Seriously !
Not only a joke, but it also works better than gravity alone.
Little did that play ground bully, Brutus, know, that hidden under the ground and within Archimedes diaper were magnets.
Now we know where Archimedes got his brains !
OOPS that's
Veljko Milkovics not Mikhail Dimitriyev.
https://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/
sorry
floor
Different Brutus same personality type.
Latest info 2019 @
http://www.vemirc.com/wp-content/uploads/2020/03/2-550-155982040271-76.pdf
Maximum efficiency of oscillator utilized for pumping the water corresponds to 92.07%.
quotes
"International Journal of Mechanical and Production Engineering, ISSN(p): 2320-2092, ISSN(e):
2321-2071 Volume -7, Issue-3, Mar.-2019, http://iraj.in
Optimum Parametric Analysis of Mechanical Oscillator for Pumping Application71
OPTIMUM PARAMETRIC ANALYSIS OF MECHANICAL OSCILLATOR FOR PUMPING APPLICATION
1
REJIN BALACHANDRAN,
2
NANDU A,
3
NIRMAL M S
1,2
Student, Department of Mechanical Engineering, Mar Baselios College of Engineering and Technology, Mar Ivanios Vidyan agar Thiruvananthapuram, Kerala, India
3
Assnt. Professor, Department of Mechanical Engineering, Mar Baselios College of Engineering and Technology, Mar Ivanios Vidyanagar Thiruvananthapuram, Kerala, India
E -mail:
1
rejin777msd@gmail.com,
2
nandu02792gmail.com"
"Abstract
2 stage mechanical oscillator is a mechanism with new mechanical effects. This was invented by a Serbian scientist, Veljko Milkovic. It is a source of clean energy. In this mechanism,
we use a higher efficient energy transformation from the input to the output side of the mechanism. A pendulum oscillates on one side of a lever, which is pivoted. The
oscillation of the pendulum is converted to output via the lever. The output contains a
bellow, which uses the reciprocating motion to pump air and water. Various analyses like length ratio, weight ratio and efficiency test were conducted with the fabricated oscillator. Oscillator is constructed with a telescopic pendulum which facilitates the adjustment of length. The
pivot position as well as the weight ratio of the lever is varied throughout the experiment and the optimum location and weight ratio corresponding to maximum discharge is found out. Maximum efficiency of oscillator utilized for pumping the water corresponds to 92.07%. With the improvement of the mechanical oscillator can be effectively used for pressurizing the working medium - air."
floor
I still intend to build / test a small device for my self.
I did a study on computer instead of a build. see below
more
floor
Magnets under the swing would be the equivalent of a stronger gravity under one side of the lever.
But on one side only. Would this make a difference in the final outcome ?
floor
