Hi all, decided to follow through with the project that was not finished in the past, was posting to the 'GEM' thread previously, where user that_prophet was sharing similar ideas.Though his version did not seem to emphasize the use of heavy flywheel, think it is needed though.Started working on building the setup a few days ago.
It was going to be like the Wilson wheel generator, though decided to use a separate pulley for the motor and a belt around the heavy mdf flywheel itself, which will be three 1/2" thick, mdf discs secured together for now.
Here is the cad drawing of the project.peace love light :)
(https://i.postimg.cc/VrjThs6N/Flywheel-Generator.png) (https://postimg.cc/VrjThs6N)
SKY THOSE HOT GIRLS WILL GIVE ME FREE ABUNDANT ENERGY
FOR THE REST OF MY EARTHLY LIFE..
Hi seychelles, not sure what you are speaking about.
So the project is coming along, built a homemade router circle guide out of 1/4" thick mdf, with a 5/8" diameter pivot channel, so the circle diameter is adjustable.The good thing about this is, it will have the intended shaft hole size right from the start and the discs will be more true and accurate, without having to do any extra steps.It looks like each 2 foot diameter, 1/2" mdf disc will weigh around 5.7lbs., so about 17 pound flywheel to begin this project, can add more discs if needed.peace love light :)
my suggestion is to power the flywheel from it,s rim so to
get the advantage of leverage, 2 a pma should be connected directly
to the main shaft. 3 the acceleration of the flywheel should be grater that of
gravitational acceleration is approximately 9.8 m/s2, THEN YOU ARE
GARUNTIED TO GET FREE ENERGY..
FREE FREE ENERGY FLYWHEEL.
Hi seychelles, thanks for the reply, seems like a good idea.
Though that is why the drive motor in this project is using a step down pulley ratio at input motor,
to give more leverage and keep the motor at higher rpms, where it is more efficient.
Then, with the help of the heavy flywheel, reconvert the slower rpms of flywheel into higher rpms at the alternator.
And the flywheel mass once at designated rpm, does not require the same input that was
needed to get it to that rpm,which is where the magic probably dwells, we shall see.
peace love light :)
TO UNDERSTAND THE PULSE MOTOR IS THE MOST EFFICIENT BECAUSE IT IS USING
THE DORMANT MAGNET THAT IS AWAKEN WHEN THE COIL IS PULSED, HENCE NO BUCKING
OF APPROACHING MAGNETS. THE MAGNETIC FORCE FIELD IS SHUNTED IN THE IRON CORE
UNTIL IT IS AWAKEN BY THE COILS..CAPISH,,
EVEN MORE EFFICIENT..
SUPER SUPER MOTOR..THANKS TO LANCA V SHARING.
EVEN MORE SUPER DOOPER.
I don't want to impose, just for information (https://sites.google.com/view/non-fuel-energy-generating/non-fuel-device?authuser=0). The flywheel is a capacitor, and must operate in pulse mode. However in any case, the generator needs to be done to the system, and many more interesting options.
Hi all, Hi rakarskiy, thanks for sharing.
Yes, have a pulse motor controller built that may help serve that function.
Cut the flywheel discs today, just need to secure the 3 discs together and continue on the main support structure.
Will post some pics tomorrow sometime.
peace love light :)
Quote from: SkyWatcher123 on August 07, 2019, 11:42:48 AM
What do you expect from this setup except the stored energy in the flywheel that was supplied by the scooter motor?
Vidar
Hi all, Hi low-Q, we shall see apparently.
Here is the progress so far.
Will screw the three 1/2" thick mdf discs together, which form the flywheel pulley and then work on the structure supports.
peace love light :)
(https://i.postimg.cc/fJJ5nnmx/flywheel-generator1.jpg) (https://postimg.cc/fJJ5nnmx)
@Sky Watcher
Please forgive me to meddle here. If you say so, I`ll delete this post.
@seychelles
Your post#4 (image) is a crude drawing of Mr. Tinman "nonsense pulse motor"
It would be polite and fair to mention the original inventor when posting.
Some details are changed but the fundamental concept is same.
kind regards
Alvaro
Hi alvaro_cs, you're fine and thanks for looking at the thread.
This project aims to use mostly off the shelf items and homemade items, such as the homemade pulse motor controller.
Though a cheap boost converter may work also, for adjusting motor speed from 12 volt battery.
peace love light :)
Hi all, the project is progressing well.
Completed the flywheel support structure and painted the flywheel to protect against moisture.
Will work on the motor support structure next and v-belt and pulley install.
peace love light :)
(https://i.postimg.cc/FdXLMZSL/flywheel-generator-project-2.jpg) (https://postimg.cc/FdXLMZSL)
Nice wood work SkyWatcher123. Looking forward to see more :-)
Vidar
Hi Skywatcher123, I really look forward to seeing your results with this. A lot of youtube vids seem to show this type of setup working well but since I don't trust the truth in many youtube vids I will look forward to your results as I completely trust your information. One thing I've come to conclude over some years of looking at this type device (I think Chas Campbell device was the first one I saw that seemed legit) is that the flywheel needs to be fairly heavy and that a slightly loose belt on the shaft may be important - not loose enough to slip but loose enough that it might set up an oscillation. Just some thoughts and not at all sure this is correct. Best of luck in this project.
Hi e2matrix, thanks for the kind and positive words.
Will do the best I can to see some positive results.
Finished mounting the motor and motor pulley support structure.
Next step is to get a v-belt that fits , meausred around 48" long, for the 3:1 pulley ratio on motor to flywheel shaft.
