Overunity.com Archives
Solid States Devices => solid state devices => Topic started by: trevstar on August 11, 2019, 11:24:48 AM
Title: Simple Overunity Method With Capacitors
Post by: trevstar on August 11, 2019, 11:24:48 AM
Hello all.
Has anyone tried the following method or are there any threads on this? I first saw this years ago.
"Make yourself a test set up. Use 2 large low voltage capacitors. Make sure one is about 1/2 the capacity of the other. Charge the smaller one fully and discharge it into the larger one. Take measurements on both before and after discharging them together to see how much power is transferred.
Now do the same with a small bulb in series as you discharge the small cap into the larger one. Measure the power levels in both caps. You will have some light produced and some heat, but the WHOLE charge is transferred to the other capacitor!!"
those paragraphs are quoted from the following site
www.linux-host.org/energy/sgcarter.html
The guy insists that it worked for him. There is some question about if the original charge remains in the smaller cap.    Has this been discussed here already?
Thanks,Trevor
Title: Re: Simple Overunity Method With Capacitors
Post by: poynt99 on August 11, 2019, 02:44:30 PM
Yes,
This "new idea" has been beaten to death a few times. There is no gain or OU, or Free Energy of any sort with this.
I did a detailed analysis of cap-to-cap energy transfer years ago. The file is still here.
https://overunity.com/downloads/sa/view/down/209/ (https://overunity.com/downloads/sa/view/down/209/)
Post by: trevstar on August 11, 2019, 03:26:06 PM
Thanks,I appreciate the link.That answers the question.This has been discussed
Also, there is no overunity.
On to the next topic!
Trevor
Post by: shylo on August 12, 2019, 04:41:19 AM
Hi Trevstar,
You can transfer a charged bank to an identical bank and preform work in the process.
You will lose some but not 50%.(with the right circuit)
The work I'm trying to do is running a generator/pulsemotor that adds charge to the banks so they don't deplete.
artv
Post by: Jeg on August 12, 2019, 06:44:09 AM
Quote from: shylo on August 12, 2019, 04:41:19 AM
Hi Trevstar,
artv
I agree with artv. I do the same and i have only 14% losses instead of 50%. I find it possible to reach even higher levels of efficiency.
ps. It is more appropriate to calculate energy than charges. https://www.electronics2000.co.uk/calc/capacitor-charge-calculator.php
Post by: trevstar on August 12, 2019, 10:28:22 AM
Well that is INTERESTING
Thanks Artv and Jeg. So I can discharge one cap into the other and run a load and only loose  14% of the charge.  That is promising.  Certainly worth looking into.
Post by: Jeg on August 12, 2019, 10:40:00 AM
Quote from: trevstar on August 12, 2019, 10:28:22 AM
.... and only loose  14% of the charge.
Hi
You should better look at the attached calculator above. Total charges are the same after discharge. Losses take place at the stored energy, because energy depends on the square of the voltage. :)
Post by: trevstar on August 12, 2019, 04:00:12 PM
artv
Do you have more info on this?  I have only basic electronics knowledge so please give the simplified version if you could.
Thanks,Trevor
Post by: LazerBolts on August 25, 2019, 12:42:52 AM
The circuit seems far too elaborate to work which then would consume effort it appears to be published without providing adequate measurements.
Post by: mmm4free on June 19, 2022, 06:34:45 PM
Quote from: trevstar on August 11, 2019, 11:24:48 AM
Hello all.
Thanks,Trevor
Link is offline, take one of this snapshots.
https://web.archive.org/web/20140501000000*/http://www.linux-host.org/energy/sgcarter.html
Post by: stivep on June 19, 2022, 07:46:06 PM
Quote from: poynt99 on August 11, 2019, 02:44:30 PM
Yes,
I absolutely agree.
OU doesn't exist,
Perpetual motion doesn't exist,
Free Energy is just the energy that does not have to be paid for but it must come from somewhere
In other words if nature pays for this energy then this is Free Energy.
you may have free food at home. if you're Father pays for it too.
There is no gain nor OU nor any Free Energy or any sort of this in such  capacitor based configuration.
Thank you for your job, as you spend a lot of time to make PDF.
The only what I didn't see there is word impedance.
Resistance is only the property of DC , however it applies to AC only as purely resistive in it's nature <component.>*
Impedance is only the property of  AC characterized by
–XL inductive reactance
–XC capacitive reactance
whenever we are dealing with discharging capacitor we are dealing with AC and impedance- not with the resistance alone.
The same  is with e.g rectangular impulses were leading-edge and trailing edge are AC
and top of an impulse (the highest amplitude) is DC.
note:by word <component.>* we understand purely resistive resistor that does not have any reactive XL  and XC
        Coil in DC, is only resistive and is not  reactive.(no XL)
        Capacitor in DC acts as an open circuit and after is charged or discharged is no longer reactive. (no XC)
Wesley.
Post by: nix85 on June 19, 2022, 08:26:13 PM
https://en.wikipedia.org/wiki/Two_capacitor_paradox
Post by: norman6538 on June 22, 2022, 09:40:49 AM
Stivep said "I absolutely agree.
OU doesn't exist,
you may have free food at home. if you're Father pays for it too."
But that does not explain the Finsrud machine nor my pendulum that is dropped from 2pm and travels up to noon and falls back to 6pm....
The pendulum secret is in the magnetic spin. When mag polarity is flipped it does not work.
Norman
Post by: kolbacict on June 22, 2022, 11:00:39 AM
Quote from: norman6538 on June 22, 2022, 09:40:49 AM
Norman
Not only did you succeed.
Here a friend writes that he also achieved something.
https://overunity.com/19160/overunity-phisics-experiment/msg568232/#msg568232 (https://overunity.com/19160/overunity-phisics-experiment/msg568232/#msg568232)
only to me nothing doesn't work . But I need it more than anyone...
Post by: alan on June 22, 2022, 11:31:53 AM
The energy of capacitors is comparable to elastic compression.
OU is possible, take a magnet, bring an iron ball to its field, and when it starts accelerating, the kinetic energy of the ball increases without energy input, W=F.s work is done. The energy input is EFTV.
Post by: Tijean on June 22, 2022, 05:15:10 PM
I like the alternative view in the 2 Capacitors Paradox, wich is said, if you take a capacitor charge with positive and another one charge with negative and connect them with a perfect conductor, the result will be 0 volt,,, where the energy has gone,,, Isn't it a Scallar wave effect ???
Jean
