Re: O.U. Magnet force shielding 2 and so on (https://overunity.com/18876/o-u-magnet-force-shielding-2-and-so-on/msg558220/#msg558220)
What if : (force time displacement) = kinetic energy , geral theory ,linear
kinetic energy x k = usable energy,specific theory ,translatoric
https://en.wikipedia.org/wiki/Kinematics (https://en.wikipedia.org/wiki/Kinematics)
K-reis-Verschiebungs-Winkel/-Grad angular/momentum Drehung/Wechsel
about "distance" and/or "time" fine tuning
http://www.rexresearch.com/kenyon/kenyon.htm (http://www.rexresearch.com/kenyon/kenyon.htm)
"lumens machine" has to be electric : minimum a. for A,B, Group pm fine tuning controle
b. for output torque x rpm (linear) controle,by translated pm force max.
Related the attraction/repulsion force difference :
http://jnaudin.free.fr/html/2magpup.htm (http://jnaudin.free.fr/html/2magpup.htm) but the tangential repulsive force measured is 574 g.
the axial repulsive force measured is 1254 g
Did You attractive force and repulsive force difference measurements ?
Unruh-Principle ! unruh = restless ,the "automatic clock/watch" batteryfree work process
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Unruh_%28Uhr%29 (https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Unruh_%28Uhr%29)
from spring-quenching watches to automatic to quartz to kinetic
https://iknowwatches.com/seiko-automatic-vs-kinetic-watches/ (https://iknowwatches.com/seiko-automatic-vs-kinetic-watches/)
http://www.rexresearch.com/invnindx.htm (http://www.rexresearch.com/invnindx.htm) A-Z
specific magnetism related
http://www.rexresearch.com/dyke/slntwpn.htm (http://www.rexresearch.com/dyke/slntwpn.htm) weapon or tool/instrument
http://www.rexresearch.com/wadle/wadle.htm (http://www.rexresearch.com/wadle/wadle.htm)
http://www.rexresearch.com/davis/davis.htm (http://www.rexresearch.com/davis/davis.htm)
http://www.rexresearch.com/dotto/dotto.htm (http://www.rexresearch.com/dotto/dotto.htm)
volumetric air space as "air core" for transformation
mono-coidal or helicoidal or multi-coidal (dis-/advantages)
instead air as core liquid or solid,non-/ferrous
mangnet field lines polarisation,electro field lines + magnet field lines polarisation
131 years back,publication,relatively unknown,zero citations :
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=427606A&KC=A&FT=D&ND=3&date=18900513&DB=EPODOC&locale=en_EP (https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=427606A&KC=A&FT=D&ND=3&date=18900513&DB=EPODOC&locale=en_EP)
description : row 22 +
( experiments : one coil charging or both ,direct current or alternating current or pulsed or mixed )
ERICH Kaifler,Ex-SIEMENS-er :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=kaifler&CPC=&IC=&Submit=Search (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=kaifler&CPC=&IC=&Submit=Search)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=27&ND=3&adjacent=true&locale=en_EP&FT=D&date=20011129&CC=DE&NR=10025289A1&KC=A1 (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=27&ND=3&adjacent=true&locale=en_EP&FT=D&date=20011129&CC=DE&NR=10025289A1&KC=A1)
Patten and Kaifler,but micro-/nano
electro-/magnetism and temperature/pressure
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thercond.html (http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thercond.html)
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8502303A1&KC=A1&FT=D&ND=3&date=19850523&DB=EPODOC&locale=en_EP (https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8502303A1&KC=A1&FT=D&ND=3&date=19850523&DB=EPODOC&locale=en_EP)
http://www.chenyang.de/hauptseite.htm (http://www.chenyang.de/hauptseite.htm) Magnet Arrangement and Magnetic Circuits of Magnetic Assemblies
because each topic by me has archive function :
https://www.youtube.com/watch?v=dOyYYoPIAlM (https://www.youtube.com/watch?v=dOyYYoPIAlM)
https://magstar.eu/wp-content/uploads/2021/01/Tesla-oscillator-july-1919-electrical-experimenter.pdf (https://magstar.eu/wp-content/uploads/2021/01/Tesla-oscillator-july-1919-electrical-experimenter.pdf)
"...circuits ..." = phase/s
" 85% can be recovered = can be efficiently transform-ed/-ated : input/primary and output/secondary
??? vibrating spring Diapason function ? harmonics/resonance
Helmholtz Hohlraum cavitator/resonator Hohlraum = Vakuum/Vacuum cavitator= chamber/Roehre/tube
Otto v.Guericke
In public he demonstrated the power of air pressure with spectacular experiments. He achieved special attention in 1654 when he was on the Haidplatz in Regensburg on the occasion of a Reichstag in the presence of Emperor Ferdinand III. and had spectacular experiments performed by many princes on the effect of air pressure. [3] In the summer of 1657, Guericke had put two large hemispheres (¾ Magdeburger Elle) made of copper (Magdeburg hemispheres) together using a seal and pumped the air out of the interior. Then eight horses were harnessed to each hemisphere, one after the other, which they were supposed to tear apart, but this did not succeed. When the balls were filled with air again, they fell apart on their own. In another attempt, Guericke had a cylinder with a movable piston set up. A rope was attached to the piston, which ran over a pulley and was held by 50 men. When Guericke sucked the air out of the cylinder, the men could not prevent the piston from lowering because the atmospheric air pressure was stronger against a vacuum. That was the momentous invention of his hoist.
With his experiments, Guericke confirmed conclusions that Blaise Pascal had drawn ten years earlier from the experiment Void in the Void. Furthermore, his experiments and inventions showed that nature knows a vacuum. The "horror of the void" (Horror Vacui) postulated by Aristotle was thus refuted.
https://de.wikipedia.org/wiki/Umformer (https://de.wikipedia.org/wiki/Umformer)
In electrical power engineering, a converter is a mechanical combination of rotating electrical machines that convert one type of current into another, for example direct current into alternating current. A conversion between alternating currents with different frequencies is also possible; frequency converters are used for this.
