rezonansu schumanna nizej i nizej.
Orginalnego odb. nigdy nie dotykasz i nic przy nim nie zmieniasz.
Ale teraz ten twoj orginalny odb bedzie twoim nadajnikiem.
Czyli podlaczasz do niego teraz generator.
Patrzysz czy oba pracuja na przemian.
Potem powracasz do pierwszej konfiguracji.
Twoj nadajnik jest nadajnikiem a twoj odbiornik jest odbiornikiem.
I tu zachodzi ciekawa rzecz.
Teraz bazujac na twoim juz teraz doswiadzeniu z przekazem energii
ktore jest kluczowe ,
Z nadajnika wyciagasz cala cewke wys nap. w jej miejsce wkladasz granat Tariela https://youtu.be/zE4GjB1cWLQ?t=513 (https://youtu.be/zE4GjB1cWLQ?t=513)
Orginalnego pierwszego Odb. nie ruszasz wogole. Tak jak byl dostr. tak go zostawiasz.
Bawisz sie z nawijajac cewke w lewo , prawo jak popadnie lub tez tak jak to robil Akula lub Ruslan, caly czas trzymasz 52MHz na generatorze.
Patrzysz sie czy odb ci cos pokazuje.
Tak naprawde to nie ma wielkiego znaczenia .
Za kazdym razem kiedy zmieniasz kierunek nawiniecia to skracasz fizyczna skladowa.
W rezultacie masz cos malego a zachowuje sie jak duza antena.
Podstawowa zasada :
Najpierw dostroj sie do rez. na najmniejszej cewce jaka mozesz nawinac a potem mozesz albo nadawac albo odbierac, Jak sobie chesz.
Ale odb musi byc na odleglosci ok. 10m minimum dla 52MHz .
Jak juz zrobisz ze ci ta cewka Tariela/ Akuly pracuje to wlasciwie zrobiles Kapanadze.
Znasz mechanizm dostrojenia sie do harmonicznej.
Wszystko co teraz trzeba to wiedziec ze jestes kupe za wysoko musisz zejsc nizej z czest.
Faza jest regulowana w stosunku do ziemi.
Faza potrzebuje punktu odniesienia i ziemia jest twoim punktem odniesienia
Tariel zbytnio sie nie przejmowal. W pokazie dla mnie uzyl wysokowoltowy generator iskry od grzejnika od gazu
Jego koncepcja wymagala pierwszego impulsu aby wzbudzic Zenneck fale a potem urzadzenie pracowalo samo.
Wesley
All experiments are done on your own risk based on your own decision.
HV is dangerous.
Tutaj masz caly sekret Kapanadze.
Wesley
Dla r2fpl:
Popatrz kolejnosci:
Masz dwoch ludzi
- Fizik Man
- Dimitry Maximow
Dimitry patrzy na to co zrobiFizik Man i robi swoje wywody.
Wogole wejdz na jego str. i zobacz co on tam ma.
https://www.youtube.com/watch?v=NBXwiN7LHAo (https://www.youtube.com/watch?v=NBXwiN7LHAo)
. https://www.youtube.com/watch?v=OMZJyr6VCyA (https://www.youtube.com/watch?v=OMZJyr6VCyA)
. https://www.youtube.com/watch?v=ACTYSFl_qkA (https://www.youtube.com/watch?v=ACTYSFl_qkA)
. https://www.youtube.com/watch?v=Dqekpxwjzn0 (https://www.youtube.com/watch?v=Dqekpxwjzn0)
. https://www.youtube.com/watch?v=L6mJ_RDdNuU (https://www.youtube.com/watch?v=L6mJ_RDdNuU) bardzo ciekawy generator nanosek..
Wynurzenia:
1. Skladowe logiki myslenia
a. Mozesz sie koncentrowac na blokach i detalach.
znak i znak lub
b Mozesz szukac generalnego mechanizmu ktory tym rzadzi.
Oba podpunkty punktu 1. zaprowadza cie do jakiegos konca , gdzie jest rozwiazanie albo koniec korytarza bez wyjscia.
Akcja :
2. szukasz nowego korytarza i znow jest to samo.
Wniosek:
3.nigdy nie bedzie inaczej. Zawsze beda tylko dwie logiczne skladowe. (patrz punkt1 podpunkt a , b)
4.rozwiazan jest wiele i korytarzy bez rozwiazan tez jest wiele.( "wszystkie drogi prowadza do Rzymu")
5.Moje rozwiazanie z Falowodem Schumann'a odpowiada punktowi 1b. i dziala sprawdzilem.
6.Mozesz szukac dalej ale i tak na koniec zawsze wrocisz spowrotem do punktu 1
Podsumowanie :
bledem prawie wszystkich ktorzy chca powtorzyc Kapanadze., jest ignorowanie lub pogwalcenie logiki.
Ludzie nie rozumieja, filozowi ktora jest matka wszystkich nauk.
Mozesz byc bogatym prymitywem jak Trump lub bogatym bandyta jak ten tam ze wschodu.
A mozesz byc zwyklym myslicielem ktory zyje bez stresow i ktoremu nic do zycia nie brakuje np jak ja.
U ciebie liczy sie czas. Jako mysliciel mozesz stac sie bogatym tez.
Ja juz nic nie musze.
Efekt koncowy:
Ci wszyscy wokol "szukacze" FE,ida w ciemnosci i obijaja sie o takich samych jak oni sami.
I teraz przedstaw sobie ze to ty patrzysz z gory na nich wszystkich i widzisz wszystkie ich bledy.
tak jak bys patrzyl na mrowisko, na tych wszystkich w ich korytarzach.
Ty widzisz wszystko to czego oni nie widza w tym samym interwale czasowym (Delta T)
Ten post tutaj to jest twoj klucz do sukcesu.
Mnie nic nie jest wiecej potrzebne , Ja jestem zyciowym minimalista.
Mam ten spokoj ktorego (zakladam) oni nie maja i radosc z zycia.
Wesley
https://www.youtube.com/watch?v=sweXFKSXMxo (https://www.youtube.com/watch?v=sweXFKSXMxo)
I remember.
It seemed that you wanted to talk about me.
Even though you met kapanadze, you did not understand the generator principle,
In the meantime, you had a lot of thoughts.
It was a principle you did not know until a few days ago.
I understand the generator principle since Ruslan published two circuits.
I realized then that the kapanadze generator is the same principle.
Quote from: AlienGrey on February 06, 2019, 02:56:35 PM
Hmm So America owns every charged particle on the planet that's made in a thunder storm I don't think so! It would be interesting to know if the energy they will be transmitting is 'CARSNOGENIC' which I expect it will be! I expect they will be importing Satan's throne Hitler imported from Turkey that is now in the Pergermum museum in Berlin next for their amusement. Still I have had my say and I'm not amused.
Pergamon-(Altar- )Museum, first was built 1897-1899
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FPergamonmuseum
Pergamon-Altar
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FPergamonaltar
How about using an ultrasonic mister to vaporize DMSO/iodine solution in the bedroom?
https://books.google.co.jp/books?id=Opm9BwAAQBAJ&pg=PA33&lpg=PA33&dq=respiratory+distress+syndrome++dmso&source=bl&ots=gw-LrdleN-&sig=ACfU3U1eJQNCMhUgs2JRtkRTHEZj5jxLcw&hl=en&sa=X&ved=2ahUKEwjx5b6mmbjgAhUBQN4KHVeXDXgQ6AEwCXoECAAQAQ#v=onepage&q=respiratory%20distress%20syndrome%20%20dmso&f=false
https://www.translationalres.com/article/0022-2143(92)90136-9/abstract
Quote from: ramset on February 15, 2019, 11:38:24 AM
Wesley
Do you have a small Cryogenic Dewar we could borrow for some superconductor experiments at one of the open source Labs in USA also we still have some iron wire to test for "NMR excess energy testing"at several open source labs.please remove if inappropriate
respectfully
Chet K
Yes I have whole cryogenic lab.
I have chamber to test electronic elements in temperature 4K. ( four degrees of Kelvin)
And Yes You can have Dewar I should have few of them.
Just tell me when.
Wesley.
https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/ (https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/)In 1988, PhD James Corum, (one of two brothers) focused interest of the public, on to his own private research of Tesla.
QuoteSome harmonic of the fundamental earth resonant frequency—up to approximately 25 – 35 kHz—is used for the oscillator frequency.
In this frequency range the around-the-world propagation efficiency is in the general area between 93 to 87%.
As the frequency is increased above this point, efficiency further decreases.
At 160 kHz the efficiency falls below 10%. [Corum, K. L. and J. F. Corum,
"Nikola Tesla, Lightning Observations and Stationary Waves,"
Proceedings of the 1994 Colorado Springs Tesla Symposium, 1994, Appendix II, "The Zenneck Surface Wave"]
The oscillatory transformer provides the high voltage alternating current needed to periodically charge the transmitter's elevated terminal.
A monochromatic subcarrier signal is then added.
This is in the form of an abrupt lower frequency electrical impulse applied at a rate approaching the fundamental earth resonance frequency.
Higher frequency impulses, above the oscillator frequency are also added at every harmonic of the low frequency subcarrier impulse,
be it the fundamental earth resonance frequency or some lower harmonic of same.
[Corum & Corum] While the following quote refers to the use of an RF alternator in conjunction with a resonance transformer to produce continuous waves,
it appears to be applicable to the excitation of earth resonance modes as well.
Number of inventors added small building blocks:
https://patents.google.com/patent/US3278937A/en (https://patents.google.com/patent/US3278937A/en)
till scientific crowd around was ready for
WAVEGUIDE and TEM, TE, TM modes.https://apps.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf (https://apps.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf)
This PDF explains all possible science in this area till year:1966
and is easy to understand for these who wants to build Kapanadze today.
(Example: http://www.nuenergy.org/uploads/tesla/US645576.pdf (http://www.nuenergy.org/uploads/tesla/US645576.pdf)
this patent has a lot to do with that article.)
Simple summary:
1.Kapanadze coil represents electrically shortened HV part of Tesla coil transformer.
2.Everything that you do with HV part of regular Tesla Coil you can do with Kapanadze coil.
3.The only difference is that with regular Tesla coil you need much much more space all around.
4. TEM and TE, TM modes of transmission / receiving and taping into "reservoir of" energy are always the same for all of them.
5. Everything including us - we are walking at that
interface earth/air ( think and look only at that sticky area.)
a. This area is also the wall of Schumann waveguide.
b. This area is also used by Surface Waves.
6. No matter if you sending energy from A to B using surface wave, or extracting energy from Schumann waveguide you always use surface wave for it.
7. Waveguide has finite geometrical dimensions. It can be:
a piece of pipe,
b rectangle,
c dielectric slab
e HV car wire
f electrical wire with insulation
g Earth/ air/ionosphere XYZ coordinates are fixed.
by that: Locally present surface wave at the interface has finite parameters to be exactly
at this place and at that frequency.
Kapanadze went much more advanced than that. Instead of using passive antenna he created active interacting antenna to stimulate the phenomena of.... of the same as would be achievable with other methods.
https://youtu.be/zE4GjB1cWLQ?t=606 (https://youtu.be/zE4GjB1cWLQ?t=606) Wesley
PART 2a
Example:
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474393/#msg474393 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474393/#msg474393)
When you look at picture below look at conditions required to lunch or receive or tune into surface wave.
1- phase
2- angle of incident
3. polarization
each twist allows you to tune whole assembly to parameters of interest using very short electrically piece of wire.
and using active instead of passive structure.
However ground must be present and some stability of that circuitry as well.
Spark gap is only one of many ways to create voltage potential.
That could be enough at the right length to catch energy, but lack of stability did not make it to last long, except for SR193,
and few others.
Summary:
1.At no point it is important how strong is Schumann resonance
Energy fluctuation inside waveguide is seen only at interface.And only in form of surface wave.
and there is plenty of energy there.
However Electromagnetic waves in space can not see each other and can not interact .
Photons have no idea about other photons.
2.special condition of interface has unlimited number of users using surface wave at the same time.
That means that you can tune to nature or someone e.g Zenneck Wave.
But to do that the few more parameters need to match.
Corum Brothers created polyphase ( multi-phase) signal to make it harder to intercept.
3. All of these individual surface waves do not see each other, and do not know if there is any presence of any other energy in the interface.
4. Tariel Kapanadze Coil is much more advanced than any Corum Brothers structure
Wesley
Resonance alone is not enough to sustain the process. This is just a required element. The source must come from passing through another medium.
PART 3.
Quote from: r2fpl on February 17, 2019, 08:10:36 AMResonance alone is not enough to sustain the process. This is just a required element. The source must come from passing through another medium.
If we consider that we want to start with Schumann resonance, for example 26.4Hz for the first resonator and for the coil 1/4 = 105.6Hz, and this frequency is considered our second resonator we already have 422,4 Hz on the second coil. Assuming that we can do this many times, we get many repetitions.
The few ways :
One is to calculate all variables starting from four fundamental Maxwell equations, with surface wave in mind.
calculate each section place two of them together, and check against the sample.
However parameters of polarization, phase and frequency can be known to us if we transmit from A to B. at first, and than use
our experience to move lower in frequency. So playing at first with Tx/Rx pair is your mandatory experience before you move to Schumann waveguide surface wave components.
The same antenna of our Tx or Rx (pair)
= our receiving antenna for our surface wave in Schumann Waveguide.
Wesley
link to picture below:
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
Simple answer: this is the principle Kapanadze devices !
The standing wave is a reflection from the ground with the help of TT. This is the main rule! Spark gap is just an interlude for the TT inductor as in Tesla.
You can search for reflection by measuring V-SWR for antennas.
..middle picture is GIF animation. Please download to desktop if not run.
PART4
Yes the mechanism you explained is one of mechanisms, behind Kapanadze/clones.
Other mechanisms:
1. Think about vertically polarized standing wave.
It is bouncing back and forth in Cartesian XYZ space
(You can also imagine Euclidean geometrical space)
At certain point, after e.g 55 bounces velocity of envelope ( rybka)( the fishes) https://youtu.be/7pE83oajjoo?t=517 (https://youtu.be/7pE83oajjoo?t=517) upper right corner
can be 50 times slower than free space speed.
Let's call it group velocity.
And now you are able to take this signal and without losses feed it into
another (resonating at 1/100 of lambda CCW) , part of the coil.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/171961/ (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/171961/)
But this part of the coil has its own Slow Wave factor caused by thick dielectric
of HV wire.
Now this section is coupled to resonance by pricking insulation of that wire in right position of
waveform, traveling in that covered with dielectric wire.
https://youtu.be/KLAPRNWuAn4?t=600 (https://youtu.be/KLAPRNWuAn4?t=600) ( watch for another minute)
And yet the two sections:
- the one before and one now, are in perfect resonance in its
fraction of lambda.
However both together now work much better at 1000th of a lambda.
For better understanding let's take an example:
You have two or more 1/4 lambda antennas,
It is not important if any of antennas is 20 cubic yards big or it is at the size of your cigarette lighter.
Both of the antennas must RESONATE at first!!!!
Both of the antennas will do excellent job.
However efficiency of each one of the antennas is a trade.
link to antenna should be only for reference of (How to phase)
https://www.hamradio.me/antennas/improving-the-super-j.html (https://www.hamradio.me/antennas/improving-the-super-j.html)
link to coils in motors
http://www.davidsonsales.com/docs_pdf/CoilPitch.pdf (http://www.davidsonsales.com/docs_pdf/CoilPitch.pdf)
For these
we look at how slow is phase velocity for total distance from A to B. ( when you looking at envelope)
The ultimate goal is to actively match with our Kapanadze clone coil exactly to the condition of surface wave at this particular point of interface ( air/ earth)
If we use active antenna instead of passive antenna than our active signal can be compared with that very particular point having geometrical XYZ on that interface.
This signal can be than discriminated/ compared/ mixed/ demodulated for our benefit.
And that is your Free Energy
Schumann waveguide has fixed XYZ diameters and like every waveguide its wall ( the interface can accept immersed probe like in the slotted line)
Slotted Line: https://www.daenotes.com/electronics/communication-system/slotted-line (https://www.daenotes.com/electronics/communication-system/slotted-line)
Wesley
PART 4a
explanation:
man made surface wave is exactly the same as
nature made surface wave but has different polarization, phase angle , frequency
It has also different impedance than loved by us standard 50 Ohm.
Summary:
Surface Wave known also as Zenneck Wave is our focus media despite the fact if we plan to transmit from A to B
or we trying to extract energy .
We will be always looking at interface and right match to man made or nature made surface wave.
You do not care about efficiency of any of sub-sections of Kapanadze/clone HV coil.
Efficiency is only important, when you deal with bits and pieces of energy to be preserved.
Our general assumption is that in the interface we have plenty enough energy in surface wave to deal with.
But at first we must tune into it.
By method used by Corum brothers it will be big humongous Tesla Tower. Even at 18kHz
By method used by Tariel Kapanadze it will be very unstable but small Kapanadze active coil assembly.
Both of methods must have proper ground.
Wesley
I agree about Q factor and no-Radio type Kapanadze device.
Only created in place HiVoltage can make something usefull (if it is real) with Ground connected
device which "suck electrons" or create something unknown or make something like mC2 punch=> contra punch. Something like Second + Third Newton's law of motion. Only difference is we do that with Electric "hammers". We create Force in colision between mases and create contercforce on it. Like when we magnetise and demagnetise material which than is captured with Coils.
I see only thease explanations.
a movie here from Geographic society ,mentions Zenneck waves at 6 min mark
https://www.youtube.com/watch?time_continue=368&v=wFiW2lqdnlM (https://www.youtube.com/watch?time_continue=368&v=wFiW2lqdnlM)
from topic about thermionic tech and pending public release [ambient harvesting with energy densities to industrial use levels with daisy chaining , mentioned around 23.40 min mark
http://www.energeticforum.com/renewable-energy/21105-nano-boxx-24-7-electric-power-using-only-ambient-heat.html (http://www.energeticforum.com/renewable-energy/21105-nano-boxx-24-7-electric-power-using-only-ambient-heat.html)
please remove if inappropriate or already mentioned [so much info got buried here]
respectfully Chet K
Quote from: ramset on February 18, 2019, 11:59:11 AM
respectfully Chet K
Thank you for the link Chet K
let me know when you need the cryogenic flask.
Wesley
https://www.youtube.com/watch?v=ODYy-ifTu1M
Fizikman
Naval Weapon Center about it.https://apps.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf (https://apps.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf)
https://www.youtube.com/watch?v=GdlkeI0bXy4 (https://www.youtube.com/watch?v=GdlkeI0bXy4)
Wesley
''WITHOUT PREJUDICE''
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531591/#msg531591
The burden of proof is only on your side.
You claim that the Kapanadze machine is overunity, so give the proof,
Wesley's response:
I have never said in my life that overunity exists.
No, but does this video you produced prove it does?
end of quote.
((Tariel kapanadze HV generating circuit SHGS)))
no ofence but can we just kick all this tyersome stuff down the loo 8) 8) and flush it please do!
Well, it looks like a video showing a working device for me!
Also did anyone notice >>> THE FULL MOON? (depicts the end of hostilities) <<<
Date Time Native American
February 19 10:53 A.M. SNOW Full Moon
Let"s think different.
We know the Ground connection give us the "Amplification" in Radio therms.
It means, we connect good Ground in our Radio station and we can get much better "signal".
Every one knows that.
But, there is "selected" range of that effect.
In GHz diapasone we don't need Ground, because we use our parabolic dish surface like reflection surface/ground.
IT MEANS, THE GROUND CAN BE USEFULL ONLY AT LIMITED SPECTRUM OF WAVES.
I want ask real DXers here, which part of frequency diapasone is most dependant from "ground antenna".
Thank you!
Quote from: Ansis on February 21, 2019, 08:19:54 AM
if you look on Eric Dollard's youtube site he and the other feller Tom Brown ? made a video about it.
https://search.yahoo.com/search?fr=mcafee&type=E210US91082G91208&p=youtube+eric+dollard+tom+brown
Thank you!
Maybe Kapanadze use Ground to charge Battery inside his box?
Maybe Direct Current is the answer?
If LongWaves is hunngry for Ground and we know AC of 50Hz is dependant from Ground(it is main reason for stealing electricity from Grid companies of HiVoltage from 220V in East, it is in East because of dependency of Voltage potencial for better efficiency of steeling!!!). Maybe there is some anomaly? Maybe there is potencial(from or 1 point), from which start avalanche SuperMega Stealing?
Be free to think like that, because we are investigators!
Quote from: NickZ on February 21, 2019, 09:12:47 AM
: Guys: Why don't you discuss Zenneck waves and related technologies, just in Wesley's thread, instead of spreading these discussion over onto threads like the Dally thread, that has nothing to do with wireless transfer of electricity over distances, at a cost to you. Which is not going to be free energy, at all, nor similar to the Kapanadze/Akula/Ruslan type of devices discussed and replicated there. As it looks like no one or very few guys are all that interested in wireless transfer distracting us, with unrelated technologies. I just wanted to answer to Ansis, sorry to add the above. I probably should have done it in the Dally thread instead.
But, the idea is to separate the different technologies into their own threads, if possible, as they don't work the same.
Yes Nick it should ''junk'' should be deleted and then we might be able to create an index to find things
Quote from: Ansis on February 21, 2019, 09:23:28 AM
LongWaves is not "hunngry for Ground", it's just a question of engineering, not of principle. In any case for long waves, the second pole is obtain by a long wire. But at 50Hz, we are no more in the "long wave" range (30 Khz to 300 KHz), we are in the very very very long wave range (https://en.wikipedia.org/wiki/Super_low_frequency) (6000 Km) so that we can't have an efficient "second pole". We are no more in radio frequencies, and only in the near field (field directly linked to nearby conductors, almost not propagating). It's almost impossible to produce efficient propagating waves at theses frequencies.
PART 6.
SURFACE WAVES: WHAT ARE THEY? WHY ARE THEY INTERESTING?
For us understanding surface wave is the key to electrical energy for free.
When we talking about Schumann waveguide it is not important what is energy level
at fundamental 7.83Hz Schumann frequency and its harmonics.
We only need to remember that wee need to be at lowest Schumann frequency harmonics we are physically able to be.
when we go with frequency of our Rx,Tx pair or just Receiver, into 18kHz or lower than our reactive losses are the smallest.
more is explained in article:
https://www.armms.org/media/uploads/1259319847.pdf (https://www.armms.org/media/uploads/1259319847.pdf)
and less interesting but useful article :
Isolation of the Zenneck Surface Wave
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.651.4359&rep=rep1&type=pdf (http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.651.4359&rep=rep1&type=pdf)
Please remember that experience with Zenneck wave as A to B transmission will be needed to
extract energy from Schuman waveguide.
Mechanism is almost the same.
Naturally present surface wave in the interface has different frequency , phase and needs polarization
and impedance match at the receiver Rx side. ( your FE).
Tariel Kapanadze and his clones ( SR193, Akula, Ruslan) used structure that I name active probe.
the term Active probe is used in patents of James Corum and Corum Brothers.
A surface wave requires an interface between two media as it exists partially in both.
Therefore if the electric field is unable to penetrate into one of the media, a surface wave
cannot propagate.
This could therefore imply that the skin depth is proportional to the
magnitude of surface wave produced and indirectly proportional to the magnitude of space
wave produced with an exponential dependence.
It is from this concept that the definition of the 'surface wave region' was derived.
Zenneck Wave does not radiate in Far Field and is in form of TEM in TM mode
Wesley
There are plenty of mechanisms allowing to build electrically short 1/1000 of lambda resonating structures such as Kapanadze and its clones coil.
mkjekyll (https://overunity.com/profile/mkjekyll.104399/) contribution is: https://patents.google.com/patent/US3083364 (https://patents.google.com/patent/US3083364)
This contribution is important as explanation of means of electrically short
coil (caduceus like coil structure.)
Means of bifilar winding with proper spacing
have been explained in the language of 1963 antenna science, but for us
important is to point art of physical application.
Electrically Short HV part of Tesla Coil is Kapanadze coil.
Small size is our goal.
You retain similar to full size structure parameters such as desired frequency , amplitude, impedance, and able to maneuver proper polarization.
What one must understand is:
Kapanadze trick with 9V battery can ( but not must) be seen as coupling into energy of another system
By activating active probe that is "immersed" into that system.
By trying to keep language in level of average reader I 'm in must to use words that I try mark as
".. " or ( ..) or active probe.
But I'll try to use active probe word with proper explanation.( explained in sections 1-5)
Much easier to explain it , would be to use example from classical mechanics, however
it will be only graphical form that in the sense can not serve as quantum related.
Let's say you have slightly vibrating hot water pipe, and you clamp it is certain point.
You may see that pipe start to resonate mechanically with quite increased amplitude.
Only energy to find the right spot for the clamp, was delivered by You.
You do not need to pay for pump and water.
At the end of the cycle, of the pump action the motor rotation slows and vibration of the pipe, can reach its damaging maximum.
Active probe operates based on the same logical concept:
Lets place energy that is paid by someone but not you, on the same level as natural energy that is
created by nature and is not paid by you.
Wesley
PART7=====================================================================
1.This is very easy explanation to almost every nontechnical reader of basic antenna futures.
https://www.pulseelectronics.com/antenna_basic_concepts/
2. Tesla coil is made out of two coils:
a. low voltage coil ( usually at the bottom of structure)
b. HV coil( usually inside of low voltage coil)
- is air/ ( can be vacuum) based resonant transformer.
(can be called air transformer)
(some of variations of Tesla coil can have more than one low or/and high voltage coils)
2a If we place inside of low voltage coil, the coil (HV) that is in length shorter than
corresponding to given frequency required physical diameter (e.g Tariel Kapanadze coil)
it means that we compromised some of parameters of
aperture of suitable HV coil.
https://en.wikipedia.org/wiki/Antenna_aperture (https://en.wikipedia.org/wiki/Antenna_aperture)
This may become very much positive and fulfilling our expectations, as we care only about certain
properties ( certain effect) of such antenna or coil manifesting its usefulness.
2b. Antenna Efficiency
QuoteThe efficiency of an antenna is a ratio of the power delivered to the antenna relative to the power radiated from the antenna.
A high efficiency antenna has most of the power present at the antenna's input radiated away.
A low efficiency antenna has most of the power absorbed as losses within the antenna, or reflected away due to impedance mismatch.
However this quote from above can be very much misleading .
You may have, very, very small antenna ( 5cm/2inch long) perfectly resonating at 1/100 of y(lambda)
and full size antenna (10m long/ 393.700787 inch) perfectly resonating at 1/4 of y.
The efficiency of both antennas is different. But both are performing well.
It is the conditions( very specific parameters that we may be interested with) that matters .
In our case we are interested in antenna that is small in size and we do not care much about losses created by small size
of an antenna
http://www.antenna-theory.com/basics/efficiency.php (http://www.antenna-theory.com/basics/efficiency.php)
2c. In our case (2b) we have in mind passive or active structure.
if passive antenna ( in form of e.g Tesla Coil) is used - it is used as Rx not Tx antenna.
We care not much about efficiency of the antenna as we assume that in given point
we have plenty of energy for that antenna to resonate with.
2d. In our case (2b) if we use active antenna ( also known as active probe) than
you need to read my notes about active probe in
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531943/#msg531943 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531943/#msg531943)
and everything that is related to active probe in PART 1 to 6
3. Such structure does not deffer much from typical antennas in regards to:
a- ability to be build as resonating structure at 1/2 y , 1/4y 1/100y 1/1000y and so on.
b- ability to accept delivered to its input frequency that makes existing structure to resonate at 1/2 y , 1/4y 1/100y 1/1000y
and at its
harmonics ( important).
4. you must first resonate than radiate.
this is mandatory requirement to everything possible in air transformers employed as
" let go to all of it " ( passage) of signal.
5. Receiving antenna can be build exactly the same as transmitting antenna .
Rx- receiver ( abbreviation )
Tx- transmitter ( abbreviation )
Wesley
PART 8
Each lightning burst creates electromagnetic waves that begin to circle around
Earth captured between Earth's surface and a boundary about 60 miles up.
Some of the waves - if they have just the right wavelength
- combine, increasing in strength, to create a repeating atmospheric heartbeat known as Schumann resonance.
Wesley
For the purpose of comparing with some information mentioned by me earlier.
I translated set of schematics from the same author.
System is stated as verified to work.
I'm responsible for translation only.
System includes many different options.
set of H quality large format schematic is available .
But it will oversize the page.
Schematic Translation #6 ( look at page 6 )
Tesla said : You can synchronize work of source S with Sj that is similar in nature. or any number of such sources.
gives chance to amplify oscillations and distribution of them in any area or organize transport
( distribution of electrical energy produced by Sj to source S having in mind that these signals are reversed in phase.
Tesla N. Lesson M Tesla print 2003 386s page L140
title: about electrical resonance L-135-L140
Schematic Translation #5 TV2 winded LEFT ( look at page 5 )
TV1 winded RIGHT
Schematic Translation #4 ( look at page 4 and 4a )
1.In variant TV2 without resonator use start winding from L res. coils of output , wind from the sides .( you can L res. wind in the middle of the former and output on the sides of the former)
Position of indicator please find experimentally( start from center of the former over L res.
You can also try to pull winds to increase pitch.) external look of TV2 similar to in Kapanadze.
2. Tr2 you can split to two independent current transformers.
3. U resonator ( free oscillations)
4.One of ways to tune:
5. connect Katcher and tune it to free oscillations adjusting Crest1, L2 and coil TV2 in such a way that all of windings of TV2 resonates in frequency of Katcher free oscillations.
Connect inverter now, and tune it using RV1 and Cres2 to frequency multiple to frequency
of Katcher is such a way that oscillations of current on L res are synchronized in zero amplitude of Katcher free oscillations using adjustment RV3 till synchronized between inverter and Katcher.
Adjust phase of windings ,
Length of wire or each coil make multiplying (- even) for example:
Resonator 200m( meters), than L res.- can be 1/4 lambda around 50m, or 1/16 of lambda
or 1/32 of lambda and so on.
You can use also use odd ( not even) harmonics 1/3 instead of 1/4 lambda and so on.
In such a way you can than wind output windings.
the main point is to have all windings of resonator, to resonate at frequency of free oscillations (or its harmonics.)
you can wind around of TV2 (over the TV2,) few winds of wire, Lres or you can do the same inside of L res. or inside of transformer you can insert pipe with longitudinal slot.
there are plenty of options.
Depends from your construction you can add another resonator.
It will definitely work better not worse than without it.
On TV2 OUT1 and OUT2 should be in opposite phase.(180 degrees out of phase)
1. Inverter sinus or resonance- (you can have 50Hz as well)
is creating traveling oscillations and makes possible to retrieve energy at desired frequency.
Retrieving of energy is possible when, "traveling" oscillations (send oscillations) synchronizes itself with, reflected current oscillations.
Voltage in its zero amplitude manifests maximum velocity( I can call it the right point.)
2. synchronizator is synchronizing cycle of inverter 1 and katcher 4
3. air transformer is made based on Tesla Transformer.
4. Katcher Borovina creates free oscillations and by that makes possible to create "stream"
"Stream" is controlled by us response of mechanisms of nature in area of energy transfer.
6.After you made the device try than to change value of resistors,
you will notice that voltage potentials almost don't change.
You will see however change of current . Properly assembled device pretty stable, even if parameters of elements are changing.
7. katcher with self stabilization
8. terminals to connect battery during Start.( like Kapanadze 9V)
9.In "stream" based devices mutual interaction makes processes to be supported by existence of other processes. Reflected signal in resonance circuit when in phase sequence is supporting incoming signal from another resonance circuit. By that amplification of "stream" is possible
note: "stream" look at sub-point 4 of point 4.
10. In effect current in transformer TV2 is flowing due to voltage fluctuation in TV1
11.Nominal impedance for Katcher that utilities field transistor VT2
R1-1.2k Ohm not less than 2W
R2 470 Ohm not less than 2 W
You may be in need to adjust value of R3 R4 to required value or you will have problem with self stabilization.
12. option of self stabilization
13. Driving Coil (OC)-60 winds. Please wind in the same direction as your resonator .Length Oc should be even ( not odd) to length of resonator
14. TV2 output coils please wind in the opposite direction (OUT1 other than OUT 2.. the same story is with OUT3 and OUT4 )
15. or like this for small power.
16. Resonator TV2 - right winding.
17. explained in point 11.
18. control of current
19. TV1 left winding
20. It should look like this for big power
21. to L res current (look at Tr3)
22. Voltage on resonator.
23. Power - Fast diodes
24. balance.
25. to inverter? I'm not sure.
26. TV1 Tesla
Schematic translation #3
Wesley
This is my set for sonoluminescence.
I need to have new resonator suitable for HA2
https://www.acoustics.co.uk/pal/wp-content/uploads/2015/11/Booster-Amplifier-User-Guide.pdf (https://www.acoustics.co.uk/pal/wp-content/uploads/2015/11/Booster-Amplifier-User-Guide.pdf)
Images: corresponds with link from above .
Wesley
here is set of HQ schematics
Wesley
No power supply self oscillated FE
The difference of potential is created by Metal roof of 1 story ( 1 floor with attic )
The by PhD James Corum from Viziv diameter of the top capacitor should be multiplied by factor of 4 (at best) to have distance between earth and top capacitor calculated.
Top capacitor that is elevated to this height is not ionizing air and not influenced by earth.
But that depends from ground properties below the top capacitor or roof of the house.
So we may just base on fact that square area of top capacitor should be as large as possible, but not to large vs height.
Note: In one of the tests battery was used to power transistor from picture 1
The current inside the light-bulb is so strong....
( well.. I should say to be correct: The voltage is so big,and current is as it is )
that the Tungsten of the lightbulb is not able to be heated due to internal gas/ vacuum of the lightbulb momentary HV breakdown.
Note : simulation of the same can be easily made by placing flat pieces of sheets of aluminum or copper or even rust protected other metals on the roof or elevated from the ground.
These sheets can be just edge to edge lying down and yet touching one on another .
Wesley
Electrical Energy of Kapanadze
https://youtu.be/yNs2wc8nRJw (https://youtu.be/yNs2wc8nRJw)
Wesley
Look at picture below.
https://youtu.be/yNs2wc8nRJw?t=12 (https://youtu.be/yNs2wc8nRJw?t=12)
Ten Spark Gap to u mnie byl Bomac USN-CBNQ-1B40 Argon filled Gas Switching Tube
1kW impuls.
Ty zastosowales kondensator ot R-140 a ja malem pod reka pare ceramicznych kondensatorow.
Na jedno wyszlo.
Nie radze ci publikowac Twojego video. Nie ryzykuj teraz.
Wesley
Yes, you right this is the way.
here:
I did it.
Wesley.
Dobra nie ma co,- patrz w dol.
I nie wychodz z tym teraz . Nawet nie trzymaj tego u siebie.
Zawiez do Krakowa.
Hans potem podjedzie do ciebie, 5 godzin z Hamburga.
Do Stefana nie daleko, ale to twoja decyzja.
Wesley
I have got numerous of requests to post more information in regards to my last video in other languages.
First is my response to Dr Hans:
Das Gerät wird jetzt nach Krakau transportiert.
Ja, er will es dir geben.
Sie können sich an Stefan wenden.
Ich bin jetzt dagegen.
Er kann sich Konsequenzen aussetzen.
Nein, ich kann jetzt dem deutschsprachigen Publikum keine
umfassendere Erklärung geben.
Wesley
PS:
Funken-Lücke-Tube P24 1139 habe ich wenige von ihnen. Ich werde es am Montag senden
As requested I'm posting model number of spark gap
with trigger.
Tested :
- triggered by small voltage impulses up to 267 kHz passed
- spectrum center of the bandwidth peak regulated from 6kHz to 267kHz passed
- width of peak included all F of all L ( L1;L2;L3;L4) moving from low 600Hz at front edge up to 2.4kHz
so we say around 2.4- 0.6= 1.8kHz in average)
- sliding bandwidth of interest up down passed with great success.
- sides of bandwidth of interests are irregular and quite sloping.
but this is not important at all. The top must include all F of each individual resonance and move up or down on request.
Note:
bandwidth peak is the center of the highest amplitude region having at its lowest still 75% of amplitude for frequencies of interest region.
Application:
- Tesla coil passed
- structure from my video. passed
Description:
1. 0.15mm copper foil 2m wide 10m long x 3= 6x10 area as top capacitor at 15m high.
2. cooper foil is one side adhesive,applied on the top of flat dielectric below.( can be commercial from Home Depot)
3. regular flat wooden roof served as base to the structure.
3a.yes, at one point structure was elevated but due to strong wind, weight of dielectric was increased
But that wind lead me to remarkable conclusion.
(Results of 3a are not to be published yet.)
Dr Hans, ich werde Ihnen Ergebnisse am Montag in demselben Paket mit der Funken-Lücke senden.
Stefan hat seine eigenen Probleme jetzt. Belästigen Sie ihn so nicht, bis wir bereit sind.
Ich respektiere ihn sehr viel.
https://www.radioexperimenter.us/exp-1966/precision-slotted-line.html (https://www.radioexperimenter.us/exp-1966/precision-slotted-line.html)
Instrumentation:
- E4407b
- R3267
- HP4194a
at no voltage test:
-R3754B
performed at S11, S21, S12, S22,
Note: from 10Hz to 10kHz S parameter is not available as HP4194A was used due to R3754B limitation.
problem:
-R3754B starts from 10kHz but it goes up to 150MHz if needed
so for low F from 10Hz i used HP4194a at gain phase mode with rectangular graph.
-HP 8753D 30 kHz to 3 GHz was not used.
Correction:HP 8753D was checked again and my version of it works from 30kHz to 6 GHz
So for anything above 30kHz is OK.
-Surface wave origin and intensity (compared Cost Rica and New York)
Look exactly here: this will explain you everything:
this was the whole problem of all of these guys.
https://youtu.be/yNs2wc8nRJw?t=352 (https://youtu.be/yNs2wc8nRJw?t=352)
Yes I have wide noise generator but spark gap with trigger, gives me so good results.
Conclusion:
- results of this tests explains why Tariel Kapanadze used spark gap at his first devices.- next test is oriented on comparison of furnace spark generator frequency response vs spark gap in dielectric.
- common factor is that in both cases we deal with dielectric:
a. foil on the roof .
b. HV wire prick by sharp end wire connected to gas furnace HV spark generator from Tariel show to Wesley in 2011
- test works good on much smaller cooper area serving as top capacitor (such as 2x2m on dielectric)
-having few pieces such as 1x2m is more convenient.
-lying on the roof few pieces at different angle works great, as its is capacitive reactance can be regulated by moving them
Note:
Tests have been provided under my supervision but with help of two guys (after virus I'm not so strong yet)
- energy intensity geographically varies in Costa Rica test site and New York, New Jersey,
That would explain why Akula work in Kazakhstan and did not work at Riga Latvia
and in Hamburg Germany.
But Ruslan at the same Riga did not have much problem as he was tuned there.
However Ruslan was not examined by Tiger or me yet.
Tiger couldn't explain it too. He is back home now asking me to visit him in Kazakhstan.
Energy density note is my own assumption, and can't be taken for granted .
Note: I'm not going to visit Tiger now. It is to close to Moscow influence.
Wesley
Please look up in previous post find 4194A in gain phase mode ( in green color)
Wesley
Some explanation to the questions in Russian as requested:
Q. Привет, Уэсли.
Я всё же считаю, что у Капанадзе и его репликациях происходят манипуляции с магнитным полем индуктора. То, что ты показал это другой тип устройств.
Wesley response:
Я думаю, вы ошибаетесь. "Манипуляция" - то процесс a не источник энергии.
Никто кроме меня когда-либо не указывал на происхождение энергии в устройствe Тариэля Капанадзе
Я прав на все 100% Hикакого другого объяснения, поскольку никогда не было каких-либо объяснений.
У Тариэла было только два варианта. Отправлять энергию из точки А в В или извлекать энергию из волновода Шумана.
Вот почему б..ы так cошли c ума сейчас. Все они молчат в ожидании директивы, что со мной делать.
В моем блоге у меня полный иммунитет. Ho б..ы делают все возможное.
Q.Электроэнергию этого Viziv я смогу у себя поймать и пользоваться? Когда его включат?
Wesley response:
Viziv работает уже 52 дня. Но они до сих пор держат головы вниз. «Электроэнергию этого Viziv я смогу у себя поймать»
Нет Вы не можете Это многофазных 21 элементa, чтобы соответствовать и изменения кода доступа каждые 2 секунды
Q.<"Все они молчат в ожидании директивы, что со мной делать"> - разве они вообще могут с тобой что то сделать?
А для Viziv нужен специальный приёмник энергии со своим кодом доступа? Хакнуть можно?
Если энергии идёт до дури, то можно же просто хоть часть снимать?
Энергия радиоволн то есть!? Пусть не вся мощность, а хотя бы часть.
Детекторный приёмник, например. На каких частотах она передаёт? Я эфир просканирую.
Wesley response:
Здесь вы показываете полное отсутствие понимания волны Ценнека . частотa ~ 18 кГц.
Посмотрите мои последние два видео и попытайтесь понять .
Проблема в том, что https://youtu.be/zE4GjB1cWLQ?t=565 (https://youtu.be/zE4GjB1cWLQ?t=565) - это все, а не только электричество.
Они будут знать ваше точное местоположение и каждый ваш шаг. Вот почему Визив не подавляет головы.
Это США, и мы можем остановить Визив, если они нападают на нашу конфиденциальность.
Вы не можете получить волну Ценнека, так как эта волна не распространяется в дальнем поле.
Так что вы не можете отсканировать волну Ценнека.
Это: поляризация и фазовое соотношение стоячей волны в приемникe,
- теперь взаимодействующей с Поверхностной волной, известной как Волна Zenneck
А в россии? Они могут даже дать некоторым из вас электроэнергию за полцены в обмен на информацию, которую они собирают о вас.
Q.А как они дадут энергию за полцены, если волна не распространяется в дальнем поле?
И разве эта волна имеет огромную информационную пропускную способность, чтобы заменить собой все магистральные
средства связи (это весь оптоволоконный трафик Земли, что ты перечислил в видео)?
Wesley response:
Волна Ценнека существует на границе раздела между двумя диэлектриками с различными свойствами или между материалaми земля. и воздух.
Это называется интерфейсом, -воздух, который имеет устойчивые диэлектрические свойства -земля «среда с потерями»,котopa имеет нe устойчивые
Вам легко понять это без физики.
Представьте себе слона, который сжимается тяжелым катком и теперь плоский, но живой и может поместиться в интерфейс.
Волна Ценнека излучает не в пространстве XYZ, а в пространстве XY, но это является только экспрессивным - это только выразительное объяснение.
Волна Ценнека излучает в Near Field Волна Ценнека не излучает в Far Field https://en.wikipedia.org/wiki/Near_and_far_field (https://www.youtube.com/redirect?stzid=UgwRN-7DgeoTPTr3VEV4AaABAg.8sDgbeiOSu38sEbZodjVtc&q=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FNear_and_far_field&event=comments&redir_token=ioWZMZaCGY8rjAPzTYMyN9LMqsF8MTU1MjMwNTQwMUAxNTUyMjE5MDAx)
Q.Спасибо за разъяснение. Теперь базовая картина нарисовалась! Получается, что она стелится по земле, создавая половину стоячей волны в воздухе
и другую половину стоячей волны в земле. Волна стоячая и никуда не бежит от передатчика.
Радиус действия передатчика ограничен одной полуволной от частоты 18КГц. 18КГц - 16,666км. 1 полуволна будет равна 8,333км.
Пучность стоячей волны будет в 4,1км. Род поля - магнитный, без электрической напряжённости поля (E).
То есть это генератор магнитного поля с радиусом 8,3км. На расстоянии 4,1км магнитное поле максимальное.
Wesley response:
Нет, снова Вы ошибаетесь.
С обычной Tx электромагнитная волна производится один раз, а затем вы можете отключить Tx Bолна будет продолжать путешествие.
Волна Ценнека в интерфейсе должна быть TEM в режиме TM Если вы отключите Tx, эта волна больше не существует.
https://www.electronics-notes.com/articles/antennas-propagation/rf-feeders-transmission-lines/waveguide-modes-te-tm-tem.php (https://www.youtube.com/redirect?stzid=UgwRN-7DgeoTPTr3VEV4AaABAg.8sDgbeiOSu38sEnFcZV-wA&q=https%3A%2F%2Fwww.electronics-notes.com%2Farticles%2Fantennas-propagation%2Frf-feeders-transmission-lines%2Fwaveguide-modes-te-tm-tem.php&event=comments&redir_token=ioWZMZaCGY8rjAPzTYMyN9LMqsF8MTU1MjMwNTQwMUAxNTUyMjE5MDAx)
Волна Ценнека в интерфейсе TEM в режиме TM существует при включенном Tx Так как нет нагрузки, то нет потерь в целой земле / воздушный интерфейс
Это обычная физика, друг мой, но это экзотическая часть физики для большинства профессионалов. Чтобы понимать это,
Вы должны сначала понять то, что - волновод И понять, что земля - это стена волновода Шумана.
Земля также это <'средa с потерями'> lossy media, для волнового интерфейса (Взаимодействие с воздухом.)
Земля также это разрядная стенка для электрических ударов и колебаний энергии внутри волновода Шуманa
И поскольку диаметры XYZ волновода Шумана не меняются, и существует резонанс Шумана, который является доказательством
существующей там энергии 'переменного тока'/сигналa/ wave/волна мы можем погрузить зонд внутрь этого волновода.
И это - наш Приемник
More in next post.Picture 1
This process is similar to Slotted Line but instead of being used to measure impedance it acts as active Rx.
The probe is interacting now with wall of waveguide( for simplicity take cylindrical waveguide)
due to XYZ geometry and charge distribution if active probe is used.
Think of it as probe from inner side instead form outer side.The opposite of that from patent.
https://patents.google.com/patent/US3391355 (https://patents.google.com/patent/US3391355)
As we humans are inside of it.
So traditional slotted line is compromise taking place due to its physical dimension.
and by that we are no longer limited with frequency response of Slotted Line
More in next post.
Q.Вот теперь вообще понятно стало! Не все твои зрители учёные и знают вещи, которые для тебя элементарны.
Поэтому столько вопросов было. Я не мог представить как выглядит эта волна и как себя ведёт в среде.
И ты объяснил не только мне одному. Многие, кто прочитает эту переписку, тоже поймут об этой волне.
Таким образом, я своими вопросами подтягиваю тебе аудиторию, которая прочитав комментарии лучше
поймёт суть твоих идей, что ты хочешь донести.
Note:
I can understand all of 27 Slavic languages but I can speak only few of them so I'm sorry I can not translate
based on given group request, as I'm not able to be accurate in writing.
Wesley
Related to previous post look up in green color
Tariel Kapanadze did not have slotted line so he prick HV wire to find the right phase and maximum amplitude, to adjust phase relation .
https://youtu.be/KLAPRNWuAn4?t=639 (https://youtu.be/KLAPRNWuAn4?t=639)
Wesley
related to post from above (brown color)
Wesley
Related to subject from above.
Continuation by implementation of another block
to previous schematic ( look here)
https://youtu.be/yNs2wc8nRJw?t=265 (https://youtu.be/yNs2wc8nRJw?t=265)
Wesley
https://www.youtube.com/watch?v=H7sp2hzYWf0 (https://www.youtube.com/watch?v=H7sp2hzYWf0)
https://www.nature.com/articles/nature08294 (https://www.nature.com/articles/nature08294)
The link below is explanation of picture FErers222 -1.jpg ( from post above.)
https://www.youtube.com/watch?v=QlBE_H1b_e0&feature=youtu.be (https://www.youtube.com/watch?v=QlBE_H1b_e0&feature=youtu.be)
Wesley
Q:Warning! Меня человек предупредил по поводу данного видео: "
Эта лампа сильный источник гамма излучения, играться не рекомендую.
С фиолетовыми излучениями предельно осторожным надо быть."
A man warned me about this video
This lamp is a strong source of gamma radiation,
I do not recommend playing.
You should be extremely careful with violet color radiations.
Wesley's response:
Вы меня совершенно запутали
Я думаю, что вы ошибочно размещены - ответит в неправильном месте( по ошибке отправили ответит не в том месте)
I think you mistakenly posted answer in the wrong place
Если вы говорите о Spark Gap:
If you are talking about this Spark Gap
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532343/#msg532343 (https://www.youtube.com/redirect?event=comments&stzid=UgzR9C2RUISLNZ-LuJl4AaABAg.8sMAZhRJWb68sMFoquGXwK&redir_token=sHvkZVv6d8FJMDfmaTx55vI-3HZ8MTU1MjQzNTA1OEAxNTUyMzQ4NjU4&q=https%3A%2F%2Foverunity.com%2F17735%2Fwesleys-kapanadze-and-other-fe-discussion-forum%2Fmsg532343%2F%23msg532343)
Oтвет:
Kаждый разрядник генерирует рентген,( X-ray)
Every Spark Gap creates X-ray
Striking one stone by another stone creates X-ray.
я не согласен с вами что эта трубка разрядника создает гамма.
Это абсолютно невозможно. https://en.wikipedia.org/wiki/Gamma_ray#Gamma_ray_production (https://www.youtube.com/redirect?event=comments&stzid=UgzR9C2RUISLNZ-LuJl4AaABAg.8sMAZhRJWb68sMFoquGXwK&redir_token=sHvkZVv6d8FJMDfmaTx55vI-3HZ8MTU1MjQzNTA1OEAxNTUyMzQ4NjU4&q=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FGamma_ray%23Gamma_ray_production)
У меня есть целая лаборатория физики элементарных частиц.
Но вместо того, чтобы спорить с вами, допустим, что вы правы, так чисто теоретически.
Если вы правы, говорите как ..?
Я уверен, что у вас нет ответа.
Each Spark Gap generates X-rays, (X-ray)
I disagree with you that this Spark Gap tube creates gamma.
It is absolutely impossible.
Some spark gaps have been doped with CS137 and so on.
But that has nothing to do with generating gamma due to its Spark Gap operation.
I have whole lab of particle physics.
Some material for you to watch about this part of my lab.
Лекция для вас:
https://youtu.be/GdlkeI0bXy4?t=32 (https://youtu.be/GdlkeI0bXy4?t=32)
https://www.youtube.com/watch?v=KxEqiS5H1DE (https://www.youtube.com/watch?v=KxEqiS5H1DE)
https://youtu.be/izzujmKROWI?t=164 (https://youtu.be/izzujmKROWI?t=164)
https://youtu.be/k2PJVIkyW5Y?t=34
https://youtu.be/CQ3gPFfgDp8 (https://youtu.be/CQ3gPFfgDp8)
Wesley
Wesley,
About to buy either a new cheaper spectrum analyzer or an older circa 2000 VNA. Was wondering if you have a VNA with FFT capability from the era I see in your rack can it substitute well for the newer higher memory Spectrum analyzer with partial vector analyzer capability? In other words can you use your VNA for most of the SA functionality to the effect you would reach for this tool?
Also have you happened to find any option to allow power factor calcs with a VNA if one has a differential probe? Some of these units look to have two inputs which beats a SA with a tracking gen.
I have been using the computer interface Spec Analyzer and just need a dedicated unit so thought these era 2000 units might be better with less memory but the ability to properly impedance match with a Smith charts and correct VSWR calculations.
Thanks,
Mick
In here I have 3 but actually two of them
( the third one is 4194A Gain Phase Analyzer this is great toy.)
Faster than anything new I have tested in the market.
Just "lightning fast"
in addition I have Impedance parameters program similar to LCR that was used by previous owner.
Some kind of exotic luxury option.
here is the spec.
https://s3-eu-west-1.amazonaws.com/content.microlease.com/static/Catalogue/Datasheets/Advantest_R3754B.pdf (https://s3-eu-west-1.amazonaws.com/content.microlease.com/static/Catalogue/Datasheets/Advantest_R3754B.pdf)
-HP 8753D 30 kHz to 3 GHz but I have 6GHz version.
http://www.testequipmentdepot.com/usedequipment/hewlettpackard/networkanalyzers/8753d.htm (http://www.testequipmentdepot.com/usedequipment/hewlettpackard/networkanalyzers/8753d.htm)
I must correct some information. from the previous post.
8753D Network Analyzer has a frequency range from 30 kHz to 3 GHz, which can be extended to 6 GHz with
Option 006, a resolution of 1 Hz, power range of -85 to +10 dBm, and a maximum input level of 10 dBm.
This model has a built-in S-parameter test set, which gives the user forward and reverse measurements, enabling
them to fully characterize their instrument with one connection.
https://www.apexwaves.com/analyzers/keysight-technologies/8753-network-analyzers/8753D (https://www.apexwaves.com/analyzers/keysight-technologies/8753-network-analyzers/8753D)
4194A gain phase analyzer plus impedance it starts from 10Hz.
Wesley
More of R3754B
https://www.advantest.com/documents/11348/146687/pdf_mn_ER3754_user_MANUAL.pdf
Wesley
So I can go the lowest to 10kHz with measurement of:
- my Tesla coil resonances.
-any resonance circuit
My VNA or NA are not the newest one but real goodies.
What I must compromise:
-everything below 10kHz.
For that I use 4194A. that is ~30 years old unit, and nothing can be better in this price range.
But..
4194A is not VNA
So what is the solution:
Here is quite tempting option:
https://www.advantest.com/web/advantest/products/electronic-measuring-instruments/r3755a-r3760 (https://www.advantest.com/web/advantest/products/electronic-measuring-instruments/r3755a-r3760)
The R3755A network analyzer
Note: do not look at the R3760 network analyzer,
Where to buy:
https://www.ebay.com/itm/ADVANTEST-NETWORK-ANALYZER-CARD-R3755A/131555851726?epid=1225141993&hash=item1ea156fdce:g:KoUAAOxy4fVTAFNM (https://www.ebay.com/itm/ADVANTEST-NETWORK-ANALYZER-CARD-R3755A/131555851726?epid=1225141993&hash=item1ea156fdce:g:KoUAAOxy4fVTAFNM)
they have 4 of them.
But shop around before you buy.
6. software source:
on that page click on button application
go down of the page to Firmware and read if the software is right for you.
This is nice modern tool( ~2012) made by reputable manufacturer
but again starts from 10kHz..... to 300MHz
so after you buy it and it works you can't go lower than 10kHz
Wesley
related to previous post
Wesley
Wesley,
Also can one use a frequency divider in order to go below the 10kHz or do we get too much impedance loading with low frequencies for such a solution to be practical?
I think there are multipliers to go the other way but likely one has to give up something to get like SNR or dynamic range...
Not generation but wireless charging, over kilometers :
https://thetechranch.com/global-energy-transmission-provides-ultimate-solution-for-infinite-drone-flight/
This thing is 70 years old concept.https://www.youtube.com/watch?time_continue=4&v=A58auF2dhCQ (https://www.youtube.com/watch?time_continue=4&v=A58auF2dhCQ)
Wesley
Microwave has been known for wireless charging way of rectenna for years, just keep the beam width tight but it is still lossy except for near field loose coupled resonance, if one can parallel keep high Q and get eventual gain but major pain. There are more tricks of the trade like anything but for a drone is not efficient use of energy.
Wesley I was interested in which you reach for more often impedance or VNA, just curiosity and in the case of the impedance analyzer how do the in and output impedance work if not limited to 75 ohm coupling, I have never used.
I can do quite a bit with VTVM bare bones so yeah I know I don't need this gear and already have some good stuff for my audio business so may not bother. Just would be cool to have some RF gear to help with antenna design.
Thanks again
Let's go to: https://www.youtube.com/watch?time_continue=4&v=A58auF2dhCQ (https://www.youtube.com/watch?time_continue=4&v=A58auF2dhCQ)
The interview is with : Leonid Plekhanov CEO of Global Energy Transmission (GET corp since April 2015.) established in 2015.
But patent application is filed as company ( not as corporation,) with 2 years later date. 03 17 2017.
So it looks like These Russians, did not close their company,prior to opening corporation
and in USA company can be you, and you, can be company.
Company is your "second last name" if you will.
So that Patent Application is not property of corporation unless stated.
https://www.youtube.com/channel/UC_9zn1vg6UbvFmJHj50bUcg/videos (https://www.youtube.com/channel/UC_9zn1vg6UbvFmJHj50bUcg/videos)
Publisher had only 20,224 views for all of their videos for all of this years.
Video generated
only 83 views since published on Jan 21, 2019.
in other piece of paper they are shown as highly educated Moscow
QuoteMoscow Institute of Physics and Technology (MIPT) in 2005
(Department of Physics and Quantum Electronics),
Master of Science in applied physics and mathematics. and so on.
Compared : video testimony and this link:
http://getcorp.com/get-introduction/team/ (http://getcorp.com/get-introduction/team/)
Literature:
https://thetechranch.com/global-energy-transmission-provides-ultimate-solution-for-infinite-drone-flight/ (https://thetechranch.com/global-energy-transmission-provides-ultimate-solution-for-infinite-drone-flight/)
http://www.freepatentsonline.com/y2017/0271925.html (http://www.freepatentsonline.com/y2017/0271925.html)
https://patents.google.com/patent/US20170271925A1/en (https://patents.google.com/patent/US20170271925A1/en)
https://patentimages.storage.googleapis.com/ba/95/34/16c08cb522ba87/US20170271925A1.pdf (https://patentimages.storage.googleapis.com/ba/95/34/16c08cb522ba87/US20170271925A1.pdf)
Wesley
Step1 measuring of real structure of Tesla coil with VNA
We have been talking about VNA and NA
Wesley
step 2. measuring of real
Tesla coil structure with VNA
Original link:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172114/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172114/)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531984/#msg531984 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531984/#msg531984)
Wesley
step 3 - 3aa. measuring of real
Literature:
page 3-9
page 3-10
https://www.advantest.com/documents/11348/146687/pdf_mn_ER3754_user_MANUAL.pdf (https://www.advantest.com/documents/11348/146687/pdf_mn_ER3754_user_MANUAL.pdf)
So one simple measurement and you know everything about it.
It'll save you days of work .
So is it that simple?
Yes and no.
It is simple but there are some variables that can not be solved by use of VNA.
example: your load ( output) is measured as if it was 50 ohm.
So you can connect in real test few lightbulbs in series to compensate for 50 ohm.
And that's another discussion.
Wesley
Original link:
step 3.aaa measuring of real
Note: Attenuator is needed , but:
a. it is good to measure output voltage of your VNA
or check what is the voltage it in manual.
b. Than prior to use VNA, connect tracking generator from your spectrum analyzer or any sweep generator
to primary of Tesla coil and at secondary connect your oscilloscope.
c. find frequency that has maximum amplitude on your oscilloscope.
d. based on this measurement you will know already a lot about your Tesla coil and you may not need VNA.
Voltage present in secondary of Tesla coil will allow you to get proper attenuation required by manual of your VNA.
e. generator of your working prototype should be tuned to red region of frequency generation
Wesley
VNA
Some of the VNA have been made for production line of X-tal
crystal oscillators.
And they have build in more tools to
measure resonators and resonating circuits.
Tesla coil is:
- air transformer
- resonant transformer
- can act as filter
Assembly made of coils and capacitors can be treated as one DUT
(Device Under Test )with single input and output.example of possible measurements is listed below:
Conclusion.
That what was taking months and years now can be done in few minutes.
Most of you are happened to dig in the dark for years, and VNA is your pair of glasses.
But you need some flashlight too.
I do really try, to provide it for you guys
Device made by you, has one purpose, and that is Electrical Energy for Free
Such a devices are exotic as:
- scientific base of energy origin is questionable.
Note:Wesley provided explanation, in this part of forum.
- prior art exists mostly in form of unexplained pieces of information
- any device that is made for any purpose must be replicable (able to be copied or reproduced exactly.)
Note: on the picture below
-any time crystal resonator is used for our purpose you can use word filter
and Tesla Coil can be our filter .
That will analyzed in next post.
Wesley,
Yes yes the VNA is better than graph paper and a a scope and mush guessing in the dark from all the interactions of RF. OK I ordered old HP for few hundred bucks, hope it gets here and works, of course it will not be aligned so next I must ask do you think it is necessary to have the alignment kit or to just to rent ? This unit supposedly goes from DC to 2 gHz and i don't plane on working more than a few mHz aside from that old 300 mHz battery we discussed if I ever get back to it.
Also a large expense are the probes, what does one need to work up to a few mHz besides some very good coax and connectors for the DUT? I have heard that using the BNC to SMA adapters and some premade SMA cables can work pretty well, your thoughts?
Thanks,
Mick
Wesley,
As always digesting the very good info you post and the Smith tube video is super cool! Thanks for all the charts and explanations.
Hey someone obviously wants you around.
Can I ask what it was you did in professional life, or is this too personal?
Thanks again,
Mick
Thank you for kind words.
Before you pay for VNA or NA.
some pros and cones.
https://www.youtube.com/watch?v=LN9PKKdFibo (https://www.youtube.com/watch?v=LN9PKKdFibo)
note:
-Calibration kit can be any.
-look at second picture.
some additional literature:
http://www.rfwireless-world.com/Terminology/S-Parameters-Scattering-parameter.html (http://www.rfwireless-world.com/Terminology/S-Parameters-Scattering-parameter.html)
http://www.antenna-theory.com/definitions/sparameters.php (http://www.antenna-theory.com/definitions/sparameters.php)
Question is:
Do you need S parameter?
No you do not need S parameter but is good to have it.
And that gives you a lot of room to hunt for used VNA or NA that is not compromised like VNA from video.
Wesley
Quote from: F6FLT on March 17, 2019, 07:45:23 AM
Remote energy transmission, either thanks to the near field at a short distance that does not greatly exceed the size of the resonant system, or at a long distance by radiowaves beams or light beams, are conventional techniques known since the beginning of the 20th century.
Their efficiency is poor, and implementation is difficult, especially for powering mobile equipment, which is why the industry has made little use of them so far.
It has nothing to do with free energy.
Do somebody think that this kind of science results are unused or not improved since these papers/ knowledge publication worldwide ?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Dd&AP=&PR=&PD=&PA=Manfred+gregor&IN=&CPC=&IC=&Submit=Search (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Dd&AP=&PR=&PD=&PA=Manfred+gregor&IN=&CPC=&IC=&Submit=Search)
F.e. un-/ visible light beams in Terra-/Giga-Watt range( per sqcm)
For example for lunar/orbital/astral "Solar Farming" and 24/365 to earth transmission.
Or as Fusion reactor beam.
Or as welder.
Or for tunnel/channel construction ( stone/rock melting)
Similar research :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Winfield+salisbury&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Winfield+salisbury&CPC=&IC=)
East-/West-world comparison, completing and improving
As "13 years old boy/girl " you can soon begin to change your world like he did :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FSebastian_Ziani_de_Ferranti
Age in numbers does not indicate intelligence or wisdome.
I agree Zenneck waves exists but misconception is it's radio waves.
Tesla knew about theoretical explanation of this kind of waves and this is what
we should investigate first. However the notion that it's an explanation of free energy is far from truth.
Free energy is much more simple.
Quote from: forest on March 17, 2019, 09:35:38 AM
Not only Tesla but Marconi in 1918 in Bolinas California have been trying to do that what Viziv is doing.
Till RCA with Government shut Marconi's project down in 1921.
So what I'm doing is fallowing Tesla and Marconi steps.
I'm investigating the phenomena.
TEM Electromagnetic waves can be polarized in TM or TE mode.
I do not see any misconception here.
Free Energy is much more simple
If you can share you opinion in this area it will be interesting.
Wesley
Wesley,
I think the S parameters are important especially if one is trying to determine Brewster angle or whatever proper terminology is for Z wave.
Well lets see if the unit I purchased works on arrival before looking at other options,
Agilent 89441A
however this would likely be a good option if not:
https://store.siglentamerica.com/product/sva1015x/
Thank you for the info on the standards parts. I am interested in what you think about probes or using SNA cables and adapter, highest and best use connecting DUT?
Brake lines messed with, besides being underhanded evil that is downright lacking in class and taste. I think that Keshe guy is also a main suppression agent for them or else he would not be able to freely rip people off, he did the same thing to his own worker and this mans gf. I guess if one wants to be a con man then simply sell OU bullshit. Like world improvement ministries guy with a rap sheet of cons going back years. I think they find these scammers and then somehow use them to data mine so everyone who has the answer or is close should take heed.
Had you known what you know now maybe you would not have put your neck out for everyone's benefit but then again it can only be accepted as evidence of success.
When books are burned or other data is censored or buried, this is predominantly for one reason.
If someone here wants to think empirically and wind some coils and attempt some actual bench work; like so many of the amazing people at this site then great, if not comments should be reserved and respectful from the theoretical thinkers who have not yet ventured into the lab.
VNA uses directional coupler so if you do not have VNA
but NA you are not is bad situation at all.
So it is must know it and must have it for many applications.!!!!!
#158: Directional Coupler Basics & how to sweep SWR of an antenna | Return Loss | VSWR
https://www.youtube.com/watch?v=iBK9ZIx9YaY (https://www.youtube.com/watch?v=iBK9ZIx9YaY)
Used directional couplers you can get for 1 to 5 dollars or less from hamfests, or other similar places.
I know that it sounds crazy to some of you but, don't worry about lower range written on of them.
typical Directional Coupler works from above DC up
Try it.
Wesley.
Shocking-effect. ?
Hello Ansis,
It would be no wonder if we estipulate these claims by 50 Hz net-grid frequency x HF-factor :
https://patents.google.com/patent/WO2004100349A1/en (https://patents.google.com/patent/WO2004100349A1/en)
Voltage dividing by frequency changes and possible claimed results, " Example 1"
https://patents.google.com/patent/US5130608A/en (https://patents.google.com/patent/US5130608A/en)
"Using Ohm's Law" for the theory and compare with reality !
wmbr
OCWL
p.s. : pulse power / Usherenko-effect
p.s. II : for all household heating appliances usefull , hot water and cooking related
Yes.
Shocking effect was discovered when load with non isolated wires was merged into water
with naked hands and we see no short circuit and we see light and we where not electricuted at all.
Next shock was wire diameter.
0.5 mm wire was enogh to transfer energy to long distances!, without looses!!!
It means, if Kapanarze use Energy Transver, he uses 20-300kHz fake "water pipe".
And yes, Kapanadze was in Latvia for 3 month!
And what?
Nothing.
He spend 20 000 Lats(currency) make health procedures in Linezers hospital and go home!
Why no results?
Because of no possibility to fake that "device".
All guys ask him, to give directions, materials to search for his MAGIC to come true!
Nothing.
It is "black box".
If peoples are lying to others, than that is only FOR MONEY!!!
After the incident Tariel didn't want to deal with L..ma any longer.
Dear Void I know everything that you don't
I speak their language as if I was one of them.
Wesley
Hello Wesley. Maybe you have seen some of these old Kapanadze videos before, but here are some interesting
old videos of Kapanadze demonstrating some of his other types of free energy devices.
Several old videos showing Kapanadze's disk generators of a few types, what looks to be a car engine
that is running on water?, and a 'hydraulic' free energy generator. Where does an architect come up with this stuff? ;)
Is Tariel Kapanadze good friends with aliens? ;D
Установка Tariel Kapanadze/Тариеля Капанадзе (Одна из первых демонстраций)
Installation Tariel Kapanadze / Tariel Kapanadze (One of the first demonstrations)
(Some weird looking generator)
https://www.youtube.com/watch?v=2G8PVTKtOzA
Установка Tariel Kapanadze/Тариеля Капанадзе (Униполярка)
Setting Up Tariel Kapanadze / Tariella Kapanadze (Unipolary)
(Disc generators and a car engine running on water?)
(Edit: I don't see Kapanadze in the car engine demo part, but Kapanadze has mentioned once that he had such an invention)
https://www.youtube.com/watch?v=7JQSyQAVqzc
Гидравлический генератор Капанадзе 3 2015(сентябрь)
Hydraulic generator Kapanadze 3 2015 (September)
(self runs and lights up a bunch of lights)
https://www.youtube.com/watch?v=pdVLbev859M
There are a few more interesting Kapanadze videos on that same Youtube account some people
may not have seen before.
Wesley,
Will the directional couplers rated to 1gHz for CATV work for the low SW frequencies and if so which levels of DB loss will serve better for SWR measurements lower or higher?
Perhaps this is a level of heresy, I don't know just looking for affordable ways to tinker.
Thanks,
Mick
Wesley, guys, I posted some links to some video demonstrations of some other types of devices
by Kapanadze including some different types of disc generators, and an apparent hydraulic generator from 2015.
Apparently quite different approaches/configurations than Kapanadze's coil generators.
See those video links here:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532768/#msg532768
Apparently the video at the first link is one of Kapanadze's very first demos. It would be interesting
to know what Kapanadze had to say in that very early demo, to compare notes.
Do you think there could be a common principle behind all of Kapanadze's quite different types of generators
(coil, discs, hydraulic)? If you think there is a common principle behind them, what do you see that might be in
common between these three different approaches (besides possible tricks ;) ) ? If they all work on different principles,
then how could Kapanadze come up with three completely different approaches like that? If they are all working on the same
or similar principle, then what may be common between those three different types of Kapanadze generators?
A puzzle for you.
Quote from: NickZ on March 19, 2019, 11:04:13 AM
Nelson: Well, no you didn't clarify the part about self running and self feed back. As most all of the shown self runners are based on a feed back circuit, to keep them going.
In the video below, translated by Wesley, you are showing a device that needs only a one or just a few second pre-charge to start. But, then it is shown running on it's own for much longer than it would normally be expected from the small 9v battery one second change. As your device was stopped after a short while, I would now have to assume that it does not keep running for much longer than what is being shown, less than a minute. Is this correct?
https://youtu.be/mz9NRYQJJt0 (https://youtu.be/mz9NRYQJJt0)
You can also PM me, if you'd rather not discuss this openly. I would understand your position.
Hi Nick,
Nick, I am not going to detail the process used in this circuit, because I am currently disputing in court the intellectual property of this same system, which was retained in Germany by the company with which I was working, but what is demonstrated in this video is not an overunity system, the system was not projected to self run even could self run some minutes , with a resistive load.
It is a Resonant system with some interesting characteristics of "amplification"able to show more work in output than it is input in terms of efficiency, But it is all mere assumptions on my side that would have to be checked in the laboratory with independent and competent entities.
This is a unpublished video where you could see the same circuit without be totally assembled, but show how much power a 9v could store :) and provide output :) to a 60w 220v motor with a a 2kg metal disc on the load.
https://photos.app.goo.gl/JEYdPrEdXYX8AMHR6
All the best Nick
Hi Nick, my guess is Kapanadze somehow got his hands on a compilation containing a collection
of different inventions for free energy. Maybe some secret document(s) compiled by some department of
the former Soviet military, and somebody passed it on to Kapanadze, or Kapanadze otherwise got his hands on it.
Kapanadze seems to be a very smart guy. With that basic starting information, he was able to replicate several different
types of devices. Either that, or Kapanadze is pretty friendly with some aliens. ;D
That first generator that Kapanadze shows at the first video link I posted seems to possibly be
an electric motor driving a long shaft with several non-balanced fly wheels on it of different types, and
the end of that shaft drives a generator which loops back and powers the electric motor.
This appears to be different than his other disc generators which might only have two discs of two
different types of metal, and which may be some special type of homopolar generators.
Then the hydraulic generator appears to work on a completely different type of setup.
If you add Kapanadze's different coil generators onto that list, and possibly even a car engine that
can run on water, and you get quite a few different types of free energy generators coming from one man.
All of them are amazing on their own, if legit. Pretty mind boggling coming from one person.
So, either former Soviet secret compendium document of free energy inventions, or Tariel talks to aliens. ;D
You can also PM me if you'd rather not discuss this openly. I would understand your position.
Interesting video did you notice the black torrid, now that is interesting.
For TheOldScientist:
Dear TheOldScientist (https://www.youtube.com/channel/UCNbdkwT-LstmshlLDOqs7JA) I'm very impressed with your work.
However I have different opinion about DSW. It is 2019 now giving us new light on the subject matter.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532845/#msg532845 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532845/#msg532845)
The two related to surface wave videos are here. :
https://www.youtube.com/watch?v=zE4GjB1cWLQ&t=565s (https://www.youtube.com/watch?v=zE4GjB1cWLQ&t=565s)
https://www.youtube.com/watch?v=yNs2wc8nRJw&t=1s (https://www.youtube.com/watch?v=yNs2wc8nRJw&t=1s)
You may also view, not related but giving a perspective at some of my lab activities at:
https://youtu.be/k2PJVIkyW5Y?t=34 (https://youtu.be/k2PJVIkyW5Y?t=34)
Wesley
Part2.
https://www.youtube.com/watch?v=pqJzn8Y1HFw (https://www.youtube.com/watch?v=pqJzn8Y1HFw)
Basic explanation about transverse and longitudinal wave.
Electromagnetic wave ( also omnidirectional) do not require medium,
Transverse electromagnetic wave TEM .......... do not require medium,(TEM means directional wave)
Mechanical longitudinal wave .............................. requires medium ,
Electromagnetic Surface wave is TEM needs no medium but needs waveguide or interface. This wave is traveling inside of waveguide or interface from point of origination A to point where load is connected. B
That travel along the earth/air interface takes time
Wesley
Tom Bearden, Quote
"Some time in or before 2001, Bearden began to identify himself as "Tom Bearden, Ph.D.", and claims to have written a Ph.D. thesis,
he has never made this thesis public or provided affiliation or details.
The Skeptical Inquirer, among others, revealed that Bearden obtained his Ph.D. for "life experience and for life accomplishment" from Trinity College
and University, which the magazine describes as "a British institution with no building, campus, faculty, or president, and run from a post office box
in Sioux Falls, South Dakota".
This institution is not accredited by any recognized accreditation association and is generally regarded as a diploma mill.
It has since changed its name to Bronte International University and its exact location is uncertain."
You can call him "Doctor"
They are empty meaningless self-appointed titles.
"Bearden founded and directed the Alpha Foundation's Institute for Advanced Study (AIAS) to further propagate his theories.
This group has published papers in established physics journals and in books published by leading publishing houses,
but one analysis lamented these publications because the texts were "full of misconceptions and misunderstandings concerning
the theory of the electromagnetic field" and also states that 'existence of non-transverse waves in vacuum does not imply
that electromagnetism is not a U (1) gauge theory.'"
"Bearden supports his various claims with a wide range of crank theories, including the proposal that all electrical devices,
from batteries to electromechanical generators, in reality operate on vacuum energy.
These theories offer no concrete testable predictions, none have been published in independent, peer-reviewed physics
literature, and Bearden himself has little formal training in physics."
He is not a credentialed 'Renegade', a man of science – he is just self-proclaimed set of credentials.
Read also here about
Eric Dollard:
Wesley
Note: Above quote contains opinion expressed only.
And just because it is posted by me.
It is in category of my personal opinion expressed.
As it was reedited by me to fit socially acceptable format.
Hello there,
@Stivep i'm really interested in your theory about how one could extract energy from the "schuman wave guide" would you care to elaborate a bit more on that? i personally have only some ideas but no real theory or the needed know how to be able to come up with one
Visited:
Ted A.
2 FE guys
1 university
got 1 electron microscope
1683 miles in 2 days/2 nights
I'm going to bed
Wesley
literature/ source
main video. https://youtu.be/DNxob3yY4LE (https://youtu.be/DNxob3yY4LE)
picture1 https://youtu.be/DNxob3yY4LE?t=277 (https://youtu.be/DNxob3yY4LE?t=277)
picture 5 and picture 6 https://youtu.be/DNxob3yY4LE?t=471 (https://youtu.be/DNxob3yY4LE?t=471)
Electron microscope stack photo . ( I did not take pictures of it yet)
Visiting their laboratory https://www.tedmagnetics.com/ (https://www.tedmagnetics.com/) and getting their development results demonstrated :
C. O. P. : ? Impressed ?
https://patents.google.com/patent/US20150364979 (https://patents.google.com/patent/US20150364979)
https://patents.google.com/patent/US20090096219A1/en (https://patents.google.com/patent/US20090096219A1/en)
https://patents.google.com/patent/US20070242406A1/en (https://patents.google.com/patent/US20070242406A1/en)
Sincerely
OCWL
In that case why do it your self ? when you could have PM'd him?
and he has 3 threads with all the same name, I mean! why let anyone post here at all!!
Hi Wesley,
That's far out, what do you intend your first use of the EScope, checking out core materials?
You must have a large home or a very understanding wife as likely there is gear all over you place.
Mick
Hi Ianca,
That't the flux switching design used in old puter mag ram memory, also the magnetic boots Radis. Joe Flynn is said to have worked very hard getting the bugs out. http://www.flynnresearch.net/technology/PPMT%20Technology.htm
Requires a rectangular BH curve material. Or take a step further with conditioned magnets and then one has the Sweet device.
Samsung is said to make a motor based on flux switching but very difficult to find, not sure if they are allowed out of Japan.
Mk
Active or passive switch devices :
https://books.google.pt/books?id=iwEAAAAAMBAJ&pg=PA102&lpg=PA102&dq=wiegand+coil&source=bl&ots=05KqLezhpG&sig=ACfU3U0SOyaqT2Z6VAQuCZvO8NKvRb5bGw&hl=de&sa=X&ved=0ahUKEwjGvq6hhqHhAhWtyYUKHXyWDu8Q6AEIGzAF#v=onepage&q=wiegand%20coil&f=false (https://books.google.pt/books?id=iwEAAAAAMBAJ&pg=PA102&lpg=PA102&dq=wiegand+coil&source=bl&ots=05KqLezhpG&sig=ACfU3U0SOyaqT2Z6VAQuCZvO8NKvRb5bGw&hl=de&sa=X&ved=0ahUKEwjGvq6hhqHhAhWtyYUKHXyWDu8Q6AEIGzAF#v=onepage&q=wiegand%20coil&f=false)
Probably this is the " electromagnetic phenomena" used by him as "coated wire " :
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390 (https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390)
Flynn brothers research and usefull info https://web.archive.org/web/20040610131607/http://flynnresearch.net/ (https://web.archive.org/web/20040610131607/http://flynnresearch.net/)
Flynns company name now : https://www.qmpower.com/ (https://www.qmpower.com/)
This is for me the question for getting the right answer and solution !?
https://www.tedmagnetics.com/energy/wp-content/uploads/2016/05/Results_v4-e1464274784852.jpg
EMP/signal input and output ( kind?)
Comparing the power density from a " nuclear power to heat to electric plant" with Harry Goldbaums device
A nominal generator, approximately the volume of two men's shoe boxes, including the battery and control module, can supply extraordinary output.. Even operating at a low frequency of 400 hertz, the net induced voltage is +/- 8.4Kva/sec, (which is an hourly rating of 30.2Mva/hr (40,500Hp)). For comparison, power plants generate from 375 to 758 Mva; a wind turbine generates 2-3 Mva; a large heliostat may generate 280Mva..
show us how powerfull 10 cm x 10 cm x 10 cm [ dividing with 2 men' s shoebox volume and multiplicate with f.e. 29767 KW (~ 40500 hp by 400 Hz propulsion)] " EMP POWER CUBES " could become !
In this power range motor controler ,inverter and battery charger are in the 1 $cent/W production costs level.
From Euro-currency view and for comparison : $, Hongkong or U.S. ?
1 shoebox dimension : 35 cm x 20 cm x 10 cm = 7000 ccm
2 " : = 7000 ccm x 2 = 14000 ccm
EMP POWER CUBE 10 cm x 10 cm x 10 cm = 1000 ccm
29767 KW ( 400 Hz): 14 = more than 2 MW per " EMP POWER CUBE"
I think that 1/100 from 2 MW is for the common household sufficient :
" MICRO EMP POWER CUBE" ( POWER STICK )
like https://www.logistik-xtra.de/polysteel-600 (https://www.logistik-xtra.de/polysteel-600)
Taking oeko-energie.de and mtbest.net their " intelligent household" consume numbers,1/1000 from 2 MW is enough :
a theoretical 1 cm x 1 cm x 1 cm cube with 2 KW output( 400 Hz)
Negative "sink" Voltage energy
1 Wh = 3600 Wsec and by 400 Hz cycling : 3600 x 400 x 2 = 2880000 Wpulse( average, Wpulse peak?)
1. https://youtu.be/2G8PVTKtOzA?t=528 (https://youtu.be/2G8PVTKtOzA?t=528) here is ground wire. (
look at picture: ground wire of Tariel Kapanadze electro hydraulic device.jpg )
2. https://youtu.be/7JQSyQAVqzc?t=849 (https://youtu.be/7JQSyQAVqzc?t=849) this combustion engine is HHO operated ( exclude this part of video please)
3. https://en.wikipedia.org/wiki/Homopolar_generator (https://en.wikipedia.org/wiki/Homopolar_generator) in parts of video where Faraday disc is shown , it is to amuse the audience. ( ground wire is not excluded)
4. https://youtu.be/7JQSyQAVqzc?t=1299 (https://youtu.be/7JQSyQAVqzc?t=1299) here electric motor is powering Faraday disc, and Faraday disc
is producing synchronizing impulses for HV Generator only. ( ground wire is not excluded) https://youtu.be/qdJ1V_yDv-c?t=651 (https://youtu.be/qdJ1V_yDv-c?t=651)
It fits my explanation about
active probe. https://youtu.be/yNs2wc8nRJw?t=261 (https://youtu.be/yNs2wc8nRJw?t=261)5. https://youtu.be/7JQSyQAVqzc?t=4296 (https://youtu.be/7JQSyQAVqzc?t=4296) ( ground wire is not excluded)
6. https://www.youtube.com/watch?v=mG_FsBn2qxk (https://www.youtube.com/watch?v=mG_FsBn2qxk) capacitive active load coupling used many times by Tariel, Akula, Ruslan.( look at picture below)
so the wire has two functions:
- capacitive coupling ( not required when real ground is connected)
- when real ground is used : tuning circuit (The LC circuit) between ground and LC oof the coil.
7. verification by Stefanov of ground wire: https://youtu.be/e_kXFGNdANU?t=429 (https://youtu.be/e_kXFGNdANU?t=429)
short story:
Quote from: Void on March 25, 2019, 01:07:06 AM
Kapanadze has also claimed he had an invention of an internal combustion engine which ran on water.
Do not confuse two of them. HHO is different concept.
Should we ignore all of that because it doesn't fit in with someone's preferred speculations of how his devices work?
That is a serious question.
That is correct.
Receiver is more forgiving. I does not have to look like traditional Tesla Coil.
Wesley
Corum brothers:
Some helpful links:
https://en.wikipedia.org/wiki/Zenneck_wave (https://en.wikipedia.org/wiki/Zenneck_wave)
http://www.tfcbooks.com/mall/corum_bib.htm (http://www.tfcbooks.com/mall/corum_bib.htm)
http://www.tfcbooks.com/mall/corum.htm (http://www.tfcbooks.com/mall/corum.htm)
https://www.evangel.edu/press_releases/tesla-wireless-electricity-corum/ (https://www.evangel.edu/press_releases/tesla-wireless-electricity-corum/)
http://www.zamandayolculuk.com/html-3/dr.james.f.corum.htm (http://www.zamandayolculuk.com/html-3/dr.james.f.corum.htm)
https://www.eevblog.com/forum/dodgy-technology/bullshit-texzon-wireless-power/ (https://www.eevblog.com/forum/dodgy-technology/bullshit-texzon-wireless-power/)
http://rexresearch.com/corumzenneck/corumzenneck.html (http://rexresearch.com/corumzenneck/corumzenneck.html)
https://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf (https://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf)
https://www.reddit.com/r/Tesla/comments/9xixyv/the_corums_have_funding_texzon_technology_is_now/ (https://www.reddit.com/r/Tesla/comments/9xixyv/the_corums_have_funding_texzon_technology_is_now/)
https://www.reddit.com/r/Tesla/comments/9xixyv/ (https://www.reddit.com/r/Tesla/comments/9xixyv/)
the_corums_have_funding_texzon_technology_is_now/ go to below and look for links
QuoteIt's neat they're revisiting Tesla's early tower work from before 1910. I wonder if they're using the low frequencies Tesla talked about like the 4-12 kHz range he mentioned in patents.
Corum bros are already at 18kHz
Wesley
Backing up a little as another member brought up the TED device from Wesley's video mentioning Ted Annis. I would like to present the "missing" source of the energy for everyone to dig into.
https://earthsky.org/earth/mms-data-new-event-magnetic-reconnection-plasma
https://science.energy.gov/news/featured-articles/2018/10-03-18/
https://www.americanscientist.org/article/reconnecting-magnetic-fields
mkjekyl
some addition to magnetics with regards to Ted Annis
Quote//Dr. Prat-Camps said: "We have created the first device that behaves like a diode for magnetic fields.//
//or to make one magnet connect to another without the connection happening in the opposite direction.//
https://m.phys.org/news/2018-11-defy-19th-century-law-physics.html (https://m.phys.org/news/2018-11-defy-19th-century-law-physics.html)
Wes
http://cds.cern.ch/record/39474/files/11465.jpeg?version=1
Quote from: lancaIV on March 26, 2019, 09:25:59 AM
Sincerely
OCWL
Thank You lancaIV
picture #8 shows reluctance switches drivers.
That means flip/flops- each pair of banana connectors is for one reluctance switch.
Wesley
Ted Annis
100kW/h
reluctance switches should be placed at places next to bar magnets( magnets are visible from this position as they are behind the top bars)
Reluctance switches are not shown on the pictures .
Wesley
more of it
Wesley
Ted Annis 5a look for 1 page back
"Plastic or aluminum" doesn't play any function .
It is just structure added to keep everything together.
I'm little confused between 5a and 5b:
Location of magnets should be shown on my video file that
I have made during my visit .
But concept of operation of 100kW/h is exactly the same as shown on my
already published YouTube video.
Look here: https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg533027/#msg533027
Wesley
#1 For Ted Annis in subject matter:
Terfenol-D
1.5x10=15
15=$5000
5000/15=1/15 of the 10" =$33.333
And that is enough.
http://www.free-energy-info.com/Smith.pdf (http://www.free-energy-info.com/Smith.pdf) -go to Magnetic Resonance Power System Suggestions for Construction
https://www.youtube.com/watch?v=l0sGJCabMTY (https://www.youtube.com/watch?v=l0sGJCabMTY) mechanical force effect on Terfenol-D
https://lib.dr.iastate.edu/rtd/214/ (https://lib.dr.iastate.edu/rtd/214/)
https://www.youtube.com/watch?v=cG4fGxVlV7g (https://www.youtube.com/watch?v=cG4fGxVlV7g)
https://youtu.be/P99zwRV7Wns?t=6 Terfenol D
https://youtu.be/uc4EVhl-EuY?t=111
Terfenol-D, an alloy of the formula TbxDy1−xFe2 (x ~ 0.3), is a magnetostrictive material. It was initially developed in the 1970s by
the Naval Ordnance Laboratory in United States.http://activesignaltechnologies.com/Terfenol1.html
skip it as to be watched last:
https://en.wikipedia.org/wiki/Terfenol-D wikipedia.
https://youtu.be/FdNuGp01pcE?t=293
http://tdvib.com/terfenol-d/ where to buy it.
https://acronyms.thefreedictionary.com/TERFENOL-D some applications
Wesley
#2 For Ted Annis in subject matter:
https://youtu.be/uc4EVhl-EuY?t=142 (https://youtu.be/uc4EVhl-EuY?t=142)
the picture is large to better show details
http://activesignaltech.com/Terfenol1.html
Wesley
more of Ted
Wesley
This is really good. :)
1. Tesla coil winder:
https://www.youtube.com/watch?v=eyqC4ZJxYxo&feature=youtu.be (https://www.youtube.com/watch?v=eyqC4ZJxYxo&feature=youtu.be)
- one of the buttons of calculator disassembled and now used with magnetic contact from alarm system .
- the cut off part of drill with the switch on it is used for variable speed adjustment.
2.
3D printer used to print parts of more sophisticated Tesla Coil Winder
https://www.youtube.com/watch?v=W2jFp8tXoh0 (https://www.youtube.com/watch?v=W2jFp8tXoh0)
3. for comparison few of Wesley;s winders video from 2012/13 and some other machines.
https://www.youtube.com/watch?v=GsEBfDNRFhM (https://www.youtube.com/watch?v=GsEBfDNRFhM)
https://www.youtube.com/watch?v=hOT7Bg6oipw (https://www.youtube.com/watch?v=hOT7Bg6oipw)
https://www.youtube.com/watch?v=FW7-YPPDjCk (https://www.youtube.com/watch?v=FW7-YPPDjCk)
https://www.youtube.com/watch?v=A_fQ63GTmKA (https://www.youtube.com/watch?v=A_fQ63GTmKA)
Wesley
more of Ted Annis.
Wesley
Galfenol is less expensive and almost as good a magnetostriction as Terfenol. I had time to watch the Annis video in full today and noticed Wesley put up some mag-ram and a square BH so sorry to be redundant but it's nice to know others think alike. Also read the Annis patent and he mentions the Radus boots too, pretty cool.
Might even be able to DIY galfenol with iron and gallium and a forge. Best prices I found on Alibaba
Now I must ask what property does Terfenol D have besides converting movement to energy or energy to movement in a very high Q?
Some other ideas, what core materials dont short out high voltage, Barrium Ferrite, Micrometal...
Thank you mkjekyll
link are at first post below the video:
Pinned by stivep1 stivep1 (https://www.youtube.com/channel/UC1ZrGlkxBvG9WOwIs2eApLA)
https://patents.google.com/patent/WO2009046265A1/tr (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fpatents.google.com%2Fpatent%2FWO2009046265A1%2Ftr&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx), compare dates of filing. Это устройство работает с, самозапиткой, selflooping
https://patentimages.storage.googleapis.com/62/00/84/e06f92b5a2938e/WO2009046265A1.pdf (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fpatentimages.storage.googleapis.com%2F62%2F00%2F84%2Fe06f92b5a2938e%2FWO2009046265A1.pdf&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) compare different versions !!!!
https://patentimages.storage.googleapis.com/5b/06/7a/a683a3e327631c/US20140091890A1.pdf (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fpatentimages.storage.googleapis.com%2F5b%2F06%2F7a%2Fa683a3e327631c%2FUS20140091890A1.pdf&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx), compare different versions !!!!
https://www.tedmagnetics.com/ (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fwww.tedmagnetics.com%2F&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) https://www.tedmagnetics.com/ (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fwww.tedmagnetics.com%2F&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx)
https://maritime.org/doc/neets/mod01.pdf (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fmaritime.org%2Fdoc%2Fneets%2Fmod01.pdf&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) http://info.ee.surrey.ac.uk/Workshop/advice/coils/mu/#bhcurve (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=http%3A%2F%2Finfo.ee.surrey.ac.uk%2FWorkshop%2Fadvice%2Fcoils%2Fmu%2F%23bhcurve&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx)
https://www.doitpoms.ac.uk/tlplib/ferroelectrics/printall.php (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fwww.doitpoms.ac.uk%2Ftlplib%2Fferroelectrics%2Fprintall.php&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) http://fullfunctioneng.com/info/Hall%20vs%20VR.pdf (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=http%3A%2F%2Ffullfunctioneng.com%2Finfo%2FHall%2520vs%2520VR.pdf&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) !!!! important
http://www.cmi-ferrite.com/products/Gapped.htm (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=http%3A%2F%2Fwww.cmi-ferrite.com%2Fproducts%2FGapped.htm&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) http://www.eamagnetics.com/product/ceramicferrite/ (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=http%3A%2F%2Fwww.eamagnetics.com%2Fproduct%2Fceramicferrite%2F&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx) https://www.youtube.com/watch?v=zg8V9XCgIqs (https://www.youtube.com/watch?v=zg8V9XCgIqs)
https://www.researchgate.net/publication/224289652_Analysis_of_a_Virtual_Air_Gap_Variable_Reactor (https://www.youtube.com/redirect?event=comments&stzid=UgxmpeE4NwhCqlCkUt94AaABAg&q=https%3A%2F%2Fwww.researchgate.net%2Fpublication%2F224289652_Analysis_of_a_Virtual_Air_Gap_Variable_Reactor&redir_token=sgThjYWSS7YO-_IwZuW33Q3OGRF8MTU1Mzk0NzQyMUAxNTUzODYxMDIx)
These are the links for Ted Annis
Wesley
Super cool winding machines Wesley!
The torroid one looks like fun, but I imagine wastes quite a bit of wire if all bearings and moving parts are not smoothly operating and aligned.
I would like to order two coils from you if you can accommodate, but as is well known there are only so many hours in a day?
I ran into the quagmire of coil winding machines or lack thereof, as it seems there is very little for the experimenter that can accommodate the length or girth without getting ito something one needs machinery movers to relocate.
I picture something along the lines of a cheap wood lathe from Harbor Fright with a sowing machine foot pedal and an opto-counter For the more adventurous an additional transverse of some type with a stepper motor that could be added to such a simple contraption and controlled via some optical limits with reflective absorptive stickers.
I was looking at the Chinese CNC winders but doubt those can accommodate much more than a guitar pickup and the operation of these so called CNC winders is difficult to find.
Mick
Wesley,
Thank you for the answer/inference to that query. At first glance seems like a way to accommodate fast switching with a saturable reactor. I will have to drill down further in the previously linked authors thesis here:
https://tspace.library.utoronto.ca/bitstream/1807/17754/1/Dolan_Dale_SL_200906_PhD_Thesis.pdf
Науч.Студия SERGEY KACHAN
Scientific Study
High Voltage Radiometer Test
https://www.youtube.com/watch?v=fvycYK3NBpg&feature=youtu.be (https://www.youtube.com/watch?v=fvycYK3NBpg&feature=youtu.be)
Wesley
Addition to magnetics started from mentioning Ted Annis
A Brief Tour of the IEC Factory Floor
https://www.youtube.com/watch?v=1bA2OMRcxKo&feature=youtu.be (https://www.youtube.com/watch?v=1bA2OMRcxKo&feature=youtu.be)
https://www.youtube.com/watch?v=UbWkIKgehLI (https://www.youtube.com/watch?v=UbWkIKgehLI)
https://www.youtube.com/channel/UCoCUQc5Q2NzSqEUdk9naoXQ (https://www.youtube.com/channel/UCoCUQc5Q2NzSqEUdk9naoXQ)
Wesley
Polarisation of Transverse Waves
This is simply amazing video.
So the point is:
to be able to create surface wave we need first to polarize it in XYZ Cartesian space.
We may apply Euclidean geometry as well but for simplicity lets just stay the first one.
and now watch this one:
https://www.youtube.com/watch?v=e1RuhKTwlV4 (https://www.youtube.com/watch?v=e1RuhKTwlV4)
For these who did not fallow my series about surface wave please watch this:
https://youtu.be/zE4GjB1cWLQ?t=591 (https://youtu.be/zE4GjB1cWLQ?t=591)
This is how Corum brothers did it and you can do it too.
Wesley
Simplified explanation of polarization.
The phenomena of reflection, refraction, interference, diffraction are common to both transverse waves and longitudinal waves.
But the transverse nature of electromagnetic wave is demonstrated by the phenomenon of polarization.
Light is electromagnetic wave as well.
