https://vyrdudji.com/images/yootheme/blog-16.jpg
https://www.youtube.com/watch?v=-ZAH24-z9m8&feature=youtu.be
QuoteYevgeny Khomyak (Ukraine): this video shows the device and connection of the vyrdudji BTG system that I developed. In the next video, I will clearly show all the input and output parameters of this BTG (self-propelled motor).
Author's website: https://vyrdudji.com/
The next video will tell you about the parameters and features.
Awesome.
I see you use an ESP8266, ESP-12S.
I am using the same module in this board I am building.
What do you think of my theory, for the construction of a Flywheel testbench, unrelated to this engine of yours. The flywheel should never decelerate in the "charging period", its acceleration graph must be clost to zero yet positive or higher.
Extra energy could perhaps be a possibility, but only in a few ways. A physical characteristic that is not well defined is reaction force time.
http://www.halexandria.org/dward133.htm
Since static physics is well defined we cant discover anything, whatever they say, goes, 100%. So lets go where they dont even have formulas for yet, areas to discover have to do with lag of reaction force during impulse.
Now you must find a way to input a disconnecting flywheel onto a greater flywheel, and find an arrangement where the delay is so delayed
that you actually have time to physically decouple using a system that you make. Thus causing a bug in the system and every action or lack of has a reaction, now we are entering the zone, that has a beat frequency. Using an eccentric wheel, one can translate an intermediate wheel in high tension or no tension zone, and if a squeeze static wheel is there to limit the movement an oscillation can be had between it and the input static wheel wich is attached to the input motor.
Now the magic happens when you communicate with the stuff around you, at the magic frequency,This will cause a vacuum to form with the universe and you will take in energy from a localized orberth effect from the universe just as a space probe. Slowing the universe down.
We must find ways to oscillate things in the varying of the acceleration, pulse, the third derivative wich will interact with the universe. For the goal is to use a machine that has a localized orberth advantage,
And you cant constantly gain velocity either, at some point you must connect to release the energy and disconnect the output so start back up, and so on. In a sawtooth fashion.
Lets say the third derivative oscillation resonates to soften things, it preps the area for you to suck it in.
Answer the Flywheel question? You have been quiet lately with regards to flywheels, are you not motivated by them?
You dont think Chas Campbell made it work do you?
You showed this on energeticforum.com your circuit but Skywatcher wasnt too motivated.
I guess he picked it up and made good use of his 3d printer, I'm impressed by his electro-mechanical design skills It gave mea few ideas.
Quote from: Toolofcortex on January 22, 2020, 12:59:50 PM
The flywheel is a storage device, and for our purposes it can only work in a pulsed kinetic circuit. For example, the question: What is a charged electric capacitor? How to determine this? Second question: What is a charged flywheel? I have my own point of view on this issue, set out in my book.
Yes, your books are very nice, I am still reading.
I will use for reference for my Testbench.
Quote from: rakarskiy on January 22, 2020, 02:54:18 PM
If a flywheel is a mechanical capacitor, then what is a mechanical inductor?
Quote from: Toolofcortex on January 22, 2020, 05:38:36 PM
The flywheel is a mechanical inductor. A balloon or pressure storage tank is a mechanical capacitor. A spring could also be considered a mechanical capacitor.
An inductor is a part of an electric machine that is responsible for creating a working magnetic flux in it. As an inductor, both the rotor and the stator can act.
The capacitor is designed to store charge and energy of the electric field..The capacitor is a passive electronic component. The capacitance of the capacitor is measured in farads.
A flywheel is a massive rotating wheel that is used as a storage device (inertial accumulator?) for kinetic energy or to create an inertial moment.
The principle of operation of the capacitor is as follows: when an external EMF source is applied to the capacitor plates, the dielectric located between these plates begins to accumulate energy in the form of an electric field.
The word accumulator is translated from Latin as (accumulo) - collect, accumulate. The algorithm of this product is as follows: It uses a reversible chemical process that takes place in the electrolyte and on the electrodes (cathode and anode).
That is, the principle of operation of the flywheel is suitable for comparison with the algorithm of the capacitor, not the battery. The battery stores energy in the form of a reversible chemical reaction. The flywheel receives kinetic energy, which it accumulates. The capacitor receives electrical energy and accumulates it.
