Free Energy (whatever name you ant to give it) is NOT possible with conventional electromagnetism.
This should be apparent from how many thing have been tried here!!!
Free Energy comes from engineering the aether, but hey, you might not believe me.
So, I want to prove it to you!
You see, roughly 90% of people can feel aetheric energy!
And if you start including really simple aetheric principles into your circuits, success becomes possible and actually inevitable eventually!
The aether is no longer a mystery, I can explain to you how to involve it in circuits!
I have focused on studying the aether itself and I have not done anything that could have produced Free Energy, but that can be your achievement!
Every device that has gone properly (or infinity) OU uses the aether, and the issue is that even really subtle details can matter!
The way wires are connected for instance!
What I want to do is to teach you guys to feel the energy, and show you how to amplify the aetheric functioning in a device till it reaches a state that it can develop proper overunity!
I will make a bet with you, if 10 people here (not all new sockpuppet accounts) follow my instructions and none feel a damn thing, I'll send $100 to each of you! But I would have to be very very unlucky to get no one who is sensitive to energy when most people can feel energy, albeit I will need photos to show you tried.
If you guys begin to use this energy, with sensitivity, in experiments, this forum will be infinity more successful at chasing aetheric energy.
It took me 17 years before I felt energy from an experiment, and it has been another 7 really learning about how to engineer the aether.
It would seem a waste not to share this with other seekers.
My experience is mysteriously no one gives a damn about the secrets of the universe, well, please prove me wrong guys!
I have already demonstrated miracles with this energy!
Good. Now you Think about somethig , what is really powering generators. IT is ether
Quote from: forest on July 24, 2018, 05:13:00 AM
When I studied electrical machines it was Faraday's laws pertaining to induced mmf. Ether had nothing to do with it!
Ultimately EVERYTHING is ether/aether.
But for the fact that we tend to have names for regular forms that are easily recognized as material, we call it electrons, matter, water, light etc...
Now, yes regular electric current does involve a little bit of less materialized "ether", and some sources are more abundant that others, electrical power from the earth has a lot, electric power from a battery can be ok, generators can be very good. And electric power from the mains is mostly stripped of this aetheric energy.
The aetheric component can leak out the ends of a wire, it can be radiated out. Indeed the more beneficial type is generally killed by the flow of electrons, this is what Tesla found and stopped the current super fast, thing is there is a better way, just apply the negative poles (no positive) of electro-aetheric sources to a circuit and you will replenish this form of energy, this is what I am confident Grey meant by "split the positive" but I will avid going too deep into the theory just yet, the basic take away is use 2 batteries and connect just the negative of one to a circuit powered by the other, the bigger the battery the better, this will make the circuit operate different, see what an easy simple test that is! Just that is enough to really help!
The other way is to use a single battery but to split the wire from the positive so the aetheric energy from that end is diverted, this works because aetheric energy flows in a fluid dynamic manner, you can divert the positive energy. Aetheric circuits do better when not connected to mains is the other point to make.
Quote from: aussiebattler on July 24, 2018, 05:28:33 AM
Agreed Battler, Aether has nothing to do with the basic function of generators or really any conventional electrical device
, even when there is an aetheric component present, it is not used for anything and it is too small most of the time to be of use.However if you feed the output of a generator into a motor in a closed loop, sometimes it can become enough and such systems can trip into self powering mode, this has been demonstrated by a surprisingly large number of people, it requires pretty decent aetheric component and the establishment of aetheric flux linkage between the devices.
It is necessary that the devices are well isolated from any ground or mains power, and still it helps if the circuit is designed to allow for overunity operation, what I mean is to gain OU often you must de-link things, for instance imagine you have a device that needed input power, but it boosted the output power through a load, you connect it between a battery, but any degree to which it helps just drains the battery faster, yes there is still an energy gain, but that energy gain drains the battery faster by increasing the voltage across the load which increases the current across the load. So to get Overunity you have to design a part of the circuit that could gain power without any reflection, this is pretty basic, but it is needed to make the best use of any incidental OU, there are plenty of strightforward ways of doing this.
Again you are correct about motor--generators but in ordinary generator threre .is a aether input also or they would be as inefficient as the original Pixii od Clark dynamos. There is no way they work by energy conversion from mechanical inout only but to prove it a large money is required.
Can you cut to the chase, what is your missing ingredient ? anddon't say an electric motor please ! :o
So it's quite refreshing to see that Eather is the main source of matter that is invisible and it is the source of traction for gyroscopic effect as all these patents from 1900's to the present show unidirectional vector movement against an invisible force....in a vacuum of space and with out gravity effect. go figure out how that is possible without Eather.
Standard physics is a a loss to explain the twisting of a rotating wheel 90 deg. all they say it's an effect.. Great !
Pulling yourself against vacuum of space by using a a rotating mass makes no sense without traction...Remember Newton, action and reaction are imprinted in teachings of science.. Hello... Eather or whatever that is "X" is..
Take a look at the latest photos from Hubbel telescope, trillions of galactic objects ....it will blow your mind..
Acca...
Quote from: AlienGrey on July 24, 2018, 02:10:31 PM
I will tell you the missing ingredient, it is building a device that develops aetheric energy.
But before I go into it, here is a post I wrote to someone that might prove useful...
Have you considered that these Free Energy devices create anomolies such as cold current...
Non-shocking current...
Spontaneously charging things...
Arcing at low voltages
Incandescent bulbs glowing off colour
Sometimes demonstration of anti-gravity...
Sometimes low voltage DC completes in open circuit...
Sometimes materials becomes changed...
