Overunity.com Archives
New theories about free energy systems => The Aether => Topic started by: volantis on February 03, 2022, 02:39:30 PM
Title: How to quantify and engineer devices to work with the Aether
Post by: volantis on February 03, 2022, 02:39:30 PM
I have published a book, Secrets of the Aether, in 2004. I have now updated the work to the fourth edition, and I am still finishing the editing. The book is available free online at sota.aetherwizard.com.
This work is of special interest to free energy researchers since it quantifies the Aether in physical units. This theory provides a very easy to understand Unified Force Theory. This book explains why the present MKS and SI systems of units are faulty, and gives the correct system of units. This book also quantifies a second type of charge, which is magnetic charge. Magnetic charge and electrostatic charge are two different manifestations of charge, and which are related to each other.
My most important new contribution to physics is in quantifying Albert Einstein's tensor equation in terms of a simple Newtonian formula, similar to how Karl Schwarzschild simplified the unnecessarily complex Riemann curvature mathematics as the Schwarzschild exact solution for the circular deflection angle around massive objects.
https://sota.aetherwizard.com/17-the-relativity-theories#mass_equal_aether
I am here to answer questions for those who are working on free energy devices and looking for clues as to how to tap the Aether as an energy source.
Title: Re: How to quantify and engineer devices to work with the Aether
Post by: vasik041 on February 03, 2022, 03:25:41 PM
Hello Volantis,
what are your views on how free energy device should be constructed ?
Thanks,Vasik
Post by: volantis on February 03, 2022, 05:32:59 PM
Quote from: vasik041 on February 03, 2022, 03:25:41 PM
I foresee several possibilities, and they have already been developed.
The Casimir Effect
I show the Casimir equation is the same as the strong force equation for the electron. Mainstream physics claims the electron does not experience the strong force, and yet the Casimir equation transposes easily into an equation that shows the magnetic charge of the electron creating force with the magnetic charge of another electron.
https://sota.aetherwizard.com/unified-force-theory#CasimirEffect
By magnetically aligning electrons such that the magnetic charges on two opposing plates are facing each other, and moving the plates just the right distance apart, the space between the plates will oscillate and generate new photons. The photons will then strike the plates and convert to electrons, thus increasing the potential of the plates. This potential can then be drawn off as current.
This experiment was actually performed by Steven Lamoreaux.
http://web.mit.edu/kardar/www/research/seminars/Casimir/PRL-Lamoreaux.pdf
The experiment showed an "anomalous" potential increase, which he incorrectly brushed off as a thermoelectric effect. Physicists are not allowed to create free energy devices!
The MEG generator
Tom Bearden built his MEG generator and he probably had accidentally tuned it right at one point and produced free energy. Unfortunately, he then resorted to using Maxwell's equations as a way to "improve" his invention and it went downhill since.
I believe he was on the right track in capturing Aether currents from the environment. However, the Aether is not accurately described by the magnetic equations of Maxwell. Maxwell's equations are based on units from the MKS and SI systems of units, which are both flawed.
The Aether unit is a quantum rotating magnetic field. Aether units can be aligned to produce macro rotating magnetic fields, and this happens with three phase motors, rotating magnets, microwaves, high potential Tesla coils, and in many other devices. There are quantum rotating magnetic fields in simple conductors, and anywhere eddy currents are generated.
The trick is to align the Aether units in a way that forms a loop. The Aether can be made to rotate in numerous ways. One way that I like experimenting with is with an electromagnet near a large block of aluminum or copper. Maglev trains are built upon this principle, and there are video demonstrations on YouTube and other services.
If the Aether can be placed into a loop outside of an electric conductor, it can add electrical current to a standard closed circuit.
Positive Holes
Also, it is possible to create Aether currents that use Aether in place of the electron as the charge carrier of a circuit. This particular manifestation is the "cold electricity" often observed in free energy devices. Since the Aether has no physical mass (contained angular momentum) it carries its dipole electrostatic charge without friction. You know this effect in electronics as positive holes moving through semiconductors. The positive holes are actual Aether units that are moving opposite to the flow of the electrons.
The physics I have developed are based on a far more advanced system of units than are the MKS and SI units. With this new QMU (quantum measurements units) system, you can easily understand numerous ways to manipulate the constants of physics and to produce the effect you are looking for.
I have made lots of progress in developing this physics especially in unifying the fundamental forces and properly quantifying the space density gradient around massive objects. However, there is much more work to be done and I simply do not have the resources to do it all in my lifetime.
I find that I am most productive when I have a specific challenge facing me, which is why I posted here. If there are technically inclined persons here who would like some guidance, I am willing to provide it. This allows me to tap into the creativity and resources of others. My interest is in furthering the science, while the experimenter's interest is in developing free energy. We all win.
Post by: Floor on February 04, 2022, 10:52:31 AM
First.
I do not consider myself as qualified to comment here, other than as a
free energy researcher.
