(The following text taken from 'The Free Energy Secrets of Cold Electricity' by Peter A Lindemann and looks likely to be the basis of the SM TPU)
Tesla accidentally discovered an electrostatic "super-charging" effect while trying to verify Hertz' discovery of electro-magnetic waves. After hundreds of experiments, he learned how to control and maximize this phenomenon. This led him to the discovery that electricity is made up of different components, that can be separated from each other, and that a pure, gaseous etheric energy can be fractionated away from
the flow of electrons in a circuit designed to produce short duration, unidirectional impulses. When all the conditions were right, this gaseous, etheric energy would manifest itself as a spatially distributed voltage that would radiate away from the electrical circuit as a "light-like ray" that could charge other surfaces within the field.
From now on, I would like to refer to this phenomenon as "The Electro-Radiant Event" and summarize its characteristics as follows:
1. The Electro-Radiant Event is produced when a high-voltage, direct
current is discharged across a spark gap and interrupted abruptly
before any reversals of current can occur.
2. This effect is greatly increased when the source of direct current is
a charged capacitor.
3. The Electro-Radiant Event leaves wires and other circuit
components perpendicular to the flow of current.
4. The Electro-Radiant Event produces a spatially distributed voltage
that can be thousands of times higher than the initial spark
discharge voltage.
5. It propagates instantaneously as a longitudinal, electrostatic "light-
like ray" that behaves similarly to an incompressible gas under
pressure.
6. Electro-Radiant effects are solely characterized by impulse duration
and voltage drop in the spark gap.
7. Electro-Radiant effects penetrate all materials and create
?electronic responses? in metals like copper and silver. In this case,
?electronic responses? means that an electrical charge will build up
on copper surfaces exposed to Electro-Radiant emissions.
8. Electro-Radiant impulses shorter than 100 microseconds are
completely safe to handle and will not cause shock or harm.
9. Electro-Radiant impulses shorter than 100 nanoseconds are cold
and easily cause lighting effects in vacuum globes.
The "Electro-Radiant Event" is essentially the "gain mechanism" that Tesla discovered that is the basis of his Magnifying Transmitter. It is the foundation of his claim that he was able to create more energy in his output than it took to initiate it in his input.
http://satanicsingles.com/library/The_Free_Energy_Secrets_of_Cold_Electricity.pdf (http://satanicsingles.com/library/The_Free_Energy_Secrets_of_Cold_Electricity.pdf)
(The following is a message from Steve Mark to Mannix, showing that TAO was on the right track about the TPU, and also confirming the above post)
I want to mention about something I read on the site. A person named TAO wrote this to you a while back:
>As a gesture of good faith towards you and the rest I'll throw out some insights...
Lets talk about the 'kick.' When the old Edison DC generators were turned on, back in the day, they released this 'kick' and killed many workers in the process. A man by the name of Tesla had seen this. He wondered how and why this 'kick' would occur. So he experimented with wire and disruptive discharges from capacitors. It was found by him that this kick could be made so powerful that it could explode wires instantly. This kick came out of the wires perpendicularly. He discharged capacitors into stout wire and through a spark gap. The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap. Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines. His goals were to get the time in which the discharge is STOPPED to be much quicker. As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge. These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire.
So, based on those things, lets look at the Mark device. Lets say Steven put one big stout cable around or in the rings,and all around these he had many many windings. Now, if Steven put into that stout cable a current and before the current could get to the end of the wire, he stopped it's flow abruptly, then perpendicular radiations (the KICKS), the same Tesla observed, would appear and spread from this stout cable, this would cause Tesla'a copper charging effect, which would hit all the other wires in Steven's coils. Now, if Steven wired the coils right and stopped the discharge of the current through the coils he would be able to extract a lot of extra energy from the tap points on the coils. This is basically how Tesla's magnifying transmitter works.
Capacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY
before the current makes it to the end of the wire, and this KICK comes out of the wires
perpendicularly. This KICK would then charge copper with electrons(hot electricity) or their opposites(cold electricity). It just depends on how you setup the device.
So, I would say that Steven's KICKS have a direct relationship to Tesla's Magnifying Transmitter, its REAL operation.<
So Lindsay, this guy definitely has the secret. I do not know if he will be able to duplicate power generation, but he does have the secret.
Do you think he knows it?
The only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
Lindsay, it is so VERY hard to describe things with words!