Converters and, in particular, frequency converters have a similar area of application, but in contrast to converters they represent a power electronic device without mechanically moving components.
we call this today DC/AC inverter +frequency converter ,german Wechsel(strom)Richter und Frequenzumrichter
or time-/function-/pulse-/frequency- generator = oscillator https://en.wikipedia.org/wiki/Electronic_oscillator (https://en.wikipedia.org/wiki/Electronic_oscillator)
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.udo-leuschner.de/basiswissen/SB123-05.htm (https://translate.google.com/translate?sl=auto&tl=en&u=https://www.udo-leuschner.de/basiswissen/SB123-05.htm)
https://en.wikipedia.org/wiki/Polyphase_system (https://en.wikipedia.org/wiki/Polyphase_system)
https://www.yourelectricalguide.com/2017/04/purely-resistive-inductive-capacitive.html (https://www.yourelectricalguide.com/2017/04/purely-resistive-inductive-capacitive.html)
https://en.wikipedia.org/wiki/Scott-T_transformer (https://en.wikipedia.org/wiki/Scott-T_transformer)
Interconnection[edit (https://en.wikipedia.org/w/index.php?title=Scott-T_transformer&action=edit§ion=1)]
At the time of the invention, two-phase motor loads also existed and the Scott connection allowed connecting them to newer three-phase supplies with the currents equal on the three phases.[3] (https://en.wikipedia.org/wiki/Scott-T_transformer#cite_note-All_About_Circuits-3) This was valuable for getting equal voltage drop and thus feasible regulation of the voltage (https://en.wikipedia.org/wiki/Voltage_regulation) from the electric generator (https://en.wikipedia.org/wiki/Electric_generator) (the phases cannot be varied separately in a three-phase machine). Nikola Tesla (https://en.wikipedia.org/wiki/Nikola_Tesla)'s original polyphase power system (https://en.wikipedia.org/wiki/Polyphase_system) was based on simple-to-build two-phase four-wire components. However, as transmission distances increased, the more transmission-line efficient three-phase system became more common. (Three phase power can be transmitted with only three wires, where the two-phase power systems required four wires, two per phase.) Both 2 φ and 3 φ components coexisted for a number of years and the Scott-T transformer connection allowed them to be interconnected.
https://en.wikipedia.org/wiki/Polyphase_coil (https://en.wikipedia.org/wiki/Polyphase_coil)
2D/3D monitor dimension
Quote from LankaIV
END of that quote
Not of that design.
Lumen's / Telecom's design does not need an electric component in order to
arrive at more kinetic energy output than kinetic energy input.
although
It might be improved by controlling or adjusting one or more of the field
intensities as distances change ? Maybe electrically ?
Permanent magnet interactions are more simple than
electro magnet interactions.
1. Field fluctuations occur mostly outside of the permanent magnets.
2. Inductance and reactance, need a conductor.
A conductor is absent from the permanent magnets (mostly)
3. capacitance and its aspects, need a dielectric and electric
charge environment, also absent from the permanent magnets (mostly).
It should be interesting to begin to establish correlations between the two
in an O.U. context
best wishes
floor
Floor,I could constate your argument,if we have not specific use targets : rotative,linear ,both,converting,et cet.
Yes,a ready to use permanent magnet (undefined,ARNOLD : 4000 pm configuration variations ) is easier looking than an electro-magnet and its process !
force per gram/cbcm :
https://patents.google.com/patent/US8847720B2/en
How big an equivalent permanent magnet ?
Wmbr
OCWL
yes, of course and I agree.
Establish a goal or set of goals ? Specifics ?
A particular design or class of designs ?
What would you like to approach ?
floor
Given that we are considering the displacements caused by permanent
magnet forces as energy.....
We can label either of these two as energy density (in that context).
The greatest magnitude of magnetic force / field density (of record) has been
arrived at through the use of electromagnets.
The greatest magnitude of magnetic force / field density per unit of
mass and or weight (of record), has been arrived at through the use of permanent
magnets (considering also, the electric supply source for electromagnets).
Rotating devices conserve energy as momentum.
Linear devices must expend energy to cause acceleration over and over again.
Energy expended to cause acceleration is the product of both the mass of the
accelerated object and the speed to which that object is accelerated.
Low mass and slow speed will reduce energy wasted as accelerations.
But also....
Large displacement (long output strokes) will reduce the number of accelerations
needed per unit of time.
High force, slow output stroke speed, low mass and long output strokes= high
efficiency and high power.
Convert this to high speed continuous rotation after the initial kinetic energy
production as desired.
The bottom line is that arriving at large Joules per second in not limited to RPM (rotations per minute).
A little from this
https://patents.google.com/patent/EP1821391A1/en (https://patents.google.com/patent/EP1821391A1/en)
easier/more complex than ... ? https://patentimages.storage.googleapis.com/31/0c/eb/9606fb3f8a0657/imgf0003.png
and
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19810301&CC=SE&NR=8006009L&KC=L (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19810301&CC=SE&NR=8006009L&KC=L)
We are able to pick and choose some things in life, other things, we cannot.[/size]To be able to have / experience life is a temporary arrangement.This is not an option.Humans are a / one of, the major forces on this planet.We are "intelligent" and optionally we may behave accordingly.Life's experiences and the universe are bigger than man's intelligence, immeasurably so.This is not optional either.That which created us and sustains and holds us is ultimately in charge.Our choices matter.People are often frustrated and feel ineffective.Every moment holds the potential for any individual to bring forthsomething of great value. Each one of us has far more effect upon those around us than we generally are inclinedto acknowledge. It's big. it's significant. It matters. We matter. We are effective andaffecting.This is not optional.No matter "where one is coming from" it is legitimate and has value, whenit is expressed honestly / when we acknowledge our own responsibility for theeffects, our expression will have.But we all too often are in denial of this fact, and / or may feel as if we are powerless.We aren't.
:o ,wie : 8) erfahrungsgeschwaengert !
1.Hochschule von Alexandria https://de.wikipedia.org/wiki/Alexandrinische_Schule (https://de.wikipedia.org/wiki/Alexandrinische_Schule)
2. STAR TREK,"DUNE" : ? / !?
3. Gott ist tot (F.N.) ,Ueber-ES (H.R.)
4. https://rationalwiki.org/wiki/Alex_Chiu (https://rationalwiki.org/wiki/Alex_Chiu)
5. https://www.spiegel.de/ausland/nigeria-boko-haram-chef-soll-sich-in-die-luft-gesprengt-haben-a-c2c31399-f462-4c1d-ad0f-90a2b08d3c5f (https://www.spiegel.de/ausland/nigeria-boko-haram-chef-soll-sich-in-die-luft-gesprengt-haben-a-c2c31399-f462-4c1d-ad0f-90a2b08d3c5f)
good : good good : bad bad : bad
6. https://genius.com/Monty-python-meaning-of-life-lyrics (https://genius.com/Monty-python-meaning-of-life-lyrics)
7. https://translate.google.com/translate?sl=hu&tl=en&u=https://www.bz-berlin.de/klassiker/op-erfolgreich-kopf-auf-fremden-koerper-transplantiert (https://translate.google.com/translate?sl=hu&tl=en&u=https://www.bz-berlin.de/klassiker/op-erfolgreich-kopf-auf-fremden-koerper-transplantiert)
8. https://en.wikipedia.org/wiki/Actroid (https://en.wikipedia.org/wiki/Actroid)
Model(l) : "Mini"-Golf https://upload.wikimedia.org/wikipedia/commons/thumb/1/16/Actroid-DER_01.jpg/800px-Actroid-DER_01.jpg (https://upload.wikimedia.org/wikipedia/commons/thumb/1/16/Actroid-DER_01.jpg/800px-Actroid-DER_01.jpg)
Maxi-Golf = 18-Loch/holes Mini= hole in 1 Loch-Karten-Schlitz,where ? Or wire-less payments ?
