Publication Number
US2014-0159845
Title
SELF-SUSTAINING ELECTRIC POWER GENERATOR UTILIZING
ELECTRONS OF LOW INERTIAL MASS TO MAGNIFY INDUCTIVE
Abstract
Electrical oscillations in a "sending coil" radiate inductive photons toward one or more "energy-magnifying coils" comprised of a photoconductor, doped semiconductor, or a superconductor. Electrons of low inertial mass in the energy-magnifying coil(s) receive from the sending coil a transverse force having no in-line back-force. The low-mass electrons in the energy-magnifying coil(s) receive acceleration proportional to normal electron mass divided by the lower mass. Secondarily radiated inductive-photon energy is magnified proportionally to the electrons' greater acceleration, squared. Magnified inductive-photon energy from the energy-magnifying coil(s) induces oscillating electric energy in one or more "output coil(s)." The electric energy output exceeds energy input if more of the photon-induction energy is directed toward the output coil(s) than as a counterforce to the sending coil.
After initiating the oscillations, the generation of electric power becomes self-sustaining.
Field
[0002] This disclosure introduces a technical field in which practical electrical energy is created in accordance with the
overlooked exception to the energy-conservation rule that Herman von Helmholtz described in his 1847 doctrine on
energy conservation: "If......bodies possess forces which depend upon time and velocity, or which act in directions
other than lines which unite each pair of material points,.....then combinations of such bodies are possible in which force
may be either lost or gained ad infinitum." A transverse inductive force qualifies for Helmholtz's ad infinitum rule, but this
force is not sufficient of itself to cause a greater energy output than input when applied to electrons of normal mass due to
their unique charge-to-mass ratio. However, the increased acceleration of conduction electrons of less-than-normal
inertial mass, as occurs in photoconductors, doped semiconductors, and superconductors, is proportional to the normal
electron mass divided by the low electron mass, and the magnification of harnessable inductive energy is proportional
to the greater relative acceleration, squared.
Brief Description Of The Drawings
[0023] FIG. 1(A) is a perspective view schematically depicting a sending coil in relationship to an energy-magnifying coil such that inductive photons from the sending coil propagate to the energy-magnifying coil.
[0024] FIG. 1(B) is a schematic end view of the sending coil and energy-magnifying coil of FIG. 1(A), further depicting
radiation of inductive photons from the sending coil and respective directions of electron flow in the coils.
[0025] FIG. 1(C) is a schematic end view of the sending coil and energy-magnifying coil of FIG. l(A), further depicting
the production of inwardly radiating and outwardly radiating magnified inductive photons from the energy-magnifying coil.
[0026] FIG. 2(A) is a perspective view schematically showing an internal output coil coaxially nested inside the energy magnifying coil to allow efficient induction of the internal output coil by the energy-magnifying coil, wherein the induction current established in the internal output coil is used to power a load connected across the internal output coil.
[0027] FIG. 2(B) is a schematic end view of the coils shown in FIG.2(A), further depicting the greater amount of magnified inductive-photon radiation that is received by the external output coil in comparison to the lesser amount that is directed
toward the sending coil to act as a back-force.
[0028] FIG. 3 is an electrical schematic diagram of a representative embodiment of a generating apparatus.
[0029] FIG. 4 is a schematic end view of a representative embodiment comprising a centrally disposed sending coil
surrounded by six energy-magnifying coils each having an axis that is substantially parallel to the axis of the sending
coil. A respective internal output coil is coaxially nested inside each energy-magnifying coil, and the energy-magnifying
coils are arranged so as to capture substantially all the inductive photons radiating from the sending coil.
[0030] FIG. 5 is a schematic end view of the embodiment of FIG. 4, further including an external output coil situated
coaxially with the sending coil and configured to surround all six energy-magnifying coils so as to capture outwardly radiating
inductive photons from the energy-magnifying coils. Also depicted is the greater amount of magnified inductive photon radiation
that is received by the internal output coils and the external output coil in comparison to the lesser amount of inductive-photon radiation that is directed toward the sending coil to act as a back-force. Also shown are the arrays of LED's used for exciting the energy-magnifying coils to become photoconductive.
[0031] FIG. 6 is a perspective view of the embodiment of FIGS. 4 and 5, but further depicting respective inter coil connectors for
the energy-magnifying and internal output coils, as well as respective leads for the sending coil, internal output coils, and external output coil.
[0032] FIG. 7 is a schematic head-end view schematically depicting exemplary current-flow directions in the sending
coil, energy-magnifying coils, internal output coils, and external output coils, as well as in the various intercoil connectors,
of the embodiment of FIG.4.
[0033] FIG. 8 is a schematic end view showing an embodiment of the manner in which intercoil connections can be
made between adjacent energy-magnifying coils.
[0034] FIG. 9(A) is a schematic end view depicting the coil configuration of an embodiment in which a sending coil and
an internal output coil are nested inside an energy-magnifying coil, which is in turn nested inside an exterior output coil.