Sometimes energy fields manifest around these devices...
Have you considered that if something very different is happening from what conventional electromagnetism predicts, maybe it isn't conventional electromagnetism?
Have you considered maybe it's not a coincidence so many devices have a circular nature...
Have you considered that maybe Tesla was right... Maybe Wilhelm Reich was right... Maybe Konstantin Meyl was right...
Maybe Moray was right... Maybe Stubblefield's crazy achievements which make no sense conventionally, maybe Keely's achievements are based of what they are obviously based on?! Maybe Searl was right, and Hamel, both demonstrating Free Energy and Antigravity...
You have been looking in the wrong place if you have been focused on trying to make a bootstrap device based on conventional electromagnetism, that only EVER leads to conventional results.
Free Energy research is full of accounts involving anomalies, simple devices doing not just one impossible thing, but 2 or 3 or more!
Look at Sweet, look at Bedini, look at Gray, look at the Adam's motor, none of this stuff has just Free Energy, there are other anomalies! That's because they are engineering the medium of matter.
Of course who could work out how these disparate device work, who could see the commonalities in them, the correlations and see the underlying aetheric science, the aether that you cannot buy a meter for? It seems almost hopeless, except I spent roughly 24 years finding out how! I can help most people feel the aether and tell you how it works, what the correlations are and take you through it.
So, the aether is the key.
So, what should you do about this info? Ignore it? Or change course?
To convince you it is worth changing course I am willing to "PROVE" to you that what I am talking about is real!
But, there are no meters that can detect aetheric energy and if there were it would be of little use, there is too much going on, a number on a meter would be of little value.
But I assert that 90% of the general population can feel this energy to some degree, though that can go down or up depending on the type of person. Some Audiences might only be 50%, but at any rate I cannot Guarantee you will be able to feel energy, but I can however assure you that if a number try you might become reasonably convinced from others feeling it, either at your place, or online.
The second promise I make is that there are guidelines for involving the aether, small details and techniques I can tech you that are near effortless to include the are not detrimental to the conventional operation of an electrical device that can make a BIG differences to the aetheric functionality.
If you are willing to try things and don't need proof, I could just give you these techniques, I could tell you about a hundred of them!
Adding some aetheric components to a circuit is not guaranteed to trip it into a OU operation, but it will take it in the right direction generally. Aetheric techniques/components don't all fit together in a sense of "more is better" and i will try to give understanding as much as I have gained as to what the deal is.
AlienGrey, if you want to know how to make aetheric energy work, tell me what device you have sitting around, under test or collecting dust you would consider lightly modifying (probably in entierly reversible ways) and I will see what techniques I have found could be tried.
Or you could make the "aetheric inductor" I posted in the other thread.
Or you could ask me for an alternative coil you could make to possibly feel energy from.
Quote from: aether22 on July 24, 2018, 08:22:21 PM
I have a anomaly when i charged two aluminum plates with 300VDC. About one feet away i have a
detector for AC (100-600VAC). It light up even tho i have no AC. At least 100Vac detected. Further
away it light up when i touch it.
I believe the aether or zero point energy or whatever you may want to call it may be important in tapping OU. Given your experience and research into the aether have you built anything that can be considered OU or COP >1 ? While I find the possibility of 'feeling' the energy interesting as I have been sensitive to such in the past I consider it still a very subjective thing. I would only be interested in building something if it could achieve a usable energy level - even if it is to just power an LED light. Suggestions?
Quote from: e2matrix on July 25, 2018, 02:21:01 PM
Hi e2matrix...
So no, I don't have something that can light an LED, but that is because I really have not tested this to create Free Energy. I don't tend to do experiments with electrical energies.
The why of that is that I mostly want to focus on the aetheric side, and as soon as I have to make electric circuits I have a complicating factor that can interfere and and has different requirements, also it slows things down, also I don't like the feeling of the energy as much, at least until I found that electrons were eating up the negative energy, basically the moving electrons recombine that energy as they flow. This can be easily fixed i have since learnt.
Also, MOST of my experiments have not been physical at all! A lot have been images, because the principles of aetheric energy are somewhat (but not entierly) invariable to the energies used to embody them! So I can make unpowered circuits with wire fast, images faster. but electrical circuits where I have to worry about both disciplines much less. And for what it's worth, as much as I like the idea of Free Energy, I am much more pumped for Antigravity and that is my true focus.
Oh, and finally, failed experiments bum me the fuck out! If you don't try you can't fail! I know that is super lame of me, but the great thing about experimenting with the aether is that I can feel what is happening so it never occurs as a failure, and failures teach me a lot too as I get great feedback.
The problem with seeking Free Energy is often it just "didn't work" and there is no real feedback other than that.
At any rate, I understand you would rather I had something empirical to show, something that seems a bit more obvious, but the thing is if it could only faintly light an LED it would likely be of little use, this stuff is as often as not all or nothing! It either works fully, or doesn't, if something is weak seldom has that sort of thing been upscaled.
So no, I can't give you something that can create a reliable physical effect, because I have done few experiments that do such. Physical effects have been...
#1 a few experiments have lead to glass breaking without conventional cause (nothing touching it and synchronized to some action), and not by chance. I have not sought to replicate this.
#2 Some images have caused monitors to play up, but not that reliably.
#3 Healing.
So, it just so happens that the experiments with broken glass used physical energies, magnets or chemicals and batteries, most others have not used any energy.
The healing makes sense, massive healings have taken place and bio-energy is the main energy around these things.
So what I have found is that if you want a certain effect, the energy you use should be related to that, so don't expect electrical energy without using electromagnetism.