Sincerely, SM
Attached to this post is the Magnetic Power patent for a solid state free energy torroid. It is very interesting but this point is made.
QuoteUse of a resonant circuit, particularly with inclusion of a capacitor as suggested, facilitates recirculation of energy within the input circuit, generally producing efficient excitation and a reduction of required input power as loads are applied.
And TAO mentions here..
QuoteCapacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY before the current makes it to the end of the wire, and this KICK comes out of the wires perpendicularly.
And Lindemann
Quote1. The Electro-Radiant Event is produced when a high-voltage, direct
Just bulding a coil and pulsing frequency through it and measuring output alone is not going to achieve anything. The discharging of a capacitor phenomenon seems to be very important to these devices.
It appears there may be two more ingredients needed to make MPI's patent work: Superconductivity and perhaps Plasma.
Read the last part of the following link:
http://www.zpenergy.com/modules.php?name=News&file=article&sid=1357
AM
The operation of the device would be a small battery to start a control circuit which creates the short pulse and radiant effect, and then an oscillation which creates usable electricity.
QuoteThe only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
Now the question really has to be asked, which approach did SM use to create the oscillation ?
Is the oscillation caused by combining frequencies and hitting some kind of harmonic? Or is it something to do with spinning/expanding/collapsing magnetic fields?
This evidence points to the later, but the main effort of this board has been the former.
I urge you to read the Magnetic Power patent. It really does have some great information on this very subject.
Hey! You forgot to include John Bedini - he uses capacitors to capture the radiant energy too.
Mark Goldes - CEO of MPI - stated on another site that an additional element was required for the Gunderson device to work and that this would be added in an ammendement to the patent at a later time - who knows what that could be?
This topic: http://www.overunity.com/index.php?topic=1827.0
illustrates a device that appears similar to Gunderson's. Probably have a better chance at duplicating that than the MPI patent application.
Rather than copying and duplicating - construct an idea of how and why these devices work and then do your own experiments and develop your own device - or develop one together - as a team.
TAO's description is a good place to start.
I have started to test this theory using my current TPU, I read the link that Grumpy posted in the other thread and it gave me a few ideas. My current testing is using a spark gap feeding a collector coil and using the associated control coils as the radiant energy collector/primary and the feedback coil as the secondary.
Detail....
My testing setup is using an ignition coil as the high voltage source (for now) which uses a GM control module as the coil control using a audio generator as the trigger source. This feeds the collector coil and so far has revealed that the control coils do infact pickup the electrostatic voltage.
I am using the control coils as the radiant energy collector and the primary of a step down transformer, the feedback is the secondary of the transformer. The results so far has shown that with 30kv in from the ignition coil, I get over 1200v out measured on the feedback coil (open circuit), with a 13k load resistor connected across the feedback coil I get approx 200vp-p. My scope reveals a ringing signal. I have not changed the control coil configuration from Ottos yet. I plan on changing this today to see what effect/changes I get.
My questions to be answered currently are;
By changing the control coils to a series configuration do they provide increased output?
If they do, If the feedback coil is wound in a reversed coil (transformer winding) improve output?
The most important question is, do these changes change the waveform to generate a more positive pulse output?
My Current TPU design used is;
Collector coils 15 turns 16 AWG stranded lamp cord wound clockwise for a 6" diameter coil
Control coils, 4 per layer each with 170 turns 30AWG magnet wire, spaced 1/2' apart.
Feedback coil, 17 turns of a single 16AWG wire over each control coil, series connected.
COnsiderations
Do I need to change the TPU design to a single control coil/radiant energy collector?
Is a second coil over the control coils needed to improve the coupling transformer?
Do I need to wrap the feedback or second coil opposing the other previous coils?
So far the tests I performed show more promise than the pulsed control coils. So I will continue to test variations of the TPU using this concept.
An observation, after reviewing the EV gray doco from the link Grump posted and reviewing the pix that were recently posted of closeups of the 18' TPU and its center coils, this now looks like a simple set of transformers (10:1 roughly). COuld these of been the signal sources conversion transformer which priovides the step up action to charge the Caps?
There was another pix that showed an open wire coming from the large TPU (stranded). could this of been a radiant energy collector wire? (I say this since the collector only requires a single connection which is fed to the primary of the step down/isolation transformer, which the other side is connected to ground.
The other item or interest is the item that looks like a fuse, could this be his spark gap? I think he may be using either a blown fuse or a xeon strobe bulb (I know this is far fetched but I am not sure about the characteristics of these).
