Overunity.com Archives
Mechanical free energy devices => mechanic => Topic started by: gearturbine on March 26, 2023, 07:02:14 AM
Title: ·I Deal with the Requirements of a New Mathematical Symbol in Order to Explain
Post by: gearturbine on March 26, 2023, 07:02:14 AM
I deal with the Requirements of a new mathematical symbol, in order to explain the Retrodynamic Phenomenon Effect, that occurs in an invention that I am developing. It is called the "Retrodynamic Effect" and it is created by having a situation of an axis turning in the opposite direction in a rotating system and in this way a great force is created. And there is currently no mathematical symbol that can explain it.[/font]
[/font]
*[/font]
[/font]
The Mathematical/Physical Symbol. What is required for the Explanation and Application in the Formula of the Retrodynamic Effect. Which has the quality of being applied in the Gear Turbine Project. What would it be to join the Symbols of ·1- (+) Addition and ·2- (X) Multiplication. It would be a Symbol with 8 Eight Points: 4 four of the symbol of + addition and four of the symbol of X multiplication. This is because it is a sum that continues to repeat the 2 Two forces the Action/RightRotation and the Reaction/Levorotation. The 2 Two Forces uniting, increasing each other into one. And is called "MULTIPLUS". And in this way increasing its Power considerably. a sum that is multiplied and/or a multiplication that is added. When Active of the Rotor/action of the system and the internal flow/reaction that does it in the opposite way (in favor at the Blades circular move. Thats Why) applying in the individual vane connected next to its partner Gear internally fit in a planetary way internally in the casing, in this way. This is because that is how it works, they are the union and interaction of two forces face to face, front to front and therefore two symbols. DextroGiro and/or LevoGiro. Action And/or Reaction. + and/or X.[/font][/color]
[/font][/color]
[/font][/color]
Is It Possible to Apply + Newton III Motion Law as a Dynamic System in a Motor Engine Device [/font]
[/font]
Is it Possible to Apply Physically Newton's Third Law of Motion as a Dynamic Cycle System in a Motor Device in a + Positive Way?[/font][/color]
[/font]
3rd Thermodynamic Law Applicate in a Power-Plant Device. The Reaction at From of the Action. New Torque Power. It's a simple Plus Formula of the Interaction of the Two Powers: 1/Action, + 2/Reaction = Retrodynamic. / For every action there is an equal and opposite reaction. 2 Forces in 1 System.[/font]
[/font]
RETRODYNAMIC Effect - Dextrogiro/Action => vs <= Levogiro/Reaction Phenomena Effect. / Rotor/RPM VS InFlow/Way. 3d Thermodynamic Law Applicate in a Power-Plant Device. The Reaction at Front of the Action. New Torque Power. It's a simple Plus Formula of the Interaction of the Two Powers: 1/Action, + 2/Reaction = Retrodynamic.[/font]
[/font]
"Changing rotation inside a mass makes it possible to change its inertial properties. It is the equation for a jet motion without rejection of any mass." Albert Einstein.[/font]
[/font]
The logic of creation of an inertial propulsion system is thus: Any motion is rotation ---- Rotation of a matter generates a space-time Torsion ---Torsion of space - time is described by Ricci torsion --- Ricci torsion is an inertial field-----the rest mass of any object is determined by its inertial field---- operating by fields and forces of inertia inside of mass we can create inertial propulsion system which moves according to the equation [m (t) dv/dt =-vdm/dt].[/font]
[/font]
Newton's Third Law of Motion: III. For every action there is an equal and opposite reaction.[/font]
[/font]
It is the sum of both (two) Forces - one to other / Are two Forces in one system.[/font]
[/font]
The formula of the Retrodinamic effect is a simple mathematical summation. What is Dextrogiro plus Levogiro, gives the result of the sum, of what is the total, which is the retrodynamic effect. But keeps doing Exponential.[/font]
[/font]
Retrodynamic Effect, are two Forces Actives in one system.  [/font]
It's like when the Star Trek Enterprise Spaceship Accelerates into the depth of space but spinning 2Two Opposites Forces (Like the Ying-Yang Concept) on a Central Axis in a Rotary Manner Way. [/font]
[/font]
http://stateoftheartnovelinflowtech.blogspot.com (http://stateoftheartnovelinflowtech.blogspot.com)[/font]
[/font]
https://padlet.com/gearturbine/un2slbar3s94 (https://padlet.com/gearturbine/un2slbar3s94)
[/font][/color]
[/font][/color]
*[/font]
[/font]
·RETRODYNAMIC Effect / Some Points of View:[/font]
[/font]
I always explain it well, but another thing is that you don't understand it.[/font]
As if it were an everyday question. [/font]
[/font]
And they don't take it as a disruption, which changes schemes.[/font]