To borrow a colloquialism.  My view is that the virtual photon is perhaps more
common, even than dirt. I'm pretty certain that it is essential to and is an unseen
foundation of, the functioning of  absolutely every physical event.  Regardless of
whether or not any event, is in general considered as common or as exotic, the reality
is perhaps that it is only the observing of virtual events as such, that is uncommon
and exotic. Those virtual events in and of their selves are perhaps billions of times
more common than are, for example, chemical reactions.
It may be that only the mystic and the physicist ever intentionally take an objective
view of time.  That human beings have no control over time other than an ability to
set an order to events, may be nothing more than a limitation we our selves have
co-created. That point of view may simply be a perceptual bias, but, one which also
severely limits for us, the possibilities.
Question...
Is your book, to be specific, one that yields itself to understanding by the non
academically inclined ?
      floor
Post by: forest on February 04, 2022, 11:02:59 AM
What about simple ordinary induction based on Faraday laws ? Do you know Clemente Figuera patents ?
Post by: volantis on February 04, 2022, 12:47:54 PM
Quote from: Floor on February 04, 2022, 10:52:31 AM
Is your book, to be specific, one that yields itself to understanding by the non academically inclined ?
You should be able to perform basic algebra if you want to understand the equations, and to be able to apply them to an engineering project.
Whether you will be able to understand the book, or not, will depend on you. Give it a read and find out.
Dave
Post by: volantis on February 05, 2022, 12:17:46 PM
Quote from: forest on February 04, 2022, 11:02:59 AM
I had not heard about the Clemente Figuera patent before. I just looked it up and it is brilliant. I need to look into this some more. Do you have good links?
The Faraday laws are the same in MKS units and also in my new QMU units insofar as magnetic flux per time equals potential. However, when inductance is calculated it should be equal to potential per resonance.
indc = potn / rson
where rson is resonance and is equal to frequency squared.
However, your inquiry is leading me to a new discovery with regard to calculating inductance. In the Aether Physics Model there is a unit called "curl" where:
curl = 6.333 x 10^4 coul^2 / kg * m
Wherever curl appears in an equation, its numerical portion is equal to radians. So to produce an inductance of 100 mH with 30 m of wire would require a curl of 4.737 x 10^-3 curl, which is equal to 4.737 x 10^-3 radians.
30 m / 100 mH = 4.737 x 10^-3 curl
I just need to figure out what the radians refer to in terms of coil winding.
In QMU, curl is equal to velocity per magnetic flux. The reciprocal of curl is equal to permeability. And just as in the MKS system of units, permeability is still equal to inductance per length.
I hope I can find a resource that will help me to better understand the Clemente Figuera patent. I think I may gain some new insight by studying this.
Post by: Floor on February 05, 2022, 12:39:57 PM
@ volantis
You might find these types of interactions of interest as well.
https://overunity.com/14311/work-from-2-magnets-19-output-2/msg563518/#msg563518
                    best wishes
Post by: forest on February 05, 2022, 02:32:25 PM
You can find most of the info here https://figueragenerator.wordpress.com/
and article https://alpoma.net/tecob/?page_id=8258
Post by: volantis on February 05, 2022, 03:24:58 PM
Quote from: forest on February 05, 2022, 02:32:25 PM
You can find most of the info here https://figueragenerator.wordpress.com/ (https://figueragenerator.wordpress.com/)
and article https://alpoma.net/tecob/?page_id=8258 (https://alpoma.net/tecob/?page_id=8258)
I managed to find those links by doing a search. I was hoping that someone on this forum has been building the device as seen in the original patent.
Since replying to you this morning, your question inspired me to make another important physics discovery. I have been wracking my brain for the past twenty years trying to figure out how to get rid of the weirdness of Maxwell's equations. I finally did it, and surprise of surprises, the solution is directly related to the Schwarzschild solution for light defraction around massive bodies and the perigee precession of objects orbiting massive objects. By the time this gets fully fleshed out, I will have completely fixed all of the mysteries of physics. So thank you very much for your inspiring question.
You can see the first clue of the solution I am referring to at this page in the section under Inductance:
https://sota.aetherwizard.com/units#indc
I am freely releasing this information in case someone else wants to try to beat me to the punch here in the final stretch of developing the Aether Physics Model. I suspect nobody will take up the challenge, and I will get 100% credit for completely revamping physics.
Post by: i/o on February 08, 2022, 05:28:03 PM
I see a lot of theories here.  Do you have a device built using this "knowledge" in your book?  Show us that..otherwise, all you are offering is yet another wild goose chase.  Thanks for the post.
Post by: volantis on February 08, 2022, 07:34:46 PM
Quote from: i/o on February 08, 2022, 05:28:03 PM
Who are you to make that judgment and by what authority? Do you have a free energy device? Do you have a new and improved theory of physics? Otherwise, you are just another cynic trying to make a name for yourself by judging others.
The Casimir experiment I mentioned and linked to was very real. Several experimenters throughout history have had success with their own experiments. Nikola Tesla drove a Pierce Arrow automobile outfitted with an electric motor and no battery, powered by nothing other than his free energy device, and drove it 90 mph and for several weeks.