In this EV gray doco Grumpy linked us to EV gray is using a Triode as a gate/diode to trigger the spark and prevent the oscillations from the spark gap and create a unidirectional flow. My thought is can we use a high voltage diode from a microwave oven to replace the Triode to create the unidirectional flow while still using a simple high voltage souce (Ignition coil)? Or do we need to look to use a 555 timer, a step up transformer (10:1 or 20:1), a diode bridge and another device to trigger the discharge of the cap and ensure the unidirectional flow?
I will continue on my current path with the TPU as it is and try a few wiring variations first, then consider changing (or making a new TPU) using the coil variations I mentioned above.
I will post more when I have anything to share. Hopefully this post makes sense and provides some usefull info.
Quote from: archon79 on January 21, 2007, 04:19:26 AM
discharge voltage.
pressure.
Like a match in gasoline, splitting atoms to a nucelar explosion, a little vibration to Nitro glycerine. And its labeled as cold because the 'fire', 'Explosion', the force propulsion happens at a higher frequency from us or the burning of oxygen.
--giantkiller. And that it why Tesla could sit in the field of blue sparks.
So here is the migratory path of the energy production,
1: Kicks? what are kicks and where do they come from? (Remember those days?)
2: Kicks are no problem to achieve or consistently produce for some of us .That is really easy to do once you realize the the potential in has to exceed the volume of copper. For instance, magwire compared to the higher gauge. But harvesting is a problem. Why? Enough production does not equal enough power. You touch the small radient energy with any metal and it doesn't show up. Alot of us have seen this.
3: Up the energy. It has been consistantly shown to use caps. I take it you use them on the input to the coil not the output like alot of previous attempts.
--giantkiller. This a great way to start off the week! Thanks guys. I thought I was going to get a rest but 11 days left. :o
Thanks for the post Arcon.
Carl,
I did the test you proposed: compare the Otto's collector coils connections vs simplr serial connections.
Result is that with serial connection you have spikes 5 -6 time bigger in amplitude...but not rot mag field.
In my case with Otto connection I've max 100V, with series connection about 650V.
Roberto
Roberto,
If we now add another frequency which is either higher or lower, we should get a rotating field again due to the hetrodyning effect.
I have not tried the TPU with 2 HV coils yet, only one, my next set of tests will use 2 HV coils.
The only issue I am facing with using these HV coils is that my scope cannot display the entire waveform! My scope can do (full deflection, highest setting) 200V/div 8 div, thus only 1600vp-p and my scope goes full screen when just measuring the feedback coil! under load I get it to drop to roughly 200vpp. I am still working on the spark gap design which will use a magnet to quench the spark. I also need to see if this will help with the unidirectional flow issue.
I have noticed though that if I place the spark gap after the collector coil the coil reduces the operating range (frequency) to the 3Khz area (this is based on a collector with 15 turns of 16AWG stranded wire). I had a wider range with the spark gap in the leadin to the coil. I am wondering how this will change with a single turn collector or just a change in the number of turns. humm....
What I like about this setup is the signal sources do not have to be sync'd since we want a difference in them. also the operating frequency so far is closer to SM's TPU.
More to test....
Carl,
I'm very interested about your spark-gap tests, please let me know further results. For my side I'm preparing to do some tests of the same kind but by using a less dangerous method perhaps not so efficent!
I'm starting to build an arrangement that does use a 'shuttling capacitor' a-la-T.Bearden to provide the voltage discharge into TPU. In this way I should easily reach the 6 - 12 KHz needed for my 6" TPU all copper (in my case the sweet freq are: 6, 8 and 12 KHz) with a much less current supply!.
With Otto arrangement but also with all-serial wiring I'm able to glow bright red a 60 W/220V light bulb with a 10V @ 2 A supply, so the goal is to see if with electrolitic cap discharge will be possible to obtain a better conversion.
After that I'm preparing to build a new 4" TPU with another philosopy...it will be lighter ...no more than 80gm.
So at work!
Roberto
Carl, here's how I intend to do
Roberto
Hi Ronotte,
A TL494 can achieve most of this circuit (Osc, flip-flop, duty) except for the indivdual pulse width timing.
You could perhaps connect to a 555 in monostable mode.
Using descretes, perhaps an oscillator with a saw tooth output, 3 comparators, a flip-flop and a mosfet driver.
