Overunity.com Archives
builders board => Virtual Movement of Magnetic Fields => Topic started by: Ufopolitics on April 07, 2022, 09:40:19 AM
Title: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Post by: Ufopolitics on April 07, 2022, 09:40:19 AM
Hello to All,
First, I would like to thank Pierre Cotnoir for showing his setup, plus the moderated Thread by Gotoluc...unfortunately now gone south.
All this readings and watching his videos, make me realize what I was doing wrong in all my experiments in these fields about seven or eight years ago...
Do to these exhaustive experiments done many years ago, trying to get just the Magnetic Field moving within the steel cores and windings...then just by seen Pierre's videos, and reading his comments on that Thread, I realized where was my main error, and to put it in simple words:
I was collapsing the Magnetic Field...
And this is the crucial point here!!...the whole, main field can NEVER DIE!!, not even for one millisecond or even one nanosecond...So, you could switch a minimal number of coils at a time, but ALWAYS leaving the majority of coils which configure each Pole, turned on.
Then the words from Thomas Bearden, (Rest In Peace) kept pounding on my ears: "Whatever you do...don't ever, kill the Dipole!!"
If you collapse the main field by cutting off its feed, even for a fraction of a second, everything will have to restart again from scratch...and so, you will never get to generate a growing, development over time of energy output...simple.
And of course, there are some other "secrets" involved to make it more and more successful...however, I would not keep any of these secrets just for me here...my point in opening this Thread, is that You will also be successful reproducing this effects...as that would be my "protection".
I will start, like I always do...when I disclose something that eventually will become more clever, more complicated...and that is by first starting by a very simple experiment...very simple.
A long time ago, I built a small mechanical Rotary Switch, which could commutate a series of coils remotely...by just wires transfering the switching.
And NO, you can not just buy it "off the shelf", or "order it on line" anything that even looks similar to this type of switch...so, yes, it has to be built from scratch.
This Rotary Switch I used it to run the 1908 Clemente Figuera setup...where the Field is only moved forward and back, by step up, step down, just by the High side or Positive feed...so, my rotary was set with only one brush feeding the coils, while negative ground was always connected.
However, I had the original switch set with dual slip rings...and now, I had to dust it off...and reset it for dual brushes sweeping on a 16 elements, brand new commutator...I am still working on that...
This way, I will be able to show a system working without a lot of clever circuits, consisting on a bunch of relays, or FET's...and Microprocessors, like an Arduino or a Raspberry PI...or any other Programmable Logic Controller....plus writing codes, etc,etc.
I will put it in straight Black and White, for sake of the simplest understanding first.
And attached is an image of this simple test...diagram, that I would be testing and adding a video very soon.
The Rotary Switch should be build with heavy contacts, which could be used also for higher voltages and amperages in the future...while a very small motor will be in charge to just rotate the brushes and slip ring...and I will  keep adding images of my progress here...
Cheers
Ufopolitics
Title: Re: Energy Generation by moving Magnetic Field through Steel Core and Copper Coils
Post by: Ufopolitics on April 07, 2022, 10:18:10 AM
BASIC MAIN WINDINGS AND CIRCUIT OF GENERATOR STATOR PLUS STATIONARY LAP WOUND ARMATURE
Here I will show a Diagram of the Basic Winding which involves a Generator Field (Green outer windings of a Single Phase shown here, without showing the rotor exciting coils) and the Inner Stationary Rotor...which is basically a typical Simplex Lap Winding, however (and this is the first secret) that the size of the main poles, (here are just two Poles) must MATCH the Generator Output Coils width.
Now, the good news is that we could find this whole similar set up in an Universal Brushed Motor...already wound from factory, with balanced coils in size and in number of turns, in Armature and in Stator... ;D
These type of Universal Motors, as also the Permanent Magnet ones, have a Lap wound Armature...and they perform by keeping an ALWAYS ON AND STATIC Magnetic Field...and in charge of the Rotation are the series connected coils constantly rversing their Polarity in Voltage hence in Magnetic Poles...
So, no matter how fast this rotor is spinning...the Magnetic Field will always remain static, lingering spatially all the way to interact with the coils on the Stator.
Then what we will be doing here...is just the "Reverse Engineering" of the whole system...which means to keep rotor static, firmly attached to main frame, keeping an air gap...where we could just use high temp tape that we use for coils winding...instead of the air gap.
And then rotating just the Magnetic Field by rotating the Brushes with our simple Rotary Switch... ;)
Post by: Ufopolitics on April 07, 2022, 10:39:41 AM
FURTHER EXPLANATION ON THE SIMPLEX LAP WOUND ARMATURE
So, all these coils in the armature are connected in SERIES in a FULL CLOSED LOOP...with a "Y" derivation to each commutator element from each coil...
And brushes, typically set apart by 180º, are in charge to DIVIDE this Stationary (on motor) Field Poles in North-South...and this imaginary line between the two brushes, comes to be what is called as the "Bloch Wall"...which is normally PERPENDICULAR to the Stators Coils dividing line.
When the Armature is energized (Positive and Negative) through the brushes, there is immediately developed a full Attraction and a Full Repulsion at each Magnetic Pole, forcing the Rotor to "spin"...but what is actually taking place is that one of the coils of each pole side are reversing their polarity, by "passing to the other side" of the Magnetic Field, defined by the Brushes imaginary line...while Field is completely Static.
The great side of these type of windings, is that Currents are kept on the low side (and pretty constant) during operation, no matter how high we dial the Voltages up...which keeps the Magnetic Field very stable.
Explanation of the attached Image:
It is an Upper View of a typical PM Symmetrical Motor, where I have painted all coils with the same color as the magnetic pole where they are "momentarily" energized by the brushes...so Red are South Pole Coils, and Blue are North Side Coils...and this is an image taking place in a fraction of a second...as they are constantly exchanging from one side to the other side of the Static Magnetic Field....
If you notice the Field is always ON and Static, while majority of coils are energized polarizing the Field main poles...as ONLY TWO COILS AT A TIME (one coil per pole), are switching or reversing polarities...this is exactly what we need for our test.
To be continued and keep checking for further editing
Cheers
Ufopolitics
Title: Re: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Post by: Ufopolitics on April 08, 2022, 05:07:51 PM
Hello to All,
Thanks RhineX for sending me the video links!! :D
About this guy in Korea, who is doing very similar experiments (2016-2018) as the test I have proposed, and that I am working on at the moment...
They say He is getting somewhere around 170% COP...but I have not confirmed that yet...
Anyways, just to share his work and video links here...
In my opinion, He is making some mistakes...and have no idea how he can reach those numbers.
He is overkilling his setup, the brushes rotation are using a too heavy assembly, too big motor (as Prime Mover), ... just to turn brushes and slip ring assy we do not need that much power!!!
I am using a very small, little 5-18V motor that not even reaches one amp at max RPM's...
In the second video (2018) He is got a different configuration...making even heavier the prime mover...without upgrading his main Generator output source or the Universal Motor...
Again, it is not needed that many brushes like he has on second video...maybe four or six at max, which will divide the Field in four or six poles, instead of two poles with two brushes...and having more fields will reduce the required speed to reach 50-60 cycles...same as in a typical generator.
There are many things that could be done on this setup...like adjusting Brushes Angle, to narrow the Field width from 180º up to 90º ...or more...but all depends on the stator width.
FIRST VIDEO (2016) (https://www.youtube.com/watch?v=bWJITEQeGho)
SECOND VIDEO (2018) (https://www.youtube.com/watch?v=KZeZyR8LD7A)
Cheers
Ufopolitics
Post by: Ufopolitics on April 08, 2022, 05:09:57 PM
And here are some images from his latest (2018) video...
Post by: Ufopolitics on April 08, 2022, 05:45:42 PM
Resuming...
Anyways, no matter what, it is great to see that someone, on the other side of the Globe...is also trying to work on this... :)
As it shows that there is an Induction generated by just rotation of the Virtual Field through the static steel cores and coils...
As I mentioned before...this is just a simple testing to observe, read your parameters...as the same rotary switch could be used to drive much bigger fields on larger machines...
Eventually there could be done a better winding, specifically designed for a higher field density and strength on the Armature or Static Rotor.
What I really want to test...is the posibility to loop the output to the Input, after ac from output passing diode bridge and running small cap...to the input...then disconnect PSU... :D
I will be very happy, if this could be achieved...even if a second load could not be added...but eventually allow us to add specific secondaries at 90 degrees from main output coils (in order not to upset mains)...just to loop Exciter...like any small single phase generator does... ;)
Cheers
Ufopolitics
Post by: Ufopolitics on April 09, 2022, 03:18:34 PM
Hello to All,
Again, I want to thank Member RhineX for sending me the links to the Google Patent of this device build by Jae-Soon Park (the Korean guy), that I previously posted his tests...
Here is the link for the USPTO Patent link: PATENT # 8629588 (https://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=8629588.PN.&OS=PN/8629588&RS=PN/8629588)
And I could not believe this guy patented his tests!!...which were meant just to do that, test, research, experiment, improve means to output better results...etc,etc.
And He is still adding the huge motor (on pat images) and the same type of armature arrangement, which already exists in all Universal Motors Lap Windings...
An "off the shelf", OEM, Universal Motor, like he shows, -on his tests, and on his patent- will never, ever, output the same way as a dedicated Generator-Frame and Windings will do, based on number of turns, wire gauge, spatial  distribution of the coils, which could have included Three Phase Windings, plus the looping coils to feed exciter or stationary coils here... etc,etc...
He just spent the money, hire attorneys and patented an unfinished product...maybe, because he was "excited" by his results...then decided to "protect" his idea/invention...from others who may steal it...
Anyways, this test is just what I said previously it is...a simple test, it will get way more complicated later on...it is just so you can see what happens here...compare Input versus Output numbers, measure Amps and Volts In-Out...What happens when loaded?...check which best RPM is suited for a better Output Sinewave, seen on a Scope...add then running caps...and retest...and so on and on.
One of the issues I have found on these system from my previous experiments...and now I have seen it on one of his videos below, as it happened exactly the same way to me:
On this video HERE (https://www.youtube.com/watch?v=scfEaNilYHk), at  minute 0:43 He shorts the output with his hand (Picture attached)...bulbs go off...and unless we are talking about 12 V and low amperage, stioll is AC, no diode bridge here...and let's realize these are incandescent bulbs, not LED's...