https://www.youtube.com/watch?v=eogpIG53Cis (https://www.youtube.com/watch?v=eogpIG53Cis)
alignment : natural (active/passive) or synthetical(active/passive)
we,as creature =Lebewesen,with anima=animal/s and eventually mamma=mammal/s wish/es to overcome situations :
barriers,frontiers : https://www.youtube.com/watch?v=MCCAaAso5VU (https://www.youtube.com/watch?v=MCCAaAso5VU)
too much,too less
in small(mind sphere),in great(body sphere)
By this we use experience,experiments :learning by other/s,by doing/mimikry/simulation to reach our target:
the right balance and satisfaction(temporal,local,object-related)
X : maximum to minimum,minimum to maximum
line track : V or U or their physical invers movement or ----- plan,flat
modelling cars : https://www.modellbau-berlinski.de/rc-fahrzeuge-und-zubehoer (https://www.modellbau-berlinski.de/rc-fahrzeuge-und-zubehoer)
modelling: race track https://carrera-toys.com/de/44/rennbahn (https://carrera-toys.com/de/44/rennbahn)
opto/inductive track,small https://www.youtube.com/watch?v=TcBnSp0SpcM (https://www.youtube.com/watch?v=TcBnSp0SpcM)
inductive track,great : https://en.wikipedia.org/wiki/Induction_loop (https://en.wikipedia.org/wiki/Induction_loop)
https://www.schlader.at/wp/wp-content/uploads/Autodrom.jpg (https://www.schlader.at/wp/wp-content/uploads/Autodrom.jpg)
modelling free 4D track https://www.rc-network.de/ (https://www.rc-network.de/) for free flying planes/jets,free swimming boats ,......
by wireless induction
autonomous induction experiment : https://ieeexplore.ieee.org/document/5618092 (https://ieeexplore.ieee.org/document/5618092)
test field :
https://i0.wp.com/motonewsworld.com/wp-content/uploads/2021/04/worldsbk-czech-autodrom-most-2.jpg?fit=1200%2C800&ssl=1 (https://i0.wp.com/motonewsworld.com/wp-content/uploads/2021/04/worldsbk-czech-autodrom-most-2.jpg?fit=1200%2C800&ssl=1)
target :
https://spectrum.ieee.org/transportation/advanced-cars/6-key-connectivity-requirements-of-autonomous-driving (https://spectrum.ieee.org/transportation/advanced-cars/6-key-connectivity-requirements-of-autonomous-driving)
sourced by autonomous energy generator dynamic circuit
about speed/velocity track specific records ,efficiency-independent :
https://en.wikipedia.org/wiki/Bonneville_Speedway (https://en.wikipedia.org/wiki/Bonneville_Speedway)
this records more efficiency related :
https://en.wikipedia.org/wiki/Shell_Eco-marathon (https://en.wikipedia.org/wiki/Shell_Eco-marathon)
in the german version (more informative than english version)
https://de.wikipedia.org/wiki/Shell_Eco-Marathon (https://de.wikipedia.org/wiki/Shell_Eco-Marathon)
translated :
Akkumulator /Batterie
Prototype: 2014 wurde vom Team TERA TU Graz ein neuer Rekord aufgestellt mit 1091,6 km/kWh.[7]
Urban Concept: Hier kam das französische Team Electricar Solutions 2012 auf eine Reichweite von 262,6 km/kWh – eine Steigerung um 29,6 km/kWh zum alten Rekord.[1]
accumulator
Prototype: In 2014 the TERA TU Graz team set a new record with 1091.6 km / kWh. [7]
Urban Concept: The French team Electricar Solutions achieved a range of 262.6 km / kWh in 2012 - an increase of 29.6 km / kWh to the old record. [1]
MARATHON RULES/CONDITIONING
The aim of the Shell Eco-Marathon is to drive as long as possible with as little energy as possible.
Each vehicle must cover a distance of 25 kilometers in a maximum of 50 minutes (this corresponds to an average speed of at least 30 km / h).
During this trip, the fuel consumption is measured.
In order to make the results of the different categories comparable, it is calculated how many (milli-) liters of super gasoline contain the same amount of energy as the fuel consumed.
Finally, it is extrapolated how many kilometers the vehicle could theoretically cover with the amount of energy from a whole liter of super gasoline.
To compare electrically powered and fuel-powered vehicles, the required amount of fuel in liters or the amount of energy in kWh is converted into the other unit.
The URBAN COMMUTER specifications :
Horn, rearview mirror and seat belt are just as mandatory in the Urban Concept category as fire extinguishers and roll bars.
The maximum width of the vehicles is limited to 1.3 m, [5] whereby the ratio between height and width must not exceed 1.25.
There are no restrictions on the design and use of materials for the vehicles.
let us look and listen to experimenter :
https://www.youtube.com/watch?v=UICxLbNRIgw (https://www.youtube.com/watch?v=UICxLbNRIgw)
0:28 vid accompanying moto-bike tachometer shows 45-48 Km/h for modified rated 350 W e-bike motorized speed velocity comparison
by flat street (back-/forward wind ?) and away moto-bike wind-shadow
let us assume :
(rated 350 W) 500 VA per hour electricity consume and by average 40 Km/h ( flat track) this means : 100/40 x 500 = 1250 VAh/100 Km
compared above listen world-record :
Indian modification 1250 Wh/100 Km = 80 Km/KWh to WR : 262,6 km/kWh
means, theoretical : indian bike modifying with Li Yng micro-motors transmission = WR - level !
modifying with Ferreira cap-windings motor = WR - level !
But : related second listen WR : indian modified 80 Km/KWh to WR : 1091,6 km/kWh
anymore the Li Yng micro-motors transmission,only more the Ferreira cap-windings e-drive reach OVER-WR-unity !
Mr. Li Yng,do not worry : micro-motors transmission and Henri Trilles capacitive windings amplifier : back to OVER-WR-unity track !
U2 :)
max speed, average velocity ? vehicle weight/electric motor rated power ? max allowed weight ?