And when light is directional than this is Electromagnetic Transverse Wave TEM
Polarization of transverse waves:
If we were to use light as an example
Light waves coming out of some crystals
have their "vibrations" in only one direction, perpendicular to the direction of propagation.
These waves are said to be polarized.
Since the vibrations are restricted to only one plane parallel to the axis of the crystal, the light is said to be plane polarized.
(the same is with any other frequency)
The phenomenon of restricting the "vibrations" into a particular plane is known as polarization.
https://youtu.be/K0vaLj2ZRA4?t=53 (https://youtu.be/K0vaLj2ZRA4?t=53)
https://youtu.be/JWy0QsBZgbk?t=65
We need vertically polarized surface wave.
Wesley
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg533160/#msg533160 (https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg533160/#msg533160)
Thank you for the link r2fpl
Excellent.
https://www.youtube.com/watch?v=nkMndCsNRQU (https://www.youtube.com/watch?v=nkMndCsNRQU)
I have little problem with author graphical explanation
in terms of impedance match.
Wesley
Excellent entry to understand polarization of electromagnetic wave.
https://www.youtube.com/watch?v=84AcKIcF7VY (https://www.youtube.com/watch?v=84AcKIcF7VY)
We do not have here TM mode of TEM wave but having right understanding we can move into TM.
It is unfortunate but it is realistic to say that:
-some of you may chose to move by biological horse energy
- some others by mechanical horse power
- someone else by electrical equivalent of the above.
By that I say that everything is easy or very easy, but you can read - only if you know an alphabet of phenomena responsible for Surface Wave.
The difference between scientist and average person can be insignificant after few days of watching (by you) some of the material dedicated to surface wave.
My posts are short I'm traveling again.
Wesley
::) https://en.m.wikipedia.org/wiki/Dielectric (https://en.m.wikipedia.org/wiki/Dielectric) ;)
and clearly : https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FDiode
Servus
OCWL
As requested:
Answer to Acca/ MAGNETVORTEX
Magnet Flux Block for IEC Earth Engine
https://www.youtube.com/watch?v=ksltXUWRvh4 (https://www.youtube.com/watch?v=ksltXUWRvh4)
Sector based magnetization is alternative technique that can make sectors in one piece of magnetized material.
There is no such thing as monopole magnet.
The biggest mistake of many of you is that when:
- bar is 10cm long
- south is magnetized 3cm from left side of the bar
- North is magnetized at the end of right side of the bar
than south will behave as regular magnet.. that you made S longer by extending it with the same piece of material.
The Gaussmeter will show at the left hand side extended South lower magnetic flux.
Your sample may vary from my drawing.!!
The lack of magnetic field around the sandwich or half of the sandwich is explained by closing magnetic flux with that metal bracket.
But that only applies to very much particular magnetization.
As you remember magnetic flux of ferrite ring is self contained too.
Literature:
https://www.microwavejournal.com/directories/3337-buyer-s-guide/listing/763-walker-scientific-inc-walker-magnetic-group
Please note that videos how to magnetize sectors in one piece of materials have been removed by the company.
I was able to see them but I did not make copy of it.
It happened in 2015 /16
If you are able to find them in any place it will be you contribution to that what Stefan is trying to do now.
I do not have time to look for it as I deal with another electron microscope that must be transported and installed.
Many times you have complained including NickZ that I'm not giving you full information ..
You want more than show me more!!!!
I know how to do it and I have devices to do it.
But with video everything will be clear
Show me how much you care!!
Wesley
So we are talking about any information of sector magnetization( name can be different)
by Walker Scientific magnetic division.. to be found anywhere in the internet space.
or any other as videos have been deleted on purpose. ( e.g technology sold to others)
This may explain secret https://www.youtube.com/watch?v=XZkuteW_Q9k&feature=youtu.be&t=19 (https://www.youtube.com/watch?v=XZkuteW_Q9k&feature=youtu.be&t=19)
Oh cool you have magnetizers!
You can use to make Floyd Sweet device, to condition barium magnet need a SCR to set so unit only triggers at top center of compression of sine, feed sine freq of choice into magnet (US probably 60Hz) and switch polarity n-s-n-s-n-s etc
When success can see movable blob viewing magnet on CRT with second magnet.
I DID THE QUICK SEARCH IN YOUTUBE BUT I DIDN'T FIND ANYTHING ABOUT SECTOR MAGNETIZATION .
IT LOOKS LIKE THE BEST KEPT SECRET.
YOU GUYS NEED TO LOOK IN WEB PAGES.
APART FROM IT, IT IS GOOD MONEY TOO.
BUT I HAVE TO MUCH FUN IN LIFE .............TO CONCENTRATE MYSELF ON MAKING MONEY.
SO I'M ASKING FOR YOUR HELP DUE TO LACK OF TIME.
In order for you to understand what I'm looking for is video explanation can be on vimeo or youtube
-method of magnetization of sectors in one solid piece of material.
videos below are interesting but nit yet that what IU;m looking for.
and not yet what you need.
Please help me to find it.
the example of sector magnetization but not technique of doing so is here:
https://www.youtube.com/watch?v=MOWZc8UUs5E&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&index=4 (https://www.youtube.com/watch?v=MOWZc8UUs5E&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&index=4)
https://www.youtube.com/watch?v=zzQJLGtJV9o&index=7&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7 (https://www.youtube.com/watch?v=zzQJLGtJV9o&index=7&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7) partial but not yet.
https://youtu.be/TPNLjxRf_GI?list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&t=150 (https://youtu.be/TPNLjxRf_GI?list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&t=150) this one show coil needed to magnetize material.
and you need specialized coils for my magnetizer.
https://www.youtube.com/watch?v=0CXl2Gyl6h8 I didn't see it yet but it sounds interesting
https://youtu.be/2wQZ1ZCsrRo?t=293 (https://youtu.be/2wQZ1ZCsrRo?t=293) I didn't see it yet so I do not know if it is valuable
but not here:
1.https://www.youtube.com/watch?v=bp_y05q7J58 (https://www.youtube.com/watch?v=bp_y05q7J58) this guy doesn't know what he has and how to use it but I hope he was able to learn.
2.https://www.youtube.com/watch?v=-VMJN_hoVbk&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7 (https://www.youtube.com/watch?v=-VMJN_hoVbk&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7) this one is for speakers
3.https://youtu.be/CdQAZ-e6494?t=169 (https://youtu.be/CdQAZ-e6494?t=169)
4.https://www.youtube.com/watch?v=wzXRFp0DDrU&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&index=12 (https://www.youtube.com/watch?v=wzXRFp0DDrU&list=PLG3u0gcV6DRNgwaPAt-UzL86h6qOawmf7&index=12) this one is just cool but nothing more.
5.https://www.youtube.com/watch?v=4SbUHzqiAfM (https://www.youtube.com/watch?v=4SbUHzqiAfM) industrial magnetizer
Wesley
http://www.walkermagnet.com/lifting-magnets-overview.htm (http://www.walkermagnet.com/lifting-magnets-overview.htm)
I went to their web site but no words about my magnetizer
So they might have been told to remove videos and keep their mouth shut or they sold technology
to entity that doesn't want that to be known.
So we may speculate:
what such entity could be!!!!
So I'm asking you to dig for anything any trace of it
Wesley
copy of manual:
Wesley
ps: look for more:
https://www.artisantg.com/PLC/57663-1/Walker_Scientific_DCM_30_DCM_Series_Direct_Current_Magnetizer
so what happened with series of these educational videos
and where to look for trace of it.
Wesley
Hunting missing videos:
http://www.walkermagnet.com/ (http://www.walkermagnet.com/)
News
We Moved
Walker Magnetics, a subsidiary of Spencer Turbine, has relocated our Worcester, Massachusetts Sales and Engineering
office to our existing Windsor, Connecticut production facility effective November 5th, 2018.
This move completes the integration of Walker Magnetics with Spencer Turbine, which began with the relocation
of our manufacturing capabilities to the Windsor facility last year. Going forward,
Walker Magnetic will be a stronger company poised for growth and in a better position to service our valued clients.
The Walker team's new address is:
600 Day Hill Rd
Windsor, CT 06095
After 2 hours spend I found that this technology is intentionally unavailable
For these who do not understand what is going on.
In 2015/16 I have seen series of videos explaining how to connect fixtures - coils able to magnetize regions sectors in solid piece of magnetizable material.
that means I could have 20 different magnets in one small piece of material without cuts and in different XYZ patterns.
Than in one day videos have been removed.
It looks like MA headquarter of Walker Scientific after relocation ..was not relocated. but it was closed or sold.
I can tell you this is easy and big .....
Wesley
https://youtu.be/IANBoybVApQ
This company has a patent for it and I saw it. This is point magnetization. Each surface with any pattern is applied as a pixel with appropriate polarity step by step. The effect is amazing. It is a type of CNC machine with a strong polarizing head.
This way you can have any number of fields in any area like hundreds of small magnets or millions.
r2fpl,thanks for sharing !
https://en.m.wikipedia.org/wiki/Programmable_magnet
that video https://youtu.be/IANBoybVApQ (https://youtu.be/IANBoybVApQ) starts from showing closed manufacturing pump plant.
But from my link, you see that Walker Scientific was division of Spencer Turbine, has relocated from Worcester, Massachusetts
to Windsor, Connecticut production facility .
Range of voltage is ~1000VDC
Wesley
early year 2000 product of Walker Scientific explaining how to build the fixture to print magnets
2.This product did have series of videos removed from YouTube in end of 2015
3.We may assume but we do not know that Walker Scientific Magnetic Division moved from MA to CT
but section that was manufacturing my magnetizers was closed.
The technique was based on fixtures connected to my magnetizers allowing to print magnets
Wesley
My conclusion is that
Alabama Polymagnet Coorelated Magnetics
might be just licensee of the machine from company with name: Coorelated Magnetics but not original patent owners?
https://web.archive.org/web/20161220105804/http://www.crr-llc.com/correlated-magnetics/
Wesley
Update:
From that technology Long distance RF ID was created in 2004.
https://web.archive.org/web/20161109202550/http://www.crr-llc.com/tag/
QuoteIn 2004, Larry was challenged with developing a tag system to be used for identifying assets,
where the tag could not transmit a signal yet had to convey asset identifying information over relatively long distances.
After some research, Larry settled on developing a system based upon modulating reflector (MR) tags, which do not transmit signals but instead vary their radar cross-sections in accordance
with time-varying codes thereby enabling interrogating radar having a priori knowledge of the codes to receive information from the MR tags. As part of the development,
Larry made substantial improvements to previous MR tag systems including incorporating the antennas of the MR tags into retro reflectors to increase the signal-to-noise (SNR)
of the MR tags and to enable the MR tags to be read from multiple interrogation angles.
Larry filed a provisional patent application for using retro reflectors with MR tags in August of 2004.
When CRR was founded in December 2006, Larry assigned the pending MR tag technology patent application
to CRR. CRR successfully prosecuted the patent application resulting in U.S. patent 7,479,884 (https://web.archive.org/web/20161109202550/http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=7479884.PN.&OS=PN/7479884&RS=PN/7479884). In 2008,
Larry conceived of another improvement to his MR tag system that involved embedding the retro reflectors into a
dielectric material in order to further increase interrogation distance. CRR filed a continuation-in-part patent
application in October 2008, which resulted in issued U.S. patents 8,395,484 (https://web.archive.org/web/20161109202550/http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=8,395,484.PN.&OS=PN/8,395,484&RS=PN/8,395,484) and 8,730,014 (https://web.archive.org/web/20161109202550/http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=8730014.PN.&OS=PN/8730014&RS=PN/8730014).
Wesley
http://rwgresearch.com/open-projects/making-poly-magnets-cmr/
http://cr-res.com/correlated-magnetics
this is not the printer patent but it shows a similar principle https://patents.google.com/patent/US8179219
https://patents.google.com/patent/US20150137919
Quote from: r2fpl on April 02, 2019, 09:02:26 AM
http://rwgresearch.com/open-projects/making-poly-magnets-cmr/ (http://rwgresearch.com/open-projects/making-poly-magnets-cmr/)
https://www.youtube.com/watch?v=MOWZc8UUs5E (https://www.youtube.com/watch?v=MOWZc8UUs5E)
http://cr-res.com/correlated-magnetics (http://cr-res.com/correlated-magnetics)
this is not the printer patent but it shows a similar principle https://patents.google.com/patent/US8179219 (https://patents.google.com/patent/US8179219)
https://patents.google.com/patent/US20150137919 (https://patents.google.com/patent/US20150137919)
Hi,
I thought i will never get to see
Magnetic bubbles within Magnets after seeing video of Thomas Bearden years ago.Those type mentioned behave like a flip-flop or in another words return to the same spot.It takes little energy to move those bubbles.
But i am not sure if these magnetic bubbles shown in your link is static or able to move freely(Flip-Flop).
Thank you my friend r2fpl
It looks like rwg42985 guy (https://www.youtube.com/channel/UCLuDKTNDFfat7iO7KGE7fQA)is an example that everyone of you can learn magnetics
I know this face from another YouTube channel
Wesley
https://youtu.be/KP2G4fE0ssI?t=400 (https://youtu.be/KP2G4fE0ssI?t=416)
In this video you see winder that can lay down wire with space. Ideal for capacitive reactance of L.
magpwr thank you for your help with links
Wesley
QuoteQuote from: r2fpl on Today at 03:02:26 PM (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg533243/#msg533243)http://rwgresearch.com/open-projects/making-poly-magnets-cmr/ (http://rwgresearch.com/open-projects/making-poly-magnets-cmr/)
the last link is excellent - the patent.
Do you see any other patents ?
So we can know what they got what they did not?
Wesley
Some of them list here but I do not know yet what it is.
Material presented herein may relate to and/or be implemented in conjunction with multilevel correlated magnetic systems and methods for producing a multilevel correlated magnetic system such as described in
U.S. Pat. No. 7,982,568 issued Jul. 19, 2011 which is all incorporated herein by reference in its entirety.
Material presented herein may relate to and/or be implemented in conjunction with energy generation
systems and methods such as described in
U.S. patent application Ser. No. 13/184,543 filed Jul. 17, 2011, which is all incorporated herein by reference in its entirety.
Such systems and methods described in
U.S. Pat. No. 7,681,256 issued Mar. 23, 2010,
U.S. Pat. No. 7,750,781 issued Jul. 6, 2010,
U.S. Pat. No. 7,755,462 issued Jul. 13, 2010,
U.S. Pat. No. 7,812,698 issued Oct. 12, 2010,
U.S. Pat. Nos. 7,817,002, 7,817,003, 7,817,004, 7,817,005, and 7,817,006 issued Oct. 19, 2010,
U.S. Pat. No. 7,821,367 issued Oct. 26, 2010,
U.S. Pat. Nos. 7,823,300 and 7,824,083 issued Nov. 2, 2011,
U.S. Pat. No. 7,834,729 issued Nov. 16, 2011,
U.S. Pat. No. 7,839,247 issued Nov. 23, 2010,
U.S. Pat. Nos. 7,843,295, 7,843,296, and 7,843,297 issued Nov. 30, 2010,
U.S. Pat. No. 7,893,803 issued Feb. 22, 2011,
U.S. Pat. Nos. 7,956,711 and 7,956,712 issued Jun. 7, 2011,
U.S. Pat. Nos. 7,958,575, 7,961,068 and 7,961,069 issued Jun. 14, 2011,
U.S. Pat. No. 7,963,818 issued Jun. 21, 2011, and
U.S. Pat. Nos. 8,015,752 and 8,016,330 issued Sep. 13, 2011 are all incorporated by reference herein in their entirety.
Wesley
I know how to make the fixtures and how to operate the Walker magnetizing equipment.
Here's a commercial example of a motor using sector magnetization. This is an AC-Delco brand automotive radiator fan motor designed to run on 12 VDC. All you magnet motor folks should really think about this DC motor and try to figure out how it actually works. It produces a good amount of torque, yet when unpowered spins freely without cogging.
But to make the kind of magnets used in the IEC motor you don't need sector magnetization. All you need is to stick the strong magnet to a thick piece of mu-metal, and then you too can duplicate the "razor blade" trick shown in the IEC demonstrations.
To reply #2460 " patent abandonation" it is to remark that this application
is now integrated in https://patents.google.com/patent/US10204727B2/en (https://patents.google.com/patent/US10204727B2/en) and active. !
Caution not to abuse their commercial U. S. -market rights !
Impressive how many improvements as new applications -prioritynumbers- are integrated in this one :
https://worldwide.espacenet.com/publicationDetails/biblio?CC=US&NR=10204727B2&KC=B2&FT=D# (https://worldwide.espacenet.com/publicationDetails/biblio?CC=US&NR=10204727B2&KC=B2&FT=D#)
Question : why only U.S. patent application and not WO ?
Edit: have to correct me,
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Larry+w.++Fullerton&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Larry+w.++Fullerton&IN=&CPC=&IC=)
and here the WO but EP Register information : " deemed to be withdrawn"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130502&CC=WO&NR=2013063273A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130502&CC=WO&NR=2013063273A1&KC=A1#)
https://en.m.wikipedia.org/wiki/Larry_W._Fullerton R.I.P. 24.11.2016
About "magnetizer" : walkerscientific, Walker Magnetic Group
https://web.archive.org/web/20061110112451/http://www.walkerscientific.com/Products/magnetizing_conditioning_index.html (https://web.archive.org/web/20061110112451/http://www.walkerscientific.com/Products/magnetizing_conditioning_index.html)
CMR Demos Its Printed Polarity Magnets
www.youtube.com/watch?v=drD416THU7Y (http://www.youtube.com/watch?v=drD416THU7Y)
Correlated Magnetics Attach Polymagnet Animation
https://www.youtube.com/watch?v=9T26k2iFyNM (https://www.youtube.com/watch?v=9T26k2iFyNM)
Latch Polymagnet Demo
https://www.youtube.com/watch?v=l1NTAQBtmhE (https://www.youtube.com/watch?v=l1NTAQBtmhE)
Spring Polymagnet Demo
https://www.youtube.com/watch?v=aiAt-x8i90Y (https://www.youtube.com/watch?v=aiAt-x8i90Y)
Attach Polymagnet Demo
https://www.youtube.com/watch?v=h8uAjvfJNHo (https://www.youtube.com/watch?v=h8uAjvfJNHo)
Polymagnet and ferrofluid display
https://www.youtube.com/watch?v=ny41-gHhUqE (https://www.youtube.com/watch?v=ny41-gHhUqE)
http://www.polymagnet.com/about-2/ (http://www.polymagnet.com/about-2/)
Printing Your Own Magnets
https://www.popularmechanics.com/technology/gadgets/reviews/a10696/this-is-awesome-printing-your-own-magnets-16900288/ (https://www.popularmechanics.com/technology/gadgets/reviews/a10696/this-is-awesome-printing-your-own-magnets-16900288/)
also a video:
A Closer Look At The Mini Magnet Printer
https://www.youtube.com/watch?v=SWuVzhTd6Fc (https://www.youtube.com/watch?v=SWuVzhTd6Fc)
and the bad news:Larry W. Fullerton
https://en.wikipedia.org/wiki/Larry_W._Fullerton (https://en.wikipedia.org/wiki/Larry_W._Fullerton)
Patents: https://patents.justia.com/inventor/larry-w-fullerton (https://patents.justia.com/inventor/larry-w-fullerton)
Wesley
was made by me, it does not work like an oscillator. and can not work, the direct current is broken.
did you wind coils of magnetostructive rod -(points 1 to 5)
for each given material permeability is given.
go to right page.
QuoteMagnetostriction (cf. electrostriction) is a property of ferromagnetic materials
that causes them to change their shape or dimensions during the process of magnetization.
The variation of materials' magnetization due to the applied magnetic field changes the
magnetostrictive strain until reaching its saturation value, λ.
https://en.wikipedia.org/wiki/Magnetostriction (https://en.wikipedia.org/wiki/Magnetostriction)
Wesley
We are living in a "design"- world : https://newatlas.com/gold-melt-room-temperature/57327/ (https://newatlas.com/gold-melt-room-temperature/57327/)
Fullerton worked with 200.000 Ampere bursts to change " conventional structure".
sentire( to sense), fuehlen( to feel) power density :
2 shoeboxes total ( battery + controler) , but net the generator only 1 shoebox-dimension for xxxxxx KW output.
One cube, 1 cm x 1 cm x 1 cm : 2 KW output, by related cycle process frequency.
It is time to make this " generator" 3d-printable.
1 cm x 1 cm x 1 cm : 2 KW x 24hpeak= 48 KWhp per day
human individual body cooling / heating energy need. : 12 W
MDI Dome,112 sqm : 2400 W heat peak by 400 W electric heat pump ( -20 °C ambient condition )
Electric multimotor-gear car 1 KWh/ 100 Km , 150 Kmpeak velocity( 130 Kmpeak street legality)
Electric intelligent household power need per day : 3 KWh ( /24 : 125 W )
There are only ferrite rods. :'(
But what is (positive dc input)?
if there is no way for it. is a capacitor in the path? :)
Quote from: kolbacict on April 04, 2019, 03:47:09 AM
Can you, kolbacict, define -by eye - in " solar ink dots" the capacitor/condensator ?! ;)
1 cm x 1 cm x 1 cm compact " solar ink dots" -cube output compared with 2 KW 1 ccm cube !?
Goldbaum device : " coating" ! Material,physical emf effect !?
this circled in red. if it were not there, a cascade with a common base would result.
Quote from: kolbacict on April 03, 2019, 03:21:30 PM
Quote from: kolbacict on April 04, 2019, 03:47:09 AMThere are only ferrite rods. :'(
Quote from: kolbacict on April 04, 2019, 12:17:24 PMthis circled in red. if it were not there, a cascade with a common base would result.
Hi kolbacict,
I have edited the schematic you uploaded, at least to make the circuit work as a kind of blocking oscillator.
I agree that the original schematic cannot work: "the direct current (to the emitter) is broken" as you said.
If you attempt to build this modified schematic, and you are not getting any pulse at the output where it is indicated originally, flip the ends of either the feed back coil to the base or the main coil at the collector, ok? (i.e. only the wires of any one of the coils)
For your information:
--the positive DC input is the supply voltage input with respect to the ground (which is the negative polarity),
--try to use a variable power supply, starting from a few volts to as high as 12 or 15 V, to find the best operating point for the oscillator, this also depends on your transistor specifications--the indicated output is via a coupling capacitor from the collector of the transistor, use here a capacitor whose capacitive reactance is but a few Ohms at the pulse frequency
I do not know where you can get a "negative magnetorestrictive rod" though... and I do not think its high price (if true) is worth the trouble to purchase such.
Gyula
gyulasun I do thank you very much for your contribution
good work
I think application is a part of the problem:
https://fas.org/man/dod-101/navy/docs/es310/asw_sys/asw_sys.htm (https://fas.org/man/dod-101/navy/docs/es310/asw_sys/asw_sys.htm)
Figure 17. Bi-static sonar.
Material must be as listed in green color.
the system acts as mechanical transducer
look at link below and the lower picture marked as figure1 system Block diagram
https://www.ijert.org/research/sonar-fish-detection-and-measurement-system-with-pic16f873-IJERTV4IS060453.pdf (https://www.ijert.org/research/sonar-fish-detection-and-measurement-system-with-pic16f873-IJERTV4IS060453.pdf)
So the unfortunate was that book http://www.free-energy-info.com/Smith.pdf (http://www.free-energy-info.com/Smith.pdf)
was trying to refer to something that was wrongly explained.
but the idea is quite fascinating.
If you compare Tx configuration from the lower picture and Rx configuration, it looks like both use transducer .
and Smith assumption is that process of receiving is just reverse action .
Note: I should make schematic more easy to understand
but let it stay this way for now.
All that is important is to make Base able to open emitter/collector junction at first.
Than you can chose what you want to send between collector and emitter.
And for how long. There is no output in the schematic.
So you can exclude this part.
The amplification can be done from the same + impulse.
but if you want to have train of impulses send than you can use terminal marked output as external impulse delivery.
Would that be as long as saturation of the capacitor?
-or you want to cut power to Base before that.
Wesley
literature: https://www.youtube.com/watch?v=WaHD7665NeM (https://www.youtube.com/watch?v=WaHD7665NeM)
Wesley
Wesley perhaps I am a bot off topic now but a very solid RF guy turned me onto this VNA, looks interesting have to find out more such as is tracking gen limited like in the Chinese box.
https://www.arraysolutions.com/antenna-analyzers%20/vna-uhf-dx
Looks as though the coupler is inside the unit similar to many antenna analyzers, I do not know the downside of this config.
I don't participate on these forums much but have watched presentations and I highly respect the stuff Tinselkoala presents, thank you for participating in Wesleys tech circus!
Mick
$1300 I think, they have a single port unit for about $500. The frequency response looks good but so did the Siglent until one gets to the lowside of the tracking gen which did not match lowside of the spectrum analyzer. Not o mention the crazy software pricing.
Still looking for a you tube or video of performance. Likely CPU-Ram related if code is not bloated DLL files that choke the puter.
The pci card unit you mentioned did not go low enough and the HP Vxi card unit that does go low enough
https://www.ebay.com/itm/HP-Agilent-89640A-VXI-Based-2-7-GHz-RF-Vector-Signal-Analyzer-PRICE-DROP/232488518625?hash=item36216543e1:g:PBkAAOSwo-RZuuSv
https://www.keysight.com/us/en/software/application-sw/89600-vsa-software.html#Bundles
the software is very costly and may not have the scattering or smith charting. I cant find the software free from Keysite except the 30day trial Maybe I should sell the HP 89411 I got working and get the little computer based one, lower S/N ratio but more functionality. Although that HP can go super low so may be worth hanging onto even without the S parameters.
Most of the cheap puter ones do not work below a few hundred MHz so I think the unit I posted is different in that it is based on a lower freq unit and uses freq multiplication for higher frequencies, this would explain the lower dynamic range on the higher frequencies.
It looks like the best deal you can make is buying old used VNA.
Other options:
Software from Keysight / Agilent is crazy expensive.
The toughest part is that we are dealing with HV.
https://youtu.be/YrRc-xieWjE?t=683 (https://youtu.be/YrRc-xieWjE?t=683)
https://youtu.be/Mn8TLBsR3r0?t=501 (https://youtu.be/Mn8TLBsR3r0?t=501)
Wesley
I do not use any form of decoupler.
Coupling in measured circuit is critical to make it work.
Devices used to measure must not be in any way a part of this process.
Inverse square law is primary tool to be able to take measurement safely to equipment.
https://en.wikipedia.org/wiki/Inverse-square_law (https://en.wikipedia.org/wiki/Inverse-square_law)
When possible I use decade attenuator.
Short wire 1cm, inside N connector of Spectrum Analyzer not connected to anything
if HV is involved.
Wesley
Wesley,
I meant to isolate the power side from ground and kill common mode noise on the supply side, not decouple the measurement side.
Nice setup with the divider pads though.
but I can't do anything. I wanted to get it. There is a strong desire.
But not yet. :'(
stivep with all those sofiticated instruments what you have not figure out how
make a free energy machine..look just send me over an oscilloscope spectrum analyzer and a swr meter
and i will put you all on a platter the kapadnaze free energy machine..easy.
STIVEP I WAS JUST JOKING. I AM SEYCHELLOIS, THAT IS MY ANCESTORS ARE FRENCH
BORN ON PRASLIN ISLAND SEYCHELLES INDIAN OCEAN. I DID MY ELECTRONICS TRAINING IN AUSTRALIA.
I WORKED THERE AS AN ELECTRONIC ENGINEER AS AN RF TECHNICIAN WITH MOTOROLA
COMMUNICATION.. SO IT WAS IN THE ERA WHEN TWO WAY RADIOS WAS KING. I SAW THE
ADVENT OF COMPUTER FROM CARD TO COMMODORE 64K AND WINDOWS 96 AND THERE IS
MY WHOLE PLUS MORE..I WAS JUST JOSHING..I LIVE ON PRASLIN ISLAND AND I JUST WENT
FISHING ON MY KAYAK TO CATCH LUNCH AND DINNER.. PEACE LOVE AND ENJOY THE PRIVILEGE
OF EXISTENCE.
seychelles I'm impressed .
https://vimeo.com/96710893
Wesley
The problem is that no one knows what is the basis of Kapanadze's operation. All this is speculation. We can reject a lot but also leave a lot. The variety of devices and the way of working is very diverse but we are looking for a common part. Kapanadze in each version shows unnecessary tiles and probably everyone has understood this for a long time. If it does everything we see it can be an invalid or just a fragment without much meaning for understanding.
Time is all theories and one thing that he said is that it is a resonance current. Behind this there is a lot of possibilities, and without additional information about the source, we will not do anything.
I want to point out that a lot can indicate something that is in the way electron tubes work. There are a few options here too, and Steven Mark says that this is fundamental to his device and wonders why nobody did it.
He mentions this in his correspondence before he fell silent.
Everyone is looking for a magnetic induction, and they forgot why the current is flowing! that's what S.Mark was talking about.
Why is Kapanadze all the wires that go in the middle of the coil? this can be an element of the device's operation.
We do not generate a magnetic field! so what are we doing ...?!
Contrary, I think that magnetic field is important here and I saw some russian videos indicating large magnetic field around the devices. In fact I'm quite sure the ratio of input energy to the magnetic field intensity (pulsed) is directly related to the overunity factor of device.
Tesla noted his devices behaved like electrostatic machines the more sharp gradient he used. Well, to me electrostatic effects may be produced by abruptly changing magnetic fields.
Wesley,
You visited T.K. so had time to talk to him one on one. He released a video of a machine of some type and I have not seen enough detail to make an assessment of what he is doing.
In your opinion, does the electrical device have roots in the mechanical one?
How do you think he came up with his discovery of one or the other, did he mention this area of thought?
I always wondered if he was just playing with two Tesla coils to see if he could send power, or if it was something else.
Thanks,
Mick
Quote from: forest on April 06, 2019, 11:40:25 AM
I'm not saying that there is no magnetic field. I say that it is not created in a traditional way. It can be created in a different way. This is really a different look at the same. Nobody does this like Steven Mark, and it is unbelievable that all experiments start the same and end for most of us. I'm not saying that Steven Mark and Kapanadze are the same device but that you can do a different magnetic field that we create by the speed of the wave and not by the power!
Quote from: stivep on April 06, 2019, 01:47:59 PM
That is not true.
Base for knowledge is ability to repeat and multiply.
Akula, Ruslan Vasums, Sr193,
Nobody confirmed it after them! and this is the reason why I think that we still do not know.
It seems that all these devices work on a similar principle, but we also do not know if this is the case.
There is no information between them how it works. We only have pictures and stories and some schemes. This is not enough as you can see.
I know a lot about them mainly from the Internet and my experiences and that's why I have more and more to say.
Can we say that all work on the same principle? NO; because we do not know that.
Akula - his scheme of the eternal flashlight had a battery in the capacitor, this is fact.
Ruslan - it's hard to say what is true and what is not. There are people harmed by him.
Vasmus - I do not know anything for the fact that he works.
Sr193 - there is conflicting information, even who it is? is it a name/nick Akula or Fabrice Adrian or "Adrian Guska" or someone else. His device and description of operation is identical to that of Kapanadze, he says.
All this knowledge comes from the Internet; films; text and diagrams.
Quote from: r2fpl on April 06, 2019, 02:11:13 PM
//Nobody confirmed it after them!//
You are absolutely right form your perspective.
But from their perspective you are wrong just because they know what you do not know.
Your perspective may change.
And it is up to them to change it in the matter of a minute.
Wesley
stiveip
I wrote "electrostatic effects" not electrostatic forces.
It's apparent that Tesla devices act on ions and charges around, that effects probably first discovered by Tesla in 1890- 1891 seems to me the key element Tesla used later in every part actively.
Read this http://amasci.com/tesla/tesecr1.html
Absolutely marvelous!
Quote"My bet is on the above: a single breakthrough now lost. Tesla invented Fire (well, Fire-II.) Also the Wheel. And the laser, the transistor, all of them wrapped up in a single invention. And then to avoid being chained to a peak and having his liver daily torn out by eagles, he kept it to himself. Tesla's behavior has all the earmarks"
or did he the opposite ?
I know that we can talk about it indefinitely and it is empty talk. After reading Steven Mark's extensive abstracts that have broadened my knowledge, I have greater respect for a different view of the same. It is true that we can not see simple solutions as people of a certain age. You are limited by our knowledge and searching for patterns that we know.
This is the key and the lock depends on what you choose.
https://www.youtube.com/watch?v=66tEd-qh6dQ
Some interesting play with Avramenko
Wesley
Think about Dr.Nikola Tesla without him :
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FCharles_P._Steinmetz (https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FCharles_P._Steinmetz)
When their cooperation broke what happend with Dr.Tesla and what with "Prometeus/Proteus" ?
By their life and the industrial evolution "after" !?
mkjekyll and : " No ! ' Clearly not only by Tesla-Steinmetz our net- on/ off grid technology is based , hundreds up to thousand several other genious people improved the ancient poor efficiency and lower machine work life andpower-density !
"The Hall of Fame " ( and honor) of inter-/ national EE
"Greatness"- comparison ! ? By eye or ' oeuvre'?
https://www.sciencephoto.com/media/661988/view/einstein-and-steinmetz-historical-image (https://www.sciencephoto.com/media/661988/view/einstein-and-steinmetz-historical-image)
http://s3.amazonaws.com/dsg.files.app.content.prod/gereports/wp-content/uploads/2015/12/10165119/121442-Steinmetz-and-Einstein-uncropped1.jpg (http://s3.amazonaws.com/dsg.files.app.content.prod/gereports/wp-content/uploads/2015/12/10165119/121442-Steinmetz-and-Einstein-uncropped1.jpg)
gift from Wesley:
One of the forum guys was given AC/DC power supply from 0 to 50kV to experiment with Viziv tech/ Kapanadze/Surface wave/etc.
Spectrum analyzer
set of brand new surgery lamps
-at no charge.
The power supply could be used also for electron beam acceleration.
It is AC/ DC mechanically regulated to the single V.
So:
- if one would put 50kV in primary of Tesla at ratio 100 than you'll get 5 000 000V
- if one would put 50kV in primary of Tesla at ratio 1000 than you'll get 50 000 000V
here are some pictures :
Wesley
Legal Note: Never play with HV. Never Touch it. :)
more of it.
Wesley
lanca,
Yes you are mostly correct except I do not agree that Tesla was handicapped intellectually simply because he did not leave notes of calculus and transforms all over. Much of his work went up in flames and much was performed in his head and not written. His patents are written well enough to protect but minimal enough to obfuscate.
Machines built by his company are still running in small parts of the grid.
Proteus job was to define Tesla's work in expressions of math and by doing so is closest to the grandfather of the EE
I suppose you and I differ on opinions of the Man as I think he was quite brilliant, in this we shall agree to disagree. Building logic gates before 1910 but also a man of his time so some things he said can be seen with 20-20 vision backwards as questionable. However these instances do not detract from all he built and left us, and I am sure there is much more to his work than you or I have been allowed to see.
Maybe in Germany his work was not eliminated from the history books, here it was for sure until somewhat recently.
But of course Laplace is important for all RF analysis, and Leigh Page for going outside the neighborhood.
http://translationportal.epo.org/emtp/translate/?ACTION=abstract-retrieval&COUNTRY=PT&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=104492&OPS=ops.epo.org/3.2&SRCLANG=pt&TRGLANG=en (http://translationportal.epo.org/emtp/translate/?ACTION=abstract-retrieval&COUNTRY=PT&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=104492&OPS=ops.epo.org/3.2&SRCLANG=pt&TRGLANG=en)
mkjekyll,do you know an easy way to get " ultra- low" friction bearing ?
When the SKF/NSK conventional bearing by 3000 RPM e-motor revolutions guarants 20000 hours lifetime,this above rotor device with 18000 RPM would by 8766 hours/year need a fast bearing change !
Linear calculation : 6000 RPM = 10000 h 12000 RPM = 5000 h 18000 RPM = 3333 h
2 billions bearing rotations ( under torque load) seems much , by divison 2 billions/18000 RPM ~ 1850 h life
All 3 months bearing change makes RF converting machines relatively expensive. !
√18000 (RPM)~ 134 (RPM)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19771103&CC=DE&NR=2617553A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19771103&CC=DE&NR=2617553A1&KC=A1#)
Are similar devices industrial known and available ?"Citing documents : Rolls Royce ( turbines) and Schaeffler( FAG Kugelfischer) "
I am thinking in the " fractional MW" range 1-10 KW,for high KWs the solution can be :
https://en.m.wikipedia.org/wiki/Magnetic_bearing (https://en.m.wikipedia.org/wiki/Magnetic_bearing)
What was Teslas Turbine bearing in use ? Lifetime. ? e-storage flywheels ?
lanca,
I do not have time to read the link you sent right now but for lets say the bearings in a Porsche Turbocharger are ceramic to withstand high RPM and temperature or fluid bearings.
Depending on load radial or axial, some use combination of bearings.
Like you said magnetic is a good choice but I am not aware of load capability on those. The tried and true are hydrostatic fluid bearings.
https://en.wikipedia.org/wiki/Fluid_bearing
I will get back to your links later, thanks
lanca,
Only one page came from that patent app when I clicked to translate to PDF so I could not grasp the gist of the concept.
As far as what kind of bearing on the TT back in Tesla's time he used I have no idea but can look into it. He used special nozzles from some manufacturer so assuming he found the best source at the time. There was something about the materials not being good enough at the time such as warping, but one never knows if this is part of the disinformation as with much to do with the boundary layer turbine design he came up with has been propagated. I am not sure the turbine ran on what most people think of being steam but may have been designed to run on LOx since Tesla really liked the Linde system. This would be a good way to go because all friction generated heat could be used as fuel as long as the expansion could continue without freezing things and if it was designed as such the bearing would likely have been air/gas bearings. But of course I could be completely wrong on the LOx angle. The particle beam was designed to run on air pressure to create a vacuum to allow for a vacuum tube that could fire nano projectiles out the open end and retain a vacuum on the cathode end, so he did consider using air for things like this and his oscillator too.
With these cool new multi-pole magnets Wesley brought up seems like magnetic bearings are mega-market potential. If the race can float equidistant from the shaft with enough force to prevent touching and galling the surface and also center itself axially then this would be huge!
I seem to recall having a hard drive that used the multipolar magnets on a solid ring, so the technology is not so new, but perhaps this CNC magnetizing probe is the latest breakthrough.
Bearings, probably why the educational info evaporated.
VIZIV - if they want to transmit energy to the whole world, where do they want to take it? there is no power plant of that power there?
mkjekyll, thanks for your inside thinking !
But the "bearing" remains as friction and wear problem ( or is it not ?) !
About magnetic devices ,research sponsored by Army :
https://patents.justia.com/inventor/herbert-a-leupold (https://patents.justia.com/inventor/herbert-a-leupold)
We have output force improving devices and methods and input energy saving techniques, the barrier is in the transmission and for motors and generator the bearings.
Instead rotative devices using static- no mechanical parts transformer can be a partial solution.But here the physical movement as revolution/ rotation has to become transformed in "digital rotations" ,the pulses are here arcs/spikes,coils life shortening. EDM like.
The next question : charge/ load coverage ratio controle ,especially during voltage/ current inrush peaks .
All this points are by " high costs solution" resolved, the use from these methods in low-cost manner and globalproliferation and DIY- maintenance( no service costs)simplicity is the work, included local production and material re- furbishing/- cycling.
No waste !
Moment. They say that only from one place in Texas will they distribute waves all over the world. Do you want to say that there will be other stations of this type where there are, for example, power plants in every country? Is it that every country will have to generate energy and send it to them and will they distribute it? I know that there may be any scenario, but this answer is needed to understand where they want to have this energy.
This is so frightening but no more than the lack of money in the wallet and only virtually.
So we should put even more pressure on it to have it for ourselves and not be on the belt.
Quote from: lancaIV on April 09, 2019, 08:28:31 AM
Wesley, I do not think that !
For the energetic sector electricity has 30% use quote actually, petroleum based products are in commercial worth several times higher.
The prohibition from "plastics" out from fossil ( a/ biotic ?) oil/ natural gas would sooner change the rules of trade !
Also in future the CO2- certificate price for green house gas emission will make pollution more expensive.
VIZIV has to work and compete against 1,5/2 US$ cents/KWh global movable electricity generating plants.
No country and no organisation like the OPEC will anymore decide the price-max. ! Liberation !
price floating = less manipulated investment return warranty
with no return and total lost risk
I think you are wrong. They have long ago established it a long time ago. See that confernation was with the Arabs.
Wesley, I am African !
I remarked in the last time new studies results :
human growth- peak in quality ( not peak in quantity) reached by and true woman education and emancipation by law ! ( counter- act : IslamicEstate : re- slavery of the womans; many european females went there )
In China it is now allowed to have more than one child : the most one child parents there do not want more !In Europe the one child family in intelligent households standart.
Psychological saturation !
You know the Malthus- number apocalypse : 200 billions humans , but this will never become reality !
That's how I understand it, but I do not understand where Kapanadze's energy comes from, if you first have to deliver it, because VIZIV has to do it.
http://appft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-bool.html&r=0&f=S&l=50&TERM1=CPG+Technologies&FIELD1=AANM&co1=AND&TERM2=&FIELD2=&d=PG01
Kapanadze is seen as Rx-receiver only.
Energy fluctuation in Schumann waveguide is manifested by Schumann resonances frequencies.
That alone must impact waveguide boundaries( walls)
(Slotted Line - is a must to understand for sensing such fluctuation in waveguide.)
Naturally present in interface Surface Wave in Schumann waveguide is exactly the same as that of Viziv. (TEM in TM mode)
The interface is earth/air " 2D space"
The only difference to Viziv is that this energy is receive it only.
Wesley
Quote from: stivep on April 06, 2019, 09:13:06 PM
https://www.youtube.com/watch?v=66tEd-qh6dQ (https://www.youtube.com/watch?v=66tEd-qh6dQ)
Wesley
Interesting play....emphasis is on "play"
Systemtic measurement-error : He measured open-loop voltage and not Voltage under load ( inner resistance
of intrument is the load while measureing current )
So the calculation of power is wrong.
Additional error might be bandwidth of instrument.
Mike
#2534 mkjekyll :
when 1 coil x 1000000 coil turns x 1 Ampere-turn ~ revolution = 1 Mio. A
or. 1 coil x 1 coil turn x 1000000 Ampere-turns= 1 Mio. A
so are the same
1 coil x 1000 coil turns x 1000 Ampere-turns= 1 Mio.A
( dividing in 10 , 100 , ..coils x coil turns x Ampere-turns )
The Kunel- bearing device , a bearing in a bearing, so 360.000 mechanical revolutions divides in 600x600 mechanical "revolution each "-stages would mean less friction and less wear ! Available ?
Kunel- amplifier device, factor 10: 10 Ampere- coils
More or less "Mass" : coil mass in Kg or more or less "Speed- velocity" in pulsed Hz cycles
AlienGrey,many "Puzzle"-parts will change the future :
https://www.google.com/search?q=24%2F7+power+transmission+drone&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=24%2F7+power+transmission+drone&ie=utf-8&oe=utf-8&client=firefox-b)
+ flying "Viziv"- Transceiver
+ 24/7 flying solar-/ wind- energy-glider f. e. http://airhes.com/
But this is only for on-grid consumer,industrial and private, important.
Off-grid net-architecture is with less over-head costs, 50% cheaper.
Sincerely
OCWL
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172606/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172606/image//)
serious devices, no doubt. And this is what we have. ;)
lanca,
This Kunel coil sounds fascinating along with the iterated bearing concept, can you provide some links or PDF's with some in depth info? I think I recall something from the Kelly free energy book about Kunel but likely your data would be more stable. There The future will likely be some type of hybrid bearing with the magnetic part and rollers or balls when load overcomes the magnets repulsion.
here is a quick quote concerning bearings and mag repulsion motors
http://wheelerfluidfilmbearings.com/advantages-of-babbitt-bearings-and-sound-babbitt-foundry-practices/
https://www.ijedr.org/papers/IJEDR1701064.pdf
lanca,
with the multiple series coils if inductance the same they can still be different phase, use RF trick to get dBi antenna gain then PFC. This is reason TK uses motor disconnected, it is running like rotary condense correcting PF.
Yes the ratio multiplier trick if phased properly should work, good idea, give it a test!
https://patents.google.com/patent/EP1501174A1/fr (https://patents.google.com/patent/EP1501174A1/fr)
It is not the device for itself which makes power management "complicated", it is the charge/ load relation or ratio.
In Europe the net-grid consumer frequency 50 Hz( a 2 signals) =
3000 RPM or 50 RPS =
1 Rev/Hz, 1 Rev/2 signals
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2012256422A1&KC=A1&FT=D&ND=3&date=20121011&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2012256422A1&KC=A1&FT=D&ND=3&date=20121011&DB=EPODOC&locale=en_EP#)
[0092] 1 W. /Revolution per minute
[0093] 0,25 W. / Revolution per minute
[0094] 0,01 W. /Revolution per minute
hertzian cycle amplitude and frequency and duty cycle modulation
in rotative - motive or generic - devices or static= non moving parts device !
http://spiff.rit.edu/classes/phys213/lectures/amp/amp_long.html
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=http%3A%2F%2Fwww.arestov.de%2Findex.php%2Fde%2Felektromotoren%2Fwindenergie (https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=http%3A%2F%2Fwww.arestov.de%2Findex.php%2Fde%2Felektromotoren%2Fwindenergie)
before : singular /after : plural ( double, triple,....) coils
"Example : a wind turbine with nominal 400 W .... "
? Watt / RPM
before : at 20 m/ sec 70 W
after. : at 10-12m/ sec. 320 W
Less input pressure/ force/ energy but more output energy/power
20 m/sec = 72 Km/ h wind velocity : 70 W output :P from rated 400 W
lanca,
Thanks,
I will have a look when I have more time but it looks very interesting, the French patent app.
We could also do much better just driving high impedance windings for very high voltage and stepping it down loose coupled to overcome a lot of the drag associated with the Lenz law.
By the way some might find interesting the magnetic design of the Alexanderson alternato, Don Smith was an interesting character.
my new Electron Microscope
https://youtu.be/64oFAQMCVAA?t=870 (https://youtu.be/64oFAQMCVAA?t=870)
Stability of the power supply is 0. 0007% That is much better than required for electron beam plasma accelerator.
Wesley
Wesley,
I hope I am not going outside the thread with this question.
If one was looking for a very high quality 10-160 meter amateur radio rig for high reliability proper wiring inside, very high sensitivity, low noise, high selectivity and high DDDR what models might you recommend?
I know some rebuilt Kenwood twins from late seventies are considered great, but what else. I know they are also limited and I am looking for some good DX ability if shit hits fan. I don't like the sound of some of the cheap SDR I have heard perhaps the expensive ones are much better, however I dislike the lack of fullness to the tone I hear so far. I don't remember this lack of audio quality with the old analog PLL receivers, but I may have selective amnesia.
Thanks,
Mick
Advice from my friends to mkjekyll : Try TS 2000
You can also modify it and open all away from 160m to 70cm.
This in not Ham forum so unfortunately not many of us will be able to help you.
Wesley
Thanks Wesley
Quote from: mkjekyll on April 13, 2019, 11:21:59 AM
Thanks Wesley
But I can tell you that if it comes to any subject of rigs, feeding lines, antennas, amplifiers, bands and its propagation,
SSB, CW at: A1, A2, A3,
FM, AM I'm probably better or much better than most of the guys called hams .
I just can not be one of them because is tedious, monotonous, in a sense.- to little is taking place in given time period.
But I have friends in this area mostly top notch but even them I'm able to put in the corner from time to time.
No definitely not in DX area but in area of technicality .
Talking about Swiss quality:Yes it is . I have got
Electron Microscope
made in Switzerland as a special order.
(with English/US cooperation.)
I'm having so much fun with LEO 435VP it will take me around 2 months or so.
Microscope is made from 2 modules and it looks like desk with 2 parts.
Entity disconnected wires to separate two pieces prior to transportation.
Because of security clearance,the guy who did it is not authorized to interact .
It looks like he thought, he would be delegated to another scientific organization to assembly of it.
So he made some labels on the wires but not much.
on the picture
LEO 435VP and total mess in lab #1.jpg You see marking
"Vacuum jar glass bell"( This is how it looks like:
https://www.youtube.com/watch?v=ISoW1yhVpjs (https://www.youtube.com/watch?v=ISoW1yhVpjs)
Wesley
more of it
Wesley
Dear mkjekyll
I have much more than that.
Quote from: stivep on April 13, 2019, 02:52:12 PM
You see marking "Vacuum jar glass bell"
Wesley
A Powerful Electricty Generator That Functions Uniquely Using Electromagnetic Phenomena
Wesley
MORE OF IT
Wesley.
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390 (https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390)
http://www.freepatentsonline.com/8847720.pdf (http://www.freepatentsonline.com/8847720.pdf)
Используемый переключатель постоянного тока в переменный имеет максимальную 780 кГц по сравнению со 180 Гц в генераторах тока. Такие высокие частоты индуцирующего тока генерируют чрезвычайно высокую выходную мощность. Он создает высокочастотные циклические магнитные поля внутри и вокруг проводов ряда индукторов, которые соединены в параллельную цепь.
Концентрические силовые линии этого поля распространяются и разрушаются в релятивистском времени, когда они пересекают провода индуктивов, которые также связаны в параллельной цепи. Циклическое напряжение и ток протекают в индуктивности, которая является выходной мощностью генератора.
"в индуктивности, которая является выходной мощностью генератора." niet tochnogo pierievoda - na primier:
"Циклическое напряжение и текущий поток вызваны в призывниках, который является выходной мощностью генератора."
ili na primier:
"Циклические напряжение и ток индуцируется в призывников, который является выходная мощность генератора."
Выработка электроэнергии - очевидное применение. Даже самые крупные генераторы требуют минимальной инфраструктуры и будут иметь низкие эксплуатационные расходы. Они могут быть расположены в или около места потребления, и могут быть связаны, чтобы обеспечить любое количество требуемой мощности, по требованию. Они могут быть закрыты, чтобы запускаться снова, как того требует спрос. Они могут приводить в действие двигательные установки для всех типов наземных транспортных средств, морских судов, самолетов и космических аппаратов
Параллельная схема 'катушек' индуктивности и индуктивности обеспечивает избыточность, что обеспечивает непрерывную генерацию даже в случае повреждения или неисправности некоторых компонентов. Экранирование предотвращает выход магнитных полей.
ОНИ НЕ КАТУШКИ, НО ЧТО-ЛИБО ПОДОБНОЕ ПАРАЛЛЕЛЬНЫХ ПРОВОДОВ ПРЯМОУГОЛЬНОЙ ФОРМЫ
Единственным внешним источником энергии, необходимым для этих генераторов, является батарея, которая подает ток для начального цикла (циклов) постоянного тока на высокочастотный переключатель постоянного тока в переменный ток в компьютеризированном модуле управления, который затем подает высокочастотный переменный ток. ток на индукторы. Это создает высокочастотные циклические магнитные поля, которые индуцируют напряжение и ток в проводах ряда окружающих индукторов в качестве выхода генератора.
Часть этого тока доступна для нагрузки и может регулироваться так, чтобы можно было подавать любое напряжение, силу тока, количество фаз и частоту. Другая часть индуцированного токового выхода индуктива подается обратно на катушки индуктивности, обеспечивая ток для последующих циклов, и батарея затем удаляется из цепи.
Номинальный генератор, приблизительно объем двух мужских коробок обуви, включая батарею и модуль контроля, может поставлять необычайную продукцию.. Даже работая в низкой частоте 400 герц, вызванное напряжение сети -/-8.4Kva/sec, (который является почасовой оценкой 30.2Mva/hr (40,500Hp)). Для сравнения, электростанции производят от 375 до 758 Mva; турбина ветра производит 2-3 Mva; большой heliostat может произвести 280Mva..
Wesley
https://www.youtube.com/watch?v=bLt7pvJJfN4 (https://www.youtube.com/watch?v=bLt7pvJJfN4)
the title of original video is:
Magnetic Field Changing in Time
- Electromagnetic Induction Generating Electrical Energy
The title of original patent is :
- Electromagnetic induction device for generation of electrical power
suggestion: look at parallel rings on video
and compare it with parallel straight wire "coils" from patent
Wesley
https://en.m.wikipedia.org/wiki/Biot%E2%80%93Savart_law
https://m.youtube.com/watch?v=CACD5jX8fsY (https://m.youtube.com/watch?v=CACD5jX8fsY)
https://m.youtube.com/watch?v=JZ2pDlhqPio (https://m.youtube.com/watch?v=JZ2pDlhqPio)
https://m.youtube.com/watch?v=LFJjls7B6_c (https://m.youtube.com/watch?v=LFJjls7B6_c)
https://m.youtube.com/watch?v=9UN_ucrThWQ (https://m.youtube.com/watch?v=9UN_ucrThWQ)
https://m.youtube.com/watch?v=sjTwiRf4kXc (https://m.youtube.com/watch?v=sjTwiRf4kXc)
https://m.youtube.com/watch?v=3ub4CzL9hMM
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=667647&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en (http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=667647&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en)
Input 30 W DC. Output 300 VA( W) pulsed 20 Hz
How many "constant Watt" are " pulsed Volt-Ampere" equivalent ?
Kanarev ,pulse power calculation :
15000 W peak ~ 144 W average ~ 1,4 Watt real power
300 V a 50 A. - pulse on/ off. - ?
Force amplification of power by modulation
https://www.youtube.com/watch?v=3gzbaYUNRjM (https://www.youtube.com/watch?v=3gzbaYUNRjM)
Wesley
https://www.youtube.com/watch?v=NeJJ5YojxHE (https://www.youtube.com/watch?v=NeJJ5YojxHE)
Wesley
https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=WO&NR=2014070629A1&KC=A1&FT=D&ND=1&date=20140508&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=WO&NR=2014070629A1&KC=A1&FT=D&ND=1&date=20140508&DB=&locale=#)
https://register.epo.org/application?number=EP13851432&tab=main (https://register.epo.org/application?number=EP13851432&tab=main)
https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=US&NR=8847720B2&KC=B2&FT=D&ND=&date=20140930&DB=&locale=# (https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=US&NR=8847720B2&KC=B2&FT=D&ND=&date=20140930&DB=&locale=#)
only as information
and a link : citing documents Lukas Emch
https://worldwide.espacenet.com/publicationDetails/citedDocuments?CC=WO&NR=2014070629A1&KC=A1&FT=D&ND=1&date=20140508&DB=&locale= (https://worldwide.espacenet.com/publicationDetails/citedDocuments?CC=WO&NR=2014070629A1&KC=A1&FT=D&ND=1&date=20140508&DB=&locale=)
one wire + one wire , 1mtr distance to 10 cm distance to 1 cm distance to 1 mm distance in Newton
https://www.nist.gov/si-redefinition/ampere-history
Where are in Physics the maximal and minimal limits !?
2013 !
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.mpg.de%2F6769805%2Fnegative_absolute_temperatur (https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.mpg.de%2F6769805%2Fnegative_absolute_temperatur)
" negativer Druck"
Plasma and its properties focuses attention of few Russian experimenters
We have few new names popular in Russian FE community.
1. Fizik man (https://www.youtube.com/channel/UCwama-l19TyG5E-bR3NSmmw) a. https://www.youtube.com/watch?v=U-vW1II_3uM (https://www.youtube.com/watch?v=U-vW1II_3uM)
b. https://www.youtube.com/watch?v=zrYeso7FFZ4 (https://www.youtube.com/watch?v=zrYeso7FFZ4)
correction: first picture refers to video 1b
2. Vasily Vorobyov (https://www.youtube.com/channel/UClpYo8baRT9WcT6IIAwTYyw) c. https://youtu.be/t-o7dL3Iq94?t=82 (https://youtu.be/t-o7dL3Iq94?t=82)
d. https://www.youtube.com/watch?v=xhkqtb-N2B0 (https://www.youtube.com/watch?v=xhkqtb-N2B0)
video # d is replication of чип ( Chip) experiment/ so is effect taking place in Ruslan Kalabuhov/so is in Kapanadze
3.the main man in focus is чип (Chip):
in many of comments чип art [glow=
orange,2,300] is for some reason ./not easily accessible/ protected/by close to him known experimenters [/glow]
look at translation of comments below video (second picture from below )
Note I didn't list чип here yet.
In contrary :
4.SIRIUS SOTIS ТЕХНИКА is conservative and very much respected in FE.
https://www.youtube.com/channel/UCSZOce0WccuPzbcghA36DlQ/videos (https://www.youtube.com/channel/UCSZOce0WccuPzbcghA36DlQ/videos)
Wesley
This might give some ideas to a few working on resonant flux switching:
https://www.cettechnology.com/what-is-a-planar-transformer/
https://www.isemagnetics.com/publicaties/detail.php?ID=347
I know Chris Sykes. I met him several months ago. Wesley, what was the purpose of your posts about him?
TT!
Quotehttps://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172549/image//
Here such device works for me. from the ferrite antenna from the radio.
And it should not work. There is no generation in the simulator.because the gain of the cascade with a common base is less than 1
But in practice it works.
Hi kolbacict,
It is good the circuit oscillates in practice when built from a correct schematic. In the circuit simulator, have you tried to flip the wires of coil T1 ? (or T2, it does not matter which of them) Or what coupling factor did you choose between T1 and T2 (mutual inductance)?
Regarding the common base single transistor stage its voltage gain can be much higher than 1 so basically the simulator should work also. What is the number of turns for T1 and T2? Try to increase the number of turns for T2 if it happens to be less than that of T1.
Gyula
Similar concept is proposed by guy who is close to hiding himself "chip"
Wesley
Hi. A factory rod was taken (LW, MW; radio receiver magnetic antenna). contur coil.
As it is not surprising, the generation is available for any connection. (flip) :)
https://www.youtube.com/watch?v=9yFTWQXY1oI (https://www.youtube.com/watch?v=9yFTWQXY1oI)
18MHz 800V
Russian military tube used in generator is GU50.
The end of the rod is made from graphite.
The flame is caused by adding capacitance of human hand holding metal wire. (https://youtu.be/9yFTWQXY1oI?t=315 (https://youtu.be/9yFTWQXY1oI?t=315))
The nature of the flame explained by narrator is natural presence of Oxygen, Nitrogen transmutating Graphite.
However author says that Graphite has nothing to do with nature of the flame and Graphite is only the "victim" of the interaction
Between O and N, in presence of HV
Wesley
Note:
no interpretation
This post is related to energy conversion using Terfenol D, and is not in any way related to my post from above:
http://tdvib.com/terfenol-d/ (http://tdvib.com/terfenol-d/)
https://aip.scitation.org/doi/pdf/10.1063/1.5006676 (https://aip.scitation.org/doi/pdf/10.1063/1.5006676)
Terfenol-D has the largest room temperature magnetostriction (http://www.tdvib.com/magnetostriction/) of any known material. T
Terfenol-D is a solid-state material [glow=violet ,2,300]capable of converting energy from one form to another.[/glow]
Picture from below shows Ted Annis application of Terfenol D
Wesley
Answer to mkjekyll:http://www.magnets.com.cn/Magnetic-powder/dry-pressing-strontium-ferrite-magnetic-materials.html (http://www.magnets.com.cn/Magnetic-powder/dry-pressing-strontium-ferrite-magnetic-materials.html)
QuoteWhat is the difference in a magnet that is aligned prior to sintering and one that is not?
No such thing as aligned prior to
sintering exists.!!!!
Yes I agree that such term is in use.
Temperature of sintering around 1200C (2192F)must affect magnetization of particles making the magnet
So when in green stage that magnet is different from the ready to use one.
for these interested what sintering is:
process of making (a powdered material) coalesce into a solid or porous mass by heating it (and usually also compressing it) without liquefaction.
The problem we have here is
Curie temperature:In physics and materials science, the
Curie temperature(Tc),
or Curie point, Quoteis the temperature at which certain materials lose their permanent magnetic properties,
to be replaced by induced magnetism.
The Curie temperature is named after Pierre Curie, who showed that magnetism was
lost at a critical temperature.
https://en.wikipedia.org/wiki/Curie_temperature (https://en.wikipedia.org/wiki/Curie_temperature)
Note to mkjekyll:
Please note that
anisotropic powder is not grown crystals but mechanically powdered crystals in withing particles.
Wesley
Answer to mkjekyll #2:
some videos from sintering.
https://www.youtube.com/watch?v=rVyVqtQrjnI (https://www.youtube.com/watch?v=rVyVqtQrjnI) process of heating at temperature below curie temperature
https://www.youtube.com/watch?v=pwOu8Jkjwms (https://www.youtube.com/watch?v=pwOu8Jkjwms) this one is exotic ( skip it unless you know what it is)Please note that magnet wire has nothing to do with magnet.
https://youtu.be/6hPodO-ZsTY?t=26 (https://youtu.be/6hPodO-ZsTY?t=26)
https://www.youtube.com/results?search_query=sintering+of+magnethttps://www.youtube.com/watch?v=7-KSDPWw7jU (https://www.youtube.com/results?search_query=sintering+of+magnethttps://www.youtube.com/watch?v=7-KSDPWw7jU)
https://www.youtube.com/watch?v=lJ22svZFGKc (https://www.youtube.com/watch?v=lJ22svZFGKc) - interesting and educational.
this is the green stage
https://www.youtube.com/watch?v=nHjayUoi8L4 (https://www.youtube.com/watch?v=nHjayUoi8L4) much more primitive way to sinter
this video deserves your attention( starts from given time)
https://youtu.be/jq8WOUFeCcg?t=138 Curie temperature
Wesley
Science don't want to touch explanation of Avramienko fork phenomena.
I don't have time to write much
I'm preoccupied with my Electron Microscope
But for these who read Russian here it is:
https://drive.google.com/file/d/1rqFe0HVdSqCDitYSLFcpFqyy4cC3loMu/view
Wesley
Assembly of LEO 435VP is going takes me some time.
Some links to EDXRF detector mounted in the instrument:
1. https://www.youtube.com/watch?v=WIcTTPffyMw (https://www.youtube.com/watch?v=WIcTTPffyMw)
EDS Inca Calibration
2. https://youtu.be/SdpXFcf_La0?t=929 (https://youtu.be/SdpXFcf_La0?t=929)
Energy Dispersive X Ray Spectroscopy
3. https://www.youtube.com/watch?v=xlXEP5yONA0 (https://www.youtube.com/watch?v=xlXEP5yONA0)
Introduction to Energy Dispersive X-ray Spectrometry (EDS
I'm in process -of checking connections:
The two HD one in LEO 435VP and one with separate computer dedicated to INCA two units:
a.inca mics
b. inca x-stream
Both of them are being replaced with new one.
Yes I do have shot gun powder residue analysis capability too.
This is great for powder analysis .
Compaction press for the green stage, prior to sintering is not a problem .
working on crystalline of the ferrite.
We expect new sample to be send from Riga.
Oxford Instruments ISIS 300 EDX spectrometer operating in variable pressure mode at 10
Pascals with an accelerating voltage of 10 kV and a beam current of 500 picoamps for 1000 frames
http://research.engineering.ucdavis.edu/cnm2/wp-content/uploads/sites/11/2017/04/EDXS-SOP_033017.pdf (http://research.engineering.ucdavis.edu/cnm2/wp-content/uploads/sites/11/2017/04/EDXS-SOP_033017.pdf)
Oxford Instruments Energy-Dispersive Spectroscopy (EDS) Operating Manual
https://www.ncdoj.gov/getdoc/335a812e-088d-4df5-ac0b-6e5ce8357bd7/SEM-EDX-GSR-ASPEX.aspx (https://www.ncdoj.gov/getdoc/335a812e-088d-4df5-ac0b-6e5ce8357bd7/SEM-EDX-GSR-ASPEX.aspx) -
Characteristic Gunshot Residue Particles.
GSR Casework procedure manual
http://meteorite.unm.edu/site_media/pdf/SEM_Manual2006.pdf (http://meteorite.unm.edu/site_media/pdf/SEM_Manual2006.pdf)
This is JEOL but it has manual for Link from ISIS older version
http://eprints.whiterose.ac.uk/114574/9/ASTM%20paper%20Graphite%20in%20Steel%20DVEdmonds_SubmittedMainDocument_newer%20version.pdf (http://eprints.whiterose.ac.uk/114574/9/ASTM%20paper%20Graphite%20in%20Steel%20DVEdmonds_SubmittedMainDocument_newer%20version.pdf)
Picture below is an example of application.
SEA5120 is university lab grade XRF.
The major advantage with LEO 435VP is WDS technique that is an addition to traditional EDS
Wesley
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4082842/ (https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4082842/)
Quotecomponents of gunshot residue (GSR), in particular, metallic particles originating from the ammunition primer, reveal characteristic properties and so provide themselves a
high value evidence of using a firearm. Only few particles, of total mass no greater than 100 picograms, can be accepted as the evidence relating an individual with a shooting incident.
The fundamental criterion of the identification of metallic gunshot particles is their chemical contents, that is, rarely occurring set of elements: lead, antimony, and
barium as well as their morphology reflecting the kinetics of the processes undergoing during a gunshot, especially rapid cooling of droplets of the molten metals
present in the expanding plum of products of the primer detonation and the propellant combustion.
In our application violent processes in the ferrite associated with strong vibration and sound can be analyzed by analysis of its kinetics - in "after facts".
I'm very careful now, watching every step to properly estimate any possible side effects .
Wesley
Dr Judy Wood
supported John Hutchison Hutchison effect.
http://www.drjudywood.com/articles/a/bio/Wood_Bio.html (http://www.drjudywood.com/articles/a/bio/Wood_Bio.html)
Her report was scrutinized , .
http://www.drjudywood.com/wp/court-case-qui-tam/ (http://www.drjudywood.com/wp/court-case-qui-tam/)
https://www.youtube.com/watch?v=sXB83Heh3_c&list=PLD9157ED196DB53DE (https://www.youtube.com/watch?v=sXB83Heh3_c&list=PLD9157ED196DB53DE)
This is somehow similar to Hutchison Effect
https://www.damninteresting.com/retired/the-hutchison-effect/ (https://www.damninteresting.com/retired/the-hutchison-effect/)
https://intalek.com/Index/Projects/SmartLINK/SmartLINK.htm (https://intalek.com/Index/Projects/SmartLINK/SmartLINK.htm)
original samples:
https://www.youtube.com/watch?time_continue=14&v=TsKL9n3NDiw (https://www.youtube.com/watch?time_continue=14&v=TsKL9n3NDiw)
Intalek.inc sends us to :
RELATED RESEARCHUS PATENT 512,340 (https://intalek.com/Index/Projects/SmartLINK/00512340.PDF), COIL FOR ELECTRO MAGNETS, N. TESLA, January 9, 1894.
US PATENT 593,138 (https://intalek.com/Index/Projects/SmartLINK/00593138.PDF), ELECTRICAL TRANSFORMER, N. TESLA, November 2, 1897.
US PATENT 645,576 (https://intalek.com/Index/Projects/SmartLINK/00645576.PDF), SYSTEM OF TRANSMISSION OF ELECTRICAL ENERGY, N. TESLA, March 20, 1900.
US PATENT 649,621 (https://intalek.com/Index/Projects/SmartLINK/00649621.PDF), APPARATUS FOR TRANSMISSION OF ELECTRICAL ENERGY, N. TESLA, May 15, 1900.
US PATENT 723,188 (https://intalek.com/Index/Projects/SmartLINK/00723188.PDF), METHOD OF SIGNALING, N. TESLA, March 17, 1903.
US PATENT 725,605 (https://intalek.com/Index/Projects/SmartLINK/00725605.PDF), SYSTEM OF SIGNALING, N. TESLA, April 14, 1903.
US PATENT 787,412 (https://intalek.com/Index/Projects/SmartLINK/00787412.PDF), ART OF TRANSMITTING ELECTRICAL ENERGY THROUGH THE NATURAL MEDIUM, N. TESLA, April 18, 1905.
Scalar Wave Technology (https://intalek.com/Index/Projects/SmartLINK/ScalarWaveTechnology-Experimental-Kit2003.pdf), by Konstantin Meyl.
Yet another video of intalek.com:
Magnetic Field Generator (free energy)
https://www.youtube.com/watch?v=PPHRBtQ08ro (https://www.youtube.com/watch?v=PPHRBtQ08ro)
this video is fallowed by additional link
http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf (http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf)
http://www.intalek.com/Papers/Handout3.pdf (http://www.intalek.com/Papers/Handout3.pdf)
Hutchison moved to US from Canada and he lives in small house.
Wesley
Literature:
Difference of isotropic and anisotropic magnet
https://www.eng-tips.com/viewthread.cfm?qid=304367 (https://www.eng-tips.com/viewthread.cfm?qid=304367)
Isotropic Magnet and Anisotropic Magnet
http://www.simotecthailand.co.th/en/knowledge6.html (http://www.simotecthailand.co.th/en/knowledge6.html)
Orientation technology of anisotropic injection magnet
https://www.magnet-sdm.com/2016/09/18/806/ (https://www.magnet-sdm.com/2016/09/18/806/)
https://www.mpcomagnetics.com/product/arc-anisotropic-hard-ferrite-magnet/ (https://www.mpcomagnetics.com/product/arc-anisotropic-hard-ferrite-magnet/)
How Ferrite Magnets are made
https://e-magnetsuk.com/ferrite_magnets/ferrite_magnets_made.aspx (https://e-magnetsuk.com/ferrite_magnets/ferrite_magnets_made.aspx)
https://en.wikipedia.org/wiki/Ferrite_%28magnet%29 (https://en.wikipedia.org/wiki/Ferrite_%28magnet%29)
Wesley
Wesley,
Thanks for posting the video link, it is always a great feeling to see a young person who is interested enough to build things rather than buy things. This man has amazing talent that he did not come by in school. Our public schools now have mostly removed music and science, unless one goes to a charter school.
It is a shame more parents don't encourage this kind of adventure as obviously this man was encouraged.
I love the varispeed on that lathe, fantastic.
Here is a great video of the Audi plant building electric motors https://www.youtube.com/watch?v=zttC2x9nMEw
JUST PASSING BY.
http://www.patentsencyclopedia.com/imgfull/20150102675_01
https://www.youtube.com/watch?v=3MXOFqDWvgA&feature=youtu.be
Presentation of resonance based electrical motor
from 3....5kw originally it is now 10kW
Based on inventor claim.
Wesley.
https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fadgex.ru%2F (https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fadgex.ru%2F)
They, adgex.ru,have several solutions " in the pipe" ....
Energybrick : 25.000 charge cycles ,super fast charging ,......
http://www.ntpo.com/izobretenija/alternativnaya-energetika/netradicionnye-istochniki-jenergii/7479-rezonansnyj-generator-ank (http://www.ntpo.com/izobretenija/alternativnaya-energetika/netradicionnye-istochniki-jenergii/7479-rezonansnyj-generator-ank)
https://www.youtube.com/watch?v=tg_J_bcLB2o&feature=youtu.be (https://www.youtube.com/watch?v=tg_J_bcLB2o&feature=youtu.be)
When Load is 7.2 Ohm motor is turning slower than when output is shorted.
Wesley
Способ получения статического электричества
Method of creating static electricity
Patent:
http://www.ntpo.com/izobreteniya-rossiyskoy-federacii/elektroenergetika/alternativnye-istochniki-energii/vetroelektrostancii/37929-sposob-polucheniya-staticheskogo-elektrichestva.html (http://www.ntpo.com/izobreteniya-rossiyskoy-federacii/elektroenergetika/alternativnye-istochniki-energii/vetroelektrostancii/37929-sposob-polucheniya-staticheskogo-elektrichestva.html)
Wesley
"BELL SHAPE" like in Lithuania Experiment measured by Linas
https://yandex.ua/images/search?pos=27&img_url=https%3A%2F%2Fvia-midgard.com%2Fuploads%2Fposts%2F2011-03%2F1301119610_fig-10-10.jpg&text=%D0%93%D0%A1%D0%A5%D0%95%D0%9C%D0%AB%20%D0%B3%D0%B5%D0%BD%D0%B5%D1%80%D0%B0%D1%82%D0%BE%D1%80%D0%B0%20%D0%9C%D0%B5%D0%B5%D1%80%D0%B0&rpt=simage&source=related-duck&rlt_url=https%3A%2F%2F3.bp.blogspot.com%2F-eXZR-Vwafxk%2FXAOXJth0M8I%2FAAAAAAAA_Ls%2FnpVXGcCOROM61im5zwq48_wQsSzlO0P4wCLcBGAs%2Fs1600%2FStanley%252BMeyer%252BHHo%252BHydrogen%252Bsteam%252Bresonator%252Bschematic.png&ogl_url=https%3A%2F%2Fvia-midgard.com%2Fuploads%2Fposts%2F2011-03%2F1301119610_fig-10-10.jpg (https://yandex.ua/images/search?pos=27&img_url=https%3A%2F%2Fvia-midgard.com%2Fuploads%2Fposts%2F2011-03%2F1301119610_fig-10-10.jpg&text=%D0%93%D0%A1%D0%A5%D0%95%D0%9C%D0%AB%20%D0%B3%D0%B5%D0%BD%D0%B5%D1%80%D0%B0%D1%82%D0%BE%D1%80%D0%B0%20%D0%9C%D0%B5%D0%B5%D1%80%D0%B0&rpt=simage&source=related-duck&rlt_url=https%3A%2F%2F3.bp.blogspot.com%2F-eXZR-Vwafxk%2FXAOXJth0M8I%2FAAAAAAAA_Ls%2FnpVXGcCOROM61im5zwq48_wQsSzlO0P4wCLcBGAs%2Fs1600%2FStanley%252BMeyer%252BHHo%252BHydrogen%252Bsteam%252Bresonator%252Bschematic.png&ogl_url=https%3A%2F%2Fvia-midgard.com%2Fuploads%2Fposts%2F2011-03%2F1301119610_fig-10-10.jpg)
http://the-eye.eu/public/concen.org/Build%20Your%20Own%20Stanley%20Meyer%20Water%20Fuel%20Cell%202015%20research%20pack/pics/circuits%20and%20schematics/ (http://the-eye.eu/public/concen.org/Build%20Your%20Own%20Stanley%20Meyer%20Water%20Fuel%20Cell%202015%20research%20pack/pics/circuits%20and%20schematics/)
Wesley
https://iwanthho.wordpress.com/
Wesley
So bell waveform from sparkgap as well as from spark train generator from gas furnace, and Tariel Kapanadze has form of
-the infinitely growing signal.
But Stanley Meyer waveform shows the same behavior
We assume that his invention was real so is Tariel Kapanadze.
And now you have similarity between the two.
https://www.youtube.com/watch?v=xvBsaBWt84Q&t=39s (https://www.youtube.com/watch?v=xvBsaBWt84Q&t=39s)
This video shows spark gap waveform made by Russian I spoke to few minutes ago.
Wesley
This is my old experience with an electrostatic field.
Look at the LED minus when the coil is disconnected.
The meaning lasts longer than the power.
Unfortunately, I do not have an oscilloscope measurement but it's easy to repeat it.
https://www.youtube.com/watch?v=Iz1M-I_F6SU
Hi Wesley,
This is the patent application in which Figure 10 you searched for is included:
https://worldwide.espacenet.com/publicationDetails/biblio?CC=WO&NR=9207861A1&KC=A1&FT=D&ND=&date=19920514#
Found and deduced from this url link's pictures:
Gyula
In the 1994 Don Smith video (11 minute mark) Don talks about the trumpet waveform where he refers to the book "Vacuum Tubes by Karl Rudolph Strangenberg. Pgs. 578 - 579". In his case the trumpet waveform is a result of the grounding shunt (electron source) of L2.
Quote "This whole device is like a pump"
Also 1996 video at the 1:02 mark.
Here's what Don says about resonate induction: Resnate induction transfer disturbs a large number of adjacent electrons which were not a part of the original source. The pulsating (pumping effect) then incorporates the newly available extra electrons into the ongoing energy generation source system. A near unity energy system of resonate air core coils and the extra acquired electron energy source constitutes an overunity system.
https://www.youtube.com/watch?v=or_wCy2OzWk
Tiger( the guy who was hired by
Stefanov to examine Akula device):
Current of HV HF signal is send
Capacitor is at that moment in magnetic field of Low Frequency signal.
That at certain point causes mechanical vibration of dielectric of capacitor.
that movement inside of plates( aluminum foil) of capacitor creates additional charge.
Wesley
Note: for these who don't understand the importance of it :If no-interupting or overloading factor exist the bell waveform would be infinitely growing.It looks like Stanley Meyer water fuel cell patentBut "I didn't find exactly that drawing.
Klystron
links
Quote1.Stanley Meyer ,book , patents, schematics, etc.
http://www.globalkast.com/documentation.htm (http://www.globalkast.com/documentation.htm)
1.a. Book: The Birth of New Technology (pdf)
http://www.globalkast.com/docs/S.Meyer_The_Birth_of_New_Technology.pdf (http://www.globalkast.com/docs/S.Meyer_The_Birth_of_New_Technology.pdf)
1.b. p114 Voltage intensifier circuit
p138 Dynamic voltage system
p201 Opposite voltage charging effect
2. Stephen Meyer-MLS-Hydroxyl Filling Station
http://www.globalkast.com/docs/stephen_meyer_USPatent-20050246059.pdf (http://www.globalkast.com/docs/stephen_meyer_USPatent-20050246059.pdf)
3. Andrija Puharich-Method & Apparatus For Splitting Water Molecules
http://www.globalkast.com/docs/Andrija%20Puharich%20-%20US4394230.pdf (http://www.globalkast.com/docs/Andrija%20Puharich%20-%20US4394230.pdf)
4. JLN Labs - Water Fuel Cell ( WFC ) Researches
http://jnaudin.free.fr/wfc/index.htm (http://jnaudin.free.fr/wfc/index.htm)
Wesley
Quote from: stivep on May 08, 2019, 12:38:43 PM
Wesley
Excerpts from, "The Don Smith Book - Magnetic Resonance Energy Crafting Systematic Index" by Richard Friedrich
Klystron
Quote from: a.king21 on May 10, 2019, 05:21:59 PM
Klystron
Thank you very much https://en.wikipedia.org/wiki/Klystron (https://en.wikipedia.org/wiki/Klystron)
I see it as helpful information.
However Klystron operates at HF band and acts as a valve
But here we have:
1. Low-Frequency Klystron for Accelerator Applications
https://www.researchgate.net/publication/224287346_Low-Frequency_Klystron_for_Accelerator_Applications (https://www.researchgate.net/publication/224287346_Low-Frequency_Klystron_for_Accelerator_Applications)
and that is interesting.
The low frequency for the article and application is still quite high 201MHz.
2. The table III sends us to 100MHz
3.https://www.sciencedirect.com/science/article/pii/S0031891459905397 (https://www.sciencedirect.com/science/article/pii/S0031891459905397)
QuoteA description is given of a servo, stabilizing the frequency of a microwave oscillator to the resonance
frequency of a cavity, modulated at an audio frequency.
The stabilizer requires no re-adjustment and is designed especially for very short waves and continuous operation
Thee is not much explanation and audible frequency may act as pulse beat.
so we may scrap point 3.
I see a.king21 comment as important.
Traveling-wave tube:
QuoteTraveling-wave tube. A traveling-wave tube ( TWT, pronounced "twit")
or traveling-wave tube amplifier ( TWTA, pronounced "tweeta") is a specialized
vacuum tube that is used in electronics to amplify radio frequency (RF) signals
in the microwave range. The TWT belongs to a category of "linear beam"
tubes, such as the klystron
https://en.wikipedia.org/wiki/Traveling_wave_tube (https://en.wikipedia.org/wiki/Traveling_wave_tube)
https://www.revolvy.com/page/Traveling%252Dwave-tube (https://www.revolvy.com/page/Traveling%252Dwave-tube)
One of simple techniques is to take CRT from old oscilloscope or old long neck CRT. Cut just the neck( the longer the better.)
Open neck is the glass tube similar to
cold catode tube.- https://en.wikipedia.org/wiki/Cold_cathode (https://en.wikipedia.org/wiki/Cold_cathode)
The only difference is that our tube has filament.
We than may at easiest place it in glass jar and vacuum it, or heat it with torch and and join it it to glass tube from
Glass Pyrex labware, .
I did it in the past. It is doable.
The targeted focused electron beam can be check using piece of fluorescent screen from old CRT or fluorescent lamp.
https://www.youtube.com/watch?time_continue=3&v=3OgsqhxwGmo
Wesley
PS:
But everything that is big can be scaled down. ..well not everything.. waveguide must have real estate to work.
By that Schumann waveguide is space between earth and ionosphere.
some snack of good and old
https://www.youtube.com/watch?time_continue=47&v=OI_HFnNTfyU
Wesley
A klystron needs input power to heat the filament for emitting electrons from the cathode.
Also high positive voltages should be created by a power supply for accelerating
the electrons and to maintain the negative resistance.
So basically this device has a COP < 1 in itself, just like the good old electric valves or transistors etc we use for amplifying any signal.
So question remains where the 'magic' happens if COP > 1 result is forecast?
Gyula
Quote from: gyulasun on May 10, 2019, 06:35:11 PM
Gyula
There is almost never COP>1 unless you dealing with Coefficient of Performance – Heat Pump, Refrigerator, Air Conditioner.
There is no overunity.
however the subject was brought to your attention by CHAIN OF INTERACTIONS STARTING WITH ionisation in presence of hydrogen for
Stanley Meyer that was next compared to Tariel Kapanadze
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534102/#msg534102 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534102/#msg534102)
I found common factors ( similarity) between the two.
Quote from: stivep on May 08, 2019, 01:25:09 PM
Thank you.
the 3 factors:
-HV
-resonance
-ionization
in Stanley Mayer and Tariel Kapanadze are accounted for.
we also have electrostatic potential.
By that we can conclude that ionization of the air when compared to picture ( two links)
showing hydrogen phases of energy conversion and Bell waveform (known as trumpet ) can be a factor of must have it!!!
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172822/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172822/image//)
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172823/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172823/image//)
-in other words I'm pointing at identification of energy conversion based on its components e.g hydrogen look at the picture and its descriptors.
Wesley
The RLC circuit is not an effect. It's a cause. Phase conjugate mirror creates negative resistance.
Look again at the RlC circuit. Check the ARRL nomograph .
You are looking for 120 cps. 60 up and 60 down.
Read Gabriel Kron.
Remember Kirchoffs laws are a special case. They do not apply to external magnetic fields.
Nearly every circuit has an internal or external magnetic field. Use Faraday's law instead.
All the physics books even at University level have have it wrong.
Don't believe me. Believe MIT
https://www.bing.com/videos/search?q=kirchoff+is+for+the+birds&view=detail&mid=943946C8F2CCD60A2132943946C8F2CCD60A2132&FORM=VIRE (https://www.bing.com/videos/search?q=kirchoff+is+for+the+birds&view=detail&mid=943946C8F2CCD60A2132943946C8F2CCD60A2132&FORM=VIRE)
from last minute:
Secret of Svobodian motor.
Often videos are deleted so please make copy of this video.
https://www.youtube.com/watch?reload=9&v=A_Zd5L3WXCo&feature=youtu.be (https://www.youtube.com/watch?reload=9&v=A_Zd5L3WXCo&feature=youtu.be)
Please look in this video at uneven surface of original Svobodian coils.
Wesley
a. King21 : very small written : " c. Eigen-function" ( Figure 4 )
An array :
https://worldwide.espacenet.com/publicationDetails/biblio?II=0&ND=2&adjacent=true&FT=D&date=20061031&CC=CH&NR=695975A5&KC=A5#
https://www.youtube.com/watch?v=vmU1Jjs94ZI (https://www.youtube.com/watch?v=vmU1Jjs94ZI)
there is some misunderstanding in the video
about impedance and its reactive components in minute 5:57
Here you have link to calculate inductive reactance.
http://www.learningaboutelectronics.com/Articles/Inductor-impedance-calculator.php (http://www.learningaboutelectronics.com/Articles/Inductor-impedance-calculator.php)
https://en.wikipedia.org/wiki/Bifilar_coil (https://en.wikipedia.org/wiki/Bifilar_coil)
QuoteIn electrical terms, this means that the self-inductance (https://en.wikipedia.org/wiki/Self-inductance) of the bifilar coil is zero.
if it is Zero at this configuration.
But coil wire capacitance means capacitive reactance is not zero.!!!
Impedance exists only at AC and has 3 components:
-resistance
- capacitive reactance
- inductive reactance
the trick making that what we are waiting for is parasitic oscillations.
the concept of coil of Svobodian is shown on the pictures;
Wesley
#2
I'm simply delighted by comment at 7:17 expressed in the video from above.
The coil of Svobodian shown in
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534233/#msg534233 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534233/#msg534233)
cancels its inductance but becomes capacitively active.
Good conclusion.
Wesley
#3
In minute 8:01 of the video from above there is a statement:
QuoteSince we have only capacitive component left in bifilar coil than we can work at frequency of capacitive reactance with another coil.
Well every capacitor has his own inductive reactance .
It is the matter of relation.
for bifilar :
coil to coil inductance =0
( if it can be zero look at types of bifilar https://en.wikipedia.org/wiki/Bifilar_coil (https://en.wikipedia.org/wiki/Bifilar_coil) )
Coil capacitive reactance in that relation is evident.
But now you take this assembly in relation to itself...
And you are very much surprised.
so Gentlemen in video proposes such assembly interaction with another coil.
https://youtu.be/vmU1Jjs94ZI?t=519 (https://youtu.be/vmU1Jjs94ZI?t=519)
here his is too revolutionary but very interesting.
He explains circular motion ( rotation of the disc - with the fixed center pin) of the magnets with fixed coils or reverse and interaction of such bifilar assembly -with magnetic field of the magnet.
We need to understand here:
That bifilar can only be canceling one of reactive components ( Inductive Reactance )if there is no influence of external moving field due to rotation.
Wesley
#4
in 9:10 gentelmen says that capacitive reactive character of inductor means leading capacitive reactance.
If you look at Smith Chart you can see that voltage is now rapidly increased.
It could go to few thousands V .
due to rotation of the disc with magnets( or coils) that Voltage variation creates force supporting and increasing rotation at "right frequency."
This is done due to magnet being close to coil assembly during rotation and than going away.
I went so far to half of the video and I'm satisfied
Wesley
#5
the confusion starts usually when you look at product of interaction.
Capacitance is characteristic by charge storage.
Inductance is characteristic by its magnetic field.(when current is flowing)
So addition of another magnetic field from magnet on the disc approaching fixed position coil
makes this bifilar balanced coil structure to "go crazy" for that particular moment in time.
The gentleman is mentioning Caduceus ( Lithuania Experiment part 2)
However in https://youtu.be/vmU1Jjs94ZI?t=734 statement about Free energy doesn't explain what energy is coming from.
He only says how to get the energy.( his own opinion)
Wesley
#6
In minute 15:15 he is mentioning
please skip this link: (GRAHAM winding parameters https://watch-winder.store/watch-winding-table/graham/ (https://watch-winder.store/watch-winding-table/graham/))
Gramme coil:
https://en.wikipedia.org/wiki/Gramme_machine (https://en.wikipedia.org/wiki/Gramme_machine)
https://en.wikipedia.org/wiki/File:Gramme_Ring_-_4_coil.svg (https://en.wikipedia.org/wiki/File:Gramme_Ring_-_4_coil.svg)
I'm confused with if I understood good the guy mentioning Stanley Meyer
tube coaxial structure.
And than the related to mechanical resonance ?
I'll look at it tomorrow.
I didn't see entire video yet.
Wesley
Hi to everyone.
And what was this device?
part of the device Soviet-made.
His scheme.
Quote from: gyvulys666 on May 14, 2019, 12:36:57 AM
stivep. dont u think your picture with coil is wrong?"" [size=0px]secret of Svobodian engine ( motor)3.jpg (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172874/)[/font][/size]"" in this pic it seems simple bifilar winding style.
guy in video from start mentions caduceus winding style .
he also mentions in video about solenoid coil style winding and tells to wind one layer of coil one direction then u make new layer in other direction
and every layer changes direction and as i understood all these layers all are separate wires. after u finish winding these separate layers u must connect them
so in the end it would look like caduceus coil (paralleled like your bifilar picture)
https://www.youtube.com/watch?v=A_Zd5L3WXCo&t=4s (https://www.youtube.com/watch?v=A_Zd5L3WXCo&t=4s)
However question to you guys :)
what is the difference between
CC and
CCW coil winded on the same former and the same bifilar winded with double wire ?
Wesley
Quote from: kolbacict on May 14, 2019, 02:24:17 AM
Hi to everyone.
His scheme.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-8/resonant-filters/
https://en.wikipedia.org/wiki/Voltage_divider
Wesley
Hi to everyone.
His scheme.
It is very likely a tunable low pass filter whose cut-off frequency can be varied by a DC control voltage connected to the series resistor
input and the common ground rail. With varying the DC voltage you can change the capacitance of the varicap diodes hence tune the filter.
(The series resonant circuits help improve attenuation at further frequencies to be attenuated.)
Here you can see a band pass filter, also tunable by varicap diodes: http://www.amateurradioreceivers.net/blueltnbpf.htm (http://www.amateurradioreceivers.net/blueltnbpf.htm)
Gyula
sinusoidal signal is delivered to C1 -
After C1 the LC1 shorts to the ground (in Notch filter fashion) one single frequency that must be eliminated by filter.
However this LC1 has its own bandwidth so it is primary frequency and some adjacent frequencies that will be cut.
The LC2 acts similar to LC1
The L1x and the last L.x a different coils.
-L1X has 2 winds
-L.x has 4+ 2 with extended distance (pitch) between the winds.( note that you have 21 coils and only 20 diodes)
That last two winds pitch have been manually adjusted to resonance.
rule: the wider is the distance between winds the higher is its resonance frequency.
If frequency of the rest of Lx coils differs from frequency of L.x coil than the bandwidth of band pass filter is set.
If frequency of the rest of Lx coils differs from frequency of L.x coil but it overlaps resonance boarder of L.x coil than we have nice clean continuous widening of band pass filter.
L1x becomes invisible at frequency of its own resonance as if was not there at all.
the same story is with rest of Lx coils
It is band pass filter where only positive impulses are allowed at the output.
The frequency of operation is in 200+MHz
C1 (2 capacitors in green color) and Lx coils determines bandwidth of band pass filter.
Widening of bandwidth of bandpass filter by overlapping
Wesley
https://youtu.be/yNs2wc8nRJw?t=352 (https://youtu.be/yNs2wc8nRJw?t=352)
https://youtu.be/_YPVwfnvqw0?t=326 (https://youtu.be/_YPVwfnvqw0?t=326)
вот почему ваш CE не работает
Ранняя стадия искровых передатчиков 1901-1927 года
работала с довольно хорошим шумом
из-за ширины полосы искрового промежутка от низкой до 1 ГГц и максимальной на 20 кГц. Вам нужен генератор шума, а не наносекундный генератор.
Вот почему импульсный генератор создания искры ( train impulse generator)
от газового котла является лучшим для его и он был использован в презентации Тариэл Капанадзе мне в 2011 году.
Посмотрите на видео здесь
Wesley
1000pf green capacitor.
10pf blue capacitor.
diodes D901a
330Ω resistor.
Thank you . did not expect such interest. :)
p.s. D 901 is a varicap.
But why is it a varicap and not a diode?
Generally atypical circuitry.
We could not understand what it was.
https://en.wikipedia.org/wiki/Varicap (https://en.wikipedia.org/wiki/Varicap)
https://youtu.be/ngvJ0Wv8cFo?t=449 (https://youtu.be/ngvJ0Wv8cFo?t=449)
The Lx coils disappear in resonance increasing the voltage of positive half of an sinusoidal signal
As we decrease the voltage the capacitance is increased.
As we increase the voltage the capacitance will decrease.
But because we have capacitor C1 at the beginning of the filter than we do not have DC Bios Voltage .
And because we have capacitor C1 at the rear of the filter we have it insulated from DC Bios if there is any.
If there is no voltage at Varicap than its capacitance will be at fixed value.
So since sinusoidal signal is now changed to only positive halves that acts as DC bios in the time intervals between the halves .( if there is any voltage >0 )
So to understand it please think of it as system working at Lx coil resonance frequency where capacitive reactance of D901 is compensated to steady fixed and quickly adjusted value .
So think of it as not "important change" because at output the Voltage will be always the same and will be compensated to keep frequency of output signal at fixed value.
However before I will be sure what I'm talking about I need to have original specification of original D901.
here I found:
https://eandc.ru/catalog/detail.php?ID=5793 (https://eandc.ru/catalog/detail.php?ID=5793)
https://eandc.ru/pdf/diod/d901.pdf (https://eandc.ru/pdf/diod/d901.pdf)
https://www.youtube.com/watch?v=icw8terKP-M
Note: I said the system work at frequency 200MHz +
The specification takes as an example 50MHz but it is not the highest frequency of Varicap.
Honestly I don't know what is the top limit.
I only look at coils to determine Frequency of the system resonat stage
Wesley
Advice:
- Connect generator with sinusoidal signal to input
- connect oscilloscope or spectrum analyzer) to output
- gradually increase frequency
Note:
diode works with Voltage from 0 to 50V but.
typical generator gives around 1V max 10V. so that may be not enough.
For these who don't know what is varicap /varactor
https://www.electronics-notes.com/articles/electronic_components/diode/varactor-varicap-diode.php (https://www.electronics-notes.com/articles/electronic_components/diode/varactor-varicap-diode.php)
Do not confuse it with Varistor!!!
https://en.wikipedia.org/wiki/Varistor (https://en.wikipedia.org/wiki/Varistor)
Wesley
The following link describes how by using nanospheres to harvest evanescent waves from viruses in order to see them without the normal Ab limit issues.
The interested researcher should investigate Nikola Tesla's use of spheres and micro spheres in context with evanescent fields
Hail Royal Raymond Rife
https://www.cnet.com/news/nanoscope-makes-live-viruses-visible-for-first-time/
Tariel Kapanadze device schematic published at realstrannik.com
http://realstrannik.com/media/kunena/attachments/344/file_8febeaf.jpg (http://realstrannik.com/media/kunena/attachments/344/file_8febeaf.jpg)
Wesley
@ gyvulys666
all these layers are 2 separate coils in 2 wires. layers need to wind alternately by 2 wires by different directions.
Translation of the text, attached to the picture posted by me here :
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534370/#msg534370 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534370/#msg534370)
Original text:
в схему используется принцип Исмаеля Ависо
Ничего не надо больше делать. Схема работает без всякой фапч , сама синхронизируется.
Земля не требуется , это увод Капы. Главное запустить ключ. Он должен слегка быть открытым.
Здесь загвоздка в том что ключ находится под переменным напряжением 15 - 20 вольт 50 гц.
Иначе фокус не получится. Всех это смущает даже спецов.
При таком режиме возникают малозатратный способом волны убийцы.
Капа сжёг ведро транзисторов. Вы молодец умеете рисовать , а я чел прошлого
века плохо владею айпадом. Пока все . Желаю удачи.