So Free Energy would not have been possible with hardly any of the experiments I have done to date. Also I have found that aetheric bandwidth is critical, meaning you want a wide range of aetheric energies to create a more complete effect.
And if I had Free Energy working, I would not be sharing it here, I would share it with the world in some way that cannot be stopped. If you aren't interested, that's fine, but I am coming here because I think that I have techniques that could trip stubborn devices with FE potential into operation with little cost and effort, it costs nothing to try.
Ok. I am in.
Eather22, tell me the way you experienced that energy.
Lets go from there.
Maybe we can find a way to make something work.
best regards
Joule thief can power 1,8v led with a 1,5v battery using magnetic back emf.
Good!
Ok, so the first the first thing, there are 2 ways to do this...
One is I could tell you techniques to use, and you could apply these techniques to promising Free Energy circuits, maybe ones you made before that didn't work as expected, and see if they now show any signs of Free Energy, or any signs of anomalies such as cold currents, arc's at strangely low voltages and the like.
The other thing is you could see if you can feel the energy, this is not necessary, but it will be a HUGE help!
If we want to focus on that possibility first, then you could consider either trying to feel energy from an image, yes, I know that sounds weird, but it turns out light can do more than just burn circuits into silicon, it can burn circuits into the aether that it manifests in, quite reasonable when you think about it like that, light can also push matter around and start fires, so it is more physical that we tend to think.
The other thing is you can make a coil, this has even higher odds of working, or should have but everyone is different, still I have fund some people that feel energy from images and not from coils.
So if you want to do either one, go to the Aether transformer/inductor thread where there are instructions on both, the best version of the image is not in the first post but further down.
If you want I can email you also. feel free to pm me, just be aware the message might be wiped out before I get to read it if Stefan finally updates the forum.
A standard generator would be OU or self sustaining if it wasn't for the cogging effect from the Lenz Law pulling the rotor back into register.
when the system is up and running the primary draw is reduced to just the IR2 losses. part of the secondary is fed back to the system to maintain the field. the amperage to the primaries is still being circulated through the exciting system but not being used by the primaries.
the electricity is the Aether pulled from counter space dimension caused by the polarization of the primaries. the whole free electron in the copper wire is the biggest joke of them all. if you pull electrons from a copper atom then it becomes NOT copper.
generators are Aetheric accumulators pulling in electricity that is basically a pressure system. this is brought on by the polarization of the Aether as magnetism cancels out two dimensions of gravity leaving one dimensional electric flow from counter space into space. when a load is presented to a standard generator the current is increased to the exciters until the output is producing enough for the exciters and the load. that is the pressure in the system is increased until it can maintain the exciters and the load. it takes time for the pressure to build up as in a few seconds. Aether pressure from counter space.
the whole key i think for OU is to preserve the power to the primaries as in recycle the energies and for opposing primaries. if the losses to power the primaries are reduced to just the IR2 losses them you are well on your way to an OU device.
a standard off the shelf transformer conforms to the conservation of energy but the motional electric field does NOT as it is non- conservative therefore if one was to use these principals a device can and will provide the power to it's self and the load once started.
preserve the power used to the primaries not expend it.
Marathonman
Quote from: marathonman on July 26, 2018, 05:26:42 PM
Marathonman
That's not really true the thing you refer to as a generator doesn't generate any thing it's a contradiction in terms !
it's a device that generates BEMF and forces + and - potentials further apart the heat is produced by the BEMF and the way it is internally wired make some electronics to make it more efficient and your in business.
Faraday's law of induction is a basic law of electromagnetism predicting how a magnetic field will interact with an electric circuit to produce an electromotive force (EMF)—a phenomenon called electromagnetic induction.
Pretty words marathon man, but there is no truth to them.
Generators are MOSTLY explained correctly by convention, by Lenz Law.
There is however a degree of truth, electricity is not a flow of aether, it is a flow of valence electrons (or ions outside of metal) due to either a change imbalance or due to an EMF, and an EMF is like an electric field/force that pops into being due to some change or movement or time varying nature of a magnetic field.
Curiously this EMF exists as with Hooper-Moonstein even where the magnetic field is not detectable because it sums to zero, but it turns out despite summing to zero magnetic fields still exist, this is also how a transformer works despite there being potentially no detectable magnetic field where the secondary turns are.
Now, there are some clever ideas like that of the MEG and switched flux paths there it seems maybe Free Energy should happen, but it never seems to, but I digress, it is however hard to analyze these systems.
Fact is, conventional physics accurately and almost completely explains most things to very high degrees of accuracy, even to parts per million!
Free Energy does not just happen, and when it does happen there is more that just Free Energy going on, there is almost every time other anomalies observed!
Ok, so back to generators, you see there are a bunch of ways that generators can involve the aether, this is a secondary current, it can be generated by a generator and it flows though a wire, and it can even be sort of like electricity, this stuff often won't read on a meter, sometimes it seems loads can actually burn this stuff, but most of the time there is too little of this stuff to do anything.
And it is this aetheric current, this radionic like energy that flows through the wires, can easily flow out the end of a wire because unlike electrons that move slow, this stuff moves like a high speed fluid.
You description is somewhat fitting for this.
And it could be that this energy somewhat increases the efficiency of motors and generators.
You; "Pretty words marathon man, but there is no truth to them."
Me: you have absolutely no clue what so ever as to the truth.
Me; the electricity is the Aether pulled from counter space dimension caused by the polarization of the primaries.