If you follow the schematic for the TL494 you could create a device from descretes but with two different duty cycles by using the ramp of the oscillator and a comparator.
Is there an advantage to be gained by pulse charging the cap?
Rob
@Ronotte
Your design is basically a switchmode powersupply. - there's NO chance for overunity with the design you show.
One thing that seems a bit odd is that you're also pulse-charging the cap - there's no need to do that, besides from making the circuit more complex :o
I would suggest that you read a little about SMPS:
http://en.wikipedia.org/wiki/Switching-mode_power_supply
They're efficient, but ALWAYS under 100% (unfortunately)
Quote from: ronotte on January 22, 2007, 11:29:47 AM
... Result is that with serial connection you have spikes 5 -6 time bigger in amplitude...but not rot mag field.
Roberto
Hi ronotte,
Can you answer a question now or later in time about - my theoretic curiosity working - if you are pursuing the rotational field or not(?), or about your results comparing both (rotational/not rot.), when you get good results of course.
@MeggerMan
Yes Rob,TL494 is a fine complete device but it isn't good for my purpose as it handles only 42V @ 0,5A (out section) and is slow also, rise time= 100 nsec. - IRFP450 handles 500V @ 14A with rdsON=0,4ohm...risetime= 36 nsec, falltime=35 nsec and is internally protected!!.
Pulse charging the cap is an easy way to do the job - a better way would be to use 'ramp charge' but for my test only purpose I think that pulse charge is nice.
@Thedane
I'm not searching for overunit with this arrangement. It's just to test & evaluate the amount of RE generation in the case I do interrupt the voltage (very quick pulse) before it reaches the iron-wire end (this is the reason to use at least 100 mt. of garden-iron wire -slow relaxation time...6 times slower than the copper and pulses narrower than 100 nsec). In this way I should be able to generate some amount of RE (Tesla did use spark gap & HV) and collect it with a copper collector coil.
@Yamanashi
Of course the test is aiming to evalute & optimize RE creation and so augmenting my actual TPU efficency. I'm thinking to pulse in this way the existing inner collector rather than the Control-Coils as I already have a rot mag field.
Anyway all suggestios are wellcome, please discuss
Roberto
Hi Ronotte,
QuoteYes Rob,TL494 is a fine complete device but it isn't good for my purpose as it handles only 42V @ 0,5A (out section) and is slow also, rise time= 100 nsec. - IRFP450 handles 500V @ 14A with rdsON=0,4ohm...risetime= 36 nsec, falltime=35 nsec and is internally protected!!.
Well, of course you would seperate your pulse generator power supply off from your MOSFET power supply - this would seem obvious to me.
Its upper freqency is spec'ed as 300kHz but I found I could crank it up to 600kHz with no problems, is this still too slow?
Yes, I could quote MOSFET specs all day long, but at the end of the day, its mainly what the shape of the pulse looks like on a scope and what voltage will fry it.
QuotePulse charging the cap is an easy way to do the job - a better way would be to use 'ramp charge' but for my test only purpose I think that pulse charge is nice.
Are you saying that pulse or ramp charging is key to getting more energy out than in, or just a way to completely isolate the output mosfet from the power source directly?
This is a circuit I am working on at the moment:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm25%2Fkingrs%2FMEG1b.png&hash=4cb3b0f0557e0353137e04481727947277736a94)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm25%2Fkingrs%2FMEG1b_parts.png&hash=6bb5dd75cf836b69e7fd91d8903e4224c832fba2)
Rob
Hi MeggerMan,
and YES I'm trying to obtain both things togheter....I agree with you that MOSFET solution isn't the best but it's easy and cheap (I pajed the IRFP450 only ? 1,25/cad)...but there are driving problems as you have to charge the input capacitance also due to Miller effect...to do so there's need of much input current....if you want to have fast rise time.....so the use of a mosfet driver like IRF7307 or similar are mandatory....you can connect directly to the gate almost every thing but then what you get from the drain is not deterministic.... :D
Your project seems nice but I'm not following the MEG.
Roberto
@ rob
That is a very interesting PCB.I like it much!! Have you put a neo mag in to your rot field? if not, drop one in or use a cotton thread between two small neos suspended above your mag field and see what happens. MOAB
I'm sure you are all aware of this already, but Leon Dragone seems to have found the exact same thing with his spark-gap electroentropic device.
See: http://jnaudin.free.fr/dragone/dragone.htm
Also, the Newman spark-gap effect could have the same underlying cause!