ключ коротит катушка в пике амплитудой таким образом беззатратно получается мощные
ВВ импульсах с огромная мощность которые усиливает токовую составляющую инвертора
Translation of text to the schematic from above
In the diagram principle of Исмаеля Ависо ( Ismael Aviso) is used
I found this link https://www.youtube.com/watch?time_continue=1&v=XyPRt-uxnKs (https://www.youtube.com/watch?time_continue=1&v=XyPRt-uxnKs)
original link attached to the text:
http://mazeto.net/index.php/topic,10995.msg103833.html#msg103833 (http://mazeto.net/index.php/topic,10995.msg103833.html#msg103833)
Nothing more to do.
The schematic works without PLL, synchronized itself. The Earth is not required, this is Kapanadze concept.
The main thing to start a key. (K)
It should be opened slightly.
Here is the difficulty that a key is in that under a variable AC Voltage of 15 - 20 volt 50 гц. Otherwise it will not work. All this confuses even professionals
In this mode, a low-energy consuming killer wave occurs.
Kapanadze burned plenty of transistors
Well done, you know how to draw, but I as a person from last century I have little control of the iPad. For now. Good luck.
The key will short the coil at peak amplitude so that powerful explosive pulses with enormous power are obtained without cost, which are amplified by the current component of the inverter.
End of translation.
Note: "current component" is the current in the inverter
Note : relation to Ismael Aviso mentioned in translated text, can be seen as similar to Stanley Meyer and his water car.
Wesley
Interesting schematic from Ismael. His shock wave would be the ferroresonance mode of the circuit in which one can derive the FM magnetic from the AM electric. The input power needs regulation as one is looking for the bifurcation point of the core material, whatever it may be, in the case that it can achieve saturation from the minimal input as it needs to change state
The first part acts as a laser in which the half wave diode pumps the core to saturation at which point it dumps the magnetic pulse EMP as it drops back down to the relaxed state
One must also use some PCF when moving from RF to DC so as not to backfeed for transformation to occur and to slow the wave down, similar to a moderator or backwards wave oscillator.
https://www.nature.com/articles/s41598-018-20771-w/figures/1
For the few here who understand this, let them elaborate if they wish...
https://en.wikipedia.org/wiki/Stochastic_resonance
stochastic resonance is interesting ...
they say that a normal (casual) :)varicap transforms the thermal noise voltage into a potential difference across the terminals. It is too small to measure with a microvoltmeter, even with an input resistance of 1MΩ.It accumulates on the parallel condenser for a minute, then connects to the device. I tried, I did not succeed. Why?
Kol, you want to harvest Johnson noise, in that case everything has to be tuned to the gnats ass and all parts need to be extremely high tolerance and RF layout rules on the boards has to followed and a really crappy resistor or some other better source needs to be used such as a spark gap and then one is building the TK device .
For thermal harvesting one would be better off growing some IR antenna 1/4 wave resonator and making a rectenna than one would harvesting thermo noise the way I envision from your question. Better off with a temp differential like a wellhole and the sun and simply use Peltier junctions
Stochastic resonance is actually what is happening with the spark gap switch, lots of energy in a little spark and a great seed to pertubate the local out of equilibrium...
The varactorp diode is simply a pump and the same can be accomplished on the B side with a variometer or it's analog which could be a piece of Terfenol D used properly
https://www.youtube.com/watch?v=HbJ_I3xbIMg (https://www.youtube.com/watch?v=HbJ_I3xbIMg)
https://www.youtube.com/watch?v=v-PZIedBQO0 (https://www.youtube.com/watch?v=v-PZIedBQO0)
https://www.youtube.com/watch?v=9Pj2K_myDu8 this one is difficult to swallow for some of you.
Wesley
https://www.google.com/search?q=bleskin+patent&client=firefox-b-m&prmd=ivns&ei=mAvfXMrpGOifjLsPvZaTkAI&start=10&sa=N (https://www.google.com/search?q=bleskin+patent&client=firefox-b-m&prmd=ivns&ei=mAvfXMrpGOifjLsPvZaTkAI&start=10&sa=N)
SOKRATES ALMANACH
page 44,45,46,47
Quote from: kolbacict on May 17, 2019, 07:17:03 AM
https://youtu.be/99UQQWda8Hc?t=313 (https://youtu.be/99UQQWda8Hc?t=313)
think about white noise
1. did you have white noise?
2. what in your opinion is the difference between thermal noise and white noise?
http://www.fis.unipr.it/~gigi/dida/strumentazione/harvard_noise.pdf (http://www.fis.unipr.it/~gigi/dida/strumentazione/harvard_noise.pdf)https://www.quora.com/What-exactly-are-shot-noise-thermal-noise-and-white-noise (https://www.quora.com/What-exactly-are-shot-noise-thermal-noise-and-white-noise)
Wesley
Stochastic Resonance. A stochastic resonance is a phenomenon in which a nonlinear
system is subjected to a periodic modulated signal so weak as to be normally undetectable,
but it becomes detectable due to resonance between the weak deterministic signal and stochastic noise.
The earliest definition of stochastic resonance was the maximum of the output signal strength as a function of noise (http://mathworld.wolfram.com/Noise.html) (Bulsara and Gammaitoni 1996).
http://mathworld.wolfram.com/StochasticResonance.html
Wesley
https://youtu.be/OqBRWt0UqXE?t=436 (https://youtu.be/OqBRWt0UqXE?t=436)
this one is not about resonance but is easy enough for understanding
this video is very good.
https://www.youtube.com/watch?v=DvN4Nv4Am6s
In this one guy got lost in subject
https://youtu.be/oY3rhszk5z8?t=916 (https://youtu.be/oY3rhszk5z8?t=916)
Wesley
for Russian speaking audience this is very easy explanation:
https://www.youtube.com/watch?v=KYC42xd744g
Wesley
@tysB3,
when I saw your coil-arrangement I rememered the subject unilateral-induction by [size=0pt]Eugene M. Efimov[/size][/color]
see here in original language:
http://www.sciteclibrary.ru/rus/catalog/pages/11518.html
English translation attached
Mike
[/font]
http://aflb.ensmp.fr/AFLB-342/aflb342m669.pdf (http://aflb.ensmp.fr/AFLB-342/aflb342m669.pdf)
this is great thank you ramset
Wesley
Yes great video where one can see the noise perturbation acting as lubricant.
Also excellent post concerning sonoluminence and resulting emissions. Think of moderation similarly to function of slow wave oscillator or BWO
https://www.daenotes.com/electronics/microwave-radar/backward-wave-oscillator-circulator
Quote from: mkjekyll on May 18, 2019, 01:59:28 PM
https://www.daenotes.com/electronics/microwave-radar/backward-wave-oscillator-circulator (https://www.daenotes.com/electronics/microwave-radar/backward-wave-oscillator-circulator)
Carcinotronhttps://en.wikipedia.org/wiki/Backward-wave_oscillator (https://en.wikipedia.org/wiki/Backward-wave_oscillator)
http://electriciantraining.tpub.com/14183/css/The-Backward-Wave-Oscillator-102.htm (http://electriciantraining.tpub.com/14183/css/The-Backward-Wave-Oscillator-102.htm)
Wesley
Carcinotron, yes pertinent post Wesley, what requirements need be met to make a slow wave structure?
Maybe some are interested in breaking the functions down in modules as the three following-- At least for me it has interest. As Don Smith said one should experiment in unit parts first to understand the function before trying to build the whole device.
Let's go back and look at lightening and the return strike, what parameters need be met to create the return?
TK got the caduceus part right, it has two functions what are they?
What requirements must exist to cause an EMP shot from a core?
Also go back to Wesleys vid Andrey Pastukhov where he shows the 2 pipes then here https://www.eh-antenna.com/EH_theory.html
And please remember this stuff is extremely dangerous and can kill you without prior notice so as Wesley says, don't touch it don't do it. Or to paraphrase; by the time you hear that sound, your soul is already in the lost and found...
One can go back and read Tesla Colorado Springs Notes and see the urgency in his writings when he brought down the thousands of strike lightening storm on top of his location. I can imagine even the man OK working day to day with 1-2 million volts had a wake up call on that one.
Circular polarization
https://youtu.be/Fu-aYnRkUgg
Quote from: stivep on May 19, 2019, 02:42:03 PM
Carcinotron
Wesley
hi stivep,
I have got rather acceptable
"trumpet waveform" from just one the Nelson device.That guy got real potential but choose to stay humble for reason unknown.
The last i've seen a trumpet waveform was from a youtube video posted in China whom understood Don smith device.It was discussed a long time ago in one of the topic in overunity.Shown as lighting many 220v bulbs.
I do hope both of you can get in touch.I am merely a unofficial reverse engineer but understand nothing.
@magpwr:
see here
https://www.youtube.com/watch?v=D7QiI8p1gi4 (https://www.youtube.com/watch?v=D7QiI8p1gi4)
this is dated back to 2011. Chris will like it.
Mike
Why are diodes (столбы) D1001-D1100 used in the Lithuanian experiment?
They do not work or almost do not work at 15kHz. Not to mention the above ...
Viziv build his tower working at 18kHz.
- the closest they could come to that lower harmonics of Schumann frequency.
their Seneca Experiment at 52MHz
In https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534102/#msg534102 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534102/#msg534102)
i pointed that trumpet known also as bell waveform was achieved in HHO device of Stanley Meyer.
If no-interrupting or overloading factor exist the bell waveform would be infinitely growing.
Wesley
@wesley,
more than a year has passed when I found this two pages 210 and 211 in the old realstrannik-forum. I was busy with other things but since you posted this scheme here:
I thought it fits. For those of you who do not understand russian I first post the english transation of page 210 followed by the original link.Discussion is only interesting on page 210 and 211.
https://translate.google.com/translate?hl=de&sl=ru&tl=en&u=https%3A%2F%2Fweb.archive.org%2Fweb%2F20180305145539%2Fhttp%3A%2F%2Frealstrannik.ru%2Fforum%2F39-kapanadze%2F135125-generatory-kapanadze-obshhaya-tema-3.html%2F%3Fstart%3D3762 (https://translate.google.com/translate?hl=de&sl=ru&tl=en&u=https%3A%2F%2Fweb.archive.org%2Fweb%2F20180305145539%2Fhttp%3A%2F%2Frealstrannik.ru%2Fforum%2F39-kapanadze%2F135125-generatory-kapanadze-obshhaya-tema-3.html%2F%3Fstart%3D3762)
Original:
https://web.archive.org/web/20180305145539/http://realstrannik.ru/forum/39-kapanadze/135125-generatory-kapanadze-obshhaya-tema-3.html/?start=3762 (https://web.archive.org/web/20180305145539/http://realstrannik.ru/forum/39-kapanadze/135125-generatory-kapanadze-obshhaya-tema-3.html/?start=3762)
wesley can you remember the topic in realstrannik-forum belonging to this picture "schematic of tariel device posted in realstrannik.jpg" so we can follow the discussion there. (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172896/)
Mike
All the same, I'm wrong. D1006 operates at 15 kHz.
But still better to use КЦ103-КЦ106,Кц109 etc.
Dynatron very much known Ukrainian FE activist published picture below
Wesley
http://www.r-charge.net/Don-Smith-Resonance-Energy-Crafting-Systematic-Index-Book_p_316.html (http://www.r-charge.net/Don-Smith-Resonance-Energy-Crafting-Systematic-Index-Book_p_316.html)
He may know, but he will not. :)
And maybe the whole thing in the switching windings from parallel to serial.
the energy of the magnetic field remains, but after switching, we have twice the voltage.
I'm right?
Can you get an archive of these magazines there? And why did it cease to exist many years ago?
You are right!
As you said I have social issue problem which you don't, so, dont be angry (anger is not social issue behaviour), I wish you well.!
And I am not your "Dear" , please, we are not that close.!
Cheers!
By a strange coincidence, the production of neutrons is by HV and Ion. What is the neutron bombardment used for? to change the atomic structure to radioactive. It is really strange that there are so many similarities. Maybe it's too far away from the way the kapa device works, but you have to look deeper.
If you think that kapa put there material like in a patent or similar, the rest of the device is for stimulating the material to work. Could he know about it? he could not have invented it but only built it based on some materials he got or took.
Moderator addition:
https://www.glossary.oilfield.slb.com/Terms/n/neutron_generator.aspx (https://www.glossary.oilfield.slb.com/Terms/n/neutron_generator.aspx)
QuoteA device for producing high-energy neutrons by using a charged particle accelerator. Neutron generators are used in various pulsed neutron devices and some neutron porosity measurements. In a typical device, deuterium (2D) and tritium (3T) ions are accelerated towards a target also containing the same isotopes. When 2D and 3T collide, they react to produce a neutron with an energy of about 14.1 MeV. The first neutron generators were built in the late 1950s and soon led to the first pulsed neutron capture (https://www.glossary.oilfield.slb.com/en/Terms/n/neutron_capture.aspx) log.
http://www.nsd-fusion.com/Technology/How%20to%20use%20Neutrons/
Part 1:bibliography
http://www.marychin.org/shows/msc/Chapter1.pdf (http://www.marychin.org/shows/msc/Chapter1.pdf)
https://kb.osu.edu/bitstream/handle/1811/3147/v41n03_131.pdf?sequence=1 (https://kb.osu.edu/bitstream/handle/1811/3147/v41n03_131.pdf?sequence=1)
http://aei.pitt.edu/91361/1/3895.pdf (http://aei.pitt.edu/91361/1/3895.pdf)
https://www.sciencedirect.com/science/article/pii/S0168900218312208 (https://www.sciencedirect.com/science/article/pii/S0168900218312208)
QuoteThe parameters that control the production of neutrons are the working pressure
of the fuel gas, applied voltage (https://www.sciencedirect.com/topics/physics-and-astronomy/electric-potential), measured current and cathode (https://www.sciencedirect.com/topics/physics-and-astronomy/cathodes) geometries.
QuoteThe neutrons emitted from the source are confirmed using neutron monitor, bubble dosimeters (https://www.sciencedirect.com/topics/physics-and-astronomy/dosimeters), nuclear track detectors, and
He-3 proportional counter (https://www.sciencedirect.com/topics/physics-and-astronomy/proportional-counters). Presently, the device produces neutrons up to the order of
106 n/sec at discharge voltage ranging from -60 kV to -80 kV, and discharge current of 20 mA to 30 mA.
non-accessible but accessible:https://nuclear-knowledge.com/neutron_initiators.php (https://nuclear-knowledge.com/neutron_initiators.php)
QuoteGun assembly devices (https://nuclear-knowledge.com/gun_gadget.php) stay in a
supercritical state during a relatively long time - a time which is sufficient for a background
neutron to initiate the fission chain reaction.
Internal Neutron Initiation:Polonium-Beryllium (Po-Be) initiatorsTritium/Deuterium InitiatorsExternal Neutron Initiators (ENIs)
Wesley
Additional material for part 1
less important.
https://physics.aps.org/synopsis-for/10.1103/PhysRevC.99.044907 (https://physics.aps.org/synopsis-for/10.1103/PhysRevC.99.044907)
https://en.wikipedia.org/wiki/Neutron_generator (https://en.wikipedia.org/wiki/Neutron_generator)
Wesley
You want us to build that?
Wesley, what are you doing?
You were excellent researcher before, What happened to you?
And don't take this as insult or something.
It is not my intention!
moderator addition:
Thermo Scientific MP 320 https://assets.thermofisher.com/TFS-Assets/CAD/product-images/F72973~p.eps-650.jpg
Lightweight, Portable Neutron Generator
https://www.thermofisher.com/document-connect/document-connect.html?url=https%3A%2F%2Fassets.thermofisher.com%2FTFS-Assets%2FCAD%2FSpecification-Sheets%2FD10497~.pdf&title=TVAgMzIw (https://www.thermofisher.com/document-connect/document-connect.html?url=https%3A%2F%2Fassets.thermofisher.com%2FTFS-Assets%2FCAD%2FSpecification-Sheets%2FD10497~.pdf&title=TVAgMzIw)
Part 2 bibliography for transmutation. Neutron transmutation.
https://nrl.mit.edu/facilities/ntds (https://nrl.mit.edu/facilities/ntds)
QuoteNTD (Neutron Transmutation) Doping process takes place when undoped (high purity) silicon is irradiated in a thermal neutron flux. The purpose of semiconductor doping is to create free electrons (low resistivity). The thermal neutron is captured by the 30Si atom, which has a 3% abundance in pure Si. Due to the high neutron/proton ratio of 31Si, it will release a beta and, by converting a neutron to a proton, the Si-31 atom transmutes to a P-31 atom.
Nuclear transmutationhttps://en.wikipedia.org/wiki/Nuclear_transmutation (https://en.wikipedia.org/wiki/Nuclear_transmutation)
QuoteNuclear transmutation is the conversion of one chemical element (https://en.wikipedia.org/wiki/Chemical_element) or an isotope (https://en.wikipedia.org/wiki/Isotope) into another chemical element.
QuoteArtificial transmutation may occur in machinery that has enough energy to cause changes in the nuclear structure of the elements. Such machines include particle accelerators (https://en.wikipedia.org/wiki/Particle_accelerator) and tokamak (https://en.wikipedia.org/wiki/Tokamak) reactors
however
QuoteRadioactive thorium (https://en.wikipedia.org/wiki/Thorium) was converting itself into radium (https://en.wikipedia.org/wiki/Radium) in 1901.
so these processes require little to none outside influence
Whenever you have transmutation you have energy conversion
( Lithuania Experiment)
Neutron activation:Quoteis the process in which
neutron radiation (https://en.wikipedia.org/wiki/Neutron_radiation) induces (https://en.wikipedia.org/wiki/Induced_radioactivity) radioactivity (https://en.wikipedia.org/wiki/Radioactivity) in materials, and occurs
when atomic nuclei (https://en.wikipedia.org/wiki/Atomic_nucleus) capture free neutrons (https://en.wikipedia.org/wiki/Free_neutron), becoming heavier and
entering excited states (https://en.wikipedia.org/wiki/Excited_state).
The excited nucleus often decays immediately by emitting gamma rays (https://en.wikipedia.org/wiki/Gamma_rays),
or particles such as beta particles (https://en.wikipedia.org/wiki/Beta_decay), alpha particles (https://en.wikipedia.org/wiki/Alpha_particle), fission products (https://en.wikipedia.org/wiki/Fission_products),
Think of energy level that is in MeV's. for single particle.
If it comes from isotope there is no need to do anything it is just spontaneous.
homemade fusor (nuclear fusion reactor) - neutron and x-ray radiation, silver activation
https://youtu.be/v9DXecl-OX8?t=55
Neutron Transmutation Database (NeuTran)
https://nrdb.nims.go.jp/index_en.html (https://nrdb.nims.go.jp/index_en.html)
Example of transmutation with Neutron:A neutron collides with a nitrogen atom, resulting in a transmutation.
https://brainly.com/question/11156764 (https://brainly.com/question/11156764)
Understanding Transmutation
https://www.youtube.com/watch?time_continue=18&v=JD5VEzsUE04 (https://www.youtube.com/watch?time_continue=18&v=JD5VEzsUE04) ( not everyone will understand it)
The good thing is that in practice these processes are easy to "observe".
You don't need to view it it is general information about power generation an d not in our direction
https://www.youtube.com/watch?time_continue=2555&v=14GwG__3mMQ (https://www.youtube.com/watch?time_continue=2555&v=14GwG__3mMQ)
Natural Transmutation funny and easy
https://www.youtube.com/watch?time_continue=344&v=I7WTQD2xYtQ (https://www.youtube.com/watch?time_continue=344&v=I7WTQD2xYtQ)
Transition and transmutation the difference. https://youtu.be/FFJwX_kHPx4?t=51 (https://youtu.be/FFJwX_kHPx4?t=51)
Wesley's N gun based on Colman experiment. ( bombardment)
https://youtu.be/0xXZT7YQDE8?t=514 (https://youtu.be/0xXZT7YQDE8?t=514) in English
https://youtu.be/K1f6EBx9GtY?t=488 (https://youtu.be/K1f6EBx9GtY?t=488) in Russian.
Harold COLMAN & Ronald GILLESPIE Power Generator
http://rexresearch.com/colman/colman.htm (http://rexresearch.com/colman/colman.htm)
Wesley
There is no safe way.
But it is relative term.
Think about tank in your car with gasoline in it.
You know that you can not smoke when pumping gasoline.
You know that vapor of gasoline if flammable.
But you drive your car.
So is with decaying particles / isotopes.
The substance of Colman is not active in decaying form but
-When bombarded with photons of 456MHz in impulse frequency 2-6/s
it does what it says on the video.
You know that inverse square law is the key to understand safety.
http://www.radprocalculator.com/InverseSquare.aspx (http://www.radprocalculator.com/InverseSquare.aspx)
This one is for electromagnetic wave including gamma.
Just few cm from the source the energy level of randomly emitted photons and particles is levels down.
At few cm more it becomes non detectable by most modern detectors for AM 241 or CS137 sources.
http://www.spectrumtechniques.com/products/sources/ (http://www.spectrumtechniques.com/products/sources/)
You know that
collimator is
Quotea device that narrows a beam of particles or waves.
To narrow can mean either to cause the directions of motion
to become more aligned in a specific direction
https://en.wikipedia.org/wiki/Collimator (https://en.wikipedia.org/wiki/Collimator)
This acts as your safety enclosure
You know behavior of alpha beta gamma neutron.
And that is enough to know to have the same level of confidence as you have with gasoline tank.
Alpha is heavy and slow.
Beta is faster but it is also particle
Gamma is fast
Neutron is fast ( particle)
When not slowed down Neutron simply miss the target and is mostly not interacting with it.
To slow it down you need Teflon or other similar plastic.
I
n this point of video the click you hear is me simply pushing the button of the microphone
As fast as I could ( manually)
That creates pulses at Tx of 100W output at 440MHz.
Due to high SWR the max power out was 20W PEP.https://youtu.be/0xXZT7YQDE8?t=902 (https://youtu.be/0xXZT7YQDE8?t=902)
the TX used was TS2000. no antenna but few winds of coil in Near Field
3cm from Colman tube.
The simplest way to have N generator is source of alpha particles and beryllium
https://www.physicsforums.com/threads/a-question-on-beryllium-as-a-neutron-moderator.390193/ (https://www.physicsforums.com/threads/a-question-on-beryllium-as-a-neutron-moderator.390193/)QuoteNeutrons are liberated when beryllium nuclei are struck by energetic alpha particles producing the nuclear
reaction 9 4 Be + 4 2 He → 12 6 C + n. where 4 2 He is an alpha particle and 12 6 C is a carbon-12 nucleus.
Beryllium also releases neutrons under bombardment by gamma rays.
https://en.wikipedia.org/wiki/Beryllium (https://en.wikipedia.org/wiki/Beryllium)
The source of alpha home smoke detector with Am241
Wesley
Legal note:
This information is for education purposes only.
I don't take responsibility for your action.
QuoteThink about tank in your car with gasoline in it.
Why doesn't gasoline in a tank explode in electric gasoline pumps with their sparkling brushes? Even when gasoline runs out, it sucks in air ?
Quote from: kolbacict on June 02, 2019, 03:32:14 AM
here is some answer
https://answers.yahoo.com/question/index?qid=20070605223936AAPpsHs (https://answers.yahoo.com/question/index?qid=20070605223936AAPpsHs)
https://answers.yahoo.com/question/index?qid=20071013225842AAUUjh8&guccounter=1&guce_referrer=aHR0cHM6Ly93d3cuYmluZy5jb20v&guce_referrer_sig=AQAAAD64ABzzzTmp1MtpVraFHjdY9pwmSRaana5uPEqM_DdQTKsWB7Hkp57_0IKlwzVUrto0BqjOhZ8xrFlhbebmC0V6DDdt3jWVKrTq_wtglsZw8DY1ypV8B4CZDig8f5-nvo-vG17V3sq3ucZijgPUjqst_RAvDGPqyKp3S8bpkROd (https://answers.yahoo.com/question/index?qid=20071013225842AAUUjh8&guccounter=1&guce_referrer=aHR0cHM6Ly93d3cuYmluZy5jb20v&guce_referrer_sig=AQAAAD64ABzzzTmp1MtpVraFHjdY9pwmSRaana5uPEqM_DdQTKsWB7Hkp57_0IKlwzVUrto0BqjOhZ8xrFlhbebmC0V6DDdt3jWVKrTq_wtglsZw8DY1ypV8B4CZDig8f5-nvo-vG17V3sq3ucZijgPUjqst_RAvDGPqyKp3S8bpkROd)
QuoteGasoline does not conduct electricity.
Only water with minerals in it will conduct. Distilled water won't even conduct.
I wondered the same thing when I first changed a tank pump. 1) DC not AC
2) properly grounded
3) gas requires a mixture of air and fuel with compression and spark to combust.
Wesley
QuoteNow if you ran out of gas, let the pump run dry and kept it running until just before it burned it self out, then pumped fresh air into the tank at exactly the right time you might get it to explode.
:) :D ;D
Well, I basically thought so.
Anyway, wish you luck!
Cheers!
Wesley
When did you see the device operating in the garage of Kapanadze. Did you hear any sound? e.g. noise? squeaking? or something you can describe.
Yes I did.
Sound of relay- click
Tariel helper was trying to fool my attention (yelling) , and sound of battery charger( booster) used
to start the device.
So he was sparking the two clips of the two wires to create the sound of the spark.
Than in one point (while using his voice at loud) he connected the two electrodes to the device.
There was characteristic sound of the relay from the device.
Wesley
The sound of the relay was continuous? or just on switching? what speed could he have had if he was still working?
Was another sound heard. I mean a squeal of 4-15kHz
I know that you have already thought about all this but try to match the best solution all the time.
I also know that you are currently a supporter of Viziv from Kapanadze and this is also a good explanation but I am looking for a connection with ferrites that also have other properties when they are made of different materials.
I deal with this because I had an interesting test and it brought me closer to the ferrites. I remember Kapa saying that he uses 5-6 ferrites in his first device. I do not know why most of them think that coils are there. We also know that similar effects can be with pure iron so an iron pipe could be there. It all hangs up but I want to say that it is now perhaps an investigation to which he returns after 2 years. You can say that I made a circle.
Quote from: lancaIV on June 02, 2019, 09:38:13 AM
HUMANITY mandates FAIRNESS, simple humans not :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fm.tagesspiegel.de%2Fgesellschaft%2Fevolutionsbiologe-jared-diamond-zum-ersten-mal-gibt-es-die-moeglichkeit-eines-weltweiten-kollapses%2F24351438.html%3Futm_referrer%3Dhttps%253A%252F%252Fgetpocket.com%252Frecommendations%26utm_source%3Dpocket-newtab
The Alabama estate administration : without HUMANITY, only classical humanoid = apartheid and racism
Are you saying you are trying to help your people in a closed community by this type of technology ?
Quote from: r2fpl on June 04, 2019, 06:36:33 AM
yeah iron might work in a relay but it's far too slow for optimum gain a person in the real world would want to except as optimum.
I agree that the need for a spark that gives a wide spectrum because it is not for frequencies only ...!
What you have heard is the effect of the relay which after the jump no longer worked?
Quote from: stivep on June 04, 2019, 08:52:08 PM
You need to understand that original spark gap was replaced by Tariel Kapanadze ""Helper with HV train pulse generator from gas heating furnace.
Wesley
Is that device is made by Kapanadze or that man on your video?
What I am trying to ask is: Did they all know how it works or only Kapanadze itself?
Thanks!
Wesley,
A short while back we were talking VNA's and you were kind enough to make some recommendations the final one being the PCI card unit.
I found this AIM unit interesting and would love your opinion concerning it's specs since you are much more knowledgeable in this gear. I showed it to you before and not sure if your response was humbug or what. I like the fact it is very modern, inexpensive and has been recommended by some RF guys I know. However I am not sure of our requirements besides S parameters and the frequency.
https://www.arraysolutions.com/antenna-analyzers%20/vna-uhf
I am coming back on some time and look forward to going down that one rabbit hole.
Thanks,
Mick
translation
Hello everyone.
Im being a bit skeptical now but thats the point I guess.
I looked up antennas and Refractions and surface waves etc.
Im not an expert but In order to get surface wave (zenneck for example)
Wave must travel thru more refractive material first and experience total refraction when reaches less refractive material at brewster angle.
Здравствуйте все. Сейчас я немного скептически отношусь, но в этом и есть смысл. Я посмотрел антенны и "Преломления",( refraction) а также поверхностные волны и т. Д. Я не эксперт, но для того, чтобы получить поверхностную волну (например, zenneck), волна должна сначала проходить через большее количество "преломляющего" (refractive) материала и испытывать полное {"преломление",(refraction) когда достигает меньшего "преломляющего" (refractive) материала под углом Брюстера.
So source must be underground .
tesla coil + ground seems to work just like communication antenna. Monopole antenna create mirror image by reflection from ground surface
and behaves like dipole antenna.
Так что источник должен быть под землей. Земля катушки Тесла, кажется, работает так же, как антенна связи. Монопольная антенна создает зеркальное отражение при отражении от поверхности земли и ведет себя как дипольная антенна.
When you succeed in launching a surface wave you get total Refraction and no reflection so no ground mirror effect .
No ground mirror effect means no underground image of the antenna aka probe so wesleys simulation of tesla coil launching air/ground interface Zenneck wave will not work because you get reflection only.
Im probably missing something and all my knowledge comes from wikipedia Lol.
Maybe thats why Tesla went bankrupt digging tunnels for grounding of his magnifying transmitter.
Когда вам удастся запустить поверхностную волну, вы получите полное преломление и никакого отражения, так что нет эффекта зеркала. Отсутствие эффекта наземного зеркала означает отсутствие подземного изображения антенны или зонда, поэтому имитация моделирования катушки Тесла, запускающего воздушный / наземный интерфейс, волны Зеннека не будет работать, поскольку вы получаете только отражение. Я, наверное, что-то упустил, и все мои знания получены из Википедии Lol. Возможно, именно поэтому Тесла обанкротился, копая туннели для заземления своего увеличительного передатчика.
Thank You and please explain me why am I wrong.
Спасибо и, пожалуйста, объясните мне, почему я не прав.
Simple short answer from moderator:
you didn't include in your analysis:
1. polarization
2. HV static forces
3. Standing wave
Простой короткий ответ от модератора,
вы не включили в свой анализ :
1. поляризация
2. статические силы ВН
3. стоячая волна
Note translation was added to original post by moderator to help Stalker to understand better.
перевод был добавлен в оригинальный пост модератором, чтобы помочь Сталкер лучше понять.
Questions directed to me from Russian audience:
What frequency Viziv tower works at.?
answer :
18kHz when in full power ( 22kHz when testing)
but The 18kHz is at the harmonic of Schumann resonance.!!!!!!!!!!!
Башня Viziv работает в частоте 18kHz. но хорошо .... э
должнa работать na 18kHz когда на полную мощность
Снова Вы должны ждать part #2 моей статьи, чтобы понять больше..
(22kHz test mode)
18 кГц - гармоника нo резонанса Шумана. !!!!!!!!!!!
Note: but this is not one single frequency - it is spectrum of available frequencies at 18kHz.
Wesley
Please let me clarify some nonsense in my post. It really takes a lot of time to compose it . And time is what I lack the most.
1. Polarization Is it only physical orientation of coil . just like vertical monopole or dipole . spheres one over another in vertical lane above ground ?
2. HV static - While watching clip from Andrey Pastukhov i can see person being carefull keeping hands away from antenna . so high voltage(like tesla coil) is necessary?
3. Standing Wave - https://en.wikipedia.org/wiki/Standing_wave wiki posted animation about two waves traveling one right other left. Is this why 90 degree and two coils? Then coil 3
inside the two, experience that kind of wave form creation? (still its a bit confusing )
1. Polarization - Electromagnetic waves (such as light), traveling in free space or another homogeneous isotropic non-attenuating medium, are properly described as transverse waves, meaning that a plane wave's electric field vector E and magnetic field H are in directions perpendicular to (or "transverse" to) the direction of wave propagation; E and H are also perpendicular to each other. By convention, the "polarization" direction of an electromagnetic wave is given by its electric field vector.
From a video https://www.youtube.com/watch?v=zE4GjB1cWLQ now i know that this is controlled by adjusting a distance between ground and top capacitor (top load) . ? what if i want to excite surface wave using other material instead of earth ( air and water)?? same principle?
2. HV static - While watching clip from Andrey Pastukhov i can see person being carefull keeping hands away from antenna . So high voltage(like tesla coil) is necessary?
Tesla coil may work properly up to a megahertz or little more, but what about 52 mhz ?
This high frequency gives me 4.73 feet length of wire and that is not enough to build tesla coil or slayer exciter. And this is my another
question will this work with kacher ( slayer circuit ) or classic tesla coil setup is necessary ? Im looking for easy way to pulse coil at resonant frequency.
3. Standing waves
https://www.youtube.com/watch?v=DovunOxlY1k
So simply for this condition i need resonance?
http://www.deepfriedneon.com/tesla_frame0.html
following instructions from your video https://www.youtube.com/watch?v=zE4GjB1cWLQ I need to keep this "tesla coil" resonating (L1-L2),
what about 1/4 wavelength for my secondary coil wire length ?
Nodes and standing waves were present in hairpin circuit . That required resonant match of nst transformer to capacitors used in series.
I wonder if i can simulate this using signal generator and observe it on my cheap Chinese oscilloscope . Any suggestions how?
Thats it for now.
Thank You.
Tiger from Kazakhstan
This is his work with Electret.
https://en.wikipedia.org/wiki/Electret (https://en.wikipedia.org/wiki/Electret)
The capacitor next to Spark Gap is 0.1microfarad
Wesley
Electret - I've done experiments with these waxes and the effect is positive.
The film has successful and failed attempts with electret as well as the effect of charging plexiglass to a negative value which is strange.
You can have similar effects with Teflon (PTFE) or plexi have much better electrostatic properties.
However, there are not many potentials but they are permanent.
https://www.youtube.com/watch?v=OeuAaR1TvxY
Creating Electret from spool of coax wire
Important!!!:
The HV od 30kV or less, can not make spark from shield to inner wire.
Wesley
Wesley,
You mentioned 6 types of devices you were able to observe can you quickly name the devices or theories?
I was working on, or having contact with number of applications:
1 mechanical from application of existing longitudinal wave using sound
2.mechanical from application of existing longitudinal wave using vibration
3.electrical based on energy extraction from lightning by turning part of its energy into decaying standing wave
causing secondary micro-lightning( avalanche and utilizing one in small size controlled environment)
4. Colman
5.electrostatic based on electron trajectory bend in vacuum in presence of steady magnetic field.( similar to tokomac-
a toroidal apparatus for producing controlled reactions in hot plasma and having noting to do with fusion)
6. extraction of electrical energy from Schumann Waveguide / Kapanadze concept7 magnetic Ted Annis
8.Magnetic/Mechanical Extraction and conversion of energy into electrical energy from magnet losing its magnetic force in time.
9.electrostatic Lithuania Experiment.
There are 3 applications in particle physics
Wesley
Thanks Wesley,
Very interesting list. One could in fact refer to much of nuclear physics as proton electricity, I think this is a better nomenclature for some of what we care about here.
Between the lines there is quite a bit available if one uses the modern technology differently, an MRI for instance. If one looks closely this is akin to the Coleman and several other devices if used in another mode. This probably makes some sense to you...
https://www.youtube.com/watch?v=CuJzVV1piPc (https://www.youtube.com/watch?v=CuJzVV1piPc)
Wesley
https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf (https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf)
Wesley
Equipment used by J Corum to transmit Zenneck wave
Оборудование, используемое Дж. Корумом для передачи волны Ценнека.
Wesley
Picture at the bottom right is showing original Seneca lake recreation of Borrows experiment from 1936.
In 2014 J Corum. used equipment Tx( green color) Rx (orange)
The Viziv tower is marked correspondingly Rx/Tx
So if you know what it is you can make the same
progress.
Фотография справа внизу показывает оригинальный -Сенека озеро воссоздание эксперимента Борроуз 1936 года.
В 2014 году Дж. Корум. использованное оборудование Tx (зеленый цвет) Rx (оранжевый) Башня Viziv
обозначена соответственно Rx / Tx.это что вы можете
Wesley
In 4:25 of that video it clearly show that they are using power lines for power.
If they developed method of delivering power on distance to your car, they will make millions based only on delivery method.
They don't need overunity for that.
The guy in Viziv video states that system is less than 100% efficient.
Which suggests that they are working only on power delivery part which will make them rich.
Can you tell where you found evidence that Viziv use method for extracting more then input?
If that is the case, then every receiver will receive more than Viziv towers emits and people will fast figure out that the secret is in receiver, reverse engineering it, and use it for themselves, without Viziv emitters.
So, logic dictates that OU part is in emitters,or before emitters, so nobody can reverse engineer it?
Quote from: WhatIsIt on June 21, 2019, 07:28:31 PM
Viziv is not
Nobody is.
There is no overunity never existed and will never exist.
Extra energy comes from energy conversion from the source of energy that our device coupled to .
That is why energy extraction from Schumann Wave guide is not overunity but Free Energy.
Wesley
Quote from: stivep on June 21, 2019, 07:51:19 PM
Viziv is not
Nobody is.
Wesley
In that case every receiver will receive more than Viziv towers emits (from Schumann Wave guide) and people will fast figure out that the secret is in receiver, reverse engineering it, and use it for themselves, without Viziv emitters.
So, Viziv will give to people receivers which can do that.
What stops the people to make their own (copy of Viziv receivers) receivers to extract from Schumann sea of energy?
Viziv will actually give receivers on a plate to everyone which makes them heroes.
The second thing is what feeds Schumann sea of energy?
It is our beloved planet generator. Planet core which provides for us field around planet and protect us.
What do you think will happen when whole world starts to pull energy from Schumann?
What will happen to that generator?
I think we will not live enough, (if the core slows), to tell!
No Viziv will most likely be using the technique Tesla came up with for encoding which is the same concept as Fourier transform, an analogue key if you will. The defined power apex will require phase accurate leading edge tuning. So one is either tuning to the Viziv signal or natural one. Some smart folks may figure out how to hack the VIziv receivers so they don't require Viziv but pulling power from both sources would be like trying to sync to two different master word clocks.
We are like ants pulling power from that interface. Some huge oversize Hoover damn size undertaking could pull too much and likely cause some problems with P waves.
Quote from: stivep on June 21, 2019, 07:21:03 PM
progress.
Wesley
Rx orange marked by you is a dipole used to generate Norton wave compered to zenneck surface wave in this experiment.
they were on a boat and i doubt they used it for receiving power. they measured field strength and i believe they used different type of equipment.
Thank you and waiting for more important information .
ps.
I need relative permittivity and conductivity of distiled water at 1.85 Mhz .
Im flexible on frequency Thank You.
Hi guys, I don't know if in the past you have been talking about this patent, but it is really interesting. It talks about harvesting energy from Schumman earth resonances as a metod of energy conversion proposed by Wesley. It use a Tesla Coil and and a ground system antenna. Also the patent has cited other importants patents.
"Power receiver for extracting power from electric field energy in the earth"
This is the company: www.earthenergies.net (http://www.earthenergies.net)
"The Company's patented technology integrates state-of-the-art electronics with newly discovered geodynamo-based low-frequency subsurface electromagnetic wave energy, into scalable electric power delivery for residential and microgrid applications"
Quote from: saturnio on June 22, 2019, 10:34:04 PM
I have analyzed patent from Earth Energy and
I think that it will be the best if I make video about it.
There is some interesting material there.
http://www.freepatentsonline.com/20150102675.pdf (http://www.freepatentsonline.com/20150102675.pdf)At link shows that is not secure.
so go here:https://patents.justia.com/assignee/earth-energies-inc
but that doesn't give you any good
the best is direct here:
https://patents.google.com/patent/US9564268B2/en (https://patents.google.com/patent/US9564268B2/en)Wesley
Wesley dear friend, I see some have found this article, I wonder if any one person has found a way of actually generating that schumann frequency of 7.85 hz with division of available crystal devices or modules with out
ending up with a pile of trailing digits below the decimal point. Thoughts any one ?
regards AG
Quote from: stivep on June 29, 2019, 09:55:41 PM
Wesley
Wesley, one thing that I find quite interesting is the grounding. As we know, in some Kapanadze videos there is an special grounding as attached picture shows.
From patent:"In the resonant mode, the
impedance of the power receiver 10 is reduced to near zero thus inducing ground currents to flow into the power receiver 10 where the ground currents are converted to useful form".... (where "power receiver" is the "ground system", that as I know it is not a simple thing)
"applying a high voltage electrical impulse to the resonant circuit to induce current flow from the ground terminal through the resonant circuit,"
Great point saturnio and that's why i have mentioned expensive grounding that killed Teslas tower.
From Kapanadze we learn that it might be smaller and cheaper but this might limit output of device.
Vizin provide patents for surface probes.
1 Tesla tower with ground connection and thats what they build in Texas .
2 Probe with 2 terminals aka spheres . This seems to not need any ground connection at least at transmitter end , im not sure about receiver.
Dear Forum
This might be unrelated to topic ( At this point).
Its been discussed in a past but im still having problems with explanation .
Do to lack of input im unable to get some satisfying results.
https://youtu.be/KLAPRNWuAn4 is a video where Wesley is doing so called dielectric excitation .
All the posts about Vizin got me little confused and i think i have mistaken this technology with what Wesley did in his video.
What i have now is flyback with two primaries and schematic of phase shifter circuit .
Once more this is not vizin or kapanadze. Not yet . I need to see this first before i can move forward.
Vizin is using phase shift (time delay) to compensate for wave tilt so they can get physical wave at precise angle (brewster angle LoL).
Pastuhkov claims wave form creation when two electromagnetic fields collide at 90 degree time delay .
Is it voltage and current delayed or just one?
His small black box cant be tesla coil and patent does not specify that it must be air core transformer. Thats why ill try with flyback.
Have any of you build it and got positive results ?
Am i going in the right direction?
My flyback has a diode so im planning on using other end to make connection with my sphere antenna and see what happens.
People claim Vizin build based on Nikola Tesla work. I have never came across anything about surface wave, em wave polarization , time delay of a wave
while reading about Tesla or his work. They all claim he used EM wave ( Radio wave ) for transfer of energy, but all his patents state otherwise .
Then you can read in his colorado springs notes that he used non radiating wave .
Scottish physicist Sir David Brewster (1781–1868)
Brewster, David (1815). "On the laws which regulate the polarisation of light by reflexion from transparent bodies". Philosophical Transactions of the Royal Society of London.
This guy did his research years before Tesla so Tesla must know this and came up with idea of using this polarization not only for light waves but for EM too.
So why all publications talk about ground currents (NORTON) and non of them mention Zenneck surface wave.
Sommerfeld, Arnold, "Uber die Ausbreitung der Wellen in der Drahtlosen Telegraphie" (Tr. The Propagation of Waves in Wireless Telegraphy) 1909
Zenneck, Jonathan, "Über die Fortpflanzung ebener elektromagnetischer Wellen längs einer ebenen Leiterfläche und ihre Beziehung zur drahtlosen Telegraphie" (Tr. "About the propagation of electromagnetic plane waves along a conductor plane and their relationship to wireless telegraphy") 1907
At Colorado Springs, in May 1899, Tesla, several of his assistants, and a local contractor commenced the construction of Tesla's laboratory shortly after arriving in Colorado Springs, Colorado
That means Tesla did it a decade before first theoretical paper has been published. Where we can find information related to this research. Is it suppressed, lost , or it never happen.
How Vizin guys came up with this? they must be very smart.
Still there is one more question:
Now we know he used Zenneck surface wave and Interface was and still is located between earth and air underneath our feet .
His first patent talked about and experimentally proved possibility of wireless energy transfer via upper strata of earths atmosphere.
What if Wesley is looking at wrong interface. Air earth interface works fine for Vizin, but all static charges are up in the air.
Its only different approach to a problem of extracting free energy that has its source at our SUN.
Maybe this is why Vizin is transferring electrical energy and not tapping in to unlimited source of energy.
Going back to my questions about dielectric and Wesleys experiment .
I would really appreciate Your input, Is flyback any good or its just another dead end im running in to.
Any suggestions how test my flyback using signal generator and driving 2 transistors 90degree phase delay ? Im thinking about flyback driver circuit because its running at resonant frequency,
and phase shifter circuit to feed 90degree input for second transistor. Coax is good time delay but at high frequency and will not work for my
flyback.
https://www.youtube.com/watch?v=FHXZ9C914S0 Phase shift circuit im considering at the moment.
Thank You
-video editing
-what computer is right for the job
-what is configuration of video editing computer
- Davinci Resolve 16 video/ film editing software and colorist software
-difference between video camera and film camera-difference between graded and non graded files by comparison of V-log RAW vs V-log RAW graded
Davinci Resolve is for free Hollywood editing software for both video and film.Studio version cost $300
https://youtu.be/xAXXaNJzwjE (https://youtu.be/xAXXaNJzwjE)
Wesley
Links to remember for future study:
5.3.3 - The resistance/impedance relationship
https://www.tlc-direct.co.uk/Book/5.3.3.htm (https://www.tlc-direct.co.uk/Book/5.3.3.htm)
Unveiling the topological nature of electromagnetic surface waves
https://physicsworld.com/a/unveiling-the-topological-nature-of-electromagnetic-surface-waves/ (https://physicsworld.com/a/unveiling-the-topological-nature-of-electromagnetic-surface-waves/)
A New Approximate Method for Lightning-Radiated ELF/VLF Ground Wave Propagation over Intermediate Ranges
https://www.hindawi.com/journals/ijap/2018/9353294/ (https://www.hindawi.com/journals/ijap/2018/9353294/)
15-000-Volts-30mA-Neon-Transformer
https://www.partsforsigns.com/allanson-101530bpx120r-uni-serve-neon-transformer-15000v-30ma/?msclkid=54a2e56dcca51792d911b8779b3f8b34 (https://www.partsforsigns.com/allanson-101530bpx120r-uni-serve-neon-transformer-15000v-30ma/?msclkid=54a2e56dcca51792d911b8779b3f8b34)
https://www.ebay.com/itm/Allanson-1530BPX120-15-000-Volts-30mA-Neon-Transformer-at-120Volts/264242723514?epid=15122339 (https://www.ebay.com/itm/Allanson-1530BPX120-15-000-Volts-30mA-Neon-Transformer-at-120Volts/264242723514?epid=1512233907&hash=item3d8617faba:g:ar4AAOSwIA1cjeMO)
Method and Apparatus for Extracting and Conveying Electrical Energy From the Earth's Ionosphere Cavity
https://patents.google.com/patent/US20150102676A1/en (https://patents.google.com/patent/US20150102676A1/en)
Wave Impedance and Phase
https://em.geosci.xyz/content/maxwell1_fundamentals/harmonic_planewaves_homogeneous/impedancephase.html (https://em.geosci.xyz/content/maxwell1_fundamentals/harmonic_planewaves_homogeneous/impedancephase.html)
http://www.hyiq.org/ (http://www.hyiq.org/). Take it with grain of salt
http://www.hyiq.org/Updates/Update?Name=Update%2014-04-06 (https://chavascience.com/index.php/en/https://chavascience.com/en/hydrogen)
Solid state electric generator
https://patents.google.com/patent/US7830065B2/en (https://patents.google.com/patent/US7830065B2/en)
Polarization density
https://en.wikipedia.org/wiki/Polarization_density (https://en.wikipedia.org/wiki/Polarization_density)
White Paper: What Actually Creates The 90 Degree Coupler Phase Shift?
https://www.rfglobalnet.com/doc/what-actually-creates-the-90-degree-coupler-p-0001 (https://www.rfglobalnet.com/doc/what-actually-creates-the-90-degree-coupler-p-0001)
Method for transmitting electromagnetic energy and device for implementing same
https://patents.google.com/patent/WO2013191576A1/en (https://patents.google.com/patent/WO2013191576A1/en)
https://patents.google.com/patent/US7830065B2/e (https://patents.google.com/patent/US7830065B2/e)
Andrey Pastukhov and Wesley you must see it
https://m.youtube.com/watch?v=KLAPRNWuAn4 (https://m.youtube.com/watch?v=KLAPRNWuAn4https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/2775/post/last_msg/535943/)
Turnstile antenna
https://en.wikipedia.org/wiki/Turnstile_antenna (https://en.wikipedia.org/wiki/Turnstile_antenna)
ferromagnetic materials ( top of page)
https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq (https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWRm1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic%20material&f=false)
=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp- (https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWRm1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic%20material&f=false)
Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWR (https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWRm1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic%20material&f=false)
m1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic (https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWRm1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic%20material&f=false)
%20material&f=false (https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWRm1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic%20material&f=false)
All of the links have logical consequences
Wesley
Links to remember:
Top loaded slow wave helical resonator
Explanation of what is base, center, top load/Ed coil
https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Loading_ (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Loading_coil&ved=2ahUKEwjxocjTtZbjAhVSh-AKHX7tDEIQFjATegQIAxAB&usg=AOvVaw0jtjY3Njp4wM6jrgxO6MBf&cshid=1562077849381)
coil&ved= (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Loading_coil&ved=2ahUKEwjxocjTtZbjAhVSh-AKHX7tDEIQFjATegQIAxAB&usg=AOvVaw0jtjY3Njp4wM6jrgxO6MBf&cshid=1562077849381)2ahUKEwjxocjTtZbjAhVSh-AKHX7tDEIQFjATegQIAxAB&usg=AOvVaw0jtjY3Njp4wM6jrgxO6MBf& (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Loading_coil&ved=2ahUKEwjxocjTtZbjAhVSh-AKHX7tDEIQFjATegQIAxAB&usg=AOvVaw0jtjY3Njp4wM6jrgxO6MBf&cshid=1562077849381)
cshid=1562077849381 (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.wikipedia.org/wiki/Loading_coil&ved=2ahUKEwjxocjTtZbjAhVSh-AKHX7tDEIQFjATegQIAxAB&usg=AOvVaw0jtjY3Njp4wM6jrgxO6MBf&cshid=1562077849381)
Polyphase system
https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/ (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Polyphase_system&ved=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MVMCZW7)Polyphase_ (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Polyphase_system&ved=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MVMCZW7)
system&ved (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Polyphase_system&ved=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MVMCZW7)=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MV (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Polyphase_system&ved=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MVMCZW7)
MCZW7 (https://www.google.com/url?sa=t&source=web&rct=j&url=https://en.m.wikipedia.org/wiki/Polyphase_system&ved=0ahUKEwjDh4LMu5bjAhWMTN8KHeetDrYQmhMIXjAE&usg=AOvVaw0DNxyFpkR-GNFa7MVMCZW7)
Wesley
Links to remember:
https://www.researchgate.net/publication/266887036_Input_Characteristics_of_Coated_Thin_Wire_Helix_Antenna (https://www.researchgate.net/publication/266887036_Input_Characteristics_of_Coated_Thin_Wire_Helix_Antenna)
or more accurate:
(a) Geometry of a monofilar helical antenna mounted on a large ground plane; (b) The image theory defined equivalent problem.
https://www.researchgate.net/figure/a-Geometry-of-a-monofilar-helical-antenna-mounted-on-a-large-ground-plane-b-The_fig1_266887036 (https://www.researchgate.net/figure/a-Geometry-of-a-monofilar-helical-antenna-mounted-on-a-large-ground-plane-b-The_fig1_266887036)
more of the same guy from link above:
Sulaiman Adeniyi Adekola
https://www.researchgate.net/profile/Sulaiman_Adekola (https://www.researchgate.net/profile/Sulaiman_Adekola)
We are interested with image of coil and the plane .
now compare it with image Fig.14 of J Corum
http://rexresearch.com/corumzenneck/US2017077715A1.pdf (http://rexresearch.com/corumzenneck/US2017077715A1.pdf)
Wesley
Links to remember:
polyphase system for generating, transmitting, and distributing electric current as well.
https://teslauniverse.com/nikola-tesla/articles/nikola-tesla-3 (https://teslauniverse.com/nikola-tesla/articles/nikola-tesla-3)
Polyphase system is used by J Corum ( patent)to restrict theft of Viziv energy transmitted by use of earth/ air interface .
Poly is not Multi.
So it is particular phase relation that is mentioned in Corum patent.
references:
https://www.teslasociety.com/pdf/who_was_the_real_dr_nikola_tesla.pdf (https://www.teslasociety.com/pdf/who_was_the_real_dr_nikola_tesla.pdf) early corum paper.
Corum, Miller &
Corum: Surface Waves TEXZON TECHNOLOGIES CONFERENCE PAPER [DRAFT DATE: March 23, 2016]
... 1988), the 60 Hz Ring Power Multiplier (1998, 2003, 2009, 2013), and the
Polyphase Surface Wave Probe (2013, 2014, 2015),
and holds several dozen patents. He has authored over 125 technical papers and reports, and his principal ...
QuoteCorum, Miller & Corum: Surface Waves TEXZON TECHNOLOGIES CONFERENCE PAPER [DRAFT DATE:
March 23, 2016] ... 1988), the 60 Hz Ring Power Multiplier (1998, 2003, 2009, 2013), and the
Polyphase Surface Wave Probe (2013, 2014, 2015), and holds several dozen patents.
Wesley
Links to remember:
Re: slow-wave helical resonator
https://www.pupman.com/listarchives/2002/August/msg00303.html (https://www.pupman.com/listarchives/2002/August/msg00303.html)
Wesley
Wesley hi, if any one is interested I have a schumann resonance design using 5 chips no shimmering micro only Cmos gives 7.825hz output if any one is interested I will draw out circuit and component list'
regards AG
https://overunity.com/18269/revolutionary-air-conditioner/msg536149/#new (https://overunity.com/18269/revolutionary-air-conditioner/msg536149/#new)
near/far field effect ?does the electric earth surface network, distribution by wire, change the earth/orbital magneto-/iono-sphere density ?
how will be the effect by propagated limitless wireless transmission ?
The Dmitriev publishing is from 1998;
Specific attention : point 3.2. ....
1998-2019 : who is observing this electro-magnetic planetar/solar system/interstellar progress
Analysis of the equipment used in J Corum
Wesley
The 4.9 meter 1.82 MHz surface wave probe and field strength measurements (out to 20 miles)
compared with predicted fields for Zenneck[/font], a λ/4 tower (with 120 radials),
and the actual [/font]Norton vertical stub with only an 8 ft. ground rod at the base of the pole.
2/12/2016:
C = 45 pF, VRMS= 42.4 volts, εr= 15, σ = 0.012, Rg= 35 Ω. For radiation: h/λ = 0.030, Rr]= 1.38 Ω, ηr = 3.8%.
for exact wording look at picture 3 below
with the same text.
Wesley
characterization of equipment used in J.Corum experiment
http://thehistoryofrecording.com/Test_Equipment/Manuals/HP/HP3200B.pdf (http://thehistoryofrecording.com/Test_Equipment/Manuals/HP/HP3200B.pdf)
Wesley
some other choices for amplifier
for 1.8MHz and others for 52MHz
Recommended is much simpler setup that requires only
one box.
It is
TS-2000 or any other equivalent
at 52MHz that is Ham radio band.
https://www.youtube.com/watch?v=pxvd7Hts-hw&list=PL0-gH_7Nm60Zkogw5sdlSTcOseWaefHI6
this video shows operation at 52MHz -( 6 meter band)
https://www.youtube.com/watch?v=X3Q9AVM7lsU
this video shows operation at 1.8MHz -( 160 meter band)
https://www.youtube.com/watch?v=ZgGylgeU4SY
this video shows the remote head TM-D700a of
The Kenwood TS-B2000 is a 'silver box' version of the TS-2000 (https://www.universal-radio.com/catalog/hamhf/1978.html).
Picture of this Transceiver is below
https://www.youtube.com/watch?v=zSKQYPRrI-Y
Wesley
The advantages and disadvantages of using Ham Transceiver instead of J.Corum setup.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg536279/#msg536279 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg536279/#msg536279)
Advantages:
1. one box operation
2. only battery is required to power the device or AC.
3. fast automatic tuning
4. visual observation of SWR
5. if Ts-B2000 is used than it is even more convenient:
a. remote head TM-D700a is connected with 6ft -12ft cable.
b. radio can be in convenient position and head can be next to your eye view.
c. when Tesla coil is used than TS-B2000 can be at some distance say 54ft and head can be another 12ft from the radio
Disadvantages :
1. when SWR/ VSWR is to big ( mismatch 1-3 and more ) you shouldn't
use continuous carrier as you may damage the power transistor
note : front-end transistor term is reserved to Rx not to Tx (and that confuses some of you)
2. High Standing wave is not friendly environment for Transceivers.
recommendation:
use of Transmatch
http://www.arrl.org/transmatch-antenna-tunercan (http://www.arrl.org/transmatch-antenna-tunercan) help lot.
note : TS 2000 and TS-b2000 both have automatic antenna tuner however additional transmatch/ antenna tunner is recommended.
1. switch Tx to CW.
2. connect Key
or
3. automatic keyer
4. don't allow continuous long dashes better use dots.
reasoning:
1.Tx has approximately the same amount of time to rest between dots or short dashes (as is used to transmit.)
2. The power transistor cool-down is very effective between signals.
original link that post is related to :
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg536259/#msg536259
Wesley
Advantages
of use J Corum configuration:
commercial amplifiers are very tough.
-strong enough to withstand adverse conditions or rough or careless handling.
- most of them have overload circuitry.
- lowering voltage from signal generator you can regulate output power from PA.
-you can deliver to PA sinusoidal signal or any other waveform of your choice.
Disadvantages
-when you blow your amplifier - you can say goodby to it.
and you will be hunting for another one for quite a good time.
Note:
-this equipment is 3 times more expensive than Kenwood TS-2000
but ham equipment is often very cheap and easy to find.
at best on hamfest.
- you can use any of other transceivers e.g Yesu.
there is large amount of 100W output Mobile transceivers with remote head,.
Note:
Use of unmodulated CW (A1 European standard known as A1) is your sinusoidal signal.
Use of modulated CW (A2 European standard known as A2) with usually 800 Hz- 1kHz signal is your "square signal."equivalent if keyed.
The difference is that that in
A2 - you are dealing here with modulated carrier at length of dots or dashes mechanically activated but electronically spaced.
However for effect of J. Corum there is no difference.
Preferred is A1
Wesley
Configuration for test:
1 take J.Corum equipment and connect it as shown here:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg536161/#msg536161 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg536161/#msg536161)
or
1a.take Kenwood TS-b2000 or any other e.g Yesu and you don't need anything else
1b. make sure that frequency of Tx or Trasceiver is 52MHz.
2. connect surface wave probe to output of your Tx or amplifier.
2a. if using TS-b2000 you have additional transmatch it is your big benefit.
2b.connect your transmatch (antenna tuner) between surface wave probe and your TS-b2000
Note:
Your surface wave probe is your Tesla coil.The load of your Tx or Amplifier or your transmatch is your primary winding of Tesla coil The secondary of your Tesla coil must be grounded
The parameters of Tesla coil for 2200m are given here.
https://youtu.be/zE4GjB1cWLQ?t=367 (https://youtu.be/zE4GjB1cWLQ?t=367)
use 1.8MHz and remember that it is 1600m and not 2200m
as indicated on the picture .
is easy to re-tune
The lower the frequency the more winds is required.
the higher the frequency the less winds is required
At minimum of 54ft you need to have another Tesla coil acting as a receiver.
the distance can be greater but not smaller than that
]top capacitor must!!! have means of being adjusted in elevation measured from the ground!!
Structure of the mast , must be made from dielectric e.g PCV sliding telescoping UP/DOWN
Another means of height change of Top Capacitor is to hung it on a balloon or between to masts. used to elevate the Top Capacitor.
The rope used to lift the Top Capacitor UP can not be made from wire or "dielectric". it must be natural string or thin rope.
Wesley
Top capacitor must be quite large at best.
to prevent sparks.
It can look like Doughnut .
The minimum distance of Top Capacitor from the ground is 4x its diameter.
Wesley
Adjustment of distance from ground of Top Capacitor is the most important
factor of launching Zenneck Surface wave .
AFTER SUCCESSFUL test using power transfer in the interface in form of Zenneck Surface wave
the experimenter is ready to step 2
-extracting energy (FE) from Schumann waveguide.
Wesley
I don't take any responsibility for your action.
Wesley
Top Capacitor of Tx
1. It is the structure that is adjusted in elevation / extended in height
(the measurement from base to top).
2. It has shape of preferred head of the mushroom..
It can be however done from aluminum "air tube"
Flexible Aluminium Air Ducting Ventilation Accessory (https://www.ebay.co.uk/itm/Flexible-Aluminium-Air-Ducting-Ventilation-Accessory-Alloy-Vent-Tube-Hose-Duct-/141484081812)
also called : Hose Application: Duct / Exhaust
picture 1
3.It's capacitance can be increased by internal mechanism of
tube inside of another tube with air or Teflon dielectric.
However other means are allowed by sliding piece of inner tubing/s
the effect of such is capacitance match to desired F of resonance. (picture 1b)
4. Viziv used on the top of the doughnut additional half semi spherical structure .
To increase capacitance nad manipulate with capacitive reactance of Top Capacitor
Wesley
Position of Top Capacitor:
Since Viziv tower is fixed there is no way to change potion of Top capacitor in Vertical elevation.
We may assume that there is whole mechanism inside of the space of
Top Capacitor to change capacitance of the Top Capacitor.
The Umbrella /(Ambrela) inside of space above the torus.
Wesley
Next subject to discuss is :
cylindrical waves
1.- point source
2. line source
3. wave front
4. cylindrical wave behavior in Near Field
This is crucial information to understand How Surface wave is created in the interface Earth/Air
I will finish this article later.
Cylindrical Wave :
Electric field is perpendicular to the direction of propagation and is gradually decreasing with the distance from Tesla tower.
Line source must be cylindrical - so is Tesla coil
Magnetic field is at 90 degrees to electric field and fits into the Earth/ air area called - interface.
This is our TM mode.
Note:
picture 3 is showing Cylindrical Wave
in medium - Air.
There are two views the top one is at slight tilt.
The lower on e is at YZ coordinates.
Wesley
Quote from: groot on June 30, 2019, 04:18:20 PM
https://youtu.be/KLAPRNWuAn4 (https://youtu.be/KLAPRNWuAn4) dielectric excitation .
Wesley : the bottom line is that Pastukhov method
- misinterprets the phenomena
Viziv is using phase shift (time delay) to compensate for wave tilt so they can get physical wave at precise angle (brewster angle LoL).
polarization of the single TEM wave to see it in TM mode and in interface.
Top Capacitor of that ( single) HV winding of Tesla coil produces Standing Wave
- Vertical elevation of that Top Capacitor is making the trick
to receive that surface wave is need another Tesla coil 54 foot in the distance or more from
the first one.
that Tesla Coil can( but doesn't have to) look like Tx ( the transmitting Tesla Coil) And (for the moment) nothing more.
Jonathan Zenneck made it known in 1901.
Sommerfeld added to it.
https://en.wikipedia.org/wiki/Jonathan_Zenneck (https://en.wikipedia.org/wiki/Jonathan_Zenneck)
http://www.tfcbooks.com/teslafaq/q&a_039.htm (http://www.tfcbooks.com/teslafaq/q&a_039.htm)
Tesla would find it . but he was cut short with money .
-Marconi in Bolinas Ca in 1921/4 was restricted by ( government decision with use of RCA )
Can you give me link to the exact quote and page saying it?
Wesley
.. we know he used Zenneck surface wave and Interface was and still is located between earth and air underneath our feet .
What if Wesley is looking at wrong interface. Air earth interface works fine for Viziv, but all static charges are up in the air.
No I'm not looking at wrong interface .
but instead I'm looking only at one side of Schumann Waveguide that is The Earth surface
with air on the top of it.
It just happened that such structure is an interface for TEM that when properly polarized works in TM mode and can
in result be seen in that interface an be named as surface wave that was recognized as
Zenneck wave.
So if you take any waveguide it has
-shape (length/ width)
The special form of guiding is provided in the interface.
But in general:
waveguides have walls .Schumann waveguide walls are ionosphere and earth.
And earth is at the same time a part of interface Air/ Earth
- so i
nterfaces in our case are two
different mediums placed together FACE TO FACE
having different
dielectric properties such as air and earth
where:
-Air is non-conductive medium
-Earth is conductive but lossy medium
To have working interface it is mandatory to have one of the mediums to be conductive.
That expressions applies mostly only to our case of J Corum/ Zenneck/ Summerfield /Viziv/ Texzon/..
flyback.
https://www.youtube.com/watch?v=FHXZ9C914S0 (https://www.youtube.com/watch?v=FHXZ9C914S0) Phase shift circuit im considering at the moment.
Thank You
Any transformer can be driven at its own resonant frequency.
that includes
-transformers with ferrite core
-air transformers as Tesla coil.
-any two or more coils at any shape and number of winds coupled in
Near Field.-any "neon"HV transformers
Wesley
SURFACE WAVES
AND THE'CRUCIAL PROPAGATION EXPERIMENT
by K.L. Corum, Brigadier General (Ret.) M.W. Miller, Ph.D,and J.F. Corum, Ph.D.Texzon Technologies, LLC
In 1908
Jonathan Zenneck formulated his mathematical explanation supporting existence of surface waves known as Zenneck Wave.
Tesla must know about it but since he was cut with finances by JP Morgan in 1897 ,he concentrated on building his
Wardenclyffe Tower (1901–1917)
In his time K. Norton discovered
radiative ground wave known as the
Norton surface wave.
QuoteGround wave refers to the propagation of radio waves (https://en.wikipedia.org/wiki/Radio_propagation) parallel to and adjacent
to the surface of the Earth, following the curvature of the Earth.
This radiative ground wave is known as the Norton surface wave
https://en.wikipedia.org/wiki/Surface_wave (https://en.wikipedia.org/wiki/Surface_wave)
https://www.pitt.edu/~jdnorton/teaching/HPS_0410/chapters/quantum_theory_waves/index.html (https://www.pitt.edu/~jdnorton/teaching/HPS_0410/chapters/quantum_theory_waves/index.html)
As oppose to :
Radiative Norton wave the Zenneck wave is:
non-radiative
1979 Hill and Wait analytically found an aperture distribution that excites a pure Zenneck surface wave with no radiation field.
Note:
no radiation field means, it does not radiate in air above the earth in
Far Field
It is the effect of
cylindrical wave in
Near Field around cylindrical antenna ( Tesla Tower)and its
electrical field is
Quoteevanescent (exponentially decreasing) in the +z-direction.
From that time but based on today's knowledge we call it :
Quoteno Hertzian radiation or Norton ground-wave radiation whatsoever
I need to mention here that Marconi was trying to send electrical energy using earth in Bolinas California in 1913.
https://youtu.be/r3XVRd-G56k?t=655 (https://youtu.be/r3XVRd-G56k?t=655)
Please take this video as asserting but not explaining.
However in:
https://youtu.be/r3XVRd-G56k?t=1002 (https://youtu.be/r3XVRd-G56k?t=1002)
Marconi schematic
Marconi was screwed by newly formed RCA "
in 1921 -. business in Bolinas was closed due to RCA action.
Marconi started to sue US government of illegal use of his patent during 1WW.
After death of Tesla, US Government revoked patent rights of Marconi and gave it to Tesla who was dead in this time.
US was freed from paying any money to Marconi. Wesley
speedy125
Surface Electromagnetic Waves
http://www.rroij.com/open-access/surface-electromagnetic-waves.php?aid=87345 (http://www.rroij.com/open-access/surface-electromagnetic-waves.php?aid=87345)
https://gradestack.com/Electromagnetic-Field/Transmission-Lines/Transmission-Line-Modes/19383-3931-38714-study-wtw (https://gradestack.com/Electromagnetic-Field/Transmission-Lines/Transmission-Line-Modes/19383-3931-38714-study-wtw)
______________________________________________________________________________________________________
Wesley
links that likely will be used in this set of posts.
1. Transmission Line Modes
2. Model FIM-71 portable, laboratory quality Field Strength Meter
https://testequipment.center/Product_Documents/Potomac-Instruments-FIM-71-Specifications-32D80.pdf (https://testequipment.center/Product_Documents/Potomac-Instruments-FIM-71-Specifications-32D80.pdf)
3. Basic Tesla's Experiments (Part 7) - Standing Wave, Node, Reflection
https://www.youtube.com/watch?v=nkMndCsNRQU&t=1s (https://www.youtube.com/watch?v=nkMndCsNRQU&t=1s)
4. Milford TX Tesla Tower Close Up
https://www.youtube.com/watch?v=WJtPNR4T6FI (https://www.youtube.com/watch?v=WJtPNR4T6FI)
5. 1 - Class 12 - Physics - Wave Optics - Wave front and Huygens's principle
https://www.youtube.com/watch?v=sk_2OOWjjes (https://www.youtube.com/watch?v=sk_2OOWjjes)
6. 2_2 Electric Field Superpostion
https://www.youtube.com/watch?v=FMOGXwR4HAs (https://www.youtube.com/watch?v=FMOGXwR4HAs)
7. Normal (geometry)
https://en.wikipedia.org/wiki/Normal_(geometry (https://en.wikipedia.org/wiki/Normal_(geometry))
8. Wavefront
https://en.wikipedia.org/wiki/Wavefront (https://en.wikipedia.org/wiki/Wavefront)
9. 3.6 Plane Wave Polarization
https://www.youtube.com/watch?v=84AcKIcF7VY&t=50s (https://www.youtube.com/watch?v=84AcKIcF7VY&t=50s)
10. open and shorted slow wave helical resonators
no link yet
11. Re: slow-wave helical resonator
12. Green's functions
https://www.youtube.com/watch?v=-riPW1yt_fA (https://www.youtube.com/watch?v=-riPW1yt_fA)
13. point of charge / line of charge......point source/ line source
no link yet
Wesley
14. Slow Wave Helical Resonator -Corum
http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla's_Extra_Coil_6.24.14.pdf (http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla's_Extra_Coil_6.24.14.pdf)
15. RF coils, helical resonators and voltage magnification ... -Corum
https://hamwaves.com/inductance/doc/corum.2001.pdf (https://hamwaves.com/inductance/doc/corum.2001.pdf)
16. The real science of non-Hertzian waves (by Paul Nicholson)
http://www.capturedlightning.com/frames/Non-Herzian_Waves.html (http://www.capturedlightning.com/frames/Non-Herzian_Waves.html)
Wesley
Any word on grounding.
Do we need a long rod ?
Is it important to keep it all ( top load , coil , ground rod) in one vertical straight line??
Thank You
"Excitation and use of guided surface wave modes on lossy media"
http://montalk.net/notes/tesla-wireless-technology (http://montalk.net/notes/tesla-wireless-technology)
Infinite Energy Magazine, ( https://en.wikipedia.org/wiki/Infinite_Energy_(magazine (https://en.wikipedia.org/wiki/Infinite_Energy_(magazine))
Wesley
Some links and quotes as example:
https://www.integrityresearchinstitute.org/Members/IRIANNUAL2016.pdf (https://www.integrityresearchinstitute.org/Members/IRIANNUAL2016.pdf)
Wesley
http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0cdl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL2.14&d=HASH0cf796676d1abfb3fa69e6.6.3>=1
Quote from: lancaIV on July 17, 2019, 07:15:22 AM
At first : Wesley, you can ever delete my poste !
I like and respect you lancaIV, but some of posting of anyone, not related close, enough will be removed, especially when
something must go....for others to see better.
Please contribute for benefit of others
but someone must clean the space and keep it organized .
This place is not a chat room ,
it is my notebook with public access, only the most vital information should be hold here.
and your or mine temporary mood is not important to be preserved.
Wesley
https://patents.google.com/patent/US645576A/en (https://patents.google.com/patent/US645576A/en)
In figure B ~ 30000 - 35000 feets lenght
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=39&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220710&CC=GB&NR=157263A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=39&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220710&CC=GB&NR=157263A&KC=A#)
figure 11: rectangular Tesla coil
https://en.m.wikipedia.org/wiki/Hermann_Plauson (https://en.m.wikipedia.org/wiki/Hermann_Plauson)
1919 document-text
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.nuenergy.org%2Fgewinnung-und-verwertung-der-atmospharischen-elektrizitat-deutsch%2F (https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.nuenergy.org%2Fgewinnung-und-verwertung-der-atmospharischen-elektrizitat-deutsch%2F)
" non-ionizing radiation" as source for "thermal-ionizing radiation effect" Diathermie pseudo-HF by ELF
Quote from: r2fpl on July 17, 2019, 04:43:23 AM
http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0cdl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL2.14&d=HASH0cf796676d1abfb3fa69e6.6.3>=1 (http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0cdl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL2.14&d=HASH0cf796676d1abfb3fa69e6.6.3>=1)
T.E. Bearden is first part of the link.I"ll place it in garbage can.
New Energy Technology (PACE, 1990
just forget it - business as usual but with long hands No respectable organization would disorient purposely a reader unless is good for the business.
At the same page we see referral of J Corum
that should not be mistaken with the first part it has nothing to do with it.
For these who are confused:QuoteA scalar wave is a purported type of electromagnetic (https://rationalwiki.org/wiki/Electromagnetism) wave that works outside physics (https://rationalwiki.org/wiki/Physics) as we know it.
https://rationalwiki.org/wiki/Scalar_wave (https://rationalwiki.org/wiki/Scalar_wave)
So only Corum part of the article is valuable and entertaining.
Wesley
thank you for the links:
Quote from: lancaIV on July 17, 2019, 09:31:25 AM
patent speculates around regular electrostatic motor. and fig 11 is the stator part of such motor.
1919 document-text
interesting but not applicable and that is why was not commercialized Wesley
One of Tesla coil assembly is
magnifier.
J. Corum from Viziv made wholeinvestigative testing based on original Tesla's Colorado Springs diary.
https://en.wikipedia.org/wiki/Tesla_coil (https://en.wikipedia.org/wiki/Tesla_coil)
Extra Coil
QuoteThree coil, triple-resonant, or magnifier circuits - These are circuits with three coils, based on Tesla's "magnifying transmitter"
circuit which he began experimenting with sometime before 1898 and installed in his Colorado Springs lab 1899-1900, and patented in 1902.
[36] (https://en.wikipedia.org/wiki/Tesla_coil#cite_note-Patent1119732-36)[37] (https://en.wikipedia.org/wiki/Tesla_coil#cite_note-Sarkar2-37)[38] (https://en.wikipedia.org/wiki/Tesla_coil#cite_note-Reed-38) They consist of a two coil air-core step-up transformer similar to the Tesla transformer, with the secondary connected to a third
coil not magnetically coupled to the others, called the "extra" or "resonator" coil, which is series-fed and resonates with its own capacitance.
The presence of three energy-storing tank circuits (https://en.wikipedia.org/wiki/Tank_circuit) gives this circuit more complicated resonant behavior. It is the subject of research,
but has been used in few practical applications.
the picture of such assembly is here:
http://www.coe.ufrj.br/~acmq/tesla/mres6.jpg (http://www.coe.ufrj.br/~acmq/tesla/mres6.jpg)The same article makes us understand how to calculate easy way
Low Frequency assemblycalled: multiple resonance networks operated as Tesla coil like devices
giving us(or multiple resonance network with distributed load capacitance)
and that is the Tesla Extra coil functionhttp://www.coe.ufrj.br/~acmq/tesla/mres6.html (http://www.coe.ufrj.br/~acmq/tesla/mres6.html)http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla%27s_Extra_Coil_6.24.14.pdf
Important is to understand tuning of Tesla Coil to resonance is critical facor
when dealing with Viziv energy transfer from point A
to point B
using earth/air interface
called interface.
as it is shown here:https://en.wikipedia.org/wiki/File:Simple_SSTC.gif (https://en.wikipedia.org/wiki/File:Simple_SSTC.gif)and here:
https://upload.wikimedia.org/wikipedia/commons/thumb/9/97/Tesla-coil_eq.gif/260px-Tesla-coil_eq.gif (https://upload.wikimedia.org/wikipedia/commons/thumb/9/97/Tesla-coil_eq.gif/260px-Tesla-coil_eq.gif)
complex of capacitive reactive series and parallel LC circuts could b e found when equivalent circuit of Tesla Coil is analyzed.
all of that can be approximated to one single capacitive reactive C2:
https://upload.wikimedia.org/wikipedia/commons/thumb/f/f4/Tesla_coil_circuit.svg/500px-Tesla_coil_circuit.svg.png (https://upload.wikimedia.org/wikipedia/commons/thumb/f/f4/Tesla_coil_circuit.svg/500px-Tesla_coil_circuit.svg.png)Wesley
http://www.tfcbooks.com/mall/corum_bib.htm (http://www.tfcbooks.com/mall/corum_bib.htm)
Wesley
for your entertainment:
https://steemit.com/science/@mage00000/tesla-s-magnifying-transmitter-part-1-introduction (https://steemit.com/science/@mage00000/tesla-s-magnifying-transmitter-part-1-introduction)
https://steemit.com/science/@mage00000/tesla-s-magnifying-transmitter-part-2-high-voltage-generation (https://steemit.com/science/@mage00000/tesla-s-magnifying-transmitter-part-2-high-voltage-generation)
https://steemit.com/history/@mage00000/the-discovery-of-tesla-s-magnifying-transmitter-part-3 (https://steemit.com/history/@mage00000/the-discovery-of-tesla-s-magnifying-transmitter-part-3)
Wesley
https://patents.justia.com/inventor/james-f-corum (https://patents.justia.com/inventor/james-f-corum)
2014 was the year of dreams to Corum brothers
.https://youtu.be/zE4GjB1cWLQ?t=183 (https://youtu.be/zE4GjB1cWLQ?t=183)
2019 pile of patents have been issued
2019 first intercontinental A to B energy transfer was announced as to happen till the end of the year.
https://youtu.be/zE4GjB1cWLQ?t=560 (https://youtu.be/zE4GjB1cWLQ?t=560)
Wesley
There are a lot of patents now
US20180259399A1
https://patents.google.com/patent/US20180259399A1/en?oq=US20180259399+A1 (https://patents.google.com/patent/US20180259399A1/en?oq=US20180259399+A1)
Wesley
Wesley, do you have an XRF (xray fluorescence spectrograph) machine in your lab? I ask because a friend of ours has an hypothesis about possible elemental transmutation under certain conditions of low pressure, high voltage and high frequency. We would like to test some small samples before and after exposure to the experimental regimen.
I have one available to me but it would involve a 200 mile round trip for me to use it. Much simpler if you have one.
Yes I have
https://youtu.be/CQ3gPFfgDp8 (https://youtu.be/CQ3gPFfgDp8)
It is university grade lab EDXRF
X-ray fluorescence (XRF) with vacuum
SEIKO
SEA 5120
from Sodium to Uranium
read on line about it.
It is not so much published as the device was crazy expensive.
Indeed ...
but not for me...
-it operates on LN2.
My Liquid nitrogen line farm, is disconnected now due to my electron microscope LEO 435VE
exchanging place with old scanning microscope
So the place is a mess now.
so I need to find if the suitable grade of LN2 is around to be delivered
in my area into my dewar .
There is also another limitation.
The sample must be tested before transmutation and than after that.
-or two samples of the same origin as mentioned above must be send to me .
the rest needs to be discussed on PM.
There is much older one and lower number model with flap up-down chamber
SEA2110
Much smaller chamber this thing is pretty accurate but I would call it Jewellery grade not academic grade.
https://www.ebay.com/itm/XRF-Gold-Tester-Seiko-SEA2110-x-ray-fluorescence-for-Precious-Metal-Assay/283495312416?hash=item4201a32c20:g:fdsAAOSwhI1a9bVm (https://www.ebay.com/itm/XRF-Gold-Tester-Seiko-SEA2110-x-ray-fluorescence-for-Precious-Metal-Assay/283495312416?hash=item4201a32c20:g:fdsAAOSwhI1a9bVm)
compare pictures with my video.
another option is to use Scanning Electron Microscope - it does the same , even better.
Well not always
Wesley
https://arxiv.org/pdf/1903.10294 (https://arxiv.org/pdf/1903.10294)
Wesley
https://en.m.wikipedia.org/wiki/Theta_wave (https://en.m.wikipedia.org/wiki/Theta_wave)
and Dr. Kazumi Masaki research and developments ( sender/emissor and receiver )
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=Theta&PN=&AP=&PR=&PD=&PA=&IN=Kazumi+masaki&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=Theta&PN=&AP=&PR=&PD=&PA=&IN=Kazumi+masaki&CPC=&IC=)
This frequency range has many possibilities
"Virtual teacher" in "neurophone style" ( ultra- learning time saving and memory quality increase)
https://www.google.com/search?q=neurophone&ie=utf-8&oe=utf-8&client=firefox-b-m
and later "neuro-scan" as mind reader and to " 4d robot cloud"
Experimental and Theoretical Realization of ZenneckWave-based Non-Radiative,
Non-Coupled Wireless Power Transmission
Sai Kiran Oruganti,
Jagannath Malik,
Jongwon Lee,
Woojin Park,
Bonyoung Lee,
Seoktae Seo,
Dipra Paul,
Haksun Kim,
Thomas Thundat
and Franklin Bien.
Ulsan National Institute of Science and Technology, Republic of Korea
University at Buffalo, New York, USA
https://arxiv.org/pdf/1903.10294.pdf
Wesley
Radioactive SparkGap
https://youtu.be/bTyg9hKEooM
What can be the parameters of such a filter? Frequency is approximately 1 GHz.
http://www.pe1rki.com/23cmfilters.html (http://www.pe1rki.com/23cmfilters.html)
Quoteattenuation on 950mhz 60db, on 1800mhz 80db and on the second harmonic 55db.
bandpass characteristic for atv tuned is about 0.2-0.25db loss in passband.
tuned to 1296mhz and with sma connectors i can go a little below 0.2db.
this filter is already in use at many many ssb stations around the world.
i also have a filter that filters 950 and 1800mhz a bit worse but will have 0.15db loss.
i remember i made this filter only once but i lost its specs but it was very low loss.
for tuning filters i use a very expensive vector network analyzer from hewlett packard.
rigol and signal hounds and simular network analyzer equipment do not come close to
the accuracy of hp. so beware, do not retune my filters, you can actualy make it worse without knowing it.
i have even seen several times that the rigol actualy shows a filter making gain instead of loss...
Cavity Filters. Cavity filters are one of many types of
Radio Frequency (RF) filters, and are one of the fundamental building blocks of modern communications systems.
http://www.amateur-radio-wiki.net/index.php?title=What_is_a_cavity_filter%3F
(http://www.amateur-radio-wiki.net/index.php?title=What_is_a_cavity_filter%3F)https://www.youtube.com/watch?time_continue=489&v=QavRKwectm4 (https://www.youtube.com/watch?time_continue=489&v=QavRKwectm4)
https://www.youtube.com/watch?time_continue=1&v=CBx5Xz1v0J4
(https://www.youtube.com/watch?time_continue=1&v=CBx5Xz1v0J4)https://www.youtube.com/watch?v=sM2ltv7x0zA
https://www.youtube.com/watch?v=PLMziyM7EgQ
Wesley
wonderful. :) And then my compatriots got water in their mouths. are silent.
https://youtu.be/XOTLfnMOSqQ (https://youtu.be/XOTLfnMOSqQ)
Free Energy extraction from Schumann waveguide
Wesley
Information about coil I used as transmitter is here
second picture method of tuning Tx to create surface wave:
correction- changing elevation of sphere adjust wave tilt angle and polarization in respect to earth air interface
more is here- https://youtu.be/XOTLfnMOSqQ?t=601
Wesley
1.Nice visualization of standing wave.
https://www.youtube.com/watch?time_continue=6&v=fz-jJahvwt8 (https://www.youtube.com/watch?time_continue=6&v=fz-jJahvwt8)
Wesley
in regards
https://youtu.be/XOTLfnMOSqQ?t=776 (https://youtu.be/XOTLfnMOSqQ?t=776)
shown exactly in this 3 minutes of my video
https://youtu.be/XOTLfnMOSqQ?t=931 (https://youtu.be/XOTLfnMOSqQ?t=931)
Wesley
https://en.wikipedia.org/wiki/Schumann_resonances
Description. In the normal mode descriptions of Schumann resonances, the fundamental mode is a standing wave in the Earth–ionosphere cavity with a wavelength equal to the circumference of the Earth.
Wesley
Kapanadze uses a very simple rule and there is no special wave or special resonance.
The whole process is to understand why there is earth grounding in the cable and why there is electricity!
Because the current actually flows with it (cable). Ask yourself why and understand the principle.
It is not out of this world and everything is real.
hint: when will electricity come from earth?
this is the principle of Kapanadze and its unlimited device power.
When the electric charge goes to the ground, and when from the ground.
Anyone who understands this will know how the Kapanadze device works.
There is nothing special beyond this dependence.
The only difficulty is to complete this task correctly.
This is not Schumann resonances, Zenneck etc. This is my opinion and I want to mislead anyone.
Quote from: r2fpl on August 25, 2019, 03:05:20 PM
than what?
Explain whole process please
What this "electric charge" comes from?
What is the mechanism of energy transfer?
What is the entire path into the Tariel Kapanadze receiver?
Wesley
As you can see, there are not many people who want to do it, but who want to get it on their plate.
Why is it like that ?
Probably most have lost hope that it is possible and only look here and waiting for publication.
I am sorry but I will not write about this principle beyond what I wrote.
Someone doesn't care.
Only you are interested and persistent for a long time.
You're not waiting just looking for a solution like me.
Energy transfer makes no sense within the home.
The only need is a free energy generator.
Hallo r2fpl and stivep I think there are more people interested in discovering how it works .
I am allready many years enthousiast about Kapanadze and Donald Smith and Akula, Andrian Guschka etc .
I am doing small test`s and i would Love to get some more information .. I think this Planet will be happy to see more of this .
Yeahhh r2fpl I Think you will make many more people happy not only stivep, Wesley or me or your self .. but many more people on this Planet will benefit from what you allready discovered .
Here is some of the things I did over time to gather and share information to help solve some parts of the puzzle maybe.
My Prezi presentations with lots of info and links
https://prezi.com/dp7j0ydwqmu-/don-smith-bucking-coil/ and
https://prezi.com/fiwgtl78it85/donz-device/
And some small video`s https://www.youtube.com/watch?v=_uDusLU5IPQ
I am Happy, I would Love to learn more .
Quote from: Utopia Now on August 26, 2019, 08:03:58 AM
https://prezi.com/dp7j0ydwqmu-/don-smith-bucking-coil/ (https://prezi.com/dp7j0ydwqmu-/don-smith-bucking-coil/) and
https://prezi.com/fiwgtl78it85/donz-device/ (https://prezi.com/fiwgtl78it85/donz-device/)
And some small video`s https://www.youtube.com/watch?v=_uDusLU5IPQ (https://www.youtube.com/watch?v=_uDusLU5IPQ)
hi,
I just seen the provided youtube video but the waveform don't look impressive.
I have previously uploaded a video of mine in youtube where i produce a
waveform which is rarely seen using
just kapanadze coil.https://www.youtube.com/watch?v=op9KVhxjhps (https://www.youtube.com/watch?v=op9KVhxjhps)
Please do read expanded youtube description starting from recent 3x PLL multiplier video.I am currently extremely busy with multiple projects at the moment and wasn't free to touch my setup for few weeks now.
Please don't ask me questions now until my next upcoming final video on kapanadze.Thanks for understanding. 8)
Quote from: stivep on August 25, 2019, 11:03:15 AM
so where is the "trick" of activation?
Wesley
There is no any trick.
Just read this and accept reality ;-)
(warning !!! Polish language)
http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-Tesla
http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-100-lecie.pdf
http://www.cft.edu.pl/cft_work/en/getfile.html,file-20190628222514-b3d532bf78ce3e810444f8e6ae6ec15d18b0f4fa.pdf
http://www.czasopisma.pan.pl/Content/112630/PDF/062-065%20kulak_pol.pdf
You can even ask these scientists for an update in the context of the Viziv Milford Tower.
BR
Clearuniverse
I'm sorry I had to write you back.
This is the effect of growth, I think. I had the same effect. There is probably nothing more.
Quote from: r2fpl on August 26, 2019, 10:21:47 AM
hi r2fpl,
It's nearly 11pm here.
The pll multiplier circuit did reveal that i was using wrong capacitor value 100nf at kapanadze output hence it was lowered to
20nf.Akula was using
5nf after the line filter maybe due to the capacitance at the input from his Power supply unit.
Pll isn't part of the final demo since i was using a jumper selection and will be sticking at divide by 3.
My old experiment done around 1 year using AKula layout gave me around
"82khz sine wave" but circuit was operating at around 9khz.The amplitude was mere
2Vpp after using interrupter circuit at high voltage around 4.5Kvpp ...5Kvpp.If hv is removed it revert back to parametric state divide by 3 of L/C resonance.
Back then i was using 100nf at the kapanadze output.I gave up back then.
This upcoming experiment once i am available will be the final attempt with the provide layout shown in youtube.
Quote from: magpwr on August 26, 2019, 11:02:57 AM
hi r2fpl,
The pll multiplier circuit did reveal that i was using wrong capacitor value 100nf at kapanadze output hence it was lowered to 20nf.Akula was using 5nf after the line filter maybe due to the capacitance at the input from his Power supply unit.
My old experiment done around 1 year using AKula layout gave me around "82khz sine wave" but circuit was operating at around 9khz.The amplitude was mere 2Vpp after using interrupter circuit at high voltage around 4.5Kvpp ...5Kvpp.If hv is removed it revert back to parametric state divide by 3 of L/C resonance.
It's hard for me to accept that Kapanadze needed an oscilloscope. As you can see, you have never seen anything like that in the movies. Of course he might have had an oscilloscope.
My analysis came to understand what is happening on the ground wire.
See this video again https://www.youtube.com/watch?v=T4xUe62nWtA&t=758s
There is a measurement through the clamp and there is 25A there.
Now we know that the current flows on this cable.
Find the moment in the movie when it uses two different places where it connects to the ground and you will understand that grounding has changed something.
If it changed the resistance by 1ohm nothing would happen but it would have to change for a greater value. The conclusion is that they are not standing waves. Of course you can say that he used 'feedback' to compensate them but this is not true because the bulbs were no longer 5kW! See: first start = all bulbs are on, ground change = only a few are on.
I think it is very important to correctly understand why this is happening.
To make this device he needed nothing more than a multimeter.
...All these are just my opinions.
Strangely, indepedant of this thread I have been thinking about the burial of the radiator.We are assuming "Earth" is "Earth". I have not seen anywhere where attention is given to the depth of the object in the ground.Also I wonder if the wire attached to the radiator was insulated. To me it appears there are other dynamics involved butnote that where the video is being shot appears quite dry and they have to keep pooring water in the hole.
I have a gut feeling that if a lump of metal is burried and an insulated cable is attached to it, it would act differently to one with uninsulated cable. I can not do any experiments myself as I only have one functional arm.
Quote from: MasterPlaster on August 26, 2019, 02:05:33 PM
In this case, contact with earth and metal is obviously required for the version I am thinking of.
The film has two different grounding locations: https://www.youtube.com/watch?v=T4xUe62nWtA
1.water pipe
2.car radiator
the difference in these places gives a hint about why grounding is needed. We have two options:
a) energy goes to earth
b) energy comes from the earth
Both of these points are possible but what do we know about the differences?
(a) clamp meter = 25A in place to earth so the circuit would have to be closed to earth! but it is not so unless Kapnadze has deceived us.
(b) is 25A justified? Yes of course. The question remains as possible. Possible ! and the circuit does not have to be closed.
This is the most important thing that everyone does not understand.
Does it meet all the dependencies we know from the accounts of witnesses, Kapanadze stories, patent, rules looking at movies, device power and Kapanadze's statement that the amount of energy is practically any in quantity - YES
... still this is only my point of view.
Wesley - I'm sorry if I interrupt your thread?
Hello.
Im trying to build 1.8Mhz transmitter. I try to stick to slayer exciter circuit.
Question is :
I have small coil 0.5 inch diameter and approximately 1000 turns but i cant get it to work at all.
Many turns primary or just a few still not getting any hv.
Is diameter too small?
Next question is :
If i use bigger coil that works fine and adjust its wire length for standing wave, resonance at 492 khz 500 feet wire length
how it will change the distance I need to keep between Tx and Rx?
Is that frequency dependent ? I am not going to use more than 80W. Top load is a toroid 30 inch diameter ( still need to calculate that) .
Mast is pvc and i should be able to get it up 6 to 18 feet.
Thx
Im sorry for oversized Photo.
Wesley did you use 1/4 wavelength resonator?
What about 3/4 of a wavelength ?
1.8 Mhz Is pretty short wave. I just try to avoid hard tunning, expensive mmc and all the interference coming with SGTC.
Thx
yes groot but since it is a lot of coil to wind I used approach of Tariel Kapanadze
CW CCW to make coil electrically smaller.
However this is not needed .
Remember HV TESLA COIL MUST BE in VERTICAL!!! position
Effect of energy transfer between two Tesla coils at some distance is seen and recorded.
In Near Field it behaves as
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg537509/#msg537509 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg537509/#msg537509)
but
for experimenter operating with limited tools, make sure that you really extracting energy from interface at best there is need to be 63f =19m or more , from the Tesla coil acting as Tx
Fluency in this first step is needed to go to second part of it and that is extracting energy from Schumann Waveguide
https://patents.google.com/patent/US10103452B2/en?oq=Patent+number:+10103452 (https://patents.google.com/patent/US10103452B2/en?oq=Patent+number:+10103452)++
The configuration from above picture is also not needed.
However it is closer to SR193 , Akula, Ruslan (yoke)
The advice is not to complicate things.
All of that WORKS!!!
there is not better or worse solution
The only advantage comparing to classical Tesla coil is SIZE!!
Konfiguracja jak na rysunku u gory nie wymagana.
Nie komplikowac sobie zycia.
Wszystkie podane konfuguracje pracuja tak samo roznica jest tylko w rozmiarach
Cewka wys napiecia musi byc pionowa!!
Wesley
Quote from: clearuniverse on August 26, 2019, 09:50:39 AM
http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-Tesla (http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-Tesla)
http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-100-lecie.pdf (http://www.oa.uj.edu.pl/~koperski/work/Dwerniczek-www/Bieszczady_2008/prezentacje/AK_2008-100-lecie.pdf)
http://www.cft.edu.pl/cft_work/en/getfile.html,file-20190628222514-b3d532bf78ce3e810444f8e6ae6ec15d18b0f4fa.pdf (http://www.cft.edu.pl/cft_work/en/getfile.html,file-20190628222514-b3d532bf78ce3e810444f8e6ae6ec15d18b0f4fa.pdf)
http://www.czasopisma.pan.pl/Content/112630/PDF/062-065%20kulak_pol.pdf (http://www.czasopisma.pan.pl/Content/112630/PDF/062-065%20kulak_pol.pdf)
BR
Clearuniverse
super dziekuje.
Very good
Wesley
Another very actual knowledge about ULF/ELF science and Schumann resonance.
Language: English and Polish.
https://pub.igf.edu.pl/files/Pdf/Pubs/132.pdf
Nowadays You can't discover anything new without expensive test equipment and big knowledge about modern physics.