You; "That's not really true the thing you refer to as a generator doesn't generate any thing it's a contradiction in terms."
who said anything about generating but you. it is YOU who is wrong and stop putting words in other people mouths and read what they say not what you thought they said. it is you that does not know how a standard generator works. they are Aetheric pressure systems all day long.
You; "Generators are MOSTLY explained correctly by convention, by Lenz Law."
Me; WRONG again and not even close. living in a fantasy land explained with incorrect assumptions.
You; "it is a flow of valence electrons (or ions outside of metal)"
Me; Completely wrong again. typical Dogma taught College School BS grasping for straws handed down from generation to generation.
You; "Fact is, conventional physics accurately and almost completely explains most things to very high degrees of accuracy"
Me; OMG ! i can't stop laughing, that is like watching Feynman explaining a magnetic field and squirming on a hot pan.
"Faraday's law of induction is a basic law of electromagnetism predicting how a magnetic field will interact with an electric circuit to produce an electromotive force (EMF)—a phenomenon called electromagnetic induction."
WOW ! now i never would of thought of that if you were not here. thank you so much and thank you for sharing.
Not much learned here but very comical though. needs a few more years to ripen.
Marathonman
Quote from: marathonman on July 26, 2018, 10:45:38 PM
We will have to agree to disagree.
But it is worth noting that electricity, the movement of charges, these charges are already in matter in this dimension.
What you are saying is true only of the aetheric component of electricity, and the aetheric component can be stripped and the thing called electricity still occurs.
I am not saying that EMF's don't maybe pull aetheric energies which might have a pseudo or fractional electrical charge from a couterspace dimension, not that I would say it does, but I don't know what a "counter-space dimension" is in the first place.
Certainly electron and proton like energies are moved by such a generator, and these might be described as extra-dimensional or something similar.
I did not say that, another poster did.
They have HUGE holes in their understnading, and there are whole areas of physics held together by sellotape and faith in Einstein.
But they also get a lot of things right, and there is a ton of evidence for electrons and a lot of details about it, there are maybe some funny things about spin and there are a few issues, but there is a lot that they get right and get right to amazing degrees, I don't throw out all of conventional physics, I just throw out portions that are obviously and proven false. But each to their own.
Marathonman
IMO you are conflating 2 things.
The hadcore materialistic electrcicity which shows few if any signs of overunity or anomaly.
And the aetheric component which might be what you say it is.
The aetheric component can be huge for certain type of electrical energy generation, and this is the energy that can easily be turned into more and more energy with suitable processing.
Your quote /quote tags need some work.
Quote from: TinselKoala on July 27, 2018, 01:28:47 AM
Ah crap, something about this adds all sorts of font junk I have to clean up as well, just cleaned up my reply to you, ok, note to self, I should NOT intersperse replies here.
NOTE: FIXED
I'll agree on that one.
all of man's electric machines are of electrical pressure (pressure systems)
Regards.
Marathonman
I remember I read something about this topic There was discussion in early 1900 about aetheric force and the consensus was established that there is only one electricity , whih means all so called aetheric effects or even metaphysic effects can be finally explained by science. I believe it so that aetheric effects are simply electromagnetic effects here the sourc of power is our Earth not tthe circuit power source.
Quote from: forest on July 27, 2018, 08:06:23 AM
I guess that depends on what is in a name.
You say "it is all electricity".
That makes me ask "What is electricity?".
And, I mean, be really specific!
Do you accept there are positive and negative charges?
Do you accept the negative charges fly through a vacuum with the right setup, but the positive charges don't... because they are atoms!
Do you accept electric fields motivate electrons?
Do you accept that a magnetic field can place forces of electrical charges based on some confusing set of conditions, but, essentially by movement or time varying and whatever an N-machine is?
See, if electricity is just charges and their moving because of an imbalance or a field's forces, then electricity is electrons and ions and their movements, but MOSTLY electrons as even in ionization they are the only net movement (well, assuming metal is part of the circuit).
So if you are saying "electricity is charged bits of matter and associated field forces somewhat' then I would answer that no, electricity is most assuredly not aether. or, not more aether than matter is at any rate.
as I am a full time researcher and experimenter in "Overunity" systems, I won't be hypocritical, I will assume the.....for now "assumptions" of aether being a key to reciprocal energy efficiency systems, how is it you propose or intend to empirically show viable methods and/or technologies that can be utilized right now ???
I am an optimist at heart, you need to be in my line of work, but even in my experiments and successes, I do NOT just blatantly imply exciting and promising already is available without backing it up in some way......
your statements as they are, are intriguing as an idea, but can it be implemented, what organized data have you acquired to even suggest that this is a viable idea, much less an actual, beginning to a new direction ???, again, trying to think positively and assuming you have something more convincing than your current statements to inspire even a modicum of confidence in your idea, how far down the road do you estimate the ability to integrate the "aether contingency" into current research and/or full on experimentation ???
as patient as people can be here, it's aggravating enough just doing what we do now, trying every day, little by little to solve every new puzzle, patience wears eventually, if you intend to come in here with a claim of "OU" can't exist without MY theorem, you better be ready and able to pop that dinner in the microwave REAL FAST, because these people here have been starving for some promising results for a LONG TIME and they don't want to wait for dinner till tomorrow, while you hold a picture of a steak in their faces.......you will have a riot on your hands.
so, don't tell us what you think, empirically SHOW us what you ACTUALLY have please...
Thank You for your time sir and hopefully a viable addition/alternative to further progresses our cause
Hello J. Hewitt, I will try my best to address your post, thanks for being an optimist, let's get cracking.
Well, I'm not.