The Currents on the Output show they are higher in size than at Input...however, if you get the output and short it...say at 3 Amps...no sparks take place at all....the output just collapses (I have done that)...on his videos the two incandescent bulbs just turn off...and of course, the prime mover, turning the brushes is not affected by the short as they are two completely independent circuits.
But the issue here is that even looking as a higher Output, on V&A, Amps does not have the "real power" as they represent on the readings.
I mean, if you just touch, 120 Volts and 3 Amps in AC Output, you will get a shock!!...but not here...
This issue could be resolved, but not simply...we will have to modify the Exciting Armature, structure and windings...
What I think is happening here, is the fact that a Magnetic Field backed up by a moving steel core (like we have in all rotary generators), will enhance, add more density to the power output... much more than just the virtual field rotation on a full static steel core...
But, the solution would be shown after I make it work, and be sure it does solve this issue, (still some time until I make that specific armature structure and windings)...as I have to first test the simple Universal Motor...and do all this measurements and tests.
Cheers
Ufopolitics
Edit 1: I just noticed when uploading images here, on MAIN DIAGRAM_2...that he uses an Inverter, to feed back output power back to brushes (Input) through a battery...I mean, I hope he is referring to a simple Diode Bridge...and not to a whole inverter set...
Post by: Ufopolitics on April 09, 2022, 03:41:12 PM
PATENT 8,629,588 CLASSIFICATION:
H02K53/00 - Alleged dynamo-electric perpetua mobilia
Perpetua mobilia obtained e.g. by
by combining electrodynamic machines (e.g. small motor driving a larger generator whose output is used to feed the driving motor;)
by particular arrangements of PM (permanent magnets) only.
This is the typical response from any Patent Office in the International Commonwealth of Patent Treaties...
Whenever an individual walks in their offices claiming a "combination of electrodynamic machines"...where a small motor (or circuit) is driving a larger generator, then looping it all...
You can NOT Patent Free Energy System guys!!...do not insist!!...It is money and time wasted!!
No one will even pay attention to your invention.
Ufopolitics
Post by: Ufopolitics on April 10, 2022, 02:37:44 PM
NOTICE TO ALL:
I would  NOT, under ANY circumstances, allow nor accept, ANY Nay Sayer's Comments here, on these Threads.
That is the ONLY reason I accepted to DISCLOSE HERE...as a Moderator , thanks to Administrator of the entire site, Stefan Hartmann and to "Chet" RAMSET.
So, if you post any "Nay" saying comments here...and you are still "seeing it" ...you may need to REFRESH  your browser, which resets your "Cache Memory"..
Or it could be that I am not logged in, or away from the website...it will not take long, though, as it will get done, in time...
This Thread is intended ONLY for people willing to do (BUILD) all future tests and share them, verify their results HERE.
Images, at least, should be posted of your progress, but videos would be more suitable.
I will allow any willing builder to open his-her thread under the main one.
All others, please, just remain as viewers...and like I always write on all my videos: many thanks for watching!!
Respectfully
Ufopolitics (Moderator)
Post by: citfta on April 10, 2022, 04:32:08 PM
Hi Ufo,
I hope you don't mind if I ask a question about this topic.  I think I am missing something.  I don't understand what the difference is between this machine with the rotating brushes and a regular car alternator.  Both of them are moving a magnetic field inside the stator coils.  And both of them maintain a continuous strength magnetic field.  So what makes the machine of this thread any better than a car alternator.  What am I missing?  Am I misunderstanding what I am looking at?  Thanks for any clarification you can give.
Respectfully,
Carroll
Post by: Ufopolitics on April 10, 2022, 05:00:49 PM
Quote from: citfta on April 10, 2022, 04:32:08 PM
Hi Ufo,
Respectfully,
Carroll
Hello Citfta,
Great question!!!...excellent!!
Sure I can answer your doubts, even though I know that you know perfectly well how both are designed as how they work...
As you may have missed something...
THE SPATIAL GEOMETRY OF THE MAGNETIC FIELD
If you look again at a car alternator...the Magnetic Field is completely Static, no matter how fast you spin the rotor...
Alternators have the Coil, which generates the Magnetic Field, wound around (or parallel we could say) to the rotor shaft...then generating an upper and a lower pole.
The rotor steel core configuration (top and bottom) have these tooth like, which redirects the magnetic poles and alternate them in N/S/N/S/N in order to be facing the Induced Coils and Stator core...
However, the Magnetic Field is always Static (related to main N/S poles spatial positioning)...
And so, what we are going to be doing here is Moving the Magnetic Field through steet cores and coils which are completely static.
Ufopolitics
Post by: Ufopolitics on April 10, 2022, 05:05:15 PM
Hello,
Here is my Rotary Switch progress...almost finished, have to set all connecting bolts-nuts...and hook all wires...plus make all connecting 16 wires to be soldered to the armature/rotor of the test small universal motor.
I ordered  a couple of Universal heavier DC Motors...should be coming next week hopefully.
I set my hand there on one pic...so you could compare sizes of the whole rotary power switch...
Yes, I installed a brand new flat commutator, 16 elements...
And made some "tune up" and clean up to the small little motor...which I wound specially for this job a long time ago...in order to consume very little power, as to have pretty good torque...no need to go over 4000 RPM's for this job.
Cheers
Ufopolitics
Post by: citfta on April 10, 2022, 05:37:05 PM
Thanks for your reply to my question.  I'll keep following along to see how this works out.
Very nice looking brush/commutator set-up you have built.  Really looks great!
Later,
Carroll
Post by: Ufopolitics on April 13, 2022, 01:35:03 PM
Hello to All,
THE TANK CIRCUIT IN A TYPICAL GENERATOR
This is related to a typical, Single Phase Home Generator...any wattage
And here I would be specifically relating to the Excitation Circuit composed of:
1- Two Stator Coils, facing each others at 180º, and normally set at 90º to the Main Output Fields...these two coils are made of finer wire than main out Coils, and they have a plug which connects to a Running Capacitor. So, this Two Coils (in series between them) are in Parallel connected to a Cap...
And so, what we have here is simply a "Parallel Tank or Resonant Circuit (https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/parallel-tank-circuit-resonance/)"... ;D
2- The second part of this circuit are the Two Rotor Coils...which are also in a closed circuit by two Diodes.
I am showing a Diagram of both circuits in one image for clear understanding, to compare and to explain...
At plain start, from rest, any Generator have two small permanent magnets, set at 180º in Rotor Core...which assists in case any magnetic reminiscence in the rotor steel core is gone...
Besides that, if a Generator has been in storage for a long time...it may also need a "Flash Charge"...which is just to charge the Running Capacitor with an external currentof 120V or 220V (if the case)...then our generator is ready to start generating output.
Once the Magnetic Field starts rotating at the required Frequency, (50-60Hz normally) it will Induce an AC Current in Stator Coils, which in term is stored in Running Capacitor...and so...the old  story about Tank Circuits starts the "back and forth" jump of currents...
Point is, that the Exciter Circuit operates in two stages...
1- Charge takes place from the Tank Circuit to Rotor Coils at 90º...to a Full Magnetization of the Steel Core.
2- Discharge of the Rotor Circuit Coils, again at 90º more degrees, into the Output Coils...through Induction or Flux discharge (call it as you please.. :) ).
Please see attached Diagram of the Charge-Discharge Stages of the Exciter Circuit...
Here are some useful links to a better understanding, plus using the Formulas...and conversions
Calculations and Formulas of Tank Circuits (https://www.allaboutcircuits.com/tools/tank-circuit-resonance-calculator/)
Calculator finding out one parameter (https://goodcalculators.com/resonant-frequency-calculator/), when having at least two of the three involved (f, L & C) or Frequency, Inductance and Capacitance required to be in Resonance...
Conversion from Microhenry to Henry (https://www.inchcalculator.com/convert/microhenry-to-henry/)
The previous Calculator gives results in Microhenry...so to take it to Henry
Well, We all know the Frequency that a Generator operates...it is either 50 or 60 Hertz...
The Inductance of our coils by measuring with an LCR Meter...
And We calculate the Cap value we need to work out successfully.
Note: This knowledge is very useful in order to conduct the tests with the Universal Motor...and be successful.
ATTENTION: ANY NAYSAYER COMMENTS , JUST WILLING TO START DISRUPTING HERE, WITHOUT ANY GOOD INTENTION OF CRITICISM OR CONTRIBUTIONS, WILL BE REMOVED "IPSO FACTO"!!
Respectfully
Ufopolitics
Post by: Ufopolitics on April 13, 2022, 02:16:04 PM
Hello again,
Today a Universal Motor would be arriving...it is a German build...pretty strongly made...oops...it just arrived while I was typing!!
Here is a pic... ;D
Is a Groschopp, and all connections are outside...in order to set it in series conn. or parallel connections...or to measure each coil individually...as Armature Inductance and resistance right from the two brushes...
It can work with 120V and with 50V...AC or DC...
I also ordered two LCR Meters, different calculating algorithms, in order to compare accuracy...
I will also verify on my lab generators for Equation Formula consistency of all parameters...L,C,R basically...as Frequency is constant.
Cheers
Ufopolitics
Post by: Ufopolitics on April 14, 2022, 12:38:52 PM
Hello to All,
Ok, the Groschopp Universal Motor runs beautifully, very smooth, no spark gaps...I still need to take it to 3600 RPMs and take Armature readings of V&A
These type of motors after you turn them off completely...they keep spinning freely for a long while...since they do not have magnets...there is zero magnetic friction....feels great!!
But  there "was" an issue...this motor have 24 elements in the commutator, my Rotary Switch commutator have only 16 elements...
So I have to get all this into a CAD...in order to find a possible sequence...without affecting the Magnetic Field overall behavior.
And yes, I found it...while the only change would be minimal in Field performance...here is the diagram for connections plus the angles of field propagation.
When Brushes are in between two segments (division of two elements at center of brush, as shown on Diagram) of a non connected element. the Field will reduce from 24 total Coils to 20 Coils active...meaning 10 Coils North and 10 Coils South...until brushes make full contact with commutator element, then Field will go back to 24 Coils active, 12 Coils per pole.