BR,
Clearuniverse
Quote from: clearuniverse on August 27, 2019, 09:11:45 AM
QuoteP polarization is commonly referred to as transverse-magnetic (TM), and has also been termed
pi-polarized or tangential plane polarized. S polarization is also called transverse-electric (TE),
as well as sigma-polarized or sagittal plane polarized.
https://en.wikipedia.org/wiki/Polarization_(waves (https://en.wikipedia.org/wiki/Polarization_(waves))
Serdecznie dziekuje
Wesley
How that can be done?
There are few ways to go around.
One of them is to take look at third order of Schumann resonances
and realize that 60Hz is 3 times of that.
I think I said to much now :)
But I'm trying to attract the most involved brains in this forum
Note: that what makes upset some of opportunists here
Everything published here prevents anyone from
any form of patent protection in the future.
Everything that I decided to publish is in public domain and it is the information with one purpose in mind .
Wesley
60 Hz /3 = 20 Hz. + " it must be vertical" hypo-/thesis ! ?
Counter-design and concept, horizontal:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=667647&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en (http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=667647&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en)
Inducing flux ( centrifugal) / induced flux ( centipetal)
For some unknown :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Adolf+zielinski&IN=&CPC=&IC=
Ok ale Wesley powiedz nam skad sie bierze ta ekstra energia? jonosfera jakos wzmacnia te fale ktorymi strzelamy miedzy jonosfera a ziemia? jesli tak to dlaczego?
Ok but Wesley tell us from where the extra energy is coming from? is the ionosphere amplifying the waves we are shooting between ionosphere and the earth ? if so then why?
There is no extra energy and never was any extra energy.
If you take your Tx and connect your coaxial cable ( 50 Ohm transmission line) open or shorted at the end you have impedance mismatch.
Standing wave will be bouncing back and forth.
However if you now connect 20 Ohm resistor or antenna to the free end of that coaxial cable than part of this energy will be dissipated to this load.
That Standing wave will be lesser of SWR mismatch 5:1, 3:1, 2:1 and so on...
The same is with standing wave in Schumann waveguide .Part of that energy can sink into
interface earth/air in the right conditions when wave tilt angle and polarization is right.
All you need next is to take device of Tariel Kapanadze = Tesla coil
and tune it to that:
-Frequency ,
-polarization
-tilt angle.
-impedance
Wesley
Hallo Lanca, what is the original source of the very interesting translation .
Quote60 Hz /3 = 20 Hz. + " it must be vertical" hypo-/thesis ! ?
Quote from: Utopia Now on August 30, 2019, 03:42:45 AM
Historical up to 100 years back :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Marcel+meredieu&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Marcel+meredieu&CPC=&IC=)
Probably of similar interest :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Fr&AP=&PR=&PD=&PA=&IN=Danyel+beaupre&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Fr&AP=&PR=&PD=&PA=&IN=Danyel+beaupre&CPC=&IC=)
Here special "Augenmerk(- samkeit) " : Resonateur electro-dynamique
If it helps someone:
http://jnaudin.online.fr/systemg/html/sysGtst2.htm
ACTIVATION:
https://youtu.be/XOTLfnMOSqQ?t=1003 (https://youtu.be/XOTLfnMOSqQ?t=1003)
Faraday effect. In physics, the Faraday effect or Faraday rotation is a magneto-optical phenomenon
—that is, an interaction between light and a magnetic field in a medium.
The Faraday effect causes a rotation of the plane of polarization which is linearly proportional to the component of the magnetic field in the direction of propagation.
https://en.wikipedia.org/wiki/Faraday_rotation (https://en.wikipedia.org/wiki/Faraday_rotation)
https://en.wikipedia.org/wiki/Faraday_effect (https://en.wikipedia.org/wiki/Faraday_effect)
We are stealing from the standing wave some energy due to partial impedance match.
That is our "irregularity", in comparison to regular standing wave that has no impedance match and its energy is trapped in this standing wave.
https://youtu.be/XOTLfnMOSqQ?t=759 (https://youtu.be/XOTLfnMOSqQ?t=759)
Wesley
where does the potential difference appear on the electrodes of a heated vacuum diode?
Cathode: This is the electrode that is heated and emits the electrons.
Anode:
This electrode in the vacuum tube or valve has a high potential to attract electrons from the cathode.
Grid: This is the valve electrode that has a variable potential and is used to control the flow of electrons between cathode and anode.
https://www.electronics-notes.com/articles/electronic_components/valves-tubes/what-is-a-tube-basics-tutorial.php (https://www.electronics-notes.com/articles/electronic_components/valves-tubes/what-is-a-tube-basics-tutorial.php)
Wesley
no no. I connect no voltage to any electrode. Just warm the cathode and measure the voltage between the cathode and anode with a voltmeter.
Edison has nothing to do with it. ;)
Anode:Target area: area of anodes struck by cathode electrons also called (focal track)
• Tube Current: number electrons flowing
from cathode to anode kVp
- on exposure
- measured in mA (milliamperes)
• Filament current: 3-6 A (amperes)
- mAs = number filament electrons
boiled off x time filament heated
When you have cathode at right temperature and no other voltage connected than cloud of electrons is moving to colder area
or away from the filament.
only when you connect any measurement tool you have current flowing by means of closed circuit by that device.
Internal impedance of your V meter is determining current flow and only
now when you have current flow you have
potential difference.
Rather you must have
potential difference first or at the same time QuoteA potential difference is the energy per unit charge in an electrical circuit.
Potential difference must be measured between two points because it is generally impractical to measure the electrical potential of a single point. ...
Potential difference is commonly known as voltage because volts are the standard unit of measure for this quantity. It is also known historically as pressure and tension.
http://www.wisegeek.com/what-is-a-potential-difference.htm
(http://www.wisegeek.com/what-is-a-potential-difference.htm)https://en.wikipedia.org/wiki/Hot_cathode
Wesley
Well, here's a volt-ampere characteristic.
8mka-0.7v.
20mka-0.6v.
30mka-0.5v.
60mka-0.45v.
100mka-0.4v.
200mka-0.35v.
500mka-0.25v.
600mka-0.2v.
with load resistance 10mOhm
the voltage at the electrodes reaches 3v. !
That is correct the higher the impedance( resistance) - the higher is the potential difference - the lower is the current.
However Power dissipated on the load ( your meter)is the same.
Ohms law for resistance instead of impedance:
U= R x I
Wesley
Hello, long time no type...
@Wesley
I have a few ideas that I'd like some feedback on... my parent's recently bought a new property and I've been re-looking at ideas I've seen.
1. The first was LED garden lights, using the ground as a single-wire-no-return conductor to remote coils and stepdowns to power LED lights for the drive path, and various... 1)
if There is a a large board with a lot of tuning forks that all resonate at the same frequency, doesn't that collecitively have more energy than none (although tuning forks would be unloaded,
whereas I'm putting LEDs on which would consume some of the energy)...
I haven't really seen anyone progress with a distrubuted ground-based tesla system... have you?
Cieling fans...
There's also these bladeless fans (truly bladeless, working much like a tesla turbine)
https://exhalefans.com/ (https://exhalefans.com/) they have a patent on it so... can't just produce these I suppose;
but the patent does seem overly specific, and with only slight modifications can fall outside it.
which then also reminded me to look into ' schauberger repulsine '
https://frankgermano.wordpress.com/viktor-schauberger-the-repulsine/ (https://frankgermano.wordpress.com/viktor-schauberger-the-repulsine/)
which instead of having a flat disk, has a disk with a sin-wave ripple in it.
considering the air flow of that fan though, the widening space as the radius increases,
I suppose (after refreshing on venturi effect) decreases the speed of the air moving laterally out as there's more space to fill, or
it would be lower pressure... higher tempurature I suppose.
But then, if instead of having flat disks, the disks were rippled, probably so each layer is 180 degrees out of
phase with the next so the chambers and gaps are smallest/largest instead of being parallel...
Air Multiplier...
So then a variation of that that, if you look up 'bladeless fan' actually goes to dyson fan
(which was invented 30 years ago by toshiba apparently [size=78%]https://www.telegraph.co.uk/technology/news/6377644/Dyson-fan-was-it-invented-30-years-ago.html (https://www.telegraph.co.uk/technology/news/6377644/Dyson-fan-was-it-invented-30-years-ago.html)
but never produced.... ) which isn't actually bladeless at all, but appears to be on the surface.
It is mostly a ring, with a chamber that exits a 3mm slit (velocity increase) behind a coanda foil with an open center.
In this open system, it is claimed to get 15x the airflow than the originating bladed fan... the narrow slit accelerates a
cylinderical air circle at 55mph(dyson) which then induces air in the center, as the coanda air foil expands the ring, creating a lower pressure,
which draws air in through the center of the ring. Then additionall there's an entrainment of air on the outside as it draws air around the outside of the ring also...
(see really bad attached image...)
couldn't these be chained so a very small one x15 into one with a gap around the ouside into another pipe to another similar mulitplier.
Is this entirely useless because although the airflow is 15x it's at 1/15th the speed/pressure?
Being an open system, it's certainly not limited to a confinement...
Should be able to almost 3d print some really small replicas, and then just blow a little to start it, and it would sustain itself (should probably include a blocking off switch too...
And that brings me back to - so... can a current in a wire induce currents? High frequency signals on the outside of a wire, and lower in the inside?
(I don't know... I don't see a way to get from the above hydro(fluid)-dynamic system to electornics in this case....
forks if they vibrate mechanically than we dealing with F of sound and longitudinal wave.
If direction of the longitudinal wave energy having the same vector direction can become sum of vectors than Yes.
the energy of forks will be concentrated after all of the losses.
Wesley
The tuning forks thing is to liken many exact same Inductance Coils/Capactance Toploads in resonance with an original generator...
Part #2Quote from: d3x0r on September 09, 2019, 01:13:31 AM
Viktor Schauberger https://youtu.be/yXPrLGUGZsw?t=2297 (https://youtu.be/yXPrLGUGZsw?t=2297)
1.
Kelvin Generator https://en.wikipedia.org/wiki/Kelvin_water_dropper (https://en.wikipedia.org/wiki/Kelvin_water_dropper)
2
. Resonance Structures/Assigning Formal Charge
https://www.youtube.com/watch?v=fYCzeFEAfjg (https://www.youtube.com/watch?v=fYCzeFEAfjg)
conditions for resonance look here for 30 seconds only :- https://youtu.be/fYCzeFEAfjg?t=410 (https://youtu.be/fYCzeFEAfjg?t=410)
comment nitrogen N
in form of gas can be mechanically separated from air.
2b. .
not included in video but helpfulcarbon QuoteCarbon (from Latin (https://www.bing.com/search?q=Latin%20language%20wikipedia): carbo "coal") is a chemical element (https://www.bing.com/search?q=Chemical%20element%20wikipedia) with
the symbol (https://www.bing.com/search?q=Symbol%20(chemistry)%20wikipedia) C and atomic number (https://www.bing.com/search?q=Atomic%20number%20wikipedia) 6. It is nonmetallic (https://www.bing.com/search?q=Nonmetal%20wikipedia) and tetravalent (https://www.bing.com/search?q=Tetravalence%20wikipedia)—making four electrons (https://www.bing.com/search?q=Electron%20wikipedia) available to form
covalent (https://www.bing.com/search?q=Covalent%20bond%20wikipedia) chemical bonds (https://www.bing.com/search?q=Chemical%20bond%20wikipedia). It belongs to group 14 of the periodic table. Three isotopes (https://www.bing.com/search?q=Isotopes%20of%20carbon%20wikipedia) occur naturally, C (https://www.bing.com/search?q=Carbon-12%20wikipedia) and C (https://www.bing.com/search?q=Carbon-13%20wikipedia) being stable, while C (https://www.bing.com/search?q=Carbon-14%20wikipedia) is a
radionuclide (https://www.bing.com/search?q=Radionuclide%20wikipedia), decaying with a half-life (https://www.bing.com/search?q=Half-life%20wikipedia) of about 5,730 years. Carbon is one of the few elements known since antiquity (https://www.bing.com/search?q=Discoveries%20of%20the%20chemical%20elements%20wikipedia).
Carbon is the 15th most abundant element in the Earth's crust (https://www.bing.com/search?q=Abundance%20of%20elements%20in%20Earth's%20crust%20wikipedia), and the fourth most abundant element in the universe by mass (https://www.bing.com/search?q=Abundance%20of%20the%20chemical%20elements%20wikipedia) after
hydrogen (https://www.bing.com/search?q=Hydrogen%20wikipedia), helium (https://www.bing.com/search?q=Helium%20wikipedia), and oxygen (https://www.bing.com/search?q=Oxygen%20wikipedia). Carbon's abundance, its unique diversity of organic compounds (https://www.bing.com/search?q=Organic%20compound%20wikipedia), and its unusual ability to form polymers (https://www.bing.com/search?q=Polymer%20wikipedia)
at the temperatures commonly encountered on Earth (https://www.bing.com/search?q=Earth%20wikipedia) enables this element to serve as a common element of all known life (https://www.bing.com/search?q=Carbon-based%20life%20wikipedia).
https://www.bing.com/search?q=carbon&pc=MOZI&form=MOZCON (https://www.bing.com/search?q=carbon&pc=MOZI&form=MOZCON)
Wesley
Related Victor Schauberger Wirbel/Vortex/Swirl research :
https://www.google.com/search?client=firefox-b-m&q=pax+pacific+impeller&oq=pax+pacific+impeller&aqs=heirloom-srp (https://www.google.com/search?client=firefox-b-m&q=pax+pacific+impeller&oq=pax+pacific+impeller&aqs=heirloom-srp)..
" impeller can mix 4 millions gallons of water using only 150 Watts "
"butterfly"- Chaos-theory : how much energy as Brownian movement this 150 Watt can stimulate in 4 million of gallons( gallon : ancient portuguese mass : 3,785 Liter) of water
http://egm-international.com/index_co2.htm (http://egm-international.com/index_co2.htm) Vortex-/Wirbel-Wandler/Converter
https://en.m.wikipedia.org/wiki/Windhexe (https://en.m.wikipedia.org/wiki/Windhexe)
Used Substantives /Nomen + deklination( Nom.,Dativ,Genitiv,Akkusativ,Ablativ,Vokativ). and Infinitives/Verbum+ conjugation( 1.Pers., 2.Per.,... Singularis/Pluralis + termination : Praesens,Praeteritum,Perfect,Plusquamperfekt,Futur I ,Futur II):
tornar = to turn = tourner = drehen = winden= vertere Tornado/Vertex or Vortex
Wind/Vento/Bento and Gesch-Wind-igkeit= velocity /velocidade
velare, velo= round/rotation velociped from um-runden/rotieren/to round rotare ( per second/minute/hour/....) Rotor
stare=estar( todifferfrom: ser) =stehen= to stand Stator Still-Stand E-/e-/state as social Nation and as statistical Situation/ Moment
The first "Neuzeit-Akademie der Wissenschaften""Physics" father- language has been Latin,
later German(Reichkanzlei zu Prag/Praha -Hochdeutsch
zu lithografische Institut/Duden-Hochdeutsch"= (hannoverische Welfen-)saechsisch=saxonic
/French/ Anglosaxonic(= english, no scottish/irish/Walsh = celto-iberic languages)
Who can not read original publication language and only trust to given by 2nds/3rd their hand. and mind translations get probably "dimensional" basic idea reproduction errors !
Our thinking and as translation tool: spoken and written language is 4 and more dimensional like the assimilated
4 and more dimensional algometric humbots digital mind for the human-free industrial production. !
Re: 3. Vortex Tubes
These aren't either Shauberger or Dyson Air Mulitplier....
while interesting, Viktor Schauberger had literally curled tubes... which for certain capacitiies of fluid velocities reduce flow rates... but they require tuning to operate in a certain range...
(although as I was considering it; certainly Vortex Tubes shouldn't be ignored)
So... they say dolphins and other fish will make vortex rings to eat... It didn't really click how that would work until I saw this
https://www.youtube.com/watch?v=AqATMuyAhPo (https://www.youtube.com/watch?v=AqATMuyAhPo) 'How To Build A Fire With A Plunger' is a terrible name for the video.
8:27 Intro to clip of fish doing so (https://youtu.be/AqATMuyAhPo?t=527)
11:31 goldfish crackers get caugnt, and swept along ring (https://youtu.be/AqATMuyAhPo?t=691)
Which... I'd suppose if there was small things like plankton they would get caught up also, and (perhaps) the vortex is slurped up like a straw full of micro food stuff
Vortex Rings... I saw a coanda quad copter today also; wasn't very good... I think there's something missing, either fins to divert the airflow circularly, or a lip, or ripple to cause rings to happen... but then I guess rings are self-stable and don't influence the outer flows very much
Vortex rings ~ Ampere-turns circum-venting/swirling the coil ( out-side / in-side) :
peripetal and/or centrifugal movement
Up to 990 KW output/ ? weight
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP#)
Up to 1 MW/ 27,2 Kg ( 60 lbs )
https://www.google.com/url?q=http://www.wonksmedia.com/dec.pdf&sa=U&ved=2ahUKEwiE7q_35MnkAhUpA2MBHWH2BGkQFjACegQIBxAB&usg=AOvVaw1bVcXEBtDsFIpTC0QlPVz2 (https://www.google.com/url?q=http://www.wonksmedia.com/dec.pdf&sa=U&ved=2ahUKEwiE7q_35MnkAhUpA2MBHWH2BGkQFjACegQIBxAB&usg=AOvVaw1bVcXEBtDsFIpTC0QlPVz2)
per KW installation : 10 Euros/KW private endconsumer/industrial consumer price ?
1 MW x 10 Euros = 10000 Euros / device weight : 27,2 Kg = 367 Euros/Kg
Imris generator production costs calculation( permalloy, copper, capacitor,...) 32 Euros/ Kg (2012 list prices)
By material value 10 Euros/KW( included well margin ) generator will become real and an alternative to
1500 Euros/KW solar/Wind/Biogas "farming".
For me only known higher power-to-weight ratio devices :
https://patents.google.com/patent/US8847720B2/en (https://patents.google.com/patent/US8847720B2/en)
And
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=45&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=45&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A#)
https://www.google.com/url?q=https://www.sciencealert.com/world-s-oldest-nobel-prize-winner-says-his-new-device-will-give-clean-cheap-energy&sa=U&ved=2ahUKEwif2Ye47cnkAhWlx4UKHbgWBRAQFjAAegQIBBAB&usg=AOvVaw3MFcU2G_SFVRKzLOQLzNeo (https://www.google.com/url?q=https://www.sciencealert.com/world-s-oldest-nobel-prize-winner-says-his-new-device-will-give-clean-cheap-energy&sa=U&ved=2ahUKEwif2Ye47cnkAhWlx4UKHbgWBRAQFjAAegQIBBAB&usg=AOvVaw3MFcU2G_SFVRKzLOQLzNeo)
or instead
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870527&CC=DE&NR=3540683A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870527&CC=DE&NR=3540683A1&KC=A1#)
10@7 W per sqm= 10 MW/sqm = 1 KW/sq-cm conversion possibility
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A#)
To compare the Zielinski/Sines generator fair :
the Harold Goldbaum with Zielinski apparent power-to-weight ratio :
Zielinski ( 4500 Ampere x 220 Volt/50 Hz) / weight
Sines 1 MW : ? Hz/27,2 Kg
Goldbaum : if with 400 Hz 60 KW per hour then with 50 Hz = 7,5 KW per hour dividing with weight 705 ccm x 7,5 g
= 7,5 KW/5,3 Kg power-to weight ratio
Resume :
Goldbaum generator by weight and same output frequency more than 25x times heavier than Sines/ Zielinski generator
Technology for superconductive devices becomes cheaper :
https://patentauction.com/patent.php?nb=13984 (https://patentauction.com/patent.php?nb=13984)by Anatoly Rokhvarger and Lubov Chigirinsky and M.Topchiashvili ( 2000,2004)
91° Kelvin : ::) hmm, mit der Schukeyschen Delta-Omega Maschine, kaskadiert : = - 180 ° Celsius
Kelvin Zeropoint to Celsius Zeropoint ?
https://pt.m.wikipedia.org/wiki/Motor_Schukey (https://pt.m.wikipedia.org/wiki/Motor_Schukey)
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.thermodyna.com%2Fjuergen-schukey.html (https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fwww.thermodyna.com%2Fjuergen-schukey.html)
Ed Sines US Navy work :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#)
Based by their priority dates : Schukey, Sines/US Navy and the HTS coil : global open source ( excl. US 2004 application https://patents.google.com/patent/US7632784 )
civil and military carrier technology for land,sea and air
High power electric beam tool/weapon :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=68&ND=3&adjacent=true&locale=en_EP&FT=D&date=19891018&CC=DD&NR=272727A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=68&ND=3&adjacent=true&locale=en_EP&FT=D&date=19891018&CC=DD&NR=272727A1&KC=A1#)
High energy focus-point delivery : Mega- up to Gigawatt
Un-/friendly application possibility :
Fast cutting house walls, granit cavity engraver( for new water delivering channel f.e.),closed Tresor opener,
military tanks and jets internal heat increaser ( soldiers" cross" like fried chicken) ,
bridges/dams and tunnels e-cutter ,
nuclear solid/liquid waste incineration,minerals smelter et cetera pipapo
Ready for the future eWar without frontier ! This, WE ARE : from cold war era to eWargames competition !
Telemetrical : by joy-stick ;D for Collateralwins
summary:
The real power used by Tx was quite small and insufficient to
provide coast to coast communication.
However total power used to power Tx was huge.
Spark gap created spectrum of frequencies having one dominating center of the lob
where the amplitude was at its highest.
So when receiver or transmitter shifted from desired target frequency than adjacent frequency was immediately available to be used due to existing wide spark gap spectrum.
The bandwidth of Rx and Tx circuitry was so wide, so Rx and Tx was always tuned for communication.
look here :
https://youtu.be/XOTLfnMOSqQ?t=939 (https://youtu.be/XOTLfnMOSqQ?t=939)
By comparison Tariel Kapanadze used at his first devices Tesla Coil and spark gap.
So the spectrum of frequencies created exactly the same lob with ready to use frequencies.
but now our Tx is made by nature.
There are many different ways of
activation:
https://youtu.be/XOTLfnMOSqQ?t=990 (https://youtu.be/XOTLfnMOSqQ?t=990)
Due to Tesla coil characteristic when you have Top Capacitor on the top of Tesla coil RF signal is only present in near field and than is vanishing.
by rules of Brewster Angle
https://en.wikipedia.org/wiki/Brewster%27s_angle (https://en.wikipedia.org/wiki/Brewster%27s_angle)
So we may think that Marconi used big masts and aerial antennas in Tx .
however in Rx he used balloon with straight piece of wire.
And that receiver is our key point
The receiver could only receive surface wave as it was sensitive only to that what could exist in near field of Rx
the receiver and transmitter must be alike but acts in reverse.
Tx is transmitting to primary coil and induces voltage in HV secondary winding.
Rx is receiving signal using HV coil and is inducing it into Low voltage coil.
Note:
Quoteboth the receiver and transmitter must be alike but acts in reverse.
that means Rx and Tx don't have to look alike but they must act electrically as if they were the same.
Wesley
question to Wesley:
QuoteI used a stack of rings cores wound it with 48 turns and added a parallel cap of 0.2 uf. 200nf
and fed it with 40khz resonance max amplitude placed one scope channel across the coil and stabbed each turn of the winding in turn
hoping to get a phase shift up the coil but all that changed was the amplitude.
Any idea's or what am I doing wrong ?
This require
slow wave velocity
https://www.britannica.com/science/wave-velocity (https://www.britannica.com/science/wave-velocity)
https://en.wikipedia.org/wiki/Phase_velocity (https://en.wikipedia.org/wiki/Phase_velocity)
link below:
https://electronics.stackexchange.com/questions/369046/transfer-function-of-phase-change-controlled-with-capacitance (https://electronics.stackexchange.com/questions/369046/transfer-function-of-phase-change-controlled-with-capacitance)
https://www.youtube.com/watch?v=SGel5QNSkIQ (https://www.youtube.com/watch?v=SGel5QNSkIQ)
for capacitive reactive circuits.
other links;
RLC Circuits (5 of 14) Inductive Reactance; Phase Shift, Phasor Diagrams, Frequency, An Explanation
https://www.youtube.com/watch?v=qEjBHmXDBqo (https://www.youtube.com/watch?v=qEjBHmXDBqo)
https://www.youtube.com/watch?v=idf1JQ003nc (https://www.youtube.com/watch?v=idf1JQ003nc)
RLC Circuits (13 of 14) Summary of RLC Circuit Analysis
https://www.youtube.com/watch?v=30J5U0ThRUc (https://www.youtube.com/watch?v=30J5U0ThRUc)
Phase Shift in AC Signalshttps://www.youtube.com/watch?v=FHXZ9C914S0
Build A Simple Phase Shift Circuit
this should be easy enough
basically without going to anything difficult
it is behavior of capacitive reactance and inductive reactance in the same circuit.
and that can be shown easily on Smith Chart
https://en.wikipedia.org/wiki/Smith_chart
(https://en.wikipedia.org/wiki/Smith_chart)other example:
from practical stand point
1.If you feed two coils with the same signal but number of turns is different than you get phase shift
2 If you feed straight piece of wire and coil from the same signal than you get phase shift
3. if you feed two exact coils with the same signal but one coil has capacitor in series than you get phase shift ( however F of resonance will not be the same)
4. if you feed two exact coils with the same signal but one coil has capacitor in parallel than you get phase shift ( however F of resonance will not be the same)
5. if you feed two exact coils with the same signal but pitch ( space between winds is not the same) than you get phase shift
and so on.....
6. take two coils but one of the coils will have few winds in CCW you will get phase shift
hint:
1.wind two windings on the former with the same number of winds.like bifilar.
2.connect two ends together at the bottom and two ends together from the other side of assembly.
3. feed it from the same generator
4. now try to short few winds of one of the coils with piece of wire and look at scope.
you will see two signals separated by delay.
if you carefully chose the <short point> you will regulate phase.
but to see that you need to adjust frequency !!!!!
one possible explanation out of many:if there is difference between two coils in length of the wire than one signal from one of the coils will arrive faster than the signal from second coil.
the signal from the coil with more winds is called
slow wave Wesley
QuoteHowever that device or rather mechanical concept of two pancake shape coiled springs ( mechanical watch springs)
I assumed that these were not coil springs, but trajectories of motion of some mass.
It doesn't matter .
Quotecoil springs, but trajectories of motion of some mass.
is
-the classical mechanics.
Wesley
Standing wave and resonance - two required conditions to send energy via surface wave.
Do we have standing wave at resonance in series LC circuit ( tesla coil ) or
they are adjusted separately?
Magnet wire is sold in spools of aprox. length. Unfortunately i have wind my coils without
making a measurement. Now this two "same" coils are not same at all.
How can i choose top load capacitance to get all the numbers right.
"Approximately" 500 feet 25awg wire and coil has 3.89mH . I tried to measure ohms and
compare it to online calculators but its not taking me anywhere.
Thx
https://www.google.com/imgres?imgurl=https%3A%2F%2Fi.pinimg.com%2Foriginals%2Fca%2F4d%2F2a%2Fca4d2a27f6ac1a5d2f4ab601ad2ad66b.jpg&imgrefurl=https%3A%2F%2Fwww.pinterest.com%2Fpin%2F516365913517034535%2F&docid=kAznm8G2tmEBQM&tbnid=eLZzOdtT90EmnM%3A&vet=10ahUKEwjL94i2r9rkAhXrRxUIHZLvDVwQMwhCKAAwAA..i&w=513&h=837&client=ubuntu&bih=899&biw=1280&q=konstantin%20meyl%20free%20energy&ved=0ahUKEwjL94i2r9rkAhXrRxUIHZLvDVwQMwhCKAAwAA&iact=mrc&uact=8
Quote from: lancaIV on September 18, 2019, 08:14:01 AM
To #2897 :
A lot of good interesting links I'll try to respond to it little later
Wesley
subiect:SLOW WAVE
reason:- slow wave can explain why Tariel Kapanadze coil is so small
-make Tesla coil smaller even though the frequency for given 1/4 y is very low
source:
http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla%27s_Extra_Coil_6.24.14.pdf (http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla%27s_Extra_Coil_6.24.14.pdf)
factors making Tesla coil electrically small yet still performing:
-slow wave
-CW and CCW winding
- resonant cavities/ half rings ( this part is controversial to some of you even if it was explained by Dr Corum)
stored:
here and in https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg539447/#msg539447 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg539447/#msg539447)
Wesley
https://www.youtube.com/watch?v=NogGKkxB1NE&feature=youtu.be (https://www.youtube.com/watch?v=NogGKkxB1NE&feature=youtu.be)
video says:
5kW after battery is disconnected two upper coils are used to (ionizate)/ ionize air and than coil at the bottom
is receiving - converting "this" energy and delivering it to the load -the lightbulb
On the left hand side we have box that has unspecified role and content.
Device is close in its look (only) to hydroelectric device of Tariel Kapanadze.
Note:I only made short summary of the wording used in the video.
I don't in any way try to provide confirmation or try to deny any facts stated in video.
Wesley
Hi, Wesley, I found this on 'the my nik forum' re Delomorto thread some of the stuff looks interesting but i'm having some trouble finding some of the characters (hieroglyphics) are difficult to translate for me (tut) as they are not on the google keyboard :'(
any chance you can have a quick look at the ones with the red rings round them please
kind regards.
Dave
Ref http://freeenergylt.narod.ru/index/0-48 PS goto this site at your own risk
https://www.youtube.com/watch?v=qdRz3GBR_Qs (https://www.youtube.com/watch?v=qdRz3GBR_Qsjust)
just for fun.
Wesley
https://www.youtube.com/watch?v=oaiVc51WKcc (https://www.youtube.com/watch?v=oaiVc51WKcc)
Yet another one
Wesley
Quote from: DavidWolff on October 10, 2019, 07:40:05 AM
kind regards.
Dave
Ref http://freeenergylt.narod.ru/index/0-48 (http://freeenergylt.narod.ru/index/0-48) PS goto this site at your own risk
Requested translation is below
Wesley
Hi Wesley and thank you for that.
I'm still a little confused as to what the language is exactly
Also, some might find this of use although winding the coil might not be a one would expect it to be wound.
Катушка L1и L2 намотана на каркасе d40, содержат no 40 витков множльного ировода 1мм
The coil L1 and L2 is wound on a d40 frame, they contain no 40 turns of a multiplier of 1 mm
В схеме нужно крен12 эаменuмь на крен8б цлц любую
Рассмоянце молько
coil L1 and L2 winded on coil former d=40mm has 40 winds stranded wire 1mm
you need to make change relay 12 change to relay B6 or any other relay working with 12 V
Рассмоянце молько
Рассмоянце- there is no such word
молько- milk
Most likely this is slang but you made mistake in first word
Wesley
Quote from: stivep on October 13, 2019, 01:33:46 PM
give me link to his comment if you have one.
If you don't have it than this comment of yours is irrelevant
Wesley
https://youtu.be/Urdotg_CPJo
Didn't you know that ?
Some who do not watch the movies to the end and then are surprised.
It is difficult to know now what is truth and what is not truth.
There used to be a photo showing devices in production. I have this picture but I don't want to put it here. If you want, I will send it to you pr.
After countless hours of running back and forward in my garage with a glass of water in my hand,
I found that sweet spot Hooray .
Somebody forgot to mention that size of glass matters LOL
Hello, i going back a few years back when there was one person (with nickname in the forums "Tungus Wiliam") who interesting explained in detail the principle of operation of the Tariel Kapanadze generator with presented schematic diagram. In this regard i provide an archive document (https://realstrannik.com/media/kunena/attachments/224/Tungus1.pdf) in Russian that could be translated into English
and short part from this document referring to the description of the details in the diagram:
QuoteНа схеме точка А питается от моста и емкости С2, требования к параметрам
тока и напряжения определяются потребителями в виде контура L1C1,
автогенератором G, и генератором питающим ключ VT1.
Точка В является для контура источником тока от моста (точка А) и источником
постоянного высокого напряжения от строчного трансформатора М. Питание на
контур снимается с конденсатора – накопителя энергии С3.
Через строчные трансформаторы M и P продеты полвитка резонансного контура
L1C1.
Генератор - auto G – автогенератор, обратная связь для поддержания резонанса
без ФАПЧ заведена с обмотки L7.
Обмотка L2 высоковольтная, питаемая током колебательного контура L1C1 и
выполняет функцию повышения потенциала в точке В сохраняя баланс
растраченной энергии контура, чем больше ток в контуре, тем выше потенциал
точки B. Для контроля заряда емкости С3 и ограничения напряжения можно
ставить разрядник или варистор. Рекомендуемое напряжение на контуре 800
вольт, этот параметр расчетный и зависит от нагрузки и цепей сброса энергии с
контура, таких как строчник P.
Строчник P выполняет функцию трансформатора тока с мощной обмоткой
съема Lp и высоковольтной L3.
Обмотка Lp является источником тока для повышающего преобразователя
между точками DH.
Ключевание катушки и L(R) производится с частотой 50 Hz с заполнением ВЧ
( например 100 кГц) скважность – 2.
В период отсутствия накачки L( R ) емкость С4 пополняется высоковольтной
энергией от L3, катушка S может не применяться, разрядник W то же, цепь
может быть замкнута от L3 до точки D.
Емкость C4 - основной накопительный элемент , рекомендуемый диапазон
заряда емкости должен быть в пределах 440-880 вольт, при циклах отбора
энергии при ключевании нагрузки заряд не должен снижаться ниже 400-440 v.
Дроссель L(R) со стороны заземления представляет мощный насос электронов,
а для всей схемы от транса тока P - это ФВЧ и апроксиматор для выделения
синусоподобного сигнала 50 Hz.
Провод Q может быть выполнен в виде внутренней обмотки дросселя с
согласованным напрвлением тока, но я бы не стал этого делать, выигрыш не
большой и фронты режет при ключевании VT1.
Номиналы элементов рассчитываются исходя из энергетики блоков питания,
нагрузки и личных предпочтений, все узлы и блоки очень простые.......
P.S. Схему можно усложнить или упростить......по желанию.......
Hello Wesley.
https://www.youtube.com/watch?v=3urK7ybyyZM
Link is to one of many many kapanadze demo videos .
Could you point me to JUST ONE that shows kapanadze device working and a guy taking measurement of current in a ground wire.
According to Corums patents you adjust polyphase probe while taking current measurement at the ground stake.
Unless you use a probe without grounding ( they patented this too ) you should see a current flow.
Video translated by you shows a measurement of 0 (volt? , amp?) before device was turned on, and then once its on there is a guy touching it with his tongue. No measurement .
If this technology is based on surface wave and air earth interface , and grounding is utilized should we see current in this wire??
My assumptions are based on Corums patents only. https://patentimages.storage.googleapis.com/4d/66/f0/2ebc8481c0e629/US9941566.pdf
Line 35 to 40 .
https://www.youtube.com/watch?v=Goq76CQapyI
22min 25 sec in to video - is this a current measurement in a ground wire??
THX
Quote from: groot on October 16, 2019, 06:01:42 PM
I said that this is the most important thing how this device works !!! no one understands why?
there are two possibilities that I know:
1. the current is in a loop with the earth
2. HV goes to the ground wire.
It's enough to do experiments to understand, but everyone is just waiting for the device. That is why those who have achieved something do not share with others because others are passive.
Hello
Since everyone is eager to answer questions i have one more. ;D
Tesla coil is often described as antenna. Its very poor antenna that is radiating poorly.
Nikola Tesla designed it as a device that sends power over large distances. ( im skipping word wireless on purpose)
Antenna Fundamentals:
VSWR is the ratio of the maximum voltage to minimum voltage on the transmission line. With an impedance mismatch, the VSWR is greater than one, indicating the presence of reflections. As the impedance at the end of the transmission line becomes higher—approaching open circuit, the VSWR approaches infinity, indicating that all the power is reflected. This situation is similar to the incidence of a light beam at an interface between two media, such as air and water, in which some light is reflected and some goes into the water. VSWR reduces the amount of power transmitted to the antenna or reduces the signal from the antenna when it is used to receive signals.
Resonance and standing wave, resonant voltage building up at the TOP LOAD and discharge, a spark, corona discharge.
maybe just maybe all this occurrences are unwanted effects, all tesla coil builders seek sparks and corona and Nikola Tesla tried to avoid all of that .
Reading colorado springs notes made by Tesla we can find out that he was sending up to 1000amps thru ground stake.
Thx
please delete this
Why?
It's true that Tesla's coils achieve the maximum standing wave. Quarter wave resonance. And yet, combine it with LC resonance.
Such an antenna does not really emit.
Quote1. the current is in a loop with the earth
not everyone is waiting but some favor to work on experiments instead of posting pages after pages of information ( relevant ore not). it drives more and more poeple away than helping them.
1. kind of sort of....
Quote from: x_name41 on October 16, 2019, 12:25:18 PM
Translated by Google Translate
Groot
QuoteSince everyone is eager to answer questions i have one more. ;D
Hey Groot, the reason so few have been able to make this work is because they have not read Tesla's work or listened to what he was saying. People often describe it as an antenna however in order to produce the desired effects we must do the opposite of what everyone else does and turn the antenna upside down.
Tesla said the HV secondary coil and the top load must be perfectly insulated to prevent all corona effects, radiation and losses. Nobody listens and they use a leaky top load which will radiate energy and negate the proper effects. Everyone has it backwards and upside down thus it is no wonder they cannot make anything work. The process was to store a great deal of energy in the insulated coil and top load with no losses or radiation then drive it into the ground plane in a single impulse with no return. This produced a HV surface conduction wave which travels along the ground much like a solition wave. What Tesla was trying to do was reproduce the effects similar to a lightning strike to ground. He even said this was where he initially got the idea... lightning. Think about that, lightning is obviously not an antenna and it does not produce EM waves therefore it's not the same thing.
Now one could say the wave like disturbance must dissipate and it does to some extent however we should understand this is not a Hertz or alternating EM wave this is a DC conduction wave. From Tesla's work with extremely HV he understood that even the best insulators act like conductors if the voltage is high enough. From this he deducted and proved through experiment that voltage (a difference in potential) can be replaced with a singular wave of very high potential which does not alternate in potential like an EM wave.
Understand, an ocean wave "alternates" like an EM wave above and below the average or mean height bound to every other wave however a solition wave travels as a singular disturbance not bound to any other waves. Obviously, if it is not bound to any other EM waves then it can act independent of them and is not bound to act like them. As it turns out all one has to do is not do the same thing as everyone else does over and over and over... do something different. I mean it's so obvious and self-evident it boggles the mind doesn't it?.
Why anyone would keep doing the same thing over and over when they know it doesn't work is apparently beyond my understanding. So there you have it, do something different, do the opposite and you will be well on your way. People just aren't all that smart but mother nature is a genius with billions of years of evolution to back her up, think about that.
Quote from: onepower on October 23, 2019, 06:46:38 PM
Groot
Hi onepower. Thank you for your reply its much appreciated. I totally agree with you. Everyone should educate themselves and follow intuition.
Thank you for sharing your opinion ill look in to it.
One must be open minded but should restrain from foolish coping some diagrams not knowing how that device work.
Thx
Groot
QuoteHi onepower. Thank you for your reply its much appreciated. I totally agree with you. Everyone should educate themselves and follow intuition.
No problem, I agree and it's strange how all these patents we see are almost never as they seem. The most important parts relating to a working principal and the process are always missing. The trick I have found is to not get too hung up on what we think we see or hearsay and look at any given technology objectively and conceptually.
Absolutely the biggest mistake I see many people making is assuming because something looks similar to what we have seen in the past it must act or work similar which is not always the case. My line of reasoning is that if I was actually intelligent all of the answers should come naturally and flow like water however this is not the case. At which point it occurred to me that it was never the capacity to retain a bulk knowledge of science or technology which relates to other people but to try to do our own thing as an individual. Conjure up a new concept, start experimenting and see where it takes us.
scalable power from the atmosphere ?
http://www.conflowpower.com/ (http://www.conflowpower.com/)
editNew thread for CONFLOW
https://overunity.com/18359/conflow-power-unlimited-harvesting-scalability-from-atmosphere-and/msg539970/#new
QuoteConjure up a new concept, start experimenting and see where it takes us.
totally agree. There are a lot of lies on the Internet. Do not trust anyone and do not listen to anyone. Do it yourself. I try.
Quote from: ramset on October 28, 2019, 09:11:06 AM
Seems like that deserves it's own message thread. Quite amazing if it's real and ever gets into production. It does seem like they are getting close.
Title of video is:
Экскурсия по музею БТГ Free Energy [EBM] которого нет, Pr. Szabo в Будапеште около 10 лет назад.
Trip to museum of FE EBM that doesn't exist, Professor szhabo in Budapest around 10 years ago.
https://www.youtube.com/watch?reload=9&v=1TyDfrn5JAE (https://www.youtube.com/watch?reload=9&v=1TyDfrn5JAE)
this is next step of history of EBM popular in year 2009 an d 2012
Information is related by Russians so please "grain of salt" or "pinch of salt"
EBM - ENERGY BY MOTION
first translated comment from Russian's
:Gammamanager ещё делает БТГ?
is Gammamenager still making Free energy Generator?
Уже давно не делает, темболее это Канада потом удрали в Венгрию, потом кое кто почил а дочка все просрала, вернее продала.
They dont work on it long time ago , ,remember that is Canada , than they escaped to Hungary and than he did make some progress but.. daughter ... she wasted or to be more accurate sold it.
Их абривеатура крайняя EBM «Energy by movement»
Their device it was exactly EBM «Energy by motion»
Максим давно в моей публикации, очень давно..
https://rakarskiy.io.ua/s1682635/parallelnyy_magnitnyy_potok_tehnologiya_djo_flinna (https://rakarskiy.io.ua/s1682635/parallelnyy_magnitnyy_potok_tehnologiya_djo_flinna)
Maxim he is long time in my publication, very long time.
( they talk about Joe Flynn)
В конце Вестли не понравится так как Флинн далеко не первый просто Америка так столбит за собой технологии
At the end Wesley will not be happy about it as USA is so much .. for its technologies.
Это русский образец подобной технологии
http://ckb-topaz-yug.ru/nashi-razrabotki/eppm-5-kvt.html (http://ckb-topaz-yug.ru/nashi-razrabotki/eppm-5-kvt.html)
This is russian example of that technology
А ну гляну
Let me look at it...
Сделали ,только помалкивают...
Yes ..they did it .. but they dont want to say to much..
more about EBM is here;
https://youtu.be/a_lQyfM9QIc?t=171
https://rakarskiy.io.ua/s2640425/generaciya_beztoplivnaya_ebm_energy_by_movement
Wesley
Congratulations! The IAP has given us the 47.2 GHZ (at least for 4 yrs)
To do with as we please, including building energy receivers designed to the 1/4" wavelength
American FCC still prohibits broadcast at that frequency to amateur radio, but they have no jurisdiction
over energy reception.
Telecom stepped down, which means that's our "free energy"
Beamed down to us from nuclear satellites that will last 100 yrs!
Explain to the ignorant what it is.
QuoteBeamed down to us from nuclear satellites
Quote47.2 GHZ
Wesley,
Those Ortec's look gorgeous, I guess you like to collect these, can't blame you.
OK I think I may have time to get back to the Coleman experiments in awhile. At this point I do not care about spectrum lines only safety. When you told me about the thing throwing neutrons without gamma I stopped the experiment. Do you still stand by this claim? If so the particle detector is paramount for safety reasons.
I have an alpha beta gamma detector I made with Russian tube but nothing for the particles.
I know you are hesitant in talking too much about this device due to your friend who is invested heavily. Is he at all interested in consulting or licensing, could you inquire? It could save a bunch of time. I know neutron particle detection requires sensitive setup and containment and imagine boring a hole in the lead shielding around the experiment for just the detector probe end would be optimal. What was the frequency of neutrons you were able detect per hour?
Don't worry I did not start the Coleman experiment from your data, but only found you in a search when I was bringing the thing up, just curious if anyone else had attempted same. Just to say you are not a bad influence that made me experiment with this, only the good influence that made me take pause.
Thank you for the great videos and science!
Hello
I came across this website recently
https://www.inverse.com/article/45546-nikola-tesla-conspiracy-theory
Thx to professor Corum we know that this is possible and Tesla was right all along.
Wesley you know much more and much better about this project so answer this.
Tesla was digging deep in to rock at Colorado location to create a good ground connection. He even run water 24/7 to keep resistance low.
Corum explains in his patents that there must be incident present at Brewster angle, and physics teach us about refractive index and two mediums and that wave must originate in certain medium. Antenna ground mirror reflection tells us how to do it. It takes a lot of work to accomplish.
So now tell me why they didnt build it at sea, under water ? according to Tesla and Corum this can be received anywhere in the world including sea and ocean, and if you can receive it there im certain you can Transmit as well.
By any chance does anyone know where was located a power plant that supplied Wardenclyffe Tower ?
Thx
Why does the asymmetric inductance with a permanent magnet not create a constant component in the AC circuit?By analogy with a semiconductor diode.because there is an asymmetry of the forward and reverse current.
I'm not sure what is that you asking for.
Can you be more specific?
Are you asking about The asymmetry between forward and reverse conduction as the basis for rectification ?
http://tuttle.merc.iastate.edu/ee201/topics/diodes/diodes.pdf (http://tuttle.merc.iastate.edu/ee201/topics/diodes/diodes.pdf)
One of examples of asymmetry and related to it energy is here:
https://arxiv.org/ftp/arxiv/papers/1801/1801.05229.pdf (https://arxiv.org/ftp/arxiv/papers/1801/1801.05229.pdfWesley)
Wesley
Well, something like that. A semiconductor diode rectifies the voltage, and a nonlinear inductance should rectify the current.But there was no constant voltage on the load.
first lets clarify what is :
The behavior of an inductor for which the voltage drop across the inductor
is not proportional to the rate of change of current, such as when the inductor
has a core of magnetic material in which magnetic induction is not proportional to magnetic field strength.https://encyclopedia2.thefreedictionary.com/nonlinear+inductance (https://encyclopedia2.thefreedictionary.com/nonlinear+inductance)
Example of Variable Inductor that in this case has the inductance as a function of its current
:http://www.beigebag.com/case_nonlinear_ind.htm (http://www.beigebag.com/case_nonlinear_ind.htm)
Conclusions:A lossless, nonlinear inductor model has been created.
This model is suitable for use in strongly nonlinear applications such as those using square
loop cores, or by curve fitting, to create a somewhat 'softer' models more nearly
approaching the performance low loss devices operated over a large range of flux (current) where a lossless, linear, straight line, unsaturating device model does not
fully result in good approximations of the actual circuit behavior.
but.. that what is puzzling me is:
-your wording pointing about rectification
-addition of permanent magnets
can you explain it more?
Wesley
Quote-addition of permanent magnets
This allows, as I think, to have different inductive reactance for forward and reverse current.
But can a certain frequency be extracted from the chaotic thermal motion by placing randomly scattered molecules in a volume resonator? Similar to how this is done in a radio receiver, in the input resonant circuit of which the necessary frequency is allocated from all the chaos of ether noises?The resonator will be very small, given the small mean free path.
1. some of construction of buildings in Texas by Texon/ Viziv/ :
https://nationwideconstruction.com/wp-content/uploads/2016/12/2758.jpg (https://nationwideconstruction.com/wp-content/uploads/2016/12/2758.jpg)
https://nationwideconstruction.com/wp-content/uploads/2016/12/2830.jpg (https://nationwideconstruction.com/wp-content/uploads/2016/12/2830.jpg)
https://nationwideconstruction.com/wp-content/uploads/2016/12/2779.jpg (https://nationwideconstruction.com/wp-content/uploads/2016/12/2779.jpg)
2. in 2017 Texon..// Viziv was looking for additional money in 15 million dollars information IS MENTIONING FEW OTHER PLAYERS .
https://www.bizjournals.com/dallas/news/2017/03/17/form-d-friday-15-million-for-a-waxahachie-firm-to.html (https://www.bizjournals.com/dallas/news/2017/03/17/form-d-friday-15-million-for-a-waxahachie-firm-to.html)
3. 2018. Viziv $34.1M
QuoteSome might ask what the unique-looking tower off Interstate-35E just outside Waxahachie is. It belongs to Viziv Technologies, which is the culmination of more than four decades of research in the field of Electromagnetic Surface Waves, CEO Brig. Gen. Michael Miller recently told Dallas Innovates (https://dallasinnovates.com/meet-the-innovators-brig-gen-michael-w-miller-viziv-technologies/). The research focuses mainly on methods to propagate the electromagnetic phenomenon known as the Zenneck surface wave, which unlike traditional radio waves, is guided along the earth's surface. Viziv's primary engineering focus is development of a means to synthesize this surface wave in "real world" conditions for use in various applications such as communications or energy.
In January,2918 Viziv announced that it had raised (https://dallasinnovates.com/follow-the-money-yourcause-exits-in-157m-deal-viziv-technologies-raises-1-37m/) an additional $1.372 million in two funding rounds.
Wesley
RF Inductance Calculator for Single‑Layer Helical Round‑Wire Coils
Link:
RF Inductance Calculator for Single‑Layer Helical Round (http://hamwaves.com/inductance/en/index.html)Jun 30, 2019 ·
Dr.
James F.
Corum, K1AON is the founder inventor and patents holder for Viziv/ Texon
QuoteThe inductor calculator presented on this page is unique in that
it employs the n = 0 sheath helix waveguide mode to determine the inductance of a coil,
irrespective of its electrical length.
Unlike quasistatic (https://en.wikipedia.org/wiki/Quasistatic_approximation) inductance calculators, this RF inductance calculator allows
for more accurate inductance predictions at high frequencies by
including the transmission line effects apparent with longer coils.
Furthermore, the calculator closely follows
the National Institute of Standards and Technology (NIST) (http://nist.gov/) methodology
for applying round wire and non-uniformity correction factors and
takes into account both the proximity effect and the skin effect.
The development of this calculator has been primarily based on a
2001 IEEE Microwave Review article by the Corum brothers (https://hamwaves.com/inductance/doc/corum.pdf)7
and the correction formulas presented in
David Knight's, G3YNH, theoretical overview (http://www.g3ynh.info/zdocs/magnetics/part_1.html),1
extended with a couple of personal additions.
Which equivalent circuit should be used?
Both equivalent circuits yield exactly the same coil impedance at the design frequency.
For narrowband applications around a single design frequency
the effective equivalent circuit may be used.
When needed, additional equivalent circuits may be calculated for additional design frequencies.
The lumped equivalent circuit is given here mainly for the purpose
of comparing with other calculators.
By adding a lumped stray capacitance in parallel, this equivalent circuit
tries to mimic the frequency response of the coil impedance.
This will be accurate only for a limited band of frequencies
centred around the design frequency.
so there are some practical tools including calculator by Dr James Corum
Wesley
Article
https://operationdisclosure1.blogspot.com/2019/12/opdis-compilation-of-articles-part-2_24.html (https://operationdisclosure1.blogspot.com/2019/12/opdis-compilation-of-articles-part-2_24.html)
explains again what is we talking about here:
Viziv Surface Wave System
Tesla Technology Has Been Revived
Aaron and Melissa Dykes of TruthstreamMedia were driving outside of Dallas near the small farming town of Milford, Texas, when a strange tower in the middle of a field caught their eye. It almost seemed like a joke because the shape was unmistakable. It looked just like Tesla/" target="_blank">Nikola Tesla's Wardenclyffe Tower, the legendary experimental wireless transmission station he built in 1901 in Shoreham, New York to transmit phone calls, fax images and electrical power but which was demolished 16 years later due to bankruptcy.
A little bit of research revealed that the tower's owners are Viziv Technologies and that the structure is, in fact a Tesla wireless transmission tower! Viziv is currently reviving the technologies of Tesla/" target="_blank">Nikola Tesla, having "developed a system of patent-pending processes and equipment to efficiently launch the Zenneck surface wave...[which is ] an electromagnetic wave that uses the surface of the earth as a waveguide enabling it to carry communications signals or electrical power efficiently over long distances..."...
https://vizivtechnologies.com/technology/ (https://vizivtechnologies.com/technology/)
The Viziv surface wave system represents a paradigm shift in the science of electromagnetics.
WHAT IT IS
Our Viziv surface wave system allows the Earth itself to be used for clean, safe and efficient transfer of power between any two points on the globe, wirelessly. The system represents a paradigm shift in the science of electromagnetics.
Today's power distribution system of wired grids is fragile and aging. The transition to a global wireless system utilizing the Zenneck surface wave is a breakthrough that will effectively "cut the cord" between power generation facilities and the local distribution grids. This breakthrough will significantly enhance energy surety, reliability, and resiliency of the world's electrical distribution systems.
HOW IT WORKS
Viziv Technologies has developed a system of patent-pending processes and equipment to efficiently launch the Zenneck surface wave. Currently, our research and commercialization efforts are focused on energy transfer and communications, but we recognize that this technology has the potential to impact numerous sectors of the economy.
A Zenneck Surface Wave is an electromagnetic wave that uses the surface of the earth as a waveguide enabling it to carry communications signals or electrical power efficiently over long distances.
This wireless power system will employ a "transmitter probe," located near a power generation plant, to launch a Zenneck carrier wave. Receiver antennae will be positioned appropriately around the world to receive the signal and download the power into a local microgrid or conventional grid architecture.
The wave is impervious to weather effects such as lightning or geomagnetic disturbance or electromagnetic pulses (EMP), including those associated with a nuclear detonation. Unlike a wired grid, the Zenneck wave cannot be physically attacked and cyber attacks would be challenged to target or cause cascading failures to a wireless system.
When launched, the Zenneck Surface Wave literally envelops the planet like a balloon, enabling transmitter probes to be placed anywhere power can be generated and receivers to be placed anywhere power is needed....
This paper, recently presented at an Association of Energy Engineers conference, provides an overview of Viziv wireless power systems, its evolution, and implications for the future:
https://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf (https://vizivtechnologies.com/wp-content/uploads/2017/10/TWP-Paper-10-3-2017.pdf)
James F. CORUM, et al. : Zenneck Wave Transmitter Patents --
SUPERPOSITION OF GUIDED SURFACE WAVES ON LOSSY MEDIA
US2018151933
Authentication to enable/disable guided surface wave receive equipment
CN108352731
EXCITATION AND USE OF GUIDED SURFACE WAVE MODES ON LOSSY MEDIA
US2018183128
US2018180729
VARIABLE FREQUENCY RECEIVERS FOR GUIDED SURFACE WAVE TRANSMISSIONS
US2018159374
US2018151933
https://patents.justia.com/inventor/james-f-corum?page=2
Patents by Inventor James F. Corum
Wesley
http://wi-tap.energy/wp-content/uploads/2016/02/Goubau_On-the-Zenneck-Surface-Wave.pdf
(http://wi-tap.energy/wp-content/uploads/2016/02/Goubau_On-the-Zenneck-Surface-Wave.pdf)
Dr. Zenneck in time of Tesla and Marconi was a professor in Munich Technical University Germany.
Goubau was his student
Goubau made single wire energy transmission while Dr Zeneck discovered Zenneck wave.
All of them based on Tesla and used Tesla coil.
Marconi in Bolinas California was trying to send energy over the Air/Earth interface till was stopped by US government ( newly created RCA 1919 - 1921)
Some people in Long Island NY were trying to preserve Tesla's facility and for Dr Corum it was opportunity to mark himself and his work.
http://teslasociety.com/corum.htm (http://teslasociety.com/corum.htm)
I was there too, but only to visit it.
Wesley
overview of Viziv in Dec 2018
https://thedailydialectics.com/SurfaceWaves/Visiv (https://thedailydialectics.com/SurfaceWaves/Visiv)
Wesley
В режиме стоячей волны волна Зоммерфельда-Ценнека
https://www.dissercat.com/content/novye-tipy-poverkhnostnykh-elektromagnitnykh-voln-v-provodyashchikh-sredakh
(https://www.dissercat.com/content/novye-tipy-poverkhnostnykh-elektromagnitnykh-voln-v-provodyashchikh-sredakh)And basic requirement is that Wave must be in TM mode
http://www.sciteclibrary.ru/texsts/rus/stat/st5745.pdf
(http://www.sciteclibrary.ru/texsts/rus/stat/st5745.pdf)
ВТЕКАЮЩИЕ И ВЫТЕКАЮЩИЕ НЕСОБСТВЕННЫЕ МОДЫ:АНАЛИЗ ДИССИПАТИВНЫХ ДИСПЕРСИОННЫХ УРАВНЕНИЙИ ВОЛНА ЦЕННЕКА
М. В. Давидович
Wesley
For Russian audience:
Вы должны понимать разницу между Viziv, основанным на Маркони и Тесле, и моей технологией, основанной на волноводе Шумана.
Практически это то же самое.
* Визив передает в катушку Тесла, чем в области между катушкой Тесла и дальним полем где-то вокруг зоны Френеля.
https://en.wikipedia.org/wiki/Near_and_far_field
(https://en.wikipedia.org/wiki/Fresnel_zone)
QuoteQuotequestion:Эта модель Регионa Френеля учитывает то, что электромагнитная волна может иметь продольную составляющую электрического поля?
Нет Регион Френеля важен для нас только из-за его существования,
Mы знаем, что он существует
Мы можем указать на пространство между катушкой Тесла и ее дальним полем в точке,
где наклонная линия проведена от вершины катушки к земле под приблизительным углом
между землей и этой линией между от 62 до 67 градусов. глубитca в землю.
С этого момента он становится Zenneck Wave в интерфейсе в режиме TM.
Не выходя за пределы дальнего поля под приблизительным углом от 64 до 67 градусов к земле,
постоянная волна в катушке Тесла преобразуется в волновой наклон сигнала в режиме TM
https://www.electronics-notes.com/articles/antennas-propagation/rf-feeders-transmission-lines/waveguide-modes-te-tm-tem.php (https://www.electronics-notes.com/articles/antennas-propagation/rf-feeders-transmission-lines/waveguide-modes-te-tm-tem.php)
https://www.rfwireless-world.com/Terminology/difference-between-TE-wave-and-TM-wave.html (https://www.rfwireless-world.com/Terminology/difference-between-TE-wave-and-TM-wave.html)
https://youtu.be/XOTLfnMOSqQ?t=294 (https://youtu.be/XOTLfnMOSqQ?t=294)
ПОСЛЕ ТОГО, ЭЛЕКТРОМАГНИТНАЯ ВОЛНА В РЕЖИМЕ ТМ ПОЙМАНА В ЛОВУШКУ В ИНТЕРФЕЙСЕ ЗЕМЛЯ / ВОЗДУХ
ЭТА ВОЛНА НЕ ИЗЛУЧАЕТСЯ В ВОЗДУХЕ.
С этого момента закон обратных квадратов не так сильно влияет на эту волну.
https://en.wikipedia.org/wiki/Inverse-square_law (https://en.wikipedia.org/wiki/Inverse-square_law)
Эта волна может быть получена идентичной катушкой Тесла в России или другом месте Земли на 92-98% от ее первоначальной мощности.
Так как у нас есть конденсатор между ионосферой и землей, который делает волновод Шумана, теперь это правила волновода, которые применяются.
К счастью для нас, мы идем ходим на одной из границ этого волновода.
Bставив зонд в обычный волновод, мы можем извлечь некоторые колебания энергии в этом волноводе.
но этот зонд должен быть настроен на резонанс на частоту, где энергия должна быть извлечена c этой волны Zenneck .
Quoteanother words Fresnel Region is important to us as it helps us to pin point
the exact point were virtual sloping line from top of tesla coil is entering the earth.
that line doesn't exist .
It is our form of explaining how the process works.
But we must specify at what distance from the tesla coil, we'll start deal with Zenneck Wave.
Everything is explained in my videos you must view all 3 of them.
List of videos will be given below
Wesley
отрицательность энергии бесплатно - это перенаселение и искусственный апокалипсис
Легкость жизни может сделать права на жизнь привилегией
Люди будут умирать из-за недостатка пищи, они очень скоро погубят землю, всего через несколько лет.
Wesley
Wesley,
It looks as if you have removed all of the Coleman videos you had at you tube, is this correct or am I looking at the wrong place?
I imagine someone else got the same phone call C&D
Being that Tesla had his lab burned right when he began investigating LENR with particle beams and X-rays and the power of liquefying /cooling gases perhaps the gatekeepers on this info are much older and more informed than we care to conceive. Who was pulling Mr Morgans strings?
QuoteВизив, может привести к распаду России примерно в 2024 году.
What for? Most people have made their choice. They want to be slaves.They are all happy.
Quote from: mkjekyll on December 30, 2019, 11:29:54 AM
Wesley,
I'm in the run so quick answer
Please check if links works
https://youtu.be/-PMMK4KHXYU (https://youtu.be/-PMMK4KHXYU)
https://youtu.be/Mk3ku_dBzBM (https://youtu.be/Mk3ku_dBzBM)
https://youtu.be/V5jFtrpatrA (https://youtu.be/V5jFtrpatrA)
https://youtu.be/5x-qMfdZngo (https://youtu.be/5x-qMfdZngo)
https://youtu.be/K1f6EBx9GtY (https://youtu.be/K1f6EBx9GtY)
https://youtu.be/WpBpk1Cg7ns (https://youtu.be/WpBpk1Cg7ns)
https://youtu.be/gKkcdfSdt5Q (https://youtu.be/gKkcdfSdt5Q)
https://youtu.be/1wCPOr3RSNo (https://youtu.be/1wCPOr3RSNo)
https://youtu.be/QucsK2hg0eo (https://youtu.be/QucsK2hg0eo)
https://youtu.be/w2nGASfHso0 (https://youtu.be/w2nGASfHso0)
:) Wesley
Quote from: kolbacict on December 30, 2019, 11:42:04 AM
good comment
Wesley
Wesley..I am presently using the Ferrite TV core with 50 / 15 primary + 150 cadaceous secondary coil setup.
My system uses a "resonant / feedback" using home-made 2(two) - 10" bifilar pick-up coils (only one thread in each is used though) made of 40 gauge wire.One measures 11.6 mH, the other 9.95 mH. I measure 1.5- 4v output from these.I am only inputting to the 15 turn,the 50 turn has a capacitor across it.My scope is the PCSU 1000.
These coils (antennae) need careful adjusting relative to the 2 "di-pole" output wires from the amp to the core.This is where an avalanche / feedback signal seems to be generated the most.The bubble area surrounding all this is also RF sensitive.
https://www.youtube.com/watch?v=OCPEYxvkelM
https://www.youtube.com/watch?v=Manv1aDJqa0
These coils, alone, feed an OPA541 which I have ran as low as 12v and as high as 40v. (I ran one at 50v and broke it). The best output I have gotten from the core, measured by my Sper-Scientific microwave / RF meter, is 1.612 when running the amp at 18.5 volts / .49 amp.(max is 3 on the meter,and average is .5 or 1/2 and alarm goes off exceeding 1.0) .I have no problem getting that core to resonate at 1.14 MHz with ~ 100-400 KHZ undertones,and semi-lighting a 14watt / 120 volt bulb. I can run it up to 39 volts @ 1.8 amp and get a better bulb output. My AM radio also lets me know when the core is resonating.
Problem is there are about 7 or more resonant points varying in voltage/ current usage of the amp-but only one special one at 18-20v (also at ~ 1.14 MHz) that will just pop-up and the core just takes off--Ive seen it as high as 2.2.The coils must be extra carefully adjusted to hit that certain spot,but still I find no great gain of input to output voltage / current relative to any other.When it resonates at whatever voltage/ current the bulb starts to light.
So..do I need to wind a "Grenade" coil and and run the core output to this? I assume the "Grenade" coil is used as an air core transformer due to the higher frequencies it can handle.....Can I then expect a higher flux density for the input voltage / current---I expect an additional 2 amps will be needed to run that coil too.I have already ordered a bigger OPA amp and will be ready.From what I measure I am using up to 1.5 amps at 39 volts to half light a 124 ohm,120v .12 amp bulb.
Not looking too good right now.
Also..I did light a 4 watt bulb pretty good using a 12v Radio Shack 27 MHz CB transceiver with a 7" diameter coiled 10 foot RG59 cable and a MUR120 30MHZ diode on the cable end.Got a video on that too. I estimate .14 amp @ 13v to half light a .05 amp / 120v bulb.
Ray with all due respect Wesley has gone into depth concerning the VNA on this thread including model numbers spelling out the words and even helping advise me on proper models for the process. It would be a bit of a hassle to write out Vector Network Analyser each time therefore the contraction. These things are expensive units and not well understood by engineers outside the bounds of hardcore RF such as antenna design. Basically a network analyser allows one to compare the incident and reflected wave against a transmitted signal over a selected bandwidth as quickly as possible. There are two type Scalar and Vector where the scalar measures magnitude and the vector adds the phase component which is pretty important for studying boundary type waves.
Wesley, thanks for the links, very good. Could you recall a device in your video you quickly flashed on "Resonant Nuclear Reactor" and provide some insight to this?
Have a wonderful New Year!
Wesley hi there I wonder if you can help me, I think I'm writing about Ruslans Video 1kw5 dated the 3/1/19
you made a split-screen video translation, what I want to ask is concerning that and a couple of other videos
that appear to employ spark plugs and LOPT high voltage, I notice you have a well-stocked lab and what my self
and a couple of the other lads were wondering if you know or have looked at the speed in nanoseconds or microseconds
of pulsed energy sparks or if you can comment on this, please.
Kind regards and wish you a happy and prosperous new year
Raymondo
Quote from: mkjekyll on December 31, 2019, 09:07:15 AM
please provide me with link related to your question.
whatever exists in big scale it exists in small scale too
https://www.youtube.com/watch?v=ZkBFWp5d9x0Have (https://www.youtube.com/watch?v=ZkBFWp5d9x0Have) a wonderful one too. :)
the exact point is here : https://youtu.be/ZkBFWp5d9x0?t=633 (https://youtu.be/ZkBFWp5d9x0?t=633)
Wesley
ps: some fundamentals:https://www.youtube.com/watch?v=989mSwMvcWQ
https://www.youtube.com/watch?v=5FUpzT74z3w (https://www.youtube.com/watch?v=5FUpzT74z3wsome)
links from the past
QuoteMichel Meyer invented a very neat way of excitation of nuclear reactions by nuclear magnetic resonance.
I also came to this idea, but I found it difficult to determine.
It uses a resonance in ferromagnetic materials, and huge values of the magnetic fields inside them.
Such principles are similar to some works of John V. Keely
Мишель Мейер придумал очень изящный способ возбуждения ядерных реакций при помощи ядерного магнитного резонанса.
Мне тоже приходила такая идея, но я считал ее трудноосуществимой.
Он использует резонанс в ферромагнетиках, и чудовищные значения магнитных полей внутри них.
Подобные принципы схожи с некоторыми работами Джона V. Keely
Michelle Meyer a inventé une façon très soignée de l'excitation des réactions nucléaires par résonance magnétique nucléaire.
Je suis également venu à cette idée, mais je trouve qu'il est difficile à déterminer. Il utilise une résonance dans les matériaux ferromagnétiques,
et d'énormes valeurs des champs magnétiques à l'intérieur. Michelle Meyer inventó una manera muy clara de la excitación
reacciones nucleares mediante resonancia magnética nuclear. También llegué a esta idea, pero me resultaba difícil de
determinar. Utiliza una resonancia en los materiales ferromagnéticos, y grandes valores de los campos magnéticos dentro de ellos.
Wesley
longitudinal wave behavior
-that is mechanical wave
https://www.youtube.com/watch?v=gRu8TTudpb0 (https://www.youtube.com/watch?v=gRu8TTudpb0Wesley)
Wesley
Dear magnetstoo thank you for your experiment
I need some more time to understand it.
For past few months I'm in and out, not even having time for my videos
Wesley
Was there anything other than radiation in the experiment with the Coleman tube? Electricity from the output. ?
Mr. Wesley..I can only imagine how busy you are from all your videos....I have since increased the output by 50% and perhaps achieved nearly 66% efficiency compared to a direct 120v outlet connection.I have eliminated the 50 turn and the inner copper liner, I have also eliminated the 5th coil and now using a previously unused thread of one of the antennae coils...Im now running only the 15 turn inner winding for input....It is a delicate balance but I have a ( what appears to be ) 33% lighting of a 20watt, .16a , 120v, 66.5 ohm Xenon bulb with only 43.5 volts @ .2 amp @ 90 kHz...This would equate to approx. 130 volt @ .07amp for this 120 volt .16a bulb running at about 33%..I can turn my AM radio on also and NOT get the static background but a nearly clean AM broadcast because the system is "locked in" as it were.. The spectrum analysis shows multiple peaks up to 3+ MHz at the output of the Ferrite ...My OPA541 amp is only good to 40 volts.I have not received the big one yet.I have some minor heat loss in the amp ( do not need a fan now) and the 15 turn winding. I am also using a 2.4 volt (square, sine,triangle...does not matter much )input @ ~ 180 kHz from my "Wavetek" signal generator into one of the unused coils for a back resonance.There certainly is not much current in these coils as they are 38 and 40 gauge wire @ about 11mH. Input voltage to the OPA541 from the antennae appears to be .1v..or perhaps 1v when measured with an analog meter.....Frequency should be 90kHz. Input frequency = output frequency...
I am hoping to add and receive some insight into how to increase the magnetic field output..I am applying some of Don Smiths ideas also.If any one else
has some ideas and a near working model,Id like to hear of what else I can do, short of winding a grenade coil which I may end up doing, as it looks as if I have reached the end of efficiency with this present set-up..because I have tried to update what I can..I will post to Y-Tube when I get organized...All in all it all appears to be ( must be ) a smooth transition between input and output As Don Smith said "They must talk to each other"...My output amp is running far far cooler than it did, to light the same bulb at the same brightness.
If you wind the secondary coil in the opposite (left hand) direction
The magnetic field induced will oppose the primary
(current will run in the same direction in both coils)
This will amplify the magnetic field in the core (ferrite/air/etc.)
[note: this only works with connected core transformers.
Toroids, square/rectangle loops, connected plates,
"U" transformers, etc.
Where the magnetic field loops back on itself.]
{air cores are 3-dimensional spacial fields
independent from the physical coil}
Happy New Year!
After some time without overunity.com I decide to go further with my "investigation" or search for the true.
All I see here from Wesley is idea of Standing Wave induced "hot spots" in the area of Planet Earth, which is plausible.
But, I don't want to be that person which will live in that "hot spot", because of health damage in long period of time.
About "how Kapanadze make that trick" I think I have more simple explanations.
Lets go in to the past. All talks from Kapanadze was about 700kHz...
Are you remember that?
Very many peoples remember experiments with Tesla Biffilar pancake coils and Induction ovens...
Frequency is from 28kHz to 50kHz in many Induction ovens.
Remember that, no one was electrocuted when peoples take load (230V 100W-1000W lamps in full bright with no isolated wires connected in water)!!!
All internet is full with these videos and I myself was the part of "investigators" in Latvia...
Secret is here - High Frequency can be transferred trough water and Earth and "ground pipe".
There is no Free Energy.
Kapanadze use 700kHz Amplitude Modulated Transceiver.
All remember "relay click" activated with 9V battery?
This relay just make connection with AM receiver, which was part of all tricks.
Remember SR?
Remember "must be "good ground" ;D :o :) ...
This is it!
Happy New Year, Wesley and others!
P.S. Don`t try to make Energy from nothing, you will fail!
Interesting plausible hypothesis Ansis if he was a crooked fraudster, although I would still give Kapanadze's patent the benefit of the doubt at this stage for its alleged authenticity, if it was not for the fact that he shares similar common electrical schematic topology techniques with other 'free energy' researchers & developers such as Don Smith, Ed Gray- Marvin Cole Motor, Bedini, Nikola Tesla, and Alfred Hubbard.
If you can easily dismiss him, then all these other inventors don't have a leg to stand on I guess.
We see no results.
All "Dons Smits" talks are just talks.
Energy cant be created from nothing.
This is real life.
Everything is not free.
Energy is created by man, here on the Earth.
All kinds of energy we can transfer, but we need energy.
Kapanadzes patents are based on Energy Magnification...
It means we need energy(accumulators) for Amplification...
All accumulators go flat.
Only transfered energy can be received and can do usefull work!
Free Energy is never existed in Nature.
All energies have "father"... :).
Space Energy comes from Space.
Water energy comes from flow of river.
Heat energy comes from wood, coal, nuclear...
So it goes.
Be happy!
Quote from: Ansis on January 08, 2020, 03:32:16 AM
When ? whare ?
I only heard 200 kHz when he says Kapanadze. Also that it can be 50Hz output 100Hz 400Hz.
However, what you say may be true were it not for the fact that the device was also 100kW and several people worked there. If there was a ~700kHz connection from the ground, the power would also have to come from the ground! even more than 100kW. So where were they connected? To the transformer of the local power distributor? maybe, but it would have to be a scam.
Yes, I hear the relay jump and this was confirmed by Wesley as he was at Kapanadze but it does not help because this mode can be used for other purposes.
When the measurement is made via a clamp meter it shows correct current readings. This is how it looks, so the clamp meter would have to be ready for 700kHz reading
Quote from: Ansis on January 08, 2020, 05:07:22 AM
We see no results.
This is real life.
So it goes.
Be happy!
You are very wrong. You live because there is energy everywhere. We want it in the form of electricity and it is difficult for us.
...Kapanadzes patents are based on Energy Magnification... YES but maybe it is converted (fridge and others devices)
All information about Kapanadze talks is from his tapes, recorded 10 years ago by russian or ukrainian enthusiasts...
In fact pipe is ideal energy transfer line.
Pipe is Amplitude Modulated by 50Hz with 700 000Hz main frequency.
Of course Kapanadze is greate man!
He is genius!
But?
David Copperfield is genius too!
Energy is in all mass.
Mass causes gravity, which is a separate quantity of energy.
a potential energy based on the locations of the masses.
Therefore, space itself contains energy.
(mass and 3-d distance)
Gravity is the potential energy of 2 masses to become 1 mass.
(which increases the total energy of the mass by the additional mass)
Therefore, mass in the presence of other mass creates energy, relating it
in the form of kinetic energy, as it combines its energy with that of the other mass.
Total final energy of the mass system is the same as before they approached each other.
However, the change in kinetic and potential energy was created AND transferred elsewhere
as they were approaching.
Let's take this a bit further and consider galactic masses (countable) infinite distance apart.
There is (countablly) infinite kinetic energy between these galaxies.
Infinite!!!
Defined only by the special dimensions and the magnitude of the mass.
So by increasing the energy of a mass (by adding more mass) creates energy from the vacuum.
If the universe is truly "expanding", then the potential energy of the universe is infinitely increasing.
It is practically unfeasible but totally "possible" for us to create gravity generators
By placing solenoids on asteroids in space.
As they approach, the kinetic energy of gravitational acceleration is transferred into
the induction coil.
And after an elastic collision sends them in different ways, the
universal expansion increases the potential energy between them.
This is, by definition, perpetual motion / overunity.
And completely accepted by modern physics.
Furthermore: the accepted value of universal expansion is an accelerating
quantity. Thus, space itself is infinitely increasing in potential energy.
This includes the space we live in.
Quote from: sm0ky2 on January 08, 2020, 09:40:36 AM
the induction coil.
Sounds like pie in the sky and beyond most people's scope of reality. ;D
Good morning!
I discover interesting thing relaited with old LiPo batteries!
Batteries about 10-15 years old, when they are lose capacity, is turning in to SuperCapacitors with capability to recharge themself. Of course energy density after "recharging" period of 12-20 houres drops down, but it is amayzing. My setup is made from 3 old+1 old, but not compleatly dead LiPo 18650.
I watch this YT video about quantum battery.
Very interesting.
https://youtu.be/7fM4e0cx5zU
Thats all for now.
Yes, for better results 3 batteries must be dry and we must go and destroy elements by charging them with 25Hz DC impulses and Voltage must be around 9Volts and Voltage on the batteries in that moment must be 5V DC.
Good luck!
Ansis,quote
Good morning!
Very interesting.
https://youtu.be/7fM4e0cx5zU (https://youtu.be/7fM4e0cx5zU)
Thats all for now.
Good luck!end quote
maybe start a topic ?
I will drop in Plengo topic [great open source experimenter here with dry "energy harvesters"
Chet K link here https://overunity.com/15035/crystal-cell-research-for-experimenter/msg541798/#msg541798
more info PLEASE ?
OK.
I just observed possibility of "second life" for old stuff with interesting properties.
I just give the idea, not to throw away but use for projects? or whatever.
Ansis
yes some will say "not safe" or other comments
if you could give more detail ?[new topic maybe ?
to understand recycling these or this "back to life" ??would be nice to understand
and a great open source project
thx Chet K even start new topic in Wesley section?circuit timing etc etc seems simple at a glance
I forgot to include data taken from the output of the core,after the bridge diode, to the 125w bulb...#6 is a Log of the spectrum showing the wide spread of frequencies and the falling off around 2.5 MHz -of which I found also an interesting region.Core has a natural rez about 1.14 MHz.Also a picture of the 125w bulb--(grow lamp for plants) it has a blueish coating.The picture is close to its actual brightness,perhaps a bit brighter.
Quote from: sm0ky2 on January 08, 2020, 09:35:36 AM
There is (countablly){countability only has one l} infinite kinetic energy between these galaxies.
Infinite!!!
Would anyone be prepared to challenge this idea as to what gravity actually is and how it really works
I know the above idea is outdated and it is more about electricity and vibration and the way electrons and protons are bound and pull and bind together in order to lessen their potential charge and are thus
strongly attracted to the center that being the center of the earth where there charge wóúld be minimal.
and gravity as far as mass and weight is just an effect of the elusion this assumption is based on.
Raymondo
Sorry...I made a big mistake assuming perhaps the 125 watt was 1/3 brightness.
I did a direct hookup of the 125w bulb to the D.C. var. power supply.
My devices output compares to 20 volt / .4 amp , -my device consumes 44 volt
/ .4 amp....nowhere near even 1/3 brightness either .I kept looking and doubting
about the output,yet, how to measure it..Oh,and sorry for the monster size pic of the bulb,
I grabbed my camera while I was uploading, and did not realize the setting I was using....
If the coil / antennae idea intrigues you, Ralph Grimes of RWG Research on You-Tube was
making them with up to 46 gauge wire. I have long since taken my coil maker apart.The bi-fi coils
were just a curiosity at the time..I wondered "what if I had a bi-fi coil that had very small wire and how would it respond to RF ".
..You cannot shove much current through these obviously
as they will burn up,or arc..My filament ends are separated so I can wire them any way I wanted.I use them now as singles.
Hi Wesley and others!
I study the oscillatory circuit in resonance and the removal of reactive energy from it with the help of short and powerful pulses.
Remember SR193 - "Create a low-cost electromagnetic field, and then just move it."
something current for today:
https://www.youtube.com/watch?v=Dbnc1M944RA&feature=youtu.be (https://www.youtube.com/watch?v=Dbnc1M944RA&feature=youtu.be)
ZPower Recent Technology Demonstrations
for comparison when you klick at underneath of main window at
Reed Huish (https://www.youtube.com/channel/UC6R8eugtg32UsCZDhSjixsw) Youtube
it gives you all old videos from the same guy from early 1990 and 2000.
https://www.youtube.com/watch?v=2RBPGlW8hXQThis (https://www.youtube.com/watch?v=2RBPGlW8hXQThis)
this video shows how plates are made.
Wesley
Quote from: stivep on January 11, 2020, 07:41:27 AM
Wesley
They haven't found the investor for so many years? now they probably show it in India. If he took only 1-10 $ from anyone willing to make his device, he would have been a millionaire long ago.
What is wrong ?
:D Потому что его устройство похоже на батарейку, а обработка
встроенным компьютером вообще не увязывается с получением энергии, слишком сложно оно устроено!
Translated by moderator:
Because his device is like a battery, and processing by the built-in computer
is not at all linked to energy production, it is too complicated!
Quote from: DELAMORTO on January 11, 2020, 08:40:55 AM
:D Потому что его устройство похоже на батарейку, а обработка встроенным компьютером вообще не увязывается с получением энергии, слишком сложно оно устроено!
Yes I see what you mean, and it's great to see you hear, welcome.
Я уверен что в установке свободной энергии ,
Капанадзе использует раскаченный колебательный контур, как основу для накопления электромагнитного поля в катушке.
На это поле он воздействует коротким, но мощным электромагнитным импульсом, сдвигая поле в катушку съема.
Как пример- схема, не уверен что именно так , но похоже!
translated by moderator:
I am sure that in the installation of free energy,
Kapanadze uses a swayed oscillating circuit as the basis for the accumulation of the electromagnetic field in the coil.
This field is affected by a short but powerful electromagnetic pulse, shifting the
field into the pickup coil.
As an example, here is a diagram,
I'm not sure what it is, but it seems like !
I have problem with analysis
https://www.youtube.com/watch?v=zE4GjB1cWLQ (https://www.youtube.com/watch?v=zE4GjB1cWLQ)
https://www.youtube.com/watch?v=XOTLfnMOSqQ&t=301s
(https://www.youtube.com/watch?v=XOTLfnMOSqQ&t=301s)https://youtu.be/yNs2wc8nRJw?t=277 (https://youtu.be/yNs2wc8nRJw?t=277)
Wesley
Quote from: DELAMORTO on January 11, 2020, 09:45:37 AM
I'm not sure what it is, but it seems like!
Hi and Thanks for the diagram and it's an interesting view and much appreciated of the idea concept, have you a better much higher HD quality image you can share, please?
Привет и спасибо за диаграмму, и это интересный вид и высоко ценится идея концепции, не могли бы вы поделиться гораздо более высоким качеством HD-изображения, которым вы можете поделиться, пожалуйста?
Raymondo
Kapanadze in the video said- "this is the classic Tesla scheme, only no one could make it work!"
Watch the video with the can, all the wires that go to the can are low current, only the wires on the reel itself are thick! So the current is formed in this place. And what can heat the wires - the oscillatory circuit in resonance! But no one could remove energy from such a circuit (again we recall the words of Kapanadze)
Kapanadze was able to squeeze out energy from the circuit! This is his secret.
Принцип очень простой- есть колебательный контур, последовательный или параллельный, который накапливает в себе электромагнитное поле Все знают, что там гуляет огромный реактивный ток, но извлечь его нельзя - рушится резонанс.
Но я думаю, что используя индуктор и разряд заряженного до высокого напряжения конденсатор (схема Теслы), можно это поле сдвигать в сторону катушки съема, создавая в ней ЭДС!
Я вы знаете давно веду поиски, но этот вариант мне пришел в голову совсем недавно, на новый год, я буду проверять эту теорию сам и предлагаю всем кому интересно это сделать тоже!
The principle is very simple - there is an oscillatory circuit, serial or parallel, which accumulates an electromagnetic field in itself. Everyone knows that a huge reactive current is walking there, but you cannot extract it - the resonance is collapsing.
But I think that using an inductor and a capacitor charged to a high voltage (Tesla's circuit), this field can be shifted towards the pickup coil, creating an EMF in it!
You know, I've been searching for a long time, but this option came to my mind just recently, for the new year, I will test this theory myself and suggest that everyone who is interested in doing this too!
stivep, вы понимаете - что где есть ЭДС, там есть и ОЭДС. Среда упругая на электромагнитные импульсы, она может возвращать поле обратно в колебательный контур, тем самым производя колебания переменной частоты в катушке съема.
Когда мы как контур пинаем поле в катушку съема, а среда ее возвращает обратно в контур.
Частоту резонансную может задавать генератор, это самое простое.
Посмотрите видео " аквариум" при включении идет звук перегруза трансформатора, это накачивается колебательный контур, ток падает потребления когда контур раскачен, для поддержки его колебаний не нужно много энергии- мало затратное электромагнитное поле !
Quote from: DELAMORTO on January 11, 2020, 11:02:18 AM
stivep, you understand - that where there is EMF, there is also OEDS. The medium is elastic to electromagnetic pulses, it can return the field back to the oscillating circuit, thereby producing oscillations of variable frequency in the pick-up coil. When we kick a field into a pickup coil as a contour, and its medium returns back to the contour. The resonant frequency can be set by the generator, this is the simplest.
Watch the video "aquarium" when turning on, the transformer overload sounds, it oscillates, the current drops when the circuit is swayed, it doesn't need a lot of energy to support its vibrations — low-cost electromagnetic field!
Please understand Delamorto that we here in Western World of physics don't take anything by descriptor <<
it is>>
Пожалуйста, поймите, Деламорто, что мы здесь не принимаем ничего, в Западном мире науки, используя слово « есть ».We also don't use word Elastic medium (Среда упругая) without specifying of what exactly it is, based on properties of that elastic medium.
Мы также не используем слово Эластичная среда Среда упругая без указания того, что именно это такое, основываясь на свойствах этой эластичной среды.There is process before
Есть процесс, прежде чем есть :Quoteproducing oscillations of a variable frequency in a coil
Explain that process please
Объясните пожалуйста этот процесс
Wesley
Wesley, сделайте колебательный контур, замерьте какой ток в нем гуляет в резонансе, греются и конденсатор и провода.
Эту энергию никто не мог использовать без разрушения резонанса в нем.
Капанадзе видимо нашел способ по Тесла.
На фото я вижу конденсаторы и катушку- это колебательный контур!
Quote from: DELAMORTO on January 11, 2020, 10:46:23 AM
You're wrong. Kapanadze uses solid 1 wire.
Without getting too involved here would not harmonics fit into this Categorie of the drawn-out elastic band.
Raymondo
Quote from: stivep on January 11, 2020, 11:46:09 AM
You welcomed with any findings thank you for that.However you didn't respond to my questions from above. Can you?
Мы приветствyeм вас с любыми выводами, спасибо вам за это.
Однако вы не ответили на мои вопросы сверху.
Ты можешь....прежде чем вы углубитесь в то,нa чем вы пытаетесь сосредоточить наше вимание??
Простой вопрос :
от куда энергии берется и как
от куда Энергия берется до того,и как она попадет на устройство.
Объяснить весь процесс
Wesley
DELAMORTO replied that it was an oscillatory circuit. They call it REKTIVKA, I think you know what it is.
The problem is that no one can get that power out of this circuit. It is only in calculations and measurements before loading. When you do load, the resonance falls and the circuit begins to operate normally.
Until the phases overlap, it looks like kW, that's why some see power here.
r2fpl, да именно так, как сказал Капанадзе- никто не мог заставить его работать.
Весли, а по вашему что потребляет 60-100ват в видео "Банка" ? Это накачка колебательного контура!
Have you gotten that Los Alamos radiation meter? Probably Opengheimer worked with this yet. :)
I also want this. ;)
I now have a 250 watt, 2.2a, 4.1 ohm IR bulb running on my system.Bad thing is, brightness is only about 1/10 of what the actual output would be if the D.C. input was applied straight to the bulb. Power input is now 48v @ .85a---I received the OPA 549,it works fine but has a 30v limit,so Im using the OPA541 with its 40v limit pushed to 48v.Overall the core still runs cool but the heat sink on the OPA is getting rather warm.I had to re-adjust for the 250 watt,now the IF is down to about 95 kHz from the previous 190 kHz,and the output at the bulb is now 45kHz from its previous 100kHz.There is one small area where the antennae adjusts,about 1 sq.in, where the bulb lights the brightess. The AM radio still has a clean signal with no static,but no stations can now be heard so I assume its over-riding the 455kHz IF.
Let me add this unusual fact about this---this 250 watt has the same "color" or " brightness" as the 4watt I tried,the 20 watt, and the 125 watt,....It all appears as if the voltage is constant in all of these,but the amperage is what varies with the load, (that is just an observation) .....Why I cannot fully light a 4 watt / 125 volt bulb puzzles me when I can light, just as easily, this 250 watt bulb....But Im on the case...I have 45 KHz to go.
This is the first time,as I recall , Ive seen such a frequency drop in my IF stage.Did not appear to drop before,but things changed when I tried the OPA549 and then switched back....I have noticed this drop in earlier trials with this split core setup,but I was using Neon bulbs as the load in which case the voltage output kept going up,I had 1700v before the 7 watt stereo amp driver gave up (I think the 1700 volts back-flashed)..It was never the same after.
Im not trying to "ramble", just letting anyone interested know the data I have accumulated.
I now have 375w hooked up ---(again, only 10% output / input ratio)---I have included some measurements taken direct from the antennaes ( L-coils ).
Also ,the ground line I use is about 40 feet of what appears as silver coated, multi-strand, 2/0 wire.It was a little expensive but not the worst in price.
The system did not drop in frequency adding the extra 125 watt,so I have not reached that limit yet I guess.I also found that with a smaller load the core output can be run off just one leg of the 150 turn cad. coil...Also, the IF stage can be eliminated too but a small load and careful tuning would be needed.
I hooked up a 120v / 250 watt, 67 ohm heating element and it reached 125 deg F inside 15 minutes with an input of 48volts / .28amp..It will draw twice more amps but will not be as efficient. I can tell by the output on the scope when it resonates or does not. I guess the OPA541 absorbs this extra current, because I cannot find any where else it goes.
What are these plates? Outlined in color.
This is a good example of an excess energy machine. The process of which is defined clearly and has been replicated and exhibited in other patents and applications.
Clear explanation of known principles
No hogwash pseudoscience such as fancy waves and surface energy that Wesley goes no about
https://patents.google.com/patent/US20160049839A1/en?assignee=Arion+Technologia+Brasil-Gestao+De+Ativos+S%2fA
Quote from: endlessoceans on January 14, 2020, 08:36:08 PM
https://patents.google.com/patent/US20160049839A1/en?assignee=Arion+Technologia+Brasil-Gestao+De+Ativos+S%2fA (https://patents.google.com/patent/US20160049839A1/en?assignee=Arion+Technologia+Brasil-Gestao+De+Ativos+S%2fA)
https://patents.google.com/patent/US20160049839A1/en?assignee=Arion+Technologia+Brasil-Gestao+De+Ativos+S%2fA#legalEvents
Wesley
Quote from: stivep on January 14, 2020, 09:13:35 PM
Wesley
This guy only makes dummies. Others also confirm this.
I talked to him and asked why he did it. He replied that he had a purpose in what he was doing.
Just read the patent and then read how much MION reaches the ground to understand that the guy does not know what he is writing about.
I found in his movie the moment the device turns off before turning off. It looks like someone next to him turns the device off and on or is controlled.
https://www.youtube.com/watch?v=G7oYqjiiQJg
https://www.youtube.com/watch?v=D-mVLHf5ws4 ===== https://www.youtube.com/watch?v=E5PtzEVMe7k
It is enough to understand that it is a transmission of energy. Wesley showed the same thing a year ago with a light bulb. Is this an FE? NO !
In the light of modern scientific view we all should know that energy can not be created or destroyed so all devices must transmit and/or convert energy from one state to another , from one place to another.
QuoteMy friend Māris Slanārs, will give you 1000$ if you will make perpetum mobile device which lite up LED diode which will never ends!
What about this?
https://www.youtube.com/watch?v=5ho0_obiakM (https://www.youtube.com/watch?v=5ho0_obiakM)
Now keeping that in mind how LC circuit can increase energy?
Common knowledge is that resonant tuned LC circuit multiply/increase voltage or amperage and its not at the cost of other like electrical transformer.
So what transmitts energy in to this circuit?
Thx
P.S.
If you object this point of view please direct me to publications that states this is not happening.
Video with old man and swinging weight needs one old man energy.
Or need energy of 1 slave.
P.S. If we take electric-mechanic "arm", that energy will exeed power of "created energy", because of work.
The only man which I know is YT user "lasersaber" who made devices with very small consumption but with no real work capabilities. He use it for longlong time spiners or microAmp light emiters.
All devices consume power from power sources like Capacitors, SuperCapacitors, Batteries or Nuclear batteries.
Very interesting!!!!
But no Free Energy!
Quoteansis
But no Free Energy!
You cant consume something that cant be created or destroyed. Simple rule that changes whole logic
Quote from: groot on January 15, 2020, 08:45:55 AM
SO WHAT HAS THAT GOT TO DO WITH ANYTHING HERE, This could be confusing but what I'm saying is a Generator just agitates
electrons magnetically (they don't really go anywhere) the same goes for ZP when they get excited when they hit obstacles and get hot
they don't get manufactured or destroyed, but don't forget the sun generates magnetic radiation that's hitting the earth that's FE plus other radiation that can be absorbed and converted into something else.
Raymondo
Dear Raymondo
Do you know how pendulum works?
You put it in high potential state and release it.
Potential energy gets converted into kinetic energy.
Lets say there is no or minimum friction than all potential energy gets converted into kinetic energy and process repeats itself once there all energy gets converted because you created unbalance. Nature, ambient needs ballance. So youre kinetic energy must convert into potential again.
GENERATOR it provides you with potantial energy always. You get kinetic energy only when you short the output.
If you were using up energy only in all devices why pendulum wont stop as soon as energies are equal? Instead it keeps going past balanced point and itself creates unbalance?
Potantial is the cause. Kinetic , amprege is only the result.
You can have potantial without kinetic energy amperage but you cant have amprege without potantial.
Broadcast station is not wasting energy radiating, it transfers energy back to ambient medium. Thats the purpose of radiation. Waveguide is much more efficient for energy transfer but not as convenient cause ambient is everywhere.
Go to tesla lectures he explains all of it much better than i am.
Thank you
https://www.youtube.com/watch?v=_L--KkMFh7Y&feature=youtu.be
Wesley
Quote from: groot on January 16, 2020, 07:22:00 AM
To Wesley.
Wkoncu cos zaczynasz kumac. ;D
Pozdrawiam
Any one Be aware, the legal term to understand means to admit and become a subordinate by entering a contract usually with the legal mafia.
I doubt this any different anywhere on the planet.
Regards Raymondo
About video of Okki.
Earth ground is active after 100V AC.
It means Ground wire act as independent "pole" for AC circuits.
All schematics act with Ground wire like 0(ground).
If we push frequecy up, this will improve "connection".
I experiment with this kind of circuits.
After 200V AC, effect is much better.
But, we can't make Free Energy from it!
Circuit eat Current anyway.
But like I sad, we can make illusion of Free Energy, because Earth act like short circuit for AC one pole(ground).
I think Kapanadze find it and make circuit which create illusion of energy creation from "aether".
It is very spectacular in deed!
When we go to circus we pay money for show!
For better understanding we must know, Earth is full with "free Electrons"!
In OKKi experiment we see Current drop.
It means "ground electrons" go to another direction!
From ground to circuit!
Wait 1 minute and I'll find a movie about Lightning!
https://youtu.be/RLWIBrweSU8
In the movie look at the Streamers from Earth!
Lightning come from Cloud, but Earth answer with "free electrons" from the Earth side!
Dear Ansis i have an idea.
Please take 2 amp meters one single cell battery and a light buld ( 1.5v 0.25amp preffered)
Connect light bulb across battery in series with both amp meters. As: positive pole of battery connects to amp meter [1] then amp meter to light bulb , light bulb to amp meter [2] and amp meter [2] to negative pole of battery.
Please observe the reading and tell me how many amp was consumed by the light bulb?
According to your post there should be more amps before current enters the light bulb then after current exits the load.
QuoteBut, we can't make Free Energy from it!
Thank you
Both Ampermeters in series give identical mesurements.