Then, will start mounting the permanent magnet alternator and long v-belt.peace love light :)
(https://i.postimg.cc/G9SLGGQT/Flywheel-project-motor-mounted.jpg) (https://postimg.cc/G9SLGGQT)
Your design is pure shit, did you even look at the Chas Campbell video and try to replicate his build? Why is his thing so shaky? How to interrupt the driver wheel from wheel to source and back again and just give enough force
to drive it.
If we are to believe the pseudoscience, then at least follow some theory other than just connecting 1v1 on a static frame. I believe however that this technique does not work since Chas Campbell has not been heard from.
believe I have solved these devices, and will refer to them as kinetic oscillators, they simply are a form of pulse magnetic motor, but with pulleys.
But not like Bedini, this is like ideal magnetic situation, tangantial and shielded, so dollar for dollar it is in fact superior technique.
The trick revolves around pulley squeeze by hidden eccentric or on a hidden eccentric on floating bouncy wheel and any variation thereof.
So you must engineer the bouncing frame accordingly and make use of that, with the pulleys.
Thus creating pulses of tangantial force, and this causes OU when right freq is hit, and this depends on load, too much load and the oscillation dies.
Think variable loading jus before the point of degeneration. The big Flywheel absorbs this but your must regenerate it.
Know your place padawan, listen to rakarskiy.
Hi all, still working on the flywheel project, just taking my time and not rushing it.
Have the alternator and long belt lined up and mounted, need to get a short belt for the drive motor and then adjust both sides for proper belt tension.
All positive and helpful replies welcome. ;) :)
Bad, bad design.
Show the design and I will confirm if good or bad. You need 3 wheels, + a static bouncer wheel. The motor has a wheel between it and the intermediate bouncy frame wheel. The intermediate wheel drives the big wheel with proper frequency according to your load, wich should be adjustable. The tension of both ends of the intermediate should be adjustable, the weight of the eccentric should also be adjtstable The pulley themselves can act as a spring to a certian extent but a static wheel can also absorb that shock. But your design objective is to find the perfect middle ground of tensions, so as your eccentric intermediate wheel can act as a sort of clutch/transistor, and minimize wasted friction with pulleys in this exchange.
Keep in your place, padawan. Negative feedback is what you need.
https://www.quora.com/Does-centrifugal-and-centripetal-force-acts-on-the-electrons-of-an-atom
Investigate this.
If the electron and protons are being affected by centrifugal force, is it possible that they can cause a wave like motion that persists in the flywheel and helps us multiply our force and reduce our recharge cost? And we just "keep pulsing" to keep it all working.
Maybe using acceleration/deceleration cycles accomplishes the miracle you seek.
The question I am asking myself is first of all, how does this even look like inside the solid balanced flywheel, in terms of mass distribution and the motions of protons, do the protons rotate around an axis or they oscillate back and forth? Second, is if the rate at wich you are accelerating/decelerating your flywheel with described technique(based on my gut instinct and watching the video) is even fast enough to have an effect (beneficial) on the molecular structure.
Because I am pretty sure that Chas Campbell uses the eccentric technique I described for you.
I saw your little comment on energeticforum.com
For an old guy, you sound awful lot like a thin skinned millenial.
This is because I know exactly who I am dealing with, a girly dude, a "my feelings first" type of builder, red paint vs not having anything adjustable, I know you dont feel adding all the gear I told you,you like doing it your way, just another a non-cooperative old guy. These people I like to troll, I dont like them, they cramp my style and discourage everything because they are just bad.
Why do you do have do do these projects? Its not for you, you should do gardening and help around with other things.
Its too bad you know... Your whole attitude. Because I have a special design for this, a flywheel experimenters dream, a fully adjustable test bench, a researched design that is a "doubler" of the effect I described for you, basically an assault of the Flywheel by massive force inputs, the kind of numbers you could never get with magnets, with carefully placed pulleys, and tension wheels.
I'm taking over this thread, I'm the captain now thx 8).
here is some interesting litterature
http://www.zamandayolculuk.com/html-3/space_warp_principles.htm
http://www.resonantfractals.org/Magnetism/Flywheel.htm
Hi armcortex, thanks for the productive aspects of your posts, the other things and assumptions will be ignored and you are forgiven always.
Please continue to share, It's not your thread or mine, it's all of ours, to share ideas with mutual respect.
It is unfortunate you have difficulty with that, though I will read anything you wish to share.
Though it is my choice which path I take, just as you are free to choose your path.peace love light :)
https://www.youtube.com/watch?v=2qyvX9j5i3U
https://overunity.com/4672/accelerating-forces/msg96915/#msg96915
Listen to David Lowrance, he is special.
I am not forgiven, you are forgiven, for now. But you must become more obedient.
Read David's post, and see what applies and what doesnt. Then, see what I said about the eccentric and see if it applies (Its my opinion), then, go watch the other Chas Campbell videos.
Now, try to improve your design to succeed. Your flywheel needs to act like a magic dean drive but Force is at the circumference right where you want it instead, the energy comes from the Dean drive effect.
Flywheel Energy Multiplier Mini Project 2019
https://www.youtube.com/watch?v=XJ761y8G06g
I am glad to inform you that the technology of generating electricity with a flywheel in the design (or rather its multiplication), has been mastered in the city of Ufa (Russia).
Video clip1 (https://www.youtube.com/watch?time_continue=38&v=owq9U9yPTS4&feature=emb_logo)
Video clip2 (https://www.youtube.com/watch?v=uevz76PVQGY)
Video clip1 (https://www.youtube.com/watch?v=1GCDCkSHam8)
everyone can get acquainted with the design.