energy (recuperation) sourced/delivered for example
https://www.youtube.com/watch?v=xV9y7lFOKNA&t=106s (https://www.youtube.com/watch?v=xV9y7lFOKNA&t=106s) https://www.youtube.com/watch?v=NcQFRXriVDc (https://www.youtube.com/watch?v=NcQFRXriVDc)
and/or e-pedalling
https://www.google.com/search?rlz=1C1AVFC_enPT930PT930&source=univ&tbm=isch&q=electric+car+generative+pedalling&sa=X&ved=2ahUKEwjayuCngojxAhWHN8AKHZ3bBmcQjJkEegQIAhAB&cshid=1623154715965106&biw=1366&bih=605 (https://www.google.com/search?rlz=1C1AVFC_enPT930PT930&source=univ&tbm=isch&q=electric+car+generative+pedalling&sa=X&ved=2ahUKEwjayuCngojxAhWHN8AKHZ3bBmcQjJkEegQIAhAB&cshid=1623154715965106&biw=1366&bih=605)
Why/not answer/question : https://docs.google.com/document/d/1u3Dr5Ey9PrMiSHmqQs61aLFsZQYxW51wHDamm8vF3bY/mobilebasic (https://docs.google.com/document/d/1u3Dr5Ey9PrMiSHmqQs61aLFsZQYxW51wHDamm8vF3bY/mobilebasic)
https://www.explainthatstuff.com/how-regenerative-brakes-work.html (https://www.explainthatstuff.com/how-regenerative-brakes-work.html)
from e-bike to trike ,how many rated W need for average 40 Km/h ( + allowed weight)
catalog : https://german.alibaba.com/g/trike.html (https://german.alibaba.com/g/trike.html)
let us take : https://german.alibaba.com/product-detail/eu-warehouse-free-shipping-cheap-adult-big-wheel-48v-1500w-brushless-motorized-electric-drift-trike-ce-approved-60830784454.html?spm=a2700.7724857.normal_offer.d_title.54042635EiwUKs (https://german.alibaba.com/product-detail/eu-warehouse-free-shipping-cheap-adult-big-wheel-48v-1500w-brushless-motorized-electric-drift-trike-ce-approved-60830784454.html?spm=a2700.7724857.normal_offer.d_title.54042635EiwUKs)
900 W or 1500 W rated power
25 Km/h max 55 Km/h max
A. I do not see street legality ! B. it is for R&D interests about consume/recuperation : the lowest possible !
btw: https://german.alibaba.com/product-detail/new-e-trike-1000w-2000w-3000w-enclosed-4-wheel-electric-trike-scooter-electric-tricycle-adult-62297848912.html?spm=a2700.7724857.normal_offer.d_title.54042635MAwrUY (https://german.alibaba.com/product-detail/new-e-trike-1000w-2000w-3000w-enclosed-4-wheel-electric-trike-scooter-electric-tricycle-adult-62297848912.html?spm=a2700.7724857.normal_offer.d_title.54042635MAwrUY)
4 rad Electric ::) Trike Scooter
3 wheels = trike 4 wheels/rad = quad
AUTODROME experiments,autonomous drive,( unmanned )
for
https://www.google.com/search?q=autonomous+city+shuttle&rlz=1C1AVFC_enPT930PT930&oq=autonomous+city+shuttle&aqs=chrome..69i57j33i160.9530j0j7&sourceid=chrome&ie=UTF-8 (https://www.google.com/search?q=autonomous+city+shuttle&rlz=1C1AVFC_enPT930PT930&oq=autonomous+city+shuttle&aqs=chrome..69i57j33i160.9530j0j7&sourceid=chrome&ie=UTF-8)
steering wheel free
Beyond Tesla Inc.,Toyoda/Toyota,VW,MB,GM aera thinking
Beyond human self-driver
for the global tachometer > 100 Km/h fraction :
( diabolic thinking,I :-[ : https://german.alibaba.com/product-detail/new-eec-300cc-trike-cvt-60074768033.html?spm=a2700.7724857.normal_offer.d_image.54042635SlIOAm (https://german.alibaba.com/product-detail/new-eec-300cc-trike-cvt-60074768033.html?spm=a2700.7724857.normal_offer.d_image.54042635SlIOAm) ::) ;) :)
but : Igittegitt ! : Gas/Diesel engine motorized ,stinker ! Brueller ! Verschwender ! )
https://en.wikipedia.org/wiki/Sinclair_C5 (https://en.wikipedia.org/wiki/Sinclair_C5)
Enthusiasts have established owners' clubs and some have modified their vehicles substantially, adding bigger wheels, jet engines, and high-powered electric motors to propel their C5s at speeds of up to 150 miles per hour (240 km/h).
Rock-it ! ;D ( An e-torpedo on 3-wheels) Safe,street legal ? :-\
https://www.youtube.com/watch?v=eKRD7Agdm1k (https://www.youtube.com/watch?v=eKRD7Agdm1k) 210 Km/h,bow hey,so slow ? ;D
IN THE CITY ??? ?? https://www.youtube.com/watch?v=isFrMU7q6OA (https://www.youtube.com/watch?v=isFrMU7q6OA) :o Citydrom
Our world is based by rules and the "how to take rules"- operation manual similar easy https://www.youtube.com/watch?v=JYNyQcblzgI (https://www.youtube.com/watch?v=JYNyQcblzgI)
198? : P.M.-Magazin article : bullit-like vacuum channel journing, velocity 10 000 Km/h : f.e. Europe/North-America in < 1 hour
MACH 10
orbital pendant : https://de.wikipedia.org/wiki/S%C3%A4nger_(Raumtransportsystem (https://de.wikipedia.org/wiki/S%C3%A4nger_(Raumtransportsystem))
https://de.wikipedia.org/wiki/Awangard_(Hyperschallwaffe (https://de.wikipedia.org/wiki/Awangard_(Hyperschallwaffe))
https://en.wikipedia.org/wiki/Avangard_(hypersonic_glide_vehicle (https://en.wikipedia.org/wiki/Avangard_(hypersonic_glide_vehicle))
MACH 20+
Often forgotten fact is that each magnetic field line wants to get away from all others, magnet literally wants to explode, but the force is, of course, too weak to explode it.
A-B fields
http://freenrg.info/Physics/Scalar_Vector_Pot_And_Rick_Andersen/Rick_Andersen_Ortho.html
from LankaIV via floor
http://eprints.utar.edu.my/150/1/MH-2011-0705513-1.pdf
Thanks Lanka
This may interest someone here:
Energy generation apparatus and methods based upon magnetic flux switching https://patents.google.com/patent/WO2009046265A1/en
Laka post today
https://overunity.com/18713/perpetual-magnetic-toy-and-explanation/msg553391/#msg553391
reply #10 : The machine is built to run on the principle of what ?
https://de-m-wikipedia-org.translate.goog/wiki/Automatikuhr?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de ?
The invention of the automatic, bidirectional winding mechanism with rotor and changer for pocket watches , which took place until 1775, is attributed to Abraham-Louis Perrelet . In 1778 at the latest [4] Hubert Sarton had also developed a pocket watch with an automatic winding mechanism. Abraham Louis Breguet also produced a forerunner of the modern automatic movement in 1787. He named his pocket watch with an automatic winding mechanism Perpetuelle . [5]
In 1922, the French company Leroy created the first wristwatch with an automatic movement, powered by a pendulum oscillating weight, which, however, was not sold.
From FR to CH :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=CH&ENGINE=google&FORMAT=docdb&KIND=A4&LOCALE=en_EP&NUMBER=1433271&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en
to automatique Quartz system
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=26&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820430&CC=CH&NR=629355A&KC=A#
Did anyone calculated the energetic input to total time function energetic consume from this small devices ?
wmbr
OCWL
Some thoughts from Lanka IV
Offline lancaIV
elite_member
Hero Member
View Profile Email Personal Message (Offline)
User posts join approval queueModerated
(No subject)
« Sent to: Floor on: May 01, 2022, 03:22:13 PM »
« You have forwarded or responded to this message. »
Reply
Delete
Hello floor,I hope Your situation is well !