I don't understand joke.
P.S. If you have good low resistance Ampmeters, everything is correct!
If you have high resistance Ampmeters, you can observ mismatch.
Thank you for your reply Ansis
Why you think im making a joke?
This simple experiment disprove your claim that circuit is "eating up" the current.
If you attach earth grounding will this make more current?
No? But wait what about all the free electrons you introduce to the circuit?
Earth grounding is a part of safety system of a circuit breaker. It gives a current safe path of low resistance so circuit breaker can activate and you dont get electrocuted.
This has nothing to do with free electrons in earth other than low resistance conduction.
Tesla coil can be grounded. It performs better. Is it free electrons from earth? No its ground plain image that makes tesla coil perform better and not free earth electrons. Tesla coil is nothing more than 1/4 wave antenna. Only difference is that tesla coil radiate poorly compered to radio antenna.
I assume you compare current in a circuit to fluid that os accumulated in enclosed vessel and circuit is a bridge, pipe as you like to empty vessel.
If its so then current should be less then what it is before it enters the load. But is not and you just confirmed that.
This means that current is not a fluid that performs work and is being used up, converted in quantity.
Since your light bulb has specific resistance current can reach only level set by known laws of ohm.
If you use light bulb of lower resistance current will increase.
Does that means your battery can produce more current. ?
No it means current depands on resistance of the path , your bridge between dipole.
So why battery is being drained off current since it does not create current? Current my friend is only the effect of killing the dipole. Dipole does not create current, dipole creates condition of unballance that ambient medium try to fix by ballancing and effect of it is a current in a closed loop. Without closing the loop ambient cant react to presence of a dipole.
More to come if you are interested. No jokes only lessons.
Thank you
Your true is only in your Universe!
All Free Energy believers, make they'r own reality!
Dipole is negative and positive wave ballanced in the antena which is constructed for perfect match.
It is radio.
Dipole is AC if you want, every frequency have physical dimentions according with frequency.
Radio physics.
Nothing more.
P.S. I believe in Free electrons of the Earth and that is my crazyness if you want!
Free Energy is hox and I believe in that!
https://www.youtube.com/watch?v=_Ec7ba6vutg
see time 6:40 after all video
However, it doesn't matter because you need potential relative to the earth. I do not know the production method only + or - without costs.
If you find such a method I showed you when the electricity will come from the ground.
Are these your "free electrons" happy?
Only V changes on the other side.
Groot Thanks for your interesting analysis of how power can be taken from a battery, but what is happening is a chemical reaction is taking place and once the 'reaction' of consuming the fuel produced by that reaction the dipole will die. Unlike dielectric radiant electricity is eternal! Re Top Beardon reference. Have a look on youtube POT of GOLD I think what Wesley is trying to get across is explained in the last four videos.
Happy days!
Raymondo
Maybe someone try this?
It is well known as "resonance transformer".
Maybe here is someone who can tell - Yes, I try it and this is it! Or - No this is BS!
Thank you!
And why in smart books about ferroresonance they write that when a ferromagnet is placed in a magnetic field, the spins of all electrons will be oriented
in one direction ? And the sample shall magnetized. But what about
Pauli's principle that on the same orbital cannot be with the same spins ?
Maybe this will help you in your understanding?
http://aboveunity.com/thread/non-inductive-experiment/
This guy is a bit of a kook sometimes but he does good work.
In general, this is to Rakarsky. It was he who offered a lot of flashlights.
p.s.
Quotehttp://aboveunity.com/thread/non-inductive-experiment/
Thanks. think about it.
I work as far as possible.For me.
Quotehttps://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/174755/
The author mentions some sort of sawtooth impulse.
There are no sawtooth voltages in this circuit.
I made similar designs. There are only impulses, meander.
Платите мне $100 один раз, но с каждого пользователя! Я открываю принцип Капанадзе!
Будем смеяться все!
Весли, я видео в личное пошлю, оно только для ваших глаз, как подтверждение этой схемы!
Think you know what reality is? think again!
the real world of quantum mechanics, REALY? more like Scientific madness comes LIGHT what is it and how does it intertwine in our interest?
https://www.youtube.com/watch?v=ISdBAf-ysI0
New intrigue! Even Kapanadze is surprised!
The fact that the Resonant circuit was dispersed, it is clear that the question was removed without disruption. I think by electrostatic induction.
https://www.youtube.com/watch?v=2sj7FHiXje8
https://www.youtube.com/watch?v=9X8G57ZAmds
QuoteAt the time, Nikola Tesla plunged into an ocean of inexhaustible energy,and he saw how to use it.We also saw it.We were able to develop devices that transform this energy into radiant energy.To create radiant energy, you only need a pulse, the excitation of the medium,and then the device works by itself.With minimal energy consumption, we can excite an environment that can transform into an inexhaustible ocean of energy at the outlet.We have ready-made samples that we can provide for measurements and research, but only on our territory.
Quote from: rakarskiy on January 26, 2020, 12:14:56 PM
Mr. Rakarskiy, I'm not sure what sort of device that is as it doesn't appear to have any HV interrupter on view, do you have any more details on that device?
Regards Raymondo
The point is simply I'm not going to buy the video and even if I got to see the video I simply wouldn't advertise the fact.
Question... ???
What is he difference between the zero current node point of standing wave, on a unterminated or terminated line.
And the zero current node point of standing wave, on a unterminated or terminated bifilar line.
http://www.mysearch.org.uk/websiteX/html/4%20Spherical%20Standing%20Waves.htm
How does it feel to be an electron of proton at that particular point in space? Can this area be hacked?
Quote from: Raycathode on January 26, 2020, 12:38:51 PM
Regards Raymondo
Why did you decide that there should be a spark gap? For parallel resonance (which is clearly visible in the device being demonstrated), a single key is sufficient, according to the quasi-resonant system (https://www.researchgate.net/figure/IGBT-based-parallel-quasi-resonant-inverter_fig1_298847631). (Any induction cooker works on this principle). What I was interested in was the technology for removing the swinging power (current + voltage) in the oscillating circuit. For me, this is possible (the result of the calculation in the figure, the power supply scheme from A 12V battery and on a resonant coil). I do it myself, but I can't take off the swinging force yet. That's why I assumed that via capacitive transmission.
I am interested in devices that run on battery power and without grounding. One of the videos shown shows this episode. Closing this device in a self-propelled device is already a matter of engineering solutions. How much is really inexpensive to Download, for me the question is solved, but I can not delete, without the reaction of the source, yet. How real this moment is for the demonstrators, I can neither confirm nor deny.
Hi! All these videos about 50Hz resonance buzz and "energy" suction "from ground wire" is only stealing from grid.
Remove your Power line and nothing will happen!
It is old scheme of energy stealing from power grid!
We take phase from Electric grid, than take Earth and we are stealing energy from grid!
Guys, don`t be stupid!
We can steal thousands of Watts!
With buzz or without!
Circus.
Quote from: Ansis on January 27, 2020, 05:32:35 AM
Circus.
Ansis hi, Your talking about something else, not everything with earth sucks energy from the grid, anyway the electric companies are out of date
and need to change they are destroying the planet with pollution of burning fossil fuel Henry Moray used an earth so where did he get his 'phase' from 100 miles out in the desert? he sucked power from the environment.
Besides How can anyone possibly steal electricity from the grid since it is metered to do what you're suggesting one (an idiot) would have to connect cables on the incoming meter input side (that's a suicide trip ot the flash could be blinding)!! and since the neutral is linked to earth it is at earth potential !! so there you go not possible in the west.
Raymondo
In old days my friend, which is not my friend anymore use that scheme and he pay 5Lats for electric bill but heat up all house...
Quote from: Ansis on January 27, 2020, 08:47:10 AM
In old days my friend, which is not my friend anymore use that scheme and he pay 5Lats for the electric bill and heat up all house...
Not friend, oh dear :'( it was the same here. Now have to use hot water bottle and cat to keep warm, sad isn't it?
When Wesley says no free lunch, he just saying that Science says there is no reality and Albert Einstien got it all wrong and as we get higher in frequency like the UV light spectrum we get a lot of free electrons in a WAVE like 911 bull shit, Professor Jim Al-Khalili proved it!
Sorry
Regards Raymondo
Ansis, most these new things have no earth.
Please answer question, what is differenc between standing wave and standing wave on a bifilar transmission line
Standing waves are waves of voltage and current which do not propagate (i.e. they are stationary), but are the result of interference between incident and reflected waves along a transmission line.
A node is a point on a standing wave of minimum amplitude.
An antinode is a point on a standing wave of maximum amplitude.
Standing waves can only exist in a transmission line when the terminating impedance does not match the line's characteristic impedance. In a perfectly terminated line, there are no reflected waves, and therefore no standing waves at all.
At certain frequencies, the nodes and antinodes of standing waves will correlate with the ends of a transmission line, resulting in resonance.
The lowest-frequency resonant point on a transmission line is where the line is one quarter-wavelength long. Resonant points exist at every harmonic (integer-multiple) frequency of the fundamental (quarter-wavelength).
Standing wave ratio, or SWR, is the ratio of maximum standing wave amplitude to minimum standing wave amplitude. It may also be calculated by dividing termination impedance by characteristic impedance, or vice versa, which ever yields the greatest quotient. A line with no standing waves (perfectly matched: Zload to Z0) has an SWR equal to 1.
Transmission lines may be damaged by the high maximum amplitudes of standing waves. Voltage antinodes may break down insulation between conductors, and current antinodes may overheat conductors.
https://www.youtube.com/watch?v=rAZVGVAUd3E
Agree.
But! We in terms of "Energy", speaking only about spending of energy!
Kapanadze in his tapes, go to sleep, but his son? (Gia) starts to speak out!
In that conversation he tell to his talk mate about "amplification of energy", which in fact we see in Turkey experiment. Kapanadze use Power grid for "amplification"?
Or is it just fake?
I think it is not so easy!
He is genius, but is he evil or lamb, we don't know.
Quote from: Ansis on January 27, 2020, 10:40:44 AM
Agree.
Or is it just fake?
He is probably just a gray jedi.
A bit like qui-gon jin.
All videos of Steven Mark torroidal transformer unit which is available in YT are beutifull!
Resonating wood core perpendicular winded transformer which is pulsed by 2 small toroidal generators, which working? so nicelly!
No one knows what it is!
I love it!
But, what it is?
Quote from: stivep on January 27, 2020, 03:49:56 PM
Я могу бесплатно cделать на своем канале перевод видео материала,
который должен быть лучшего качества, но я мой друг не за деньги.
Никто не может купить меня, и я ничего не покупаю.
Но я ecт деньги, так как я ключ к тем, кто уважает меня. вот как это работает.
Мы, Запад, единственное место, которое вы можете заинтересовать.
Так что я даю вам возможность быть видимым миру.
Достаточно ясно, чтобы сказать, что я никогда не буду вашим клиентом.
При всем уважении, Delamorto. Вот почему люди доверяют мне и ценят мое мнение.
Yes I agree and you can add me in with that too.
Raymondo
https://youtu.be/zE4GjB1cWLQ (https://youtu.be/zE4GjB1cWLQ)
https://youtu.be/XOTLfnMOSqQ (https://youtu.be/XOTLfnMOSqQ)
(https://youtu.be/yNs2wc8nRJw)
Wesley
Delamorto, I suggest you offer individual counseling and videos to private builders who will pay you 5000$.
There is nothing against the law in this.
Your circuit.... You are just LUCKY to be a russian speaker.
You got lucky, is what I think. Might you share the luck with me for a fee?
Quote from: stivep on January 27, 2020, 06:28:45 PM
I examined Tariel Kapanadze device in Tbilisi and I didn't find fake there.
9 years after my return from Tbilisi I found explanation of Kapanadze in Viziv.
But Dr James Corum and his even more brilliant brother Kenneth Corum didn't go officially that far.
Your problem my dear Friends is that you are waiting for someone to leak it to you.
You have it in front of your eyes and likely none of you wants to try it out.
My 3 videos says it all.
https://www.youtube.com/watch?v=yNs2wc8nRJw&feature=youtu.be (https://www.youtube.com/watch?v=yNs2wc8nRJw&feature=youtu.be)
Indeed, we can say that you held the Kapanadze device (KAPAGENERATOR) in your hands, you explain how it works, the work done in this area as a researcher is impressive and deserves respect. I assume this is your version of how it might work.
There is one interview with Tariel (https://yadi.sk/i/lLMDf5utvwvBNg), where He claims that the closest approach to his principle was made by Andrey Melnichenko (https://www.youtube.com/channel/UCEtqI2EhN32Mvq7Wp5G9Vpg) (whose last scheme is a reverse-pass Converter with a OU conversion effect). Tariel also has a Converter. Forward or reverse, the Converter is a DC/DC class. The spark gap is the key for the pulses in the Converter circuit. There is a version that Tariel in Soviet times, in a Research Institute of the USSR, was in charge of the economic part, and concurrently responsible for the Archive. This Institute was engaged in the development of gravitational aircraft. And this effect was discovered by them accidentally or developed for the energy source of such an aircraft device.
I think the formula of the Kapanadze device is simple, the Ohm's law must be triggered In the secondary circuit for the full circuit. There are several devices that intersect and one of them is the "Tricky zatsarinin transformer (https://www.skif.biz/files/28995a.pdf)", but Sergei Borisovich has it running on alternating current.
Researchers have not yet solved the principle of operation of the tricky transformer and Kapanadze Converter. Zacarinin, (claiming that the principle of operation of the device can be made in several variants) has filed a patent application. Unfortunately, this patent has not been publicly available since 2008, and more than 10 years have passed.
Probably in the RU 2412520 paper is Zatsarinin transformer knowledge incorporated.
rakarsky,related "Ohms ( and Fourier) law" : Prof. Michal Lipson ,Columbia Engineering
macro-scale versus nano-scale "Nanoscale heat transfer 100 times stronger than previously thought
( all about circuits : April 05,2016 from nature nanotechnology March 07,2016 )
Quote from: lancaIV on January 28, 2020, 09:21:26 AM
Ohm's law (https://i.pinimg.com/236x/6f/60/36/6f6036bf97e23bba134617b751e29159.jpg) is an empirical physical law that determines the ratio of the electromotive force of a source
(or electric voltage) to the current flowing in a conductor and the resistance of the conductor. Founded by
Georg Ohm in 1826 (published in 1827) and named after Him. By the way, this is not a fundamental law of physics,
but a special case. This is our University physics.
May I use your collective minds for an instance?
https://overunity.com/18325/creating-tpu-steven_mark/msg542361/#msg542361
Please.
But when in nanoscale a macroscale experiment ruled by "Ohmsche Gesetz-es-Vorgabe" gives different result,-up to 10000% different - we have to explain the " nanoscale universal physics" !
Some years before the science discovered similar anomalies in carbon nano-tubes ( CNT ) ! VELOCITY !
How is it that a medium sized supercap can cause this reaction?
Its a force multiplier on the first pulse, series of pulse, this can only be done with echo wave technology create hole for cheaper.
The node has a density wave, its not current, its the "probability of current" in a weakened field. How is this good for us?
What does it mean to "associate with the earth". How can something be affected by such a weak magnetic field?
Simply wondering why the TPU and Schwartz have this, and multiple frequencies?
Here is an article about power transmission according to Tesla and VIZIV now.
https://www.quora.com/Are-there-any-research-papers-of-Nikola-Tesla-that-suggest-he-was-working-on-wireless-electricity
Not my quote, but very important-Kapanadze said: "his device, not fully invented by him, but skillfully compatible, the generator consumes 40 watts, and gives 5000 watts" adjusted for the video, the gene eats about 70 Watts, gives 2600 watts fact!
Kapanadze said: "the generator does not respond to load changes in the widest range, up to a sudden shutdown of this." At the same time, it turned off the load, and then turned it on when the gene was working. Fact!
On a Philosophical level,
How does one end of the circuit know that one end of the circuit is an open circuit? Once its P Mosfet turns on.
The same way, how does water know one end of the pipe is welded shut?
This is a factor of time, charging up, and a counter acting force, or Impedance, wich communicates back to Source, Its a NO-GO.
Now Imagine, You send a wave, and right at the sweet spot, You steal all the electrons with an impulse field.
How does the system react? Is this still a High Impedance circuit?
Well, I guess you dont know for sure.
Of course you would not know the exact answer to this particular situation.
This is like asking you what is the source of energy.
You dont know...You say you know, or do you?
Do I even know? Dam... This is confusing.
It is destructive interference, I believe.
https://physics.stackexchange.com/questions/23930/what-happens-to-the-energy-when-waves-perfectly-cancel-each-other
Yeah I know that... But what about when there is not even a magnetic field?
Does stuff blow up and go sideways like trains colliding?
Oh, silly me.
It seems you dont know the answer, because there is no answer.
Pardon my ignorance.
When there is a complete destructive interference of two light beams, Maxwell's equations predict that the energy becomes zero. Let's have the case of two coherent collinear beams, out of phase 180 degrees, like the case of the antilaser.
E1=Emsin(kx−ωt);E2=Emsin(kx−ωt+p)B1=Bmsin(kx−ωt);B2=Bmsin(kx−ωt+p)
E=E1+E2 and B=B1+B2
EB=Emsin(kx−ωt)+Emsin(kx−ωt+p)=Bmsin(kx−ωt)+Bmsin(kx−ωt+p)
But, sin(kx−ωt+p)=−sin(kx–ωt) , Then, E=0 and B=0 and,
UT=UE+UB=12ԑ0E2+12μ0B2=0
This is the classical interpretation of the waves electromagnetism during total destructive interference, following Maxwell. Maxwell's description of the energy of the light wave is of an undulating energy that predictably reaches a maximum and later becomes zero. The proposed solution to this problem is to calculate the mean of the energy when the fields are maxima.
What is the physical meaning of an energy that have to be averaged in order to have the real magnitude. If the principle of conservation of energy is to be applied to this phenomenon, the energy must be constant, have an unique value for each instant during the movement of the wave. What is the meaning of that situation that has not been recognized for more than a century?
What almost nobody want to admit is that electromagnetism is incomplete, because cannot describe the electromagnetic radiation adequately, and generate a violation of the principle of conservation of energy.
As Helder Velez said: "We don't have theory?". NO Then we must rethink." He has a proposition: EM energy is not transported, only is an excitation of the medium, the quantum vacuum, or the quantum plenum as I prefer to call it. But this is only an id
https://www.youtube.com/watch?v=lAbGzwLh2QE&feature=emb_title
QuoteFuel-free generator for electric car 5kW on IR2153
QuoteAlexander Stupnikov is looking for the police, he sold broken generators.
Here is another author Alexander Stupnikov, his blog on YouTube is empty today.
https://www.youtube.com/channel/UCP1Iy4__2vn5yRlWSbMX9Bw/videos
I tried to find at least one episode with the sale of this device, or a police summary where this person is listed as wanted. There are no confirmations For or against the device.
What planet have you been living on? this guy did a blog on OU not so long ago he is now living in India trying to find investors, should be fun.
why doesn't he just give it away? He has made the dam thing so complicated it's a white elephant in the living room to anyone who gets involved.
Ask just a whatt about it.
Quote from: Raycathode on January 29, 2020, 03:10:32 AM
why doesn't he just give it away? Ge has made the dam thing so complicated it's a white elephant in the living room to anyone who gets involved.
In which India? He is from Ukraine, and the photo of the diagram made by his hand shows his contact phone number. For an international call, dial +38 before the number
I managed to trim down this resonant system and put flat magnets in between the 2 ferrite halves (they dont seem to hurt nor help so ..)..I no longer need the IF section.My feedback capacitor was leaking due to overvolting also...Here are the new pics and data.....
Sir..Can you please resize images...entire page becomes unreadable ....[yes Stefan should have method to fix this ??]running back and forth to read makes it very difficult thx Chet
images from above on one page
Small recomendations from me about efficiency.
Induction is Energy wasting.
All 90% efficient coils are closed type or with very big cores.
We need get inducive kick, to make induction, which is main reason for Inductive energy transfer.
All Tesla coils are creating very big energy field, which is Energy wasting.
How I see "energy amplification"?
All Kapanadze type devices have hiden source of electricity 100%.
Is it Power line or LiPo, but it is fact!
Second.
If we create artifical Magnetic Field, which is 10, 100, 1000 times biger than normal Induction force made by Induction itself, than we can get artifical Secondary Voltage, but!!! How to do that?
How?
In Kapanadzes video, where is aquarium in the garage, there is 2, 12V 7A, lead acid batteries, which is making illusion of Free Energy. There is TC, big! This is for creating big Impulses for Primary impulse. Than, we see many HiFrequency TV type transformers-recievers, which is main collectors. Than "ground wire" and secret energy mixer, which is neccesary to make sinhronisation betwee all that, because of energy transfering- recieving. But, all that is trick! After 10 houres all is flat. It is for money making! :(
Probably "Kirchhoffs laws" are giving answer ,beside circuits also thermal radiation related
Quote from: Toolofcortex on January 29, 2020, 10:11:31 AM
The answer is that the energy is gone, and when perfectly destructive.
I dont understand why maxwell would say the energy si zero is there is heat energy.
I will have to review it, did you read above?
Yes heat, probably, I guess, that would be the immediate answer from the internet, I will stop my searches.
Maxwell was disturbed by this, I dont think he would be disturbed if it was All heat.
What are you like? you trust the word of a polytical polatician b (sad) ;D ;D What is heat? hmm? it's a vibration! the Atom is the Bullshiter!
go back to school that man, start here > https://www.youtube.com/results?search_query=jim+al-khalili
https://www.youtube.com/watch?v=anvb_PXG1YA&feature=emb_title
https://www.youtube.com/watch?v=yKjgMmZcFA0
2014, demonstration of a resonant transducer. Westley, this guy must be a Russian-speaking provocateur again.
It probably uses a similar scheme for swinging the contour: http://pikucha.ru/wp-content/uploads/2016/07/Jelektricheskaja-shema-indukcionnogo-nagrevatelja.jpg
The guy tells how he removes, and calculates the resonance of the secondary circuit and demonstrates the work on the load. Unfortunately, it does not demonstrate the consumption of the reference resonant circuit.
Wesley, from what American device is this board? Presumably a device of the 60s.
It was abducted by me a very long time. But the device is still older. :)
https://www.cryptomuseum.com/df/1100ar/index.htm (https://www.cryptomuseum.com/df/1100ar/index.htm)
moderated
Thanks for the interesting site. But it seems to me there were digital indicators. And the performance is desktop, not in the rack.Although it seems that it was in a past life ...
Well I do not know what is going on with this device.....it is now running on a minimum... 2 induction coils, 1/2 ferrite core, 1 diode , 2 capacitors and the OPA541,plus heavy grounds...and I have the same output with 1/2 the core missing...It now starts with momentarily touching the dipole ground to the 1/2 core,15 turn winding.....The output of the core is now one wire which goes through a .3 micro-farad capacitor which itself runs cold.The single diode gets warm but can be held in the fingers, yet tries to light 370watts of bulb power.The core also does not appear to be warming up....The OPA541 is running 44.8 volts @ .8 amp @ 85 kHz now and must be somehow powering those bulbs through that small .3uF capacitor---I can feel the heat radiating from the orange filaments.I do have a heavy ground connected to the diode and the OPA541...If the induction coils are moved too far away,the system shuts down and will not restart until the dipole ground is again touched to the core winding.The ground can stay attached or removed--makes no difference.
It does appear though that both capacitors play a significant role in the resonant core.I know the coils do.I adjusted the capacitors,a month ago, for maximum output, and minimum capacitance for the 14 watt bulb I was using.
Now here, I removed the second half of the core while it was running, I held the second half of the core to the first half and felt the buzzing from them as they tried to connect.I then decided to try just the one half (15 turn half) and it lit the bulbs,I then removed the ground side and the bulbs stayed lit. So I am now down to one wire trying to light 370 watts. Bulbs colour and brightness have not seemed to have changed as when I had all that other attached,but the frequency of the system has went from 65kHz to about 80 kHz.OPA541 can be ran without its fan for cooling but appears to warm up over time------------- ..Note this is an ongoing project and I can only tell you what I have discovered....Schematic is correct as I believe it to be.Nothing hidden.
I posted a bit too soon it seems because my system no longer uses the small caps,nor does it need a momentary contact--it starts as always by adjusting the bi-fi-coil,of which 1 is only required but 2 gives it a boost.And the bi-fi- hookup lines have been reduced only because it made no difference in output that I notice,so I left those off too.It is much more streamlined for a given output.----The ground line---that has a big influence I now notice...The system will not run with a flat copper cable line to the copper water pipes,I tried...It uses a 40 ft. line, of 2/0 silver coated,multi strand cable ,clamped to a 3 foot copper pipe hammered into the ground...System appears to run the same without all the extra baggage.System resonance has dropped to about 54 kHz from 65 kHz.Still uses a single diode.System will not start nor run without the 1/2 core attached with its dangling wire.It will run with either the 15 or 150 (cadaceous) coil/core attached,despite the wire to nowhere.The core gives out a stronger field with a larger load..... RWG Research on You-Tube makes similar induction coils if your curious where to find them.Im sure he still makes them.
This is interesting!
https://youtu.be/jHK7kKsVVw0
Yes it is interesting.
Wesley
Ok..looks like a fail...it lights the bulb without the core @ 35kHz. I tried 3 different core winding combinations and they all responded about the same,which made me wonder.So I removed the core and used a straight hookup ---Im sure I tried this earlier and it did not work.This time the bulb lights...Back to the drawing board !!
Quote of Mark comment:
QuoteAll of the answers for you is provided by guy name Wesley in his 3 videos
https://www.youtube.com/watch?v=XOTLfnMOSqQ (https://www.youtube.com/watch?v=XOTLfnMOSqQ)
https://www.youtube.com/watch?v=yNs2wc8nRJw&t=277s (https://www.youtube.com/watch?v=yNs2wc8nRJw&t=277s)
his youtube is - stivep1
For more detailed technical aspects go to
Start up or down from here
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg533486/#msg533486 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg533486/#msg533486)
Zenneck wave is transferred from Top capacitor of Tesla air Transformer, at Brewster angle to Earth/Air interface.
That wave doesn't propagate in FAR Field.
We may describe it as :
Wave from group of Surface Waves
-type Zenneck Wave
mode: TM mode ( Transverse Magnetic. )
And that wave in Fresnel zone between Near Field and Far Field at angle around ~67 degrees is trapped in the interface.
The receiver looks exactly the same as transmitter.
Receiver can be placed at any point of the earth or ocean.
Viziv with PhD J.Corum and K Corum ( brothers) and involvement of Chevron plays with Tx-Rx energy transfer.
But Schumann Waveguide by its own energy fluctuation inside of that Waveguide triggered by lightnings has two boundaries
-Earth
-Ionosphere
The Earth is accessible to us.
If at Brewster angle energy is deposited to that boundary as Zenneck Wave at TM mode ,- this energy is trapped in the INTERFACE earth/air.
For simplicity think of it as 2D space around the earth.
Than this energy can be "extracted" - (received) by a Tesla coil with Top Capacitor tuned to this particular frequency.
more you will find in links attached to this comment .
Dear Mark you absolutely correct
thank you
Wesley
I found a "recent" (2013) patent that uses an interesting device for either testing or for use..It is the device,that I find interesting.The patent itself describes a process
for making GHz ferrite.
http://www.hatz.hr/hrv/skupovi/tesla_unesco_proceedings.pdf
the only interesting was page 53
and cavity filters
Wesley
https://youtu.be/pFEB0chiuJA
This link is about horns, but maybe something else too?!
this is interesting Ukrainian work
by
Dean of Ukrainian University of Schevchenko in Kiev
member of Academy of science
It is related to
Effective LENR and transmutation of stable and radioactive isotopes in growing biological systems
https://www.sciencedirect.com/science/article/pii/B9780128159446000129 (https://www.sciencedirect.com/science/article/pii/B9780128159446000129)
https://youtu.be/k43a8Zd3S5s?list=PLkL_orlZx-99ABvz_7ws_Ibs4OEtybY1n&t=311 (https://youtu.be/k43a8Zd3S5s?list=PLkL_orlZx-99ABvz_7ws_Ibs4OEtybY1n&t=311)
this one is in English/ heavy accent
https://www.youtube.com/watch?v=1en1E2s-gbM
ICCF-18 : Jean-Paul Biberian and Vladimir Vysotskii "Transmutations in ..."
https://www.youtube.com/watch?v=f0hxFbuGr48 (https://www.youtube.com/watch?v=f0hxFbuGr48)
Elementu transmutācija = Трансмутация элементов = Transmutation of elements
___________________________________________________________________
some links:
https://www.youtube.com/watch?v=zNdlN4QEhfw
(https://www.youtube.com/watch?v=zNdlN4QEhfw)https://www.youtube.com/watch?v=6pJyNE-LIUY
https://www.youtube.com/watch?v=7ght_bhaoKM
https://www.youtube.com/watch?v=YOHSMWh2Dxs
(https://www.youtube.com/watch?v=6pJyNE-LIUY)https://https://www.youtube.com/watch?v=r2PoM-62aII
https://www.youtube.com/watch?v=9TbFaKfYZ8U
www.youtube.com/watch?v=GYwkd4_1aaY (https://www.youtube.com/watch?v=GYwkd4_1aaY) russian only
Joachim Knebel - Breaking the Wall of High Level Nuclear Waste @Falling Walls 2010
https://www.youtube.com/watch?v=UwtylygTLAU (https://www.youtube.com/watch?v=UwtylygTLAU)
Idea: Complementary Transmutation Nuclear Reactor
https://www.youtube.com/watch?v=HbMvoL5T3uM (https://www.youtube.com/watch?v=HbMvoL5T3uM)
Mrs. KJ Explains: Sem. 2; 8.06 Transmutation of Elements
https://www.youtube.com/watch?v=TXJWXL2F0gY (https://www.youtube.com/watch?v=HbMvoL5T3uM)
ICCF22 - Nuclear Transmutation with Carbon and Oxyhydrogen Plasma - Slobodan Stankovic
https://www.youtube.com/watch?v=lkQIO-L7Tic (https://www.youtube.com/watch?v=lkQIO-L7Tic)
this one is different in nature and don't take it to seriously however it is nicely done
https://www.youtube.com/watch?v=OlGzt9ur1bY (https://www.youtube.com/watch?v=OlGzt9ur1bY)
Wesley
Hi Wesley,
Just an addition: a search on their book "Transmutation of Stable and Radioactive Isotopes in Biological Systems"
reveals a presentation on "the short prehistory, phenomenology, experiments, reasons and perspectives",
see here:
https://mospace.umsystem.edu/xmlui/bitstream/handle/10355/36823/TransmutationStableRadioactivePresentation.pdf
Gyula
Quote from: gyulasun on March 28, 2020, 06:12:16 PM
Hi Wesley,
see here:
https://mospace.umsystem.edu/xmlui/bitstream/handle/10355/36823/TransmutationStableRadioactivePresentation.pdf (https://mospace.umsystem.edu/xmlui/bitstream/handle/10355/36823/TransmutationStableRadioactivePresentation.pdf)
Gyula
Yes you found original article of .Dr VladimirVysotskii
Thank You
Wesley
FULL HD Kapanadze self runing 5 KW Autonome : https://www.youtube.com/watch?v=wQYwnOCWOws&feature=youtu.be (https://www.youtube.com/watch?v=wQYwnOCWOws&feature=youtu.be)
New developement about Viziv Technology in response to Mark comment :
https://hackaday.com/2019/11/20/texas-tesla-tower-titillates/#comment-6223868 (https://hackaday.com/2019/11/20/texas-tesla-tower-titillates/#comment-6223868)
PART#1
QuoteGeorge says:April 2, 2020 at 8:43 pm (https://hackaday.com/2019/11/20/texas-tesla-tower-titillates/#comment-6234066)Let me try to clear the air here.
I worked for a company that invested in this and I had the opportunity to visit this site.
I got to see first hand over 1KW (a one HP motor was operating with no interconnecting wires)
received at over 1km. This was using one of the smaller devices, not the big tower.
The big tower was under construction and was testing using just a few watts..
The small tower/device was running about 5KW from a AM broadcast transmitter.
This project is real and there is no magic.
The Corum's are first rate scientists and have been identified by the US government
as a national resource with their work at Airforce Cambridge.
I had the chance to talk with them at the Viziv/Texzon facility.
They are considered THE authority on Tesla's RF work and Ball Lightning by the
Russians and Americans both.
They indicated that they had full access to all the Tesla documents in Belgrade
while working with the 1st and 2nd directors and hinted there is nothing at Wright Pat.
They made it clear the work in Milford is to basically make and "extension cord"
for power and global communications with very low power and phased arrays for location.
There is no free energy nonsense. Their calm is that they discovered how to produce a
Zenneck Surface wave by illuminating the ground with RF fields at the Brewster angle.
A Zenneck wave drops off as one over the square root of the distance.
However when a load is connected to earth all the power went to the load with minor losses.
During the presentation they indicated it was much the same as using teledeltos paper.
https://en.wikipedia.org/wiki/Teledeltos (https://en.wikipedia.org/wiki/Teledeltos)
PART#2
QuoteThey showed us a laser pointer reflected off the conference room table, at the Brewster angle
there was no reflection.
But, if you looked along the edge of the table the light was very bright.
They explained the light energy was trapped along the surface of the table.
They spent 40 years trying to figure out how to do the same thing with RF.
They indicated the obstacle was the earth dirt around the tower.
Apparently the dirt was frequency sensitive and it made the Brewster angle non real and complicated.
That was when they lost me.
Some how they made a complicated Brewster angle by playing
with the phase between the vertical and horizontal parts of the local RF fields.
This somehow this made an infinite plane.
I hope some day they publish what is behind all the patents.
They did not mention anything about Schumann resonance as you have alluded to above.
They only said their wave guide was one sided just the ground and they work very hard to prevent radiation.
Their real joy was the the replication of an experiment done by Bell Labs in the mid 30s.
The Corum's were able to demonstrate that the 1930s experiment was incomplete.
http://rexresearch.com/corumzenneck/texzon.pdf (http://rexresearch.com/corumzenneck/texzon.pdf)
PART#3
QuoteThey replicated what Bell Labs did and then demonstrated that if the radiation was removed
by making the structure very small and the RF fields were just so for the water, a ZenneckSurface
wave could be produced.
That proved that Zenneck and Sommerfield were right back around 1910.
With Zenneck waves there are no near and far fields, just a traveling wave with very low loss.
From what I was able to get out of the presentation regarding Tesla was that they had reproduced
Tesla's Colorado Springs experiment and sent power 25 miles.
They were quite adamant that thereare no Tesla secrets and no cover ups.
Everything you need is in the existing Tesla literature.
What is not in the literature is the "how does it work".
That is in their patents and 40 years of hard labor.
One of the Corum's had a big sign in his office,Do what Tesla tells you to do and you get the same results.
Don't try to do what you think Tesla did (something like that).
There was also a working replica of one of Tesla receivers in his office.
It was the same one he used to listen to the Jovian decametric signals and hear one, two, three.
There was also a working replica of the "eagle bug" from the great seal from the US embassy in Russia.
Who knows what else they are working on...
It was a fascinating day spent at Milford, TX.
Wesley
Wesley's translation from English into Russian:
QuoteДжордж говорит 2 апреля 2020 года в 8 43 вечера.
Позвольте мне попытаться очистить воздух здесь.
Я работал в компании, которая инвестировала в это, и у меня была возможность посетить этот сайт.
Я увидел из первых рук более 1 кВт (двигатель мощностью один л.с. работал без соединительных проводов) на расстоянии более 1 км.
Это было использование одного из небольших устройств, а не большой башни.
Большая башня строилась и тестировалась с использованием всего лишь нескольких ватт.
Небольшая башня / устройство работала на расстоянии около 5 кВт от передатчика AM-вещания. Этот проект настоящий и в нем нет магии.
«Корум» - это первоклассные ученые, и правительство США определило их как национальный ресурс для своей работы в ВВС Кембридж.
У меня была возможность поговорить с ними на объекте Визив / Тексон. Они считаются авторитетом в работе
Теслы в РФ и Ball Lightning как русскими, так и американцами.
Они указали, что имеют полный доступ ко всем документам Тесла в Белграде
во время работы с 1-м и 2-м режиссерами и намекнул, что у. Wright Pat. ничего нет
Они дали понять, что работа в Милфорде состоит в том, чтобы в основном сделать и «удлинитель»
для глобальных коммуникаций с очень малой мощностью и фазовыми переходами.
Там нет бессмыслицы свободной энергии
они обнаружили, как производить волну поверхности Зеннека, освещая землю <радиочастотными полями> под углом Брюстера.
Однако, когда нагрузка подключена к земле, вся мощность пошла на нагрузку с небольшими потерями
Во время презентации они указали, что это почти то же самое, что и использование бумаги для теледотов.
teledeltos paper.
QuoteОни показали нам лазерную указку, отраженную от стола в конференц-зале,
под углом Брюстера
отражения не было.
Но если вы посмотрите вдоль края стола, свет был очень ярким.
Они объяснили, что световая энергия была захвачена вдоль поверхности стола.
Они потратили 40 лет, пытаясь понять, как сделать то же самое с РФ. Они указали, что препятствием была <земляная грязь вокруг башни>
Очевидно, грязь чувствительна к частоте, и это делало угол Брюстера нереальным и сложным.
Это было, когда они
<потеряли меня.>=(Они потеряли мое внимание)
Некоторым образом они сделали сложный угол Брюстера, играя с фазой между вертикальной и горизонтальной
частями локальных радиочастотных полей.
Это каким-то образом сделало бесконечную плоскость.
Я надеюсь, что когда-нибудь они опубликуют то, что стоит за всеми патентами.
Они ничего не упоминали о резонансе Шумана, как вы упоминали выше. Они только сказали, что их волновод
был только односторонним, и они очень усердно работают, чтобы предотвратить излучение.
Их настоящей радостью было повторение эксперимента, проведенного Bell Labs в середине 30-х годов.
Корум смог продемонстрировать, что эксперимент 1930-х годов был неполным.
QuoteОни повторили то, что сделали Bell Labs, а затем продемонстрировали, что, если излучение было удалено,
сделав структуру очень маленькой, а радиочастотные поля были точно такими же, как для воды,
то можно было бы создать волну Zenneck
Это доказало, что Zenneck и Sommerfield были правильны обратный приблизительно в 1910
С волнами Ценнека нет ближних и дальних полей, только бегущая волна с очень малыми потерями.
Из того, что я смог извлечь из презентации, касающейся Теслы, я узнал, что они воспроизвели эксперимент
Теслы в Колорадо-Спрингс и отправили мощность в 25 миль. (40.2336 km).
Они были совершенно непреклонны в том, что нет секретов Теслы и нет прикрытий. Все, что вам нужно,
в существующей литературе Тесла. В литературе нет «как это работает». Вот в их патентах и 40 лет каторжных работ.
У одного из Корумов был большой знак в его офисе: делай то, что Тесла говорит тебе делать, и ты получаешь те же результаты.
Не пытайтесь делать то, что, по вашему мнению, сделал Тесла (что-то подобное). В его офисе была также рабочая копия одного из приемников Теслы.
Это был тот же самый, который он использовал, чтобы слушать декаметрические сигналы
Юпитера и слышать один, два, три. Была также рабочая копия «орлиного жука» с большой печати посольства США в России.
Кто знает, над чем еще они работают ... Это был восхитительный день, проведенный в Милфорде, Техас.
Wesley
*Thank you my friend.*
speedy 125 has gave us new piece of information.
Some news about NMR , I was find something ,
(... Actual evidence of nuclear electric resonance has now been discovered by accident in a lab at the University of New South Wales (UNSW) in Australia,
thanks to faulty equipment.
The breakthrough gives scientists a new level of control over nuclei, and could seriously speed up the development of quantum computers. ... )
https://www.sciencealert.com/in-an-accidental-discovery-australian-engineers-solve-58-year-old-quantum-mystery?fbclid=IwAR1TFgv7GLiBo9HcZoNaskzjmLof3uWhc9aFf0e548CHmH7eMgSGGPIv7VA (https://www.sciencealert.com/in-an-accidental-discovery-australian-engineers-solve-58-year-old-quantum-mystery?fbclid=IwAR1TFgv7GLiBo9HcZoNaskzjmLof3uWhc9aFf0e548CHmH7eMgSGGPIv7VA)
also,
Article
Published: 11 March 2020
Coherent electrical control of a single high-spin nucleus in silicon
https://www.nature.com/articles/s41586-020-2057-7 (https://www.nature.com/articles/s41586-020-2057-7)
Wesley
#3171: yes,nice optimation potential for silicon nano-grain-dots as ink for surface printing !
I would as research tool combine with
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890201&CC=DD&NR=264511A1&KC=A1 (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890201&CC=DD&NR=264511A1&KC=A1)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870603&CC=DD&NR=246367A5&KC=A5 (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870603&CC=DD&NR=246367A5&KC=A5)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT
=D&date=19860730&CC=DD&NR=237897A5&KC=A5 (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19860730&CC=DD&NR=237897A5&KC=A5)
I mean Stockholm Nobelprize-work level ,Manfred Alexander Gregor his discoveries !
What me wonders about the Viziv technology is their fixation ,as tower !
The russian AIRHES idea as flowing ballons/zeppelins/cigars would giving beside water,electric energy also a
emitting and receiving body(great absorption and reflecting field) for telecommunication !Thin kevlar film ?
https://airhes.com/ (https://airhes.com/)
https://newatlas.com/air-hes-cloud-power-clean-water-energy-vapor/33512/ (https://newatlas.com/air-hes-cloud-power-clean-water-energy-vapor/33512/)
Inflatable -cool earth- like concepts ? https://www.coolearthsolar.com/ (https://www.coolearthsolar.com/)
Remembers me also Otto von Traun and Prof.Herman Plauson their ballon concept !
http://www.mareasistemi.com/DIDATTICA%2027/Hermann%20Plauson%20%20Conversion%20of%20Atmospheric%20Electricity%20%28Articles%20&%20patents%29.htm (http://www.mareasistemi.com/DIDATTICA%2027/Hermann%20Plauson%20%20Conversion%20of%20Atmospheric%20Electricity%20%28Articles%20&%20patents%29.htm)
Body with solar dot ink ?
And 24/365 topic Owen P. Barker solar cell use for telecommunication US5009243 https://patents.google.com/patent/US5009243A/en (https://patents.google.com/patent/US5009243A/en)
Some Corum documents found.
corum
this file in RAR is asking for password
Wesley
Quote from: stivep on April 28, 2020, 01:44:56 PM
Wesley
Dear Wesley. The password for the RAR file is corum.
All the best...
Wesley...I got this antennae system to operate into transformers, a small 240 to 24v & smaller 120 to (12v + 12v)....they connected in reverse but they both can light up 40w of bulb power pretty good.Im including the schem and pic.I tried a microwave transformer - connected forward- but had little luck,will try again later.------Have you ever tried to align a satellite dish using only a hand compass? I have.And that is what this system is akin to.
That 680uF cap can be bypassed as I am not sure that is how was connected now---it will run without it but less output. But my system has just dropped out since testing larger transformers.I put the 240v TFMR back on and it blew the diode (somehow). Now I am having other problems as it will not link-up nor respond to movement.I have had the whole thing apart starting from scratch---It ran for a couple seconds with the 14 watt then that was it--blew that diode,could be the OPA amp but its power lights are on.
It blew the OPA541 amp and the diode,------I replaced both then it blew another diode...again replaced .But it still will not even try to run through a transformer,nothing.it shows the current moving through but it will not even dim the bulb.Ive checked everything over and over,so its back to basics... Also,not shown earlier ,the OPA amp DOES require an external gnd at the output side else it will not tune in this system.Im including a "basic" system setup which worked just to give an idea what Im doing.The transformers was an afterthought.
Part 1 EEV blog criticism creates protest of FE community
https://youtu.be/l6uPHxQVEgQ (https://youtu.be/l6uPHxQVEgQ)
Wesley
https://youtu.be/He5xQOJHlrU (https://youtu.be/He5xQOJHlrU)
Understanding of energy conversion, extraction, transfer
Wesley
OK. Fresh idea!
Horn which amplify sound about 1000X!
Than in the stream of this mega signal we put EM device based on Neodymium Magnets and coils, which is constructed in Free Fluctuation coil which is tuned in to the Resonance!
Why not?
Quote from: Ansis on June 02, 2020, 04:28:58 AM
OK. Fresh idea!
Why not?
Because you don't have a better idea.
How do you annoy some one who is anti alternative energy? answer keep poking them any way you can to build up there blood pressure.
So what's that really got to do with alternative energy ?
well think about it stutter the energy feed (interrupt it). Thanks Geo and Egor ;D ;D
Quote from: Ansis on June 02, 2020, 04:53:09 AM
There is only real things or speculations.
Nothing more/less.
Ideas comes from Nature/God.
That`s it.
It`s my idea.
That`s it.
Others can do what they want.
Amen.
Hi Ansis, go for your idea, letus know how you get on.
chears Raymondo
12v 40w x2 Jensen Audio amp fed through the 12v to 120v transformer now works lighting up a 25w bulb--Im still shooting for higher.I also used a 300w purple "Urban" amp,I blew an output but repaired it.The OPA541 module got blown by accidentally shoving 72v into it by hooking up the batteries wrong--have another on the way from China.I figured since the resonant frequency falls close to the audio arena,why not try an audio amp.Both the "Urban" and "Jensen" use nearly the same config-unplug one,plug in the other--Jenson is more efficient.On the O-scope there is 2 frequencies,the lowest about 1/20 the highest--but the frequencies spread up to 1.5MHz--These are not coming out of the audio amps.
Sorry for interrupting with magnet motors :
short note on the run:
INVESTIGATION ON THE FREE ENERGY MAGNET MOTORS NEO TENG YI
A project report submitted in partial fulfillment of there
requirements for the award of the degree of Bachelor (Hons
of Mechatronics Engineering Faculty of Engineering and Science University Tunku
Abdul Rahman ]May 2011
http://eprints.utar.edu.my/150/1/MH%2D2011%2D0705513%2D1.pdf (http://eprints.utar.edu.my/150/1/MH%2D2011%2D0705513%2D1.pdf)
Wesley
Memo :
1. Sommerfeld and Zenneck wave propagation for a finitely conducting one-dimensional rough surface
https://vdocuments.mx/sommerfeld-and-zenneck-wave-propagation-for-a-finitely-conducting-one-dimensional.html (https://vdocuments.mx/sommerfeld-and-zenneck-wave-propagation-for-a-finitely-conducting-one-dimensional.html)
2.[IEEE Propagation Conference (LAPC) - Loughborough, United Kingdom (2010.11.8-2010.11.9)] 2010 Loughborough
Antennas & Propagation Conference - Isolation of the Zenneck surface wave
https://vdocuments.mx/ieee-propagation-conference-lapc-loughborough-united-kingdom-2010118-2010119-58526242b641c.html (https://vdocuments.mx/ieee-propagation-conference-lapc-loughborough-united-kingdom-2010118-2010119-58526242b641c.html)
3.Download - Observation of Zenneck-type waves in microwave propagation experiments (https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html)
4.Observation of Zenneck-type waves in microwave propagation experiments
https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html (https://vdocuments.mx/observation-of-zenneck-type-waves-in-microwave-propagation-experiments.html)
5.Possibility of superluminal behaviors for X -like and Zenneck waves
https://vdocuments.mx/possibility-of-superluminal-behaviors-for-x-like-and-zenneck-waves.html (https://vdocuments.mx/possibility-of-superluminal-behaviors-for-x-like-and-zenneck-waves.html)
6.Electromagnetic Surface Wave Attenuation Caused by Acoustic Wave Radiation
https://vdocuments.mx/electromagnetic-surface-wave-attenuation-caused-by-acoustic-wave-radiation.html (https://vdocuments.mx/electromagnetic-surface-wave-attenuation-caused-by-acoustic-wave-radiation.html)
7.Surface-wave luneberg lens antennas
https://vdocuments.mx/surface-wave-luneberg-lens-antennas.html (https://vdocuments.mx/surface-wave-luneberg-lens-antennas.html)
8.Excitation of sea surface wave by short-wave radiator
https://vdocuments.mx/excitation-of-sea-surface-wave-by-short-wave-radiator.html (https://vdocuments.mx/excitation-of-sea-surface-wave-by-short-wave-radiator.html)
9.Surface Wave Propagation Preliminary work developing a method for surface wave detection Amy Zheng Andrew Johnanneson.
https://vdocuments.mx/surface-wave-propagation-preliminary-work-developing-a-method-for-surface-wave.html (https://vdocuments.mx/surface-wave-propagation-preliminary-work-developing-a-method-for-surface-wave.html)
10.Lens design for surface wave applications
https://vdocuments.mx/lens-design-for-surface-wave-applications.html (https://vdocuments.mx/lens-design-for-surface-wave-applications.html)
11. https://vdocuments.mx/search?q=Zenneck+surface+wave&per_page=8 (https://vdocuments.mx/search?q=Zenneck+surface+wave&per_page=8)
12.On the relation between Surface Plasmons and Sommerfeld's Surface Electromagnetic Waves
https://www.semanticscholar.org/paper/On-the-relation-between-Surface-Plasmons-and-Waves-Dyab-Abdallah/593dd702a9b6051652a7fbf4dc4f2df38e7697a7 (https://www.semanticscholar.org/paper/On-the-relation-between-Surface-Plasmons-and-Waves-Dyab-Abdallah/593dd702a9b6051652a7fbf4dc4f2df38e7697a7)
13.Brief overview about Surface Wave theory and applications
https://www.semanticscholar.org/paper/Brief-overview-about-Surface-Wave-theory-and-Balosso- (https://www.semanticscholar.org/paper/Brief-overview-about-Surface-Wave-theory-and-Balosso-)
Sokoloff/e7f1b1a020f0f0d2bf7c45d68075690246678a79?tab=abstract&citingPapersSort=is-influential&citingPapersLimit=
10&citingPapersOffset=0&citedPapersSort=is-influential&citedPapersLimit=10&citedPapersOffset=10
14.Zenneck surface oscillations in the sphere dielectric resonator immersed in high lossy liquid
https://www.semanticscholar.org/paper/Zenneck-surface-oscillations-in-the-sphere-immersed-Ganapolskii-Eremenko/d41299173437028b336c26a8772ade0f109d62d1 (https://www.semanticscholar.org/paper/Zenneck-surface-oscillations-in-the-sphere-immersed-Ganapolskii-Eremenko/d41299173437028b336c26a8772ade0f109d62d1)
15. https://www.semanticscholar.org/paper/Surface-Waves-Barlow/686d2a3ce72918969e9a74edb49364521b2357cc/figure/4 (https://www.semanticscholar.org/paper/Surface-Waves-Barlow/686d2a3ce72918969e9a74edb49364521b2357cc/figure/4)
16. https://pdfs.semanticscholar.org/d3c2/de8b26cfcb179dc63ec3e3c7ed75ffefe494.pdf (https://pdfs.semanticscholar.org/d3c2/de8b26cfcb179dc63ec3e3c7ed75ffefe494.pdf)
17.The Excitation of Plane Surface Waves
https://www.semanticscholar.org/paper/The-Excitation-of-Plane-Surface-Waves-Cullen/d3c2de8b26cfcb179dc63ec3e3c7ed75ffefe494 (https://www.semanticscholar.org/paper/The-Excitation-of-Plane-Surface-Waves-Cullen/d3c2de8b26cfcb179dc63ec3e3c7ed75ffefe494)
18.The application of electromagnetic surface waves to wireless energy transfer
https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06 (https://www.semanticscholar.org/paper/The-application-of-electromagnetic-surface-waves-to-Peterson/f9d3824240e41b4748a403adbd0c140f2f580a06)
19.THE PROPAGATION AND EXCITATION OF SURFACE WAVES IN AN ABSORBING LAYER
http://www.jpier.org/PIER/pier19/02.970718p.Ling.SU.pdf (http://www.jpier.org/PIER/pier19/02.970718p.Ling.SU.pdf)
20.Surface wave
https://wiki2.org/en/Surface_wave (https://wiki2.org/en/Surface_wave)
21.Why Do Surface Waves Exist?
http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf (http://emlab.utep.edu/ee5390em21/Lecture%2021%20--%20Surface%20waves.pdf)
22.Excitation of the Zenneck surface wave by a vertical aperture
https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969 (https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969)
Wesley
I miss very much
Jerry..the owner of Keelynet.com
Jerry Passed away suddenly 2017/06/19, he will be missed.
Not everyone knows about it, and people are asking me why Keelynet is down.
Wesley
https://vdocuments.mx/chapter-2-waveguide-and-components-propagation-mode-of-electromagnetic-wave.html (https://vdocuments.mx/chapter-2-waveguide-and-components-propagation-mode-of-electromagnetic-wave.html)
way to understand phenomena in Waveguide
where main for us is TM transverse Magnetic mode
Wesley
https://www.nature.com/articles/s41467-020-16114-x
use of NMR to investigate batteries and its material as a transition from gasoline to electric power
Wesley
Wesley,...few years back was speaking with Jerry's friend and partner/associate..He was quite upset about loosing Jerry and about where all this would go.[Keely net, Some people were trying to help him ??
Will see if I can find his number and give a call [very nice fellow]hope all is well By you.[and thx for all you do for open source community]
respectfully
Chet K
Hullo!
I've been doing some disrelated research to energy... so this may seem to be coming from entirely out of left field.
Let me start with some links, and then go on to explain what they are...
https://www.geogebra.org/3d/spxzup4s (https://www.geogebra.org/3d/spxzup4s) (arccos)
https://www.geogebra.org/u/d3x0r (https://www.geogebra.org/u/d3x0r) (various graphs I've done with this neat widget, mostly disrelated to the eventual discussion)
https://www.geogebra.org/m/a5dauj6s (https://www.geogebra.org/m/a5dauj6s) (this was early attempt, it is very slow; it's essentially the same as the first, but 2 dimensional instead of a slider)
I did figure out, however, extended arcsin and arccos that are valid; but arccos(cos(a)+cos(b)) is a number that only that operation can produce. (or approximate with a bunch of other things). Makes picking a random secure key kinda nice - suppose that's where elliptic curve stuff is based.
https://d3x0r.github.io/STFRPhysics/math/ (https://d3x0r.github.io/STFRPhysics/math/) This is arccos(x) - (x*2/pi) ... +/- 1 around the origin... The difference in the change for adding a little bit at the ends are a very steep slope. (sine, is similar, but harder to graph, because it loops back on itself and doesn't really go anywhere).
The slope of the arcsin(x) curve is similar if reverse biased with a counter instead... the existing arc-sin can sort of work as-is, but store the number of wraps in a counter floor(angle/2pi). in parallel with the sin result, and then the original angle can be recovered also; otherwise sin() can only return the principle angle. cos(), however, can return the number of wraps ...
This is hard to explain exactly what this graph is showing... but it does remind me of the electron orbital shapes. This also is why from the middle (0) to negative.. until a maximum of absolute 0, the next step is the hottest thing. (If the thing itself is very hot then it will give energy to the system and prevent the system as a whole from going below 0. There's a good chance the same behavior happens at the top end, so you have to put in more and more energy exponenetially (leaving the origin) until a maximum, which inverts very which quickly to reverse the state to the other directions.
The feedbacks only occur where arccos( cos(x) + n ) > 1 .
while resolving what the graph of arccos looks like, it actually simply extends, because the 'forward' is +/-1 and balances out in a 'real' way. It is basically the shape of a closed surface; although vertically up and down it is also the same as the sine graph. The sine graph in its 'natural' state is the shape of open space...
I spent some time developing some meshing algorithms a while ago...
https://d3x0r.github.io/IsoSurface-MultiTexture/ (https://d3x0r.github.io/IsoSurface-MultiTexture/) In this demo, there is a 'sine waves' Input data, which is a 3d plot of sin(x)+sin(y)+sin(z), and the surface at 0.... The surface itself is entirely 1 surface, but has inifinite holes in it(?) ... the arc-sin function at >1 wraps backwards on the x-axis ... the space immediately 'in front' of sine is real and imaginary (open)... so the arcsin function is the graph of the open space side... Anyway; it's all a matter of perspective, if you just are the thing rotating, it's all just silly to think about.
Okay so then, A while ago I was playing with `mobially` wound coils (ABHA), and my royer/scope had huge feedback especially under load... The graph of the normalized arccos( cos(x)*2 ) looks a lot like that... such that what was coming back was greater than 1x cos wave (?). Probably a coincidence. However, this other graph, but to go back to the numbers, the projection of power outside the curve reflects differently immediately in the view of deltaX... at deltaX+1 it's very hard to get some places... The function of arccos( >1) is also negative, but odes not reach the full range of the negativity... this would be a very good solution for rubber banding/exponentiated limiting...
Hopf Fibrations - https://www.youtube.com/watch?v=AKotMPGFJYk Fasciating :) These are those neat interlink toroidal links, which are a subset of quaternions (all that wonderful math I've been doing). They resemble the shape of magentic fields... (although I suspect moving iron filings is a projection of the field, and not really the field itself.... )
So; I built this fancy new mesher that can generate arbitrary shapes, and dynamically reshape them (dig out some of the closed space); but then I need to know where it 'is' of the physics of the thing, so I started on this physics engine, but Matricii (Matrixes) are limited in their ability to carry rotations except for very small ticks; and quaternions are really no better... there is, however, a layer under the quaternions called 'log quatnerion' or apply the natural log function to a quaternion, which just makes it a 0 ( exp(0) = 1 ). and a bunch of imaginary rotations for each axis in the total angles each... these then get 'truncated' to 2pi, or their principle values, and can be applied as quaternions or matricii, and get some rotations... but there's been NO math on these.
It's like all this time there's this huge issue that noone's figured out a mapping from the rotation space ( arcsin( sin(a)+sin(b) ) and arccos(cos(a)+cos(b)) ) being the axises... The arcsin and arccos functions are 'continuous' in rotation space.... but somehow when sine rotates it affects the cos part.
(wow I'm really sorry, I'm realizing this is probably all about 99% useless, which makes it effectively a nil thing)
J
https://www.youtube.com/watch?v=BYLCH33UWwU (https://www.youtube.com/watch?v=BYLCH33UWwU)
https://www.amazon.com/Yinlong-66160H-Battery-Energy-Storage/dp/B07P1MZY5T (https://www.amazon.com/Yinlong-66160H-Battery-Energy-Storage/dp/B07P1MZY5T)
Wesley
Hello Wesley,
interested in cheap electricity storage I saw as alternative,1/2 price : https://www.alibaba.com/product-detail/GOOSUN-hot-sale-lto-battery-55ah_62140142727.html (https://www.alibaba.com/product-detail/GOOSUN-hot-sale-lto-battery-55ah_62140142727.html)
Keep it well
OCWL
tnx LankaIV
here for curiosity is :
What's Inside a Tesla Model S Battery Pack -- World's FIRST Tesla Swapped Nissan 350Z - Part 9
https://www.youtube.com/watch?v=ENu8uuPIss8
(https://www.youtube.com/watch?v=ENu8uuPIss8)https://www.youtube.com/watch?v=ouOqWZM28Qw (https://www.youtube.com/watch?v=ouOqWZM28Qw)https://www.youtube.com/watch?v=oM8YKgSgfxs
Wesley
https://youtu.be/Z7rd04KzLcg?t=2201 See also this Eric Weinstein guy... Geometric Unity: A First Look which is about... well a lot of geometry babel :) But essiantially.. trying to get to work within the base system (curvature) instead of the product of evaluation of curvature (matrixes/quaternions) which are what relativity is actually sort of based on - it's a truncate -1 to +1 system because of 'symmetry'
I'm starting this other thread... I won't bother you with this any more; but I do sort of want to share a lot of this.
https://www.youtube.com/watch?v=mBjBuP0oPbc (https://www.youtube.com/watch?v=mBjBuP0oPbc) THis is just using some plastic yard trimmer line to make a neat fidget toy.
https://d3x0r.github.io/STFRPhysics/3d/index.html (https://d3x0r.github.io/STFRPhysics/3d/index.html) I did make this demo to view rotations as natural angles instead of matrixes or truncated quaternions. (I know, mathy graphical things, but really, primordial to relativity (curvature), and quantum mechanical spin states.
If you move the Z slider .... no if you Click on the Z slider and then use the arrow keys to move it a couple ticks left or right.... and then click on the blue-ish ball and rotate to the right... You'll see some interesting shapes start to form... the primary curvature reminds me of a magnetic iso-potential flux line through a solenoid coil... where with very small rotations, the solenoid is tall and thin, and as you increase the rotations it becomes more circular - to the point of almost being circular... BUT that rotation line (which there's a curvature.md document in the git repository that describes this in more detail... and there's a link at the bottom of the demo to the repository)
https://overunity.com/18542/review-of-mobially-wound-coils12-abha (https://overunity.com/18542/review-of-mobially-wound-coils12-abha)
J
- There's no such thing in the real universe as a point, or a thing with infinite curvature. there are things that go in a line with 0 curvature.
- 'curvature' and 'angle' mathematically are the same values and use the same functions; they're sort of like different units (degrees or radians, but more like cubic-centimeter and milli-liter) Angle sort of implies you had an origin you're rotating around, where curvature applies to the point whereever it is (if anywhere).
https://youtu.be/Z7rd04KzLcg?t=2201 (https://youtu.be/Z7rd04KzLcg?t=2201)
Wesley
This is a double post. https://overunity.com/13925/toroidal-coils/msg547891/#msg547891 (https://overunity.com/13925/toroidal-coils/msg547891/#msg547891)
For the electrical engineers... If I count the turns, and count the radius, and get an LC, and measure that LC for a coil to be the same, the coil IS the same as any other coil of similar LC?
Then how would anyone ever know the difference. This is NOT tough; and there is no trickery in the jump cuts. No video I make and post or promote has ads or is expecting some personal gain from you watching it.
Edit: https://www.youtube.com/watch?v=u9kUO3Luzfw (https://www.youtube.com/watch?v=u9kUO3Luzfw) (winding plastic coils with wire instead)
which becomes the test coil in these...
https://www.youtube.com/watch?v=zuIiA7TWzmY (https://www.youtube.com/watch?v=zuIiA7TWzmY)
https://www.youtube.com/watch?v=TUZyoQwoG9c (https://www.youtube.com/watch?v=TUZyoQwoG9c)
J
So... in the kapanadze aquarium video... there's this toroid slinkly like coil (apparently; you don't really know the inner geometry), with a spark gap that's a high voltage impulse generator.
The coils respond - transfer power, on the edges of a square wave....
and I'm just going to quote myself from somewhere else
My friend the skeptic kept saying - look it's just like every other coil, don't you think over the past X hundred years... yadda yadda .... And it's the same resistance everywhere, even from people that are open to new ideas...
I understand we're all a lot jaded - disatisfied by any, really, even interesting result...
I kept trying to give away my lab ... free to a good home.... But the above requires no special ferrite, a pulse generator probably would work best - a very sharp impulse since that's what the ringback is anyway
I also have come to understand that although what I'm trying to show is plain as day and simple for me - like if anyone half cared to analyze these videos like kapanadze videos they'd actually not have that had of a time. ... but at the same time I'm showing you glass of water, and I'm saying it's fresh water, and not salt water, but you can't touch or do anything with it yourself, so all you can do is say well, test it like this... but I don't need to it's quite fresh... that's an entirely different glass of water over there.... and ... maybe ... this can show you it's really not so hard to get a couple glasses of water yourself?
J
I do Hope all are well...
Me; I don't really have a lot of time to wait around for confirmations from anyone; I dodn't know who else to implore to take a few arm-spans of wire and tinker....
It has a few inches of usable wireless tranfer range ; probably more if you had a proper resonance....
I may not have stressed enough - the reaction to get power on the pick coil is in no way resonance; it's a 'high' frequency because the LEDS were really only lighting on the leading edge... and I needed a lot of leading edges to make it bright...
And maybe I should be skeptical of myself, and say, If there is any trickery I did, I'm not are of it, and can't imagine what sort of trick I might have pulled when I wasn't looking.
-- Correction --
I did have one of the coils shorted on the one case, I can't prove any difference this way.
Wish someone else would have spoted - hey... those two blue wires... they shouldn't be together? Oh, right.
I'll have to keep diggging. Sorry
I do have questions about what 'exactly' is 'a caduceus coil'
These are just shared from my account... I did post this video a while ago.
If the Green coil first shown is 'caduceus[/size]' ...
https://photos.app.goo.gl/RFKXQqDBqmZxBmP87 (https://photos.google.com/share/AF1QipMcJKz_ylqNMe-zWAt65xjWj-w5JHKS-fvZK-Rh9agh9rga-R0mFlOYTzqzAs8l0Q?key=VEoyN0t4S2pMWWhac2pFaVAxTFZWRmtjZy1tRzBB) (video, only the first seconds matter) the rest are images.
Then isn't also this red wound coil? That's just a single wire.
https://photos.app.goo.gl/wEJAZVugrWaTHPSc6 (https://photos.app.goo.gl/wEJAZVugrWaTHPSc6)
do crosses at the poles count?
https://photos.app.goo.gl/E3uKufigic37z3gn7 (https://photos.google.com/share/AF1QipMucCKE-3VfstgD0NJPHlsbMSQeM6VCSLVyif8rJR68Gdaz3sN0l80j9a_tGcCv-Q?key=dXNrYVBMX0haUW03cW5VYmtYdGU1RElaU0pxNjl3)
https://photos.app.goo.gl/4d7nhDK4Upk5PFGy5 (https://photos.app.goo.gl/4d7nhDK4Upk5PFGy5)
https://photos.app.goo.gl/JsfmxxtjoeENFs78A (https://photos.app.goo.gl/JsfmxxtjoeENFs78A)
https://photos.app.goo.gl/G6rUgUvkNBuaNUyL8 (https://photos.app.goo.gl/G6rUgUvkNBuaNUyL8) (bigger really isn't better...)
https://photos.app.goo.gl/HgvzXfHTJYn9yDkr5 (https://photos.app.goo.gl/HgvzXfHTJYn9yDkr5) (collapsed)
Quote from: d3x0r on July 13, 2020, 03:24:29 PM
Follow the story on Wilbert B. SMITH.
Story said that geometry of caduceus coil was given to him from contacts with aliens as free energy coil.
http://www.rexresearch.com/smith/caduceus3.htm
http://www.rexresearch.com/smith/smith2.htm
I did go back and dig up aquarium photos and there is more visible than I remembered.... ya and this would be entirely different than that ....
So... if I had a coil of wire, and drilled some holes in it an wound one of the mobial coils... 1( I could have it entirely cross and have the opposing side vertical with the outside...
could also twist the ends, but to make the outside loops vertical, the inside would have to be wrapped around and look more solenoial than across...
https://photos.app.goo.gl/rKrHsVsGyuWB9do39
Quote from: d3x0r on July 14, 2020, 02:19:05 AM
Aquarium?
Kapanadze used sometimes Caduceus and sometimes bifilar.
He said that Caduceus is better , but bifilar is also good.
Both are capacitor coils.
Is there any connection to that?
On picture it seems Caduceus?
That coil was used when Wesley meet Kapanadze,
and Kapanadze made small device for him to observe.
And Caduceus symbol looks more bifilar to me, than Caduceus.
In Sumerian tablets it represents ability to fly.
Or maybe the source of power for the flying engine?
This symbol is used also as medical symbol over the centuries.
It did not change much in time.
Maybe someone before us knew the secret?
But, if the head and tail means polarities,
why heads are on the same side,
and tails on the other?
So, at the end Caduceus could be free energy coil?
https://youtu.be/7GlaYj7J5s8?t=541 (https://youtu.be/7GlaYj7J5s8?t=541) (starts at 9:01)
Lithuania OU experiment #3 of series of videos.English.
this is really convoluted story
Patience is required to understand all of the variables
Svobodian Andrey is Dead.
source: https://www.youtube.com/watch?v=ppg8gG5tD5g (https://www.youtube.com/watch?v=ppg8gG5tD5g)
according to :
This video is made by MOHAPX100 the critic of Svobodian Andrey
Video explains in Russian that Svobodian Andrey died.
He also stays that death was not natural and likely caused by some sort of "Mafia"
Quote: <people with whom Svobodian Andrey should not make jokes>
some other material to remind you who is Svobodian Andrey :
https://www.youtube.com/watch?v=4yoxX5ujhig (https://www.youtube.com/watch?v=4yoxX5ujhig)
https://www.youtube.com/watch?v=_8uUrjnW5w0 (https://www.youtube.com/watch?v=_8uUrjnW5w0)
cause:
from fire and fume caused by faulty air conditioner in his lab/room* .
claim: he didn't wake up..on time..
Main characters involved:
1- MOHAPX100 youtube blogger Russian heavily attacking Andrey Tirtha and Svobodian Andrey( author of revelation)
2- Andrey Tirtha Андрей Тиртха youtube blogger
3- Svobodian Andrey self made inventor of magnetic motor, youtube blogger from South Korea originally from Moldova-( not conformed)
4- Sergey Kachan youtube blogger excellent professional attacked by Tirtha.
5 -Wesley : me who made few videos about Svobodian Andrey
Explanation in points:
1. MOHAPX100 made number of ~20 videos criticizing Svobodian Andrey.as thieve, fraudulent lair abusing other people's money.
Svobodian Andrey sued him for 20 000 dollars due to this criticism and around 10 month ago, he lost in Russian court.( corrupted Russian court)
2. MOHAPX100 is Russian who says that:
he doesn't care about viewers opinions expressed, nor his own channel, nor money made from YouTube.
he makes only ~$5.67 per month from monetizing of ~100+ of his videos but still keeps monetizing ..
Question is why?
Who compensates him for his work? Russian propaganda?
3. MOHAPX100 "celebrating" now death of Svobodian Andrey
He says that 10 month ago group of people knocked to his door demanding him to stop criticism of Svobodian Andrey "Unexpected visitors"
said
Quote:that Svobodian Andrey promised them to pay their invested in him money back,
if they stop negative videos of MOHAPX100
quick introduction to Svobodian Andrey :
Inventor of magnetic motor emigrated to South Korea where he found and investor.
Heavily criticized by Russian propaganda
4. Андрей Тиртха (Andrey Tirtha)
who in ~Mar 4, 2019 visited Svobodian Andrey in South Korea and made supporting videos.
a. https://youtu.be/3kA3CW5FD5Y?t=97 (https://youtu.be/3kA3CW5FD5Y?t=97)
Andrey Tirtha the supporter of Svobodian Andrey is threatening
Sergey Kachan https://www.youtube.com/user/Dssvvx/videos (https://www.youtube.com/user/Dssvvx/videos)
with Russian Court for his criticism of Svobodian Andrey
Note : Interesting is that Andrey Tirtha is Ukrainian suspected as working with Russian propaganda.
Very questionable in value of published material. I have negative opinion about his channel.
b. Andrey Tirtha videos supporting Svobodian Andrey:
- https://www.youtube.com/watch?v=pIJ9eDirCuQ (https://www.youtube.com/watch?v=pIJ9eDirCuQ) video criticizes Сергей Качан Sergey Kachan
-https://www.youtube.com/watch?v=tfVIJiHwL9Q
-https://www.youtube.com/watch?v=3kA3CW5FD5Y
-https://www.youtube.com/watch?v=IKEIl3zIJLg
5. MOHAPX100 says: that Svobodian Andrey collected ~2 million dollars from investors and he was approached by
some sort of Mafia ( presumably Russian mafia- my own addition)
and that caused his death.
Legal note:
All of the wording used and opinion expressed is my personal opinion only.
My understanding of Russian language may cause non-accurate translation.
My rights as an American to my freedom of speech is written in American constitution.
All facts may be corrected if found misleading or incorrect.
No apology is intended to be served to any offended party as my intention is not to offend anyone.
Wesley
questions formulated by СЕРГЕЙ:
СЕРГЕЙ STALKER,
8:14 AM
примерный список вопросов только по тесле:
1.число витков индуктора
(amount of winds of primary coil of Tesla Coil assembly - called bellow T.C*.)
2.расстояние от индуктора до HV теслы
( gap between Primary and secondary of T.C*)
3.на сколько широко располагается индуктор по отношению к ширине намотки теслы
( diameter and drawing of assembly T.C*)
4.как выбирается длина провода теслы.
(How to calculate length of wire used for Tesla T.C*assembly)
5.как изменяется частота теслы с заземлением и без
( How frequency of T.C* changes when with ground [ connection] and without)
6.длина заземления теслы
( length of wire of ground cable of T.C )7.сечение провода теслы ( diameter of ground wire of T.C )
8.шаг провода теслы
(pich of wind to wind [ distance] of T.C*)
9.диаметр намотки и соотношение к высоте намотки и как влияет на габариты уединённой ёмкости
( diameter of winding and its relation to height of winding and how it affects at mutual capacitive reactance)
10. исходя из чего выбирается уединённая ёкость
( what mutual capacitive reactance depends of in T.C*)
11. как влияет форма уединённой ёмкости на её ёмкость
(how form of mutual capacitive reactance affects on physical capacitance of assembly in T.C*)
12. что определяет частоту теслы
(what frequency of T.C*- Tesla Coil assembly depends from.)
13. что определяет LC резонанс теслы и как смещать эти частоты
( what LC resonance in T.C* depends from and how to mix these frequencies)
14. меняется ли LC резонанс от наличия заземления
( is LC resonance in its form and/or frequency dependent from form and quality of grounding)
15. как определить в каком волновом распределение находится тесла от подаваемой частоты
( how to find/calculate frequency difference and frequencies distribution range ,
and how much they are differing from main frequency feeding primary of T.C*)
( that question apply to both independent cases:
этот вопрос относится к обоим независимым случаям :
a. when T.C* is fed by spark gap generator. (когда T.C * питается от генератора искрового разрядника.)
b. when T.C* is fed by single frequency generator) ( когда T.C * питается от одночастотного генератора)
16.как влияют формы и режимы питания индуктора на тип разряда теслы
( how is form and type of <powering> feeding of T.C * impacting discharge of HV Tesla coil (if desired.)
17. при каких условиях появляется статический потенциал вокруг теслы и как изменить его знак
what conditions must be met to create static charge around T.C * and how to change its polarity (+/-)
18. как влияет сопротивление заземления на режим работы теслы
( How impedance/resistivity of ground/ing is affecting stability of Tesla coil - T.C * work/tuning )
19. как диаметр каркаса при неизменной длине проводника теслы влияет на габариты уединённой ёмкости
( how <Fi> size of coil former (HV coil) is affecting mutual capacitance/capacitive reactance
if we just change <Fi> of coil former but we don't change physical length of wire used for that HV coil)
20. как высота уединённой ёмкости над теслой влияет на её LC резонанс
(How height of Top capacitor [ distance from the ground/elevation change ] affects LC resonance frequency of T.C *)
21 как выбрать длину индуктора и соотнести с длиной проводника теслы
( How to chose length of HV coil former based on desired length of wire used to wind HV Tesla coil of T.C* assembly.)
22. направление намотки проводника теслы и её индуктора
( CW or CCW direction of winding both coils - the HV and primary coil of T.C* assembly.)
23. может ли работать тесла без индуктора
( can Tesla coil work without primary coil?)
24 как выбрать напряжение питания теслы
( how to chose/ calculate the voltage used to power T.C* assembly.)
25. какая разница между раскачкой теслы с помощью магнитного поля или электрического поля
( what is the difference between starting T.C* by use of magnetic field or electric field/ potential )
26. как формируется стоячая волна в тесле
( how standing wave is formed in T.C*)
27. по какой причине разряд теслы без тока
( what is the reason of HV Tesla coil sparking to the ground?)
и этот список можно продолжать и это только тесла.
Вот это всё знать как "Отче наш" а после уже к системе переходить.
And that is the list of the most important fundamental questions.
( the guide describing fundamental ruling of to how to make Tesla coil acting as FE converting device from known and properly recognized
energy source at its natural origin)
That Tesla Coil assembly T.C* will act as your device you are looking for to get your free Energy for Free.
На большинство ответов я смогу дать ответ, не спрашивая разрешения у доктора Ханса
Важна только форма этого объяснения.
Будет ли это :
1. видеоклип на YouTube?
2. YouTube-лайф презентация в реальном времени с чатом - чтобы задать вопросы и сформулировать мысли?
3. ..... Skype конференция ( скриншоты и видеоролики, а затем обсуждение.)
Answer to most of the questions I will be able to formulate
in form that will be chosen for it:
1. Youtube
2 Youtube with chat as conference
3. Skype
Wesley
Thanks for doing a great explanation on Andrei...
Acca aka Al...
https://www.tntech.edu/engineering/research/cesr/wireless-power/power-through-earth.php
Wesley
competition to Dr Corum in rights to technology
https://patents.google.com/patent/US2542462 (https://patents.google.com/patent/US2542462)
Wesley
Publication number:
hujlo-von #2 Patent with earlier filing date: Zenneck wave A to B energy transfer applied by me and Dr Hans.
Explanation of page 1.
The technology described in patent of
Charles I. Beard will be compared to
generalized PhD. J. Corum patents.
Charles I. Beard:
QuotePulses are applied to the earth surface directly.
J.Corum: Quote energy is applied by means energy entering interface at Brewster Angle
Conclusion:
the J.Corum method is not only one that creates Zenneck wave(known also as surface wave )( known also as boundary wave) in the interface.
Charles I. Beard:
QuoteWave traveling along the boundary or interface between two media.
J.Corum:
QuoteInserted Zenneck wave exist in the boundary between earth( the lossy conductor) and air( the dielectric)
Conclusion: both statements are exactly the same from physics stand point.
Charles I. Beard:
Quoteboundary wave is cancelled
J.Corum
Quoteboundary wave is not canceled , not reflected and not refracted.
Conclusion: in order to cancel something first you must detect it.
:) in any of the cases this is the prove of Zenneck Wave in the interface.
Wesley
How can these serpentine printed inductors work like inductors? in the same place, in adjacent conductors, currents flow in opposite directions. It looks more like a bifilar.
https://proxy.imgsmail.ru/?email=krol86ik%40mail.ru&e=1600596030&flags=0&h=eQOt0t0F43C-RPSkTpxtzQ&url173=Zm9ydW1zLnJhZGlvZGV0YWxpLXNmZXJhLmNvbS91cGxvYWRzL21vbnRobHlfMjAyMF8wOS8xLnRodW1iLmpwZy43NDc3YWQ3NzQ0MGNjMmMxZjRlZDA5MzZkZmE5NjkwOC5qcGc~&is_https=1 (https://proxy.imgsmail.ru/?email=krol86ik%40mail.ru&e=1600596030&flags=0&h=eQOt0t0F43C-RPSkTpxtzQ&url173=Zm9ydW1zLnJhZGlvZGV0YWxpLXNmZXJhLmNvbS91cGxvYWRzL21vbnRobHlfMjAyMF8wOS8xLnRodW1iLmpwZy43NDc3YWQ3NzQ0MGNjMmMxZjRlZDA5MzZkZmE5NjkwOC5qcGc~&is_https=1)
Quote from: kolbacict on September 17, 2020, 06:23:22 AM
Capacitance between winds and inductance of wire creates impedance of printed circuit path acting as resonance filter/ choke/impedance matching/attenuator e.t.c
Wesley
it might be interesting ...
http://www.unconv-science.org/pdf/25/stepanov.pdf (http://www.unconv-science.org/pdf/25/stepanov.pdf)
PART#1
original articleQuote from: kolbacict on September 24, 2020, 01:26:43 PM
yes it is thank you.
Wesley
PART#2
Translation of article from above:On the physical effects arising from the
outflow of high-pressure water
Quotevapor from a spiral channel formed
by a steel pipe wound on a conical mandrel
I.N. Stepanov ∗
Abstract — The reason that prompted the publication of this article was the work of
I.A. Melnik
about the appearance of rotating masses in the vicinity
unidentified field called field rotation, which affects the half-life
... This work is
the closest analogue of the experiment carried out in 1981, according to the idea of the famous scientist A.F. Okhatrina.
The scheme of the experiment is presented and the goal of the task is stated.
Given a description of the parts of the equipment used and devices.
The results of the measurements are given, presented in graphical form, and
also information about the pathogenic effects on experimenters who were near the working
installation.
I
n the early 80s. A.F. Okhatrin, on the basis of his theoretical studies, suggested that when high-pressure
water vapor is passed through a metal tube wound on a conical frame,
when the vapor flows into the atmosphere, i.e. in the vicinity of the apex of
the conical spiral, ionizing radiation is possible.
The idea was so interesting that it was decided to test this assumption experimentally
A 25-litre
steam generator with a built-in 4 kW was used as a .receiver
The thickness of the receiver's walls allowed to get overheated steam with pressure up to 16 atm.
The spiral channel thin-walled steel tube Ø16х1 in length of 20 m was wound on a circle from 16 mm of plywood
in diameter of 70 mm, laying on a horizontal plane, "turn by turn"
When the winding was completed, a flat spiral was obtained, consisting of 20 turns, the largest of which had a diameter of 800 mm,
the diameter of the small turn was 100 mm.
After being removed from the mandrel, the flat spiral was additionally stretched along the axis by about 1 meter so that, as a result,
the generatrix of the resulting funnel acquired a shape close to an exponential, (Spiral cone)- funnel.
In order to eliminate possible distortions of the obtained spatial shape of the channel,
during the experiments, a light supporting structure was made for the spiral, which
corresponded to the final shape of the envelope.
This frame made it possible to position the funnel in such a way that its symmetry axis
lay in the horizontal plane, the rotation is right
The block diagram of the experimental setup is shown
in Fig. 1.
The outlet pipe of the
steam generator through the valve was connected with a hose to the beginning of the
spiral (turn of the largest diameter).
Steam flowed along the spiral channel accelerated, so that the maximum flow velocity was observed
at the end of the tube with free flow of steam into the atmosphere near the spiral axis
.A.F. Okhatrin assumed that in the process of accelerating the flow of steam in a spiral and
its outflow into the atmosphere, an electric current and ionizing radiation should appear in
the spiral near the apex of the cone
Therefore, in the region of the end section of the tube on the axis of the spiral, an ionizing radiation
counter STS-6 was placed, connected through a preamplifier to a
frequency meter Ch-3-33,
and a DC voltmeter was connected to the ends of the tube
The experiment was carried out as follows.
When voltage was applied to the heater, the STS-6 counter was started.
He showed a natural background of radiation at 13 micro-roentgen / hour,
and a voltmeter - zero potential difference at the ends of the tube
After the steam generator heated the water and the superheated steam pressure reached 16 atm,
the valve was opened and steam entered the spiral channel.
From that moment on, the STS-6 meter began to record a gradually increasing number of pulses,
and the voltmeter - the emergence of a potential difference with positive polarity at the beginning of the tube.
________________
Approximately 105 seconds after the beginning of the steam outflow from the tube, the number of
pulses recorded by the counter reached a maximum of 11 milliroentgens / hour, which exceeded the
natural radioactive background by almost three orders of magnitude, and after that it began to gradually decrease.
The readings of the voltmeter, whose numerical values reached a maximum of 2 volts, behaved in a similar way.
The results of measurements of the number of pulses recorded by the STS6 counter during the spiral flow of steam are shown in Fig. 2.
By the end of the experiment, which lasted 195 seconds, the pressure in the steam
generator became equal to atmospheric pressure and the outflow of steam stopped.
By this time, the STS-6 counter readings returned to a level of 13 microroentgens / hour,
and the voltage at the ends of the coil became zero
problem #3.
In addition, it should be added that the installation during experiment
- had a clearly pathogenic effect on the experimenters when in close proximity to the device.
-pulsed headaches,
-dry mouth,
-mild nausea,and loss of energy were felt.
After the steam was completely out from the device
in about one hour later
all the negative effect on the experimenters bodies ceased.
end of translation
the conclusions will be in the next comments
Wesley
While looking in the internet for the
Author: Alexander Shishkin
mentioned by Martin Fleischmann Memorial Project (https://www.youtube.com/channel/UCEy09JW5XAd95JmknU1JOeQ)
in the video https://www.youtube.com/watch?v=gcF-KSLIAWs (https://www.youtube.com/watch?v=gcF-KSLIAWs)
Video title: A New Type of Penetrating Radiation (Alexander Shishkin)
1,719 views •Feb 8, 2019
who in •Oct 5, 2018 made video having only 204 views
Title of video: Alexander Shishkin - Part of 25th Sochi CNT&BL Presentation
https://www.youtube.com/watch?v=68BOYCbtcwc (https://www.youtube.com/watch?v=68BOYCbtcwc)
I went across very interesting list of Andrea Rossi
https://e-catworld.com/display-posts/ (https://e-catworld.com/display-posts/)
The purpose of the site is to provide a place for news, information, analysis and discussion of all things
pertaining to Andrea Rossi's Energy Catalyzer invention which holds the promise of providing a much
cheaper, cleaner and more efficient means of power production than we have ever seen.
surprisingly this list is still active
with the latest news:First Third Party Test Successful, Certifying Agency Testing Scheduled (https://e-catworld.com/2020/09/24/first-third-party-test-successful-certifying-agency-testing-scheduled/) (9/24/2020)
Note: All of said above in the last few posts starting from
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551033/#msg551033 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551033/#msg551033)
is talking about LENR .
Wesley
PART#5
continuation from Part#4
Analysis of problem#3 listed in PART#2
Quote from: stivep on September 25, 2020, 10:04:41 AM
PART#5
Quote from: stivep on September 24, 2020, 07:27:55 PMwe can take all of mentioned and come to conclusion
If for the moment we start to think that for some reason :
-Andrea Rossi is not the hoax magician.
-Russian with https://www.youtube.com/watch?v=gcF-KSLIAWs (https://www.youtube.com/watch?v=gcF-KSLIAWs) is not the hoax magician.
-Russian with https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551033/#msg551033 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551033/#msg551033) is not the hoax magician.
-Italian Scientists https://www.youtube.com/watch?v=xQ-_T1nWqP0 (https://www.youtube.com/watch?v=xQ-_T1nWqP0) who are base on Russian Experimenters are not the hoax magicians.
-My own Experience with http://rexresearch.com/colman/colman.htm (http://rexresearch.com/colman/colman.htm) presented in https://www.youtube.com/watch?v=-PMMK4KHXYU (https://www.youtube.com/watch?v=-PMMK4KHXYU) is not my hallucination.
-My own suffering in Lithuania Experiment was manifestation of NEUTRON emission (and Gamma as phenomena associated with Neutron emission ) from Yoke.
THAN WE HAVE MADE - a NEUTRON GUN .
AND NEUTRON GUN (neutron emission) IS THE PRIMARY TOOL ALWAYS PRESENT IN ANY and Every LNR
( LOW ENERGY NUCLEAR REACTOR)
By means of Neutron bombardment we affecting structure of an atom leading to disintegration by means of Transmutation.
-that would explain Free Energy phenomena explainable is my experiments
-that would explain what the energy comes from :1. Harold COLMAN & Ronald GILLESPIE
Power Generator
https://www.nuenergy.org/a-new-apparatus-for-producing-an-electric-current/ (https://www.nuenergy.org/a-new-apparatus-for-producing-an-electric-current/)
2.
Hendershot Fuelless Generator:
https://revolution-green.com/hendershot-fuel-less-generator-fact-fiction (https://revolution-green.com/hendershot-fuel-less-generator-fact-fiction)/
https://fuel-efficient-vehicles.org/energy-news/?page_id=1166
(https://fuel-efficient-vehicles.org/energy-news/?page_id=1166)3.
Nicola Tesla anecdote (https://en.wikipedia.org/wiki/Anecdote) electric car https://en.wikipedia.org/wiki/Nikola_Tesla_electric_car_hoax (https://en.wikipedia.org/wiki/Nikola_Tesla_electric_car_hoax)
Wesley.
PART#6
Ortec Neutron source.
1. n. [Formation Evaluation] A device for producing high-energy neutrons by using a charged particle accelerator.
Neutron generators are used in various pulsed neutron devices and some neutron porosity measurements.
In a typical device, deuterium (2D) and tritium (3T) ions are accelerated towards a target also containing the same isotopes.
When 2D and 3T collide, they react to produce a neutron with an energy of about 14.1 MeV.
The first neutron generators were built in the late 1950s and soon led to the first pulsed neutron capture (https://www.glossary.oilfield.slb.com/Terms/n/neutron_capture.aspx) log.
Synonyms: accelerator source (https://www.glossary.oilfield.slb.com/Terms/a/accelerator_source.aspx)
See: activation log (https://www.glossary.oilfield.slb.com/Terms/a/activation_log.aspx), chemical neutron source (https://www.glossary.oilfield.slb.com/Terms/c/chemical_neutron_source.aspx), neutron interactions (https://www.glossary.oilfield.slb.com/Terms/n/neutron_interactions.aspx), neutron porosity (https://www.glossary.oilfield.slb.com/Terms/n/neutron_porosity.aspx), pulsed neutron spectroscopy log
(https://www.glossary.oilfield.slb.com/Terms/p/pulsed_neutron_spectroscopy_log.aspx)https://www.youtube.com/watch?v=UyD3S8uGMWE
https://www.youtube.com/watch?v=d6xRrDKR4Qo
I'm working on it
please come later
PART#6 a
https://mountsopris.com/ql40-ngen-neutron-generator/ (https://mountsopris.com/ql40-ngen-neutron-generator/)
http://www.starfireindustries.com/ngentrade-neutron-generators.html (http://www.starfireindustries.com/ngentrade-neutron-generators.html)
PART#6 b.
https://view.officeapps.live.com/op/view.aspx?src=https%3A%2F%2Findico.phys.vt.edu%2Fevent%2F2%2Fcontributions%2F271%2Fattachments%2F208%2F231%2FSNAC_11_Raghavan.pptx (https://view.officeapps.live.com/op/view.aspx?src=https%3A%2F%2Findico.phys.vt.edu%2Fevent%2F2%2Fcontributions%2F271%2Fattachments%2F208%2F231%2FSNAC_11_Raghavan.pptx)
than click on the picture
or
https://www2.lbl.gov/Science-Articles/Archive/neutronGenerator.html (https://www2.lbl.gov/Science-Articles/Archive/neutronGenerator.html)
or download here:
https://indico.phys.vt.edu/event/2/contributions/271/attachments/208/231/SNAC_11_Raghavan.pptx (https://indico.phys.vt.edu/event/2/contributions/271/attachments/208/231/SNAC_11_Raghavan.pptx)
-Lithuania experiment (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551370/#msg551370 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551370/#msg551370))
-energy extraction from Schumann Waveguide (https://youtu.be/He5xQOJHlrU ) (https://youtu.be/He5xQOJHlrU)
Wesley
https://www.youtube.com/watch?v=suIAo0EYwOE
What some of us don't know about Nicola Tesla
Wesley
Quote from: stivep on October 03, 2020, 10:38:20 PM
Wesley
We know that magnetization waves travel along ferromagnetic cores at a certain velocity (associated with domain wall movement, inter-atomic distances, electron flip times etc) so it may be possible to construct the equivalent to that Tesla fluid valve using ferromagnetic material as the transport channel. Do you know if anyone has tried this? A core where waves travelling in opposite directions have different characteristics could offer an interesting assymetrical transformer design where the primary does not see the secondary load, see sketch below. I have used Tesla's fluid geometry but the actual geometry would rely on experiments. For the experimenter it probably needs iron-dust cores cast into various shapes, but they would be large so as to get useable delay around the small interconnecting loops.
Smudge
QuoteWe know that magnetization waves travel along ferromagnetic cores at a certain velocity
There is a study on this topic.I apologize that in Russian ...
I hope you will be able to download this :
https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer#pf1f
(https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer#pf1f)
look here for additional information:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg550404/#msg550404
The interesting is the date of it 1949
Wesley
Quote from: kolbacict on October 04, 2020, 01:00:20 PM
Thank you kolbacict. I can see from the equations that this is of interest. I just need to get it translated. I am of the opinion that the atomic dipoles responsible for ferromagnetism are the gateway to hidden forces of Nature that come from the virtual particles of free space. And utilizing the propagation time delay effects of magnetic waves through transformer cores is one route towards obtaining an assymetrical system that yields OU.
Smudge
material for study
____________________
NMR:
1.https://overunity.com/18502/nuclear-magnetic-resonance-nmr/msg551729/#new (https://overunity.com/18502/nuclear-magnetic-resonance-nmr/msg551729/#new)
sub:
a.https://www.sciencedirect.com/science/article/pii/B9780128035818028071 (https://www.sciencedirect.com/science/article/pii/B9780128035818028071) Magnetic Viscosity
sub transmutation:
a.https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/30/ (https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/30/)
b.https://overunity.com/8503/ultrasonic-piezonuclear-reactions/30/ (https://overunity.com/8503/ultrasonic-piezonuclear-reactions/30/) ULTRASONIC PIEZONUCLEAR REACTIONS
2. Controversy around Fabio Cardone
a.https://www.youtube.com/watch?v=1BfLeD01pbw (https://www.youtube.com/watch?v=1BfLeD01pbw)
Convegno Lern Cirps Sapienza Roma Allan Widom fisico teorico di Boston 1
b.https://www.youtube.com/watch?v=gcF-KSLIAWs (https://www.youtube.com/watch?v=gcF-KSLIAWs)
New type of penetrating radiation - Alexander Shishkin
c.https://e-catworld.com/2019/02/09/video-a-new-type-of-penetrating-radiation-alexander-shishkin/ (https://e-catworld.com/2019/02/09/video-a-new-type-of-penetrating-radiation-alexander-shishkin/)
d.https://staff.polito.it/alberto.carpinteri/piezonuclear%20reactions%20conference/4maggio2012.pdf
PiezonuclearFissionFissionReactionsReactionsin in, RocksRocks::EvidencesEvidencesfromfromMicrochemicalMicrochemicalAnalysisAnalysis, ,
Neutron Neutron EmissionEmission, and , and GeologicalGeologicalTransformation
e. https://www.technologyreview.com/2009/07/07/211779/can-pressure-waves-speed-up-nuclear-decay/
Can Pressure Waves Speed Up Nuclear Decay?
f. https://arxiv.org/abs/0903.3104 (https://arxiv.org/abs/0903.3104) Piezonuclear neutrons from fracturing of inert solids F. Cardone, A. Carpinteri, G. Lacidogna
g.https://arxiv.org/abs/0910.2368 (https://arxiv.org/abs/0910.2368)
Reply to the "Comment on 'Piezonuclear decay of thorium' [Phys. Lett. A 373 (2009) 1956]" [Phys. Lett. A 373 (2009) 3795] by G. Ericsson et al F.Cardone, R.Mignani, A.Petrucci
h.https://arxiv.org/ftp/arxiv/papers/0907/0907.0623.pdf (https://arxiv.org/ftp/arxiv/papers/0907/0907.0623.pdf)
https://www.researchgate.net/publication/45872090_Comments_on_the_Reply_to_'Comment_on_Piezonuclear_decay_of_ (https://www.researchgate.net/publication/45872090_Comments_on_the_Reply_to_'Comment_on_Piezonuclear_decay_of_)
thorium_Phys_Lett_A_373_2009_1956'_Phys_Lett_A_2009_in_press_Phys_Lett_A_2009_in_press_by_F_Cardone_et_al Comments on the "Reply to 'Comment on "Piezonuclear decay of thorium" [Phys. Lett. A 373 (2009) 1956]' [Phys. Lett. A (2009, in press]" [Phys. Lett. A (2009), in press] by F. Cardone et. al
i. https://ui.adsabs.harvard.edu/abs/2009PhLA..373.3797C/abstract (https://ui.adsabs.harvard.edu/abs/2009PhLA..373.3797C/abstract)
Reply to "Comment on 'Piezonuclear decay of thorium' [Phys. Lett. A 373 (2009) 1956]" [Phys. Lett. A 373 (2009) 3795]
j. https://www.sciencedirect.com/science/article/abs/pii/S0375960109014893 (https://www.sciencedirect.com/science/article/abs/pii/S0375960109014893)
k. https://ui.adsabs.harvard.edu/abs/2009PhLA..373.1956C/abstract (https://ui.adsabs.harvard.edu/abs/2009PhLA..373.1956C/abstract)
l.
