From Member Grumpy/Sigma 16
very nice indeed !!---------------------------------------------------------------------------------
Quote repost
https://www.nextbigfuture.com/2018/08/nuclear-fusion-updated-project-reviews.html
Self-Sustaining-Vibrational and Acoustic Piezoelectric Resonator-Acoustic Refigeration Core Generator of Electricity, Heating and Cooling - SS-VAPER-ARC
I just ran across this in a response to an article on the different fusion reactors being built by several companies.
Nuclear Fusion Updated project reviews
https://www.nextbigfuture.com/2018/08/nuclear-fusion-updated-project-reviews.html (https://www.nextbigfuture.com/2018/08/nuclear-fusion-updated-project-reviews.html)
Timothy Sipp
5 points
11 hours ago
The future of high energy density physics isn't even Nuclear. It's Solid State Electronic Fusion driven by a passive mechanically amplified pressure wave (acoustic) amplifier that generates a 4.345 MW/sq meter energy density with a pressure wave of 186dB. That's 1 million times more powerful than an Atlas 5 rocket launch contained in a bottle the size of a side by side refrigerator. The energy input is about 530 watts of electric power.
The intense sound waves create several small areas within the reactors resonators that are almost double the energy density of Nuclear Fusion, about 2.4 MW/sq meter. This sound turns the gaseous medium inside the reactors resonators into a cold ionized plasma, about 150 deg F at optimum power output after warming up. Similar heat to an incandescent light bulb.
This plasma stimulates the bulk modulus in large (160kV/discharge) mono-crystalline piezoelectric (iii-v Aluminum-Nitride) chips with resonant frequencies between about 1.2 and 3.6 megahertz. This system was patents pending since 2013, but the USPTO denied the small defense contractor their patent, meanwhile Lockheed Martin stole the design from the inventor through Los Alamos National Lab and Sandia National Lab and accused him of espionage and treason and when that didn't stick, they told the Securities and Exchange Commission he was a fraud preventing him from getting development funds.
The inventor, me, Timothy J sipp, has made all relevant material publicly available for review, including the computer models developed with LANL. Go to to read all about how it works, why it doesn't violate the Laws of Thermodynamics and download the computer software that LANL developed and my model to check my data for yourself.
Lockheed Martin had Sandia Labs build several reactors over 2 yrs ago. They have been running ever since, producing clean Green electricity for 2 yrs straight without a day of downtime. Each VAPER-ARC Reactor can produce 4GW of electricity and 6MW of heating and cooling via embedded Axial Regenerating Stack Acoustic Refrigeration Cores invented by Dr. Greg Swift of LANL. The Vibrational and Acoustic PiezoElectric Resonator Acoustic Refrigeration Core Reactor is the future of renewable energy for electric power and it already exists.
Trump, Russia, Mercer, Tillerson and the usual suspects making money from Fossil Fuels and Nuclear Power don't want you to know about it. So why am I not dead if this is true? Cuz I'm one tough SOB and I know where the other bodies are buried. OORAH! Semper Fidelis. Semper Veritus.
Timothy J. (Tio) Sipp
A Google search for Timothy Sipp turns up a few hits.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwi1o8CwyM7cAhXqi1QKHR9WBW4QFjAAegQICBAB&url=http%3A%2F%2Ftimothyjsipp.com%2F&usg=AOvVaw2jgWO-qWra0-zHtAc3S1o0 (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwi1o8CwyM7cAhXqi1QKHR9WBW4QFjAAegQICBAB&url=http%3A%2F%2Ftimothyjsipp.com%2F&usg=AOvVaw2jgWO-qWra0-zHtAc3S1o0)
http://www.freepatentsonline.com/y2016/0001325.html (http://www.freepatentsonline.com/y2016/0001325.html)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&cad=rja&uact=8&ved=2ahUKEwi1o8CwyM7cAhXqi1QKHR9WBW4QFjAJegQIABAB&url=http%3A%2F%2Fvaperpower.com%2Fportfolio%2F&usg=AOvVaw3VSCiEYbma6WLzycZWsG4E (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&cad=rja&uact=8&ved=2ahUKEwi1o8CwyM7cAhXqi1QKHR9WBW4QFjAJegQIABAB&url=http%3A%2F%2Fvaperpower.com%2Fportfolio%2F&usg=AOvVaw3VSCiEYbma6WLzycZWsG4E)
" Semper Fidelis !" Let him,Timothy Sipp ever be glad !
" Semper Veritus !" Trustability to get is for us humans really difficult
And by denying the publicated research development results and inventions as to read in his " Description : Description of Related Art : ...." he, Mr. Sipp, did not listed the thermal-acoustic devices from Oscar Lee Fellows
or. thermionic cells from Joseph C. Yater.
"Semper Veritus: veritas majestatis pluralis nobilii aut veritas populi singularis"
A snip from Tim's Bio /portfolio
in 2003 I realized a simple but elegant design to increase the efficiency of using hydrogen to generate electricity rather than using fuel-cells. I called it the Blossom Generator. The system used electrolysis to separate water into Brown's Gas that was then injected by valves into a specially shaped resonating chamber with smaller Helmholtz resonators perpendicularly arrayed radially around the center of the main chamber increasing the combustion pressure up to 512 times more than standard cavities. Instead of driving the motion of a piston attached to a crank shaft to turn wheels or a generator, the chambers were lined with high efficiency piezoelectric chips that generate electric discharge in proportion to the sound pressure level. The design was in fact a 10 kilowatt generator the size of a microwave that ran on water in a closed loop. It required the simultaneous invention of a process called high pressure steam electrolysis, also mine.end Snip
Quite amazing if all he states is true and he certainly seems to have a handle on high level terminology and knowledge. I'm thinking he should contact the likes of Elon Musk to get help with what he needs to build some of this tech. 530 watts in yields 4.6 Megawatts out - YES! Unfortunately his ideas and patents are far beyond anything us OU garage builders could put together.