One thing is for certain, mainstream physics cannot engineer devices like this. I have a new system of physics which can do great things, such as correctly unify the fundamental forces, properly quantify Albert Einstein's mass/energy tensor in terms of Newtonian type equations, and I recently made a discovery in quantifying inductance when someone in this thread asked me a question about it.
I am in the process right now of doing physical experiments that not only demonstrates my new equation, but also allows me to further develop even more improvements to the equations.
Do you know anything at all about physics, and have you built anything? I have another website online that shows my earlier experiments from twenty years ago when I first discovered these new physics. It is tesla-coil-builder.com. I studied everything I could about Tesla and his work to better understand the physics so that I could go beyond the Standard Model and make new discoveries.
You want to criticize me and not offer something new to work with? Get a life!
Post by: i/o on February 08, 2022, 08:49:15 PM
I think you will agree that if you want to make a free energy device, an antigravity device or a time technology device you must work with the aether.  Most of us have studied the greats in physics here.  They didn't find what we are now looking for so rehashing their travels are not likely to produce anything new towards our goals here.  I think it is logical to assume that if one is going  to experiment with the aether one needs to find an aether detector or sensor to assist in those experiments.  I have identified 3 detectors for this purpose.  However, if I don't show it detecting a supply of aether, it is just my beliefs or, at best, a theory.  That is what I am actively pursuing now.  If we (our community) can find a ready source of aether to play with, we could all make serious advances into a better understanding of aether and see paths to developing aether based technologies such as required in free energy or gravity based technologies.  We can only do this as a community. At some point, to succeed, we will have to share our knowledge, real knowledge with the community.  History has proved that human nature goes against one man holding his secret tight to the chest.  In this, they have failed us all.  Tesla's Pierce Arrow is a shining example of this secrecy that served no one.
So, volantis, I am not judging you, I want more from you if you have it.  Do you know more than what you are giving us?  Look at all the great genius inventors who held onto their secrets and helped no one by taking their technologies to their graves.  We are only left with rumours of greatness that would have served humanity so well.
So, I apologize if I hurt your feelings.  I did not mean to do that.
Post by: volantis on February 08, 2022, 10:49:55 PM
Quote from: i/o on February 08, 2022, 08:49:15 PM
[/size]
And you think I haven't? Did you read my book at sota.aetherwizard.com? I don't think there is a person on Earth who understands the Aether better than I do.
Quote[/size]So, volantis, I am not judging you, I want more from you if you have it.  Do you know more than what you are giving us?
Have you read my book at sota.aetherwizard.com? You can't accuse me of holding back.
I just shared my latest discovery in this thread just an hour after I made the discovery. Are you skilled enough to understand the very simple math involved?
In fact, that post about inductance and my recent posting of the equations on my website leads us directly to having an Aether detector. Aether is not mysterious, and it has been measured and manipulated by scientists and engineers for hundreds of years.
The Aether is a sea of quantum rotating magnetic fields. When you hold a magnet in your hand and move the magnet around, you are directly manipulating the surrounding Aether. The problem is not that we cannot detect the Aether or manipulate it, the problem is that physicists do not understand what the Aether is because they deny it exists.
Today, I took some old coils I had wound and tested them with my new equation. The equation works beautifully. As a result of the equation, and the new understanding that the numerical portion of the unit of permeability is expressed in turns of an air coil, I can now expand on that idea.
Physicists have for a hundred years incorrectly quantified permeability in relative terms. The permeability of space is considered as 1, and the permeability of physical objects are given a strength relative to the permeability of space. I will wind a test coil to once again demonstrate the equation works for an air coil, and the test coil will be on a form that I can slide a snug fitting solid iron pipe into. I will then be able to observe how much inductance a given volume of iron has in terms of turns of permeability. The equations that result from this data will further improve my understanding of how physical matter interacts with the permeability of space (Aether). This is a very important improvement in physics that people need to understand.
I have strong reason to suspect that the data will reflect a pattern that I have seen in General Relativity theory. If I am correct, this will open another door on the quest for free energy. If I am right, our free energy devices need to account for both the curl of space and the permeability of physical matter. When we design our experiments, the geometry of the physical matter must match, and balance, the geometry of space (Aether).
I hope to produce a short video of the experiment to post online so that others can better understand what I am trying to communicate.
I don't hold back. My biggest obstacle is finding experimenters and theorists smart enough to understand basic dimensional analysis. It seems that most people have no clue how to multiply and divide units, or how to interpret units. And also, I have been fighting death this Winter. I developed a severe hypertension where my daily blood pressure was as high as 174/112 and I couldn't get it down with any medication. Fortunately, I started an exercise and diet regimen that is working and today, after two months, my blood pressure is down to 140/92. I have been working as hard as I can on my physics theories to make sure this information is available to anyone interested in it, while I am still alive. When I am gone, the websites will eventually run out of service and the information will disappear. I haven't found anybody interested in learning and applying the theory, let alone someone who will preserve it.
Post by: i/o on February 08, 2022, 11:00:38 PM
I look forward to your video, volantis.  Keep exercising.  Exercise is the miracle drug.  Sounds like we fight the same fight.  Good luck to you.
