Not much power per day ? 50W x 24h = 1200 W*h / day
Sufficient as primary power source for 80 sqm room heating ( West-Europe, coastal area), www.oeko-energie.de (http://www.oeko-energie.deand) and www.mtbest.net (http://www.mtbest.net) household appliances electric energy demand per day and warm water delivery for 3 capita
Construction : Mukherjee DC motor concept
Material input : Helmut Schiller DC input motor( AC output alternator)
3000 RPM , 100W nominal F= B*I*L
Controle Unit F'= 2B* I*L , non rotative H.Schiller DC motor, rotor/stator fixed
device start : by " hand crank "
Material weight estimation : motor 150 gr. + controle unit 200 gr.
China / India : alibaba/ aliexpress 37,5 Euros/Kg pm motor and generator average
" perpetuum" lifetime : bearings 3000 RPM ca. 20000 hours ( 1 year : 8766 hours ) improvement : www.bufo.ru (http://www.bufo.ru) surface treatment/ coating
NUFM : 2x Geo : 4-5 x
coils ca. 100000 hours ( ~ over 10 years permanent )
less RPM clearly possible = more material weight ( costs ! ) 1500 RPM ~ 3000 RPM device x 2 factor 1000 RPM~ 3000 RPM device x 3 factor
hand crank force : human counter body force ?
Non rotative = mechanical no movement = Transformator kind :
https://patents.google.com/patent/DE19804277C2/pt-pt (https://patents.google.com/patent/DE19804277C2/pt-pt)
https://tesla3.com/hilden-brand-jack/ (https://tesla3.com/hilden-brand-jack/) but here I and H- core
https://patents.google.com/patent/DE3938577A1/de (https://patents.google.com/patent/DE3938577A1/deU-) U -core + " L = ( WE + WM) x Hz "
_____________________________________________________________________
My private household calculation :
80 sqm 4000 Wattp heat per hour to 10 Watt per hour electric storage energy need
warmwater 3 capita : 1350 KWh per annum to 25 Wh per day electric storage energy need
kitchen appliances, light : 1500 Wh per day to 150 Wh per day electric storage energy need
( 10 x 24 ) + 25 + 150 = 415 in W* h electric storage energy per day : generating 1200 W* h per day
~ 12 Volt x 85 Ah battery
enough is enough
Energy storage :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1#
(https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1#)and " citing documents"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161027&CC=US&NR=2016315367A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161027&CC=US&NR=2016315367A1&KC=A1#)
Radiant Energy or Blacklight or wattfree energy or displacement current : to electricity conversion
C.0.P. : beginning small
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#C.O.P)
C.O.P. : 2 x 70W out
35 W lamp in
Marzahn
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=)
C. O. P. : 4,166 650 W ( 5 panels x 70W x reflector amplification) out
156 W (12 x 13 W lamps ) in
up to 8,0. by solar panel coating and 2019 fluorescent lamps use
https://m.youtube.com/watch?v=cBFAe3rArCg (https://m.youtube.com/watch?v=cBFAe3rArCg) as lamp/-s drive
7W + 8W LED output
Volt * Ampere input ?
"Agitation-/Stimulation-" C.O.P.: 375 x ? ( theoretical nominal/ measure numbers 1:1 )
Mahrzahn optimized + Morin drive : C.O.P. :
3000 x
Radiant Energy to DC Electricity receiver + converter
10%. error quote : 2700 x 90% error quote : 300 x. 99% error quote : 30 x 99,9% error quote : 3x
defensive research & experimenting with great trial chances and low risks : Analytik, Stochastik
which is the pattent you speak in the links you posted ???? if I click on this https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=) will gave me a full page of another links with more pattent number applications in german language......
where is the patent about you speak here ?: C. O. P. : 4,166 650 W ( 5 panels x 70W x reflector amplification) out
Quote from: sinergicus on January 22, 2019, 07:30:22 AM
which is the pattent you speak in the links you posted ??? ? if I click on this https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=) will gave me a full page of another links with more pattent number applications in german language......
Hello sinergicus,
these several " utility model(l) " application by Paul Heinrich Marzahn shows several possibilities and their
improvements, because this it is ever important to see the technical process and the device effect !
Publications in German, but the espacenet site offers a translation possibility :
650 W ( 5x solarcell modules a 70W + radiation amplifying mirrors) : (12 x 13 W lamps) = 4,166
"SELECT LANGUAGE":
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=29520064U1&KC=U1&FT=D&ND=3&date=19960314&DB=EPODOC&locale=en_EP# (https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=29520064U1&KC=U1&FT=D&ND=3&date=19960314&DB=EPODOC&locale=en_EP#)
F.e. in "English " :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29520064&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
7W + 8W LED lamps output : 100% - 0% comparison with direct plug !