Related 'field' and working with there are in quantum mechanics two think parameters :
https://www.google.com/search?q=dimensionless+physics&ie=utf-8&oe=utf-8&client=firefox-b-m
https://www.google.com/search?client=firefox-b-m&q=unitless+definition+physics&oq=unitless+physics&aqs=heirloom-srp.2.0l3
Working physical we should ask : freedom-degrees in cubical and/or round non/evacuated area/space !?
How much from Lorentz force is electro-magneto-gravito ion-/proton-wind ?!
Light velocity and distance-overbridging in medium/in vacuuo !? ≥ 300 000 km/sec possible ? How,why !?
Because I am one time more 'off-lined' by the Admin. I will any more later posting in non own began threads !
Is there not a relationship Lenz/Ohm and Fleming/inverse Ohm = Siemens ,developper from the ' dynamo ' ?
Sincerely
Oliver Christoph Waldhelm Lanca
Quote from: lancaIV on May 04, 2022, 05:14:41 AM
We are a designing society,
partial going down to cellular reproduction programming : Serbia : human cloning .
In EE and FE a field variance and to controle spectrum :
https://en.m.wikipedia.org/wiki/Hysteresis
and specific https://www.electronics-tutorials.ws/electromagnetism/magnetic-hysteresis.html
The field working area has to become defind,
the signals(also called : pulses or waves or oscillations = p.o.v.) configurated,
to develop in this field the wished force ( 4d including reactio 5d ) from given pressure ( 3d) !
The pressure input result is different,when different specific materials ( used element,their quantity,recflection grade, hardness ,purity are in use ! Commercial/industrial re-/production warranty !?)
Like here to see and remark ,soft/hard or
https://www.electronics-tutorials.ws/wp-content/uploads/2013/08/mag20.gif?fit=477%2C298?fit=355,226
centrifugal /centipetal orientation pressing ,from in RT ambient liquid metals !?
Nothing in concept new : EMD,EHD(Hydro=water=semi-metal),MHD technology applied !
And finally : it seems that our Nature system is holographic : cycle in a sub-cycle in .....
time to to milli-time micro-time to nano-time to femto-time circuits stand-by controle
by on/off switching,this is actually industrial the THz- devices mass production class
Input signal energy saving by Watt-to VA to VAr
to VAr: controlled ≤ 100% - duty cycle sublimes conventional time d
Changing,retroduction the " Nature BIOS program"
For comparison and digital fictive MEG-designing :
when 50 Hz in-/trans-verter ~ 3 000 RPM rotor/stator or rotoverter concept
500 Hz 30 000 RPM
1 KHz 60 000 RPM
1 MHz 60 000 000 RPM
1 GHz 60 000 000 000 RPM
1 THz 60 000 000 000 000 RPM
or 1 000 000 000 000 RPS
Quantum generator low space but high power output potential !
Btw : the Nature BIOS is 100% digital ,the humans are Nature sub-systems ,their BIOS idem 100% digital
Sincerely
OCWL
Quote from: lancaIV on May 05, 2022, 06:46:03 AM
Hello floor,
I wrote this as message to kolbacict
but it makes part from emg-engineering ,as R&D and by application :
Hello kolbacict,
Hoping You are well !
You ,probably,differ motors and generators and/or motors with genrrator coils in their behaviour !
A-/synchron,self-dynamic( by electro magnets) ,.......
Inertia start-phase Ampere-tuning
https://www.google.com/search?client=firefox-b-m&q=+rheostat+in+electric+circuit&oq=+rheostat+in+electric+circuit&aqs=heirloom-srp..
and/or
Inertia start-phase Voltage-tuning
https://www.google.com/search?q=varistor&ie=utf-8&oe=utf-8&client=firefox-b-m
Using both,rheostat and varistor,means minimalist = near " demand/serve" unity input ,
but the real specific device ,for experiment or in mass use,has to be strictly defined/finded by experiments !
Related Bedini rated/real world batteries capacity and Beardens rated/real world permanent magnets force I
present also Fred Miekkas motor and/or generator devices improvement ,based by
physical textbook theoretical energy/power output versus industrial typical rated/average/waranty related/simple and cheap production//obsolescent
pre-/reservation habits :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Fred+Miekka&CPC=&IC=
We can assume
motor and/or generator each 1 KW PURE production costs(50 KW unit ),with variable speed and torque controller,
following Roy Kessingers motor/generator production concept R&D 5 US$/hp ~ 6,75 US$/KW and the controller in
the international freedomcar US DOE engine project in the 15 US$/hp ~ 20 US$/KW !
Through controller price decrease potential we can assume in future,by later REPRAP industrial process
total drive system PURE production costs per KW unit ,for 50 KW rated drive :
from 20 US$/KW to 17,5 US$/KW to 15 US$/KW ............. !
We are actually calculating with unwarranted, non-capitalized US F.E.D. e-/paper-$ ,
with monetary retroduction from ' money=coin material worth"-PARITY systematics ,
the US e-/paper $ transforms to REAL WORLD 10/1 "US coin $" ! Zero tax,Zero credit !
And from " drop away"-society misleading to refurbish/recycling logics !
FE generator for less than ....... US-RW-THALER !
Ihr US-Amerikaner nutzt die imperiale Karls-Thaler ,Mund-faul : ( Karls-) Tdoalar/ Doaler/Dol(l)ar:!
Jeder Thaler/Dol(l)ar besteht aus einer FIXEN WertEINHEIT !
Wie REICH oder ARM/POOR Ihr US-Amerikaner seid entscheidet nicht Forbes/Fortune,
sondern einfache KLASSISCHE KALKULATION,
zudem aus dem Bereich der Quanten-Algometrik :
Das eherne Zinsgesetz ! The eternal tax-law ! Its followed Walras law and Pareto inverse-/pyramids logics !
Haus,Hof und Gesinde ABSCHREIBUNG/psycho-physio-logical Existence-Amortization
inklusive,linear und/oder progressiv : Lebend-Vieh und Lebende ! Cattle and humans ,physically amortized
Viele Staedte zu sehen,Buch-technisch : abgeschrieben/neutralized/profictio :
1 Euro ,Dol(lar),Rubel,Rupie,Renminbi ,......... RET(in Peace,)-Buchwert
Viele Geisterstaedte,mit Geister-Menschen,Buch-technisch : abgeschrieben : 0 Euro/Dol(l)ar,Rubel,.......
Quantum-,Algometrische Buchhaltung,auf den Pixel,/dot genau !
Dialektischer Idealismus, Hegel
Dialektischer Materialismus ,Marx/Engels
Digital-materialistischer Idealismus WIR,-Genrration ,anhand Planckschrr Grundlagen-Forschung und opto-elektrischrr Fraunhofrr Spectrallinien-Aneendung
Forumsteilnehmer deren Beitraege besitzen ,* KLANGFARBE" =
deren spezifische - momentan/,lokale- Eigenfrequenz !Oder die des genutzten Auto-Translator-Program(m),ers/ierers !?
