Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: JackJohn on January 09, 2022, 02:42:27 AM
Title: Motor Generator Without external Supply need. ( TEST VIDEO )
Post by: JackJohn on January 09, 2022, 02:42:27 AM
watch the video and don't forget to SUBSCRIBE MY CHANEL to watch the video proving that my generator motor doesn't need an external power supply. don't forget to turn on subtitles.
In this video the device is still not finished, I just made the final preparations to test the AC output voltage from the generator coil compared to a DC power supply with different voltages needed for the driving motor
explanation: the test uses a power supply that can be adjusted and set from 10VDC to 20VDC.
In this test I only tested 1 coil which later there would be 4 coils that I used as a coil generator, and the results obtained were 17VAC Output Generator coil for a 10VDC motor power supply up to 50VAC  Output Generator coil for a 20VDC drive motor supply.
if you like it just support me by Subscribe My Youtube Chanel
Lets Cek It Out
https://youtu.be/5ThhxSDcWWo
Title: Re: Motor Generator Without external Supply need. ( TEST VIDEO )
Post by: Floor on January 09, 2022, 12:02:57 PM
Peace be with you as well.
Welcome to the Over Unity forum.
Unfortunately I am only an English speaker.
Thank you for your presentation.  I wish you success.
Post by: captainpecan on January 09, 2022, 10:28:23 PM
Welcome to the forum. I apologize, I also only speak English so I do not know if you answered this. But did you measure amps at all? You will need to know both volts amd Current (Amps) In order to know if the output is enough to run it. And then, the differences between AC pulses and DC constant current can also be a bit misleading with simple multimeter tests to compare. Do you have those measurements you can share yet? It can be tricky and you can easily mislead yourself as many of us have done before to ourselves. Do not hesitate to ask questions on measuring in this forum. There are many great minds in here that are happy to help.
Post by: JackJohn on January 09, 2022, 10:38:42 PM
200 more readers and around 150 who watched the video on 1 Day but only 8 people subscribed  ;D ;D ;D ;D
Post by: JackJohn on January 10, 2022, 12:34:42 AM
Quote from: captainpecan on January 09, 2022, 10:28:23 PM
It's true that I haven't taken amperage measurements in this test, I used a very efficient 12VDC motor from used printer to drive the device and as a generator later I will use 2 transformers, each of transformer have 2 coil on it which has the same wire resistance, so there will be a total of 4 generator coils. each of which produces a voltage as I tested in the video, which later I will direct of the AC outputs from each coil using a bridge diode and I will parallel all four DC output of them to get the amperage which will later be able to meet the power supply needs for the drive motor. I've insert some of my own concepts to the Device for reduce braking due to lens effect.
Post by: JackJohn on January 10, 2022, 12:45:50 AM
Quote from: Floor on January 09, 2022, 12:02:57 PM
Thank you very much for your welcome and pray, may success always be with you. In the video I use a different language and the subtitles also can't be interpreted 100% correctly, maybe in the next video I will try to speak English to make it clearer
Post by: Floor on January 10, 2022, 01:57:05 AM
Some times the best way to proceed is in a written form.
Subtitles in the video, perhaps in English.
          or
Written explanations can be printed out and then videoed during the video.
          however...
Texts which are written in a video cannot be easily copied and then
posted to an online translator.
Best are written explanations    posted online,   that accompany pictures, or the videos.
If you prefer them to be in English, you can write them in your own language
and translate them online, then post them here.
Any one can then use an online translation software and read it in their
own language, what ever their own language is.
Post by: JackJohn on January 10, 2022, 02:24:35 AM
Quote from: Floor on January 10, 2022, 01:57:05 AM
          or
          however...
Thank you for your good advice sir, I am not an experienced YouTuber and don't really understand how to interact with people from other countries, what you suggest is very useful
Post by: pauldude000 on January 10, 2022, 09:35:25 AM
Jack, I wish you luck on your device, but going for amperage will be where the extra coils start producing fields of their own, which will bog down the system as those fields will be opposite of the field activating them. Lenz's law is a pain. If you want to see it in action, drop a powerful neodymium or other rare earth magnet into a highly conductive aluminum, copper, or brass pipe. The principle the law represents is what makes the magnet travel slowly down the pipe, resisting gravity.
To bypass Lenz's law requires voltage with little amperage, not vice/versa. That doesn't matter because generated voltage can be reduced afterwards to increase available amperage -- and watts = watts. If I have to generate electricity, I know that it will be much more efficient to generate 1kw with high voltage than with low, as amperage/winds determines magnetic field generated by the stator coils. Pure voltage yields weird results (voltage leading amperage by 90 degrees or more).
The biggest problem I have found is that we generate electricity using brute force. Instead of making the electricity want to flow down a perfectly good conductor it already likes to travel down, we hit it sideways to force it through the conductor at 90 degrees from the point of impact. (magnetic lines of force cutting through the conductor to displace electrons)
Treat it like a mini particle accelerator and you bypass Lenz's law entirely, as it no longer applies. Something to think about.
Paul Andrulis
Post by: JackJohn on January 10, 2022, 10:02:43 AM
Quote from: pauldude000 on January 10, 2022, 09:35:25 AM
Paul Andrulis
About high voltage and very low amperage, I have applied it to my device, didn't I also say above that in this test the supply of the 12VDC driving motor was able to produce a voltage of 28VAC which if DCed it would be 37VDC for each coil, while later there would be 4 generator coils installed on the those devices. That's one technique I mentioned, high Voltage low Amperage generator coil, while there are still 2 new techniques that I will include in the device whose function will be the same as reducing braking that occurs due to the Lenz Effect. I have calculated everything. Thank you for your support
In the other my test Video I've been Test about Lenz Effect on the Device with short generator coil and nothing Brake happen on rotor, I mean the speed is still and not reduce
Post by: JackJohn on January 10, 2022, 10:40:21 PM
This My Device Look Like
Post by: Floor on January 10, 2022, 11:30:39 PM
Thank you for the update and for more information.
Post by: JackJohn on January 11, 2022, 04:45:59 AM
For Everyone ,I will upload a test video when the device is completely finished in a few days. If you are interested in seeing it, please subscribe to my video channel, don't forget to activate the bell
https://www.youtube.com/channel/UCNq7mOliCpU-2znPht1ihxA
Remember in this device testing video later there will be no tricks, lies, cheats, fakes and I will present it clearly and transparently without hiding anything
Regarding the success or failure of the device that I am working on, I will still upload the video, if it fails OU then it can be a lesson and we can discuss it a later but if the device is successful overunity then it is free for all of you to replicate it and hopefully it will be useful