Edit 2: Again, this fluctuation of the field (from 12 to 10 coils per pole) only takes place eight times in a full turn, while Field running in full (all 12 coils per pole) through the other 16 full contacts...since there are only eight elements not connected, and spread around the 24 elements circumference.
Please note that all light blue Motor Commutator elements are not connected, so I am jumping one every two elements connected...with a total of eight [8] Coils which are not connected to switch, however, they are all still connected in  series between them.
So, this sequence will take place only in the transition from element to element...and not affecting the whole main  field overall performance...I hope.
Edit 1: Where I believe I would be able to notice this is on the Scope signal...maybe a bit of scattering, not a straight smooth curve...we will see.
Ufopolitics
Post by: Cadman on April 14, 2022, 06:53:39 PM
Hi Ufo,
You know a lot more about this stuff than I do, but isn't this setup apt to cause a lot of sparking at the brushes? Maybe AC caps across the switch's commutator segments would help?
Just a thought.
Post by: Ufopolitics on April 15, 2022, 08:07:14 AM
Quote from: Cadman on April 14, 2022, 06:53:39 PM
Hi Ufo,
Just a thought.
Hello Cadman,
It shouldn't...let me explain.
This is a typical Symmetric Motor , a Lap wound where coils are all in series.
They run very smoothly at "idle" (no load)...no sparks...current (Amperage) maintains itself regulated at a constant level...and when accelerated it even comes down a bit.
However, the minute you add a mechanical load, everything changes...sparks galore and currents increase to max values.
But, on this design, I will not have any mechanical load at the rotor...it is just rotating a massless field through the metals (steel & copper)...the rotor would be static.
And as long as the prime mover (small motor) keeps spinning the field, the rotor coils will just keep "warm"...
It is the same, exact function, as when the motor is running at idle...no mechanical load.
When we add a load at output stators, they will magnetize stronger, but rotor is static, so Lenz have no where to go...where to act.
And the rotating, Exciting field may demand a bit of higher power (by showing a drop at loaded output power) to compensate for the stronger magnetization of the stators...that is all.
Same exact behavior as a loaded generator, where the gas engine needs to step up torque and speed , because it drops as heavier loads are added to output...
AVR will detect this drop at output, and increase magnetization at Exciter Coils...
And here we will not need a higher torque, just increase a bit of speed to small motor and power to Exciter...which will eventually be done automatically by the stators exciting coils (not on this test yet) when speed of rotating field is increased.
I will be adding a small AC Cap, at the input, between both brushes...but for another test I am planning as well.
However, these are all assumptions, until I test it for real...setup will answer all our doubts...I maybe completely wrong.
It did arce and sparked a lot prior, when I was collapsing the coils in every single degree of rotation...
We will see now...
Thanks and warm Regards friend.
Ufopolitics
Post by: Ufopolitics on April 15, 2022, 03:07:59 PM
Hello,
Here is an update image...
Done with the rotary contacts wiring and small universal tool motor commutator wiring ...now match and connect.
Still lot of work ahead...but, getting closer...
Had to clean up a huge mess on bench previously...to now create a second mess... :)
Btw, I got one of the LCR Meters yesterday (orange one, on right hand of screen)
Cheers
Ufopolitics
Post by: Ufopolitics on April 17, 2022, 05:58:07 PM
Hello...and Happy Eastern to All!!
I have done some quick tests with the small RYOBI Hand Tool...and it came out wonderful.
Of course, this is a small motor so have to play with smaller voltages.
But the main issue here that I want to share, is how I have set the brushes on the rotary switch...yesterday, I was testing with just two brushes...and there was a lot of sparking, a lot of BEMF returning back to Input PSU...
So I decided to close the Field Range by adding four brushes (this brush housing on switch, was designed for 4 brushes) but they have to be in a way that is NOT as Motors have it.
Normally a four brush motor will have an arrangement of /+/-/+/- / and that way the field gets split into Four Fields at the Rotor.
However, I did it in order to keep just one field, but close its angle at the Poles, by setting brushes like: /+/+/-/-/ , therefore, the coils within the two plus (+) and two minus (-) will not be energized, not generating a field, but just conducting power...and so, Field Spectrum is way much cleaner.
Magnetic Field will not have any "scrambling" which happens with just two brushes...and it is due to coils at the contacts (+/-) will be intersecting with BOTH main poles...I will make next week a CAD to show what I mean, however, on my previous image here that have an armature, wound with lap windings, you can see that I colored these next to input plus and minus in a different color (magenta) than all the red-blue coils defining the North-South Poles.
I will upload again that image here...for easier access.
I will also upload a picture here of this way to arrange the four brushes at rotary switch...
SHORT TEST VIDEO (https://www.youtube.com/watch?v=DQpWmvkAqsc)
Now, this video above is NOT Published on my Channel, (I do not want my subscribers to go like WTH is that??...lol, since I always give an explanation previously) so, it is UNLISTED, and I made it just for this Forum.
Ufopolitics
P.D: This video is not trying to demonstrate any Overunity at all...it was only intended to show a couple of things.
1- We can increase Output Power by just increasing Field rotational speed, without affecting -at all- Input parameters (V&A).
2- Also to share the huge difference it did to my previous tests by changing to four brushes, the way I have described prior...
Post by: Ufopolitics on April 22, 2022, 12:17:23 PM
THE MAIN GENERAL IDEA OF FIELD SPECTRUM DISPLACEMENT...given as a short Abstract:
ABSTRACT:
A Sequential Series of Orderly Switching, that could be done in several ways, from a primitive small Rotary Switch, or Relays, or from State of the Art in Electronics, all leading to perform same Mutations of smaller percentages of the Main Magnetic Field, without ever allowing a full collapse of the main Magnetic Field, which induce to a Displacement over Space/Time of this Field Spectrum of apparent Massless and Invisible to plain eyes, through all metals where it is generated, eg: Steel Cores, Copper Coils, etc...
This continuous displacement of this Field Spectrum through space/time, while all components which generate it, stay static, will produce pure and constant Energy, for as long as it keeps moving.
I know this should have been on my first page...and I can change that...but I will not...it is still about the same, exact main principle of whole Thread and Sub-Threads here...
Ufopolitics
Post by: Semi on April 23, 2022, 03:40:26 PM
Hey Ufo,
I did some Math regarding the RPM and switching Frequency of the RMF. It would be awesome If you could double check this please?
Also I have some thoughts and Questions I would like to point out.
On a Generator with 50 Hz Output Frequency:
Time Period T = 1/f with f in Hz = 1/s
- a 2 Pole Rotor must spin with the same speed, it has therefor T_2P = 20 ms,
- a 4 Pole Rotor can spin just half this fast to get the 50 Hz out, f_4P=25 Hz, -> T_4P = 40 ms
Q: What is a typically exciting Voltage on a constantly rotating power generator?
Is it approx the same Voltage in DC as the Output? Like in a Car Alternator, where after the initial
exciting from the Batterie, the output Voltage serves as an exciting source. Approx 12V i.e.
If you have a 24 Slot commutator, means 24 Coils, now with 4 Poles, means 6 coils for each Pole and 12 for 2 Poles.
So these 12 coils must be switched or rather shifted with the Time Period T_RMF, that it simulates T_4P ?!
Therefor it must be:
12 x T_RMF = T_4P (x stands for times, not for the cross product)
this is equal to:
12 x f_4P = f_RMF => 12 x 25 Hz = 300 Hz -> T_RMF = 3,33 ms
This also means, with your 4 Pole and 24 Coil RMF, the output Signal must be 12 times slower than your input Signal.
You have to drive 300 Hz on the Input, to simulate a with 25 Hz rotating 4 Pole Rotor, to get your 50 Hz Signal out.
Q: Can you confirm this? Can you measure your coils switching frequency with your osci? Perhaps with the single shot function?
I think you've already proven a lot of your claims with your short clip. If I figure the values right, your excited DC EMF is almost
the same as your induced AC EMF.
Q: Any Idea why this is?
I thought, compared to a generator or Transformer, the output Voltage stands in a relation to the number of turns from the input
and output windings. Hence an universal motor doesn't have this relation between input and output windings. A Generator does.
So it could make sense, that your induced EMF will be more or less always the same as
your excited EMF. Generally spoken, in Generators and transformers, the Induced EMF is a function of the input frequency,
If N1 is not equal to N2. I think it could be possible that in an universal motor N1=N2, due to its nature.
Q: Can you confirm this? Did you measure different excited and induced EMF with different frequencies?
Q: What is the nominal Voltage your rotor has to take, when running as a Motor?
Q: What are your Coil Values? Different Values from different LCR-Meters?
Cheers
Semi
Post by: Ufopolitics on April 24, 2022, 02:51:22 PM
Quote from: Semi on April 23, 2022, 03:40:26 PM
Hey Ufo,
Hello Semi,
Wow...what a "bombardment of questions" here....hehehehe
But, ok, about your above first question...
let's remember who dictates the Output Frequency in a Generator?
It is dictated by the RPM of the Exciter, and directly -in  a typical generator- is given by the speed of the ICE Engine.
Yes, of course the higher the number of poles on the Exciter, the lesser the RPM's required.
For an Output of 50Hz a Two Pole Exciter Rotor must reach 3000 RPM's, while a Four Pole will just need half of that, or 1500 RPM's.
And so, for a 60 Hz, it needs 3600 RPM's for Two Poles, and 1800 RPM's for a four poles exciter.
No, the voltage to power the generator exciter coils is HIGHER, than the Output Voltage.
For example, a typical 120V/20A Output Generator will require its exciter to run at approximatedly 170-180V and 1-2 amps
this is equal to:
Sorry Semi, but I do  not understand your reasoning (Mathematics) on this...
You are mixing 12 (from 12 Coils in a 2P) with "T_4P"?
But basically it is the total opposite to your conclusions above...No, the Field can never rotate faster than the outpur frequency required!!
If you do that, there would not be any output at all...
Here we are rotating a Spectrum that goes faster than light...and can go through metals like through air...so, more likely The Field must be driven SLOWER, than the needed output frequency...and that applies to 2P and 4P...and even 6P.
To get the right and best output frequency, the Field must be driven very slowly...and up, until the reached correct timing is met...if you keep going higher, after reaching the "sweet spot"...the output will start decreasing.