You can also compare the flywheel and the condenser with the verb CONDENSE. An inductor is a Converter of electrical energy into a magnetic field. What did you want to compare, which mechanical means converts mechanical energy into a magnetic field? Sounds like fun.
What about this nonsense here? Is it the international scam mafia again?
What is it with people and big costly investments that dont work? This thing must cost at least 50,000$
I mean yeah... The camera is filming and they are acting busy? Are they gonna call the prince of Saud and threaten him??? WTF is this cheap video accomplishing anyways?
https://www.youtube.com/watch?v=g_Z1S_1GlxA
What of the German flywheel engine that went into submarines in your book?
Form what I see, This and the Chas designs would have slower delay vs the indian 1 shaft design.
This obviously can only be and must have to do with impulse delay. The thing is, in this Turkish video I see nothing that ressembles an eccentric or loose flywheel
that could act as a disconnecting force and the sprocket seems totally circular. So the reaction time will be there, only slightly more delayed than a straight shaft. Or maybe its all in the output thyristors ?? Mess with the CEMF???
But also, there is a second part to this, this I take from the user "libra-spirit", If the electrons in the flywheel and protons go by centrifugal force, what happens when there is an oscillation of acceleration?
Does this "movement" cause some sort of motion in the "ether".. I mean, ever since the Schwartz thing all bets are off... What are "solar rays"???...
I see some turkish comment, video, about "axial flux generator"... Is this what the Turkish originator is telling his people?
https://www.youtube.com/watch?v=OopKS0DlQz8
And a good recap...
https://www.youtube.com/watch?v=hZ1sfTmDvnw
The first we can't say if we don't know for sure (neither confirmation nor reverse). The Turkish company is not alone. First, there is no address and price list for the purchase, which is a fraud? For a moment, imagine the material resources spent on construction! Why make a video and make us laugh? How this design can work, I described, it turns out, you have not read. Second, where did I get the flywheel of a German submarine's engine? Again, you don't have information about the content. Another principle was discussed there, and today there is a variant of another. In total, two technologies of such systems came out of Germany during the Second world war, but I did not consider flywheels there. One technology is being developed under the patronage of the us and Russian governments. There are more than single engines and generators.
I did not read, its a tough pill to swallow.
Get the right russian translater for img, then swallow.
Anyways if you are not building it, you should tell us about it maybe somebody will pick it up.
Whats your design idea?
Its rare I see people willing to build big Flywheels and be dedicated enough.
Yeah I have the Russian version of Rakarsky's book, I chose the wrong site.
I would like to buy the English version but I know I am not in a position to make it right now so I am holding back.
It is good knowledge to keep as reference.
I think its unfair for the non-russian speakers to try and get a build going I wonder if this is not the russian Goverment trying to get russians across the world to rule over us as we cant decrypt all this russian info, quite sad... Everywhere I look its all russian img, where is the good english researchers @ ??? Are we dumb ?
Quote from: Toolofcortex on January 23, 2020, 11:59:27 AM
Check email.
Splendid.
I am getting close.
This is just excellent research and good recap of everything, and for anybody thats truely an inventor and your info is everywhere.
Now you got a reference, concrete stuff about what you will be facing.
You gotta keep an open mind you know... Apply these skills to your own design.
I see you have many suspicions with regards to Chas Campbell,
One thing tho, could it not be that the flywheel attached to the wooden plan be in fact eccentric, wouldnt we need a shifting intermediate to dodge the force reaction?
What happens in the event that the force reation has been dodged? What physical manifestation does this incur?
Quote from: Toolofcortex on January 23, 2020, 01:53:48 PM
On the contrary, I think its design is the standard. Whether or not there was an eccentric, I have no information. The design I was considering also had no eccentricity. With an eccentric, its shafts would simply not hold up.
You misunderstand me.
An eccentric weigh ( hidden in a circular wheel), a wheel that is loose on hinge or totally free, between the pulleys, 2 sets of pulleys to keep this balanced and straight, with a wheel limiters as to not cause wear on the pulleys and in case of disaster.
Centrifugal shift that would cause a disconnect/connect on a input side, and output side. With advantageous delay and perhaps a resonance in the ether?
Not on a shaft.
Well, it seems I am surprising you with this what if question?