Simply, things move through stages.
The first stage the thing might not even be known about or guessed.
The next stage some have experience of it and it becomes a myth or something magical, this is where the aether is currently for most.
The next stage is where electricity was when it could twitch a frogs leg, there was proof of it, but no clear utility, but that brought more study and elementary understanding.
The next stage brought electricity to more vigorous experimentation and useful things began do be made, this blossomed into what we have today which is the final stage, an advanced level of utilization
Now, some people have taken this aether thing to the second to last stage, there useful things could be made.
I however am currently only at the frogs legs twitching stage, though in some ways ore advanced, and yet simultaneously if you don't count subjective human experience, maybe even objective human experience and sensation of this energy, not quite that stage.
But, the point is that to get it to the next stage, I don't think pulling out a finished product is the answer, as people will just focus on the product and not care how it works, replications will fail again as people assume it works just electrically.
I am pushing the science and the understanding itself!
If you want a Free Energy design, or an Antigravity design, there are LOTS to choose from, what I am presenting is simultaneously much more and much less.
I am showing you the science, the understanding, not an end product, but the ability to be a pioneer with understanding of a fresh new branch of science that has been newly unlocked, what could be found is limitless and is more than just overunity.
Yes, there is unknown, and results beyond those of feeling energy cannot really be guaranteed.
I believe I am on the precipice of getting this to work, but if I do I will be too scared to share, now I can share rather more freely as I am just a crank, and not worth the bother.
Maybe I could share this now with you guys, and as MOST people feel the energy so at least some of you will, and then you will experiment and find the energy works much as I say, but perhaps you won't get any breakthrough, it won't have cost anyone much, it won't have likely stopped anyone from getting OU/FE but it will have been just a curiosity, something you include in designs but doesn't help or hinder.
But there is another possibility, if I am right I have cracked enough of the "code" that within the first month of people trying things with this energy, some startling anomalous and maybe OU results are obtained, and quickly this grows and revolutionizes the world.
Everyone here that works on this goes down in history as a pioneer that revolutionized science and technology and took the first steps to making Star Trek type technology a possibility.
I consider that both of these possibilities are about even, and the second possibility is so bright, and it takes the responsibility off of me.
Ok, you said not just viable technologies, but viable methods, well I have viable methods to produce an energy that the vast majority of humanity can directly feel (and ways it can be objective). I think the ability to evolve a clearly real and novel energy field is viable, as for how can I prove it is the same thing in use from claims of fringe inventors of the past, I can provide correlations aplenty if you want to delve into that, that show that they used these same techniques, of course that is not proof, it could be a coincidence, but how likely is it that they used techniques that produce an energy but didn't use that energy as part of their technology???
Now sure, I would love to be in a position to present you with more, but is this not potentially worthwhile if I am right that it can make the difference between stumbling in the dark and actually working with both knowledge and an ability to feel your way to success?
As I have said, this energy can be felt, I wish it was "can be felt by everyone", but sadly it is merely "can be felt by most".
But that is still far far better than "can be felt be a small minority".
Or worse "can only be felt by me".
The question is, if that is the best I can do, should I just let the rest of you stumble in the dark when I have decoded so much?
Well I have 24 years of research into this.
I had enough evidence to focus my life of this full time essentially for 17 years with only correlations to show this is what was the force behind past experimenters success.
I have been willing to go into correlative detail, but now, I am willing, but mostly I would rather dive into more powerful evidence and action, still if you want to go into that we could, but it is more powerful to experience it, more useful too.
I am not asking people to take things on faith.
If you agree that "aether" is the driving force behind Free Energy and Antigravity, then it stands to reason that if I can present means of generating some kind of substance or field or energy that seems to match this 'aether" and works with similar looking means and principles that you are willing to assume is key, then very probably what I am presenting is not some novel but irrelivant distraction, but is the very same aether.
Again, I would like to present more than that, I would like to have more than that to present, but is this not still a significant amount?
As for what evidence, my evidence is my own experience with feeling this energy and having others feel.
Now I get that for some people who want meter readings and hard data, that just isn't enough, but if these subjective or partly objective experiences can be shared with most people, does it nor become useful enough data?
I mean, it would want to be on the fringe, on the leading edge, you might have to climb onto the skinny branches, you might have to work without cement foundations.
If you want safe settled science that has white papers and calibrated instruments and decades of research to confirm things, then you shouldn't be out in the fringe looking to bring new things into science.
If you are not inspired be the pioneering spirit, by learning new things and exploring things that are not already well established, then this research isn't for you.
I think that it can easily be mixed into current research with little to no effort and expense and risk.
I think it can have high payoffs.
I think it might only work to produce a strong result often enough to be well worthwhile. I expect that involving aetheric energy to bring material results with little investiment at a rate that does not make it all that much of a long shot.
In truth, I don't think it is down the road at all, I think we are here, it only takes someone to be interested and to remain interested as I try and pass on my knowledge.
If someone was "tell me what to do to this experiment I am about to try right now" I could probably give them 20 different ways to improve their chance of success which would be easily implemented.
Well, then I guess the question is back to you guys, how long are you going to dick around before you ask me what the techniques are?
How long are you going to wait before you test the image I uploaded in the 'aetheric transformer/inductor" thread, or the coil in that same thread?
I am ready to help you guys right now, pull out that OU motor that didn't work.
Pull out that Kapanadze coil that didn't work.
Pull out that Hendershot, Hubbard, anything really that doesn't work.
And make the changes I suggest, and see what you get!
Ask me about the physics of the aether.
Ask me about the techniques.