Cheers
Semi
Thanks, but we still can NOT establish any rules up to now...related to Input versus Output relationships...it is way too early for conclusions!!
So, like we say in USA..."do not jump at the gun..."... ;D
I was just making a simple test, like I have proposed...but these Universal Motors are FAR, from being even "similar" to the structure of a real generator configuration.
Only then, whenever we have the typical configuration that a real generator have, then we could start coming up with conclusions...and relationships...
So, it all depends on your configuration, which allows to reach much higher outputs with a minimal Input...that is the goal, my friend.
Ufopolitics
Post by: Ufopolitics on April 24, 2022, 03:13:27 PM
Hello to All,
I highly recommend FIRST to start using/playing/calculating/running simulations, etc,etc with a simple Two Pole Configuration in your setup...
Please, do not overcomplicate things before even trying and building this simple setup!!
I have a 2 Pole setup, and I had to add two more brushes to my Rotary Switch, NOT to make it a 4 Poles...BUT...in order to shorten the Field Angles of Interaction, which gets a much stronger effect without any side noises or scrambling, whenever we get crossed coils noise in the middle of the field.
So, imagine using a four pole...in order to shorten these four fields angles, you will need eight [8] Brushes in your Rotary Switch!!
Then you end up using a 1/2 HP Motor to run just the rotary switch...just like the Korean guy did... :)
Fact is, you only have a limited number of coils in any given rotor-exciter to be fitted inside any given stator...so, "spliting" coils in four or six will be like cutting in pieces a very strong two field composition, into four or six slices of the same "pie"... ;D
All the work just to drive Field at slower speeds??!!
Cheers
Ufopolitics
Post by: Semi on April 25, 2022, 03:08:18 AM
Hey Mate,
Quote from: Ufopolitics on April 24, 2022, 02:51:22 PM
Hello Semi,
I didn't mean to steamroll you there, but you kinda invited us to this ride,
so stop complaining If you have to jump curbs.  :P
Sure thing, 50 Hz by 60 times (for one minute) = 3000 RPM, or rather 3600 RPM with 60 Hz. But I like to calculate in SI.
This can't be true, not at all. I've read values from an AVR, that excites up to 90 VDC depending on the load, Output approx. 230V AC.
I don't think you get the Science here either, you're not thinking fourth dimensionally. Is the Flux Capacitor really fluxing?  ;D
Well, I thought your 4 Brushes will create an equally divided 4 Pole RMF? So I derived my Math from that. If you have "just" a 2 Pole RMF, with 24 Coils,
you would've to go even faster. Then it would be: 24 x T_RMF = T_2P => 24 x f_2P = f_RMF => 24 x 50 Hz = 1200 Hz -> T_RMF = 0,83 ms
Yes, it is totally possible that I am barking up the wrong tree here. That is why I wanted you to double-check this on your rig.
I totally get you there...
How much more theoretically can I get, when not by using Math? You have the Test rig already, why not getting some data out of it?
That is so true.
Perhaps I don't get the detailed Setup configuration you have built. I felt into the assumption trap, again.
Here my thoughts about this, please correct me...
If you have a Rotor with 24 Bars on the commutator, you will spin your brushes
around these 24 contacts. If equally divided, with 2 Brushes, you will create a 2 Pole RMF and with 4 Brushes, you will create a 4 Pole RMF.
Thanks for taking the time, very much appreciated.
Semi
Post by: Thomramzes on April 25, 2022, 02:24:31 PM
You are making the best posts ever
Post by: Ufopolitics on April 26, 2022, 11:44:40 AM
Quote from: Semi on April 25, 2022, 03:08:18 AM
Have you read the Voltage from AVR when the Generator was loaded?
With a heavy load?, not just a couple of LED's or a small fan... ;D
When the Generator is at "Idle" the AVR reduces to minimal its excitation circuit.
The "230V" Output is just based on a Double Winding at Stator, which collects double the output based on exactly the SAME EXCITING FIELD SWEEP.
The exact same way we could get Three Phase Out...
Nope, I already explained why I used Four Brushes...read my prior posts where I show my image of the 4 brushes...
So you derived your math above from a wrong assumption, so, everything is wrong.
Semi
Again, wrong assumption, maybe because not reading carefully my previous post...but no sweat...I will repost it here...without the pictures:
Quote from: Ufopolitics on April 17, 2022, 05:58:07 PM
Cheers
Ufopolitics
Post by: Ufopolitics on May 01, 2022, 01:14:51 PM
Hello to All,
My present update plus some "secrets" revealed:
I had some bad testing as also very good ones...
The bad tests I consider very important as well as the successful ones, as they teach Us what is NOT allowed, or not good on these Systems...
For example, the German Groschopp Universal Motor was a total failure!!
Why?
Its Armature-Rotor is simply an "Amp Hog"...it consumes higher amperages than volts, as I dialed up just voltage (V.L), while Current is all the way high ...and I tried with both PSU's...a switching and a Linear.
On both reacted the same exact way...
And it does spin the Field, however, the field generated is not strong enough as we loose a lot of power just on the Input.
The reason for this effect is simple, is wound with too thick gauge wire and just a few turns per coil...
The first successful test with the RYOBI Hand Tool 230 (HT230) [on short test video] had very fine wire and many turns...
So I tried another setup, with a 12 tooth armature, and the typical Simplex Lap Winding, and wire gauge 23...I am attaching an image of this winding below...
It did not work either...the sine wave projected on Scope was not uniform and the output results were also not good...
So, I went back to the original RYOBI armature which worked fine...and analyzed deeper the way it was wound...and it is a completely different type of winding as I did previously...if you notice, (picture attached) it ends with two identical coils opposed at 180 degrees.
Plus, the rotor core have 8 slots (tooth) and the commutator have 16 elements...
Note: I did NOT want to take apart my only working armature, first because it is soaked in resin...and second, because we never should take apart a working model...take it as an advice!!
So, I started searching and found this video from a guy, (I believe He is from India)... winding a Power Tool...which have 16 slots and 32 Commutator bars from an angle grinder...So, without understanding a single word he was talking about...I learned the way it was done:
VIDEO: THE SUCCESSFUL WAY TO WIND THE ARMATURE (https://www.youtube.com/watch?v=gEKl2mq-D1o&t=23s)
The way these type of armatures are wound is very different from the typical "Spiral" type...that we start just ONE COIL and keep winding series coils next to each others...untill we meet the first wire at commutator.
On this successful type, we need to WIND BOTH SIDES COILS, apart by 180 degrees, and keep going in a follow up pattern, until we meet both ends,  also apart by 180º...
But that is not all...each coil have the second coil right on top of each other, except the second coil on top, connects to the next commutator segment on the follow up sequence...
And this rises the Field Strength exponentially!!...just like a double threaded wire in a coil does, except, by just a few milliseconds of time difference.
I will show on further posts the detailed Graphics related to this type of winding...
Plus, I have been able to adapt this type of winding to many other armature patterns, like 12 and 20 tooth...which ends in exactly 16 contacts to my Rotary Switch...so, no coils are not connected during operation.
Ufopolitics
Post by: Ufopolitics on May 01, 2022, 02:27:02 PM
ADAPTING A 12 TOOTH ARMATURE TO 8 DOUBLE COILS - 16 TERMINALS
This is one of my armatures, it is wound with 28 gauge, and works beautifully!!
I wound each coil with 40 Turns...
I can dial as high as 100 Volts+ and Amperage remains around 1-2 amps...lovely Field!!
But as I increase RPM's of Field Rotation, amperage decreases.
THE METHOD EXPLAINED, ACCORDING TO GRAPHIC SHOWN:
I start by the Two Pairs of Blue Coils shown (1-2 & 9-10), each pair exactly apart by 180º...while these would be my 1.2 9, 10 terminals to rotary switch...
After done with all four coils, I come back to wind Coils 3-4 and 11-12...
And so on, following the red arrows orderly sequence, for coils winding, as for terminals to rotary switch.
Finally I will end up with two Pair of end Coils 15-16 and 7-8 exactly apart by 180º...(see picture attached)
I am actually working on a 20 Pole adapt...to this same pettern, but a bigger set up, so it requires higher number of turns...more steel, more turns.
Whoever is following this posts...and replicating them...will have a lot of fun in the end...
Get ready for ¨surprises¨ coming very soon... ;D
Ufopolitics
Post by: Ufopolitics on May 01, 2022, 05:12:40 PM
VISUALIZING THE VIRTUAL MAGNETIC FIELD ROTATING (https://www.youtube.com/watch?v=Z62RUMNjXMQ)
On above Video link, you will be able to see the Field Rotating through three different Methods...
I have developed a way to distinguish Polarizations in any given Magnetic Field through an old CRT (Cathode Ray Tube) Black and white small TV...
The Electron Beam Ray sweeping screen at very high frequency in a Horizontal Line...shows clearly the Two different Patterns which defines a NORTH  from a South.
BUILDING YOUR OWN CRT MAG FIELD SCOPE (https://www.youtube.com/watch?v=E372P74Gq6k)
On above video link you will learn how to build one for yourself...
And on the Video below, you will see the Full Video on how this is achieved...
CRT REVEALING MAGNETIC FIELD VORTEXES (https://www.youtube.com/watch?v=l7OzMURRU_k)
By the way, the Armature shown on first video demo, is the one I have shown previously...a 12T wound with 16 coils
Cheers
Ufopolitics
Post by: Ufopolitics on May 08, 2022, 02:01:18 PM
Hello,
I have moved to a 20 tooth armature due to the lack of room to do more windings on the 12 tooth...I will have to change it to a finer gauge (33) to obtain the right resistance required to drive field at higher voltages and lower amperages...so, actually I am working on three setups at the time.
This armature came off a BOSCH 700W PM Motor, I have two of them, one is completely wound with "Asymmetrical Type" and this one was already stripped off all windings...
I made it fit inside the stator of an AC (Central Air Conditioning) Blower Motor, 3 speeds by Die Grinding the interior Stator metal...lot of work!!
The way I wound the Armature is the same way as I did the 12T previously shown, but adapted now to a 20 T.
It is basically 8 pair of coils, wound with 28 gauge and like 100 turns each coil, which will give me like 4.2+ Ohms per coil
Thanks to this ratio, I can drive the Magnetic Field with 60V and like one (1) Amp...at idle RPM's (not going 3600) but like 1500-1800
I am attaching some images of the whole thing already assembled.