Nullus/Zero Geheimnisse/Secrets !
Quanten-Algometrische Vorstellung des DPMA BUERO99 - Levels :
T.T.Brown MEP as thruster ,MW to GW shocks/pulsations to deep water area - pseudo-thermo,-,vacuum-,pump,-
E-/M-2-G molecular active instead nuclear radio-active like
https://www.google.com/search?client=firefox-b-m&q=poseidon+tsunami+&oq=poseidon+tsunami+&aqs=heirloom-srp..0l5
and under ocean line valley area watering with mineral seawater ' artificial tsunami waves watering,' GIGAPUMPS
With less people and less area use more physical healthy output :
this makes indoor/sub-terrean saltwater-mixed electro-magneic plant culture possible !
10 times = 1000 % more yield by 2020-2100 maximal 50% growing world population !
Quantum-Algometrics and Cobot-fabrication means for zero-child /1 healthy child couples :
Eternal spring life !
Sincerely
OCWL
Message End
Related population estimations up to 2100,
f.e.Africa 2022- 2050- 2100
1400 Mio + 72 % 2400 Mio + 200% (/ 2022) 4100 Mio.
https://www-n--tv-de.translate.goog/wirtschaft/Putins-Krieg-bringt-Millionen-Menschen-Hunger-article23189545.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
The South pays the price Because of the drastically increased cost of living, there were unrest in more than 20 countries at the time. On average, Germans only spend about twelve percent on food, while in the Global South it is between 60 and 100 percent. That is why the World Food Program and organizations such as Welthungerhilfe are warning against underestimating the consequences of the recent price explosion for global food security and especially for regions at risk. This is especially true for low-income countries that are dependent on food imports and whose food situation has already deteriorated drastically during the corona pandemic.
No inland food/alimentation production = no /coitus !
For "Book of the Books"-Methodists = basic cristianity the demands are clear :
The fatten years,the droughts/dry years
https://www.auwaldstation.de/2013/12/18/was-sind-eigentlich-mastjahre/.Each tree species has its own rhythm in which the fattening years return.being Nature MAST-(~SATURATION)and/or ALTERNANZ -cycle pre-served ,good/bad yield years ( Tier- und Pflanzen-MAST,for many unknown :-
MAST-(SATURATION) and/or ALTERNANZ ,NATURE its TRIAGE =
SELECTION,SURVIVALMECHANISM
Voll-MAST Teil-MAST,String-MAST,Leer-MAST ~ full/no fertility years
Ho-Mens MAST-farming international ,Zucht-und Ordnungs-Regularien
The qualitative Cycle-STRUCTION ,humans double " bio periods" -cycle : ,
female menstruation,male : pollution
Wechseljahre/(ho-)meno-pause(-stop)after given quantitative bio-cells cyclic regeneration
( = bio-clock/watch program ,genetical = internal timer )
= after cycle-regeneration pause/(-stop) : Degeneration
The human body and mind bio-algorythmical phases and changes ,non/influenced,non/manipulated
Emg-spectrum : - pause(-stop) !?
mammals Men(sch) - Tier-Pflanze-Amoebe-Plankton- ........ ? Life begins : by classical / by quantum ..... ?
E-motio begins : by EE ,by quantum E ...... ?
Lanka Links
and his shared thoughts on the topic @
https://overunity.com/19272/more-clairifaction-of-floors-twist-drive/msg571312/#msg571312
Thanks Lanka
Quote from: lancaIV on May 06, 2023, 09:14:37 PM
"axial/tangential" force ratio,here specific used magnets volume and weight !? :
What happens physical in an Halbach magnets array ?
https://www.geminielectricmotor.com/about%20the%20gemini%20technology.htm (https://www.geminielectricmotor.com/about%20the%20gemini%20technology.htm)
C.O.P. 2:1
or 'translated'/translateral applied'
The general theory is that permanent magnet (PM) machines are capable of producing higher efficiencies over other such as induction motors and reluctance motors. They can be very robust and produce a large torque for their physical size. The revolutionary feature of the GEMINI motor is that it has the capability of producing more power for the same volume.
Theoretically, it is capable of handling twice the power of a same size conventional motor and while doing so, remain at the high efficiencies that PM motors are capable of.
A reduction in size comes with the obvious benefit of material reduction, hence savings in weight and cost. A less obvious advantage is in that a reduction in size opens up markets where space limitations have previously led to the use of costly and inefficient transmission systems. The manufacturing principles of the GEMINI motor are conventional in fashion and would require a minimal retooling cost as compared with other novel motors emerging from the field of research.
C.O.P. 2x+ improvement by permanent magnet new ordening : leverage (lever arm !?) cascade arrangement
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1#)
The novel magnet array disclosed herein can replace every, or substantially every, use of conventional magnets which are used in motors, generators, transformers, or any device that produces or transmits electricity with the use of permanent magnets.
The 'Ronbach' array geometrial applied,as example :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20111006&CC=US&NR=2011241349A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20111006&CC=US&NR=2011241349A1&KC=A1#)
Studying : [ 0035] - [ 0039] ,in remind : 'Affinity law/-s' or ,also called : inverse square/cube law
wmbr
OCWL
p.s.:
https://en.m.wikipedia.org/wiki/Specific_speed (https://en.m.wikipedia.org/wiki/Specific_speed)
and
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1#)
https://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3330899&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en (https://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3330899&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en)
[0012]
The invention is based on the knowledge that there is an analogy between electrical engineering and flow technology. [0013]
This consists in the fact that an electromagnetic field around an arbitrarily bent wire-shaped conductor and a flow field around an arbitrarily shaped vortex thread are described by the same law, the Biot-Savartsche law. The quantities "increase in magnetic field strength" and "increase in speed" therefore correspond to one another. Since magnetic field strength can be concentrated by winding a current-carrying conductor into a coil, you can also achieve an increase in speed in fluid mechanics by winding a vortex thread into a coil. If one arranges several vortices rotating in the same direction in such a way that their axes lie on a circle, they will rotate around the center of the circle as a result of mutual induction. The induction increases with the number of vortices. The winding speed increases and the whirl threads approach the shape of tightly packed ring vortices. The velocity field that these ring vortices induce in their interior forms the desired concentration effect.
Industrial permanent magnets are emf-charged metal blocks !
Risc : Barkhausen effect ! Resonance catastrophy !Counter-risc act : lantaniden/RE material use,radio-active,like cobalt,nuclear force battery !
EE standart 2023 :
US Navy R&D ,Ed Sines :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#)
This invention allows for the reduction in size of a high power transformers by a factor of 4 to 8 and a reduction in weight by a factor of 4 to 6, and an increase in power density by 5 to 10 in power. The efficiency of the transformer is improved by maximizing the heat transfer from the transformers interior and minimizing voltage breakdown. The thermal properties of each core 12 will dictate the quantity of the thermally conductive strip 16 material required to lower the transformer temperature to a predetermined level, some testing may be required to established the optimal amount needed to provide proper cooling.
