Hi All,
After years of experimenting on the building and test different version of the Clem engine I decided to explain how it worked.
https://www.youtube.com/watch?v=sc3NVCezxnw
Tom
Hi Tom,
I have been following your efforts to build a working Clem engine for several years now. First I must say your mechanical building skills are excellent. However you keep missing some fundamental laws of hydraulics. First you need to understand that any sudden change in direction or pressure results in added load on the driving force and added heat build up in the hydraulic fluid. In each of your designs I have seen you have fluid coming straight out from the axis and then into a 90 degree turn to give you the propulsion effect from the fluid being ejected. You also have a fairly large volume of relatively slow moving fluid which then suddenly is supposed to accelerate to high velocity to give the needed thrust to rotate your rotor.
I have a design for you to try if you are interested. It solves the problems I have pointed out. Whether it will self run or not I don't know. I don't have the mechanical skill or time to try it but would love to see what it would do.
First visualize a long cone shape with the large end attached to your center axis and supplied fluid by your pump. Now in your mind visualize gradually bending that cone shape so that the small end is eventually 90 degrees to the axis. The small end needs to be pretty small so as to give plenty of thrust. The cone should probably be long enough to go at least half way around the rotor or even farther. The more of the cone that is out near the edge of the rotor the more fluid there is to be accelerated by the centripetal force. With this design the fluid can now go from a high volume low velocity state to a high velocity low volume state and thus save a lot of energy and heat build up. For balance and efficiency you would probably need at least 4 of the cones mounted on your rotor. An idea I had to make the cones relatively easy at least to test the concept would be to use soft copper tubing and gradually reduce the size by soldering in the next smaller size as you get away from the center. Maybe start with 1/2 inch tubing and gradually work down to 1/8 inch for the nozzle.
Respectfully,
Carroll
Hello all,
I been working on the Clem Engine and could never find any paper article.
I was shocked when someone sent this to me today.
Tom
Tom
Any chance of getting some proof its an authentic newspaper article. I fear that when we say we have "evidence" we really must have it. We just need to know the paper and date published for confirmation.
Cheers
AB
Hello
Why the turbine is huge?
Let's say 1m in diameter in both Richard Clem and Victor Schauberger design?
Hi Vortex 22 (https://overunity.com/profile/vortex-22.108457/),
The problem with say the size of the rotor would be the rim jet thrust. Like gears, you have to either give up speed to increase torque or torque to increase speed.
Running at say 1800 rpm's with a 12 diameter rotor, the thrust velocity to move it at 1800 rpm's would (((d*pi)/12)*1800)/60 =94.25ft/sec.
To increase torque and to keep it the same speed say 24" diameter, you would have to increase thrust by a factor of 2.
Both of these calculation are correct, but the real world is when you put a load on these factors. Things start to slow down.
Tom
Quote from: TommeyLReed on January 22, 2023, 09:27:17 AM
Tom
Ok
I should try this configuration:
system consists of TWO closed circuits:
The first closed circuit vibrator (liquid rotating in a closed circuit)
A second closed-circuit oscillator
The second vibrator is inside the first vibrator!!
output on the second circuit
Input on the first circuit
Torus technology in mechanic version? Who knows... maybe
We are trying to create Votex in the turbine?
That's the magic!!