Ufopolitics
Post by: Ufopolitics on May 08, 2022, 02:15:28 PM
WINDING 16 COILS INTO A 20 TOOTH ARMATURE
I am attaching the winding plan here...as the wiring sequence to 16 elements commutator
I am also making a video, of different steps on the winding, that I took while I was winding the armature in different steps to final.
First, I started by the Two Pairs of Blue Coils (1-2) and (9-10) exactly apart by 180º.
All Coils are wound Clockwise (CW) when facing at me...
I am using 28 gauge, around 57 feet which comes up to around 100 turns and extending to four(4) tooth on armature.
The last Pair of coils would be 15-16 and 7-8 also at 180 degrees apart, where the end of coil number 16 will attach to start of coil number one (1) and the end of coil number eight [8] will attach to start of coil number one (1)
This way the full loop of all coils will be closed.
Cheers
Ufopolitics
Post by: Cadman on May 10, 2022, 12:21:12 PM
Thinking about generating with a rotating field of the armature. There are two magnetic fields involved with the armature, the iron and the coils. Each field begins and ends with it's source and taken together they have the effect of a single field. But this new scenario is different than the usual inducer which uses a fully established combined field at all times, only changing with the load.
In this new scenario the iron field is almost constant but the coil fields all expand, contract, change polarity, expand and contract every revolution. Rotating at a rate that produces the strongest field for the coils time constants (5) would give an averaged over time field strength which would be much less than the maximum continuous field. Rotating faster using fewer time constants would result in a weaker coil field, less amperage on the input and in turn a weaker iron field and the output watts would drop accordingly.
If this is accurate, then common sense would indicate the need for design changes to compensate. Coils with small time constants and more turns to achieve the needed ampere turns, which would need a larger armature with more iron to produce an output comparable to a motored generator.
Small time constants and more turns is counter intuitive but can be achieved with multiple windings in parallel for each coil. But that costs more input amperage. Lots to balance.
Just some thoughts for consideration.
Cadman
Post by: Ufopolitics on May 10, 2022, 01:07:23 PM
Quote from: Cadman on May 10, 2022, 12:21:12 PM
Hello Cadman,
And many thanks for your input, it is always welcomed.
Ok, I would say first that I love this type of debate...however, I disagree with you on part of the above...
As I only see one Field, IMHO, the iron core serves as the "vehicle" or saying it more "Scientific"...the "Medium" where the Field moves, flows.
With a steel core (design) we could redirect a Field displacement polarity, change its angle, and even fraction it (dividing Field) into multiple poles, like is the case with the automobile Alternator...However, it is the same exact Field that is generated by the coil that runs parallel to the alternator shaft...
If you get a permanent magnet and approach a piece of steel at very close gap...you will observe very clearly -through a simple viewing film- that the Magnet Field literally "jumps" about half of its spectrum spatial embodiment into the iron piece...Now, that does not means that the iron now have its own field.
The iron piece just served as the "appropiate vehicle" where the field Mutates to...partially, though.
The above is the main principle of Induction, my friend...and remember that Magnetic Fields are purely Directional, like a Laser Beam, coming off the very center of each of their poles face.
You have just nailed it, on the above bold statement, by me!!
And that bolts down to what Pierre Cotnoir was saying about the Field "Resolution"...or in detail, that these systems work much better with a "Higher Resolution Field".
Which means higher number of coils, and since they are all in series, we could afford lower number of turns per coil...lower resistance, that of course, would need to be calculated.
For example, in a 36 Coils Armature we would be moving the Field at a ratio of 10º for each two coils that reverse, exactly at 180º...
Remember, in this setup, one coil would be leaving South to become North, and exactly at 180º, another coil would be entering South and leaving North...meaning the Field displaced exactly 10º towards the rotation sense.
If we break down the Pole number of Coils would be exactly 18, and using an angled four brushes, like I have recommended to narrow the Field Angle, would leave about two coils on each side inactive (just conducting), so, say in reality we will always have a minimum of 16X2 Coils always on, or 16 per pole.
That is a pretty good and higher resolution.
Exactly...
Cadman
Yeap, and we do not want to rise the Input Amperage too much, but try to always drive it on the low side...however, always trying to keep the Field strong enough as to keep a constant and robust output.
Yes, lots to balance!!
Many thanks for your comments!!
Ufopolitics
Post by: Ufopolitics on May 11, 2022, 10:01:00 AM
THE HUGE DIFFERENCE BETWEEN A TRUE SINGULAR MAGNETIC FIELD VERSUS MULTIPLE SMALLER FIELDS OVERLAPPED TOGETHER.
Hello to All,
Regardless of the achievements, I am still NOT happy with the results...
The two circuits, representing the two polarities of individual coils in series, that configures one single field...still does not fully form a true singular field.
This is clearly noted when looking with magnetic viewing film, the fact that each independent coil have its own center wall, Bloch wall or Dielectric Field as Wheeler's Theory...point is, whatever the "name" we give to this clearly seen center line, that this should not happen, it does not happen in a Singular Magnetic Field.
A Singular Magnetic Field MUST have just ONE Center Wall...and, as we rotate field this wall should rotate as well...and this is not happening here.
Each Coil keeps its own Dielectric Field or Bloch Wall...and that's not good, it means we still have a fractioned Magnetic Field.
And this whole issue relates to a simple answer...GEOMETRY.
Say we build Two identical but separate Coils...and we could feed them with just one source...now, if we stack them N/S>N/S, perfectly aligned by a center imaginary axis, one on top of the other...they will form a single Bloch wall right at the joint between both, or where I set the "greater than" symbol (>).
However, once we start moving just one of the coils in a Radical Angle*...there is a point-angle where that common center wall will disappear...and return to two individual walls for each coil...
When these two Coils were aligned and just one center wall appeared, there was a Singular Field formed by the two coils.
Once this center, common wall is gone, the singular field is gone, that simple.
Now, we could project both coils aligning them with the same poles orientation, say both with North on top, next to each others, no matter if overlapped or not...and yes, we will have two North Poles but not a Singular North Field...as each coil would have its own division wall.
If we could measure Magnetic Field strength for both cases...will notice when they had a Common division wall, stock one on top of the other...that would be the strongest field strength than when set side by side, aiming separatedly independent poles...and most importantly to notice...with the same Source Input of same currents!!
Radical Angle*: The common wall will still be there for smooth, narrow angles...soft curvatures between both coils will still prevail the Singular Field.
It is not supposed that when rotating the Field at higher speeds, it just "fades off"...and Induction will decrease...so, we need to increase Input.
In my opinion, this is due to the lack of the system design, to form a TRUE SINGULAR FIELD from multiple coils arrangement.
Ufopolitics
Post by: Ufopolitics on May 11, 2022, 10:49:06 AM
MAGNETIC VIEWING FILM, REVEALING MULTIPLE FIELDS WHILE ROTATION TAKING PLACE...
Here are a couple of pictures showing an "X-Ray View" from Magnetic Viewing Film, of coils during the rotation of the virtual field...
We observe a very slight, vague "rotation" around coils, which is based on the sequenced coils reversals...However, the center division lines for each coil still is there, not moving at all.
Resuming, this design, arrangement or geometry is NOT generating a True Singular Field...
I want to see a SINGULAR division wall for one singular field generated, and moving around as well as the field...this wall must be right at center of both field poles.
We need to be able to see this center line clearly moving along the right geometry, defining where our two poles are also moving...
Ufopolitics
Post by: bistander on May 11, 2022, 12:50:20 PM
Hi Ufo,
I know you and I disagree on how viewing film works and Bloch wall and you'll likely just make my post and opinion disappear, but  notice the similarities.
What appear as light fuzzy lines are caused by the flux coming from the end turns of the eight coils which you wound and not representative of the resultant field in the air gap.
bi
Post by: Ufopolitics on May 11, 2022, 02:24:15 PM
Quote from: bistander on May 11, 2022, 12:50:20 PM
Hi Ufo,
Hi  Bi,
Nope, You are wrong, I  will not make your post disappear... ;D
but  notice the similarities...
bi
Nope, you are wrong again...I just made a short video to demonstrate how it is shown that center line by viewing film...exactly at the center of the coil
Actually, Viewing Film works on Three Dimensional Magnetic Fields, no matter if Field is Permanent or Momentary...like a coil...it will always, very precisely, detect the center division line.
COILS CENTER LINE REVEALED BY MAGNETIC VIEWING FILM (https://www.youtube.com/shorts/Z1baQ1UyoxM)
I mean, and I know you could say whatever you want...but a simple demo will show it is not on the "end turns" of the coil.
Magnets do not have "end turns" however, the film also shows the same , exact, center line, on a Permanent Magnet.
And what that line is showing, is not "flux" either.
You could make this simple test as well, and see it for yourself.
Take care
Ufopolitics
Post by: bistander on May 11, 2022, 03:19:40 PM
Quote from: Ufopolitics on May 11, 2022, 02:24:15 PM
Hi  Bi,
Take care
Ufopolitics
Thanks Ufo for not deleting me.
You have said it is the "main field", and I can't see how that is different than, magnetic field, resultant field, flux field, air gap field, or whatever term you call it, that is the issue, or object of this exercise. And that is referred to as the B vector field. As such, North and South poles, and some imaginary demarcation between the two, are irrelevant, in fact non-existent. Would you agree that a "main field", magnetic flux field, exists in the core shown below? Where is this "Bloch" wall?
edit. Image from: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/toroid.html
bi
Post by: Ufopolitics on May 11, 2022, 03:55:05 PM
Quote from: bistander on May 11, 2022, 03:19:40 PM
You have said it is the "main field", and I can't see how's that is different than, magnetic field, resultant field, flux field, air gap field, or whatever term you call it, that is the issue, or object of this exercise. And that is referred to as the B vector field. As such, North and South poles, and some imaginary demarcation between the two, are irrelevant, in fact non-existent. Would you agree that a "main field", magnetic flux field, exists in the core shown below? Where is this "Bloch" wall?
edit. Image from: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/toroid.html (http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/toroid.html)
bi
Bistander,
No matter how much you twist or bend a coil...in any given shape, where you start winding to where you finish, in simple winding (no layers, no back and forth) like your image of the toroid shows, where current enters and where it leaves, right at the center from those two points (using the circumference-arc formula, since it is a circular geo) is where the center line would be...
