Hi i have been studieing over 25 years, and i'll explain it simple
You need 3 car batteries, if you don't want them to run out make them plasma cells.
This is how put 10 liter of water with salt in a bucket. Make a aluminium plate and a copper plate, anode cathode connect them to a dc voltage, i use 32 volt, for a few days. Cook the water WITH setlement to get it concentrated. You have to play with the heat cus the plasma tries to hold the water.take a car batterie and punch a hole in it, let the asiddic flues out and poor the plasma gans in. Charge it. Done
Now build 2 coils of my design see picture forget the connections.
Then connect them in as in the final pic. Don't know what you gonna do whit that so i suggest download multisim and test it on the computer simulator cus i have blown up more than 500 microprosessors mosfets irfs etc in the years. Make it suiteable for you needs, in multisim you can choose your gauge wire everything, i do not have a pc right but i hope some of you guys gonna pick this up. Before i am gone. Thanks
Stay safe
You can download the software here https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.ni.com/en-rs/support/downloads/software-products/download.multisim.html&ved=2ahUKEwjZ5u-ltLj0AhUJ76QKHZlOC00QFnoECAQQAQ&usg=AOvVaw3RLeWLPPXT1JmmuMnd96PI
Sorry the pictures of the coil is my more advanced ones, you only need the collector wires yellow and the pulsing wire. Just play with the winding settings and gauge and diferand cores and let me know what you get
For the pulsing frequentie generator i use the arduino, the pulsing lenght should be as minimal as possible so you don' use any amps an you batteries, around 7 procent on 93 off square wave. Also be aware that the program does not measure the heat on the transistor so always use heatssink watercooled could be an option and divide the current by using multiple transistors in parralel
Arduino code would be
pint outPin = 8; // digital pin 8
pinMode(outPin, OUTPUT); // sets the digital pin as output }
void loop() {
noInterrupts();
digitalWrite(outPin, HIGH); // sets the pin on
delayMicroseconds(7); // pauses for 7 microseconds
digitalWrite(outPin, LOW); // sets the pin off
delayMicroseconds(93); // pauses for 93 microseconds
For the building of the coil i used a pvc pipe aircore drilled a hole in the midle for the collector 50 50 to create ac. Laminated copperwire same as john bedini. For i the transistors i recomment the irf's cheap and quick and allot of power. Irf540 or irf 840 or 860 just check the datasheet pdfs.
The plasma cel batteries need refueling sow what i did is pored some clearcoat epoxy into the ganz after it has been charged and let it dry. After 6 years the drycell battery with gans witch produses normaly 0.6 per cel volt went up to 1.4
The prototype tvk coil started out with the 2 wires collectors and the j bedini bifilair wires on top pulsed them and created 10 times overunity. Now you use 2 coils singlewire pulse. Make sure you use diodes on your output from the arduino to the transistor. I dont use drivers sow maybe someone can make it better let me hear i am all ears.... not eyes..i am sorry... :'(
I had a voltcraft ossiloscoop dso if you look good on the internet you can reprogram the ic and make them quicker from 100 Mhertz to 200 Mhertz 8)
Also try out capacitors instead of diodes witch heat up, they also only allow the current 1 way ;D
When i was stil running my lab and not hiding this was my end results