I am as ready to spill as you are to get results.
Hey, I want results too!
So rather than messing around with tyre kicking, I'm not asking for money, what do you have to lose honestly?!
Well, it sounds like you want to see the techniques?!
Ok, so here is the game plan.
#1 I want people to make coils or to try and feel the energy from the images, this can quickly remove a lot of doubt and skepticism, AND being able to feel what is going on with aetheric energy is a HUGE help!
While I would not say it is pointless to follow my lead if you cannot feel aetheric energy, it is immeasurably better not to be working blind, or on faith.
#2 Once a useful number of people report they can feel energy from my images/coil, I will then, depending on the number, share with just them in private, or if more on here publicly how they would go about including these techniques with little difficulty in experiments.
That really is it.
If you want to jump over stage 1, and jump to stage 2, well, ok, but I think it is far better to try and first get on the same page so you don't have to take me at my word.
Quote from: stevie1001 on July 26, 2018, 05:06:52 AM
Ok. I am in.
Lets go from there.
best regards
Ok, I feel I have already done that, but here goes...
So, I made a coil that i had a hunch might affect the aether, I put my hand above it and I felt initially a very very faint energy in my right hand.
The longer I tested it, the more and more clearly I could feel the energy in that hand, I think both the energy was getting stronger (in part due to how I learnt to move my hand) and the energy was building up in my right hand till it became acute, to the point of it being painful.
It was no longer on the edge of perception, it was a solid and real as any material thing, yes simultaneously it was unlike any normal sensation, I could feel the energy right through my hand,not just on the surface.
It felt sometimes warm, somtimes cool, but mostly it help increasingly like pressure.
It could feel tingly, the sensations changed based on different variables, as the energy and my energy changed so did the quality of the sensation.
I still could only feel it in my right hand.
It took weeks, actually I think a few months probably before I began to feel energy in my left hand, this built up slowly as I did not use it as often being right handed.
So one of the things that makes it clear it isn't just that somehow my mind has found ow to hack my body and make it feels fake sensations, because it only happens in locations that get exposed to a lot of the energy for a long time!
So there you go, that is the history of how I experience it.
It isn't spiritual, it doesn't take an altered state of mind.
It does help if your hand is tense, that seems to resist the energy better and it builds up, moving your hand toward and away from the thing to be felt is hugely important, it can make a flow even from a regular object, but probably that works much better if your hand has a stronger built up field.
It is the "state of hand" that matters more than state of mind, I mean state of mind only matters in as much as not trying to block or project, you just want the mind to be not overly critical or overly wanting, it just shouldn't interfere. Wringing fingers and dynamic hand movements help connect to the energy. See if you can feel anything at all and then try and maximize, play with it to try and see how you can maximize the effect. If you are to do anything with your mind, just put your awareness in your hand, imagine your hand becoming inflated, pumped with energy and blood from your body. The last thing you want to do is have your hand "passive", it feels energy by having energy in it, the motion causes it to receive energy, but the hand itself should be a little tense, like when making a stop sign, or "talk to the hand" :)
That is about as complete I can be, why everyone is fascinated with me and how I feel it I don't bloody well know, MOST people can feel it, I have tried hundreds of people in person, and what must be 50 people with images online and feeling energy is not rare! it is the norm.
So, rather than worrying about how and what I feel, what do YOU feel?
Have you tried it?
Give it a go now!
This sounds much like the Keshe pain pens. They give of a subtle energy which can be detected by pointing the tip between your forefinger and thumb and moving the pen around. As Aether22 has mentioned not everyone can detect this energy. In my experience it will temporarily reduce and even eliminate pain.
Quote from: tomd on July 27, 2018, 09:37:42 PM
Funny you should mention him...
Ok, so I didn't really want to go into this, but maybe I should...
First off, I think Keshe is quite scammy looking and he does not deliver well on his promises, he also seems awfully um, fuzzy headed.
But, there is a lot of connection between what Keshe is doing and what I am doing, a lot about his tech that lines up with what I am doing, what I call aether he calls plasma, which is a silly name to give it as that name is already taken!
Anyway I actually made what I called energizers which were coils stuffed into stainless steel wands, but they didn't relieve pain, there were credible miracle like healings. Then again faith healers have healings, so I don't consider that truly worth going into, it is a distraction, and the energy must be structured right to heal, and the intent must be there. Also most healings took place in very public spaces with a lot of people and I can't help but wonder if that provided the right energy and blueprint from the crowd. healing oneself alone in the comfort of your own home is possible, but harder...
But this was before Keshe did pain pens, this was 2012 or 2013.
Also I found before Keshe did or before he mentioned it about both only using one direction of spiral wind (right handed or left handed but not both) and I found out why.
I also discovered the thing about turning the end of a wire back on itself before he publicized that.
That does not mean he is being truthful and not scamming people, if he couldn't figure out how to do enough with this he might be just using it as parlor tricks to scam people.
Having said that, I could be wrong about him, but many of his claims are over the top, really demanding of proof, and they make him look silly, like claims he can materialize gold...
Thing is, everyone in this field converges on the same design features, we all find the same tings work.
Why is everybody WASTING their time on this guy's (Aether22) NONSENSE?
If he refuses to post a diagram or schematic for us to try out,
then let's move on!!! Let's not waste our time here.
Quote from: FatBird on July 30, 2018, 06:06:56 PM
You know, I always try to give some benefit of the doubt, all anyone has asked was a little convincing hard data, it made Aether22 excited, but all I've seen is asking for faith and this could/should/would, I have to agree Mr. Bird, call me when there is something, I'm hopeful for him, but very busy also
I can post plenty of diagrams and schematics, but no one has asked for any.