E. Sines private R&D :
https://newenergytimes.com/v2/news/2011/37/3721appendixd3.shtml (https://newenergytimes.com/v2/news/2011/37/3721appendixd3.shtml)
https://patents.google.com/patent/US8736085B2/en (https://patents.google.com/patent/US8736085B2/en)
http://www.rexresearch.com/markov/markov.htm (http://www.rexresearch.com/markov/markov.htm)
https://overunity.com/833/hilden-brand-magnet-motor/dlattach/attach/5493/image//
and/or
https://www.lunduniversity.lu.se/lup/publication/ac5293fd-65b6-4ca1-be28-dc9dd1677f25 (https://www.lunduniversity.lu.se/lup/publication/ac5293fd-65b6-4ca1-be28-dc9dd1677f25)
Turbomachinery,as motor-generator-couple,weight performance :
13 nominal KW /Kg each rotative machine,power-to-weight ratio improveable !
https://www.google.com/search?q=13+KW%2FKg+electric+engine&ie=utf-8&oe=utf-8&client=firefox-b-m (https://www.google.com/search?q=13+KW%2FKg+electric+engine&ie=utf-8&oe=utf-8&client=firefox-b-m)
Fabrication : 3d-scanner/digitizer,CNC/DNC to CAD,CAM/CIM,
autonomous or/and telemetrical administrated mobile 4d EE factory in a container-box
3d liquid-to-solid metal/plastics/composite printer
Target : Nano-Boxx reversible battery cycle similar economical performance claim
https://techconnectworld.com/World2017/a.php?i=1125 (https://techconnectworld.com/World2017/a.php?i=1125)
https://geospatial.blogs.com/.a/6a00d83476d35153ef022ad3c0d118200b-popup (https://geospatial.blogs.com/.a/6a00d83476d35153ef022ad3c0d118200b-popup)
40 US$/KWh capacity mass production costs
Assuming 200 US$/KWh endconsumer mass-selling price
means 200 US$ / (8766 KWh x 10 to 11 years power delivery ) : low cost in situ generated electricity
0,002 US$/KWh or 1/5 ¢/KWh GHG-emission free e-power
wmbr
OCWL
Reversible Thinking
https://worldwide.espacenet.com/searchResults?AB=&AP=&CPC=&DB=EPODOC&IC=&IN=Adolf+zielinski+&PA=&PD=&PN=&PR=&ST=advanced&TI=&bcId=1&locale=en_EP&page=0&return=true (https://worldwide.espacenet.com/searchResults?AB=&AP=&CPC=&DB=EPODOC&IC=&IN=Adolf+zielinski+&PA=&PD=&PN=&PR=&ST=advanced&TI=&bcId=1&locale=en_EP&page=0&return=true)
13. with 14. coupling
or
14. with 13. coupling
Energy use kind preference !
Thinking soft,lazy and leve/easy :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1#)
to "Citing documents"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=4&adjacent=true&locale=en_EP&FT=D&date=19950622&CC=WO&NR=9517037A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=4&adjacent=true&locale=en_EP&FT=D&date=19950622&CC=WO&NR=9517037A1&KC=A1#)
An electrical power generated from magnetic energy comprises a S-section power body which consists of a plurality of ferromagnetic plates. Two hollow vortical ferromagnetic cylinders which are axially inserted with a conductor are formed in both ends of the power body respectively. There is an excitation winding in the middle portion connecting the two ferromagnetic cylinders. The electrical power can be directly generated from magnetic energy according to the present invention
https://worldwide.espacenet.com/espacenetImage.jpg?flavour=firstPageClipping&locale=en_EP&FT=D&date=19950622&CC=WO&NR=9517037A1&KC=A1 (https://worldwide.espacenet.com/espacenetImage.jpg?flavour=firstPageClipping&locale=en_EP&FT=D&date=19950622&CC=WO&NR=9517037A1&KC=A1)
" ....... There is an excitation winding in the middle portion connecting the two ferromagnetic cylinders...."
An 'excitation winding ',by well thought to select :
https://www.google.com/search?client=firefox-b-m&q=haldar+sabyasachi+electric+coil&oq=haldar+sabyasachi+electric+coil&aqs=heirloom-srp (https://www.google.com/search?client=firefox-b-m&q=haldar+sabyasachi+electric+coil&oq=haldar+sabyasachi+electric+coil&aqs=heirloom-srp)..
https://patents.google.com/patent/WO2015189722A1/da (https://patents.google.com/patent/WO2015189722A1/da)
A. a Sabyasachi excitation winding
B. a Sabyasachi excitation double -reversible displacement circuit- windings arrangement
I am positively inspired by ' powerguru' about the costs/price developmrnt from MEG-like ' non macro-kinetical motional generator/transformer
recitating its claim :
looking temporary back
https://overunity.com/17176/electro-magneto-dynamic-carnot-cycle/ (https://overunity.com/17176/electro-magneto-dynamic-carnot-cycle/)
Electro-Magneto-Dynamic Carnot Cycle (https://overunity.com/17176/electro-magneto-dynamic-carnot-cycle/msg501703/#msg501703) « on: March 12, 2017, 03:13:13 PM »
https://overunity.com/6763/energy-amplification/8385/ (https://overunity.com/6763/energy-amplification/8385/)
« Reply #8391 on: March 09, 2019, 12:47:21 PM »
From the powerguru page : 5 KW planar/ flat inverter for 25 US$ production cost each ~ 5 US$/KWp
( 10000 units production)and Roy Kessingers 15US$/hp to 5 US$/hp motor/ generator prices range reduction ( without controle system !)we see a great price reducing potential of the " autonomous house energy system"
powerguru : planar transformer production costs
http://www.powerguru.org/planar-transformers-are-essential-for-truly-efficient-electrichybrid-vehicles/ (http://www.powerguru.org/planar-transformers-are-essential-for-truly-efficient-electrichybrid-vehicles/)
( for the original page content go to archive.org and fill in with the above enderece )
The final thing to mention is the dreaded 'C' word: COST! For some time now planar transformers have been disregarded as being too expensive. Contrary to popular opinion, the costs have significantly reduced in recent years through cheaper material costs, as the market grows, and improved manufacturing techniques. It is common for a 5kW planar transformer to cost in the region of $23 nowadays, and in volumes of 100k+ prices below $10 per piece are easily achievable. Moreover, in the 2kW-30kW power range, the use of pre-formed copper 'lead-frames' in single and multi-turn forms can achieve virtually any desired turns ratio at low cost, allowing rapid design iteration and ultimately improved time to market.
An 100 US$/KW autonomous society individual ,also called : endconsumer , 24/365 generative e-transformer with warranty-able 10 years persistent work-life ex(s)pectation !?
Near 0,1¢/KWh electric GHG-emission free 'green power' reactor !?
BRIC-estates,in co-operation,possible !?
Brazil Russia India (PR and NR) China
Independent PALOP R&D institute ?!