3 Neutron and interaction for FE
a.https://mountsopris.com/ql40-ngen-neutron-generator/ (https://mountsopris.com/ql40-ngen-neutron-generator/)
Neutron gun/ generator
b.https://www.glossary.oilfield.slb.com/Terms/n/neutron_porosity.aspx (https://www.glossary.oilfield.slb.com/Terms/n/neutron_porosity.aspx)
https://www.glossary.oilfield.slb.com/en/Terms/n/neutron_generator.aspx (https://www.glossary.oilfield.slb.com/en/Terms/n/neutron_generator.aspx)
https://ipo.lbl.gov/lbnl1764/ (https://ipo.lbl.gov/lbnl1764/)
https://hackaday.com/2020/03/16/where-do-you-get-your-neutrons-neutron- (https://hackaday.com/2020/03/16/where-do-you-get-your-neutrons-neutron-)
sources-for-nuclear-fusion-science- medicine-and-industry/ *
https://www3.nd.edu/~wzech/Application-Note-AN34-Experiments-Nuclear-Science-Experiment-18.pdf (https://www3.nd.edu/~wzech/Application-Note-AN34-Experiments-Nuclear-Science-Experiment-18.pdf)
http://adelphitech.com/ (http://adelphitech.com/) http://adelphitech.com/ (http://adelphitech.com/)
http://adelphitech.com/products/dt109-dt110.html (http://adelphitech.com/products/dt109-dt110.html) DT110-14 MeV (http://adelphitech.com/products/dt109-dt110.html) Neutron Generator
http://adelphitech.com/products/dd109m-dd110m.html (http://adelphitech.com/products/dd109m-dd110m.html) high yield fast-neutron generators
http://adelphitech.com/products/dd109-dd110.html (http://adelphitech.com/products/dd109-dd110.html) DD109 Neutron Generator
https://www2.lbl.gov/Science-Articles/Archive/neutronGenerator.html (https://www2.lbl.gov/Science-Articles/Archive/neutronGenerator.html) A new way to make "neuts" *
http://www-personal.umich.edu/~ianrit/ners575/neutron.pdf (http://www-personal.umich.edu/~ianrit/ners575/neutron.pdf) Neutron Counting
https://trace.tennessee.edu/cgi/viewcontent.cgi?article=2237&context=utk_gradthes (https://trace.tennessee.edu/cgi/viewcontent.cgi?article=2237&context=utk_gradthes)
A High-Energy Neutron Flux Spectra Measurement Method for the Spallation Neutron Source
https://www.sciencedirect.com/topics/physics-and-astronomy/neutron-sources (https://www.sciencedirect.com/topics/physics-and-astronomy/neutron-sources) Neutron Sources
https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/an34-content.htm (https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/an34-content.htm) Experiments *
https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp17.pdf (https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp17.pdf) Neutron Activation44
https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp23.pdf (https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp23.pdf) Nuclear Techniques
https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp18.pdf (https://stuff.mit.edu/afs/athena/course/22/22.09/ClassHandouts/Ortec%20AN34/Exp18.pdf) FAST neutrons
https://www3.nd.edu/~wzech/Application-Note-AN34-Experiments-Nuclear-Science-Experiment-17.pdf (https://www3.nd.edu/~wzech/Application-Note-AN34-Experiments-Nuclear-Science-Experiment-17.pdf)
AN34 Experiment 17Neutron Activation Analysis (Slow Neutrons)
https://inforgrowth.com/report/1544067/neutron-source-generator-market (https://inforgrowth.com/report/1544067/neutron-source-generator-market)
Global Neutron Source Generator Market Research Report 2019 *
https://www.ortec-online.com/-/media/ametekortec/technical-papers/homeland-security-applications-and- (https://www.ortec-online.com/-/media/ametekortec/technical-papers/homeland-security-applications-and-)
chemical- weapons-assay-pins/performance-car-mounted-neutron-gamma-ray-monitoring-system-illicit-material- detection.pdf?dmc=1&la=en&hash=2775FC0355FBF8B33BC58CE0BC14FCF5
Performance of a car-mounted neutron and gamma-ray monitoring system for illicit material detection.
http://www.gammadata.se/assets/Uploads/Fission-Meter-Portable-Neutron-Source-Identification-System.pdf (http://www.gammadata.se/assets/Uploads/Fission-Meter-Portable-Neutron-Source-Identification-System.pdf)
Fission Meter™Portable Neutron Source Identification System
https://www.ortec-online.com/products/nuclear-security-and-safeguards/chemical-weapons-identification/pins3-cw-g2 (https://www.ortec-online.com/products/nuclear-security-and-safeguards/chemical-weapons-identification/pins3-cw-g2)
PINS3-CW-G2 Portable Isotopic Neutron Spectroscopy
https://www.marketwatch.com/press-release/neutron-source-generator-market-analysis-and-advancements-outlook- (https://www.marketwatch.com/press-release/neutron-source-generator-market-analysis-and-advancements-outlook-) 2020-to-2026-vniia-adelphi-technology-ametek-ortec-gradel-nsd-fusion-2020-08-10
Neutron Source Generator Market Analysis and Advancements Outlook 2020 to 2026
https://www.ortec-online.com/products/nuclear-security-and-safeguards/neutron-fission-systems (https://www.ortec-online.com/products/nuclear-security-and-safeguards/neutron-fission-systems)
Neutron/Fission Radiation Detection
https://www.youtube.com/watch?v=v9DXecl-OX8 (https://www.youtube.com/watch?v=v9DXecl-OX8)
homemade fusor (nuclear fusion reactor) - neutron and x-ray radiation, silver activation *
https://link.springer.com/article/10.1007/s10894-018-0182-1 (https://link.springer.com/article/10.1007/s10894-018-0182-1)
Fusion Neutrons: Tritium Breeding and Impact on Wall Materials and Components of Diagnostic Systems
https://ui.adsabs.harvard.edu/abs/2013JPhG...40a5006W/abstract (https://ui.adsabs.harvard.edu/abs/2013JPhG...40a5006W/abstract)
Neutron production from the fracture of piezoelectric rocks *
https://iopscience.iop.org/article/10.1088/0954-3899/40/1/015006 (https://iopscience.iop.org/article/10.1088/0954-3899/40/1/015006)
https://www.researchgate.net/publication/313275918_Total_cross_sections_for_ultracold_neutrons_scattered_from_gases (https://www.researchgate.net/publication/313275918_Total_cross_sections_for_ultracold_neutrons_scattered_from_gases)
Total cross sections for ultracold neutrons scattered from gases
https://www.researchgate.net/publication/30411897_The_microscopic_origin_of_thermal_cracking_in_rocks_An_investigation_by_simultaneous_time-of-flight_neutron_diffraction_and_acoustic_emission_monitoring (https://www.researchgate.net/publication/30411897_The_microscopic_origin_of_thermal_cracking_in_rocks_An_investigation_by_simultaneous_time-of-flight_neutron_diffraction_and_acoustic_emission_monitoring)
The microscopic origin of thermal cracking in rocks: An investigation by simultaneous time-of-flight neutron diffraction and acoustic emission monitoring
https://www.researchgate.net/publication/51939788_Neutron_Production_from_the_Fracture_of_Piezoelectric_Rocks (https://www.researchgate.net/publication/51939788_Neutron_Production_from_the_Fracture_of_Piezoelectric_Rocks)
Neutron Production from the Fracture of Piezoelectric Rocks *
neutron porosity.
c.https://www.youtube.com/watch?v=x_QOg94J1bY (https://www.youtube.com/watch?v=x_QOg94J1bY)
compensated neutron measurement
Wesley
properties of Zenneck wave:
___________________________________
1. Surface wave cancellation electrical prospecting
2. Waves at planar boundaries at normal incidence
https://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-013-electromagnetics-and-applications-spring-2009/readings/MIT6_013S09_chap09.pdf (https://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-013-electromagnetics-and-applications-spring-2009/readings/MIT6_013S09_chap09.pdf)
3. ELECTROMAGNETIC SURFACE WAVES
http://web.mit.edu/redingtn/www/netadv/zenneck.html (http://web.mit.edu/redingtn/www/netadv/zenneck.html)
4. ELECTROMAGNETIC SURFACE WAVES
http://web.mit.edu/redingtn/www/netadv/zenneck.html#zenap (http://web.mit.edu/redingtn/www/netadv/zenneck.html#zenap)
5. SURFACE WAVE CANCELLATION ELECTRICAL PROSPECTING Patent
https://patentimages.storage.googleapis.com/3a/ae/38/ae3495f1b588f4/US2542462.pdf (https://patentimages.storage.googleapis.com/3a/ae/38/ae3495f1b588f4/US2542462.pdf)
6. Propagation Along a Two-Wire Line Located at the Air-Earth Interface
https://www.nist.gov/publications/propagation-along-two-wire-line-located-air-earth-interface (https://www.nist.gov/publications/propagation-along-two-wire-line-located-air-earth-interface)
7. Time evolution of the electric field using the rapid expansion method with pseudospectral evaluation of spatial derivatives — Part 2: Inclusion of anisotropy and the earth-air interface
https://library.seg.org/doi/abs/10.1190/geo2018-0143.1 (https://library.seg.org/doi/abs/10.1190/geo2018-0143.1)
8. A simplified calculation of transient plane waves in a presence of an imperfectly conducting half-space
https://www.witpress.com/Secure/elibrary/papers/BE05/BE05050FU.pdf (https://www.witpress.com/Secure/elibrary/papers/BE05/BE05050FU.pdf)
9. Comparative Study of the Hertz, Marconi and Tesla Low-Frequency Wireless Systems *
http://www.teslaradio.com/pages/compare.htm (http://www.teslaradio.com/pages/compare.htm)
10.Texzon Zenneck Standing Wave Wireless Power Transmission – World Wide *
http://whodoeswhat.tv/2018/08/27/texzon-zenneck-wave-wireless-power-transmission-world-wide-nupower-development/ (http://whodoeswhat.tv/2018/08/27/texzon-zenneck-wave-wireless-power-transmission-world-wide-nupower-development/)
a.https://www.safie.hq.af.mil/News/Article-Display/Article/1770582/air-force-signs-mou-to-test-resilience-improving-technology/ (https://www.safie.hq.af.mil/News/Article-Display/Article/1770582/air-force-signs-mou-to-test-resilience-improving-technology/)
11. Sommerfeld and Zenneck Wave Propagation for a Finitely Conducting One-Dimensional Rough Surface.
https://jglobal.jst.go.jp/en/detail?JGLOBAL_ID=200902154287375971 (https://jglobal.jst.go.jp/en/detail?JGLOBAL_ID=200902154287375971)
12. How Surface Waves Reduce Through-Life Costs
https://journals.sagepub.com/doi/full/10.1177/0020294013492287 (https://journals.sagepub.com/doi/full/10.1177/0020294013492287)
13. Surface waves
https://digital-library.theiet.org/content/journals/10.1049/pi-3.1953.0068 (https://digital-library.theiet.org/content/journals/10.1049/pi-3.1953.0068)
14. Zenneck Waves - I am having a hard time understanding this tech
https://forums.qrz.com/index.php?threads/zenneck-waves-i-am-having-a-hard-time-understanding-this-tech.599501/page-6 (https://forums.qrz.com/index.php?threads/zenneck-waves-i-am-having-a-hard-time-understanding-this-tech.599501/page-6)
15. REDISCOVERING THE ZENNECK SURFACE WAVE *
https://pe2bz.philpem.me.uk/Power/-%20HV/-%20Tesla/-%2021-CenturyBooks/Wireless/tws4.htm (https://pe2bz.philpem.me.uk/Power/-%20HV/-%20Tesla/-%2021-CenturyBooks/Wireless/tws4.htm)
16. Can Zenneck Surface Waves transmit large amounts of electrical power?
https://www.quora.com/Can-Zenneck-Surface-Waves-transmit-large-amounts-of-electrical-power (https://www.quora.com/Can-Zenneck-Surface-Waves-transmit-large-amounts-of-electrical-power)
17. ELI5: What is the Zenneck Wave? How does it work? How can Zenneck Wave transfer "utility-scale" electrical power wirelessly? *
https://www.reddit.com/r/explainlikeimfive/comments/9vl0pq/eli5_what_is_the_zenneck_wave_how_does_it_work/ (https://www.reddit.com/r/explainlikeimfive/comments/9vl0pq/eli5_what_is_the_zenneck_wave_how_does_it_work/)
18. On the existence and physical meaning of the Zenneck wave
https://iopscience.iop.org/article/10.3367/UFNe.0179.200907j.0801 (https://iopscience.iop.org/article/10.3367/UFNe.0179.200907j.0801)
19. Tesla Tower 2.0 in Texas *
https://www.lead-innovation.com/english-blog/death-of-the-power-cable (https://www.lead-innovation.com/english-blog/death-of-the-power-cable)
20. A STUDY FOR THE PROPAGATION OF ELECTROMAGNETIC WAVES OVER IMPERFECT GROUND PLANES BASED ON WAVES OVER IMPERFECT GROUND PLANES BASED ON SCHELKUNOFF INTEGRALS SCHELKUNOFF INTEGRALS
https://surface.syr.edu/cgi/viewcontent.cgi?article=1179&context=etd (https://surface.syr.edu/cgi/viewcontent.cgi?article=1179&context=etd)
21. The physical reality of Zenneck's surface wave: Showing that Zenneck's surface wave is not generated by vertical dipoles and is not needed to explain wave antenna operation (Monograph) Unknown Binding – January 1, 1937
https://www.amazon.com/physical-reality-Zennecks-surface-wave/dp/B0008CST6M (https://www.amazon.com/physical-reality-Zennecks-surface-wave/dp/B0008CST6M)
22. On surface electromagnetic waves V N Datsko, A A Kopylov
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.205.5534&rep=rep1&type=pdf (http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.205.5534&rep=rep1&type=pdf)
23. Electromagnetic Wave PropagationLecture 12: Oblique incidence I
https://www.eit.lth.se/fileadmin/eit/courses/eten05/ht2016/lectures/lecture12.pdf (https://www.eit.lth.se/fileadmin/eit/courses/eten05/ht2016/lectures/lecture12.pdf) ***
24. Surface Electromagnetic Waves in a Metal (https://www.researchgate.net/publication/271905529_Surface_Electromagnetic_Waves_in_a_Metal)
Ultrahigh-frequency surface electromagnetic waves in an open waveguide (https://www.researchgate.net/publication/257857686_Ultrahigh-frequency_surface_electromagnetic_waves_in_an_open_waveguide)
On surface electromagnetic waves (https://www.researchgate.net/publication/258301399_On_surface_electromagnetic_waves)
On surface electromagnetic waves (https://www.researchgate.net/publication/258301399_On_surface_electromagnetic_waves) #2
https://www.semanticscholar.org/paper/On-surface-electromagnetic-waves-Datsko-Kopylov/a26041febf32138629dccf5e443a1db505525337 (https://www.semanticscholar.org/paper/On-surface-electromagnetic-waves-Datsko-Kopylov/a26041febf32138629dccf5e443a1db505525337)
25. Surface Electromagnetic Waves https://pdfs.semanticscholar.org/5f63/113c3683c61430cb5dfeae32acdc548ff614.pdf (https://pdfs.semanticscholar.org/5f63/113c3683c61430cb5dfeae32acdc548ff614.pdf)
26. Earth Transmission ***
https://www.tntech.edu/engineering/research/cesr/wireless-power/power-through-earth.php (https://www.tntech.edu/engineering/research/cesr/wireless-power/power-through-earth.php)
27. zenneck wave
https://books.google.dk/books?id=-KX9CAAAQBAJ&pg=PA526&lpg=PA526&dq=zenneck+wave&source=bl&ots=zooWjLpUNA&sig=ACfU3U0N2bxYe-godW0zzxeB35Xf89knkA&hl=en&sa=X&ved=2ahUKEwiBxeeS4enrAhVpo4sKHR0SCpM4HhDoATAGegQIARAB#v=onepage&q=zenneck%20wave&f=false (https://books.google.dk/books?id=-KX9CAAAQBAJ&pg=PA526&lpg=PA526&dq=zenneck+wave&source=bl&ots=zooWjLpUNA&sig=ACfU3U0N2bxYe-godW0zzxeB35Xf89knkA&hl=en&sa=X&ved=2ahUKEwiBxeeS4enrAhVpo4sKHR0SCpM4HhDoATAGegQIARAB#v=onepage&q=zenneck%20wave&f=false)
28. Scientific report:
on optimum excitation of ground waves ***
http://ecee.colorado.edu/~kuester/ucb_emlab_sr053.pdf (http://ecee.colorado.edu/~kuester/ucb_emlab_sr053.pdf)
29. Beverage antenna used for zenneck Wave
https://en.wikipedia.org/wiki/Beverage_antenna (https://en.wikipedia.org/wiki/Beverage_antenna)
a. polarization: https://en.wikipedia.org/wiki/Beverage_antenna (https://en.wikipedia.org/wiki/Beverage_antenna)
30.Perfect absorption at Zenneck wave - plane wave transition
https://research.aalto.fi/en/publications/perfect-absorption-at-zenneck-wave-plane-wave-transition (https://research.aalto.fi/en/publications/perfect-absorption-at-zenneck-wave-plane-wave-transition)
31. International Electrotechnical CommissionZenneck Wave
http://www.electropedia.org/iev/iev.nsf/display?openform&ievref=705-04-67 (http://www.electropedia.org/iev/iev.nsf/display?openform&ievref=705-04-67)
32. Zenneck Wave
https://books.google.dk/books?id=hCV2Hz4SGYcC&pg=PA48&lpg=PA48&dq=zenneck+wave&source=bl&ots=-80qqGM8U0&sig=ACfU3U2IVDNFPniT4Frx-md0BiHch6Gv2A&hl=en&sa=X&ved=2ahUKEwjdyaTv3-nrAhVkmYsKHWxiAQk4FBDoATAHegQIChAB#v=snippet&q=Zenneck&f=false (https://books.google.dk/books?id=hCV2Hz4SGYcC&pg=PA48&lpg=PA48&dq=zenneck+wave&source=bl&ots=-80qqGM8U0&sig=ACfU3U2IVDNFPniT4Frx-md0BiHch6Gv2A&hl=en&sa=X&ved=2ahUKEwjdyaTv3-nrAhVkmYsKHWxiAQk4FBDoATAHegQIChAB#v=snippet&q=Zenneck&f=false)
33. Zenneck Waves in Decision Agriculture: An Empirical Verification and Application in EM-Based Underground Wireless Power Transfer (https://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=1037&context=cit_articles)
34. Excitation of the Zenneck Wave by a Tapered Line Source
https://ieeexplore.ieee.org/document/8700789#:~:text=However%252C%20by%20using%20a%20tapered%20line%20source%252C%20a,to%20what%20is%20called%20an%20%22optimum%22%20line%20source (https://ieeexplore.ieee.org/document/8700789#:~:text=However%252C%20by%20using%20a%20tapered%20line%20source%252C%20a,to%20what%20is%20called%20an%20%22optimum%22%20line%20source).
35. Download article : Zenneck wave in agriculture ***
https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer/link/5eb4036792851cbf7fae4e69/download (https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer/link/5eb4036792851cbf7fae4e69/download)
36. what is dielectric permittivity and dielectric constant? ***
https://www.edaphic.com.au/soil-water-compendium/dielectric-permittivity/ (https://www.edaphic.com.au/soil-water-compendium/dielectric-permittivity/)
37. Zenneck Waves in Decision Agriculture: An Empirical Verification and Application in EM-Based Underground Wireless Power Transfer
https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer#pf1f (https://www.researchgate.net/publication/341210497_Zenneck_Waves_in_Decision_Agriculture_An_Empirical_Verification_and_Application_in_EM-Based_Underground_Wireless_Power_Transfer#pf1f)
38. Skimming the Surface: The Return of Tesla's Surface Waves *
https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/ (https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/)
39. PATENT 2,542,462 C. i. BEARD SURFACE WAVE CANCELLATION ELECTRICAL PROSPECTING***
file:///C:/Users/bf/AppData/Local/Temp/US2542462.pdf
Wesley
New Energy Technology/Technologies Des Energies Nouvelles
by A. Michrowski
ISBN is 9780919969223 / 0919969224
Publisher:The Planetary Association ..., 1990
Edition:Softcover
http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0hdl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL2.20.14&d=HASHedccacb18da2d2ee0851c7>=2 (http://www.nzdl.org/gsdlmod?e=d-00000-00---off-0hdl--00-0----0-10-0---0---0direct-10---4-------0-1l--11-en-50---20-about---00-0-1-00-0--4----0-0-11-10-0utfZz-8-00&cl=CL2.20.14&d=HASHedccacb18da2d2ee0851c7>=2)
Wesley
https://www.youtube.com/watch?v=-B0ppe7sacw&feature=youtu.be (https://www.youtube.com/watch?v=-B0ppe7sacw&feature=youtu.be)
for entertainment
Wesley
Hello,
I was skimming through some videos in Claudio Pace´s youtube-channel and found this
video about an experiment lead by Fabio Cardone :
This video is important for educational puposes and I will not comment on this. I would request
the members here to sharpen their mind and watch carefully what he is presenting here.
Just one question: what are the chemical properties of mercury ?
Mike
Hmm ... the aluminum cone will dissolve in the mercury. It turns out an amalgam of aluminum.amalgam is oxidized in air. we get aluminum oxide. I'm wrong ?
In an old mobile phone NOKIA, a coaxial cable loop is used to connect between the boards.the diameter of this coaxial cable is 0.16mm.!the cable is very high quality. insulation does not melt.how good are the electrical parameters for this diameter?
kolbacict,
exactly: here is the list of metals which can and cannot form alloys with amalgam
https://en.wikipedia.org/wiki/Amalgam_(chemistry) (https://en.wikipedia.org/wiki/Amalgam_(chemistry))
now this is the final blow for Claudio Pace´s scientific reputation.
15 Watt of ultrasonic power applied to such a small volume of mercury certainly rip off molecules of aluminium by collapsing cavitation-bubbles which
then form aluminium-amalgam and he is presenting this as transmuted matter ! and by the way by this process certainly a good portion of mercury-vapor escaped into the room poisoning the lungs of the attendees. What a mess.
@wesley: you certainly have some scientists in your network who can be made aware of this fraud. This has to be stopped
Mike
Quote from: Kator01 on October 19, 2020, 01:23:01 PM
kolbacict,
(https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/msg550943/#msg550943)wesley: you certainly have some scientists in your network who can be made aware of this fraud. This has to be stopped
Mike
https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/msg550943/#msg550943 (https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/msg550943/#msg550943)
start to read from here for the rest of the pages
such as:
https://overunity.com/18632/ultrasonic-mechanical-cavitation-used-to-transmute-matter/msg550945/#msg550945
the whore page .
Wesley :)
Here is some guy acting as PAAR consulting LLC4623 73rd St E, Bradenton, FL 34203.
He is selling kW'ts of power in some magic box for you to use.
It promises 15 to 300kW but they don't say if it is per unit of time.
So there is difference between 300kW and 300kW/h
i
https://www.bizapedia.com/fl/paar-consulting-llc.html
(https://www.bizapedia.com/fl/paar-consulting-llc.html)https://www.corporationwiki.com/Florida/Boynton-Beach/paul-reynolds/101222688.aspx (https://www.corporationwiki.com/Florida/Boynton-Beach/paul-reynolds/101222688.aspx)
link#3 https://www.alignable.com/boynton-beach-fl/sustainable-solutions-consulting-llc/ssc
(https://www.alignable.com/boynton-beach-fl/sustainable-solutions-consulting-llc)
https://www.youtube.com/watch?v=YRK9lmzL3D8 (https://www.youtube.com/watch?v=YRK9lmzL3D8)
The video is mostly in English.
The direct link to company Website is :
https://www.paar-energy.com/ (https://www.paar-energy.com/)
The link to their videos is:
https://www.paar-energy.com/energy-in-a-box-videos (https://www.paar-energy.com/energy-in-a-box-videos)
Wesley
Andrea Rossi News:
https://e-catworld.com/2020/10/31/rossi-e-cat-has-been-licensed-for-manufacturing/
the most recent information is here :
the last one is from 1 hour ago.
New form of I assume never able to blow nuclear reactor
https://www.youtube.com/watch?v=QKeORXJ10YI (https://www.youtube.com/watch?v=QKeORXJ10YI)
Note: just to save your time please watch this video from here:
https://youtu.be/QKeORXJ10YI?t=753 (https://youtu.be/QKeORXJ10YI?t=753)
Wesley
https://www.youtube.com/watch?v=VUYyHNzQ2AM (https://www.youtube.com/watch?v=VUYyHNzQ2AM)
https://en.wikipedia.org/wiki/Magnetic_survey_(archaeology (https://en.wikipedia.org/wiki/Magnetic_survey_(archaeology))
__________________
Proton magnetometer
https://en.wikipedia.org/wiki/Proton_magnetometer (https://en.wikipedia.org/wiki/Proton_magnetometer)
on land and underwater .
marine magnetometer detection system. With a one Nano -Tesla (nT) sensitivity,
https://www.youtube.com/watch?v=9DNDlujo7J8 (https://www.youtube.com/watch?v=9DNDlujo7J8)
It can also be useful in archeology in searching for buried foundations/walls.
https://satisgeo.com/magnetometers/pmg-2-proton-magnetometer-and-gradiometer/ (https://satisgeo.com/magnetometers/pmg-2-proton-magnetometer-and-gradiometer/)
The magnetometer finds much use in mineral exploration, oil & gas exploration, archaeology and military applications etc.
https://www.youtube.com/watch?v=-p9nuDmLQug (https://www.youtube.com/watch?v=-p9nuDmLQug)
https://youtu.be/bEQX-ZRtQ44?t=256 (https://youtu.be/bEQX-ZRtQ44?t=256)
military:
https://www.youtube.com/watch?v=fKEc_iolEu0 (https://www.youtube.com/watch?v=fKEc_iolEu0)
probes 30 cm for fine resolution scan and 120 cm for deep / large object location.
"flying" magnetometerProcyon 800E Towed Magnetometer Tes
https://www.youtube.com/watch?v=gj_IASNs5cQ (https://www.youtube.com/watch?v=gj_IASNs5cQ)
science:
This video is interesting
GOES-R Magnetometer Boom Hot Thermal Deployment
https://www.youtube.com/watch?v=9iMh18J636g (https://www.youtube.com/watch?v=9iMh18J636g)
NMR Magnetometer
https://www.metrolab.com/wp-content/uploads/2015/07/PT2025_tech_note_NMR-Magnetometers-published-in-Magnetics-Technology-International.pdf (https://www.metrolab.com/wp-content/uploads/2015/07/PT2025_tech_note_NMR-Magnetometers-published-in-Magnetics-Technology-International.pdf)
https://www.youtube.com/watch?v=shHfHBSGxKk (https://www.youtube.com/watch?v=shHfHBSGxKk)
https://www.youtube.com/watch?v=cTcDGZ-7zY0 (https://www.youtube.com/watch?v=cTcDGZ-7zY0)
The sound of protons: My first NMR experiment
https://www.youtube.com/watch?v=zSnJietN4OM (https://www.youtube.com/watch?v=zSnJietN4OM)
I think Proton magnetometer and NMR magnetometer is the same device
Helium Magnetometer
NASA
https://www.youtube.com/watch?v=BTThA_PmF1k (https://www.youtube.com/watch?v=BTThA_PmF1k)
Wesley
And what is it ? It works ?
One of the losses in the oscillatory circuit that reduce the quality factor is the energy lost with the field and the electromagnetic wave. Is it possible to exclude this so that there are no radiation losses?
Shielding with different materials is not suitable because there will be losses in the materials.
They say Tesla did it ... ;)
Quote from: kolbacict on November 12, 2020, 02:21:29 PM
https://www.google.com/search?q=welle+partikel+dualismus&rlz=1C1AVFC_enPT930PT930&oq=welle+partikel&aqs=chrome.1.69i57j0.12707j1j7&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=welle+partikel+dualismus&rlz=1C1AVFC_enPT930PT930&oq=welle+partikel&aqs=chrome.1.69i57j0.12707j1j7&sourceid=chrome&ie=UTF-8)
Kirchhoff : network,network knodes a. for linear circuits b. non linear circuits studying : POWER FACTOR
https://www.google.com/search?q=power+factor&rlz=1C1AVFC_enPT930PT930&oq=power+facctor&aqs=chrome.1.69i57j0i13l7.9293j0j7&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=power+factor&rlz=1C1AVFC_enPT930PT930&oq=power+facctor&aqs=chrome.1.69i57j0i13l7.9293j0j7&sourceid=chrome&ie=UTF-8)
Only reading IS NOT STUDYING !
How many cases ? Inclusions,Exclusions,PARADOX,PARANORMAL !Why,when,whom !?
STUDY METHOD :
Paper(book),unwritten,empty pages,different colours pencils : drawing 3d by 4d thinking ,
steps 1d 2d 3d 4d actio to 5d reactio : counterforces ,shielding/neutralizing during later physical work process
Mnemonics : Orientation 100% right,in 2/3/4d -imensional application,FEMM order,in software fixed !?
Ferdinand von Braun https://de.wikipedia.org/wiki/Ferdinand_Braun (https://de.wikipedia.org/wiki/Ferdinand_Braun)
Von seinen Schülern sind Jonathan Zenneck (https://de.wikipedia.org/wiki/Jonathan_Zenneck), ein Pionier der Ionosphärenforschung (https://de.wikipedia.org/wiki/Ionosph%C3%A4re), sowie Leonid Isaakowitsch Mandelstam (https://de.wikipedia.org/wiki/Leonid_Isaakowitsch_Mandelstam) und Nikolai Dmitrijewitsch Papalexi als Begründer der russischen Hochfrequenztechnik (https://de.wikipedia.org/wiki/Hochfrequenztechnik), hervorzuheben. Max Dieckmann (https://de.wikipedia.org/wiki/Max_Dieckmann) war Doktorand (https://de.wikipedia.org/wiki/Promotion_(Doktor)) und Assistent bei ihm.
Ions-R&D https://de.wikipedia.org/wiki/Ionosph%C3%A4re (https://de.wikipedia.org/wiki/Ionosph%C3%A4re)
Parametric Generator
https://www.google.com/search?q=mandelstam+papalexi+parametric+generator&rlz=1C1AVFC_enPT930PT930&oq=mandelstam+papalexi+parametric+generator&aqs=chrome..69i57.17737j0j7&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=mandelstam+papalexi+parametric+generator&rlz=1C1AVFC_enPT930PT930&oq=mandelstam+papalexi+parametric+generator&aqs=chrome..69i57.17737j0j7&sourceid=chrome&ie=UTF-8)
His students : Mandelstam/Papalexi ( students in front his Pere,question and answer giving/receiving ' momentum')
parametric generator = FE-machine
AUT: Winter( beside water ,motor ~ Adams Motor) ,Ferdinand Franz Cap,patent/s and published BOOKS- literature
About Ferdinand F- Cap
https://www.google.com/search?q=ferdinand+franz+cap&oq=ferdinand+franz+cap&aqs=chrome..69i57j0i22i30l5.9579j0j4&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=ferdinand+franz+cap&oq=ferdinand+franz+cap&aqs=chrome..69i57j0i22i30l5.9579j0j4&sourceid=chrome&ie=UTF-8)
From the Innsbruck School of Plasma and Energy Physics founded by Cap, several students currently working as university professors in Germany and the USA emerged.
Aus der von Cap begründeten Innsbrucker Schule der Plasma- und Energiephysik gingen mehrere derzeit in Deutschland und in den USA als Hochschulprofessoren tätige Schüler hervor.
Who are these,their publications,patents ?
https://www.google.com/search?q=Innsbruck+School+of+Plasma+and+Energy+Physics&rlz=1C1AVFC_enPT930PT930&oq=Innsbruck+School+of+Plasma+and+Energy+Physics+&aqs=chrome..69i57j33i160.21506j0j7&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=Innsbruck+School+of+Plasma+and+Energy+Physics&rlz=1C1AVFC_enPT930PT930&oq=Innsbruck+School+of+Plasma+and+Energy+Physics+&aqs=chrome..69i57j33i160.21506j0j7&sourceid=chrome&ie=UTF-8)
Self-capacitance to self-re-capacitance capacitor surplus energy storage capacity ?
Welle,Wave ,Pulse : Phase,1/2 positive 1/2 negative wave-theory + practise +4d orientation (practical) rule by Fleming and Lenz parallel :
1 is B and the other H,which when a. LEADING b.LAGGING ?!
akustik,acoustics ~ frequency spectrum !? phonon ,sonar,echo-hall,delay : ac-/de-celeration, sonar-e ,re-son......
Logics : I invest 100% physical force,human mechanical, 1 round force = PUSH-puls/e
into a motor and get 90% 1st round,81% second round,72,9%,....
each round with 10% friction/drag losts ergo the TOTAT SUM(NIT) :
90% + 81% + 72,9% alone without following decelerating rounds/forces = 243,9% = over 100% input ergo
243,9/100% = minimum 2,439 times work result and 1,439 times or 143,9% over-unity !
WORK PROCESS VELOCITY and WORK PROCESS SPEED ,physical difference !
Beside RPM, ? Drehmoment/angular momentum !
Virtual RPM and angular momentum in coils,solenoids application :
The Biot-Savart Law ( also known as Laplace or Ampere Law ) the Lorentz-Force Transformer,e=mc^2 applyer
Ionen/Plasma-Physics,also called Nuclear Physics
Sincere
Can somebody download Ruslan videos and post them on torrent for example ? They are quite large size and probably vanish soon
Ruslan MP3:
https://drive.google.com/drive/folders/1jgUJMy40W3JPBP9LtxlRdbCvOdTO5oRU?usp=sharing
Ruslan repeats 100% what Vasmus said!
Where is Dally now?
Part#6
the similarity to Slobodian Andrey is described here:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg554252/#msg554252Wesley
Part#7Here in this section I will say more about
proposed by Arunas way of understanding the phenomena related to charged particle
in relation to Ruslan's device.
in
Part#4https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg554267/#msg554267 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg554267/#msg554267)
Here is conclusion ( barely formulated)by Ruslan
So say we are looking at the Top Capacitor of Tesla coil .
Quote than we deliver a rapid strike of strong short modulating impulse that is imposed upon the sinusoidal signal ( the carrier)
(both coming from internal generators) right before maximum of its amplitude.
It looks like HV spike and creates in effect a much greater response from ionized surrounding cloud in amount of charge,
when compared to the summary of power wasted on creation of this response by Ruslan 's device.
So far we see no evidence able to support such statement.
So lets analyze it from the point of view of charged particle in Top capacitor . but first we explain what is charged particle and how it behaves. Wesley
Part#7a
Properties and behavior of:
1. charge particle in stationary position
2. charged particle in motion
3. particle accelerated and gaining speed.
I'm working on it
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/179973/image// (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/179973/image//)
The smallest video was watched. On the 23rd minute he confused 7046 with 4046. PLL.
About the Akula's flashlight ...
Immediately attracted attention. :)
His drawling voice gibed in my ears. :D
Quote from: kolbacict on December 28, 2020, 02:49:15 AM
Hmmm....
https://www.ti.com/product/CD74HC7046A <--> https://www.ti.com/product/CD74HC4046A
Maybe I'm wrong. I just had only 4046
But he speaks illiterately. IMHO
Quote from: r2fpl on December 27, 2020, 01:11:46 PM
Where is Dally now?
Try Edward Lee
Quote from: kolbacict on December 28, 2020, 05:58:29 AM
I don't know Russian very well but I can see Ruslan has a problem with the calculator :o
He looks tired. Why did he record this video? He says no one will make any money on it. Has he been cheated?
He wants to show that he can give something away for free.
It confirms that the rule is the same for Dally, Vasmus, Kapanadze, Akula.
QuoteI don't know Russian very well
Well, there is, honestly, nothing to listen to.No information. The truth has been viewed only half ... :D
Ruslan Live on Youtube Now
https://www.youtube.com/watch?v=sE0nnCDlK0I
PART#1
Device producing :
0W IN and 2kW OUT:
https://youtu.be/BPdR1em-_5I (https://youtu.be/BPdR1em-_5I)
_
Wesley
PART#2
https://youtu.be/zbmEdLzkaYU?t=112 (https://youtu.be/zbmEdLzkaYU?t=112)
https://youtu.be/He5xQOJHlrU?t=373 (https://youtu.be/He5xQOJHlrU?t=373)
Wesley
PART#5
picture#2
but taken from translated version
Wesley
PART#8
The Tom Bearden
Website
http://www.cheniere.org/misc/moscowuniv.htm (http://www.cheniere.org/misc/moscowuniv.htm)
I have problem with Tom ..
first of all OVERUNITY doesn't exist!!!!
leads to this article :
__________________
another paper that comes out is general history of nonlinear oscillations :
https://www.sciencedirect.com/science/article/pii/S163107211930049X (https://www.sciencedirect.com/science/article/pii/S163107211930049X)
Wesley
I got into the hands of an interesting, incomprehensible device. What could it be?
about 10-15 turns of copper tape into a ring. And several turns of the same tape are orthogonal.
Around the circumference of the ring. There is a fluoroplastic film between the layers of copper tape.
Quote from: kolbacict on January 09, 2021, 02:13:43 AM
Yes ...
As I said before in my post...
I just found that :
the original picture file is : exactly form year 1999.
I'm proud of myself:___________________
original file :
w3.org/1999/
Wesley
Quoteare they attached to the side of the foil wind?
Yes, almost all contacts are made from tape that is wound around the circumference of the ring.
11 contacts in total. Very close, after a quarter of a turn.
Quotethe hole inside is to small for the core of a transformer.
There was probably a fixing screw.
Quotewhat was it part of ?
The fact of the matter is that I don't know.
In one of the pictures, this product was not yet broken.
Quote from: kolbacict on January 10, 2021, 01:51:30 AM
that sentence helps a lot.
Wesley
Method of measurement of
A vector network analyzer (Agilent 4395A) is used to find the resonant frequency
and measure transmission behavior between Tx and Rx.
The measured intrinsic decay rate, connected lumped capacitance,
and resonant frequency of the resonant coils
https://www.researchgate.net/publication/224235581_Efficiency_Analysis_of_Magnetic_Resonance_Wireless_Power_Transfer_With_Intermediate_Resonant_Coil/download
indicted at schematic HP4505A VNA was manufactured in 2000. or maybe some time before that.. I'm not sure
Agilent 4395A 10 Hz to 500 MHz Agilent (https://testequipment.center/Product_Documents/Agilent-4395A-Specifications-23081.pdf)
but all of that can be done with HP 4194A too.
but if you don't have it than it can be done with simple function generator and .. small coil connected to LED
Wesley
QuoteA vector network analyzer (Agilent 4395A) is used to find the resonant frequency
You're kidding ...
This is not a land of endless possibilities.
Well, at least there is such a thing. Others do not have that. :) ;)
But none of this is clear. There is a resonance at 6 MHz.
The input and output of the frequency response meter is 50 ohms.
Maybe this is the influence (resonance phenomena) of the cable.
Quote from: kolbacict on January 11, 2021, 04:13:27 AM
p.s. I also reread their 1934 works on parametric excitation of oscillations.
They never talk about the OU in their work.
Or I don't understand something.
The truth is I just don't understand NASA's interest in their work in 1969 ...
OU- (overunity) doesn't exist , never existed and will never exist.
FE- free energy (or CE in Russian) exists and is possible due to energy conversion where initial energy is free of charge.
TECH-TRAN CORPORATION
Rancocas, New Jersey
https://www.usaopps.com/government_contractors/contractor-5617683-TECH-TRAN-CORPORATION.htm (https://www.usaopps.com/government_contractors/contractor-5617683-TECH-TRAN-CORPORATION.htm)
Power, Distribution, and Specialty Transformer Manufacturing
They found it interesting.
Many year later the French man -
(The guy from he video) decided to give it the try.
Wesley
Quote from: stivep on January 11, 2021, 11:42:32 AM
I do not mind.It's right.
But the Frenchman claims that he took his 200 percent somewhere ...
I watched it. Naturally I did not understand anything. :D
The solar panel is FE or OU? Of course there is FE ! (OU = like perpetual motion)
This is a philosophical question rather than a technical one.
Everyone can tell the difference here.
The solar panel is FE. of course.
p.s. Help, support the beast.
https://www.change.org/p/%D1%83%D1%81%D1%82%D0%B0%D0%BD%D0%BE%D0%B2%D0%B8%D1%82%D1%8C-%D0%BF%D0%BE%D0%BB%D0%BD%D1%8B%D0%B9-%D0%B7%D0%B0%D0%BF%D1%80%D0%B5%D1%82-%D0%BD%D0%B0-%D0%BE%D0%BD%D0%B8%D1%85%D1%8D%D0%BA%D1%82%D0%BE%D0%BC%D0%B8%D1%8E-%D0%BE%D0%BF%D0%B5%D1%80%D0%B0%D1%86%D0%B8%D1%8E-%D0%BF%D0%BE-%D1%83%D0%B4%D0%B0%D0%BB%D0%B5%D0%BD%D0%B8%D1%8E-%D0%BA%D0%BE%D0%BD%D0%B5%D1%87%D0%BD%D1%8B%D1%85-%D1%84%D0%B0%D0%BB%D0%B0%D0%BD%D0%B3-%D0%BF%D0%B0%D0%BB%D1%8C%D1%86%D0%B5%D0%B2-%D1%83-%D0%BA%D0%BE%D1%88%D0%BA%D0%B8-%D0%B1%D0%B5%D0%B7-%D0%BC%D0%B5%D0%B4%D0%B8%D1%86%D0%B8%D0%BD%D1%81%D0%BA%D0%B8%D1%85-%D0%BF%D0%BE%D0%BA%D0%B0%D0%B7%D0%B0%D0%BD%D0%B8%D0%B9-%D0%BE%D0%BF%D0%B5%D1%80%D0%B0%D1%86%D0%B8%D1%8F-%D0%BC%D1%8F%D0%B3%D0%BA%D0%B8%D0%B5-%D0%BB/u/28360662
Quote from: r2fpl on January 14, 2021, 03:38:15 AM
OU stands for overunity and such phenomena doesn't exist.
COP>1 exist in refrigeration systems but the total energy calculation doesn't violate laws of Thermodynamics.
FE stands for Free energy - it is like anything that is for free.
-some other mechanism of nature, or someone invested in it work, resources, so you can have it for Free.
Perpetual Motion is the motion where energy delivered to the system equals energy consumed by the system and as such
violates laws of Thermodynamics.
Wesley
https://www.youtube.com/watch?v=ySEqZC5HwRA (https://www.youtube.com/watch?v=ySEqZC5HwRA)
Автономный Генератор Электроэнергии
Autonomous Electricity Generator
Translation of text in Russian:
For many years I was looking for a working sample of such a device, all the time
I came across fraudsters,
not a single invention of this kind passed the examination.
But not this time, they checked everything, measured everything, but the device works even in a closed loop
and with the power off in the room.
Currently, there is a working prototype that has already been
tested and tested, but so far it produces no more than 20W of energy.
Now we are creating a
syndicate of small investors in order to create
a device generating up to 1 MW and serial samples for the population
(apartments, summer cottages, offices) with a capacity of up to 1
0 kW
Why in Russia, because we want the introduction of these devices to start from our country.
Russian authentic text:
Много лет искал рабочий образец подобного устройства, все время попадались мошенники, ни одно подобного рода изобретение не проходило экспертизу.
Но не в этот раз, проверили все, замерили все, но прибор работает даже в замкнутом контуре и при отключённой Электроэнергии в помещении.
В настоящее время есть рабочий прототип который уже проверен и испытан, но выдаёт пока энергии не более чем 20Вт
Сейчас создаём синдикат из небольших инвесторов с целью создания прибора генерирующего до 1 мВт и серийных образцов для населения
(Квартиры, дачи, офисы) мощностью до 10 кВт Почему в России, потому что хотим чтобы внедрение данных устройств началось с нашей страны.
Wesley
too late >:(
https://youtu.be/418807W-9UE
Sorry I will post oversized pictures so you can se more details
if you have problem with to large pictures press on keyboard and hold
button ctrl
and while holding this button turn your Mouse wheel
and your picture will get smaller .
Wesley
8 more oversized photos
button ctrl
Wesley
SOME MORE PHOTOS SHOWING GROUND WIRE IN ELEVATOR
Wesley
ground wire connected to cold water pipe in bathroom of the apartment
button ctrl
Wesley
I see 3 problems with that Russian device from Moscow.
The problems are explained in the picture
Wesley
video is here
https://youtu.be/418807W-9UE (https://youtu.be/418807W-9UE)
Wesley
https://www.youtube.com/watch?v=aX21HCHlgKo
(https://www.youtube.com/watch?v=aX21HCHlgKo)https://www.youtube.com/watch?v=MhBuBivnhYo&t=17s
(https://www.youtube.com/watch?v=MhBuBivnhYo&t=17s)https://www.youtube.com/watch?v=iYv66yzEoXc
https://www.youtube.com/watch?v=AfZVdT_RuDI
Wesley
Quote from: stivep on April 01, 2021, 10:04:21 PM
(https://www.youtube.com/watch?v=MhBuBivnhYo&t=17s)https://www.youtube.com/watch?v=iYv66yzEoXc (https://www.youtube.com/watch?v=iYv66yzEoXc)
https://www.youtube.com/watch?v=AfZVdT_RuDI (https://www.youtube.com/watch?v=AfZVdT_RuDI)
Wesley
Hi stivep,
I have attached
AI enhanced image for your viewing pleasure captured at 39sec from this
Ethan Krauss YouTube video https://www.youtube.com/watch?v=2jQcf899NsA (https://www.youtube.com/watch?v=2jQcf899NsA)
We can see that smd components is used to multiply voltage.
Nothing to add.But i had to shrink 21mb full image a lot to comply with the attachment size requirement.
https://www.youtube.com/watch?v=h0cytSQR0s0
(https://www.youtube.com/watch?v=h0cytSQR0s0)https://www.youtube.com/watch?v=KCbNpRrXoWs
https://www.youtube.com/watch?v=z2xRHjsi7zY
Wesley
for these who don't want to calculate but just try 100kHz HV coil for Tesla coil:
2088 turns at length of 1/4 of km
30 gauge wire
4.5" outside OD PVC pipe.
and Tesla Coil Winder .
https://youtu.be/rKGX_o1CyO4?t=132 (https://youtu.be/rKGX_o1CyO4?t=132)
https://www.youtube.com/watch?v=sv-27wt5e9U (https://www.youtube.com/watch?v=sv-27wt5e9U)
(#0010) Automatic Tesla Coil Winding Machine - Part 1
____________________________________________
and here you have everything calculated checked and ready for 560kHz
https://youtu.be/rKGX_o1CyO4?t=278 (https://youtu.be/rKGX_o1CyO4?t=278)
Note :
Zenneck Wave will work perfectly good on that frequency
And this video looks like it is just for fun but it may be quite parctical
https://youtu.be/VnO7hNSpWq0?t=101
(https://youtu.be/VnO7hNSpWq0?t=101)
(#0047) Vacuum Filling Oil in High Voltage Scope Probe - DRSSTC vs. Spark Gap #07
https://www.youtube.com/watch?v=Aau83j4Sr5g
Wesley
Quote from: stivep on April 02, 2021, 12:13:53 PM
Wesley
And what is it ? Where to read the description? We did this, the sparks were much smaller ...
very nice presentation of wave properties and wave behavior including standing wave
https://www.youtube.com/watch?v=WSeq0Omi7DQ (https://www.youtube.com/watch?v=WSeq0Omi7DQ)
Physics 220 Lab 12 E&M Waves
So when dealing with Tesla Coil it becomes handy.
Wesley
https://youtu.be/4E7Phl_xBH4?t=714 (https://youtu.be/4E7Phl_xBH4?t=714)
Interesting presenter from the perspective of variety of information given
Wesley
Vous ne comprenez pas le Français mais cette vidéo est là pour décrédibiliser l'énergie libre en ne montrant que les projets que nous savons ici déjà fake. Si vous ne comprenez pas la totalité d'une vidéo étrangère ne la partagez pas.
Bonne soirée de la France.
veuillez vous rendre sur ce lien et formuler votre réponse. / malheureusement vous ne répondez pas à mes réponses amicales
Wesley
How ferrites are made ?
Ferrite Core
https://www.youtube.com/watch?v=sbGBZTDsE2k
(https://www.youtube.com/watch?v=sbGBZTDsE2k)Some home made methods but not so perfect.
https://www.youtube.com/watch?v=jAsRp4dvJCU
(https://www.youtube.com/watch?v=jAsRp4dvJCU)
I have the same HP4194A too.
Wesley
How to Identify an Unknown Ferrite Core
https://www.youtube.com/watch?v=Q95Vwk3kZok
Wesley
#84: Basics of Ferrite Beads: Filters, EMI Suppression, Parasitic oscillation suppression / Tutorial
https://www.youtube.com/watch?v=81C4IfONt3o
Wesley
AFTER THIS VIDEO YOU WILL UNDERSTAND TED ANIS INVENTION I assume.
Core Memory Explained and Demonstrated
This is specially important as it shows square hysteresis.
and it shows switching by ferrites.
So for Ted Anis application this is perfect.
But where to get them now?
and you need probably around 100 000 of them to be glued
or crashed into powder and re-formed in desired shape.
https://www.youtube.com/watch?v=AwsInQLmjXc
(https://www.youtube.com/watch?v=AwsInQLmjXc)Rule of practical approach applied here:
Every big device may be tested by watching behavior of its tiny mini version of it ,
You'll get small power from it but you'll see the effect.
Wesley
https://youtu.be/fwpP7gNHVGE (https://youtu.be/fwpP7gNHVGE)
https://youtu.be/XQlSM0uLkko (https://youtu.be/XQlSM0uLkko)
https://youtu.be/Kdup42Epq0o (https://youtu.be/Kdup42Epq0o)
QuoteSome home made methods but not so perfect.
I would like to know why this man makes a core for " bucking coil ". ;)
https://www.youtube.com/watch?v=c2h60hCJh2U
(https://www.youtube.com/watch?v=c2h60hCJh2U)Wesley :)
Quote from: onepower on May 01, 2021, 03:13:52 AM
There is only one reasonable solution and that is as the video claims that the resonant electrical action of the LED light circuitry once excited continues to scavenge energy from the alternating potential on the open ended live wire next to the neutral wire feeding it.
Think about my question...So how is it that a single supposedly "neutral" wire bonded to an Earth ground in the electrical panel could continue to power the LED light?. s
AC
It is simple to explain but needs some knowledge about power systems.
https://electrical-engineering-portal.com/types-of-electrical-power-distribution-systems (https://electrical-engineering-portal.com/types-of-electrical-power-distribution-systems)
It is inductive coupling.Not going deep into explanation think that every day you are walking on thousands of Volts of potential from power grid, lightning discharges of nearby thunderstorms,
and bird sits on HV power lines and nothing happened yet .. if the distance between bird legs is small enough at step voltage.
https://en.wikipedia.org/wiki/Earth_potential_rise#:~:text=%22Step%20voltage (https://en.wikipedia.org/wiki/Earth_potential_rise#:~:text=%22Step%20voltage)
The same story is with
NdaClouDzzz videos especially when he uses transformer-less 12V power supply, (with no isolation transformer)
https://en.wikipedia.org/wiki/Isolation_transformer (https://en.wikipedia.org/wiki/Isolation_transformer)
Wesley
some sidekick from main focus:
https://kids.frontiersin.org/article/10.3389/frym.2019.000 (https://kids.frontiersin.org/article/10.3389/frym.2019.000)
gas hydrates.
Gas hydrates are a solid form of water,
rather like ice, that contains gas molecules locked up in a "cage" of water molecules.
Gas hydrates are found on continental shelves around the world and in permafrost in the arctic.
We are interested in gas hydrates because they could be used as a future source of natural gas.
https://www.youtube.com/watch?v=3trDB5hN4Ug (https://www.youtube.com/watch?v=3trDB5hN4Ug)
Dry water and Burning ice: all about gas hydrates
so why we are interested with that?
China announced that as the first in the world they accomplished excavation of it.
Russian propaganda says that this is more energy than oil, coal and natural gas together but.. they rather "do" oil now
Wesley
Yes,very nice ,Wesley !
https://translate.google.com/translate?sl=auto&tl=en&u=https://worldoceanreview.com/de/wor-1/meer-und-chemie/methanhydrate/ (https://translate.google.com/translate?sl=auto&tl=en&u=https://worldoceanreview.com/de/wor-1/meer-und-chemie/methanhydrate/)
And for the C-content in in european future possibly the emission price :
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.handelsblatt.com/politik/deutschland/klimaschutzgesetz-co2-preis-von-100-euro-rueckt-in-greifbare-naehe/27154472.html?ticket%3DST-792215-MqGWaHU5pcIvZB4KvPwB-ap6 (https://translate.google.com/translate?sl=auto&tl=en&u=https://www.handelsblatt.com/politik/deutschland/klimaschutzgesetz-co2-preis-von-100-euro-rueckt-in-greifbare-naehe/27154472.html?ticket%3DST-792215-MqGWaHU5pcIvZB4KvPwB-ap6)
For the one side CO2-from-air-scrubbing industry : financed by CO2-emissioner
https://www.wri.org/insights/6-ways-remove-carbon-pollution-sky (https://www.wri.org/insights/6-ways-remove-carbon-pollution-sky)
4) Direct Air Capture
a 2018 study estimates (https://www.cell.com/joule/abstract/S2542-4351(18)30225-3) that it would cost about $94-$232 per metric ton.
Sincere OCWL
https://strannik-2.ru/index.php/forum/svobodnaya-energiya/582-samyj-prostoj-generator-svobodnoj-energii?start=120 (https://strannik-2.ru/index.php/forum/svobodnaya-energiya/582-samyj-prostoj-generator-svobodnoj-energii?start=120)
In here Rakarskiy talks about the simplest "FE" device - the linear transformer..
https://en.wikipedia.org/wiki/Linear_transformer_driver (https://en.wikipedia.org/wiki/Linear_transformer_driver)
And that is in connection with Zenneck Wave in the interface in configuration of modulating signal over the carrier.
https://youtu.be/pMI_n6MyaIs?t=25[/url]
https://en.wikipedia.org/wiki/Z_Pulsed_Power_Facility (https://en.wikipedia.org/wiki/Z_Pulsed_Power_Facility)
what's big can be small but it works.
Wesley
the energy source is natural....
it doesn't need to be build or paid for.
It only needs to be directed
All is needed is just a vector.
Wesley
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Pinch-Effekt_%28Elektrodynamik%29 (https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Pinch-Effekt_%28Elektrodynamik%29)
this was good
the angle is Brewster Angle ..
Wesley
light as electron-gas/ion-gas or plasma
https://translate.google.com/translate?sl=de&tl=en&u=https://uol.de/f/5/inst/physik/ag/physikpraktika/download/GPR/pdf/Polarisation.pdf (https://translate.google.com/translate?sl=de&tl=en&u=https://uol.de/f/5/inst/physik/ag/physikpraktika/download/GPR/pdf/Polarisation.pdf)
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Brewster-Fenster (https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Brewster-Fenster)
power frequency to radio frequency sender to receiver reconvert to power frequency
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=3214690A&KC=A&FT=D&ND=3&date=19651026&DB=EPODOC&locale=en_EP (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=3214690A&KC=A&FT=D&ND=3&date=19651026&DB=EPODOC&locale=en_EP)
https://patents.google.com/patent/WO2005055409A2/en (https://patents.google.com/patent/WO2005055409A2/en)not unknown :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=philo+farnsworth&CPC=&IC=&Submit=Search (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=philo+farnsworth&CPC=&IC=&Submit=Search)
Sincere
OCWL
p.s.: Und " liebes" lankaIV ,You would get in Germany(and Deutsch speaking countries) some anger with such "lovely ??? words",
assuming You being § 175 – Wikipedia
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/%25C2%25A7_175 (https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/%25C2%25A7_175)
Sometimes good translation is faked 8) https://www.youtube.com/watch?v=C1Sw0PDgHU4 (https://www.youtube.com/watch?v=C1Sw0PDgHU4)
Wesley,I am simple thinking !
https://www.youtube.com/watch?v=NPAx_jNQLPM (https://www.youtube.com/watch?v=NPAx_jNQLPM) https://www.youtube.com/watch?v=R2jaY5VQMTg (https://www.youtube.com/watch?v=R2jaY5VQMTg)
1280x720 Pixel bei 50 pictures pro Sekunde 3840x2160 Pixel bei 50 pictures pro Sekunde
signal-to-signal image-/and sound repeat quality transmission experiments ? 1-4% losts efficiency in quantity/quality !?
"...or ..." was related K. Masaki his description ,f.e. :
The magnetic field lines generated when an electron flow having the same phase of voltage and current flows through the coil also penetrates a metal plate or seawater.
Eindringtiefe ? Funny (but not only,some " or" cases more)
https://translate.google.com/translate?sl=de&tl=en&u=https://www.thm.de/mni/forschung/institute-gruppen/imps/imps-strahlung-information/strahlenschutz/einwirkung-und-durchdringung-von-strahlung.html (https://translate.google.com/translate?sl=de&tl=en&u=https://www.thm.de/mni/forschung/institute-gruppen/imps/imps-strahlung-information/strahlenschutz/einwirkung-und-durchdringung-von-strahlung.html)
material viskosity : Debye,Engeler and other physical units
Sincere
OCWL
p.s.: it is also the question about "service quality and warranty",
defined f.e. in Germany by law
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/%25C3%259Cbermittlungsirrtum (https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/%25C3%259Cbermittlungsirrtum)
free translator we have to see " at your own risk, legal recourse is excluded " ,but will/wants Viziv work for free ?
Quote from: lancaIV on June 05, 2021, 01:16:58 PM
https://www.youtube.com/watch?v=NPAx_jNQLPM (https://www.youtube.com/watch?v=NPAx_jNQLPM) =https://www.youtube.com/watch?v=R2jaY5VQMTg (https://www.youtube.com/watch?v=R2jaY5VQMTg)
Very nice example.
I can use it to adjust my cameras to the max focus.
But that is only one of the factors.
Key DifferencesThe 4k image is smoother, and has more detail than the 1080p image.
Edges around objects in the 1080p picture are noticeably more serrated. ...
4k content is still quite rare, most of what you watch will probably be lower-resolution satisfied up scaled to
UHD, which will look different from native 4k and 1080p.
certain resolutions can only be seen on specific displays that are large enough to make a difference.
- if your monitor isn't big enough to show a difference between the two, paying the extra cost may not be worth
the benefit of buying 4K.My motion picture cameras are :4K, Sony Ax-100 fdrax100 (https://www.bhphotovideo.com/c/product/1022653-REG/sony_fdrax100_b_hdr_ax100_full_hd_handycam.html)
5.7k EVA-1 Film camera https://youtu.be/CppZpVfgCE8 hphoto (https://www.bhphotovideo.com/c/search?Ntt=5.7k%20%20%20EVA-1&N=0&InitialSearch=yes&sts=ma) ,
6K BMPCC6k Pro. Film camera https://www.youtube.com/watch?v=ltMBvp2ENM0
when rendering the original higher resolution e.g 6K
into the 4k resolution - the picture is always better than that from any original 4K Camera _______________________________________Explanation of the above:
what is Film camera in 2021?
it doesn't use film and chemicals.
It is called Film camera but it is digital.
A film camera often has a higher resolution than what is found in most
digital cameras used for documentary or photographic work.
Well this is not always true.
Film Camera is the Cinema Camera and no any other type of camera is allowed by Netflix
or Hollywood.Film Camera has in mind almost manual operation and definitively
no continuous auto focus. It's as if we take a power of Ferrari
and manual transmission, manual brakes, manual light control, and manual fuel pump, manual speed control
but you'll never need to pay any tickets.
So survival is not guarantied.
The beauty of it is that if you are average driver you simply can't drive such car
you must be an artist and professional.
and that is why Film Camera can't be used as a -
"run and gun"
Explanation:
"Run and gun"- is a term used to describe a style of filmmaking with very little production equipment
besides a camera. Run and gun is typically used in documentary-style filmmaking, as filmmakers aren't
always given the luxury of a controlled set.Wesley
___________________________________________________
Few rules that never changes:
1. overunity doesn't exist.
2. perpetual motion machine is impossible to be made, but everything else is more close or more far to perpetual motion .
a.- practicality any machine close or far to perpetual motion is important just from the perspective of its application.
3. only original natural energy is for free, everything else must be paid for.
That means every conversion to the form of energy we prefer .. cost money.
but it may be one time cost only plus some periodic maintenance .
a.- "closeness" to Perpetual Motion is measured by efficiency efficiency is a measurable concept, quantitatively determined by the ratio of useful output to total useful input.
example:
efficiency of gasoline engine 40%
efficiency of solar panels are roughly between 15% and 18%
efficiency of Niagara falls waterfall 60 to 75%
efficiency of energy Extraction from Schumann waveguide is not important
as we don't pay for any of its Energy at any point of conversion.
From perspective of economics
Perpetual Motion is when - $1 in your hand taken out from your left pocket and than placed into right pocket still reminds unchanged
In physics :
the cost of energy used to move $1 from left to right pocket using your hands is coming from food you consumed . And if someone else paid for that food than you'll have perpetual motion but only from your point of observation.
Evaluation of devices of any of the presenters.
question they must answer:
-if it works than show me extra energy compensating losses
-If you can't show or explain to me the origin of extra energy than we have two possible options:
1- the device is using additional energy that is paid by nature but we just don't see it yet with:
-our measurement devices
-and we don't understand the mechanism of that particular energy conversion yet.
2- the device is fake among 99% of other fakes.
Wesley
Breakthrough in Nuclear Fusion? - Prof. Dennis Whyte
https://www.youtube.com/watch?v=KkpqA8yG9T4
(https://www.youtube.com/watch?v=KkpqA8yG9T4) 1 gram of Deuterium oxide gives 10MW of energy ;
And this is newer Year 2021
https://www.youtube.com/watch?v=h8uYNhevRtk (https://www.youtube.com/watch?v=h8uYNhevRtk)
(https://www.youtube.com/watch?v=KkpqA8yG9T4)10 times more energy than delivered
Wesley
5th dimensional mathematics exclude the closed system analysis,
and in this state, thermodynamics becomes irrelevant.
Homemade Heavy Water Concentrator::::
1" pvc or acrylic tubing 10-feet in length.
Suspended vertically
Fill with boiling water.
Siphon the lower 1ft after cooling.
Rinse and repeat.
Once you have harvested 10ft of water,
reboil
And extract gen2 1ft of water 10x
Continue this process for 10 cycles.
You will have high purity deuterium oxides.
So much happened in the meantime.
- Death of Tariel Kapanadze ( not verified yet )
- Viziv Chapter 11
Experimenter is publicly active/ inactive for the reason- and there is a reason for it.
https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559510/#msg559510 (https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559510/#msg559510)
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg559524/#msg559524 (https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg559524/#msg559524)
Wesley
This is receiver used by us for experiments.
SPM-139 Wandel Goltermann Selective level meter.
50Hz-32MHz
SSB, CW.
second picture is giving you close look.
Wesley
This is the same function two receivers but by American HP3586B
Wesley
Some news from India
presentation and conference in Indian style 2 weeks ago
Inventor - Amit Sehrawat
Said to be patent holder , but patent was not found by me.
Device Gravity buoyancy power plant said to be 50kW/h
Load was not inexpressive 3 light-bulbs.
Presentation was in Hindu language
Problem : how he could get patent if he stays that device works against law of physics.
Source of information :
Andrey Tirtha commenting video (in Russian only)
This guy comments are far from accuracy nor value but...
If anyone know how to electronically translate youtube voice into English let me know.
https://youtu.be/MUlj45q-PRw?t=229 (https://youtu.be/MUlj45q-PRw?t=229)
Youtube channel of inventor :Amit Sehrawat
https://youtu.be/q5_QF_nX81A?t=328 (https://youtu.be/q5_QF_nX81A?t=328)
https://www.youtube.com/watch?v=Ntz7_2IS_Ow (https://www.youtube.com/watch?v=Ntz7_2IS_Ow)
https://www.youtube.com/watch?v=xfP-2sD3bI4 (https://www.youtube.com/watch?v=xfP-2sD3bI4)
All videos in his channel :
https://www.youtube.com/user/akpatent2011/videos (https://www.youtube.com/user/akpatent2011/videos)
Wesley
patenting means "making public" ,german "Offenlegung" .
For the inventor or clearer: the applicant ,private/industry/commerce,are two ways of technical devices to patent :
a. "Utility model " patent application,10 years validity
b. "Technical Standart" patent application,20 years validity
It is ever possible to apply "perpetuum devices",functional or not, for patent : as Utility model ! ;)
There are thousands "sleeper" in the archives,for freaks/researcher often in "foreign,for reader unknown/uncommon, language" ,
or with title : "without title" 8) invention class ?
Multilingual researcher have it easier ! :) But now : automatic translator ! Other will also find "treasures" ! :'(
youtube offers also ,beside the Uttar Pradesh GBP plant vid,related Amit Sehrawat (https://www.youtube.com/channel/UC26ibBGfLygpiCTXZK2km2Q) : https://www.youtube.com/watch?v=pl3-3ELoBqc (https://www.youtube.com/watch?v=pl3-3ELoBqc)
My work: when files are open for later review
I search it , and here is the result of the search.
body of invention:
//The present invention can then be used by allowing radiant energy to strike the top of the compound//
//compound Si2 HSb2 which is poured into a mold.//
//amplification factor is typically 184,000 times the power input.//
//his invention has nothing to do with semiconduction as it relates to solid state electronics or the creation of electricity from solar radiation. //
link:
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP#)
_ ______________________________
Patent:US5252176 (A) ― 1993-10-12
Status: expired
legal status:
https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/inpadoc?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP#)
Original document:
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=5252176A&KC=A&FT=D&ND=5&date=19931012&DB=EPODOC&locale=en_EP#)
search links:
1. With Si2HSb2 crystal ( electret) 4kW/h
https://autocostruire.forumcommunity.net/?t=60961849 (https://autocostruire.forumcommunity.net/?t=60961849)
https://autocostruire.forumcommunity.net/?t=60480820 (https://autocostruire.forumcommunity.net/?t=60480820)
2. Robert HENSON Si2HSb2 Amplifier
http://www.rexresearch.com/hensonsihsb/henson.html (http://www.rexresearch.com/hensonsihsb/henson.html)
3. laser to Si2HSb2 crystal propolution rocket power.
https://bobinedinamiche.forumcommunity.net/?t=61902840 (https://bobinedinamiche.forumcommunity.net/?t=61902840)
4.Re: Curiosity on chemical process (https://overunity.com/16875/curiosity-on-chemical-process/msg507915/#msg507915)
https://overunity.com/16875/curiosity-on-chemical-process/msg507915/#msg507915 (https://overunity.com/16875/curiosity-on-chemical-process/msg507915/#msg507915)
5.Cristallo Si2HSb2 - Brevetto
https://conoscenza6.webnode.it/l/cristallo-si2hsb2-brevetto/ (https://conoscenza6.webnode.it/l/cristallo-si2hsb2-brevetto/)
6. neutron amplification:
https://www.radioactivityforum.it/forum/viewtopic.php?t=3449 (https://www.radioactivityforum.it/forum/viewtopic.php?t=3449)
Wesley
Topics targeting very much specified subject matter.
one is in English another in Russian:
1.https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560346/#msg560346 (https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560346/#msg560346)2.
https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg560156/#msg560156 (https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg560156/#msg560156)
_________________________________________Dr James F Corum and his brother Kenneth Corum. Viziv. Texon .. Tesla Tower in Milford Tx and FE...
James F Corum work was quoted also by some kind of seminarian, or priest ,making Intimidating modern science errors
But the article below is worth your time from historical perspective:
https://news.ag.org/en/News/Four-Honored-with-General-Superintendent-s-Medal-of-Honor?D=%7BA4E03528-9D9E-4538-9FD6-87E8D6162D92%7D
(https://news.ag.org/en/News/Four-Honored-with-General-Superintendent-s-Medal-of-Honor?D=%7BA4E03528-9D9E-4538-9FD6-87E8D6162D92%7D)Dear reader. Invest time, some but not a lot of money, read, interact, experiment and build the device
converting energy from its original natural form and called by you now Free Energy.if you will...
Entire energy extraction presented by me and energy transfer presented by Dr Corum is made from coils and capacitors only_________________________________________Let's sort some :
1. Quoted text:
https://www.reddit.com/r/Tesla/comments/4u6a4z/a_technical_analysis_of_the_extra_coil_as_a_slow/
(https://www.reddit.com/r/Tesla/comments/4u6a4z/a_technical_analysis_of_the_extra_coil_as_a_slow/)In regards to
positron( look at the picture below - in green color)
Quote (positron current)
There are two articles:
https://en.wikipedia.org/wiki/Positron (https://en.wikipedia.org/wiki/Positron)
would-a-flow-of-current-of-positrons-
(https://physics.stackexchange.com/questions/488455/would-a-flow-of-current-of-positrons-zap-us#:~:text=To%20your%20question%2C%20yes%2C%20positrons,positrons%20moving%20right%20to%20left.)If world was made from antiparticle and antimatter than we would have positron current.
Positron is antiparticle of electron that is part of atom and atom is part of mass.
When positron collides with electron they both stop to exist and we have in effect two photons
traveling 180 degrees apart in opposite directions. That is how PET tomography works.
2.
Quotebecause he had build the hydroelectric station there
Ames Hydroelectric Generating Plant,
constructed in 1890 near Ophir, Colorado
was build by Westinghouse. to drive the mining operation.for Gold King Mine (https://en.wikipedia.org/wiki/Gold_King_Mine)
https://en.wikipedia.org/wiki/Ames_Hydroelectric_Generating_Plant
(https://en.wikipedia.org/wiki/Ames_Hydroelectric_Generating_Plant)Tesla moved to Colorado Springs in 1899.
Here is the nature of the problem I have.
Quotereflected without change of phase
There are three opinions where two of them represents scientific papers
conforming that this is what is taking place.
no reversal of phase.1. dalkon (https://www.reddit.com/user/dalkon/) Op · 5y (https://www.reddit.com/r/Tesla/comments/4u6a4z/comment/d5oe74c/?utm_source=reddit&utm_medium=web2x&context=3) text from forum:
http://www.padrak.com/vesperman/A_Technical_Analysis_of_Tesla%27s_Extra_Coil_6.24.14.pdf
2. the original PDF of Dr Corum about slow wave is here:
(https://www.reddit.com/r/Tesla/comments/4u6a4z/a_technical_analysis_of_the_extra_coil_as_a_slow/)Note : address for both links is the same but to get to original Dr Corum paper you need to press
on the very top of the page link . as explained in
picture #2 3. https://archive.org/details/electromagneticw0000jord/page/n9/mode/2up
this link is not giving full text of:
Electromagnetic waves and radiating systems by Jordan, Edward C. (Edward Conrad)
It looks like something I'm deeply confused with . Wesley
Stivep,
Tesla transformer is OU. Slow wave secondary helical in resonance is accumulating energy.
We have some energy "for free", or another way said- Nature gives it.
In resonant tank, one impulse results in tank oscillation. We charge capacitor only ONCE , discharging it through spark gap makes MANY oscillations ( this is when Nature gives something extra ).
Each of this MANY oscillations gives off energy from primary to secondary, where that extra energy is accumulated.
It is like a grain of wheat that turns into a bowl of wheat.
We have ONE grain, put it into soil, Nature turns it into bowl of grains.
Oscillation of tuned LC circuit is a key to OU.
And Tesla mastered this setup.
Best Regards,
Pix aka Wojciech
Hi Wesley,
Resonant LC circuit like Tesla magnifier is "Free".
For ONE impulse we have MANY oscillations that we harvest.
Like swing or pendulum- you give it a one push, it swings many times.
Or a wheat grain- you plant one grain, you will get whole ear of grains.
Doesn't matter how it is named, OU or "Free", there are just a words.
Nature gives it.
It is open circuit.
Kind Regards,
Pix
Hi Wesley,
1.Then how Tesla Magnifier works? In primary circuit capacitor is charged to spark gap break voltage and then oscillations starts.
All those oscillations are accumulated in secondary ( with losses).
But it is evident that system energy is raising because of those oscillations (they are "free").
Additionally if resonant frequency of Tesla Magnifier is exact as some natural backround earthly EMF fields,
then this open circuit is harnessing extra energy from enviroment ( earth-ionosphere wave gude space).
Kapanadze always talks about enviroment. Correct me if I am wrong.
2.Ordinary heat pump has COP of 2-3. Extra energy is taken from enviroment in the form of heat. 1kW of electrical energy
consumed by work of compressor and fan gives 2-3kW
of energy in the form of heat extracted from ambient air.
3.Ferromagnetism. Ferromagnetic material amplifies external magnetic field hundreds and thousands of times.
4.Avalanche. Photomultiplier, electrons multiplier, even ordinary spark gap . Process multiplies number of electrons (current).
It is like a chain reaction.
I don't like playing the words what is OU or what is "free". It is obvious there is no "free", but always converted from some other
source that we are not paying for- like sun rays converted in PV panel.
Please see attached the closest patent in my opinion to TPU.
Kind Regards,
Pix
Quote from: pix on October 07, 2021, 05:23:42 PM
Hi Wesley,
Add 1Here you have link to what looks like reputable electrical engineering site.
https://electrical-engineering-portal.com/magnifying-transmitter-nikola-tesla
(https://electrical-engineering-portal.com/magnifying-transmitter-nikola-tesla#:~:text=The%20magnifying%20transmitter%20was%20an%20adaptation%20of%20the,tuned%20receiving%20circuit.%20Wireless%20Global%20Transmission%20of%20Power)This is exactly the text you would agree with.
Here you have much better explanation by Serbian scientist Dr Jovan Cvetić.
https://pennedout.com/things/aetheric_physics/teslas_magnifying_transmitter_principles.pdf
Add 2 QuoteOrdinary heat pump has COP of 2-3.
https://www.sfu.ca/~mbahrami/ENSC%20388/Notes/Second%20Law%20of%20Thermodynamics.pdf (https://www.sfu.ca/~mbahrami/ENSC%20388/Notes/Second%20Law%20of%20Thermodynamics.pdf)
Add 3
QuoteA magnetic field of about 1 T can be produced in annealed iron with an external
field of about 0.0002 T, a multiplication of the external field by a factor of 5000!
the explanation is here:
http://hyperphysics.phy-astr.gsu.edu/hbase/Solids/ferro.html
Add 4 this is not like chain reaction.
An
electron multiplier consisting of several electrodes (dynodes) is covered with a layer of secondary emissive material,
but multiplication is given at the expense of energy delivered to each one of dynodes.
https://psec.uchicago.edu/library/photomultipliers/Photonis_PMT_basics.pdf
(https://electrical-engineering-portal.com/magnifying-transmitter-nikola-tesla#:~:text=The%20magnifying%20transmitter%20was%20an%20adaptation%20of%20the,tuned%20receiving%20circuit.%20Wireless%20Global%20Transmission%20of%20Power)Wesley
Vladimir Atsyukovsky also believes that Tesla's transformer is over-unity.
Due to the energy of the ether. ???
Hi Wesley.
Thanks for links to articles.
1. Quote :
"Summary:Tesla magnifying Transmitter is only making HV and low current easier."
High voltage is on the top terminal of Tesla secondary, high amperage is at the grounded part. Tesla was stating that idea is to create a
huge oscillations of reactive power and convert part of that reactive power to to real power. Still, energy accumulation and gain in
Tesla Magnifier is coming mainly from primary circuit oscillations. Stepanov patents are also based on creation a lot of reactive
power by resonant circuit and converting that back to active power.
2. Heat pump and ferromagnetism are examples that we can get something extra from enviroment and nobody is calling this OU or free energy.
3.What is your opinion about Thonemann patent I attached in my previous post.
TPU looks like is based on the principle of non indictive current drive by travelling wave. Principle used to create heating current in plasmas.
Cheers,
Pix
Witam,
co do tesla magnifier'a to zawsze można przetestować w mikroskali na przykład na symulatorze, niżej przedstawiony
zmodyfikowany schemat poglądowy dla symulatora (pewnie w rzeczywistości może i by działał, ale trzeba sprawdzić),
oczywiście elementy dobrane "na oko", ale jest jeden fakt nie zmienia fazy napięcie w punktach kolejno między cewkami od L2 do L5.
Wesley, what do you think about Atsukovsky's opinion about the Tesla transformer? ;)
So many BS on this forum.
I gave TPU patent on the silver plate and nobody bothers :o
Quote from: pix on October 18, 2021, 10:35:14 AM
Please specify.
I'm not on O.U.R.https://overunityresearch.com/index.php?topic=302.375although (https://overunityresearch.com/index.php?topic=302.375although)
_______________________________________________________
https://overunityresearch.com/index.php?topic=302.375 (https://overunityresearch.com/index.php?topic=302.375)https://patents.google.com/patent/US3085189A/endirect (https://patents.google.com/patent/US3085189A/endirect) download link :
https://patentimages.storage.googleapis.com/99/e8/3c/26db34923fe819/US3085189.pdf
(https://patentimages.storage.googleapis.com/99/e8/3c/26db34923fe819/US3085189.pdfI)I must say you are the one ...worth my time.
You may try to catch me on something I said...if you can... :)
Patent Citations (5) Publication number Priority date Publication date Assignee Title
US2096460A (https://patents.google.com/patent/US2096460A/en) * 1936-01-23 1937-10-19 Bell Telephone Labor Inc Space discharge apparatus
US2163740A (https://patents.google.com/patent/US2163740A/en) * 1935-11-26 1939-06-27 Jr Nathaniel B Wales Phase wave ion gun
US2218725A (https://patents.google.com/patent/US2218725A/en) * 1938-04-22 1940-10-22 Telefunken Gmbh Electron focusing system
US2657314A (https://patents.google.com/patent/US2657314A/en) * 1947-11-18 1953-10-27 Csf Ultra short wave generator having a wide band of oscillation frequencies
US2657305A (https://patents.google.com/patent/US3085189A/en#) * 1947-01-28 1953-10-27 Hartford Nat Bank & Trust Co Traveling wave tube mixing apparatus
Cited By (5) Publication number Priority date Publication date Assignee Title
US3462636A (https://patents.google.com/patent/US3462636A/en) * 1965-04-15 1969-08-19 Siemens Ag System for the conversion of microwave energy into electric direct current energy utilizing an electron beam tube
US3521119A (https://patents.google.com/patent/US3085189A/en#) * 1968-01-10 1970-07-21 Rca Corp Rf excitation pumping of gas lasers by means of a wave guide and coupling coils
US4742278A (https://patents.google.com/patent/US4742278A/en) * 1987-06-03 1988-05-03 Iannini Robert E Single connection gas discharge display and driver
US5386181A (https://patents.google.com/patent/US5386181A/en) * 1992-01-24 1995-01-31 Neon Dynamics Corporation Swept frequency switching excitation supply for gas discharge tubes
EP1662847A2 (https://patents.google.com/patent/EP1662847A2/en) * 2004-11-29 2006-05-31 Samsung Electronics Co., Ltd.
Driving frequency modulation system and method for plasma accelerator
Some literature to share:https://www.youtube.com/watch?v=soCfpyu2q3A (https://www.youtube.com/watch?v=soCfpyu2q3A) Making Tube Amplifiers from TVs
https://www.youtube.com/watch?v=I-DlgOoz978 (https://www.youtube.com/watch?v=I-DlgOoz978) Traveling Wave Tube Amplifier
https://www.youtube.com/watch?v=RyO0Laz6aLA (https://www.youtube.com/watch?v=RyO0Laz6aLA) Traveling Wave Tube Amplifier Teardown
https://www.youtube.com/watch?v=I-DlgOoz978 (https://www.youtube.com/watch?v=I-DlgOoz978) Travelling Wave Tube Amplifier
https://www.youtube.com/watch?v=0HGdQ0C7CYg (https://www.youtube.com/watch?v=0HGdQ0C7CYg) Teardown of a Microwave Amplifier and a Traveling Wave Tube
________________________________________________________________________________
About inventor :
Peter Thonemann
https://en.wikipedia.org/wiki/Peter_Thonemann
(https://en.wikipedia.org/wiki/Peter_Thonemann)https://www.youtube.com/watch?v=enVux_Dhjr8 (https://www.youtube.com/watch?v=enVux_Dhjr8)
QuoteIn 1947, Cousins and Ware began experiments using pinch in toroidal tubes.
Thonemann was able to arrange a small amount of funding, and in 1948 began basic experiments with electrical discharges in a linear tube containing mercury gas to study the pinch effect.
By the next year he had moved to a larger copper torus and was able to demonstrate the pinch to Frederick Lindemann (https://en.wikipedia.org/wiki/Frederick_Lindemann) and John Cockcroft (https://en.wikipedia.org/wiki/John_Cockcroft).
Thonemann became the Atomic Energy Research Establishment (https://en.wikipedia.org/wiki/Atomic_Energy_Research_Establishment) (AERE) Head of Research on Controlled Thermonuclear Reactions in 1949, a position he held until 1960.[1] (https://en.wikipedia.org/wiki/Peter_Thonemann#cite_note-FOOTNOTETimes2018-1)
pinch effect
plasma_physics Cylindrical%20pinch (https://en.wikipedia.org/wiki/Pinch_%28plasma_physics%29#:~:text=%20These%20include%3A%20%201%20Uncontrolled%20%E2%80%93%20Any,called%20a%20stabilized...%206%20Cylindrical%20pinch%20More%20)
https://www.quora.com/What-is-the-details-of-the-pinch-effect-and-magnetic-fields-in-plasma-physics (https://www.quora.com/What-is-the-details-of-the-pinch-effect-and-magnetic-fields-in-plasma-physics)
https://encyclopedia2.thefreedictionary.com/Pinch+Effect (https://encyclopedia2.thefreedictionary.com/Pinch+Effect)
QuoteAt Harwell, Cockcroft had successfully argued for the construction of a much larger machine, ZETA (https://en.wikipedia.org/wiki/ZETA_(fusion_reactor)).[1] (https://en.wikipedia.org/wiki/Peter_Thonemann#cite_note-FOOTNOTETimes2018-1) By 1957, early indications were that ZETA had successfully produced tiny amounts of fusion, and the story began to leak to the press.
This led to considerable coverage about Thonemann's role in the Australian press.[2] (https://en.wikipedia.org/wiki/Peter_Thonemann#cite_note-FOOTNOTEJames2018-2)
In January it was announced that ZETA had succeeded.
After further work, it became clear that the signals of fusion were false, and the story had to be withdrawn, causing great embarrassment.[1] (https://en.wikipedia.org/wiki/Peter_Thonemann#cite_note-FOOTNOTETimes2018-1)
https://youtu.be/L0KuAx1COEk?t=1829 (https://youtu.be/L0KuAx1COEk?t=1829)
Wesley
Hi Wesley,
I stated that OU site is full of BS. It is hard to find a valuable information because it is immediately covered by tons of BS.
Your topic about Zenneck surface wave is very informative.
But it deals with "transmission of energy".
I am more concerned about creating/converting/getting some energy.
Thonemann patent could be found on internet US3085189. It is used to drive current in tokamak plasma for heating it. The same effect is happening if instead plasma we insert conductor.
Similiarities with Steven Marks words:
1.Patent is owned by US Atomic Energy Commision.
2.Electrons drift in gas or central conductor caused by travelling wave is enchancing that travelling wave. That gives feedback effect which is feeding that process. "Furnace that is feeding itself"
3.DC in central conductor.
PS.
In fact I pointed this patent to overunityforum a while ago ;)
Cheers,
Pix
Analysis of the patent no final conclusions are made in this post yet:
so :
1. we can place any tube inside of helix ( coil).2. That tube will have two electrodes from both ends.
3. one of electrodes will act as
cathode and another as
anode.3a. anode "may not be" needed if we plan to shot the particle out ...
-that can be compared to:
CRT of TV where screen doesn't have phosphor screen and anode grid.. the particle is accelerated and just shot out.
however traditional CRT mechanism of accelerating is much better for that.4. While particle in circular tube the wave makes full 360 degrees, the wave in the circuit LC is "dying"( please read in the text of the patent)
this point 4 will be corrected in next comment as it is not accurate.
5. It is an electro-magnetic induction device for the
conversion of
radio frequency electrical energy into
direct current electrical energy,
we delivering :
RF at 1MHz
of power ~2-3kW
and in result we have at the ends of the vacuum tube:
4-5V
of DC power ~2-3kW________________________________________
However we can also make reverse action.
where we delivering DC to the tube and we getting in result the ~1MHz...2-3kW
Yet another scenario is that when we
"modulate" DC( with voice) varying its amplitude
or we do reverse action means we take 1MHz and modulate it with AM Voice than the other part of the device acts as demodulator..So it is a sort of very clever transforming device....a "transformer"
however
coil 20 ( figure 1) has yet another application
Wesley
to get full text of the patent
https://patents.google.com/patent/US3085189A/en (https://patents.google.com/patent/US3085189A/en)
and than on the right hand side click
Download PDF
Acceleration mechanism:From the perspective of transmission line:
made of C and L the impedance matching doesn't care about individual
12 winds sections of the coil spaced by every next C capacitor .
The shorted end is not seen as shorted transmission line but as the last 12winds ending the LC section .
Note:
50 Ohm impedance output/input is the widely used standard for all of the devices
in the world such as generators , analyzers, amplifiers and so on.
From view of the 50 Ohm generator output:
-the entire section of all L and C connected to the generator , must represent by itself the impedance of 50 Ohm to reach SWR 1:1
So at resonance for generator the entire coil/capacitors assembly acts as the load.-Well not .... only the resistive R load is the pure load converting energy into heat.
The LC "loads" don't dissipate energy
Quotereactive loads such as inductors and capacitors dissipate zero power,
yet the fact that they drop voltage and draw current gives the deceptive impression
that they actually do dissipate power. This "phantom power" is called reactive power,
and it is measured in a unit called Volt-Amps-Reactive (VAR), rather than watts.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-11/true-reactive-and-apparent-power/ (https://www.allaboutcircuits.com/textbook/alternating-current/chpt-11/true-reactive-and-apparent-power/)
but to understand why we say that any LC antenna is the load to the transmitter even if LC doesn't dissipate energy
there is a need for deeper explanation .. so I just stop here for now...
think of it as:
-LC circuit doesn't dissipate energy because Wesley said so and he gave link to this explanation .
- any antenna is a... LC circuit and we often call it a load as it acts as a load but..from another hand the LC circuit
can't dissipate reactive power.. it is not important how many LC sections is there.. it must be 50 Ohm... that's all.
In reality I don't believe that 50 Ohm standard applies there.
-the output of the generator can be made to match to whatever is the impedance of the LC assembly.
When you make experiment , you care less about the international standards as long as it works for you..
... it is just easier for you, to make generator with impedance matching that of coil capacitor assembly winded on the glass tube - accelerator
Form particle in vacuum tube perspective: nothing is important
the particle is affected by
drag made by first section of 12 winds and accelerated by second section and so on...
Wesley
Hi Wesley,
Imagine process:
-central conductor is "kicked" by HV source to free electrons from metal lattice while at the same time travelling wave process described in the patent goes on.
Electrons drift is done much easier then, without ohmic loss caused by metal lattice collisions.
To visualise it better- electrons jumps out of the conductor during HV potential "kick" and then are dragged alongside conductor by travelling wave, falling back to central conductor. Net current and voltage difference occurs at the ends of central conductor.
Maybe that is a key to SM words about "kicks" and a "catalyst"?
Pix
What is this, an analog computer?
To simulate the Schrödinger equation in real time?
Analysis of the patent: https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561071/#msg561071 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561071/#msg561071)
You confused me:
Quote from: pix on October 24, 2021, 06:09:57 AM
Hi Wesley,
Imagine process:
we have traveling wave in the coil around the tube but not inside of the glass tube...
in the glass tube we have DC electron drift. from cathode to anode... if we have anode.. as this can be just a fist stage of an electron gun..
the cathode is not heated - it is cold cathode.
the tube has vacuum inside :- it means no grid.. no anode under HV..
the different story is when patent is talking about propelling "jet " engine application..
here is the quote from the patent:
QuoteThe invention is based on the phenomenon that the progressive magnetic field of a traveling Wave (for example the traveling
wave produced in a loaded transmission line or by spaced coils excited in different phases) exerts a unidirectional drag upon electrons in the field and that conversely
a unidirectional notion of electrons tends to produce or enhance a traveling wave.
Meaning of Traveling wave may be confusing as explaining formula not always relates to
the origin of the wave and the type of the wave. So longitudinal waves are excluded from quantum worlds and belongs entirely into classical mechanics.
So when you look at wave phenomena you must !! always remember that you are reading the right explanation for right type of wave.
To make it more confusing..
classical physics called classical mechanics is an observable world - something we can see or sense without special equipment..
-some wave behavior in both words the classical physic and quantum physics can be very similar so often we use longitudinal wave behavior to
explain electromagnetic waves that belongs to quantum world.
example: the statement QuoteTraveling wave is a wave in which the medium moves in the direction of propagation.
applies to longitudinal mechanical wave that belongs to classical mechanic section of the physics here is yet another explanation of Traveling wave:
https://byjus.com/physics/travelling-wave/#:~:text=A%20wave%20can%20be%20described%20as%20a%20disturbance,the%20medium%20is%20known%20as%20a%20travelling%20wave (https://byjus.com/physics/travelling-wave/#:~:text=A%20wave%20can%20be%20described%20as%20a%20disturbance,the%20medium%20is%20known%20as%20a%20travelling%20wave).Wesley
Hi Wesley,
Thanks for your time analysing patent.
In the first section of patent (claims) it describes that unidirectional current could be driven by progressive magnetic field of travelling wave if there is fixed longitudal metallic conductor in the centre :
"The drag may be utilised for the acceleration of elec
trons in a vacuum discharge tube to resuit in a new form
of linear accelerator.
Or it may be utilised for establishing a unidirectional
current or voltage in a circuit comprising a relatively
fixed longitudinal conductor or semi-conductor. In this
case the exciting alternating current energy and a recti
fying device results which yields a uniform or modulated
output dependent on the exciting or input energy".
We know that in metals flow of current is experiencing resistance due to collisions with atoms in metal lattice.
This is my proposal to overcome or reduce ohmic losses for electrons drift in central conductor, caused by progressive magnetic field of travelling wave.
By kicking them out of central conductor by HV pulses at the same time.
Thermionic emission may also take place and enhance the process once central conductor gets heated by current flowing.
As SM stated for his TPU, he had a "DC current with some hasch".
Very interesting thing for Thonemann energy converter is that :
" progressive magnetic field of a travelling Wave (for ex
ample the travelling wave produced in a loaded transmis
exerts a unidirectional drag upon eiectrons in the field
and that conversely a unidirectional notion of electrons
tends to produce or enhance a travelling wave. "
So we have self supporting action.
This is a beauty:
Progressive magnetic field could be easily created by loaded transmission line or by multiphase winding. So, for coils drive we can use even 3 phase current from wall socket.
Kind Regards,
Pix
Wesley,
"The drag may be utilized for the acceleration of electrons in a vacuum discharge tube to result in a new form of linear accelerator.Or it may be utilized for establishing a unidirectional current or voltage in a circuit comprising a relatively fixed longitudinal conductor or semi-conductor. In this case the exciting alternating current energy and a rectifying device results which yields a uniform or modulated output dependent on the exciting or input energy".
Quote: "you can't accelerate electrons in conductor".
Indeed. That is why I want to kick them out of conductor, by HV pulse . Now they can be accelerated by progressive magnetic field of traveling wave at the moments they jumped out of conductor ;)
Pix
Quote from: pix on October 24, 2021, 12:29:57 PM
Wesley,
True but there is no word about
proposed by you tube with conductor inside..
In order TO KICK electrons out of the conductor it must be representing a cathode but not the conductive path from one side of the tube to another.Please read my comment about acceleration from above.
So how do you propose your own device ...BASED ON ALL SAID ABOVE.
Wesley
Wesley,
My proposal:
Central conductor in form of ring, may be inserted in vacuum glass tube ( to ease exit of electrons when kicked by HV pulses), outside are located coils for creating progressive magnetic field of travelling wave.
Process:
1. create travelling wave by loaded transmission line or multiphase driven coils upon central conductor ring located inside
2. kick central conductor with HV pulses
3. when electrons are kicked outside central conductor by HV pulse they experience acceleration by travelling wave and they drops back to central conductor. Jumps and acceleration of electrons repeat every HV pulse. That is creating current flow and potential difference in central conductor. Additionally, accelerated electrons when they fall back to central conductor may collide with electrons inside conductor and give them energy necessary to leave conductor. This process may multiply current.
Please see attached. But of course arrangements may vary. We may not use vacuum glass tube but dielectric around central conductor, the important is to kick electrons out of conductor.
Pix
if the red circle inside if the vacuum tube is your closed coil acting as electron emitter, how do you apply high voltage
to it?
What is the path of the electrons emitted from the conductor?
where are the potential difference points (like in normal accelerator anode cathode)?
what is the gain (an increase in the value of power) you getting from any of your proposed configuration?
Wesley
Wesley,
To kick central conductor by HV we need to introduce another electrode.
It may be another conductor located outside vacuum glass tube. Glass serves isolator. On top of it we locate driving coils or traveling wave armature coils.
Pix
- redacted by you there is presence of:
1. HV inner coil acting upon another inner coil that is inside of glass envelope making 1:1 "air" transformer.
Because HV impulse is AC (leading edge falling edge) it will induce HV in open loop inside of the glass envelope.
2. Because HV impulse is AC (leading edge falling edge) it will induce HV in accelerating set of coils - its LC components.
for accelerating of electrons there is a need of anode and cathode or cathode and target ending point for accelerated particles.
You don't have this structure inside the glass envelope.
e. the direction of electrons is perpendicular to the direction of acceleration now.
You didn't respond to the questions:
Wesley
Wesley here is a not so simple question and it's not what we are always told
How fast does an electron travel through a wire or should I say - a magnetically charged electron
or is it the other way round, what ever!
I ask this as if it traveled at a constant speed
then how could any thing possibly work ?
Regards Sil
Quote from: AlienGrey on October 24, 2021, 04:36:30 PM
An electron in the copper wire travels at a speed of about
1 cm/sec. This is about as fast as an ant scurries on the ground.