I posted first 2 different ways for people to see if they can feel energy, so far only one person has reported trying anything on here, and he hasn't yet made it right.
If people are happy to assume that my claims are genuine and want more details (Oh, BTW the coil is a circuit diagram of sorts) and forgo the proving myself, then buckle up!
But, again I am not giving you a Free Energy device diagram, you have those, what I am giving you is aetheric component that you can add to any existing circuit claim.
But if you want me to give you an example circuit, sure, but again, this can be added to any FE circuit that makes any sense.
Mr. Aether Sir, you would probably get a much better reaction/s if you provide circuit diagrams and if you have, a list of the specific parts and components as well as the configuration, people will be much more receptive towards your outside of the box ideas :)
don't take personally
I want to re-stress...
I have been waiting for people to correctly make the coil and try and feel energy from it...
Or people to place their hand infront of the screen with an image like the one below for a few minutes.
So far no one has, despite an attempt at the coil that still needs work, despite that taking near zero effort to feel energy from an image.
Maybe folks are just being kind. My wife and I both tried the first image and thought we could feel something. Then we tried the blank spot on the monitor next to the image and felt the same thing. I just tried this new image and can feel nothing off of it. Maybe find some folks who don't know you locally and try them ?? You would have instant feedback. People who know you will tend to tell you what you want to hear just so that you will not feel bad.
Garry
Free Energy is impossible without this ,why everyone fails !
Dear writer ,"everyone" means -reziprok- you too !But "everyone" means me too,an accusation - whose I recuse !"Everyone" means that you - following your thesis- know all about each one of us and you judge us about failling !
Let me do a question,Worldtutor or World-Dekan,do you mean with "free energy" the actio- energy use under strict Gibbs-Theorem conditioning( reactio= giving back= law of conservation of energy)
or "energia por gratia" ,without compensation= against the natural " tit for tat"= 1/1 compensation !?
or that we do not need "outer-energy",because our internal "energy-body-source" is enough for a men-long life
Ever recycle-able : energy to matter and matter to energy
Thermodynamic determs using
matter ( other expressions: materia/ Materie/Material/Ding) is compressed energy energy(other expression:Think,Gedanken/Intellekt) is expanded matter
PSYCHISCHE INFORMATION abstract: konkret. PHYSISCHE FORMATION Mental energy. Compressed energy
Minkowski " Raum-Zeit " Relativitaets- Kinematik ( versus Salvadore Dali "Zeit"-Expression )
New Physics New Economy New Society New World
SpaceTime= BrainTime Time: which velocity ? Average velocity astro-phsical ~ brain
actually our world becomes digitalized- to "energy-4d computerized controlled numbers " and transverted brain=astro physically velocity fast to brain-world-print machines. ( TV-movie-serie: "numbers")
I hope for you that "my brainworld" is similar as your "brain-world": cause I work based by written laws and orders and this his related the Catholic program "dein /unser (Gedanken) Reich komme" and Immanuel Kants (Kaliningrad,Koenigsberg)
"10 Gebote/Kategorien/Mandates/Mandamentos/Log" imperativ/vocativ
GOTT, Nietzsche recusing, is not dead and makes counter-part
to Einsteins ART and SRT : ARP and SRP is GOTT(es Reich)Werk
( JHS vulgo Jesuits : opus-from opera and deii- Genitiv from deius)
Doktor Albert Einstein Mentor, Tutor and RT-Physics-"father": Prof. Herman Minkowski
Did someone compared the Religion=evolution teacher Jesus (Deo) criste 2d "Monogram " with the Minkowsi
" RaumZeit-Kegel"
RaumZeit-Perspective
WeltBildZeitGeist
The human brain from us individuals is actually the fastest computer ,related and compared to industrial production,
Computing = a designed expression from cum to com and putere = physical working in nano( down to pico-)Timespace-Dimensionality
The human body "only" his "architecto/polier/palir = from neuro (inner world) to physical (outing) executor
Intim-Sphaere = Intim-Weltbild
Heilig/holly(saint) or Satanic/Diabolic sometimes bivalent or neuter/neutral
Spacetime velocity laws and orders
Who knows about taxation laws knows about our world economy future :The economy tax for comparison has two points: the active and the passive tax zenit/nadir line/flat likean Hertzian wave
When the market passive tax is 2,5% (20 years saving)then the market active -tax is actually 27,77%(consume) using the parity-law by the Philosoph/ atomic bomb program scientist Carl August von Weizsaeckerbetter known as " Eherne Zinsgesetz " and constitution-laws conform
27,77% is the controlled price estimation tax quote for free trade i-/mobile life-essential object comparison,global : house /mobile-/mobiliar- quantity and quality defined values
Passiva and activa capital and tax parity Wrong and failling economies learn the consequences
positive and zero to negative tax
Positive,zero and negative capital
Estate bankrupcy after hyper-inflationary credit- printing
Quote from: jhewitt03041976@gmail.com on July 30, 2018, 07:08:58 PM
Ok, sure.
I just felt that I should prove the validity of my work first.
Also it is worth noting this technology can be used with sound as used in ancient times as with Keely and Leedskalnin.
Or like a number of Free Energy devices, Hamel, Searl (coils were only for pickup) and various permanent magnet motors.
The point is that I can show you principles and techniques you can use that will work at any level, you can embed things different ways, with different materials, many principles that can be embedded into 1 dimension of space can be embedded in the dimension of time instead. You can conduct aetheric energies through dielectrics, fiber optics, conductors, ferromagnetic, light/dark/colour etc...