Eu gosto tanto 'Lula,com tomates !' :-[ 8)
Que sera,sera ....!?
https://m.youtube.com/watch?v=sTsVJ1PsnMs (https://m.youtube.com/watch?v=sTsVJ1PsnMs)
wmbr
OCWL
p.s.: BR inventor with really interestant concepts
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=BR&AP=&PR=&PD=&PA=&IN=Lavigne&CPC=&IC= (https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=BR&AP=&PR=&PD=&PA=&IN=Lavigne&CPC=&IC=)
Which one meaning ?
Try it,clearly by ' conventional fuzzy logic' apply, ::) ;D ! Herr-lich naiv,Erdling !
Mas,talvez,sera/seja este :
Inventor:
LAVIGNE DE MACEDO HENRIQUE ANTONIO
As e-transformer application we will see as wright first demonstration solution :
https://www.google.com/search?client=firefox-b-m&q=vegan+e+trike&oq=vegan+e+trike&aqs=heirloom-srp (https://www.google.com/search?client=firefox-b-m&q=vegan+e+trike&oq=vegan+e+trike&aqs=heirloom-srp)..
10 000 + Km City drive range
Vegan e trike,2000 US$ /unit endconsumer price estimation at mass production selling beginning ,decreasing to 1500/1000 US$/unit .
We are not in deflation nor inflation time,we have an organized reflation economy !
https://www.google.com/search?q=Reflation&ie=utf-8&oe=utf-8&client=firefox-b-m
Walras Pareto,King-Davenant : Murphies law !?
Ihr sollt verfallen,darum werdet Ihr fallen !
Anti-2015 Merkel Orientation :
Ihr schafft ES nicht ! APO AfD !
Offline lancaIV
elite_member
Hero Member
Re: More clairifaction of floors Twist Drive
« Reply #47 on: May 09, 2023, 04:55:42 PM »
Modify
Remove
Split Topic
From german :
A.
Masse- Gewicht , physical weight
https://de.m.wikipedia.org/wiki/Masse_(Physik)
B.
we have to differ Masse- Wichte, physical specific weight
https://de.m.wikipedia.org/wiki/Wichte
C.
to differ Masse- Dichte , physical density
https://de.m.wikipedia.org/wiki/Dichte
e=mc² m is and was never ' mass' ,it is and will stay ever as ' specific mass '
Conditio : m = M1-M2 ergo : e=mc² = ( M1-M2)v² , v ≤ c e= specific energy
Deutsche Quantenphysik,deutsche Konditionierung ,deutsche Formulierung ,deutsche Logik-Gesetze !
wmbr
OCWL
Offline lancaIV
elite_member
Hero Member
Modify
Remove
Split Topic
From german :
A.
B.
C.
wmbr
OCWL
Quote from: lancaIV on May 09, 2023, 05:32:51 PM
e=mc²
1911 : before WWI https://en.m.wikipedia.org/wiki/File:1911_Solvay_conference.jpg (https://en.m.wikipedia.org/wiki/File:1911_Solvay_conference.jpg)
related
A.https://en.m.wikipedia.org/wiki/Friedrich_Hasen%C3%B6hrl (https://en.m.wikipedia.org/wiki/Friedrich_Hasen%C3%B6hrl)
B. the marriaged couple their co-working
https://de.m.wikipedia.org/wiki/Albert_Einstein (https://de.m.wikipedia.org/wiki/Albert_Einstein)
and his first wife
https://en.m.wikipedia.org/wiki/Mileva_Mari%C4%87 (https://en.m.wikipedia.org/wiki/Mileva_Mari%C4%87)
1927,before WWII :
https://rarehistoricalphotos.com/solvay-conference-probably-intelligent-picture-ever-taken-1927/ (https://rarehistoricalphotos.com/solvay-conference-probably-intelligent-picture-ever-taken-1927/)
" ...... Conditio : m = M1-M2 ergo : e=mc² = ( M1-M2)v² , v ≤ c e= specific energy ...."
Correction,the unidirectional view :
I.acceleration case conditio = ' e=mc² '
II.deceleration case : reversible e=(M1-M2)v² ,v≤ c
EMD-cycle : I.+ II. loop,"8",Sonnen-Erde-Winkelverhaeltnis-Zyklus( Erdjahr-Relativitaet)
Quenching,mining : a.specific energy
b.specific mass
c.specific time ( N.Tesla ,Uni Graz-Absolvent : e= tc² )
Minkowski multidimensionale Zeit-Raum/Raum-Zeit Kinematik : Relativistik
ergibt
https://en.m.wikipedia.org/wiki/Planck_relation (https://en.m.wikipedia.org/wiki/Planck_relation) ,und/oder the Planck–Einstein relation,
Spezifische Ausnahmen :
1
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1#)
2.https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A# (https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A#)
3. C.F.v.Weizsaeckers
https://de.m.wikipedia.org/wiki/Carl_Friedrich_von_Weizs%C3%A4cker (https://de.m.wikipedia.org/wiki/Carl_Friedrich_von_Weizs%C3%A4cker)
Germanys last " rerum naturalis"-Doyen
" Ur-Alternativen" -Theorie :
dazu diskutables Monologisieren seitens Heisenberg ,hier :
https://m.youtube.com/watch?v=txkh9xvpQAg (https://m.youtube.com/watch?v=txkh9xvpQAg)
Moderne Deutung,Personal mit fachlicher Expertise,
Lehrstuhl-Inhaber,Max-Planck-Instituts-Verbund https://m.youtube.com/watch?v=G8P_fjCPoN0 (https://m.youtube.com/watch?v=G8P_fjCPoN0)
https://www.leifiphysik.de/kern-teilchenphysik/kernspaltung-und-kernfusion/ausblick/bethe-weizsaecker-zyklus (https://www.leifiphysik.de/kern-teilchenphysik/kernspaltung-und-kernfusion/ausblick/bethe-weizsaecker-zyklus)
" Sonnen-Wind"-Re-/Aktor
Dazu :
https://www.google.com/search?client=firefox-b-m&q=NASA+Solarwind+Parker+&oq=NASA+Solarwind+Parker+&aqs=heirloom-srp (https://www.google.com/search?client=firefox-b-m&q=NASA+Solarwind+Parker+&oq=NASA+Solarwind+Parker+&aqs=heirloom-srp)..
Warum 6000° C solare Oberflaeche sich auf 1 Mio.°C Corona-Maximum aufheizt ?
Konzentriertes Flirren,' solare Fata Morgana-Licht-/Wellen-Spiegelungs-Konzentration ',Astrooptik ,Linse,con- cav/vex
Crackpot- or Quantum-Uptodate-Technology ?
https://www.google.com/search?q=Mundt+Reaktor&ie=utf-8&oe=utf-8&client=firefox-b-m
https://www.google.com/search?client=firefox-b-m&q=juergen+Mundt+Reaktor&oq=juergen+Mundt+Reaktor&aqs=heirloom-srp..0l1