A metallic separator, having a substantially parabolic shape and being situated between the sending coil and the internal
output coil, reflects some of the otherwise unused inductive photon radiation to maximize the effective radiation received
by the energy-magnifying coil. Also,the metallic shield prevents the internal output coil from receiving radiation sent
[0035] FIG. 9(B) is a schematic end view of the coil configuration of FIG. 9(A), further depicting the metallic separator
acting as a shield to restrict the back-force radiation reaching the sending coil while allowing the internal output
coil to receive a substantial portion of the magnified radiation from the energy-magnifying coil. Also depicted is the greater
amount of magnified inductive-photon radiation that is received by the internal output coil and the external output
coil in comparison to the lesser amount that is received by the sending coil to act as a back-force.
[0036] FIG. 10(A) is a schematic end view depicting the coil configuration of yet another embodiment that is similar in
some respects to the embodiment of FIG.4, but also including respective ferromagnetic cores inside the sending coil and
internal output coils. Also depicted is a metallic shield surrounding
the entire apparatus.
[0037] FIG. 10(B) is a schematic end view of a sending coil of yet another embodiment in which a ferromagnetic sleeve is
disposed coaxially around the sending coil.
This should be read by everyone
This Is Bill Barbat's work.
I have not spoken to him in quite some time.
A few here tried to help him get some proof ,But apparently some of the fixtures to create this condition are VERY expensive ?
and not certain that it works ??
I believe he is not looking to open source
Maybe I will call him anyway...
I really do like Bill ,he has much FE history / experience and some here feel he should be interviewed for his lifes experiences [as do I]
Thx
Chet
Quote from: ramset on October 15, 2018, 10:18:21 AM
Thx
Chet
Well before reading this I had a similar idea, but I was going to use bismuth and metal plates to provide excess electrons. This patenet app picture 9B shows a lot like Moray's tubes.
Well
Bill's "low mass electron's" theory was perhaps intuitive.... for what we now find [or hope to find}here http://news.fnal.gov/2018/09/first-tracks-in-prototype-for-neutrino-experiment/ (http://news.fnal.gov/2018/09/first-tracks-in-prototype-for-neutrino-experiment/) Neutrino's apparently magically transforming in and out as they see fit ??? ?-------------------------------------------------------------------------------------------------------------------------------
we get closer everyday to the secrets of the whole shabang...,some say it is our destiny ...[for told??]
we seem to be on the path to becoming creator's or manipulators of the matter around us ??
IMO an amazing time to be on the planet .....
Respectfully
Chet
Quote from: ramset on October 15, 2018, 05:06:10 PM
Well
Respectfully
Chet
Well there is not that much difference between your thoughts, this keyboard (or other matter) and light. It is all EM radiation. Now we can already create EM radiation...
Just had a glimpse of a CIA's study on how to affect your mind with EM radiation. The study mentioned headaches, boosting memory and wiping memory :(
Some of the more notable naysayers here have said in the past that anything to do with Neutrino's is bogus. However it would seem science has a lot of proof now of their existence and this article about neutrino's was quite interesting also:
https://www.sanfordlab.org/article/how-will-lbnfdune-impact-lead
Quote from: e2matrix on October 16, 2018, 12:13:59 PM
I used to be a naysayer. Did that for 40 years. Just keep executing this plan that you were told to do and you will be happy. Then stuff happens and you start for the first time to actually look wtf is happening and how the universe really is.
Then you start looking at stuff for the first time through logic. Does what I have been told really match with everything or anything? Then soon enough you find your first lie or misconception.
Then after a few years you have this picture of the universe and this "matrix" that has been put over our eyes. The scary part is that you can pick almost anything on this planet and find out, that it is just a rigged game.
Take the red pill. I wish I would have done that when I was 20. It seems with my brain it takes 40 years to realize. When your whole existence is trying to get validation from the matrix, you do stuff that the matrix tells you to. "I plaid nice in day care. Am I a good boy now?", "Yes. You might try a bit harder to hate people that do not follow rules, but this will do for now". "I graduated. Am I a good boy now?", "Yes. Now just get a house mortgage, 2 car loans and remember to pay your student dept. But for extra credit, you might want to hate this group of people, because we tell you to do so". "I have worked in this fucking company for 15 years now. Who the fuck is this person I am married to and why am I so unhappy and drink every time I get a chance?", "Now get a grip son. When you are 69 you will get your pension and you can do what every you want, but for the moment you need to vote for right/left or what ever will create the most conflict with group X".
"No. I will take the red pill instead."
Never looked back
You have progressed nicely grasshopper, the only thing I might suggest is:
Do not assume there are others like you in this world. You may indeed be outnumbered one thousand to one.
With those kind of odds against you, think carefully before you reveal any part of your world to the unknown.
Quote from: Dog-One on October 18, 2018, 02:42:17 PM
if they are all the same they are indeed all one ;D ;D ;D