In much the same way, an accurate diagram will typically be effective.
Also, because some of the things I have to share might seem a unlikely sounding, if people can feel it, then I can share a discovery that sound implausible, that should be ok, let me give you an example of an improbable sounding discovery.
Take a length of wire and alternately tap each end (must be the very tip) of the negative pole of a battery (actually you could also tap it on a magnet pole, or, lost of things) but by tapping one end twice as many times as the other, this helps create a layering of induced flows, say 4 taps on one end, 2 on the other repeated for a few minutes. This wire will have an established aether flow, but I have not yet tested to see if this will remain in an electrical circuit, but I assume it will.
Another similar thing, and this works applied tot he human body too, if you sweep a magnet or other field along a wire or arm/body and ou sweep both directions but more times in one direction (alternating frequently) you also create a flow.
The reasons for these things being in both directions is that the collisions creates energy buy a net direction creates flow, this removes problems of just doing one direction.
Another similar thing is if you have a loop or cylinder, maybe a metal band bent into a circle, if you take a single magnet like Hamel had, and point it inwards with the north pole in, and sweep it around the circle and remove it, this will retain a memory of that magnetic field (even if it is a diamagnetic loop) and this will create an enhanced aetheric vortex. Actually, this can also be layers with north and south pointing in, but more times north.
These are all examples of things once set in motion remaining that way, a form of memory.
Another things is that numbers come into this, and one very simple one is 4 can form into a vortex, and taping something esp. circular 4 (or 12 or 32) times can create an aether vortex, this would also go for 4 electrical impulses etc...
Another is doing what Hendershot did, take a piece of wire (maybe one conditioned as above, or by putting U shaped bits of wire which creates impulses in each direction along the wire) and connect it between different parts of a circuit, and not just the parts that can make conductive contact, when you do this you create a lasting interconnection between parts, so if you have a point of flux from say an electromagnet, that could connect into some wires and potentially induce Free Energy if it materializes.
Ok, so I have those ones out of the way...
Well, almost, another point is that a wire that is cut with 2 blades is different to a wire cut with a single blade (Guillotine, which can be replicated with scissors and a flat metal object) which is different to a wire broken which is different to a wire cut at an angle...
A wire cut with 2 blades imparts the energy of the 2 blades on the wire, but it is not effective, one blade is better, and angles cut with a single blade is best as straight cuts reflect aetheric energy but angled cuts support flow, and broken wire is better than cutting with 2 blades but not as good as cutting on an angle especially with a single blade. And that is just how you cut the wires makes a difference!
Do you see why this shit doesn't get replicated right? Do you see how finicky it can be? Re-read the issues I had with feeling energy from blind tests, a lot can interfere.
If you keep all turns and twists RH (meaning the same as a wood screw, like this =\\\\\\\\\\= ) you will do better than mixing left and right handed, as when these energies are both present it shuts down flow of helical energies as they flow opposite directions and collide and helical energies are the electrical energies, which is relivant in Free Energy.
So the thing is none of that is visible! These are hidden techniques that you cannot glean from looking at a design.
Ok, moving on...
So, the next secret I have given you, but it is so massive I must repeat it, make a wire grid based on that grid I posted, one square grid should be very slightly smaller, the lines that connect the 2 grids should go from the larger square CCW to the smaller square ideally. Any energy going on in this is amplified aetherically. Just make this and put as many energies in there. I also cannot overstate the importance of having as many energies going on, RF at multiple frequencies, Neo magnets, HV, ions, sound, motor, light, you want energy to be resonating, tank circuit with high circulating power, excellent, resonant cavity... use it! The more energy processing, this is how the aether gets mixed in, and it lowered the amount of power needed to kick things into action.
Another principle is to make a loop or coil with a resistor in it, next to the resistor place various things, this is an interesting effect, one thing that works well that I tried last might is a mobius strip just made of paper. Any shape capable of tessellating 2D space put neat this resistor will create a bunch of energy, a phi spiral, I have tried crop circle designs, and Sri Yantra, the flower of life. This is a very weird effect, basically energy moves fast though the loop (which could be a multiturn coil) but energy is emitted through the resistor, but this energy is structured by what is near it. Normally I don't feel every much from any of the things mentioned but near a resistor coil loop, the energy in the lop is boosted, if this means it is a type of energy I am normally insensitive to, honestly I don't know, mostly I think it emits energy these forms absorb and cycles it around increasing the energy in them, one of the best shapes is just 2 circles put together, in a drawing a faded lines functions similar to how a resistor works.
Incidentally you can just fade a black line from say the flower of line or Sri Yantra, you don't strictly need the loop.
This is powerful and so simple, it works for everyone and just seems too simple, really. But I also know others who had independently discovered the same effect!
The bottom image also uses a powerful principle that could be made of wire, a resistor (for the faded bit of the circle).
It is a very good choice to try and feed energy from.
Quote from: iflewmyown on July 30, 2018, 08:44:19 PM
Garry
So, feeling energy really anywhere when this energy is active is very possible, this is why I am careful of projections.
Secondly people who are strangers have felt energy from hidden devices with no introduction, indeed no one was expecting anyone to feel anything.
Also I have had hundreds of people feel energy from this and most are not people, I know very few people and if anything it's the other way, at least it is if I include my family as only my mother has ever felt anything, and very infrequently.
Try the bottom design in the image I just posted.
Also, people here don't seem that polite :)
What is your own ether theory? Do you have any personal websites or books to provide it? Thank you :) :) :)