The speed of an electron in a wire really has virtually nothing to do with the speed of a signal.
https://www.informit.com/articles/article. (https://www.informit.com/articles/article.aspx?p=2916283&seqNum=4#:~:text=An%20electron%20travels%20at%20a%20speed%20of%20about,to%20do%20with%20the%20speed%20of%20a%20signal.)
Wesley
Nie kapuje poco mu drut w środku, przecież im większa gęstość zjonizowanych atomów gazu tym większa przewodność, a poza tym nie trzeba ani MHz, ani kW i niekoniecznie muszą być też impulsy HV żeby zjonizować gaz, np.: lampy wzbudzane indukcją magnetyczną https://cdn.fulham.com/PDFs/Fulham_HighHorseInduction.pdf .
To jakie jest minimum dla jonizacji gazu ? Najpierw następuje przebicie, a potem podtrzymanie. Przebicie to HV, a podtrzymanie już nie koniecznie. np.Lampy rtęciowe.
Niema konkretnej stałej na tak ogólne pytanie, gdyż to jest problem złożony obliczeniowo, np.: symulacja lampy bez-elektrodowej
https://www.comsol.com/model/electrodeless-lamp-10062
https://www.comsol.com/model/download/789421/models.plasma.electrodeless_lamp.pdf
Quote from: kolbacict on October 24, 2021, 07:57:40 AM
can you give me link to the article or book I can find on the net?
Wesley
Wesley,
Quote:
Quote"where are the potential difference points (like in normal accelerator anode cathode)?
Reply:In my proposal there is no need for anode and cathode, because central conductor is acting both.
Emitting electrons during HV pulse- free electrons outside conductor being accelerated by progressive magnetic field of traveling wave,
and they fall back to conductor, eventually kicking off more electrons. It might act like dynode electrons multiplication ,
an "extra" process for electrons drag inside conductor.
To be clear- all above proposals for HV "kicking" of central conductor are just my guess,
I didn't tested them in practice. It is just a thinking how we could improve process of electrons drag inside conductor by traveling wave,
by giving them an extra energy and possibly Dynode-like multiplication effect by accelerating them when they jumped outside conductor.
But let's put aside all my proposals and guessing.
Let's come back to original text of Thonemann patent, it is clearly mentioned :
Progressive magnetic field of traveling wave could be used to drive current in longitudinal conductor or semiconductor.Unfortunately,in his patent he presented examples to drive current in vacuum tubes with anode and cathode,
he didn't presented example with solid conductor.
I assume Thonemann didn't lie in his patent and it is true statement that current in solid conductor could be driven this way.Driving current in solid conductor by his invention- "PER SE" it is very interesting,
because we will not have Lenz action like in normal electromagnetic induction ( transformers, generators).
And effect ( current flowing in conductor) is ENHANCING the cause (progressive magnetic field of traveling wave).
Not acting AGAINST the cause. This is a beautiful effect itself which is worth exploration.Regards,
Pix
Unfortunately, I don't know where it came from.
Found in my folder with pictures.
I was interested in the three-dimensional picture at the bottom.
Does this mean that we can model four-dimensional and more things in our three-dimensional world?
If there are four or more branches in the nodes of the circuit?
And why are analog computers undeservedly forgotten in our digital age?
https://www.skif.biz/index.php?name=Forums&file=viewtopic&p=717705#717705 (https://www.skif.biz/index.php?name=Forums&file=viewtopic&p=717705#717705)
I've already seen it somewhere ... ;)
Z zimnej katody przez którą płynie prąd nie da się tak łatwo wyciągnąć elektronów (gładka powierzchnia, korozja jonowa), poza tym łatwiej z zimnej katody posiadającej ostre krawędzie, kolce, trzeba by wypychać elektrony napięciem ujemnym w stosunku do siatki(bramki) która jest masą, natomiast łatwiej jest wyciągać elektrony z gorącej katody. Ale jak przyśpieszysz elektrony polem magnetycznym czy elektrycznym szybkie elektrony padające na przewodnik będą ci wybijać elektrony przewodnika(cel) i wtedy będziesz emisję promieniowania jakiegoś nie koniecznie x-ray (zależy od prędkości elektronu) poza tym (gładka powierzchnia, korozja jonowa).
Poza tym ogólnie nie wiem jaki chcesz efekt końcowy tego wszystkiego uzyskać, gdyż bawić w projekty gdzie medium głównym jest plazma, cząstki, przyśpieszanie czego kolwiek, jest złożone obliczeniowo, dużo różnych procesów odbywających się jednocześnie i dużo różnych strat, a efekt końcowy słaby a nie kiedy niebezpieczny x-ray gamma itd....
Łukaszu,
To o czym piszesz to tylko szczegóły techniczne, zaś ważna jest zasada w jaki sposób urządzenie to może działać. Ja opisałem propozycję procesu który może dać interesujące efekty i jest prosty.
Oczywiście że najlepiej jak centralny przewód z którego jest katoda dla ułatwienia emisji elektronów z powierzchni może mieć ostre krawędzie, de facto może to być nawet przejechany papierem ściernym przewód miedziany.
Wybite elektrony impulsami HV przyspieszone postępującym polem magnetycznym opadając na powrót na przewód katody mogą spowodować efekt powielaczowy a dodatkowo rozgrzewając przewód termoemisję.
Wszystko w sumie:
1. Dryft elektronów w przewodniku spowodowany postępującym polem magnetycznym, jak to jest zastrzeżone w patencie- powodujący przepływ prądu i różnicę napięcia na końcach przewodu. Który wzmacnia przyczynę tego dryftu, czyli postępujące pole magnetyczne. Nie zachodzi efekt Lenza.
2. Efekt powielaczowy, jeśli zgodnie z moją propozycją spowodujemy wybicie i przyspieszenie elektronów poza katodą.
To wszystko może spowodować że otrzymamy bardzo ciekawe urządzenie w które w sposób niekonwencjonalny wygeneruje nam energię elektryczną. Czy COP takiego urządzenia będzie >1 tego nie wiem.
Warto by wypróbować.
Już sam fakt że w przewodniku możemy spowodować przepływ prądu w wyniku postępującego wzdłuż przewodnika pola magnetycznego , i jest to efekt samo wzmacniający się- jest fascynujący i obiecujący.
Pozdrawiam,
Pix
Question ,
Does anyone have information about "Peristaltic Tokamak"?
I can't find many information on internet, or it is behind pay web sites.
Cheers,
Pix
Widzę że bawimy się w analogie ?
Zamiast piasku dajmy ciężki blok znajdujący się na dnie dużego wąskiego zbiornika. Załóżmy ze opanowaliśmy metodę przypinania i odpinania do tego bloku pustego pływaka i przesuwanie bloku do dna zbiornika i poza szczyt zbiornika.Dopinamy pływak, blok wypływa parę setek kilometrów na szczyt zbiornika gdzie odpinamy pływak i przesuwamy blok tak aby opadając poza zbiornik wygenerował nam energię elektryczną (też musimy użyć do tego sprytnej metody i generatora prądu)W sumie co otrzymamy ? Zamianę energii potencjalnej na kinetyczną i dalej na elektryczną.
W sumie to cały myk w tym przyspieszaniu jest taki ,że my nie przyspieszamy naszych elektronów ale elektrony które są obecne w otoczeniu i wysoce energetyczne
Aby daną cząstkę przyśpieszyć to ta cząstka najpierw musi być podatna na źródło przyspieszania, najczęściej musi mieć ładunek dodatni lub ujemny. Żeby uzyskać cząstki podatne to trzeba jonizować atomy pierwiastków (najczęściej gazowych) energią jonizacji (kJ/mol) aby dane atomy mogły pozbyć się najczęściej elektronu, lub zastosować emiter elektronów. W otoczeniu niema wolnych elektronów wysoko energetycznych (bo byś nie przetrwał w takim środowisku). Elektrony występują wtedy gdy ustawisz nadajnik radiowy o danej częstotliwości i obciążysz go odbiornikiem nastawionym na tą samą częstotliwość, lub w bliskim obszarze iskrownika linii wysoko napięciowych, jak również chwilowo po uderzeniu pioruna, itd, ale to są elektrony swobodne "niskoenergetyczne".
IMHO - Ja to zauważyłem jedno na tym forum zbyt wszystko mocno upraszczacie co prowadzi do błędnych interpretacji danego zjawiska.
Czy ktokolwiek może podrzucić jakiś dokument o "Peristaltic Tokamak"?
Z góry dziękuję,
Pix
Można przyspieszać samym polem magnetycznym jak w betatronie. Jednak przyspieszanie takie pochłania więcej, dużo więcej energii niż energia przyspieszona.
Tylko proces wytracania/przemiany pierwiastka może dać "coś od siebie" z tym, że to wcale nie musi oznaczać dla nas zysku energii.
Jeśli podstawić dowolny pierwiastek pod dowolne urządzenie jak Hendershot, Kapanadze, Morey, Steven Mark, Colman, Sweetfloyd i podobne wyjdzie, że wszyscy oni robili to samo "może".
Jeden używał żelaza inny miedzi, a inny kobaltu lub ferrytu baru.
Nic takiego nie napisałem że się polem magnetycznym nie da przyspieszyć, oczywiście że się da tyle że polem magnetycznym zmiennym oraz cząstka musi być podatna na przyspieszenie, (pole magnetyczne stałe w betatronie, cyklotronie jest po to by zmusić cząstkę do poruszania się po okręgu).
A poza tym jest różnica między twórcami: Hendershot - baaardzo długi rezonans, Kapanadze - podbicie napięcia na rdzeniu, Moray - pierwiastek promieniotwórczy, Steven Mark - podbicie napięcia poprzez pojemność wzajemną i połowę indukcyjności wzajemnej, Colman - sztucznie indukowana promieniotwórczość, Sweetfloyd - podbicie napięcia poprzez sterowanie magnesem.
To dobrze że każdy uważa inaczej jak to działa, bo jak by wszyscy uważali tak samo to by nie było o czym gadać, ale to nie oznacza wcale źle czy dobrze.
To oznacza, że po latach szukania rezonansu czas sobie uświadomić, że sam rezonans to za mało i same cewki to tylko silnik bez paliwa. Można nim kręcić i to robimy. Umiemy już robić 2,4 cylindry, mały, duży, w zasadzie dowolny tylko nadal nie mamy paliwa. To zdaje się dobre porównanie mi wyszło.
Marnowanie czasu na powielanie np. Akuli czy Ruslana zdaje się być tylko inspiracją i nauką elektroniki. Jeśli ich urządzenia działają to muszą mieć źródło zasilania/paliwa. Jest to albo przesył, albo baterie, albo coś co jest paliwem, a że paliwo może być różne to i trudniej zlokalizować jakie to. No i oczywiście "kabelek pod stołem".
Łatwo się gada wiedząc to teraz. Czas mija i 90% ludzi nadal nawija cewki :'(
Bo teraz to straciłem wątek, ja jedynie wspomniałem o rezonansie przy "Hendershot" - jest o bardzo małej częstotliwości jakieś mikroherce, i jest gasnący.
A co do Akuli i Ruslana to nie budowałem (replikowałem) bo w sumie po co miałbym.
Teraz to ja nie wiem: czy Ty coś robiłeś czy tylko teoria ? Hendershot mieszkał jak sam pisał w zasadzie na lotnisku i tam prowadził eksperymenty. Łatwo próbować zrozumieć teraz co odkrył, a w zasadzie co zrobił, że urządzenie działało? Moja teoria jest prosta: jest lotnisko jest radar. Radary wtedy jak i moce były dość duże więc z relacji świadków którzy obsługiwali radary z czasów nawet komuny w PL usłyszymy że w odległości kilku metrów można było na patelni smażyć jajka i tak robili nawet. Jednak wtedy mamy paliwo i zawsze to będzie paliwo bo takie rozumowanie jest 100% tylko poprawne, a szukam darmochy jak i inni pewnie. Myślę że w przyszłym roku takie fora będą bardziej oblegane jak energia pójdzie do góry.
Mógłbym cię zapytać o to samo, w czy coś zrobiłeś.
Ale po to mam szeroką wiedzę i praktyczne doświadczenie w wielu dziedzinach żeby jej używać a nie bezmyślnie replikować wszystko bo może kiedyś coś wyjdzie, i cud się stanie jak dowiem się jak to działa.
Quote from: lukaszkwiatkowskii on October 27, 2021, 11:25:53 AM
Owszem zrobiłem ale to pytanie na pytanie i bronisz się w ten sposób... i te "...bezmyślnie replikować". Słabe.
Nie odniosłeś się do Hendershota a to by było merytoryczne tu, a tak to zawalamy wątek.
Odniosłem się do Hendershota jak pisałem o rezonansie, i to było bardzo merytoryczne, chcesz szukać przyczyny w radarach twoja sprawa, co do bezmyślnego replikowania czy to było słabe czy mocne bez różnicy, dla mnie prawdziwe, możesz się nie zgadzać masz do tego prawo, po to jest prowadzona dyskusja na forum aby każdy mógł przedstawiać swoje racje, teorie, praktyki, nie wszyscy ze wszystkimi muszą się zgadzać.
Układ symetryczny, jak widać na schemacie, dwa obwody pułapkowe LC nisko-częstotliwościowe (to te z dużymi elektrolitami), odpalasz cały obwód machając magnesem przy solenoidzie, to powoduje impuls rezonansowy który zgaśnie za kilka dni.
Problem w tym, że to nadal spekulacje i domniemania. To co piszesz jest od kilku lat co najmniej na tym i innych forach ale ok. to co napędza ten rezonans ?
Znam jedno zjawisko rezonansu "wiecznego" więc wiem, że jest to możliwe i powtarzalne 100% Doświadczenie jest dość proste i sprowadza się do uchwycenia rezonansu bez źródła zasilania. Jednak ja nie potrzebuje impulsu aby go zobaczyć i nie są to fale elektromagnetyczne, a zwykły magnes który działa jak kamerton. Niby nic ale to samo mówił Steven Mark. "...Chodzi o te nic"
To jak masz obwód LC z bardzo dużym kondensatorem to chyba wiadomo gdzie jest przechowywana energia, nawet jak zasilasz przez krótką chwilę, a poza tym analizowałem to kilkanaście lat temu, więc na forach wtedy nie wiele było. Podstawy obwodów elektrycznych, magnetycznych i ich symulacja, są tu potrzebne jak cholera, jest to podstawowa wiedza żeby czym kolwiek się zająć na poważnie oraz czytanie ze zrozumieniem.
Quote from: lukaszkwiatkowskii on October 28, 2021, 05:23:43 AM
No tak symulacje... wiesz ile razy miałem FE w symulatorze! potem robiłem kilka prób i zgadnij co wychodziło.
Ale symulacja to nie jest złoty środek (jak byle co zasymulujesz to byle co otrzymasz), musisz najpierw wiedzieć jak co zasymulować, czyli musisz znać podstawy, symulacja jedynie pomaga w weryfikacji twojej teoretycznej hipotezy.
W której symulacji jest uwzględnione zewnętrzne źródło energii ?
To tylko kwestia możliwości symulatora jakie komponenty do symulacji pozwala stworzyć.
Found nothing about "Peristaltic Tokamak". :(
I see that discussion drifted away.
1.Primary surprise, that current could be induced in the conductor by lenz-less way , self supporting action of progressive magnetic field of travelling wave get lost in discussion. Looks like reversed principle of TWT. I am not sure about efficiency of that process. But I am surprised that I hasn't been taken into consideration for use as power supply device.
2. My proposal to enhance that process indeed may give no advantages, thanks Wesley for your comments.
In every COP>1 candidate system there must be identified a source of "extra", that is gained in the process.
In a thermodynamic heat pump it is heat of ambient air. By the properties of refrigerant it absorbs that heat when changing state from liquid to gas and repells it later after converted back to liquid by compressor. In such a process initial electrical energy used by compressor and fan ( for example1kW) we receive 3-4kW of energy in the form of heat. COP>1 and we know why, from where we took that "extra" energy. I also picture thermodynamic heat pump as "converter" of large amount of less useable energy ( ambient air- let's say 10 m3 at 5 deg C) to more useable energy ( air at let's say 1m3 of 40 deg C).
The same process we can utilise in electrodynamics.
I think that primary candidate for COP>1 system is again old good Tesla magnifier.
I picture it as electromagnetic pile driver. Correct me if I am wrong.
By resonant rise of voltage on top terminal we are creating a huge "pump" for electrons from the ground. Huge potential difference atracts/repells more and more electrons from the ground. A very big "action" is going on, large current is alternating on the ground terminal, large voltage is oscillating on the top terminal. Tesla mentioned that the principle is to create very large reactive power oscillations, and convert part of this to active power.
By mechanical equivalent I see this as driven mechanical pendulum with a mass increasing a bit every push is made to pendulum. Oscillation period of such pendulum stays the same, but energy is increasing due to increased mass.
If we drive that system by some naturally occuring electromagnetic waves (PV, radio waves, man made or natural), we could made them useable by such action: accumulate low energy ,low V and I but high frequency waves to high V and I low frequency one and periodically discharge it to the load.
Similiar principle as typical heat pump, or mechanical resonant amplifier (see attached).
Your opinions gentelmens?
Pix
Bo to jest jakiś staroć z początków pierwszych projektów tokamaków ok. 1970r.
https://www.youtube.com/watch?v=nO1w7S5iIN4
Generate electricity by punching wood #VeritasiumContest
Wesley
https://www.youtube.com/watch?v=yY3VHfxVnJA (https://www.youtube.com/watch?v=yY3VHfxVnJA)
How to measure 3 phase AC on an Oscilloscope
Wesley
https://youtu.be/bl_wGRfbc3w?t=129 (https://www.youtube.com/watch?v=bl_wGRfbc3w)
Physicist Despairs over Vacuum Energy
this video doesn't start from the beginning where you can hear the quote:
QuoteVacuum energy is all around us.
so I suggest to watch it form the beginning.
It is not easily consumable but worth your time.
Wesley
Quote from: pix on October 29, 2021, 05:19:51 AM
There is material but you need to go to store and pay for milk or find a cow . It cost time or time and money.
https://www.semanticscholar.org/paper/The-peristaltic-Tokamak-Wort/ded1defaf8fe29a0c8f31376abd3de6cc443b9b1 (https://www.semanticscholar.org/paper/The-peristaltic-Tokamak-Wort/ded1defaf8fe29a0c8f31376abd3de6cc443b9b1)
I understand phenomena the same way physics does.
I can't repeat here everything that is written already just because you didn't find it.
Some articles require simple registration, but I can't quote them here.
QuoteA system for the generation of toroidal current in a plasma which is prepared in a toroidal magnetic field.
The system utilizes the injection of low-frequency waves into the plasma by means of phased antenna arrays or phased waveguide arrays
https://patents.google.com/patent/US4423001A/en (https://patents.google.com/patent/US4423001A/en)
COP>1 Incredibly beautiful girl 17-18 years old. You would do everything for her..
So her beauty is your gain.. the free energy of emotion..coming to you
But that only looks like is for free... you paying for her education, entertainment, fun, maintenance, .. her luxury...
before she switch to the new guy...who can afford her now as her energy needs grows.
COP>1 is not a gain but a "phase" in energy conversion..where sum of phenomena makes balance of gain and loss.
I didn't find anything exiting in it but you may become the new Tesla .. who knows?...
I wish you luck.
Wesley
stivep
QuoteCOP>1 is not a gain but a "phase" in energy conversion..where sum of phenomena makes balance of gain and loss.
You understand this much better than most and there is only one kind of energy which relates to the motion of something on some level.
The conservation of energy is the conservation of motion and something cannot act on nothing or vice versa. Therefore energy can only be transferred or transformed but never created or destroyed.
For example, if we transform H2O, O2 falls and H2 rises by volume relative to the density of air. The phase of matter has changed which also changed the energy balance relative to the medium the elements are immersed in. Tesla proposed this kind of transformation machine in his lecture on the need for increasing human energy.
AC
Like I said there is possibility to convert static potential into kinetic energy. Tesla ttalked about it in many analogies, also in his article about increasing human energy.
Quote from: forest on November 03, 2021, 06:28:18 PM
Of course.
Charge capacitor and discharge it through spark gap to certain inductance, forming resonant tank. This is Tesla Magnifier primary LC circuit.
Potential converted to oscillations.
Oscillations are "for free". Tesla was praising oscillations.
Next- accumulate those oscillations in next inductance, forming second resonant tank. Tesla magnifier secondary coil. Helical slow wave oscillator. Now we have large activity, large reactive power.
Discharge that accumulated energy periodically to the load.
Old Master Tesla :)
https://youtu.be/-KEwkWjADEA?t=147 (https://youtu.be/-KEwkWjADEA?t=147)
Video starts from minute 2:27.
Wesley
Quote from: ramset on November 05, 2021, 07:27:25 AM
non ferrous magnetism? copper.
result "obtained" during testing a kapanadze type device?
" magnetizing " copper is something which is in the "lore" or past FE
Claims ?
Do you have opinion on possible explanation?( for copper.. Or ?
Some opinion expressed:Unfortunate is that that the article in Popular Mechanics is not scientific .Just a story for average Joe Shmoe...
QuoteThe copper itself is not magnetic, but when its approached by magnets, the electrons on the surface of the copper being rotating.
In an effort to resist the magnet's pull, the electrons briefly create their own magnetic field, which slows down the magnet's descent
https://www.popularmechanics.com/science/a15902858/copper-strong-magnets/ (https://www.popularmechanics.com/science/a15902858/copper-strong-magnets/)
The mechanics of this interaction are explained by Faraday's Law of Induction (https://en.wikipedia.org/wiki/Faraday%27s_law_of_induction), and Lenz's Law (https://simple.wikipedia.org/wiki/Lenz%27s_law),
If you have a strong enough magnetic field all matter is magnetic.
But copper is so weakly magnetic that we can't observe it without very, very large magnetic fields.
So the short answer is "No, copper isn't magnetic."
This can quickly be tested by trying to pick up a penny with a magnet.
copperMagnetism and electricity are closely related.
When a magnet moves near copper (or other metals) it sets up electrical eddy currents.
The eddy currents will repel the magnet as it falls down the copper tube.
This repulsion pushes against the magnet and slows it down.
https://www.youtube.com/watch?v=5WIKKXdxNH8 (https://www.youtube.com/watch?v=5WIKKXdxNH8)
aluminumMost matter will exhibit some magnetic attraction when under high enough magnetic fields.
But under normal circumstances aluminum isn't visibly magnetic.
https://www.youtube.com/watch?v=yk4ACjzDFRY&t=1s (https://www.youtube.com/watch?v=yk4ACjzDFRY&t=1s)
leadEven though lead is not magnetic it can interact slightly with magnetic fields.
By moving a very strong magnet past a piece lead can actually cause the lead to move.
https://www.youtube.com/watch?v=VEIYXomRdLY (https://www.youtube.com/watch?v=VEIYXomRdLY)
NickelBecause Nickel (Ni) is ferromagnetic it is used in making Alnico magnets
(consisting of aluminium (http://en.wikipedia.org/wiki/Aluminium), nickel (http://en.wikipedia.org/wiki/Nickel), and cobalt (http://en.wikipedia.org/wiki/Cobalt)).
https://www.youtube.com/watch?v=kUvm4TFAWSQ (https://www.youtube.com/watch?v=kUvm4TFAWSQ)
SilverSilver isn't magnetic.
If silver isn't magnetic, how do metal detectors find it?
Metal detectors are able to find non-magnetic metals, like gold or silver, using a principle called the Lenz effect.
Moving the metal detector over a gold coin will set up a slight electric field in the coin.
The metal detector can sense this field and alert you to the coin.
https://www.youtube.com/watch?v=PQk95NcNa_s (https://www.youtube.com/watch?v=PQk95NcNa_s)
stainless steelSince it contains iron, a magnetic metal, it would seem that stainless steel would be magnetic.
However, when nickel (Ni) is added to stainless steel the result
is a non-magnetic form of stainless steel (called austenitic stainless steel).
https://www.youtube.com/watch?v=O9DaKP2PhL4 (https://www.youtube.com/watch?v=O9DaKP2PhL4)
Titanium Titanium-weakly magnetic.. also exhibits the Lenz Effect but to a lesser extent that many other metals.
For example, when a magnet is passed over a metal like silver, copper, aluminum, or brass,
the moving magnet causes small electrical eddy currents to form in the metal.
The electrical eddy currents have their own magnetic field which interacts with the moving magnet.
The result is that the moving magnet causes the metal to move without touching it.
With more sensitive equipment the Lenz Effect could be measured in titanium.
https://www.youtube.com/watch?v=1naZTyd361U (https://www.youtube.com/watch?v=1naZTyd361U)
Wesley
Thank you very much for information Dear naserturk
(https://overunity.com/profile/naserturk.104877/)EARTH ENERGIES, INC
John Dinwiddie
Main link:
https://uspto.report/company/Earth-Energies-Inc?__cf_chl_jschl_tk__=Hmu5ONeRP__Z5dD74dQPNYSh6ssiUy9LBxkh0E4QkME-1636147351-0-gaNycGzNBj0 (https://uspto.report/company/Earth-Energies-Inc?__cf_chl_jschl_tk__=Hmu5ONeRP__Z5dD74dQPNYSh6ssiUy9LBxkh0E4QkME-1636147351-0-gaNycGzNBj0)
Patent Date
Power receiver for extracting power from electric field energy in the earth (https://uspto.report/patent/grant/11,152,793)
Grant 11,152,793 - Dinwiddie , et al. October 19, 2 2021-10-19 Power Receiver Including Faraday Cage for Extracting Power from Electric Field Energy in the Earth (https://uspto.report/patent/app/20200295677)
App 20200295677 - Dinwiddie; John ; et al.2020-09-17 Power Receiver For Extracting Power From Electric Field Energy in the Earth (https://uspto.report/patent/app/20190348842)
App 20190348842 - Dinwiddie; John ; et al.2019-11-14 Power receiver for extracting power from electric field energy in the earth (https://uspto.report/patent/grant/10,389,138)
Grant 10,389,138 - Dinwiddie , et al. A 2019-08-20 Power Receiver For Extracting Power From Electric Field Energy In The Earth (https://uspto.report/patent/app/20170117714)
App 20170117714 - Dinwiddie; John ; et al. 2017-04-27 Power receiver for extracting power from electric field energy in the earth (https://uspto.report/patent/grant/9,564,268)
Grant 9,564,268 - Dinwiddie , et al. February 7, 2 2017-02-07 Power Receiver for Extracting Power from Electric Field Energy in the Earth (https://uspto.report/patent/app/20150102675)
App 20150102675 - Dinwiddie; John ; et al. 2015-04-16 Method and Apparatus for Extracting and Conveying Electrical Energy From the Earth's Ionosphere Cavity (https://uspto.report/patent/app/20150102676)
App 20150102676 - Dinwiddie; John ; et al.
Wesley
Some opinion expressed :
https://patents.google.com/patent/US9564268B2/en (https://patents.google.com/patent/US9564268B2/en)
I analyzed that patent few years ago.
interesting is to read it.
more comments will come later
Wesley
Hi everyone,
It's a been a long time since i posted anything in this forum.Distracted by Wuhan virus and purchased new home,being a landlord and many good etc.
Thanks to Wesley dedication into FE and many of his videos posted in youtube have allowed me to gain out of the box/world experience which is not your typical daily dose of medication. ;D
The 4 layers of primary winding on Kapanadze was reduced to 3 layers (Around 185uH) and increase capacitance(Maintain same L/C frequency as previous) after 3 turns both cases to resolve impedance issues and the trumpet waveform does have a sharper rising gradient as a result after phase shift tuning which consist of SOT23-6 74HC2G14 after LM393.Nothing much to add.
All this inspired from Wesley video https://www.youtube.com/watch?v=PPHipGkfSAY (https://www.youtube.com/watch?v=PPHipGkfSAY)
But no amount of FE is going to solve the climate issue,oxygen depletion as the human and other supporting livestock population grows.
Just do search "earth oxygen level" in google it will reveal 21% and we humans needs 19.5% oxygen level in air.So we are not very far away. :)
Hi Wesley,
Thanks for providing links and info. :)
I didn't have a time today to carefully study patent, but from the first look it seems Tesla-like addjusted to Schumann resonance frequency.
Mechanism that I did described a few posts before.
Creating a lot of reactive power on secondary by resonant voltage rise of top terminal- this will "pump" electrons from ground connection, more and more.
An "open" circuit acummulating energy from enviroment.
Pix
Hi magpwr,
"Grenade" coil in Kapanadze, Akula and others- I thing the purpose is to slow down electromagnetic wave propagation. It is slow wave helical transmission line, coil wound in a curious way. This is to physically reduce the size of the coil to acommodate wave of lower frequency.
Tesla secondary and "extra" coils are exactly slow wave structures, to accomodate quarter wave in kHZ area, to minimize radiation of electromagnetic energy. The aim is to efficiently accumulate energy from primary LC circuit, with minimal radiation into space.
Very interesting subject to explore. I still don't understand the way "grenade" coil works and why that way of coiling.
Kind Regards,
Pix
Quote from: pix on November 06, 2021, 12:07:37 PM
Hi magpwr,
"Grenade" coil in Kapanadze, Akula and others- I think the purpose is to slow down electromagnetic wave propagation.
This is to physically reduce the size of the coil to accommodate wave of lower frequency.
Tesla secondary and "extra" coils are exactly slow wave structures, to accommodate quarter wave in kHZ
Kind Regards,
Pix
https://www.commutefaster.com/ATechnicalAnalysisofTeslasExtraCoilasaSlow-WaveHelicalResonator.pdf (https://www.commutefaster.com/ATechnicalAnalysisofTeslasExtraCoilasaSlow-WaveHelicalResonator.pdf)
A Technical Analysis of the Extra Coil as a
Slow Wave Helical Resonator James F. Corum, Ph.D.
Department of Electrical Engineering
West Virginia University
P0 Box 6101
Morgantown, West Virginia 26505-6101 Kenneth L. Corum
CPG Communications, Inc.
158 Salem Street
Wilmington, Massachusetts 01887They are the guys responsible for
Viziv and
Milford Texas Tesla TowerWesley
Hi folks,
It some thought experiment.
Imagine that at the same time from the same source we feed step up signal to straight conductor and slow wave structure ( for example loaded transmission line).
If we connect osciloscope at the ends we should see an impulse, due to electromagnetic wave ( potential) propagation time difference.
Am I right?
Pix
Quote from: pix on November 06, 2021, 04:02:50 PM
If we connect oscilloscope at the ends we should see an impulse, due to electromagnetic wave ( potential) propagation time difference.
Am I right?
simplified but not always correct answer:You will see the same signal coming with delay as slow wave comes later,
that may be seen as
phase delay.
For easier understanding here is an example.First path:
Think that straight line from New York to to Warsaw ( or from bottom of Tesla coil to its top) is =x in meters.
Second path:
you created additional path.
It is a coil with diameter 1mm wire
winded tight on the tube of diameter 1 meter
and long from New York to to Warsaw ( or from bottom of Tesla coil to its top)=x multiplied by n times of x in meters.
conclusion:
-signal on that coil will travel many times longer till it reaches its destination. But you may also want :
-this coil to resonate....
-convert an input voltage pulse into radiation
-have impedance match to desired 50 Ohm.____________________________________________________________________and here will be difficult.
Green's function is the solution to the differential equation with a forcing term given by a point source.
point source was explained here :
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560319/#msg560319
(https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560319/#msg560319)green function is explained here :
https://brilliant.org/wiki/greens-functions-in-physics/ (https://brilliant.org/wiki/greens-functions-in-physics/)
https://en.wikipedia.org/wiki/Green's_function (https://en.wikipedia.org/wiki/Green's_function)I created there accent on line source in my (Dr. Corum) energy transfer we are interested in line source not point source but we still need slow wave .
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560720/#msg560720so
(https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560720/#msg560720so)
And now you are ready to read this article that brings you closer to
Travelling wave tube :
https://www.egr.msu.edu/~pz/sws2012.pdf (https://www.egr.msu.edu/~pz/sws2012.pdfWesley)
Travelling wave tube was discussed here : https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561071/#msg561071 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561071/#msg561071)
however we don't need any longer traveling wave tube we can do it with semiconductors now.
Wesley
note:
the article from below applies to slow wave in plasmas and is not directly related to our case.
article is given here just for the purpose of bringing some understanding of slow wave.
The common and important is 2D wave !!! marked in the article with light green color.
the same 2D wave we use in my energy transfer and energy extraction from Schumann waveguide in TM mode
TM mode - means Transverse Magnetic mode
explained here:
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560165/#msg560165
(https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560165/#msg560165)note: word
Travelling wave tube is sometime wrote
as Traveling wave tube with one L.
Some videos explaining traveling wave tube.
Please disregard fact that it explains different tubes mostly in frequency region of very high frequencies.
This is an addition to the post from above.
Travelling Wave Tube Amplifier https://www.youtube.com/watch?v=I-DlgOoz978 (https://www.youtube.com/watch?v=I-DlgOoz978)
Travelling Wave Tube Amplifier https://youtu.be/lL3LqFTW5ms?t=99 (https://youtu.be/lL3LqFTW5ms?t=99)Teardown of a Microwave Amplifier and a Traveling Wave Tube https://www.youtube.com/watch?v=0HGdQ0C7CYg
(https://youtu.be/lL3LqFTW5ms?t=99)Traveling Wave Tube Amplifier Teardown https://www.youtube.com/watch?v=RyO0Laz6aLA (https://www.youtube.com/watch?v=RyO0Laz6aLA)
Teardown of a LogiMetrics A300/S Traveling Wave Tube Amplifier https://www.youtube.com/watch?v=mhUGVfqy3Ic (https://www.youtube.com/watch?v=mhUGVfqy3Ic)
LogiMetrics A300/S 2 - 4 GHz Traveling Wave Tube Amplifier - Repaired https://www.youtube.com/watch?v=TfxJitmqOEk (https://www.youtube.com/watch?v=TfxJitmqOEk)
here is modern reincarnation of Traveling wave tube form :
https://www.youtube.com/watch?v=A-Fcf8TmnEQ (https://www.youtube.com/watch?v=A-Fcf8TmnEQ)
it is good to understand how it works but we are using very low frequencies in our study leading to energy transfer and energy extraction.
Standing Waves: how are they different from travelling waves? | A Level Physics
https://www.youtube.com/watch?v=JUFpDFDQn0E (https://www.youtube.com/watch?v=JUFpDFDQn0E)
note: word Travelling wave tubeis sometime wrote as Traveling wave tube with one letter L.
Wesley
another application for slowed down traveling wave:
the particle accelerator.
2.4 Linacs: traveling wave
https://www.youtube.com/watch?v=8XYHO3bQkPI
(https://www.youtube.com/watch?v=8XYHO3bQkPI)well...well... it is Russian translated into English..
I like this one:
it is great (not Russian)
Linear Particle Accelerator (Principle, Construction, Working)
https://www.youtube.com/watch?v=C79838wtRZo (https://www.youtube.com/watch?v=C79838wtRZo)
The two links at the end of that video will advance you to circular/spiral accelerator Cyclotron and Synchrotron
A synchrotron is made of a torus shaped tube, whereas the cyclotron is made of a cylindrical or spherical chamber.
A cyclotron can fit in a room. A synchrotron is often the size of a football field
https://www.youtube.com/watch?v=L5zhpLfnqGc (https://www.youtube.com/watch?v=L5zhpLfnqGc)
https://www.youtube.com/watch?v=Q9bijrQfS6E (https://www.youtube.com/watch?v=Q9bijrQfS6E)
https://www.differencebetween.com/difference-between-cyclotron-and-vs-synchrotron/ (https://www.differencebetween.com/difference-between-cyclotron-and-vs-synchrotron/)
Wesley
https://uspto.report/patent/app/20200295677 (https://uspto.report/patent/app/20200295677)
power receiver for extracting power from electric field energy in the earth
The power receiver 10 converts energy in the ELF/ULF waves to useful form, e.g. 60 Hz AC or DC.
The power receiver 10 is essentially a resonance circuit that resonates at the natural resonance frequencies in the earth's electric field.
These resonance frequencies, known as Schumann resonance frequencies, occur at 7.83 Hz, 14.3 Hz, 20.8 Hz, 27.3 Hz, and 33.8 Hz.
A high voltage impulse initiates resonance within the power receiver 10. In the resonant mode, the impedance of the power receiver 10
is reduced to near zero thus inducing ground currents to flow into the power receiver 10 where the ground currents are converted to useful form.
Wesley
Hi Wesley,
I don't see in Earth Energies Inc. patents how they propose to make resonant transformer in range 0.1-200Hz.
They state to make it resonant in fundamental Schumann resonances 7.83Hz, 14.3 Hz ect. but it might be physically very large.
Big Tesla coils operate in kHZ ranges, and secondaries are at least few feet tall.
So, the challenge is to construct a coil resonating in very low frequencies. To do it, we need to use "slow wave structure", we need to slow propagation of electromagnetic wave like Tesla secondary or maybe in other, more clever way.
Kapanadze, Akula "grenade" coils might be some sort of solution to slow wave propagation. I don't understand the way they are coiled and a reason behind this shape of "grenade".
Principle of operation of Tesla-like systems, like above mentioned patents from Earth Energies Inc. is clear, the point is to find a way how we construct resonant winding for frequencies close to Schumann resonances, and have reasonable sizes.
Pix
Quote from: pix on November 07, 2021, 09:51:12 AM
Hi Wesley,
QuoteAn electrically small, efficient electromagnetic structure, that may be used as an antenna or waveguide probe,
having an electromagnetically closed, velocity-inhibiting conducting path, for supporting a standing, inhibited-velocity
wave in response to the flow of an electrical current through the path and a process for establishing the standing wave.
https://patents.google.com/patent/US4751515A/en (https://patents.google.com/patent/US4751515A/en)
https://patentimages.storage.googleapis.com/9d/2b/2a/fa977b9aae1691/US4751515.pdf (https://patentimages.storage.googleapis.com/9d/2b/2a/fa977b9aae1691/US4751515.pdf)
first step is to understand .. not the patent but mechanism of making coil small at VLF.
and
only than you can think about slow wave.
Tariel didn't understand anything.. but .. how many people wins in lotto?
Wesley
PS: Dr Corum from Viziv
application year 1986
Utilizing the Dr James Corum understanding of phenomena in question:
QuoteSuch coil that normally at Schumann resonance frequencies would be physically large,
it would still be electrically small and therefore realizable, as well as efficient.
Because propagation losses are so low at the primary Schumann resonance frequency
(below 0.25 dB per Mm according to published data),
-signals at that frequency may be transmitted to any point on the earth without significant attenuation.
Wesley
in practice we are not expecting to build LC circuit resonating in Schumann frequency resonance in our VLF coil.
We would like to.. but we can't..
..that is why Dr Corum works at 18kHz or any lower possible frequency representing harmonic of Schumman F.
the fancy Tariel Kapanadze coil was set of winds CW and CCW
making coil electrically suitable but physically small.
well.. we may have question that this coil was not vertically polarized.
that is yet another story to talk about it.
Wesley
Hi magpwr,
Kind Regards,
Pix
hi pix,
I am not sure how to to answer any of your queries.But all this while i was dabbling with harmonics 3,6,9.
I am not even sure if i am correct to say this
if we see a rising amplitude waveform can we safety say "
Q" Quality factor is more than 1".
So what does Q factor more than 1 represent if we did involve the "strange winding" in in this scenario.
Loss or no loss,less obvious loss.Or should we even involve
Q factor in this case under
HV 3rd harmonics manipulation with resistive load(Mains Bulb) and observed no further increase of input current even with short circuit test across bulb?
1000watt halogen bulb load would be next once i have the time.
Understanding Q:
-quality factor,The Q factor determines the qualitative behavior of simple damped oscillators
When (Q < 1⁄2) is said to be overdamped. Such a system doesn't oscillate at all
QuoteThe condition of Q = 1,
when the power being released by the fusion reactions is equal to the required heating power,
is referred to as breakeven, or in some sources, scientific breakeven.
https://en.wikipedia.org/wiki/Q_factor (https://en.wikipedia.org/wiki/Q_factor)
https://en.wikipedia.org/wiki/Fusion_energy_gain_factor
(https://en.wikipedia.org/wiki/Fusion_energy_gain_factor#:~:text=The%20condition%20of%20Q%20%3D%201%2C%20when%20the,be%20captured%20within%20the%20fuel%2C%20leading%20to%20self-heating.)https://eepower.com/capacitor-guide/fundamentals/q-factor/ (https://eepower.com/capacitor-guide/fundamentals/q-factor/)Wesley
Some News:
History of evolution of cars
First we were driving:
a. combustion engine cars
b. hybrid electric combustion engine cars.
c. electric cars
d. combustion engine fueled by natural gas cars
e. combustion engine fueled by hydrogen cars
f. Molecular Sieve for Hydrogen converting its energy to electric .. cars.
and that looks like future of the cars. 1170km from 5kg of Hydrogen.
1. Today the owner of amazon started his series of electric carsstack is set for $69.
Earlier this year, Amazon invested $700 million in Michigan's electric car startup Rivian,
but now the company has built on that with an order for 100,000 vans to hit the roads by 2024,
https://time.com/6116280/rivian-ipo/ (https://time.com/6116280/rivian-ipo/)
https://jalopnik.com/amazon-orders-100-000-vans-from-electric-startup-rivian-1838250731 (https://jalopnik.com/amazon-orders-100-000-vans-from-electric-startup-rivian-1838250731)
the future :
2. Hydrogen cars .Toyota Mriai
https://www.youtube.com/watch?v=lgIj2XTSBuQ
(https://www.youtube.com/watch?v=lgIj2XTSBuQ)some of opposite view point I disagree with.
But what can you expect from making money YouTube'r
https://www.youtube.com/watch?v=b88v-WvqzeQ (https://www.youtube.com/watch?v=b88v-WvqzeQ)
https://www.youtube.com/watch?v=_MsG9REFN3s (https://www.youtube.com/watch?v=_MsG9REFN3s)
https://afdc.energy.gov/vehicles/fuel_cell.html (https://afdc.energy.gov/vehicles/fuel_cell.html)
-north-american-hydrogen-fuel-cell-electric-hybrid-truck/#: (https://hydrogen-central.com/capacity-trucks-north-american-hydrogen-fuel-cell-electric-hybrid-truck/#:~:text=This%20hydrogen%20fuel%20cell%20hybrid%20electric%20terminal%20truck,first%20battery%20electric%20vehicle%20over%2010%20years%20ago.)
1kg of hydrogen= 1 gallon of gasoline
but it gives 1370km from 5kg of Hydrogen.
3. something to dream about:
Mercedes AVTR
https://www.youtube.com/watch?v=ChqM3zqTREQ (https://www.youtube.com/watch?v=ChqM3zqTREQ)
https://www.youtube.com/watch?v=ekgUjyWe1Yc
(https://www.youtube.com/watch?v=ekgUjyWe1Yc)
no brakes
no gas pedal
no steering wheel
no mirrors
but Tesla did the same too.
https://hypebae.com/2021/9/tesla-electric-autonomous-car-no-steering-wheel-pedals-self-driving-vehicle-elon-musk-2023-rumor-price-info (https://hypebae.com/2021/9/tesla-electric-autonomous-car-no-steering-wheel-pedals-self-driving-vehicle-elon-musk-2023-rumor-price-info)
second picture shows Tesla SUV
https://www.thisiswhyimbroke.com/tesla-electric-pickup/
(https://www.thisiswhyimbroke.com/tesla-electric-pickup/)https://www.highsnobiety.com/p/tesla-pickup-truck-model-p/ (https://www.highsnobiety.com/p/tesla-pickup-truck-model-p/)
Wesley
Ani wytwarzanie wodoru, ani zbudowanie ogniwa paliwowego z całą elektroniką nie jest problemem, tylko największym problemem przechowywanie wodoru,
z uwagi że wodór ma najmniejszą cząsteczkę z pośród wszystkich gazów to nie może być przechowywany w zwykłym zbiorniku, czyli musi posiadać tzw. "gąbkę wodorową"
aby można było pod dużym ciśnieniem utrzymać wodór w zbiorniku, jak również cała instalacja transportu wodoru do zbiornika musi być odpowiednio wykonana.
Wszystkie te technologie które mogły by być lepsze od ropy naftowej są negowane przez media które są opłacane przez magnatów ropy naftowej.
Reply #3488 :
Hydrogen fuel cell distance world-record :
https://fuelcellsworks.com/news/shell-eco-marathon-team-from-stralsund-wins-with-hydrogen-propulsion-and-reach-record/ (https://fuelcellsworks.com/news/shell-eco-marathon-team-from-stralsund-wins-with-hydrogen-propulsion-and-reach-record/)
2735 Km/lt. aequivalent hydrogen
https://www-adac-de.translate.goog/rund-ums-fahrzeug/autokatalog/marken-modelle/mercedes-benz/mercedes-glc-fuel-cell/?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui (https://www-adac-de.translate.goog/rund-ums-fahrzeug/autokatalog/marken-modelle/mercedes-benz/mercedes-glc-fuel-cell/?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui)
for city-car (metropoles 30 Km/h speed max. )experimental comparison :
https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster (https://en.wikipedia.org/wiki/Mercedes-Benz_F-Cell_Roadster) 350 Kg 1,2 KW/ ? Volt electric drive ,-25 Km/h max
versus
http://www.evalbum.com/314 (http://www.evalbum.com/314)
100 Kg 1,5 KW/12 V electric drive , - 40 Km/h max.
with 1,5 KW/220 V ? Km/h max. ?
Citroen Ami/ Opel Rocks level ?
https://www.youtube.com/watch?v=1R1AE955w4Q (https://www.youtube.com/watch?v=1R1AE955w4Q) - 45 Km/h max.
Hydrogen selling price/ hydrogen ultra-low production costs : https://judbarovski.livejournal.com/117497.html (https://judbarovski.livejournal.com/117497.html)
Kyoto/Paris conference results :
-80% GH-gas decrease and max 1,5°C GH-temperature increase
ambiental =Green House temperature global : +- 15,5° C average
each drive process with over ambiental " 15,5°C average + 1,5°C or K " increase is Paris-negative !
Hydrogen,ammonia,bio-fuels.synfuels,fossil fuels use : all the same global temperature increase effect, locally (heat bell) and globally !
" - the cost of hydrogen is 5.65 x $16.54= $31.9 " ,
a very "specific" ::) arithmetical result !
Mostly a common calculator ,well calibrated,gives :
5.65 x $16.54 = $93.45
Sincere
OCWL
Hydrogen is best stored as water. And cheaper. We have H2Opower on the forum who owns Steven Meyer's technology. And I tried everything, but I can't. But he doesn't speak.
Hydrogen !!?
We had very smart fellow at forum share a method for hydrogen heating.
The claim is MUCH more heat recovered through recombination and interactions with precious
Metals (found in automotive catalytic converters ) mixed with sand plus utilization of diesel fuel
Additive ( blue DEF anti sulfur additive used in trucks for emissions (has high Nitrogen content
4times as many "H" ?
I would like to try this here ?
Others have claimed 10 times more heat than energy used to electrolyze?
Respectfully
Chet
Edit for comment below
Yes I will lookup info posted at this forum tonight
And will add here to this post, and also invite ACCA to discussion!
For clarity , it is my intention to replicate this here ( however I want best possible results
So will seek guidance from ACCA for finer details .
Yes please ask this gentleman to join the conversation
Wesley
Nie "molecular sieve" tylko "fuel cell" - ogniwo paliwowe.
Co do Toyoty Mirai to posiada zbiorniki wysokociśnieniowe (700 bar), i ogniwo paliwowe.
https://www.toyota-europe.com/download/cms/euen/Toyota%20Mirai%20FCV_Posters_LR_tcm-11-564265.pdf .
Obecna cena gazu do samochodu za 1/km to ok 0,36gr przeliczając na H2 za kilometr to ok. 0,40gr.
To są realia na obecną chwilę. Koszt instalacji gazu powiedzmy 4.000 pln i tankujesz wszędzie. Gdzie tu sens dla H2 gdzie cena nowego auta Toyoty to 300.000 pln a to pewnie porównywalne
do auta za 150.000 pln + 4.000 gaz !
H2 nadal trzeba produkować, transportować itp.
Zabawki dla bogatych jak na razie. Akumulatory co roku mają coraz lepsze właściwości, a jeśli uświadomimy sobie, że jedna z pierwszych stacji w kosmosie posiadała już wtedy baterie li-ion to co teraz mają do dyspozycji ? Z czego zasilany jest laser 300kW który do pracy potrzebuje więcej niż moc lasera ?
https://www.ga.com/ga-ems-and-boeing-team-to-develop-300kw-class-helws-prototype-for-us-army
Quote from: lukaszkwiatkowskii on November 11, 2021, 12:39:27 PM
translation:
Not the molecular sieve but fuel cell.
I disagree with you.Time is running forward. Think in category of year 2022.
mylisz sie.
The material made from manganese hydride would be used to make molecular sieves within fuel tanks
which store the hydrogen and function alongside fuel cells in a hydrogen-powered system.
molecular-sieve-for-hydrogen-tanks-increases-storage-capacity-up-to-4x/
(https://eepower.com/news/molecular-sieve-for-hydrogen-tanks-increases-storage-capacity-up-to-4x/#:~:text=The%20material%20made%20from%20manganese%20hydride%20would%20be,function%20alongside%20fuel%20cells%20in%20a%20hydrogen-powered%20system.)https://eepower.com/news/molecular-sieve-for-hydrogen-tanks-increases-storage-capacity-up-to-4x/ (https://eepower.com/news/molecular-sieve-for-hydrogen-tanks-increases-storage-capacity-up-to-4x/)
QuoteThe new material would be used to make molecular sieves within fuel tanks – which store the hydrogen and work
alongside fuel cells in a hydrogen powered 'system'. The material, called KMH-1 (Kubas Manganese Hydride-1),
would enable the design of tanks that are far smaller, cheaper,
more convenient and energy dense than existing hydrogen fuel technologies,
https://fuelcellsworks.com/news/researchers-discover-new-material-that-could-unlock-the-potential-for-hydrogen-powered-vehicle-revolution/
(https://www.bing.com/aclk?ld=e87WFUkCLs-jWxz1WmTr97pDVUCUwzg6JzoqIcJsk79Zf6m4fBLseq4IaUJMEYW01554kcB5kixXPTt9CakTpekSvgGQC-o_RLruS-NZLpW-iyMpp9M2S8Fq4gdWwi4u0lqMM7gq2xt0kqKdDcSBfHIgz6q2uWR2KjePa98S2vHHQwPPkY_XkANT1ILT4Oh_5E6iQu3A&u=aHR0cHMlM2ElMmYlMmZoeWRyb2dlbjRoZWFsdGguY29tJTJmaDItbmFuby1oeWRyb2dlbi13YXRlci1ib3R0bGUlMmYlM2ZyZWYlM2R0aGY&rlid=570c57944eb41e37c3873619f5a6ad05&ntb=1)for comparison I'm giving you everything about
fuel cell.
https://www.youtube.com/watch?v=Uz2hV38PQSA (https://www.youtube.com/watch?v=Uz2hV38PQSA)
How to make a hydrogen fuel cell power generator
https://www.youtube.com/watch?v=4V5UO2BYAaY (https://www.youtube.com/watch?v=4V5UO2BYAaY)
https://www.youtube.com/watch?v=sf9U5rySRks (https://www.youtube.com/watch?v=sf9U5rySRks) Russian but is in English .
first in the world Zero emission guitar .
https://youtu.be/4V5UO2BYAaY?t=936 (https://youtu.be/4V5UO2BYAaY?t=936)
Wesley
Napisałeś wcześniej:
"f. Molecular Sieve for Hydrogen converting its energy to electric .. cars.
and that looks like future of the cars. 1170km from 5kg of Hydrogen."
a artykuł dotyczy czego innego, czyli "Molecular Sieve" nie konwertuje energii, tylko przechowuje wodór w zbiorniku tzn. jak wcześniej pisałem o zbiornikach posiadających tzw. "gąbkę wodorową" - wielowarstwowe powłoki strukturalne wodorków metali (metal hydrides).
Mniej więcej wiem o co chodzi, a mianowicie o materiał najczęściej z pvdf połączony z wielowarstwową gąbką wodorową NiTi+MgNiHx, którą można przechowywać w temp. pokojowej oraz ciśnieniu atmosferycznym
the Mirai shows us good performance !
When we divide a conventional compact class car its 6 lt. gasoline consume per 100 Km range we get 60 000 Wh/100 Km = 600 Wh/Km
https://www.tesla.com/customer-stories/world-record-father-son-drive (https://www.tesla.com/customer-stories/world-record-father-son-drive)
85 000 Wh battery capacity/681,6 Km = +- 125 Wh/Km ( by average -25 mph velocity ! )
Mirais 5.65 Kg hydrogen x 33.33 KWh/Kg (700 bar ! compressed) https://www.idealhy.eu/index.php?page=lh2_outline (https://www.idealhy.eu/index.php?page=lh2_outline)
/ 1360 Km range = 139 Wh/Km ,without given average teste drive velocity !
From Poland/Canada we know a possible lower cost alternative by same/similar Mirai Fuelcell performance :
http://www.rexresearch.com/holubowicz/holubowicz.htm (http://www.rexresearch.com/holubowicz/holubowicz.htm)
I've found one way to utilize that heat, and so propose a high efficiency engine that converts this engine heat into extra work. The conversion quadruples efficiency -- thus fuel consumption and GHG emission are cut by 80%. In addition the NOx emission is eliminated.
the above conventional compact class car 600 Wh/Km cutting by 80 % = 120 Wh/Km !
the compact class car to hybrid conversion :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19950330&CC=DE&NR=4332378A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19950330&CC=DE&NR=4332378A1&KC=A1#)
from 6 lt/100 Km to hybrid 3 lt./100 Km conversion
and by gun engine this cutted 80% = 0,6 Lt/100 Km or 60 Wh/Km !?
and this 60 Wh/Km by " gun engine ..... plus water 8:1 fuel mix "
= 52,5 Wh water and 7,5 Wh fuel consume per Kilometer ?! water as hydrogen storage and deliverer
Is the hybrid engine coupled generator not improveable in its efficiency ? 8) Kumar,Tudor-Frunzi,Kango Iida,Akio Hara,P. Arestov double coil winding,Yurth generator coil coating , ......
Energy Storage Breakthrough - Solid Hydrogen Explained
https://www.youtube.com/watch?v=U7CCq4oBgw4 (https://www.youtube.com/watch?v=U7CCq4oBgw4)
Wesley
Quote from: stivep on November 12, 2021, 07:54:56 AM
Inventor filed patent application and order of secrecy was imposed for ~ 10 years.
The technology was too good..
You are nobody special.. just the first one... so what?
Inventor wasn't allowed to talk about it , write about it , show it ..... it was forbidden to the public..
But he had priority rights to the patent if... if..... if.....
And now many years later you can hear about it:
I read some of the opinions expressed under the video : Gustav Derkits 2 days ago
QuoteThis presentation is so full of basic errors that it made me angry enough to unsubscribe.
Absorption (as is Pd:H) is distinct from hydride formation (as in TiH2).
QuoteHydrogen atoms are NOT positively charged.
Any material that contains sufficient QuoteHydrogen to function as an energy source by easily releasing H2 is by nature flammable.
Fire, once started, will release the hydrogen in the remaining material.
In this system hydrogen is stored in a very thin layer on the surface of a disk inside a machine.
QuoteYou never discussed how much the system weighs per gram of hydrogen stored and never derived the volumetric or density
energy efficiency. You said the machine extracts hydrogen "from air", an oxidizing medium, with close to zero free H2, then changed
to " smokestacks", a reducing medium, which still has very low H2 content, without thinking through whether either of these scenarios
are reasonable in a commercial setting. I've only touched a few of the many bloopers.
Send this presentation to a real chemist, if you know any, and ask for an honest critique.
The background story of this system is sketchy, with its "DOD stopped us" scenario.
The chemistry and physics are very funny. The manufacturing analysis indicates a high degree of complexity.
The engineering functional analysis shows a large amount of semi-functional dead weight, including the mass of the disk and container.
Your presentation naively accepts a lot of claims at face value. It is not an analysis.
My opinion:I have problem with
Gustav Derkits in his critique didn't mention that
Ions are always positive or negative.
Here is supporting link and quote:
QuoteIons result from atoms or molecules that have gained or lost one or more valence electrons, giving
them a positive or negative charge.
Those with a negative charge are called anions and those with a positive charge are called cations.
It has more protons than electrons, resulting in the positive charge.
why-does-an-anion-have-a-negative-charge (https://mindrightdetroit.com/faq/readers-ask-why-does-an-anion-have-a-negative-charge.html#:~:text=Ions%20result%20from%20atoms%20or%20molecules%20that%20have,protons%20than%20electrons%2C%20resulting%20in%20the%20positive%20charge.)
Solid hydrogen by wikipedia: https://en.wikipedia.org/wiki/Solid_hydrogen (https://en.wikipedia.org/wiki/Solid_hydrogen) differs in description from that explained in the video
that is talking about
Molecular solid hydrogen - in very clever form of
"sponge."QuoteH2 is by nature flammable.
Yes it will but it is up to inventor to deal with it and investor to take risk.
QuoteYou never discussed // system weighs per gram of hydrogen stored // volumetric or density//
energy efficiency.
I agree but blogger sales its content for money from YouTube and is unlikely able to address this question.
Quotewell-known hydrogen sulfide removal process is based on the reaction of hydrogen sulfide with iron oxide
https://www.sciencedirect.com/topics/engineering/iron-sponge-process
https://patents.google.com/patent/KR20150117768A/en (https://patents.google.com/patent/KR20150117768A/en)
https://patents.justia.com/patent/10847809 (https://patents.justia.com/patent/10847809)
Explanation provided by Video blogger in form of article is here:
https://undecidedmf.com/episodes/forget-solid-state-batteries-solid-hydrogen-explained (https://undecidedmf.com/episodes/forget-solid-state-batteries-solid-hydrogen-explained)
Here is site of Plasma Kinetics the patent holder .
https://plasmakinetics.com/
(https://plasmakinetics.com/#:~:text=Plasma%20Kinetics%20hydrogen%20storage%20is%20a%20reversible%20solid-state,photosynthesis.%20The%20central%20atom%20of%20chlorphyll%20is%20magnesium.)they make :
light-activated hydrides. plasma-kinetics-light-activated-hydrides.
(https://www.nextbigfuture.com/2021/04/plasma-kinetics-light-activated-hydrides.html#:~:text=Plasma%20Kinetics%20patent%20portfolio%20includes%20five%20U.S.%20patents,the%20U.S.%20Department%20of%20Energy%20in%20July%202009.)that was/is? partially restricted By DoD, DoE.
https://pubmed.ncbi.nlm.nih.gov/31950606/ (https://pubmed.ncbi.nlm.nih.gov/31950606/)
Statement of video creator:
Plasma Kinetics boasts its technology to be
17% less expensive and 30% lighter than Lithium-ion batteries for the same amount of energy stored.
Wesley
Podstawy chemii się kłaniają, czyli nie tylko występują wiązania jonowe ale też inne, najczęściej polarne np.: dwa atomy nie jonowe mogą być połączone wiązaniem polarnym.
Jeśli chodzi o samochody na wodę to wg mnie jest tu dużo nieporozumień wokół metody. Uważam że wykorzystywana jest tu energia z zewnątrz (ambient energy) do rozłożenia wody na wodór i tlen ewentualnie na natychmiastową konwersję wody w gaz tzw HHO (izomer H20 o stanie gazowym, nietrwały i wybuchowy ) - jako że gaz ma dużo większą objętość to tłumaczyłoby dużą efektywność takiego paliwa.
https://www.youtube.com/watch?v=tZ0kjilQd1s
https://www.youtube.com/watch?v=r5Fc8q5TMas
Jak widać mamy technologię aby ocalić świat od zmian klimatu ale z niej nie korzystamy :-(
Dziekuje za komentarze.
Here is much better explanation of how Hydrogen on tape like in old tape recorder works.
This Breakthrough Could Lead to the Rise of Hydrogen Fuel!
https://www.youtube.com/watch?v=yIe4GulRuYU (https://www.youtube.com/watch?v=yIe4GulRuYU)
You going to love this video.
Wesley
Plasma Kinetics hydrogen discs
https://www.autoevolution.com/news/plasma-kinetics-may-revolutionize-hydrogen-storage-for-evs-167256.html (https://www.autoevolution.com/news/plasma-kinetics-may-revolutionize-hydrogen-storage-for-evs-167256.html)
Smith told Guberman that both the disc and the film can be reused up to 150 times and are 100% recyclable.
versus
2002 priority date !
https://www.fmlink.com/articles/new-energy-company-to-offer-mail-order-hydrogen-fuel/ (https://www.fmlink.com/articles/new-energy-company-to-offer-mail-order-hydrogen-fuel/)
https://eepower.com/news/fuelsell-to-deliver-hydrogen-direct-solution-by-mail/# (https://eepower.com/news/fuelsell-to-deliver-hydrogen-direct-solution-by-mail/#)
https://patents.justia.com/patent/7399325
https://patents.google.com/patent/US7169489B2/en
https://patents.google.com/patent/US7011768B2/en
compared now > 500 Wh-1000 Wh/Kg battery capacity :
https://www.greencarcongress.com/2021/08/20210824-sion.html
https://www.nasa.gov/sites/default/files/atoms/files/650_whkg_1400_whl_recharg_batt_new_era_elect_mobility_ymikhaylik_0.pdf
https://polyplus.com/product-pipeline/
https://www.v2charge.com/innolith-claims-1000-wh-kg-battery-breakthrough/
15 KWh/Kg battery capacity is a theoretical given number :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=6501093B1&KC=B1&FT=D&ND=3&date=20021231&DB=EPODOC&locale=en_EP
probably ,cited documents,the Bolloré Group http://capacitorsciences.com/company/ will get similar high success !
Sincere
OCWL
To nie jest żaden izomer HHO, po elektrolizie powstają gazy które bardzo szybko stają się 2-atomowe, przy katodzie H2, przy anodzie O2, a w japońskim samochodzie jest zwykły elektrolizer na akumulator, a do silnika doprowadzona jest mieszanka gazów H2,O2 do spalania.
Zwykły elektrolizer nigdy nie pozwoli wyprodukować wystarczającej ilości H2 z wody używające akumulatora samochodowego aby umożliwić jego napęd bez użycia benzyny.
Izomer HHO jest odpowiedzią, wszystkie wodorki tlenowców za wyjątkiem wody są w stanie gazowym w temperaturze normalnej. Dlatego twierdzę że to może być rozwiązanie sposobu napędu samochodów spalinowych.
Zwykły akumulator pozwoli wyprodukować, a poza tym to zwykły elektrolizer niema tam warunków do izomeryzacji czego kolwiek (to dobre izomer HHO dobrze nie nazwa quantum). H2O2 jest ciekły, no i wodorki tlenowców nie są izomerami.
Why, when a hot and cold body (heater and refrigerator) is separated in space, the heat engine works. All cycles, from Carnot to Stirling.
And when they are spaced apart in time, it does not work? Cool down the body, after
for some time it heats up from the environment. Time is also called the fourth
measurement. ;)
https://kiwibyrd.org/2017/08/11/178/ (https://kiwibyrd.org/2017/08/11/178/)
Is it true that it says that the microphone can hear sounds that the ear cannot hear?
Why can't I do it?
Quote from: kolbacict on November 15, 2021, 06:45:31 AM
measurement. ;)
According to the Second Law of Thermodynamics, heat will always flow spontaneously from hot to cold, and never the other way around.
A refrigerator causes heat to flow from cold to hot by inputting work, which cools the space inside the refrigerator.
that involves
Time and
controlled Space at the same time.
Trying to separate it is like separating combustion engine from the fuel vapor in the process of igniting by the time of 1 spark.
Space is there but
right Time is not as at another spark the piston is in wrong position.
Wesley
Quote from: kolbacict on November 17, 2021, 02:32:01 AM
Why can't I do it?
technology BackDoor,
обычные микрофоны слышат хорошо
формируют частоту и фазу звуковых сигналов, которые воспроизводятся через ультразвуковые громкоговорители-спикеры.
«БэкДор» выдает на выходе два тона с частотами 40 кГц и 50 кГц.
усиливаются, , перемножаются – из-за фундаментальных нелинейностей в данной системе.
(f1 – f2) и (f1 + f2).
(f1 – f2) означает 10 килогерц, лежит в рабочем диапазоне частот микрофона,
такой сигнал проходит без изменений через фильтр низких частот
как обычный «полезный» звук.
происходит порождение своеобразной низкочастотной «тени» в слышимом диапазоне.
в системе BackDoor имеется возможность и для передачи информации по этому каналу.
можно иx модулировать
а затем демодулировать
с помощью неслышного ультразвука похищать информацию из изолированных систем, не имеющих сетевых средств коммуникацийOk. I went along entire article.
It starts interesting,
After that drifts into parapsychology, UFO, Russian pride, and all other kind of nonsense.
The Technology
Back Door can be characterized as utilization of longitudinal sound wave in the spectral range from 20kHz Up and its nonlinearity
Human can process . ( 20Hz- 20kHz ) sound.
Possible applications is ultrasound communication, automation, remote controll and and spying.
Authors proposed addition and subtraction of sub auditable sounds and down converting the difference into auditable sounds.
All the rest of that Russian text is not important .. just B.S.
Ultrasonic transmitters and receivers are mechanical devices.
and it is normal to them to hear that what we cant hear.
Good analog microphones works up to 100kHz.
Wesley
I used two dynamic heads, type 6gdv.
The frequency was fed to one 20 kHz, to the second 21 kHz.
Sound was received by the device ВШВ003
For some reason, I did not hear a sound at 1 kHz.
Quote from: kolbacict on November 20, 2021, 02:34:36 AM
Dear kolbacist.
For some reason you can't have 6 hands and 4 eyes. but some other living organisms can.
and bats operates and communicate at ultrasound frequencies.
Humans can hear from
20 Hz to 20 kHz.
Anything higher is called ultrasound or ultrasonic sound.
The reason that bats use ultrasound is because it has such a high frequency and it has a low diffraction or it bends less.
They use this sound to do a couple of things like to catch their prey and also just to get around.
https://hypertextbook.com/facts/1998/JuanCancel.shtml#:~:text=Humans (https://hypertextbook.com/facts/1998/JuanCancel.shtml#:~:text=Humans%20can%20hear%20from%2020%20Hz%20to%2020,their%20prey%20and%20also%20just%20to%20get%20around.)
Wesley
Quoteauthor=kolbacict link=topic=17735.msg561530#msg561530 date=1637134321]
Why can't I do it?Wesley
Of course you can't hear it.
the difference between 20kHz and 21kHz is 1kHz but frequency of this 1kHz is still in bandwidth your hearing is not.
You may down-convert it to any range between 20Hz to 20kHz or subtract in the mixer these two frequencies ,
this is how superheterodine works in radio
and than you'll hear it. But you can see this 1kHz at your
oscilloscope connected to your microphone.
https://en.wikipedia.org/wiki/Superheterodyne_receiver
Hint:
1. think how particle in air( micro-plastic) can hear and react with a particular frequency of sound wave= longitudinal mechanical wave in resonance.
2. think how size , weight, and density of particle is differentiated when exposed to longitudinal mechanical wave in resonance.
- process it in your brain and you are the
winner.-look in my previous post what I meant by word
winner.Wesley
To jak masz dwa mikroskopy elektronowe to jednym możesz produkować układy scalone metodą litografii bez-maskowej (maskless lithography) a dokładniej "Electron-beam lithography".
What(Who) is it ?
a drunkard lie under your table? :)
The second picture is already gone ...
QuoteOf course you can't hear it.
And why are there no beats in the air in the room between these frequencies?
With a difference frequency of 1 kHz?
Why, in an electrical circuit, this happens when two electrical signals are mixed, but not in the case of acoustic waves?
QuoteTo jak masz dwa mikroskopy elektronowe to jednym możesz produkować układy scalone metodą litografii bez-maskowej (maskless lithography) a dokładniej "Electron-beam lithography".
You can do both at once. ;)
Quote from: kolbacict on November 20, 2021, 01:19:03 PM
What(Who) is it ?
humoristic: use of two words that when spoken sounds the same but when written the are different.
difference-between-lay-and-lie https://askanydifference.com/difference-between-lay-and-lie/ (https://askanydifference.com/difference-between-lay-and-lie/)
I'm not sure what you are alluding to? :)
are you questioning that we have not one but two LEO 435VP?
We have two units of LEO 435 VP and in addition to it
we actually have the third one too, but is not working at the moment. :)
One uses Liquid nitrogen and the other is not.
the two pictures from the comment on the top that shows the same very microscope in the same very room.
One of the pictures shows slightly separated main unit from its electronics and my jacket on the floor.
so I can lie down while checking connections. :)pictures: LEO 435 VP and LEO 435 VE shows the same unit.
and nothing is gone.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561594/#msg561594 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg561594/#msg561594)
so where is the lie? :) lye ? :) Below this comment you have set of two pictures of my
two different working units.The LEO 435VP on the second picture named LEO 435 unit# 2 is in different room and it has Liquid nitrogen dewar on it.
Scanning electron microscope (SEM)
Resolution: 4 nm
Computer controlled stage: 5-Axis
Specimen chamber.
EDXRF or EDS Energy Dispersive X-ray Spectroscopy.
QuoteEnergy dispersive X-ray spectroscopy (EDS or EDX) is a chemical microanalysis technique used in conjunction with SEM.
The EDS technique detects X-rays emitted from the sample during bombardment by an electron beam to characterize the
elemental composition of the analyzed volume. Features or phases as small as 1 µm or less can be analyzed.
https://www.sciencedirect.com/topics/engineering/energy-dispersive-x-ray-spectroscopy (https://www.sciencedirect.com/topics/engineering/energy-dispersive-x-ray-spectroscopy#:~:text=Energy%20dispersive%20X-ray%20spectroscopy%20%28EDS%20or%20EDX%29%20is,as%201%20%C2%B5m%20or%20less%20can%20be%20analyzed.)
some helpful videos:https://www.youtube.com/watch?v=SdpXFcf_La0&t=926s
https://www.youtube.com/watch?v=kOJGZJa3cZg&t=164s (https://www.youtube.com/watch?v=kOJGZJa3cZg&t=164s)
https://www.youtube.com/watch?v=xlXEP5yONA0&t=20s (https://www.youtube.com/watch?v=xlXEP5yONA0&t=20s)
https://www.youtube.com/watch?v=vBu9Xzc1TgE (https://www.youtube.com/watch?v=vBu9Xzc1TgE)
https://www.youtube.com/watch?v=eOPS2AAUwOU (https://www.youtube.com/watch?v=eOPS2AAUwOU)
I used it also to analyze ferrite composition from Russian TV Rubin used in number of FE experiments.
Wesley
There will be none.Every microphone has different frequency range and different sensitivity
The two longitudinal waves must have the same frequency and be opposite in face and equal in amplitude( magnitude) at that given point you are at, to cancel
itself, but the effect will be valid only for the particular point the observer is at.
When you or your microphone moves left right you and your microphone will not hear cancellation .
If you have two different frequencies of longitudinal wave you'll not be able to mix them together unless you receive the tones and in form of electrical signal
mix them in mixer.
You can't base on article in Russian language as it was written by an analphebet (illiterate.) person in physics.
The Russian made his own comments to this article:
BackDoor: Making Microphones Hear Inaudible Sounds Nirupam Roy, Haitham Hassanieh, Romit Roy Choudhury University of Illinois at Urbana-Champaign
https://nsr.cse.buffalo.edu/mobisys_2017/papers/pdfs/mobisys17-paper01.pdf (https://nsr.cse.buffalo.edu/mobisys_2017/papers/pdfs/mobisys17-paper01.pdf)
and everything is explained in it:
I'm reading it now . If I find anything wrong in it I'll definitely note it here.
Wesley
Quotemy notes to the article :
QuoteThe diaphragm of the microphone should exhibit some sensitivity
at the high-end frequencies (> 30kHz). If the diaphragm
does not vibrate at such frequencies, there is no opportunity for non-linear mixing of signals.
(3.1 Measurements and Validation page#4)
[/font]QuoteThe second order coefficient A2 needs to be adequately high to achieve a
meaningful signal-to-noise ratio
A1 or A2..3..4 is a complex gain that can change the phase and/or
amplitude of the input frequencies,
(Linear and Non-linear Behavior page#4)
Note: You may need to connect microphone to your spectrum analyzer using separating capacitor for DC Power supply elimination.
if you put DC to input of spectrum analyzer than your instrument gets damaged.
Note: 1st order, 2nd order,3rd order are the harmonics.
(Figure 5: (a)The intermodulation distortion of signal (b) Harmonic distortion. page 5)
Note: QuoteThus far, the shadow signal is a trivial tone carrying one-bit of information (presence of absence).
(4.1 Communication page 5)
Conclusion :So they are talking about a "shadow" seen at digital output.- not in physical XYZ space.
[/font]Quoteour actual goal is to modulate the
high frequency signals at the speaker and demodulate the
shadow at the microphone to achieve meaningful data rates
Quoteany modulation that generates waveforms
with non-constant envelopes [45] is likely to suffer this problem.
Note: AM modulation is not applicable due to severe problems.
(Failure of Amplitude Modulation (AM) page 5, look also at Figure 7 )
Ok I'm giving up for today - the rest of the article is easy to understand.
Wesley
Технические характеристики
ВШВ-003-М2:Частототный диапазон, Гц 2 – 18000 =
18kHz !!!!!!!!!!!!!!!!!!!!!!!!!
Динамический диапазон, дБ 22 – 140
Частотные корректоры A, B, C, Lin
Временные характеристики Slow, Fast, 10c
Класс точности 1,0
class 1 Октавные фильтры со среднегеометрическими частотами, Гц 1 – 8000
Питание сетевое и автономноеМасса, кг 5,5.
______________________________________________________________Few Questions:
How come you made measurement with the device that goes max to 18kHz?
How did you fed 2 signals at the same time with two
6gdv. into instrument that has only one probe input?
http://www.tehno.com/product.phtml?uid=B00120039561 (http://www.tehno.com/product.phtml?uid=B00120039561)
objections and problems:
-20 kHz and 21 kHz is out of range of this instrument.______________________________________________________________Quote from: kolbacict on November 20, 2021, 02:34:36 AMSound was received by the device ВШВ003
again this device when belongs to group of class 0 or
class 1 has limit of frequency maximum to
18kHz. https://www.prostanki.com/board/item/73931
(https://www.prostanki.com/board/item/73931)Технические характеристики
ВШВ-003-М3:
18000kHzДинамический диапазон, дБ 22 – 140
Класс точности 1,0
-20 kHz and 21 kHz is out of range of this instrument.Wesley
No, no lie, it was a joke. :D
I thought an alcoholic was resting under your table ...
I am a man with humor, without which it is unbearable to live in this country. ;D
QuoteЧастототный диапазон, Гц 2 – 18000 = 18kHz !!!!!!!!!!!!!!!!!!!!!!!!!
Yes you are right. I studied the documentation poorly.
I have had it for ten years, and have not really studied it.
ok, we will continue to work. :)
True, I lowered the frequency to 16 kHz later(I don't hear that either), but the difference frequency beats were not apeared as well.
Quote from: ramset on November 21, 2021, 02:07:53 PM
Question to Wesley?
( can we do it ? Is it useful/scalable ?
https://overunity.com/18977/carat-trax-forever-battery/msg561622/#new (https://overunity.com/18977/carat-trax-forever-battery/msg561622/#new)
Chet K
Yes you can . Nothing new.
However the heat coming from central heating pipe helps.
We know that in cold temperature failure of some forms of batteries is evident.
QuoteThe Zinc and Copper Battery In a zinc-and-copper battery, the chemical reaction
involves the transfer of electrons from solid zinc to copper ions.
The zinc is therefore the anode; solid zinc is oxidized. The copper is the cathode; copper ions are reduced
https://education.seattlepi.com/happens-battery-zinc-sulfate-mixed-copper-sulfate-6031.html (https://education.seattlepi.com/happens-battery-zinc-sulfate-mixed-copper-sulfate-6031.html)
Wesley
I found a microphone from an ultrasonic TV remote control telefunken.
There is no marking. TV set in 1976. Data and connection diagram find are unrealistic.
But most likely the type is capacitor. And the maximum frequency should be quite high. ;)
Quotehttps://askanydifference.com/difference-between-lay-and-lie/
well, good reference.thanks.
It seemed to me that was a drunken man lying under your table.
That's right? :D
Known separators for non-magnetic materials using a magnetic fluid.
In them, the specific density of the liquid increases as a result of the action of an external magnetic field. The question is how much energy needs to be spent to create a magnetic field. And how much will we get from the increase in the potential energy of the floating up body? I still can't find answer in any books. maybe I was a bad seeker?
Why is not a single bubble of hydrogen or oxygen emitted between the plates of the water condenser and other components in the water generator of Marx?
Sorry to be off-topic, but there is no one else to ask. :)
https://www-n--tv-de.translate.goog/auto/Das-Brennstoffzellen-Motorrad-naht-article22954646.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui (https://www-n--tv-de.translate.goog/auto/Das-Brennstoffzellen-Motorrad-naht-article22954646.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui)
Segway does not reveal how far the e-bike can get in total, but according to the manufacturer, one gram of hydrogen should be enough for one kilometer for the Apex.1 Kg hydrogen ~ 33 KWh ergo 33 Wh per Km
fuel-to-wheel conversion efficiency ?From ebike to city-etrike ,hibrid or full electric
https://www.pinterest.com/pin/288019338658790702/ (https://www.pinterest.com/pin/288019338658790702/)Happy weekendOCWL
QuoteIf you go to newly freed from soviet terror countries you may see some people complaining
that businesses got private and nobody wants to make some parts for you on company lathe , milling machine and soon.
I understood.
I dlatego łatwiejszy start ma dowolny hobbysta z USA od innych, ja jak zaczynałem to miałem gówno a nie start, o "true rms" to ja se mogłem pomarzyć jedynie, a oscyloskop to se przerobiłem ze starego rubina.
News:
12 days ago.
12 дней назад
3200W at output.
1,752,350 views просмотры Nov 24, 2021
Mr. Elias (Filipinos)
main two links:
https://www.youtube.com/watch?v=r51TdNPA55s&t=1s (https://www.youtube.com/watch?v=r51TdNPA55s&t=1s)
https://www.youtube.com/watch?v=nb0wkOKJfCs (https://www.youtube.com/watch?v=nb0wkOKJfCs)
but I suggest first start from links below
Note: links below are from the two videos and they start from given video frame at given time reflecting interesting information.
https://youtu.be/r51TdNPA55s?t=1701 (https://youtu.be/r51TdNPA55s?t=1701)
https://youtu.be/nb0wkOKJfCs?t=1320 (https://youtu.be/nb0wkOKJfCs?t=1320)
Note : the pictures are oversized on purpose for better detail view.
Wesley
This link shows the process :
from switching ON the device.
https://youtu.be/r51TdNPA55s?t=1411
(https://youtu.be/r51TdNPA55s?t=1411)
Wesley
internal components of second unit:
https://youtu.be/nb0wkOKJfCs?t=1351 (https://youtu.be/nb0wkOKJfCs?t=1351)
Wesley
IMHO większość tego co jest na wierzchu to są śmiecie robiące za zaślepki, prawdziwe urządzenie jest niedostępne dla oczu.
We have a member "Mark Dansie" ,
He is longtime investigator of FE claims , he lives in Philippines ( has a lab there now ?)
I asked him to take a look ( he does "in person" investigations globally )
He acknowledged and said he will !
Looking forward to talking with him again , been too long !
Respectfully
Chet K
Ps
I will invite Mark to this board for comment
There is news from Russian forum that kapanadze died due to covid.
Неделю назад В ковидной больнице скончался Тариэл Капанадзе — грузинский сумрачный гений изобретатель бестопливного одноименного генератора электроэнергии. Тариэла в самой Грузии называют грузинским Тесла. Свой генератор Тариэл назвал так: капаген, от собственной фамилии.
Кто знает подробности напишите пожалуйста
additional pictures:
shows presence of capacitor made by ABB
different colors shows important information
model : CLMD-63
Please note that wires coming out of the green box
are made from multiple wires for caring on big current.
The max voltage on capacitor bank is 3.1kW
some links for your reference and study:
https://www.flipkart.com/kartex-md1803dfx-high-voltage-npn-power-transistor/p/itm56c63ee5ecaf2
https://documents.pub/document/lv-capacitor-bank-apc-abb-group-lv-capacitor-bank-apc-automatic-or-manual.html
https://www.ebay.com/itm/234316483116?hash=item368e59ca2c:g:NIAAAOSwYlJW3rfj
https://i.ebayimg.com/images/g/NIAAAOSwYlJW3rfj/s-l1600.jpg
https://library.e.abb.com/public/a82cf1a0864b4237983109a7697acea5/2GCS304014B0070-CLMD%20brochure.pdf
https://i.ebayimg.com/images/g/I00AAOSwE95gAeBO/s-l1600.jpg
https://www.ebay.com/itm/153962439533?chn=ps&mkevt=1&mkcid=28
https://i.ebayimg.com/images/g/qngAAOSwryRgAeBO/s-l1600.jpg
https://www.google.com/search?q=ABB+capacitor++BCP1&bih=988&biw=1209&client=avast-a-2&hl=en-US&tbm=shop&sa=X&ved=2ahUKEwjCucylh9D0AhUCrnIEHdtlAJUQ1TV6BAgBEFM
Wesley
Voltage on the coil can't be bigger than PN junction of the transistor in "series."
but there is something that is more interesting than that in next comment.
Note: it looks like second the rear row of transistors is there but is not connected.
Please look at first 4 transistors in front and than at the transistors at the rear..
"series."- i didn't analyze it yet - if parallel connection for Hi current was used, but Voltage level restriction on the transistor still apply
Wesley
Coil connections and HV problem around computer board
is unexplained to me
Another words:
You can't have HV "nest" - next to computer PCB
https://youtu.be/nb0wkOKJfCs?t=1372
Wesley
Czyli jednak brak urządzenia FE, bo to wygląda jakby tylko ten kondensator był tylko podłączony, (wcześniej naładowali, a przed kamerą korzystają).
The wire from the top of the coil goes here.
The distance between :
-wire from top section of transistors and
-wire from the top of big coil
is around 2".
The strength of electrostatic field, or electromagnetic field
is transferable by induction between them.
So this looks strange.
Wesley
To tak wygląda jakby przerywacz diody był zasilany między-fazowo z dużego kondensatora, tak wygląda że górny punkt podłączenia przy małej cewce (może nie być podłączony do do małej cewki) jest podłączony do emitera górnego tranzystora oraz do diody led. No i najważniejsze jak by było wysokie napięcie na tych cewkach to by były przeskoki iskier przy takiej konstrukcji (dioda by tylko raz migneła a porządnie :) bo by była różnica napięć między zwojami cewek a przypadkowymi przewodnikami).
Mam nadzieję, że demonstracja na miejscu, po których był świadek członka forum "Mark Dansie", odbędzie się wkrótce. Jest na Filipinach.
"Hopefully on-site demonstration ...witnessed by forum member Mark Dansie
Will happen soon , he is in Philippines."
Chet
In such a capacitor, many batteries can be hidden. :)
And this connector reminded me of ... :D
I don't know who Mark Dansie is.
I have nothing against these Filipinos.
Let them succeed.
Just my thoughts ... :)
I have nothing against them either,
but lets see if the device can be examined
or not.
This is probably a dumb question, but, can that big huge box run anything other than a fan?
I think that Ruslan could probably place 10 or more of his self runners 4000w builds, in that same box.
I wonder how much noise it makes? As it looks to be a mechanical contraption. Or, is that box is mostly empty?
Or full of batteries or caps. Hard to trust those people, as lying is the norm.
NickZ
Pełno fałszywych komponentów w środku ma pokazać laikom, że to poważne urządzenie, a przede wszystkim robić wrażenie na nich i robi.
To samo widzimy u Kapanadze. Niby ok ale po co to robić skoro można nic nie pokazać i też być wiarygodnym.
Magik pokazując królika uwiarygadnia się ale to nie znaczy, że on tam jest.
Już jeden niedawno z Afryki był ! i gdzie jest ?
https://twitter.com/musvanhiri/status/1309579836998942722
Co do Saith Power to parametry tych urządzeń są na obrazku https://twitter.com/saithgroup/status/1285894559784984577/photo/2 , tyle że moim zdaniem za szybko porzucił szkołę a możliwe że później przerabiali tabliczkę mnożenia, bo na początku się nie zgadza moc wejściowa z maksymalnym napięciem i prądem. Ale sądząc po parametrach we/wy to może być urządzenie typu: silnik dc, przekładnia, prądnica ac 3-fazowa, a reszta nazw to po prostu zaciemnienie.
https://beruhmte-zitate.de/zitate/124321-karl-raimund-popper-der-versuch-den-himmel-auf-erden-einzurichten-er/ (https://beruhmte-zitate.de/zitate/124321-karl-raimund-popper-der-versuch-den-himmel-auf-erden-einzurichten-er/)
"The attempt to establish heaven on earth always creates hell.
This attempt leads to intolerance, to religious wars and to the salvation of souls by the Inquisition. "
- Karl Raimund Popper, book The open society and its enemies
Source: https://beruhmte-zitate.de/zitate/124321-karl-raimund-popper-der-versuch-den-himmel-auf-erden-einzurichten-er/ (https://beruhmte-zitate.de/zitate/124321-karl-raimund-popper-der-versuch-den-himmel-auf-erden-einzurichten-er/)
https://en.wikipedia.org/wiki/Critical_theory (https://en.wikipedia.org/wiki/Critical_theory)
https://copyriot-com.translate.goog/sinistra/reading/agnado/minima.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de (https://copyriot-com.translate.goog/sinistra/reading/agnado/minima.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de)
Reflection from a damaged "life/culture/world"
Help translate this page into English. I can't do it.
My computer is old and the internet is bad. :'(
I wanted to show this to the adherents of breaking apart water molecules by electrostatics.
the nature of the true dissociation of water. especially where it is framed by me ...
https://s.11klasov.net/index.php?do=download&id=9854 (https://s.11klasov.net/index.php?do=download&id=9854)
p.s. I wanted to point out a common misconception.
misconception about that a water molecule is broken by an electric field during electrolysis.
the rupture of the molecule makes the heat!
This is the only Soviet textbook that I found, where it says directly about it ...
Quick update on Wesley's "Philippine device 3200 watts at output" investigation/analysis starting at post 3542 Dec 6. https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/3540/ (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/3540/)
Spoke a bit with MarK Dansie last night , he will make every effort ( within reason) to visit
And bring an engineer ...to view a demonstration of this technology,
And report back !
I did send link to above posted info gathered by Wesley from post 3542 and following posts.
*Should be noted that travel can still be affected by COVID restrictions!
Respectfully
Chet K
Quote from: kolbacict on December 14, 2021, 01:54:51 AM
Unfortunately I can't help you with translation.
Wesley
HOT GLUE IS USED, I AM OUT OF HERE.
A TRUE SIGN OF SFAKE.
I just wanted one page.
Where the nature of electrolytic dissociation is explaned.
The rest of the book is simply not needed.
To show to those who believe in breaking molecules apart by electrostatics.
You yourself asked ...
But I can upload it entirely in the format djvu.
I have it downloaded for a long time. It's just big, 18MB.
And I count every megabyte.
This is not America ... :D
Jeśli ci chodzi o elektryzowanie dielektryka(woda) za pomocą maszyny elektrostatycznej, to nic ci to nie da, bo aby nastąpiło przebicie dielektryka (elektroliza wody) musi połynąć prąd. Jedynym rozwiązaniem użycie generatora hv do elektrolizy wody dejonizowanej (bez aktywnych jonów), najlepiej można zastosować impulsy hv z rezonansu szeregowego lc gdzie c - komórka do elektrolizy, chyba był nawet taki patent na to autora: Stanley Meyer.
Quotenajlepiej można zastosować impulsy hv z rezonansu szeregowego lc gdzie c - komórka do elektrolizy, chyba był nawet taki patent na to autora: Stanley Meyer.
I did all this, but nothing works for me.
the amount of gas is released strictly according to Faraday's law.
That is, according to the amount of electricity coulombs passed through the cell. :(
some translation to the sentence rounded by you with pen on the picture.
-kT (also written as kBT) is the product of the Boltzmann constant, k or kBit is the amount of heat required to increase the thermodynamic entropy of a system by k.
QuoteAverage amount of thermal movement of particles equals 3/4 kT
k is constant.
1.38 x10 -15
So if we take temperature +20C we get
E=1.5x1.38x10-15x293=6.1x10-14 erg.
comparison of this result with that w hat was shown from above shows that both of them are the values of one and the same row .( both of them are alike)
Another words energy of thermal movement is sufficient to in effect achieve (disintegration) -transition into ions the dissolved in water salt.
An erg is the amount of work done by a force of one dyne exerted for a distance of one centimetre.
In the CGS base units, it is equal to one gram centimetre-squared per second -squared (g⋅cm 2 /s 2). It is thus equal to 10 −7 joules or 100 nanojoules (nJ) in SI units.
When salts are dissolved in water, they separate into ions.
Salts are ionic compounds which, when dissolved in the liquid, break up completely into ions.
Here is some material helping to answer the most basic questions:
https://lisbdnet.com/what-happens-when-nacl-is-dissolved-in-water/ (https://lisbdnet.com/what-happens-when-nacl-is-dissolved-in-water/)
Wesley
Here is an addition to the subject of salt in water.
Water as fuel unlocked by frequency resonance.
https://www.youtube.com/watch?v=p8xYUDiSGDk (https://www.youtube.com/watch?v=p8xYUDiSGDk)
I'll add more to it.
Wesley
QuoteEXACTLY!!! I can shake my own warer apart.. just need to know the frequency and the cycles that is needed. It actually would be more efficient if the power used to transmit was stronger.. oh man this guy is gonna disappear.. hes opend up a new can of worms.. meyer with the metal plates and hes gone... The inventors of the thorium battery... yea he needs to prepare..
QuoteThe man in the video John Kanzius died February 18, 2009 at the age of 64. Kanzius also admitted that this process could not be considered an energy source, as more energy is used to produce the RF signal than can be obtained from the burning gas. See Wikipedia on this.
this is from the comments under the video .. :D
The fiber-optic isolation
. It can be used in many applications and not only for Raspberry pi
https://youtu.be/jvxPtFJN5pk?t=113 (https://youtu.be/jvxPtFJN5pk?t=113)
Wesley
Ale że co, bo nie wiem, chodzi ci o izolacje sygnału po przez światłowód, taką izolację się od dawna
stosuje w przetwornicach między tranzystorowymi mostkami HV dużej mocy a głównym sterownikiem
którym najczęściej jest mikrokontroler lub układ FPGA, masz nawet tyrystory bezpośrednio sterowane światłem LTT (light triggered thyristor).
Yes it is exactly what I'm talking about
Tak dokladnie mi o to chodzi
Wesley
The purpose of this post is to focus your attention on the fact that
making Tesla coil for VLF ( Very Low Frequency) is not easy task due to long wavelength of the wave from desired few kHz to max 200kHz. at 1/4y
but Ferrite core helps a lot.
______________________________________________Each video of YouTuber:
QRQcw has a his own text below each video
-and I reprinted it for you
Video part #1.
https://www.youtube.com/watch?v=TyjHj2-MUjg (https://www.youtube.com/watch?v=TyjHj2-MUjg)VLF RECEIVE ANTENNA - BIPOLAR TESLA COIL with massive Ferrite Core - resonated to 17.65 Khz(pt1)
1st test using a BIPLOAR TESLA COIL with a MASSIVE NiZn high perm Ferrite Core
- resonated to 17.65 Khz with .003 uF of capacitance...to be used as a VLF RECEIVE ANTENNA in this first test, a
CW SIGNAL at 17.65 Khz(at -50 db) was coupled inductively into the VLF antenna on one end of the coil with 3 turns around the Ferrite Core...
to test the concepts of how well resonating the coil to 17.65 Khz would work, with the TESLA COIL windings, dimensions,
Ferrite material et al ... to increase the sensitivity of an antenna type like this for VLF RECEPTION
at the other end, 2 turns were wrapped around the core and brought up to the USB SOUND CARD LINE INPUTs...
then the SAQrx VLF SDR app was used to demodulate the 17.650 Khz CW signal,
and that is what you are hearing on this video demo...the final result...etc.
SAQrx SDR APP:https://sites.google.com/site/sm6lkm/...
newer version of SAQrx VLF SDR https://sites.google.com/site/swljo30tb/ (https://sites.google.com/site/swljo30tb/)
OBSERVATIONS:
1. resonating the BIPOLAR TESLA COIL to 17.65 Khz, with its current design and dimensions...
that particular VLF frequency produced the most VLF signal into the SOUND CARD LINE INPUTs....
even though the coil could be resonated at other frequencies, 17.65 Khz resonated with the .003 uF capacitance,
peaked the most output from the VLF ANTENNA ASSEMBLY than any other vlf frequency tried...
2. the noise floor was much quieter than using a straight long wire, or typical AM LOOP ANTENNA
next test will use a separate transmitter from a distance away, to see how well this BIPLOAR TESLA COIL VLF FERRITE CORE ANTENNA
can pick up that signal which can be viewed
here - https://youtu.be/L37vrSkaWBc (https://youtu.be/L37vrSkaWBc) VLF
Transmitter & Receiver experiments playlist: https://www.youtube.com/playlist?list (https://www.youtube.com/playlist?list).
Wesley's Comment.: a. I'm not sure what the author is trying to say. did he have in mind bifilar not bipolar winding?
b. some additional material about bipolar?
https://electricalclub.quora.com/What-is-the-bipolar-winding-of-a-center-tape-transformer-and-why-is-it-used-specifically-in-a-transistor-switching-circ (https://electricalclub.quora.com/What-is-the-bipolar-winding-of-a-center-tape-transformer-and-why-is-it-used-specifically-in-a-transistor-switching-circ)
c. ferrite core doesn't look like 1.1/4"
d. the entire channel looks like very active video production... but something is strange here.
Video part #2
https://www.youtube.com/watch?v=L37vrSkaWBc (https://www.youtube.com/watch?v=L37vrSkaWBc)QuoteVLF RECEIVE ANTENNA - BIPOLAR TESLA COIL with massive Ferrite Core - resonated to 17.65 Khz(pt2)
2nd test using a BIPLOAR TESLA COIL with a MASSIVE NiZn high perm Ferrite Core - resonated to 17.65 Khz with .003 uF of capacitance...to be used as a
VLF RECEIVE ANTENNA (1st video in this series
here - https://youtu.be/TyjHj2-MUjg (https://youtu.be/TyjHj2-MUjg))
VLF TRANSMITTER is now in a different location and it is using a VERY poor, inefficient, 20 foot long wire loop...
directly driven by a 5 watt audio amp at 17650 hz by the AD5DZ CW KEYBOARD sending a file.