Comparison input " Morin transformer" from plug / direct plug
by "Wattmeter"f. e. :
https://www.ebay.de/itm/New-UK-US-EU-Power-Energieverbrauch-Wattmeter-Stromverbrauch-Monitorsockel-LCD/401629935853?hash=item5d830278ed:m:msGyc97kzTMD1ua2wrBpcyg&var=671374784622&redirect=mobile (https://www.ebay.de/itm/New-UK-US-EU-Power-Energieverbrauch-Wattmeter-Stromverbrauch-Monitorsockel-LCD/401629935853?hash=item5d830278ed:m:msGyc97kzTMD1ua2wrBpcyg&var=671374784622&redirect=mobile)
70Watt solar panel enroled as tube and 35 Watt fluorescent long 1 mtr. lamp
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#)
Mahrzahn improved by reflector/ mirror use the "5-7%" conversion limitation by " artificial light-fall doubling"
( factor 1,85 ) in the 80/90' !
COMPARISON
Baquero Menendez used 240W/1,8 qm ~10% efficiency solarpanels
( theoret. solar light spectrum : 1333 W/ sqm )
8 x 240W and 1x 500 W lamp
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1#)
It shows that for the same output 4x 240W + coating + reflector are sufficient
This then as DC source for the " inverter concept" like http://www.patentsencyclopedia.com/app/20090079393
LancaIV, why don't you build your own "25 Euros perpetuum 50 W ( min. !) generating engine" and report back to the group only when you have your first results?
I suppose you will discover that unworkable inventions hang out by the hundreds or thousands in patent offices. :(
I have not built but I let build a permanent generating engine .
My function is to think and to decide and to administrate engineers and technicians by the work out !
Knowing the internal actio/ reactio process means that the following process was to search
for easier and cheaper devices which gives the similar result by higher generator lifetime.
Interest : portable 1 KWp modular device, non radio- active( EMW) and not radio-active ( elementary decay)
for less than 1 Euro- Cent per KWh ~ 500 Euros/KW; 10 years capital amortization and 5% capital tax
The production costs actually are in the 250 Euros/KW range ( serial production calculation)
Less by 4D-printer production and device improvement techniques.
- 70% by future REPRAP industrial production :< 100 Euros/ KW
Reference :
Paul Lucien Galey average 1 KW/ 1 Kg
Pavel Imris 1 KW/ 11 Kg ea. next 3,5 Kg a 30 Euros/ Kg production costs, 330 Euros first KW
1 KW modul sufficient for 100% of " intelligent managed private households" world- wide,
referring : www.oeko-energie.de (http://www.oeko-energie.de) their listage of household appliances and energy demand.
Clearly alternatively also possible with one 50 W generator and 2 KVAh cap.-/ battery pack configurable.
https://www.google.com/search?q=lumen+candela+lux&ie=utf-8&oe=utf-8&client=firefox-b (https://www.google.com/search?q=lumen+candela+lux&ie=utf-8&oe=utf-8&client=firefox-b)
Bernd Koehler, Paul H. Marzahn, Menendez Baquero
Different artificial light= photons sources, for photo- voltaic conversion
70 Watt DC electric output( 5,25% eff. Solarcell) : "35 Watt light bulb input" , Bernd Koehler
Really or stupid engineering and false assumption ?!
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.accende.ch%2Fblog%2Faccende-do-it%2Fdie-sache-mit-den-lumen-lux-und-candela%2F
Light Intensity = luminous flux divided by the solid angle, base : 1 metre distance
Given example : 600 cd by 3 metres distance = 66 cd
But : 600 cd by 0,1 metre distance = ?
70 Watt DC electric output ( 5,25% eff. Solarcell) : ( 35 W x 38 lumen ) light bulb input
= 1330 Wattlm
? ( 5,25%. ) : ( 15 W x 150 lumen ) light bulb input
= 2250 Wattlm
? ( 15%. ) : ( 15 W x 150 lumen ) light bulb input
? ( 56,25%. A. Marks. ) : ( 15 W x 150 lumen ) light bulb input
+ drived by Gerard Morin transformer
DC as input for C. O. P. 5x inverter
Loop: fusion reactor circuit
Quote from: lancaIV on January 27, 2019, 05:33:22 PM
"My function is to think" ::) :D ;D When do you begin?
A great moment! We will be falling on the floor laughing for hours! Thank you, lancaIV, it feels good.
" + drived by Gerard Morin transformer " translated to: drivel by Gerard Moron.
I do not need anymore to begin, because the beginning is in progress ! 8)
I am laughing about the poor consumer which have to spent so much for so less ! :)
Btw : how much are you spending for your monthly energetic consume ? ;D
Energycrisis : loop energy ;)
And, memoryman, there are many alternatives, also without the Morin transformer. :'(
Btw : how much are is Gerard spending for his monthly energetic consume ? It should be almost zero, right?
"And, memoryman, there are many alternatives, also without the Morin transformer." show me ONE that actually: is in production and works.
Almost all threads on this forum are about easily disproven OU ideas.
This transformer function is meaned.
And not what somebody in his private household is spending for energetic demands, much or zero !
And, memoryman, when you think about disproven OU- trials , it is you who think about disproven results.
Do you mean that your prrsonality is such important to become informated about experimental success ?
Before others, more important than you ?
Freedome whom Freedome belongs ( incl. Liberty)
I can't understand your reply.