[/font]
Because they really wouldn't even know about it. Being a subject that nobody has ever really dealt with.[/font]
[/font]
*[/font]
[/font]
And also to you can see it as an encrypted information.[/font]
And I know the best translator, for sure.[/font]
But the concept it's a simple sum, then keep going to increase the phenomenal interaction. [/font]
Let me make a simple caparison: One Turn is One step, OK, Well in this particular case. [/font]
When you do One Turn is One Step, And Then is another turn are gone to be Two Steps.[/font]
And in the next turn are gone to be Four steps, And the next Turn are gone to be 8 Steps. Etc...[/font]
Really too to be able to explain it, needs to invent a new Mathematical Signal. Brand New.[/font]
I Tell You. It's Like That.[/font]
[/font]
*[/font]
[/font]
I'm going to explain them perfectly well. We are going to make a comparison that each turn of the Rotor (applied in my case/Gearturbine) is a Step. It's fine. And So now when the rotor rotates with the power of the mechanical drive (Action). And furthermore, it has the internal flow contrary to its rotation (Reaction), but in favor of the individual blade attached to the gear with planetary rotation that activates the Rotor. In such a case they are two forces in a single system.[/font]
[/font]
*[/font]
[/font]
Maybe it doesn't have the best translation, but that's something else, that's not the point. But that would in no way be something that could belittle his qualities and technical virtues. And at the end of the day, all the explanations you can have are in the operation of the system. And this could not be easier to appreciate, Summed up in a simple sum. And in this case of 2Two Forces: 1Action + 2Reaction Applied in a single cycle, and thus also a single system.[/font][/color]
[/font][/color]
·A) 1Action VS/+ 2Reaction = ?[/font]
·B) 1DestroGiro VS/+ 2Levogiro = ?[/font]
·C)1Rotary Move VS/+ 2InFlow Way = ?[/font]
[/font]
Note: ·I use the "VS" Because the dynamic interaction is front to front, that's why.[/font]
·And is Added force one to the other, that's why I use the Sume/Plus mathematical symbol.[/font]
·A, B, and C are the same situation with a different word, from a different, technical view.[/font]
[/font]
Other Note: If somebody doesn't understand Cut be because of some reason. Not because my responsibility.[/font]
[/font][/color]
*[/font][/color]
[/color]Latest InFlow Generation: State of the Art Novel InFlow Tech: ·1-Gearturbine Reaction Turbine Rotary Turbo, ·2-Imploturbocompressor Impulse Turbine 1 Compression Step:
[/font][/color]
[/font]
·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Circular Power Type, ·Non Waste Parasitic Power Looses Type, ·8-X,Y Thermodynamic Cycle Way Steps. [/font]
[/font]
·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion/And Inverse, ·One Compression Step, ·Circular Dynamic Motion. Implosion Way Type, ·Same Nature of a Hurricane Satellite View.[/font]
[/font]
http://stateoftheartnovelinflowtech.blogspot.com (http://stateoftheartnovelinflowtech.blogspot.com)[/font][/color]
[/font][/color]
https://padlet.com/gearturbine/un2slbar3s94 (https://padlet.com/gearturbine/un2slbar3s94)[/font][/color]
[/font][/color]
*[/font][/color]
[/font][/color]
·State of the Art Novel  InFlow Tech Space Satellite and Habitat Power-Plant Generator - Self-Feed Unit; H2O=>HHO=>H2O=>HHO 4 Systems All in One Unit[/font]
[/font]
+PLUS; *State of the Art, Novel Technology, Featured Project Development / Space, Satellite and Habitat, Power-Plant, Generator, Self-Feed Unit; H2O=>HHO=>H2O=>HHO=>Etc... *4 Systems All in One Unit, One By One, Plus Four-4 Projects added One to Other; *·1-Gearturbine, ·2-Imploturbocompressor, ·3-Dynamic Generator, ·4-Electrolysis System:[/font][/color]
[/font][/color]
·1-GEARTURBINE; Reaction Turbine, Rotary-Turbo-InFlow Tech,Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.[/font][/color]
[/font][/color]
·2-IMPLOTURBOCOMPRESSOR; Impulse Turbine, Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.[/font][/color]
[/font][/color]
·Note;Plus-this-Two Projects to complete all the System Work/Self-Feed Unit Space Power-Plant-H2O=>HHO.[/font][/color]
·3-Dynamic Generator/New Kind.[/font][/color]
·4-Electrolysis System/BioDesign.[/font][/color]
*(3&4-Hide-Cards-on-the-Hand).[/font][/color]
:-* :P
Title: Re: ·I Deal with the Requirements of a New Mathematical Symbol in Order to Explain
Post by: gearturbine on March 26, 2023, 07:20:26 AM
:-* :P
Post by: sm0ky2 on March 27, 2023, 11:37:56 PM
Theres really no need to write new math for this
https://youtu.be/Pt9wTAL5KoU (https://youtu.be/Pt9wTAL5KoU)
Take apart an automotive turbo
Pick up a 2-header rotary lawn sprinkler
assemble the components
Add your parts in
the math wont change
