Hi All,
I have to stop getting side track, I know how the Clem engine worked and doing different builds at this time is getting nothing done.
https://www.youtube.com/watch?v=vvkpkymDHHA
Tom
Hi All,
Update on this liquid power engine using water experiment.
https://www.youtube.com/watch?v=P4UA0RBa0wo
Tom
Hi All,
Two simple test run using water pressure.
https://www.youtube.com/watch?v=m6cvuxFgvxc
https://www.youtube.com/watch?v=qnionLsKuig
Tom
Hi All,
I'm about to show some very important experiment on the Clem engine theories, nobody really knows how it worked.
I believe my design will change everything in the way we use fossil fuels. The IC engine with moving piston to create compression will be outdated with this design.
I am sticking to my proof of concept with years of experimenting, that this would increase efficiency 50% or more.
We don't have a problem with fossil fuels, we have a efficiency problem.
This is the first true liquid piston engine, using fluid to compress air above 50:1 compression.
Tom
Hi All,
This is a update on the liquid piston engine, I explain just how this works.
https://www.youtube.com/watch?v=J6FnLdqpCBs&list=TLPQMjgwODIwMjLHhWVopl52ag&index=1
Tom
Hi All,
This is a test run on the liquid combustion chamber using compress air before using propane.
https://www.youtube.com/watch?v=9tNpVdOg_Wo
Tom
Hi All,
I added a 2kw generator to this prototype liquid piston engine to test output when it use propane.
https://www.youtube.com/watch?v=A6Bshx1aHyY
Tom
Hi All,
Been doing some calculation on injecting diesel into hydraulic fluid to increase pressure from 300psi to over 3000+ psi, not going to show the combustion chamber build. This becomes every dangerous due to the internal explosive power of diesel.
I plan to build a explosive chamber for safety, I would not expect other to do the experiment.
I plan to do a video after everything was tested, you know how others would try to copy something. I don't want anyone to get hurt or killed!
Tom.