Edit: Oh! and actually it  is not just a line, but a plane that goes across like a section of the given geometry...
Whenever I finish the winding of my Toroid, You and everyone would be able to see it...
It is irrelevant to start arguing about what or who this center line is...point is that it always exists in any given magnetic field, and the importance is that I will be using it as a reference to show rotation or displacement of the Field.
Therefore, I do not want to expand this debate at this point in time...so, please, let's leave it here.
Thanks for understanding
Ufopolitics
Post by: Ufopolitics on May 13, 2022, 12:43:11 PM
Hello to All,
I am in the process to wind a Toroid with 16 coils in series, 22.5º apart, to be driven by the same Rotary Switch...is a long process...
The Magnetic Field(s) would be rotating inside the Toroidal Steel Geometry...However, this particular setup will have Four Poles, or Two Magnetic Fields.
See image attached.
It is a simple way to wind it, one coil after the other one, all in series...but driven by each split joint to the switch.
Why did I changed -all the sudden- from one structure of a ¨Two Part¨ Generator with a "Stationary Rotor" to this type?
Because I want to be able to see the WHOLE Magnetic Field actually displacing...and I was not observing that...but the coils just "flashing" a rotation, while the Center line was "in situs"...Not good!!
And, so, I believe this fact, would not allow me to drive Field at higher speeds, without loosing it...loosing Inductance gain...
So...here I go...maybe a future TPU?...I don't know...tests will tell.
Here is a Short Video...showing Coil#1 and demonstrating where poles are, as well as the Center Line...
TOROID WINDING COIL#1 (https://www.youtube.com/shorts/RP8DbJJAIqI)
Cheers
Ufopolitics
Post by: Ufopolitics on May 13, 2022, 12:55:19 PM
Hello again...
I want to clarify that this "idea" to wind a Toroid did not just come "from thin air"...or as a guess...to shoot at different options, randomly...
There is a pretty large history about this idea, behind scenes...and now, since I already know how to do it right...(at least, I hope so) then I am going to make it happen!!
A Toroid is a very clever Geometry (related to Magnetic Fields), as this one I am working on is made of laminated steel...as any other Toroid Transformer is...
I actually have Three of these that I had ordered them a long while back...two smaller like the one shown on Video...plus another one much bigger.
Here is a Post that I wrote on another Thread, answering to a statement that Member Onepower made...but I want it here, to show all, where I am coming from...:
Quote from: onepower on May 08, 2022, 07:41:25 PM
It's also important to note that to my knowledge no credible FE device ever used lap windings as is found in almost all motor/generators today.
Quote from: Ufopolitics on May 09, 2022, 08:43:42 AM
Yes, you are very right AC...
The overlapping or lap winding is used to "save room", or to fit more wires per square area (referring to motors) and for generator coils it is overlapped to reach a higher number of conductors to be induced by the rotary sweeping inductor area.
Actually, did you ALL know that the only wires that are Induced on any Two Part Rotary Generator, even the stationary rotor type, we are working on...
that only the Vertical wires are Induced?!
Yes, and I am referring to the Vertical wires in ALL Coils on the Stator, the ones parallel to the shaft, whether a real shaft or an imaginary one?
All the Horizontal, or diametrical wires in the coils are just there serving as "connectors"...but no induction is generated?
This fact sets all these machines, automatically, at 50% Induction Efficiency!!
Now, it is impossible to build a machine (from the mechanical Engineering point) where the Induction coils or Exciter circuit, travels within a "fully closed tunnel" where all the Induced coils are wound...a completely closed tunnel...where the Stator Output Coils would be on the outside...
How can you rotate "physically" an inner set of coils and their steel cores, that could travel within another hollow, but fully closed structure?
However, that would be the "perfect generator", a 100% efficient from the Induction percentage area calculation point of view...
The only way that this type of generator could be conceived, is by rotating a Virtual Magnetic Field, not physically, not including its coils and cores...
And the only "Geometry" which can give Us such characteristics is a Toroid...
And then, we would not need to do "lap windings", or overlap the coils, none of them...just to be continuously set, one after the other...in a full closed circular arrangement...
Can You guys "imagine" that?
And then, set it to work in your minds?
Ufopolitics
Post by: Ufopolitics on May 22, 2022, 04:03:10 PM
Quote from: Ufopolitics on May 11, 2022, 10:49:06 AM
Ufopolitics
Hello,
I have just quoted myself on that post where I was not "happy" because not seen the center line displacement...
I WAS COMPLETELY WRONG!!
I did not realize that Magnetic Viewing Film is just like a Polaroid Film, which captures an image and it stays there, even if image stops showing...
The only way to clear, reset magnetic viewing film imaging, is by running a small magnet around it in a circular motion, and fairly some distance away from film.
And so, if we do not clear film it will remain showing whatever it captures...
Maybe in a future, they will make such "reactive film" to capture a dynamic field movement...
So, yes, I was wrong, and the Field does move, as its brighter center line as well...
If we have that :wall: code for the emoticon hitting a brick wall...I will load it here many times... ;D
Stay tuned, I just finished making a video...
Cheers
Ufopolitics
Post by: Ufopolitics on May 22, 2022, 04:23:16 PM
Hello,
I am very  pleased to show this successful video about testing my future exciting field stator coils... ;D
EXCITING STATOR FIELDS TEST 1 (https://www.youtube.com/watch?v=J8img2TRbCU)
Again this video is "Unlisted" not to show on my Channel, but only to those who have link...
I will comment on its results later on tomorrow...but I may be adding some more text here later, basically about things, details I did not shared at video...
Thanks for watching it,
Cheers
Post by: Ufopolitics on May 22, 2022, 06:34:51 PM
Hello,
A 60 second short video, shows that when I load a 90 Watts Incandescent bulb, Input Amps drops down...from 1.88 Amp to 1.56 Amps.
Video: Input Amps drop when loaded (https://youtube.com/shorts/Pv4shFweF94?feature=share)
Cheers
Ufopolitics
Post by: Ufopolitics on May 23, 2022, 10:51:59 AM
Hello to All,
Here I will share the Spec's of my Exciter Coils.
They are wound with 23 Gauge wire and the winding sequence is shown on Graphic.
This Stator came off an AC Blower Induction Motor, which I previously tested with same armature, and the results were awful, very low output...so I stripped it.
And took it off its outer Housing...
This Stator have a total of 36 Tooth, so I used groups of nine (9) slots/tooth for each coil, and two would be dedicated to Exciiter and other two to the Main Output Coils.
There is a big difference on the Stator windings of Universal Motor Stators and Generator Stators, and I am not referring to the wider (spread over time) way to  wind them, but to the direction of windings...
In a Universal Motor, windings are Both following the same direction to wind, either CW or CCW, in order to generate a North and a South facing the Rotor/Armature...
In the case of a Generator, it is the Opposite, meaning Stator1 is wound CW and S2 is CCW, facing Armature...so, if we will energize them, they will both generate same polarity facing rotor.
This fact has to do with the way a Magnetic Fields vortex into Space...which eventually ends up by both Poles turning the same exact way...so both opposite coils will add up when connected in series, but, Hey, that is from "another chapter"... ;D
I start by Center Coil and winding outwards to next adjacent sub-coil, so, center would be Sub Coil 1, then SC2, SC3 and finally SC4...
Each Sub Coil have approx. 125-130 Turns, generating a Total Resistance whole Coil of 7.5-8.0 Ohms.
Some hints about winding these type of stator coils :
I built some copper wire Guides which will serve to keep wires all the way to the back of Stator Slot (very important), otherwise wires will start blocking the entrance for further winding (see Image Attached)
I may keep adding to this post later on "EDITS" at the bottom of this Post...as I have to move into the Brushes new arrangement following up...which was even more successful.
Cheers
Ufopolitics
EDIT 1: On the first image when I was ready to start winding sub coil#1...look at the copper guide front bent angle, and where it sets related to stator slot.
This guide settings will force wound wires to go all the way back on slot, as it gains height...and this will be very useful for further coils, to hold wire at the back of this sub coil#1...
Title: Re: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
Post by: Ufopolitics on May 23, 2022, 11:34:59 AM
...And so, after done with a Sub Coil...
You bend straight the front part of the copper guide angle...and pull them out (see image)
It should slide under the insulation paper...so, not scratching the enameled wires... ;)
Cheers
Ufopolitics
Post by: Ufopolitics on May 28, 2022, 02:04:39 PM
I have decided to migrate my Post from Holcomb Thread here...as I will show further developments in a near future:
A Brief summary...
We need to work more on our Developing and Research "Techniques"...As "enhancing" our "Powers of Deeper Analysis"...please, let me explain...
Yes, over the years we have being observing, reading, finding certain "anomalies" related to FE, and we have ignore them...or simply say "it was faked"..."a hoax"...
A very simple way to keep with the same B.S of Classic Sciences which have NOT delivered FE...and never will, unless We, as researchers, developers in the Private Sector...do it ourselves...
First thing that Clemente Figuera wrote, after succeding with his Patents back in 1908 was..."I never could have imagined it was so simple!!..."
Then Buforn tried to add "improvements" to Figuera Patent which was already working...and He screwed it off...
And yes, there has been "something" we all have been missing...to go deeper into it, to  study more and more..Magnetism, period!!
I mean, up to now, Science still have the ridiculous and rough,  "Iron shavings" as the only way to "visualize" a magnetic field...come on, please!!
After we all have Ferrofluids developed way back in time...after we all have Magnetic Viewing Film, after we have the Ferrocell  developed and patented by Tim Vanderelli, Books like Ken Wheeler "Uncovering the mysteries of Magnetism", awakening our ways to comprehend further on that beautiful Spectrum...
But we still invoke a few iron particles freely loose to "officially" understand how Magnetic Fields look like...Pathetic!!
Quote from: Feb2006 on May 27, 2022, 06:13:19 PM
What ufopoitics describing is new and game changing.
Thanks, Yes, this would be "game changing",definitively...beyond what ALL of You could ever imagine...beyond your wildest dreams...
I started playing with this tech a very long time ago...but, at that time, I was constrained (and may confess, also very stubborn) by the use of "Asymmetric Fields", and kept working for thousands of hours on the same, and only observing just a few "anomalies"...but nothing "galore"...so, I end up abandoning it...
