The pcb can modified using easyeda and can be printed from jlcpcb
https://easyeda.com/
https://jlcpcb.com/
Upload the Gerber zip file jlcpcb,pay ,you will get 10pcb for 5$to 10$ plus shipping,delivery in 10days
pwm tested
Egs002 based 310-400v DC to ac 220v, 2kw circuit
Zvs
Tesla pulsing circuit side which is marked in red ,taken from akula0083 circuit
https://realstrannik.com/forum/attachment/21000
the Russian circuit is tested and modified to working from 8 khz to 150 khz ,can the cap " c22 "on sg3525 from (10 nf to 1 nf ),
if push pull is not used ,we can you this circuit board as above pulse packer circuit along with the driver
Nice. But how to adjust it , how to make a working device coil design and so on ?
Thanks! But part numbers on schematic are totally different than part numbers on PCB. Is there any PCB compatible parts list available?
Which one is it.
See the schematic in the pdf not in the photo's.
It should be same.
Download the esayeda software you can edit the circuit and also get the part list there
Quote from: forest on February 26, 2021, 06:28:21 AM
Well that's a good question .
I cannot answer that .try it .
Rusla's friend told all the circuit are open sourced .
The circuit in the net is enough to make Ruslan device