The audio noise floor is now reduced substantially using this BIPOLOAR FERRITE CORE TESLA COIL
and the VLF SIGNAL PICKup has been increased 10s of dbs signal/noise above the previous test setups using just a long wire
SAQrx SDR APP: https://sites.google.com/site/sm6lkm/ (https://sites.google.com/site/sm6lkm/)... newer version of
VLF Transmitter & Receiver experiments playlist: https://www.youtube.com/playlist?list (https://www.youtube.com/playlist?list)...
Wesley
this post is related to previous comment of mine
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562156/#msg562156 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562156/#msg562156)
posting
QROcw you-tuber material:
Quote from: stivep on December 17, 2021, 12:46:25 PM
Wesley
Some analysis:
-his channel is very active
-no single word is ever said by him. (the
QROcw)-there is however some religious speech on few of the videos, totally disconnected from electronic theory and practice
but may be he is using this speech to present his phenomena of VoP https://www.youtube.com/watch?v=Jpln3va8olI but some of (the
QROcw) ideas are quite intriguing
https://www.youtube.com/watch?v=ECvhmA7ws-4
(https://www.youtube.com/watch?v=ECvhmA7ws-4Wesley)Wesley.
Chodzi o bipolarny transformator tesli "BIPOLAR TESLA COIL" a nie uzwojenie bipolarne.
Subject:
Why is Blender Free https://www.youtube.com/watch?v=yfg8ydtOUDg (https://www.youtube.com/watch?v=yfg8ydtOUDg)
https://en.wikipedia.org/wiki/Blender_(software) (https://en.wikipedia.org/wiki/Blender_(software)#:~:text=The%20Dutch%20animation%20studio%20NeoGeo%20%28not%20associated%20with,2%2C%201994%20is%20considered%20to%20be%20Blender%27s%20birthday.)
Explanation:
I don't want my comments to look as totally disconnected so at least in few occasions
I want to back it with my motivation.
Looking at this video I was interested with Blender that I use for few years now form perspective of affordability.
Blender is open community project Free and Open Source. done by my landsman Ton Roosendaal (https://en.wikipedia.org/wiki/Ton_Roosendaal).
Everyone in business( nonprofit is also a business) must make money.
But Ton Roosendaal. managed to give something for free to all of us and be kept afloat, and still make money .
That video of Roosendaal is a kind of temptation to me in my own field.
the problem is that the scale of Energy Extraction from Schumann Waveguide EEfSW
is overwhelmingly impacting not some sort of community but the entire world.
Consequence:
- the consequence of Blender is millions of attracted kids, students, teachers, and presenters.
- the consequence of FE is overpopulation and humanity looking for shelter.
Attraction:
- Blender is for free and attracts people by easiness, application, and provides repeatable effects.
- FE from EEfSW is for free and attracts people by easiness, application, and provides repeatable effects.
the material in 70% of it was posted by me in easy to absorb form in two languages and my Youtube video .
The missing 30% or less of it I may post in the future.
English :
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg557085/#msg557085 (https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg557085/#msg557085)
Russian:
https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559504/#msg559504 (https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559504/#msg559504)
videos:
https://www.youtube.com/watch?v=He5xQOJHlrU (https://www.youtube.com/watch?v=He5xQOJHlrU)
https://www.youtube.com/watch?v=XOTLfnMOSqQ (https://www.youtube.com/watch?v=XOTLfnMOSqQ)
https://www.youtube.com/watch?v=zE4GjB1cWLQ (https://www.youtube.com/watch?v=zE4GjB1cWLQ)
Wesley
Quote from: color on December 18, 2021, 09:46:37 AM
Dr. I think Corum is a bit sloppy... ;D ;D ;D ;D ::) 8)
Both of Corum Brothers are 76+ years old now.
They for now no longer care about world of technology so you would too in their place.
____________________________________________________Wesley
Ale czego ty oczekujesz od zwykłego użytkownika blendera, taki użytkownik oczekuje gotowca którego użyje do własnych celów (nie musi stawać się od razu programistą blendera), oraz wystarczy mu jedynie do tego komputer, internet, prąd, i żeby mu na łeb nie kapało. Druga sprawa poco zwykłemu użytkownikowi przesył energii z punktu a do g :), przecież i tak musiał by zasilić nadajnik, oczywiście bardziej by było zainteresowanie gdyby był "nadajnik naturalny". Następny problem jest taki to ilość miejsca potrzebna, nie każdy mieszka na zadupiu gdzie ma pod ręką pole, nawet jak masz domek jednorodzinny w mieście to masz też sąsiadów którzy mogą być mocno zaniepokojeni tym co zobaczą i będzie trzeba tłumaczyć milicji co to jest (a tam ciężko ze zrozumieniem :)). Ostatni problem to że nie gwarantujesz działania oraz w razie nie wiadomo jakiego wsparcia udzielasz przy uruchamianiu oraz nie wiadomo jakich efektów można się spodziewać po uruchomieniu, ile mocy mogę z tego uzyskać (czy w ogóle opłacało się to budować), to wszystko zwykłego użytkownika odstrasza.
I agree.
Device must be proven working before is widely accepted.
But you don't care if anyone accepts you if you don't benefit on it.
So is me.
Wesley
Power your home fuel-less on capacitors, make it bigger and go for your love!
https://www.youtube.com/watch?v=uJH4p2ESgh4
Isn't this the person Wesley introduced? ::)
I made another strange thing, are you interested? ::) 8)
Frequency of ~ 130kHz is little to high for long distances.
Frequency desired is 20kHz and lower.
That may require to build Rx with use of ferrites.( not all so difficult and not so bad)
Note: inverse square law doesn't apply to waveguides.
Interface air /earth is a form of 2D waveguide.
Wesley
some other equipment used in the experiments with EEFSW and Energy Transfer.
Wesley.
Wesley.
We also used model 605 and 606 Cober. 24kW i 31kW power respectively.Cober Model 605P High Power Pulse Generator
At full peak output, peak power is 24 kilowatts at 1.5% duty.
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546830/#msg546830 (https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546830/#msg546830)
Pulse amplitudes to 2200 volts can be dialed-in or extended to 20,000 volts using accessory, plug-in transformers.
https://www.tzsupplies.com/pulse-generator-high-power-cober-i5005387/
(https://www.tzsupplies.com/pulse-generator-high-power-cober-i5005387/)This video may help to understand more about plasma generators however on video they are not not using Cober
https://www.youtube.com/watch?v=dhkURRlvX0g
Wesley
To masz jeszcze prostsze, a działa i cieszy: https://www.youtube.com/watch?v=tq9jdv6zD38 , kiedyś podobny zbudowałem w podstawówce na zpt.
Quote from: lukaszkwiatkowskii on December 22, 2021, 04:46:43 AM
Poważnie ? myślałem, że żartujesz.
Tak. Nawet dostałem nagrodę, która była karą. ;D ;D ;D ;D
important to understand is that Zenneck wave doesn't radiate in air. Communication is NOT DONE IN AIR. THIS WAVE DOESN'T EXIST IN AIR.
At Near field from UP/Down tuned Top capacitor wave enters INTERFACE at Complex Brewster Angle and exists only in that interface from now.
in TM mode .
It needs to be understood that winding the particular Tesla Coil according to posted by me (first picture of my post from above.)
1. 2200m = 136,24 khz takes 30 minutes. (using lathe) or 3 hours if pivoted and all winding information is in the picture.
pivoted manual winding : at best takes 2 people
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562296/#msg562296 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562296/#msg562296)
2. this coil is good for short distance testing of A to B energy transfer as mandatory learning curve experience before EEfSW.
3. the minimum equipment that is needed for that is:
a- for Tx 3 pieces or just 1 generator, look at second picture from previous post and Tesla Coil.
b- for Rx exactly the same way winded Tesla coil and the load look at second picture from previous post.
Person walking the distance of 200m between Tx and Rx with LED testing probe in his hand starting his walk
from the Tx can see light on LED in Near Field than LED quickly light dims in Freshnel zone and disappears.
At the Tesla coil Rx (receiver site) it doesn't work that way. The power is seen only at the connected to it load.
At both the Tx and Rx impedance match and complex Brewster Angle tuning is a must!!! It will not work without it.
tuning was explained here and in two of my dedicated to it topics.start to read from here :
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546325/#msg546325
(https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546325/#msg546325)practical schematic of Tx at 2200m= 136,24 khz is here:
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg547756/#msg547756 (https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg547756/#msg547756)
in Russian: https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559483/#msg559483 (https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559483/#msg559483)
перейти на все 5 страниц
Wesley
to 3614 :
do You understand the FE spectrum from the Tesla Tower/rec/antenna device as
https://en.wikipedia.org/wiki/Ionizing_radiation FeV and FeA alpha,beta,delta,...... gain potential ?
Sincerely
OCWL
Quote from: lancaIV on December 22, 2021, 08:13:28 AM
to 3614 :
https://en.wikipedia.org/wiki/Ionizing_radiation (https://en.wikipedia.org/wiki/Ionizing_radiation) FeV and FeA alpha,beta,delta,...... gain potential ?
Streamers and sparks are not allowed in the test. Ionization is at its minimum.
I share information only and it is no way I talk someone to perform the Tests. It is at your own responsibility.
The frequency of testing is 20kHz or below it for EEfSW and presented winding coil in instruction is for 131kHz.
-good only for short range of energy transfer from point A to point B.
Wesley
• How come surface Wave known as Zenneck wave fallows the curvature of the earth?
Quote1901 Guglielmo Marconi the broadcast took place across the Atlantic at a frequency of 30 kHz
. we may assume that it was Zenneck wave that made it happened.
1901 Гульельмо Марконирадиопередача проходила через Атлантику на частоте 30 кГц.
мы можем предположить, что это была волна Зеннека, которая заставила это произойти. https://www.rroij.com/open-access/surface-electromagnetic-waves.php?aid=87345 (https://www.rroij.com/open-access/surface-electromagnetic-waves.php?aid=87345)
QuoteZenneck wave is the fact that (aside from the exponential decay factors) its field is inversely proportional to the square root of r, rather than to r itself as would be true for usual free space propagation with a source of finite extent. Again, this is not unexpected; it is simply due to the approximate two-dimensional nature of the propagation problem
http://web.mit.edu/redingtn/www/netadv/zenneck.html
This is article of MIT
QuoteJanice Turner and colleagues at Roke Manor Research (http://www.roke.co.uk/) of Romsey, U.K., have developed a Zenneck wave demo unit. This can transmit high-definition video over a length of conductor covered with dielectric with a bandwidth of up to 1.5 gigabits per second.
https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/
(https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/)
Excitation and use of guided surface wave modes on lossy media https://patents.google.com/patent/US10998604B2/en (https://patents.google.com/patent/US10998604B2/en)
Wesley
Fala Zennecka niczego nie sprawia, a tym bardziej tego jak się rozchodzi, jest jedynie reakcją na akcję źródła.
Quote from: lukaszkwiatkowskii on December 23, 2021, 04:19:02 AM
Zenneck wave is as form of electromagnetic energy has its origin, rules of interaction with presented to it our own matching load.
You need to
understand at first than speculate how to benefit and progress. Example: https://overunity.com/18992/ionosphere-oscillation-ever-attempted/msg562397/#msg562397
Wesley
I have a question. Assuming there is an artificial source of Zenneck wave somewhere on Earth how to find a place where this wave cannot be detected ? I think it's important to prove all those FE devices are not powered by manmade source
Energii wokół nas jest ogrom tylko nie umiemy jej konwertować do tej na którą się uparliśmy czyli prąd.
Nadal mamy problem ze zamianą ciepła w prąd efektywnie. Lepiej nam wychodzi konwersja pola magnetycznego ale to też nie to jest najważniejsze.
Mamy od dawna panele PV i stawiamy na to. Owszem z teorii fal ze słońca obliczono że 1m2 da kilka kWh z tym że teraz odzyskujemy kilka %.
Szum EM wydaje się być ogromem fal które wystarczy odebrać, przekształcić i wykorzystać. Są projekty takich urządzeń już na poważnie realizowane.
Zastosowanie w telefonach wiecznych. Po części ta technologia już działa w trybie impulsowym dla lokalizacji telefonu nawet jak nie ma baterii ! To jak rfid czy znane PING lub inne określenie lokalizacji.
Wystarczy przecież odbiór kilku../nastu/set/... fal i fazowanie ich aby dostać moc z rozproszonego widma. Jednak czy tu były by kW !? No zakresów jest dużo więc i kW się znajdą ale czy dla każdego ?
Czy 100 osób po 10kW to problem ? nie ale już 100.000.000 po 10kW to chyba tak aby taka technologia zadziałała w tym sensie. Może się mylę.
W końcu Viziv ma to robić tak ?
Technologia dążąca do tego to : Energy Harvesting. VIZIV coś pisali o kryptografi energii a czy to nie było by podobne.
Zatem gdzie są źródła energii? no wszędzie ale to drażniące już bo jesteśmy jak ślepcy którzy co chwila się dowiadują że wystarczy otworzyć oczy.... ale oni nie mogą.
Niedawno pewien facio Chikumbutso zrobił to łącząc fale w jedną poprzez jak to określił skupienie ich. Nie mylić z łączeniem fal !!!
https://www.ic.gc.ca/opic-cipo/cpd/eng/patent/142352/images.html?modificationDate=20130013&page=1&scale=25&rotation=0&englishDocType=Claims&frenchDocType=Revendications&type=basic_search&objectName=CLM&numPages=3&query=142352&start=&num=
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=685958A&KC=A&FT=D&ND=3&date=19011105&DB=&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/biblio?II=101&ND=3&adjacent=true&locale=en_EP&FT=D&date=19011102&CC=GB&NR=190111293A&KC=A
Quote from: lukaszkwiatkowskii on December 24, 2021, 05:37:32 AM
Piszesz o smogu EM wywołanym przez sztuczne nadajniki, a temat i moje pytanie dotyczyło fal z interfejsu Schumanna.
Dla jednych szum jeśli nie widzisz w tym sensu. Jeśli nie umiesz "zdekodować" sygnału to wszystko jest tylko szumem. Amplituda coś wnosi jeśli uznamy, że szum to jakaś wartość odniesienia.
wyjaśnię dokładniej: chodziło o całe tło EM.
Fale Schumanna to echo burz.
Przy okazji: nie ograniczaj się bo nie musisz.
types of surface waves
Wesley
Zenneck Wave can work at any frequency it will have different name and little different technique of excitation.
In regards to
https://www.youtube.com/watch?v=wIIABIU3tRw&t=487s (https://www.youtube.com/watch?v=wIIABIU3tRw&t=487s)
pointed by me in my comment from above.
Group of surface waves includes Zenneck Wave along with other types of "the same" listed.
All of them use INTERFACE but we decided to find by ourselves how Electromagnetic Wave in the Interface
(the Zenneck Wave having now different name )
behaves. We test it with tool below at optical frequency range.
https://accusrc.com/uploads/datasheets/5153_OSA-155.pdf
(https://accusrc.com/uploads/datasheets/5153_OSA-155.pdf)This is a field-ready optical spectrum analyzer offering measurements of wavelength, power, and optical SNR on the different carriers of multiwavelength signals
in the range 1450 to 1650 nm. Internal wavelength reference for high wavelength measurement accuracy. Fast and complete DWDM system analysis .
Easy and intuitive touchscreen operation. Can be powered by AC line, external DC, or internal battery.
Wesley
@Wesley.
Pełna zgoda.
Wesley co do oscylacji w jonosferze, to nie jest tylko kwestia fotonów, to są bardzo złożone interakcje procesów występujących w jonosferze i magnetosferze, polecam prostą i przyjemną lekturę: https://www.mps.mpg.de/phd/theses/spatial-and-temporal-structure-of-alfven-resonator-waves-at-the-terrestrial-plasmapause , oraz trza użyć wujka google i poszukać "Magnetosphere Alfven resonator" , "Ionosphere Alfven Resonator" , to taki prezent na gwiazdkę ;D.
Quote from: kolbacict on January 03, 2022, 04:10:57 AM
Now are we going to expect gold to rise in price?
link to the material in question:
https://news.stanford.edu/2021/12/14/new-materials-deliver-ultrathin-solar-panel/ (https://news.stanford.edu/2021/12/14/new-materials-deliver-ultrathin-solar-panel/)
components of a photosensitive foil:-TMD
tungsten diselenide
-and contacts of gold
-spanned by a layer of conducting graphene
TMD is Transition-metal dichalcogenide and is only 6.5 Å thick.
https://en.wikipedia.org/wiki/Transition_metal_dichalcogenide_monolayers (https://en.wikipedia.org/wiki/Transition_metal_dichalcogenide_monolayers)
tungsten diselenide is:
chem- Se=W=Se (Se symbol of selenium)
https://en.wikipedia.org/wiki/Tungsten_diselenide (https://en.wikipedia.org/wiki/Tungsten_diselenide)
where
W symbol is Wolfram known also as Tungsten
https://en.wikipedia.org/wiki/Tungsten (https://en.wikipedia.org/wiki/Tungsten)
Thickness of the gold contact is expected to be in ~ tens of nm.
One gram of gold can be stretched any where between 2.99 to 3 km approx.=2.1 mile.https://www.quora.com/How-many-km-a-1gm-of-gold-can-be-stretched (https://www.quora.com/How-many-km-a-1gm-of-gold-can-be-stretched)
-so it is unlikely that gold will grow in price because of that
But the energy density or energy per unit is not known to me yet.
More in new post :
Wesley
[quote
]TMDs struggled to turn more than 2 percent of the sunlight they absorb into electricity.
in comparison
silicon solar panels, is in 30 percent of photon to electric energy conversion.
It looks like TMD is as loser.. but....
if 30% is equal to 3 dollar per hour and
if 2% is equal to 0.1 $ than every 10h you gaining 1 dollar. per lighted area in square cm.
Your gain is $0.1 x n( where n is multiplication of square area e.g 1cm
2 of the panel )
Another-words it doesn't matter how much is the gain if all of it is for free after initial cost of the panel assuming its life span to be relatively long .
We don't care how bad is efficiency of solar panel as we don't pay for energy of sun. https://news.stanford.edu/2021/12/14/new-materials-deliver-ultrathin-solar-panel/ (https://news.stanford.edu/2021/12/14/new-materials-deliver-ultrathin-solar-panel/)
QuoteThe array includes the photovoltaic TMD tungsten diselenide and contacts of gold spanned by a layer of conducting graphene that
is just a single atom thick. All that is sandwiched between a flexible, skin-like polymer and an anti-reflective coating that improves the absorption of light.
QuoteWhen fully assembled, the TMD cells are less than six microns thick – about that of a lightweight office trash bag.
What is good: ?
QuoteThis research was funded by the Stanford SystemX Alliance (https://systemx.stanford.edu/), the Swiss National Science Foundation,
the Beijing Institute of Collaborative Innovation, the U.S. National Science Foundation and
the U.S. Department of Energy.
Saraswat is the Rickey/Nielsen Professor in Stanford's School of Engineering and an affiliated faculty
member of Stanford's Precourt Institute for Energy (https://energy.stanford.edu/).
___________________________________________________________________________
Viziv technology was also not a secret but..
Wesley
What does the abbreviation "E X S" mean for a car? :)
Quote from: justawatt on January 10, 2022, 11:37:14 AM
Hi
Does anyone have the photo of this in Hd which akula shared.
I have seen it here but cannot find it
https://youtu.be/H_iEE5HfEB4 (https://youtu.be/H_iEE5HfEB4)
Colour if have it please post it here
The video was made in GermanyColor is copying whatever he can just to be able to snick his Korean content without attention of moderators.
This was in Germany
in
Quotetiger 9:11 PM
2013 осень
fall (autumn) of 2013
Tiger Vitaly from Kazakhstan was brought there to help Akula, as he couldn't perform there .
The place of test was штудгард Stuttgart near Hamburg.
This is Tiger comment from 1 minute ago.
Quotetiger, 9:06 PM
да 20 ватт энергосберегайка , да к тому же горели от поля ( подключения там не было , просто провод под изолентой ) именно тогда мы заподозрили что это фейк .
yes 20W energo-sucker, and was giving light from the field, there was no connection ( to anything)
wire simply was under insulation,( second meaning of "провод под изолентой" can be translated : was having isolation ) exactly at that moment we started to suspect the fake
have you been there Tiger ?
Quotetiger, 9:13 PM
да
я был в другой лаборатории , не у Артура
I was in the lab not at Artur Stefanov place.
so he didn't see the test but Tiger suspected a fake.
To understand it better you need to know position of each player .
at first Stefanov -Russian contacted me in 2012 asking me to go with him to Hamburg for the show.
I refused.
Than Stefanov met German investor at the show.
At the same time Akula from Kazakhstan made videos.
Investor found about videos and wanted Stefanov to give him similar device.
In fear of losing the opportunity Stefanov went to Akula in Kazakhstan but to make sure that Akula's device is legit , he hired Tiger from Kazakhstan to examine Akula's device.
Tiger concluded that Akula's device is working as self powered.
All of it was to do not lose German investor money.
Stefanov went to Germany with Tiger they were working in the lab.
Akula was working in different place .
I assume but I didn't ask Tiger - that tiger was carousing between these two.
I assume that German Investor created some kind of competition:
- who will deliver that one will get money.
Wesley
Adrian Guska Death, Смерть Адриана Гуски, «Денис Днестр» How to make FE
https://youtu.be/_9foRzZEZRo
(https://youtu.be/_9foRzZEZRo)
Wesley
In Western countries, democratic countries where human rights are respected, which I have no doubt, a person, especially a new one, is identified by what is written in his document.
It's just a pathetic piece of paper. But not what he really is.
How then are you different from us?
Problem w tym aby potwierdzić swój wiek to trzeba przesłać zdjęcie dowodu osobistego lub innego dokumentu, tak na prawdę nie wiadomo komu i kto dokładnie będzie sprawdzał i wykorzystywał moje dane, więc nigdy nie posunę się do takiego kroku.
A co do rdzenia cewki odchylania to różnice dużą robi pole powierzchni poprzecznej rdzenia, co do składu to proszek ferrytowy o im mniejszej gradacji tym lepiej, np.: rdzenie z dawnych telewizorów Sony są znacznie lepsze od rubina.
Macie tu trochę fimików na temat https://www.youtube.com/playlist?list=PLhsaWT9VFiCayFMMtcl0-wTyRClcDpyD-
a jakby ktoś miał filmiki Nelsona Rocha to prosiłbym zapodać
Najłatwiej poszukać w google - video "Nelson Rocha free energy"
https://www.google.com/search?q=nelson+rocha+free+energy&client=firefox-b&source=lnms&tbm=vid&sa=X&ved=2ahUKEwjyo-yt4b31AhUCmIsKHa63CI8Q_AUoAXoECAEQAw&biw=1600&bih=742&dpr=1
Ale co wynika ze schematu to jest samodławny generator impulsów prawie-szpilkowych.
Gdybym znalazł przez google to bym nie prosił o kopie. Tych filmików było trochę więcej i jeden dotyczył prostego układu generującego radialną elektryczność , schemat jest w internecie ale z filmiku zostało tylko kilka zrzutów ekranu. Tutaj próba odtworzenia tego układu:
https://www.youtube.com/watch?v=m6lmd0HKxOw
IMHO "radialną elektryczność" to brzmi tak bardzo ezoterycznie i marketingowo jednocześnie, a poza tym jak pisałem to jest generator impulsów prawie-szpilkowych.
V(n002) - sygnał przed L3, V(n002) - sygnał po L3.
radiant energy - fakt, można też przetłumaczyć jako elektryczność promienista
"radiant energy" - to też nazwa ezoteryczno-maketingowa, stosowana po to aby dany prawie-wynalazca mógł na tym zarobić, to tak jak "quantum", tyle że rzeczywisty efekt całości to tylko placebo.
How much energy can be extracted from Schumann waveguide using described by Dr Corum interface and Wesley's method of energy extraction :
Let us take look at first at how much energy is available.
How much energy is released a year of all the lightning on earth?
About 100 bolts of lightning hit the Earth every second (http://environment.nationalgeographic.com/environment/natural-disasters/lightning-profile/) and they average about a billion joules of energy be bolt (http://www.realclearscience.com/blog/2012/05/could-we-harness-lightning-as-an-energy-source.html).
That's 3.1 billion lightning strikes per year, coming to about 3.1 billion billion joules per year, or about 860 billion kilowatt-hours (kwh) of electrical energy per year.
That estimate is pretty rough as some estimates have as much as 5 billion joules per bolt of lightning, pushing it up over 4 trillion kwh/year.
https://earthscience.stackexchange.com/questions/8249/how-much-energy-is-released-a-year-of-all-the-lightning-on-earth (https://earthscience.stackexchange.com/questions/8249/how-much-energy-is-released-a-year-of-all-the-lightning-on-earth)
Wesley
Quote from: lukaszkwiatkowskii on January 17, 2022, 04:21:22 AM
Regarding the deflection yoke, the cross sectional area of the core makes a big difference and as far as the composition goes, the finer the ferrite powder, the better, e.g. the cores from past Sony TC sets are much better than from Rubin.
It depends on what you mean by "better", e.g.: saturation level, permeability, AL value, remanence/hysteresis losses at certain frequency.
The aforementioned parameters might be better for a core used in a switching power supply, but could be considered secondary in a device taking advantage of such phenomena as NAR or NMR device where the skin depth and isotopic composition are the primary parameters of concern.
Quote from: stivep on January 29, 2022, 02:51:44 PM
Wesley
hi Wesley,
I have attached something of value in your area of interest regarding transfer of power -
Transference of Electric Power - Single Wire vs Telluric Part 1https://www.youtube.com/watch?v=Je63-2D5bf4 (https://www.youtube.com/watch?v=Je63-2D5bf4)
Telluric Transference of Electric Power - MF Band 2 8 Mileshttps://www.youtube.com/watch?v=25C-bHBdF34 (https://www.youtube.com/watch?v=25C-bHBdF34)
Do check his other videos on how he used network vector analyzer to optimize tesla coil...
I have not forgotten on why you have expanded your laboratory in the first place after observing/touching Tariel Kapanadze device...
If i recalled correctly from past message regarding some device which was presented to Tariel which likely have abnormality symptom likely after powering down device.
If Tariel is/was a electrician then he would already know the
3rd harmonics is a more dominant issue in a electrical system than any other harmonics.Please do consider the possibilities.... :D
Gradacja proszku (nie wiem jak dokładnie po angielsku, dosłownie to powder gradation)- średnia wielkość ziaren proszku całości.
Ziarnistość (granularity)- wielkość ziaren na jednostkę powierzchni.
Myślałem bardziej o zastosowaniu takim jak w urządzeniu Akuli, co do pomiarów to porównanie histerezy i krzywych strat między rdzeniami cewek odchylania z tv rubin a sony.
Co do wykresów mimo tego że sondę zrobiłeś bardziej o statycznej pojemności to wzbudzenie rdzenia występuje przy dynamicznej reaktancji indukcyjnej.
Quote from: lukaszkwiatkowskii on February 01, 2022, 08:16:03 AM
...direct translation is powder gradation - the average size of the grains in its entirety.
"the average size of the grains" is understandable to me.
Please avoid using the word "gradation" in this context, because in English this word does not have the same meaning as in your language. In English it means "stopniowanie", which when combined with "powder" yields a monstrosity like: "stopniowanie proszku".
Granularity - the size of grains per unit of area.
That makes no physical sense.
Did you mean to write: "Granularity - the amount of grains in one layer per unit of area" ?
I was rather thinking about an application in a device like the Akula's
Does this device behave like a classical transformer ?
as far as the measurement go, it is the comparison of the BH hysteresis curves and hysteresis losses between Rubin and Sony TV yokes.
This has already been done on another forum and has a high yawn factor in application to unconventional devices.
Regarding the graphs, despite that you made the probe capacitive, the excitation of the core occurs with the dynamic inductive reactance.
I do not know why you added the word "dynamic" to "inductive reactance" as the latter does not occur at all in non-dynamic situations, like with direct current.
Anyway, further experiments illustrate that the capacitive characteristics of this core also depend on the circumferential magnetization of this material performed by a toroidal winding placed far away on the other half of this core (generating 225 Ampturns of MMF).
The frequencies of some peaks become shifted up and their amplitude increases in the magnetized state.
From these experiments it is evident that the core's material can be polarized either by magnetic flux or by electric flux and that there is a definite interaction between them in the core.
IMO such measurements have a lower yawn factor than the BH curve measurements of conventional transformers and are more applicable to an unconventional device like the one depicted in this video (https://youtu.be/gbeseiPPCeM?t=192)
P.S.
I could post S21 graphs which illustrate this shift but I will not because this forum's software is annoying as it gives me no control over the size of displayed images and insists on displaying their full width, which stretches the entire page and makes this thread unreadable on small, low resolution monitors. Other SMF forums do not have this problem.
I expect that soon someone will start bitching about it and advise me to resize my images, which I will not do in order not to lose details contained within them and then an all too familiar discussion will ensue about whether it is the job of the forum's software to resize and display thumbnails of posted images ...or the poster's. Are you reading this Stefan ?!
Quote from: lukaszkwiatkowskii on February 02, 2022, 03:22:47 AM
This schematic https://overunity.com/14734/akula-1-kwatt-free-energy-generator/msg408461/#msg408461 (https://overunity.com/14734/akula-1-kwatt-free-energy-generator/msg408461/#msg408461), besides this it is easy to surmise what is conventional, meaning everything except the "perverted transformer (coil if you will)".
You assume too much.
See this thread (https://www.overunityresearch.com/index.php?topic=3926.msg90802#msg90802) for illustration.
There are links to many videos in that thread, too. I think this video (https://youtu.be/vykb0XXSQe4) is the first one.
P.S.
Akula = Shark
few things to know:
- Veripes is a scientist.
I do take his opinion very much as facts.
I was not here for some time but I'm back.
In the meantime "
-the icon of FE Eric Dollard published the article and the video.
I have respect to the guy but I don't always agree with his findings.
or to be more exact I mostly disagree with him.
here is article :
https://emediapress.com/2022/02/16/self-sustaining-charge-in-electrostatic-rotary-converter-built-by-chris-carson/ (https://emediapress.com/2022/02/16/self-sustaining-charge-in-electrostatic-rotary-converter-built-by-chris-carson/)
here is his video:
https://www.youtube.com/watch?v=AJwD23PEL9Q&t=517s (https://www.youtube.com/watch?v=AJwD23PEL9Q&t=517s)
The video talks about :
Chris Carson's rotating capacitor
Chris is one of guys from team of :
Peter Lindemann and Eric Dollard casually discuss the possibilities of Chris Carson's rotating capacitor
https://www.youtube.com/watch?v=F6K-fZAXT_A
Additional character here is one of uncle of former president Trump the
John. G Trump
https://en.wikipedia.org/wiki/John_G._Trump (https://en.wikipedia.org/wiki/John_G._Trump)
Eric Dollard talks about his article:
-Electrostatic sources of electric power
Published 1 June 1947
Physics
Electrical Engineering
John G.Trump is also known from other articles: https://academictree.org/physics/publications.php?pid=215319 (https://academictree.org/physics/publications.php?pid=215319)
So Eric Dollard is testing device that was build in 2022 by Chris Carlson based on article of John G Trump from 1947 and patented by
Inventor Onezime P. Breaux (https://patents.google.com/?inventor=Onezime+P.+Breaux) in 1978
https://patents.google.com/?inventor=Onezime+P.+Breaux (https://patents.google.com/?inventor=Onezime+P.+Breaux)
It is just 5kHz HV generator that is turning two capacitors connected into one shaft in such a way that one capacitor is
at its max when the other is in its minimum - and in process of rotation it is "compensating" the change of capacitive reactance
-in another words the only rapid change takes place in that fraction of the second when the rotating butterfly plate approaches the very edge of the fixed plate of the same capacitor.
I have problem with application of this particular physical copy of energy conversion shown on the video.
- but this is my opinion.
note: this was also discussed here : http://www.energeticforum.com/forum/energetic-forum-discussion/renewable- (http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-)
energy/14635-rotary-electrostatic-converter-by-chris-carson
Wesley
Quote from: stivep on March 02, 2022, 09:24:18 PM
few things to know:
In the meantime "
here is article :
here is his video:
https://www.youtube.com/watch?v=F6K-fZAXT_A (https://www.youtube.com/watch?v=F6K-fZAXT_A)
John. G Trump
Physics
Wesley
hi stivep,
Interesting i have seen this video with fav entertainer Eric Dollard just few weeks back.The video is like a 3D version of wimshurst generator with the usual "dielectric plates".
Regarding electrostatic to low voltage electricity i have seen few years ago-
Tesla coil "the true secret" how it was really used.
https://www.youtube.com/watch?v=qwVOp-HPIVE (https://www.youtube.com/watch?v=qwVOp-HPIVE)
how to make a electrostatic step-down transformer, part 2, ampere test, Wimshurst to low volt DC
https://www.youtube.com/watch?v=g6ipm6r7h-Y (https://www.youtube.com/watch?v=g6ipm6r7h-Y)
Back to kapanadze topic/hint-
If "resistance"
oppose the flow of electrons.
What do you think "
negative resistance" created by counter-clock wise turns after the 2nd layer of 48turns kapanadze winding would do?
Oppose or Accelerate the flow of Electrons :D
Strangely i have done a elementary experiment to test "
negative resistance" (by accident)during research of don-smith long before i lay my eyes on kapanadze topic.
I wound 10 turns of 2 similar coils(Multi strand electrical wire) base on my memory gave resistance around 0.4Ohms ea from 2 similar windings.
If you connect both windings to form one continuous winding with the assistance of croc-clip in the middle to llnk the 2 windings.The resistance in series would be expected to be around 0.8Ohms...0.9Ohms either way.
The fun part if i connect one of winding in a counter clockwise direction and link with a croc-clip in the middle.The multi-meter reveal
0.4Ohms again either way.Take note during resistance measurement
DMM does produce voltage at probe and yet resistance reading is around half of 0.9Ohms.
The experiment did defy the logic/norm which was taught in school-The resistance of a wire is directly proportional to its length of wire.
Thomas E. Bearden December 17, 1930 - February 03, 2022
At the request of Tom's daughter, Dana Bearden, we wanted to inform you of his passing:
https://www.berryhillfh.com/obituary/thomas-tom-bearden
(https://www.berryhillfh.com/obituary/thomas-tom-bearden) he was lone wolf however cooperating with Free Energy Research with Eric Dollard, Peter Lindemann and Thomas Brown
Ph.D., nuclear engineer, retired Lieutenant Colonel, CEO of CTEC, Inc.,
Director of the Association of Distinguished American Scientists, and Fellow Emeritus of the Alpha Foundation's Institute for Advanced Study.
Tom is a theoretical conceptualist active in the study of scalar electromagnetics, advanced electrodynamics, unified field theory, KGB energetics
weapons and phenomena, free energy systems, electromagnetic healing via the unified field action of extended
Sachs-Evans electrodynamics, and human development. Particularly known for his work establishing a theory of
overunity electrical power systems, scalar electromagnetic weapons, energetics weapons, and the use of time-as-energy in both power systems and the mind-body interaction.
More information on these topics can be found on Tom's website: www.cheniere.org, and DVD's on
Tom's work can be found at www.energyforthevacuum.com
Wesley
Holcolmb energy systems
https://www.newpowerprogress.com/news/holcomb-scientific-research-harnesses-electron-spin-to-deliver-power/8018093.article (https://www.newpowerprogress.com/news/holcomb-scientific-research-harnesses-electron-spin-to-deliver-power/8018093.article)
https://m.youtube.com/watch?v=vUIK1GZSduo&feature=youtu.be (https://m.youtube.com/watch?v=vUIK1GZSduo&feature=youtu.be)
Mr Holcomb's patents https://patents.justia.com/inventor/robert-ray-holcomb (https://patents.justia.com/inventor/robert-ray-holcomb)
So it begins
(How's it do what it do ...Where is the energy coming from ??)
Respectfully submitted
Chet K
Quote from: ramset on March 14, 2022, 07:03:56 AM
So it begins
Chet K
hi ramset,
Interesting link and they used words like
'Electron spin' and then few sentences later i captured this word in my head
'significantly magnifies power output'So it looks like different people or experts have different way to represent somewhat similar idea. ;D
We humans do indeed think alike at times although we view or do thing differently.In my rather "recent" video in youtube :) i did talk about singing bowl where we apply ""non-rigid"" slow hand or tool movement in order to achieve higher frequency sound from the singing bowl.Quartz singing bowl Eg:https://youtu.be/PQGisaMbw94?t=63 (https://youtu.be/PQGisaMbw94?t=63)Many members in forum were deceived by older Ruslan video where he applied resonance "i used the word rigid" such that frequency in is the same as the frequency output.No different from a step up power supply.I dabbled with 3rd harmonics to fine tune the system and i also applied 3rd sub-harmonics which you need hv source from tesla coil.Another hint about 3rd sub-harmonics used by Akula is merely comparing which of 4017 divider setting produce the exact on/off period.If anyone ever played with 4017 years ago may know that each divider setting do not give 50% on/off duty.
The HV high frequency interrupter is another key to accelerate the electrons under 3rd sub-harmonics.The HV can't be too high or too low. ;D ;D ;D
Good Luck.I have explained in the most layman term. :o
No more hints from here...
Hi If you want to divide by 1.5 50/50 you can do it with a 4076 on the input and feed back
2 4013 / divided by 2 the second devides the modified output of the 4086 from 3 to 1.5
producing 1.5 50/50 the first 4013 needs to be fed back into the 2nd input of the 4076.
Clear as mud ;)
To Divide by 3 =you would need 3 4013 and some multi input gating feed back chips
Sil
When we talk about harmonics, first consider one fundamental question.
How come that systems resonate at second harmonic.
Second harmonic is amplifying the resonant oscillation 1/2 of the time
and diminishing it other 1/2 of the time
That is a literal equivalent of pushing a swing and as it reaches half way
push it in the opposite direction with same force.
I gotta add, obviously, there are many types of resonance, namely
mechanical
acoustic
electromagnetic
nuclear magnetic (NMR)
electron spin (ESR)
quantum wave functions
For acoustic resonance, resonance at harmonics makes sense as waves are nicely packed so that end nodes/antinodes (whether it's open tube or closed on one end) align with the physical dimensions of the tube.
For LC tank as far as i know they do not resonate at harmonics (series lc behaving inductively above res freq and cap below and parallel lc inversely) so that's fine.
For mechanical systems like a swing, they clearly cannot oscillate at second harmonic.
So it begins
Chet K
the problem with extraordinary claims is that they must be proven.The literature that is provided as well as the information about the technology is insufficient to evaluate the technology.There is no such thing as less energy In then energy Out.Small amount of energy delivered may trigger energy conversion that is using yet another source of energy.for our eyes it will be an illusion of energy magnification as we don't know about that secondary source of energy.if that energy source is paid by somebody else or by nature then we have free energy.
Quote from: magpwr on March 14, 2022, 10:13:49 AM
'Electron spin' and then few sentences later i captured this word in my head 'significantly magnifies power output'S ;D ;D ;D
/electron-spin-resonance#: (https://www.sciencedirect.com/topics/medicine-and-dentistry/electron-spin-resonance#:~:text=Electron%20spin%20resonance%20%28ESR%29%20is%20a%20spectroscopic%20technique,in%20the%20presence%20of%20a%20static%20magnetic%20field.)
Quote from: nix85 on March 22, 2022, 12:29:35 AM
mechanical
acoustic
electromagnetic
electron spin (ESR)
I may have enough of time to get into a more deep and explain how the system works.
Wesley
Quote from: stivep on April 11, 2022, 10:45:10 PM
---------------------------------------------------/electron-spin-resonance#: (https://www.sciencedirect.com/topics/medicine-and-dentistry/electron-spin-resonance#:~:text=Electron%20spin%20resonance%20%28ESR%29%20is%20a%20spectroscopic%20technique,in%20the%20presence%20of%20a%20static%20magnetic%20field.)
Wesley
Wesley, explaining in a kind of
https://m.youtube.com/watch?v=nfFnbBUkxes (https://m.youtube.com/watch?v=nfFnbBUkxes)
and
https://www.google.com/search?client=firefox-b-m&q=QED+hyperphysics&oq=QED+hyperphysics&aqs=heirloom-srp (https://www.google.com/search?client=firefox-b-m&q=QED+hyperphysics&oq=QED+hyperphysics&aqs=heirloom-srp)..
either
https://www.google.com/search?q=QCD+hyperphysics&ie=utf-8&oe=utf-8&client=firefox-b-m (https://www.google.com/search?q=QCD+hyperphysics&ie=utf-8&oe=utf-8&client=firefox-b-m)
conjunction ?
https://www.google.com/search?client=firefox-b-m&q=em+spectrum&oq=em+spectrum&aqs=heirloom-srp..0l5 (https://www.google.com/search?client=firefox-b-m&q=em+spectrum&oq=em+spectrum&aqs=heirloom-srp..0l5)
to
https://www.google.com/search?client=firefox-b-m&q=emg+spectrum&oq=emg+spectrum&aqs=heirloom-srp..0l3 (https://www.google.com/search?client=firefox-b-m&q=emg+spectrum&oq=emg+spectrum&aqs=heirloom-srp..0l3)
https://www.google.com/search?q=spectralanalytik&ie=utf-8&oe=utf-8&client=firefox-b-m (https://www.google.com/search?q=spectralanalytik&ie=utf-8&oe=utf-8&client=firefox-b-m)
Experimentell - physisch matematisch-theoretisch hypo-/paren-/anti-These,Axiom
Algometrie-lAlgorythmic-Resultat /Human-Resultat : identical ?
Algology ,the study of pain ,the being as " human"/the being as "man"
wmbr
OCWL
p.s.: life-style kind and expectation ,perspective :
https://science.orf.at/stories/3212502/?utm_source=pocket-newtab-global-de-DE
https://m.youtube.com/watch?v=YrJs9OqPndI
Mf = shortly for :
" Mit freundlichem ...." ,Automat translation "Kind ...." Kind : polite,friendly,childly ::) ( Spiel-Kind im Manne)
https://www.kindergesundheit-info.de/themen/spielen/hauptsache-spielen/
Wer nicht spielt der lebt ohne Vergnuegen ,bei E- und U- Musen
Quote from: nix85 on March 15, 2022, 04:59:28 PM
Re MR Nix85 your post on the overtone freq and wave length's
So if we have a Katcher of 1.8mhz (for the sake of argument) witch way in 'F' do you think we are going
to hit the Grenade coil in frequency and why ?
Sil
Quoteto hit the Grenade coil in frequency and why ?
I don't know.
What is your voltage between the zero of the home electrical network and grounding?
I measure very little now, about three volts.
There used to be more.
Quote from: kolbacict on April 14, 2022, 11:24:01 AM
I don't know.
Do you know the correct lingo for your question home electrics ? are you asking me the differance between the potential of the nutral and earth of the off grid power return ?
No idea i dont mess with the mains it can fry your insides it's best left alone.
Sil
Analysis PART 1Quotehttps://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg565633/#msg565633 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg565633/#msg565633)
I may have a time to explain how it works,the logical path of analysis starts when we are looking at patents of
Inventor: Robert Ray Holcomb.
https://patents.justia.com/inventor/robert-ray-holcomb (https://patents.justia.com/inventor/robert-ray-holcomb).
We see
-14 recorded patents and applications.
where we exclude:
Patent number: 6776753
Patent number: 7399270
as related to pain treatment/
Patent number: 10008916 is a
Type: Grant
High efficiency AC DC electric motor, electric power generating system with variable speed, variable power, geometric isolation and high efficiency conducting elements
(https://patents.justia.com/patent/10008916)-
Filed: May 21, 2013
Date of Patent: June 26, 2018
Assignee: Redemptive Technologies Ltd Inventor: Robert Ray Holcomb
Patent number: 11196331
Compact high-efficiency, low-reverse torque electric power generator driven by a high efficiency electric drive motor (https://patents.justia.com/patent/11196331)
Type: Grant
Filed: December 21, 2017
Date of Patent: December 7, 2021
the rest of records are just patent applications.we also see that first patent
Filed: May 21, 2013
Date of Patent: June 26, 2018 belongs still to Redemptive Technologies Ltd
link: REDEMPTIVE TECHNOLOGIES LIMITED | ICIJ Offshore ... (https://offshoreleaks.icij.org/nodes/10207308)https://offshoreleaks.icij.org/nodes/10207308 (https://offshoreleaks.icij.org/nodes/10207308)
turns out with error, so we can't claim that we are dealing with company
known from affair of Panama papers money-laundering and unproven financial crime operations.
https://en.wikipedia.org/wiki/Panama_Papers (https://en.wikipedia.org/wiki/Panama_Papers)
however we are sure that
in its history shows:
U.S. Patent Documents
| U.S. Patent Documents | 10008916 (https://patents.justia.com/patent/10008916) | June 26, 2018 | Holcomb | | 20030025420 (https://patents.justia.com/patent/20030025420) | February 6, 2003 | Noble | | 20120206002 (https://patents.justia.com/patent/20120206002) | August 16, 2012 | Holcomb | | 20120206003 (https://patents.justia.com/patent/20120206003) | August 16, 2012 | Holcomb | | 20130002077 (https://patents.justia.com/patent/20130002077) | January 3, 2013 | Conde Mendez | | 20190393765 (https://patents.justia.com/patent/20190393765) | December 26, 2019 | Holcomb |
different last names , where one of them is
-Noble
and another is
Wesley
Analysis PART 2
analysis of YouTube channel
Holcomb Energy Systems (https://www.youtube.com/channel/UCUi_RHRrr80Dsa4cnUJlTAw) 342 subscribers
YouTube channel was created
Joined Jan 31, 2022
8 videos.
description:
Holcomb Scientific Research Ltd is a Dublin, Ireland-based research and development company
setting a new industry standard in electric power generation.
The Holcomb Energy System is solid-state, point of use, and requires no fuel.
It is far more affordable than any form of electric power available today
and it puts out no harmful emissions – just 100% clean power.
recognized and supported by: Dr. Jan Wulff Interview Holistic Health medical doctor, from our Global Launch Party.
https://www.youtube.com/watch?v=aAzahOni1n0 (https://www.youtube.com/watch?v=aAzahOni1n0)
for me it looks like set of commercial videos having elements of green movement, suffering nature, climate change and proposition of inventor own solution into those problems.
At best of my understanding his videos states that you still need a power source from which you can gain at least 50% of power out.
Wesley
please start reading from part number one
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg565761/#msg565761 (https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg565761/#msg565761)
Analysis PART 3
logical conclusions from listed patents of Inventor: Robert Ray Holcomb
High efficiency AC DC electric motor, electric power generating system with variable speed, variable power, geometric isolation and high efficiency conducting elements (https://patents.justia.com/patent/10008916)Patent number: 10008916
Type: Grant Filed: May 21, 2013 Date of Patent: June 26, 2018 Assignee: Redemptive Technologies Ltd Inventor: Robert Ray Holcomb
was the base for any further activity.
I suggest to start analyzing this patent first.
Compact high-efficiency, low-reverse torque electric power generator driven by a high efficiency electric drive motor (https://patents.justia.com/patent/11196331) Patent number: 11196331
Type: Grant Filed: December 21, 2017 Date of Patent: December 7, 2021 Inventor: Robert Ray Holcomb
this patent says that some sort of generator is driven by some sort of electric motor.
conclusion:
inventor was trying different approaches.
one of them was:
TURBOFAN JET ENGINE, POWERED BY AN ELECTRIC MOTOR WITH POWER FROM A HIGH EFFICIENCY ELECTRIC GENERATOR (https://patents.justia.com/patent/20200052570) Publication number: 20200052570
but all of them or most of them are in or about rotary motion, however extraordinary claims shown on his video channels shows only Stater without the rotor and that is enough to do the trick,
For your own analysis of inventor patents and applications please go to
Patents by Inventor Robert Ray Holcomb
Wesley
Quote from: AlienGrey on April 15, 2022, 04:45:48 PM
the differance between the potential of the nutral and earth ?
Exactly. Only no disconnection from the power grid. All with the usual standard connection.
You know that there is always a difference in a somewhat volt . Power grids is not ideal.
If you're lucky,you can make a hundred watts from there . :)
Analysis PART 4
logical conclusions from listed patents of Inventor section number two: Robert Ray Holcomb
I'm working on it
To jest patent prostszy konstrukcyjnie w stosunku do innych jego konstrukcji.
https://patents.google.com/patent/US20050087989A1
Quote from: lukaszkwiatkowskii on April 17, 2022, 11:24:15 AM
https://patents.google.com/patent/US20050087989A1 (https://patents.google.com/patent/US20050087989A1)
Application US10/694,326
events
2003-10-27Application filed by Robert Holcomb
2003-10-27 Priority to US10/694,3262005-02-22 Assigned to HOLCOMB HEALTHCARE SERVICES, LLC
2005-04-28Publication of US20050087989A12005-09-12 Assigned to HOLCOMB HEALTHCARE SERVICES, LLC
2008-03-21Assigned to DEMETER SYSTEMS, LLC
Status Abandoned
The more I dig into this inventor activity the more I have problems with his publications and its value.One of the links although inactive shows possible connection with a "fear" of Panama papers.
One related patent
And the rest of his other publications are just the applications.
Wesley
How can I find this Anzor?
I hope he is alive and well.
https://patentdb.ru/author/1090142 (https://patentdb.ru/author/1090142)
Quote from: mkjekyll on May 13, 2022, 05:40:38 AM
I trust you are doing well and enjoying your microscopes.
not that well but well enough.
some small things. One of them uses Ln2
for that there is a Ln2 farm and inconvenience of Dewar ( A cryogenic storage dewar )
In your Kapanadze forum there used to be a section explaining the magnetic device
a man made that uses a frame for inducing magnetic flux circuit from two permanent magnets and modulating giant magnetostrictive medium as to field switch between magnets.
https://www.youtube.com/watch?v=DNxob3yY4LE (https://www.youtube.com/watch?v=DNxob3yY4LE)
Ted Annis
I'm mentioning The mechanical device of
Aldo Costa https://www.wired.com/2004/12/reinventing-the-wheel/ (https://www.wired.com/2004/12/reinventing-the-wheel/)
https://www.youtube.com/watch?v=rsBplmMDcRQ (https://www.youtube.com/watch?v=rsBplmMDcRQ)
as an example of failure of concept.
Perpetual motion doesn't exist and it consumes all energy in the system plus losses.
The failure is in application.
Wesley
Or perhaps it's more a case of the exploit of energy in metalic wast like aluminium and or brass
both TK device and SM used them both all you aparantly have to do is break it down with magnetic impulses.
Re http://www.youtube.com/watch?v=rbkvXoDfk7g.
Sil
Re: Local Hidden Variables - For the Win? Not 101st bad idea? (https://overunity.com/19139/local-hidden-variables-for-the-win-not-101st-bad-idea/msg567890/#msg567890) « Reply #6 on: Today at 03:26:14 AM
I did respond . Look at the link attached.
You made few comments in different topics.
I admit that this response of mine is made without reading your comment from above ( as I'm preoccupied with other tasks)
I do apologize for it
Wesley
Quote from: mkjekyll on June 13, 2022, 02:39:10 PM
The Schumann waveguide concept... I am // a bit concerned about lightening.
With your waveguide coupling experiments, have you had any issues with lightening or emp events?
I assume that you were talking about was lightning.
And you were also talking about EMP.
________________________________________as far as lightning- it is just an element in energy extraction from Schumann waveguide.
This requires little explanation:
Technology of Dr. James Corum is about sending energy from point A to point B using earth/air interface.
So does Tesla coil with properly adjusted height of top capacitor, till it tunes into complex Brewster angle.
Note:
Complex Brewster angle.- is not just a Brewster angle alone - it is complex phenomena based on Brewster angle.
resulting electromagnetic energy from Tesla tower to tilt towards the earth/air interface where this wave is trapped
without reflection and refraction .
Although that interface is two-dimensional for our eyes, it acts as a waveguide for electromagnetic wave.
Inverse square law doesn't apply to waveguides, nor to it's special form the interface.Electromagnetic wave at any frequency theoretically will always fall into the interface under special condition:
the
Complex Brewster Angle.
Forming conditions suitable for complex Brewster angle is however little different for low and high very high frequencies
We are operating at very low frequencies known as VLF.
it is much easier to work with them.
Then that wave has different names and we can name it
surface plasmon polariton,but that still will be the same Zenneck wave
https://www.youtube.com/watch?v=wIIABIU3tRw&t=372s (https://www.youtube.com/watch?v=wIIABIU3tRw&t=372s)
________________________________________method of extracting energy from Schumann Waveguide is exactly the same as sending energy from point A to point B
the only difference is that we don't have a transmitter that is transmitting energy.
We only have receiver.
The receiver is exactly the same as the one used by Dr. James Corum,
and this is exactly the same Tesla tower.
The only difference is progress of operation. Means number winds of the Tesla coil and the elevation of top capacitor.
for lighting we have certain probability that the electromagnetic wave
by lightning hits the interface and the Complex Brewster Angle.
We have 1.4 billion flashes per year.
most of them deposits its energy into the earth
Earth is one of components of the earth/air interface.
It is not important where on the earth the lightning hits.
-one lightning creates avalanche of lightning around the globe.But all of those lightnings hits the interface.
Inverse square law doesn't apply to waveguides and frequencies are extremely low.
Humanity didn't know it because it's a dynamic structure and to know that this energy is there you need the receiver.
The bird sitting on the high-voltage line doesn't know that it may become a receiver if it spreads the legs far enough.
Before Marconi people didn't know that they can receive electromagnetic energy .
Wesley
The Schumann waveguide//experiments, have you had any issues with emp ?
Quote from: stivep on June 16, 2022, 05:10:18 PM
I assume you are talking about EMP.
Wesley
it was not an issues it was an application.
If you look at it Dr. (James Corum structure) we see points A and B.In the James Corum application
– A is our TX
– B is our RX
both of them are identical.
But this identity is seen not by the RX physical look but by the RX matching electrical property of TX.
So for easiness we are scanning with portable TX some structure!!!!!!!!!!!!! :)
until we see that this structure is matching a condition for becoming RX.
Then we doing some additional tuning.
and now you're ready - we are sending
EMP______________________________________________
the structure doesn't have to be a tower, or building, it can be
for example big heavy vehicle
on tracks or some sort of vehicle (if we have tires than tires separates the two plates of capacitor)
the top plate ( vehicle body) and the ground. :) However than you need more juice from TX
or group of vehicles
on tracks but unfortunately at its present form during the process of
"chewing" <it> cannot move
yes it can be a plant, storage, Arsenal, armory, storing
"metal cylinders or cylindrical objects " ,of some sort.
some specialized electronic igniters are tragically sensitive to EMP.
but it is not EMP that caught my attention rather that
it is high-voltage at RX.think of it as a coil that has inductive reactance but is ended with top plate that is on the top that is capacitively interacting
with respect to the - ground constituting second plate, in this dynamic system (and as I said RX TX is a dynamic pair) the true nature of C
can be seen in Smith chart.
Wesley
Question for connoisseurs. Oscillograms at the terminals of the motors. The motor is connected to a power source through 40 ohms, the voltage in both cases is 5 volts. The engine is from the VM12 video recorder
makes by eye, ten times more revolutions than from VCR Electronics508. The oscillograms were taken with the same sweep time.
Which motor has more poles?
It would appear the top oscillogram has more poles even though the bottom seems to have slight more compressions and rarefactions per the grid. The top has some cancellation from the sweep resonance so could have a harmonic multiple more poles.
Just a guess anyways...
Wesley,
My question is with the deep dive you have made into the Schumann wave guide transmission and harvesting, have you had any serious overvoltage/current events from drawing too fast such as a lightening strike?
Thanks,
Mick
Hello friends!
Why have they forgotten what Tariel Kapanadze himself said?
Why did they forget about cylinders and pressure gauges in his various videos?
2 times Kapanadze pointed out that this effect was found in the study of the effects of gravity, antigravity.
1.
https://www.youtube.com/watch?v=xplzL0cpKz4 (https://www.youtube.com/watch?v=xplzL0cpKz4)
https://en.wikipedia.org/wiki/Gear_pump (https://en.wikipedia.org/wiki/Gear_pump)
2.
https://youtu.be/eF0nQTXSJh8?t=85 (https://youtu.be/eF0nQTXSJh8?t=85)
"How did you yourself come to this discovery?
- To be honest, we worked on a different topic.
This happened by accident?
- Yes, it happened quite by accident. We were working on anti-gravity. And there was such an effect that we were very surprised.
Fraudster Kapanadze rotated the flywheel with a hydraulic motor, do you think? >:(
Hello!
Why "fraudster"?
Energy is produced by something inside a thick platform on which a structure of flywheels and springs is assembled.
Flywheels are just the tip of the iceberg.
Why do flywheels rotate? Witchcraft? No.
What is the function of flywheels?
Pay attention to the layer of white construction foam. Foam dampens vibrations well.
Why did Tariel have such a big problem with vibration?
Old video of Theophilius who visited Kapanadze in 2011.
https://youtu.be/M2-8HkawRHo?t=231 (https://youtu.be/M2-8HkawRHo?t=231)
He brought a diagram of the mechanical version.
There is a charging pump and a hydraulic motor.
According to the hydraulic symbols, the pump rotates in one direction, the motor can rotate in two directions.
Probably the main concept is to create cycles of compression and rarefaction in the water+.. .
It can be assumed that the hydraulic motor in the previous installation is connected to one flywheel, the hydraulic pump to another.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg272350/#msg272350 (https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg272350/#msg272350)
The oil seems to act as a cooling agent.
Quote from: Sergh on July 01, 2022, 05:41:45 AM
Why "fraudster"?
Well, I didn't get it right away.
QuoteEnergy is produced by something inside a thick platform on which a structure of flywheels and springs is assembled.
Maybe this ? Already posted a hundred times.
Quote from: kolbacict on July 01, 2022, 07:08:30 AM
This is a description of a perpetual motion machine.
Unsuitable. Useless.
There must be a source of energy.
Everything that does not have an energy source is a fake.
By the way, Kapanadze himself stated that the effect is somehow connected with the study of gravity or antigravity.
"We stumbled upon the effect while studying antigravity" (see my previous post for exact quotes on this)
"We" - this could mean people from the organization where he worked.
Not Kapanadze himself, but someone from the team.
If Kapanadze worked at the "Gruzgiprovodhoz" Institute, which designs water systems for irrigation or water disposal and the like, what kind of antigravity can we talk about there?
But you will be surprised, such organizations also have patents related to gravity.
Look in the Georgian patent database for the word "gravity".
https://www.sakpatenti.gov.ge/ka/search_engine/search/1/ (https://www.sakpatenti.gov.ge/ka/search_engine/search/1/)
Better search in Georgian language.
"Abstract" - 7th line in the list
But this is not at all about what the inventors of perpetual motion would think. ;)
some links to be memorized:
1. https://www.academia.edu/33662240/Some_Notes_on_Transmission_Line_Representations_of_Teslas_Transmitters (https://www.academia.edu/33662240/Some_Notes_on_Transmission_Line_Representations_of_Teslas_Transmitters)
Some Notes on Transmission Line Representations of Tesla's Transmitters
Zoran Blažević1, Dragan Poljak 21,2
University of Split, Faculty of Electrical Engineering, Mechanical Engineering and Naval Architecture, Split, Croatia.1
zblaz@fesb.hr,2 dpoljak@fesb.hr
2. https://www.physicsforums.com/threads/basic-hypotheticals-of-an-emp.460607/ (https://www.physicsforums.com/threads/basic-hypotheticals-of-an-emp.460607/)
Related Threads on Basic hypotheticals of an EMP
3. https://ieeexplore.ieee.org/document/4050644?arnumber=4050644 (https://ieeexplore.ieee.org/document/4050644?arnumber=4050644)
Synthesis of Passive RC Networks with Gains Greater than Unity
4. https://electronics.stackexchange.com/questions/239852/rlc-filter-as-amplifier (https://electronics.stackexchange.com/questions/239852/rlc-filter-as-amplifier)
RLC filter as amplifier? (https://electronics.stackexchange.com/questions/239852/rlc-filter-as-amplifier) is it possible that a RLC filter works as an amplifier?
If it works at resonant frequency, then the output will be greater than the input.
5. https://www.oldfriend.url.tw/article/IEEE_paper/Synthesis%20of%20Passive%20RC%20Networks%20with%20Gains.pdf (https://www.oldfriend.url.tw/article/IEEE_paper/Synthesis%20of%20Passive%20RC%20Networks%20with%20Gains.pdf)
PROCEEDINGS OF THE I.R.E.
than Unity*
HERMAN EPSTEINT, STUDENT, IRE
6. https://patents.google.com/patent/WO2019118025A1/en (https://patents.google.com/patent/WO2019118025A1/en)
Earth-ionosphere waveguide power transfer
https://patents.google.com/patent/US10852333B2/en (https://patents.google.com/patent/US10852333B2/en)
7. https://www.researchgate.net/publication/238895523_Extracting_energy_of_surface_wave_from_plasmatic_waveguide (https://www.researchgate.net/publication/238895523_Extracting_energy_of_surface_wave_from_plasmatic_waveguide)
Extracting energy of surface wave from plasmatic waveguide September 1984
Radiophysics and Quantum Electronics (https://www.researchgate.net/journal/Radiophysics-and-Quantum-Electronics-1573-9120) 27(9):833-838
DOI:10.1007/BF01041394 (http://dx.doi.org/10.1007/BF01041394)
8. https://clgiles.ist.psu.edu/pubs/brewster-magnetic.pdf (https://clgiles.ist.psu.edu/pubs/brewster-magnetic.pdf)
International Journal of Infrared and Millimeter Waves, VoL 6, No. 3, t985
BREWSTER ANGLES FOR M A G N E T I C MEDIA
C. Lee Giles* and Walter J. Wild**
Optical Sciences C e n t e r
U n i v e r s i t y o f A r i z o n a
Tucson, A r i z o n a 85721
Received November 22, 1984
9. http://www.teslaradio.com/pages/resonating.htm#:~:text=Wireless%20Transmission%20of%20Power%20 (http://www.teslaradio.com/pages/resonating.htm#:~:text=Wireless%20Transmission%20of%20Power%20)
Resonating%20Planet%20Earth%20Tesla%27s,the%20first%20cyclotron%20%281931%29.%20WIRELESS%20TRANSMISSION%20OF%20POWER
Resonating Planet Earth
Toby Grotz
Theoretical Electromagnetic Studies and Learning Association, Inc.
522 West Third StreetLeadville, CO 80461(719) 486-0133
10. https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/waveguides/ (https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/waveguides/)
Waveguides
Chapter 14 - Transmission Lines
11. https://en.wikipedia.org/wiki/Dielectric_wall_accelerator (https://en.wikipedia.org/wiki/Dielectric_wall_accelerator)
Dielectric wall accelerator
12. https://demonstrations.wolfram.com/DielectricSphereInAUniformElectricField/ (https://demonstrations.wolfram.com/DielectricSphereInAUniformElectricField/)
Dielectric Sphere in a Uniform Electric
Field
https://physics.stackexchange.com/questions/329800/induced-electric-field-in-dielectric (https://physics.stackexchange.com/questions/329800/induced-electric-field-in-dielectric)
Induced electric field in dielectric
13.https://ericpdollard.com/wp-content/uploads/2014/06/ (https://ericpdollard.com/wp-content/uploads/2014/06/)
electromagneticinductionanditspropagation.pdf#:~:text=Conversely%2C%20the%20dielectric%20field%20of%20induction%20forces%20itself,
that%20is%2C%20potential%20energy%20in%20a%20dielectric%20form.
ELECTROMAGNETIC INDUCTION
AND ITS PROPAGATION
by Eric P. Dollard
Copyright 2014
note:don't take it to seriously.
14.https://www.globalspec.com/industrial-directory/high_temperature_proximity_switches (https://www.globalspec.com/industrial-directory/high_temperature_proximity_switches)
High Temperature Proximity Switches
15. https://en.wikipedia.org/wiki/Brewster_angle_microscope (https://en.wikipedia.org/wiki/Brewster_angle_microscope)
Brewster angle microscope
16.https://docslib.org/doc/1629992/simple-transmission-line-representation-of-tesla-coil-and-teslas-wave-propagation-concept (https://docslib.org/doc/1629992/simple-transmission-line-representation-of-tesla-coil-and-teslas-wave-propagation-concept)
Simple Transmission Line Representation of Tesla Coil
and Tesla's Wave Propagation Concept
Zoran Blaževi
1, Dragan Poljak2 Mario Cvetković3
17. https://www.spirit-science.fr/ArchivesScientifiques/2016Nikolayenko.pdf (https://www.spirit-science.fr/ArchivesScientifiques/2016Nikolayenko.pdf)
Extremely Low Frequency (ELF) Radio Wave Propagation: A review
A.P. Nikolayenko1, A. Shvets1, and M. Hayakawa2
1Usikov Institute for Radio-Physics and Electronics, National Academy of Sciences of the Ukraine, Kharkov,
Proskura st. 12, 61085, Ukraine
2) The University of Electro-Communications, Advanced Wireless & Communications research Center, 1-5-1
Chofugaoka, Chofu Tokyo 182-8585, Japan
18.https://patents.google.com/patent/US20060190512A1/en (https://patents.google.com/patent/US20060190512A1/en)
Electrical power multiplication InventorJames Corum (https://patents.google.com/?inventor=James+Corum) Current Assignee CPG Technologies LLC
https://patents.google.com/patent/US20060190511A1/en (https://patents.google.com/patent/US20060190511A1/en) (second link)
18. http://www.atmo.arizona.edu/students/courselinks/spring13/atmo589/ATMO489_online/lecture_1/lect1_global_elec_circuit.html (http://www.atmo.arizona.edu/students/courselinks/spring13/atmo589/ATMO489_online/lecture_1/lect1_global_elec_circuit.html)
global atmospheric electrical circuit.
19.https://patents.google.com/patent/US20180166762A1/en?q= (https://patents.google.com/patent/US20180166762A1/en?q=)
regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar
Site preparation for guided surface wave transmission in a lossy media
James F. Corum
(https://patents.google.com/patent/US20180166762A1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar#)Kenneth L. Corum (https://patents.google.com/patent/US20180166762A1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar#)Basil F. Pinzone, Jr. (https://patents.google.com/patent/US20180166762A1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar#)James D. Lilly (https://patents.google.com/?inventor=James+D.+Lilly&scholar)Stephen W. Wilson (https://patents.google.com/patent/US20180166762A1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar#)
20.https://patents.google.com/patent/EP2932558B1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar (https://patents.google.com/patent/EP2932558B1/en?q=regions&q=site&q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar)
Excitation and use of guided surface wave modes on lossy media media
InventorJames F. Corum (https://patents.google.com/?inventor=James+F.+Corum&scholar)Kenneth L. CORUM (https://patents.google.com/?inventor=Kenneth+L.+CORUM&scholar) Current Assignee CPG Technologies LLC note:
in link :
https://patents.google.com/?q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar (https://patents.google.com/?q=guided&q=wave+transmission&q=lossy+media&before=priority:20160309&scholar)
in the top window place test:
(guided) (wave transmission) (lossy media) before:priority:20160309
21:
other:
https://patents.google.com/?inventor=Shota+Kapanadze (https://patents.google.com/?inventor=Shota+Kapanadze)
22.https://patents.google.com/patent/US11150038B1/en (https://patents.google.com/patent/US11150038B1/en)
Electromagnetic waveguide based thermal energy extraction with emissive materials and modifications
23.https://patents.google.com/patent/RU2517378C1/enResonance (https://patents.google.com/patent/RU2517378C1/enResonance)
power amplifier Russian:
may or may not be valuable, - needs to be evaluated as everything that is Russian origin.
Concept known from American magnetic amplifiers from 50ties.
Russians may just deform original design and submit it as their own.
the best joke of "some Russians" is : "I'm innocent"
https://youtu.be/l4XTAwu668M?t=108 (https://youtu.be/l4XTAwu668M?t=108) (in russian)
English subtitles . ARNOLD SCHWARZENEGGER
Wesley.
Quote from: pix on July 07, 2022, 01:38:40 PM
3.You didn't respond regarding Xiaodong Liu papers on energy multiplication in retarded resonance.
Is he also crook?
From where is coming energy gain described in 2 attached papers below this message?
4.Any comments on Strebkov patent from my previous post? COP in patent example is 5,4. 1kW in- 5,4kW out at 50Hz. See attached below.
Cheers,
Pix
we going to discuss first:
paper in question is:
– [3] Qichang Liang, Yu Liang, Xiaodong Liu, Energy Multiplier in Retarded Resonance,
April 2011, http://www.vixra.org/pdf/1104.0052v1.pdf (http://www.vixra.org/pdf/1104.0052v1.pdf)
quote .1
Quotesource absorb energy instead of output energy when the distance
between the source and receiver is ¼ of wavelength.
Such a system is an energy multiplier.
quote .2
QuoteIn retarded resonance with distance of quarter wavelength, the receiver gains energy via EMF from the source and the source also gains energy via EMF from the receiver. This system becomes an energy multiplier.
quote .3QuoteIn retarded resonance, the energy extracted from the source is determined by the retarded phase on the route. When the distance between the source and the receiver is ¼ of wavelength, the extracted energy from the source is negative. In that case, the source supplies EMF to the receiver without energy delivered. In the mean while, the current in receiver feed EMF back to source with inverted phase resulting to energy absorption in the source. The total energy of the system is increased since both source and receiver gain energy.
analysis of the source:
.1 is credible paper with credible scientists from credible institution, But!!!Energy Multiplier in Retarded Resonance Qichang Liang1 , Yu Liang2 , Xiaodong Liu1* 1. Department of Nuclear Physics, China Institute of Atomic Energy, P.O. Box 275(10), Beijing 102413, China 2. Pangeo Corporation, 2005 Black Acre Dr., Oldcastle ON, N0R 1L0, Canada * Corresponding Author, Email: liuxiaod@gmail.com
But!!!Pangeo Corporation,is actually Canadian cable manufacturing company.
https://panjiva.com/Pangeo-Cable-Industries-Ltd/1212770 (https://panjiva.com/Pangeo-Cable-Industries-Ltd/1212770)
look at their shipment note table. it's likely in other Chinese from Canada trading:
Fish Plates, Washer Screws Caed, screws –Cable Parts.
-----------------------------------------–so Canadian entity is just not important for us business – another Chinese.
–Qichang Liang1 , Yu Liang2 , Xiaodong Liu1* were not found listed as
employees and/or representatives of Institute of Atomic Energy, Beijing 102413, China
and address is P.O. Box 275(10),
- papers published might use shell with or without representation.
-scientific title e.g PhD, is not published along with names.
– papers are from 2011, – no scientific community feedback was found.
quote:
QuoteAcknowledgement Special thanks to Mrs. Yulan Yao, Mr. Jian Liang, and Mr. Fengjun Zang for their encouragements and financial support to this work.
explains that this was the job done by a student.
-----------------------------------------analysis of the paper:Chinese researchers states:
generator sends energy to connected loop antenna.
that energy in the form of EM wave, is received by another loop antenna, connected to capacitor;
that makes it resonance circuit-antenna in resonance
Receiving antenna, is at the distance of one quarter (1/4) of wavelength – still in
Near Fieldhttps://en.wikipedia.org/wiki/Near_and_far_field (https://en.wikipedia.org/wiki/Near_and_far_field)
receiver antenna sends this energy back to transmitter antenna
and that multiplies energy in total.
so from the Chinese paper standpoint this could be
used as energy generating device.
example:
100W is multiplied by a factor of 2 excluding losses, and multiplied again.
Conclusion:
It sounds like a nonsense.
Source of additional energy use for multiplications the energy coming from generator.
But if you disconnect generator from the outlet
in the middle of the process
that all multiplication is gone.
100 W from the outlet cannot turn magically into 1000 W.
butthere are plenty of other papers from other guys
talking about the same sort of something , that must be
pushing them to investigate it and publish it.
I'm going to closely look and those other papers
and give you my feedback.
Wesley
So why would we want to do that when everything on the Dally thread talks about gain at
quarter wave length yet the grenade coil does not do this now does any of it work.
I'm sure this would help every one on here!
Regards Sil
Explanation how 4 points formula describes most of the devices in question.
Question:
What the energy comes from.?
Most of people want to understand quickly the summary of given processes
in topic:
Re: Holcomb Energy Systems:Breakthrough technology to the world (https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg569362/#msg569362) « Reply #1152 on: July 30, 2022, 10:38:50 PM »
I used simple template and here I'm explaining how
to use it taking energy Extraction From Schumann Waveguide
as an example:
Format of the Template:
Please explain energy conversion process.
in this format:
1. - initial energy form and its source.
2. - in few words describe process of conversion
3. - energy form at OUTPUT of the device.
4. - please compare the initial energy used vs energy at output in units.
add1.
initial energy comes from Schumann waveguide.
The source of this energy is energy fluctuation in the waveguide.
add2.
When electromagnetic wave due to lightning discharge deposits its energy in the earth/ air interface at complex Brewster angle,
this energy in TM mode can be extracted using Tesla coil with adjusted Top Capacitor acting as a receiver.
add3.
Output energy from Tesla coil low voltage winding = energy deposited in the interface minus loses.
add4.
The lower the frequency the lower the losses.
Loses are not important to us as all energy in the interface is delivered by nature
note:
attenuation of the free space doesn't apply to waveguides.
https://en.wikipedia.org/wiki/Free-space_path_loss# (https://en.wikipedia.org/wiki/Free-space_path_loss#:~:text=In%20telecommunication%2C%20the%20free-space%20path%20loss%20%28FSPL%29%20is,obstacle-free%2C%20line-of-sight%20path%20through%20free%20space%20%28usually%20air%29.)
Inverse square law doesn't apply to waveguides.
https://en.wikipedia.org/wiki/Inverse-square_law
(https://en.wikipedia.org/wiki/Inverse-square_law#:~:text=In%20science%2C%20an%20inverse-square%20law%20is%20any%20scientific,dilution%20corresponding%20to%20point-source%20radiation%20into%20three-dimensional%20space.)earth/air interface is waveguide for Zenneck wave.Depends form the frequency
Zenneck wave can have different names and forms of excitation but all of it represents the same phenomena
explained here: https://www.youtube.com/watch?v=wIIABIU3tRw&t=352s (https://www.youtube.com/watch?v=wIIABIU3tRw&t=352s) .
Wesley
Finally someone said this! :)
Thanks Stivep for boiling it down to 4 exact points.
a) Tesla coil is acting like a probe inside waveguide.
b) Important is top terminal height, it should be movable to addjust to proper angle.
c) In my opinion VIZIV has been put down intentionally once investors and notable board
of directors realised it is not only for transmiting power wirelessly by Zenneck surface wave,
but towers intercept extra power from Schumann waveguide frequencies.
d) someone trying duplicate and build Tesla receiver will be immediately spotted and propably will face troubles, as this is quite visible thing.
e) what power could be drawn from single Tesla receiver of not so big size? Any idea?
PS.
I am in process of duplication Strebkov exact setup for resonant transformer, still waiting for 1kVA autotransformer
and 380/220v isolation toroidal transformers. Already have capacitors.
Give feedback of my results.
Cheers,
Pix
"Try to think of it as fallow .
example of thinking pattern :Electromagnetic Wave was unknown to humanity , because there was no receiver invented.
Think about human animal walking since its evolution on the earth not knowing that
earth is one of two components of 2D waveguide made from air-the dielectric and Earth -the lossy conductor.
And this structure (like any other 2D waveguide) is a medium for energy from natural source present there in TM mode.So no naturally present electromagnetic wave was never received and in time of Nikola Tesla and Marconi
it was just speculation around purpose of Tesla's Wardenclyffe Tower (1901–1917),
Many people were looking at lightning's, but thinking about energy fluctuation in atmosphere
nobody ever thought about Schumann waveguide and Schumann resonances,
Quoteglobal electromagnetic resonances (https://en.wikipedia.org/wiki/Resonance), generated and excited by lightning (https://en.wikipedia.org/wiki/Lightning) discharges in the cavity formed by the Earth's surface and the ionosphere (https://en.wikipedia.org/wiki/Ionosphere).[1] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-1)
predicted by Winfried Otto Schumann.
https://en.wikipedia.org/wiki/Winfried_Otto_Schumann (https://en.wikipedia.org/wiki/Winfried_Otto_Schumann)
until measurements made by Balser and Wagner in 1960–1963[18] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-Balser_Wagner_a-18)[19] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-Balser_Wagner_b-19)[20] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-Balser_Wagner_c-20)[21] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-Balser_Wagner_d-21)[22] (https://en.wikipedia.org/wiki/Schumann_resonances#cite_note-Balser_Wagner_e-22)
________________________________________________
In 1908 Dr. Zenneck based on Tesla and Marconi created basis for waves trapped in very special waveguide
the interface. https://youtu.be/He5xQOJHlrU?t=99 (https://youtu.be/He5xQOJHlrU?t=99)
It was also a time of Arnold Sommerfeld https://en.wikipedia.org/wiki/Arnold_Sommerfeld (https://en.wikipedia.org/wiki/Arnold_Sommerfeld)
and birth of something very exotic at that time:
QuoteSommerfeld and Zenneck wave propagation for a finitely conducting one-dimensional rough surface
https://ieeexplore.ieee.org/document/898782 (https://ieeexplore.ieee.org/document/898782)
Dr. Goubau in 1950, https://en.wikipedia.org/wiki/Goubau_line (https://en.wikipedia.org/wiki/Goubau_line)
Quotebased on work on surface waves on wires from 1899
by Arnold Sommerfeld (https://en.wikipedia.org/wiki/Arnold_Sommerfeld).[7] (https://en.wikipedia.org/wiki/Goubau_line#cite_note-Sommerfeld-7)[8] (https://en.wikipedia.org/wiki/Goubau_line#cite_note-Stulle-8) used as a feedline (https://en.wikipedia.org/wiki/Feedline) at UHF (https://en.wikipedia.org/wiki/Ultrahigh_frequency) to link high frequency transmitters (https://en.wikipedia.org/wiki/Transmitter)
and receivers (https://en.wikipedia.org/wiki/Radio_receiver) to their antennas (https://en.wikipedia.org/wiki/Antenna_(radio)),[2] (https://en.wikipedia.org/wiki/Goubau_line#cite_note-Straw-2)[3] (https://en.wikipedia.org/wiki/Goubau_line#cite_note-Lieberman-3) and in scientific research.[8] (https://en.wikipedia.org/wiki/Goubau_line#cite_note-Stulle-8)
In July 23, 1986 Dr James Corum gave me (The young man) basis to my own research.
Electromagnetic structure and method (https://patents.justia.com/patent/4751515)
Patent number: 4751515
In 2006 Dr James Corum having no money filed his provisional patent application
In 2014-02-28 Dr James Corum started to shine.
EXCITATION AND USE OF GUIDED SURFACE WAVE MODES ON LOSSY MEDIA
https://patents.google.com/patent/US20140252886A1/en (https://patents.google.com/patent/US20140252886A1/en)
In 2010 I as very much grown man started my own research that today is own by me, and partially
released to the public without any patents, but level of release is based on my partner in research
due to his contribution and based on gentleman agreement.
-often criticized by some oil/gas delivery based Far Eastern Europe terror Rashists and their puppets.
it is Extraction of Energy from Schumann waveguide.
summary:If you collect all individual raindrops, in one surface you'll likely flood it.
Earth/air interface as a highway, is affected by energy entering to it under condition of complex Brewster angle.
Bird at HV power line doesn't get electrocuted if its legs distance is relatively small.
Human can be affected by Step Potential - the voltage between the feet on the earth but not by electromagnetic energy in TM mode
trapped in the interface in ELF frequency band.
The EARTH is one of two elements of interface and you are walking on it.!!!!!!!!!!!!!!!!
The receiver based on Tesla coil can receive this energy.
https://youtu.be/He5xQOJHlrU (https://youtu.be/He5xQOJHlrU)Wesley
Hi Stivep,
1. How much power could be collected by single Tesla receiver of height, let's say 20m?
2. What frequency that Tesla receiver should be tuned to? I can't imagine size of Tesla receiver tuned to fundamental 7 or 14 Hz.
Cheers,
Pix
Quote from: pix on July 31, 2022, 02:03:56 PM
Hi Stivep,
Cheers,
Pix
height is not important. elevation of top capacitor is.
We experimented with energy transfer (based on Dr Corum A to B) in range of ~5km and a distance from New York to Los Angeles
with 1W at 86 to 95% of efficiency, but at given conditions.
So losses are very small at 17kHz.
That means that unknown to me level of energy from Schumann waveguide entering Interface is almost totally available
at the output of receiver.
My partner in research connected 0.5 W load and than 1000W load
purely resistive.!!
And that is important as system is
dynamic in nature and
INTERFACE is only a
"highway"
that appears to be empty as there is
no traffic on it.
That means current is drown based on power dissipated in the load.
Interface is not a battery and is not energy storage.!!!!
If there is
no load than there is no energy usage but "highway" is there ready to transfer
unlimited amount of energy available in the system.
picture from the bottom:
h -is height of top capacitor.
if the height is small, the Complex Brewster Angle point entering interface is closer to Tesla coil and its
top capacitor,
So the limitation of height is important mostly from perspective of unintended sparking due to dielectric constant of the Air.
- Mostly noticed if we try A to B by Dr James Corum.
second picture from the bottom:
DYNAMIC reactive systemrope - simulates interface
the boy in Dr James Corum A to B acts as transmitter or in my application as Energy Source from Schumann waveguide
the girl acts as a receiver with the load.
Assuming that energy source is strong enough it can give as much energy as receiver is able to pull (dissipate)
I hope it helps.
Wesley
QuoteHi Wesley,
Have you seen the new Rigol VNA's, if so any opinion?
https://www.rigolna.com/vna/ (https://www.rigolna.com/vna/)
The key is not in that what they advertise but with that what they are trying hide
it is not Vector Network Analyzer, it is spectrum analyzer with VNA features added.
cons:.1
I was always trying to avoid "combines" the multi-functional machines.
In 80s in your country it was very popular to have radio with tape recorder, TV, and CD player.
None of the single modules, was as good as if it was standalone.
When something went wrong you lost all of them.
.2
The RSA3000N
https://beyondmeasure.rigoltech.com/acton/attachment/1579/f-9276de63-fd6d-4e04-b9ba-ceb899ccb617/0/-/-/-/-/RSA3000E_%20Datasheet_201908-EN.pdf (https://beyondmeasure.rigoltech.com/acton/attachment/1579/f-9276de63-fd6d-4e04-b9ba-ceb899ccb617/0/-/-/-/-/RSA3000E_%20Datasheet_201908-EN.pdf)
Has :
tracking generator working from:
100 kHz to 3.0 GHz (RSA3030E-TG )
the VSWR :
300 kHz to 3.0 GHz
All of our operations are at or below 100 kHz.
So the The VNA addition is useless for our research.
Waste of your time and money.
Recommended:
HP 4194A is around 40 years old, and is much better for us than the Rigol.
at that time there was no VNA's yet.
it is gain phase analyzer and in addition gives you impedance measurement.
https://www.testequipmentdepot.com/usedequipment/hewlettpackard/impedanceanalyzers/4194a.htm (https://www.testequipmentdepot.com/usedequipment/hewlettpackard/impedanceanalyzers/4194a.htm)
https://exality.com/beautiful-hp-4194a-plots/ (https://exality.com/beautiful-hp-4194a-plots/)
https://manualmachine.com/hp/agilent4194a/1274702-user-manual/ (https://manualmachine.com/hp/agilent4194a/1274702-user-manual/)
Advantest R3754B is excellent and fast as "lightning"
https://testequipment.center/Products/Advantest-R3754B (https://testequipment.center/Products/Advantest-R3754B)
https://www3.advantest.com/documents/11348/146302/pdf_Catalog_R3754A_R3754B_jp.pdf (https://www3.advantest.com/documents/11348/146302/pdf_Catalog_R3754A_R3754B_jp.pdf)
HP 8753D
30kHz- 6GHz great tool but unfortunately doesn't go lower than 30 kHz.
note: when buying HP 8753D:
Make sure that it does have starting 30 kHz not 300 kHz lower frequency.
Make sure that it looks exactly like this:
https://www.testequipmentdepot.com/usedequipment/hewlettpackard/networkanalyzers/8753d.htm (https://www.testequipmentdepot.com/usedequipment/hewlettpackard/networkanalyzers/8753d.htm)
Wesley.
Holcomb Energy System appears to be a "Don Smith" device which he described in his later videos--Even his
suitcase model--though it contained a small battery--would power 1000 watts,it would also recharge the small battery
within.Don Smith had many "secret" contracts he could not reveal.His suitcase device,he admitted,was "1900's
technology" compared to what they already had at the time (circa 1998). At that time they had devices
running in the 5 GHZ range,which seems to point to the "5G" network we now have today. He had to teach his
lessons in Europe and Asia because American Institutions would not grant him patents nor listen to what he had.
Same with Joseph Newman--American Companies would not listen,made them spend their money,gave nothing
in return.
Does anyone here have data on the circuits or devices Tesla was using for his magnetometers?
I assume he likely built his own like on page 25 C.S.N. however at first he was perhaps buying something off the shelf also.
Does anyone know what the tech off the shelf in 1899 was for a magnetometer?
I am looking for the tech before the fluxgate and after the Gauss swinging magnet.
Classified military testing often requires entire testing device to be destroyed.
It is Switzerland made jewel, and I was lucky
It was approved to be saved. look at picture
Wesley
Here you have explanation what is what
Wesley
stivep
QuoteOften, science is presented as trafficking in absolute truths.
On the contrary, science is a framework for interpreting, systematizing, and predicting nature based on empirical observations.
That is to say, a well accepted 'theory' (framework for understanding/predicting nature)
can always be upended with sufficiently compelling contrary evidence.
I would agree and we still have a lot to learn...
For example, the property of inertia is usually missing in most models and generally lumped together with mass as if they were the same thing.
It's problematic because there are only two logical results...
1)the mass was acted on by an external influence and space cannot be empty as supposed.
2)the mass has acted on itself in some way violating multiple laws of science.
I came to this conclusion in a way similar to Richard Feynman's first principals...
https://blog.dtssydney.com/richard-feynmans-principles-of-scientific-thinking
As Feynman implies, not so much science but common sense and describing the evidence without regard to the way we feel it should be.
As such the logic involved in explaining inertia is littered with contradictions.
We cannot call "inertia" a property (a quality of something) and have no explanation of what it is or how it came to be.
The term "property" implies said quality must be due to some influence in which we have two choices, 1)internal or 2)external.
Which comes full circle back to the two initial options...
2)the mass has acted on itself in some way violating multiple laws in science.
Generally speaking whenever an argument becomes circular, ie. the supposed answer contradicts the actual question, were in trouble. That's the wonderful thing about science because there's never a shortage of questions to be asked...
AC
Quote from: onepower on August 10, 2022, 02:06:01 PM
AC
Talking about inertia:
In mostly classical physics it is
common opinion: (common sense )"that there is no "problem of inertia", on the grounds that either
-no explanation is needed for such phenomena or
- the explanation is already at hand."
just because e.g law of inertia, in one form or another, was already used before them by such people as Galileo , Descartes.
-but common opinion is just common in relation to elements making it, so it can't be taken as an axiomatic value.______________________________________________________________________________________________________
Huygens and Leibniz, seen inertial motion as uniform and on a straight line, whatever direction we like it to be in the universe.
QuoteWhen something is at rest, it tends to stay that way.
In physics inertia is described as "a property of matter
by which it continues in its existing state of motion
in a straight line unless acted upon by an external force."
Barbour's seen inertial motion as "cosmic drift," but we do not know whence it comes and what determines its course and it was year 2001.
-relativity of motion, which makes everything relative to something else.
Some others see a problem between
Inertia and Relativity? Einstein utilized Gaussian coordinates and differential geometry, for
"A A B B relativity of revolution relativity, generalized? A B B A
constructing his theory of gravity (usually called "general relativity," but a caution is necessary for this word). "
https://1library.net/article/what-is-the-problem-with-inertia-and-relativity.y4erlxrq (https://1library.net/article/what-is-the-problem-with-inertia-and-relativity.y4erlxrq)
But because we are interested with
energy and inertiawe coming to
all kind of rotational machines made by all kinds and all levels experimenters: Jeff St. John August 07, 2020:
https://www.greentechmedia.com/squared/dispatches-from-the-grid-edge/solving-the-renewable-powered-grids-inertia-problem-with-advanced-inverters (https://www.greentechmedia.com/squared/dispatches-from-the-grid-edge/solving-the-renewable-powered-grids-inertia-problem-with-advanced-inverters)
postulating :
QuoteSetting up inverters to augment or mimic that inertial stability.
referring to
virtual inertia inertia damping generation
(https://www.sciencedirect.com/science/article/pii/B9780128194324000196#:~:text=The%20concept%20of%20virtual%20inertia%20is%20adopted%20from,damping%20and%20high%20nadir%20due%20to%20load%2Fgeneration%20disturbances.)
QuoteSouth Australia. The 30-megawatt/8-megawatt-hour battery system sits at a substation
serving several towns on a peninsula that also hosts about 90 megawatts of wind farms,
with only a single connection to the mainland.
but it turns out that this is:
Quotethe megawatt-scale inverter operating the ESCRI system and the much smaller inverters
connecting rooftop solar systems to the distribution grid aren't that different,
So large scale vs small scale at your home obeys the same rules including Inertial motion at individual or summary level.
Aren't we coming back by that to: "
common opinion" (common sense ) from very top of my comment? Quote from: onepower on August 10, 2022, 02:06:01 PM
AC
Wesley
stivep
I prefer Richard Feynman's take on the matter...
"Have no respect whatsoever for authority; forget who said it and instead look what he starts with, where he ends up, and ask yourself, 'Is it reasonable?'". I think Feynman said this because he worked with some of the most intelligent people on the planet, the real authorities, and none of them could agree on anything either. So were in good company...
This is a neat video, https://www.youtube.com/watch?v=Zjm8JeDKvdc, Feynman's Father and Inertia.
However I don't believe Feynman was asking the right question in the video which should have been why does the ball remain at rest in the first place?. Here most put the cart before the horse and claim it's the conservation on energy but that's not a valid explanation of the event only a concept. The only relevant question is what's inhibiting the motion of the ball in reality, it's inertia and it has no valid explanation which holds up to scrutiny. Either the ball was influenced by something external to itself or it acted on itself.
In any case I'm happy to see we disagree, it means were making progress...
AC
Hello,
This is my first post on this forum, although till now I was a silent daily reader over many years.
I like this place because of wise people who are sharing their view, experience. Such wise people have a solid path of logical thinking and they put right questions, indicating that they have a deeper understanding of how nature actually works. Also, by the way they put such right questions, they generously make you put the brain at work in an effort to intimately try to understand inner mechanisms of things and phenomena around us.
Regarding mass and inertia:
- Mass is not an intrinsec property of matter; mass and inertia are two different things
- Inertia is not an intrinsec property of matter; inertia is an effect and the cause is the external "medium"; actually force of inertia is a hydrodynamical effect that takes place within and caused by the external "medium" (assuming that "medium" is viewd as a fluid)
Deep_Purple
Wesley,
I asked before if you had any energy avalanches that were dangerous such as lightening, normal or localized, with your surface wave device?
Due to other experiment I have already had a visit uninvited, not appreciated so have to be prudent in this location.
I recall somewhere on this thread was a pretty straight forward detail of how to build experimental unit, can you please post the pointers?
This thread is very large now.
Quote from: mkjekyll on August 14, 2022, 05:28:02 PM
Wesley,
no I didn't have.
Locally they are not allowed.
https://youtu.be/XOTLfnMOSqQ?t=587 (https://youtu.be/XOTLfnMOSqQ?t=587)
Go to my channel.
I'm traveling now. I'll respond to rest of your question later.
Wesley
Wesley,
What made you choose the size of your secondary, working with 160 meter amateur radio ?
Somewhere you mentioned as a young man Corum influenced you, did you meet him at a Tesla symposium ?
What is your understanding of the low loss inside the waveguide, normal waveguides have much higher losses than the Corum's claim ?
Thanks for the cool video productions.
Mk
Seems like a perfect harmonic of Schumann albeit very small. 70000/
Quote from: mkjekyll on August 18, 2022, 11:25:15 AM
It wasn't me but Dr. Corum who started from 144 MHz going down to 50 MHz going down to 1.8 MHz due to his license privileges,
in early stage of his scientific investigation, of energy transfer from A to B using surface wave.
Surface wave, is generalization that includes all of the waves mentioned here including
Zenneck Wavehttps://youtu.be/wIIABIU3tRw?t=27 (https://youtu.be/wIIABIU3tRw?t=27)
Despite its frequency it is the same phenomena , deferring mostly with methods of excitation.
it is in your own interests to view all videos from that channel:
https://www.youtube.com/channel/UCPC6uCfBVSK71MnPPcp8AGA (https://www.youtube.com/channel/UCPC6uCfBVSK71MnPPcp8AGA)
The core of everything is in almost never mentioned by me evanescent wave
https://en.wikipedia.org/wiki/Evanescent_field (https://en.wikipedia.org/wiki/Evanescent_field)
But it is a very foundation, for educated researcher to understand this:
http://rexresearch.com/corumzenneck/texzon.pdf (http://rexresearch.com/corumzenneck/texzon.pdf)
-that excites a pure Zenneck
surface wave with
no radiation field.1.8 MHz 160 m was just convenient for Dr. James Corum to his publish results
he could use 135.7kilohertz – 137.8kilohertz with 1 W EIRP maximum
before he got the license for 125 kHz https://fcc.report/ELS/Viziv-Technologies-LLC (https://fcc.report/ELS/Viziv-Technologies-LLC)
So there are two factors,
– What Frequency you use for experiment
and
– What frequency you publish that you used for your experiment ( legal reasons)
My suggestion is for you to deep your knowledge about
evanescent wavesand its properties.
For average audience some history:
https://www.evangel.edu/press_releases/tesla-wireless-electricity-corum/ (https://www.evangel.edu/press_releases/tesla-wireless-electricity-corum/)
Something more or less important about
evanescent waves:
This phenomenon, known as the evanescent wave, extends only to a short distance from the interface,
with power dropping exponentially with distance.
https://www.sciencedirect.com/topics/chemistry/evanescent-wave (https://www.sciencedirect.com/topics/chemistry/evanescent-wave)
-but it is exactly matching to the explanation of Zenneck wave in the interface.
The missing part in that quote is that
evanescent wave is seen as separate phenomena by itself,
and
Complex Brewster Angle is not taken into consideration.
while the word:
Complex makes all the difference to the traditional understanding of
Brewster angle
omnidirectional propagation in
free space free_space. (http://www.mike-willis.com/Tutorial/free_space.htm#:~:text=In%20free%20space%2C%20a%20radio%20wave%20launched%20from,there%20is%20nothing%20to%20prevent%20them%20doing%20so.) is restricted by
inverse square law Inverse-square_law#:~ (https://en.wikipedia.org/wiki/Inverse-square_law#:~:text=In%20science%2C%20an%20inverse-square%20law%20is%20any%20scientific,dilution%20corresponding%20to%20point-source%20radiation