Until I saw Pierre Cotnoir development, read all his posts here* (https://overunity.com/profile/pedro1.106067/area/showposts/start/0/)...and finally realized where my MAIN ERROR WAS...The "Secret"...which is already out  and spreading...
Then I finally understood almost everything, not only what I was doing wrong...but also allow me to understand all previous FE Technologies shown before...like Steven Marks TPU...like Don Smith's developments...like Kapanadze...etc,etc
Not collapsing the Main Field...but harvesting it, feeding it, while mutating only minimal small chunks to stimulate a movement...a Rotation.
Now, How successful and How far could you get??...equals how good You put it together...depends entirely on your building skills, the tools you own...and the effort you decide to waste on it...
However, I disagree that this Technology is...New?...sorry, but I do not think so:
That many "knew" way back about this tech but hid it, seize it?...Yes, definitively!!
Why?...
First, because it will reveal how wrong our Science have been for hundreds of years...when it could have been built such easily...effortlessly...and demonstrating that it could be done very long ago...The COP>1, Overunity, Motion Perpetual, etc,etc...
Second, and that I consider even more powerful...is that this technologies will also bring Us Antigravity...and time will tell...by simply altering in a certain way the molecules of steel and other alloys in a way never done before, counterways alignments of high speed traveling magnetic fields rotations...will eventually render a very light material, which will levitate...defying our "Gravitational Laws" plus breaking all the "specific weights tables for each material"...
Third and final (main reason for banning it)...By learning to "manipulate" the Magnetic Fields this way...we could eventually build very powerful EMP's (Electro-Magnetic Pulses) "Tools"...which could also end up in the making of powerful weapons...like the "Death Ray", developed and Patented by Tesla...way back, or as putting together a small and compact "Portable Venus Shooter"...All these "things" could be very dangerous...in the wrong hands...
However, going back to our Analisys Powers...we are still "constrained"...in our way of thinking...a vivid example:
WHY in this World DO WE STILL NEED A "STATOR-ROTOR-STRUCTURE" (or simply put: a Two Part Generator) where the so called "Rotor" does NOT Rotate??!!...
I mean, this is really laughable at...¿¿ A "Stationary Rotor"...??...really?
I mean, seriously...Why do we still need a "Rotor" whole structure and configuration, surrounded by a "Stator" which does not rotate?...(thinking)... ;D
And so...why do we need a "Shaft" for a  "Rotor" that does not rotate...lol??!!
Bad concepts of "definition" applied above...which keep Us within the same loop, circling over and over...and part of that loop eventually keeps Us going back to the "successful apparatuses" which generates electricity by physically rotating a rotor (doh!!)...when ACTUALLY, there is absolutely no relation between the two systems whatsoever...
Why keep constraining to a completely useless "Rotor with Shaft" within a "Stator" structure?...when we all could move to a Full Static All New Configuration, which grants way more room and "comfort" to all windings and cores we will build in a near future?
I mean, do not take me wrong, I see it as a way to "start" a development with "things" that we all have "on hand"...however, start thinking about getting rid of all these no longer required structures, in order to give more room to more efficient and better engineered developments  ...for God's sake!!
All above sounds a bit too crazy, right?...
Or maybe "too ahead of these times"...
Ufopolitics
Post by: Ufopolitics on May 29, 2022, 12:28:03 PM
Quote from: Lunkster on May 28, 2022, 03:22:07 PM
Hi
I like what you just said about what things could look like in the future with free energy!
They are similar to what most FE researchers are striving for.
After you get the full operating FE systems running we
will all be excited to see it in operation.
So thank you again for all the hours that is being worked on it to
bring this technology to the world!
Lunkster
Hello Lunkster,
Yes, thank you, I  have duplicated my post here (for my own recall later on), which was originally posted by me on Holcomb/News/Thread (https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/540/post/quote/567492/)
However, this Thread is only for Builders, who are or would be, willing to start a build based on my Main Topic and Development(s)
Although, I will accept some opinions or questions related to the build only.
All other posts related to general opinions, or just general comments would be removed.
It is ALL written at the beginning of this Thread
As I really appreciate your interest, I will please ask you to transfer your post as a quote to my last one (or as you like, without "quotes") on the Holcomb Thread (link above in blue) where I will respond about your opinions.
I will give you enough time, then I will delete your post here, plus my response.
I want to keep this Thread clean, so access to important data (for future builders) is available without having non related to build posts crowding it.
Thanks again for understanding and so I appreciate it.
Ufopolitics
Post by: Ufopolitics on May 31, 2022, 01:11:30 PM
Hello to All,
Here is a short video about testing two different Stators configurations...first was the previous one I have shown here, versus an overlapped one, using same amount of wire lenght...lesser turns, as each coilis same size...
VIDEO: TESTING TWO DIFFERENT STATORS CONFIGURATIONS (https://www.youtube.com/watch?v=DD75qPTkf_w)
Ufopolitics
Post by: Ufopolitics on June 02, 2022, 11:03:37 AM
Hello,
Some images while I was winding the new tested stator, on previous video...
Ufopolitics
Post by: Ufopolitics on June 04, 2022, 09:21:17 AM
Hello to All,
I will be winding the whole 36 slots Stator next week, it will be on a brand new 20 gauge wire spool that I just bought...
And so, this is the best configuration I could design, conceive, using 100% of all slots, for a total of 18 coils, overlapped.
Each Coil embraces 8 slots, 9 tooth.
The coils windings are separated by the red equator line shown on graphic.
So, All North Coils will be wound CW, and Southern Hemisphere Coils would be wound CCW.
North Hemisphere have Nine (9) Coils
South Hemisphere have Nine (9) Coils
I will be leaving wires out (Termination/End and Start) between coils, in order to be able to measure independently each coil and the best pairing match...it should be at 180º...but we never know.
As depending on each output, I could separate by groups or combinations thereof, like (12/6)- (6/6/6)- (14/4) etc,etc)...in order to search for correct output for the section of Exciter Coils supply (Input)
As also in order to separate output groups for different tests and applications.
I know it will work, because I have already tested four coils in the same config on my previous video...this is just a matter of building more coils...using the whole 360º magnetic field rotating sweep.
Again, I will test and upload a video as soon as done winding, and setting everything, no matter if results are positive or negative.
I am still working on the Toroid Structure...as well.
Ufopolitics
Post by: Ufopolitics on June 05, 2022, 03:20:42 PM
GENERATOR STATOR FULL WINDING STARTED...
I already started winding Stator with 20 gauge wire, according to previous shown diagram...slots only allow me 70-75 turns.
I already test Coil 1 yesterday, very successful test!!
Doing Coil#4...14 more to go...
Cheers
Ufopolitics
Post by: Ufopolitics on July 04, 2022, 02:07:18 PM
Hello to All,
Here I will be uploading three short recent videos, where I will show the point where I am in the testing of the Virtual Field Rotation plus Generation of Energy as a result.
I have finished the full winding of 18 Coils on the previous Stator Core I have shown...however, I have tried already many different configurations as related to the way I connect Coils in between...and observing results.
On these three videos I have the configuration shown on Diagram, about the way I have interconnected all 18 coils...which is different from the way a typical generator have their Stator Coils connected between them.
On this case I have connected alternatively the coils from North Hemisphere to the coils from the South Hemisphere...
Meaning, C1 End is connected to C10 Start, C10 End is connected to C2 Start, C2 End to C11 Start and so on...
This way have given me a better result in acceleration gain of the rotation of the Magnetic Field.
However, the failed part is that it adds more resistance, hence less output amperage...but still, you will see on the videos I have pretty good amperage output...
Stay tuned to watch the videos in the coming posts.
Ufopolitics
Post by: Ufopolitics on July 04, 2022, 02:30:24 PM
VIDEO DEMONSTRATING VOLTAGE 2X OVERUNITY
Ok, so on this video I show how the Generator Stators Coils are connected, plus a simple test run showing Output Voltage above Input by Two times or 2X...
SIMPLE VOLTAGE OVERUNITY DEMONSTRATION VIDEO (https://youtu.be/UrCfcG6me7s)
So, I am feeding Field with 10V as I get Output of 20+ Volts in AC, and around 18.5 in DC...No Electrolytic Caps added on this test, which -of course- will increase Output DC Voltage above shown figures.
No load on this video...just checking V In versus V Out
Stay tuned for next video...
Thks
Ufopolitics
Post by: Ufopolitics on July 04, 2022, 02:55:10 PM
On this video I clearly demonstrate that it is the Field Rotation what keeps the Generation of Power that comes at Output...By simply reducing the speed of rotation on the Rotary Switch to almost zero.
We can clearly see how the Lamp dims out, as Scope signals decrease (flatten out) to zero.
DEMONSTRATION OF FIELD ROTATION IS WHAT KEEPS ENERGY OUTPUT (https://www.youtube.com/watch?v=7ZgO9ScLczw)
Thanks for watching
Ufopolitics
Post by: Ufopolitics on July 04, 2022, 03:58:53 PM
Sorry guys, I missed the Video where I loaded Generator with a 90 Watts Halogen Lamp...here it is:
LOADING GENERATOR WITH A 90 WATTS HALOGEN LAMP (https://www.youtube.com/watch?v=niEWTHuIImQ)
Edit: I want to rectify that Current Probe Clamp blue sine wave, which is amperage, is showing (at all time) a Full amplitude (Plus and Minus currents) of close to two amps, or 20 mV which are two divisions on scope screen grid.
Not like I say on video, that is 1 amp total amplitude...but 1 amp from positive side plus 1 amp on negative side.
Thanks again
Ufopolitics
Post by: Ufopolitics on July 05, 2022, 12:55:39 PM
Hello to all
Well, last night I conducted some tests after rewiring (not rewinding) the stator coils...I used the original config as itis used on generators...
which is all CW Coils in upper Hemisphere in series attached to lowerHemispheregroup also in series...
This is a simple way to connect coils, typically, but in my case it does gives me a very high resistance (20 Ohms) for this kind of coils use normally is around 4 to 5 Ohms.
Here is the CAD Diagram
Stay tuned for coming videos...
Ufopolitics
Post by: Ufopolitics on July 05, 2022, 01:15:57 PM
Hello,
So, last night I did some tests with new wiring...lighting up a 120V/ 60 Watts Incandescent Bulb...
On these tests I was basically more focused on Amperage...Input versus Output
But I ran into some Amperage "anomaly" when adjusting the proper speed of the Rotary Switch...
And the thing is that I have been trying -for a while- to get Rotary Switch to reach a steady operational speed anywhere the 3000 to the 3600 RPM's...without the brushes to loose pressure, just a bit, but by loosing pressure there was some arcing and sparks whenever loading generator and lost contact and power went off...So, I am now running it at around 2000-1900 RPM's...
Anyways, here is the video after I adjusted brushes, by pressing them more against commutator.
REDO TEST VIDEO AFTER BRUSH ADJUSTMENT (https://www.youtube.com/watch?v=4eR65D8e74o)
The interesting part takes place after minute 5:21 (https://youtu.be/4eR65D8e74o?t=321) on...and I uploaded some frames from this sequence...
However the amperage "anomaly" I  mentioned before, did not show up again after I did the brush adjustment on this video... :(
Ufopolitics
Post by: Ufopolitics on August 06, 2022, 10:55:24 AM
Hello to All,
HOLLOW ARMATURE STATIC ROTOR
Sorry that I have been away for a while...I have ordered a few tools and equipment as some components I needed to keep making my Lab Testing.
While I have been working on all my CAD's, relating to better designs on ALL my projects...not just this one here.
But, I needed to rise some funds, some earnings, so I decided to take a course on dealing with a way to make money fast and in nice amounts...while it is very risky...Nope, do not get scared, nothing "illegal" about it...The "risk" relates that you could loose it all if you do not play responsibly, and organized, but primarily, very well trained....So, I am doing just that...getting trained to Invest on  the NYSE, basically buying and selling Stock Options...for myself only.
Now, getting back to this  project...I am working on a New Design Static Rotor, without taking apart the existing one I have...it is NOT good  to take apart "something" that is giving promising results...to go on a new "adventure"...which, could or could not work.
So, it would be just a matter of disconnect and reconnect the new one.
And so, here is a CAD, defining the basic structure of this new concept...
It has a lot of work to build it, but I am pretty sure it will work MUCH better than previous one.
Consists of 16 steel elements which I have cut from 3 old identical armatures...but before, I have drilled holes on each element, in order to run bolts-nuts, so after cutting them, they will not come apart...
The point here is to have all these 16 steel bars isolated between each others by a small gap...and using an Aluminum ring, top and bottom, to close them together,  according to my desired Diameter...so, it fits inside the Stator Core.
It would be a HOLLOW WOUND ARMATURE...where I will set inside a steel rotor, mounted on a  shaft and bearings...
The Inner Steel Rotor would be in charge to close the Magnetic Circuit, between Energized Coils across at 180º...As also to increase the strength of the Magnetic Field.
So, once I start spinning the Magnetic Field on the Static Coils and hollow Armature, this rotor will also spin, at the same ratio as the Field is rotating.
Rotor would be following the Rotating Field, attracted by the moving North-South Polarizations across at 180º.
This Rotor could serve as a Dual cooling fan, later on, to keep temp low on both, Static Rotor and Stator assemblies.
I will be making around three different Steel Rotor configurations, A, B and C.
A- Would be the heavier one, almost a full cylinder of steel, except for cutting off some metal off on both sides, as Lines A shows in a shaded area, in order to comprehend only Four Elements on each side, at 180º.
B- Is a lighter type, where I will cut off more metal out of it,  in order to compare output results, versus the A Type.
C- If, there is no substantial Output difference between A & B, then I will make the C Type Rotor, in order to be wound with a single coil...which I may just close it by a Diode (just as we see on a Brushless type Rotary Generator Rotor)...in order to increase the Field strength even more.
But, those (B & C Type) would be after I wind the 16 Coils, make the A Type Rotor and run several tests.
So, the Virtual Rotating Magnetic Field would be literally "jumping" every one steel element as the Rotary switch spins.
I believe this design will generate a much stronger Field than previous one I have...and much better defined movement on its traveling through Space/Time, as a better Resolution, since each coil would be spaced apart, overlapped, and not like before, where I literally have "8 Pairs of Coils", restricting a LOT the traveling distances of a  "Lower Resolution" Magnetic Field.
Please, if you are just commenting about my post, or whole Thread, do it on the Holcomb Thread (https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg569689/#new).
I want to keep this Thread clean, for future interested serious builders only.
I highly appreciate it, Thanks!!
Ufopolitics
Post by: Ufopolitics on August 06, 2022, 11:07:10 AM
An addition to my previous post...
I will also consider to add two small Neo rectangular magnets on each side of the Inner steel moving Rotor Center Angle of Interaction (of each N/S Poles)...to help the magnetic alignment more precisely, more robust, as also for start up from zero, with some magnetic reminiscence to induce exciter coils...
Ufopolitics
Post by: Ufopolitics on August 06, 2022, 12:04:50 PM
Hello again,
Just wanted to add some material not disclosed on previous post on Hollow Static Armature...
Here is another CAD, where I basically show all 16 Coils, spreaded over time, like is supposed to be done in any 16 tooth plain, Simplex Lap Winding Symmetrical Motor.
Now, the Magnetic Angle at which these coils would be energizing, forming their N/S Polarities, is not to be based on just one coil at each side, but -as an example on this diagram- the Magnetic Angle would be comprehending 3 Coils per Pole, as 6 Isolated Steel Elements, apart by 180º from each Magtnetic Pole.
So, whenever rotation starts, there would ALWAYS be at least ONE CENTER Coil (out of the 3) not being switched/reversed, during stepping of Angles displacement per each commutation. This will completely avoid Main Field Collapsing during Switching Rotation.
This Angle opening is defined by the 4 Brushes separation angle between -/+ on each side at the Rotary Switch brush plate...and is shown on previous posts, where I show brushes configuration and electrical distribution of -/+ poles on the Rotary Commutator Switch.
So, depending on the Coils Magnetic Angle set, the Inner Rotating Steel Rotor (previously disclosed) would be designed following that Angle spread, in order to fully close-connect plus enhance the Magnetic Field circuit.
Ufopolitics
Post by: Ufopolitics on August 08, 2022, 03:37:12 PM
Hello,
Here is a better view of Inner Rotor design.
This is the Narrower Angle Field based on brushes adjustment (position 1), which comprehends around 3 commutator elements, or 3 coils on each side (pole).
In the next (position 2) it will widen the Field to about 6 elements per pole or 6 coils.
Position number 1 will be lesser coils (total of 6), so it will be a higher amp rate (less resistance)...when Position 2 (12 coils) will have lesser amperage, more resistance.
However, this settings depends on my stator coils width, and how I am wiring them...
Ufopolitics
Post by: Ufopolitics on August 08, 2022, 03:39:26 PM
On a typical motor we have alternated -/+ or (-/+/-/+), which does cut the field in 4 poles or N/S/N/S.
So, according to this way to wire brushes, there are some coils not being energized during rotation [Idling] (the ones within the electric poles of same polarity)...and so, I get a much better sinewave than if I use just two brushes -/+ which divides the field in two poles...and scrambles the whole thing and output drops down.
And...In order to achieve this Narrow Angle of the Field (3 Coils per Pole) I use the brush connections according to image shown below:
Post by: Ufopolitics on August 08, 2022, 03:45:46 PM
Related to the Lap Winding I use on Static Rotor...
There are many ways to do a Lap Winding...
I am doing it like shown on the image below
https://www.electrical4u.com/lap-winding-simplex-and-duplex-lap-winding/ (https://www.electrical4u.com/lap-winding-simplex-and-duplex-lap-winding/)
Again, I am only using 6 out of 16 coils where the center (alternating) coil always stays on, during rotation, that is the "Narrow Field Angle".
I can have 12 coils in the wide settings...where the closer brushes, now -/+ would be -/- and +/+...
For these systems, it is better NOT to use ALL Coils on the armature, it will scramble your sinewave, as your output will not be as desired.
The scrambling I believe is due to the energized coils that are on the magnetic field limits, between N-S, or near the Dielectric Field or Bloch Wall...So, it does not project a clear Polarization of the Field, hence Induction Output is considerably reduced.
Ufopolitics
Post by: citfta on August 20, 2022, 06:40:39 AM
Hi Ufo,
I hope you don't mind if I post a link here to a thread I started.  I don't want to pollute your thread.
For those of you who don't have the expertise or equipment to build the excellent project that Ufo is building I have started a thread for an easier way to maybe possibly work with a virtual moving magnetic field.  I have not built it yet but intend to soon.  So there are no guarantees that any of this will work but I wanted to share my idea.
Here's the link:
https://overunityarchives.com/19222/maybe-possible-idea-for-duplicating-effect-of-holcomb-and-others/
Ufo, feel free to delete this if you don't want it in your thread.
Carroll
Post by: SolarLab on December 29, 2022, 01:12:24 PM
 Happy New Year Ufopolitics
CONGRATULATIONS - Your thread has been cited as "The Best Thread of the Year for 2022" by the little known
adhoc bunch - the "Society for Advanced Energy Concepts (SAEC)."
Excellent Work all around including your Builds and some Great Insight!
Thanks from everyone involved for sharing your exciting projects!
Ufopolitics ---    Topic: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg565511/#msg565511
Notables:
Ufopolitics:  (Re: Energy Generation by moving Mag Field through Static Steel Core & Copper Coils)
« Reply #47 on: May 28, 2022, 08:04:39 PM »
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg567495/#msg567495
"I have decided to migrate my Post from Holcomb Thread here...as I will show further developments in a near future:
A Brief summary...
We need to work more on our Developing and Research "Techniques"...As "enhancing" our "Powers of Deeper Analysis"...please, let me explain..."
The "Secret" - "Not collapsing the Main Field...but harvesting it, feeding it, while mutating only minimal small chunks to stimulate a movement...a Rotation."
"WHY in this World DO WE STILL NEED A "STATOR-ROTOR-STRUCTURE" (or simply put: a Two Part Generator) where the so called "Rotor" does NOT Rotate??!!... "
https://overunity.com/19085/energy-generation-by-moving-mag-field-through-static-steel-core-copper-coils/msg568549/#msg568549
All the Best to You and Your Family in the comming Year!
SL, SAEC, et.al
